[GRASS-SVN] r49880 - in grass/trunk/gui/wxpython: iclass mapdisp
vdigit
svn_grass at osgeo.org
Fri Dec 23 06:36:53 EST 2011
Author: martinl
Date: 2011-12-23 03:36:53 -0800 (Fri, 23 Dec 2011)
New Revision: 49880
grass/trunk/gui/wxpython/iclass/frame.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/vdigit/toolbars.py
wxGUI: don't import iclass.digit in vdigit.toolbars
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py 2011-12-23 10:50:43 UTC (rev 49879)
+++ grass/trunk/gui/wxpython/iclass/frame.py 2011-12-23 11:36:53 UTC (rev 49880)
@@ -19,16 +19,15 @@
import os
import sys
+import copy
-#if __name__ == "__main__":
-sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
-import copy
+if __name__ == "__main__":
+ sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
+from core import globalvar
import wx
from ctypes import *
-from core import globalvar
try:
from grass.lib.imagery import *
from grass.lib.vector import *
@@ -269,6 +268,7 @@
if name == "vdigit":
self.toolbars[name] = VDigitToolbar(self, MapWindow = self.GetFirstWindow(),
+ digitClass = IClassIVDigit,
tools = ['addArea', 'moveVertex', 'addVertex',
'removeVertex', 'editLine',
'moveLine', 'deleteLine'])
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2011-12-23 10:50:43 UTC (rev 49879)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2011-12-23 11:36:53 UTC (rev 49880)
@@ -186,7 +186,7 @@
def _addToolbarVDigit(self):
"""!Add vector digitizer toolbar
- from vdigit.main import haveVDigit
+ from vdigit.main import haveVDigit, VDigit
if not haveVDigit:
from vdigit import errorMsg
@@ -232,7 +232,7 @@
self._mgr.GetPane('3d').Hide()
self._mgr.GetPane('vdigit').Show()
self.toolbars['vdigit'] = VDigitToolbar(parent = self, MapWindow = self.MapWindow,
- layerTree = self.tree,
+ digitClass = VDigit, layerTree = self.tree,
log = log)
self.MapWindowVDigit.SetToolbar(self.toolbars['vdigit'])
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py 2011-12-23 10:50:43 UTC (rev 49879)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py 2011-12-23 11:36:53 UTC (rev 49880)
@@ -20,8 +20,6 @@
from gui_core.toolbars import BaseToolbar, BaseIcons
from gui_core.dialogs import CreateNewVector
from vdigit.preferences import VDigitSettingsDialog
-from vdigit.main import VDigit
-from iclass.digit import IClassIVDigit
from core.debug import Debug
from core.settings import UserSettings
from core.gcmd import GError
@@ -30,12 +28,13 @@
class VDigitToolbar(BaseToolbar):
"""!Toolbar for digitization
- def __init__(self, parent, MapWindow, tools = [], layerTree = None, log = None):
+ def __init__(self, parent, MapWindow, digitClass, tools = [], layerTree = None, log = None):
self.MapWindow = MapWindow
self.Map = MapWindow.GetMap() # Map class instance
self.layerTree = layerTree # reference to layer tree associated to map display
self.log = log # log area
self.tools = tools
+ self.digitClass = digitClass
BaseToolbar.__init__(self, parent)
self.digit = None
@@ -388,7 +387,7 @@
"""!Show settings dialog"""
if self.digit is None:
try:
- self.digit = self.MapWindow.digit = VDigit(mapwindow = self.MapWindow)
+ self.digit = self.MapWindow.digit = self.digitClass(mapwindow = self.MapWindow)
except SystemExit:
self.digit = self.MapWindow.digit = None
@@ -693,10 +692,7 @@
0)
self.MapWindow.pdcVector = wx.PseudoDC()
- if self.parent.GetName() == 'IClassWindow':
- self.digit = self.MapWindow.digit = IClassIVDigit(mapwindow = self.MapWindow)
- else:
self.mapLayer = mapLayer
# open vector map
@@ -737,7 +733,7 @@
if 'map' in self.parent.toolbars:
self.parent.toolbars['map'].combo.SetValue (_('Digitize'))
- if self.parent.GetName() != "IClassWindow":
+ if self.digitClass != "iclass.digit.IClassWindow":
lmgr = self.parent.GetLayerManager()
if lmgr:
lmgr.toolbars['tools'].Enable('vdigit', enable = False)
