[GRASS-SVN] r45436 - grass/branches/develbranch_6/vector/v.buffer
svn_grass at osgeo.org
Sat Feb 19 13:13:26 EST 2011
Author: mmetz
Date: 2011-02-19 10:13:26 -0800 (Sat, 19 Feb 2011)
New Revision: 45436
grass/branches/develbranch_6/vector/v.buffer/main.c
attempt to reactivate original v.buffer
Modified: grass/branches/develbranch_6/vector/v.buffer/main.c
--- grass/branches/develbranch_6/vector/v.buffer/main.c 2011-02-19 18:11:37 UTC (rev 45435)
+++ grass/branches/develbranch_6/vector/v.buffer/main.c 2011-02-19 18:13:26 UTC (rev 45436)
@@ -233,13 +233,14 @@
struct line_cats *Cats, *BCats;
char *mapset;
struct GModule *module;
- struct Option *in_opt, *out_opt, *type_opt, *buffer_opt, *tolerance_opt,
- *bufcol_opt, *scale_opt, *debug_opt, *field_opt;
+ struct Option *in_opt, *out_opt, *type_opt, *buffer_opt, *dist_opt,
+ *tolerance_opt, *bufcol_opt, *scale_opt, *debug_opt, *field_opt;
double buffer, tolerance, dtmp;
int type, debug;
int ret, nareas, area, nlines, line;
char *Areas, *Lines;
int field;
+ int dist_answer;
/* Attributes if sizecol is used */
int i, nrec, ctype;
@@ -268,8 +269,14 @@
buffer_opt->key = "buffer";
buffer_opt->type = TYPE_DOUBLE;
buffer_opt->required = NO;
- buffer_opt->description = _("Buffer distance in map units");
+ buffer_opt->description = _("DEPRECATED Buffer distance in map units");
+ dist = G_define_option();
+ dist_opt->key = "distance";
+ dist_opt->type = TYPE_DOUBLE;
+ dist_opt->required = NO;
+ dist_opt->description = _("Buffer distance in map units");
bufcol_opt = G_define_option();
bufcol_opt->key = "bufcol";
bufcol_opt->type = TYPE_STRING;
@@ -311,8 +318,10 @@
type = Vect_option_to_types(type_opt);
field = atoi(field_opt->answer);
- if ((buffer_opt->answer && bufcol_opt->answer) ||
- (!(buffer_opt->answer || bufcol_opt->answer)))
+ dist_answer = (buffer_opt->answer != NULL || dist_opt->answer != NULL);
+ if ((dist_answer && bufcol_opt->answer) ||
+ (!(dist_answer->answer || bufcol_opt->answer)))
G_fatal_error("Select a buffer distance or column, but not both.");
if (bufcol_opt->answer)
@@ -328,9 +337,14 @@
if (scale <= 0.0)
G_fatal_error("Illegal scale value");
- if (buffer_opt->answer) {
- buffer = fabs(atof(buffer_opt->answer));
+ if (dist_opt->answer)
+ buffer = fabs(atof(dist_opt->answer));
+ else if (buffer_opt->answer)
+ if (dist_answer) {
tolerance *= buffer;
G_message(_("The tolerance in map units: %g"), tolerance);
@@ -440,7 +454,7 @@
if (!(ltype & type))
continue;
- if (!Vect_cat_get(Cats, field, &cat))
+ if (field > 0 && !Vect_cat_get(Cats, field, &cat))
continue;
if (bufcol_opt->answer) {
@@ -494,9 +508,22 @@
- Vect_line_buffer(Points, buffer, tolerance, BPoints);
- Vect_write_line(&Out, GV_BOUNDARY, BPoints, BCats);
+ Vect_line_prune(Points);
+ /* looped line ? */
+ if (Points->n_points > 1 && Points->x[0] == Points->x[Points->n_points - 1] &&
+ Points->y[0] == Points->y[Points->n_points - 1]) {
+ G_debug(0, "looped line");
+ Vect_line_parallel(Points, buffer, tolerance, 1, BPoints);
+ if (BPoints->n_points > 1)
+ Vect_write_line(&Out, GV_BOUNDARY, BPoints, BCats);
+ Vect_line_parallel(Points, -buffer, tolerance, 1, BPoints);
+ else {
+ Vect_line_buffer(Points, buffer, tolerance, BPoints);
@@ -574,7 +601,7 @@
/* outer ring */
Vect_get_area_points(&In, area, Points);
/* islands */
@@ -590,8 +617,9 @@
if (l / 2 < 2 * buffer)
continue;
@@ -619,6 +647,12 @@
G_message(_("Snapping boundaries..."));
Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
+ G_message(_("Breaking polygons..."));
+ Vect_break_polygons(&Out, GV_BOUNDARY, NULL);
+ G_message(_("Removing duplicates..."));
+ Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
G_message(_("Breaking boundaries..."));
Vect_break_lines(&Out, GV_BOUNDARY, NULL);
@@ -647,6 +681,8 @@
G_debug(3, "area = %d", area);
/*** BUG *** if dynamic bufcol was used, "buffer" will only hold last value ***/
+/* TODO: use method of v.buffer2, improve it by using a custom spatial index
+ * and storing original, not cleaned buffers in a temp vector */
ret = area_in_buffer(&In, &Out, area, type, buffer, tolerance);
if (ret) {
@@ -742,6 +778,7 @@
continue;
+/* TODO: see above */
if (ret) {
