[GRASS-SVN] r45437 - grass/branches/develbranch_6/vector/v.parallel
svn_grass at osgeo.org
Sat Feb 19 13:14:06 EST 2011
Author: mmetz
Date: 2011-02-19 10:14:06 -0800 (Sat, 19 Feb 2011)
New Revision: 45437
grass/branches/develbranch_6/vector/v.parallel/main.c
attempt to reactivate original v.parallel
Modified: grass/branches/develbranch_6/vector/v.parallel/main.c
--- grass/branches/develbranch_6/vector/v.parallel/main.c 2011-02-19 18:13:26 UTC (rev 45436)
+++ grass/branches/develbranch_6/vector/v.parallel/main.c 2011-02-19 18:14:06 UTC (rev 45437)
@@ -23,14 +23,18 @@
#include <grass/Vect.h>
#include <grass/glocale.h>
+#define LEFT 0x01
+#define RIGHT 0x02
+#define BOTH (LEFT | RIGHT)
int main(int argc, char *argv[])
struct GModule *module;
- struct Option *in_opt, *out_opt, *distance_opt;
+ struct Option *in_opt, *out_opt, *distance_opt, *tolerance_opt, *side_opt;
struct Map_info In, Out;
struct line_pnts *Points, *Points2;
struct line_cats *Cats;
- int line, nlines;
+ int line, nlines, side;
double distance, tolerance;
G_gisinit(argv[0]);
@@ -49,15 +53,51 @@
distance_opt->required = YES;
distance_opt->multiple = NO;
distance_opt->description =
- _("Offset in map units, positive for right side, "
- "negative for left side.");
+ _("Offset in map units.");
+ tolerance_opt = G_define_option();
+ tolerance_opt->key = "tolerance";
+ tolerance_opt->type = TYPE_DOUBLE;
+ tolerance_opt->required = NO;
+ tolerance_opt->answer = "0.01";
+ tolerance_opt->description =
+ _("Maximum distance between theoretical arc and polygon segments "
+ "as multiple of buffer");
+ side_opt = G_define_option();
+ side_opt->key = "side";
+ side_opt->type = TYPE_STRING;
+ side_opt->required = YES;
+ side_opt->answer = "right";
+ side_opt->multiple = NO;
+ side_opt->options = "left,right,both";
+ side_opt->description = _("Side");
+ side_opt->descriptions =
+ _("left;Parallel line is on the left;"
+ "right;Parallel line is on the right;"
+ "both;Parallel lines on both sides");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
/* layer = atoi ( layer_opt->answer ); */
- distance = atof(distance_opt->answer);
- tolerance = distance / 10.;
+ distance = fabs(atof(distance_opt->answer));
+ tolerance = atof(tolerance_opt->answer);
+ tolerance *= distance;
+ side = 0;
+ G_debug(0, "side: %s", side_opt->answer);
+ switch (side_opt->answer[0]) {
+ case 'r':
+ side = RIGHT;
+ break;
+ case 'l':
+ side = LEFT;
+ break;
+ case 'b':
+ side = BOTH;
+ break;
Vect_set_open_level(2);
Vect_open_old(&In, in_opt->answer, "");
@@ -78,10 +118,17 @@
G_percent(line, nlines, 1);
ltype = Vect_read_line(&In, Points, Cats, line);
+ Vect_line_prune(Points);
- if (ltype & GV_LINES) {
- Vect_line_parallel(Points, distance, tolerance, 1, Points2);
- Vect_write_line(&Out, ltype, Points2, Cats);
+ if (ltype & GV_LINES && Points->n_points > 1) {
+ if (side & RIGHT) {
+ Vect_line_parallel(Points, -distance, tolerance, 1, Points2);
+ Vect_write_line(&Out, ltype, Points2, Cats);
+ if (side & LEFT) {
+ Vect_line_parallel(Points, distance, tolerance, 1, Points2);
else {
Vect_write_line(&Out, ltype, Points, Cats);
