[GRASS-SVN] r44858 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Jan 4 05:10:47 EST 2011
Author: mmetz
Date: 2011-01-04 02:10:47 -0800 (Tue, 04 Jan 2011)
New Revision: 44858
grass/trunk/lib/vector/Vlib/build.c
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/intersect.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/Vlib/select.c
Vlib: new spatial index
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2011-01-04 10:09:36 UTC (rev 44857)
+++ grass/trunk/lib/vector/Vlib/build.c 2011-01-04 10:10:47 UTC (rev 44858)
@@ -523,21 +523,21 @@
plus = &(Map->plus);
- if (Map->plus.Spidx_built == 0) {
+ if (plus->Spidx_built == 0) {
G_warning("Spatial index not available, can not be saved");
return 0;
/* new or update mode ? */
- if (Map->plus.Spidx_new == 1) {
+ if (plus->Spidx_new == 1) {
/* write out rtrees to sidx file */
sprintf(buf, "%s/%s", GV_DIRECTORY, Map->name);
G__file_name(fname, buf, GV_SIDX_ELEMENT, Map->mapset);
G_debug(1, "Open sidx: %s", fname);
- dig_file_init(&(Map->plus.spidx_fp));
- Map->plus.spidx_fp.file = fopen(fname, "w+");
- if (Map->plus.spidx_fp.file == NULL) {
+ dig_file_init(&(plus->spidx_fp));
+ plus->spidx_fp.file = fopen(fname, "w+");
+ if (plus->spidx_fp.file == NULL) {
G_warning(_("Unable open spatial index file for write <%s>"),
fname);
return 0;
@@ -546,10 +546,11 @@
/* set portable info */
dig_init_portable(&(plus->spidx_port), dig__byte_order_out());
- if (0 > dig_Wr_spidx(&(Map->plus.spidx_fp), plus)) {
+ if (0 > dig_Wr_spidx(&(plus->spidx_fp), plus)) {
G_warning(_("Error writing out spatial index file"));
return 0;
+ dig_spidx_free(plus);
Map->plus.Spidx_new = 0;
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2011-01-04 10:09:36 UTC (rev 44857)
+++ grass/trunk/lib/vector/Vlib/close.c 2011-01-04 10:10:47 UTC (rev 44858)
@@ -112,7 +112,7 @@
if (Map->format != GV_FORMAT_OGR_DIRECT &&
Map->plus.Spidx_built == 1 &&
Map->plus.built == GV_BUILD_ALL)
- Vect_save_sidx(Map);
+ fclose(Map->plus.spidx_fp.file);
if (Map->level == 2 && Map->plus.release_support) {
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2011-01-04 10:09:36 UTC (rev 44857)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2011-01-04 10:10:47 UTC (rev 44858)
@@ -677,7 +677,7 @@
* in bound box */
/* Create rtree for B line */
- MyRTree = RTreeNewIndex(2);
+ MyRTree = RTreeNewIndex(-1, 0, 2);
for (i = 0; i < BPoints->n_points - 1; i++) {
if (BPoints->x[i] <= BPoints->x[i + 1]) {
rect.boundary[0] = BPoints->x[i];
@@ -1214,7 +1214,7 @@
* in bound box */
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2011-01-04 10:09:36 UTC (rev 44857)
+++ grass/trunk/lib/vector/Vlib/open.c 2011-01-04 10:10:47 UTC (rev 44858)
@@ -179,6 +179,7 @@
/* initialize support structures for 2D, update to 3D when reading support files */
Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = WITHOUT_Z;
/* initialize Map->plus */
+ Map->plus.Spidx_file = 0;
dig_init_plus(&(Map->plus));
/* check OGR mapset */
@@ -280,6 +281,7 @@
/* zone not set */
if (Vect_get_zone(Map) == -1)
Vect_set_zone(Map, G_zone());
+ Vect_set_proj(Map, G_projection());
G_debug(1, "Level request = %d", level_request);
@@ -790,6 +792,7 @@
Open_level = 0;
/* initialize topo */
/* open new spatial index */
@@ -1083,6 +1086,17 @@
if (mode) {
Map->plus.Spidx_new = 1;
+ /* file based or memory based */
+ if (getenv("GRASS_VECTOR_LOWMEM")) {
+ /* free old indices */
+ dig_spidx_free(Plus);
+ /* initialize file based indices */
+ Map->plus.Spidx_file = 1;
+ dig_spidx_init(Plus);
+ G_debug(0, "%s based spatial index",
+ Map->plus.Spidx_file == 0 ? "Memory" : "File");
if (mode == 1) {
/* load spatial index for update */
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c 2011-01-04 10:09:36 UTC (rev 44857)
+++ grass/trunk/lib/vector/Vlib/select.c 2011-01-04 10:10:47 UTC (rev 44858)
@@ -34,7 +34,7 @@
G_debug(1, "Vect_spatial_index_init()");
- si->si_tree = RTreeNewIndex(2 + with_z);
+ si->si_tree = RTreeNewIndex(-1, 0, 2 + (with_z != 0));
