[GRASS-SVN] r44860 - grass/trunk/lib/init
Tue Jan 4 05:16:42 EST 2011
Author: mmetz
Date: 2011-01-04 02:16:42 -0800 (Tue, 04 Jan 2011)
New Revision: 44860
   grass/trunk/lib/init/variables.html
add documentation for new env var
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2011-01-04 10:11:44 UTC (rev 44859)
+++ grass/trunk/lib/init/variables.html	2011-01-04 10:16:42 UTC (rev 44860)
@@ -240,6 +240,12 @@
     set to override Python executable.<br>
     On Mac OS X this should be the pythonw executable for the wxGUI to work.</dd>
+  <dt>GRASS_VECTOR_LOWMEM</dt>
+  <dd>[vectorlib]<br>
+    If the environment variable GRASS_VECTOR_LOWMEM exists, memory
+    consumption will be reduced when building vector topology
+    support structures. Recommended for creating large vectors.</dd>
   <dt>GRASS_WXBUNDLED</dt>
   <dd>[wxGUI]<br>
     set to tell wxGUI that a bundled wxPython will be used.<br>
