[GRASS-SVN] r44914 - grass/branches/develbranch_6/vector/v.digit
Sun Jan 9 15:13:20 EST 2011
Author: marisn
Date: 2011-01-09 12:13:20 -0800 (Sun, 09 Jan 2011)
New Revision: 44914
   grass/branches/develbranch_6/vector/v.digit/vertex.c
v.digit Delete line if it has less than two verticles (fixes  #1256)
Modified: grass/branches/develbranch_6/vector/v.digit/vertex.c
--- grass/branches/develbranch_6/vector/v.digit/vertex.c	2011-01-09 14:54:57 UTC (rev 44913)
+++ grass/branches/develbranch_6/vector/v.digit/vertex.c	2011-01-09 20:13:20 UTC (rev 44914)
@@ -244,14 +244,23 @@
 	    type = Vect_read_line(&Map, rv->Points, rv->Cats, rv->last_line);
 	    np = rv->Points->n_points;
-	    for (i = rv->last_seg; i < np - 1; i++) {
-		rv->Points->x[i] = rv->Points->x[i + 1];
-		rv->Points->y[i] = rv->Points->y[i + 1];
-		rv->Points->z[i] = rv->Points->z[i + 1];
+	    /* Lines should have at least two vertices (start and end node). */
+	    if (np < 3 && Vect_line_alive(&Map, rv->last_line)) {
+		Vect_delete_line(&Map, rv->last_line);
+		for (i = 0; i < rv->Cats->n_cats; i++) {
+		    check_record(rv->Cats->field[i], rv->Cats->cat[i]);
+	    } else {
+		for (i = rv->last_seg; i < np - 1; i++) {
+		    rv->Points->x[i] = rv->Points->x[i + 1];
+		    rv->Points->y[i] = rv->Points->y[i + 1];
+		    rv->Points->z[i] = rv->Points->z[i + 1];
+		rv->Points->n_points--;
+		Vect_rewrite_line(&Map, rv->last_line, type, rv->Points,
+			      rv->Cats);
-	    rv->Points->n_points--;
-	    Vect_rewrite_line(&Map, rv->last_line, type, rv->Points,
-			      rv->Cats);
 	    updated_lines_and_nodes_erase_refresh_display();
 	    rv->last_line = 0;
