[GRASS-SVN] r45088 - grass/branches/develbranch_6/vector/lidar/v.surf.bspline
Tue Jan 18 14:51:36 EST 2011
Author: mmetz
Date: 2011-01-18 11:51:36 -0800 (Tue, 18 Jan 2011)
New Revision: 45088
   grass/branches/develbranch_6/vector/lidar/v.surf.bspline/description.html
update manual
Modified: grass/branches/develbranch_6/vector/lidar/v.surf.bspline/description.html
--- grass/branches/develbranch_6/vector/lidar/v.surf.bspline/description.html	2011-01-18 19:49:19 UTC (rev 45087)
+++ grass/branches/develbranch_6/vector/lidar/v.surf.bspline/description.html	2011-01-18 19:51:36 UTC (rev 45088)
@@ -81,12 +81,6 @@
 of <b><i>lambda_i</i></b> values. No vector nor raster output will be created
 when cross-validation is selected.
-<p>
-A raster output map ("<b><i>raster=</i></b>") of more than 2000x2000 (4 mill)
-cells is not allowed. If an output map would exceed this size, an error message
-is generated.
 <h2>EXAMPLES</h2>
 <h3>Basic interpolation</h3>
@@ -139,12 +133,6 @@
 DBF driver. There are no problems with the raster map output from the DBF
 driver.
-<p>
-At this time, sparse vector input ("<b><i>sparse=</i></b>") can only be used
-with interpolation from 3D vector z-coordinates (<a href="http://trac.osgeo.org/grass/ticket/96">trac #96</a>).
-<p>
 <h2>SEE ALSO</h2>
 <em><a
