[GRASS-SVN] r45089 -
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline
svn_grass at osgeo.org
Tue Jan 18 14:56:11 EST 2011
Author: mmetz
Date: 2011-01-18 11:56:10 -0800 (Tue, 18 Jan 2011)
New Revision: 45089
grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html
update manual
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html
--- grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html 2011-01-18 19:51:36 UTC (rev 45088)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.surf.bspline/description.html 2011-01-18 19:56:10 UTC (rev 45089)
@@ -81,12 +81,6 @@
of <b><i>lambda_i</i></b> values. No vector nor raster output will be created
when cross-validation is selected.
-<p>
-A raster output map ("<b><i>raster=</i></b>") of more than 2000x2000 (4 mill)
-cells is not allowed. If an output map would exceed this size, an error message
-is generated.
<h2>EXAMPLES</h2>
<h3>Basic interpolation</h3>
@@ -139,12 +133,6 @@
DBF driver. There are no problems with the raster map output from the DBF
driver.
-<p>
-At this time, sparse vector input ("<b><i>sparse=</i></b>") can only be used
-with interpolation from 3D vector z-coordinates (<a href="http://trac.osgeo.org/grass/ticket/96">trac #96</a>).
-<p>
<h2>SEE ALSO</h2>
<em><a
