[GRASS-SVN] r45139 - in grass/trunk: lib/gis raster/r.proj
Fri Jan 21 18:28:11 EST 2011
Author: martinl
Date: 2011-01-21 15:28:11 -0800 (Fri, 21 Jan 2011)
New Revision: 45139
   grass/trunk/lib/gis/parser_standard_options.c
   grass/trunk/raster/r.proj/main.c
r.proj: use standard option
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c	2011-01-21 17:56:00 UTC (rev 45138)
+++ grass/trunk/lib/gis/parser_standard_options.c	2011-01-21 23:28:11 UTC (rev 45139)
@@ -496,8 +496,8 @@
 	Opt->required = NO;
 	Opt->multiple = NO;
 	Opt->key_desc = "name";
-	Opt->label =
-	    _("Name of mapset (default: current search path)");
+	Opt->gisprompt = "old,mapset,mapset";
+	Opt->label = _("Name of mapset (default: current search path)");
 	Opt->description = _("'.' for current mapset");
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c	2011-01-21 17:56:00 UTC (rev 45138)
+++ grass/trunk/raster/r.proj/main.c	2011-01-21 23:28:11 UTC (rev 45139)
@@ -161,13 +161,8 @@
     inlocation->gisprompt = "old,location,location";
     inlocation->key_desc = "name";
-    imapset = G_define_option();
-    imapset->key = "mapset";
-    imapset->type = TYPE_STRING;
-    imapset->required = NO;
+    imapset = G_define_standard_option(G_OPT_M_MAPSET);
     imapset->description = _("Mapset containing input raster map");
-    imapset->gisprompt = "old,mapset,mapset";
-    imapset->key_desc = "name";
     imapset->guisection = _("Source");
     indbase = G_define_option();
