[GRASS-SVN] r45140 - in grass/trunk: . gui/wxpython/gui_modules lib/psdriver lib/vector/Vlib raster/r.proj
Fri Jan 21 18:44:17 EST 2011
Author: martinl
Date: 2011-01-21 15:44:17 -0800 (Fri, 21 Jan 2011)
New Revision: 45140
   grass/trunk/grasslib.dox
   grass/trunk/gui/wxpython/gui_modules/gdialogs.py
   grass/trunk/gui/wxpython/gui_modules/layertree.py
   grass/trunk/lib/psdriver/Makefile
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/raster/r.proj/main.c
r.proj: add descriptions for method
Modified: grass/trunk/grasslib.dox
--- grass/trunk/grasslib.dox	2011-01-21 23:28:11 UTC (rev 45139)
+++ grass/trunk/grasslib.dox	2011-01-21 23:44:17 UTC (rev 45140)
@@ -96,7 +96,7 @@
  - ogsf:	\ref ogsflib (OpenGL (R) ported gsurf library (required for NVIZ))
  - pngdriver:   PNG display driver library - \ref pngdriver
  - proj:	\ref projlib (wrapper to PROJ4 projection library)
- - psdriver:    PostScript display driver library - \ref psdriver
+ - psdriver:    \ref psdriver
  - python:      \ref pythonlib
  - raster:	\ref rasterlib
  - rowio:	\ref rowiolib
Modified: grass/trunk/gui/wxpython/gui_modules/gdialogs.py
--- grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-01-21 23:28:11 UTC (rev 45139)
+++ grass/trunk/gui/wxpython/gui_modules/gdialogs.py	2011-01-21 23:44:17 UTC (rev 45140)
@@ -19,6 +19,7 @@
  - SetOpacityDialog
  - StaticWrapText
  - ImageSizeDialog
+ - SqlQueryFrame
 (C) 2008-2011 by the GRASS Development Team
@@ -1672,3 +1673,55 @@
         self.width.SetValue(width)
         self.height.SetValue(height)
+class SqlQueryFrame(wx.Frame):
+    def __init__(self, parent, id = wx.ID_ANY,
+                 title = _("GRASS GIS SQL Query Utility"),
+                 *kwargs):
+        """!SQL Query Utility window
+        self.parent = parent
+        wx.Frame.__init__(self, parent = parent, id = id, title = title, *kwargs)
+        self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_sql.ico'), wx.BITMAP_TYPE_ICO))
+        self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.sqlBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                                   label = _(" SQL statement "))
+        self.sql = wx.TextCtrl(parent = self.panel, id = wx.ID_ANY,
+                               style = wx.TE_MULTILINE)
+        self.btnApply = wx.Button(parent = self.panel, id = wx.ID_APPLY)
+        self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
+        self.Bind(wx.EVT_BUTTON, self.OnCloseWindow, self.btnCancel)
+        self._layout()
+        self.SetMinSize(wx.Size(300, 150))
+        self.SetSize(wx.Size(500, 200))
+    def _layout(self):
+        """!Do layout"""
+        sizer = wx.BoxSizer(wx.VERTICAL)
+        sqlSizer = wx.StaticBoxSizer(self.sqlBox, wx.HORIZONTAL)
+        sqlSizer.Add(item = self.sql, proportion = 1,
+                     flag = wx.EXPAND)
+        btnSizer = wx.StdDialogButtonSizer()
+        btnSizer.AddButton(self.btnApply)
+        btnSizer.AddButton(self.btnCancel)
+        btnSizer.Realize()
+        sizer.Add(item = sqlSizer, proportion = 1,
+                  flag = wx.EXPAND | wx.ALL, border = 5)
+        sizer.Add(item = btnSizer, proportion = 0,
+                  flag = wx.EXPAND | wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
+        self.panel.SetSizer(sizer)
+        self.Layout()
+    def OnCloseWindow(self, event):
+        """!Close window
+        self.Close()
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py	2011-01-21 23:28:11 UTC (rev 45139)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py	2011-01-21 23:44:17 UTC (rev 45140)
@@ -260,7 +260,7 @@
             for key in ('remove', 'rename', 'opacity', 'nviz', 'zoom',
                         'region', 'export', 'attr', 'edit0', 'edit1',
                         'bgmap', 'topo', 'meta', 'null', 'zoom1', 'region1',
-                        'color', 'hist', 'prof', 'properties'):
+                        'color', 'hist', 'prof', 'properties', 'sql'):
                 self.popupID[key] = wx.NewId()
         self.popupMenu = wx.Menu()
@@ -338,6 +338,18 @@
             self.popupMenu.Append(self.popupID['topo'], text = _("Rebuild topology"))
             self.Bind(wx.EVT_MENU, self.OnTopology, id = self.popupID['topo'])
+            # determine format
+            if layer and layer.GetType() == 'vector':
+                if not self.GetPyData(self.layer_selected)[0].has_key('info'):
+                    info = grass.parse_command('v.info',
+                                               map = layer.GetName(),
+                                               shell = 'basic')
+                    self.GetPyData(self.layer_selected)[0]['info'] = info
+                info = self.GetPyData(self.layer_selected)[0]['info']
+                if info and info['format'] == 'ogr,PostgreSQL':
+                    self.popupMenu.Append(self.popupID['sql'], text = _("SQL Spatial Query"))
+                    self.Bind(wx.EVT_MENU, self.OnSqlQuery, id = self.popupID['sql'])
             if layer.GetMapset() != grass.gisenv()['MAPSET']:
                 # only vector map in current mapset can be edited
                 self.popupMenu.Enable (self.popupID['edit0'], False)
@@ -411,6 +423,13 @@
                'map=%s' % mapLayer.GetName()]
         self.lmgr.goutput.RunCmd(cmd, switchPage = True)
+    def OnSqlQuery(self, event):
+        """!Show SQL query window for PostGIS layers
+        dlg = gdialogs.SqlQueryFrame(parent = self)
+        dlg.CentreOnScreen()
+        dlg.Show()
     def OnMetadata(self, event):
         """!Print metadata of raster/vector map layer
         TODO: Dialog to modify metadata
@@ -1349,7 +1368,8 @@
     def GetOptData(self, dcmd, layer, params, propwin):
-        """!Process layer data (when changes in propertiesdialog are applied)"""
+        """!Process layer data (when changes in properties dialog are applied)
         # set layer text to map name
         if dcmd:
             self.GetPyData(layer)[0]['cmd'] = dcmd
@@ -1369,7 +1389,7 @@
                 GWarning(parent = self,
                          message = _("Map <%s> not found.") % mapName)
                 return
         # update layer data
         if params:
             self.SetPyData(layer, (self.GetPyData(layer)[0], params))
@@ -1377,7 +1397,7 @@
         # change parameters for item in layers list in render.Map
         self.ChangeLayer(layer)
         # set region if auto-zooming is enabled
         if dcmd and UserSettings.Get(group = 'display', key = 'autoZooming', subkey = 'enabled'):
             mapLayer = self.GetPyData(layer)[0]['maplayer']
@@ -1385,7 +1405,7 @@
                 render = UserSettings.Get(group = 'display', key = 'autoRendering', subkey = 'enabled')
                 self.mapdisplay.MapWindow.ZoomToMap(layers = [mapLayer,],
                                                     render = render)
         # update nviz session
         if self.mapdisplay.toolbars['nviz'] and dcmd:
Modified: grass/trunk/lib/psdriver/Makefile
--- grass/trunk/lib/psdriver/Makefile	2011-01-21 23:28:11 UTC (rev 45139)
+++ grass/trunk/lib/psdriver/Makefile	2011-01-21 23:44:17 UTC (rev 45140)
@@ -1,13 +1,16 @@
 MODULE_TOPDIR = ../..
-EXTRA_CFLAGS=-I../driver
+EXTRA_CFLAGS = -I../driver
 LIB = PSDRIVER
 PGM = psdriver
 include $(MODULE_TOPDIR)/include/Make/Lib.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
 default: lib $(ETC)/psdriver.ps
 $(ETC)/psdriver.ps: psdriver.ps
 	$(INSTALL_DATA) $< $@
+DOXNAME = psdriver
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2011-01-21 23:28:11 UTC (rev 45139)
+++ grass/trunk/lib/vector/Vlib/write.c	2011-01-21 23:44:17 UTC (rev 45140)
@@ -186,14 +186,13 @@
    \return feature offset
    \return -1 on error
-off_t
-Vect_rewrite_line(struct Map_info *Map, int line, int type,
-              const struct line_pnts *points, const struct line_cats *cats)
+off_t Vect_rewrite_line(struct Map_info *Map, int line, int type,
+			const struct line_pnts *points, const struct line_cats *cats)
     off_t ret, offset;
     G_debug(3, "Vect_rewrite_line(): name = %s, line = %d", Map->name, line);
+    fprintf(stderr, "%s", Map->head);
     if (!VECT_OPEN(Map))
 	G_fatal_error(_("Unable to rewrite feature, vector map is not opened"));
@@ -204,6 +203,7 @@
     offset = Map->plus.Line[line]->offset;
+    G_debug(3, "   offset=%lu", Map->plus.Line[line]->offset);
     ret =
 	(*Vect_rewrite_line_array[Map->format][Map->level]) (Map, line, type, offset,
 							     points, cats);
Modified: grass/trunk/raster/r.proj/main.c
--- grass/trunk/raster/r.proj/main.c	2011-01-21 23:28:11 UTC (rev 45139)
+++ grass/trunk/raster/r.proj/main.c	2011-01-21 23:44:17 UTC (rev 45140)
@@ -17,7 +17,7 @@
 *	        one of three different methods: nearest neighbor, bilinear and
 *	        cubic convolution.
-* COPYRIGHT:    (C) 2001 by the GRASS Development Team
+* COPYRIGHT:    (C) 2001, 2011 by the GRASS Development Team
 *               This program is free software under the GNU General Public
 *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -77,6 +77,7 @@
 static char *make_ipol_list(void);
+static char *make_ipol_desc(void);
 int main(int argc, char **argv)
@@ -146,7 +147,7 @@
     G_add_keyword(_("projection"));
     G_add_keyword(_("transformation"));
     module->description =
-	_("Re-projects a raster map from one location to the current location.");
+	_("Re-projects a raster map from given location to the current location.");
     inmap = G_define_standard_option(G_OPT_R_INPUT);
     inmap->description = _("Name of input raster map to re-project");
@@ -162,7 +163,8 @@
     inlocation->key_desc = "name";
     imapset = G_define_standard_option(G_OPT_M_MAPSET);
-    imapset->description = _("Mapset containing input raster map");
+    imapset->label = _("Mapset containing input raster map");
+    imapset->description = _("default: name of current mapset");
     imapset->guisection = _("Source");
     indbase = G_define_option();
@@ -176,7 +178,7 @@
     outmap = G_define_standard_option(G_OPT_R_OUTPUT);
     outmap->required = NO;
-    outmap->description = _("Name for output raster map (default: input)");
+    outmap->description = _("Name for output raster map (default: same as 'input')");
     outmap->guisection = _("Target");
     ipolname = make_ipol_list();
@@ -189,6 +191,7 @@
     interpol->options = ipolname;
     interpol->description = _("Interpolation method to use");
     interpol->guisection = _("Target");
+    interpol->descriptions = make_ipol_desc();
     memory = G_define_option();
     memory->key = "memory";
@@ -200,7 +203,7 @@
     res->key = "resolution";
     res->type = TYPE_DOUBLE;
     res->required = NO;
-    res->description = _("Resolution of output map");
+    res->description = _("Resolution of output raster map");
     res->guisection = _("Target");
     list = G_define_flag();
@@ -536,7 +539,7 @@
     exit(EXIT_SUCCESS);
-static char *make_ipol_list(void)
+char *make_ipol_list(void)
     int size = 0;
     int i;
@@ -556,3 +559,26 @@
     return buf;
+char *make_ipol_desc(void)
+    int size = 0;
+    int i;
+    char *buf;
+    for (i = 0; menu[i].name; i++)
+	size += strlen(menu[i].name) + strlen(menu[i].text) + 2;
+    buf = G_malloc(size);
+    *buf = '\0';
+    for (i = 0; menu[i].name; i++) {
+	if (i)
+	    strcat(buf, ";");
+	strcat(buf, menu[i].name);
+	strcat(buf, ";");
+	strcat(buf, menu[i].text);
+    return buf;
