[GRASS-SVN] r45220 - grass/branches/develbranch_6/vector/v.buffer2
Thu Jan 27 09:39:34 EST 2011
Author: mmetz
Date: 2011-01-27 06:39:34 -0800 (Thu, 27 Jan 2011)
New Revision: 45220
Removed:
   grass/branches/develbranch_6/vector/v.buffer2/local_proto.h
   grass/branches/develbranch_6/vector/v.buffer2/main.c
v.buffer overhaul (backport from trunk r45219)
Deleted: grass/branches/develbranch_6/vector/v.buffer2/local_proto.h
--- grass/branches/develbranch_6/vector/v.buffer2/local_proto.h	2011-01-27 14:38:30 UTC (rev 45219)
+++ grass/branches/develbranch_6/vector/v.buffer2/local_proto.h	2011-01-27 14:39:34 UTC (rev 45220)
@@ -1,9 +0,0 @@
-#ifndef LOCAL_PROTO_H
-#define LOCAL_PROTO_H
-void Vect_line_buffer2(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count);
-void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count);
-void Vect_point_buffer2(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts **oPoints);
-void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db, double dalpha, int side, int round, double tol, struct line_pnts *OutPoints);
-#endif
Modified: grass/branches/develbranch_6/vector/v.buffer2/main.c
--- grass/branches/develbranch_6/vector/v.buffer2/main.c	2011-01-27 14:38:30 UTC (rev 45219)
+++ grass/branches/develbranch_6/vector/v.buffer2/main.c	2011-01-27 14:39:34 UTC (rev 45220)
@@ -22,7 +22,6 @@
 #include <grass/Vect.h>
 #include <grass/dbmi.h>
 #include <grass/glocale.h>
-#include "local_proto.h"
 #define PI M_PI
 #ifndef MIN
@@ -33,19 +32,10 @@
 #endif
-void stop(struct Map_info *In, struct Map_info *Out)
-    Vect_close(In);
-    Vect_build_partial(Out, GV_BUILD_NONE);
-    Vect_build(Out);
-    Vect_close(Out);
 /* returns 1 if unit_tolerance is adjusted, 0 otherwise */
 int adjust_tolerance(double *tolerance)
-    double t = 0.999 * (1 - cos(2 * PI / 8 / 2));
+    double t = 0.999 * (1 - cos(PI / 8));
     G_debug(2, "Maximum tolerance = %f", t);
     if (*tolerance > t) {
@@ -58,9 +48,7 @@
 int db_CatValArray_get_value_di(dbCatValArray * cvarr, int cat, double *value)
     int t;
     int ctype = cvarr->ctype;
     int ret;
     if (ctype == DB_C_TYPE_INT) {
@@ -236,9 +224,7 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     type = Vect_option_to_types(type_opt);
-    field = atoi(field_opt->answer);
     if (((dista_opt->answer || buffer_opt->answer) && bufcol_opt->answer) ||
 	(!(dista_opt->answer || buffer_opt->answer || bufcol_opt->answer)))
@@ -251,6 +237,14 @@
 		    "option or clean manually with v.clean tool=break; "
 		    "v.category step=0; v.extract -d type=area"));
+    if (field_opt->answer)
+        field = atoi(field_opt->answer);
+    else
+	field = -1;
+    if (bufcol_opt->answer && field == -1)
+	G_fatal_error(_("The bufcol option requires a valid layer."));
     if (buffer_opt->answer)
 	G_warning(_("The buffer option has been replaced by the distance "
 		    "option and will be removed in future."));
@@ -258,6 +252,9 @@
 	G_fatal_error(_("Use the distance option instead of the buffer option."));
     tolerance = atof(tol_opt->answer);
+    if (tolerance <= 0)
+	G_fatal_error(_("The tolerance must be > 0."));
     if (adjust_tolerance(&tolerance))
 	G_warning(_("The tolerance was reset to %g"), tolerance);
@@ -265,7 +262,7 @@
     if (scale <= 0.0)
 	G_fatal_error("Illegal scale value");
+	da = db = dalpha = 0;
     if (dista_opt->answer || buffer_opt->answer) {
 	if(buffer_opt->answer)
 	    da = atof(buffer_opt->answer);
@@ -374,12 +371,15 @@
 	    G_debug(2, "line = %d", line);
 	    G_percent(line, nlines, 2);
+	    if (!Vect_line_alive(&In, line))
+		continue;
 	    ltype = Vect_read_line(&In, Points, Cats, line);
 	    if (!(ltype & type))
 		continue;
-	    if (!Vect_cat_get(Cats, field, &cat))
+	    if (field > 0 && !Vect_cat_get(Cats, field, &cat))
 		continue;
 	    if (bufcol_opt->answer) {
@@ -409,7 +409,7 @@
 			unit_tolerance);
-	    if (ltype & GV_POINTS) {
+	    if (ltype & GV_POINTS || Points->n_points == 1) {
 		Vect_point_buffer2(Points->x[0], Points->y[0], da, db, dalpha,
 				   !(straight_flag->answer), unit_tolerance,
 				   &(arr_bc[buffers_count].oPoints));
@@ -440,12 +440,16 @@
 	    int cat;
 	    G_percent(area, nareas, 2);
+	    if (!Vect_area_alive(&In, area))
+		continue;
 	    centroid = Vect_get_area_centroid(&In, area);
 	    if (centroid == 0)
 		continue;
 	    Vect_read_line(&In, NULL, Cats, centroid);
 		continue;
@@ -486,11 +490,14 @@
     /* write all buffer contours */
+    G_message(_("Writting buffers..."));
     for (i = 0; i < buffers_count; i++) {
+	G_percent(i, buffers_count, 2);
 	Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].oPoints, BCats);
 	for (j = 0; j < arr_bc[i].inner_count; j++)
 	    Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].iPoints[j], BCats);
+    G_percent(1, 1, 1);
     /* Create areas */
@@ -501,6 +508,12 @@
     G_message(_("Snapping boundaries..."));
     Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
+    G_message(_("Breaking polygons..."));
+    Vect_break_polygons(&Out, GV_BOUNDARY, NULL);
+    G_message(_("Removing duplicates..."));
+    Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
     G_message(_("Breaking boundaries..."));
     Vect_break_lines(&Out, GV_BOUNDARY, NULL);
@@ -522,9 +535,13 @@
     /* Calculate new centroids for all areas */
     nareas = Vect_get_num_areas(&Out);
     Areas = (char *)G_calloc(nareas + 1, sizeof(char));
+    G_message(_("Calculating centroids for areas..."));
+    G_percent(0, nareas, 2);
     for (area = 1; area <= nareas; area++) {
 	double x, y;
+	G_percent(area, nareas, 2);
 	G_debug(3, "area = %d", area);
 	if (!Vect_area_alive(&Out, area))
@@ -549,9 +566,12 @@
     G_debug(3, "nlines = %d", nlines);
     Lines = (char *)G_calloc(nlines + 1, sizeof(char));
+    G_message(_("Generating list of boundaries to be deleted..."));
     for (line = 1; line <= nlines; line++) {
 	int j, side[2], areas[2];
+	G_percent(line, nlines, 2);
 	G_debug(3, "line = %d", line);
 	if (!Vect_line_alive(&Out, line))
@@ -579,7 +599,9 @@
     G_free(Areas);
     /* Delete boundaries */
+    G_message(_("Deleting boundaries..."));
 	if (Lines[line]) {
 	    G_debug(3, " delete line %d", line);
 	    Vect_delete_line(&Out, line);
@@ -593,9 +615,12 @@
     Vect_cat_set(Cats, 1, 1);
 	double x, y;
@@ -625,9 +650,11 @@
        G_free(arr_bc[i].iPoints);
-    G_message(_("Attaching centroids..."));
-    Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
+    Vect_close(&In);
-    stop(&In, &Out);
+    Vect_build_partial(&Out, GV_BUILD_NONE);
+    Vect_build(&Out);
+    Vect_close(&Out);
     exit(EXIT_SUCCESS);
