[GRASS-SVN] r45221 -
grass/branches/releasebranch_6_4/vector/v.buffer2
svn_grass at osgeo.org
Thu Jan 27 09:40:21 EST 2011
Author: mmetz
Date: 2011-01-27 06:40:21 -0800 (Thu, 27 Jan 2011)
New Revision: 45221
Removed:
grass/branches/releasebranch_6_4/vector/v.buffer2/local_proto.h
grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
v.buffer overhaul (backport from trunk r45219)
Deleted: grass/branches/releasebranch_6_4/vector/v.buffer2/local_proto.h
--- grass/branches/releasebranch_6_4/vector/v.buffer2/local_proto.h 2011-01-27 14:39:34 UTC (rev 45220)
+++ grass/branches/releasebranch_6_4/vector/v.buffer2/local_proto.h 2011-01-27 14:40:21 UTC (rev 45221)
@@ -1,9 +0,0 @@
-#ifndef LOCAL_PROTO_H
-#define LOCAL_PROTO_H
-void Vect_line_buffer2(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count);
-void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count);
-void Vect_point_buffer2(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts **oPoints);
-void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db, double dalpha, int side, int round, double tol, struct line_pnts *OutPoints);
-#endif
Modified: grass/branches/releasebranch_6_4/vector/v.buffer2/main.c
--- grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2011-01-27 14:39:34 UTC (rev 45220)
+++ grass/branches/releasebranch_6_4/vector/v.buffer2/main.c 2011-01-27 14:40:21 UTC (rev 45221)
@@ -22,7 +22,6 @@
#include <grass/Vect.h>
#include <grass/dbmi.h>
#include <grass/glocale.h>
-#include "local_proto.h"
#define PI M_PI
#ifndef MIN
@@ -33,19 +32,10 @@
#endif
-void stop(struct Map_info *In, struct Map_info *Out)
- Vect_close(In);
- Vect_build_partial(Out, GV_BUILD_NONE);
- Vect_build(Out);
- Vect_close(Out);
/* returns 1 if unit_tolerance is adjusted, 0 otherwise */
int adjust_tolerance(double *tolerance)
- double t = 0.999 * (1 - cos(2 * PI / 8 / 2));
+ double t = 0.999 * (1 - cos(PI / 8));
G_debug(2, "Maximum tolerance = %f", t);
if (*tolerance > t) {
@@ -58,9 +48,7 @@
int db_CatValArray_get_value_di(dbCatValArray * cvarr, int cat, double *value)
int t;
int ctype = cvarr->ctype;
int ret;
if (ctype == DB_C_TYPE_INT) {
@@ -236,9 +224,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
type = Vect_option_to_types(type_opt);
- field = atoi(field_opt->answer);
if (((dista_opt->answer || buffer_opt->answer) && bufcol_opt->answer) ||
(!(dista_opt->answer || buffer_opt->answer || bufcol_opt->answer)))
@@ -251,6 +237,14 @@
"option or clean manually with v.clean tool=break; "
"v.category step=0; v.extract -d type=area"));
+ if (field_opt->answer)
+ field = atoi(field_opt->answer);
+ else
+ field = -1;
+ if (bufcol_opt->answer && field == -1)
+ G_fatal_error(_("The bufcol option requires a valid layer."));
if (buffer_opt->answer)
G_warning(_("The buffer option has been replaced by the distance "
"option and will be removed in future."));
@@ -258,6 +252,9 @@
G_fatal_error(_("Use the distance option instead of the buffer option."));
tolerance = atof(tol_opt->answer);
+ if (tolerance <= 0)
+ G_fatal_error(_("The tolerance must be > 0."));
if (adjust_tolerance(&tolerance))
G_warning(_("The tolerance was reset to %g"), tolerance);
@@ -265,7 +262,7 @@
if (scale <= 0.0)
G_fatal_error("Illegal scale value");
+ da = db = dalpha = 0;
if (dista_opt->answer || buffer_opt->answer) {
if(buffer_opt->answer)
da = atof(buffer_opt->answer);
@@ -374,12 +371,15 @@
G_debug(2, "line = %d", line);
G_percent(line, nlines, 2);
+ if (!Vect_line_alive(&In, line))
+ continue;
ltype = Vect_read_line(&In, Points, Cats, line);
if (!(ltype & type))
continue;
- if (!Vect_cat_get(Cats, field, &cat))
+ if (field > 0 && !Vect_cat_get(Cats, field, &cat))
continue;
if (bufcol_opt->answer) {
@@ -409,7 +409,7 @@
unit_tolerance);
- if (ltype & GV_POINTS) {
+ if (ltype & GV_POINTS || Points->n_points == 1) {
Vect_point_buffer2(Points->x[0], Points->y[0], da, db, dalpha,
!(straight_flag->answer), unit_tolerance,
&(arr_bc[buffers_count].oPoints));
@@ -436,16 +436,21 @@
if (nareas > 0)
G_message(_("Buffering areas..."));
for (area = 1; area <= nareas; area++) {
int cat;
G_percent(area, nareas, 2);
+ if (!Vect_area_alive(&In, area))
+ continue;
centroid = Vect_get_area_centroid(&In, area);
if (centroid == 0)
continue;
Vect_read_line(&In, NULL, Cats, centroid);
continue;
@@ -487,10 +492,12 @@
/* write all buffer contours */
for (i = 0; i < buffers_count; i++) {
+ G_percent(i, buffers_count, 2);
Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].oPoints, BCats);
for (j = 0; j < arr_bc[i].inner_count; j++)
Vect_write_line(&Out, GV_BOUNDARY, arr_bc[i].iPoints[j], BCats);
+ G_percent(1, 1, 1);
/* Create areas */
@@ -501,6 +508,12 @@
G_message(_("Snapping boundaries..."));
Vect_snap_lines(&Out, GV_BOUNDARY, 1e-7, NULL);
+ G_message(_("Breaking polygons..."));
+ Vect_break_polygons(&Out, GV_BOUNDARY, NULL);
+ G_message(_("Removing duplicates..."));
+ Vect_remove_duplicates(&Out, GV_BOUNDARY, NULL);
G_message(_("Breaking boundaries..."));
Vect_break_lines(&Out, GV_BOUNDARY, NULL);
@@ -522,9 +535,12 @@
/* Calculate new centroids for all areas */
nareas = Vect_get_num_areas(&Out);
Areas = (char *)G_calloc(nareas + 1, sizeof(char));
+ G_percent(0, nareas, 2);
double x, y;
+ G_percent(area, nareas, 2);
G_debug(3, "area = %d", area);
if (!Vect_area_alive(&Out, area))
@@ -552,6 +568,8 @@
for (line = 1; line <= nlines; line++) {
int j, side[2], areas[2];
+ G_percent(line, nlines, 2);
G_debug(3, "line = %d", line);
if (!Vect_line_alive(&Out, line))
@@ -580,6 +598,7 @@
/* Delete boundaries */
if (Lines[line]) {
G_debug(3, " delete line %d", line);
Vect_delete_line(&Out, line);
@@ -596,6 +615,8 @@
double x, y;
@@ -625,9 +646,11 @@
G_free(arr_bc[i].iPoints);
- G_message(_("Attaching centroids..."));
- Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
+ Vect_close(&In);
- stop(&In, &Out);
+ Vect_build_partial(&Out, GV_BUILD_NONE);
+ Vect_build(&Out);
+ Vect_close(&Out);
exit(EXIT_SUCCESS);
