[GRASS-SVN] r47035 - grass-addons/grass7/display/d.mon2
svn_grass at osgeo.org
Thu Jul 7 03:26:29 EDT 2011
Author: martinl
Date: 2011-07-07 00:26:28 -0700 (Thu, 07 Jul 2011)
New Revision: 47035
Added:
grass-addons/grass7/display/d.mon2/d.mon2.html
grass-addons/grass7/display/d.mon2/d.mon2.py
Removed:
grass-addons/grass7/display/d.mon2/d.mon.html
grass-addons/grass7/display/d.mon2/d.mon.py
grass-addons/grass7/display/d.mon2/Makefile
d.mon->d.mon2 (step2)
Modified: grass-addons/grass7/display/d.mon2/Makefile
--- grass-addons/grass7/display/d.mon2/Makefile 2011-07-07 07:25:13 UTC (rev 47034)
+++ grass-addons/grass7/display/d.mon2/Makefile 2011-07-07 07:26:28 UTC (rev 47035)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = d.mon
+PGM = d.mon2
include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass-addons/grass7/display/d.mon2/d.mon.html
--- grass-addons/grass7/display/d.mon2/d.mon.html 2011-07-07 07:25:13 UTC (rev 47034)
+++ grass-addons/grass7/display/d.mon2/d.mon.html 2011-07-07 07:26:28 UTC (rev 47035)
@@ -1,31 +0,0 @@
-<h2>DESCRIPTION</h2>
-This is just a little experiment to see if we can make the ximgview,
-wximgview, and wxpyimgview programs a bit simpler to start up.
-<p>
-Add this to your ~/.grass.bashrc file:
-<pre>
- if [ `echo "$GRASS_VERSION" | cut -f1 -d.` -eq 7 ] ; then
- alias d.mon='eval `d.mon.py -b`'
- fi
-</pre>
-<p>
-By default the temporary file will be stored in $MAPSET/.tmp/ and cleared
-at the end of the session. You can put it somewhere else with the
-<b>tempfile</b> option. For example, when working remotely with
-PuTTY (ssh without tunnelled X) + Apache:
-<pre>
- alias d.mon='eval `d.mon.py -b handler=none tempfile=/var/www/grassmap.png`'
-</pre>
-then just hit reload in your web browser whenever a refresh is needed.
-<h2>AUTHOR</h2>
-Hamish Bowman<br>
-Dunedin, New Zealand
-<br>
-<p>
-<i>Last changed: $Date$</i></p>
Deleted: grass-addons/grass7/display/d.mon2/d.mon.py
--- grass-addons/grass7/display/d.mon2/d.mon.py 2011-07-07 07:25:13 UTC (rev 47034)
+++ grass-addons/grass7/display/d.mon2/d.mon.py 2011-07-07 07:26:28 UTC (rev 47035)
@@ -1,143 +0,0 @@
-#!/usr/bin/env python
-# MODULE: d.mon(.py)
-# AUTHOR: M. Hamish Bowman, Dunedin, New Zealand
-# PURPOSE: Front end wrapper to emulate d.mon from earlier GRASSes
-# COPYRIGHT: (c) 2011 Hamish Bowman, and the GRASS Development Team
-# This program is free software under the GNU General Public
-# License (>=v2). Read the file COPYING that comes with GRASS
-# for details.
-#%Module
-#% description: Starts a graphics display monitor which can be controlled from the command line.
-#% keywords: display
-#% keywords: CLI
-#%End
-#%Option
-#% key: width
-#% type: integer
-#% description: Width for display monitor if not set by GRASS_WIDTH
-#% answer: 800
-#%End
-#%Option
-#% key: height
-#% type: integer
-#% description: Height for display monitor if not set by GRASS_HEIGHT
-#% answer: 600
-#%End
-#%Option
-#% key: handler
-#% type: string
-#% description: Window program to use
-#% options: ximgview,wximgview,wxpyimgview,qiv,none
-#% answer: wximgview
-#%End
-#%option
-#% key: tempfile
-#% type: string
-#% gisprompt: new_file,file,input
-#% description: Name and location of temp file
-#% required : no
-#%end
-#%option
-#% key: percent
-#% type: integer
-#% description: Percentage of CPU time to use
-#% answer: 10
-#%end
-#%option
-#% key: color
-#% type: string
-#% description: Background color, either a standard GRASS color or R:G:B triplet (separated by colons)
-#% answer: white
-#% gisprompt: old_color,color,color
-#%end
-#%Flag
-#% key: c
-#% description: Use the Cario driver to render images
-#%End
-#%Flag
-#% key: b
-#% description: output Bourne shell code to set up display
-#%End
-#%Flag
-#% key: d
-#% description: output DOS code to set up display
-#%End
-import sys
-import os
-from grass.script import core as grass
-def main():
- handler = options['handler']
- if options['tempfile']:
- img_tmp = options['tempfile']
- #TODO: add option for GRASS_PNG_COMPRESSION=0,1-9
- else:
- img_tmp = grass.tempfile()
- os.remove(img_tmp)
- img_tmp += ".bmp"
- if flags['b']:
- print('GRASS_PNGFILE="%s"' % img_tmp)
- if not os.environ.has_key("GRASS_WIDTH"):
- print('GRASS_WIDTH=%s' % options['width'])
- if not os.environ.has_key("GRASS_HEIGHT"):
- print('GRASS_HEIGHT=%s' % options['height'])
- if flags['c']:
- print('GRASS_RENDER_IMMEDIATE=cairo')
- else:
- print('GRASS_RENDER_IMMEDIATE=PNG')
- print('GRASS_PNG_MAPPED=TRUE')
- print('GRASS_PNG_READ=TRUE')
- print('export GRASS_PNGFILE GRASS_WIDTH GRASS_HEIGHT GRASS_RENDER_IMMEDIATE GRASS_PNG_MAPPED GRASS_PNG_READ;')
- print('d.erase color=%s;' % options['color'])
- if handler == "none":
- grass.message("Image file is '%s'" % img_tmp)
- elif handler == "qiv":
- print('qiv -T "%s" &' % img_tmp) # add --center ?
- else:
- print('%s image="%s" percent=%s &' % ( handler, img_tmp, options['percent']) )
- sys.exit(0)
- ## rest of this won't work, as parent can't inherit from the child..
- ## (unless we do some ugly g.gisenv)
- ## ... any ideas? end by running grass.call(['bash'])?
- if not grass.find_program(handler, ['--help']):
- grass.fatal(_("'%s' not found.") % handler)
- os.environ['GRASS_PNGFILE'] = img_tmp
- os.environ['GRASS_WIDTH'] = options['width']
- os.environ['GRASS_HEIGHT'] = options['height']
- if flags['c']:
- os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
- os.environ['GRASS_PNG_MAPPED'] = 'TRUE'
- os.environ['GRASS_PNG_READ'] = 'TRUE'
- #? os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
- grass.run_command('d.erase', color = options['color'])
- if handler == "qiv":
- ret = grass.call(['qiv', '-T', img_tmp])
- else:
- ret = grass.exec_command(handler, image = img_tmp, percent = options['percent'])
- sys.exit(ret)
-if __name__ == "__main__":
- options, flags = grass.parser()
- main()
-po
Copied: grass-addons/grass7/display/d.mon2/d.mon2.html (from rev 47034, grass-addons/grass7/display/d.mon2/d.mon.html)
--- grass-addons/grass7/display/d.mon2/d.mon2.html (rev 0)
+++ grass-addons/grass7/display/d.mon2/d.mon2.html 2011-07-07 07:26:28 UTC (rev 47035)
@@ -0,0 +1,31 @@
+<h2>DESCRIPTION</h2>
+This is just a little experiment to see if we can make the ximgview,
+wximgview, and wxpyimgview programs a bit simpler to start up.
+<p>
+Add this to your ~/.grass.bashrc file:
+<pre>
+ if [ `echo "$GRASS_VERSION" | cut -f1 -d.` -eq 7 ] ; then
+ alias d.mon='eval `d.mon.py -b`'
+ fi
+</pre>
+<p>
+By default the temporary file will be stored in $MAPSET/.tmp/ and cleared
+at the end of the session. You can put it somewhere else with the
+<b>tempfile</b> option. For example, when working remotely with
+PuTTY (ssh without tunnelled X) + Apache:
+<pre>
+ alias d.mon='eval `d.mon.py -b handler=none tempfile=/var/www/grassmap.png`'
+</pre>
+then just hit reload in your web browser whenever a refresh is needed.
+<h2>AUTHOR</h2>
+Hamish Bowman<br>
+Dunedin, New Zealand
+<br>
+<p>
+<i>Last changed: $Date$</i></p>
Copied: grass-addons/grass7/display/d.mon2/d.mon2.py (from rev 47034, grass-addons/grass7/display/d.mon2/d.mon.py)
--- grass-addons/grass7/display/d.mon2/d.mon2.py (rev 0)
+++ grass-addons/grass7/display/d.mon2/d.mon2.py 2011-07-07 07:26:28 UTC (rev 47035)
@@ -0,0 +1,143 @@
+#!/usr/bin/env python
+# MODULE: d.mon(.py)
+# AUTHOR: M. Hamish Bowman, Dunedin, New Zealand
+# PURPOSE: Front end wrapper to emulate d.mon from earlier GRASSes
+# COPYRIGHT: (c) 2011 Hamish Bowman, and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%Module
+#% description: Starts a graphics display monitor which can be controlled from the command line.
+#% keywords: display
+#% keywords: CLI
+#%End
+#%Option
+#% key: width
+#% type: integer
+#% description: Width for display monitor if not set by GRASS_WIDTH
+#% answer: 800
+#%End
+#%Option
+#% key: height
+#% type: integer
+#% description: Height for display monitor if not set by GRASS_HEIGHT
+#% answer: 600
+#%End
+#%Option
+#% key: handler
+#% type: string
+#% description: Window program to use
+#% options: ximgview,wximgview,wxpyimgview,qiv,none
+#% answer: wximgview
+#%End
+#%option
+#% key: tempfile
+#% type: string
+#% gisprompt: new_file,file,input
+#% description: Name and location of temp file
+#% required : no
+#%end
+#%option
+#% key: percent
+#% type: integer
+#% description: Percentage of CPU time to use
+#% answer: 10
+#%end
+#%option
+#% key: color
+#% type: string
+#% description: Background color, either a standard GRASS color or R:G:B triplet (separated by colons)
+#% answer: white
+#% gisprompt: old_color,color,color
+#%end
+#%Flag
+#% key: c
+#% description: Use the Cario driver to render images
+#%End
+#%Flag
+#% key: b
+#% description: output Bourne shell code to set up display
+#%End
+#%Flag
+#% key: d
+#% description: output DOS code to set up display
+#%End
+import sys
+import os
+from grass.script import core as grass
+def main():
+ handler = options['handler']
+ if options['tempfile']:
+ img_tmp = options['tempfile']
+ #TODO: add option for GRASS_PNG_COMPRESSION=0,1-9
+ else:
+ img_tmp = grass.tempfile()
+ os.remove(img_tmp)
+ img_tmp += ".bmp"
+ if flags['b']:
+ print('GRASS_PNGFILE="%s"' % img_tmp)
+ if not os.environ.has_key("GRASS_WIDTH"):
+ print('GRASS_WIDTH=%s' % options['width'])
+ if not os.environ.has_key("GRASS_HEIGHT"):
+ print('GRASS_HEIGHT=%s' % options['height'])
+ if flags['c']:
+ print('GRASS_RENDER_IMMEDIATE=cairo')
+ else:
+ print('GRASS_RENDER_IMMEDIATE=PNG')
+ print('GRASS_PNG_MAPPED=TRUE')
+ print('GRASS_PNG_READ=TRUE')
+ print('export GRASS_PNGFILE GRASS_WIDTH GRASS_HEIGHT GRASS_RENDER_IMMEDIATE GRASS_PNG_MAPPED GRASS_PNG_READ;')
+ print('d.erase color=%s;' % options['color'])
+ if handler == "none":
+ grass.message("Image file is '%s'" % img_tmp)
+ elif handler == "qiv":
+ print('qiv -T "%s" &' % img_tmp) # add --center ?
+ else:
+ print('%s image="%s" percent=%s &' % ( handler, img_tmp, options['percent']) )
+ sys.exit(0)
+ ## rest of this won't work, as parent can't inherit from the child..
+ ## (unless we do some ugly g.gisenv)
+ ## ... any ideas? end by running grass.call(['bash'])?
+ if not grass.find_program(handler, ['--help']):
+ grass.fatal(_("'%s' not found.") % handler)
+ os.environ['GRASS_PNGFILE'] = img_tmp
+ os.environ['GRASS_WIDTH'] = options['width']
+ os.environ['GRASS_HEIGHT'] = options['height']
+ if flags['c']:
+ os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+ os.environ['GRASS_PNG_MAPPED'] = 'TRUE'
+ os.environ['GRASS_PNG_READ'] = 'TRUE'
+ #? os.environ['GRASS_PNG_AUTO_WRITE'] = 'FALSE'
+ grass.run_command('d.erase', color = options['color'])
+ if handler == "qiv":
+ ret = grass.call(['qiv', '-T', img_tmp])
+ else:
+ ret = grass.exec_command(handler, image = img_tmp, percent = options['percent'])
+ sys.exit(ret)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
+po
