[GRASS-SVN] r47036 - grass/trunk/lib/gis
svn_grass at osgeo.org
Thu Jul 7 03:45:52 EDT 2011
Author: martinl
Date: 2011-07-07 00:45:52 -0700 (Thu, 07 Jul 2011)
New Revision: 47036
grass/trunk/lib/gis/parser.c
grass/trunk/lib/gis/parser_help.c
libgis: avoid segfault when opt->key is not defined
minor changes in doxygen
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2011-07-07 07:26:28 UTC (rev 47035)
+++ grass/trunk/lib/gis/parser.c 2011-07-07 07:45:52 UTC (rev 47036)
@@ -218,20 +218,7 @@
opt->required = NO;
opt->multiple = NO;
- opt->answer = NULL;
- opt->answers = NULL;
- opt->def = NULL;
- opt->checker = NULL;
- opt->options = NULL;
- opt->key_desc = NULL;
- opt->gisprompt = NULL;
- opt->label = NULL;
- opt->opts = NULL;
- opt->description = NULL;
- opt->descriptions = NULL;
- opt->guisection = NULL;
- opt->guidependency = NULL;
st->current_option = opt;
st->n_opts++;
@@ -245,7 +232,6 @@
G_zero(item, sizeof(struct Item));
item->option = opt;
- item->flag = NULL;
st->current_item = item;
st->n_items++;
Modified: grass/trunk/lib/gis/parser_help.c
--- grass/trunk/lib/gis/parser_help.c 2011-07-07 07:26:28 UTC (rev 47035)
+++ grass/trunk/lib/gis/parser_help.c 2011-07-07 07:45:52 UTC (rev 47036)
@@ -1,19 +1,20 @@
- * \file gis/parser_help.c
- * \brief GIS Library - Argument parsing functions (help)
- * (C) 2001-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public License
- * (>=v2). Read the file COPYING that comes with GRASS for details.
- * \author Original author CERL
- * \author Soeren Gebbert added Dec. 2009 WPS process_description document
+ \file lib/gis/parser_help.c
+ \brief GIS Library - Argument parsing functions (help)
+ (C) 2001-2009, 2011 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author Original author CERL
+ \author Soeren Gebbert added Dec. 2009 WPS process_description document
#include <stdio.h>
#include <string.h>
+#include <stdlib.h>
#include <grass/gis.h>
#include <grass/glocale.h>
@@ -25,25 +26,25 @@
static int show(FILE *fp, const char *item, int len);
- * \brief Command line help/usage message.
- * Calls to G_usage() allow the programmer to print the usage
- * message at any time. This will explain the allowed and required
- * command line input to the user. This description is given according
- * to the programmer's definitions for options and flags. This function
- * becomes useful when the user enters options and/or flags on the
- * command line that are syntactically valid to the parser, but
- * functionally invalid for the command (e.g. an invalid file name.)
- * For example, the parser logic doesn't directly support grouping
- * options. If two options be specified together or not at all, the
- * parser must be told that these options are not required and the
- * programmer must check that if one is specified the other must be as
- * well. If this additional check fails, then G_parser() will succeed,
- * but the programmer can then call G_usage() to print the standard
- * usage message and print additional information about how the two
- * options work together.
+ \brief Command line help/usage message.
+ Calls to G_usage() allow the programmer to print the usage
+ message at any time. This will explain the allowed and required
+ command line input to the user. This description is given according
+ to the programmer's definitions for options and flags. This function
+ becomes useful when the user enters options and/or flags on the
+ command line that are syntactically valid to the parser, but
+ functionally invalid for the command (e.g. an invalid file name.)
+ For example, the parser logic doesn't directly support grouping
+ options. If two options be specified together or not at all, the
+ parser must be told that these options are not required and the
+ programmer must check that if one is specified the other must be as
+ well. If this additional check fails, then G_parser() will succeed,
+ but the programmer can then call G_usage() to print the standard
+ usage message and print additional information about how the two
+ options work together.
void G_usage(void)
usage(stderr, 0);
@@ -122,6 +123,10 @@
else
key_desc = "value";
+ if (!opt->key) {
+ fprintf(stderr, "\n%s\n", _("ERROR: Option key not defined"));
+ exit(EXIT_FAILURE);
n = strlen(opt->key);
if (n > maxlen)
maxlen = n;
