[GRASS-SVN] r47077 - in grass/trunk: display/d.erase display/d.mon
scripts scripts/d.redraw
svn_grass at osgeo.org
Sat Jul 9 13:01:15 EDT 2011
Author: martinl
Date: 2011-07-09 10:01:15 -0700 (Sat, 09 Jul 2011)
New Revision: 47077
Added:
grass/trunk/scripts/d.redraw/
grass/trunk/scripts/d.redraw/Makefile
grass/trunk/scripts/d.redraw/d.redraw.html
grass/trunk/scripts/d.redraw/d.redraw.py
grass/trunk/display/d.erase/d.erase.html
grass/trunk/display/d.mon/d.mon.html
d.redraw: new module
Modified: grass/trunk/display/d.erase/d.erase.html
--- grass/trunk/display/d.erase/d.erase.html 2011-07-09 16:28:02 UTC (rev 47076)
+++ grass/trunk/display/d.erase/d.erase.html 2011-07-09 17:01:15 UTC (rev 47077)
@@ -1,17 +1,22 @@
<h2>DESCRIPTION</h2>
-<em>d.erase</em> erases the contents of the active graphics frame, and replaces it with
-the color black (by default) or by whatever color is specified by the user.
-<em>d.erase</em> will not alter the assignment of the active frame.
+<em>d.erase</em> erases the contents of the active graphics frame, and
+replaces it with the color black (by default) or by whatever color is
+specified by the user.
<h2>SEE ALSO</h2>
-<em><a HREF="d.mon.html">d.mon</a></em>
+<em>
+ <a href="d.mon.html">d.mon</a>,
+ <a href="d.redraw.html">d.redraw</a>,
+ <a href="d.rast.html">d.rast</a>,
+ <a href="d.vect.html">d.vect</a>
+</em>
<h2>AUTHOR</h2>
-James Westervelt, U.S. Army Construction Engineering
-Research Laboratory
+James Westervelt, U.S. Army Construction Engineering Research
+Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/display/d.mon/d.mon.html
--- grass/trunk/display/d.mon/d.mon.html 2011-07-09 16:28:02 UTC (rev 47076)
+++ grass/trunk/display/d.mon/d.mon.html 2011-07-09 17:01:15 UTC (rev 47077)
@@ -102,8 +102,10 @@
<h2>SEE ALSO</h2>
<em>
+ <a href="d.erase.html">d.erase</a>,
- <a href="d.vect.html">d.vect</a>,
</em>
<p>
Added: grass/trunk/scripts/d.redraw/Makefile
--- grass/trunk/scripts/d.redraw/Makefile (rev 0)
+++ grass/trunk/scripts/d.redraw/Makefile 2011-07-09 17:01:15 UTC (rev 47077)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = d.redraw
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass/trunk/scripts/d.redraw/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass/trunk/scripts/d.redraw/d.redraw.html
--- grass/trunk/scripts/d.redraw/d.redraw.html (rev 0)
+++ grass/trunk/scripts/d.redraw/d.redraw.html 2011-07-09 17:01:15 UTC (rev 47077)
@@ -0,0 +1,21 @@
+<h2>DESCRIPTION</h2>
+<em>d.redraw</em> redraws the content of currently selected
+monitor. Active monitor can be selected
+by <em><a href="d.mon.html">d.mon</a></em>.
+<h2>SEE ALSO</h2>
+<em>
+ <a href="d.vect.html">d.vect</a>,
+</em>
+<h2>AUTHOR</h2>
+Martin Landa, Czech Republic
+<p>
Property changes on: grass/trunk/scripts/d.redraw/d.redraw.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass/trunk/scripts/d.redraw/d.redraw.py
--- grass/trunk/scripts/d.redraw/d.redraw.py (rev 0)
+++ grass/trunk/scripts/d.redraw/d.redraw.py 2011-07-09 17:01:15 UTC (rev 47077)
@@ -0,0 +1,73 @@
+#!/usr/bin/env python
+# MODULE: d.redraw
+# AUTHOR(S): Martin Landa <landa.martin gmail.com>
+# PURPOSE: Redraws the content of currently selected monitor
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% description: Redraws the content of currently selected monitor.
+#% keywords: display
+#% keywords: graphics
+#% keywords: monitors
+#% keywords: CLI
+#%end
+import sys
+import shlex
+from grass.script import core as grass
+def split(s):
+ """!Platform spefic shlex.split"""
+ if sys.version_info >= (2, 6):
+ return shlex.split(s, posix = (sys.platform != "win32"))
+ elif sys.platform == "win32":
+ return shlex.split(s.replace('\\', r'\\'))
+ else:
+ return shlex.split(s)
+def main():
+ env = grass.gisenv()
+ mon = env.get('MONITOR', None)
+ if not mon:
+ grass.fatal(_("No monitor selected. Run `d.mon` to select monitor."))
+ monCmd = env.get('MONITOR_%s_CMDFILE' % mon)
+ if not monCmd:
+ grass.fatal(_("No cmd file found for monitor <%s>") % mon)
+ try:
+ fd = open(monCmd, 'r')
+ cmdList = fd.readlines()
+ grass.run_command('d.erase')
+ for cmd in cmdList:
+ grass.call(split(cmd))
+ except IOError, e:
+ grass.fatal(_("Unable to open file '%s' for reading. Details: %s") % \
+ (monCmd, e))
+ fd.close()
+ # restore cmd file
+ try:
+ fd = open(monCmd, "w")
+ fd.writelines(cmdList)
+ grass.fatal(_("Unable to open file '%s' for writing. Details: %s") % \
+ (monCmd, e))
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass/trunk/scripts/d.redraw/d.redraw.py
Added: svn:executable
+ text/x-python
+ native
