[GRASS-SVN] r47078 - grass/trunk
svn_grass at osgeo.org
Sat Jul 9 13:06:51 EDT 2011
Author: martinl
Date: 2011-07-09 10:06:51 -0700 (Sat, 09 Jul 2011)
New Revision: 47078
grass/trunk/configure
grass/trunk/configure.in
conf: NVIZ -> Tcl/Tk NVIZ
Modified: grass/trunk/configure
--- grass/trunk/configure 2011-07-09 17:01:15 UTC (rev 47077)
+++ grass/trunk/configure 2011-07-09 17:06:51 UTC (rev 47078)
@@ -745,7 +745,7 @@
fi
echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:748: checking host system type" >&5
+echo "configure:749: checking host system type" >&5
host_alias=$host
case "$host_alias" in
@@ -768,7 +768,7 @@
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:771: checking for $ac_word" >&5
+echo "configure:772: checking for $ac_word" >&5
if test -n "$CC"; then
ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -795,7 +795,7 @@
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
-echo "configure:798: checking for $ac_word" >&5
+echo "configure:799: checking for $ac_word" >&5
@@ -843,7 +843,7 @@
# Extract the first word of "cl", so it can be a program name with args.
set dummy cl; ac_word=$2
-echo "configure:846: checking for $ac_word" >&5
+echo "configure:847: checking for $ac_word" >&5
@@ -872,7 +872,7 @@
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:875: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:876: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
ac_ext=c
# CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -883,12 +883,12 @@
cat > conftest.$ac_ext << EOF
-#line 886 "configure"
+#line 887 "configure"
#include "confdefs.h"
main(){return(0);}
EOF
-if { (eval echo configure:891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cc_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -914,19 +914,19 @@
{ echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:917: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:918: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
cross_compiling=$ac_cv_prog_cc_cross
echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:922: checking whether we are using GNU C" >&5
+echo "configure:923: checking whether we are using GNU C" >&5
cat > conftest.c <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:929: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gcc=yes
else
ac_cv_prog_gcc=no
@@ -944,7 +944,7 @@
ac_save_CFLAGS="$CFLAGS"
CFLAGS=
echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:947: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:948: checking whether ${CC-cc} accepts -g" >&5
echo 'void f(){}' > conftest.c
if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -973,10 +973,10 @@
fi
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:976: checking for Cygwin environment" >&5
+echo "configure:977: checking for Cygwin environment" >&5
cat > conftest.$ac_ext <<EOF
-#line 979 "configure"
+#line 980 "configure"
int main() {
@@ -987,7 +987,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:990: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -1003,17 +1003,17 @@
CYGWIN=
test "$ac_cv_cygwin" = yes && CYGWIN=yes
echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1006: checking for mingw32 environment" >&5
+echo "configure:1007: checking for mingw32 environment" >&5
-#line 1009 "configure"
+#line 1010 "configure"
int main() {
return __MINGW32__;
; return 0; }
EOF
-if { (eval echo configure:1016: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1017: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_mingw32=yes
else
@@ -1031,7 +1031,7 @@
echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1034: checking for executable suffix" >&5
+echo "configure:1035: checking for executable suffix" >&5
if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
ac_cv_exeext=.exe
@@ -1050,23 +1050,23 @@
IEEEFLAG=
echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1053: checking for full floating-point support" >&5
+echo "configure:1054: checking for full floating-point support" >&5
if test "$cross_compiling" = yes; then
echo "$ac_t""unknown (cross-compiling)" 1>&6
echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1058: checking whether "cc -mieee" works" >&5
+echo "configure:1059: checking whether "cc -mieee" works" >&5
ac_save_cflags=${CFLAGS}
CFLAGS="$CFLAGS -mieee"
-#line 1062 "configure"
+#line 1063 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:1069: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1070: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
IEEEFLAG="-mieee"
@@ -1082,7 +1082,7 @@
else
-#line 1085 "configure"
+#line 1086 "configure"
#include <float.h>
@@ -1096,7 +1096,7 @@
EOF
-if { (eval echo configure:1099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1100: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
@@ -1109,14 +1109,14 @@
CFLAGS=-mieee
echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1112: checking for full floating-point support with -mieee" >&5
+echo "configure:1113: checking for full floating-point support with -mieee" >&5
{ echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
else
-#line 1119 "configure"
+#line 1120 "configure"
#include <float.h>
@@ -1130,7 +1130,7 @@
EOF
-if { (eval echo configure:1133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1134: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
IEEEFLAG="-mieee"
@@ -1167,7 +1167,7 @@
# Extract the first word of "pwd", so it can be a program name with args.
set dummy pwd; ac_word=$2
-echo "configure:1170: checking for $ac_word" >&5
+echo "configure:1171: checking for $ac_word" >&5
case "$pwd" in
@@ -1205,7 +1205,7 @@
fi
echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1208: checking for source directory" >&5
+echo "configure:1209: checking for source directory" >&5
if test -z "$srcdir" ; then
SRCDIR=`$pwd`
@@ -1216,7 +1216,7 @@
echo "$ac_t"""$SRCDIR"" 1>&6
echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1219: checking for build directory" >&5
+echo "configure:1220: checking for build directory" >&5
DSTDIR=`$pwd`
WINDSTDIR=`$winpwd`
@@ -1284,7 +1284,7 @@
# Extract the first word of "svnversion", so it can be a program name with args.
set dummy svnversion; ac_word=$2
-echo "configure:1287: checking for $ac_word" >&5
+echo "configure:1288: checking for $ac_word" >&5
case "$SVN_VERSION" in
@@ -1340,7 +1340,7 @@
echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1343: checking for MacOSX App" >&5
+echo "configure:1344: checking for MacOSX App" >&5
case "$enable_macosx_app" in
yes) MACOSX_APP=1 ;;
no) MACOSX_APP= ;;
@@ -1352,7 +1352,7 @@
# Check for MacOSX archs
echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1355: checking for MacOSX architectures" >&5
+echo "configure:1356: checking for MacOSX architectures" >&5
MACOSX_ARCHS=
@@ -1381,7 +1381,7 @@
# Check for MacOSX SDK
echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1384: checking for MacOSX SDK" >&5
+echo "configure:1385: checking for MacOSX SDK" >&5
MACOSX_SDK=
@@ -1391,7 +1391,7 @@
ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1394: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1395: checking for $with_macosx_sdk/SDKSettings.plist" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1435,7 +1435,7 @@
echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1438: checking how to build libraries" >&5
+echo "configure:1439: checking how to build libraries" >&5
# Check whether --enable-shared or --disable-shared was given.
if test "${enable_shared+set}" = set; then
enableval="$enable_shared"
@@ -2253,7 +2253,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2254: checking for additional include dirs" >&5
+echo "configure:2257: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2276,7 +2276,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2277: checking for additional library dirs" >&5
+echo "configure:2280: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2310,7 +2310,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2311: checking for a BSD compatible install" >&5
+echo "configure:2314: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2363,7 +2363,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
-echo "configure:2364: checking for $ac_word" >&5
+echo "configure:2367: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2394,13 +2394,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2395: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2398: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
-#line 2401 "configure"
+#line 2404 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2411,7 +2411,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2436,7 +2436,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2437: checking for $ac_word" >&5
+echo "configure:2440: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2476,7 +2476,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2477: checking for $ac_word" >&5
+echo "configure:2480: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2507,7 +2507,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2508: checking for $ac_word" >&5
+echo "configure:2511: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2545,7 +2545,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2546: checking for $ac_word" >&5
+echo "configure:2549: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2574,7 +2574,7 @@
-echo "configure:2575: checking for $ac_word" >&5
+echo "configure:2578: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2605,7 +2605,7 @@
-echo "configure:2606: checking for $ac_word" >&5
+echo "configure:2609: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2634,7 +2634,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2635: checking for $ac_word" >&5
+echo "configure:2638: checking for $ac_word" >&5
case "$PERL" in
@@ -2665,7 +2665,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2666: checking how to run the C preprocessor" >&5
+echo "configure:2669: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2678,13 +2678,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2679 "configure"
+#line 2682 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2695,13 +2695,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2696 "configure"
+#line 2699 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2705: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2712,13 +2712,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2713 "configure"
+#line 2716 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2719: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2742,10 +2742,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2743: checking for ANSI C header files" >&5
+echo "configure:2746: checking for ANSI C header files" >&5
-#line 2746 "configure"
+#line 2749 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2753,7 +2753,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2757: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2770,7 +2770,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2771 "configure"
+#line 2774 "configure"
#include <string.h>
EOF
@@ -2788,7 +2788,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2789 "configure"
+#line 2792 "configure"
#include <stdlib.h>
EOF
@@ -2809,7 +2809,7 @@
else
-#line 2810 "configure"
+#line 2813 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2820,7 +2820,7 @@
exit (0); }
EOF
-if { (eval echo configure:2821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2847,15 +2847,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2848: checking for $ac_hdr" >&5
+echo "configure:2851: checking for $ac_hdr" >&5
-#line 2851 "configure"
+#line 2854 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2859: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2884,15 +2884,15 @@
do
-echo "configure:2885: checking for $ac_hdr" >&5
+echo "configure:2888: checking for $ac_hdr" >&5
-#line 2888 "configure"
+#line 2891 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2893: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2921,15 +2921,15 @@
do
-echo "configure:2922: checking for $ac_hdr" >&5
+echo "configure:2925: checking for $ac_hdr" >&5
-#line 2925 "configure"
+#line 2928 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2933: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2958,15 +2958,15 @@
do
-echo "configure:2959: checking for $ac_hdr" >&5
+echo "configure:2962: checking for $ac_hdr" >&5
-#line 2962 "configure"
+#line 2965 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2967: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2995,15 +2995,15 @@
do
-echo "configure:2996: checking for $ac_hdr" >&5
+echo "configure:2999: checking for $ac_hdr" >&5
-#line 2999 "configure"
+#line 3002 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:3004: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3007: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3029,10 +3029,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3030: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3033: checking whether time.h and sys/time.h may both be included" >&5
-#line 3033 "configure"
+#line 3036 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3041,7 +3041,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3042: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3045: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3061,10 +3061,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3062: checking for off_t" >&5
+echo "configure:3065: checking for off_t" >&5
-#line 3065 "configure"
+#line 3068 "configure"
#if STDC_HEADERS
@@ -3091,10 +3091,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3092: checking for uid_t in sys/types.h" >&5
+echo "configure:3095: checking for uid_t in sys/types.h" >&5
-#line 3095 "configure"
+#line 3098 "configure"
EOF
@@ -3122,10 +3122,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3123: checking return type of signal handlers" >&5
+echo "configure:3126: checking return type of signal handlers" >&5
-#line 3126 "configure"
+#line 3129 "configure"
#include <signal.h>
@@ -3142,7 +3142,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3143: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3146: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3160,10 +3160,10 @@
-echo "configure:3161: checking for Cygwin environment" >&5
+echo "configure:3164: checking for Cygwin environment" >&5
-#line 3164 "configure"
+#line 3167 "configure"
int main() {
@@ -3174,7 +3174,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3175: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3178: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3192,10 +3192,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3193: checking for $ac_func" >&5
+echo "configure:3196: checking for $ac_func" >&5
-#line 3196 "configure"
+#line 3199 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3218,7 +3218,7 @@
; return 0; }
EOF
-if { (eval echo configure:3219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3244,10 +3244,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3245: checking for $ac_func" >&5
+echo "configure:3248: checking for $ac_func" >&5
-#line 3248 "configure"
+#line 3251 "configure"
@@ -3270,7 +3270,7 @@
; return 0; }
EOF
-if { (eval echo configure:3271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3296,10 +3296,10 @@
for ac_func in drand48
do
-echo "configure:3297: checking for $ac_func" >&5
+echo "configure:3300: checking for $ac_func" >&5
-#line 3300 "configure"
+#line 3303 "configure"
@@ -3322,7 +3322,7 @@
; return 0; }
EOF
-if { (eval echo configure:3323: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3348,10 +3348,10 @@
for ac_func in putenv setenv
do
-echo "configure:3349: checking for $ac_func" >&5
+echo "configure:3352: checking for $ac_func" >&5
-#line 3352 "configure"
+#line 3355 "configure"
@@ -3374,7 +3374,7 @@
; return 0; }
EOF
-if { (eval echo configure:3375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3400,10 +3400,10 @@
for ac_func in nanosleep
do
-echo "configure:3401: checking for $ac_func" >&5
+echo "configure:3404: checking for $ac_func" >&5
-#line 3404 "configure"
+#line 3407 "configure"
@@ -3426,7 +3426,7 @@
; return 0; }
EOF
-if { (eval echo configure:3427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3451,13 +3451,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3452: checking whether setpgrp takes no argument" >&5
+echo "configure:3455: checking whether setpgrp takes no argument" >&5
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3458 "configure"
+#line 3461 "configure"
#ifdef HAVE_UNISTD_H
@@ -3477,7 +3477,7 @@
EOF
-if { (eval echo configure:3478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3505,16 +3505,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3506: checking for long long int" >&5
+echo "configure:3509: checking for long long int" >&5
-#line 3508 "configure"
+#line 3511 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3515: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3518: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
@@ -3534,7 +3534,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3535: checking for W11" >&5
+echo "configure:3538: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3562,7 +3562,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3563: checking for X" >&5
+echo "configure:3566: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3622,12 +3622,12 @@
# First, try using that file with no special directory specified.
-#line 3623 "configure"
+#line 3626 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3628: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3631: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3696,14 +3696,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3697 "configure"
+#line 3700 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3704: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3808,17 +3808,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3809: checking whether -R must be followed by a space" >&5
+echo "configure:3812: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3812 "configure"
+#line 3815 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3834,14 +3834,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3835 "configure"
+#line 3838 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3873,13 +3873,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3874: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3877: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3880 "configure"
+#line 3883 "configure"
@@ -3890,7 +3890,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3911,13 +3911,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3912: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3915: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3918 "configure"
+#line 3921 "configure"
@@ -3928,7 +3928,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3956,10 +3956,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3957: checking for gethostbyname" >&5
+echo "configure:3960: checking for gethostbyname" >&5
-#line 3960 "configure"
+#line 3963 "configure"
which can conflict with char gethostbyname(); below. */
@@ -3982,7 +3982,7 @@
; return 0; }
EOF
-if { (eval echo configure:3983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -4002,13 +4002,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4003: checking for gethostbyname in -lnsl" >&5
+echo "configure:4006: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4009 "configure"
+#line 4012 "configure"
@@ -4019,7 +4019,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4020: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4048,10 +4048,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4049: checking for connect" >&5
+echo "configure:4052: checking for connect" >&5
-#line 4052 "configure"
+#line 4055 "configure"
which can conflict with char connect(); below. */
@@ -4074,7 +4074,7 @@
; return 0; }
EOF
-if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4094,13 +4094,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4095: checking for connect in -lsocket" >&5
+echo "configure:4098: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4101 "configure"
+#line 4104 "configure"
@@ -4111,7 +4111,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4134,10 +4134,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4135: checking for remove" >&5
+echo "configure:4138: checking for remove" >&5
-#line 4138 "configure"
+#line 4141 "configure"
which can conflict with char remove(); below. */
@@ -4160,7 +4160,7 @@
; return 0; }
EOF
-if { (eval echo configure:4161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4180,13 +4180,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4181: checking for remove in -lposix" >&5
+echo "configure:4184: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4187 "configure"
+#line 4190 "configure"
@@ -4197,7 +4197,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4198: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4201: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4220,10 +4220,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4221: checking for shmat" >&5
+echo "configure:4224: checking for shmat" >&5
-#line 4224 "configure"
+#line 4227 "configure"
which can conflict with char shmat(); below. */
@@ -4246,7 +4246,7 @@
; return 0; }
EOF
-if { (eval echo configure:4247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4266,13 +4266,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4267: checking for shmat in -lipc" >&5
+echo "configure:4270: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4273 "configure"
+#line 4276 "configure"
@@ -4283,7 +4283,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4284: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4315,13 +4315,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4316: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4319: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4322 "configure"
+#line 4325 "configure"
@@ -4332,7 +4332,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4372,12 +4372,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4373: checking for library containing cuserid" >&5
+echo "configure:4376: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4378 "configure"
+#line 4381 "configure"
@@ -4388,7 +4388,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4399,7 +4399,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4400 "configure"
+#line 4403 "configure"
@@ -4410,7 +4410,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4436,10 +4436,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:4437: checking for xdrmem_create" >&5
+echo "configure:4440: checking for xdrmem_create" >&5
-#line 4440 "configure"
+#line 4443 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -4462,7 +4462,7 @@
; return 0; }
EOF
-if { (eval echo configure:4463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4466: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -4480,13 +4480,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:4481: checking for xdrmem_create in -lsun" >&5
+echo "configure:4484: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 4487 "configure"
+#line 4490 "configure"
@@ -4497,7 +4497,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4516,13 +4516,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:4517: checking for xdrmem_create in -lnsl" >&5
+echo "configure:4520: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 4523 "configure"
+#line 4526 "configure"
@@ -4533,7 +4533,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4552,13 +4552,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:4553: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:4556: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 4559 "configure"
+#line 4562 "configure"
@@ -4569,7 +4569,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4588,13 +4588,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:4589: checking for xdrmem_create in -lxdr" >&5
+echo "configure:4592: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 4595 "configure"
+#line 4598 "configure"
@@ -4605,7 +4605,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4639,10 +4639,10 @@
for ac_func in asprintf
do
-echo "configure:4640: checking for $ac_func" >&5
+echo "configure:4643: checking for $ac_func" >&5
-#line 4643 "configure"
+#line 4646 "configure"
@@ -4665,7 +4665,7 @@
; return 0; }
EOF
-if { (eval echo configure:4666: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4692,10 +4692,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4693: checking for atan" >&5
+echo "configure:4696: checking for atan" >&5
-#line 4696 "configure"
+#line 4699 "configure"
which can conflict with char atan(); below. */
@@ -4718,7 +4718,7 @@
; return 0; }
EOF
-if { (eval echo configure:4719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4722: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4736,13 +4736,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4737: checking for atan in -lm" >&5
+echo "configure:4740: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4743 "configure"
+#line 4746 "configure"
@@ -4753,7 +4753,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4780,10 +4780,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4781: checking for dlsym" >&5
+echo "configure:4784: checking for dlsym" >&5
-#line 4784 "configure"
+#line 4787 "configure"
which can conflict with char dlsym(); below. */
@@ -4806,7 +4806,7 @@
; return 0; }
EOF
-if { (eval echo configure:4807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4824,13 +4824,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4825: checking for dlsym in -ldl" >&5
+echo "configure:4828: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4831 "configure"
+#line 4834 "configure"
@@ -4841,7 +4841,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4842: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4868,10 +4868,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4869: checking for iconv" >&5
+echo "configure:4872: checking for iconv" >&5
-#line 4872 "configure"
+#line 4875 "configure"
which can conflict with char iconv(); below. */
@@ -4894,7 +4894,7 @@
; return 0; }
EOF
-if { (eval echo configure:4895: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4912,13 +4912,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4913: checking for iconv in -liconv" >&5
+echo "configure:4916: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4919 "configure"
+#line 4922 "configure"
@@ -4929,7 +4929,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4948,13 +4948,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4949: checking for iconv in -lgiconv" >&5
+echo "configure:4952: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4955 "configure"
+#line 4958 "configure"
@@ -4965,7 +4965,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4984,10 +4984,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4985: checking for libiconv" >&5
+echo "configure:4988: checking for libiconv" >&5
-#line 4988 "configure"
+#line 4991 "configure"
which can conflict with char libiconv(); below. */
@@ -5010,7 +5010,7 @@
; return 0; }
EOF
-if { (eval echo configure:5011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -5028,13 +5028,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:5029: checking for libiconv in -liconv" >&5
+echo "configure:5032: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5035 "configure"
+#line 5038 "configure"
@@ -5045,7 +5045,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5064,13 +5064,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:5065: checking for libiconv in -lgiconv" >&5
+echo "configure:5068: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 5071 "configure"
+#line 5074 "configure"
@@ -5081,7 +5081,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:5082: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5085: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5118,10 +5118,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5119: checking for socket" >&5
+echo "configure:5122: checking for socket" >&5
-#line 5122 "configure"
+#line 5125 "configure"
which can conflict with char socket(); below. */
@@ -5144,7 +5144,7 @@
; return 0; }
EOF
-if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -5162,13 +5162,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5163: checking for socket in -lsocket" >&5
+echo "configure:5166: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 5169 "configure"
+#line 5172 "configure"
@@ -5179,7 +5179,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:5180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5227,7 +5227,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5228: checking for location of zlib includes" >&5
+echo "configure:5231: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5253,15 +5253,15 @@
do
-echo "configure:5254: checking for $ac_hdr" >&5
+echo "configure:5257: checking for $ac_hdr" >&5
-#line 5257 "configure"
+#line 5260 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5265: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5295,7 +5295,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5296: checking for location of zlib library" >&5
+echo "configure:5299: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5320,13 +5320,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5321: checking for deflate in -lz" >&5
+echo "configure:5324: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5327 "configure"
+#line 5330 "configure"
@@ -5337,7 +5337,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5385,7 +5385,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5386: checking for location of External PROJ.4 includes" >&5
+echo "configure:5389: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5411,15 +5411,15 @@
do
-echo "configure:5412: checking for $ac_hdr" >&5
+echo "configure:5415: checking for $ac_hdr" >&5
-#line 5415 "configure"
+#line 5418 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5420: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5423: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5456,7 +5456,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5457: checking External PROJ.4 version" >&5
+echo "configure:5460: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5464,7 +5464,7 @@
else
-#line 5465 "configure"
+#line 5468 "configure"
#include <stdio.h>
@@ -5476,7 +5476,7 @@
EOF
-if { (eval echo configure:5477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5501,7 +5501,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5502: checking for location of External PROJ.4 library" >&5
+echo "configure:5505: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5526,13 +5526,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5527: checking for pj_get_def in -lproj" >&5
+echo "configure:5530: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5533 "configure"
+#line 5536 "configure"
@@ -5543,7 +5543,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5577,7 +5577,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5578: checking for location of External PROJ.4 data files" >&5
+echo "configure:5581: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5601,14 +5601,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5602: checking for epsg" >&5
+echo "configure:5605: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5609: checking for $PROJSHARE/epsg" >&5
+echo "configure:5612: checking for $PROJSHARE/epsg" >&5
@@ -5640,7 +5640,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5641: checking for $ac_word" >&5
+echo "configure:5644: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5680,7 +5680,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5681: checking whether to use regex" >&5
+echo "configure:5684: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5700,7 +5700,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5701: checking for location of regex includes" >&5
+echo "configure:5704: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5726,15 +5726,15 @@
do
-echo "configure:5727: checking for $ac_hdr" >&5
+echo "configure:5730: checking for $ac_hdr" >&5
-#line 5730 "configure"
+#line 5733 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5738: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5768,7 +5768,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5769: checking for location of regex library" >&5
+echo "configure:5772: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5793,10 +5793,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5794: checking for regcomp" >&5
+echo "configure:5797: checking for regcomp" >&5
-#line 5797 "configure"
+#line 5800 "configure"
which can conflict with char regcomp(); below. */
@@ -5819,7 +5819,7 @@
; return 0; }
EOF
-if { (eval echo configure:5820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5846,13 +5846,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5847: checking for regcomp in -lregex" >&5
+echo "configure:5850: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5853 "configure"
+#line 5856 "configure"
@@ -5863,7 +5863,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5913,7 +5913,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5914: checking whether to use Readline" >&5
+echo "configure:5917: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5934,7 +5934,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5935: checking for location of Readline includes" >&5
+echo "configure:5938: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5960,15 +5960,15 @@
do
-echo "configure:5961: checking for $ac_hdr" >&5
+echo "configure:5964: checking for $ac_hdr" >&5
-#line 5964 "configure"
+#line 5967 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5969: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5972: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6004,15 +6004,15 @@
do
-echo "configure:6005: checking for $ac_hdr" >&5
+echo "configure:6008: checking for $ac_hdr" >&5
-#line 6008 "configure"
+#line 6011 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6013: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6016: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6046,7 +6046,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6047: checking for location of Readline library" >&5
+echo "configure:6050: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6071,13 +6071,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6072: checking for readline in -lreadline" >&5
+echo "configure:6075: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 6078 "configure"
+#line 6081 "configure"
@@ -6088,7 +6088,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:6089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6123,13 +6123,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6124: checking for add_history in -lhistory" >&5
+echo "configure:6127: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 6130 "configure"
+#line 6133 "configure"
@@ -6140,7 +6140,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:6141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6183,7 +6183,7 @@
echo $ac_n "checking whether to use JPEG""... $ac_c" 1>&6
-echo "configure:6184: checking whether to use JPEG" >&5
+echo "configure:6187: checking whether to use JPEG" >&5
echo "$ac_t"""$with_jpeg"" 1>&6
case "$with_jpeg" in
"no") USE_JPEG= ;;
@@ -6203,7 +6203,7 @@
echo $ac_n "checking for location of JPEG includes""... $ac_c" 1>&6
-echo "configure:6204: checking for location of JPEG includes" >&5
+echo "configure:6207: checking for location of JPEG includes" >&5
case "$with_jpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-includes." 1>&2; exit 1; }
@@ -6229,15 +6229,15 @@
do
-echo "configure:6230: checking for $ac_hdr" >&5
+echo "configure:6233: checking for $ac_hdr" >&5
-#line 6233 "configure"
+#line 6236 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6238: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6241: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6271,7 +6271,7 @@
echo $ac_n "checking for location of JPEG library""... $ac_c" 1>&6
-echo "configure:6272: checking for location of JPEG library" >&5
+echo "configure:6275: checking for location of JPEG library" >&5
case "$with_jpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-jpeg-libs." 1>&2; exit 1; }
@@ -6298,13 +6298,13 @@
echo $ac_n "checking for jpeg_start_compress in -ljpeg""... $ac_c" 1>&6
-echo "configure:6299: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6302: checking for jpeg_start_compress in -ljpeg" >&5
ac_lib_var=`echo jpeg'_'jpeg_start_compress | sed 'y%./+-%__p_%'`
LIBS="-ljpeg $LIBS"
-#line 6305 "configure"
+#line 6308 "configure"
@@ -6315,7 +6315,7 @@
jpeg_start_compress()
; return 0; }
EOF
-if { (eval echo configure:6316: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6319: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6334,13 +6334,13 @@
-echo "configure:6335: checking for jpeg_start_compress in -ljpeg" >&5
+echo "configure:6338: checking for jpeg_start_compress in -ljpeg" >&5
LIBS="-ljpeg $ZLIB $LIBS"
-#line 6341 "configure"
+#line 6344 "configure"
@@ -6351,7 +6351,7 @@
; return 0; }
EOF
-if { (eval echo configure:6352: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6400,7 +6400,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6401: checking whether to use GDAL" >&5
+echo "configure:6404: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -6418,7 +6418,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6419: checking for $ac_word" >&5
+echo "configure:6422: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6473,14 +6473,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6474 "configure"
+#line 6477 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6489,14 +6489,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6490 "configure"
+#line 6493 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6522,14 +6522,16 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6526: checking whether to use libLAS" >&5
+echo "configure:6532: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
-LIBLAS_INC=
USE_LIBLAS=
if test "`basename xx/$with_liblas`" = "liblas-config" ; then
@@ -6543,7 +6545,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6544: checking for $ac_word" >&5
+echo "configure:6549: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6591,15 +6593,31 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6592 "configure"
+#line 6597 "configure"
#include "confdefs.h"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6599: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6604: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
rm -rf conftest*
+ cat > conftest.$ac_ext <<EOF
+#line 6612 "configure"
+#include "confdefs.h"
+#include <liblas/capi/liblas.h>
+int main() {
+LASReader_Create("foo");
+; return 0; }
+EOF
+if { (eval echo configure:6619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+ rm -rf conftest*
+ LAS_LIBS="$LAS_LIBS"
else
@@ -6609,18 +6627,27 @@
fi
rm -f conftest*
+fi
+rm -f conftest*
LIBS=${ac_save_libs}
CFLAGS=${ac_save_cflags}
+ cat >> confdefs.h <<\EOF
+#define HAVE_LIBLAS 1
+EOF
fi
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6621: checking whether to use GEOS" >&5
+echo "configure:6651: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -6638,7 +6665,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6639: checking for $ac_word" >&5
+echo "configure:6669: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6686,15 +6713,15 @@
do
-echo "configure:6687: checking for $ac_hdr" >&5
+echo "configure:6717: checking for $ac_hdr" >&5
-#line 6690 "configure"
+#line 6720 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6725: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6730,13 +6757,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6731: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6761: checking for initGEOS in -lgeos_c_i" >&5
ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c_i $LIBS"
-#line 6737 "configure"
+#line 6767 "configure"
@@ -6747,7 +6774,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6783,13 +6810,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6784: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6814: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6790 "configure"
+#line 6820 "configure"
@@ -6800,7 +6827,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6831: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6844,7 +6871,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6845: checking whether to use TIFF" >&5
+echo "configure:6875: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6864,7 +6891,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6865: checking for location of TIFF includes" >&5
+echo "configure:6895: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6890,15 +6917,15 @@
do
-echo "configure:6891: checking for $ac_hdr" >&5
+echo "configure:6921: checking for $ac_hdr" >&5
-#line 6894 "configure"
+#line 6924 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6929: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6932,7 +6959,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6933: checking for location of TIFF library" >&5
+echo "configure:6963: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6963,13 +6990,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6964: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6994: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6970 "configure"
+#line 7000 "configure"
@@ -6980,7 +7007,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6999,13 +7026,13 @@
-echo "configure:7000: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7030: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 7006 "configure"
+#line 7036 "configure"
@@ -7016,7 +7043,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7017: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7047: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7035,13 +7062,13 @@
-echo "configure:7036: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7066: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 7042 "configure"
+#line 7072 "configure"
@@ -7052,7 +7079,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7071,13 +7098,13 @@
-echo "configure:7072: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7102: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7078 "configure"
+#line 7108 "configure"
@@ -7088,7 +7115,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7107,13 +7134,13 @@
-echo "configure:7108: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7138: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 7114 "configure"
+#line 7144 "configure"
@@ -7124,7 +7151,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7143,13 +7170,13 @@
-echo "configure:7144: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7174: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 7150 "configure"
+#line 7180 "configure"
@@ -7160,7 +7187,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7179,13 +7206,13 @@
-echo "configure:7180: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7210: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 7186 "configure"
+#line 7216 "configure"
@@ -7196,7 +7223,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7197: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7215,13 +7242,13 @@
-echo "configure:7216: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7246: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 7222 "configure"
+#line 7252 "configure"
@@ -7232,7 +7259,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:7233: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7263: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7330,7 +7357,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7331: checking whether to use PNG" >&5
+echo "configure:7361: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7349,7 +7376,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7350: checking for location of PNG includes" >&5
+echo "configure:7380: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7375,15 +7402,15 @@
do
-echo "configure:7376: checking for $ac_hdr" >&5
+echo "configure:7406: checking for $ac_hdr" >&5
-#line 7379 "configure"
+#line 7409 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7384: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7417,7 +7444,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7418: checking for location of PNG library" >&5
+echo "configure:7448: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7442,13 +7469,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7443: checking for png_read_image in -lpng" >&5
+echo "configure:7473: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7449 "configure"
+#line 7479 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7459,7 +7486,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7490: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7501,7 +7528,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7502: checking whether to use PostgreSQL" >&5
+echo "configure:7532: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7528,7 +7555,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7529: checking for location of PostgreSQL includes" >&5
+echo "configure:7559: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7554,15 +7581,15 @@
do
-echo "configure:7555: checking for $ac_hdr" >&5
+echo "configure:7585: checking for $ac_hdr" >&5
-#line 7558 "configure"
+#line 7588 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7563: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7600,7 +7627,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7601: checking for location of PostgreSQL library" >&5
+echo "configure:7631: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7629,13 +7656,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7630: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7660: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7636 "configure"
+#line 7666 "configure"
@@ -7646,7 +7673,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7647: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7677: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7665,13 +7692,13 @@
-echo "configure:7666: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7696: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7672 "configure"
+#line 7702 "configure"
@@ -7682,7 +7709,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7701,13 +7728,13 @@
-echo "configure:7702: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7732: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 7708 "configure"
+#line 7738 "configure"
@@ -7718,7 +7745,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7737,13 +7764,13 @@
-echo "configure:7738: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7768: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7744 "configure"
+#line 7774 "configure"
@@ -7754,7 +7781,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7755: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7811,13 +7838,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7812: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7842: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7818 "configure"
+#line 7848 "configure"
@@ -7828,7 +7855,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7850,13 +7877,13 @@
-echo "configure:7851: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7881: checking for PQcmdTuples in -lpq" >&5
-#line 7857 "configure"
+#line 7887 "configure"
@@ -7867,7 +7894,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7910,7 +7937,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7911: checking whether to use MySQL" >&5
+echo "configure:7941: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7930,7 +7957,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7931: checking for location of MySQL includes" >&5
+echo "configure:7961: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7956,15 +7983,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:7957: checking for $ac_hdr" >&5
+echo "configure:7987: checking for $ac_hdr" >&5
-#line 7960 "configure"
+#line 7990 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7965: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7995: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8001,7 +8028,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8002: checking for location of MySQL library" >&5
+echo "configure:8032: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8032,13 +8059,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8033: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8063: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 8039 "configure"
+#line 8069 "configure"
@@ -8049,7 +8076,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8050: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8080: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8068,13 +8095,13 @@
-echo "configure:8069: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8099: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8075 "configure"
+#line 8105 "configure"
@@ -8085,7 +8112,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8086: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8104,13 +8131,13 @@
-echo "configure:8105: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8135: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8111 "configure"
+#line 8141 "configure"
@@ -8121,7 +8148,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8122: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8152: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8140,13 +8167,13 @@
-echo "configure:8141: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8171: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8147 "configure"
+#line 8177 "configure"
@@ -8157,7 +8184,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8188: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8176,13 +8203,13 @@
-echo "configure:8177: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8207: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8183 "configure"
+#line 8213 "configure"
@@ -8193,7 +8220,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8212,13 +8239,13 @@
-echo "configure:8213: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8243: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8219 "configure"
+#line 8249 "configure"
@@ -8229,7 +8256,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8230: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8260: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8248,13 +8275,13 @@
-echo "configure:8249: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8279: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8255 "configure"
+#line 8285 "configure"
@@ -8265,7 +8292,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8284,13 +8311,13 @@
-echo "configure:8285: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8315: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8291 "configure"
+#line 8321 "configure"
@@ -8301,7 +8328,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8302: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8332: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8391,7 +8418,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
-echo "configure:8392: checking for $ac_word" >&5
+echo "configure:8422: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8440,10 +8467,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8441: checking for mysql_server_init" >&5
+echo "configure:8471: checking for mysql_server_init" >&5
-#line 8444 "configure"
+#line 8474 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -8469,7 +8496,7 @@
; return 0; }
EOF
-if { (eval echo configure:8470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8521,7 +8548,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8522: checking whether to use SQLite" >&5
+echo "configure:8552: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8541,7 +8568,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8542: checking for location of SQLite includes" >&5
+echo "configure:8572: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8567,15 +8594,15 @@
do
-echo "configure:8568: checking for $ac_hdr" >&5
+echo "configure:8598: checking for $ac_hdr" >&5
-#line 8571 "configure"
+#line 8601 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8606: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8618,7 +8645,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8619: checking for location of SQLite library" >&5
+echo "configure:8649: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8647,13 +8674,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8648: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8678: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8654 "configure"
+#line 8684 "configure"
@@ -8664,7 +8691,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8665: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8683,13 +8710,13 @@
-echo "configure:8684: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8714: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8690 "configure"
+#line 8720 "configure"
@@ -8700,7 +8727,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8719,13 +8746,13 @@
-echo "configure:8720: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8750: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8726 "configure"
+#line 8756 "configure"
@@ -8736,7 +8763,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8737: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8755,13 +8782,13 @@
-echo "configure:8756: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8786: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8762 "configure"
+#line 8792 "configure"
@@ -8772,7 +8799,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8841,7 +8868,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8842: checking whether to use FFMPEG" >&5
+echo "configure:8872: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8861,7 +8888,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8862: checking for location of FFMPEG includes" >&5
+echo "configure:8892: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8887,15 +8914,15 @@
do
-echo "configure:8888: checking for $ac_hdr" >&5
+echo "configure:8918: checking for $ac_hdr" >&5
-#line 8891 "configure"
+#line 8921 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8896: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8926: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8931,15 +8958,15 @@
do
-echo "configure:8932: checking for $ac_hdr" >&5
+echo "configure:8962: checking for $ac_hdr" >&5
-#line 8935 "configure"
+#line 8965 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8940: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8970: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8975,15 +9002,15 @@
do
-echo "configure:8976: checking for $ac_hdr" >&5
+echo "configure:9006: checking for $ac_hdr" >&5
-#line 8979 "configure"
+#line 9009 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9014: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9026,7 +9053,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:9027: checking for location of FFMPEG library" >&5
+echo "configure:9057: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -9053,13 +9080,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:9054: checking for av_free in -lavutil" >&5
+echo "configure:9084: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 9060 "configure"
+#line 9090 "configure"
@@ -9070,7 +9097,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:9071: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9101: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9089,13 +9116,13 @@
-echo "configure:9090: checking for av_free in -lavutil" >&5
+echo "configure:9120: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 9096 "configure"
+#line 9126 "configure"
@@ -9106,7 +9133,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:9107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9151,13 +9178,13 @@
echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:9152: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9182: checking for avcodec_init in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 9158 "configure"
+#line 9188 "configure"
@@ -9168,7 +9195,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9169: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9187,13 +9214,13 @@
-echo "configure:9188: checking for avcodec_init in -lavcodec" >&5
+echo "configure:9218: checking for avcodec_init in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 9194 "configure"
+#line 9224 "configure"
@@ -9204,7 +9231,7 @@
avcodec_init()
; return 0; }
EOF
-if { (eval echo configure:9205: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9249,13 +9276,13 @@
echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:9250: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9280: checking for av_set_parameters in -lavformat" >&5
ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 9256 "configure"
+#line 9286 "configure"
@@ -9266,7 +9293,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9285,13 +9312,13 @@
-echo "configure:9286: checking for av_set_parameters in -lavformat" >&5
+echo "configure:9316: checking for av_set_parameters in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9292 "configure"
+#line 9322 "configure"
@@ -9302,7 +9329,7 @@
av_set_parameters()
; return 0; }
EOF
-if { (eval echo configure:9303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9361,7 +9388,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9362: checking whether to use OpenGL" >&5
+echo "configure:9392: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9395,7 +9422,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9396: checking for location of OpenGL includes" >&5
+echo "configure:9426: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9421,15 +9448,15 @@
do
-echo "configure:9422: checking for $ac_hdr" >&5
+echo "configure:9452: checking for $ac_hdr" >&5
-#line 9425 "configure"
+#line 9455 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9430: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9460: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9463,7 +9490,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9464: checking for location of OpenGL library" >&5
+echo "configure:9494: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9492,13 +9519,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9493: checking for glBegin in -lGL" >&5
+echo "configure:9523: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9499 "configure"
+#line 9529 "configure"
@@ -9509,7 +9536,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9528,13 +9555,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:9529: checking for glBegin in -lGL" >&5
+echo "configure:9559: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9535 "configure"
+#line 9565 "configure"
@@ -9545,7 +9572,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9564,13 +9591,13 @@
-echo "configure:9565: checking for glBegin in -lGL" >&5
+echo "configure:9595: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9571 "configure"
+#line 9601 "configure"
@@ -9581,7 +9608,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9600,13 +9627,13 @@
-echo "configure:9601: checking for glBegin in -lGL" >&5
+echo "configure:9631: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9607 "configure"
+#line 9637 "configure"
@@ -9617,7 +9644,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9679,13 +9706,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9680: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9710: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9686 "configure"
+#line 9716 "configure"
@@ -9696,7 +9723,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9697: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9727: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9715,13 +9742,13 @@
-echo "configure:9716: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9746: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9722 "configure"
+#line 9752 "configure"
@@ -9732,7 +9759,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9733: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9763: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9779,10 +9806,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9780: checking for glXCreatePbuffer" >&5
+echo "configure:9810: checking for glXCreatePbuffer" >&5
-#line 9783 "configure"
+#line 9813 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -9805,7 +9832,7 @@
; return 0; }
EOF
-if { (eval echo configure:9806: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9842,10 +9869,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9843: checking for glXCreateGLXPixmap" >&5
+echo "configure:9873: checking for glXCreateGLXPixmap" >&5
-#line 9846 "configure"
+#line 9876 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9868,7 +9895,7 @@
; return 0; }
EOF
-if { (eval echo configure:9869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9911,7 +9938,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9912: checking for location of OpenGL framework" >&5
+echo "configure:9942: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9935,15 +9962,15 @@
do
-echo "configure:9936: checking for $ac_hdr" >&5
+echo "configure:9966: checking for $ac_hdr" >&5
-#line 9939 "configure"
+#line 9969 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9944: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9974: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9979,10 +10006,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9980: checking for glBegin" >&5
+echo "configure:10010: checking for glBegin" >&5
-#line 9983 "configure"
+#line 10013 "configure"
which can conflict with char glBegin(); below. */
@@ -10005,7 +10032,7 @@
; return 0; }
EOF
-if { (eval echo configure:10006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -10042,10 +10069,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10043: checking for gluBeginCurve" >&5
+echo "configure:10073: checking for gluBeginCurve" >&5
-#line 10046 "configure"
+#line 10076 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -10068,7 +10095,7 @@
; return 0; }
EOF
-if { (eval echo configure:10069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -10116,7 +10143,7 @@
-echo "configure:10117: checking for location of OpenGL includes" >&5
+echo "configure:10147: checking for location of OpenGL includes" >&5
@@ -10142,15 +10169,15 @@
do
-echo "configure:10143: checking for $ac_hdr" >&5
+echo "configure:10173: checking for $ac_hdr" >&5
-#line 10146 "configure"
+#line 10176 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10151: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10181: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10184,7 +10211,7 @@
-echo "configure:10185: checking for location of OpenGL library" >&5
+echo "configure:10215: checking for location of OpenGL library" >&5
@@ -10209,18 +10236,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10210: checking for OpenGL library" >&5
+echo "configure:10240: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 10214 "configure"
+#line 10244 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:10221: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -10244,18 +10271,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10245: checking for GLU library" >&5
+echo "configure:10275: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 10249 "configure"
+#line 10279 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:10256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10304,7 +10331,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:10305: checking whether to use Tcl/Tk" >&5
+echo "configure:10335: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -10324,7 +10351,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:10325: checking for location of Tcl/Tk includes" >&5
+echo "configure:10355: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -10350,15 +10377,15 @@
do
-echo "configure:10351: checking for $ac_hdr" >&5
+echo "configure:10381: checking for $ac_hdr" >&5
-#line 10354 "configure"
+#line 10384 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10359: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10389: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10395,15 +10422,15 @@
do
-echo "configure:10396: checking for $ac_hdr" >&5
+echo "configure:10426: checking for $ac_hdr" >&5
-#line 10399 "configure"
+#line 10429 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10437,7 +10464,7 @@
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:10438: checking Tcl version" >&5
+echo "configure:10468: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -10445,7 +10472,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 10446 "configure"
+#line 10476 "configure"
#include <stdio.h>
@@ -10457,7 +10484,7 @@
EOF
-if { (eval echo configure:10458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -10475,7 +10502,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:10476: checking Tk version" >&5
+echo "configure:10506: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -10483,7 +10510,7 @@
else
-#line 10484 "configure"
+#line 10514 "configure"
#include <stdio.h>
@@ -10495,7 +10522,7 @@
EOF
-if { (eval echo configure:10496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:10526: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -10524,7 +10551,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:10525: checking for location of Tcl/Tk library" >&5
+echo "configure:10555: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -10564,13 +10591,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:10565: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10595: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 10571 "configure"
+#line 10601 "configure"
@@ -10581,7 +10608,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10582: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10600,13 +10627,13 @@
-echo "configure:10601: checking for Tcl_Init in -ltcl" >&5
+echo "configure:10631: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 10607 "configure"
+#line 10637 "configure"
@@ -10617,7 +10644,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10618: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10644,13 +10671,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10645: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10675: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 10651 "configure"
+#line 10681 "configure"
@@ -10661,7 +10688,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10662: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10680,13 +10707,13 @@
-echo "configure:10681: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:10711: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 10687 "configure"
+#line 10717 "configure"
@@ -10697,7 +10724,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10698: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10724,13 +10751,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:10725: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10755: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 10731 "configure"
+#line 10761 "configure"
@@ -10741,7 +10768,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10742: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10760,13 +10787,13 @@
-echo "configure:10761: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:10791: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 10767 "configure"
+#line 10797 "configure"
@@ -10777,7 +10804,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:10778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10855,13 +10882,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:10856: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10886: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 10862 "configure"
+#line 10892 "configure"
@@ -10872,7 +10899,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10903: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10891,13 +10918,13 @@
-echo "configure:10892: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:10922: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10898 "configure"
+#line 10928 "configure"
@@ -10908,7 +10935,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10939: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10935,13 +10962,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:10936: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:10966: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 10942 "configure"
+#line 10972 "configure"
@@ -10952,7 +10979,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10953: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10971,13 +10998,13 @@
-echo "configure:10972: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:11002: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 10978 "configure"
+#line 11008 "configure"
@@ -10988,7 +11015,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:10989: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11015,13 +11042,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11016: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11046: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 11022 "configure"
+#line 11052 "configure"
@@ -11032,7 +11059,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11051,13 +11078,13 @@
-echo "configure:11052: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:11082: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 11058 "configure"
+#line 11088 "configure"
@@ -11068,7 +11095,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:11069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11099: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11158,13 +11185,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:11159: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:11189: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 11165 "configure"
+#line 11195 "configure"
@@ -11175,7 +11202,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11225,7 +11252,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:11226: checking whether to use ODBC" >&5
+echo "configure:11256: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -11244,7 +11271,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:11245: checking for location of ODBC includes" >&5
+echo "configure:11275: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -11270,15 +11297,15 @@
do
-echo "configure:11271: checking for $ac_hdr" >&5
+echo "configure:11301: checking for $ac_hdr" >&5
-#line 11274 "configure"
+#line 11304 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11279: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11312,7 +11339,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:11313: checking for location of ODBC library" >&5
+echo "configure:11343: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -11337,13 +11364,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:11338: checking for SQLConnect in -lodbc" >&5
+echo "configure:11368: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 11344 "configure"
+#line 11374 "configure"
@@ -11354,7 +11381,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11379,13 +11406,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:11380: checking for SQLConnect in -liodbc" >&5
+echo "configure:11410: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 11386 "configure"
+#line 11416 "configure"
@@ -11396,7 +11423,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:11397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11427: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11421,11 +11448,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:11422: checking for ODBC library" >&5
+echo "configure:11452: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 11426 "configure"
+#line 11456 "configure"
#include <windows.h>
#include <sql.h>
@@ -11433,7 +11460,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:11434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11464: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11482,7 +11509,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:11483: checking whether to use FFTW" >&5
+echo "configure:11513: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -11501,7 +11528,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:11502: checking for location of FFTW includes" >&5
+echo "configure:11532: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -11527,15 +11554,15 @@
do
-echo "configure:11528: checking for $ac_hdr" >&5
+echo "configure:11558: checking for $ac_hdr" >&5
-#line 11531 "configure"
+#line 11561 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11566: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11563,15 +11590,15 @@
do
-echo "configure:11564: checking for $ac_hdr" >&5
+echo "configure:11594: checking for $ac_hdr" >&5
-#line 11567 "configure"
+#line 11597 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11572: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11599,15 +11626,15 @@
do
-echo "configure:11600: checking for $ac_hdr" >&5
+echo "configure:11630: checking for $ac_hdr" >&5
-#line 11603 "configure"
+#line 11633 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11638: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11653,7 +11680,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:11654: checking for location of FFTW library" >&5
+echo "configure:11684: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -11678,13 +11705,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:11679: checking for fftw_execute in -lfftw3" >&5
+echo "configure:11709: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 11685 "configure"
+#line 11715 "configure"
@@ -11695,7 +11722,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:11696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11726: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11720,13 +11747,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:11721: checking for fftwnd_one in -lfftw" >&5
+echo "configure:11751: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 11727 "configure"
+#line 11757 "configure"
#include "confdefs.h"
@@ -11737,7 +11764,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11768: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11762,13 +11789,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:11763: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:11793: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 11769 "configure"
+#line 11799 "configure"
@@ -11779,7 +11806,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:11780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11836,7 +11863,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11837: checking whether to use BLAS" >&5
+echo "configure:11867: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -11857,7 +11884,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11858: checking for location of BLAS includes" >&5
+echo "configure:11888: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11877,7 +11904,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11878: checking for location of BLAS library" >&5
+echo "configure:11908: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11903,15 +11930,15 @@
do
-echo "configure:11904: checking for $ac_hdr" >&5
+echo "configure:11934: checking for $ac_hdr" >&5
-#line 11907 "configure"
+#line 11937 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11942: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11946,13 +11973,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11947: checking for dnrm2_ in -lblas" >&5
+echo "configure:11977: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 11953 "configure"
+#line 11983 "configure"
@@ -11963,7 +11990,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:11964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11982,13 +12009,13 @@
-echo "configure:11983: checking for dnrm2_ in -lblas" >&5
+echo "configure:12013: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11989 "configure"
+#line 12019 "configure"
@@ -11999,7 +12026,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:12000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12043,13 +12070,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:12044: checking for ATL_xerbla in -latlas" >&5
+echo "configure:12074: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 12050 "configure"
+#line 12080 "configure"
@@ -12060,7 +12087,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:12061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12075,13 +12102,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:12076: checking for sgemm_ in -lf77blas" >&5
+echo "configure:12106: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 12082 "configure"
+#line 12112 "configure"
@@ -12092,7 +12119,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12107,13 +12134,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:12108: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:12138: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 12114 "configure"
+#line 12144 "configure"
@@ -12124,7 +12151,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:12125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12170,16 +12197,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:12171: checking for sgemm in $vlib_flags" >&5
+echo "configure:12201: checking for sgemm in $vlib_flags" >&5
-#line 12173 "configure"
+#line 12203 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:12180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12210: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -12197,13 +12224,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:12198: checking for sgemm_ in -lblas" >&5
+echo "configure:12228: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 12204 "configure"
+#line 12234 "configure"
@@ -12214,7 +12241,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12229,13 +12256,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:12230: checking for dgemm_ in -ldgemm" >&5
+echo "configure:12260: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 12236 "configure"
+#line 12266 "configure"
@@ -12246,7 +12273,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:12247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12261,13 +12288,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:12262: checking for sgemm_ in -lsgemm" >&5
+echo "configure:12292: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 12268 "configure"
+#line 12298 "configure"
@@ -12278,7 +12305,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12312,13 +12339,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:12313: checking for acosp in -lsunmath" >&5
+echo "configure:12343: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 12319 "configure"
+#line 12349 "configure"
@@ -12329,7 +12356,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:12330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12360: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12344,13 +12371,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:12345: checking for sgemm_ in -lsunperf" >&5
+echo "configure:12375: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 12351 "configure"
+#line 12381 "configure"
@@ -12361,7 +12388,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12391,13 +12418,13 @@
# Generic BLAS library
-echo "configure:12392: checking for sgemm_ in -lblas" >&5
+echo "configure:12422: checking for sgemm_ in -lblas" >&5
ac_save_LIBS="$LIBS"
LIBS="-lblas $LIBS"
-#line 12398 "configure"
+#line 12428 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12408,7 +12435,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:12409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12447,7 +12474,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:12448: checking whether to use LAPACK" >&5
+echo "configure:12478: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -12472,7 +12499,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:12473: checking for location of LAPACK includes" >&5
+echo "configure:12503: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -12492,7 +12519,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:12493: checking for location of LAPACK library" >&5
+echo "configure:12523: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -12518,15 +12545,15 @@
do
-echo "configure:12519: checking for $ac_hdr" >&5
+echo "configure:12549: checking for $ac_hdr" >&5
-#line 12522 "configure"
+#line 12552 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12557: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12558,10 +12585,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:12559: checking for dsegv_" >&5
+echo "configure:12589: checking for dsegv_" >&5
-#line 12562 "configure"
+#line 12592 "configure"
which can conflict with char dsegv_(); below. */
@@ -12584,7 +12611,7 @@
; return 0; }
EOF
-if { (eval echo configure:12585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -12611,13 +12638,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12612: checking for desgv_ in -llapack" >&5
+echo "configure:12642: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 12618 "configure"
+#line 12648 "configure"
@@ -12628,7 +12655,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:12629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12660,13 +12687,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:12661: checking for dgesv_ in -llapack" >&5
+echo "configure:12691: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 12667 "configure"
+#line 12697 "configure"
@@ -12677,7 +12704,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12696,13 +12723,13 @@
-echo "configure:12697: checking for dgesv_ in -llapack" >&5
+echo "configure:12727: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 12703 "configure"
+#line 12733 "configure"
@@ -12713,7 +12740,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:12714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12769,7 +12796,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:12770: checking whether to use Cairo" >&5
+echo "configure:12800: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -12801,7 +12828,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:12802: checking for location of cairo includes" >&5
+echo "configure:12832: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12827,15 +12854,15 @@
do
-echo "configure:12828: checking for $ac_hdr" >&5
+echo "configure:12858: checking for $ac_hdr" >&5
-#line 12831 "configure"
+#line 12861 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12866: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12871,7 +12898,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12872: checking for location of cairo library" >&5
+echo "configure:12902: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12891,7 +12918,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12892: checking for cairo linking flags" >&5
+echo "configure:12922: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12907,10 +12934,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12908: checking for cairo_create" >&5
+echo "configure:12938: checking for cairo_create" >&5
-#line 12911 "configure"
+#line 12941 "configure"
which can conflict with char cairo_create(); below. */
@@ -12933,7 +12960,7 @@
; return 0; }
EOF
-if { (eval echo configure:12934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -12967,10 +12994,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12968: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12998: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12971 "configure"
+#line 13001 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -12993,7 +13020,7 @@
; return 0; }
EOF
-if { (eval echo configure:12994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -13026,10 +13053,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:13027: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:13057: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 13030 "configure"
+#line 13060 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -13052,7 +13079,7 @@
; return 0; }
EOF
-if { (eval echo configure:13053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13083: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -13094,7 +13121,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13095: checking whether to use FreeType" >&5
+echo "configure:13125: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -13113,7 +13140,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13114: checking for location of FreeType includes" >&5
+echo "configure:13144: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13139,15 +13166,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13140: checking for $ac_hdr" >&5
+echo "configure:13170: checking for $ac_hdr" >&5
-#line 13143 "configure"
+#line 13173 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13148: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13178: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13181,7 +13208,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13182: checking for location of FreeType library" >&5
+echo "configure:13212: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13206,13 +13233,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13207: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13237: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 13213 "configure"
+#line 13243 "configure"
@@ -13223,7 +13250,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:13224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13264,7 +13291,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13265: checking whether to use NLS" >&5
+echo "configure:13295: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -13284,10 +13311,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13285: checking for gettext" >&5
+echo "configure:13315: checking for gettext" >&5
-#line 13288 "configure"
+#line 13318 "configure"
which can conflict with char gettext(); below. */
@@ -13310,7 +13337,7 @@
; return 0; }
EOF
-if { (eval echo configure:13311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -13328,13 +13355,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:13329: checking for gettext in -lintl" >&5
+echo "configure:13359: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 13335 "configure"
+#line 13365 "configure"
@@ -13345,7 +13372,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:13346: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13380,7 +13407,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:13381: checking whether to use C++" >&5
+echo "configure:13411: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -13396,7 +13423,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13397: checking for $ac_word" >&5
+echo "configure:13427: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -13425,7 +13452,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:13426: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:13456: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -13436,12 +13463,12 @@
cat > conftest.$ac_ext << EOF
-#line 13437 "configure"
+#line 13467 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:13442: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -13467,19 +13494,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:13468: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:13498: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:13473: checking whether we are using GNU C++" >&5
+echo "configure:13503: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13480: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:13510: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -13497,7 +13524,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:13498: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:13528: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -13538,7 +13565,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:13539: checking whether to use openDWG" >&5
+echo "configure:13569: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -13558,7 +13585,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:13559: checking for location of openDGW includes" >&5
+echo "configure:13589: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -13584,15 +13611,15 @@
do
-echo "configure:13585: checking for $ac_hdr" >&5
+echo "configure:13615: checking for $ac_hdr" >&5
-#line 13588 "configure"
+#line 13618 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13623: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13626,7 +13653,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:13627: checking for location of openDWG library" >&5
+echo "configure:13657: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -13667,7 +13694,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:13668: checking whether to use POSIX threads" >&5
+echo "configure:13698: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -13687,7 +13714,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:13688: checking for location of POSIX threads includes" >&5
+echo "configure:13718: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -13713,15 +13740,15 @@
do
-echo "configure:13714: checking for $ac_hdr" >&5
+echo "configure:13744: checking for $ac_hdr" >&5
-#line 13717 "configure"
+#line 13747 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13722: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13752: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13755,7 +13782,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13756: checking for location of POSIX threads library" >&5
+echo "configure:13786: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13780,10 +13807,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13781: checking for pthread_create" >&5
+echo "configure:13811: checking for pthread_create" >&5
-#line 13784 "configure"
+#line 13814 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -13806,7 +13833,7 @@
; return 0; }
EOF
-if { (eval echo configure:13807: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -13833,13 +13860,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13834: checking for pthread_create in -lpthread" >&5
+echo "configure:13864: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
LIBS="-lpthread $LIBS"
-#line 13840 "configure"
+#line 13870 "configure"
@@ -13850,7 +13877,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:13851: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13906,7 +13933,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13907: checking for special C compiler options needed for large files" >&5
+echo "configure:13937: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13914,7 +13941,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13915 "configure"
+#line 13945 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13930,7 +13957,7 @@
; return 0; }
EOF
-if { (eval echo configure:13931: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -13939,7 +13966,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13940 "configure"
+#line 13970 "configure"
@@ -13955,7 +13982,7 @@
; return 0; }
EOF
-if { (eval echo configure:13956: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13986: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13975,11 +14002,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13976: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14006: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13980 "configure"
+#line 14010 "configure"
@@ -13995,14 +14022,14 @@
; return 0; }
EOF
-if { (eval echo configure:13996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14026: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 14003 "configure"
+#line 14033 "configure"
#define _FILE_OFFSET_BITS 64
@@ -14020,7 +14047,7 @@
; return 0; }
EOF
-if { (eval echo configure:14021: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14051: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -14039,11 +14066,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14040: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14070: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 14044 "configure"
+#line 14074 "configure"
@@ -14059,14 +14086,14 @@
; return 0; }
EOF
-if { (eval echo configure:14060: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14090: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14067 "configure"
+#line 14097 "configure"
#define _LARGE_FILES 1
@@ -14084,7 +14111,7 @@
; return 0; }
EOF
-if { (eval echo configure:14085: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14115: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -14103,25 +14130,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14104: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14134: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 14108 "configure"
+#line 14138 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14115: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14145: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14122 "configure"
+#line 14152 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -14130,7 +14157,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14131: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14161: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -14151,25 +14178,25 @@
fi
-echo "configure:14152: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14182: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 14156 "configure"
+#line 14186 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14163: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14193: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 14170 "configure"
+#line 14200 "configure"
#include <stdio.h>
@@ -14178,7 +14205,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14179: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14209: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -14201,18 +14228,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14202: checking for fseeko" >&5
+echo "configure:14232: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 14206 "configure"
+#line 14236 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:14213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14243: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -14229,10 +14256,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14230: checking if system supports Large Files at all" >&5
+echo "configure:14260: checking if system supports Large Files at all" >&5
-#line 14233 "configure"
+#line 14263 "configure"
#include <stdio.h>
@@ -14264,7 +14291,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14295: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -14293,7 +14320,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:14294: checking whether to use wxWidgets" >&5
+echo "configure:14324: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -14314,7 +14341,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:14315: checking for $ac_word" >&5
+echo "configure:14345: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -14362,7 +14389,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:14363: checking wxWidgets version" >&5
+echo "configure:14393: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -14385,15 +14412,15 @@
do
-echo "configure:14386: checking for $ac_hdr" >&5
+echo "configure:14416: checking for $ac_hdr" >&5
-#line 14389 "configure"
+#line 14419 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14394: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14424: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15021,7 +15048,7 @@
echo ""
-echo " NVIZ: `if test -n "${USE_TOGL}" ; then echo yes ; else echo no ; fi`"
+echo " Tcl/Tk NVIZ: `if test -n "${USE_TOGL}" ; then echo yes ; else echo no ; fi`"
echo ""
@@ -15050,7 +15077,7 @@
echo " Large File support (LFS): `if test -n "${USE_LARGEFILES}" ; then echo yes ; else echo no ; fi`"
-echo " libLAS support: `if test -n "${USE_LIBLAS}" ; then echo yes ; else echo no ; fi`"
+echo " LIBLAS support: `if test -n "${USE_LIBLAS}" ; then echo yes ; else echo no ; fi`"
echo " MySQL support: `if test -n "${USE_MYSQL}" ; then echo yes ; else echo no ; fi`"
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in 2011-07-09 17:01:15 UTC (rev 47077)
+++ grass/trunk/configure.in 2011-07-09 17:06:51 UTC (rev 47078)
@@ -1932,7 +1932,7 @@
LOC_MSG([ MacOSX architectures: ${MACOSX_ARCHS}])
LOC_MSG([ MacOSX SDK: ${MACOSX_SDK}])
LOC_MSG()
-LOC_MSG_USE(NVIZ,USE_TOGL)
+LOC_MSG_USE(Tcl/Tk NVIZ,USE_TOGL)
LOC_MSG()
LOC_MSG_USE(BLAS support,USE_BLAS)
LOC_MSG_USE(C++ support,USE_CXX)
