[GRASS-SVN] r47141 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Sun Jul 17 12:24:51 EDT 2011
Author: aghisla
Date: 2011-07-17 09:24:51 -0700 (Sun, 17 Jul 2011)
New Revision: 47141
grass/branches/develbranch_6/locale/po/grasslibs_it.po
Updated Italian translation of grasslibs
Modified: grass/branches/develbranch_6/locale/po/grasslibs_it.po
--- grass/branches/develbranch_6/locale/po/grasslibs_it.po 2011-07-17 16:22:21 UTC (rev 47140)
+++ grass/branches/develbranch_6/locale/po/grasslibs_it.po 2011-07-17 16:24:51 UTC (rev 47141)
@@ -13,7 +13,7 @@
"Project-Id-Version: grasslibs_it\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-06-09 20:20+0200\n"
-"PO-Revision-Date: 2011-07-15 19:13+0100\n"
+"PO-Revision-Date: 2011-07-17 18:16+0100\n"
"Last-Translator: Anne Ghisla <a.ghisla at gmail.com>\n"
"Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
"Language: it\n"
@@ -520,7 +520,7 @@
#: ../lib/gis/mapset_msc.c:60
#, c-format
msgid "Unable to make mapset element %s (%s): %s"
-msgstr ""
+msgstr "Impossibile creare l'elemento %s (%s) nel mapset: %s"
#: ../lib/gis/mapset_msc.c:64
#, c-format
@@ -554,7 +554,7 @@
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
#, c-format
msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine nord (%g>%g)"
#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
msgid "Illegal latitude for North"
@@ -563,7 +563,7 @@
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
#, c-format
msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine sud (%g>%g)"
#: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
msgid "Illegal latitude for South"
@@ -572,12 +572,12 @@
#: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
#, c-format
msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine ovest (%g>%g)"
#: ../lib/gis/adj_cellhd.c:118 ../lib/gis/adj_cellhd.c:286
#, c-format
msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine est (%g>%g)"
#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
msgid "North must be north of South"
@@ -629,7 +629,7 @@
#: ../lib/gis/parser.c:341
msgid "Example: income < 1000 and inhab >= 10000"
-msgstr ""
+msgstr "Esempio: income < 1000 e inhab >= 10000"
#: ../lib/gis/parser.c:349
msgid "Table name"
@@ -901,7 +901,7 @@
#: ../lib/gis/parser.c:1992
msgid "Unable to spawn the 'wish' program"
-msgstr ""
+msgstr "Impossibile avviare il programma 'wish'"
#: ../lib/gis/parser.c:2011
msgid "Unable to determine program name"
@@ -1215,12 +1215,12 @@
#: ../lib/gis/open_misc.c:45
#, c-format
msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
+msgstr "G__open_misc(read): mapset <%s> non corrisponde a xmapset <%s>"
#: ../lib/gis/open_misc.c:67
#, c-format
msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
+msgstr "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
#: ../lib/gis/home.c:39
msgid "unable to determine user's home directory"
@@ -2210,7 +2210,7 @@
#: ../lib/vector/diglib/plus_area.c:299
msgid "Attempt to delete isle from dead area"
-msgstr "Tentativo di cancellare isola da area "
+msgstr "Tentativo di cancellare isola da area inesistente"
#: ../lib/vector/diglib/plus_area.c:316
#, c-format
@@ -2339,7 +2339,7 @@
#: ../lib/vector/Vlib/cats.c:45
msgid "Vect_new_cats_struct(): Out of memory"
-msgstr ""
+msgstr "Vect_new_cats_struct(): Memoria esaurita"
#: ../lib/vector/Vlib/cats.c:129
#, c-format
@@ -2405,7 +2405,7 @@
#: ../lib/vector/Vlib/intersect.c:1164 ../lib/vector/Vlib/intersect.c:1185
#: ../lib/vector/Vlib/intersect.c:1202
msgid "Error while adding point to array. Out of memory"
-msgstr ""
+msgstr "Errore nell'aggiungere il punto all'array. Memoria eaurita"
#: ../lib/vector/Vlib/level.c:38
msgid "Map structure was never initialized"
@@ -2461,7 +2461,7 @@
#: ../lib/vector/Vlib/geos.c:56
#, c-format
msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr ""
+msgstr "Vect_read_line_geos(): l'id %d della feature è irragionevole (numero massimo di features nella mappa vettoriale <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:61
msgid "only native format supported"
@@ -2486,7 +2486,7 @@
#: ../lib/vector/Vlib/geos.c:203
#, c-format
msgid "Unable to read line offset %ld"
-msgstr ""
+msgstr "Impossibile leggere l'offset %ld della linea "
#: ../lib/vector/Vlib/geos.c:410
#, c-format
@@ -2731,12 +2731,12 @@
#: ../lib/vector/Vlib/area.c:257 ../lib/vector/Vlib/area.c:286
#, c-format
msgid "Attempt to read topo for dead area (%d)"
-msgstr ""
+msgstr "Tentativo di leggere la topologia da un'area inesistente (%d)"
#: ../lib/vector/Vlib/area.c:313
#, c-format
msgid "Attempt to read topo for dead isle (%d)"
-msgstr ""
+msgstr "Tentativo di leggere la topologia da un'isola inesistente (%d)"
#: ../lib/vector/Vlib/header.c:95 ../lib/vector/Vlib/header.c:143
#, c-format
@@ -2751,12 +2751,12 @@
#: ../lib/vector/Vlib/header.c:187
#, c-format
msgid "Unknown keyword %s in vector head"
-msgstr ""
+msgstr "Parola chiave %s sconosciuta nell'header del vettoriale"
#: ../lib/vector/Vlib/read.c:102
#, c-format
msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
-msgstr ""
+msgstr "Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di features nella mappa vettoriale <%s>: %d)"
#: ../lib/vector/Vlib/build_nat.c:93
msgid "Unable to add area (map closed, topo saved)"
@@ -3005,12 +3005,12 @@
#: ../lib/vector/Vlib/net.c:346
msgid "Setting node costs..."
-msgstr ""
+msgstr "Impostazione in corso dei costi dei nodi..."
#: ../lib/vector/Vlib/net.c:402
#, c-format
msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
+msgstr "Record del database non trovato per il nodo %d (cat = %d) (costo impostato a 0)"
#: ../lib/vector/Vlib/net.c:429
msgid "Flattening the graph..."
@@ -3162,7 +3162,7 @@
#: ../lib/vector/Vlib/open.c:622
#, c-format
msgid "Unable to stat file <%s>"
-msgstr ""
+msgstr "Impossibile eseguire 'stat' sul file <%s>"
#: ../lib/vector/Vlib/open.c:731
msgid "Size of 'coor' file differs from value saved in topology file"
@@ -3195,12 +3195,12 @@
#: ../lib/vector/Vlib/open_ogr.c:147
#, c-format
msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
-msgstr ""
+msgstr "Versione %d.%d del formato dell'indice delle features non è supportata da questa release. Ricostruire la topologia o aggiornare GRASS."
#: ../lib/vector/Vlib/open_ogr.c:152
#, c-format
msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
+msgstr "Questa versione di GRASS non supporta appieno il formato %d.%d dell'indice delle features del vettore. Si consiglia di ricostruire la topologia o aggiornare GRASS."
#: ../lib/vector/Vlib/level_two.c:251 ../lib/vector/Vlib/level_two.c:276
#: ../lib/vector/Vlib/level_two.c:300 ../lib/vector/Vlib/level_two.c:319
@@ -3252,7 +3252,7 @@
#: ../lib/vector/Vlib/build_ogr.c:333
msgid "Partial build for OGR is not supported"
-msgstr ""
+msgstr "Build parziale per OGR non supportato"
#: ../lib/vector/Vlib/build_ogr.c:342
msgid "Random read is not supported by OGR for this layer, cannot build support"
@@ -3287,7 +3287,7 @@
#: ../lib/rst/interp_float/interp2d.c:119
#: ../lib/rst/interp_float/interp2d.c:125 ../lib/ogsf/gsd_img_mpeg.c:317
msgid "Out of memory"
-msgstr "Fuori memoria"
+msgstr "Memoria esaurita"
#: ../lib/vector/Vlib/line.c:199 ../lib/vector/Vlib/line.c:231
msgid "Index out of range in"
@@ -3461,7 +3461,7 @@
#: ../lib/gpde/N_parse_options.c:80
msgid "Maximum number of iteration used to solver the linear equation system"
-msgstr ""
+msgstr "Numero massimo di iterazioni utilizzato per risolvere il sistema di equazioni lineari"
#: ../lib/gpde/N_parse_options.c:89
msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
@@ -3480,44 +3480,56 @@
"\n"
"++ Running geom_data unit tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli unit test geom_data ++"
#: ../lib/gpde/test/test_geom.c:41
msgid ""
"\n"
"-- geom_data unit tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli unit test geom_data --"
#: ../lib/gpde/test/test_geom.c:43
msgid ""
"\n"
"-- geom_data unit tests finished successfully --"
msgstr ""
+"\n"
+"-- Unit test geom_data conclusi con successo --"
#: ../lib/gpde/test/test_gradient.c:42
msgid ""
"\n"
"++ Running gradient unit tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli unit test gradient ++"
#: ../lib/gpde/test/test_gradient.c:44
msgid "\t 1. testing 2d gradient"
-msgstr ""
+msgstr "\t 1. test del secondo gradient"
#: ../lib/gpde/test/test_gradient.c:47
msgid "\t 2. testing 3d gradient"
-msgstr ""
+msgstr "\t 2. test del terzo gradient"
#: ../lib/gpde/test/test_gradient.c:51
msgid ""
"\n"
"-- Gradient unit tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli unit test gradient --"
#: ../lib/gpde/test/test_gradient.c:53
msgid ""
"\n"
"-- Gradient unit tests finished successfully --"
msgstr ""
+"\n"
+"-- Unit test gradient conclusi con successo --"
#: ../lib/gpde/test/test_main.c:49 ../lib/gmath/test/test_main.c:47
msgid "Choose the unit tests to run"
@@ -3552,130 +3564,160 @@
"\n"
"++ Running gwflow integration tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli integration test gwflow ++"
#: ../lib/gpde/test/test_gwflow.c:48
msgid "\t 1. testing 2d gwflow"
-msgstr ""
+msgstr "\t 1. test di gwflow 2D"
#: ../lib/gpde/test/test_gwflow.c:51
msgid "\t 2. testing 3d gwflow"
-msgstr ""
+msgstr "\t 2. test di gwflow 3D"
#: ../lib/gpde/test/test_gwflow.c:55
msgid ""
"\n"
"-- gwflow integration tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli integration test gwflow --"
#: ../lib/gpde/test/test_gwflow.c:57
msgid ""
"\n"
"-- gwflow integration tests finished successfully --"
msgstr ""
+"\n"
+"-- Integration test gwflow conclusi con successo --"
#: ../lib/gpde/test/test_solute_transport.c:43
msgid ""
"\n"
"++ Running solute_transport integration tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli integration test solute_transport ++"
#: ../lib/gpde/test/test_solute_transport.c:45
msgid "\t 1. testing 2d solute_transport"
-msgstr ""
+msgstr "\t 1. test di solute_transport 2D"
#: ../lib/gpde/test/test_solute_transport.c:48
msgid "\t 2. testing 3d solute_transport"
-msgstr ""
+msgstr "\t 2. test di solute_transport 3D"
#: ../lib/gpde/test/test_solute_transport.c:52
msgid ""
"\n"
"-- solute_transport integration tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli integration test solute_transport --"
#: ../lib/gpde/test/test_solute_transport.c:55
msgid ""
"\n"
"-- solute_transport integration tests finished successfully --"
msgstr ""
+"\n"
+"-- Integration test solute_transport conclusi con successo --"
#: ../lib/gpde/test/test_assemble.c:42
msgid ""
"\n"
"++ Running assembling unit tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli unit test assembling ++"
#: ../lib/gpde/test/test_assemble.c:44
msgid "\t 1. testing 2d assembling"
-msgstr ""
+msgstr "\t 1. testing di assembling 2D"
#: ../lib/gpde/test/test_assemble.c:47
msgid "\t 2. testing 3d assembling"
-msgstr ""
+msgstr "\t 2. testing di assembling 3D"
#: ../lib/gpde/test/test_assemble.c:51
msgid ""
"\n"
"-- Assembling unit tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli unit test assembling --"
#: ../lib/gpde/test/test_assemble.c:53
msgid ""
"\n"
"-- Assembling unit tests finished successfully --"
msgstr ""
+"\n"
+"-- Unit test assembling conclusi con successo --"
#: ../lib/gpde/test/test_heat.c:33
msgid ""
"\n"
"++ Running heat flow integration tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli untegration test del flusso di calore ++"
#: ../lib/gpde/test/test_heat.c:35
msgid "\t 1. testing 2d heat flow"
-msgstr ""
+msgstr "\t 1. test del flusso di calore 2D"
#: ../lib/gpde/test/test_heat.c:37
msgid "\t 2. testing 3d heat flow"
-msgstr ""
+msgstr "\t 1. test del flusso di calore 3D"
#: ../lib/gpde/test/test_heat.c:40
msgid ""
"\n"
"-- heat flow integration tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli integration test del flusso di calore --"
#: ../lib/gpde/test/test_heat.c:42
msgid ""
"\n"
"-- heat flow integration tests finished successfully --"
msgstr ""
+"\n"
+"-- Integration test del flusso di calore conclusi con successo --"
#: ../lib/gpde/test/test_arrays.c:48
msgid ""
"\n"
"++ Running array unit tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli unit test array ++"
#: ../lib/gpde/test/test_arrays.c:50
msgid "\t 1. testing 2d arrays"
-msgstr ""
+msgstr "\t 1. test degli array 2D"
#: ../lib/gpde/test/test_arrays.c:53
msgid "\t 2. testing 3d arrays"
-msgstr ""
+msgstr "\t 2. test degli array 3D"
#: ../lib/gpde/test/test_arrays.c:57
msgid ""
"\n"
"-- Array unit tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli unit test array --"
#: ../lib/gpde/test/test_arrays.c:59
msgid ""
"\n"
"-- Array unit tests finished successfully --"
msgstr ""
+"\n"
+"-- Unit test array conclusi con successo --"
#: ../lib/gpde/test/test_les.c:35
msgid ""
@@ -4134,7 +4176,7 @@
#: ../lib/ogsf/GS2.c:1737 ../lib/ogsf/GS2.c:1745 ../lib/ogsf/GS2.c:1755
#: ../lib/ogsf/GS2.c:1803
msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
+msgstr "GS_load_att_map(): Memoria esaurita. Impossibile caricare la mappa"
#: ../lib/ogsf/GS2.c:1831
msgid "Loading failed"
@@ -4218,7 +4260,7 @@
#: ../lib/ogsf/gsdrape.c:207
msgid "Unable to process vector map - out of memory"
-msgstr "Impossibile processare il vettoriale - fuori memoria"
+msgstr "Impossibile processare il vettoriale - memoria esaurita"
#: ../lib/db/dbmi_base/legal_dbname.c:25
#, c-format
@@ -4465,18 +4507,24 @@
"\n"
"++ Running solver unit tests ++"
msgstr ""
+"\n"
+"++ Esecuzione degli unit test solver ++"
#: ../lib/gmath/test/test_solvers.c:42
msgid ""
"\n"
"-- Solver unit tests failure --"
msgstr ""
+"\n"
+"-- Fallimento degli unit test solver --"
#: ../lib/gmath/test/test_solvers.c:44
msgid ""
"\n"
"-- Solver unit tests finished successfully --"
msgstr ""
+"\n"
+"-- Unit test solver conclusi con successo --"
#: ../lib/gmath/test/bench_solver_krylov.c:34
msgid ""
