[GRASS-SVN] r47154 - grass/trunk/lib/gis
svn_grass at osgeo.org
Mon Jul 18 05:15:35 EDT 2011
Author: martinl
Date: 2011-07-18 02:15:35 -0700 (Mon, 18 Jul 2011)
New Revision: 47154
grass/trunk/lib/gis/env.c
gislib: update env.c doxygen documentation
Modified: grass/trunk/lib/gis/env.c
--- grass/trunk/lib/gis/env.c 2011-07-18 09:06:41 UTC (rev 47153)
+++ grass/trunk/lib/gis/env.c 2011-07-18 09:15:35 UTC (rev 47154)
@@ -276,7 +276,7 @@
\brief Get environment variable
- Calls G_fatal_error() if name not set.
+ G_fatal_error() is called when variable is not found.
\param name variable name
@@ -289,12 +289,12 @@
if (value)
return value;
- G_fatal_error(_("G_getenv(): Variable %s not set"), name);
+ G_fatal_error(_("Variable '%s' not set"), name);
return NULL;
- \brief Read variable from specific place
+ \brief Get variable from specific place
Locations:
- G_VAR_GISRC
@@ -303,7 +303,7 @@
- \param loc location id
+ \param loc location (G_VAR_GISRC, G_VAR_MAPSET)
\return variable value
\return NULL if not found
@@ -315,7 +315,7 @@
if (value)
return value;
- G_fatal_error(_("%s not set"), name);
return NULL;
@@ -341,7 +341,7 @@
\brief Get environment variable from specific place
\return char pointer to value for name
\return NULL if name not set
@@ -357,11 +357,10 @@
- \brief Set environment variable
+ \brief Set environment variable (updates .gisrc)
If value is NULL, becomes an G_unsetenv().
- Updates .gisrc
\param value variable value
@@ -373,11 +372,9 @@
- \brief Set environment variable from specific place
+ \brief Set environment variable from specific place (updates .gisrc)
- Updates .gisrc
@@ -392,7 +389,7 @@
- \brief Set environment name to value
+ \brief Set environment name to value (doesn't update .gisrc)
@@ -404,11 +401,11 @@
- \brief Set environment name to value from specific place
+ \brief Set environment name to value from specific place (doesn't update .gisrc)
void G__setenv2(const char *name, const char *value, int loc)
@@ -436,7 +433,7 @@
Updates .gisrc
void G_unsetenv2(const char *name, int loc)
