[GRASS-SVN] r46648 - grass/trunk/locale/po
Thu Jun 9 14:04:03 EDT 2011
Author: neteler
Date: 2011-06-09 11:04:03 -0700 (Thu, 09 Jun 2011)
New Revision: 46648
   grass/trunk/locale/po/grasslibs_ar.po
   grass/trunk/locale/po/grasslibs_cs.po
   grass/trunk/locale/po/grasslibs_de.po
   grass/trunk/locale/po/grasslibs_el.po
   grass/trunk/locale/po/grasslibs_es.po
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasslibs_hi.po
   grass/trunk/locale/po/grasslibs_it.po
   grass/trunk/locale/po/grasslibs_ja.po
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grasslibs_lv.po
   grass/trunk/locale/po/grasslibs_ml.po
   grass/trunk/locale/po/grasslibs_mr.po
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_pt.po
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_ru.po
   grass/trunk/locale/po/grasslibs_sl.po
   grass/trunk/locale/po/grasslibs_th.po
   grass/trunk/locale/po/grasslibs_tr.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grasslibs_zh.po
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/locale/po/grasswxpy_cs.po
   grass/trunk/locale/po/grasswxpy_de.po
   grass/trunk/locale/po/grasswxpy_el.po
   grass/trunk/locale/po/grasswxpy_es.po
   grass/trunk/locale/po/grasswxpy_fr.po
   grass/trunk/locale/po/grasswxpy_id.po
   grass/trunk/locale/po/grasswxpy_it.po
   grass/trunk/locale/po/grasswxpy_ja.po
   grass/trunk/locale/po/grasswxpy_ml.po
   grass/trunk/locale/po/grasswxpy_pl.po
   grass/trunk/locale/po/grasswxpy_pt.po
   grass/trunk/locale/po/grasswxpy_pt_br.po
   grass/trunk/locale/po/grasswxpy_ru.po
   grass/trunk/locale/po/grasswxpy_th.po
   grass/trunk/locale/po/grasswxpy_tr.po
   grass/trunk/locale/po/grasswxpy_vi.po
   grass/trunk/locale/po/grasswxpy_zh.po
msgs updated from template files
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_ar.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ar\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2005-03-09 12:50+0100\n"
 "Last-Translator: Dr. Alaa Masoud <alaamasoud at hotmail.com>\n"
 "Language-Team: Arabic <grass-translations at lists.osgeo.org>\n"
@@ -366,74 +366,74 @@
 msgid "Unable to locate symbol <%s>"
 msgstr "لم يمكن فتحه %s فى %s"
-#: ../lib/raster/gdal.c:132
+#: ../lib/raster/gdal.c:134
 #, fuzzy
 msgid "Unable to load GDAL library"
 msgstr "%s: لم يمكن فتح ملف  الطبوغرافية للكتابة\n"
-#: ../lib/raster/gdal.c:362
+#: ../lib/raster/gdal.c:364
 #, fuzzy
 msgid "Unable to open GDAL file"
-#: ../lib/raster/gdal.c:466 ../lib/raster/open.c:570
+#: ../lib/raster/gdal.c:468 ../lib/raster/open.c:570
 #, fuzzy, c-format
 msgid "Invalid map type <%d>"
 msgstr " [%s] غير قادر على أنشاء ملف عنوان رئيسى ل"
-#: ../lib/raster/gdal.c:472
+#: ../lib/raster/gdal.c:474
 #, fuzzy, c-format
 msgid "Unable to get <%s> driver"
 msgstr " %s لم يمكن فتح"
-#: ../lib/raster/gdal.c:481
+#: ../lib/raster/gdal.c:483
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using <%s> driver"
-#: ../lib/raster/gdal.c:489
+#: ../lib/raster/gdal.c:491
 #, c-format
 msgid ""
 "Driver <%s> does not support direct writing. Using MEM driver for "
 "intermediate dataset."
 msgstr ""
-#: ../lib/raster/gdal.c:495
+#: ../lib/raster/gdal.c:497
 #, fuzzy
 msgid "Unable to get in-memory raster driver"
 msgstr "لم يتم انشاء عملية جديدة"
-#: ../lib/raster/gdal.c:502
+#: ../lib/raster/gdal.c:504
 #, fuzzy, c-format
 msgid "Unable to create <%s> dataset using memory driver"
 msgstr "لم يتم كتابة روابط قاعدة البيانات"
-#: ../lib/raster/gdal.c:506
+#: ../lib/raster/gdal.c:508
 #, c-format
 msgid "Driver <%s> does not support creating rasters"
 msgstr ""
-#: ../lib/raster/gdal.c:522
+#: ../lib/raster/gdal.c:524
 #, fuzzy
 msgid "Unable to set geo transform"
-#: ../lib/raster/gdal.c:526
+#: ../lib/raster/gdal.c:528
 #, fuzzy
 msgid "Unable to set projection"
-#: ../lib/raster/gdal.c:530
+#: ../lib/raster/gdal.c:532
 #, fuzzy, c-format
 msgid "Unable to create cell_misc/%s/gdal file"
 msgstr "لم يمكن فتح ملف مؤقت"
-#: ../lib/raster/gdal.c:546
+#: ../lib/raster/gdal.c:548
 #, fuzzy, c-format
 msgid "Error writing cell_misc/%s/gdal file"
 msgstr "خطا فى كتابة الدليل الفراغى\n"
-#: ../lib/raster/gdal.c:594
+#: ../lib/raster/gdal.c:596
 #, fuzzy, c-format
 msgid "Unable to create output file <%s> using driver <%s>"
@@ -4107,7 +4107,7 @@
 msgid "Unable to create rendering context"
-#: ../lib/nviz/lights.c:174
+#: ../lib/nviz/lights.c:171
 #, fuzzy
 msgid "Unable to define new light"
@@ -4459,6 +4459,20 @@
 msgid "Please recompile with Large File Support (LFS)"
 msgstr ""
+#: ../lib/init/lock.c:38
+#, c-format
+msgid "Usage: %s file pid"
+msgstr ""
+#: ../lib/init/lock.c:42
+msgid "Concurrent mapset locking is not supported on Windows"
+msgstr ""
+#: ../lib/init/lock.c:60
+#, c-format
+msgid "Unable to write lockfile %s (disk full? Permissions?)"
+msgstr ""
 #: ../lib/init/grass.py:60
 #, fuzzy
 msgid "WARNING"
@@ -4751,7 +4765,7 @@
 msgid "Starting GRASS GIS..."
 msgstr ""
-#: ../lib/init/grass.py:1020
+#: ../lib/init/grass.py:1022
 #, python-format
 msgid "Launching '%s' GUI in the background, please wait..."
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_cs.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -14,7 +14,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_cs\n"
 "PO-Revision-Date: 2011-05-04 18:42+0200\n"
 "Last-Translator: \n"
 "Language-Team:  <cs at li.org>\n"
@@ -377,73 +377,73 @@
 msgstr "Nelze nalézt symbol <%s>"
 msgstr "Nelze naèíst GDAL knihovnu"
 #, fuzzy
 msgstr "Nelze otevøít soubor %s"
 #, fuzzy, c-format
 msgstr "Nesprávné jméno vektorové mapy <%s>"
 #, fuzzy, c-format
 msgstr "Nelze otevøít <%s>"
 #, fuzzy, c-format
 msgstr "Nelze vytvoøit tabulku <%s>"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Nelze zapsat øádku rastru %i"
 #, fuzzy, c-format
 msgstr "Nelze otevøít databázi <%s> pomocí ovladaèe <%s>"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Nelze nastavit zaostøení"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Nelze èíst hlavièkový soubor"
 #, fuzzy, c-format
 msgstr "Chyba pøi zapisování souboru s prostorovým indexem."
 #, fuzzy, c-format
 msgstr "Nelze otevøít soubor %s v <%s>"
@@ -4115,7 +4115,7 @@
 msgstr "Nelze vytvoøit obsah robrazení"
 msgstr "Nelze definovat novou linii"
@@ -4519,6 +4519,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4816,7 +4830,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_de.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_de\n"
 "PO-Revision-Date: 2011-05-08 20:58+0100\n"
 "Last-Translator: Markus Neteler <neteler osgeo.org>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
@@ -381,73 +381,73 @@
 msgstr "Kann das Symbol <%s> nicht lokalisieren."
 msgstr "Kann die GDAL-Bibliothek nicht laden."
 #, fuzzy
 msgstr "Kann Datei %s nicht öffnen."
 #, fuzzy, c-format
 msgstr "Kann nicht zum Verzeichnis %s wechseln."
 #, fuzzy, c-format
 msgstr "Kann %s nicht öffnen."
 #, fuzzy, c-format
 msgstr "Kann Datei <%s> nicht erzeugen"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Kann die Rasterreihe %i nicht schreiben."
 #, fuzzy, c-format
 msgstr "Kann Datenbank '%s' mit Treiber <%s>nicht öffnen"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Kann Datei head nicht lesen"
 #, fuzzy, c-format
 msgstr "Fehler beim Schreiben des spatial index aufgetreten "
 #, fuzzy, c-format
 msgstr "Kann Datei %s in %s nicht öffnen"
@@ -4120,7 +4120,7 @@
 msgstr "Kann keinen Rendering Kontext erzeugen."
 msgstr "Kann neues Licht nicht definieren."
@@ -4524,6 +4524,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4821,7 +4835,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_el.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_el\n"
 "PO-Revision-Date: 2008-10-16 11:25+0300\n"
 "Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
 "Language-Team: Báóßëåéïò Áíôùíßïõ <grass-translations at lists.osgeo.org>\n"
@@ -376,73 +376,73 @@
 msgstr "Áäõíáìßá åíôïðéóìïý óõìâüëïõ <%s>"
 msgstr "Áäõíáìßá öüñôùóçò âéâëéïèÞêçò GDAL "
 #, fuzzy
 msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
 #, fuzzy, c-format
 msgstr "ËÜèïò üíïìá äéáíõóìáôéêïý ÷Üñôç <%s>"
 #, fuzzy, c-format
 msgstr "Áäõíáìßá áíïßãìáôïò <%s>"
 #, fuzzy, c-format
 msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Áäõíáìßá åããñáöÞò ãñáììÞ raster %i"
 #, fuzzy, c-format
 msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Áäõíáìßá focus"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Áäõíáìßá áíÜãíùóçò head áñ÷åßïõ"
 #, fuzzy, c-format
 msgstr "ÓöÜëìá åããñáöÞò ÷ùñéêþí äåäïìÝíùí óôï áñ÷åßï"
 #, fuzzy, c-format
 msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ %s óôï <%s>"
@@ -4141,7 +4141,7 @@
 msgstr "Áäõíáìßá äçìéïõñãßáò rendering"
 msgstr "Áäõíáìßá åýñåóçò íÝïõ öùôüò"
@@ -4545,6 +4545,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4843,7 +4857,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_es.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -14,7 +14,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_es\n"
 "PO-Revision-Date: 2011-04-15 14:03+0100\n"
 "Last-Translator: Joana Palahí <joana at sigte.udg.edu>\n"
 "Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -394,74 +394,74 @@
 msgstr "No es posible localizar el símbolo <%s>."
 msgstr "No ha sido posible cargar la librería GDAL."
 #, fuzzy
 msgstr "No se puede abrir el archivo %s "
 #, fuzzy, c-format
 msgstr "El nombre del mapa vectorial <%s> no es válido"
 #, fuzzy, c-format
 msgstr "No se puede abrir <%s>"
 #, fuzzy, c-format
 msgstr "No se puede crear la tabla <%s>"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "No se puede escribir la fila ráster. %i"
 #, fuzzy, c-format
 msgstr "No se puede abrir la base de datos <%s> con el controlador <%s>"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "No es posible establecer el foco."
 #, fuzzy
 #, fuzzy, c-format
 msgstr "No se puede leer el archivo de cabecera"
 #, fuzzy, c-format
 msgstr "Error al escribir el archivo de índices espaciales"
 #, fuzzy, c-format
 msgstr "No se puede abrir el archivo %s en <%s>"
@@ -4306,7 +4306,7 @@
 msgstr "No ha sido posible crear un contexto de creación de la visualización."
 msgstr "No ha sido posible definir una nueva fuente de luz."
@@ -4721,6 +4721,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -5019,7 +5033,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_fr.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_fr\n"
 "PO-Revision-Date: 2008-07-19 22:40+0100\n"
 "Last-Translator: Pascal Obstétar <pascal.obstetar at wanadoo.fr>\n"
 "Language-Team: French <grass-translations at lists.osgeo.org>\n"
 msgstr "Impossible de supprimer la table <%s>"
 #, fuzzy
 msgstr "Allocation mémoire impossible\n"
 #, fuzzy
 msgstr "Impossible d'ouvrir le fichier %s"
 #, fuzzy, c-format
 msgstr "Format invalide\n"
 #, fuzzy, c-format
 msgstr "Impossible d'ouvrir la base de données <%s> avec le driver <%s>"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Impossible d'écrire la ligne matricielle %i"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Impossible de deviner le format site!"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Impossible de lire le fichier d'en-tête"
 #, fuzzy, c-format
 msgstr "Erreur lors de l'écriture du fichier d'index spatial."
 #, fuzzy, c-format
@@ -4239,7 +4239,7 @@
 msgstr "Impossible de créer un nouveau processus"
 #, fuzzy
 msgstr "Impossible d'ouvrir le fichier %s dans %s"
@@ -4645,6 +4645,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4942,7 +4956,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_hi.po
--- grass/trunk/locale/po/grasslibs_hi.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_hi.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_hi\n"
 "PO-Revision-Date: 2005-12-22 14:34+0100\n"
 "Last-Translator: Markus Neteler <neteler at itc.it>\n"
 "Language-Team: Hindi <grass-translations at lists.osgeo.org>\n"
 msgstr "का"
 #, fuzzy
 msgstr "के लिए"
 #, fuzzy
 msgstr "का"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, fuzzy, c-format
 msgstr "का"
 #, fuzzy, c-format
 msgstr "का"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "a"
 #, fuzzy, c-format
 msgstr "के लिए"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "का"
 #, fuzzy
 msgstr "का"
 #, fuzzy, c-format
 msgstr "के लिए n"
 #, fuzzy, c-format
 msgstr "त्रुटि n"
 #, fuzzy, c-format
 msgstr "का"
@@ -4124,7 +4124,7 @@
 msgstr "a"
 #, fuzzy
 msgstr "का"
@@ -4476,6 +4476,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 msgid "WARNING"
 msgstr ""
@@ -4764,7 +4778,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_it.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_it\n"
 "PO-Revision-Date: 2011-03-22 00:52+0100\n"
 "Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -382,73 +382,73 @@
 msgstr "Impossibile trovare il simbolo <%s>"
 msgstr "Impossibile caricare le librerie GDAL"
 #, fuzzy
 msgstr "Impossibile aprire il file %s in %s"
 #, fuzzy, c-format
 msgstr "impossibile cambiare la directory %s"
 #, fuzzy, c-format
 msgstr "Impossibile aprire %s"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "impossibile creare un nuovo processo"
 #, fuzzy, c-format
 msgstr "Non posso scrivere i collegamenti del database"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Non riesco ad aprire il file temp"
 #, fuzzy, c-format
 msgstr "Errore nella scrittura del file dell'indice spaziale.\n"
 #, fuzzy, c-format
@@ -4083,7 +4083,7 @@
 msgstr ""
 msgstr "Impossibile definire un nuova luce"
@@ -4433,6 +4433,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4730,7 +4744,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_ja.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ja\n"
 "PO-Revision-Date: 2010-09-08 17:33+0100\n"
 "Last-Translator: Akira Taniguchi <taniguti at apptec.co.jp>\n"
 "Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -368,73 +368,73 @@
 msgstr "シンボルを検索できません <%s>"
 msgstr "GDALライブラリを読み込めません"
 #, fuzzy
 msgstr "���"
 #, fuzzy, c-format
 msgstr "����� ���� ���\n"
 #, fuzzy, c-format
 msgstr "���"
 #, fuzzy, c-format
 msgstr "���"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "�������: ����� �����������n"
 #, fuzzy, c-format
 msgstr "���"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "���"
 #, fuzzy
 msgstr "���"
 #, fuzzy, c-format
 msgstr "���"
 #, fuzzy, c-format
 msgstr "���"
 #, fuzzy, c-format
 msgstr "���"
@@ -4086,7 +4086,7 @@
 msgstr "レンダリングコンテキストを作成できません"
 msgstr "新しいライトを定義できません"
@@ -4490,6 +4490,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4787,7 +4801,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_ko.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ko\n"
 "PO-Revision-Date: 2005-12-22 14:49+0100\n"
 "Last-Translator: Huidae Cho\n"
 "Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -360,74 +360,74 @@
 msgstr "Datum %s 테이블파일을 열 수 없습니다"
 #, fuzzy
 msgstr "임시파일을 열 수 없습니다"
 #, fuzzy
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "자동 MASK파일을 열 수 없습니다"
 #, fuzzy, c-format
 msgstr "'%s' 디버그파일을 열 수 없습니다"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -4006,7 +4006,7 @@
 #, fuzzy
@@ -4358,6 +4358,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 msgid "WARNING"
 msgstr ""
@@ -4640,7 +4654,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_lv.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_lv\n"
 "PO-Revision-Date: 2006-12-09 01:00+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian <grass-translations at lists.osgeo.org>\n"
@@ -376,74 +376,74 @@
 msgstr "Neiespējami atvērt failu %s iekš %s"
 #, fuzzy
 msgstr "Nevar atvērt topo failu rakstīšanai: %s\n"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "neispējami mainīt direktoriju uz %s"
 #, fuzzy, c-format
 msgstr "Neisespējami atvērt %s"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "neiespējami rakstīt quant failu!"
 #, fuzzy, c-format
 msgstr "Nevar atvērt datubāzi %s"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Nevar atvērt 'temp'/pagaidu failu"
 #, fuzzy, c-format
 msgstr "Kļūdu rakstīšana ārpus telpisko datu index faila.\n"
 #, fuzzy, c-format
@@ -4155,7 +4155,7 @@
 msgstr "neiespējami izveidot jaunu procesu"
 #, fuzzy
@@ -4516,6 +4516,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4813,7 +4827,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ml.po
--- grass/trunk/locale/po/grasslibs_ml.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_ml.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ml\n"
 "PO-Revision-Date: 2010-08-24 11:31+0530\n"
 "Last-Translator: Mohammed Rashad <rashadkm at gmail.com>\n"
 "Language-Team: GRASS Malayalam Translation Team <rashadkm at gmail.com>\n"
@@ -359,73 +359,73 @@
 msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "ഫയൽ തുറക്കൻ പറ്റുന്നില്ല %s"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "ഡേറ്റാബേയ്സ് <%s> തുറക്കൻ പറ്റുന്നില്ല <%s>"
 #, fuzzy, c-format
 msgstr "ടേബിൾ ഉണ്ടാക്കാൻ പറ്റുന്നില്ല <%s>"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "ഡ്രയ്വ്വർ തുടങ്ങാൻ സാധിക്കുന്നില്ല <%s>"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "വെക്റ്റർ മാപ്പ് വായിക്കാൻ പട്ടുന്നില്ല"
 #, fuzzy
 msgstr "വെക്റ്റർ അടയ്ക്കാൻ പറ്റുന്നില്ല <%s>"
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
@@ -3957,7 +3957,7 @@
 msgstr ""
 msgstr ""
@@ -4307,6 +4307,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 msgid "WARNING"
 msgstr ""
@@ -4588,7 +4602,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_mr.po
--- grass/trunk/locale/po/grasslibs_mr.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_mr.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: Grass 6.0\n"
 "PO-Revision-Date: 2005-06-02 18:00+0530\n"
 "Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
 "Language-Team: Marathi <www.janabhaaratii.org.in>\n"
 msgstr "%s उघडता आले नाही"
 #, fuzzy
 msgstr "temp फाइल उघडता आली नाही"
 #, fuzzy
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -4004,7 +4004,7 @@
 #, fuzzy
@@ -4356,6 +4356,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4641,7 +4655,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_pl.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pl\n"
 "PO-Revision-Date: 2010-09-17 23:56+0100\n"
 "Last-Translator: Maciej Sieczka <msieczka at msieczka dot org>\n"
 "Language-Team: GRASS Translation Team\n"
@@ -372,71 +372,71 @@
 msgstr "Nie znaleziono symbolu <%s>"
 msgstr "Nie można załadować biblioteki GDAL"
 msgstr "Nie można otworzyć pliku GDAL"
 #, c-format
 msgstr "Niedozwolony typ mapy <%d>"
 #, fuzzy, c-format
 msgstr "Nie można otworzyć <%s>"
 #, fuzzy, c-format
 msgstr "Nie można utworzyć tabeli: [%s]"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Nie można odczytać rzędu rastra %i"
 #, fuzzy, c-format
 msgstr "Nie można utworzyć nowego procesu"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Nie można odczytać mapy wektorowej "
 msgstr "Nie można ustawić projekcji"
 #, fuzzy, c-format
 msgstr "Nie można odczytać nagłówka pliku"
 #, fuzzy, c-format
 msgstr "Błąd podczas zapisu pliku topo"
 #, fuzzy, c-format
 msgstr "W %s nie można otworzyć pliku %s"
@@ -4087,7 +4087,7 @@
 msgstr "Nie można utworzyć kontekstu renderowania"
 msgstr "Nie można zdefiniować nowego światła"
@@ -4489,6 +4489,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4774,7 +4788,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_pt.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pt\n"
 "PO-Revision-Date: 2007-06-18 22:26-0300\n"
 "Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail dot com>\n"
 "Language-Team: Portuguese <grass-translations at lists.osgeo.org>\n"
 msgstr "Impossível abrir arquivo %s"
 #, fuzzy
 msgstr "Impossível adicionar arco"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Impossível mudar de diretório para %s"
 #, fuzzy, c-format
 msgstr "não consegui abrir [%s]"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Impossível abrir base de dados <%s> com driver <%s>"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Impossível ler arquivo de cabeçalho"
 #, fuzzy, c-format
 msgstr "Erro de escrita no arquivo de índices espaciais."
 #, fuzzy, c-format
 msgstr "não foi possível abrir o arquivo %s em %s"
@@ -4122,7 +4122,7 @@
 msgstr "Impossível criar novo processo"
 #, fuzzy
@@ -4486,6 +4486,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4783,7 +4797,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_pt_br\n"
 "PO-Revision-Date: 2007-05-20 10:44-0300\n"
 "Last-Translator: Paulo E. P. Marcondes <paulomarcondes at gmail.com>\n"
 "Language-Team: Brazilian Portuguese <grass-translations at lists.osgeo.org>\n"
 #, fuzzy
 msgstr "não consegui calcular centróide para área %d"
 #, fuzzy
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "não consegui criar novo processo"
 #, fuzzy, c-format
 msgstr "não consegui abrir banco de dados %s"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "não consegui abrir arquivo temporário"
 #, fuzzy, c-format
 msgstr "Erro de escrita no arquivo de índices espaciais.\n"
 #, fuzzy, c-format
@@ -4131,7 +4131,7 @@
 #, fuzzy
@@ -4492,6 +4492,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4789,7 +4803,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_ru.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_ru\n"
 "PO-Revision-Date: 2009-01-27 22:58-0600\n"
 "Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
 "Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
 msgstr "Невозможно найти символ <%s>"
 msgstr "Невозможно загрузить библиотеку GDAL"
 #, fuzzy
 msgstr "Невозможно открыть файл %s"
 #, fuzzy, c-format
 msgstr "Неправильное имя векторного слоя <%s>"
 #, fuzzy, c-format
 msgstr "Невозможно открыть <%s>"
 #, fuzzy, c-format
 msgstr "Невозможно создать таблицу <%s>"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "Невозможно записать строку растра %i"
 #, fuzzy, c-format
 msgstr "Невозможно открыть БД <%s> с помощью драйвера <%s>"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Невозможно установить фокус"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Не могу открыть файл заголовка"
 #, fuzzy, c-format
 msgstr "Ошибка записи файл пространственного индекса"
 #, fuzzy, c-format
 msgstr "Невозможно открыть файл %s в <%s>"
@@ -4114,7 +4114,7 @@
 msgstr "Невозможно создать контекст отрисовки"
 msgstr "Невозможно установить новый источник света"
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_sl.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_sl\n"
 "PO-Revision-Date: 2005-04-26 09:38+0200\n"
 "Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
 "Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
@@ -372,74 +372,74 @@
 msgstr "Nezmo¾en odpreti datoteko %s v %s"
 #, fuzzy
 msgstr "Ne morem odpreti datoteke topo za pisanje: %s\n"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "ne morem spremeniti direktorija v %s"
 #, fuzzy, c-format
 msgstr "Ne morem odpreti %s"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "ne morem ustvariti novega procesa"
 #, fuzzy, c-format
 msgstr "Ne morem zapisati povezav z bazo podatkov."
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Ne morem odpreti temp datoteke"
 #, fuzzy, c-format
 msgstr "Napaka pri pisanju datoteke sidx.\n"
 #, fuzzy, c-format
@@ -4152,7 +4152,7 @@
 #, fuzzy
@@ -4513,6 +4513,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4810,7 +4824,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_th.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_th\n"
 "PO-Revision-Date: 2008-01-05 15:19+0700\n"
 "Last-Translator: man <mansv68 at yahoo.co.th>\n"
 "Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -371,74 +371,74 @@
 msgstr "ไม่สามารถลบตารางได้ <%s>"
 #, fuzzy
 msgstr "ไม่สามารถเพิ่ม network arc"
 #, fuzzy
 msgstr "ไม่สามารถเปิดไฟล์ %s ได้"
 #, fuzzy, c-format
 msgstr "ไม่สามารถอ่านข้อมูลแผนที่เชิงเส้นได้ <%s%s>"
 #, fuzzy, c-format
 msgstr "ไม่สามารถเปิดได้ %s"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "ไม่สามารถแถวของแผนที่เชิงภาพ %i"
 #, fuzzy, c-format
 msgstr "ไม่สามารถเปิดตาราง <%s> ด้วยตัวขับ <%s>"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "ไม่สามารถอ่าน ส่วนหัวของไฟล์ได้"
 #, fuzzy, c-format
 msgstr "เกิดข้อผิดพลาดขณะเขียน spatial index ไฟล์ "
 #, fuzzy, c-format
 msgstr "ไม่สามารถเปิดไฟล์ได้ %s ใน %s"
@@ -4105,7 +4105,7 @@
 msgstr "ไม่สามารถสร้างการทำงานใหม่ได้"
 #, fuzzy
 msgstr "ไม่สามารถลบไฟล์  '%s'"
@@ -4511,6 +4511,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4808,7 +4822,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_tr.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_tr\n"
 "PO-Revision-Date: 2010-11-08 15:14+0200\n"
 "Last-Translator: Saban Safak <ssafak at cvm.com.tr>\n"
 "Language-Team: Türkçe <grass-translations at lists.osgeo.org>\n"
@@ -365,73 +365,73 @@
 msgstr "<%s> simgesi yüklenemedi"
 msgstr "GDAL kütüphanesi yüklenemedi"
 #, fuzzy
 msgstr "Geçici dosya açılamıyor"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "<%s> açılamıyor"
 #, fuzzy, c-format
 msgstr "<%s> tablosu oluşturulamıyor"
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "%i raster satırı yazılamıyor"
 #, fuzzy, c-format
 msgstr "<%s>  veritabanı <%s> sürücüsüyle açılamıyor"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "Vektör harita okunamıyor"
 #, fuzzy
 msgstr "<%s> vektörü kapatılamıyor"
 #, fuzzy, c-format
 msgstr "Üstbilgi dosyası okunamıyor"
 #, fuzzy, c-format
 msgstr "Konumsal indek dosyasını yazmada hata"
 #, fuzzy, c-format
 msgstr "%s içindeki <%s> dosyası açılamadı"
@@ -4038,7 +4038,7 @@
 msgstr ""
 msgstr ""
@@ -4388,6 +4388,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4684,7 +4698,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_vi.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_vi\n"
 "PO-Revision-Date: 2010-08-27 11:18+0700\n"
 "Language-Team: American English <kde-i18n-doc at kde.org>\n"
@@ -372,73 +372,73 @@
 msgstr "Không thể định vị biểu tượng <%s>"
 msgstr "Không thể nạp thư viện GDAL"
 #, fuzzy
 msgstr "Không thể mở tập tin %s trong %s"
 #, fuzzy, c-format
 msgstr "không thể đổi thư mục đến %s"
 #, fuzzy, c-format
 msgstr "không thể mở %s"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "không thể tập tin quant!"
 #, fuzzy, c-format
 msgstr "Không thể mở CSDL"
 #, c-format
 msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy, c-format
 msgstr "Không thể mở tập tin tạm"
 #, fuzzy, c-format
 msgstr "Lỗi khi đang ghi tập tin chỉ mục không gian.\n"
 #, fuzzy, c-format
@@ -4117,7 +4117,7 @@
 msgstr "Không thể tạo ngữ cảnh kết xuất"
 msgstr "Không thể định nghĩa nguồn sáng mới"
@@ -4521,6 +4521,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4818,7 +4832,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasslibs_zh.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grasslibs_zh\n"
 "PO-Revision-Date: 2007-12-13 16:42+0100\n"
 "Last-Translator: Su Yongheng <night2008 at gmail.com>\n"
 "Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
 msgstr "无法打开文件 %s 在 %s 中"
 #, fuzzy
 msgstr "无法为区域 %d 计算质心"
 #, fuzzy
 #, fuzzy, c-format
 msgstr "无法将目录改变到%s"
 #, fuzzy, c-format
 msgstr "无法打开%s"
 #, fuzzy, c-format
 #, c-format
 msgid ""
 msgstr ""
 #, fuzzy
 msgstr "不能创建新进程"
 #, fuzzy, c-format
 msgstr "无法打开数据库 %s"
 #, c-format
 msgstr ""
 #, fuzzy
 msgstr "无法打开%s"
 #, fuzzy
 msgstr "无法打开%s"
 #, fuzzy, c-format
 msgstr "无法打开临时文件"
 #, fuzzy, c-format
 msgstr "写空间索引文件时出错。\n"
 #, fuzzy, c-format
@@ -4126,7 +4126,7 @@
 msgstr "不能创建新进程"
 #, fuzzy
@@ -4533,6 +4533,20 @@
 msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
 #, fuzzy
 msgid "WARNING"
@@ -4822,7 +4836,7 @@
 msgstr ""
 #, python-format
 msgstr ""
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_ar.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
@@ -258,13 +258,14 @@
 #: ../raster3d/r3.in.ascii/main.c:242 ../raster/r.in.poly/main.c:30
 #: ../raster/r.in.gdal/main.c:82 ../raster/r.in.bin/main.c:236
 #: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.png/main.c:522
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.external/main.c:524
-#: ../raster/r.in.ascii/main.c:70 ../raster/r.in.mat/main.c:92
-#: ../raster/r.in.arc/main.c:61 ../vector/v.in.ogr/main.c:106
-#: ../vector/v.in.db/main.c:53 ../vector/v.in.sites/main.c:58
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.convert/main.c:37 ../vector/v.in.lidar/main.c:148
-#: ../vector/v.in.ascii/main.c:49 ../vector/v.external/main.c:49
+#: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:161
+#: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
+#: ../raster/r.in.mat/main.c:92 ../raster/r.in.arc/main.c:61
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
+#: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
+#: ../vector/v.in.lidar/main.c:154 ../vector/v.in.ascii/main.c:49
+#: ../vector/v.external/main.c:49
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:3
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:3
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
@@ -367,18 +368,18 @@
 #: ../raster/r.info/main.c:70 ../raster/r.surf.area/main.c:88
 #: ../raster/r.surf.fractal/main.c:38 ../raster/r.covar/main.c:51
 #: ../raster/r.statistics3/main.c:389 ../raster/r.rescale/main.c:48
-#: ../raster/r.solute.transport/main.c:229 ../raster/r.proj/main.c:146
-#: ../raster/r.out.mpeg/main.c:102 ../raster/r.fill.dir/main.c:85
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.univar/r.univar_main.c:96
-#: ../raster/r.cross/main.c:73 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.category/main.c:52 ../raster/r.clump/main.c:46
-#: ../raster/r.out.tiff/main.c:91 ../raster/r.in.xyz/main.c:160
-#: ../raster/r.texture/main.c:75 ../raster/r.surf.random/main.c:36
-#: ../raster/r.out.arc/main.c:60 ../raster/r.surf.contour/main.c:60
-#: ../raster/r.colors/main.c:168 ../raster/r.statistics/main.c:55
-#: ../raster/r.li/r.li.padcv/padcv.c:39 ../raster/r.li/r.li.mpa/mpa.c:41
-#: ../raster/r.li/r.li.patchnum/main.c:36 ../raster/r.li/r.li.mps/mps.c:42
-#: ../raster/r.li/r.li.pielou/pielou.c:58
+#: ../raster/r.solute.transport/main.c:229 ../raster/r.in.lidar/main.c:161
+#: ../raster/r.proj/main.c:146 ../raster/r.out.mpeg/main.c:102
+#: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.univar/r.univar_main.c:96 ../raster/r.cross/main.c:73
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
+#: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
+#: ../raster/r.surf.contour/main.c:60 ../raster/r.colors/main.c:168
+#: ../raster/r.statistics/main.c:55 ../raster/r.li/r.li.padcv/padcv.c:39
+#: ../raster/r.li/r.li.mpa/mpa.c:41 ../raster/r.li/r.li.patchnum/main.c:36
+#: ../raster/r.li/r.li.mps/mps.c:42 ../raster/r.li/r.li.pielou/pielou.c:58
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:40
 #: ../raster/r.li/r.li.cwed/cwed.c:48 ../raster/r.li/r.li.padsd/padsd.c:39
 #: ../raster/r.li/r.li.richness/richness.c:41
@@ -433,6 +434,7 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:2
 #: ../locale/scriptstrings/r.grow_to_translate.c:2
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:2
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:2
@@ -1665,7 +1667,8 @@
 msgid "Illegal east coordinate <%s>, skipping."
 msgstr "!تم تحديد إحداثى شمال فارغ"
-#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.lidar/main.c:591
+#: ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr ""
@@ -1720,7 +1723,7 @@
 #: ../vector/v.what/main.c:54 ../vector/v.transform/main.c:82
 #: ../vector/v.overlay/main.c:58 ../vector/v.class/main.c:44
 #: ../vector/v.build.polylines/main.c:113 ../vector/v.convert/main.c:36
-#: ../vector/v.in.lidar/main.c:147 ../vector/v.net.flow/main.c:58
+#: ../vector/v.in.lidar/main.c:153 ../vector/v.net.flow/main.c:58
 #: ../vector/v.segment/main.c:54 ../vector/v.normal/main.c:74
 #: ../vector/v.net.path/main.c:40 ../vector/v.univar/main.c:63
 #: ../vector/v.label/main.c:59 ../vector/v.to.rast/main.c:40
@@ -1845,7 +1848,7 @@
 #: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:462
-#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:565
+#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:596
 #: ../vector/v.net.flow/main.c:170 ../vector/v.net.path/path.c:109
 #: ../vector/v.to.points/main.c:293 ../vector/v.surf.rst/main.c:579
 #: ../vector/v.net.centrality/main.c:242 ../vector/v.net.components/main.c:149
@@ -1856,7 +1859,7 @@
 #: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:796
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
-#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:570
+#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:601
 #: ../vector/v.to.points/main.c:298 ../vector/v.in.ascii/main.c:504
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
@@ -1868,7 +1871,7 @@
 #: ../vector/v.random/main.c:199 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:472
-#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:576
+#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:607
 #: ../vector/v.to.points/main.c:304 ../vector/v.in.ascii/main.c:394
 #, fuzzy, c-format
 msgid "Unable to grant privileges on table <%s>"
@@ -2351,7 +2354,7 @@
 msgstr "تكلفة للخلايا المنعدمة والتى فى الأساس غير مشمولة"
 #: ../raster/r.walk/main.c:274 ../raster/r.cost/main.c:229
-#: ../raster/r.in.xyz/main.c:238
+#: ../raster/r.in.lidar/main.c:211 ../raster/r.in.xyz/main.c:238
 msgid "Percent of map to keep in memory"
 msgstr "النسبة من الخريطة للحفظ بالذاكرة"
@@ -2585,7 +2588,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:181
-#: ../vector/v.in.lidar/main.c:172
+#: ../vector/v.in.lidar/main.c:178
 msgid "Name for new location to create"
 msgstr "اسم المقع الجديد"
@@ -2594,7 +2597,7 @@
 msgstr "تغلب على الإسقاط مستخدما إسقاط الموقع"
 #: ../raster/r.in.gdal/main.c:144 ../raster/r.external/main.c:562
-#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:199
+#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:213
 msgid "Extend location extents based on new dataset"
 msgstr "مد حدود الموقع معتمدا على مجموعة البيانات الجديدة"
@@ -2662,14 +2665,14 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:335 ../vector/v.in.ogr/main.c:480
-#: ../vector/v.in.lidar/main.c:320
+#: ../vector/v.in.lidar/main.c:351
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:341 ../vector/v.in.ogr/main.c:486
-#: ../vector/v.in.lidar/main.c:326
+#: ../vector/v.in.lidar/main.c:357
 #, fuzzy, c-format
 msgid "Location <%s> created"
 msgstr "%s لم يمكن فتح "
@@ -2680,14 +2683,16 @@
 "for checking"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:370 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:516 ../vector/v.in.lidar/main.c:359
+#: ../raster/r.in.gdal/main.c:370 ../raster/r.in.lidar/main.c:296
+#: ../raster/r.external/main.c:105 ../vector/v.in.ogr/main.c:516
+#: ../vector/v.in.lidar/main.c:390
 #, fuzzy
 msgid "Over-riding projection check"
 msgstr "طباعة نوع الملف الراسترى فقط"
-#: ../raster/r.in.gdal/main.c:381 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:525 ../vector/v.in.lidar/main.c:368
+#: ../raster/r.in.gdal/main.c:381 ../raster/r.in.lidar/main.c:305
+#: ../raster/r.external/main.c:113 ../vector/v.in.ogr/main.c:525
+#: ../vector/v.in.lidar/main.c:399
 #, fuzzy
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
@@ -2703,9 +2708,10 @@
 msgid "Dataset PROJ_INFO is:\n"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:424 ../raster/r.external/main.c:156
+#: ../raster/r.in.gdal/main.c:424 ../raster/r.in.lidar/main.c:321
+#: ../raster/r.in.lidar/main.c:328 ../raster/r.external/main.c:156
 #: ../vector/v.in.ogr/main.c:541 ../vector/v.in.ogr/main.c:548
-#: ../vector/v.in.lidar/main.c:384 ../vector/v.in.lidar/main.c:391
+#: ../vector/v.in.lidar/main.c:415 ../vector/v.in.lidar/main.c:422
 #, fuzzy
 msgid "Import dataset PROJ_INFO is:\n"
@@ -2723,8 +2729,9 @@
 "'location' parameter.\n"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:454 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:599 ../vector/v.in.lidar/main.c:442
+#: ../raster/r.in.gdal/main.c:454 ../raster/r.in.lidar/main.c:379
+#: ../raster/r.external/main.c:186 ../vector/v.in.ogr/main.c:599
+#: ../vector/v.in.lidar/main.c:473
 #, fuzzy
 msgid "Projection of input dataset and current location appear to match"
 msgstr "إعادة توقيع خريطة راسترية من مكان إلى المكان الحالى"
@@ -6799,7 +6806,7 @@
 msgid "SECTION 1a (of %1d): Initiating Memory."
 msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:296
+#: ../raster/r.watershed/ram/init_vars.c:300
 #, c-format
 msgid "SECTION 1b (of %1d): Determining Offmap Flow."
 msgstr ""
@@ -7738,6 +7745,152 @@
 msgid "Could not create and solve the linear equation system"
 msgstr "اسم الخريطة الراسترية"
+#: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:162
+#: ../vector/v.surf.bspline/main.c:93
+#: ../vector/v.lidar.edgedetection/main.c:73
+#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
+msgid "LIDAR"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:165
+msgid "Create a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:169
+#, fuzzy
+msgid "LiDAR LAS input file"
+msgstr "ملف المدخل"
+#: ../raster/r.in.lidar/main.c:177 ../raster/r.in.xyz/main.c:176
+#, fuzzy
+msgid "Statistic to use for raster values"
+msgstr "تقرير الإحصائيات للخرائط الراسترية"
+#: ../raster/r.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:221
+#: ../raster/r.in.lidar/main.c:230 ../raster/r.in.xyz/main.c:180
+#: ../raster/r.in.xyz/main.c:248 ../raster/r.in.xyz/main.c:257
+msgid "Statistic"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:189 ../raster/r.in.xyz/main.c:188
+#: ../raster/r.in.arc/main.c:81
+msgid "Storage type for resultant raster map"
+msgstr "نوع التخزين للخريطة الراسترية الناتجة "
+#: ../raster/r.in.lidar/main.c:196 ../raster/r.in.xyz/main.c:223
+#, fuzzy
+msgid "Filter range for z data (min,max)"
+msgstr "min,max :المدى الصحيح"
+#: ../raster/r.in.lidar/main.c:203 ../raster/r.in.xyz/main.c:230
+msgid "Scale to apply to z data"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:220 ../raster/r.in.xyz/main.c:247
+#, fuzzy
+msgid "pth percentile of the values"
+msgstr "طريقة تقرير الإنحدار"
+#: ../raster/r.in.lidar/main.c:229 ../raster/r.in.xyz/main.c:256
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:222
+#: ../vector/v.in.lidar/main.c:203
+#, fuzzy
+msgid "Override dataset projection (use location's projection)"
+msgstr "تغلب على الإسقاط مستخدما إسقاط الموقع"
+#: ../raster/r.in.lidar/main.c:239 ../raster/r.in.xyz/main.c:261
+msgid "Scan data file for extent then exit"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:266
+#, fuzzy
+msgid "In scan mode, print using shell script style"
+msgstr "طباعة الأحصاء فى صورة شل سكربت"
+#: ../raster/r.in.lidar/main.c:263 ../vector/v.in.lidar/main.c:238
+#, c-format
+msgid "Input file <%s> is not a LAS LiDAR point cloud"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:281 ../vector/v.in.ogr/main.c:501
+#: ../vector/v.in.lidar/main.c:372
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:311 ../vector/v.in.ogr/main.c:531
+#: ../vector/v.in.lidar/main.c:405
+#, fuzzy
+msgid "GRASS LOCATION PROJ_INFO is:\n"
+msgstr "%s لم يمكن فتح "
+#: ../raster/r.in.lidar/main.c:371 ../vector/v.in.ogr/main.c:591
+#: ../vector/v.in.lidar/main.c:465
+#, c-format
+msgid ""
+"\n"
+"You can use the -o flag to %s to override this projection check.\n"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:374 ../vector/v.in.ogr/main.c:594
+#: ../vector/v.in.lidar/main.c:468
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:391 ../raster/r.in.xyz/main.c:307
+#, fuzzy
+msgid "Invalid zrange"
+msgstr "%s:منطقة غير صالحة"
+#: ../raster/r.in.lidar/main.c:485 ../raster/r.in.xyz/main.c:394
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:497 ../raster/r.in.xyz/main.c:406
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:560 ../raster/r.in.xyz/main.c:488
+msgid "zrange will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:579 ../raster/r.in.xyz/main.c:524
+#, fuzzy
+msgid "Reading data ..."
+msgstr "التوقيع ..."
+#: ../raster/r.in.lidar/main.c:596
+#, fuzzy
+msgid "Could not rewind input file"
+msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
+#: ../raster/r.in.lidar/main.c:757 ../raster/r.in.xyz/main.c:721
+#, fuzzy
+msgid "Writing to map ..."
+msgstr "كتابة ملف جديد...\n"
+#: ../raster/r.in.lidar/main.c:1103 ../raster/r.in.xyz/main.c:1059
+#, fuzzy, c-format
+msgid "%lu points found in region."
+msgstr "%d نقاط تم تحميلها\n"
+#: ../raster/r.in.lidar/main.c:1127 ../raster/r.in.xyz/main.c:1086
+msgid "Scanning data ..."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:1178 ../raster/r.in.xyz/main.c:1174
+#, c-format
+msgid "Range:     min         max\n"
+msgstr ""
 #: ../raster/r.proj/main.c:147 ../general/g.proj/main.c:61
 #: ../general/g.setproj/main.c:79 ../vector/v.proj/main.c:64
 #: ../locale/scriptstrings/m.proj_to_translate.c:3
@@ -8621,12 +8774,6 @@
 msgid "Unable to open TIFF world file for writing"
 msgstr "[%s]لم يتم فتح ملف الخلية ل "
-#: ../raster/r.in.xyz/main.c:162 ../vector/v.surf.bspline/main.c:93
-#: ../vector/v.lidar.edgedetection/main.c:73
-#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
-msgid "LIDAR"
-msgstr ""
 #: ../raster/r.in.xyz/main.c:164
 msgid ""
 "Create a raster map from an assemblage of many coordinates using univariate "
@@ -8638,20 +8785,6 @@
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
 msgstr "الملف  الأسكى الراسترى المطلوب ادخاله"
-#: ../raster/r.in.xyz/main.c:176
-#, fuzzy
-msgid "Statistic to use for raster values"
-msgstr "تقرير الإحصائيات للخرائط الراسترية"
-#: ../raster/r.in.xyz/main.c:180 ../raster/r.in.xyz/main.c:248
-#: ../raster/r.in.xyz/main.c:257
-msgid "Statistic"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.arc/main.c:81
-msgid "Storage type for resultant raster map"
-msgstr "نوع التخزين للخريطة الراسترية الناتجة "
 #: ../raster/r.in.xyz/main.c:199
 msgid "Column number of x coordinates in input file (first column is 1)"
 msgstr ""
@@ -8664,35 +8797,6 @@
 msgid "Column number of data values in input file"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:223
-#, fuzzy
-msgid "Filter range for z data (min,max)"
-msgstr "min,max :المدى الصحيح"
-#: ../raster/r.in.xyz/main.c:230
-msgid "Scale to apply to z data"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:247
-#, fuzzy
-msgid "pth percentile of the values"
-msgstr "طريقة تقرير الإنحدار"
-#: ../raster/r.in.xyz/main.c:256
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:261
-msgid "Scan data file for extent then exit"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:266
-#, fuzzy
-msgid "In scan mode, print using shell script style"
-msgstr "طباعة الأحصاء فى صورة شل سكربت"
 #: ../raster/r.in.xyz/main.c:270
 msgid "Ignore broken lines"
 msgstr ""
@@ -8701,33 +8805,11 @@
 msgid "Please specify a reasonable column number."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:307
-#, fuzzy
-msgid "Invalid zrange"
-msgstr "%s:منطقة غير صالحة"
-#: ../raster/r.in.xyz/main.c:394
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:406
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
 #: ../raster/r.in.xyz/main.c:482
 msgid ""
 "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:488
-msgid "zrange will not be taken into account during scan"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:524
-#, fuzzy
-msgid "Reading data ..."
-msgstr "التوقيع ..."
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
 #: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
@@ -8756,25 +8838,6 @@
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:721
-#, fuzzy
-msgid "Writing to map ..."
-msgstr "كتابة ملف جديد...\n"
-#: ../raster/r.in.xyz/main.c:1059
-#, fuzzy, c-format
-msgid "%lu points found in region."
-msgstr "%d نقاط تم تحميلها\n"
-#: ../raster/r.in.xyz/main.c:1086
-msgid "Scanning data ..."
-msgstr ""
-#: ../raster/r.in.xyz/main.c:1174
-#, c-format
-msgid "Range:     min         max\n"
-msgstr ""
 #: ../raster/r.texture/main.c:79
 #, fuzzy
 msgid "Generate images with textural features from a raster map."
@@ -10925,7 +10988,7 @@
 #: ../raster/r.to.vect/main.c:97 ../raster/r.to.vect/main.c:104
 #: ../vector/v.in.ogr/main.c:192 ../vector/v.in.ogr/main.c:217
-#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:184
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:198
 #: ../vector/v.to.rast/main.c:74 ../vector/v.to.rast/main.c:80
 #: ../vector/v.to.rast/main.c:86
 #, fuzzy
@@ -10973,7 +11036,7 @@
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
 #: ../vector/v.in.ogr/main.c:927 ../vector/v.random/main.c:294
-#: ../vector/v.in.lidar/main.c:696
+#: ../vector/v.in.lidar/main.c:755
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "لم يمكن حشر صف جديد: %s"
@@ -17752,8 +17815,7 @@
 msgstr "لم يمكن اختيار البيانات من الجدول"
 #: ../vector/v.out.svg/main.c:370 ../vector/v.lrs/v.lrs.label/main.c:348
-#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.out.ogr/attrb.c:51
-#: ../vector/v.overlay/main.c:363
+#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.overlay/main.c:363
 #, fuzzy
 msgid "Unable to fetch data from table"
@@ -18254,17 +18316,17 @@
 "\t\tMapInfo File: mapinfo file name"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:163
+#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:169
 #, fuzzy
 msgid "Import subregion only"
 #: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:226
-#: ../vector/v.in.lidar/main.c:164 ../vector/v.in.lidar/main.c:193
+#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:207
 msgid "Subregion"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:166
+#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:172
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr ""
@@ -18321,18 +18383,13 @@
 #: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:79
 #: ../vector/v.voronoi/main.c:138 ../vector/v.overlay/main.c:123
-#: ../vector/v.in.lidar/main.c:183 ../vector/v.to.points/main.c:215
+#: ../vector/v.in.lidar/main.c:197 ../vector/v.to.points/main.c:215
 #, fuzzy
 msgid "Do not create attribute table"
 msgstr "عدم انشاء جدول الخواص"
-#: ../vector/v.in.ogr/main.c:222 ../vector/v.in.lidar/main.c:189
+#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:208
 #, fuzzy
-msgid "Override dataset projection (use location's projection)"
-msgstr "تغلب على الإسقاط مستخدما إسقاط الموقع"
-#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:194
-#, fuzzy
 msgid "Limit import to the current region"
 msgstr "استخدام المنطقة الحالية"
@@ -18340,7 +18397,7 @@
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:204
+#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:218
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
@@ -18360,12 +18417,12 @@
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:252
+#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:272
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "خريطة مخرجة حيث ستكتب النقاط"
-#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:255
+#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:275
 #: ../vector/v.edit/main.c:88
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists"
@@ -18376,38 +18433,14 @@
 msgid "Layer <%s> not available"
-#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:263
+#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:294
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:291
+#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:322
 msgid "4 parameters required for 'spatial' parameter"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:501 ../vector/v.in.lidar/main.c:341
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:531 ../vector/v.in.lidar/main.c:374
-#, fuzzy
-msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr "%s لم يمكن فتح "
-#: ../vector/v.in.ogr/main.c:591 ../vector/v.in.lidar/main.c:434
-#, c-format
-msgid ""
-"\n"
-"You can use the -o flag to %s to override this projection check.\n"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:594 ../vector/v.in.lidar/main.c:437
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
 #: ../vector/v.in.ogr/main.c:617
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
@@ -18445,7 +18478,7 @@
 msgid "Column type not supported (%s)"
 msgstr "نوع العمود غير مدعم"
-#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:558
+#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:589
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "%s بالمشغل %s لم يمكن فتح قاعدة البيانات"
@@ -18497,27 +18530,27 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1017
+#, fuzzy
+msgid "Merge boundaries:"
+msgstr "وصل الفئات...\n"
+#: ../vector/v.in.ogr/main.c:1022
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1021
+#: ../vector/v.in.ogr/main.c:1026
 #, fuzzy
 msgid "Remove dangles:"
 msgstr "لم يتم حساب شبه مركز المساحة"
-#: ../vector/v.in.ogr/main.c:1027
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1031
+#: ../vector/v.in.ogr/main.c:1036
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1037
-#, fuzzy
-msgid "Merge boundaries:"
-msgstr "وصل الفئات...\n"
 #: ../vector/v.in.ogr/main.c:1055 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:607 ../vector/v.buffer/main.c:699
 msgid "Cannot calculate area centroid"
@@ -19439,7 +19472,7 @@
 msgstr ""
 #: ../vector/v.random/main.c:142 ../vector/v.in.dxf/main.c:80
-#: ../vector/v.in.lidar/main.c:209 ../vector/v.external/args.c:53
+#: ../vector/v.in.lidar/main.c:223 ../vector/v.external/args.c:53
 #: ../vector/v.edit/args.c:216
 msgid "Do not build topology"
 msgstr ""
@@ -21294,7 +21327,7 @@
 msgid "Cannot select attributes for cat = %d"
-#: ../vector/v.out.ogr/attrb.c:64
+#: ../vector/v.out.ogr/attrb.c:58
 #, fuzzy, c-format
 msgid "No database record for cat = %d and export of 'cat' disabled"
 msgstr "cat = %d لا يوجد تسجيل للخط"
@@ -23304,45 +23337,64 @@
 msgid "[%d] categories read into memory"
 msgstr "%-5d الفئات قرأت فى الذاكرة\n"
-#: ../vector/v.in.lidar/main.c:149
+#: ../vector/v.in.lidar/main.c:155
 #, fuzzy
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
 msgstr "ادخال ملف راسترى ثنائى كطبقة خريطة راسترية جراسية"
-#: ../vector/v.in.lidar/main.c:152
+#: ../vector/v.in.lidar/main.c:158
 #, fuzzy
 msgid "LAS input file"
 msgstr "ملف المدخل"
-#: ../vector/v.in.lidar/main.c:153
+#: ../vector/v.in.lidar/main.c:159
 msgid "LiDAR input files in LAS format (*.las or *.laz)"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:178
+#: ../vector/v.in.lidar/main.c:185
+msgid "Only import points of selected return type"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:186
 #, fuzzy
+msgid "If not specified, all points are imported"
+msgstr "ادخال القيم الصحيحة "
+#: ../vector/v.in.lidar/main.c:192
+#, fuzzy
 msgid "Print LAS file info and exit"
-#: ../vector/v.in.lidar/main.c:591
+#: ../vector/v.in.lidar/main.c:289
 #, fuzzy, c-format
+msgid "Unknown filter option <%s>"
+msgstr "نوع غير معروف"
+#: ../vector/v.in.lidar/main.c:623
+#, fuzzy, c-format
 msgid "Importing %d points..."
 msgstr "الخريطة الفيكتورية لنقاط البدء"
-#: ../vector/v.in.lidar/main.c:719
+#: ../vector/v.in.lidar/main.c:778
 #, fuzzy, c-format
 msgid "%d points imported"
-#: ../vector/v.in.lidar/main.c:721
+#: ../vector/v.in.lidar/main.c:780
 #, c-format
 msgid "%d input points were not valid"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:723
+#: ../vector/v.in.lidar/main.c:782
 #, fuzzy, c-format
 msgid "%d input points were outside of the selected area"
+#: ../vector/v.in.lidar/main.c:784
+#, fuzzy, c-format
+msgid "%d input points were filtered by return number"
 #: ../vector/v.net.flow/main.c:60
 msgid "flow"
 msgstr ""
@@ -29226,6 +29278,46 @@
 msgid "Uncompressed geonames file from (with .txt extension)"
 msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:1
+msgid "Download several tiles of MODIS products using pyModis"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:3
+#, fuzzy
+msgid "Name of MODIS product"
+msgstr "اسم الخريطة المدخلة"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:4
+msgid "Name of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:5
+msgid "Password of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:6
+msgid "Folder where saves the data, full path"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:7
+#, fuzzy
+msgid "The names of tile/s to download"
+msgstr "عدد النقاط المطلوب تخصيصها"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:8
+msgid "The day from start download. If not set the download starts from today"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:9
+msgid ""
+"The day to stop download. If not set the download stops 10 day before the "
+"start day"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:10
+msgid "For debug mode, it will write more info in the log file"
+msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
 msgid ""
 "Export a raster map to a text file as x,y,z values based on cell centers."
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_cs.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_cs\n"
 "PO-Revision-Date: 2010-03-07 15:38+0100\n"
@@ -260,13 +260,14 @@
@@ -366,18 +367,18 @@
@@ -432,6 +433,7 @@
@@ -1677,7 +1679,8 @@
 msgstr "Neplatná východní souøadnice <%s>"
 #, c-format
 msgstr "Prùchod #%d (z %d) ..."
@@ -1731,7 +1734,7 @@
@@ -1855,7 +1858,7 @@
@@ -1866,7 +1869,7 @@
 #, c-format
@@ -1878,7 +1881,7 @@
 #, c-format
@@ -2362,7 +2365,7 @@
 "vynechány"
 msgstr "Èást mapy v procentech, která má být uchována v pamìti"
@@ -2599,7 +2602,7 @@
 msgstr ""
 msgstr "Název nové location, která má být vytvoøena"
@@ -2608,7 +2611,7 @@
 msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
 msgstr "Hranice location se zvìt¹í podle nového datasetu"
@@ -2683,7 +2686,7 @@
 msgstr ""
 msgid ""
 "location."
@@ -2692,7 +2695,7 @@
 "novou location."
 #, c-format
 msgstr "Location <%s> vytvoøena"
@@ -2705,13 +2708,15 @@
 "Nelze pøevést informace o vstupní mapové projekci do formátu GRASSu (pro "
 "kontrolu)"
 msgstr "Pøeskakuji kontrolu projekce."
 msgid ""
 "\n"
@@ -2727,9 +2732,10 @@
 msgstr "PROJ_INFO datasetu je:\n"
 msgstr "iMPORT PROJ_INFO datasetu je:\n"
@@ -2750,8 +2756,9 @@
 "Zva¾te vytvoøení nové location s parametry 'location' ze vstupního "
 "datasetu.\n"
 msgstr "Mapová projekce vstupního datasetu a aktuální location souhlasí."
@@ -6868,7 +6875,7 @@
 msgstr "ÈÁST 1a (z %d1d): inicializace pamìti."
 #, c-format
 msgstr "ÈÁST 1b (z %1d): Urèuji odtok mimo mapu."
@@ -7894,6 +7901,154 @@
 msgstr "Nelze vytvoøit a vyøe¹it soustavu lineárních rovnic"
+msgid "LIDAR"
+msgstr ""
+#, fuzzy
+msgstr ""
+"Vytvoøí rastrovou mapu smontováním více souøadnic za pomoci univariantní "
+"statistiky"
+#, fuzzy
+msgstr "Vstup selhal"
+msgstr "Statistika pou¾itá pro rastrové hodnoty"
+msgid "Statistic"
+msgstr "Statistika"
+msgstr "Typ ulo¾ení výsledné rastrové mapy"
+msgstr "Rozsah filtru pro z data: (min,max)"
+msgstr "Nastavit na z data"
+msgstr "pth percentil hodnot"
+msgid ""
+"observations"
+msgstr ""
+"Vyøadit <trim> procent nejmen¹ích a <trim> procent nejvet¹ích hodnot "
+"pozorování"
+msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
+msgstr "Projdi soubor, nalezni okrajové hodnoty a ukonèi se"
+msgstr "Ve scan módu tiskni ve stylu pro shell skript"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+"Nelze pøevést informace o vstupní mapové projekci do formátu GRASSu (pro "
+"kontrolu)"
+msgstr "GRASS LOCATION PROJ_INFO  je:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Mù¾ete pou¾ít pøepínaè -o pro %s a pøeskoèit toto ovìøení.\n"
+msgid ""
+"set.\n"
+msgstr ""
+"Zva¾te vytvoøení nové location s parametry 'location' ze vstupního "
+"datasetu.\n"
+msgstr "Neplatné zrange"
+msgstr "Nelze vypoèítat percentil bez urèené volby pth!"
+msgstr "Nelze spoèítat trim prùmìr bez zadané volby trim!"
+msgstr "na rozsah z nebude bìhem hledání brán zøetel"
+msgstr "Ètu data... "
+#, fuzzy
+msgstr "Nelze otevøít výstupní soubor <%s>"
+msgstr "Zapisuji do vrstvy ..."
+#, c-format
+msgstr "%lu bodù nalezeno v regionu."
+msgstr "Prohledávání dat ..."
+#, c-format
+msgstr "Rozsah:     min         max\n"
@@ -8745,12 +8900,6 @@
 msgstr "Nelze otevøít soubor tfw pro zápis"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8763,19 +8912,6 @@
 msgstr "ASCII soubor obsahující vstupní data (\"-\" pro standardní vstup)"
-msgstr "Statistika pou¾itá pro rastrové hodnoty"
-msgid "Statistic"
-msgstr "Statistika"
-msgstr "Typ ulo¾ení výsledné rastrové mapy"
 msgstr ""
@@ -8790,34 +8926,6 @@
 msgstr "Èíslo sloupeèku hodnot bunìk ve vstupním souboru"
-msgstr "Rozsah filtru pro z data: (min,max)"
-msgstr "Nastavit na z data"
-msgstr "pth percentil hodnot"
-msgid ""
-"observations"
-msgstr ""
-"Vyøadit <trim> procent nejmen¹ích a <trim> procent nejvet¹ích hodnot "
-"pozorování"
-msgstr "Projdi soubor, nalezni okrajové hodnoty a ukonèi se"
-msgstr "Ve scan módu tiskni ve stylu pro shell skript"
 msgstr "Ignorovat zlomené linie"
@@ -8826,31 +8934,11 @@
 msgstr "Prosím, zadejte pøijatelné èíslo sloupce."
-msgstr "Neplatné zrange"
-msgstr "Nelze vypoèítat percentil bez urèené volby pth!"
-msgstr "Nelze spoèítat trim prùmìr bez zadané volby trim!"
 msgid ""
 msgstr "Pokud není vstupem soubor je mo¾né provést pouze jeden prùchod."
-msgstr "na rozsah z nebude bìhem hledání brán zøetel"
-msgstr "Ètu data... "
 #, c-format
@@ -8882,24 +8970,6 @@
 msgstr "©patná souøadnice z linie %lu sloupec %d <%s>"
-msgstr "Zapisuji do vrstvy ..."
-#, c-format
-msgstr "%lu bodù nalezeno v regionu."
-msgstr "Prohledávání dat ..."
-#, c-format
-msgstr "Rozsah:     min         max\n"
 msgstr "Vytvoøí obrázky s texturálními vlastnostmi rastrové mapy."
@@ -11041,7 +11111,7 @@
 msgid "Attributes"
@@ -11094,7 +11164,7 @@
 #, c-format
 msgstr "Nelze vlo¾it nový øádek: %s"
@@ -18000,8 +18070,7 @@
 msgstr "Nelze vybrat atributy pro cat=%d"
 msgstr "Nelze vybrat data z tabulky"
@@ -18507,16 +18576,16 @@
 "\t\tESRI ShapeFile: název souboru ShapeFile\n"
 "\t\tSoubor MapInfo: název souboru MapInfo"
 msgstr "Importuj pouze subregion"
 msgid "Subregion"
 msgstr "Subegion"
 msgstr "Formát: xmin,ymin,xmax,ymax - obvykle Z,J,V,S"
@@ -18575,15 +18644,11 @@
 msgstr "Nevytváøet atributovou tabulku"
-msgstr "Pøepi¹ mapovou projekci (pou¾ij map. projekci location)"
 msgstr "Limit pøi importu do souèasného regionu"
@@ -18591,7 +18656,7 @@
 msgstr "Zmìnit mázev sloupce na malé písmo"
 msgid ""
@@ -18611,12 +18676,12 @@
 msgstr "Zdroj dat obsahuje %d vrstev:"
 #, c-format
 msgstr "Vektorová mapa '%s' ji¾ existuje a bude pøepsána."
 #, c-format
@@ -18627,43 +18692,14 @@
 msgstr "Vrstva <%s> není dostupná"
 msgstr "Vyberte souèasné nastavení regionu nebo prostorové volby, ne oboje"
 msgstr " 4 parametry vy¾adovány pro 'prostorový' parametr."
-msgid ""
-"checking"
-msgstr ""
-"Nelze pøevést informace o vstupní mapové projekci do formátu GRASSu (pro "
-"kontrolu)"
-msgstr "GRASS LOCATION PROJ_INFO  je:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"Mù¾ete pou¾ít pøepínaè -o pro %s a pøeskoèit toto ovìøení.\n"
-msgid ""
-"set.\n"
-msgstr ""
-"Zva¾te vytvoøení nové location s parametry 'location' ze vstupního "
-"datasetu.\n"
 #, fuzzy, c-format
@@ -18703,7 +18739,7 @@
 msgstr "Typ sloupce není podporován (%s)"
 #, c-format
 msgstr "Nelze otevøít databázi <%s> ovladaèem <%s>"
@@ -18754,27 +18790,27 @@
 msgstr "Vyèistit hranice na uzlech:"
+#, fuzzy
+msgstr "Zlomit hranice:"
 msgstr "Mìním hranice pøívìskù  na linie:"
 #, fuzzy
 msgstr "Mazání pøívìskù"
 msgstr "Mìním hranice mostù na linie:        "
 msgstr "Mazání mostù:"
-#, fuzzy
-msgstr "Zlomit hranice:"
@@ -19694,7 +19730,7 @@
 msgstr "Pou¾ij funkci drand48() místo rand()"
 msgstr "Nevytváøej topologii"
@@ -21559,7 +21595,7 @@
 msgstr "Nelze vybrat atributy pro cat= %d"
 #, c-format
 msgstr ""
@@ -23555,45 +23591,64 @@
 msgstr "[%d] kategorií naèteno do pamìti."
 #, fuzzy
 msgstr "Konvertuje vektorové vrstvy OGR na GRASS vektorové mapy."
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Celoèíselné hodnoty jsou importovány"
+#, fuzzy
 msgstr "Vypí¹e historii rastrové mapy namísto infa"
 #, fuzzy, c-format
+msgstr "Neznámá volba  pravidla: '%s'"
+#, fuzzy, c-format
 msgstr "Importuji body ..."
 #, fuzzy, c-format
 msgstr "%d bodù naèteno"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d bodù mimo práhovou hodnotu"
+#, fuzzy, c-format
+msgstr "%d bodù mimo práhovou hodnotu"
 msgid "flow"
 msgstr ""
@@ -29538,6 +29593,46 @@
 msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Název vstupní vrstvy"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Poèet bodù, které mají být rozmístìny"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_de.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_de\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2011-05-14 23:18+0100\n"
 "Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
@@ -259,13 +259,14 @@
@@ -364,18 +365,18 @@
@@ -430,6 +431,7 @@
@@ -1678,7 +1680,8 @@
 msgstr "Ungültige Ost-Koordinate <%s>, wird übersprungen."
 #, c-format
 msgstr "Durchlauf %d (von %d) ..."
@@ -1732,7 +1735,7 @@
@@ -1857,7 +1860,7 @@
 #, c-format
@@ -1880,7 +1883,7 @@
 #, c-format
@@ -2356,7 +2359,7 @@
 "ignoriert."
 msgstr "Prozentteil der Karte, der im Speicher gehalten werden soll."
@@ -2598,7 +2601,7 @@
 msgstr ""
 msgstr "Name der neu zu erstellenden Location."
@@ -2607,7 +2610,7 @@
 msgstr "Übersteuere die Projektion (verwende Projektion der Location)."
 msgstr "Vergrößere die Location basierend auf dem neuen Datensatz."
@@ -2686,7 +2689,7 @@
 "dieser Parameter ist für die weitere Berechnung empfehlenswert."
 msgid ""
 "location."
@@ -2695,7 +2698,7 @@
 "erstelle daher keine neue Location."
 #, c-format
 msgstr "Location <%s> erstellt."
@@ -2708,13 +2711,15 @@
 "Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format "
 "konvertieren, zwecks Überprüfung."
 msgstr "Übersteuere die Überprüfung der Projektion."
 msgid ""
 "\n"
@@ -2731,9 +2736,10 @@
 msgstr "Datensatz PROJ_INFO:\n"
 msgstr "Zu importierender Datensatz PROJ_INFO:\n"
@@ -2757,8 +2763,9 @@
 "des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu "
 "erzeugen.\n"
 msgstr ""
 "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
@@ -6938,7 +6945,7 @@
 msgstr "ABSCHNITT 1a (von %1d): Initiiere den Speicher."
 #, c-format
 msgstr "ABSCHNITT 1b (of %1d): Ermittle den Fluß aus der Karte heraus."
@@ -8005,6 +8012,158 @@
 msgstr "Kann das lineare Gleichungssystem nicht erzeugen und lösen."
+msgid "LIDAR"
+msgstr ""
+#, fuzzy
+msgstr ""
+"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
+"univariater Statistik."
+#, fuzzy
+msgstr "Eingabe fehlgeschlagen."
+msgstr "Statistik um Rasterwert zu bestimmen"
+msgid "Statistic"
+msgstr "Statistik"
+msgstr "Speichertyp der resultierenden Rasterkarte."
+msgstr "Filterbereich für z-Daten (min,max)."
+msgstr "Skalierungsfaktor für die z-Daten."
+msgstr "Perzentil der Werte"
+msgid ""
+"observations"
+msgstr ""
+"Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten "
+"Beobachtungen."
+msgstr ""
+"Übersteuere die Projektion des Datensatzes (verwende Projektion der "
+"Location)."
+msgstr ""
+"Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
+msgstr "Im Lesemodus Ausgabe im Shell-Skript-Stil."
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+"Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
+"konvertieren, zwecks Überprüfung."
+msgstr "GRASS LOCATION PROJ_INFO:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
+"übersteuern.\n"
+msgid ""
+"set.\n"
+msgstr ""
+"Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der "
+"Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
+msgstr "Ungültige z-Spanne."
+msgstr "Kann das Perzentil nicht berechnen ohne die Angabe von pth!"
+msgstr "Kann keinen getrimmten Mittelwert (trimmean) ohne Angabe von trim!"
+msgstr "zrange wird im Lesemodus nicht berücksichtigt."
+msgstr "Lese Daten..."
+#, fuzzy
+msgstr "Konnte die Ausgabedate <%s> nicht öffnen."
+msgstr "Schreibe in die Karte ..."
+#, c-format
+msgstr "%lu Punkte in der Region gefunden."
+msgstr "Lese Daten ..."
+#, c-format
+msgstr "Bereich:     min         max\n"
@@ -8866,12 +9025,6 @@
 msgstr "Kann das TIFF-Worldfile nicht zum Schreiben öffnen."
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8884,19 +9037,6 @@
 msgstr "ASCII-Datei mit Eingabedaten (oder \"-\" um von stdin zu lesen)"
-msgstr "Statistik um Rasterwert zu bestimmen"
-msgid "Statistic"
-msgstr "Statistik"
-msgstr "Speichertyp der resultierenden Rasterkarte."
 msgstr ""
@@ -8910,35 +9050,6 @@
 msgstr "Spaltenummer der Daten in der Eingabedatei."
-msgstr "Filterbereich für z-Daten (min,max)."
-msgstr "Skalierungsfaktor für die z-Daten."
-msgstr "Perzentil der Werte"
-msgid ""
-"observations"
-msgstr ""
-"Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten "
-"Beobachtungen."
-msgstr ""
-"Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
-msgstr "Im Lesemodus Ausgabe im Shell-Skript-Stil."
 msgstr "Ignoriere kaputte Zeilen."
@@ -8947,18 +9058,6 @@
 msgstr "Bitte geben Sie eine sinnvolle Spaltenummer an."
-msgstr "Ungültige z-Spanne."
-msgstr "Kann das Perzentil nicht berechnen ohne die Angabe von pth!"
-msgstr "Kann keinen getrimmten Mittelwert (trimmean) ohne Angabe von trim!"
 msgid ""
@@ -8966,14 +9065,6 @@
 "Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang "
 "ausgeführt werden."
-msgstr "zrange wird im Lesemodus nicht berücksichtigt."
-msgstr "Lese Daten..."
 #, c-format
@@ -9005,24 +9096,6 @@
 msgstr "Schlechte Z-Koordinate in Zeile %lu Spalte %d. <%s>"
-msgstr "Schreibe in die Karte ..."
-#, c-format
-msgstr "%lu Punkte in der Region gefunden."
-msgstr "Lese Daten ..."
-#, c-format
-msgstr "Bereich:     min         max\n"
 msgstr "Erzeugt Texturbilder von einer Rasterkarte."
@@ -11179,7 +11252,7 @@
 msgid "Attributes"
@@ -11232,7 +11305,7 @@
 #, c-format
 msgstr "Kann neue Zeile %s nicht einfügen."
@@ -18123,8 +18196,7 @@
 msgstr "Kann die Attribute für cat=%d nicht selektieren."
 msgstr "Kann Daten nicht aus der Tabelle ziehen."
@@ -18646,16 +18718,16 @@
 " \t\tESRI Shapefile: Name des Shapefiles\n"
 "\t\tMapInfo Datei: Mapinfo-Dateiname."
 msgstr "Importiere nur einen Ausschnitt."
 msgid "Subregion"
 msgstr "Ausschnitt"
 msgstr "Format: xmin,ymin,xmax,ymax - gewöhnlich W,S,O,N"
@@ -18715,17 +18787,11 @@
 msgstr "Keine Attributtabelle erzeugen."
-msgstr ""
-"Übersteuere die Projektion des Datensatzes (verwende Projektion der "
-"Location)."
 msgstr "Begrenze den Import auf die aktuelle Region."
@@ -18733,7 +18799,7 @@
 msgstr "Ändere Spaltenname zu Kleinbuchstaben"
 msgid ""
@@ -18753,12 +18819,12 @@
 msgstr "Datenquelle enthält %d Layer:"
 #, c-format
 msgstr "Die Vektorkarte <%s> existiert bereits und wird überschrieben."
 #, c-format
@@ -18769,46 +18835,16 @@
 msgstr "Layer <%s> ist nicht vorhanden."
 msgstr ""
 "Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option "
 "'spatial' aber nicht beide."
 msgstr "4 Werte sind für den Parameter 'spatial' nötig."
-msgid ""
-"checking"
-msgstr ""
-"Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
-"konvertieren, zwecks Überprüfung."
-msgstr "GRASS LOCATION PROJ_INFO:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
-"übersteuern.\n"
-msgid ""
-"set.\n"
-msgstr ""
-"Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der "
-"Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
 #, c-format
@@ -18852,7 +18888,7 @@
 msgstr "Spaltentyp (%s) wird nicht unterstützt."
 #, c-format
 msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
@@ -18903,26 +18939,26 @@
 msgstr "Säubere Grenzen an den Knoten:"
+msgstr "Verbinde Grenzen:"
 msgstr "Ändere Grenzüberstände zu Linien:"
 #, fuzzy
 msgstr "Entferne Überstände (dangles)"
 msgstr "Ändere Brücken der Grenzen zu Linien:"
 msgstr "Lösche Brücken:"
-msgstr "Verbinde Grenzen:"
@@ -19864,7 +19900,7 @@
 msgstr "Verwende die drand48() Funktion anstelle von rand()."
 msgstr "Erzeuge keine Topologie."
@@ -21787,7 +21823,7 @@
 msgstr "Kann die Attribute für cat=%d nicht auswählen."
 #, c-format
 msgstr ""
@@ -23823,45 +23859,64 @@
 msgstr "[%d] Kategorien in den Speicher gelesen."
 #, fuzzy
 msgstr "Konvertiere OGR Vektorlayer in das GRASS Vektorkarten."
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Integer-Werte wurden importiert."
+#, fuzzy
 msgstr "Gebe Rasterhistorie anstelle der Info aus."
 #, fuzzy, c-format
+msgstr "Unbekannte Regeloption: '%s'"
+#, fuzzy, c-format
 msgstr "Importiere Punkte..."
 #, fuzzy, c-format
 msgstr "%d Punkte geladen."
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d Punkte außerhalb des Schwellenwertes."
+#, fuzzy, c-format
+msgstr "%d Punkte außerhalb des Schwellenwertes."
 msgid "flow"
 msgstr ""
@@ -29803,6 +29858,46 @@
 msgstr "Unkomprimierte geonames-Datei (mit der Dateiendung .txt)."
+msgstr ""
+#, fuzzy
+msgstr "Name der Eingabekarte."
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Die Zahl der Punkte, die verteilt werden sollen."
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_el.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_el\n"
 "PO-Revision-Date: 2009-02-19 10:29+0200\n"
 "Last-Translator: Vasilios Antoniou <vantoniou at gmail.com>\n"
 "Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
@@ -254,13 +254,14 @@
@@ -357,18 +358,18 @@
@@ -423,6 +424,7 @@
@@ -1623,7 +1625,8 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -1676,7 +1679,7 @@
@@ -1800,7 +1803,7 @@
@@ -1811,7 +1814,7 @@
 #, fuzzy, c-format
@@ -1823,7 +1826,7 @@
 #, c-format
@@ -2277,7 +2280,7 @@
 msgstr ""
 msgstr ""
@@ -2508,7 +2511,7 @@
 msgstr ""
 msgstr ""
@@ -2517,7 +2520,7 @@
 msgstr ""
 msgstr ""
@@ -2583,14 +2586,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr ""
 #, c-format
 msgstr ""
@@ -2601,13 +2604,15 @@
 "for checking"
 msgstr ""
 msgstr ""
 msgid ""
 "\n"
@@ -2621,9 +2626,10 @@
 msgstr ""
 msgstr ""
@@ -2640,8 +2646,9 @@
 msgstr ""
 msgstr ""
@@ -6530,7 +6537,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7452,6 +7459,145 @@
 msgstr "Áäõíáìßá äçìéïõñãßáò êáé ëýóçò ôïõ ãñáììéêïý óõóôÞìáôïò"
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
+msgstr ""
+msgid "Statistic"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"observations"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+msgstr ""
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+#, fuzzy
+msgstr "ËÜèïò óõíôåôáãìÝíåò"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "×Üñôçò åðáíáöüñôéóçò óå  m^3/s"
+#, fuzzy
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+msgstr ""
+#, c-format
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
@@ -8273,12 +8419,6 @@
 msgstr ""
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8289,19 +8429,6 @@
 msgstr ""
-msgstr ""
-msgid "Statistic"
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8314,32 +8441,6 @@
 msgstr ""
-msgstr ""
-msgstr ""
-msgstr ""
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8348,33 +8449,11 @@
 msgstr ""
-#, fuzzy
-msgstr "ËÜèïò óõíôåôáãìÝíåò"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "×Üñôçò åðáíáöüñôéóçò óå  m^3/s"
 #, c-format
@@ -8403,24 +8482,6 @@
 msgstr ""
-msgstr ""
-#, c-format
-msgstr ""
-msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
@@ -10460,7 +10521,7 @@
 msgid "Attributes"
@@ -10506,7 +10567,7 @@
 #, c-format
 msgstr ""
@@ -16961,8 +17022,7 @@
 msgstr ""
 msgstr ""
@@ -17430,16 +17490,16 @@
 msgstr ""
 msgstr ""
 msgid "Subregion"
 msgstr ""
 msgstr ""
@@ -17493,15 +17553,11 @@
 msgstr ""
-msgstr ""
 msgstr ""
@@ -17509,7 +17565,7 @@
 msgstr ""
 msgid ""
@@ -17529,13 +17585,13 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr ""
 "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
 #, c-format
@@ -17546,37 +17602,14 @@
 msgstr ""
 msgstr ""
 msgstr ""
-msgid ""
-"checking"
-msgstr ""
-msgstr ""
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -17614,7 +17647,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
@@ -17665,26 +17698,26 @@
 msgstr ""
+#, fuzzy
+msgstr "ÅããñáöÞ %s áðü %s..."
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
-#, fuzzy
-msgstr "ÅããñáöÞ %s áðü %s..."
@@ -18541,7 +18574,7 @@
 msgstr ""
 msgstr ""
@@ -20290,7 +20323,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -22186,45 +22219,63 @@
 msgstr ""
 #, fuzzy
 msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
 #, fuzzy
 msgstr ""
+msgstr ""
+msgstr ""
 #, fuzzy
 msgstr "Ôõðþíåé ôïí ðßíáêá êáé êëåéíåé (Ýîïäïò)"
 #, fuzzy, c-format
+msgstr "¶ãíùóôïò ôýðïò"
+#, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "äåí âñÝèçêå"
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
+#, c-format
+msgstr ""
 msgid "flow"
 msgstr ""
@@ -27759,6 +27810,44 @@
 msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_es.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -12,7 +12,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_es\n"
 "PO-Revision-Date: 2011-05-17 16:53+0100\n"
 "Last-Translator: Joana Palahí <joana at sigte.udg.edu>\n"
 "Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -265,13 +265,14 @@
@@ -371,18 +372,18 @@
@@ -437,6 +438,7 @@
 msgstr "Coordenada Este <%s> no admitida, saliendo."
 #, c-format
 msgstr "Pase #%d (de %d)..."
@@ -1858,7 +1861,7 @@
@@ -1869,7 +1872,7 @@
 #, c-format
@@ -1881,7 +1884,7 @@
 #, c-format
@@ -2360,7 +2363,7 @@
 "Coste asignado a celdas nulas. Por defecto, las celdas nulas son excluidas"
 msgstr "Porcentaje de mapa a mantener en memoria"
@@ -2605,7 +2608,7 @@
 msgstr ""
 msgstr "Nombre de la nueva localización a crear"
@@ -2614,7 +2617,7 @@
 msgstr "Ignorar proyección (usar proyección de la localización)"
 msgstr ""
 "Ampliar la extensión de la localización en base a nuevo conjunto de datos"
 msgstr ""
 msgid ""
 "location."
@@ -2701,7 +2704,7 @@
 "se puede crear la nueva localización."
 #, c-format
 msgstr "Localización <%s> creada"
@@ -2714,13 +2717,15 @@
 "No se puede convertir la información de la proyección del mapa de entrada al "
 "formato de GRASS para comprobar"
 msgstr "Ignorando comprobación de proyección"
 msgid ""
 "\n"
@@ -2737,9 +2742,10 @@
 msgstr "La PROJ_INFO del conjunto de datos es:\n"
 msgstr ""
 "La información de proyección (PROJ_INFO) del conjunto de datos a importar "
@@ -2763,8 +2769,9 @@
 "Considere generar una nueva localización a partir del conjunto de datos de "
 "entrada usando el parámetro 'localización'.\n"
 msgstr ""
 "Las proyecciones del conjunto de datos de entrada y de la localización "
@@ -6906,7 +6913,7 @@
 msgstr "SECCIÓN 1a (de %1d): iniciando memoria."
 #, c-format
 msgstr "SECCIÓN 1b (de %1d): Determinando flujo Offmap."
@@ -7955,6 +7962,159 @@
 msgstr "No se puede crear y resolver el sistema de ecuaciones lineal"
+msgid "LIDAR"
+msgstr ""
+#, fuzzy
+msgstr ""
+"Crear un mapa ráster a partir de un ensamblaje de muchas coordenadas usando "
+"estadísticas univariantes."
+#, fuzzy
+msgstr "Archivo DXF de entrada"
+msgstr "Estadística a utilizar para los valores ráster"
+msgid "Statistic"
+msgstr "Estadístico"
+msgstr "Tipo de almacenamiento para el mapa ráster resultante"
+msgstr "Rango de filtrado para los datos Z (mínimo, máximo)"
+msgstr "Escala a aplicar a los datos Z"
+msgstr "pth percentil de los valores"
+msgid ""
+"observations"
+msgstr ""
+"Descartar <trim> porcentaje de las menores y <trim> porcentaje de las "
+"mayores observaciones"
+msgstr ""
+"Ignorar proyección del conjunto de datos (usar proyección de la localización)"
+msgstr "Escanear archivo de datos para la extensión y luego salir"
+msgstr "En modo de escaneo, imprimir usando estilo de script de consola"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+"No se puede convertir información de la proyección del mapa de entrada a "
+"formato GRASS para comprobar"
+msgstr "La información de proyección (PROJ_INFO) de la localización es:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Puede usar la opción -o para que %s ignore la comprobación de esta "
+"proyección.\n"
+#, fuzzy
+msgid ""
+"set.\n"
+msgstr ""
+"Considere generar una nueva localización con el parámetro 'localización' del "
+"conjunto de datos de entrada.\n"
+msgstr "rangoz no válido"
+msgstr "No es posible calcular el percentil sin especificar la opción pth!"
+msgstr ""
+"No es posible calcular la media recortada sin especificar la opción de "
+"recorte!"
+msgstr "el rango z no se tendrá en cuenta durante el escaneo"
+msgstr "Leyendo datos ..."
+#, fuzzy
+msgstr "No se puede leer el archivo de intervalo"
+msgstr "Escribiendo al mapa..."
+#, c-format
+msgstr "%lu puntos encontrados en la región."
+msgstr "Escaneando datos..."
+#, c-format
+msgstr "Rango:     mínimo          máximo\n"
@@ -8824,12 +8984,6 @@
 msgstr "No se puede abrir el archivo de referenciación TIFF para escritura"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8843,19 +8997,6 @@
 msgstr ""
 "Archivo ASCII que contiene los datos de entrada (o \"-\" para leer de stdin)"
-msgstr "Estadística a utilizar para los valores ráster"
-msgid "Statistic"
-msgstr "Estadístico"
-msgstr "Tipo de almacenamiento para el mapa ráster resultante"
 msgstr ""
@@ -8870,34 +9011,6 @@
 msgstr "Número de columna de los valores de datos en el archivo de entrada"
-msgstr "Rango de filtrado para los datos Z (mínimo, máximo)"
-msgstr "Escala a aplicar a los datos Z"
-msgstr "pth percentil de los valores"
-msgid ""
-"observations"
-msgstr ""
-"Descartar <trim> porcentaje de las menores y <trim> porcentaje de las "
-"mayores observaciones"
-msgstr "Escanear archivo de datos para la extensión y luego salir"
-msgstr "En modo de escaneo, imprimir usando estilo de script de consola"
 msgstr "Ignorar líneas quebradas"
@@ -8906,34 +9019,12 @@
 msgstr "Por favor, especifique un número de columna razonable."
-msgstr "rangoz no válido"
-msgstr "No es posible calcular el percentil sin especificar la opción pth!"
-msgstr ""
-"No es posible calcular la media recortada sin especificar la opción de "
-"recorte!"
 msgid ""
 msgstr ""
 "Si la entrada no es de un archivo sólo se puede realizar un único pase."
-msgstr "el rango z no se tendrá en cuenta durante el escaneo"
-msgstr "Leyendo datos ..."
 #, c-format
@@ -8965,24 +9056,6 @@
 msgstr "Coordenada Z incorrecta línea %lu columna %d. <%s>"
-msgstr "Escribiendo al mapa..."
-#, c-format
-msgstr "%lu puntos encontrados en la región."
-msgstr "Escaneando datos..."
-#, c-format
-msgstr "Rango:     mínimo          máximo\n"
 msgstr "Genera imágenes con elementos texturales a partir de un mapa ráster."
@@ -11132,7 +11205,7 @@
 msgid "Attributes"
@@ -11185,7 +11258,7 @@
 #, c-format
 msgstr "No se puede insertar nueva línea: %s"
@@ -18078,8 +18151,7 @@
 msgstr "No se pueden seleccionar los atributos para la categoría %d"
 msgstr "No se pueden recopilar datos de la tabla"
@@ -18586,16 +18658,16 @@
 "\t\tShapefile ESRI: nombre del shapefile\n"
 "\t\tArchivo MapInfo: nombre del archivo MapInfo"
 msgstr "Importar sólo la subregión"
 msgid "Subregion"
 msgstr "Subregión"
 msgstr "Formato: xmin,ymin,xmax,ymax - normalmente W,S,E,N"
@@ -18655,16 +18727,11 @@
 msgstr "No crear la tabla de atributos"
-msgstr ""
-"Ignorar proyección del conjunto de datos (usar proyección de la localización)"
 msgstr "Limitar importación a la región actual"
@@ -18672,7 +18739,7 @@
 msgstr "Cambiar nombres de columna a minúsculas"
 msgid ""
@@ -18692,12 +18759,12 @@
 msgstr "El origen de datos contiene %d capas:"
 #, c-format
 msgstr "El vectorial <%s> ya existe y será sobrescrito"
 #, c-format
@@ -18708,45 +18775,14 @@
 msgstr "Capa <%s> no disponible"
 msgstr "Seleccionar la opción región actual o la opción espacial, no ambas"
 msgstr " Se requieren 4.parámetros para el parámetro 'espacial'"
-msgid ""
-"checking"
-msgstr ""
-"No se puede convertir información de la proyección del mapa de entrada a "
-"formato GRASS para comprobar"
-msgstr "La información de proyección (PROJ_INFO) de la localización es:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"Puede usar la opción -o para que %s ignore la comprobación de esta "
-"proyección.\n"
-#, fuzzy
-msgid ""
-"set.\n"
-msgstr ""
-"Considere generar una nueva localización con el parámetro 'localización' del "
-"conjunto de datos de entrada.\n"
 #, fuzzy, c-format
@@ -18790,7 +18826,7 @@
 msgstr "Tipo de columna no soportado (%s)"
 #, fuzzy, c-format
 msgstr "No se puede abrir la base de datos <%s> por el controlador <%s>"
@@ -18841,26 +18877,26 @@
 msgstr "Limpiar contornos en los nodos:"
+msgstr "Unir contornos:"
 msgstr "Cambiar nodos colgantes de los contornos a líneas:"
 #, fuzzy
 msgstr "Eliminar balanceos"
 msgstr "Cambiar puentes de contornos a líneas:"
 msgstr "Eliminar puentes:"
-msgstr "Unir contornos:"
@@ -19792,7 +19828,7 @@
 msgstr "Usar la función drand48() en vez de rand()"
 msgstr "No construir topología"
@@ -21704,7 +21740,7 @@
 msgstr "No se pueden seleccionar atributos para la categoría = %d"
 #, c-format
 msgstr ""
@@ -23732,45 +23768,64 @@
 msgstr "[%d] categorías leídas en memoria"
 #, fuzzy
 msgstr "Convertir capas vectoriales OGR a mapas vectoriales de GRASS."
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Se importan los valores enteros"
+#, fuzzy
 msgstr "Imprimir histórico del ráster en vez de información"
 #, fuzzy, c-format
+msgstr "Opción de norma: '%s' desconocida"
+#, fuzzy, c-format
 msgstr "Importando puntos..."
 #, fuzzy, c-format
 msgstr "%d puntos cargados"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d puntos fuera del umbral"
+#, fuzzy, c-format
+msgstr "%d puntos fuera del umbral"
 msgid "flow"
 msgstr ""
@@ -29703,6 +29758,46 @@
 msgstr "Archivo geonames sin comprimir de (con extensión .txt)"
+msgstr ""
+#, fuzzy
+msgstr "Nombre de una capa de entrada"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "El número de puntos a situar"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
@@ -36606,10 +36701,6 @@
 #~ "forma impresa por v.db.connect -g, esto es, con variables sustituidas"
 #, fuzzy
-#~ msgid "Could not read range file"
-#~ msgstr "No se puede leer el archivo de intervalo"
-#, fuzzy
 #~ msgid "%d update/insert errors"
 #~ msgstr "%d errores al insertar"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_fr.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -11,7 +11,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_fr\n"
 "PO-Revision-Date: 2008-07-19 23:20+0100\n"
 "Last-Translator: Pascal Obstétar <pascal.obstetar at wanadoo.fr>\n"
 "Language-Team: Français <grass-translations at lists.osgeo.org>\n"
@@ -376,18 +377,18 @@
@@ -442,6 +443,7 @@
@@ -1758,7 +1760,8 @@
 msgstr "Coordonnées Est <%s> illégale"
 #, fuzzy, c-format
 msgstr "classe %d (%d)\n"
@@ -1816,7 +1819,7 @@
@@ -1944,7 +1947,7 @@
@@ -1956,7 +1959,7 @@
 #, fuzzy, c-format
@@ -1968,7 +1971,7 @@
 #, fuzzy, c-format
@@ -2469,7 +2472,7 @@
 "Coût assigné aux cellules vides. Par défaut, les cellules vides sont ignorées"
 msgstr "Pourcentage de la couche à garder en mémoire"
@@ -2722,7 +2725,7 @@
 msgstr ""
 msgstr "Nom du nouveau Secteur (location) à créer"
@@ -2731,7 +2734,7 @@
 msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
 msgstr "Étendre le Secteur actuel en fonction des données importés"
@@ -2802,7 +2805,7 @@
 msgstr ""
 msgid ""
 "location."
@@ -2812,7 +2815,7 @@
 # c-format
 #, fuzzy, c-format
 msgstr "Secteur %s créé!"
@@ -2826,14 +2829,16 @@
 "Impossible de convertir l'information de projection de la couche de données "
 "au format GRASS pour vérification"
 #, fuzzy
 msgstr "Projection source"
 #, fuzzy
 msgid ""
@@ -2854,9 +2859,10 @@
 msgstr ""
 # c-format
 #, fuzzy
 msgstr "Secteur : %s\n"
@@ -2880,8 +2886,9 @@
 "Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
 "des données en entrée.\n"
 #, fuzzy
 msgstr ""
@@ -7291,7 +7298,7 @@
 "\n"
 "SECTION 1a (de %1d): Initialisation de la mémoire."
 #, fuzzy, c-format
 msgstr ""
@@ -8377,6 +8384,165 @@
 msgstr "Impossible de créer la couche raster %s"
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Fichier DXF source"
+#, fuzzy
+msgstr "Statistique de couches raster."
+msgid "Statistic"
+msgstr ""
+msgstr "Type de stockage pour la couche raster créée"
+#, fuzzy
+msgstr "Rang des valeurs entières: min,max"
+msgstr ""
+#, fuzzy
+msgstr "Format de sortie pour la pente"
+msgid ""
+"observations"
+msgstr ""
+#, fuzzy
+msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
+msgstr ""
+#, fuzzy
+msgstr "Produit les statistiques à la façon d'un script shell"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+"Impossible de convertir l'information de projection de la couche de données "
+"au format GRASS pour vérification"
+# c-format
+#, fuzzy
+msgstr "Secteur : %s\n"
+#, fuzzy, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
+#, fuzzy
+msgid ""
+"set.\n"
+msgstr ""
+"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
+"des données en entrée.\n"
+# c-format
+#, fuzzy
+msgstr "Etiquette date&heure invalide"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Rotation des données ... "
+# c-format
+#, fuzzy
+msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
+# c-format
+#, fuzzy
+msgstr "Écriture %s..."
+# c-format
+#, fuzzy, c-format
+msgstr "%d points en dehors de la région courante"
+#, fuzzy
+#, c-format
+msgstr ""
@@ -9298,12 +9464,6 @@
 msgstr "Impossible d'ouvrir le fichier TIFF world pour l'écriture"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -9315,20 +9475,6 @@
 msgstr "Fichier ascii contenant les signatures spectrales"
-#, fuzzy
-msgstr "Statistique de couches raster."
-msgid "Statistic"
-msgstr ""
-msgstr "Type de stockage pour la couche raster créée"
 #, fuzzy
@@ -9344,35 +9490,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Rang des valeurs entières: min,max"
-msgstr ""
-#, fuzzy
-msgstr "Format de sortie pour la pente"
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Produit les statistiques à la façon d'un script shell"
 msgstr ""
@@ -9382,34 +9499,11 @@
 msgstr "Veuillez spécifier une colonne z vraisemblable"
-# c-format
-#, fuzzy
-msgstr "Etiquette date&heure invalide"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Rotation des données ... "
 #, c-format
@@ -9438,28 +9532,6 @@
 msgstr ""
-# c-format
-#, fuzzy
-msgstr "Écriture %s..."
-# c-format
-#, fuzzy, c-format
-msgstr "%d points en dehors de la région courante"
-#, fuzzy
-#, c-format
-msgstr ""
 #, fuzzy
@@ -11765,7 +11837,7 @@
 #, fuzzy
@@ -11818,7 +11890,7 @@
 #, c-format
 msgstr "Impossible d'insérer une nouvelle ligne : %s"
@@ -19037,8 +19109,7 @@
 msgstr "Impossible de sélectionner les attributs pour cat = %d"
 #, fuzzy
 msgstr "Impossible de sélectionner des données dans la table"
@@ -19582,18 +19653,18 @@
 "\t\tShapefile ESRI : nom du shapefile\n"
 "\t\tFichier MapInfo : nom du fichier mapinfo"
 #, fuzzy
 msgstr "Afficher seulement la région de la couche raster"
 #, fuzzy
 msgid "Subregion"
 msgstr "Région\n"
 #, fuzzy
 msgstr ""
@@ -19664,17 +19735,12 @@
 msgstr "Ne pas créer de table attributaire"
 #, fuzzy
-msgstr "Ne pas tenir compte de la projection (utiliser celle du Secteur)"
-#, fuzzy
 msgstr "Ne pas modifier la région courante"
@@ -19682,7 +19748,7 @@
 msgstr ""
 msgid ""
@@ -19703,12 +19769,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Le vecteur '%s' existe déjà."
 #, fuzzy, c-format
@@ -19719,48 +19785,16 @@
 msgstr "La couche '%s' n'est pas disponible"
 msgstr ""
 #, fuzzy
 msgstr "4 paramètres sont requis pour le paramètre 'spatial'"
-msgid ""
-"checking"
-msgstr ""
-"Impossible de convertir l'information de projection de la couche de données "
-"au format GRASS pour vérification"
 # c-format
-#, fuzzy
-msgstr "Secteur : %s\n"
-#, fuzzy, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"Vous pouvez utiliser le drapeau -o de %s pour sauter cette vérification.\n"
-#, fuzzy
-msgid ""
-"set.\n"
-msgstr ""
-"Tentez de générer un nouveau Secteur (location) avec le paramètre 'location' "
-"des données en entrée.\n"
-# c-format
 #, fuzzy, c-format
@@ -19805,7 +19839,7 @@
 msgstr "Type de colonne (%s) non géré"
 #, fuzzy, c-format
 msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
@@ -19859,27 +19893,27 @@
 msgstr ""
+#, fuzzy
+msgstr "impossible de mettre à jour les limites"
 msgstr ""
 #, fuzzy
 msgstr "Suppression des centroïdes en doublons..."
 msgstr ""
 msgstr ""
-#, fuzzy
-msgstr "impossible de mettre à jour les limites"
@@ -20853,7 +20887,7 @@
 msgstr "Utilise la fonction drand48() (par défaut=rand() )"
 #, fuzzy
@@ -22875,7 +22909,7 @@
 # c-format
 #, fuzzy, c-format
 msgstr "Aucun enregistrement pour la catégorie (cat = %d)"
@@ -25002,46 +25036,66 @@
 msgstr "%-5d catégories lues en mémoire.\n"
 #, fuzzy
 msgstr "Convertit des fichiers vecteurs OGR dans GRASS. Pilotes disponibles:\n"
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "données entières importées"
+#, fuzzy
 msgstr "Afficher l'historique du raster à la place des infos générales"
 #, fuzzy, c-format
+msgstr "Type inconnu"
+#, fuzzy, c-format
 msgstr "Importation des objets de la couche %d..."
 #, fuzzy, c-format
 msgstr "%d points chargés\n"
 #, fuzzy, c-format
 msgstr "Coordonnées de la carte"
 # c-format
 #, fuzzy, c-format
 msgstr "%d points en dehors du seuillage"
+# c-format
+#, fuzzy, c-format
+msgstr "%d points en dehors du seuillage"
 msgid "flow"
 msgstr ""
@@ -31348,6 +31402,46 @@
 msgstr "Fichier GNS décompressé provenant de NGA (avec extension .txt)"
+msgstr ""
+#, fuzzy
+msgstr "Nom de la couche source"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Nombre de points à placer"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
@@ -41548,11 +41642,6 @@
 # c-format
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
-# c-format
-#, fuzzy
 #~ msgid "unable to create raster"
 #~ msgstr "impossible de créer raster\n"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_hi.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_hi\n"
 "PO-Revision-Date: 2005-12-20 22:29+0100\n"
 "Last-Translator: Markus Neteler <neteler at itc.it>\n"
 "Language-Team: Hindi <grass-translations at lists.osgeo.org>\n"
@@ -264,13 +264,14 @@
 #: ../raster3d/r3.in.ascii/main.c:242 ../raster/r.in.poly/main.c:30
 #: ../raster/r.in.gdal/main.c:82 ../raster/r.in.bin/main.c:236
 #: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.png/main.c:522
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.external/main.c:524
-#: ../raster/r.in.ascii/main.c:70 ../raster/r.in.mat/main.c:92
-#: ../raster/r.in.arc/main.c:61 ../vector/v.in.ogr/main.c:106
-#: ../vector/v.in.db/main.c:53 ../vector/v.in.sites/main.c:58
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.convert/main.c:37 ../vector/v.in.lidar/main.c:148
-#: ../vector/v.in.ascii/main.c:49 ../vector/v.external/main.c:49
+#: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:161
+#: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
+#: ../raster/r.in.mat/main.c:92 ../raster/r.in.arc/main.c:61
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
+#: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
+#: ../vector/v.in.lidar/main.c:154 ../vector/v.in.ascii/main.c:49
+#: ../vector/v.external/main.c:49
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:3
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:3
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
@@ -375,18 +376,18 @@
 #: ../raster/r.info/main.c:70 ../raster/r.surf.area/main.c:88
 #: ../raster/r.surf.fractal/main.c:38 ../raster/r.covar/main.c:51
 #: ../raster/r.statistics3/main.c:389 ../raster/r.rescale/main.c:48
-#: ../raster/r.solute.transport/main.c:229 ../raster/r.proj/main.c:146
-#: ../raster/r.out.mpeg/main.c:102 ../raster/r.fill.dir/main.c:85
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.univar/r.univar_main.c:96
-#: ../raster/r.cross/main.c:73 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.category/main.c:52 ../raster/r.clump/main.c:46
-#: ../raster/r.out.tiff/main.c:91 ../raster/r.in.xyz/main.c:160
-#: ../raster/r.texture/main.c:75 ../raster/r.surf.random/main.c:36
-#: ../raster/r.out.arc/main.c:60 ../raster/r.surf.contour/main.c:60
-#: ../raster/r.colors/main.c:168 ../raster/r.statistics/main.c:55
-#: ../raster/r.li/r.li.padcv/padcv.c:39 ../raster/r.li/r.li.mpa/mpa.c:41
-#: ../raster/r.li/r.li.patchnum/main.c:36 ../raster/r.li/r.li.mps/mps.c:42
-#: ../raster/r.li/r.li.pielou/pielou.c:58
+#: ../raster/r.solute.transport/main.c:229 ../raster/r.in.lidar/main.c:161
+#: ../raster/r.proj/main.c:146 ../raster/r.out.mpeg/main.c:102
+#: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.univar/r.univar_main.c:96 ../raster/r.cross/main.c:73
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
+#: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
+#: ../raster/r.surf.contour/main.c:60 ../raster/r.colors/main.c:168
+#: ../raster/r.statistics/main.c:55 ../raster/r.li/r.li.padcv/padcv.c:39
+#: ../raster/r.li/r.li.mpa/mpa.c:41 ../raster/r.li/r.li.patchnum/main.c:36
+#: ../raster/r.li/r.li.mps/mps.c:42 ../raster/r.li/r.li.pielou/pielou.c:58
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:40
 #: ../raster/r.li/r.li.cwed/cwed.c:48 ../raster/r.li/r.li.padsd/padsd.c:39
 #: ../raster/r.li/r.li.richness/richness.c:41
@@ -441,6 +442,7 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:2
 #: ../locale/scriptstrings/r.grow_to_translate.c:2
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:2
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:2
@@ -1725,7 +1727,8 @@
 msgid "Illegal east coordinate <%s>, skipping."
 msgstr "पूर्व"
-#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.lidar/main.c:591
+#: ../raster/r.in.xyz/main.c:531
 #, fuzzy, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "n"
@@ -1779,7 +1782,7 @@
 #: ../vector/v.what/main.c:54 ../vector/v.transform/main.c:82
 #: ../vector/v.overlay/main.c:58 ../vector/v.class/main.c:44
 #: ../vector/v.build.polylines/main.c:113 ../vector/v.convert/main.c:36
-#: ../vector/v.in.lidar/main.c:147 ../vector/v.net.flow/main.c:58
+#: ../vector/v.in.lidar/main.c:153 ../vector/v.net.flow/main.c:58
 #: ../vector/v.segment/main.c:54 ../vector/v.normal/main.c:74
 #: ../vector/v.net.path/main.c:40 ../vector/v.univar/main.c:63
 #: ../vector/v.label/main.c:59 ../vector/v.to.rast/main.c:40
@@ -1906,7 +1909,7 @@
 #: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:462
-#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:565
+#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:596
 #: ../vector/v.net.flow/main.c:170 ../vector/v.net.path/path.c:109
 #: ../vector/v.to.points/main.c:293 ../vector/v.surf.rst/main.c:579
 #: ../vector/v.net.centrality/main.c:242 ../vector/v.net.components/main.c:149
@@ -1917,7 +1920,7 @@
 #: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:796
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
-#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:570
+#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:601
 #: ../vector/v.to.points/main.c:298 ../vector/v.in.ascii/main.c:504
 #, fuzzy, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
@@ -1929,7 +1932,7 @@
 #: ../vector/v.random/main.c:199 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:472
-#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:576
+#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:607
 #: ../vector/v.to.points/main.c:304 ../vector/v.in.ascii/main.c:394
 #, fuzzy, c-format
 msgid "Unable to grant privileges on table <%s>"
@@ -2424,7 +2427,7 @@
 msgstr "खर्च"
 #: ../raster/r.walk/main.c:274 ../raster/r.cost/main.c:229
-#: ../raster/r.in.xyz/main.c:238
+#: ../raster/r.in.lidar/main.c:211 ../raster/r.in.xyz/main.c:238
 #, fuzzy
 msgid "Percent of map to keep in memory"
 msgstr "का"
@@ -2670,7 +2673,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:181
-#: ../vector/v.in.lidar/main.c:172
+#: ../vector/v.in.lidar/main.c:178
 #, fuzzy
 msgid "Name for new location to create"
 msgstr "के लिए"
@@ -2680,7 +2683,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:144 ../raster/r.external/main.c:562
-#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:199
+#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:213
 #, fuzzy
 msgid "Extend location extents based on new dataset"
 msgstr "चालू"
@@ -2750,14 +2753,14 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:335 ../vector/v.in.ogr/main.c:480
-#: ../vector/v.in.lidar/main.c:320
+#: ../vector/v.in.lidar/main.c:351
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:341 ../vector/v.in.ogr/main.c:486
-#: ../vector/v.in.lidar/main.c:326
+#: ../vector/v.in.lidar/main.c:357
 #, fuzzy, c-format
 msgid "Location <%s> created"
 msgstr "n"
@@ -2769,14 +2772,16 @@
 "for checking"
 msgstr "के लिए"
-#: ../raster/r.in.gdal/main.c:370 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:516 ../vector/v.in.lidar/main.c:359
+#: ../raster/r.in.gdal/main.c:370 ../raster/r.in.lidar/main.c:296
+#: ../raster/r.external/main.c:105 ../vector/v.in.ogr/main.c:516
+#: ../vector/v.in.lidar/main.c:390
 #, fuzzy
 msgid "Over-riding projection check"
 msgstr "नहीं n"
-#: ../raster/r.in.gdal/main.c:381 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:525 ../vector/v.in.lidar/main.c:368
+#: ../raster/r.in.gdal/main.c:381 ../raster/r.in.lidar/main.c:305
+#: ../raster/r.external/main.c:113 ../vector/v.in.ogr/main.c:525
+#: ../vector/v.in.lidar/main.c:399
 #, fuzzy
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
@@ -2792,9 +2797,10 @@
 msgid "Dataset PROJ_INFO is:\n"
 msgstr ""
-#: ../raster/r.in.gdal/main.c:424 ../raster/r.external/main.c:156
+#: ../raster/r.in.gdal/main.c:424 ../raster/r.in.lidar/main.c:321
+#: ../raster/r.in.lidar/main.c:328 ../raster/r.external/main.c:156
 #: ../vector/v.in.ogr/main.c:541 ../vector/v.in.ogr/main.c:548
-#: ../vector/v.in.lidar/main.c:384 ../vector/v.in.lidar/main.c:391
+#: ../vector/v.in.lidar/main.c:415 ../vector/v.in.lidar/main.c:422
 #, fuzzy
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "n"
@@ -2814,8 +2820,9 @@
 "'location' parameter.\n"
 msgstr "a सेट n"
-#: ../raster/r.in.gdal/main.c:454 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:599 ../vector/v.in.lidar/main.c:442
+#: ../raster/r.in.gdal/main.c:454 ../raster/r.in.lidar/main.c:379
+#: ../raster/r.external/main.c:186 ../vector/v.in.ogr/main.c:599
+#: ../vector/v.in.lidar/main.c:473
 #, fuzzy
 msgid "Projection of input dataset and current location appear to match"
 msgstr "का जोड़ा n"
@@ -6985,7 +6992,7 @@
 msgid "SECTION 1a (of %1d): Initiating Memory."
 msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:296
+#: ../raster/r.watershed/ram/init_vars.c:300
 #, c-format
 msgid "SECTION 1b (of %1d): Determining Offmap Flow."
 msgstr ""
@@ -7942,6 +7949,155 @@
 msgid "Could not create and solve the linear equation system"
 msgstr "का a"
+#: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:162
+#: ../vector/v.surf.bspline/main.c:93
+#: ../vector/v.lidar.edgedetection/main.c:73
+#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
+msgid "LIDAR"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:165
+msgid "Create a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:169
+#, fuzzy
+msgid "LiDAR LAS input file"
+msgstr "है n"
+#: ../raster/r.in.lidar/main.c:177 ../raster/r.in.xyz/main.c:176
+#, fuzzy
+msgid "Statistic to use for raster values"
+msgstr "के लिए."
+#: ../raster/r.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:221
+#: ../raster/r.in.lidar/main.c:230 ../raster/r.in.xyz/main.c:180
+#: ../raster/r.in.xyz/main.c:248 ../raster/r.in.xyz/main.c:257
+msgid "Statistic"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:189 ../raster/r.in.xyz/main.c:188
+#: ../raster/r.in.arc/main.c:81
+#, fuzzy
+msgid "Storage type for resultant raster map"
+msgstr "के लिए"
+#: ../raster/r.in.lidar/main.c:196 ../raster/r.in.xyz/main.c:223
+#, fuzzy
+msgid "Filter range for z data (min,max)"
+msgstr "पूर्णांक"
+#: ../raster/r.in.lidar/main.c:203 ../raster/r.in.xyz/main.c:230
+msgid "Scale to apply to z data"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:220 ../raster/r.in.xyz/main.c:247
+#, fuzzy
+msgid "pth percentile of the values"
+msgstr "के लिए ढाल"
+#: ../raster/r.in.lidar/main.c:229 ../raster/r.in.xyz/main.c:256
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:222
+#: ../vector/v.in.lidar/main.c:203
+msgid "Override dataset projection (use location's projection)"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:239 ../raster/r.in.xyz/main.c:261
+msgid "Scan data file for extent then exit"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:266
+#, fuzzy
+msgid "In scan mode, print using shell script style"
+msgstr "छापें"
+#: ../raster/r.in.lidar/main.c:263 ../vector/v.in.lidar/main.c:238
+#, c-format
+msgid "Input file <%s> is not a LAS LiDAR point cloud"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:281 ../vector/v.in.ogr/main.c:501
+#: ../vector/v.in.lidar/main.c:372
+#, fuzzy
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr "के लिए"
+#: ../raster/r.in.lidar/main.c:311 ../vector/v.in.ogr/main.c:531
+#: ../vector/v.in.lidar/main.c:405
+#, fuzzy
+msgid "GRASS LOCATION PROJ_INFO is:\n"
+msgstr "n"
+#: ../raster/r.in.lidar/main.c:371 ../vector/v.in.ogr/main.c:591
+#: ../vector/v.in.lidar/main.c:465
+#, fuzzy, c-format
+msgid ""
+"\n"
+"You can use the -o flag to %s to override this projection check.\n"
+msgstr "n"
+#: ../raster/r.in.lidar/main.c:374 ../vector/v.in.ogr/main.c:594
+#: ../vector/v.in.lidar/main.c:468
+#, fuzzy
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
+msgstr "a सेट n"
+#: ../raster/r.in.lidar/main.c:391 ../raster/r.in.xyz/main.c:307
+#, fuzzy
+msgid "Invalid zrange"
+msgstr "के लिए थीटा"
+#: ../raster/r.in.lidar/main.c:485 ../raster/r.in.xyz/main.c:394
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:497 ../raster/r.in.xyz/main.c:406
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:560 ../raster/r.in.xyz/main.c:488
+msgid "zrange will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:579 ../raster/r.in.xyz/main.c:524
+#, fuzzy
+msgid "Reading data ..."
+msgstr "n"
+#: ../raster/r.in.lidar/main.c:596
+#, fuzzy
+msgid "Could not rewind input file"
+msgstr "नहीं"
+#: ../raster/r.in.lidar/main.c:757 ../raster/r.in.xyz/main.c:721
+#, fuzzy
+msgid "Writing to map ..."
+msgstr "n"
+#: ../raster/r.in.lidar/main.c:1103 ../raster/r.in.xyz/main.c:1059
+#, fuzzy, c-format
+msgid "%lu points found in region."
+msgstr "नहीं"
+#: ../raster/r.in.lidar/main.c:1127 ../raster/r.in.xyz/main.c:1086
+#, fuzzy
+msgid "Scanning data ..."
+msgstr "n"
+#: ../raster/r.in.lidar/main.c:1178 ../raster/r.in.xyz/main.c:1174
+#, c-format
+msgid "Range:     min         max\n"
+msgstr ""
 #: ../raster/r.proj/main.c:147 ../general/g.proj/main.c:61
 #: ../general/g.setproj/main.c:79 ../vector/v.proj/main.c:64
 #: ../locale/scriptstrings/m.proj_to_translate.c:3
@@ -8834,12 +8990,6 @@
 msgid "Unable to open TIFF world file for writing"
 msgstr "के लिए"
-#: ../raster/r.in.xyz/main.c:162 ../vector/v.surf.bspline/main.c:93
-#: ../vector/v.lidar.edgedetection/main.c:73
-#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
-msgid "LIDAR"
-msgstr ""
 #: ../raster/r.in.xyz/main.c:164
 msgid ""
 "Create a raster map from an assemblage of many coordinates using univariate "
@@ -8851,21 +9001,6 @@
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
 msgstr "उत्तर पूर्व"
-#: ../raster/r.in.xyz/main.c:176
-#, fuzzy
-msgid "Statistic to use for raster values"
-msgstr "के लिए."
-#: ../raster/r.in.xyz/main.c:180 ../raster/r.in.xyz/main.c:248
-#: ../raster/r.in.xyz/main.c:257
-msgid "Statistic"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.arc/main.c:81
-#, fuzzy
-msgid "Storage type for resultant raster map"
-msgstr "के लिए"
 #: ../raster/r.in.xyz/main.c:199
 #, fuzzy
 msgid "Column number of x coordinates in input file (first column is 1)"
@@ -8881,35 +9016,6 @@
 msgid "Column number of data values in input file"
 msgstr "का"
-#: ../raster/r.in.xyz/main.c:223
-#, fuzzy
-msgid "Filter range for z data (min,max)"
-msgstr "पूर्णांक"
-#: ../raster/r.in.xyz/main.c:230
-msgid "Scale to apply to z data"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:247
-#, fuzzy
-msgid "pth percentile of the values"
-msgstr "के लिए ढाल"
-#: ../raster/r.in.xyz/main.c:256
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:261
-msgid "Scan data file for extent then exit"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:266
-#, fuzzy
-msgid "In scan mode, print using shell script style"
-msgstr "छापें"
 #: ../raster/r.in.xyz/main.c:270
 msgid "Ignore broken lines"
 msgstr ""
@@ -8919,33 +9025,11 @@
 msgid "Please specify a reasonable column number."
 msgstr "ज़ेड."
-#: ../raster/r.in.xyz/main.c:307
-#, fuzzy
-msgid "Invalid zrange"
-msgstr "के लिए थीटा"
-#: ../raster/r.in.xyz/main.c:394
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:406
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
 #: ../raster/r.in.xyz/main.c:482
 msgid ""
 "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:488
-msgid "zrange will not be taken into account during scan"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:524
-#, fuzzy
-msgid "Reading data ..."
-msgstr "n"
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
 #: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
@@ -8974,26 +9058,6 @@
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:721
-#, fuzzy
-msgid "Writing to map ..."
-msgstr "n"
-#: ../raster/r.in.xyz/main.c:1059
-#, fuzzy, c-format
-msgid "%lu points found in region."
-msgstr "नहीं"
-#: ../raster/r.in.xyz/main.c:1086
-#, fuzzy
-msgid "Scanning data ..."
-msgstr "n"
-#: ../raster/r.in.xyz/main.c:1174
-#, c-format
-msgid "Range:     min         max\n"
-msgstr ""
 #: ../raster/r.texture/main.c:79
 #, fuzzy
 msgid "Generate images with textural features from a raster map."
@@ -11151,7 +11215,7 @@
 #: ../raster/r.to.vect/main.c:97 ../raster/r.to.vect/main.c:104
 #: ../vector/v.in.ogr/main.c:192 ../vector/v.in.ogr/main.c:217
-#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:184
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:198
 #: ../vector/v.to.rast/main.c:74 ../vector/v.to.rast/main.c:80
 #: ../vector/v.to.rast/main.c:86
 #, fuzzy
@@ -11200,7 +11264,7 @@
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
 #: ../vector/v.in.ogr/main.c:927 ../vector/v.random/main.c:294
-#: ../vector/v.in.lidar/main.c:696
+#: ../vector/v.in.lidar/main.c:755
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr ""
@@ -18170,8 +18234,7 @@
 msgstr "के लिए"
 #: ../vector/v.out.svg/main.c:370 ../vector/v.lrs/v.lrs.label/main.c:348
-#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.out.ogr/attrb.c:51
-#: ../vector/v.overlay/main.c:363
+#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.overlay/main.c:363
 #, fuzzy
 msgid "Unable to fetch data from table"
 msgstr "सभी"
@@ -18684,18 +18747,18 @@
 "\t\tMapInfo File: mapinfo file name"
 msgstr "n n फ़ाइल"
-#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:163
+#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:169
 #, fuzzy
 msgid "Import subregion only"
 msgstr "छापें"
 #: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:226
-#: ../vector/v.in.lidar/main.c:164 ../vector/v.in.lidar/main.c:193
+#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:207
 #, fuzzy
 msgid "Subregion"
 msgstr "n"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:166
+#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:172
 #, fuzzy
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr "आयात प"
@@ -18757,16 +18820,12 @@
 #: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:79
 #: ../vector/v.voronoi/main.c:138 ../vector/v.overlay/main.c:123
-#: ../vector/v.in.lidar/main.c:183 ../vector/v.to.points/main.c:215
+#: ../vector/v.in.lidar/main.c:197 ../vector/v.to.points/main.c:215
 #, fuzzy
 msgid "Do not create attribute table"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:222 ../vector/v.in.lidar/main.c:189
-msgid "Override dataset projection (use location's projection)"
-msgstr ""
-#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:194
+#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:208
 #, fuzzy
 msgid "Limit import to the current region"
 msgstr "नहीं"
@@ -18775,7 +18834,7 @@
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:204
+#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:218
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
@@ -18795,12 +18854,12 @@
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:252
+#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:272
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "i n"
-#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:255
+#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:275
 #: ../vector/v.edit/main.c:88
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists"
@@ -18811,41 +18870,15 @@
 msgid "Layer <%s> not available"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:263
+#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:294
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:291
+#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:322
 #, fuzzy
 msgid "4 parameters required for 'spatial' parameter"
 msgstr "के लिए."
-#: ../vector/v.in.ogr/main.c:501 ../vector/v.in.lidar/main.c:341
-#, fuzzy
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr "के लिए"
-#: ../vector/v.in.ogr/main.c:531 ../vector/v.in.lidar/main.c:374
-#, fuzzy
-msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:591 ../vector/v.in.lidar/main.c:434
-#, fuzzy, c-format
-msgid ""
-"\n"
-"You can use the -o flag to %s to override this projection check.\n"
-msgstr "n"
-#: ../vector/v.in.ogr/main.c:594 ../vector/v.in.lidar/main.c:437
-#, fuzzy
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr "a सेट n"
 #: ../vector/v.in.ogr/main.c:617
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
@@ -18883,7 +18916,7 @@
 msgid "Column type not supported (%s)"
 msgstr "नहीं"
-#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:558
+#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:589
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "स्रोत"
@@ -18937,27 +18970,27 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1017
+#, fuzzy
+msgid "Merge boundaries:"
+msgstr "n"
+#: ../vector/v.in.ogr/main.c:1022
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1021
+#: ../vector/v.in.ogr/main.c:1026
 #, fuzzy
 msgid "Remove dangles:"
 msgstr "के लिए n"
-#: ../vector/v.in.ogr/main.c:1027
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1031
+#: ../vector/v.in.ogr/main.c:1036
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1037
-#, fuzzy
-msgid "Merge boundaries:"
-msgstr "n"
 #: ../vector/v.in.ogr/main.c:1055 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:607 ../vector/v.buffer/main.c:699
 msgid "Cannot calculate area centroid"
@@ -19872,7 +19905,7 @@
 msgstr "फंक्शन"
 #: ../vector/v.random/main.c:142 ../vector/v.in.dxf/main.c:80
-#: ../vector/v.in.lidar/main.c:209 ../vector/v.external/args.c:53
+#: ../vector/v.in.lidar/main.c:223 ../vector/v.external/args.c:53
 #: ../vector/v.edit/args.c:216
 #, fuzzy
 msgid "Do not build topology"
@@ -21749,7 +21782,7 @@
 msgid "Cannot select attributes for cat = %d"
 msgstr "के लिए"
-#: ../vector/v.out.ogr/attrb.c:64
+#: ../vector/v.out.ogr/attrb.c:58
 #, fuzzy, c-format
 msgid "No database record for cat = %d and export of 'cat' disabled"
 msgstr "नहीं के लिए"
@@ -23767,45 +23800,64 @@
 msgid "[%d] categories read into memory"
 msgstr "n"
-#: ../vector/v.in.lidar/main.c:149
+#: ../vector/v.in.lidar/main.c:155
 #, fuzzy
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
 msgstr "n"
-#: ../vector/v.in.lidar/main.c:152
+#: ../vector/v.in.lidar/main.c:158
 #, fuzzy
 msgid "LAS input file"
 msgstr "है n"
-#: ../vector/v.in.lidar/main.c:153
+#: ../vector/v.in.lidar/main.c:159
 msgid "LiDAR input files in LAS format (*.las or *.laz)"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:178
+#: ../vector/v.in.lidar/main.c:185
+msgid "Only import points of selected return type"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:186
 #, fuzzy
+msgid "If not specified, all points are imported"
+msgstr "बिन्दु"
+#: ../vector/v.in.lidar/main.c:192
+#, fuzzy
 msgid "Print LAS file info and exit"
 msgstr "छापें का"
-#: ../vector/v.in.lidar/main.c:591
+#: ../vector/v.in.lidar/main.c:289
 #, fuzzy, c-format
+msgid "Unknown filter option <%s>"
+msgstr "अज्ञात क़िस्म"
+#: ../vector/v.in.lidar/main.c:623
+#, fuzzy, c-format
 msgid "Importing %d points..."
 msgstr "n"
-#: ../vector/v.in.lidar/main.c:719
+#: ../vector/v.in.lidar/main.c:778
 #, fuzzy, c-format
 msgid "%d points imported"
 msgstr "लोड हो गया n"
-#: ../vector/v.in.lidar/main.c:721
+#: ../vector/v.in.lidar/main.c:780
 #, c-format
 msgid "%d input points were not valid"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:723
+#: ../vector/v.in.lidar/main.c:782
 #, fuzzy, c-format
 msgid "%d input points were outside of the selected area"
 msgstr "बिन्दु n"
+#: ../vector/v.in.lidar/main.c:784
+#, fuzzy, c-format
+msgid "%d input points were filtered by return number"
+msgstr "बिन्दु n"
 #: ../vector/v.net.flow/main.c:60
 msgid "flow"
 msgstr ""
@@ -29747,6 +29799,46 @@
 msgid "Uncompressed geonames file from (with .txt extension)"
 msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:1
+msgid "Download several tiles of MODIS products using pyModis"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:3
+#, fuzzy
+msgid "Name of MODIS product"
+msgstr "का"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:4
+msgid "Name of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:5
+msgid "Password of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:6
+msgid "Folder where saves the data, full path"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:7
+#, fuzzy
+msgid "The names of tile/s to download"
+msgstr "संख्या का"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:8
+msgid "The day from start download. If not set the download starts from today"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:9
+msgid ""
+"The day to stop download. If not set the download stops 10 day before the "
+"start day"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:10
+msgid "For debug mode, it will write more info in the log file"
+msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
 msgid ""
 "Export a raster map to a text file as x,y,z values based on cell centers."
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_it.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_it\n"
 "PO-Revision-Date: 2008-03-26 17:32+0100\n"
 "Last-Translator: Marco Curreli <marcocurreli at tiscali it>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
@@ -268,13 +268,14 @@
@@ -377,18 +378,18 @@
@@ -443,6 +444,7 @@
@@ -1683,7 +1685,8 @@
 msgstr "Coordinate est non valide <%s>, vengono tralasciate."
 #, c-format
 msgstr ""
@@ -1738,7 +1741,7 @@
@@ -1865,7 +1868,7 @@
@@ -1876,7 +1879,7 @@
 #, fuzzy, c-format
@@ -1888,7 +1891,7 @@
 #, fuzzy, c-format
@@ -2364,7 +2367,7 @@
 "esclusi."
 msgstr "Percentuale di mappa da tenere in memoria"
@@ -2606,7 +2609,7 @@
 msgstr ""
 msgstr "Nome della nuova locazione da creare"
@@ -2615,7 +2618,7 @@
 msgstr "Sovrascrive la proiezione (usa la proiezione della location)"
 msgstr ""
@@ -2681,7 +2684,7 @@
 msgstr ""
 msgid ""
 "location."
@@ -2690,7 +2693,7 @@
 "formato di GRASS; impossibile creare una nuova location."
 #, c-format
 msgstr "Location <%s> creata"
@@ -2701,13 +2704,15 @@
 "for checking"
 msgstr ""
 msgstr ""
 msgid ""
 "\n"
@@ -2725,9 +2730,10 @@
 msgstr "PROJ_INFO del dataset è:\n"
 msgstr ""
@@ -2749,8 +2755,9 @@
 "Si prenda in considerazione di generare una nuova location dal dataset di "
 "input usando il parametro location\n"
 msgstr ""
 "La proiezione del dataset di input e della location corrente sembrano "
@@ -6807,7 +6814,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7750,6 +7757,151 @@
 msgstr "Nome della mappa raster risultante"
+msgid "LIDAR"
+msgstr ""
+#, fuzzy
+msgstr ""
+"Crea un raster da un assemblaggio di molte coordinate usando statistiche "
+"univariate"
+#, fuzzy
+msgstr "File di input"
+msgstr ""
+msgid "Statistic"
+msgstr ""
+msgstr "Tipo di dati memorizzati per la mappa raster risultante"
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"observations"
+msgstr ""
+#, fuzzy
+msgstr "Sovrascrive la proiezione (utilizza quella della locazione)"
+msgstr ""
+#, fuzzy
+msgstr "In modalità scansione, stampa usando lo stile dello script di shell"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+msgstr "GRASS LOCATION PROJ_INFO è:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Lettura dei dati in corso ..."
+#, fuzzy
+msgstr "Impossibile aprire il file di output <%s>"
+#, fuzzy
+msgstr "Scrittura della mappa in corso ..."
+#, fuzzy, c-format
+msgstr "Tovati %lu punti nella regione."
+#, fuzzy
+msgstr "Scansione dei dati in corso ..."
+#, c-format
+msgstr "Campo di variazione:     min         max\n"
@@ -8631,12 +8783,6 @@
 msgstr "Impossibile aprire il  file TIFF  World per la scrittura"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8651,19 +8797,6 @@
 msgstr ""
 "File ASCII contenente i dati di input (o \"-\" per leggere dallo stdin)"
-msgstr ""
-msgid "Statistic"
-msgstr ""
-msgstr "Tipo di dati memorizzati per la mappa raster risultante"
 msgstr ""
@@ -8676,33 +8809,6 @@
 msgstr ""
-msgstr ""
-msgstr ""
-msgstr ""
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "In modalità scansione, stampa usando lo stile dello script di shell"
 msgstr ""
@@ -8711,32 +8817,11 @@
 msgstr ""
-msgstr ""
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Lettura dei dati in corso ..."
 #, c-format
@@ -8765,26 +8850,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Scrittura della mappa in corso ..."
-#, fuzzy, c-format
-msgstr "Tovati %lu punti nella regione."
-#, fuzzy
-msgstr "Scansione dei dati in corso ..."
-#, c-format
-msgstr "Campo di variazione:     min         max\n"
 msgstr ""
@@ -10895,7 +10960,7 @@
 msgid "Attributes"
@@ -10943,7 +11008,7 @@
 #, c-format
 msgstr "Impossibile inserire una nuova regola: %s"
@@ -17683,8 +17748,7 @@
 msgstr "Non posso selezionare gli attributi per cat=%d"
 #, fuzzy
 msgstr "Non è possibile recuperare i dati dalla tabella"
@@ -18177,17 +18241,17 @@
 msgstr ""
 #, fuzzy
 msgstr "Importa solamente la sottoregione"
 msgid "Subregion"
 msgstr "Sottoregione"
 msgstr ""
@@ -18242,18 +18306,13 @@
 #, fuzzy
 msgstr "Non crea la tabella degli attributi"
 #, fuzzy
-msgstr "Sovrascrive la proiezione (utilizza quella della locazione)"
-#, fuzzy
 msgstr "Limita l'importazione alla regione corrente"
@@ -18261,7 +18320,7 @@
 msgstr ""
 msgid ""
@@ -18281,12 +18340,12 @@
 msgstr ""
 #, c-format
 msgstr "La mappa vettoriale <%s> esiste già e sarà sovrascritta"
 #, c-format
@@ -18297,37 +18356,14 @@
 msgstr "Layer <%s> non disponibile"
 msgstr ""
 msgstr ""
-msgid ""
-"checking"
-msgstr ""
-msgstr "GRASS LOCATION PROJ_INFO è:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -18365,7 +18401,7 @@
 msgstr "Tipo di colonna non supportato (%s)"
 #, fuzzy, c-format
 msgstr "Non è possibile aprire il database <%s> col driver <%s>"
@@ -18416,26 +18452,26 @@
 msgstr ""
+msgstr ""
 msgstr ""
 #, fuzzy
 msgstr "Rimuovi i doppi"
 msgstr ""
 msgstr ""
-msgstr ""
@@ -19342,7 +19378,7 @@
 msgstr "Usa la funzione drand48() invece di rand()"
 msgstr "Non costruisce la topologia"
@@ -21189,7 +21225,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -23170,45 +23206,64 @@
 msgstr ""
 #, fuzzy
 msgstr "Converte vettore OGR in vettore GRASS"
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Vengono importati i valori interi"
+#, fuzzy
 msgstr "Stampa la cronologia del raster invece delle informazioni"
 #, fuzzy, c-format
+msgstr "Opzione '%s' sconosciuta"
+#, fuzzy, c-format
 msgstr "Importando punti ..."
 #, fuzzy, c-format
 msgstr "%d categorie duplicate nel vettoriale"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d punti esterni ai limiti"
+#, fuzzy, c-format
+msgstr "%d punti esterni ai limiti"
 msgid "flow"
 msgstr ""
@@ -28954,6 +29009,44 @@
 msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_ja.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -13,7 +13,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ja\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2010-03-03 14:00+0900\n"
 "Last-Translator: AkiraTaniguchi <taniguti at apptec.co.jp>\n"
 "Language-Team: Japanese <grass-translations at lists.osgeo.org>\n"
@@ -256,13 +256,14 @@
@@ -361,18 +362,18 @@
@@ -427,6 +428,7 @@
@@ -1662,7 +1664,8 @@
 msgstr "無効な座標値(東) <%s> "
 #, c-format
 msgstr "#%d (%d中) 経過...  "
@@ -1715,7 +1718,7 @@
@@ -1839,7 +1842,7 @@
@@ -1850,7 +1853,7 @@
 #, c-format
@@ -1862,7 +1865,7 @@
 #, c-format
@@ -2331,7 +2334,7 @@
 msgstr "NULL値に代入する値(デフォルトではNULLセルは除外) "
 msgstr "メモリに残すマップの割合(%) "
@@ -2565,7 +2568,7 @@
 msgstr ""
 msgstr "作成するロケーション"
@@ -2574,7 +2577,7 @@
 msgstr "現在のロケーションの投影法を使用"
 msgstr "データセットをもとにロケーションを拡張"
@@ -2645,7 +2648,7 @@
 msgstr ""
 msgid ""
 "location."
@@ -2654,7 +2657,7 @@
 "できません"
 #, c-format
 msgstr "ロケーション <%s> が作成されました"
@@ -2666,13 +2669,15 @@
 msgstr ""
 "入力ラスターマップの投影情報をチェック用のGRASSフォーマットに変換できません"
 msgstr "最優先の投影チェック"
 msgid ""
 "\n"
@@ -2688,9 +2693,10 @@
 msgstr "データセットの PROJ_INFO 情報は:\n"
 msgstr "インポートしたデータセットの PROJ_INFOは次のとおり :\n"
@@ -2712,8 +2718,9 @@
 "'location'パラメータを用いて、入力データセットからの新規ロケーション作成を検"
 "討して下さい .\n"
 msgstr "入力データセットと現在領域の投影は整合しているようです"
@@ -6740,7 +6747,7 @@
 msgstr "セクション 1a (%1d中): メモリの初期化  "
 #, c-format
 msgstr "セクション 1b (%1d中): マップ外の流量を決定する.  "
@@ -7673,6 +7680,149 @@
 msgstr "NULL値に代入する値"
+msgid "LIDAR"
+msgstr ""
+#, fuzzy
+msgstr "一変量の統計で,多くの座標の集合からラスタマップを作成"
+#, fuzzy
+msgstr "入力するファイル"
+msgstr "ラスター値に使用する統計"
+msgid "Statistic"
+msgstr "統計量 "
+msgstr "保存形式 "
+msgstr "z データのフィルターレンジ (min,max)  "
+msgstr "z データに指定する縮尺"
+msgstr "pth の百分率値"
+msgid ""
+"observations"
+msgstr ""
+"観測した <trim> パーセント(最小側)および <trim> パーセント(最大側) を廃棄"
+msgstr "データセット投影を再定義します (現在のロケーションの投影法を使用)"
+msgstr "データ ファイルの範囲をスキャンして終了"
+msgstr "スキャンモードで,シェルスクリプト形式で出力"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr "入力マップ投影情報をチェックのためGRASSフォーマットに変換できません"
+msgstr "GRASS LOCATION PROJ_INFO は:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"この投影チェックのオーバーライドに -o フラッグから %s まで使用できます.\n"
+msgid ""
+"set.\n"
+msgstr ""
+"入力データセットから'ロケーション'パラメーターのある新しいロケーションを作成"
+"してください.\n"
+msgstr "不正なZ座標範囲"
+msgstr "pth オプションの指定無しでは,百分率を計算できません!"
+msgstr "trim オプション無しでは,刈り込み平均を計算できません"
+msgstr "スキャン中,zrange は評価に取り込まれません"
+msgstr "データを読込中..."
+#, fuzzy
+msgstr "出力ファイル <%s> を開けませんでした"
+msgstr "マップを書出し中..."
+#, c-format
+msgstr "%lu 箇所が領域内に見つかりました"
+msgstr "データをスキャンしています..."
+#, c-format
+msgstr "範囲:       最小        最大\n"
@@ -8527,12 +8677,6 @@
 msgstr "TIFFワールドファイルを出力できません"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8543,19 +8687,6 @@
 msgstr "入力データを含む ASCII ファイル (または \"-\" で標準入力から)"
-msgstr "ラスター値に使用する統計"
-msgid "Statistic"
-msgstr "統計量 "
-msgstr "保存形式 "
 msgstr "入力ファイルの x 座標の列番号 (最初の列は 1)"
@@ -8568,33 +8699,6 @@
 msgstr "入力ファイルのデータ値の列番号"
-msgstr "z データのフィルターレンジ (min,max)  "
-msgstr "z データに指定する縮尺"
-msgstr "pth の百分率値"
-msgid ""
-"observations"
-msgstr ""
-"観測した <trim> パーセント(最小側)および <trim> パーセント(最大側) を廃棄"
-msgstr "データ ファイルの範囲をスキャンして終了"
-msgstr "スキャンモードで,シェルスクリプト形式で出力"
 msgstr "切れたラインは無視する  "
@@ -8603,31 +8707,11 @@
 msgstr "妥当な列番号を指定して下さい"
-msgstr "不正なZ座標範囲"
-msgstr "pth オプションの指定無しでは,百分率を計算できません!"
-msgstr "trim オプション無しでは,刈り込み平均を計算できません"
 msgid ""
 msgstr "ファイルからの入力でない場合,単一パスだけが可能です"
-msgstr "スキャン中,zrange は評価に取り込まれません"
-msgstr "データを読込中..."
 #, c-format
@@ -8659,24 +8743,6 @@
 msgstr "不正な z-座標 ライン %lu 列 %d. <%s>  "
-msgstr "マップを書出し中..."
-#, c-format
-msgstr "%lu 箇所が領域内に見つかりました"
-msgstr "データをスキャンしています..."
-#, c-format
-msgstr "範囲:       最小        最大\n"
 msgstr "ラスターマップからテクスチャーフィーチャー画像を作成"
@@ -10796,7 +10862,7 @@
 msgid "Attributes"
@@ -10847,7 +10913,7 @@
 #, c-format
 msgstr "新しい行: %s を挿入できません"
@@ -17606,8 +17672,7 @@
 msgstr "cat=%d の属性を選択できません"
 msgstr "表からデータを取得できません"
@@ -18106,16 +18171,16 @@
 "\t\tESRIシェープファイル:シェープファイル名\n"
 "\t\tマップ情報ファイル:マップ情報ファイル名"
 msgstr "小領域のみインポートします"
 msgid "Subregion"
 msgstr "小領域"
 msgstr "フォーマット:xmin,ymin,xmax,ymax - 通常は西、南、東、北"
@@ -18172,15 +18237,11 @@
 msgstr "属性テーブルを作成しないで下さい"
-msgstr "データセット投影を再定義します (現在のロケーションの投影法を使用)"
 msgstr "インポートをこの領域に限定します"
@@ -18188,7 +18249,7 @@
 msgstr "行名を小文字に変換"
 msgid ""
@@ -18208,12 +18269,12 @@
 msgstr "データソースは %d レイヤーあります"
 #, c-format
 msgstr "ベクトルマップ <%s> は既に存在し上書きされません"
 #, c-format
@@ -18224,41 +18285,14 @@
 msgstr "レイヤー <%s> は利用できません"
 msgstr "現在の範囲フラッグか空間オプションの片方だけを選択してください"
 msgstr "「空間」パラメーターには4変数が必要"
-msgid ""
-"checking"
-msgstr "入力マップ投影情報をチェックのためGRASSフォーマットに変換できません"
-msgstr "GRASS LOCATION PROJ_INFO は:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"この投影チェックのオーバーライドに -o フラッグから %s まで使用できます.\n"
-msgid ""
-"set.\n"
-msgstr ""
-"入力データセットから'ロケーション'パラメーターのある新しいロケーションを作成"
-"してください.\n"
 #, fuzzy, c-format
@@ -18301,7 +18335,7 @@
 msgstr "列タイプはサポートされていません (%s)"
 #, c-format
 msgstr "ドライバー <%s> でデータベース <%s> を開けません"
@@ -18352,27 +18386,27 @@
 msgstr "ノードにある境界を除去します:"
+#, fuzzy
+msgstr "境界をくずします:"
 msgstr "境界ダングルをラインに変更します:"
 #, fuzzy
 msgstr "ぶら下がりを削除"
 msgstr "境界ブリッジをラインに変更します:"
 msgstr "ブリッジを除去します:"
-#, fuzzy
-msgstr "境界をくずします:"
@@ -19291,7 +19325,7 @@
 msgstr "rand() の代わりに drand48()機能を使用してください"
 msgstr "トポロジー作成不可"
@@ -21133,7 +21167,7 @@
 msgstr " cat = %d の属性を選択できません"
 #, c-format
 msgstr ""
@@ -23121,45 +23155,64 @@
 msgstr "[%d] のカテゴリーをメモリに読み込む"
 #, fuzzy
 msgstr "OGRベクトルレイヤーをGRASSベクトルマップに変換します."
 #, fuzzy
 msgstr "入力するファイル"
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "整数データをインポート"
+#, fuzzy
 msgstr "情報の代わりに履歴を出力します"
 #, fuzzy, c-format
+msgstr "不明なルールオプション:'%s'"
+#, fuzzy, c-format
 msgstr "ポイントをインポート中、、、"
 #, fuzzy, c-format
 msgstr "タイトル"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d のポイントが閾値外"
+#, fuzzy, c-format
+msgstr "%d のポイントが閾値外"
 msgid "flow"
 msgstr ""
@@ -28882,6 +28935,46 @@
 msgstr "解凍された geonamesファイル( .txt 拡張子)  "
+msgstr ""
+#, fuzzy
+msgstr "入力するファイル"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "割り当てるポイントの数"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_ko.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ko\n"
 "PO-Revision-Date: 2005-08-09 22:53-0500\n"
 "Last-Translator: Huidae Cho\n"
 "Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -246,13 +246,14 @@
@@ -349,18 +350,18 @@
@@ -415,6 +416,7 @@
@@ -1604,7 +1606,8 @@
 msgstr "출력할 래스터맵"
 #, c-format
 msgstr ""
@@ -1658,7 +1661,7 @@
@@ -1782,7 +1785,7 @@
@@ -1793,7 +1796,7 @@
 #, fuzzy, c-format
@@ -1805,7 +1808,7 @@
 #, fuzzy, c-format
@@ -2269,7 +2272,7 @@
 msgstr ""
 msgstr ""
@@ -2502,7 +2505,7 @@
 msgstr ""
 msgstr ""
@@ -2511,7 +2514,7 @@
 msgstr ""
 msgstr ""
@@ -2577,14 +2580,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr ""
 #, c-format
 msgstr ""
@@ -2595,14 +2598,16 @@
 "for checking"
 msgstr ""
 #, fuzzy
 msgstr "출력할 래스터맵"
 msgid ""
 "\n"
@@ -2616,9 +2621,10 @@
 msgstr ""
 msgstr ""
@@ -2635,8 +2641,9 @@
 msgstr ""
 msgstr ""
@@ -6566,7 +6573,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7491,6 +7498,144 @@
 msgstr ""
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "출력할 래스터맵"
+msgstr ""
+msgid "Statistic"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"observations"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+msgstr ""
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "출력할 래스터맵"
+#, fuzzy
+msgstr "출력할 래스터맵"
+msgstr ""
+#, fuzzy, c-format
+msgstr "출력할 래스터맵"
+msgstr ""
+#, c-format
+msgstr ""
@@ -8323,12 +8468,6 @@
 msgstr "출력할 래스터맵"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8339,19 +8478,6 @@
 msgstr ""
-msgstr ""
-msgid "Statistic"
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8364,32 +8490,6 @@
 msgstr ""
-msgstr ""
-msgstr ""
-msgstr ""
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8398,32 +8498,11 @@
 msgstr ""
-msgstr ""
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "출력할 래스터맵"
 #, c-format
@@ -8452,24 +8531,6 @@
 msgstr ""
-msgstr ""
-#, fuzzy, c-format
-msgstr "출력할 래스터맵"
-msgstr ""
-#, c-format
-msgstr ""
 msgstr ""
@@ -10538,7 +10599,7 @@
 #, fuzzy
@@ -10586,7 +10647,7 @@
 #, c-format
 msgstr ""
@@ -17089,8 +17150,7 @@
 msgstr ""
 #, fuzzy
 msgstr "출력할 래스터맵"
@@ -17576,16 +17636,16 @@
 msgstr ""
 msgstr ""
 msgid "Subregion"
 msgstr ""
 msgstr ""
@@ -17639,15 +17699,11 @@
 msgstr ""
-msgstr ""
 msgstr ""
@@ -17655,7 +17711,7 @@
 msgstr ""
 msgid ""
@@ -17675,12 +17731,12 @@
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
@@ -17691,37 +17747,14 @@
 msgstr "출력할 래스터맵"
 msgstr ""
 msgstr ""
-msgid ""
-"checking"
-msgstr ""
-msgstr ""
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -17759,7 +17792,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "출력할 래스터맵"
@@ -17810,27 +17843,27 @@
 msgstr ""
+#, fuzzy
+msgstr "출력할 래스터맵"
 msgstr ""
 #, fuzzy
 msgstr "출력할 래스터맵"
 msgstr ""
 msgstr ""
-#, fuzzy
-msgstr "출력할 래스터맵"
@@ -18710,7 +18743,7 @@
 msgstr ""
 msgstr ""
@@ -20478,7 +20511,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -22408,44 +22441,62 @@
 msgstr ""
 #, fuzzy
 msgstr "출력할 래스터맵"
 #, fuzzy
 msgstr "출력할 래스터맵"
 msgstr ""
+msgstr ""
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
+msgstr "출력할 래스터맵"
+#, fuzzy, c-format
 msgstr "출력할 래스터맵"
 #, fuzzy, c-format
 msgstr "출력할 래스터맵"
 #, c-format
 msgstr ""
 #, c-format
 msgstr ""
+#, c-format
+msgstr ""
 msgid "flow"
 msgstr ""
@@ -28051,6 +28102,44 @@
 msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_lv.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_lv\n"
 "PO-Revision-Date: 2006-12-09 01:04+0200\n"
 "Last-Translator: Maris Nartiss <maris.kde at gmail.com>\n"
 "Language-Team: Latvian <grass-translations at lists.osgeo.org>\n"
@@ -255,13 +255,14 @@
@@ -362,18 +363,18 @@
@@ -428,6 +429,7 @@
@@ -1642,7 +1644,8 @@
 msgstr "x koordināte"
 #, c-format
 msgstr ""
@@ -1696,7 +1699,7 @@
@@ -1822,7 +1825,7 @@
@@ -1833,7 +1836,7 @@
 #, fuzzy, c-format
@@ -1845,7 +1848,7 @@
 #, fuzzy, c-format
@@ -2323,7 +2326,7 @@
 msgstr ""
 msgstr ""
@@ -2557,7 +2560,7 @@
 msgstr ""
 msgstr "Janveidojamā novietojuma nosaukums"
@@ -2566,7 +2569,7 @@
 msgstr "Neņemt vērā projekciju (izmantot pašreizējā novietojuma projekciju)"
 msgstr "Paplašināt novietojuma apjomu pamatojoties uz jauno datu kopu"
@@ -2634,14 +2637,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr ""
 #, fuzzy, c-format
 msgstr "Novietojums %s ir izveidots!"
@@ -2652,14 +2655,16 @@
 "for checking"
 msgstr ""
 #, fuzzy
 msgstr "Ignorē projekciju pārbaudi."
 msgid ""
 "\n"
@@ -2674,9 +2679,10 @@
 msgstr ""
 #, fuzzy
 msgstr "nevar atvērt %s"
@@ -2694,8 +2700,9 @@
 msgstr ""
 msgstr ""
@@ -6717,7 +6724,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7657,6 +7664,151 @@
 msgstr "Rastra kartes nosaukums"
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Ieejas fails"
+msgstr ""
+msgid "Statistic"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Izejas karte kurā tiks ierakstīti punkti"
+msgid ""
+"observations"
+msgstr ""
+#, fuzzy
+msgstr "Neņemt vērā projekciju (izmantot pašreizējā novietojuma projekciju)"
+msgstr ""
+#, fuzzy
+msgstr "Drukāt statistiku komandrindas skripta stilā"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+#, fuzzy
+msgstr "nevar atvērt %s"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+#, fuzzy
+msgstr "nederīgs reģions: %s"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Drukā ... "
+#, fuzzy
+msgstr "nevar atvērt vektorfailu <%s> iekš <%s>"
+#, fuzzy
+msgstr "Rakstu jaunu failu... \n"
+#, fuzzy, c-format
+msgstr "Drukāt tekošo reģionu pēc platuma/garuma"
+#, fuzzy
+#, c-format
+msgstr ""
@@ -8517,12 +8669,6 @@
 msgstr "Neiespējami atvērt šūnu failu[%s]"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8534,19 +8680,6 @@
 msgstr "ASCII fails ar ievades datiem"
-msgstr ""
-msgid "Statistic"
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8559,34 +8692,6 @@
 msgstr ""
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Izejas karte kurā tiks ierakstīti punkti"
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Drukāt statistiku komandrindas skripta stilā"
 msgstr ""
@@ -8595,33 +8700,11 @@
 msgstr ""
-#, fuzzy
-msgstr "nederīgs reģions: %s"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Drukā ... "
 #, c-format
@@ -8650,26 +8733,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Rakstu jaunu failu... \n"
-#, fuzzy, c-format
-msgstr "Drukāt tekošo reģionu pēc platuma/garuma"
-#, fuzzy
-#, c-format
-msgstr ""
 #, fuzzy
@@ -10812,7 +10875,7 @@
 #, fuzzy
@@ -10860,7 +10923,7 @@
 #, c-format
 msgstr "Nevar izveidot jaunu rindu: %s"
@@ -17591,8 +17654,7 @@
 msgstr "Nevar iatlasīt datus no tabulas"
 #, fuzzy
 msgstr "Nevar atlasīt datus no tabulas"
@@ -18102,17 +18164,17 @@
 "\t\tESRI Shapefile: faila nosaukums\n"
 "\t\tMapInfo fails: mapinfo faila nosaukums"
 #, fuzzy
 msgstr "Drukāt tikai rastra kartes reģionu"
 msgid "Subregion"
 msgstr ""
 msgstr ""
@@ -18168,18 +18230,13 @@
 #, fuzzy
 msgstr "Nevajag taisīt atribūtu tabulu"
 #, fuzzy
-msgstr "Neņemt vērā projekciju (izmantot pašreizējā novietojuma projekciju)"
-#, fuzzy
 msgstr "Sākuma punkts ir ārpus pašreizējā reģiona."
@@ -18187,7 +18244,7 @@
 msgstr ""
 msgid ""
@@ -18207,12 +18264,12 @@
 msgstr ""
 #, fuzzy, c-format
 #, fuzzy, c-format
@@ -18223,38 +18280,14 @@
 msgstr "rastra karte <%s> nav atrasta"
 msgstr ""
 msgstr ""
-msgid ""
-"checking"
-msgstr ""
-#, fuzzy
-msgstr "nevar atvērt %s"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -18294,7 +18327,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Nevar atvērt datubāzi  %s pēc adreses %s"
@@ -18346,27 +18379,27 @@
 msgstr ""
+#, fuzzy
 msgstr ""
 #, fuzzy
 msgstr ""
 msgstr ""
-#, fuzzy
@@ -19280,7 +19313,7 @@
 msgstr ""
 msgstr ""
@@ -21140,7 +21173,7 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Datubāzes konekcija nav definēta"
@@ -23153,45 +23186,64 @@
 msgstr "%-5d kategorijas ielasītas atmiņā.\n"
 #, fuzzy
 msgstr "Konvertē OGR vektorus uz GRASS vektoriem. Pieejamie draiveri:\n"
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Importējamais rastra fails"
+#, fuzzy
 msgstr "Eksistējošas rastra kartes nosaukums"
 #, fuzzy, c-format
+msgstr "Nezināms/nepazīstms tips"
+#, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "%d punkti ielādēti\n"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "%d punkti ielādēti\n"
 msgid "flow"
 msgstr ""
@@ -29072,6 +29124,45 @@
 msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Līniju skaits"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_mr.po
--- grass/trunk/locale/po/grassmods_mr.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_mr.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: Grass 6.0\n"
 "PO-Revision-Date: 2005-06-02 18:00+0530\n"
 "Last-Translator: Swapnil Hajare <dreamil at gmail.com>\n"
 "Language-Team: Marathi <www.janabhaaratii.org.in>\n"
@@ -245,13 +245,14 @@
@@ -351,18 +352,18 @@
@@ -417,6 +418,7 @@
@@ -1617,7 +1619,8 @@
 msgstr "तक्त्याचे नाव"
 #, c-format
 msgstr ""
@@ -1671,7 +1674,7 @@
@@ -1795,7 +1798,7 @@
@@ -1806,7 +1809,7 @@
 #, fuzzy, c-format
@@ -1818,7 +1821,7 @@
 #, fuzzy, c-format
@@ -2283,7 +2286,7 @@
 msgstr ""
 msgstr ""
@@ -2516,7 +2519,7 @@
 msgstr ""
 msgstr ""
@@ -2525,7 +2528,7 @@
 msgstr ""
 msgstr ""
@@ -2591,14 +2594,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr ""
 #, fuzzy, c-format
@@ -2609,14 +2612,16 @@
 "for checking"
 msgstr ""
 #, fuzzy
 msgstr "'%s'. ड्राइवर चालू होत नाही"
 msgid ""
 "\n"
@@ -2630,9 +2635,10 @@
 msgstr ""
 msgstr ""
@@ -2649,8 +2655,9 @@
 msgstr ""
 msgstr ""
@@ -6600,7 +6607,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7527,6 +7534,145 @@
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "तक्त्याचे नाव"
+msgstr ""
+msgid "Statistic"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"observations"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+msgstr ""
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+#, fuzzy
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "'%s'. ड्राइवर चालू होत नाही"
+#, fuzzy
+msgstr ""
+#, fuzzy, c-format
+msgstr ""
+#, c-format
+msgstr ""
@@ -8369,12 +8515,6 @@
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8385,19 +8525,6 @@
 msgstr ""
-msgstr ""
-msgid "Statistic"
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8410,32 +8537,6 @@
 msgstr ""
-msgstr ""
-msgstr ""
-msgstr ""
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8444,33 +8545,11 @@
 msgstr ""
-#, fuzzy
-msgstr "तक्त्याचे नाव"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "'%s'. ड्राइवर चालू होत नाही"
 #, c-format
@@ -8499,24 +8578,6 @@
 msgstr ""
-msgstr ""
-#, fuzzy, c-format
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
@@ -10604,7 +10665,7 @@
 #, fuzzy
@@ -10652,7 +10713,7 @@
 #, c-format
 msgstr ""
@@ -17195,8 +17256,7 @@
 msgstr "डेटाबेसची यादी दाखवता येणार नाही"
 #, fuzzy
@@ -17687,16 +17747,16 @@
 msgstr ""
 msgstr ""
 msgid "Subregion"
 msgstr ""
 msgstr ""
@@ -17750,15 +17810,11 @@
 msgstr ""
-msgstr ""
 #, fuzzy
@@ -17767,7 +17823,7 @@
 msgstr ""
 msgid ""
@@ -17787,12 +17843,12 @@
 msgstr ""
 #, c-format
 msgstr ""
 #, fuzzy, c-format
@@ -17803,37 +17859,14 @@
 msgstr ""
 msgstr ""
-msgid ""
-"checking"
-msgstr ""
-msgstr ""
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -17871,7 +17904,7 @@
 msgstr ""
 #, fuzzy, c-format
@@ -17922,27 +17955,27 @@
 msgstr ""
+#, fuzzy
 msgstr ""
 #, fuzzy
 msgstr ""
 msgstr ""
-#, fuzzy
@@ -18833,7 +18866,7 @@
 msgstr ""
 msgstr ""
@@ -20632,7 +20665,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -22579,44 +22612,62 @@
 msgstr ""
 #, fuzzy
 #, fuzzy
 msgstr ""
+msgstr ""
+msgstr ""
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
 #, fuzzy, c-format
 #, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
 msgid "flow"
 msgstr ""
@@ -28278,6 +28329,44 @@
 msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_pl.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmodes_pl\n"
 "PO-Revision-Date: 2010-09-19 00:34+0100\n"
 "Last-Translator: Maciej Sieczka <msieczka at msieczka dot org>\n"
 "Language-Team: Polish <grass-translations at lists.osgeo.org>\n"
@@ -260,13 +260,14 @@
@@ -365,18 +366,18 @@
@@ -431,6 +432,7 @@
@@ -1656,7 +1658,8 @@
 msgstr "Pominięto niedozwoloną współrzędną wschodnią <%s>"
 #, c-format
 msgstr "Przebieg #%d (z %d)..."
@@ -1710,7 +1713,7 @@
@@ -1835,7 +1838,7 @@
@@ -1846,7 +1849,7 @@
 #, c-format
@@ -1858,7 +1861,7 @@
 #, c-format
@@ -2322,7 +2325,7 @@
 "obliczeń"
 msgstr "Procent mapy trzymany w pamięci"
@@ -2558,7 +2561,7 @@
 msgstr ""
 msgstr "Nazwa lokacji która ma być utworzona"
@@ -2567,7 +2570,7 @@
 msgstr "Forsuj projekcję (użyj projekcji z lokacji)"
 msgstr "Rozszerz zasięg lokacji opartej na nowych ustawieniach danych"
@@ -2635,14 +2638,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr ""
 #, c-format
 msgstr "Lokacja <%s> została stworzona"
@@ -2653,13 +2656,15 @@
 "for checking"
 msgstr ""
 msgstr ""
 #, fuzzy
 msgid ""
@@ -2675,9 +2680,10 @@
 msgstr ""
 msgstr ""
 msgstr ""
 msgstr ""
@@ -6759,7 +6766,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7690,6 +7697,149 @@
 msgstr "Nie można utworzyć mapy rastrowej %s"
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Plik wejściowy"
+#, fuzzy
+msgstr "Informacje statystyczne dla rastrowych warstw mapy."
+msgid "Statistic"
+msgstr "Statystyka"
+msgstr "Sposób przechowywania dla wynikowej mapy rastrowej"
+#, fuzzy
+msgstr "Zakres wartości całkowitych: min,max"
+msgstr ""
+#, fuzzy
+msgstr "ciąg znaków reprezentujący wartości rastra 'no data'"
+msgid ""
+"observations"
+msgstr ""
+#, fuzzy
+msgstr "Forsuj projekcję (użyj projekcji z lokacji)"
+msgstr ""
+#, fuzzy
+msgstr "Wyświetl ustawienia bieżącego regionu (styl skryptu powłoki)"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+msgstr ""
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+#, fuzzy
+msgstr "Niewłaściwy przedział czasowy"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr "Wczytywanie danych..."
+#, fuzzy
+msgstr "Nie można otworzyć pliku wyjściowego <%s>"
+msgstr "Zapis do mapy ..."
+#, fuzzy, c-format
+msgstr "%lu punktów znalezionych w regione."
+msgstr "Skanowanie danych..."
+#, c-format
+msgstr "Zakres:     min         max\n"
@@ -8573,12 +8723,6 @@
 msgstr "Nie mozna otworzyć pliku [%s] do odczytu"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8590,20 +8734,6 @@
 msgstr "Plik ascii zawierajÄ…cy sygnatury widmowe"
-#, fuzzy
-msgstr "Informacje statystyczne dla rastrowych warstw mapy."
-msgid "Statistic"
-msgstr "Statystyka"
-msgstr "Sposób przechowywania dla wynikowej mapy rastrowej"
 msgstr ""
@@ -8616,35 +8746,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Zakres wartości całkowitych: min,max"
-msgstr ""
-#, fuzzy
-msgstr "ciąg znaków reprezentujący wartości rastra 'no data'"
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Wyświetl ustawienia bieżącego regionu (styl skryptu powłoki)"
 msgstr "Ignoruj uszkodzone linie"
@@ -8653,32 +8754,11 @@
 msgstr ""
-#, fuzzy
-msgstr "Niewłaściwy przedział czasowy"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-msgstr "Wczytywanie danych..."
 #, c-format
@@ -8707,24 +8787,6 @@
 msgstr ""
-msgstr "Zapis do mapy ..."
-#, fuzzy, c-format
-msgstr "%lu punktów znalezionych w regione."
-msgstr "Skanowanie danych..."
-#, c-format
-msgstr "Zakres:     min         max\n"
 msgstr ""
@@ -10849,7 +10911,7 @@
 msgid "Attributes"
@@ -10896,7 +10958,7 @@
 #, c-format
 msgstr "Nie można wstawić nowego wiersza: %s"
@@ -17691,8 +17753,7 @@
 msgstr "Nir można wybrać atrybutów dla pola #%d"
 msgstr "Nie można odczytać danych z tabeli "
@@ -18180,17 +18241,17 @@
 msgstr ""
 #, fuzzy
 msgstr "Wyświetl tylko region mapy rastrowej"
 msgid "Subregion"
 msgstr "Podregion"
 msgstr ""
@@ -18245,16 +18306,11 @@
 msgstr "Nie twórz tabeli atrubutów."
-#, fuzzy
-msgstr "Forsuj projekcję (użyj projekcji z lokacji)"
 msgstr "Ogranicz import do bieżącego regionu"
@@ -18262,7 +18318,7 @@
 msgstr ""
 msgid ""
@@ -18282,12 +18338,12 @@
 msgstr ""
 #, c-format
 msgstr "Mapa wektorowa <%s> już istnieje i zostanie nadpisana"
 #, fuzzy, c-format
@@ -18298,37 +18354,14 @@
 msgstr "Warstwa <%s> jest niedostępna"
 msgstr ""
 msgstr "Dla parametru 'przestrzennego' wymagane sÄ… 4 parametry"
-msgid ""
-"checking"
-msgstr ""
-msgstr ""
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -18366,7 +18399,7 @@
 msgstr "Typ kolumny nieobsługiwany (%s)"
 #, c-format
 msgstr "Nie można otworzyć bazy danych <%s> przez sterownik <%s>"
@@ -18419,28 +18452,28 @@
 msgstr ""
+#, fuzzy
+msgstr "Nie można otworzyć pliku wejściowego"
 msgstr ""
 #, fuzzy
 msgstr "%5d usuniętych wierzchołków"
 msgstr ""
 #, fuzzy
-#, fuzzy
-msgstr "Nie można otworzyć pliku wejściowego"
@@ -19329,7 +19362,7 @@
 msgstr ""
 #, fuzzy
@@ -21167,7 +21200,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -23173,45 +23206,64 @@
 msgstr "Wczytano %d kategorii z mapy"
 #, fuzzy
 msgstr "Konwertuje warstwy wektorowe OGR na wektorowe mapy GRASS."
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Wartości całkowite zostały zaimportowane"
+#, fuzzy
 msgstr "Wyświetl historię rastra zamiast informacji"
 #, fuzzy, c-format
+msgstr "Nieznany kolor: [%s]"
+#, fuzzy, c-format
 msgstr "Zapiywanie %s ..."
 #, fuzzy, c-format
 msgstr "Wyświetl ustawienia bieżącego regionu"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "Wyświetl ustawienia bieżącego regionu"
 msgid "flow"
 msgstr ""
@@ -29026,6 +29078,46 @@
 msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Nazwa wejściowej warstwy"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Liczba punktów do wyznaczenia"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_pt.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -10,7 +10,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_pt\n"
 "PO-Revision-Date: 2007-06-21 21:54-0300\n"
 "Last-Translator: Daniel de Castro Victoria <daniel dot victoria at gmail dot "
 "com>\n"
@@ -443,6 +444,7 @@
@@ -1716,7 +1718,8 @@
 msgstr "Coordenada Leste ilegal <%s>"
 #, fuzzy, c-format
 msgstr "classe %d (%d)\n"
@@ -1771,7 +1774,7 @@
@@ -1898,7 +1901,7 @@
@@ -1909,7 +1912,7 @@
 #, fuzzy, c-format
@@ -1921,7 +1924,7 @@
 #, fuzzy, c-format
@@ -2414,7 +2417,7 @@
 "Custo designado para células NULL. Por padrão, células NULL são excluídas."
 msgstr "Porcentagem do mapa para manter em memória"
@@ -2656,7 +2659,7 @@
 msgstr ""
 msgstr "Nome da nova locação a criar"
@@ -2665,7 +2668,7 @@
 msgstr "Sobrescrever projeção (usar projeção da locação)"
 msgstr "Estender locação baseado nos novos dados"
@@ -2734,7 +2737,7 @@
 msgstr ""
 msgid ""
 "location."
@@ -2743,7 +2746,7 @@
 "GRASS, não posso criar nova locação."
 #, fuzzy, c-format
 msgstr "Locação: %s\n"
@@ -2757,14 +2760,16 @@
 "Não consegui converter a projeção do mapa de entrada para o formato do GRASS "
 "para verificação"
 #, fuzzy
 msgstr "Fonte"
 #, fuzzy
 msgid ""
@@ -2782,9 +2787,10 @@
 msgstr ""
 #, fuzzy
@@ -2808,8 +2814,9 @@
 "Considere gerar uma nova locação com o parâmetro 'location' do dado de "
 "entrada.\n"
 #, fuzzy
 msgstr ""
@@ -7026,7 +7033,7 @@
 msgstr "de Memória."
 #, fuzzy, c-format
 msgstr "de Por cento Concluir "
@@ -8046,6 +8053,160 @@
 msgstr "Não consegui criar arquivo raster [%s]."
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Arquivo de entrada DXF"
+#, fuzzy
+msgstr "Relatório de estatísticas para mapas raster."
+msgid "Statistic"
+msgstr ""
+msgstr "Tipo de armazenamento para o mapa resultante"
+#, fuzzy
+msgstr "Intervalo de inteiro: min,max"
+msgstr ""
+#, fuzzy
+msgstr "Formato para relatar a declividade"
+msgid ""
+"observations"
+msgstr ""
+#, fuzzy
+msgstr "Sobrescrever projeção (usar projeção da locação)"
+msgstr ""
+#, fuzzy
+msgstr "Mostra as estatísticas em estilo shell script"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+"Não consegui converter a projeção do mapa de entrada para o formato do GRASS "
+"para verificação"
+#, fuzzy
+msgstr "Locação: %s\n"
+#, fuzzy, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Você pode usar a opção -o para %s para ignorar esta verificação.\n"
+#, fuzzy
+msgid ""
+"set.\n"
+msgstr ""
+"Considere gerar uma nova locação com o parâmetro 'location' do dado de "
+"entrada.\n"
+#, fuzzy
+msgstr "Fonte inválida: %s"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Rotacionando dados ... "
+#, fuzzy
+msgstr "Não consegui abrir arquivo vetorial <%s>"
+#, fuzzy
+msgstr "Escrevendo [%s]..."
+#, fuzzy, c-format
+msgstr "%d pontos fora da região atual."
+#, fuzzy
+#, c-format
+msgstr ""
@@ -8961,12 +9122,6 @@
 msgstr "Não consegui abrir o arquivo de células [%s]"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8978,20 +9133,6 @@
 msgstr "Arquivo ASCII contendo assinaturas espectrais"
-#, fuzzy
-msgstr "Relatório de estatísticas para mapas raster."
-msgid "Statistic"
-msgstr ""
-msgstr "Tipo de armazenamento para o mapa resultante"
 #, fuzzy
@@ -9007,35 +9148,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Intervalo de inteiro: min,max"
-msgstr ""
-#, fuzzy
-msgstr "Formato para relatar a declividade"
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Mostra as estatísticas em estilo shell script"
 msgstr ""
@@ -9045,33 +9157,11 @@
 msgstr "Especifique uma coluna z razoável."
-#, fuzzy
-msgstr "Fonte inválida: %s"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Rotacionando dados ... "
 #, c-format
@@ -9100,26 +9190,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Escrevendo [%s]..."
-#, fuzzy, c-format
-msgstr "%d pontos fora da região atual."
-#, fuzzy
-#, c-format
-msgstr ""
 #, fuzzy
@@ -11304,7 +11374,7 @@
 #, fuzzy
@@ -11356,7 +11426,7 @@
 #, c-format
 msgstr "Não consegui inserir nova linha: %s"
@@ -18371,8 +18441,7 @@
 msgstr "Não consegui selecionar atributo para cat=%d"
 #, fuzzy
 msgstr "Não consegui selecionar dados da tabela"
@@ -18898,18 +18967,18 @@
 "\t\tArquivo shape ESRI: nome do arquivo\n"
 "\t\tArquivo do MapInfo: nome do arquivo"
 #, fuzzy
 msgstr "Imprime apenas a região do mapa raster"
 #, fuzzy
 msgid "Subregion"
 msgstr "Região\n"
 #, fuzzy
 msgstr "Importar apenas subregião (xmin,ymin,xmax,ymaz  - normalmente W,S,E,N)"
@@ -18977,17 +19046,12 @@
 msgstr "Não criar tabela de atributo."
 #, fuzzy
-msgstr "Sobrescrever projeção (usar projeção da locação)"
-#, fuzzy
 msgstr "Não atualizar a região atual"
@@ -18995,7 +19059,7 @@
 msgstr ""
 msgid ""
@@ -19015,12 +19079,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "O vetor '%s' já existe."
 #, fuzzy, c-format
@@ -19031,46 +19095,15 @@
 msgstr "Camada '%s' não disponível"
 msgstr ""
 #, fuzzy
 msgstr " 4 parâmetros são requeridos para o parâmetro 'spatial'."
-msgid ""
-"checking"
-msgstr ""
-"Não consegui converter a projeção do mapa de entrada para o formato do GRASS "
-"para verificação"
-#, fuzzy
-msgstr "Locação: %s\n"
-#, fuzzy, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"Você pode usar a opção -o para %s para ignorar esta verificação.\n"
-#, fuzzy
-msgid ""
-"set.\n"
-msgstr ""
-"Considere gerar uma nova locação com o parâmetro 'location' do dado de "
-"entrada.\n"
 #, fuzzy, c-format
@@ -19112,7 +19145,7 @@
 msgstr "Tipo da coluna não suportado (%s)"
 #, fuzzy, c-format
 msgstr "Não conseguir abrir banco de dados %s com driver %s"
@@ -19167,27 +19200,27 @@
 msgstr ""
+#, fuzzy
+msgstr "não consegui atualizar limites"
 msgstr ""
 #, fuzzy
 msgstr "Removendo centróides duplicados ..."
 msgstr ""
 msgstr ""
-#, fuzzy
-msgstr "não consegui atualizar limites"
@@ -20121,7 +20154,7 @@
 msgstr "Usar função drand48() (padrão= rand() )"
 #, fuzzy
@@ -22068,7 +22101,7 @@
 #, fuzzy, c-format
 msgstr "Sem registro no banco para categoria %d"
@@ -24144,45 +24177,64 @@
 msgstr "%-5d categorias lidas para a memória\n"
 #, fuzzy
 msgstr "Converte vetores OGR para GRASS. Drivers disponíveis:\n"
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "valores inteiros são importados"
+#, fuzzy
 msgstr "Mostra histórico do vetor ao invés de informações"
 #, fuzzy, c-format
+msgstr "Tipo desconhecido"
+#, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "%d pontos carregados\n"
 #, fuzzy, c-format
 msgstr "Coordenadas de entrada não foram informadas"
 #, fuzzy, c-format
 msgstr "%d pontos além do limite"
+#, fuzzy, c-format
+msgstr "%d pontos além do limite"
 msgid "flow"
 msgstr ""
@@ -30264,6 +30316,46 @@
 msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Nome de uma camada de entrada"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Número de pontos a alocar"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
@@ -39680,10 +39772,6 @@
 #~ msgstr "Não consegui abrir arquivo ASCII [%s]"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
-#~ msgstr "Não consegui abrir arquivo vetorial <%s>"
-#, fuzzy
 #~ msgid "Number of raster rows to hold in memory"
 #~ msgstr "Número de linhas para manter na memória"
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_pt_br.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -11,7 +11,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_pt_br\n"
 "PO-Revision-Date: 2011-06-05 14:40-0300\n"
 "Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
 "Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
@@ -123,7 +123,9 @@
 #: ../raster3d/r3.info/r3.info.main.c:81
 msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr "Imprime informações básicas sobre uma camada de mapa 3D especificada pelo usuário."
+msgstr ""
+"Imprime informações básicas sobre uma camada de mapa 3D especificada pelo "
+"usuário."
 #: ../raster3d/r3.info/r3.info.main.c:88
 msgid "Name of input 3D raster map"
@@ -151,7 +153,8 @@
 #: ../raster3d/r3.info/r3.info.main.c:114
 msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr "Imprime apenas o carimbo de data do mapa raster 3D (dia.mês.ano hora:min:seg)"
+msgstr ""
+"Imprime apenas o carimbo de data do mapa raster 3D (dia.mês.ano hora:min:seg)"
 #: ../raster3d/r3.info/r3.info.main.c:122 ../raster/r.walk/main.c:447
 #: ../raster/r.walk/main.c:452 ../raster/r.walk/main.c:817
@@ -233,7 +236,8 @@
 #: ../raster3d/r3.in.ascii/main.c:90
 msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr "Texto para representar célula sem valor de dados (use 'none' se não houver)"
+msgstr ""
+"Texto para representar célula sem valor de dados (use 'none' se não houver)"
 #: ../raster3d/r3.in.ascii/main.c:174
 #, c-format
@@ -246,19 +250,23 @@
 #: ../raster3d/r3.in.ascii/main.c:209
 #, c-format
-msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
-msgstr "Ainda há dados no arquivo de entrada depois de uma importação completa dos dados esperados.  [%.4f ...]"
+msgid ""
+"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgstr ""
+"Ainda há dados no arquivo de entrada depois de uma importação completa dos "
+"dados esperados.  [%.4f ...]"
 #: ../raster3d/r3.in.ascii/main.c:242 ../raster/r.in.poly/main.c:30
 #: ../raster/r.in.gdal/main.c:82 ../raster/r.in.bin/main.c:236
 #: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.png/main.c:522
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.external/main.c:524
-#: ../raster/r.in.ascii/main.c:70 ../raster/r.in.mat/main.c:92
-#: ../raster/r.in.arc/main.c:61 ../vector/v.in.ogr/main.c:106
-#: ../vector/v.in.db/main.c:53 ../vector/v.in.sites/main.c:58
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.convert/main.c:37 ../vector/v.in.lidar/main.c:148
-#: ../vector/v.in.ascii/main.c:49 ../vector/v.external/main.c:49
+#: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:161
+#: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
+#: ../raster/r.in.mat/main.c:92 ../raster/r.in.arc/main.c:61
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
+#: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
+#: ../vector/v.in.lidar/main.c:154 ../vector/v.in.ascii/main.c:49
+#: ../vector/v.external/main.c:49
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:3
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:3
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
@@ -359,18 +367,18 @@
 #: ../raster/r.info/main.c:70 ../raster/r.surf.area/main.c:88
 #: ../raster/r.surf.fractal/main.c:38 ../raster/r.covar/main.c:51
 #: ../raster/r.statistics3/main.c:389 ../raster/r.rescale/main.c:48
-#: ../raster/r.solute.transport/main.c:229 ../raster/r.proj/main.c:146
-#: ../raster/r.out.mpeg/main.c:102 ../raster/r.fill.dir/main.c:85
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.univar/r.univar_main.c:96
-#: ../raster/r.cross/main.c:73 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.category/main.c:52 ../raster/r.clump/main.c:46
-#: ../raster/r.out.tiff/main.c:91 ../raster/r.in.xyz/main.c:160
-#: ../raster/r.texture/main.c:75 ../raster/r.surf.random/main.c:36
-#: ../raster/r.out.arc/main.c:60 ../raster/r.surf.contour/main.c:60
-#: ../raster/r.colors/main.c:168 ../raster/r.statistics/main.c:55
-#: ../raster/r.li/r.li.padcv/padcv.c:39 ../raster/r.li/r.li.mpa/mpa.c:41
-#: ../raster/r.li/r.li.patchnum/main.c:36 ../raster/r.li/r.li.mps/mps.c:42
-#: ../raster/r.li/r.li.pielou/pielou.c:58
+#: ../raster/r.solute.transport/main.c:229 ../raster/r.in.lidar/main.c:161
+#: ../raster/r.proj/main.c:146 ../raster/r.out.mpeg/main.c:102
+#: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.univar/r.univar_main.c:96 ../raster/r.cross/main.c:73
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
+#: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
+#: ../raster/r.surf.contour/main.c:60 ../raster/r.colors/main.c:168
+#: ../raster/r.statistics/main.c:55 ../raster/r.li/r.li.padcv/padcv.c:39
+#: ../raster/r.li/r.li.mpa/mpa.c:41 ../raster/r.li/r.li.patchnum/main.c:36
+#: ../raster/r.li/r.li.mps/mps.c:42 ../raster/r.li/r.li.pielou/pielou.c:58
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:40
 #: ../raster/r.li/r.li.cwed/cwed.c:48 ../raster/r.li/r.li.padsd/padsd.c:39
 #: ../raster/r.li/r.li.richness/richness.c:41
@@ -425,6 +433,7 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:2
 #: ../locale/scriptstrings/r.grow_to_translate.c:2
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:2
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:2
@@ -441,8 +450,12 @@
 #: ../raster3d/r3.cross.rast/main.c:263
 #, fuzzy
-msgid "Creates cross section 2D raster map from 3d raster map based on 2D elevation map"
-msgstr "Cria mapa raster 2D cross section a partir de mapas raster 3d baseados em mapas de elevação 2D"
+msgid ""
+"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
+"map"
+msgstr ""
+"Cria mapa raster 2D cross section a partir de mapas raster 3d baseados em "
+"mapas de elevação 2D"
 #: ../raster3d/r3.cross.rast/main.c:275 ../raster3d/r3.to.rast/main.c:215
 #: ../visualization/nviz2/cmd/volume.c:40
@@ -452,8 +465,12 @@
 #: ../raster3d/r3.cross.rast/main.c:289 ../raster/r.to.rast3elev/main.c:412
 #: ../raster/r.to.rast3/main.c:223
-msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
-msgstr "As configurações de região 2d e 3d estão diferentes. Usarei as configurações g3d para ajustar a região 2d."
+msgid ""
+"The 2d and 3d region settings are different. I will use the g3d settings to "
+"adjust the 2d region."
+msgstr ""
+"As configurações de região 2d e 3d estão diferentes. Usarei as configurações "
+"g3d para ajustar a região 2d."
 #: ../raster3d/r3.cross.rast/main.c:309 ../raster3d/r3.to.rast/main.c:230
 #: ../raster3d/r3.to.rast/main.c:271 ../raster3d/r3.out.vtk/main.c:205
@@ -489,8 +506,12 @@
 msgstr "Nome do mapa raster resultante"
 #: ../raster3d/r3.to.rast/main.c:96
-msgid "Use the same resolution as the input G3D map for the 2d output maps, independent of the current region settings"
-msgstr "Use a mesma resolução do mapa G3D de entrada para os mapas 2d de saída, independente das cofigurações da região atual"
+msgid ""
+"Use the same resolution as the input G3D map for the 2d output maps, "
+"independent of the current region settings"
+msgstr ""
+"Use a mesma resolução do mapa G3D de entrada para os mapas 2d de saída, "
+"independente das cofigurações da região atual"
 #: ../raster3d/r3.to.rast/main.c:203
 msgid "Converts 3D raster maps to 2D raster maps"
@@ -502,8 +523,12 @@
 msgstr "Abrir mapa raster 3d <%s>"
 #: ../raster3d/r3.to.rast/main.c:254
-msgid "The 2d and 3d region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
-msgstr "As configurações das regiões 2d e 3d são diferentes. Usando as configurações de janela 2D para ajustar a parte 2D da região 3D."
+msgid ""
+"The 2d and 3d region settings are different. Using the 2D window settings to "
+"adjust the 2D part of the 3D region."
+msgstr ""
+"As configurações das regiões 2d e 3d são diferentes. Usando as configurações "
+"de janela 2D para ajustar a parte 2D da região 3D."
 #: ../raster3d/r3.to.rast/main.c:286 ../raster3d/r3.out.v5d/main.c:202
 #: ../raster/r.gwflow/main.c:366 ../raster/r.li/r.li.daemon/list.c:49
@@ -591,8 +616,12 @@
 msgstr "Favor fornecer três mapas vetoriais g3d [x,y,z]"
 #: ../raster3d/r3.out.vtk/main.c:174
-msgid "No g3d data, RGB or xyz-vector maps are provided! Will only write the geometry."
-msgstr "Sem dados g3d, mapas RGB ou vetor-xyz são fornecidos! Vou escrever apenas a geometria."
+msgid ""
+"No g3d data, RGB or xyz-vector maps are provided! Will only write the "
+"geometry."
+msgstr ""
+"Sem dados g3d, mapas RGB ou vetor-xyz são fornecidos! Vou escrever apenas a "
+"geometria."
 #: ../raster3d/r3.out.vtk/main.c:194
 #, c-format
@@ -629,7 +658,9 @@
 msgstr "dp tem valores de 0 a 20"
 #: ../raster3d/r3.out.vtk/main.c:449
-msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
+msgid ""
+"The 2d and 3d region settings are different. The g3d settings are used to "
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:541
@@ -642,7 +673,8 @@
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:39
 msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
-msgstr "write_vtk_structured_point_header: Escrevendo cabeçalho VTKStructuredPoint"
+msgstr ""
+"write_vtk_structured_point_header: Escrevendo cabeçalho VTKStructuredPoint"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:95
 msgid "write_vtk_structured_grid_header: Writing VTKStructuredGrid-Header"
@@ -650,7 +682,8 @@
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:116
 msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-msgstr "write_vtk_unstructured_grid_header: Escrevendo VTKUnstructuredGrid-Header"
+msgstr ""
+"write_vtk_unstructured_grid_header: Escrevendo VTKUnstructuredGrid-Header"
 #: ../raster3d/r3.out.vtk/errorHandling.c:65
 msgid "unable to close input 3d raster map"
@@ -670,7 +703,9 @@
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr "Criar dados pontuais (pointdata) VTK ao invés de dados de células (celldata) VTK (dados de célula é o padrão)"
+msgstr ""
+"Criar dados pontuais (pointdata) VTK ao invés de dados de células (celldata) "
+"VTK (dados de célula é o padrão)"
 #: ../raster3d/r3.out.vtk/parameters.c:56
 msgid "top surface 2D raster map"
@@ -681,16 +716,25 @@
 msgstr "Mapa raster 2D de superfície de fundo"
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
-msgstr "Cria saída de elevação 3d com uma superfície de topo e piso, ambos os mapas raster sendo requisitados."
+msgid ""
+"Create 3d elevation output with a top and a bottom surface, both raster maps "
+"are required."
+msgstr ""
+"Cria saída de elevação 3d com uma superfície de topo e piso, ambos os mapas "
+"raster sendo requisitados."
 #: ../raster3d/r3.out.vtk/parameters.c:82
-msgid "Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr "3 mapas raster (r,g,b) 3d que serão usado para criar valores rgb [mapavermelho, mapaverde, mapaazul]"
+msgid ""
+"Three (r,g,b) 3d raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr ""
+"3 mapas raster (r,g,b) 3d que serão usado para criar valores rgb "
+"[mapavermelho, mapaverde, mapaazul]"
 #: ../raster3d/r3.out.vtk/parameters.c:92
 msgid "Three (x,y,z) 3d raster maps to create vector values [xmap,ymap,zmap]"
-msgstr "3 mapas raster (r,g,b) que serão usado para criar valores rgb [mapavermelho, mapaverde, mapaazul]"
+msgstr ""
+"3 mapas raster (r,g,b) que serão usado para criar valores rgb [mapavermelho, "
+"mapaverde, mapaazul]"
 #: ../raster3d/r3.out.vtk/parameters.c:99 ../raster/r.out.vtk/parameters.c:96
 #: ../vector/v.out.vtk/main.c:77
@@ -726,8 +770,12 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:332
 #, c-format
-msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
-msgstr "write_vtk_data: Gravando dados de célula (celldata) %s com linhas %i colunas %i profundidades %i para arquivo vtk-ascii"
+msgid ""
+"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
+"ascii file"
+msgstr ""
+"write_vtk_data: Gravando dados de célula (celldata) %s com linhas %i colunas "
+"%i profundidades %i para arquivo vtk-ascii"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:390
 msgid "write_vtk_rgb_data: writing rgb data"
@@ -736,7 +784,8 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:427
 #: ../raster3d/r3.out.vtk/writeVTKData.c:460
 msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr "Valores de mapa raster 3d incorretos! Valores devem estar entre 0 e 255!\n"
+msgstr ""
+"Valores de mapa raster 3d incorretos! Valores devem estar entre 0 e 255!\n"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:490
 msgid "write_vtk_vector_data: writing vector data"
@@ -747,19 +796,27 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:60
-msgid "Input 3d-raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
+msgid ""
+"Input 3d-raster map providing the status for each cell, = 0 - inactive, 1 - "
+"active, 2 - dirichlet"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:65
-msgid "Input 3d-raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input 3d-raster map with the x-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:70
-msgid "Input 3d-raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input 3d-raster map with the y-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:75
-msgid "Input 3d-raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input 3d-raster map with the z-part of the hydraulic conductivity tensor in "
+"[m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:80
@@ -777,23 +834,32 @@
 msgstr "Lendo arquivo dig_att...\n"
 #: ../raster3d/r3.gwflow/main.c:93
-msgid "Output 3d-raster map storing the piezometric head result of the numerical calculation"
+msgid ""
+"Output 3d-raster map storing the piezometric head result of the numerical "
+"calculation"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:99
-msgid "Output 3d-raster map storing the groundwater filter velocity vector part in x direction [m/s]"
+msgid ""
+"Output 3d-raster map storing the groundwater filter velocity vector part in "
+"x direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:105
-msgid "Output 3d-raster map storing the groundwater filter velocity vector part in y direction [m/s]"
+msgid ""
+"y direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:111
-msgid "Output 3d-raster map storing the groundwater filter velocity vector part in z direction [m/s]"
+msgid ""
+"z direction [m/s]"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:117
-msgid "Output 3d-raster map Storing the groundwater budget for each cell [m^3/s]\n"
+msgid ""
+"Output 3d-raster map Storing the groundwater budget for each cell [m^3/s]\n"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:127
@@ -801,7 +867,9 @@
 msgstr "Usa máscara G3D (se existir)"
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
+msgid ""
+"Use a full filled quadratic linear equation system, default is a sparse "
+"linear equation system."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:161 ../raster/r.basins.fill/main.c:55
@@ -832,7 +900,9 @@
 msgstr "Assinaturas para usar na classificação"
 #: ../raster3d/r3.gwflow/main.c:165
-msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:182 ../raster/r.gwflow/main.c:257
@@ -862,8 +932,12 @@
 msgstr "Erro fechando arquivo g3d"
 #: ../raster3d/r3.mkdspf/main.c:82
-msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
-msgstr "Cria um arquivo de exibição a partir de um arquivo grid3 existente, de acordo com os limiares especificados."
+msgid ""
+"Creates a display file from an existing grid3 file according to specified "
+"threshold levels."
+msgstr ""
+"Cria um arquivo de exibição a partir de um arquivo grid3 existente, de "
+"acordo com os limiares especificados."
 #: ../raster3d/r3.mkdspf/main.c:90
 msgid "Name of an existing 3d raster map"
@@ -1408,8 +1482,13 @@
 msgstr ""
 #: ../raster/r.his/main.c:67
-msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr "Gera camadas de mapa raster vermelha, verde e azul combinando valores de matiz (hue), intensidade e saturação (HIS) a partir das camadas de mapas raster de entrada fornecidas pelo usuário."
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+"Gera camadas de mapa raster vermelha, verde e azul combinando valores de "
+"matiz (hue), intensidade e saturação (HIS) a partir das camadas de mapas "
+"raster de entrada fornecidas pelo usuário."
 #: ../raster/r.his/main.c:76 ../display/d.his/main.c:76
 msgid "Name of layer to be used for HUE"
@@ -1543,7 +1622,8 @@
 #: ../raster/r.in.poly/main.c:32
 msgid "Creates raster maps from ASCII polygon/line/point data files."
-msgstr "Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
+msgstr ""
+"Cria mapas raster a partir de arquivos de dados de polígono/linha/ponto."
 #: ../raster/r.in.poly/main.c:36
 msgid "Name of input file; or \"-\" to read from stdin"
@@ -1578,7 +1658,8 @@
 msgid "Illegal east coordinate <%s>, skipping."
 msgstr "Coordenada Leste ilegal <%s>, pulando."
-#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.lidar/main.c:591
+#: ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "Passagem #%d (de %d) ..."
@@ -1632,7 +1713,7 @@
 #: ../vector/v.what/main.c:54 ../vector/v.transform/main.c:82
 #: ../vector/v.overlay/main.c:58 ../vector/v.class/main.c:44
 #: ../vector/v.build.polylines/main.c:113 ../vector/v.convert/main.c:36
-#: ../vector/v.in.lidar/main.c:147 ../vector/v.net.flow/main.c:58
+#: ../vector/v.in.lidar/main.c:153 ../vector/v.net.flow/main.c:58
 #: ../vector/v.segment/main.c:54 ../vector/v.normal/main.c:74
 #: ../vector/v.net.path/main.c:40 ../vector/v.univar/main.c:63
 #: ../vector/v.label/main.c:59 ../vector/v.to.rast/main.c:40
@@ -1680,7 +1761,9 @@
 #: ../raster/r.contour/main.c:90
 msgid "Produces a vector map of specified contours from a raster map."
-msgstr "Produz um mapa vetorial dos contornos especificados a partir de um mapa raster."
+msgstr ""
+"Produz um mapa vetorial dos contornos especificados a partir de um mapa "
+"raster."
 #: ../raster/r.contour/main.c:101
 msgid "List of contour levels"
@@ -1756,7 +1839,7 @@
 #: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:462
-#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:565
+#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:596
 #: ../vector/v.net.flow/main.c:170 ../vector/v.net.path/path.c:109
 #: ../vector/v.to.points/main.c:293 ../vector/v.surf.rst/main.c:579
 #: ../vector/v.net.centrality/main.c:242 ../vector/v.net.components/main.c:149
@@ -1767,7 +1850,7 @@
 #: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:796
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
-#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:570
+#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:601
 #: ../vector/v.to.points/main.c:298 ../vector/v.in.ascii/main.c:504
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
@@ -1779,7 +1862,7 @@
 #: ../vector/v.random/main.c:199 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:472
-#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:576
+#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:607
 #: ../vector/v.to.points/main.c:304 ../vector/v.in.ascii/main.c:394
 #, c-format
 msgid "Unable to grant privileges on table <%s>"
@@ -1840,7 +1923,8 @@
 #: ../raster/r.out.pov/main.c:124
 #, fuzzy
 msgid "Converts a raster map layer into a height-field file for POV-Ray."
-msgstr "Converte uma camada raster num campo de altura (height field) para o POVRAY."
+msgstr ""
+"Converte uma camada raster num campo de altura (height field) para o POVRAY."
 #: ../raster/r.out.pov/main.c:131
 msgid "Name of output povray file (TGA height field file)"
@@ -1922,7 +2006,9 @@
 #: ../raster/r.describe/main.c:57
 msgid "Prints terse list of category values found in a raster map layer."
-msgstr "Imprime lista compacta dos valores de categoria encontrados numa camada raster"
+msgstr ""
+"Imprime lista compacta dos valores de categoria encontrados numa camada "
+"raster"
 #: ../raster/r.describe/main.c:68 ../raster/r.stats/main.c:127
 msgid "String representing no data cell value"
@@ -1963,15 +2049,23 @@
 msgstr "\rLendo arquivo [%s] ..."
 #: ../raster/r.le/r.le.trace/main.c:58
-msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
-msgstr "Exibe as fronteiras de cada patch r.le e mostra como a fronteira é traçada, exibe os índices de atributo, tamanho, perímetro e forma para cada patch e grava os dados em um arquivo de saída."
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
+msgstr ""
+"Exibe as fronteiras de cada patch r.le e mostra como a fronteira é traçada, "
+"exibe os índices de atributo, tamanho, perímetro e forma para cada patch e "
+"grava os dados em um arquivo de saída."
 #: ../raster/r.le/r.le.setup/sample.c:1049
 msgid "Cannot read vector"
 msgstr "Não consegui ler vetor"
 #: ../raster/r.le/r.le.setup/main.c:59
-msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgid ""
+"Interactive tool used to setup the sampling and analysis framework that will "
+"be used by the other r.le programs."
 msgstr ""
 #: ../raster/r.le/r.le.setup/main.c:63
@@ -1983,11 +2077,15 @@
 msgstr "Mapa vetorial para sobrepor"
 #: ../raster/r.le/r.le.patch/main.c:50
-msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
 msgstr ""
 #: ../raster/r.le/r.le.pixel/main.c:47
-msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
 msgstr ""
 #: ../raster/r.out.ascii/main.c:62
@@ -2004,8 +2102,12 @@
 msgstr "Nome do mapa de grid ASCII de saída (use out=- para a saída padrão)"
 #: ../raster/r.out.ascii/main.c:93
-msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
-msgstr "Número de valores impressos antes da quebra de linha (somente formatos SURFER ou MODFLOW)"
+msgid ""
+"Number of values printed before wrapping a line (only SURFER or MODFLOW "
+"format)"
+msgstr ""
+"Número de valores impressos antes da quebra de linha (somente formatos "
+"SURFER ou MODFLOW)"
 #: ../raster/r.out.ascii/main.c:101
 msgid "String to represent null cell (GRASS grid only)"
@@ -2079,8 +2181,14 @@
 msgstr "Tipo de feição"
 #: ../raster/r.surf.gauss/main.c:42
-msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
-msgstr "Módulo GRASS para produzir uma camada raster de desvios gaussianos cuja média e desvio padrão sejam especificados pelo usuário. Usa um gerador gaussiano de números aleatórios."
+msgid ""
+"GRASS module to produce a raster map layer of gaussian deviates whose mean "
+"and standard deviation can be expressed by the user. It uses a gaussian "
+"random number generator."
+msgstr ""
+"Módulo GRASS para produzir uma camada raster de desvios gaussianos cuja "
+"média e desvio padrão sejam especificados pelo usuário. Usa um gerador "
+"gaussiano de números aleatórios."
 #: ../raster/r.surf.gauss/main.c:48
 msgid "Name of the output random surface"
@@ -2168,8 +2276,15 @@
 #: ../raster/r.walk/main.c:183
 #, fuzzy
-msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
-msgstr "Gera uma camada raster mostrando o custo cumulativo de movimento entre diferentes localizações sobre um mapa raster de entrada cujos valores de célula representam o custo."
+msgid ""
+"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input elevation raster map "
+"layer whose cell category values represent elevation combined with an input "
+"raster map layer whose cell values represent friction cost."
+msgstr ""
+"Gera uma camada raster mostrando o custo cumulativo de movimento entre "
+"diferentes localizações sobre um mapa raster de entrada cujos valores de "
+"célula representam o custo."
 #: ../raster/r.walk/main.c:193
 msgid "Name of elevation input raster map"
@@ -2221,10 +2336,11 @@
 #: ../raster/r.walk/main.c:266 ../raster/r.cost/main.c:220
 msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr "Custo designado para células NULL. Por padrão, células NULL são excluídas."
+msgstr ""
+"Custo designado para células NULL. Por padrão, células NULL são excluídas."
 #: ../raster/r.walk/main.c:274 ../raster/r.cost/main.c:229
-#: ../raster/r.in.xyz/main.c:238
+#: ../raster/r.in.lidar/main.c:211 ../raster/r.in.xyz/main.c:238
 msgid "Percent of map to keep in memory"
@@ -2323,7 +2439,8 @@
 #: ../raster/r.walk/main.c:427
 msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr "Atenção: atribuindo custo negativo  a células nulas. Células nulas excluídas."
+msgstr ""
+"Atenção: atribuindo custo negativo  a células nulas. Células nulas excluídas."
 #: ../raster/r.walk/main.c:562 ../raster/r.walk/main.c:572
 #: ../raster/r.cost/main.c:409 ../raster/r.cost/main.c:419
@@ -2454,11 +2571,13 @@
 msgstr "Metadados"
 #: ../raster/r.in.gdal/main.c:127
-msgid "The offset will be added to the band number while output raster map name creation"
+msgid ""
+"The offset will be added to the band number while output raster map name "
+"creation"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:181
-#: ../vector/v.in.lidar/main.c:172
+#: ../vector/v.in.lidar/main.c:178
 msgid "Name for new location to create"
@@ -2467,13 +2586,14 @@
 #: ../raster/r.in.gdal/main.c:144 ../raster/r.external/main.c:562
-#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:199
+#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:213
 msgid "Extend location extents based on new dataset"
 msgstr "Estender locação baseado no novo conjunto de dados"
 #: ../raster/r.in.gdal/main.c:155
 msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr "Força mapas Lat/Lon a se ajustarem em coordenadas geográficas (90N,S; 180E,W)"
+msgstr ""
+"Força mapas Lat/Lon a se ajustarem em coordenadas geográficas (90N,S; 180E,W)"
 #: ../raster/r.in.gdal/main.c:160
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:13
@@ -2481,7 +2601,9 @@
 msgstr "Manter os números das bandas em vez de usar os nomes das cores"
 #: ../raster/r.in.gdal/main.c:165
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the raster file."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:190
@@ -2512,39 +2634,57 @@
 msgstr "Mapa raster <%s> já existe"
 #: ../raster/r.in.gdal/main.c:258
-msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
+msgid ""
+"The polynomial rectification used in i.rectify does not work well with NOAA/"
+"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
+"(-tps)"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:274
-msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgid ""
+"Input raster map is flipped or rotated - cannot import. You may use "
+"'gdalwarp' to transform the map to North-up."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:315
-msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
+msgid ""
+"Map bounds have been constrained to geographic coordinates. You will almost "
+"certainly want to check map bounds and resolution with r.info and reset them "
+"with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:335 ../vector/v.in.ogr/main.c:480
-#: ../vector/v.in.lidar/main.c:320
-msgid "Unable to convert input map projection to GRASS format; cannot create new location."
-msgstr "Não consegui converter a projeção do mapa de entrada para o formato do GRASS, não posso criar nova locação."
+#: ../vector/v.in.lidar/main.c:351
+msgid ""
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location."
+msgstr ""
+"Não consegui converter a projeção do mapa de entrada para o formato do "
+"GRASS, não posso criar nova locação."
 #: ../raster/r.in.gdal/main.c:341 ../vector/v.in.ogr/main.c:486
-#: ../vector/v.in.lidar/main.c:326
+#: ../vector/v.in.lidar/main.c:357
 #, c-format
 msgid "Location <%s> created"
 msgstr "Locação <%s> criada"
 #: ../raster/r.in.gdal/main.c:354 ../raster/r.external/main.c:89
-msgid "Unable to convert input raster map projection information to GRASS format for checking"
-msgstr "Não consegui converter a projeção do mapa raster de entrada para o formato do GRASS para verificação"
+msgid ""
+"Unable to convert input raster map projection information to GRASS format "
+"for checking"
+msgstr ""
+"Não consegui converter a projeção do mapa raster de entrada para o formato "
+"do GRASS para verificação"
-#: ../raster/r.in.gdal/main.c:370 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:516 ../vector/v.in.lidar/main.c:359
+#: ../raster/r.in.gdal/main.c:370 ../raster/r.in.lidar/main.c:296
+#: ../raster/r.external/main.c:105 ../vector/v.in.ogr/main.c:516
+#: ../vector/v.in.lidar/main.c:390
 msgid "Over-riding projection check"
 msgstr "Se sobrepondo à verificação da projeção"
-#: ../raster/r.in.gdal/main.c:381 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:525 ../vector/v.in.lidar/main.c:368
+#: ../raster/r.in.gdal/main.c:381 ../raster/r.in.lidar/main.c:305
+#: ../raster/r.external/main.c:113 ../vector/v.in.ogr/main.c:525
+#: ../vector/v.in.lidar/main.c:399
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -2560,28 +2700,37 @@
 msgid "Dataset PROJ_INFO is:\n"
 msgstr "PROJ_INFO do conjunto de dados é:\n"
-#: ../raster/r.in.gdal/main.c:424 ../raster/r.external/main.c:156
+#: ../raster/r.in.gdal/main.c:424 ../raster/r.in.lidar/main.c:321
+#: ../raster/r.in.lidar/main.c:328 ../raster/r.external/main.c:156
 #: ../vector/v.in.ogr/main.c:541 ../vector/v.in.ogr/main.c:548
-#: ../vector/v.in.lidar/main.c:384 ../vector/v.in.lidar/main.c:391
+#: ../vector/v.in.lidar/main.c:415 ../vector/v.in.lidar/main.c:422
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "PROJ_INFO do conjunto de dados importado é:\n"
 #: ../raster/r.in.gdal/main.c:446
 msgid ""
 "\n"
-"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the "
+"location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Você pode usar a opção -o para r.in.gdal para ignorar esta verificaçãoe usar a definição de locação para o conjunto de dados.\n"
+"Você pode usar a opção -o para r.in.gdal para ignorar esta verificaçãoe usar "
+"a definição de locação para o conjunto de dados.\n"
 #: ../raster/r.in.gdal/main.c:449 ../raster/r.external/main.c:181
-msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
-msgstr "Considere gerar uma nova locação a partir do conjunto de dados de entrada usando o parâmetro 'location'.\n"
+msgid ""
+"Consider generating a new location from the input dataset using the "
+"'location' parameter.\n"
+msgstr ""
+"Considere gerar uma nova locação a partir do conjunto de dados de entrada "
+"usando o parâmetro 'location'.\n"
-#: ../raster/r.in.gdal/main.c:454 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:599 ../vector/v.in.lidar/main.c:442
+#: ../raster/r.in.gdal/main.c:454 ../raster/r.in.lidar/main.c:379
+#: ../raster/r.external/main.c:186 ../vector/v.in.ogr/main.c:599
+#: ../vector/v.in.lidar/main.c:473
 msgid "Projection of input dataset and current location appear to match"
-msgstr "Projeção do conjunto de dados de entrada e locação atual parecem combinar"
+msgstr ""
+"Projeção do conjunto de dados de entrada e locação atual parecem combinar"
 #: ../raster/r.in.gdal/main.c:460 ../raster/r.external/main.c:644
 msgid "Proceeding with import..."
@@ -2654,12 +2803,14 @@
 #: ../raster/r.in.gdal/main.c:938
 #, c-format
 msgid "Setting grey color table for <%s> (8bit, full range)"
-msgstr "Configurando tabela de cores cinza para <%s> (8bit, intervalo completo)"
+msgstr ""
+"Configurando tabela de cores cinza para <%s> (8bit, intervalo completo)"
 #: ../raster/r.in.gdal/main.c:951
 #, c-format
 msgid "Setting grey color table for <%s> (16bit, image range)"
-msgstr "Configurando tabela de cores cinza para <%s> (16bit, intervalo de imagem)"
+msgstr ""
+"Configurando tabela de cores cinza para <%s> (16bit, intervalo de imagem)"
 #: ../raster/r.in.gdal/main.c:962 ../raster/r.circle/main.c:154
 #: ../raster/r.surf.fractal/main.c:85 ../raster/r.composite/main.c:261
@@ -2842,7 +2993,9 @@
 #: ../raster/r.in.bin/main.c:466
 #, c-format
-msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign east= and west= correctly?"
 msgstr ""
 #: ../raster/r.in.bin/main.c:489
@@ -2859,8 +3012,12 @@
 msgstr "Mapa raster a ser amostrado"
 #: ../raster/r.rescale.eq/main.c:54
-msgid "Rescales histogram equalized the range of category values in a raster map layer."
-msgstr "Reescalona histograma equalizado o intervalo de valores de categoria em uma camada de mapa raster."
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+"Reescalona histograma equalizado o intervalo de valores de categoria em uma "
+"camada de mapa raster."
 #: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:60
 msgid "The name of the raster map to be rescaled"
@@ -2868,7 +3025,9 @@
 #: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:68
 msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr "Intervalo dos dados de entrada a ser reescalonados (padrão: intervalo completo do mapa de entrada)"
+msgstr ""
+"Intervalo dos dados de entrada a ser reescalonados (padrão: intervalo "
+"completo do mapa de entrada)"
 #: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:75
 msgid "The resulting raster map name"
@@ -2928,11 +3087,14 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:108
-msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:116
-msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
+msgid ""
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:123 ../vector/v.surf.bspline/main.c:156
@@ -2951,7 +3113,9 @@
 #: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:100
 #, fuzzy
-msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
 msgstr "Encontre melhores parâmetros utilizando o método de validação cruzada"
 #: ../raster/r.resamp.bspline/main.c:151
@@ -3089,8 +3253,12 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:160
 #, fuzzy, c-format
-msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
-msgstr "Correlação cruzada: %d são demasiados pontos. A validação cruzada demoraria demasiado tempo"
+msgid ""
+"%d are too many cells, recommended are < 100 cells. The cross validation "
+"would take too much time."
+msgstr ""
+"Correlação cruzada: %d são demasiados pontos. A validação cruzada demoraria "
+"demasiado tempo"
 #: ../raster/r.resamp.bspline/crosscorr.c:169
 #: ../vector/v.surf.bspline/crosscorr.c:81
@@ -3105,7 +3273,8 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:193
 #: ../vector/v.surf.bspline/crosscorr.c:146
 #, c-format
-msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid ""
+"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:211
@@ -3128,14 +3297,18 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:313
 #: ../vector/v.surf.bspline/crosscorr.c:301
-msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
+msgid ""
+"Different number of splines and lambda_i values have been taken for the "
+"cross correlation"
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:315
 #: ../vector/v.surf.bspline/crosscorr.c:303
 #, fuzzy, c-format
-msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr "Correlação cruzada: O valor mínimo para o teste (rms=%lf) foi obtido com:\n"
+msgid ""
+"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr ""
+"Correlação cruzada: O valor mínimo para o teste (rms=%lf) foi obtido com:\n"
 #: ../raster/r.resamp.bspline/crosscorr.c:323
 #: ../vector/v.surf.bspline/crosscorr.c:311
@@ -3172,7 +3345,9 @@
 msgstr ""
 #: ../raster/r.drain/main.c:131
-msgid "Output drain vector map (recommended for cost surface made using knight's move)"
+msgid ""
+"Output drain vector map (recommended for cost surface made using knight's "
+"move)"
 msgstr ""
 #: ../raster/r.drain/main.c:139
@@ -3202,7 +3377,9 @@
 msgstr "Conta número de células ao longo do caminho"
 #: ../raster/r.drain/main.c:163
-msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
+msgid ""
+"The input surface is a cost surface (if checked, a direction surface must "
+"also be specified"
 msgstr ""
 #: ../raster/r.drain/main.c:175
@@ -3214,7 +3391,9 @@
 msgstr ""
 #: ../raster/r.drain/main.c:184
-msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
+msgid ""
+"Direction raster not specified, if direction flag is on, a direction raster "
+"must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:192
@@ -3280,7 +3459,8 @@
 #: ../raster/r.support/main.c:57
 msgid "Allows creation and/or modification of raster map layer support files."
-msgstr "Permite a criação e/ou modificação dos arquivos de suporte dos mapas raster"
+msgstr ""
+"Permite a criação e/ou modificação dos arquivos de suporte dos mapas raster"
 #: ../raster/r.support/main.c:67
 msgid "Text to use for map title"
@@ -3428,7 +3608,8 @@
 #: ../raster/r.lake/main.c:194
 msgid "Both seed map and coordinates cannot be specified"
-msgstr "Tanto o mapa de origem quanto as coordenadas não puderam ser especificadas!"
+msgstr ""
+"Tanto o mapa de origem quanto as coordenadas não puderam ser especificadas!"
 #: ../raster/r.lake/main.c:197
 msgid "Seed map or seed coordinates must be set!"
@@ -3460,7 +3641,9 @@
 msgstr "get_img: Memória Esgotada! (Out of Memory)"
 #: ../raster/r.lake/main.c:269
-msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
+msgid ""
+"Given water level at seed point is below earth surface. Increase water level "
+"or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:348
@@ -3490,7 +3673,8 @@
 #: ../raster/r.surf.idw/main.c:108
 #, fuzzy
 msgid "Surface interpolation utility for raster map."
-msgstr "Utilitário de interpolação de superfícies para camadas de mapas raster."
+msgstr ""
+"Utilitário de interpolação de superfícies para camadas de mapas raster."
 #: ../raster/r.surf.idw/main.c:118 ../raster/r.surf.idw2/main.c:76
 #: ../vector/v.surf.idw/main.c:109
@@ -3644,17 +3828,23 @@
 #: ../raster/r.stats/main.c:279
 #, c-format
-msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgid ""
+"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
+"will be ignored."
 msgstr ""
 #: ../raster/r.stats/main.c:295
 #, c-format
-msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgid ""
+"Cats for raster map <%s> are either missing or have no explicit labels. "
+"Using %s=%d."
 msgstr ""
 #: ../raster/r.stats/main.c:301
 #, fuzzy, c-format
-msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgid ""
+"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
+"option"
 msgstr "de"
 #: ../raster/r.stats/main.c:334 ../raster/r.recode/read_rules.c:35
@@ -3694,12 +3884,14 @@
 #: ../raster/r.compress/main.c:110
 #, fuzzy, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr "[%s] é uma reclassificação de [%s em %s] - não é possível editar o cabeçalho!"
+msgstr ""
+"[%s] é uma reclassificação de [%s em %s] - não é possível editar o cabeçalho!"
 #: ../raster/r.compress/main.c:112
 #, fuzzy, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
+msgstr ""
 #: ../raster/r.compress/main.c:155
 #, c-format
@@ -3760,7 +3952,9 @@
 #: ../raster/r.circle/main.c:54
 #, fuzzy
 msgid "Creates a raster map containing concentric rings around a given point."
-msgstr "Nome do mapa raster contendo informação de coordenada norte do caminho retrógrado"
+msgstr ""
+"Nome do mapa raster contendo informação de coordenada norte do caminho "
+"retrógrado"
 #: ../raster/r.circle/main.c:64
 #, fuzzy
@@ -3804,8 +3998,22 @@
 msgstr ""
 #: ../raster/r.sun/main.c:234
-msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
-msgstr "Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, comprimento do dia) são guardados num arquivo de histórico de mapa. Alternativamente, um horário local pode ser especificado para calcular ângulo de incidência solar e/ou mapas raster de irradiância. O efeito de sombreamento da topografia também pode ser opcionalmente incorporado."
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
+msgstr ""
+"Calcula mapas raster de irradiação solar direta(feixe) difusa e refletida "
+"para um dado dia, latitude, superfície e condições atmosféricas. Parâmetros "
+"solares (p.ex. alvorada, ocaso, declinação, irradiância extraterreste, "
+"comprimento do dia) são guardados num arquivo de histórico de mapa. "
+"Alternativamente, um horário local pode ser especificado para calcular "
+"ângulo de incidência solar e/ou mapas raster de irradiância. O efeito de "
+"sombreamento da topografia também pode ser opcionalmente incorporado."
 #: ../raster/r.sun/main.c:248 ../raster/r.horizon/main.c:198
 msgid "Name of the input elevation raster map [meters]"
@@ -3828,24 +4036,34 @@
 msgstr ""
 #: ../raster/r.sun/main.c:257
-msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
-msgstr "Nome do mapa de aspecto (aspecto do terreno ou azimute do painel solar) [graus decimais]"
+msgid ""
+"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
+"[decimal degrees]"
+msgstr ""
+"Nome do mapa de aspecto (aspecto do terreno ou azimute do painel solar) "
+"[graus decimais]"
 #: ../raster/r.sun/main.c:266
 msgid "A single value of the orientation (aspect), 270 is south"
 msgstr "Um único valor da orientação (aspecto), 270 é sul"
 #: ../raster/r.sun/main.c:275
-msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
-msgstr "Nome do mapa de declividade (declividade do terreno ou inclinação do painel solar) [graus decimais]"
+msgid ""
+"Name of the input slope raster map (terrain slope or solar panel "
+"inclination) [decimal degrees]"
+msgstr ""
+"Nome do mapa de declividade (declividade do terreno ou inclinação do painel "
+"solar) [graus decimais]"
 #: ../raster/r.sun/main.c:283
 msgid "A single value of inclination (slope)"
 msgstr "Um único valor de inclinação (declividade)"
 #: ../raster/r.sun/main.c:292
-msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr "Nome do arquivo raster com o coeficiente de turbidez atmosférica de Linke [-]"
+msgid ""
+"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr ""
+"Nome do arquivo raster com o coeficiente de turbidez atmosférica de Linke [-]"
 #: ../raster/r.sun/main.c:302
 msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -3872,7 +4090,8 @@
 #: ../raster/r.sun/main.c:350
 #, fuzzy
 msgid "Name of real-sky beam radiation coefficient input raster map [-]"
-msgstr "Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
+msgstr ""
+"Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
 #: ../raster/r.sun/main.c:359
 #, fuzzy
@@ -3905,25 +4124,41 @@
 msgstr ""
 #: ../raster/r.sun/main.c:393
-msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Saída de irradiação do feixe [W.m-2] (modo 1) ou arquivo raster de irradiação [Wh.m².dia-1] (modo 2)"
+msgid ""
+"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+"Saída de irradiação do feixe [W.m-2] (modo 1) ou arquivo raster de "
+"irradiação [Wh.m².dia-1] (modo 2)"
 #: ../raster/r.sun/main.c:402
 msgid "Output insolation time raster map [h] (mode 2 only)"
 msgstr "Saída de mapa raster de tempo de insolação [h] (apenas modo 2)"
 #: ../raster/r.sun/main.c:411
-msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Saída de irradiação difusa [W.m-2] (modo 1) ou arquivo raster de irradiação [Wh.m².dia-1] (modo 2)"
+msgid ""
+"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
+msgstr ""
+"Saída de irradiação difusa [W.m-2] (modo 1) ou arquivo raster de irradiação "
+"[Wh.m².dia-1] (modo 2)"
 #: ../raster/r.sun/main.c:420
-msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr "Saída de irradiação refletida [W.m-2] (modo 1) ou arquivo raster de irradiação [Wh.m².dia-1] (modo 2)"
+msgid ""
+"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
+"map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
+"Saída de irradiação refletida [W.m-2] (modo 1) ou arquivo raster de "
 #: ../raster/r.sun/main.c:429
 #, fuzzy
-msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgid ""
+"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
+"irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr ""
 #: ../raster/r.sun/main.c:436
 msgid "No. of day of the year (1-365)"
@@ -3931,11 +4166,14 @@
 #: ../raster/r.sun/main.c:445
 msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr "Intervalo de tempo para computar soma de radiação do dia todo [horas decimais]"
+msgstr ""
+"Intervalo de tempo para computar soma de radiação do dia todo [horas "
+"decimais]"
 #: ../raster/r.sun/main.c:452
 msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr "Valor de declinação (sobrepõe o valor calculado internamente) [radianos]"
+msgstr ""
+"Valor de declinação (sobrepõe o valor calculado internamente) [radianos]"
 #: ../raster/r.sun/main.c:460
 msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
@@ -3999,7 +4237,8 @@
 msgstr ""
 #: ../raster/r.sun/main.c:605
-msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgid ""
+"If you use the horizon option you must also set the 'horizonstep' parameter."
 msgstr ""
 #: ../raster/r.sun/main.c:611
@@ -4008,7 +4247,9 @@
 #: ../raster/r.sun/main.c:613
 #, fuzzy
-msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgid ""
+"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
+"time"
 msgstr "Modo ângulo"
 #: ../raster/r.sun/main.c:618
@@ -4026,7 +4267,9 @@
 msgstr ""
 #: ../raster/r.sun/main.c:679
-msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgid ""
+"If you want to save memory and to use shadows, you must use pre-calculated "
+"horizons."
 msgstr ""
 #: ../raster/r.sun/main.c:724 ../general/g.region/printwindow.c:247
@@ -4071,7 +4314,9 @@
 msgstr "Converte mapas raster para o formato VTK-ASCII"
 #: ../raster/r.out.vtk/main.c:72
-msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
+msgid ""
+"No input maps specified. You need to specify at least one input map or three "
+"vector maps or three rgb maps."
 msgstr ""
 #: ../raster/r.out.vtk/main.c:130 ../raster/r.out.vtk/main.c:190
@@ -4088,7 +4333,8 @@
 #: ../raster/r.out.vtk/main.c:231
 #, fuzzy
 msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr "Mapas RGB errados. Mapas devem ser do mesmo tipo! Saída RGB não adicionada!"
+msgstr ""
+"Mapas RGB errados. Mapas devem ser do mesmo tipo! Saída RGB não adicionada!"
 #: ../raster/r.out.vtk/main.c:260
 #, fuzzy
@@ -4097,8 +4343,10 @@
 #: ../raster/r.out.vtk/main.c:270
 #, fuzzy
-msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid ""
+"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr ""
 #: ../raster/r.out.vtk/parameters.c:34
 msgid "Raster map(s) to be converted to VTK-ASCII data format"
@@ -4120,18 +4368,24 @@
 #: ../raster/r.out.vtk/parameters.c:69
 #, fuzzy
-msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgid ""
+"Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr "Criar dados pontual VTK ao invés de dado VTK celular (padrão)"
 #: ../raster/r.out.vtk/parameters.c:79
 #, fuzzy
-msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgid ""
+"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr ""
 #: ../raster/r.out.vtk/parameters.c:89
 #, fuzzy
 msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
+msgstr ""
 #: ../raster/r.out.vtk/parameters.c:114
 msgid "Use structured grid for elevation (not recommended)"
@@ -4143,8 +4397,11 @@
 msgstr "Usar polydata-trianglestrips para criação da malha de elevação"
 #: ../raster/r.out.vtk/parameters.c:126
-msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr "Usar polydata-vertices para criação da malha de elevação (para usar com vtkDelauny2D)"
+msgid ""
+"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr ""
+"Usar polydata-vertices para criação da malha de elevação (para usar com "
+"vtkDelauny2D)"
 #: ../raster/r.out.vtk/parameters.c:132
 #, fuzzy
@@ -4211,7 +4468,8 @@
 #: ../raster/r.quant/main.c:51
 #, fuzzy
 msgid "Produces the quantization file for a floating-point map."
-msgstr "Esta rotina produz um arquivo de quantização para um mapa floating point."
+msgstr ""
+"Esta rotina produz um arquivo de quantização para um mapa floating point."
 #: ../raster/r.quant/main.c:59
 msgid "Raster map(s) to be quantized"
@@ -4354,8 +4612,13 @@
 #: ../raster/r.slope.aspect/main.c:154
 #, fuzzy
-msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
-msgstr "Gera mapas raster de declividade, direção da encosta, curvaturas e derivadas parciais a partir de um mapa raster com valores verdadeiros de elevação. Aspecto é calculado no sentido anti-horário a partir do leste."
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from a elevation raster map."
+msgstr ""
+"Gera mapas raster de declividade, direção da encosta, curvaturas e derivadas "
+"parciais a partir de um mapa raster com valores verdadeiros de elevação. "
+"Aspecto é calculado no sentido anti-horário a partir do leste."
 #: ../raster/r.slope.aspect/main.c:156
 #, fuzzy
@@ -4412,12 +4675,14 @@
 #: ../raster/r.slope.aspect/main.c:209
 #, fuzzy
-msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgid ""
+"Name for output first order partial derivative dx (E-W slope) raster map"
 msgstr "Nome do arquivo da primeira derivada parcial dx (declive E-W)"
 #: ../raster/r.slope.aspect/main.c:216
 #, fuzzy
-msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgid ""
+"Name for output first order partial derivative dy (N-S slope) raster map"
 msgstr "Nome do arquivo da primeira derivada parcial dy (declive N-S)"
 #: ../raster/r.slope.aspect/main.c:223
@@ -4441,7 +4706,9 @@
 #: ../raster/r.slope.aspect/main.c:252
 msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr "Mínimo valor da declividade (em porcentagem) para qual o aspecto será computado"
+msgstr ""
+"Mínimo valor da declividade (em porcentagem) para qual o aspecto será "
+"computado"
 #: ../raster/r.slope.aspect/main.c:261
 msgid "Do not align the current region to the elevation layer"
@@ -4459,7 +4726,9 @@
 #: ../raster/r.slope.aspect/main.c:334
 #, c-format
-msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgid ""
+"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%"
+"s>, <%s>, <%s>, <%s> or <%s>"
 msgstr ""
 #: ../raster/r.slope.aspect/main.c:358
@@ -4539,8 +4808,14 @@
 msgstr "Mapa raster 3D <%s> não encontrado"
 #: ../raster/r.cost/main.c:143
-msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
-msgstr "Gera um mapa raster mostrando o custo acumulado de movimento entre diferentes localizações em um mapa raster de entrada cujos valores de célula representam o custo."
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+"Gera um mapa raster mostrando o custo acumulado de movimento entre "
+"diferentes localizações em um mapa raster de entrada cujos valores de célula "
+"representam o custo."
 #: ../raster/r.cost/main.c:150
 msgid "Name of raster map containing grid cell cost information"
@@ -4597,7 +4872,8 @@
 #: ../raster/r.cost/main.c:336
 #, fuzzy
 msgid "Assigning negative cost to null cell. Null cells excluded."
+msgstr ""
 #: ../raster/r.cost/main.c:458
 #, fuzzy, c-format
@@ -4824,8 +5100,12 @@
 msgstr "criando novo arquivo cats ..."
 #: ../raster/r.patch/main.c:55
-msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr "Cria um mapa raster composto, usando valores conhecidos de categorias de uma (ou mais) camada(s) para preencher áreas de \"no data\" em outra camada."
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+"Cria um mapa raster composto, usando valores conhecidos de categorias de uma "
+"(ou mais) camada(s) para preencher áreas de \"no data\" em outra camada."
 #: ../raster/r.patch/main.c:62
 msgid "Name of raster maps to be patched together"
@@ -4865,7 +5145,9 @@
 msgstr "Fonte"
 #: ../raster/simwe/r.sim.sediment/main.c:118
-msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
 msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:125
@@ -4892,7 +5174,8 @@
 #: ../raster/simwe/r.sim.sediment/main.c:138
 #, fuzzy
 msgid "Name of detachment capacity coefficient raster map [s/m]"
+msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:143
 #, fuzzy
@@ -4948,7 +5231,9 @@
 msgstr "Nome do mapa vetorial (2d) de entrada"
 #: ../raster/simwe/r.sim.sediment/main.c:182
-msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
+msgid ""
+"Name of the sampling points output text file. For each observation vector "
+"point the time series of sediment transport is stored."
 msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:183
@@ -5112,7 +5397,9 @@
 msgstr "Nome do raster de entrada"
 #: ../raster/simwe/r.sim.water/main.c:191
-msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
+msgid ""
+"point the time series of water depth is stored."
 msgstr ""
 #: ../raster/simwe/r.sim.water/main.c:197
@@ -5166,7 +5453,9 @@
 #: ../raster/simwe/simlib/input.c:58
 #, c-format
-msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
 msgstr ""
 #: ../raster/simwe/simlib/input.c:171
@@ -5406,7 +5695,9 @@
 #: ../raster/r.out.ppm3/main.c:58
 #, fuzzy
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr "Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução da região atualmente definida."
+msgstr ""
+"Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução da "
+"região atualmente definida."
 #: ../raster/r.out.ppm3/main.c:63 ../raster/r.composite/main.c:89
 #, c-format
@@ -5437,8 +5728,11 @@
 msgstr "Inportação de vetor incompleta"
 #: ../raster/r.transect/main.c:106
-msgid "Outputs raster map layer values lying along user defined transect line(s)."
-msgstr "Gera uma camada de valores de um mapa raster ao redor de linhas de perfil definidas pelo usuário."
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+"Gera uma camada de valores de um mapa raster ao redor de linhas de perfil "
+"definidas pelo usuário."
 #: ../raster/r.transect/main.c:110
 msgid "Raster map to be queried"
@@ -5450,12 +5744,16 @@
 #: ../raster/r.transect/main.c:130 ../raster/r.profile/main.c:91
 msgid "Output easting and northing in first two columns of four column output"
-msgstr "Exporta leste e norte nas duas primeiras colunas da saída de quatro colunas"
+msgstr ""
+"Exporta leste e norte nas duas primeiras colunas da saída de quatro colunas"
 #: ../raster/r.random/main.c:55
 #, fuzzy
-msgid "Creates a raster map layer and vector point map containing randomly located points."
-msgstr "Cria um mapa raster e um mapa vetorial de pontos contendo locais aleatórios"
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+"Cria um mapa raster e um mapa vetorial de pontos contendo locais aleatórios"
 #: ../raster/r.random/main.c:64
 msgid "Name of cover raster map"
@@ -5622,7 +5920,8 @@
 msgstr ""
 #: ../raster/r.los/main.c:245
-msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgid ""
+"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
 msgstr ""
 #: ../raster/r.los/main.c:250
@@ -5635,15 +5934,19 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:62
-msgid "Input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
+msgid ""
+"Input raster map providing Boundary condition status: 0-inactive, 1-active, "
+"2-dirichlet"
 msgstr ""
 #: ../raster/r.gwflow/main.c:67
-msgid "Input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:72
-msgid "Input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
+msgid ""
+"Input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:77
@@ -5680,15 +5983,20 @@
 msgstr "Título do raster de saída"
 #: ../raster/r.gwflow/main.c:106
-msgid "Output raster map storing the groundwater filter velocity vector part in x direction [m/s]\n"
+msgid ""
+"Output raster map storing the groundwater filter velocity vector part in x "
+"direction [m/s]\n"
 msgstr ""
 #: ../raster/r.gwflow/main.c:112
-msgid "Output raster map storing the groundwater filter velocity vector part in y direction [m/s]\n"
+msgid ""
+"Output raster map storing the groundwater filter velocity vector part in y "
 msgstr ""
 #: ../raster/r.gwflow/main.c:118
-msgid "Output raster map storing the groundwater budget for each cell [m^3/s]\n"
+msgid ""
+"Output raster map storing the groundwater budget for each cell [m^3/s]\n"
 msgstr ""
 #: ../raster/r.gwflow/main.c:126
@@ -5700,11 +6008,14 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:140
-msgid "Input raster map providing the water level (head) of the river with leakage connection in [m]"
+msgid ""
+"Input raster map providing the water level (head) of the river with leakage "
+"connection in [m]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:147
-msgid "Input raster map providing the leakage coefficient of the river bed in [1/s]."
+msgid ""
+"Input raster map providing the leakage coefficient of the river bed in [1/s]."
 msgstr ""
 #: ../raster/r.gwflow/main.c:155
@@ -5712,11 +6023,15 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:162
-msgid "Input raster map providing the leakage coefficient of the drainage bed in [1/s]"
+msgid ""
+"Input raster map providing the leakage coefficient of the drainage bed in [1/"
+"s]"
 msgstr ""
 #: ../raster/r.gwflow/main.c:173
-msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
+msgid ""
+"Allocate a full quadratic linear equation system, default is a sparse linear "
+"equation system."
 msgstr ""
 #: ../raster/r.gwflow/main.c:206
@@ -5725,14 +6040,17 @@
 msgstr "Cor da Borda"
 #: ../raster/r.gwflow/main.c:208
-msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:218 ../raster/r.solute.transport/main.c:244
 #: ../raster/r.topidx/main.c:53
 #, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr "Locação Lat/Long não é suportada por %s. Favor reprojetar o mapa primeiro."
+msgstr ""
+"Locação Lat/Long não é suportada por %s. Favor reprojetar o mapa primeiro."
 #: ../raster/r.gwflow/main.c:233
 msgid "Please provide river_head, river_leak and river_bed maps"
@@ -5759,7 +6077,9 @@
 #: ../raster/r.statistics2/main.c:104
 #, fuzzy
-msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
 msgstr "Estatística orientadas a objetos ou categorias."
 #: ../raster/r.statistics2/main.c:114 ../raster/r.statistics/main.c:76
@@ -5772,7 +6092,8 @@
 #: ../raster/r.statistics2/main.c:143 ../raster/r.statistics/main.c:86
 msgid "Cover values extracted from the category labels of the cover map"
-msgstr "Valores de cobertura extraídos dos rótulos de categorias no mapa de cobertura"
+msgstr ""
+"Valores de cobertura extraídos dos rótulos de categorias no mapa de cobertura"
 #: ../raster/r.statistics2/main.c:148 ../raster/r.statistics3/main.c:425
 msgid "Create reclass map with statistics as category labels"
@@ -5836,7 +6157,8 @@
 #: ../raster/r.profile/main.c:53
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr "Imprime os valores do mapa raster ao longo das linhas definidas pelo usuário."
+msgstr ""
+"Imprime os valores do mapa raster ao longo das linhas definidas pelo usuário."
 #: ../raster/r.profile/main.c:64
 msgid "Name of file for output (use output=- for stdout)"
@@ -5910,8 +6232,12 @@
 msgstr "Mapa raster de entrada"
 #: ../raster/r.buffer/main.c:69
-msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "Cria uma camada raster mostrando zonas tampão ao redor das células que contém valores de categoria não-NULOS."
+msgid ""
+"Creates a raster map layer showing buffer zones surrounding cells that "
+"contain non-NULL category values."
+msgstr ""
+"Cria uma camada raster mostrando zonas tampão ao redor das células que "
+"contém valores de categoria não-NULOS."
 #: ../raster/r.buffer/main.c:81
 #: ../locale/scriptstrings/r.buffer_to_translate.c:7
@@ -5968,8 +6294,12 @@
 #: ../raster/r.series/main.c:133
-msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
-msgstr "Define cada célula da saída como função dos valores designados para as células correspondentes nos mapas raster de entrada."
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+"Define cada célula da saída como função dos valores designados para as "
+"células correspondentes nos mapas raster de entrada."
 #: ../raster/r.series/main.c:147
 msgid "Aggregate operation"
@@ -6013,7 +6343,9 @@
 msgstr "Nome do mapa raster de elevação"
 #: ../raster/r.usler/main.c:70
-msgid "roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-Swaify (1985)"
+msgid ""
+"roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-"
+"Swaify (1985)"
 msgstr ""
 #: ../raster/r.spread/main.c:103 ../raster/r.spreadpath/main.c:90
@@ -6024,11 +6356,21 @@
 #: ../raster/r.spread/main.c:105
 #, fuzzy
-msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr "Simula o espalhamento elipticamente anisotrópico numa janela gráfica e gera um mapa raster do tempo cumulativo de espalhamento, sendo dados mapas contendo a razão de espalhamento (RdE), as direções de RdE e os focos originais. Opcionalmente produz mapas raster contendo as coordenadas UTM para o traçado das rotas de espalhamento."
+msgid ""
+"Simulates elliptically anisotropic spread on a graphics window and generates "
+"a raster map of the cumulative time of spread, given raster maps containing "
+"the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr ""
+"Simula o espalhamento elipticamente anisotrópico numa janela gráfica e gera "
+"um mapa raster do tempo cumulativo de espalhamento, sendo dados mapas "
+"contendo a razão de espalhamento (RdE), as direções de RdE e os focos "
+"originais. Opcionalmente produz mapas raster contendo as coordenadas UTM "
+"para o traçado das rotas de espalhamento."
 #: ../raster/r.spread/main.c:110
-msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
+msgid ""
+"It optionally produces raster maps to contain backlink UTM coordinates for "
+"tracing spread paths."
 msgstr ""
 #: ../raster/r.spread/main.c:118 ../raster/r.spread/main.c:127
@@ -6041,7 +6383,8 @@
 #: ../raster/r.spread/main.c:120
 msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr "Nome do mapa raster contendo máxima razão de espalhamento (RdE) (cm/min)"
+msgstr ""
+"Nome do mapa raster contendo máxima razão de espalhamento (RdE) (cm/min)"
 #: ../raster/r.spread/main.c:129
 msgid "Name of raster map containing DIRections of max ROS (degree)"
@@ -6056,17 +6399,25 @@
 msgstr "Nome do mapa raster contendo focos iniciais"
 #: ../raster/r.spread/main.c:155
-msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr "Nome do mapa raster contendo máxima distância de avistamento (m) (requer w/-s)"
+msgid ""
+"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr ""
+"Nome do mapa raster contendo máxima distância de avistamento (m) (requer w/-"
+"s)"
 #: ../raster/r.spread/main.c:163
-msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgid ""
+"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
 msgstr "Nome do mapa raster contendo velocidade do vento das chamas (pés/min)"
 #: ../raster/r.spread/main.c:171
 #, fuzzy
-msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
-msgstr "Nome do mapa raster contendo a umidade do combustível fino da célula recebendo um tição incandescente (requer w/-s)"
+msgid ""
+"Name of raster map containing fine Fuel MOISture of the cell receiving a "
+"spotting firebrand (%) (required w/ -s)"
+msgstr ""
+"Nome do mapa raster contendo a umidade do combustível fino da célula "
+"recebendo um tição incandescente (requer w/-s)"
 #: ../raster/r.spread/main.c:179
 msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
@@ -6074,7 +6425,9 @@
 #: ../raster/r.spread/main.c:186
 msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr "Densidade de amostragem para computação adicional (intervalo: 0.0 - 1.0 (0.5))"
+msgstr ""
+"Densidade de amostragem para computação adicional (intervalo: 0.0 - 1.0 "
+"(0.5))"
 #: ../raster/r.spread/main.c:193
 msgid "INITial TIME for current simulation (0) (min)"
@@ -6142,8 +6495,11 @@
 #: ../raster/r.surf.idw2/main.c:84
 #, fuzzy
-msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr "Bancos de dados lat/long não são suportados por r.flow. Use 'r.watershed' para calcular fluxo."
+msgid ""
+"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr ""
+"Bancos de dados lat/long não são suportados por r.flow. Use 'r.watershed' "
+"para calcular fluxo."
 #: ../raster/r.surf.idw2/main.c:88
 #, c-format
@@ -6232,7 +6588,8 @@
 msgstr "Mapa de entrada: terreno bloqueando fluxo superficial, para USLE"
 #: ../raster/r.watershed/front/main.c:103
-msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgid ""
+"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:110
@@ -6293,7 +6650,8 @@
 #: ../raster/r.watershed/front/main.c:165
 #, fuzzy
 msgid "Slope length and steepness (LS) factor for USLE"
-msgstr "Saída de mapa: fator de comprimento do declive e declividade (LS) para USLE"
+msgstr ""
+"Saída de mapa: fator de comprimento do declive e declividade (LS) para USLE"
 #: ../raster/r.watershed/front/main.c:171
 #, fuzzy
@@ -6335,7 +6693,9 @@
 msgstr "Habilita opção de swap em disco: Operação é lenta"
 #: ../raster/r.watershed/front/main.c:208
-msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgid ""
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
 msgstr ""
 #: ../raster/r.watershed/front/main.c:213
@@ -6425,13 +6785,30 @@
 #, fuzzy, c-format
 msgid ""
 "USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold "
+"[flow=overland_flow_map] [drainage=drain_direction_map] "
+"[depression=depression_map] [accumulation=accumulation_map] "
+"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
 "\n"
 "USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold "
+"[drainage=drain_direction_map] [depression=depression_map] "
+"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
+"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
+"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
+"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
+"creation:\n"
+"[basin=watershed_basin_map] [stream=stream_segment_map] "
+"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
 "\n"
-msgstr "mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo mapear mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo mapear mapear comprimento mapear limiar mapear mapear mapear exibir mapear comprimento Bloqueio mapear mapear LS comprimento mapear mapear mapear"
+msgstr ""
+"mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo mapear "
+"mapear comprimento mapear limiar mapear mapear mapear exibir mapear "
+"comprimento Bloqueio mapear mapear LS comprimento mapear mapear mapear"
 #: ../raster/r.watershed/ram/do_astar.c:27
 #: ../raster/r.watershed/seg/do_astar.c:33
@@ -6506,7 +6883,7 @@
 msgid "SECTION 1a (of %1d): Initiating Memory."
 msgstr "de Memória."
-#: ../raster/r.watershed/ram/init_vars.c:296
+#: ../raster/r.watershed/ram/init_vars.c:300
 #, fuzzy, c-format
 msgid "SECTION 1b (of %1d): Determining Offmap Flow."
 msgstr "de Por cento Concluir "
@@ -6695,17 +7072,20 @@
 #: ../raster/r.watershed/shed/com_line.c:83
 #, fuzzy
-msgid "depression map indicates all the locations in the current map window where"
+msgid ""
+"depression map indicates all the locations in the current map window where"
 msgstr "mapear todos em atual mapear"
 #: ../raster/r.watershed/shed/com_line.c:84
 #, fuzzy
-msgid "water accumulates and does not leave by the edge of the map. Lakes without"
+msgid ""
+"water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr "não de mapear"
 #: ../raster/r.watershed/shed/com_line.c:85
 #, fuzzy
-msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid ""
+"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr "de para"
 #: ../raster/r.watershed/shed/com_line.c:86
@@ -6720,7 +7100,8 @@
 #: ../raster/r.watershed/shed/com_line.c:88
 #, fuzzy
-msgid "Hit <return> by itself for the next question if there is no depression map."
+msgid ""
+"Hit <return> by itself for the next question if there is no depression map."
 msgstr "<return> seguinte é mapear."
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -6732,12 +7113,15 @@
 #: ../raster/r.watershed/shed/com_line.c:101
 #, fuzzy
-msgid "watershed basins.  The number of watershed basins is indirectly determined"
+msgid ""
+"watershed basins.  The number of watershed basins is indirectly determined"
 msgstr "de é"
 #: ../raster/r.watershed/shed/com_line.c:102
 #, fuzzy
-msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
+msgid ""
+"by the `basin threshold' value.  The basin threshold is the area necessary "
+"for"
 msgstr "limiar limiar é área"
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -6747,17 +7131,20 @@
 #: ../raster/r.watershed/shed/com_line.c:105
 #, fuzzy
-msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid ""
+"`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr "não"
 #: ../raster/r.watershed/shed/com_line.c:106
 #, fuzzy
-msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid ""
+"drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr "é"
 #: ../raster/r.watershed/shed/com_line.c:107
 #, fuzzy
-msgid "by the surface flow going into stream segments between stream interceptions."
+msgid ""
+"by the surface flow going into stream segments between stream interceptions."
 msgstr "fluxo entre fluxo."
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -6772,17 +7159,20 @@
 #: ../raster/r.watershed/shed/com_line.c:111
 #, fuzzy
-msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid ""
+"(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr "para"
 #: ../raster/r.watershed/shed/com_line.c:112
 #, fuzzy
-msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgid ""
+"develop stream channels than neighboring areas with high infiltration rates)."
 msgstr "fluxo."
 #: ../raster/r.watershed/shed/com_line.c:113
 #, fuzzy
-msgid "The user can create a map layer with potential overland flow values, and"
+msgid ""
+"The user can create a map layer with potential overland flow values, and"
 msgstr "mapear"
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -6797,7 +7187,8 @@
 #: ../raster/r.watershed/shed/com_line.c:119
 msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
-msgstr " 1) acres,          2) metros quadrados, 3) milhas quadradas, 4) hectares,"
+msgstr ""
+" 1) acres,          2) metros quadrados, 3) milhas quadradas, 4) hectares,"
 #: ../raster/r.watershed/shed/com_line.c:120
 #, fuzzy
@@ -6894,7 +7285,8 @@
 #: ../raster/r.watershed/shed/com_line.c:296
 #, fuzzy
-msgid "ability to generate several variables in the Revised Universal Soil Loss"
+msgid ""
+"ability to generate several variables in the Revised Universal Soil Loss"
 msgstr "para em"
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -6916,7 +7308,9 @@
 #: ../raster/r.watershed/shed/com_line.c:351
 #, fuzzy
-msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgid ""
+"where the value indicates the percent of disturbed (barren) land in that "
+"cell."
 msgstr "de em célula."
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -6962,8 +7356,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid "that prevents the surface flow distance from getting too long.  Normally,"
-msgstr "isso previne que a distância de fluxo superficial fique muito grande.  Normalmente,"
+msgid ""
+"that prevents the surface flow distance from getting too long.  Normally,"
+msgstr ""
+"isso previne que a distância de fluxo superficial fique muito grande.  "
+"Normalmente,"
 #: ../raster/r.watershed/shed/com_line.c:385
 #, fuzzy
@@ -6979,7 +7376,8 @@
 #: ../raster/r.watershed/shed/com_line.c:401
 #, fuzzy
-msgid "slope length.  You may input a raster map indicating the locations of these"
+msgid ""
+"slope length.  You may input a raster map indicating the locations of these"
 msgstr "comprimento mapear de"
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -6989,7 +7387,8 @@
 #: ../raster/r.watershed/shed/com_line.c:403
 #, fuzzy
-msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgid ""
+"Hit <return> by itself for the next question if there is no blocking map."
 msgstr "<return> seguinte é Bloqueio mapear."
 #: ../raster/r.watershed/shed/basin_maps.c:12
@@ -7121,7 +7520,9 @@
 #: ../raster/r.info/main.c:73
 #, fuzzy
 msgid "Output basic information about a raster map layer."
-msgstr "Imprime informações básicas sobre uma camada de mapa especificada pelo usuário."
+msgstr ""
+"Imprime informações básicas sobre uma camada de mapa especificada pelo "
+"usuário."
 #: ../raster/r.info/main.c:84
 msgid "Print raster map resolution (NS-res, EW-res) only"
@@ -7212,8 +7613,12 @@
 msgstr "Calculando sombras a partir do DEM..."
 #: ../raster/r.covar/main.c:54
-msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
-msgstr "Calcula uma matriz de covariancia/correlação para as camadas do mapa raster especificadas pelo usuário."
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
+msgstr ""
+"Calcula uma matriz de covariancia/correlação para as camadas do mapa raster "
+"especificadas pelo usuário."
 #: ../raster/r.covar/main.c:61
 msgid "Print correlation matrix"
@@ -7311,7 +7716,9 @@
 #: ../raster/r.statistics3/main.c:469
 #, fuzzy, c-format
 msgid "Number of quantiles (%d) does not match number of output maps (%d)"
-msgstr "Número de colunas definidas (%d) não coincide com o número de colunas (%d) da entrada."
+msgstr ""
+"Número de colunas definidas (%d) não coincide com o número de colunas (%d) "
+"da entrada."
 #: ../raster/r.statistics3/main.c:486
 #, fuzzy, c-format
@@ -7344,7 +7751,9 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:79
-msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
+msgid ""
+"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
+"dirichlet- and 3 - transfer boundary condition"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:85
@@ -7368,11 +7777,14 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:103
-msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid ""
+"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:112
-msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
+msgid ""
+"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
+"reaction)"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:117
@@ -7393,15 +7805,21 @@
 msgstr "Mapa base raster"
 #: ../raster/r.solute.transport/main.c:132
-msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
+msgid ""
+"The resulting concentration of the numerical solute transport calculation "
+"will be written to this map. [kg/m^3]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:140
-msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in x "
 msgstr ""
 #: ../raster/r.solute.transport/main.c:147
-msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in y "
 msgstr ""
 #: ../raster/r.solute.transport/main.c:161
@@ -7413,7 +7831,9 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:177
-msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
+msgid ""
+"Use this number of time loops if the CFL flag is off. The timestep will "
+"become dt/loops."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:187
@@ -7430,7 +7850,9 @@
 msgstr "Número de pontos de interpolação"
 #: ../raster/r.solute.transport/main.c:233
-msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:258
@@ -7463,7 +7885,8 @@
 #: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid "The time step is to large: %gs. The largest time step should be of size %gs."
+msgid ""
+"The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:397
@@ -7476,6 +7899,160 @@
 msgid "Could not create and solve the linear equation system"
 msgstr "Não consegui criar arquivo raster [%s]."
+#: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:162
+#: ../vector/v.surf.bspline/main.c:93
+#: ../vector/v.lidar.edgedetection/main.c:73
+#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
+msgid "LIDAR"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:165
+msgid "Create a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+#: ../raster/r.in.lidar/main.c:169
+#, fuzzy
+msgid "LiDAR LAS input file"
+msgstr "Arquivo de entrada"
+#: ../raster/r.in.lidar/main.c:177 ../raster/r.in.xyz/main.c:176
+#, fuzzy
+msgid "Statistic to use for raster values"
+msgstr "Relatório de estatísticas para mapas raster."
+#: ../raster/r.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:221
+#: ../raster/r.in.lidar/main.c:230 ../raster/r.in.xyz/main.c:180
+#: ../raster/r.in.xyz/main.c:248 ../raster/r.in.xyz/main.c:257
+msgid "Statistic"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:189 ../raster/r.in.xyz/main.c:188
+#: ../raster/r.in.arc/main.c:81
+msgid "Storage type for resultant raster map"
+msgstr "Tipo de armazenamento para o mapa resultante"
+#: ../raster/r.in.lidar/main.c:196 ../raster/r.in.xyz/main.c:223
+#, fuzzy
+msgid "Filter range for z data (min,max)"
+msgstr "Intervalo de inteiro: min,max"
+#: ../raster/r.in.lidar/main.c:203 ../raster/r.in.xyz/main.c:230
+msgid "Scale to apply to z data"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:220 ../raster/r.in.xyz/main.c:247
+#, fuzzy
+msgid "pth percentile of the values"
+msgstr "Formato para relatar a declividade"
+#: ../raster/r.in.lidar/main.c:229 ../raster/r.in.xyz/main.c:256
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:222
+#: ../vector/v.in.lidar/main.c:203
+#, fuzzy
+msgid "Override dataset projection (use location's projection)"
+msgstr "Sobrescrever projeção (usar projeção da locação)"
+#: ../raster/r.in.lidar/main.c:239 ../raster/r.in.xyz/main.c:261
+msgid "Scan data file for extent then exit"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:266
+#, fuzzy
+msgid "In scan mode, print using shell script style"
+msgstr "Mostra as estatísticas em estilo shell script"
+#: ../raster/r.in.lidar/main.c:263 ../vector/v.in.lidar/main.c:238
+#, c-format
+msgid "Input file <%s> is not a LAS LiDAR point cloud"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:281 ../vector/v.in.ogr/main.c:501
+#: ../vector/v.in.lidar/main.c:372
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr ""
+"Não consegui converter a projeção do mapa de entrada para o formato do GRASS "
+"para verificação"
+#: ../raster/r.in.lidar/main.c:311 ../vector/v.in.ogr/main.c:531
+#: ../vector/v.in.lidar/main.c:405
+#, fuzzy
+msgid "GRASS LOCATION PROJ_INFO is:\n"
+msgstr "Locação: %s\n"
+#: ../raster/r.in.lidar/main.c:371 ../vector/v.in.ogr/main.c:591
+#: ../vector/v.in.lidar/main.c:465
+#, fuzzy, c-format
+msgid ""
+"\n"
+"You can use the -o flag to %s to override this projection check.\n"
+msgstr ""
+"\n"
+"Você pode usar a opção -o para %s para ignorar esta verificação.\n"
+#: ../raster/r.in.lidar/main.c:374 ../vector/v.in.ogr/main.c:594
+#: ../vector/v.in.lidar/main.c:468
+#, fuzzy
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
+msgstr ""
+"Considere gerar uma nova locação com o parâmetro 'location' do dado de "
+"entrada.\n"
+#: ../raster/r.in.lidar/main.c:391 ../raster/r.in.xyz/main.c:307
+#, fuzzy
+msgid "Invalid zrange"
+msgstr "Fonte inválida: %s"
+#: ../raster/r.in.lidar/main.c:485 ../raster/r.in.xyz/main.c:394
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:497 ../raster/r.in.xyz/main.c:406
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:560 ../raster/r.in.xyz/main.c:488
+msgid "zrange will not be taken into account during scan"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:579 ../raster/r.in.xyz/main.c:524
+#, fuzzy
+msgid "Reading data ..."
+msgstr "Rotacionando dados ... "
+#: ../raster/r.in.lidar/main.c:596
+#, fuzzy
+msgid "Could not rewind input file"
+msgstr "Não consegui abrir arquivo vetorial <%s>"
+#: ../raster/r.in.lidar/main.c:757 ../raster/r.in.xyz/main.c:721
+#, fuzzy
+msgid "Writing to map ..."
+msgstr "Escrevendo [%s]..."
+#: ../raster/r.in.lidar/main.c:1103 ../raster/r.in.xyz/main.c:1059
+#, fuzzy, c-format
+msgid "%lu points found in region."
+msgstr "%d pontos fora da região atual."
+#: ../raster/r.in.lidar/main.c:1127 ../raster/r.in.xyz/main.c:1086
+#, fuzzy
+msgid "Scanning data ..."
+#: ../raster/r.in.lidar/main.c:1178 ../raster/r.in.xyz/main.c:1174
+#, c-format
+msgid "Range:     min         max\n"
+msgstr ""
 #: ../raster/r.proj/main.c:147 ../general/g.proj/main.c:61
 #: ../general/g.setproj/main.c:79 ../vector/v.proj/main.c:64
 #: ../locale/scriptstrings/m.proj_to_translate.c:3
@@ -7565,7 +8142,8 @@
 #: ../raster/r.proj/main.c:226
 #, fuzzy
-msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgid ""
+"Print input map's bounds in the current projection and exit (shell style)"
 msgstr "Imprime a região atual (no estilo de script em shell)"
 #: ../raster/r.proj/main.c:251 ../vector/v.proj/main.c:134
@@ -7810,8 +8388,12 @@
 #: ../raster/r.fill.dir/main.c:88
 #, fuzzy
-msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
-msgstr "Filtra e gera um mapa de elevação sem depressões e uma direção de fluxo a partir de um mapa de elevação fornecido"
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+"Filtra e gera um mapa de elevação sem depressões e uma direção de fluxo a "
+"partir de um mapa de elevação fornecido"
 #: ../raster/r.fill.dir/main.c:95 ../raster/r.topmodel/main.c:82
 #, fuzzy
@@ -7820,7 +8402,8 @@
 #: ../raster/r.fill.dir/main.c:99 ../raster/r.topmodel/main.c:89
 #, fuzzy
-msgid "Name for output flow direction map for depressionless elevation raster map"
+msgid ""
+"Name for output flow direction map for depressionless elevation raster map"
 msgstr "(o)   Mapa de direção com mapa de elevação sem depressões"
 #: ../raster/r.fill.dir/main.c:104
@@ -7935,8 +8518,10 @@
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:99
-msgid "Calculates univariate statistics from the non-null cells of a raster map."
-msgstr "Calcula estatísticas univariada das células não nulas de um mapa raster."
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+"Calcula estatísticas univariada das células não nulas de um mapa raster."
 #: ../raster/r.univar/r3.univar_main.c:37
 msgid "3D Raster map used for zoning, must be of type CELL"
@@ -7944,12 +8529,19 @@
 #: ../raster/r.univar/r3.univar_main.c:106
 #, fuzzy
-msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgid ""
+"Calculates univariate statistics from the non-null 3d cells of a raster3d "
+"map."
+msgstr ""
 #: ../raster/r.cross/main.c:76
-msgid "Creates a cross product of the category values from multiple raster map layers."
-msgstr "Cria um produto cruzado dos valores de categorias a partir de múltiplas camadas raster"
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+"Cria um produto cruzado dos valores de categorias a partir de múltiplas "
+"camadas raster"
 #: ../raster/r.cross/main.c:85
 #, c-format
@@ -7991,8 +8583,14 @@
 #: ../raster/r.resamp.rst/main.c:151
 #, fuzzy
-msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
-msgstr "Reinterpola e computa análise topográfica de um raster de entrada para um novo mapa raster (possivelmente com uma resolução diferente) usando uma spline regularizada com tensão e suavização."
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+"Reinterpola e computa análise topográfica de um raster de entrada para um "
+"novo mapa raster (possivelmente com uma resolução diferente) usando uma "
+"spline regularizada com tensão e suavização."
 #: ../raster/r.resamp.rst/main.c:162
 msgid "Desired east-west resolution"
@@ -8214,8 +8812,12 @@
 #: ../raster/r.category/main.c:55
 #, fuzzy
-msgid "Manages category values and labels associated with user-specified raster map layers."
-msgstr "Mostra valores de categoria e rótulos associados com camadas raster especificadas pelo usuário."
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+"Mostra valores de categoria e rótulos associados com camadas raster "
 #: ../raster/r.category/main.c:68
 #, fuzzy
@@ -8267,7 +8869,8 @@
 #: ../raster/r.category/main.c:265
 #, fuzzy
 msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr "O mapa é ponto flutuante! Ignorando lista de cats, usando lista de vals"
+msgstr ""
+"O mapa é ponto flutuante! Ignorando lista de cats, usando lista de vals"
 #: ../raster/r.category/main.c:282
 msgid "vals argument is required for floating point map!"
@@ -8285,8 +8888,12 @@
 #: ../raster/r.clump/main.c:50
 #, fuzzy
-msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
-msgstr "Agrupa células que formam áreas fisicamente discretas num raster, em categorias únicas."
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+"Agrupa células que formam áreas fisicamente discretas num raster, em "
+"categorias únicas."
 #: ../raster/r.clump/main.c:61
 msgid "Title"
@@ -8334,12 +8941,16 @@
 #: ../raster/r.out.tiff/main.c:176
 #, fuzzy, c-format
-msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
+msgid ""
+"Raster map <%s>> is a floating point map. Fractional values will be rounded "
+"to integer"
 msgstr "mapear em é mapear Decimal para!"
 #: ../raster/r.out.tiff/main.c:182
 #, fuzzy
-msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgid ""
+"Color map for palette must have less than 256 colors for the available range "
+"of data"
 msgstr "Cor mapear menos disponível intervalo de"
 #: ../raster/r.out.tiff/main.c:196
@@ -8357,14 +8968,10 @@
 msgid "Unable to open TIFF world file for writing"
 msgstr "Não consegui abrir o arquivo de células [%s]"
-#: ../raster/r.in.xyz/main.c:162 ../vector/v.surf.bspline/main.c:93
-#: ../vector/v.lidar.edgedetection/main.c:73
-#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
-msgid "LIDAR"
-msgstr ""
 #: ../raster/r.in.xyz/main.c:164
-msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgid ""
+"Create a raster map from an assemblage of many coordinates using univariate "
+"statistics."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:168
@@ -8372,24 +8979,12 @@
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
 msgstr "Arquivo ASCII contendo assinaturas espectrais"
-#: ../raster/r.in.xyz/main.c:176
-#, fuzzy
-msgid "Statistic to use for raster values"
-msgstr "Relatório de estatísticas para mapas raster."
-#: ../raster/r.in.xyz/main.c:180 ../raster/r.in.xyz/main.c:248
-#: ../raster/r.in.xyz/main.c:257
-msgid "Statistic"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.arc/main.c:81
-msgid "Storage type for resultant raster map"
-msgstr "Tipo de armazenamento para o mapa resultante"
 #: ../raster/r.in.xyz/main.c:199
 #, fuzzy
 msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr "Número da coluna usada como coordenada x (primeira coluna é 1) para o modo de pontos"
+msgstr ""
+"Número da coluna usada como coordenada x (primeira coluna é 1) para o modo "
+"de pontos"
 #: ../raster/r.in.xyz/main.c:207
 msgid "Column number of y coordinates in input file"
@@ -8399,33 +8994,6 @@
 msgid "Column number of data values in input file"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:223
-#, fuzzy
-msgid "Filter range for z data (min,max)"
-msgstr "Intervalo de inteiro: min,max"
-#: ../raster/r.in.xyz/main.c:230
-msgid "Scale to apply to z data"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:247
-#, fuzzy
-msgid "pth percentile of the values"
-msgstr "Formato para relatar a declividade"
-#: ../raster/r.in.xyz/main.c:256
-msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:261
-msgid "Scan data file for extent then exit"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:266
-#, fuzzy
-msgid "In scan mode, print using shell script style"
-msgstr "Mostra as estatísticas em estilo shell script"
 #: ../raster/r.in.xyz/main.c:270
 msgid "Ignore broken lines"
 msgstr ""
@@ -8435,37 +9003,17 @@
 msgid "Please specify a reasonable column number."
 msgstr "Especifique uma coluna z razoável."
-#: ../raster/r.in.xyz/main.c:307
-#, fuzzy
-msgid "Invalid zrange"
-msgstr "Fonte inválida: %s"
-#: ../raster/r.in.xyz/main.c:394
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:406
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr ""
 #: ../raster/r.in.xyz/main.c:482
-msgid "If input is not from a file it is only possible to perform a single pass."
+msgid ""
+"If input is not from a file it is only possible to perform a single pass."
 msgstr ""
-#: ../raster/r.in.xyz/main.c:488
-msgid "zrange will not be taken into account during scan"
-msgstr ""
-#: ../raster/r.in.xyz/main.c:524
-#, fuzzy
-msgid "Reading data ..."
-msgstr "Rotacionando dados ... "
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
 #: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the "
+"following character(s) in row %lu:\n"
 "[%s]"
 msgstr ""
@@ -8488,26 +9036,6 @@
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr ""
-#: ../raster/r.in.xyz/main.c:721
-#, fuzzy
-msgid "Writing to map ..."
-msgstr "Escrevendo [%s]..."
-#: ../raster/r.in.xyz/main.c:1059
-#, fuzzy, c-format
-msgid "%lu points found in region."
-msgstr "%d pontos fora da região atual."
-#: ../raster/r.in.xyz/main.c:1086
-#, fuzzy
-msgid "Scanning data ..."
-#: ../raster/r.in.xyz/main.c:1174
-#, c-format
-msgid "Range:     min         max\n"
-msgstr ""
 #: ../raster/r.texture/main.c:79
 #, fuzzy
 msgid "Generate images with textural features from a raster map."
@@ -8612,13 +9140,22 @@
 #: ../raster/r.texture/h_measure.c:84
 #, fuzzy
-msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
-msgstr "Pixel negativo ou sem dados encontrado. Este módulo ainda não é capaz de processar buracos no mapa, por favor preencha com r.fillnuls ou outro algoritmo."
+msgid ""
+"Negative or no data pixel found. This module is not yet able to process no "
+"data holes in a map, please fill with r.fillnulls or other algorithms"
+msgstr ""
+"Pixel negativo ou sem dados encontrado. Este módulo ainda não é capaz de "
+"processar buracos no mapa, por favor preencha com r.fillnuls ou outro "
+"algoritmo."
 #: ../raster/r.texture/h_measure.c:88
 #, c-format
-msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
-msgstr "Categorias demais (encontrei: %i, máx: %i). Tente rescalonar ou reclassificar o mapa."
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
+msgstr ""
+"Categorias demais (encontrei: %i, máx: %i). Tente rescalonar ou "
+"reclassificar o mapa."
 #: ../raster/r.texture/h_measure.c:927
 #, c-format
@@ -8627,8 +9164,12 @@
 #: ../raster/r.surf.random/main.c:40
 #, fuzzy
-msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
-msgstr "Produz uma camada de mapa raster com desvios aleatórios uniformes, cujo intervalo pode ser expresso pelo usuário."
+msgid ""
+"Produces a raster map of uniform random deviates whose range can be "
+"expressed by the user."
+msgstr ""
+"Produz uma camada de mapa raster com desvios aleatórios uniformes, cujo "
+"intervalo pode ser expresso pelo usuário."
 #: ../raster/r.surf.random/main.c:47
 msgid "Minimum random value"
@@ -8676,7 +9217,8 @@
 #: ../raster/r.surf.contour/main.c:64
 #, fuzzy
 msgid "Generates surface raster map from rasterized contours."
-msgstr "Programa para geração de superfícies a partir de isolinhas rasterizadas."
+msgstr ""
+"Programa para geração de superfícies a partir de isolinhas rasterizadas."
 #: ../raster/r.surf.contour/main.c:67
 #, fuzzy
@@ -8761,7 +9303,9 @@
 #: ../raster/r.colors/main.c:257
 #, fuzzy
-msgid "One of \"-r\" or options \"color\", \"raster\" or \"rules\" must be specified!"
+msgid ""
+"One of \"-r\" or options \"color\", \"raster\" or \"rules\" must be "
+"specified!"
 msgstr "Um de!"
 #: ../raster/r.colors/main.c:260
@@ -8820,7 +9364,8 @@
 #: ../raster/r.colors/rules.c:43
 #, c-format
 msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr "Carregue as regras, \"end\" quando concluir, \"help\" se precisar de ajuda.\n"
+msgstr ""
+"Carregue as regras, \"end\" quando concluir, \"help\" se precisar de ajuda.\n"
 #: ../raster/r.colors/rules.c:52
 #, fuzzy, c-format
@@ -8920,7 +9465,8 @@
 #: ../raster/r.li/r.li.padcv/padcv.c:38
 #, fuzzy
 msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
 #: ../raster/r.li/r.li.padcv/padcv.c:40 ../raster/r.li/r.li.mpa/mpa.c:42
 #: ../raster/r.li/r.li.patchnum/main.c:37 ../raster/r.li/r.li.mps/mps.c:43
@@ -8974,11 +9520,14 @@
 #: ../raster/r.li/r.li.patchnum/main.c:35
 #, fuzzy
-msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr "Não consegui fechar o novo mapa g3d"
 #: ../raster/r.li/r.li.mps/mps.c:41
-msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.pielou/pielou.c:57
@@ -8996,7 +9545,8 @@
 msgstr "Exibir"
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:39
-msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.cwed/cwed.c:47
@@ -9007,7 +9557,8 @@
 #: ../raster/r.li/r.li.padsd/padsd.c:38
 #, fuzzy
 msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
 #: ../raster/r.li/r.li.richness/richness.c:40
 #: ../raster/r.li/r.li.dominance/dominance.c:42
@@ -9025,7 +9576,8 @@
 #: ../raster/r.li/r.li.patchdensity/main.c:34
-msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.simpson/simpson.c:40
@@ -9204,7 +9756,9 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:202
-msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+msgid ""
+"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
+"Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:212
@@ -9228,7 +9782,9 @@
 #: ../raster/r.out.gdal/main.c:266
 #, c-format
-msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgid ""
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:271
@@ -9257,17 +9813,23 @@
 #: ../raster/r.out.gdal/main.c:434
 #, c-format
-msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+msgid ""
+"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
+"avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:445
 #, c-format
-msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid ""
+"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
+"datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:453
 #, c-format
-msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+msgid ""
+"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
+"This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:462 ../raster/r.out.gdal/main.c:505
@@ -9375,7 +9937,10 @@
 #: ../raster/r.out.gdal/main.c:743 ../raster/r.out.gdal/main.c:756
 #: ../raster/r.out.gdal/main.c:771
 #, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
+msgid ""
+"Mismatch between metadata nodata value and actual nodata value in exported "
+"raster: specified nodata value %g gets converted to %d by selected GDAL "
+"datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:719 ../raster/r.out.gdal/main.c:746
@@ -9391,7 +9956,10 @@
 #: ../raster/r.out.gdal/main.c:785
 #, c-format
-msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+msgid ""
+"raster: specified nodata value %g gets converted to %g by selected GDAL "
+"datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:788
@@ -9407,22 +9975,32 @@
 #: ../raster/r.out.gdal/export_band.c:171
 #, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %d will "
+"be used to represent no-data values in the input map. You can specify a "
+"nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:176
 #, c-format
-msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgid ""
+"Input raster map contains cells with NULL-value (no-data). The value %g will "
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:186
 #, c-format
-msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgid ""
+"The default nodata value is present in rasterband <%s> and would lead to "
+"data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:193
 #, c-format
-msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgid ""
+"The user given nodata value %g is present in rasterband <%s> and would lead "
+"to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:235
@@ -9472,7 +10050,8 @@
 #: ../raster/r.null/main.c:92
 #, fuzzy
 msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr "Fazer o serviço apenas se o mapa não tiver um arquivo bitmap de valores nulos"
+msgstr ""
+"Fazer o serviço apenas se o mapa não tiver um arquivo bitmap de valores nulos"
 #: ../raster/r.null/main.c:97
 msgid "Create NULL-value bitmap file validating all data cells"
@@ -9485,7 +10064,9 @@
 #: ../raster/r.null/main.c:119
 #, c-format
-msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgid ""
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/main.c:125
@@ -9967,13 +10548,19 @@
 #: ../raster/r.sunmask/main.c:118
 #, fuzzy
-msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
 #: ../raster/r.sunmask/main.c:119
 #, fuzzy
-msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
-msgstr "Calcula áreas de sombra a partir da posição do sol e de um modelo de elevação digital. Deve ser especificada A: posição exata do sol ou B: data e hora para cálculo da posição por r.sunmask."
+msgid ""
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+"Calcula áreas de sombra a partir da posição do sol e de um modelo de "
+"elevação digital. Deve ser especificada A: posição exata do sol ou B: data e "
+"hora para cálculo da posição por r.sunmask."
 #: ../raster/r.sunmask/main.c:133
 #, fuzzy
@@ -10031,7 +10618,9 @@
 #: ../raster/r.sunmask/main.c:199
 #, fuzzy
 msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr "B: fuso horário (leste positivo, diferença de GMT, também usar para compensar horário de verão)"
+msgstr ""
+"B: fuso horário (leste positivo, diferença de GMT, também usar para "
+"compensar horário de verão)"
 #: ../raster/r.sunmask/main.c:208
 #, fuzzy
@@ -10082,8 +10671,12 @@
 #: ../raster/r.sunmask/main.c:279
 #, fuzzy
-msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
-msgstr "Nem a posição do sol nem as definições de norte/leste data/hora/fuso horário estão completas."
+msgid ""
+"Neither sun position nor east/north, date/time/timezone definition are "
+"complete"
+msgstr ""
+"Nem a posição do sol nem as definições de norte/leste data/hora/fuso horário "
+"estão completas."
 #: ../raster/r.sunmask/main.c:283
 #, fuzzy, c-format
@@ -10092,8 +10685,12 @@
 #: ../raster/r.sunmask/main.c:288
 #, fuzzy
-msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
-msgstr "Usando ajustes de altitude e azimute do sol definidos pelo usuário (ignorando eventuais outros valores)\n"
+msgid ""
+"Using user defined sun azimuth, altitude settings (ignoring eventual other "
+"values)"
+msgstr ""
+"Usando ajustes de altitude e azimute do sol definidos pelo usuário "
+"(ignorando eventuais outros valores)\n"
 #: ../raster/r.sunmask/main.c:396
 #, fuzzy
@@ -10234,12 +10831,16 @@
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgid ""
+"Unable to calculate sun position in un-projected locations. Specify "
+"sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgid ""
+"Specified point %f, %f outside of current region, is that intended? Anyway, "
+"it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98
@@ -10357,7 +10958,9 @@
 #: ../raster/r.thin/main.c:59
 msgid "Thins non-zero cells that denote linear features in a raster map layer."
-msgstr "Afina células não-zero que indicam feições lineares em uma camada de mapa raster."
+msgstr ""
+"Afina células não-zero que indicam feições lineares em uma camada de mapa "
+"raster."
 #: ../raster/r.thin/main.c:71
 #, fuzzy
@@ -10436,8 +11039,12 @@
 #: ../raster/r.reclass/main.c:54
 #, fuzzy
-msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
-msgstr "Cria um novo mapa cujas categorias são baseadas na reclassificação do usuário sobre as categorias de um mapa raster existente."
+msgid ""
+"Creates a new raster map whose category values are based upon a "
+"reclassification of the categories in an existing raster map."
+msgstr ""
+"Cria um novo mapa cujas categorias são baseadas na reclassificação do "
+"usuário sobre as categorias de um mapa raster existente."
 #: ../raster/r.reclass/main.c:59
 #, fuzzy
@@ -10471,7 +11078,8 @@
 #: ../raster/r.reclass/main.c:103
 #, fuzzy, c-format
 msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
+msgstr ""
 #: ../raster/r.reclass/main.c:105
 #, fuzzy, c-format
@@ -10604,11 +11212,13 @@
 #: ../raster/r.to.vect/main.c:96
 msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr "Usa valores do raster como categorias em vez de uma seqüência única (apenas CELL)"
+msgstr ""
+"Usa valores do raster como categorias em vez de uma seqüência única (apenas "
+"CELL)"
 #: ../raster/r.to.vect/main.c:97 ../raster/r.to.vect/main.c:104
 #: ../vector/v.in.ogr/main.c:192 ../vector/v.in.ogr/main.c:217
-#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:184
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:198
 #: ../vector/v.to.rast/main.c:74 ../vector/v.to.rast/main.c:80
 #: ../vector/v.to.rast/main.c:86
 #, fuzzy
@@ -10617,8 +11227,12 @@
 #: ../raster/r.to.vect/main.c:102
 #, fuzzy
-msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
-msgstr "Escreve valores raster como coordenada z. Não cria tabela. Atualmente só suporta pontos."
+msgid ""
+"Write raster values as z coordinate. Table is not created. Currently "
+"supported only for points."
+msgstr ""
+"Escreve valores raster como coordenada z. Não cria tabela. Atualmente só "
+"suporta pontos."
 #: ../raster/r.to.vect/main.c:109
 msgid "Do not build vector topology (recommended for massive point conversion)"
@@ -10630,7 +11244,9 @@
 msgstr "Mostra oso formatos suportados e encerra"
 #: ../raster/r.to.vect/main.c:129
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
+"table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:202 ../vector/v.in.sites/main.c:172
@@ -10654,7 +11270,7 @@
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
 #: ../vector/v.in.ogr/main.c:927 ../vector/v.random/main.c:294
-#: ../vector/v.in.lidar/main.c:696
+#: ../vector/v.in.lidar/main.c:755
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "Não consegui inserir nova linha: %s"
@@ -10714,8 +11330,12 @@
 msgstr ""
 #: ../raster/r.kappa/main.c:71
-msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
-msgstr "Calcula a matriz de erro e o parâmetro 'capa' para avaliação da acurácia do resultado da classificação."
+msgid ""
+"Calculate error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+"Calcula a matriz de erro e o parâmetro 'capa' para avaliação da acurácia do "
+"resultado da classificação."
 #: ../raster/r.kappa/main.c:77
 #, fuzzy
@@ -10776,7 +11396,9 @@
 #: ../raster/r.coin/main.c:69
 #, fuzzy
-msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
 msgstr "Reescalona o intervalo dos valores de categorias num mapa raster."
 #: ../raster/r.coin/main.c:77
@@ -10795,7 +11417,9 @@
 msgstr "Unidade de distância"
 #: ../raster/r.coin/main.c:92
-msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgid ""
+"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
+"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
 msgstr ""
 #: ../raster/r.coin/main.c:99
@@ -10835,8 +11459,12 @@
 #: ../raster/r.digit/main.c:46
 #, fuzzy
-msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
-msgstr "Ferramenta interativa para desenhar e salvar feições vetoriais usando um dispositivo apontador (mouse)"
+msgid ""
+"Interactive tool used to draw and save vector features on a graphics monitor "
+"using a pointing device (mouse) and save to a raster map."
+msgstr ""
+"Ferramenta interativa para desenhar e salvar feições vetoriais usando um "
+"dispositivo apontador (mouse)"
 #: ../raster/r.digit/main.c:55
 msgid "Display commands to be used for canvas backdrop (separated by ';')"
@@ -10939,7 +11567,14 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:184
-msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgid ""
+"Computes horizon angle height from a digital elevation model. The module has "
+"two different modes of operation:  1. Computes the entire horizon around a "
+"single point whose coordinates are given with the 'coord' option. The "
+"horizon height (in radians). 2. Computes one or more raster maps of the "
+"horizon height in a single direction.  The input for this is the angle (in "
+"degrees), which is measured  counterclockwise with east=0, north=90 etc. The "
+"output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:207
@@ -10947,23 +11582,33 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:223
-msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer around the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:231
-msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer eastward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:239
-msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer westward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:247
-msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer northward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:255
-msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer southward the present "
+"region"
 msgstr ""
 #: ../raster/r.horizon/main.c:263
@@ -11036,8 +11681,12 @@
 msgstr "Não consegui ler arquivo de limite"
 #: ../raster/r.horizon/main.c:473
-msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
-msgstr "Não consegui informações de projeção da locação atual: favor ajustar a latitude via opção 'lat' ou 'latin'!"
+msgid ""
+"Can't get projection info of current location: please set latitude via 'lat' "
+"or 'latin' option!"
+msgstr ""
+"Não consegui informações de projeção da locação atual: favor ajustar a "
+"latitude via opção 'lat' ou 'latin'!"
 #: ../raster/r.horizon/main.c:596 ../raster/r.in.ascii/main.c:195
 #: ../raster/r.in.arc/main.c:135
@@ -11081,13 +11730,16 @@
 #, fuzzy
 msgid ""
 "\n"
-"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the "
+"location definition for the dataset.\n"
 msgstr ""
 "\n"
 #: ../raster/r.external/main.c:207
-msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgid ""
+"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
+"transform the map to North-up."
 msgstr ""
 #: ../raster/r.external/main.c:210
@@ -11323,7 +11975,9 @@
 #: ../raster/r.volume/main.c:61
 #, fuzzy
-msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgid ""
+"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
+"vector points map containing the calculated centroids of these clumps."
 msgstr "de pontos mapear de."
 #: ../raster/r.volume/main.c:67
@@ -11394,7 +12048,8 @@
 #: ../raster/r.carve/enforce_ds.c:174
 #, fuzzy
-msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgid ""
+"Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr "de é não."
 #: ../raster/r.carve/main.c:76
@@ -11403,7 +12058,9 @@
 #: ../raster/r.carve/main.c:77
 #, fuzzy
-msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
 msgstr "fluxo para profundidade"
 #: ../raster/r.carve/main.c:82
@@ -11461,8 +12118,12 @@
 msgstr "para."
 #: ../raster/r.mode/main.c:58
-msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
-msgstr "Encontra a moda dos valores de um mapa de cobertura dentro de áreas com o mesmo valor de categoria em um mapa base especificado pelo usuário"
+msgid ""
+"Finds the mode of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
+msgstr ""
+"Encontra a moda dos valores de um mapa de cobertura dentro de áreas com o "
+"mesmo valor de categoria em um mapa base especificado pelo usuário"
 #: ../raster/r.mode/main.c:64
 msgid "Base map to be reclassified"
@@ -11501,8 +12162,12 @@
 #: ../raster/r.report/parse.c:47
 #, fuzzy
-msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
-msgstr "mi(lhas),me(tros),k(ilometros),a(cres),h(ectares),c(ontagem de células),p(orcentagem de cobertura)"
+msgid ""
+"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
+"cover"
+msgstr ""
+"mi(lhas),me(tros),k(ilometros),a(cres),h(ectares),c(ontagem de células),p"
+"(orcentagem de cobertura)"
 #: ../raster/r.report/parse.c:57
 msgid "Character representing no data cell value"
@@ -11588,7 +12253,8 @@
 #: ../raster/r.composite/main.c:75
 #, fuzzy
-msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
 msgstr "Combina camadas vermelhas, verdes e azuis numa única camada composta."
 #: ../raster/r.composite/main.c:101
@@ -11624,18 +12290,26 @@
 #: ../raster/r.spreadpath/main.c:93
 #, fuzzy
-msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
-msgstr "Traça recursivamente o caminho de menor custo retrocedendo para as células das quais o custo cumulativo foi calculado."
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+"Traça recursivamente o caminho de menor custo retrocedendo para as células "
+"das quais o custo cumulativo foi calculado."
 #: ../raster/r.spreadpath/main.c:102
 #, fuzzy
 msgid "Name of raster map containing back-path easting information"
-msgstr "Nome do mapa raster contendo informação de coordenada leste do caminho retrógrado"
+msgstr ""
+"Nome do mapa raster contendo informação de coordenada leste do caminho "
+"retrógrado"
 #: ../raster/r.spreadpath/main.c:110
 #, fuzzy
 msgid "Name of raster map containing back-path northing information"
-msgstr "Nome do mapa raster contendo informação de coordenada norte do caminho retrógrado"
+msgstr ""
+"Nome do mapa raster contendo informação de coordenada norte do caminho "
+"retrógrado"
 #: ../raster/r.spreadpath/main.c:118
 msgid "The map E and N grid coordinates of starting points"
@@ -11687,7 +12361,9 @@
 #: ../raster/r.flow/main.c:425
 #, fuzzy
-msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a elevation raster map."
+msgid ""
+"Construction of slope curves (flowlines), flowpath lengths, and flowline "
+"densities (upslope areas) from a elevation raster map."
 msgstr "de"
 #: ../raster/r.flow/main.c:434
@@ -11746,8 +12422,12 @@
 #: ../raster/r.flow/main.c:550
 #, fuzzy
-msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+msgid ""
+"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
+"calculating flow accumulation."
+msgstr ""
 #: ../raster/r.flow/io.c:85
 #, fuzzy
@@ -11888,8 +12568,11 @@
 #: ../raster/r.in.ascii/main.c:77
 #, fuzzy
-msgid "ASCII raster file to be imported. If not given reads from standard input"
-msgstr "Arquivo ASCII para converter para vetor binário, se não for dado, lê da entrada padrão"
+msgid ""
+"ASCII raster file to be imported. If not given reads from standard input"
+msgstr ""
+"Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+"entrada padrão"
 #: ../raster/r.in.ascii/main.c:95 ../raster/r.in.arc/main.c:95
 #, fuzzy
@@ -12112,8 +12795,15 @@
 msgstr "Gera estatísticas areais para os mapas raster."
 #: ../raster/r.ros/main.c:215
-msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
-msgstr "Gera três ou quatro camadas de mapa raster exibindo 1) razão de espalhamento (RdE) base (perpendicular), 2) máxima RdE (avanço), 3) direção da máxima RdE e opcionalmente 4) a máxima distância potencial de avistamento"
+msgid ""
+"Generates three, or four raster map layers showing 1) the base "
+"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
+"direction of the maximum ROS, and optionally 4) the maximum potential "
+"spotting distance."
+msgstr ""
+"Gera três ou quatro camadas de mapa raster exibindo 1) razão de espalhamento "
+"(RdE) base (perpendicular), 2) máxima RdE (avanço), 3) direção da máxima RdE "
+"e opcionalmente 4) a máxima distância potencial de avistamento"
 #: ../raster/r.ros/main.c:222
 msgid "Name of raster map containing fuel MODELs"
@@ -12149,7 +12839,9 @@
 #: ../raster/r.ros/main.c:269
 msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr "Nome do mapa raster contendo a direção das encostas (graus, anti-horário a partir do Leste)"
+msgstr ""
+"Nome do mapa raster contendo a direção das encostas (graus, anti-horário a "
+"partir do Leste)"
 #: ../raster/r.ros/main.c:274
 msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
@@ -12165,17 +12857,23 @@
 msgstr "Também calcular máxima distância de avistamento"
 #: ../raster/r.ros/main.c:296
-msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
+msgid ""
+"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
+"moisture layers is required."
 msgstr ""
 #: ../raster/r.ros/main.c:320
 #, c-format
-msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
+msgid ""
+"A wind direction layer should be given if the wind velocity layer <%s> has "
+"been given"
 msgstr ""
 #: ../raster/r.ros/main.c:325
 #, c-format
-msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
+msgid ""
+"A wind velocity layer should be given if the wind direction layer <%s> has "
+"been given"
 msgstr ""
 #: ../raster/r.ros/main.c:339
@@ -12206,7 +12904,8 @@
 #: ../raster/r.topidx/main.c:42
 #, fuzzy
 msgid "Creates topographic index map from elevation raster map."
-msgstr "Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
+msgstr ""
+"Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
 #: ../raster/r.topidx/topidx.c:42 ../imagery/i.landsat.toar/main.c:468
 #, fuzzy
@@ -12220,7 +12919,10 @@
 #: ../raster/r.topidx/file_io.c:30
 #, c-format
-msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
+msgid ""
+"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
+"%.2f]! Needs to be at least identical or the current region resolution lower "
+"than the input map resolution"
 msgstr ""
 #: ../raster/r.topidx/file_io.c:78
@@ -12244,7 +12946,9 @@
 #: ../raster/r.regression.line/main.c:61
 #, fuzzy
-msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgid ""
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
 msgstr "ASCII para não."
 #: ../raster/r.regression.line/main.c:65 ../general/g.region/main.c:141
@@ -12481,8 +13185,13 @@
 #: ../raster/r.param.scale/interface.c:57
 #, fuzzy
-msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
-msgstr "Extrai parâmetros de terreno a partir de um DEM. Usa uma aproximação multi-escalar ao extrair parâmetros ajustados quadraticamente para janelas de qualquer tamanho (por mínimos quadrados)"
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
+msgstr ""
+"Extrai parâmetros de terreno a partir de um DEM. Usa uma aproximação multi-"
+"escalar ao extrair parâmetros ajustados quadraticamente para janelas de "
+"qualquer tamanho (por mínimos quadrados)"
 #: ../raster/r.param.scale/interface.c:75
 msgid "Output raster layer containing morphometric parameter"
@@ -12524,8 +13233,11 @@
 #: ../raster/r.in.arc/main.c:63
 #, fuzzy
-msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr "Converte um raster ASCII (GRID) do ESRI ARC/INFO em uma camada raster binária."
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr ""
+"Converte um raster ASCII (GRID) do ESRI ARC/INFO em uma camada raster "
+"binária."
 #: ../raster/r.in.arc/main.c:70
 #, fuzzy
@@ -12576,12 +13288,18 @@
 "\n"
 #: ../raster/r.neighbors/main.c:121
-msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
-msgstr "Define a categoria de cada célula como função das categorias das células vizinhas, e grava os novos valores numa camada raster de saída."
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+"Define a categoria de cada célula como função das categorias das células "
+"vizinhas, e grava os novos valores numa camada raster de saída."
 #: ../raster/r.neighbors/main.c:131
 #, fuzzy
-msgid "Name of an input raster map to select the cells which should be processed"
+msgid ""
+"Name of an input raster map to select the cells which should be processed"
 msgstr "Mapa raster para guardar os resultados rejeitados"
 #: ../raster/r.neighbors/main.c:149 ../vector/v.neighbors/main.c:69
@@ -12844,11 +13562,15 @@
 #: ../general/g.proj/input.c:259
 #, fuzzy, c-format
-msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgid ""
+"Read of file %s was successful, but it did not contain projection "
+"information. 'XY (unprojected)' will be used"
 msgstr "Ler de não conter"
 #: ../general/g.proj/main.c:64
-msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format)."
 msgstr ""
 #: ../general/g.proj/main.c:67
@@ -12864,7 +13586,9 @@
 #: ../general/g.proj/main.c:77
 #, fuzzy
 msgid "Print projection information (in conventional GRASS format)"
-msgstr "Não consegui converter a projeção do mapa de entrada para o formato do GRASS para verificação"
+msgstr ""
+"para verificação"
 #: ../general/g.proj/main.c:83
 #, fuzzy
@@ -12878,7 +13602,8 @@
 #: ../general/g.proj/main.c:95
 #, fuzzy
-msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid ""
+"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
 msgstr "para"
 #: ../general/g.proj/main.c:105
@@ -12924,7 +13649,9 @@
 msgstr ""
 #: ../general/g.proj/main.c:162
-msgid "Force override of datum transformation information in input co-ordinate system"
+msgid ""
+"Force override of datum transformation information in input co-ordinate "
+"system"
 msgstr ""
 #: ../general/g.proj/main.c:167 ../general/g.proj/main.c:176
@@ -12934,7 +13661,9 @@
 #: ../general/g.proj/main.c:168
 #, fuzzy
-msgid "Create new projection files (modifies current location unless 'location' option specified)"
+msgid ""
+"Create new projection files (modifies current location unless 'location' "
+"option specified)"
 msgstr "atual localização localização"
 #: ../general/g.proj/main.c:177
@@ -12986,11 +13715,16 @@
 #: ../general/g.proj/output.c:183
 #, fuzzy, c-format
-msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
+msgid ""
+"You must select the PERMANENT mapset before updating the current location's "
+"projection. (Current mapset is %s)"
 msgstr "atual localização é"
 #: ../general/g.proj/output.c:215
-msgid "N.B. The default region was updated to the new projection, but if you have multiple mapsets g.region -d should be run in each to update the region from the default."
+msgid ""
+"N.B. The default region was updated to the new projection, but if you have "
+"multiple mapsets g.region -d should be run in each to update the region from "
+"the default."
 msgstr ""
 #: ../general/g.proj/output.c:219
@@ -13107,7 +13841,8 @@
 msgstr "Arquivo de saída PostScript"
 #: ../general/g.message/main.c:36
-msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid ""
+"Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:38
@@ -13330,7 +14065,10 @@
 msgstr "não."
 #: ../general/g.setproj/main.c:456
-msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+msgid ""
+"But if you change zone, all the existing data will be interpreted by "
+"projection software. GRASS will not automatically re-project or even change "
+"the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:461
@@ -13483,7 +14221,9 @@
 #: ../general/g.transform/main.c:324
 #, fuzzy
 msgid "Computes a coordinate transformation based on the control points."
-msgstr "Retifica uma imagem por transformação das coordenadas de cada pixel da imagem a partir de pontos de controle."
+msgstr ""
+"Retifica uma imagem por transformação das coordenadas de cada pixel da "
+"imagem a partir de pontos de controle."
 #: ../general/g.transform/main.c:333
 #, fuzzy
@@ -13491,7 +14231,11 @@
 msgstr "Ordem do polinômio de retificação (1-3)"
 #: ../general/g.transform/main.c:341
-msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgid ""
+"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
+"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
+"forward coordinates difference (destination);rxy;reverse coordinates "
+"difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
 #: ../general/g.transform/main.c:351 ../vector/v.out.ascii/args.c:44
@@ -13540,7 +14284,8 @@
 msgstr "Salva quadro atual"
 #: ../general/g.mapset/main.c:48
-msgid "Optionally create new mapset or list available mapsets in given location."
+msgid ""
+"Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:56
@@ -13604,7 +14349,9 @@
 #: ../general/g.mapset/main.c:179
 #, c-format
-msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
+msgid ""
+"%s is currently running GRASS in selected mapset or lock file cannot be "
+"checked"
 msgstr ""
 #: ../general/g.mapset/main.c:184
@@ -13650,7 +14397,9 @@
 #: ../general/g.mapsets/main.c:63
 #, fuzzy
-msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgid ""
+"Affects the user's access to data existing under the other mapsets in the "
+"current location."
 msgstr "Cópias disponível em atual Pesquisa localização para atual."
 #: ../general/g.mapsets/main.c:71
@@ -13722,7 +14471,9 @@
 #: ../general/g.copy/main.c:45
 #, fuzzy
-msgid "Copies available data files in the current mapset search path to the user's current mapset."
+msgid ""
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
 #: ../general/g.copy/main.c:51
@@ -13957,7 +14708,9 @@
 #: ../general/g.mlist/main.c:66
 #, fuzzy
-msgid "Lists available GRASS data base files of the user-specified data type to standard output."
+msgid ""
+"Lists available GRASS data base files of the user-specified data type to "
+"standard output."
 msgstr "Listas disponível de para."
 #: ../general/g.mlist/main.c:81
@@ -14043,7 +14796,9 @@
 msgstr ""
 #: ../general/g.region/main.c:124
-msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
+msgid ""
+"The difference between the projection's grid north and true north, measured "
+"at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:130
@@ -14057,8 +14812,12 @@
 #: ../general/g.region/main.c:147
 #, fuzzy
-msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
-msgstr "Alinhar região com a resolução (padrão = alinha com os limites, apenas resolução 2D)"
+msgid ""
+"Align region to resolution (default = align to bounds, works only for 2D "
+"resolution)"
+msgstr ""
+"Alinhar região com a resolução (padrão = alinha com os limites, apenas "
+"resolução 2D)"
 #: ../general/g.region/main.c:153
 msgid "Do not update the current region"
@@ -14076,7 +14835,9 @@
 #: ../general/g.region/main.c:180
 msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr "Ajustar a região coincidente com esse mapa raster 3D (tanto valores 2D como 3D)"
+msgstr ""
+"Ajustar a região coincidente com esse mapa raster 3D (tanto valores 2D como "
+"3D)"
 #: ../general/g.region/main.c:243
 msgid "Value for the top edge"
@@ -14132,7 +14893,8 @@
 #: ../general/g.region/main.c:338
 msgid "Adjust region cells to cleanly align with this raster map"
-msgstr "Ajustar as células da região para alinharem claramente com este mapa raster"
+msgstr ""
+"Ajustar as células da região para alinharem claramente com este mapa raster"
 #: ../general/g.region/main.c:349
 #, fuzzy
@@ -14209,12 +14971,16 @@
 msgstr ""
 #: ../general/g.region/printwindow.c:412
-msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+msgid ""
+"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
+"the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:637
 #, fuzzy
-msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgid ""
+"WGS84 output not possible as this location does not contain datum "
+"transformation parameters. Try running g.setproj."
 msgstr ""
 "Saída WGS84 não é possível pois esta locação não contém\n"
 "parâmetros de transformação do .datum. Execute g.setproj"
@@ -14283,7 +15049,9 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:73
-msgid "Generates the font configuration file by scanning various directories for fonts"
+msgid ""
+"Generates the font configuration file by scanning various directories for "
+"fonts"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:79
@@ -14291,20 +15059,26 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:84
-msgid "Write font configuration file to standard output instead of $GISBASE/etc"
+msgid ""
+"Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:92
-msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
+msgid ""
+"Comma-separated list of extra directories to scan for Freetype-compatible "
+"fonts as well as the defaults (see documentation)"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:109
 #, fuzzy, c-format
-msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid ""
+"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "O vetor '%s' já existe."
 #: ../general/g.mkfontcap/main.c:121
-msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
+msgid ""
+"This GRASS installation was compiled without Freetype support, extradirs "
+"parameter ignored"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:148
@@ -14401,7 +15175,9 @@
 #: ../general/g.findfile/main.c:97
 #, c-format
-msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+msgid ""
+"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%"
+"s> does not correspond"
 msgstr ""
 #: ../general/g.findfile/element.c:7
@@ -14492,7 +15268,9 @@
 msgstr ""
 #: ../display/d.font/main.c:49
-msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgid ""
+"Selects the font in which text will be displayed on the user's graphics "
+"monitor."
 msgstr "Selecione a fonte que será mostrada na monitor gráfico do usuário."
 #: ../display/d.font/main.c:57
@@ -14531,12 +15309,17 @@
 #: ../display/d.font/main.c:127
 #, c-format
-msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid ""
+"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../display/d.rast.arrow/main.c:98
-msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
-msgstr "Desenha setas representando a direção para mapas raster contendo dados de orientação."
+msgid ""
+"Draws arrows representing cell aspect direction for a raster map containing "
+"aspect data."
+msgstr ""
+"Desenha setas representando a direção para mapas raster contendo dados de "
+"orientação."
 #: ../display/d.rast.arrow/main.c:102
 msgid "Name of raster aspect map to be displayed"
@@ -14634,11 +15417,16 @@
 msgstr ""
 #: ../display/d.grid/main.c:54
-msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
-msgstr "Sobrepõe uma malha especificada pelo usuário no quadro ativo do monitor gráfico."
+msgid ""
+"Overlays a user-specified grid in the active display frame on the graphics "
+"monitor."
+msgstr ""
+"Sobrepõe uma malha especificada pelo usuário no quadro ativo do monitor "
+"gráfico."
 #: ../display/d.grid/main.c:62
-msgid "Size of grid to be drawn (0: north-south resolution of the current region)"
+msgid ""
+"Size of grid to be drawn (0: north-south resolution of the current region)"
 msgstr ""
 #: ../display/d.grid/main.c:63
@@ -14798,15 +15586,21 @@
 msgstr "Substitui o conteúdo do quadro ativo com a cor definida pelo usuário"
 #: ../display/d.erase/main.c:40
-msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-msgstr "Cor para apagar, ou uma cor padrão do GRASS ou uma triplete R:G:B (separada por dois pontos)"
+msgid ""
+"Color to erase with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Cor para apagar, ou uma cor padrão do GRASS ou uma triplete R:G:B (separada "
+"por dois pontos)"
 #: ../display/d.erase/main.c:45
 msgid "Remove all frames and erase the screen"
 msgstr "Remove todas os quadros e limpa a tela"
 #: ../display/d.geodesic/main.c:46
-msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
+msgid ""
+"Displays a geodesic line, tracing the shortest distance between two "
+"geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.geodesic/main.c:55 ../display/d.path/main.c:65
@@ -15001,8 +15795,11 @@
 msgstr ""
 #: ../display/d.legend/main.c:87
-msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
-msgstr "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+msgid ""
+"Displays a legend for a raster map in the active frame of the graphics "
+"monitor."
+msgstr ""
+"Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
 #: ../display/d.legend/main.c:91 ../display/d.zoom/main.c:76
 #: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
@@ -15026,7 +15823,8 @@
 msgstr "Número de rótulos de texto para a legenda gradiente"
 #: ../display/d.legend/main.c:133
-msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid ""
+"Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
 #: ../display/d.legend/main.c:143
@@ -15071,12 +15869,15 @@
 #: ../display/d.legend/main.c:308
 msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr "Parte da legenda está fora do quadro. Textos podem não ser exibidos corretamente."
+msgstr ""
+"Parte da legenda está fora do quadro. Textos podem não ser exibidos "
+"corretamente."
 #: ../display/d.legend/main.c:312
 #, fuzzy
 msgid "Drawing horizontal legend as box width exceeds height"
-msgstr "Desenhando legenda horizontal, pois a largura da caixa excede a altura.\n"
+msgstr ""
+"Desenhando legenda horizontal, pois a largura da caixa excede a altura.\n"
 #: ../display/d.legend/main.c:323
 #, fuzzy, c-format
@@ -15108,7 +15909,9 @@
 #: ../display/d.legend/main.c:457
 #, fuzzy
 msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr "Forçando uma legenda suave: categorias demais para a altura da janela atual.\n"
+msgstr ""
+"Forçando uma legenda suave: categorias demais para a altura da janela "
+"atual.\n"
 #: ../display/d.legend/main.c:487 ../display/d.histogram/main.c:180
 #, fuzzy, c-format
@@ -15126,7 +15929,8 @@
 #: ../display/d.vect.chart/main.c:66
 #, fuzzy
-msgid "Displays charts of vector data in the active frame on the graphics monitor."
+msgid ""
+"Displays charts of vector data in the active frame on the graphics monitor."
 msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
 #: ../display/d.vect.chart/main.c:83
@@ -15205,8 +16009,12 @@
 #: ../display/d.rgb/main.c:57
 #, fuzzy
-msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
-msgstr "Exibe três mapas raster selecionados pelo usuário como bandas vermelha, verde e azul no quadro gráfico atual"
+msgid ""
+"Displays three user-specified raster maps as red, green, and blue overlays "
+"in the active graphics frame."
+msgstr ""
+"Exibe três mapas raster selecionados pelo usuário como bandas vermelha, "
+"verde e azul no quadro gráfico atual"
 #: ../display/d.rgb/main.c:62 ../display/d.rast/main.c:79
 msgid "Make null cells opaque"
@@ -15219,8 +16027,12 @@
 #: ../display/d.where/main.c:47
 #, fuzzy
-msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
-msgstr "Identifica as coordenadas geográficas associadas com locações no quadro ativo do monitor gráfico"
+msgid ""
+"Identifies the geographic coordinates associated with point locations given "
+"in display coordinates."
+msgstr ""
+"Identifica as coordenadas geográficas associadas com locações no quadro "
+"ativo do monitor gráfico"
 #: ../display/d.where/main.c:57
 #, fuzzy
@@ -15241,7 +16053,9 @@
 msgstr "Saída lat/long referenciada ao elipsóide atual"
 #: ../display/d.where/main.c:76
-msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgid ""
+"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
+"parameters defined in current location (if available)"
 msgstr ""
 "Saída lat/long referenciada ao elipsóide WGS84 usando parâmetros\n"
 "de transformação de datum definidos na locação atual (se disponível)"
@@ -15302,8 +16116,11 @@
 #: ../display/d.barscale/main.c:92
 #, fuzzy
-msgid "The screen coordinates for top-left corner of label ([0,0] is lower-left of frame)"
-msgstr "Coordenadas em porcentagem do quadro ([0,0] é o canto superior esquerdo)"
+msgid ""
+"The screen coordinates for top-left corner of label ([0,0] is lower-left of "
+"frame)"
+msgstr ""
+"Coordenadas em porcentagem do quadro ([0,0] é o canto superior esquerdo)"
 #: ../display/d.barscale/main.c:100
 #, fuzzy
@@ -15320,8 +16137,12 @@
 msgstr "Escolha apenas uma opção -n ou -s"
 #: ../display/d.measure/main.c:49
-msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
-msgstr "Mede os comprimentos e áreas de feições desenhadas pelo usuário no quadro ativo do monitor gráfico."
+msgid ""
+"Measures the lengths and areas of features drawn by the user in the active "
+"display frame on the graphics monitor."
+msgstr ""
+"Mede os comprimentos e áreas de feições desenhadas pelo usuário no quadro "
+"ativo do monitor gráfico."
 #: ../display/d.measure/main.c:55
 msgid "Line color 1"
@@ -15345,8 +16166,13 @@
 #: ../display/d.his/main.c:67
 #, fuzzy
-msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
-msgstr "Gera camadas vermelha verde e azul combinando valores de matiz (hue), intensidade e saturação (HIS) a partir das camadas raster fornecidas pelo usuário."
+msgid ""
+"Displays the result obtained by combining hue, intensity, and saturation "
+"(his) values from user-specified input raster map layers."
+msgstr ""
+"Gera camadas vermelha verde e azul combinando valores de matiz (hue), "
+"intensidade e saturação (HIS) a partir das camadas raster fornecidas pelo "
+"usuário."
 #: ../display/d.his/main.c:95
 msgid "Percent to brighten intensity channel"
@@ -15354,7 +16180,10 @@
 #: ../display/d.what.rast/main.c:53
 #, fuzzy
-msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgid ""
+"Allows the user to interactively query the category contents of multiple "
+"raster map layers at user specified locations within the current geographic "
+"region."
 msgstr "para de mapear atual."
 #: ../display/d.what.rast/main.c:74
@@ -15384,7 +16213,9 @@
 #: ../display/d.thematic.area/main.c:79
 #, fuzzy
-msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
+msgid ""
+"Displays a thematic vector area map in the active frame on the graphics "
+"monitor."
 #: ../display/d.thematic.area/main.c:89
@@ -15401,7 +16232,9 @@
 msgstr "Assinaturas para usar na classificação"
 #: ../display/d.thematic.area/main.c:105 ../vector/v.class/main.c:67
-msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
+msgid ""
+"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
+"(normal distribution);"
 msgstr ""
 #: ../display/d.thematic.area/main.c:116 ../vector/v.class/main.c:78
@@ -15468,7 +16301,9 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:164
-msgid "When printing legend info , include extended statistical info from classification algorithm"
+msgid ""
+"When printing legend info , include extended statistical info from "
+"classification algorithm"
 msgstr ""
 #: ../display/d.thematic.area/main.c:168
@@ -15534,7 +16369,9 @@
 msgstr "Cor desconhecida: [%s]"
 #: ../display/d.thematic.area/main.c:298
-msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
+msgid ""
+"You gave both manual breaks and a classification algorithm or a number of "
+"classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.thematic.area/main.c:335
@@ -15560,7 +16397,8 @@
 #: ../display/d.thematic.area/main.c:378 ../display/d.vect/main.c:608
 #, fuzzy
-msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgid ""
+"The bounding box of the map is outside the current region, nothing drawn."
 msgstr "Os limites do mapa estão além da região atual. Nada a exibir.\n"
 #: ../display/d.thematic.area/main.c:427
@@ -15603,7 +16441,9 @@
 #: ../display/d.thematic.area/plot1.c:129 ../display/d.vect/area.c:79
 #: ../display/d.vect/plot1.c:137
 #, fuzzy, c-format
-msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
+msgid ""
+"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
+"BBB where RGB values range 0-255."
 msgstr "Cor definição não seqüência Coluna de RGB intervalo."
 #: ../display/d.thematic.area/plot1.c:147 ../display/d.vect/area.c:98
@@ -15627,8 +16467,11 @@
 #: ../display/d.thematic.area/plot1.c:278
 #, fuzzy, c-format
-msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
-msgstr "Erro na definição de cor na coluna GRASSRGB, elemento %d com cat %d: cor %s"
+msgid ""
+"Error in color definition column (%s), element %d with cat %d: colorstring [%"
+"s]"
+msgstr ""
+"Erro na definição de cor na coluna GRASSRGB, elemento %d com cat %d: cor %s"
 #: ../display/d.thematic.area/plot1.c:285
 #, fuzzy, c-format
@@ -15638,8 +16481,10 @@
 #: ../display/d.thematic.area/plot1.c:353 ../display/d.vect/area.c:345
 #: ../display/d.vect/plot1.c:451
 #, fuzzy, c-format
-msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid ""
+"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr ""
 #: ../display/d.colortable/main.c:63
 #, fuzzy
@@ -15671,12 +16516,14 @@
 #: ../display/d.colortable/main.c:114
 #, c-format
-msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid ""
+"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:128
 #, c-format
-msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid ""
+"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:139
@@ -15725,8 +16572,12 @@
 msgstr "Exibir"
 #: ../display/d.histogram/main.c:88
-msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
-msgstr "Mostra u m histograma em forma de pizza ou barras para um arquivo raster especificado pelo usuário."
+msgid ""
+"Displays a histogram in the form of a pie or bar chart for a user-specified "
+"raster map."
+msgstr ""
+"Mostra u m histograma em forma de pizza ou barras para um arquivo raster "
+"especificado pelo usuário."
 #: ../display/d.histogram/main.c:92
 msgid "Raster map for which histogram will be displayed"
@@ -15772,8 +16623,12 @@
 #: ../display/d.linegraph/main.c:122
 #, fuzzy
-msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
-msgstr "Gera e mostra gráficos simples sobre camadas de mapa no quadro ativo do monitor gráfico."
+msgid ""
+"Generates and displays simple line graphs in the active graphics monitor "
+"display frame."
+msgstr ""
+"Gera e mostra gráficos simples sobre camadas de mapa no quadro ativo do "
+"monitor gráfico."
 #: ../display/d.linegraph/main.c:126
 #, fuzzy
@@ -15844,7 +16699,8 @@
 msgstr "Erro lendo arquivo de limite."
 #: ../display/d.title/main.c:52
-msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid ""
+"Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:63
@@ -15881,17 +16737,24 @@
 #: ../display/d.graph/main.c:61
 #, fuzzy
-msgid "Program for generating and displaying simple graphics on the display monitor."
+msgid ""
+"Program for generating and displaying simple graphics on the display monitor."
 msgstr "Programa para gerar e exibir gráficos simples no monitor gráfico."
 #: ../display/d.graph/main.c:68
-msgid "Name of file containing graphics commands, if not given reads from standard input"
-msgstr "Nome do arquivo contendo comandos gráficos, se não houver, lê da entrada padrão"
+msgid ""
+"Name of file containing graphics commands, if not given reads from standard "
+"input"
+msgstr ""
+"Nome do arquivo contendo comandos gráficos, se não houver, lê da entrada "
+"padrão"
 #: ../display/d.graph/main.c:76
 #, fuzzy
 msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr "Cor para desenhar, tanto uma cor padrão do GRASS como uma triplete R:G:B (separada por dois pontos)"
+msgstr ""
+"Cor para desenhar, tanto uma cor padrão do GRASS como uma triplete R:G:B "
+"(separada por dois pontos)"
 #: ../display/d.graph/main.c:83
 #, fuzzy
@@ -15926,7 +16789,9 @@
 msgstr "Não consegui ler símbolos, não consegui exibir pontos"
 #: ../display/d.what.vect/main.c:61
-msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region."
 msgstr "s"
 #: ../display/d.what.vect/main.c:77
@@ -16092,8 +16957,11 @@
 msgstr "ATENÇÃO: %s - arquivo de vetores não foi encontrado\n"
 #: ../display/d.text/main.c:142
-msgid "Draws text in the active display frame on the graphics monitor using the current font."
-msgstr "Exibe texto no quadro ativo do monitor gráfico usando a fonte selecionada."
+msgid ""
+"Draws text in the active display frame on the graphics monitor using the "
+"current font."
+msgstr ""
+"Exibe texto no quadro ativo do monitor gráfico usando a fonte selecionada."
 #: ../display/d.text/main.c:148
 msgid "Text to display"
@@ -16105,12 +16973,16 @@
 #: ../display/d.text/main.c:165
 msgid "Text color, either a standard GRASS color or R:G:B triplet"
-msgstr "Cor do texto, tanto uma cor padrão do GRASS como uma triplete R:G:B (separada por dois pontos)"
+msgstr ""
+"Cor do texto, tanto uma cor padrão do GRASS como uma triplete R:G:B "
 #: ../display/d.text/main.c:173
 #, fuzzy
 msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
 #: ../display/d.text/main.c:182
 msgid "The screen line number on which text will begin to be drawn"
@@ -16118,8 +16990,12 @@
 #: ../display/d.text/main.c:190
 #, fuzzy
-msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
-msgstr "Posição da tela a partir da qual o texto será desenhado (porcentagem, [0,0] é o canto inferior direito)"
+msgid ""
+"Screen position at which text will begin to be drawn (percentage, [0,0] is "
+"lower left)"
+msgstr ""
+"Posição da tela a partir da qual o texto será desenhado (porcentagem, [0,0] "
+"é o canto inferior direito)"
 #: ../display/d.text/main.c:198
 msgid "Text alignment"
@@ -16206,8 +17082,11 @@
 msgstr "Consultar"
 #: ../display/d.labels/main.c:46
-msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
-msgstr "Exibir rótulos (criados com v.label) no quadro ativo no monitor gráfico"
+msgid ""
+"Displays text labels (created with v.label) to the active frame on the "
+"graphics monitor."
+msgstr ""
+"Exibir rótulos (criados com v.label) no quadro ativo no monitor gráfico"
 #: ../display/d.labels/main.c:52
 msgid "Ignore rotation setting and draw horizontally"
@@ -16251,7 +17130,9 @@
 #: ../display/d.rast/main.c:54
 #, fuzzy
 msgid "Displays user-specified raster map in the active graphics frame."
+msgstr ""
 #: ../display/d.rast/main.c:59 ../imagery/i.class/main.c:101
 #, fuzzy
@@ -16271,7 +17152,9 @@
 #: ../display/d.rast/main.c:74 ../display/d.vect/main.c:267
 #, fuzzy
 msgid "Either a standard color name or R:G:B triplet"
+msgstr ""
 #: ../display/d.rast/main.c:75 ../display/d.rast/main.c:80
 msgid "Null cells"
@@ -16293,8 +17176,12 @@
 msgstr "%s=%s - nome ilegal"
 #: ../display/d.rast.num/main.c:74
-msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
-msgstr "Sobrepõe valores de categorias em um mapa raster no quadro ativo do monitor gráfico."
+msgid ""
+"Overlays cell category values on a raster map layer displayed to the "
+msgstr ""
+"Sobrepõe valores de categorias em um mapa raster no quadro ativo do monitor "
+"gráfico."
 #: ../display/d.rast.num/main.c:86
 msgid "Color for drawing grid, or \"none\""
@@ -16327,7 +17214,8 @@
 #, fuzzy
 msgid ""
 "\n"
-"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
+"Your current window setting may be too large. Cells displayed on your "
+"graphics window may be too small for cell category number to be visible."
 msgstr "atual definição Células ativo célula para."
 #: ../display/d.rast.num/main.c:187
@@ -16412,7 +17300,9 @@
 msgstr ""
 #: ../display/d.nviz/main.c:439
-msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgid ""
+"Skipping this point, selected point is outside region. Perhaps the camera "
+"setback distance puts it beyond the edge?"
 msgstr ""
 #: ../display/d.zoom/main.c:62
@@ -16420,7 +17310,9 @@
 msgstr ""
 #: ../display/d.zoom/main.c:64
-msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgid ""
+"Allows the user to change the current geographic region settings "
+"interactively, with a mouse."
 msgstr "Permite ao usuário alterar interativamente os ajustes da região atual"
 #: ../display/d.zoom/main.c:84
@@ -16464,7 +17356,8 @@
 #: ../display/d.zoom/main.c:232
 #, fuzzy
 msgid "No previous zoom available"
-msgstr "esta é a primeira vez que executa d.zoom; não há zoom prévio disponível\n"
+msgstr ""
+"esta é a primeira vez que executa d.zoom; não há zoom prévio disponível\n"
 #: ../display/d.zoom/main.c:236
 msgid "Returning to previous zoom"
@@ -16534,21 +17427,29 @@
 #: ../display/d.vect/main.c:119
 #, fuzzy
 msgid "Displays user-specified vector map in the active graphics frame."
+msgstr ""
 #: ../display/d.vect/main.c:133
 msgid "Display"
 msgstr "Exibir"
 #: ../display/d.vect/main.c:134
-msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;Display z-coordinate of features (only for 3D vector maps)"
+msgid ""
+"shape;Display geometry of features;cat;Display category numbers of features;"
+"topo;Display topology information (nodes, edges);dir;Display direction of "
+"linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;"
+"Display z-coordinate of features (only for 3D vector maps)"
 msgstr ""
 #: ../display/d.vect/main.c:163 ../display/d.vect/main.c:173
 #: ../display/d.vect/main.c:277 ../display/d.vect/main.c:287
 #, fuzzy
 msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr "Cor do fundo, tanto uma cor padrão do GRASS como uma triplete R:G:B, ou \"none\""
+msgstr ""
+"Cor do fundo, tanto uma cor padrão do GRASS como uma triplete R:G:B, ou "
+"\"none\""
 #: ../display/d.vect/main.c:169
 msgid "Area fill color"
@@ -16576,7 +17477,9 @@
 #: ../display/d.vect/main.c:202
 #, fuzzy
 msgid "Name of column for line widths (these values will be scaled by wscale)"
-msgstr "Nome da coluna para largura das linhas (estes valores serão escalonados com wscale)"
+msgstr ""
+"Nome da coluna para largura das linhas (estes valores serão escalonados com "
+"wscale)"
 #: ../display/d.vect/main.c:209
 #, fuzzy
@@ -16661,22 +17564,31 @@
 msgstr "Alinhamento vertical do rótulo"
 #: ../display/d.vect/main.c:329
-msgid "Minimum region size (average from height and width) when map is displayed"
-msgstr "Tamanho mínimo da região (média entre altura e largura) quando exibir mapa"
+msgid ""
+"Minimum region size (average from height and width) when map is displayed"
+msgstr ""
+"Tamanho mínimo da região (média entre altura e largura) quando exibir mapa"
 #: ../display/d.vect/main.c:337
-msgid "Maximum region size (average from height and width) when map is displayed"
-msgstr "Tamanho máximo da região (média da altura e largura) quando exibir mapa"
+msgid ""
+"Maximum region size (average from height and width) when map is displayed"
+msgstr ""
+"Tamanho máximo da região (média da altura e largura) quando exibir mapa"
 #: ../display/d.vect/main.c:345
 #, fuzzy
 msgid "Get colors from map table column (of form RRR:GGG:BBB)"
-msgstr "Usar cor de preenchimento a partir da coluna 'GRASSRGB' (RRR:GGG:BBB) da tabela do mapa."
+msgstr ""
+"Usar cor de preenchimento a partir da coluna 'GRASSRGB' (RRR:GGG:BBB) da "
+"tabela do mapa."
 #: ../display/d.vect/main.c:351
 #, fuzzy
-msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
-msgstr "Preencher áreas com cores aleatórias de acordo com o número da categoria"
+msgid ""
+"Random colors according to category number (or layer number if 'layer=-1' is "
+"given)"
+msgstr ""
+"Preencher áreas com cores aleatórias de acordo com o número da categoria"
 #: ../display/d.vect/main.c:358
 #, fuzzy
@@ -16692,11 +17604,15 @@
 msgstr ""
 #: ../display/d.vect/main.c:369
-msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
+msgid ""
+"This makes circle areas proportionate to the size_column values instead of "
+"circle radius"
 msgstr ""
 #: ../display/d.vect/main.c:412
-msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
+msgid ""
+"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
+"ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:443
@@ -16725,16 +17641,22 @@
 #: ../display/d.vect/main.c:642
 #, fuzzy
-msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgid ""
+"Unable to display areas, topology not available. Please try to rebuild "
+"topology using v.build or v.build.all."
 msgstr "Não consegui exibir áreas, topologia não disponível"
 #: ../display/d.vect/main.c:649
 #, fuzzy
-msgid "Unable to display lines by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
+msgid ""
+"Unable to display lines by id, topology not available. Please try to rebuild "
 msgstr "Não consegui exibir linhas por id, topologia não disponível"
 #: ../display/d.vect/main.c:700
-msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
+msgid ""
+"Unable to display topology, not available.Please try to rebuild topology "
+"using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/area.c:69
@@ -16744,8 +17666,10 @@
 #: ../display/d.vect/area.c:278
 #, fuzzy, c-format
-msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-msgstr "Erro na definição de cor na coluna GRASSRGB, área %d com cat %d: cor %s"
+msgid ""
+"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgstr ""
+"Erro na definição de cor na coluna GRASSRGB, área %d com cat %d: cor %s"
 #: ../display/d.vect/area.c:284
 #, fuzzy, c-format
@@ -16784,8 +17708,11 @@
 #: ../display/d.vect/plot1.c:375
 #, fuzzy, c-format
-msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
+msgid ""
+"Error in color definition column '%s', feature id %d with cat %d: "
+"colorstring '%s'"
+msgstr ""
 #: ../display/d.vect/plot1.c:383
 #, fuzzy, c-format
@@ -16794,8 +17721,10 @@
 #: ../display/d.vect/plot1.c:505
 #, fuzzy, c-format
-msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+msgid ""
+"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+msgstr ""
 #: ../display/d.vect/plot1.c:616
 #, fuzzy, c-format
@@ -16870,7 +17799,9 @@
 #: ../vector/v.sample/main.c:114
 #, fuzzy
 msgid "Sampled values will be multiplied by this factor"
-msgstr "Fator de escala opcional para valores lidos do mapa raster. Valores amostrados serão multiplicados por esse fator."
+msgstr ""
+"Fator de escala opcional para valores lidos do mapa raster. Valores "
+"amostrados serão multiplicados por esse fator."
 #: ../vector/v.sample/main.c:140 ../vector/v.reclass/main.c:125
 #: ../vector/v.surf.idw/read_sites.c:36
@@ -17003,7 +17934,8 @@
 msgstr "Indicador de valor nulo"
 #: ../vector/v.db.select/main.c:90
-msgid "Print minimal region extent of selected vector features instead of attributes"
+msgid ""
+"Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:94 ../db/db.select/main.c:242
@@ -17016,7 +17948,9 @@
 #: ../vector/v.db.select/main.c:135
 #, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgid ""
+"Unable to open vector map <%s> at topology level. Flag '%c' requires "
+"topology level."
 msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
 #: ../vector/v.db.select/main.c:142 ../vector/v.to.rast3/main.c:77
@@ -17069,7 +18003,9 @@
 msgstr ""
 #: ../vector/v.net.alloc/main.c:66
-msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+msgid ""
+"Centre node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:93 ../vector/v.net.iso/main.c:100
@@ -17087,7 +18023,9 @@
 msgstr "Número de colunas"
 #: ../vector/v.net.alloc/main.c:111
-msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgid ""
+"Categories of centres (points on nodes) to which net will be allocated, "
+"layer for this categories is given by nlayer option"
 msgstr ""
 #: ../vector/v.net.alloc/main.c:182
@@ -17183,7 +18121,13 @@
 msgstr "região <%s> não encontrada"
 #: ../vector/v.net/args.c:36
-msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);arcs;new line is created from start point to end point;report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
+msgid ""
+"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
+"connect still unconnected points to vector network by inserting new line(s);"
+"arcs;new line is created from start point to end point;report;print to "
+"standard output {line_category start_point_category end_point_category};"
+"nreport;print to standard output {point_category line_category[,"
+"line_category...]}"
 msgstr ""
 #: ../vector/v.net/args.c:72
@@ -17342,8 +18286,7 @@
 msgstr "Não consegui selecionar atributo para cat=%d"
 #: ../vector/v.out.svg/main.c:370 ../vector/v.lrs/v.lrs.label/main.c:348
-#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.out.ogr/attrb.c:51
-#: ../vector/v.overlay/main.c:363
+#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.overlay/main.c:363
 #, fuzzy
 msgid "Unable to fetch data from table"
 msgstr "Não consegui selecionar dados da tabela"
@@ -17387,7 +18330,9 @@
 #: ../vector/v.to.db/update.c:32 ../vector/v.to.db/query.c:83
 #, fuzzy, c-format
 msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr "Conexão com banco de dados não definida para a camada <%d>. Execute v.db.connect."
+msgstr ""
+"Conexão com banco de dados não definida para a camada <%d>. Execute v.db."
+"connect."
 #: ../vector/v.to.db/update.c:82
 #, fuzzy
@@ -17417,7 +18362,8 @@
 #: ../vector/v.to.db/parse.c:41
 #, fuzzy
 msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr "Para coord de ponto/centróide válido, comprimento de linha/contorno válido)"
+msgstr ""
+"Para coord de ponto/centróide válido, comprimento de linha/contorno válido)"
 #: ../vector/v.to.db/parse.c:46
 #, fuzzy
@@ -17443,7 +18389,9 @@
 #: ../vector/v.to.db/parse.c:87
 #, fuzzy
 msgid "E.g. 'cat', 'count(*)', 'sum(val)'"
-msgstr "Coluna de pesquisa usada para a opção 'query'. P. ex.: 'cat', 'count(*)', 'sum(val)'"
+msgstr ""
+"Coluna de pesquisa usada para a opção 'query'. P. ex.: 'cat', 'count(*)', "
+"'sum(val)'"
 #: ../vector/v.to.db/parse.c:93
 #, fuzzy
@@ -17457,7 +18405,9 @@
 #: ../vector/v.to.db/parse.c:104
 msgid "In print mode prints totals for options: length,area,count"
-msgstr "No modo impressão, imprime os totais para as opções: comprimento, área e contagem"
+msgstr ""
+"No modo impressão, imprime os totais para as opções: comprimento, área e "
+"contagem"
 #: ../vector/v.to.db/parse.c:139
 msgid "This option requires one column"
@@ -17509,7 +18459,9 @@
 #: ../vector/v.to.db/query.c:108
 #, c-format
-msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
+msgid ""
+"Query for category '0' (no category) was not executed because of too many (%"
+"d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:145
@@ -17623,7 +18575,16 @@
 msgstr "Número de pontos de interpolação"
 #: ../vector/v.generalize/main.c:104
-msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
+msgid ""
+"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
+"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
+"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
+"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
+"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
+"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
+"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
+"smoothing;network;Network generalization;displacement;Displacement of lines "
+"close to each other;"
 msgstr ""
 #: ../vector/v.generalize/main.c:118
@@ -17720,7 +18681,8 @@
 #: ../vector/v.generalize/main.c:494
 #, c-format
-msgid "%d boundaries were not modified because modification would damage topology"
+msgid ""
+"%d boundaries were not modified because modification would damage topology"
 msgstr ""
 #: ../vector/v.generalize/main.c:497
@@ -17785,7 +18747,9 @@
 #: ../vector/v.build/main.c:39
 #, fuzzy
 msgid "Creates topology for vector map."
-msgstr "Criar rótulos de pintura para arquivo vetorial do GRASS e atributos relacionados."
+msgstr ""
+"Criar rótulos de pintura para arquivo vetorial do GRASS e atributos "
+"relacionados."
 #: ../vector/v.build/main.c:46
 #, fuzzy
@@ -17797,7 +18761,9 @@
 msgstr ""
 #: ../vector/v.build/main.c:59
-msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
+msgid ""
+"build;build topology;dump;write topology to stdout;sdump;write spatial index "
+"to stdout;cdump;write category index to stdout"
 msgstr ""
 #: ../vector/v.build/main.c:88
@@ -17834,7 +18800,9 @@
 #: ../vector/v.in.ogr/main.c:126
 #, fuzzy
 msgid "OGR layer name. If not given, all available layers are imported"
-msgstr "Vetor de saída, se não for fornecido, camadas disponíveis serão apenas mostradas"
+msgstr ""
+"Vetor de saída, se não for fornecido, camadas disponíveis serão apenas "
+"mostradas"
 #: ../vector/v.in.ogr/main.c:128
 #, fuzzy
@@ -17847,18 +18815,18 @@
 "\t\tArquivo shape ESRI: nome do arquivo\n"
 "\t\tArquivo do MapInfo: nome do arquivo"
-#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:163
+#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:169
 #, fuzzy
 msgid "Import subregion only"
 msgstr "Imprime apenas a região do mapa raster"
 #: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:226
-#: ../vector/v.in.lidar/main.c:164 ../vector/v.in.lidar/main.c:193
+#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:207
 #, fuzzy
 msgid "Subregion"
 msgstr "Região\n"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:166
+#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:172
 #, fuzzy
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr "Importar apenas subregião (xmin,ymin,xmax,ymaz  - normalmente W,S,E,N)"
@@ -17874,7 +18842,9 @@
 #: ../vector/v.in.ogr/main.c:154
 #, fuzzy
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr "Tamanho mínimo da área a importar (unidades quadradas). Áreas menores e ilhas serão ignoradas. Deve ser maior que snap^2"
+msgstr ""
+"Tamanho mínimo da área a importar (unidades quadradas). Áreas menores e "
+"ilhas serão ignoradas. Deve ser maior que snap^2"
 #: ../vector/v.in.ogr/main.c:160
 #, fuzzy
@@ -17883,8 +18853,13 @@
 #: ../vector/v.in.ogr/main.c:162
 #, fuzzy
-msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
-msgstr " ponto;importar centróides das áreas como pontos;linha;importar limites das áreas como linhas;limite;importar linhas como limites das áreas;centróide;importar pontos como centróides"
+msgid ""
+"point;import area centroids as points;line;import area boundaries as lines;"
+"boundary;import lines as area boundaries;centroid;import points as centroids"
+msgstr ""
+" ponto;importar centróides das áreas como pontos;linha;importar limites das "
+"áreas como linhas;limite;importar linhas como limites das áreas;centróide;"
+"importar pontos como centróides"
 #: ../vector/v.in.ogr/main.c:173
 msgid "Snapping threshold for boundaries"
@@ -17895,8 +18870,12 @@
 msgstr "-1 para não haver snap"
 #: ../vector/v.in.ogr/main.c:190
-msgid "List of column names to be used instead of original names, first is used for category column"
-msgstr "Lista de nomes de colunas para usar no lugar dos nomes originais, o primeiro será usado para a coluna categoria"
+msgid ""
+"List of column names to be used instead of original names, first is used for "
+"category column"
+msgstr ""
+"Lista de nomes de colunas para usar no lugar dos nomes originais, o primeiro "
+"será usado para a coluna categoria"
 #: ../vector/v.in.ogr/main.c:197
 msgid "List available layers in data source and exit"
@@ -17912,17 +18891,12 @@
 #: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:79
 #: ../vector/v.voronoi/main.c:138 ../vector/v.overlay/main.c:123
-#: ../vector/v.in.lidar/main.c:183 ../vector/v.to.points/main.c:215
+#: ../vector/v.in.lidar/main.c:197 ../vector/v.to.points/main.c:215
 msgid "Do not create attribute table"
 msgstr "Não criar tabela de atributo."
-#: ../vector/v.in.ogr/main.c:222 ../vector/v.in.lidar/main.c:189
+#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:208
 #, fuzzy
-msgid "Override dataset projection (use location's projection)"
-msgstr "Sobrescrever projeção (usar projeção da locação)"
-#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:194
-#, fuzzy
 msgid "Limit import to the current region"
 msgstr "Não atualizar a região atual"
@@ -17930,8 +18904,10 @@
 msgid "Change column names to lowercase characters"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:204
-msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector file."
+#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:218
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the vector file."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:262
@@ -17948,12 +18924,12 @@
 msgid "Data source contains %d layers:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:252
+#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:272
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
-#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:255
+#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:275
 #: ../vector/v.edit/main.c:88
 #, fuzzy, c-format
 msgid "Vector map <%s> already exists"
@@ -17964,38 +18940,15 @@
 msgid "Layer <%s> not available"
 msgstr "Camada '%s' não disponível"
-#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:263
+#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:294
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:291
+#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:322
 #, fuzzy
 msgid "4 parameters required for 'spatial' parameter"
 msgstr " 4 parâmetros são requeridos para o parâmetro 'spatial'."
-#: ../vector/v.in.ogr/main.c:501 ../vector/v.in.lidar/main.c:341
-msgid "Unable to convert input map projection information to GRASS format for checking"
-#: ../vector/v.in.ogr/main.c:531 ../vector/v.in.lidar/main.c:374
-#, fuzzy
-msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr "Locação: %s\n"
-#: ../vector/v.in.ogr/main.c:591 ../vector/v.in.lidar/main.c:434
-#, fuzzy, c-format
-msgid ""
-"\n"
-"You can use the -o flag to %s to override this projection check.\n"
-msgstr ""
-"\n"
-"Você pode usar a opção -o para %s para ignorar esta verificação.\n"
-#: ../vector/v.in.ogr/main.c:594 ../vector/v.in.lidar/main.c:437
-#, fuzzy
-msgid "Consider generating a new location with 'location' parameter from input data set.\n"
-msgstr "Considere gerar uma nova locação com o parâmetro 'location' do dado de entrada.\n"
 #: ../vector/v.in.ogr/main.c:617
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
@@ -18014,24 +18967,30 @@
 #: ../vector/v.in.ogr/main.c:730
 #, fuzzy, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr "Escrevendo coluna <%s> com largura fixa de 40 caracteres (pode ser truncado)"
+msgstr ""
+"Escrevendo coluna <%s> com largura fixa de 40 caracteres (pode ser truncado)"
 #: ../vector/v.in.ogr/main.c:753
 #, fuzzy, c-format
-msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
-msgstr "Largura da coluna '%s' ajustada para 255 (não foi especificada pelo OGR), alguns textos podem ser truncados!"
+msgid ""
+"Width for column %s set to 255 (was not specified by OGR), some strings may "
+"be truncated!"
+msgstr ""
+"Largura da coluna '%s' ajustada para 255 (não foi especificada pelo OGR), "
+"alguns textos podem ser truncados!"
 #: ../vector/v.in.ogr/main.c:765
 #, fuzzy, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
+msgstr ""
 #: ../vector/v.in.ogr/main.c:769
 #, c-format
 msgid "Column type not supported (%s)"
 msgstr "Tipo da coluna não suportado (%s)"
-#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:558
+#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:589
 #, fuzzy, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "Não conseguir abrir banco de dados %s com driver %s"
@@ -18086,27 +19045,27 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1017
+#, fuzzy
+msgid "Merge boundaries:"
+msgstr "não consegui atualizar limites"
+#: ../vector/v.in.ogr/main.c:1022
 msgid "Change boundary dangles to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1021
+#: ../vector/v.in.ogr/main.c:1026
 #, fuzzy
 msgid "Remove dangles:"
 msgstr "Removendo centróides duplicados ..."
-#: ../vector/v.in.ogr/main.c:1027
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change boundary bridges to lines:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1031
+#: ../vector/v.in.ogr/main.c:1036
 msgid "Remove bridges:"
 msgstr ""
-#: ../vector/v.in.ogr/main.c:1037
-#, fuzzy
-msgid "Merge boundaries:"
-msgstr "não consegui atualizar limites"
 #: ../vector/v.in.ogr/main.c:1055 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:607 ../vector/v.buffer/main.c:699
 msgid "Cannot calculate area centroid"
@@ -18124,8 +19083,15 @@
 #: ../vector/v.in.ogr/main.c:1138
 #, c-format
-msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
-msgstr "%d áreas representam mais feições (sobreposição) , pois os polígonos se sobrepõe na(s) camada(s) de entrada. Estas áreas estão ligadas a mais de uma linha na tabela de atributos. O número de feições para essas áreas está armazenado com categoria na camada %d"
+msgid ""
+"%d areas represent more (overlapping) features, because polygons overlap in "
+"input layer(s). Such areas are linked to more than 1 row in attribute table. "
+"The number of features for those areas is stored as category in layer %d"
+msgstr ""
+"%d áreas representam mais feições (sobreposição) , pois os polígonos se "
+"sobrepõe na(s) camada(s) de entrada. Estas áreas estão ligadas a mais de uma "
+"linha na tabela de atributos. O número de feições para essas áreas está "
+"armazenado com categoria na camada %d"
 #: ../vector/v.in.ogr/main.c:1148
 #, fuzzy, c-format
@@ -18169,8 +19135,12 @@
 #: ../vector/v.in.ogr/main.c:1207
 #, fuzzy
-msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
-msgstr "Dado de entrada possui feições 3D. Vetor criado é apenas 2D, use a opção -z para importar vetor 3D."
+msgid ""
+"Input data contains 3D features. Created vector is 2D only, use -z flag to "
+"import 3D vector"
+msgstr ""
+"Dado de entrada possui feições 3D. Vetor criado é apenas 2D, use a opção -z "
+"para importar vetor 3D."
 #: ../vector/v.in.ogr/geom.c:193
 #, fuzzy
@@ -18214,7 +19184,9 @@
 #: ../vector/v.to.rast3/main.c:51
 #, fuzzy
 msgid "Converts a vector map (only points) into a 3D raster map."
-msgstr "Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada raster 3D do GRASS."
+msgstr ""
+"Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada "
+"raster 3D do GRASS."
 #: ../vector/v.to.rast3/main.c:62
 #, fuzzy
@@ -18243,7 +19215,9 @@
 msgstr "Inportação de vetor incompleta"
 #: ../vector/v.extract/main.c:94
-msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgid ""
+"Selects vector objects from an existing vector map and creates a new map "
+"containing only the selected objects."
 msgstr ""
 #: ../vector/v.extract/main.c:99
@@ -18272,7 +19246,9 @@
 #: ../vector/v.extract/main.c:135
 #, fuzzy
 msgid "If '-' given reads from standard input"
-msgstr "Arquivo ASCII para converter para vetor binário, se não for dado, lê da entrada padrão"
+msgstr ""
+"Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+"entrada padrão"
 #: ../vector/v.extract/main.c:143
 msgid "Number of random categories matching vector objects to extract"
@@ -18285,14 +19261,18 @@
 #: ../vector/v.extract/main.c:154
 #, fuzzy
 msgid "Enter -1 to keep original categories or the desired NEW category value"
-msgstr "Digite -1 para manter a categoria original ou um NOVO valor de categoria. Se 'novo' >= 0, a tabela não será copiada."
+msgstr ""
+"Digite -1 para manter a categoria original ou um NOVO valor de categoria. Se "
+"'novo' >= 0, a tabela não será copiada."
 #: ../vector/v.extract/main.c:155
 msgid "If new >= 0, table is not copied"
 msgstr ""
 #: ../vector/v.extract/main.c:173
-msgid "List, file, where and random options are exclusive. Please specify only one of them"
+msgid ""
+"List, file, where and random options are exclusive. Please specify only one "
+"of them"
 msgstr ""
 #: ../vector/v.extract/main.c:219
@@ -18326,7 +19306,9 @@
 msgstr "%d categorias carregadas da tabela"
 #: ../vector/v.extract/main.c:296
-msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:302
@@ -18336,12 +19318,16 @@
 #: ../vector/v.extract/main.c:306
 #, c-format
-msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+msgid ""
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:329
 #, c-format
-msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
+msgid ""
+"Random category count is larger or equal to uniq \"%s\" feature category "
+"count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:366
@@ -18372,8 +19358,11 @@
 #: ../vector/v.in.db/main.c:57
 #, fuzzy
-msgid "Creates new vector (points) map from database table containing coordinates."
-msgstr "Cria novo vetor (pontos) a partir de tabela do banco de dados contento coordenadas."
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+"Cria novo vetor (pontos) a partir de tabela do banco de dados contento "
+"coordenadas."
 #: ../vector/v.in.db/main.c:61
 msgid "Input table name"
@@ -18414,7 +19403,8 @@
 #: ../vector/v.in.db/main.c:133
 #, fuzzy, c-format
-msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid ""
+"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr "A tabela de vetores '%s' já existe."
 #: ../vector/v.in.db/main.c:141 ../vector/v.transform/trans_digit.c:95
@@ -18456,11 +19446,16 @@
 msgstr "Mapa vetorial não é 3D"
 #: ../vector/v.net.iso/main.c:76
-msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
+msgid ""
+"Splits net to bands between cost isolines (direction from centre). Centre "
+"node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:114
-msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
+msgid ""
+"Categories of centres (points on nodes) to which net will be allocated. "
+"Layer for this categories is given by nlayer option."
 msgstr ""
 #: ../vector/v.net.iso/main.c:123
@@ -18509,7 +19504,9 @@
 msgstr ""
 #: ../vector/v.net.salesman/main.c:108
-msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:126
@@ -18556,8 +19553,14 @@
 #: ../vector/v.perturb/main.c:87
 #, fuzzy
-msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-msgstr "Parâmetro(s) da distribuição. Se a distribuição é uniforme, apenas o máximo é necessário. Para uma distribuição normal, a média e o desvio padrão são necessários."
+msgid ""
+"If the distribution is uniform, only one parameter, the maximum, is needed. "
+"For a normal distribution, two parameters, the mean and standard deviation, "
+"are required."
+msgstr ""
+"Parâmetro(s) da distribuição. Se a distribuição é uniforme, apenas o máximo "
+"é necessário. Para uma distribuição normal, a média e o desvio padrão são "
+"necessários."
 #: ../vector/v.perturb/main.c:97
 msgid "Minimum deviation in map units"
@@ -18606,11 +19609,15 @@
 msgstr ""
 #: ../vector/v.net.distance/main.c:63
-msgid "Computes shortest distance via the network between the given sets of features."
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:66
-msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
+msgid ""
+"Finds the shortest paths from a feature 'to' to every feature 'from' and "
+"various information about this realtion are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:75
@@ -18671,7 +19678,9 @@
 msgstr "Não posso dar privilégios na tabela %s"
 #: ../vector/v.distance/main.c:122
-msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
 msgstr ""
 #: ../vector/v.distance/main.c:126
@@ -18724,11 +19733,20 @@
 msgstr ""
 #: ../vector/v.distance/main.c:187
-msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of the nearest point on 'to' feature;to_along;distance between points/centroids in 'from' map and the linear feature's start point in 'to' map, along this linear feature;to_angle;angle between the linear feature in 'to' map and the positive x axis, at the location of point/centroid in 'from' map, counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;attribute of nearest feature given by to_column option"
+msgid ""
+"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
+"to_x;x coordinate of the nearest point on 'to' feature;to_y;y coordinate of "
+"the nearest point on 'to' feature;to_along;distance between points/centroids "
+"in 'from' map and the linear feature's start point in 'to' map, along this "
+"linear feature;to_angle;angle between the linear feature in 'to' map and the "
+"positive x axis, at the location of point/centroid in 'from' map, "
+"counterclockwise, in radians, which is between -PI and PI inclusive;to_attr;"
+"attribute of nearest feature given by to_column option"
 msgstr ""
 #: ../vector/v.distance/main.c:205
-msgid "Column name(s) where values specified by 'upload' option will be uploaded"
+msgid ""
+"Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:206
@@ -18757,7 +19775,9 @@
 msgstr ""
 #: ../vector/v.distance/main.c:230
-msgid "The output is written to stdout but may be uploaded to a new table created by this module. From categories are may be multiple."
+msgid ""
+"The output is written to stdout but may be uploaded to a new table created "
+"by this module. From categories are may be multiple."
 msgstr ""
 #: ../vector/v.distance/main.c:288
@@ -18979,7 +19999,7 @@
 msgstr "Usar função drand48() (padrão= rand() )"
 #: ../vector/v.random/main.c:142 ../vector/v.in.dxf/main.c:80
-#: ../vector/v.in.lidar/main.c:209 ../vector/v.external/args.c:53
+#: ../vector/v.in.lidar/main.c:223 ../vector/v.external/args.c:53
 #: ../vector/v.edit/args.c:216
 #, fuzzy
 msgid "Do not build topology"
@@ -19000,7 +20020,9 @@
 msgstr ""
 #: ../vector/v.random/main.c:229
-msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
+msgid ""
+"You have created unsupported column type. This module supports only INTEGER "
+"and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:258
@@ -19045,7 +20067,8 @@
 msgstr "writeVTKHeader: Escrevendo cabeçalho VTK"
 #: ../vector/v.out.vtk/writeVTK.c:186
-msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid ""
+"No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.ascii/main.c:45
@@ -19055,7 +20078,8 @@
 #: ../vector/v.out.ascii/main.c:47
 #, fuzzy
 msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr "Converte um mapa vetorial binário do GRASS num mapa vetorial GRASS ASCII"
+msgstr ""
+"Converte um mapa vetorial binário do GRASS num mapa vetorial GRASS ASCII"
 #: ../vector/v.out.ascii/main.c:53
 #, fuzzy
@@ -19073,7 +20097,9 @@
 #: ../vector/v.out.ascii/main.c:77
 #, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topology level. Only points, lines can be processed."
+msgid ""
+"Unable to open vector map <%s> at topology level. Only points, lines can be "
+"processed."
 #: ../vector/v.out.ascii/main.c:112
@@ -19102,8 +20128,12 @@
 #: ../vector/v.out.ascii/args.c:25
 #, fuzzy
-msgid "Path to resulting ASCII file ('-' for standard output) or ASCII vector name if '-o' is defined"
-msgstr "Caminho para o arquivo ASCCI resultante ou nome do vetor ASCII se '-o' foi definido"
+msgid ""
+"Path to resulting ASCII file ('-' for standard output) or ASCII vector name "
+"if '-o' is defined"
+msgstr ""
+"Caminho para o arquivo ASCCI resultante ou nome do vetor ASCII se '-o' foi "
+"definido"
 #: ../vector/v.out.ascii/args.c:31
 #, fuzzy
@@ -19194,7 +20224,9 @@
 #: ../vector/v.outlier/main.c:76 ../vector/v.surf.bspline/main.c:106
 #: ../vector/v.lidar.edgedetection/main.c:82
 #: ../vector/v.lidar.correction/main.c:77
-msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+msgid ""
+"Estimate point density and distance for the input vector points within the "
+"current region extends and quit"
 msgstr ""
 #: ../vector/v.outlier/main.c:88
@@ -19556,8 +20588,12 @@
 #: ../vector/v.qcount/main.c:71
 #, fuzzy
-msgid "Name for output quadrant centres map (number of points is written as category)"
-msgstr "Resultados dos centros dos quadrados, o número de pontos é escrito como categoria"
+msgid ""
+"Name for output quadrant centres map (number of points is written as "
+"category)"
+msgstr ""
+"Resultados dos centros dos quadrados, o número de pontos é escrito como "
+"categoria"
 #: ../vector/v.qcount/main.c:77
 #, fuzzy
@@ -19587,7 +20623,8 @@
 #: ../vector/v.mkgrid/main.c:67
 #, fuzzy
 msgid "Creates a vector map of a user-defined grid."
-msgstr "Converte um mapa vetorial binário do GRASS numa camada raster do GRASS."
+msgstr ""
+"Converte um mapa vetorial binário do GRASS numa camada raster do GRASS."
 #: ../vector/v.mkgrid/main.c:78
 #, fuzzy
@@ -19671,8 +20708,12 @@
 #: ../vector/v.delaunay/main.c:88
 #, fuzzy
-msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
-msgstr "Cria um diagrama de Voronoi a partir de um mapa vetorial de pontos ou centróides"
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+"Cria um diagrama de Voronoi a partir de um mapa vetorial de pontos ou "
+"centróides"
 #: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:97
 #, fuzzy
@@ -19743,7 +20784,9 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:66
@@ -19867,7 +20910,8 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid "Column containing offset from milepost for the beginning of next segment"
+msgid ""
+"Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:191
@@ -20083,7 +21127,9 @@
 #: ../vector/v.lrs/v.lrs.segment/main.c:74
 #, fuzzy
-msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
 msgstr "Cria pontos ao longo das linhas de entrada"
 #: ../vector/v.lrs/v.lrs.segment/main.c:82
@@ -20094,7 +21140,9 @@
 #: ../vector/v.lrs/v.lrs.segment/main.c:113
 #, fuzzy
 msgid "Name of file containing segment rules. If not given, read from stdin."
+msgstr ""
+"padrão"
 #: ../vector/v.lrs/v.lrs.segment/main.c:180
 #: ../vector/v.lrs/v.lrs.segment/main.c:234
@@ -20209,7 +21257,9 @@
 #: ../vector/v.reclass/main.c:71
-msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
 msgstr ""
 #: ../vector/v.reclass/main.c:88
@@ -20314,8 +21364,13 @@
 #: ../vector/v.kernel/main.c:109
 #, fuzzy
-msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
-msgstr "Gera um mapa de densidade a partir dos pontos usando um kernel gaussiano 2D isotrópico móvel, ou opcionalmente gera uma mapa vetorial de densidade sobre uma rede vetorial com um kernel 1D."
+msgid ""
+"Generates a raster density map from vector point data using a moving kernel "
+"or optionally generates a vector density map on a vector network."
+msgstr ""
+"Gera um mapa de densidade a partir dos pontos usando um kernel gaussiano 2D "
+"isotrópico móvel, ou opcionalmente gera uma mapa vetorial de densidade sobre "
+"uma rede vetorial com um kernel 1D."
 #: ../vector/v.kernel/main.c:113
 msgid "Input vector with training points"
@@ -20361,7 +21416,9 @@
 msgstr "Métrica desconhecida: [%s]."
 #: ../vector/v.kernel/main.c:169
-msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
+msgid ""
+"none;No method applied at nodes with more than 2 arcs;split;Equal split "
+"(Okabe 2009) applied at nodes;"
 msgstr ""
 #: ../vector/v.kernel/main.c:176
@@ -20370,15 +21427,22 @@
 msgstr "Tipo desconhecido"
 #: ../vector/v.kernel/main.c:184
-msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
-msgstr "Tenta calcular um desvio padrão ótimo com 'stddeviation' como máximo. (experimental)"
+msgid ""
+"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
+"maximum (experimental)"
+msgstr ""
+"Tenta calcular um desvio padrão ótimo com 'stddeviation' como máximo. "
+"(experimental)"
 #: ../vector/v.kernel/main.c:189
 msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr "Apenas calcular o desvio padrão ótimo e finalizar (nenhum mapa é gerado)"
+msgstr ""
+"Apenas calcular o desvio padrão ótimo e finalizar (nenhum mapa é gerado)"
 #: ../vector/v.kernel/main.c:194
-msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+msgid ""
+"In network mode, normalize values by sum of density multiplied by length of "
+"each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
 #: ../vector/v.kernel/main.c:199
@@ -20396,11 +21460,15 @@
 #: ../vector/v.kernel/main.c:240
-msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+msgid ""
+"Optimal standard deviation calculation is supported only for node method "
+"'none' and kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:244
-msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+msgid ""
+"Optimal standard deviation calculation is supported only for kernel function "
+"'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:301
@@ -20410,8 +21478,12 @@
 #: ../vector/v.kernel/main.c:323
 #, fuzzy, c-format
-msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
-msgstr "Escolha automática do parâmetro de suavização (desvio padrão), valor máximo do desvio padrão foi ajustado para %f"
+msgid ""
+"Automatic choice of smoothing parameter (standard deviation), maximum "
+"possible value of standard deviation is set to %f"
+msgstr ""
+"Escolha automática do parâmetro de suavização (desvio padrão), valor máximo "
+"do desvio padrão foi ajustado para %f"
 #: ../vector/v.kernel/main.c:330
 #, c-format
@@ -20430,8 +21502,12 @@
 #: ../vector/v.kernel/main.c:348
 #, fuzzy, c-format
-msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
-msgstr "distâncias entre todos os pontos maiores que %e (4 desvios padrão) não consegui calcular valor ótimo."
+msgid ""
+"Distances between all points are beyond %e (4 * standard deviation), unable "
+"to calculate optimal value."
+msgstr ""
+"distâncias entre todos os pontos maiores que %e (4 desvios padrão) não "
+"consegui calcular valor ótimo."
 #: ../vector/v.kernel/main.c:359
 #, c-format
@@ -20504,83 +21580,135 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:263
-msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
+msgid ""
+"The map contains islands. With the -c flag, islands will appear as filled "
+"areas, not holes in the output map."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:269
 #, fuzzy, c-format
-msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Pontos encontrados, mas não requeridos para exportação. Verifique o parâmetro 'type'."
+msgid ""
+"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+"%d Pontos encontrados, mas não requeridos para exportação. Verifique o "
+"parâmetro 'type'."
 #: ../vector/v.out.ogr/main.c:274
 #, fuzzy, c-format
-msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Linhas encontradas, mas não requeridas para exportação. Verifique o parâmetro 'type'."
+msgid ""
+"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+"%d Linhas encontradas, mas não requeridas para exportação. Verifique o "
 #: ../vector/v.out.ogr/main.c:280
 #, fuzzy, c-format
-msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Fronteiras encontradas, mas não requeridas para exportação. Verifique o parâmetro 'type'."
+msgid ""
+"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+"%d Fronteiras encontradas, mas não requeridas para exportação. Verifique o "
 #: ../vector/v.out.ogr/main.c:286
 #, fuzzy, c-format
-msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Centróides encontrados, mas não requeridos para exportação. Verifique o parâmetro 'type'."
+msgid ""
+"%d centroid(s) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
+"%d Centróides encontrados, mas não requeridos para exportação. Verifique o "
 #: ../vector/v.out.ogr/main.c:291
 #, fuzzy, c-format
-msgid "%d area(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr "%d Áreas encontradas, mas não requeridas para exportação. Verifique o parâmetro 'type'."
+msgid ""
+"%d area(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
+"%d Áreas encontradas, mas não requeridas para exportação. Verifique o "
 #: ../vector/v.out.ogr/main.c:295
 #, fuzzy, c-format
-msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid ""
+"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:300
 #, fuzzy, c-format
-msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid ""
+"%d volume(s) found, but not requested to be exported. Verify 'type' "
+"parameter."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:306
 #, fuzzy
-msgid "No points found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No points found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:315
 #, fuzzy
-msgid "No lines found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No lines found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:325
 #, fuzzy
-msgid "No boundaries found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No boundaries found, but requested to be exported. Will skip this feature "
+"type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:334
 #, fuzzy
-msgid "No areas found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No areas found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:344
 #, fuzzy
-msgid "No centroids found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No centroids found, but requested to be exported. Will skip this feature "
+"type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:353
 #, fuzzy
-msgid "No faces found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No faces found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:362
 #, fuzzy
-msgid "No kernels found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No kernels found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:371
 #, fuzzy
-msgid "No volumes found, but requested to be exported. Will skip this feature type."
+msgid ""
+"No volumes found, but requested to be exported. Will skip this feature type."
+msgstr ""
 #: ../vector/v.out.ogr/main.c:382
 #, fuzzy
@@ -20594,7 +21722,9 @@
 #: ../vector/v.out.ogr/main.c:406
 #, c-format
-msgid "Append existing layer requires opening data source in update mode, forcing '-%c' flag"
+msgid ""
+"Append existing layer requires opening data source in update mode, forcing '-"
+"%c' flag"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:424
@@ -20623,17 +21753,23 @@
 #: ../vector/v.out.ogr/main.c:491
 #, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
+"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:503
 #, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options DIM "
+"(parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:510
 #, c-format
-msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)."
+msgid ""
+"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
+"'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:527
@@ -20648,7 +21784,9 @@
 #: ../vector/v.out.ogr/main.c:541
 msgid "No attribute table found -> using only category numbers as attributes"
-msgstr "Nenhuma tabela de atributos encontrada -> usando apenas números de categorias como atributos"
+msgstr ""
+"Nenhuma tabela de atributos encontrada -> usando apenas números de "
+"categorias como atributos"
 #: ../vector/v.out.ogr/main.c:545
 msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -20721,7 +21859,9 @@
 #: ../vector/v.out.ogr/args.c:17
 #, fuzzy
-msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
+msgid ""
+"Combination of types is not supported by all output formats. Default is to "
+"use first type found in input vector map."
 msgstr "A combinação de tipos não é suportada por todos os formatos."
 #: ../vector/v.out.ogr/args.c:28
@@ -20777,8 +21917,12 @@
 #: ../vector/v.out.ogr/args.c:88
 #, fuzzy
-msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
-msgstr "Exportar apenas feições com categorias. De outro modo, todas as feições serão exportadas."
+msgid ""
+"Also export features without category (not labeled). Otherwise only features "
+"with category are exported."
+msgstr ""
+"Exportar apenas feições com categorias. De outro modo, todas as feições "
+"serão exportadas."
 #: ../vector/v.out.ogr/args.c:94
 #, fuzzy
@@ -20796,7 +21940,9 @@
 #: ../vector/v.out.ogr/args.c:112
 #, fuzzy
-msgid "Create a new empty OGR layer in defined OGR datasource and exit. Nothing is read from input."
+msgid ""
+"Create a new empty OGR layer in defined OGR datasource and exit. Nothing is "
+"read from input."
 msgstr "Cria um novo mapa vazio e sai. Nada é lido da entrada"
 #: ../vector/v.out.ogr/attrb.c:41
@@ -20804,7 +21950,7 @@
 msgid "Cannot select attributes for cat = %d"
-#: ../vector/v.out.ogr/attrb.c:64
+#: ../vector/v.out.ogr/attrb.c:58
 #, fuzzy, c-format
 msgid "No database record for cat = %d and export of 'cat' disabled"
 msgstr "Sem registro no banco para categoria %d"
@@ -20851,7 +21997,8 @@
 #: ../vector/v.surf.bspline/main.c:177
 #, fuzzy
 msgid "Name of attribute column with values to approximate"
-msgstr "Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
+msgstr ""
+"Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
 #: ../vector/v.surf.bspline/main.c:185
 msgid "Maximum memory to be used for raster output (in MB)"
@@ -20888,7 +22035,9 @@
 #: ../vector/v.surf.bspline/main.c:314
 #, c-format
-msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
+msgid ""
+"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
+"a raster output or other driver."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:336
@@ -20932,12 +22081,18 @@
 #: ../vector/v.surf.bspline/crosscorr.c:72
 #, fuzzy, c-format
 msgid "%d are too many points. The cross validation would take too much time."
-msgstr "Correlação cruzada: %d são demasiados pontos. A validação cruzada demoraria demasiado tempo"
+msgstr ""
+"Correlação cruzada: %d são demasiados pontos. A validação cruzada demoraria "
+"demasiado tempo"
 #: ../vector/v.surf.bspline/crosscorr.c:85
 #, fuzzy
-msgid "Maybe, it takes too long. It will depend on how many points you are considering."
-msgstr "Correlação cruzada: Talvez, demora demasiado tempo. Dependerá da quantidade de pontos que está a considerar"
+msgid ""
+"Maybe, it takes too long. It will depend on how many points you are "
+"considering."
+msgstr ""
+"Correlação cruzada: Talvez, demora demasiado tempo. Dependerá da quantidade "
+"de pontos que está a considerar"
 #: ../vector/v.surf.bspline/crosscorr.c:114
 #, c-format
@@ -21118,7 +22273,9 @@
 msgstr ""
 #: ../vector/v.vol.rst/main.c:245
-msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
+msgid ""
+"Interpolates point data to a G3D grid volume using regularized spline with "
+"tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:253
@@ -21259,11 +22416,16 @@
 #: ../vector/v.vol.rst/user1.c:109
 msgid "Column type of wcolumn is not supported (must be integer or double)"
-msgstr "Tipo da coluna não suportado. Coluna \"wcolumn\" deve ser do tipo inteiro ou \"double\""
+msgstr ""
+"Tipo da coluna não suportado. Coluna \"wcolumn\" deve ser do tipo inteiro ou "
+"\"double\""
 #: ../vector/v.vol.rst/user1.c:128
-msgid "Column type of smooth column is not supported (must be integer or double)"
-msgstr "Tipo da coluna não suportado. Coluna \"smooth\" deve ser do tipo inteiro ou \"double\""
+msgid ""
+"Column type of smooth column is not supported (must be integer or double)"
+msgstr ""
+"Tipo da coluna não suportado. Coluna \"smooth\" deve ser do tipo inteiro ou "
+"\"double\""
 #: ../vector/v.external.out/link.c:44
 #, fuzzy
@@ -21504,15 +22666,20 @@
 #: ../vector/v.patch/main.c:70
 #, fuzzy
 msgid "Creates a new vector map by combining other vector maps."
-msgstr "Converte um mapa vetorial binário do GRASS pela combinação de outros camadas de mapa vetorial."
+msgstr ""
+"Converte um mapa vetorial binário do GRASS pela combinação de outros camadas "
+"de mapa vetorial."
 #: ../vector/v.patch/main.c:81
 #, fuzzy
-msgid "Name for output vector map where bounding boxes of input vector maps are written to"
+msgid ""
+"Name for output vector map where bounding boxes of input vector maps are "
+"written to"
 msgstr "Mapa de saída no qual os erros serão gravados"
 #: ../vector/v.patch/main.c:85
-msgid "Append files to existing file (overwriting existing files must be activated)"
+msgid ""
+"Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:90
@@ -21523,7 +22690,9 @@
 #: ../vector/v.patch/main.c:92
 #, fuzzy
 msgid "Only the table of layer 1 is currently supported"
-msgstr "Também copiar tabela de atributos. Apenas a tabela da camada 1 é suportada atualmente"
+msgstr ""
+"Também copiar tabela de atributos. Apenas a tabela da camada 1 é suportada "
+"atualmente"
 #: ../vector/v.patch/main.c:97
 #, fuzzy
@@ -21774,8 +22943,11 @@
 msgstr "Texto para para seguinte de mapear"
 #: ../vector/v.support/main.c:118
-msgid "Command line to store into vector map history file (used for vector scripts)"
-msgstr "Linha de comando para guardar no arquivo de histórico de mapa vetorial (usado para scripts de vetor)"
+msgid ""
+"Command line to store into vector map history file (used for vector scripts)"
+msgstr ""
+"Linha de comando para guardar no arquivo de histórico de mapa vetorial "
+"(usado para scripts de vetor)"
 #: ../vector/v.support/main.c:122
 msgid "Replace comment instead of appending it"
@@ -21792,7 +22964,8 @@
 #: ../vector/v.select/main.c:54
 #, fuzzy
-msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
 msgstr "Selecionar feições da entradaA pelos feições da entradaB"
 #: ../vector/v.select/main.c:87
@@ -21887,9 +23060,15 @@
 #: ../vector/v.select/args.c:47
 #, fuzzy
-msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
+msgid ""
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+"given layer is defined."
 msgstr ""
-"O operador define relações requeridas entre feições. Uma feição é escrita para a saída se o resultaddo da operação 'entradaA operador entradaB' for verdadeiro. Uma feição de entrada pode ser considerada verdadeira se a categoria da camada estiver definida.\n"
+"O operador define relações requeridas entre feições. Uma feição é escrita "
+"para a saída se o resultaddo da operação 'entradaA operador entradaB' for "
+"verdadeiro. Uma feição de entrada pode ser considerada verdadeira se a "
+"categoria da camada estiver definida.\n"
 "\tsopreposição: feições parcial ou completamente sobrepostas"
 #: ../vector/v.select/args.c:52
@@ -21897,7 +23076,15 @@
 msgstr ""
 #: ../vector/v.select/args.c:57
-msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
+msgid ""
+"overlap;features partially or completely overlap;equals;features are "
+"spatially equals (using GEOS);disjoint;features do not spatially intersect "
+"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
+"features spatially touches (using GEOS);crosses;features spatially crosses "
+"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
+"contains;feature B is completely inside feature A (using GEOS);overlaps;"
+"features spatially overlap (using GEOS);relate;feature A is spatially "
+"related to feature B (using GEOS, requires 'relate' option);"
 msgstr ""
 #: ../vector/v.select/args.c:74
@@ -21911,8 +23098,12 @@
 #: ../vector/v.voronoi/main.c:119
 #, fuzzy
-msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgid ""
+"Creates a Voronoi diagram from an input vector map containing points or "
+"centroids."
+msgstr ""
+"centróides"
 #: ../vector/v.voronoi/main.c:134
 msgid "Output tessellation as a graph (lines), not areas"
@@ -21938,7 +23129,9 @@
 msgstr "Não consegui copiar a tabela"
 #: ../vector/v.lidar.growing/main.c:78
-msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:83
@@ -22007,7 +23200,9 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:350
-msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:370
@@ -22043,7 +23238,8 @@
 #: ../vector/v.net.steiner/main.c:523
 #, c-format
-msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid ""
+"[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:528
@@ -22073,7 +23269,9 @@
 #: ../vector/v.what/main.c:70
 #, fuzzy
 msgid "If not given read from standard input"
+msgstr ""
+"entrada padrão"
 #: ../vector/v.what/main.c:77
 msgid "Query threshold distance"
@@ -22086,7 +23284,9 @@
 #: ../vector/v.what/main.c:146
 #, fuzzy, c-format
 msgid "Number of given vector maps (%d) differs from number of layers (%d)"
-msgstr "Número de colunas definidas (%d) não coincide com o número de colunas (%d) da entrada."
+msgstr ""
+"Número de colunas definidas (%d) não coincide com o número de colunas (%d) "
+"da entrada."
 #: ../vector/v.what/main.c:155
 #, fuzzy, c-format
@@ -22240,7 +23440,9 @@
 msgstr "Lendo coordenadas do arquivo."
 #: ../vector/v.transform/main.c:85
-msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgid ""
+"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+"vector map."
 msgstr ""
 #: ../vector/v.transform/main.c:90
@@ -22271,8 +23473,12 @@
 #: ../vector/v.transform/main.c:113
 #, fuzzy
-msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
-msgstr "Usar opções de transformação (xshift, yshift, zshift, xscale, yscale, zscale, zrot) ao invés dos pontos"
+msgid ""
+"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
+"yscale, zscale, zrot) are used instead"
+msgstr ""
+"Usar opções de transformação (xshift, yshift, zshift, xscale, yscale, "
+"zscale, zrot) ao invés dos pontos"
 #: ../vector/v.transform/main.c:121
 #, fuzzy
@@ -22327,7 +23533,9 @@
 msgstr ""
 #: ../vector/v.transform/main.c:206
-msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
+msgid ""
+"Name of table and name for output vector map must be different. Otherwise "
+"the table is overwritten."
 msgstr ""
 #: ../vector/v.transform/main.c:220
@@ -22372,7 +23580,9 @@
 #: ../vector/v.transform/trans_digit.c:106
 #, c-format
-msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
+msgid ""
+"Unable to select value for category %d from table <%s>, column <%s>. For "
+"category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:117
@@ -22426,13 +23636,23 @@
 #: ../vector/v.overlay/main.c:99
 #, fuzzy
-msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
+msgid ""
+"Feature is written to output if the result of operation 'ainput operator "
+"binput' is true. Input feature is considered to be true, if category of "
 msgstr ""
 #: ../vector/v.overlay/main.c:104
-msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+msgid ""
+"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
+"(only for atype=area);not;features from ainput not overlayed by features "
+"from binput;xor;features from either ainput or binput but not those from "
+"ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:117
@@ -22456,7 +23676,9 @@
 #: ../vector/v.overlay/main.c:232
 #, fuzzy, c-format
 msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
+msgstr ""
 #: ../vector/v.overlay/main.c:267
 #, fuzzy
@@ -22538,7 +23760,10 @@
 #: ../vector/v.class/main.c:161
-msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+msgid ""
+"The discontinuities algorithm indicates that some class breaks are not "
+"statistically significant at alpha=0.05. You are advised to reduce the "
+"number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:190
@@ -22578,7 +23803,10 @@
 msgstr "Nome da coluna categoria"
 #: ../vector/v.build.polylines/main.c:128
-msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
+msgid ""
+"no;Do not assign any category number to polyline;first;Assign category "
+"number of first line to polyline;multi;Assign multiple category numbers to "
+"polyline"
 msgstr ""
 #: ../vector/v.build.polylines/main.c:212
@@ -22656,7 +23884,8 @@
 #: ../vector/v.convert/att.c:37
 #, fuzzy
 msgid "No category labels (dig_cats) found, no table created"
-msgstr "Rótulos de categorias (dig_cats) não encontrados, tabela não foi criada.\n"
+msgstr ""
+"Rótulos de categorias (dig_cats) não encontrados, tabela não foi criada.\n"
 #: ../vector/v.convert/att.c:42
 #, fuzzy
@@ -22690,8 +23919,12 @@
 #: ../vector/v.convert/read.c:99
 #, fuzzy
-msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
-msgstr "ATENÇÃO: arquivo de entrada não é portável.Tentarei converter, mas a conversão pode falhar. Por favor leia o manual para informações detalhadas."
+msgid ""
+"Input file is not portable. We will attempt to convert anyway but conversion "
+"may fail. Please read manual for detail information."
+msgstr ""
+"ATENÇÃO: arquivo de entrada não é portável.Tentarei converter, mas a "
+"conversão pode falhar. Por favor leia o manual para informações detalhadas."
 #: ../vector/v.convert/read.c:185
 #, fuzzy, c-format
@@ -22798,45 +24031,64 @@
 msgid "[%d] categories read into memory"
 msgstr "%-5d categorias lidas para a memória\n"
-#: ../vector/v.in.lidar/main.c:149
+#: ../vector/v.in.lidar/main.c:155
 #, fuzzy
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
 msgstr "Converte vetores OGR para GRASS. Drivers disponíveis:\n"
-#: ../vector/v.in.lidar/main.c:152
+#: ../vector/v.in.lidar/main.c:158
 #, fuzzy
 msgid "LAS input file"
 msgstr "Arquivo de entrada"
-#: ../vector/v.in.lidar/main.c:153
+#: ../vector/v.in.lidar/main.c:159
 msgid "LiDAR input files in LAS format (*.las or *.laz)"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:178
+#: ../vector/v.in.lidar/main.c:185
+msgid "Only import points of selected return type"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:186
 #, fuzzy
+msgid "If not specified, all points are imported"
+msgstr "valores inteiros são importados"
+#: ../vector/v.in.lidar/main.c:192
+#, fuzzy
 msgid "Print LAS file info and exit"
 msgstr "Mostra histórico do vetor ao invés de informações"
-#: ../vector/v.in.lidar/main.c:591
+#: ../vector/v.in.lidar/main.c:289
 #, fuzzy, c-format
+msgid "Unknown filter option <%s>"
+msgstr "Tipo desconhecido"
+#: ../vector/v.in.lidar/main.c:623
+#, fuzzy, c-format
 msgid "Importing %d points..."
 msgstr "Escrevendo [%s]..."
-#: ../vector/v.in.lidar/main.c:719
+#: ../vector/v.in.lidar/main.c:778
 #, fuzzy, c-format
 msgid "%d points imported"
 msgstr "%d pontos carregados\n"
-#: ../vector/v.in.lidar/main.c:721
+#: ../vector/v.in.lidar/main.c:780
 #, c-format
 msgid "%d input points were not valid"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:723
+#: ../vector/v.in.lidar/main.c:782
 #, fuzzy, c-format
 msgid "%d input points were outside of the selected area"
 msgstr "%d pontos além do limite"
+#: ../vector/v.in.lidar/main.c:784
+#, fuzzy, c-format
+msgid "%d input points were filtered by return number"
+msgstr "%d pontos além do limite"
 #: ../vector/v.net.flow/main.c:60
 msgid "flow"
 msgstr ""
@@ -22926,7 +24178,9 @@
 #: ../vector/v.segment/main.c:69
 #, fuzzy
 msgid "'-' for standard input"
+msgstr ""
+"entrada padrão"
 #: ../vector/v.segment/main.c:132 ../vector/v.segment/main.c:172
 #, fuzzy, c-format
@@ -23119,8 +24373,11 @@
 #: ../vector/v.net.path/main.c:66
 #, fuzzy
-msgid "Name of file containing start and end points. If not given, read from stdin"
-msgstr "Nome do arquivo contendo comandos gráficos, se não houver, lê da entrada padrão"
+msgid ""
+"Name of file containing start and end points. If not given, read from stdin"
+msgstr ""
+"Nome do arquivo contendo comandos gráficos, se não houver, lê da entrada "
+"padrão"
 #: ../vector/v.net.path/main.c:93
 #, fuzzy
@@ -23128,7 +24385,10 @@
 msgstr "Distância máxima do ponto para a rede"
 #: ../vector/v.net.path/main.c:94
-msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
+msgid ""
+"If start/end are given as coordinates. If start/end point is outside this "
+"threshold, the path is not found and error message is printed. To speed up "
+"the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.net.path/main.c:107
@@ -23173,15 +24433,21 @@
 #: ../vector/v.univar/main.c:66
 #, fuzzy
 msgid "Calculates univariate statistics for attribute."
-msgstr "Calcula estatísticas univariada das células não nulas de um mapa raster."
+msgstr ""
+"Calcula estatísticas univariada das células não nulas de um mapa raster."
 #: ../vector/v.univar/main.c:67
 #, fuzzy
-msgid "Variance and standard deviation is calculated only for points if specified."
-msgstr "Calcula estatísticas univariadas para atributo. Variância e desvio padrão é calculado apenas para pontos se especificado."
+msgid ""
+"Variance and standard deviation is calculated only for points if specified."
+msgstr ""
+"Calcula estatísticas univariadas para atributo. Variância e desvio padrão é "
+"calculado apenas para pontos se especificado."
 #: ../vector/v.univar/main.c:122
-msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgid ""
+"Incompatible vector type(s) specified, only number of features, minimum, "
+"maximum and range can be calculated"
 msgstr "Tipos de vetor especificados incompatíveis, apenas números de feiçoes"
 #: ../vector/v.univar/main.c:127
@@ -23202,7 +24468,9 @@
 #: ../vector/v.label/main.c:62
 #, fuzzy
 msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+"relacionados."
 #: ../vector/v.label/main.c:69
 msgid "If not given the name of the input map is used"
@@ -23248,8 +24516,11 @@
 msgstr "Largura da linha"
 #: ../vector/v.label/main.c:251
-msgid "size and space options vary significantly which may lead to crummy output"
-msgstr "opções de tamanho e espaço variam muito, o que pode gerar saída de baixa qualidade"
+msgid ""
+"size and space options vary significantly which may lead to crummy output"
+msgstr ""
+"opções de tamanho e espaço variam muito, o que pode gerar saída de baixa "
+"qualidade"
 #: ../vector/v.label/main.c:259
 msgid "Too many parameters for <reference>"
@@ -23268,7 +24539,8 @@
 #: ../vector/v.to.rast/main.c:44
 #, fuzzy
 msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
 #: ../vector/v.to.rast/main.c:63
 #, fuzzy
@@ -23277,13 +24549,17 @@
 #: ../vector/v.to.rast/main.c:64
 #, fuzzy
-msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
+msgid ""
+"attr;read values from attribute table;cat;use category values;val;use value "
+"specified by value option;z;use z coordinate (points or contours only);dir;"
+"output as flow direction (lines only)"
 msgstr ""
 "Fonte dos valores do raster:\n"
 "\t\tattr - ler valores da tabela de atributos\n"
 "\t\tcat - usar valores de categoria\n"
 "\t\tval - usar valores especificados pela opção 'value'\n"
-"\t\tz - usar coordenada z (somente pontos ou isolinhas) \t\td    - saída como direção de fluxo (apenas linhas)"
+"\t\tz - usar coordenada z (somente pontos ou isolinhas) \t\td    - saída "
+"como direção de fluxo (apenas linhas)"
 #: ../vector/v.to.rast/main.c:73
 #, fuzzy
@@ -23311,7 +24587,9 @@
 #: ../vector/v.to.rast/main.c:119
 msgid "Column parameter cannot be combined with use of category values option"
-msgstr "Parâmetro coluna não pode ser combinado com o uso da opção valores de categoria"
+msgstr ""
+"Parâmetro coluna não pode ser combinado com o uso da opção valores de "
+"categoria"
 #: ../vector/v.to.rast/main.c:124
 msgid "Column parameter cannot be combined with use of value option"
@@ -23423,7 +24701,8 @@
 #: ../vector/v.to.rast/support.c:173
 #, fuzzy, c-format
 msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr "Erro na definição de cor na coluna GRASSRGB, área %d com cat %d: cor %s"
+msgstr ""
+"Erro na definição de cor na coluna GRASSRGB, área %d com cat %d: cor %s"
 #: ../vector/v.to.rast/support.c:176
 msgid "Color set to [200:200:200]"
@@ -23536,7 +24815,9 @@
 #: ../vector/v.in.ascii/main.c:51
 #, fuzzy
 msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+msgstr ""
 #: ../vector/v.in.ascii/main.c:55
 #, fuzzy
@@ -23561,7 +24842,9 @@
 #: ../vector/v.in.ascii/main.c:82
 #, fuzzy
 msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr "Número de linhas do cabeçalho para pular no começo do arquivo de entrada (escritas no histórico do mapa)"
+msgstr ""
+"Número de linhas do cabeçalho para pular no começo do arquivo de entrada "
+"(escritas no histórico do mapa)"
 #: ../vector/v.in.ascii/main.c:91
 msgid "Column definition in SQL style (points mode)"
@@ -23569,7 +24852,9 @@
 #: ../vector/v.in.ascii/main.c:92
 #, fuzzy
-msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
+msgid ""
+"For example: 'x double precision, y double precision, cat int, name varchar"
+"(10)'"
 msgstr ""
 "Definições de coluna para modo de ponto em estilo SQL, por exemplo:\n"
 "'x double precision, y double precision, cat int, name varchar(10)'"
@@ -23581,27 +24866,40 @@
 #: ../vector/v.in.ascii/main.c:113
 #, fuzzy
 msgid "Number of column used as y coordinate (points mode)"
-msgstr "Número da coluna usada como coordenada y (primeira coluna é 1) para o modo de pontos"
+msgstr ""
+"Número da coluna usada como coordenada y (primeira coluna é 1) para o modo "
+"de pontos"
 #: ../vector/v.in.ascii/main.c:123
 #, fuzzy
 msgid "Number of column used as z coordinate (points mode)"
+msgstr ""
+"de pontos"
 #: ../vector/v.in.ascii/main.c:124
 #, fuzzy
 msgid "First column is 1. If 0, z coordinate is not used"
-msgstr "Número da coluna usada como coordenada z (primeira coluna é 1) para o modo de pontos. Se 0, coordenada z não é usada."
+msgstr ""
+"Número da coluna usada como coordenada z (primeira coluna é 1) para o modo "
+"de pontos. Se 0, coordenada z não é usada."
 #: ../vector/v.in.ascii/main.c:134
 #, fuzzy
 msgid "Number of column used as category (points mode)"
-msgstr "Número da coluna usada como coordenada x (primeira coluna é 1) para o modo de pontos"
+msgstr ""
+"Número da coluna usada como coordenada x (primeira coluna é 1) para o modo "
+"de pontos"
 #: ../vector/v.in.ascii/main.c:136
 #, fuzzy
-msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
-msgstr "Número da coluna usada como categoria (primeira coluna é 1) para o modo de pontos. Se 0, uma categoria única é designada para cada linha e escrita na nova coluna cat"
+msgid ""
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
+msgstr ""
+"Número da coluna usada como categoria (primeira coluna é 1) para o modo de "
+"pontos. Se 0, uma categoria única é designada para cada linha e escrita na "
+"nova coluna cat"
 #: ../vector/v.in.ascii/main.c:145
 #, fuzzy
@@ -23678,14 +24976,16 @@
 #: ../vector/v.in.ascii/main.c:270
 #, fuzzy
-msgid "z column number > minimum last column number (incorrect field separator?)"
+msgid ""
+"z column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 "número da coluna z > mínimo da última coluna\n"
 "(separador de campo incorreto?)"
 #: ../vector/v.in.ascii/main.c:275
 #, fuzzy
-msgid "cat column number > minimum last column number (incorrect field separator?)"
+msgid ""
+"cat column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 "número da coluna cat > mínimo da última coluna\n"
@@ -23712,8 +25012,11 @@
 #: ../vector/v.in.ascii/main.c:416
 #, fuzzy, c-format
-msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgid ""
+"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr ""
+"da entrada."
 #: ../vector/v.in.ascii/main.c:444
 #, fuzzy, c-format
@@ -23756,13 +25059,17 @@
 msgstr "Rotacionando dados ... "
 #: ../vector/v.in.ascii/main.c:528
-msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
+msgid ""
+"Could not close attribute table. The DBMI driver did not accept all "
+"attributes"
 msgstr ""
 #: ../vector/v.external/main.c:52
 #, fuzzy
 msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
+msgstr ""
 #: ../vector/v.external/main.c:98
 #, fuzzy, c-format
@@ -23854,7 +25161,9 @@
 msgstr ""
 #: ../vector/v.clean/main.c:90
-msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
+msgid ""
+"change the type of boundary dangle to line, threshold ignored if < 0, input "
+"line type is ignored"
 msgstr ""
 #: ../vector/v.clean/main.c:92
@@ -23862,7 +25171,9 @@
 msgstr ""
 #: ../vector/v.clean/main.c:93
-msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
+msgid ""
+"change the type of bridges connecting area and island or 2 islands from "
+"boundary to line"
 msgstr ""
 #: ../vector/v.clean/main.c:95
@@ -23876,7 +25187,13 @@
 #: ../vector/v.clean/main.c:97
-msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed"
+msgid ""
+"break (topologically clean) polygons (imported from non topological format, "
+"like ShapeFile). Boundaries are broken on each point shared between 2 and "
+"more polygons where angles of segments are different;prune;remove vertices "
+"in threshold from lines and boundaries, boundary is pruned only if topology "
+"is not damaged (new intersection, changed attachement of centroid), first "
+"and last segment of the boundary is never changed"
 msgstr ""
 #: ../vector/v.clean/main.c:104
@@ -23896,7 +25213,9 @@
 #: ../vector/v.clean/main.c:114
 #, fuzzy
 msgid "Threshold in map units, one value for each tool"
-msgstr "Tolerância em unidades de mapa, um valor para cada ferramenta (padrão: 0.0[,0.0,...])"
+msgstr ""
+"Tolerância em unidades de mapa, um valor para cada ferramenta (padrão: 0.0"
+"[,0.0,...])"
 #: ../vector/v.clean/main.c:115
 msgid "Default: 0.0[,0.0,...])"
@@ -24066,7 +25385,8 @@
 #: ../vector/v.clean/prune.c:212
 #, c-format
-msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid ""
+"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 #: ../vector/v.clean/prune.c:216
@@ -24080,13 +25400,18 @@
 msgstr "Arquivo raster para importar"
 #: ../vector/v.surf.idw/main.c:90
-msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
-msgstr "Interpolação de superfícies a partir de dados pontuais pelo Inverso do Quadrado da Distância"
+msgid ""
+"Surface interpolation from vector point data by Inverse Distance Squared "
+"Weighting."
+msgstr ""
+"Interpolação de superfícies a partir de dados pontuais pelo Inverso do "
+"Quadrado da Distância"
 #: ../vector/v.surf.idw/main.c:99
 #, fuzzy
 msgid "Name of attribute column with values to interpolate"
+msgstr ""
 #: ../vector/v.surf.idw/main.c:100 ../vector/v.surf.idw/main.c:124
 #, fuzzy
@@ -24100,8 +25425,12 @@
 #: ../vector/v.surf.idw/main.c:116
 #, fuzzy
-msgid "Slower but uses less memory and includes points from outside region in the interpolation"
-msgstr "Não indexar pontos por célula (lento, porém usa menos memória e inclui pontos de fora da região na interpolação)"
+msgid ""
+"Slower but uses less memory and includes points from outside region in the "
+"interpolation"
+msgstr ""
+"Não indexar pontos por célula (lento, porém usa menos memória e inclui "
+"pontos de fora da região na interpolação)"
 #: ../vector/v.surf.idw/main.c:131
 #, fuzzy
@@ -24146,7 +25475,9 @@
 msgstr ""
 #: ../vector/v.parallel/main.c:91
-msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
+msgid ""
+"left;Parallel line is on the left;right;Parallel line is on the right;both;"
+"Parallel lines on both sides"
 msgstr ""
 #: ../vector/v.parallel/main.c:101
@@ -24165,7 +25496,9 @@
 #: ../vector/v.buffer/main.c:196
 #, fuzzy
 msgid "Creates a buffer around vector features of given type."
-msgstr "Cria um buffer ao redor de feições de um determinado tipo (áreas devem conter centróide)"
+msgstr ""
+"Cria um buffer ao redor de feições de um determinado tipo (áreas devem "
+"conter centróide)"
 #: ../vector/v.buffer/main.c:215
 #, fuzzy
@@ -24195,8 +25528,12 @@
 #: ../vector/v.buffer/main.c:254
 #, fuzzy
-msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
-msgstr "Distância máxima entre o arco teórico e segmentos do polígono como múltiplos do buffer"
+msgid ""
+"Maximum distance between theoretical arc and polygon segments as multiple of "
+"buffer"
+msgstr ""
+"Distância máxima entre o arco teórico e segmentos do polígono como múltiplos "
+"do buffer"
 #: ../vector/v.buffer/main.c:259
 msgid "Make outside corners straight"
@@ -24211,7 +25548,10 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:278
-msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
+msgid ""
+"The bufcol option may contain bugs during the cleaning step. If you "
+"encounter problems, use the debug option or clean manually with v.clean "
+"tool=break; v.category step=0; v.extract -d type=area"
 msgstr ""
 #: ../vector/v.buffer/main.c:289
@@ -24240,7 +25580,9 @@
 msgstr "Não consegui selecionar dados da tabela"
 #: ../vector/v.buffer/main.c:394
-msgid "No features available for buffering. Check type option and features available in the input vector."
+msgid ""
+"No features available for buffering. Check type option and features "
+"available in the input vector."
 msgstr ""
 #: ../vector/v.buffer/main.c:409
@@ -24318,7 +25660,9 @@
 #: ../vector/v.edit/main.c:56
-msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
 msgstr ""
 #: ../vector/v.edit/main.c:65
@@ -24328,7 +25672,9 @@
 #: ../vector/v.edit/main.c:132
 #, fuzzy, c-format
-msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgid ""
+"Unable to open vector map <%s> as the background map. It is given as vector "
+"map to be edited."
 msgstr "não consegui abrir arquivo de vetores <%s> em <%s>"
 #: ../vector/v.edit/main.c:143
@@ -24347,7 +25693,9 @@
 #: ../vector/v.edit/main.c:202
 #, c-format
-msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgid ""
+"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
+"the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:240
@@ -24414,7 +25762,9 @@
 #: ../vector/v.edit/main.c:328
 #, c-format
-msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+msgid ""
+"Multiple background maps were given. Selected features will be copied only "
+"from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:338
@@ -24457,18 +25807,34 @@
 msgstr ""
 #: ../vector/v.edit/args.c:55
-msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
+msgid ""
+"create;Create new (empty) vector map;add;Add new features to existing vector "
+"map;delete;Delete selected features from vector map;move;Move selected "
+"features in vector map;vertexmove;Move vertex of selected vector lines;"
+"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
+"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
+"vector lines;select;Select lines and print their ID's;catadd;Set new "
+"categories to selected vector features for defined layer;catdel;Delete "
+"categories from selected vector features for defined layer;copy;Copy "
+"selected features;snap;Snap vector features in given threshold;flip;Flip "
+"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
+"labeling (automated assignment of z coordinate to vector lines);chtype;"
+"Change feature type (point<->centroid, line<->boundary)"
 msgstr ""
 #: ../vector/v.edit/args.c:100
 #, fuzzy
 msgid "ASCII file to be converted to binary vector map"
-msgstr "Arquivo ASCII para converter para vetor binário, se não for dado, lê da entrada padrão"
+msgstr ""
+"Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+"entrada padrão"
 #: ../vector/v.edit/args.c:102
 #, fuzzy
 msgid "If not given (or \"-\") reads from standard input"
+msgstr ""
+"entrada padrão"
 #: ../vector/v.edit/args.c:112
 msgid "Difference in x,y,z direction for moving feature or vertex"
@@ -24507,7 +25873,9 @@
 msgstr ""
 #: ../vector/v.edit/args.c:170
-msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
+msgid ""
+"length;Select only lines or boundaries shorter/longer than threshold "
+"distance;dangle;Select dangles shorter/longer than threshold distance"
 msgstr ""
 #: ../vector/v.edit/args.c:178
@@ -24516,11 +25884,15 @@
 msgstr "Nome do mapa raster"
 #: ../vector/v.edit/args.c:185
-msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+msgid ""
+"Snap added or modified features in the given threshold to the nearest "
+"existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:187
-msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
+msgid ""
+"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
+"vertex"
 msgstr ""
 #: ../vector/v.edit/args.c:195
@@ -24608,7 +25980,9 @@
 #: ../vector/v.info/main.c:45
 #, fuzzy
 msgid "Outputs basic information about a vector map."
-msgstr "Imprime informações básicas sobre uma camada de mapa vetorial especificada pelo usuário."
+msgstr ""
+"Imprime informações básicas sobre uma camada de mapa vetorial especificada "
+"pelo usuário."
 #: ../vector/v.info/parse.c:24
 #, fuzzy
@@ -24617,8 +25991,12 @@
 #: ../vector/v.info/parse.c:30
 #, fuzzy
-msgid "Print types/names of table columns for specified layer instead of info and exit"
-msgstr "Mostra tipos/nomes das colunas da tabela para a camada especificada ao invés da info"
+msgid ""
+"Print types/names of table columns for specified layer instead of info and "
+"exit"
+msgstr ""
+"Mostra tipos/nomes das colunas da tabela para a camada especificada ao invés "
+"da info"
 #: ../vector/v.info/parse.c:35
 #, fuzzy
@@ -24873,7 +26251,13 @@
 msgstr "ícone para remover"
 #: ../vector/v.category/main.c:99
-msgid "add;add a new category;del;delete category (-1 to delete all categories of given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
+msgid ""
+"add;add a new category;del;delete category (-1 to delete all categories of "
+"given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to "
+"layer 1);sum;add the value specified by cat option to the current category "
+"value;report;print report (statistics), in shell style: layer type count min "
+"max;print;print category values, more cats in the same layer are separated "
+"by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:115
@@ -24890,11 +26274,14 @@
 msgstr ""
 #: ../vector/v.category/main.c:138
-msgid "Database connection and attribute tables for concerned layers are not changed"
+msgid ""
+"Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:156
-msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+msgid ""
+"Invalid category number (must be equal to or greater than 0). Normally "
+"category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:165
@@ -24989,8 +26376,14 @@
 #: ../vector/v.surf.rst/main.c:147
 #, fuzzy
-msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
-msgstr "Interpolação e análise topográfica a partir de pontos ou isolinhas em formato vetorial para formato raster ponto flutuante do GRASS, usando uma spline regularizada com tensão e suavização."
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+"Interpolação e análise topográfica a partir de pontos ou isolinhas em "
+"formato vetorial para formato raster ponto flutuante do GRASS, usando uma "
+"spline regularizada com tensão e suavização."
 #: ../vector/v.surf.rst/main.c:154
 #, fuzzy
@@ -25048,8 +26441,10 @@
 msgstr "Nome da coluna contendo parâmetros de  suavização"
 #: ../vector/v.surf.rst/main.c:311
-msgid "Maximum distance between points on isoline (to insert additional points)"
-msgstr "Máxima distância entre pontos numa isolinha (para inserir pontos adicionais)"
+msgid ""
+"Maximum distance between points on isoline (to insert additional points)"
+msgstr ""
+"Máxima distância entre pontos numa isolinha (para inserir pontos adicionais)"
 #: ../vector/v.surf.rst/main.c:320
 #, fuzzy
@@ -25074,13 +26469,21 @@
 #: ../vector/v.surf.rst/main.c:428
 #, fuzzy
-msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
-msgstr "Ambas opções de validação cruzada devem ser especificadas (opção -v e saída de vetor cvdev)"
+msgid ""
+"Both cross-validation options (-c flag and cvdev vector output) must be "
+"specified"
+msgstr ""
+"Ambas opções de validação cruzada devem ser especificadas (opção -v e saída "
+"de vetor cvdev)"
 #: ../vector/v.surf.rst/main.c:431
 #, fuzzy
-msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
-msgstr "A validação cruzada não pode ser calculada junto com malhas de saída ou arquivo devi"
+msgid ""
+"The cross-validation cannot be computed simultaneously with output raster or "
+"devi file"
+msgstr ""
+"A validação cruzada não pode ser calculada junto com malhas de saída ou "
+"arquivo devi"
 #: ../vector/v.surf.rst/main.c:449
 msgid "Using anisotropy - both theta and scalex have to be specified"
@@ -25145,7 +26548,9 @@
 #: ../vector/v.surf.rst/main.c:648
 #, c-format
-msgid "Processing all selected output files will require %d bytes of disk space for temp files"
+msgid ""
+"Processing all selected output files will require %d bytes of disk space for "
+"temp files"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:668
@@ -25230,7 +26635,9 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:71
-msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:81
@@ -25302,7 +26709,9 @@
 msgstr "Calculando médias das classes ..."
 #: ../vector/v.net.centrality/main.c:99
-msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:129
@@ -25362,7 +26771,8 @@
 #: ../vector/v.db.connect/main.c:55
 #, fuzzy
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr "Mostra/seleciona conexão no BD entre um mapa vetorial e tabela de atributos"
+msgstr ""
+"Mostra/seleciona conexão no BD entre um mapa vetorial e tabela de atributos"
 #: ../vector/v.db.connect/main.c:77
 #, fuzzy
@@ -25394,7 +26804,8 @@
 #: ../vector/v.db.connect/main.c:103
 msgid "Print types/names of table columns for specified layer and exit"
-msgstr "Mostra tipos/nomes das colunas da tabela para a camada especificada e sai"
+msgstr ""
+"Mostra tipos/nomes das colunas da tabela para a camada especificada e sai"
 #: ../vector/v.db.connect/main.c:110
 msgid "Overwrite connection parameter for certain layer"
@@ -25425,12 +26836,14 @@
 #: ../vector/v.db.connect/main.c:199
 #, c-format
-msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid ""
+"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:205
 #, c-format
-msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid ""
+"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:268
@@ -25445,8 +26858,12 @@
 #: ../vector/v.db.connect/main.c:304 ../vector/v.db.connect/main.c:322
 #, c-format
-msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
-msgstr "A tabela <%s> é agora parte do mapa veeteoria <%s> e pode ser apagada ou sobrescrita pelos módulos do GRASS/"
+msgid ""
+"The table <%s> is now part of vector map <%s> and may be deleted or "
+"overwritten by GRASS modules"
+msgstr ""
+"A tabela <%s> é agora parte do mapa veeteoria <%s> e pode ser apagada ou "
+"sobrescrita pelos módulos do GRASS/"
 #: ../vector/v.db.connect/main.c:343
 #, c-format
@@ -25458,8 +26875,12 @@
 msgstr "Privilégios de seleção foram concedidos na tabela"
 #: ../vector/v.db.connect/main.c:353
-msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
-msgstr "Para definir uma nova conexão, você tem que especificar os parâmetros: driver, banco de dados, tabela [, chave [, camada]]"
+msgid ""
+"For defining a new connection you have to specify these parameters: driver, "
+"database, table [, key [, layer]]"
+msgstr ""
+"Para definir uma nova conexão, você tem que especificar os parâmetros: "
+"driver, banco de dados, tabela [, chave [, camada]]"
 #: ../vector/v.out.pov/main.c:49
 msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
@@ -25484,7 +26905,9 @@
 msgstr "Incremento para a coordenada Z"
 #: ../vector/v.out.pov/main.c:76
-msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
+msgid ""
+"This string is appended to each z coordinate. Examples: '*10', '+1000', '*10"
+"+100', '*exaggeration'"
 msgstr ""
 #: ../vector/v.out.pov/main.c:84
@@ -25531,7 +26954,9 @@
 #: ../vector/v.drape/main.c:146
 #, fuzzy
 msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr "Converter vetor 2D para 3D pela amostragem do raster de elevação. Padrão: amostragem pela vizinhança próxima"
+msgstr ""
+"Converter vetor 2D para 3D pela amostragem do raster de elevação. Padrão: "
+"amostragem pela vizinhança próxima"
 #: ../vector/v.drape/main.c:157
 #, fuzzy
@@ -25567,7 +26992,8 @@
 msgstr ""
 #: ../vector/v.drape/main.c:384
-msgid "No features drapped. Check your computational region and input vector map."
+msgid ""
+"No features drapped. Check your computational region and input vector map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:51
@@ -25585,8 +27011,13 @@
 #: ../vector/v.neighbors/main.c:53
 #, fuzzy
-msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
-msgstr "Define a categoria de cada célula como função das categorias das células vizinhas, e grava os novos valores numa camada raster de saída."
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map."
+msgstr ""
+"Define a categoria de cada célula como função das categorias das células "
+"vizinhas, e grava os novos valores numa camada raster de saída."
 #: ../vector/v.neighbors/main.c:75
 #, fuzzy
@@ -25650,7 +27081,8 @@
 #: ../vector/v.what.rast/main.c:86
 #, fuzzy
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr "Atualizar na tabela os valores do raster nas posições dos pontos vetoriais"
+msgstr ""
+"Atualizar na tabela os valores do raster nas posições dos pontos vetoriais"
 #: ../vector/v.what.rast/main.c:91
 msgid "Name of input vector points map for which to edit attribute table"
@@ -25670,7 +27102,9 @@
 #: ../vector/v.what.rast/main.c:161
 msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr "Tipo do raster é 'float' e tipo da coluna é inteiro, alguns dados foram perdidos !!"
+msgstr ""
+"Tipo do raster é 'float' e tipo da coluna é inteiro, alguns dados foram "
+"perdidos !!"
 #: ../vector/v.what.rast/main.c:241
 #, fuzzy, c-format
@@ -25891,7 +27325,9 @@
 msgstr "Área\n"
 #: ../misc/m.cogo/main.c:227
-msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:229
@@ -26002,7 +27438,8 @@
 #: ../visualization/nviz/src/nviz_init.c:148
 msgid "Number of elevation files does not match number of colors files"
-msgstr "Número de arquivos de elevação não coincide com o número arquivos de cor"
+msgstr ""
+"Número de arquivos de elevação não coincide com o número arquivos de cor"
 #: ../visualization/nviz/src/nviz_init.c:159
 #, fuzzy
@@ -26014,7 +27451,9 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/main.c:53
-msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in a 3D space."
+msgid ""
+"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
+"data) in a 3D space."
 msgstr ""
 #: ../visualization/nviz2/cmd/main.c:131
@@ -26316,7 +27755,8 @@
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:603
-msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgid ""
+"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
 msgstr ""
 #: ../visualization/nviz2/cmd/args.c:607
@@ -26583,7 +28023,9 @@
 msgstr "Cria EPS (Encapsulated PostScript) ao invés de PostScript."
 #: ../ps/ps.map/main.c:119
-msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
+msgid ""
+"Describe map-box's position on the page and exit (inches from top-left of "
+"paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:124
@@ -26669,7 +28111,9 @@
 #: ../ps/ps.map/r_vpoints.c:245
 #, c-format
-msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
+msgid ""
+"The mapping instruction <%s> will be renamed to <%s> in future versions of "
+"GRASS. Please use <%s> instead."
 msgstr ""
 #: ../ps/ps.map/r_group.c:29
@@ -26738,8 +28182,14 @@
 #: ../ps/ps.map/ps_clrtbl.c:54
 #, fuzzy
-msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
-msgstr "Seu arquivo cats/ file é inválido. Um arquivo cats/  com categorias e rótulos é necessário para a escala de cores quando usar raster CELL. Nenhuma escala de cores será designada para esta saída PostScript."
+msgid ""
+"Your cats/ file is invalid. A cats/ file with categories and labels is "
+"required for 'colortable' when using categorical legends; see the r.category "
+"help page. Colortable creation has been skipped."
+msgstr ""
+"Seu arquivo cats/ file é inválido. Um arquivo cats/  com categorias e "
+"rótulos é necessário para a escala de cores quando usar raster CELL. Nenhuma "
+"escala de cores será designada para esta saída PostScript."
 #: ../ps/ps.map/scale.c:136
 msgid "PSmap: do_scale(): shouldn't happen"
@@ -26921,7 +28371,9 @@
 #: ../db/db.connect/main.c:87
 #, fuzzy
 msgid "Default group of database users to which select privilege is granted"
-msgstr "Grupo padrão de usuários do banco de dados que possuem privilégio de seleção (select)"
+msgstr ""
+"Grupo padrão de usuários do banco de dados que possuem privilégio de seleção "
+"(select)"
 #: ../db/db.connect/main.c:122
 #, fuzzy
@@ -26961,18 +28413,30 @@
 #: ../db/drivers/postgres/describe.c:116
 #, c-format
-msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
-msgstr "coluna '%s' : tipo int8 (bigint) armazenado como inteiro (4 bytes) alguns dados podem ser danificados"
+msgid ""
+"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
+"may be damaged"
+msgstr ""
+"coluna '%s' : tipo int8 (bigint) armazenado como inteiro (4 bytes) alguns "
+"dados podem ser danificados"
 #: ../db/drivers/postgres/describe.c:120
 #, c-format
-msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
-msgstr "coluna '%s' : tipo character está armazenado como varchar(250) alguns dados podem ser perdidos"
+msgid ""
+"column '%s' : type character varying is stored as varchar(250) some data may "
+"be lost"
+msgstr ""
+"coluna '%s' : tipo character está armazenado como varchar(250) alguns dados "
+"podem ser perdidos"
 #: ../db/drivers/postgres/describe.c:126
 #, c-format
-msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
-msgstr "coluna '%s' : tipo bool (booleano) está armazenado como char(1), valores 0 (falso), 1 (verdadeiro)"
+msgid ""
+"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
+"(true)"
+msgstr ""
+"coluna '%s' : tipo bool (booleano) está armazenado como char(1), valores 0 "
+"(falso), 1 (verdadeiro)"
 #: ../db/drivers/postgres/parse.c:55 ../db/drivers/mysql/parse.c:71
 msgid "'user' in database definition is not supported, use db.login"
@@ -26980,7 +28444,8 @@
 #: ../db/drivers/postgres/parse.c:59 ../db/drivers/mysql/parse.c:75
 msgid "'password' in database definition is not supported, use db.login"
-msgstr "'password' não é suportado na definição do banco de dados, use db.login"
+msgstr ""
+"'password' não é suportado na definição do banco de dados, use db.login"
 #: ../db/drivers/postgres/parse.c:63
 msgid "Unknown option in database definition for PostgreSQL: "
@@ -27033,8 +28498,12 @@
 #: ../db/drivers/mysql/describe.c:126
 #, fuzzy, c-format
-msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgid ""
+"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
+"damaged"
+msgstr ""
 #: ../db/drivers/mysql/parse.c:60
 #, fuzzy
@@ -27120,8 +28589,12 @@
 #: ../db/drivers/ogr/describe.c:196
 #, c-format
-msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
-msgstr "coluna '%s', tipo 'string': comprimento desconhecido -> armazenado como varchar(250) alguns dados podem ser perdidos"
+msgid ""
+"column '%s', type 'string': unknown width -> stored as varchar(250) some "
+"data may be lost"
+msgstr ""
+"coluna '%s', tipo 'string': comprimento desconhecido -> armazenado como "
+"varchar(250) alguns dados podem ser perdidos"
 #: ../db/drivers/ogr/db.c:58
 #, fuzzy
@@ -27177,7 +28650,9 @@
 #: ../db/db.execute/main.c:116
 #, fuzzy
 msgid "'-' to read from standard input"
+msgstr ""
+"entrada padrão"
 #: ../db/db.execute/main.c:136
 msgid "Ignore SQL errors and continue"
@@ -27250,7 +28725,8 @@
 #: ../db/db.select/main.c:196
 #, fuzzy
 msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr "comando SQL select, por exemplo: 'select * from cesta where fruta = 'maçã''"
+msgstr ""
+"comando SQL select, por exemplo: 'select * from cesta where fruta = 'maçã''"
 #: ../db/db.select/main.c:201
 #, fuzzy
@@ -27287,7 +28763,9 @@
 #: ../db/db.describe/main.c:104
 #, fuzzy
 msgid "Print column names only instead of full column descriptions"
-msgstr "mostra apenas os nomes das colunas ao invés das descrições completas das colunas"
+msgstr ""
+"mostra apenas os nomes das colunas ao invés das descrições completas das "
+"colunas"
 #: ../db/db.describe/main.c:109
 #, fuzzy
@@ -27329,8 +28807,12 @@
 #: ../db/db.copy/main.c:39
 #, fuzzy
-msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
-msgstr "Copiar tabela. Tanto 'from_table' (opcionalmente com 'where') quanto a opção 'select' podem ser usadas, mas não ao mesmo tempo."
+msgid ""
+"Either 'from_table' (optionally with 'where') can be used or 'select' "
+"option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+"Copiar tabela. Tanto 'from_table' (opcionalmente com 'where') quanto a opção "
+"'select' podem ser usadas, mas não ao mesmo tempo."
 #: ../db/db.copy/main.c:45
 msgid "Input driver name"
@@ -27360,7 +28842,8 @@
 #, fuzzy
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
 msgstr ""
-"Comando 'select' completo (somente se 'from_table' e 'where' não forem usados),\n"
+"Comando 'select' completo (somente se 'from_table' e 'where' não forem "
+"usados),\n"
 " \t\tp.ex.:SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
 #: ../db/db.copy/main.c:87
@@ -27390,7 +28873,8 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
 #, fuzzy
-msgid "Displays spectral response at user specified locations in group or images."
+msgid ""
+"Displays spectral response at user specified locations in group or images."
 msgstr "em"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:2
@@ -27457,13 +28941,19 @@
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:1
 #, fuzzy
-msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgid ""
+"Converts all older versions of GRASS vector maps in current mapset to "
+"current format."
 msgstr "todos em atual para atual"
 #: ../locale/scriptstrings/r.buffer_to_translate.c:1
 #, fuzzy
-msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "Cria uma camada raster mostrando zonas tampão ao redor das células que contém valores de categoria não-NULOS."
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
+msgstr ""
+"Cria uma camada raster mostrando zonas tampão ao redor das células que "
+"contém valores de categoria não-NULOS."
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:1
 #, fuzzy
@@ -27497,7 +28987,9 @@
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
 #, fuzzy
-msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
 msgstr "mapear aspecto"
 #: ../locale/scriptstrings/r.plane_to_translate.c:3
@@ -27605,7 +29097,9 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:19
 #, fuzzy
-msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgid ""
+"Output long/lat in decimal degrees, or other projections with many decimal "
+"places"
 msgstr "em"
 #: ../locale/scriptstrings/m.proj_to_translate.c:21
@@ -27635,7 +29129,8 @@
 #: ../locale/scriptstrings/v.krige_to_translate.c:4
 #, fuzzy
 msgid "Name of attribute column with numerical value to be interpolated"
+msgstr ""
 #: ../locale/scriptstrings/v.krige_to_translate.c:6
 msgid "If omitted, will be <input name>_kriging"
@@ -27703,7 +29198,9 @@
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
 #, fuzzy
-msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
 msgstr "de em."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:3
@@ -27723,7 +29220,8 @@
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
 #, fuzzy
-msgid "Name of region to use instead of current region for bounds and resolution"
+msgid ""
+"Name of region to use instead of current region for bounds and resolution"
 msgstr "Nome de para de atual"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
@@ -27764,7 +29262,8 @@
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
 #, fuzzy
-msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
 msgstr "transformar para"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
@@ -27823,7 +29322,9 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
+msgid ""
+"Downloads, installs extensions from GRASS Addons SVN repository into local "
+"GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:4
@@ -27856,12 +29357,16 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:12
 #, fuzzy
-msgid "List available modules in the GRASS Addons SVN repository including modules description"
+msgid ""
+"List available modules in the GRASS Addons SVN repository including modules "
+"description"
 msgstr "Lista camadas disponíveis e finaliza"
 #: ../locale/scriptstrings/g.extension_to_translate.c:14
 #, fuzzy
-msgid "List available modules in the GRASS Addons SVN repository (shell script style)"
+msgid ""
+"List available modules in the GRASS Addons SVN repository (shell script "
+"style)"
 #: ../locale/scriptstrings/g.extension_to_translate.c:16
@@ -27937,7 +29442,9 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
 #, fuzzy
-msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
 msgstr "mapear menos área em"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
@@ -28044,7 +29551,9 @@
 #: ../locale/scriptstrings/v.report_to_translate.c:10
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for OGR access."
+msgid ""
+"A single vector map can be connected to multiple database tables. This "
+"number determines which table to use. Layer name for OGR access."
 msgstr ""
 #: ../locale/scriptstrings/v.report_to_translate.c:11
@@ -28054,7 +29563,8 @@
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
 #, fuzzy
-msgid "Allows to update a column in the attribute table connected to a vector map."
+msgid ""
+"Allows to update a column in the attribute table connected to a vector map."
 msgstr "para para em atributo para mapear"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:5
@@ -28073,7 +29583,8 @@
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
 #, fuzzy
-msgid "Value to update the column with, can be (combination of) other column(s)"
+msgid ""
+"Value to update the column with, can be (combination of) other column(s)"
 msgstr "para para para em"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:9
@@ -28083,13 +29594,16 @@
 #: ../locale/scriptstrings/v.db.update_to_translate.c:10
 #, fuzzy
-msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
+msgid ""
+"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
+"col2>1)"
 msgstr "de SQL instrução palavra-chave"
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
 #, fuzzy
 msgid "Displays a raster map and its legend on a graphics window"
-msgstr "Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
+msgstr ""
+"Exibe a legenda para um mapa raster no quadro ativo do monitor gráfico."
 #: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
 #, fuzzy
@@ -28112,7 +29626,9 @@
 msgstr "Nome do mapa raster a ser usado para <%s>"
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid "Removes a vector object (point, line, area, face etc.) from a vector map through attribute selection."
+msgid ""
+"Removes a vector object (point, line, area, face etc.) from a vector map "
+"through attribute selection."
 msgstr ""
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:5
@@ -28127,7 +29643,9 @@
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:8
 #, fuzzy
-msgid "WHERE conditions for vector delete, without 'where' keyword (e.g. \"elevation IS NULL\")"
+msgid ""
+"WHERE conditions for vector delete, without 'where' keyword (e.g. "
+"\"elevation IS NULL\")"
 #: ../locale/scriptstrings/g.manual_to_translate.c:1
@@ -28161,7 +29679,8 @@
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
 #, fuzzy
-msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgid ""
+"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
 #: ../locale/scriptstrings/r.mask_to_translate.c:1
@@ -28218,7 +29737,9 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
 #, fuzzy
-msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
 msgstr "em de"
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
@@ -28232,12 +29753,15 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:7
 #, fuzzy
-msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
+msgid ""
+"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
+"all bands"
 msgstr "faixa para Cilindro faixa"
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:8
 #, fuzzy
-msgid "Base name for output raster map (band number will be appended to base name)"
+msgid ""
+"Base name for output raster map (band number will be appended to base name)"
 msgstr "Título do raster de saída"
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:9
@@ -28247,7 +29771,8 @@
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
 #, fuzzy
-msgid "Renames a column in the attribute table connected to a given vector map."
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
 msgstr "para atributo para mapear"
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
@@ -28265,7 +29790,9 @@
 msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid "Sets color rules for features in a vector map using a numeric attribute column."
+msgid ""
+"Sets color rules for features in a vector map using a numeric attribute "
+"column."
 msgstr ""
 #: ../locale/scriptstrings/v.colors_to_translate.c:6
@@ -28336,7 +29863,9 @@
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:3
 #, fuzzy
 msgid "Create a 3D line from 3 column data"
-msgstr "Cria novo vetor (pontos) a partir de tabela do banco de dados contento coordenadas."
+msgstr ""
+"Cria novo vetor (pontos) a partir de tabela do banco de dados contento "
+"coordenadas."
 #: ../locale/scriptstrings/v.in.lines_to_translate.c:4
 #, fuzzy
@@ -28349,7 +29878,8 @@
 msgstr "Separador de Campos"
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:1
-msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
 msgstr ""
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:4
@@ -28384,7 +29914,9 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:13
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:8
-msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgid ""
+"number determines which table to use."
 msgstr ""
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:14
@@ -28600,7 +30132,9 @@
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:1
 #, fuzzy
-msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
 msgstr "Nomes pontos mapear"
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:4
@@ -28614,8 +30148,11 @@
 #, fuzzy
-msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
+msgid ""
+"Calculates univariate statistics from a raster map based on vector polygon "
+"map and uploads statistics to new attribute columns."
+msgstr ""
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
 #, fuzzy
@@ -28646,8 +30183,49 @@
 msgid "Uncompressed geonames file from (with .txt extension)"
 msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:1
+msgid "Download several tiles of MODIS products using pyModis"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:3
+#, fuzzy
+msgid "Name of MODIS product"
+msgstr "Nome de uma camada de entrada"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:4
+msgid "Name of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:5
+msgid "Password of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:6
+msgid "Folder where saves the data, full path"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:7
+#, fuzzy
+msgid "The names of tile/s to download"
+msgstr "Número de pontos a alocar"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:8
+msgid "The day from start download. If not set the download starts from today"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:9
+msgid ""
+"The day to stop download. If not set the download stops 10 day before the "
+"start day"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:10
+msgid "For debug mode, it will write more info in the log file"
+msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
 msgstr ""
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
@@ -28663,7 +30241,9 @@
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
 #, fuzzy
 msgid "Create a 3D vector points map from 3 column Matlab data"
+msgstr ""
+"coordenadas."
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
 #, fuzzy
@@ -28747,7 +30327,9 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
 #, fuzzy
-msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
@@ -28766,7 +30348,9 @@
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:9
 #, fuzzy
-msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgid ""
+"Data types depend on database backend, but all support VARCHAR(), INT, "
+"DOUBLE PRECISION and DATE"
 msgstr "de tipos ativo banco de dados todos Suporte NÚM.INT"
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -28968,7 +30552,8 @@
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
 #, fuzzy
-msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgid ""
+"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
 msgstr "em"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
@@ -28978,7 +30563,8 @@
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
 #, fuzzy
-msgid "Output raster map with nulls filled by interpolation from surrounding values"
+msgid ""
+"Output raster map with nulls filled by interpolation from surrounding values"
 msgstr "mapear"
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
@@ -28993,8 +30579,12 @@
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
 #, fuzzy
-msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
-msgstr "Nenhuma tabela de atributos encontrada -> usando apenas números de categorias como atributos"
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+"Nenhuma tabela de atributos encontrada -> usando apenas números de "
+"categorias como atributos"
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:4
 msgid "dissolve"
@@ -29095,7 +30685,8 @@
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
 #, fuzzy
-msgid "Drops a column from the attribute table connected to a given vector map."
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -29189,7 +30780,9 @@
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
 #, fuzzy
-msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
 msgstr "atributo para de mapear"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
@@ -29209,7 +30802,9 @@
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
 #, fuzzy
-msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+msgid ""
+"Name and type of the new column(s) (types depend on database backend, but "
+"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
@@ -29228,7 +30823,8 @@
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
 #, fuzzy
 msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr "Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
+msgstr ""
+"Cria um índice topográfico, ln (a/tan(beta)), mapeia do mapa de elevação."
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
 #, fuzzy
@@ -29268,7 +30864,8 @@
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:10
 #, fuzzy
-msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgid ""
+"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
 msgstr "Definir para"
 #: ../locale/scriptstrings/i.oif_to_translate.c:1
@@ -29386,8 +30983,11 @@
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
 #, fuzzy
-msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:4
 msgid "Extended statistics (quartiles and 90th percentile)"
@@ -29449,8 +31049,12 @@
 msgstr ""
 #: ../imagery/i.smap/main.c:43
-msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
-msgstr "Efetua uma classificação contextual da imagem usando estimação sequencial máxima a posteriori (SMAP)."
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+"Efetua uma classificação contextual da imagem usando estimação sequencial "
+"máxima a posteriori (SMAP)."
 #: ../imagery/i.smap/interp.c:225
 #, fuzzy
@@ -29624,7 +31228,9 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
+msgid ""
+"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
+"kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:127
@@ -29653,7 +31259,9 @@
 #: ../imagery/i.pca/main.c:67
 #, fuzzy
 msgid "Principal components analysis (PCA) for image processing."
-msgstr "Programa de Análise Canônica de Componentes (CCA) para processamento de imagens."
+msgstr ""
+"Programa de Análise Canônica de Componentes (CCA) para processamento de "
+"imagens."
 #: ../imagery/i.pca/main.c:72
 #, fuzzy
@@ -29700,7 +31308,9 @@
 #: ../imagery/i.pca/main.c:214
 #, fuzzy
 msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr "O intervalo da escala deve ser > 0. Utilizando os valores pré-definidos: 0,255"
+msgstr ""
+"O intervalo da escala deve ser > 0. Utilizando os valores pré-definidos: "
+"0,255"
 #: ../imagery/i.pca/main.c:251 ../imagery/i.pca/main.c:299
 #: ../imagery/i.pca/main.c:426
@@ -29749,7 +31359,9 @@
 msgstr "Número de pontos de interpolação"
 #: ../imagery/i.evapo.pm/main.c:61
-msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
@@ -29811,7 +31423,8 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:82
-msgid "Uses red and nir bands mostly, and some indices require additional bands."
+msgid ""
+"Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:87
@@ -29825,7 +31438,16 @@
 msgstr "Nome do mapa raster de elevação"
 #: ../imagery/i.vi/main.c:91
-msgid "arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green atmospherically resistant vegetation index;gemi;Global Environmental Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference Vegetation Index;"
+msgid ""
+"arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation "
+"Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green "
+"atmospherically resistant vegetation index;gemi;Global Environmental "
+"Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified "
+"Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted "
+"Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;"
+"Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple "
+"Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference "
+"Vegetation Index;"
 msgstr ""
 #: ../imagery/i.vi/main.c:110
@@ -29962,7 +31584,12 @@
 #: ../imagery/i.modis.qc/main.c:132
-msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) 1Km 8-days;"
+msgid ""
+"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
+"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
+"LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo "
+"Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) "
+"1Km 8-days;"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:147
@@ -29971,7 +31598,37 @@
 msgstr "Nome do mapa raster para ser reescalonado"
 #: ../imagery/i.modis.qc/main.c:148
-msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: Stat
 eQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud neighbourbrdf_correction_performed;mod13A2: if BRDF correction performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: separate land from various water objectspossible_snow_ice;mod13A2: if snow/ice present in pixelpossible_shadow;mod13A2: if shadow is present in pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;mcd43B2: Quality of BRDF correction performedsun_z_angle_at_loca
 l_noon;mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;mcd43B2q: Quality of BRDF correction performed"
+msgid ""
+"adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
+"cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
+"diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
+"modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;"
+"mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;"
+"mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average "
+"Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;"
+"data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;"
+"mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS "
+"Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error "
+"Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow "
+"Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow "
+"Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;"
+"mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: StateQA Internal "
+"Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow "
+"Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow "
+"Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;"
+"mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA "
+"Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
+"Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;"
+"mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity "
+"range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud "
+"neighbourbrdf_correction_performed;mod13A2: if BRDF correction "
+"performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: "
+"separate land from various water objectspossible_snow_ice;mod13A2: if snow/"
+"ice present in pixelpossible_shadow;mod13A2: if shadow is present in "
+"pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;"
+"mcd43B2: Quality of BRDF correction performedsun_z_angle_at_local_noon;"
+"mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;"
+"mcd43B2q: Quality of BRDF correction performed"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:191
@@ -29980,11 +31637,14 @@
 msgstr "Nome da camada raster da superfície fractal"
 #: ../imagery/i.modis.qc/main.c:199
-msgid "Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
+msgid ""
+"Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:200
-msgid "1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR 1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
+msgid ""
+"1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR "
+"1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:211
@@ -30084,8 +31744,12 @@
 #: ../imagery/i.rectify/main.c:98
 #, fuzzy
-msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
-msgstr "Retifica uma imagem por transformação das coordenadas de cada pixel da imagem a partir de pontos de controle."
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+"Retifica uma imagem por transformação das coordenadas de cada pixel da "
+"imagem a partir de pontos de controle."
 #: ../imagery/i.rectify/main.c:112
 #, fuzzy
@@ -30107,8 +31771,11 @@
 #: ../imagery/i.rectify/main.c:147
 #, fuzzy
-msgid "Use current region settings in target location (def.=calculate smallest area)"
-msgstr "Usa as definições da região atual na locação alvo (padrão: calcular a menor área)"
+msgid ""
+"Use current region settings in target location (def.=calculate smallest area)"
+msgstr ""
+"Usa as definições da região atual na locação alvo (padrão: calcular a menor "
+"área)"
 #: ../imagery/i.rectify/main.c:151
 #, fuzzy
@@ -30283,7 +31950,9 @@
 msgstr "mapa vetorial <%s> não encontrado"
 #: ../imagery/i.landsat.toar/main.c:65
-msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+."
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:67 ../imagery/i.landsat.acca/main.c:106
@@ -30332,7 +32001,9 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:99
-msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
+msgid ""
+"mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;"
+"tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:113
@@ -30447,8 +32118,12 @@
 msgstr ""
 #: ../imagery/i.vpoints/main.c:97
-msgid "Set registration points for an imagery group from a vector map or keyboard entry."
-msgstr "Marcar pontos de registo para um grupo de imagem a partir de uma mapa vectorial ou através do teclado."
+msgid ""
+"Set registration points for an imagery group from a vector map or keyboard "
+"entry."
+msgstr ""
+"Marcar pontos de registo para um grupo de imagem a partir de uma mapa "
+"vectorial ou através do teclado."
 #: ../imagery/i.vpoints/main.c:105 ../imagery/i.points/main.c:106
 #, fuzzy
@@ -30513,7 +32188,8 @@
 #: ../imagery/i.eb.h_SEBAL01/main.c:104
 #, fuzzy
 msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
-msgstr "Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
+msgstr ""
+"Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
 #: ../imagery/i.eb.h_SEBAL01/main.c:109
 #, fuzzy
@@ -30658,7 +32334,9 @@
 msgstr "Tipo de feição"
 #: ../imagery/i.eb.netrad/main.c:88
-msgid "Name of the difference of temperature from surface skin to about 2 m height [K]"
+msgid ""
+"Name of the difference of temperature from surface skin to about 2 m height "
+"[K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:89
@@ -30716,7 +32394,9 @@
 msgstr "Nome do raster de saída"
 #: ../imagery/i.eb.evapfr/main.c:54
-msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgid ""
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
 msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:60 ../imagery/i.eb.soilheatflux/main.c:71
@@ -30753,7 +32433,9 @@
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:79
-msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
@@ -30856,7 +32538,9 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:104
-msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
+msgid ""
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN.\n"
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:108
@@ -30910,7 +32594,9 @@
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:51
-msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:57
@@ -30944,7 +32630,9 @@
 #: ../imagery/i.his.rgb/main.c:51
-msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:57
@@ -31034,7 +32722,8 @@
 #: ../imagery/i.gensigset/get_train.c:58 ../imagery/i.gensig/get_train.c:55
 #, fuzzy, c-format
 msgid "Training class %d only has one cell - this class will be ignored"
-msgstr "Classe de treinamento [%d] só tem uma célula - esta classe será ignorada."
+msgstr ""
+"Classe de treinamento [%d] só tem uma célula - esta classe será ignorada."
 #: ../imagery/i.gensigset/get_train.c:63 ../imagery/i.gensig/get_train.c:60
 #, fuzzy
@@ -31100,7 +32789,8 @@
 #: ../imagery/i.ifft/main.c:80
 #, fuzzy
 msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
-msgstr "Transformada Inversa Rápida de Fourier (ifft) para processamento de imagens."
+msgstr ""
+"Transformada Inversa Rápida de Fourier (ifft) para processamento de imagens."
 #: ../imagery/i.ifft/main.c:85
 #, fuzzy
@@ -31175,7 +32865,9 @@
 #: ../imagery/i.cca/main.c:88
 msgid "Canonical components analysis (cca) program for image processing."
+msgstr ""
+"imagens."
 #: ../imagery/i.cca/main.c:95 ../imagery/i.class/main.c:111
 #, fuzzy
@@ -31215,7 +32907,8 @@
 #: ../imagery/i.cca/main.c:225
 #, fuzzy, c-format
 msgid "The output cell map <%s.%d> has values outside the 0-255 range."
-msgstr "Mapa de células de saída <%s.%d> possui valores além do limite 0-255.\n"
+msgstr ""
+"Mapa de células de saída <%s.%d> possui valores além do limite 0-255.\n"
 #: ../imagery/i.cca/transform.c:24
 msgid "Unable to allocate cell buffers."
@@ -31245,7 +32938,9 @@
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
+msgid ""
+"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
+"to radiance first)"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:104
@@ -31293,7 +32988,8 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:159
-msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgid ""
+"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:164
@@ -31475,7 +33171,9 @@
 #: ../imagery/i.fft/main.c:106
 msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr "Máscara raster encontrada, considere excluir (veja página man). Continuando..."
+msgstr ""
+"Máscara raster encontrada, considere excluir (veja página man). "
+"Continuando..."
 #: ../imagery/i.fft/main.c:129
 #, fuzzy, c-format
@@ -31496,7 +33194,9 @@
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:69
-msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
+msgid ""
+"Computes evapotranspiration calculation Prestley and Taylor formulation, "
+"1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
@@ -31646,13 +33346,21 @@
 #: ../imagery/i.cluster/main.c:79
-msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:82
 #, fuzzy
-msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
-msgstr "Uma função de imagens que gera assinaturas espectrais para tipos de cobertura do solo usando um algoritmo de agrupamento. A assinatura resultante é usada como entrada para i.maxlik, para gerar uma classificação não-supervisionada da imagem."
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+"Uma função de imagens que gera assinaturas espectrais para tipos de "
+"cobertura do solo usando um algoritmo de agrupamento. A assinatura "
+"resultante é usada como entrada para i.maxlik, para gerar uma classificação "
+"não-supervisionada da imagem."
 #: ../imagery/i.cluster/main.c:101
 msgid "Initial number of classes"
@@ -31665,7 +33373,8 @@
 #: ../imagery/i.cluster/main.c:117
 msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
-msgstr "Intervalos de amostragem (por linhas e colunas); padrão: ~10.000 pixels"
+msgstr ""
+"Intervalos de amostragem (por linhas e colunas); padrão: ~10.000 pixels"
 #: ../imagery/i.cluster/main.c:124
 msgid "Maximum number of iterations"
@@ -31850,7 +33559,8 @@
 #: ../imagery/i.cluster/main.c:286
 #, fuzzy
 msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr "Memória Esgotada. Por favor execute novamente escolhendo uma amostra menor"
+msgstr ""
+"Memória Esgotada. Por favor execute novamente escolhendo uma amostra menor"
 #: ../imagery/i.cluster/main.c:292
 #, c-format
@@ -31859,13 +33569,19 @@
 #: ../imagery/i.cluster/main.c:295
 #, fuzzy
-msgid "Not enough sample points. Please run again and choose a larger sample size."
-msgstr "Pontos da amostra insuficientes. Por favor execute novamente, escolhendo uma amostra maior"
+msgid ""
+"Not enough sample points. Please run again and choose a larger sample size."
+msgstr ""
+"Pontos da amostra insuficientes. Por favor execute novamente, escolhendo uma "
+"amostra maior"
 #: ../imagery/i.cluster/main.c:299
 #, fuzzy
-msgid "Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr "Pontos não-nulos insuficentes na amostra. Verifique sua região atual (e máscara)"
+msgid ""
+"Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr ""
+"Pontos não-nulos insuficentes na amostra. Verifique sua região atual (e "
+"máscara)"
 #: ../imagery/i.cluster/main.c:312
 #, c-format
@@ -31884,7 +33600,9 @@
 #: ../imagery/i.cluster/main.c:324
 #, fuzzy, c-format
 msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr "Não consegui escrever arquivo de assinatura <%s> para o grupo <%s>, subgrupo <%s>"
+msgstr ""
+"Não consegui escrever arquivo de assinatura <%s> para o grupo <%s>, subgrupo "
+"<%s>"
 #: ../imagery/i.cluster/main.c:329
 #, c-format
@@ -32194,7 +33912,9 @@
 " digitar as variáveis manualmente"
 #: ../imagery/i.evapo.mh/main.c:72
-msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
+msgid ""
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
@@ -32369,13 +34089,19 @@
 #: ../imagery/i.maxlik/main.c:67
 #, fuzzy
-msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
-msgstr "Uma função que classifica as reflectâncias espectrais em imagens baseado na informação de assinatura espectral gerada por i.cluster, i.class ou i.gensig."
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, i.class, or i.gensig."
+msgstr ""
+"Uma função que classifica as reflectâncias espectrais em imagens baseado na "
+"informação de assinatura espectral gerada por i.cluster, i.class ou i.gensig."
 #: ../imagery/i.maxlik/main.c:80
 #, fuzzy
 msgid "Generated by either i.cluster, i.class, or i.gensig"
+msgstr ""
 #: ../imagery/i.maxlik/main.c:85
 #, fuzzy
@@ -32389,14 +34115,18 @@
 #: ../imagery/i.maxlik/open.c:27
 #, fuzzy, c-format
-msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
+msgid ""
+"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
+"have at least 2 raster maps."
 msgstr ""
 "Subgrupo [%s] do grupo [%s] não possui arquivos.\n"
 "O subgrupo deve ter ao menos 2 arquivos."
 #: ../imagery/i.maxlik/open.c:30
 #, fuzzy, c-format
-msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
+msgid ""
+"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
+"least 2 raster maps."
 msgstr ""
 "Subgrupo [%s] do grupo [%s] possui 1 arquivo.\n"
@@ -32417,13 +34147,21 @@
 msgstr "assinatura %d inválida (singular) - ignorada."
 #: ../imagery/i.class/main.c:94
-msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
+msgid ""
+"Generates spectral signatures for an image by allowing the user to outline "
+"regions of interest."
 msgstr ""
 #: ../imagery/i.class/main.c:97
 #, fuzzy
-msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
-msgstr "Uma função que gera uma assinatura espectral para uma imagem por permitir que o usuário delineie regiões de interesse. O arquivo de assinatura resultante pode ser usado como entrada para i.maxlik ou como assinatura semente para i.cluster."
+msgid ""
+"The resulting signature file can be used as input for i.maxlik or as a seed "
+"signature file for i.cluster."
+msgstr ""
+"Uma função que gera uma assinatura espectral para uma imagem por permitir "
+"que o usuário delineie regiões de interesse. O arquivo de assinatura "
+"resultante pode ser usado como entrada para i.maxlik ou como assinatura "
+"semente para i.cluster."
 #: ../imagery/i.class/main.c:116
 #, fuzzy
@@ -32596,21 +34334,26 @@
 #: ../imagery/i.class/add_point.c:22
 #, c-format
 msgid "Can't mark another point.  Only %d points allowed.  Sorry."
-msgstr "Não posso marcar outro ponto.  Somente %d pontos permitidos.  Desculpe."
+msgstr ""
+"Não posso marcar outro ponto.  Somente %d pontos permitidos.  Desculpe."
 #, fuzzy
-msgid "Cannot allocate memory for auxiliar matrix.Consider changing region (resolution)"
-msgstr "Não consegui alocar memória para 'string'"
+#~ msgid ""
+#~ "Cannot allocate memory for auxiliar matrix.Consider changing region "
+#~ "(resolution)"
+#~ msgstr "Não consegui alocar memória para 'string'"
 #, fuzzy
-msgid ""
-"\n"
-"ERROR: Required parameter <%s> not set:\n"
-"    (%s).\n"
-msgstr "parâmetro para"
+#~ msgid ""
+#~ "\n"
+#~ "ERROR: Required parameter <%s> not set:\n"
+#~ "    (%s).\n"
+#~ msgstr "parâmetro para"
 #, fuzzy
-#~ msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
+#~ msgid ""
+#~ "resolution"
 #~ msgid "raster3d, voxel, export"
@@ -32622,8 +34365,11 @@
 #~ msgid "raster3d, voxel, import"
 #~ msgstr "raster3d, voxel, import"
-#~ msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-#~ msgstr "Converte um arquivo texto raster ASCII 3D para uma camada de mapa raster 3D (binário)."
+#~ msgid ""
+#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+#~ msgstr ""
+#~ "Converte um arquivo texto raster ASCII 3D para uma camada de mapa raster "
+#~ "3D (binário)."
 #~ msgid "Unable to close output map"
 #~ msgstr "Não consegui fechar o mapa de saída"
@@ -32710,8 +34456,12 @@
 #~ msgid "raster, statistics"
 #~ msgstr "raster, statísticas"
-#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Encontra a mediana dos valores num mapa com áreas designadas com o mesmo valor de categoria a partir de um mapa base especificado pelo usuário."
+#~ msgid ""
+#~ "Finds the median of values in a cover map within areas assigned the same "
+#~ "category value in a user-specified base map."
+#~ msgstr ""
+#~ "Encontra a mediana dos valores num mapa com áreas designadas com o mesmo "
+#~ "valor de categoria a partir de um mapa base especificado pelo usuário."
 #~ msgid "Name of base raster map"
 #~ msgstr "Nome do mapa raster base"
@@ -32753,7 +34503,9 @@
 #~ msgstr "Suprimir mensagens de erro de cruzamentos simples"
 #~ msgid "Converts a raster map layer into a height-field file for POVRAY."
-#~ msgstr "Converte uma camada raster num campo de altura (height field) para o POVRAY."
+#~ msgstr ""
+#~ "Converte uma camada raster num campo de altura (height field) para o "
+#~ "POVRAY."
 #~ msgid "raster, hydrology"
 #~ msgstr "raster, hidrologia"
@@ -32928,7 +34680,8 @@
 #~ msgstr "arquivo de horizonte num. %d <%s> não encontrado"
 #~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr "Importa arquivo raster suportado pela GDAL para uma camada raster binária."
+#~ msgstr ""
+#~ "Importa arquivo raster suportado pela GDAL para uma camada raster binária."
 #~ msgid "Required"
 #~ msgstr "Exigido"
@@ -32987,10 +34740,12 @@
 #~ msgid ""
 #~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
+#~ "Do you want to create/reset the null file for [%s] so that null cell "
+#~ "values are considered valid data? "
 #~ msgstr ""
 #~ "\n"
-#~ "Você deseja criar/reajustar o arquivo de nulos para [%s] de maneira que as células nulas sejam consideradas como dados válidos?"
+#~ "Você deseja criar/reajustar o arquivo de nulos para [%s] de maneira que "
+#~ "as células nulas sejam consideradas como dados válidos?"
 #~ msgid "Error writing null row [%d]."
 #~ msgstr "Erro escrevendo linha nula [%d]."
@@ -33020,7 +34775,9 @@
 #~ msgstr "        mapa de ponto flutuante"
 #~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "linhas * colunas * bytes por célula deve ser igual ao tamanho do arquivo (%lu)"
+#~ msgstr ""
+#~ "linhas * colunas * bytes por célula deve ser igual ao tamanho do arquivo "
+#~ "(%lu)"
 #~ msgid "If you need help figuring them out, just hit ESC"
 #~ msgstr "Se voc"
@@ -33041,10 +34798,14 @@
 #~ msgstr "Editar o cabeçalho de qual camada?"
 #~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "[%s] é uma reclassificação de [%s] - não é possível editar o cabeçalho! Execute support em [%s]."
+#~ msgstr ""
+#~ "[%s] é uma reclassificação de [%s] - não é possível editar o cabeçalho! "
+#~ "Execute support em [%s]."
 #~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] é uma reclassificação de [%s em %s] - não é possível editar o cabeçalho!"
+#~ msgstr ""
+#~ "[%s] é uma reclassificação de [%s em %s] - não é possível editar o "
+#~ "cabeçalho!"
 #~ msgid "Cannot open raster map [%s]!"
 #~ msgstr "Não consegui abrir mapa raster [%s]!"
@@ -33083,7 +34844,8 @@
 #~ msgstr "O arquivo parece estar compactado.\n"
 #~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "Muito provavelmente o cabeçalho está incorreto, mas você é quem decide.\n"
+#~ msgstr ""
+#~ "Muito provavelmente o cabeçalho está incorreto, mas você é quem decide.\n"
 #~ msgid "The header for [%s] says the file is compressed. "
 #~ msgstr "O cabeçalho de [%s] diz que o arquivo está compactado."
@@ -33091,8 +34853,12 @@
 #~ msgid "The file does NOT appear to be compressed.\n"
 #~ msgstr "O arquivo NÃO parece estar compactado.\n"
-#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
-#~ msgstr "Cabeçalho indica %d linhas%s no mapa de células, mas o formato real do arquivo indica %d linhas%s"
+#~ msgid ""
+#~ "Header indicates %d row%s in the raster map, but the actual file format "
+#~ "indicates %d row%s"
+#~ msgstr ""
+#~ "Cabeçalho indica %d linhas%s no mapa de células, mas o formato real do "
+#~ "arquivo indica %d linhas%s"
 #~ msgid "Unable to write header for [%s]."
 #~ msgstr "Não consegui escrever cabeçalho para [%s]."
@@ -33175,18 +34941,22 @@
 #, fuzzy
 #~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
-#~ msgstr "Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
+#~ msgstr ""
+#~ "Nome do mapa raster com o coeficiente de radiação do feixe de céu real [-]"
 #, fuzzy
 #~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-#~ msgstr "Nome do mapa raster do coeficiente de radiação difusa de céu real [-]"
+#~ msgstr ""
+#~ "Nome do mapa raster do coeficiente de radiação difusa de céu real [-]"
 #, fuzzy
 #~ msgid "time and insol_time are incompatible options"
 #~ msgstr "incompatível"
 #, fuzzy
-#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
+#~ msgid ""
+#~ "Mode 1: instantaneous solar incidence angle & irradiance given a set "
+#~ "local time"
 #~ msgstr "Modo ângulo"
 #, fuzzy
@@ -33283,12 +35053,18 @@
 #~ msgstr "Utilitário de interpolação bilinear para camadas de mapas raster"
 #, fuzzy
-#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
-#~ msgstr "Valor específico de entrada designado para os pólos Norte e/ou Sul em malhas latitude-longitude."
+#~ msgid ""
+#~ "Specific input value to be assigned to the north and/or south poles for "
+#~ "longitude-latitude grids"
+#~ msgstr ""
+#~ "Valor específico de entrada designado para os pólos Norte e/ou Sul em "
+#~ "malhas latitude-longitude."
 #, fuzzy
 #~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Usar \"scale\" da linha de comando é obsoleto. Por favor use a instrução \"scale mapping\""
+#~ msgstr ""
+#~ "Usar \"scale\" da linha de comando é obsoleto. Por favor use a instrução "
+#~ "\"scale mapping\""
 #~ msgid "Apply filter only to zero data values"
 #~ msgstr "Aplicar filtro somente para valores zerados"
@@ -33323,7 +35099,8 @@
 #, fuzzy
 #~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
+#~ msgstr ""
 #, fuzzy
 #~ msgid "Name of the transport capacity coefficient raster map [s]"
@@ -33402,11 +35179,19 @@
 #~ msgstr "Não consegui ler linha do arquivo raster \n"
 #, fuzzy
-#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
-#~ msgstr "Converte um arquivo raster do GRASS numa imagem PPM com a resolução da região atualmente definida."
+#~ msgid ""
+#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
+#~ "of the currently defined region."
+#~ msgstr ""
+#~ "Converte um arquivo raster do GRASS numa imagem PPM com a resolução da "
+#~ "região atualmente definida."
-#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr "Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução da região atualmente definida."
+#~ msgid ""
+#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+#~ "resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr ""
+#~ "Converte 3 camadas raster do GRASS (R,G,B) em uma imagem PPM na resolução "
+#~ "da região atualmente definida."
 #, fuzzy
 #~ msgid "raster, transect"
@@ -33509,8 +35294,12 @@
 #~ msgid "Unable to open raster map <%s> in mapset <%s>"
 #~ msgstr "Não consegui abrir mapa raster [%s] em [%s]"
-#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
-#~ msgstr "Acha a média de valores nas áreas de mesma categoria num mapa de cobertura, dado um mapa base especificado pelo usuário."
+#~ msgid ""
+#~ "Finds the average of values in a cover map within areas assigned the same "
+#~ msgstr ""
+#~ "Acha a média de valores nas áreas de mesma categoria num mapa de "
+#~ "cobertura, dado um mapa base especificado pelo usuário."
 #~ msgid "%s: ERROR running %s command"
 #~ msgstr "%s: ERRO executando comando %s"
@@ -33536,7 +35325,8 @@
 #~ msgstr "Mapa de Entrada: quantidade de fluxo superficial por célula"
 #~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "Mapa de entrada ou valor: porcentagem de terreno alterado, para USLE"
+#~ msgstr ""
+#~ "Mapa de entrada ou valor: porcentagem de terreno alterado, para USLE"
 #~ msgid "Input map: terrain blocking overland surface flow, for USLE"
 #~ msgstr "Mapa de entrada: terreno bloqueando fluxo superficial, para USLE"
@@ -33560,7 +35350,9 @@
 #~ msgstr "Mapa de saída: útil para exibição visual dos resultados"
 #~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "Saída de mapa: fator de comprimento do declive e declividade (LS) para USLE"
+#~ msgstr ""
+#~ "Saída de mapa: fator de comprimento do declive e declividade (LS) para "
+#~ "USLE"
 #~ msgid "Output map: slope steepness (S) factor for USLE"
 #~ msgstr "Saída de mapa: fator de comprimento de declividade (S) para USLE"
@@ -33569,7 +35361,8 @@
 #~ msgstr "Mapa de entrada: tamanho mínimo de bacias de drenagem exteriores"
 #~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "Valor de entrada: comprimento máximo para fluxo superficial, para USLE"
+#~ msgstr ""
+#~ "Valor de entrada: comprimento máximo para fluxo superficial, para USLE"
 #, fuzzy
 #~ msgid ""
@@ -33608,14 +35401,28 @@
 #, fuzzy
 #~ msgid ""
 #~ "USAGE for basin delineation:\n"
-#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+#~ "%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
+#~ "[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
 #~ "\n"
 #~ "USAGE for ARMSED FILE creation:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
+#~ "%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
+#~ "[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
+#~ "ha=half_basin_map ar=ARMSED_file_name\n"
 #~ "\n"
 #~ "USAGE for slope length determination:\n"
-#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
-#~ msgstr "mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo mapear mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo mapear mapear comprimento mapear limiar mapear mapear mapear exibir mapear comprimento Bloqueio mapear mapear LS comprimento mapear mapear mapear"
+#~ "%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
+#~ "[de=depression_map] [ac=accumulation_map] [di=display_map] "
+#~ "[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
+#~ "LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or "
+#~ "map]"
+#~ msgstr ""
+#~ "mapear limiar mapear mapear mapear mapear exibir mapear mapear fluxo "
+#~ "mapear mapear limiar mapear mapear mapear mapear exibir mapear mapear "
+#~ "fluxo mapear mapear comprimento mapear limiar mapear mapear mapear exibir "
+#~ "mapear comprimento Bloqueio mapear mapear LS comprimento mapear mapear "
+#~ "mapear"
 #, fuzzy
 #~ msgid "unable to open elevation map layer"
@@ -33760,8 +35567,12 @@
 #~ msgstr "Lendo arquivo dig_att...\n"
 #, fuzzy
-#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+#~ msgid ""
+#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+#~ "resolution of the currently defined region."
+#~ msgstr ""
 #, fuzzy
 #~ msgid "Unable to read header of raster map <%s>"
@@ -33772,7 +35583,9 @@
 #~ msgstr "Não consegui criar índice"
 #, fuzzy
-#~ msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
+#~ msgid ""
+#~ "Raster map <%s> in mapset <%s> is a floating point map. Decimal values "
+#~ "will be rounded to integer!"
 #~ msgstr "mapear em é mapear Decimal para!"
 #, fuzzy
@@ -33784,7 +35597,8 @@
 #~ msgstr "Escrevendo %s de %s..."
 #~ msgid "Surface generation program from rasterized contours."
-#~ msgstr "Programa para geração de superfícies a partir de isolinhas rasterizadas."
+#~ msgstr ""
+#~ "Programa para geração de superfícies a partir de isolinhas rasterizadas."
 #~ msgid "Name of existing raster map containing contours"
 #~ msgstr "Nome do mapa raster existente contendo isolinhas"
@@ -33793,11 +35607,14 @@
 #~ msgstr "Gera mapa raster de elevação"
 #, fuzzy
-#~ msgid "Unused; retained for compatibility purposes, will be removed in future"
+#~ msgid ""
+#~ "Unused; retained for compatibility purposes, will be removed in future"
 #~ msgstr "em"
 #, fuzzy
-#~ msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
+#~ msgid ""
+#~ "Invoke slow, but memory frugal operation (generally not needed, will be "
+#~ "removed in future)"
 #~ msgstr "não em"
 #, fuzzy
@@ -33816,7 +35633,9 @@
 #~ msgstr "Arquivo raster de entrada (imagem FFT, parte real)"
 #, fuzzy
-#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+#~ msgid ""
+#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
+#~ "be specified!"
 #~ msgstr "Um de!"
 #~ msgid "Resultant raster map (not used with 'distribution')"
@@ -34013,15 +35832,21 @@
 #, fuzzy
 #~ msgid "Thins non-zero cells that denote linear features in a raster map."
-#~ msgstr "Afina células não-zero que indicam feições lineares em uma camada de mapa raster."
+#~ msgstr ""
+#~ "Afina células não-zero que indicam feições lineares em uma camada de mapa "
+#~ "raster."
 #, fuzzy
 #~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
 #~ msgstr "Erro lendo arquivo raster [%s]."
 #, fuzzy
-#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
-#~ msgstr "Cria um novo mapa cujas categorias são baseadas na reclassificação do usuário sobre as categorias de um mapa raster existente."
+#~ msgid ""
+#~ "Creates a new map layer whose category values are based upon a "
+#~ "reclassification of the categories in an existing raster map layer."
+#~ msgstr ""
+#~ "Cria um novo mapa cujas categorias são baseadas na reclassificação do "
+#~ "usuário sobre as categorias de um mapa raster existente."
 #~ msgid "Raster map to be reclassified"
 #~ msgstr "Mapa raster a ser reclassificado"
@@ -34230,7 +36055,9 @@
 #~ msgstr "Não consegui atualizar região atual"
 #, fuzzy
-#~ msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+#~ msgid ""
+#~ "Construction of slope curves (flowlines), flowpath lengths, and flowline "
+#~ "densities (upslope areas) from a raster digital elevation model (DEM)."
 #~ msgstr "de"
 #, fuzzy
@@ -34340,8 +36167,12 @@
 #~ msgstr "Inportação de vetor incompleta"
 #, fuzzy
-#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
-#~ msgstr "Converte um raster ASCII (GRID) do ESRI ARC/INFO em uma camada raster binária."
+#~ msgid ""
+#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+#~ "map layer."
+#~ msgstr ""
+#~ "Converte um raster ASCII (GRID) do ESRI ARC/INFO em uma camada raster "
+#~ "binária."
 #, fuzzy
 #~ msgid "File containing weights"
@@ -34356,7 +36187,10 @@
 #~ msgstr "Fonte"
 #, fuzzy
-#~ msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+#~ msgid ""
+#~ "Copies available data files in the user's current mapset search path and "
+#~ "location to the appropriate element directories under the user's current "
+#~ "mapset."
 #~ msgstr "Cópias disponível em atual Pesquisa localização para atual."
 #, fuzzy
@@ -34387,7 +36221,8 @@
 #~ msgstr "localização"
 #, fuzzy
-#~ msgid "Would you still like to overwrite the current projection information "
+#~ msgid ""
+#~ "Would you still like to overwrite the current projection information "
 #~ msgstr "como para atual "
 #, fuzzy
@@ -34645,7 +36480,9 @@
 #~ msgstr "Exibir"
 #, fuzzy
-#~ msgid "Creates and displays a menu within the active frame on the graphics monitor."
+#~ msgid ""
+#~ "Creates and displays a menu within the active frame on the graphics "
+#~ "monitor."
 #~ msgstr "Exibir dados vetoriais do GRASS no quadro ativo do monitor gráfico"
 #, fuzzy
@@ -34769,41 +36606,66 @@
 #~ msgid "display, position, querying"
 #~ msgstr "Exibir"
-#~ msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
-#~ msgstr "Identifica as coordenadas geográficas associadas com locações no quadro ativo do monitor gráfico"
+#~ msgid ""
+#~ "Identifies the geographic coordinates associated with point locations in "
+#~ "the active frame on the graphics monitor."
+#~ msgstr ""
+#~ "Identifica as coordenadas geográficas associadas com locações no quadro "
+#~ "ativo do monitor gráfico"
 #~ msgid "One mouse click only"
 #~ msgstr "Apenas um clique do mouse"
 #, fuzzy
-#~ msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
+#~ msgid ""
+#~ "Displays the rhumbline joining two user-specified points, in the active "
+#~ "frame on the user's graphics monitor."
-#~ msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
-#~ msgstr "Gera e mostra gráficos simples sobre camadas de mapa no quadro ativo do monitor gráfico."
+#~ msgid ""
+#~ "Generates and displays simple graphics on map layers drawn in the active "
+#~ "graphics monitor display frame."
+#~ msgstr ""
+#~ "Gera e mostra gráficos simples sobre camadas de mapa no quadro ativo do "
+#~ "monitor gráfico."
-#~ msgid "Unix file containg graphing instructions, if not given reads from standard input"
-#~ msgstr "Nome do arquivo contendo comandos gráficos, se não houver, lê da entrada padrão"
+#~ msgid ""
+#~ "Unix file containg graphing instructions, if not given reads from "
+#~ "standard input"
+#~ msgstr ""
+#~ "Nome do arquivo contendo comandos gráficos, se não houver, lê da entrada "
+#~ "padrão"
-#~ msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
-#~ msgstr "Cor para desenhar, tanto uma cor padrão do GRASS como uma triplete R:G:B (separada por dois pontos)"
+#~ msgid ""
+#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
+#~ "(separated by colons)"
+#~ msgstr ""
+#~ "Cor para desenhar, tanto uma cor padrão do GRASS como uma triplete R:G:B "
+#~ "(separada por dois pontos)"
 #~ msgid "Use mouse to interactively place scale"
 #~ msgstr "Use o mouse para posicionar a escala"
-#~ msgid "The screen coordinates for top-left corner of label ([0,0] is top-left of frame)"
-#~ msgstr "Coordenadas em porcentagem do quadro ([0,0] é o canto superior esquerdo)"
+#~ msgid ""
+#~ "The screen coordinates for top-left corner of label ([0,0] is top-left of "
+#~ "frame)"
+#~ msgstr ""
+#~ "Coordenadas em porcentagem do quadro ([0,0] é o canto superior esquerdo)"
 #, fuzzy
 #~ msgid "display, geometry"
 #~ msgstr "Exibir"
-#~ msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
-#~ msgstr "Desenha texto no quadro ativo do monitor gráfico usando fontes TrueType."
+#~ msgid ""
+#~ "Draws text in the graphics monitor's active display frame using TrueType "
+#~ "fonts."
+#~ msgstr ""
+#~ "Desenha texto no quadro ativo do monitor gráfico usando fontes TrueType."
 #, fuzzy
 #~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Coordenadas em porcentagem do quadro ([0,0] é o canto inferior esquerdo)"
+#~ msgstr ""
+#~ "Coordenadas em porcentagem do quadro ([0,0] é o canto inferior esquerdo)"
 #~ msgid "Path to TrueType font (including file name)"
 #~ msgstr "Caminho para a fonte TrueType (incluindo nome do arquivo)"
@@ -34904,7 +36766,9 @@
 #~ msgstr "Nome dos quadros para salvar"
 #, fuzzy
-#~ msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
+#~ msgid ""
+#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
+#~ "be done first, if any."
 #~ msgstr ""
 #~ "Lista os números a ser movidos, \"from\" á \"to\".\n"
 #~ "\t\tNota: as opções de remoção, se houver, serão executadas primeiro."
@@ -35062,7 +36926,9 @@
 #~ msgstr "Número da camada. Se -1, todas as camadas serão exibidas"
 #, fuzzy
-#~ msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
+#~ msgid ""
+#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
+#~ "if the monitor is refreshed)"
 #~ msgstr "Não adicionar á lista de vetores e comandos no monitor"
 #, fuzzy
@@ -35093,8 +36959,12 @@
 #~ msgid "Raster map to be sampled"
 #~ msgstr "Mapa raster a ser amostrado"
-#~ msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
-#~ msgstr "Fator de escala opcional para valores lidos do mapa raster. Valores amostrados serão multiplicados por esse fator."
+#~ msgid ""
+#~ "Option scaling factor for values read from raster map. Sampled values "
+#~ "will be multiplied by this factor"
+#~ msgstr ""
+#~ "Fator de escala opcional para valores lidos do mapa raster. Valores "
+#~ "amostrados serão multiplicados por esse fator."
 #, fuzzy
 #~ msgid "Bilinear interpolation (default is nearest neighbor)"
@@ -35169,7 +37039,9 @@
 #~ msgstr "Camada número"
 #, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+#~ msgid ""
+#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d"
+#~ "(egrees)"
 #~ msgstr "mi(lhas), f(eet - pés), me(tros), k(ilometros), a(cres), h(ectares)"
 #, fuzzy
@@ -35180,15 +37052,21 @@
 #~ msgstr "Se definido em 0, coordenadas z serão usadas. (vetor 3D apenas)"
 #~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr "Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
+#~ msgstr ""
+#~ "Coluna da tabela de atributos com valores para interpolar (se camada > 0)"
 #, fuzzy
 #~ msgid "Layer but not column with z values given"
+#~ msgstr ""
 #, fuzzy
-#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
-#~ msgstr "Não existe mapa vectorial para interpolar. A interpolação será efectuada utilizando <%s> mapa vectorial"
+#~ msgid ""
+#~ "No vector map of sparse points to interpolate was specified. "
+#~ "Interpolation will be done with <%s> vector map"
+#~ msgstr ""
+#~ "Não existe mapa vectorial para interpolar. A interpolação será efectuada "
+#~ "utilizando <%s> mapa vectorial"
 #~ msgid "Decomposition failed"
 #~ msgstr "A decomposição falhou"
@@ -35214,7 +37092,9 @@
 #, fuzzy
 #~ msgid "Creates topology for GRASS vector map."
-#~ msgstr "Criar rótulos de pintura para arquivo vetorial do GRASS e atributos relacionados."
+#~ msgstr ""
+#~ "Criar rótulos de pintura para arquivo vetorial do GRASS e atributos "
+#~ "relacionados."
 #, fuzzy
 #~ msgid "Vector map <%s> not found in the current mapset"
@@ -35225,11 +37105,19 @@
 #~ msgstr "Converte vetores OGR para GRASS. Drivers disponíveis:\n"
 #, fuzzy
-#~ msgid "Unable to convert input map projection to GRASS format; cannot create new location"
-#~ msgstr "Não consegui converter a projeção do mapa de entrada para o formato do GRASS, não posso criar nova locação."
+#~ msgid ""
+#~ "Unable to convert input map projection to GRASS format; cannot create new "
+#~ "location"
+#~ msgstr ""
+#~ "Não consegui converter a projeção do mapa de entrada para o formato do "
+#~ "GRASS, não posso criar nova locação."
-#~ msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
-#~ msgstr "Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada raster 3D do GRASS."
+#~ msgid ""
+#~ "Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+#~ "raster map layer."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS (apenas pontos) numa camada "
+#~ "raster 3D do GRASS."
 #~ msgid "Column name (type must be numeric)"
 #~ msgstr "Nome da coluna (tipo deve ser numérico)"
@@ -35239,8 +37127,12 @@
 #, fuzzy
-#~ msgid "Layer number (if -1, all features in all layers of given type are extracted)"
-#~ msgstr "Número da camada. Se 1, todas as feições em todas as camadas de um tipo serão extraídas."
+#~ msgid ""
+#~ "Layer number (if -1, all features in all layers of given type are "
+#~ "extracted)"
+#~ msgstr ""
+#~ "Número da camada. Se 1, todas as feições em todas as camadas de um tipo "
+#~ "serão extraídas."
 #~ msgid "Layer 0 not supported"
 #~ msgstr "Camada 0 não suportada"
@@ -35267,8 +37159,14 @@
 #~ msgid "Vector points to be spatially perturbed"
 #~ msgstr "Pontos a ser perturbados espacialmente"
-#~ msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
-#~ msgstr "Parâmetro(s) da distribuição. Se a distribuição é uniforme, apenas o máximo é necessário. Para uma distribuição normal, a média e o desvio padrão são necessários."
+#~ msgid ""
+#~ "Parameter(s) of distribution. If the distribution is uniform, only one "
+#~ "parameter, the maximum, is needed. For a normal distribution, two "
+#~ "parameters, the mean and standard deviation, are required."
+#~ msgstr ""
+#~ "Parâmetro(s) da distribuição. Se a distribuição é uniforme, apenas o "
+#~ "máximo é necessário. Para uma distribuição normal, a média e o desvio "
+#~ "padrão são necessários."
 #, fuzzy
 #~ msgid "vector, geometry"
@@ -35328,10 +37226,13 @@
 #, fuzzy
 #~ msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-#~ msgstr "Converte um mapa vetorial binário do GRASS num mapa vetorial GRASS ASCII"
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS num mapa vetorial GRASS ASCII"
 #~ msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-#~ msgstr "Caminho para o arquivo ASCCI resultante ou nome do vetor ASCII se '-o' foi definido"
+#~ msgstr ""
+#~ "Caminho para o arquivo ASCCI resultante ou nome do vetor ASCII se '-o' "
+#~ "foi definido"
 #, fuzzy
 #~ msgid "Parameter '%s' ignored in standard mode"
@@ -35389,7 +37290,9 @@
 #, fuzzy
 #~ msgid "Output quadrant centres, number of points is written as category"
-#~ msgstr "Resultados dos centros dos quadrados, o número de pontos é escrito como categoria"
+#~ msgstr ""
+#~ "Resultados dos centros dos quadrados, o número de pontos é escrito como "
+#~ "categoria"
 #, fuzzy
 #~ msgid "Counting sites in quadrats..."
@@ -35397,7 +37300,8 @@
 #, fuzzy
 #~ msgid "Creates a GRASS vector map of a user-defined grid."
-#~ msgstr "Converte um mapa vetorial binário do GRASS numa camada raster do GRASS."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS numa camada raster do GRASS."
 #, fuzzy
 #~ msgid "vector, reclass, attributes"
@@ -35416,19 +37320,28 @@
 #~ msgstr "Não consegui ler MASK"
 #, fuzzy
-#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgid ""
+#~ "Converts GRASS vector map to one of the supported OGR vector formats."
 #~ msgstr "Converter para um dos formatos vetoriais suportados pelo OGR."
 #, fuzzy
-#~ msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
-#~ msgstr "Tipo de feição. A combinação de tipos não é suportada por todos os formatos."
+#~ msgid ""
+#~ "Feature type(s). Combinations not supported by all output formats. "
+#~ "Default: first type found in input."
+#~ msgstr ""
+#~ "Tipo de feição. A combinação de tipos não é suportada por todos os "
+#~ "formatos."
 #, fuzzy
 #~ msgid "OGR format"
 #~ msgstr "Formato OGR."
-#~ msgid "Export features with category (labeled) only. Otherwise all features are exported"
-#~ msgstr "Exportar apenas feições com categorias. De outro modo, todas as feições serão exportadas."
+#~ msgid ""
+#~ "Export features with category (labeled) only. Otherwise all features are "
+#~ "exported"
+#~ msgstr ""
+#~ "Exportar apenas feições com categorias. De outro modo, todas as feições "
+#~ "serão exportadas."
 #, fuzzy
 #~ msgid "Volumes will be exported as sets of faces."
@@ -35439,44 +37352,83 @@
 #~ msgstr "Não consegui encontrar o mapa de entrada <%s>"
 #, fuzzy
-#~ msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Áreas encontradas, mas não requeridas para exportação. Verifique o parâmetro 'type'."
+#~ msgid ""
+#~ "%d areas found, but not requested to be exported. Verify 'type' parameter."
+#~ msgstr ""
+#~ "%d Áreas encontradas, mas não requeridas para exportação. Verifique o "
+#~ "parâmetro 'type'."
 #, fuzzy
-#~ msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
-#~ msgstr "%d Linhas encontradas, mas não requeridas para exportação. Verifique o parâmetro 'type'."
+#~ msgid ""
+#~ "%d kernel(s) found, but not requested to be exported. Verify 'type' "
+#~ "parameter."
+#~ msgstr ""
+#~ "%d Linhas encontradas, mas não requeridas para exportação. Verifique o "
 #, fuzzy
-#~ msgid "No points found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "%d Pontos encontrados, mas não requeridos para exportação. Verifique o parâmetro 'type'."
+#~ msgid ""
+#~ "No points found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "%d Pontos encontrados, mas não requeridos para exportação. Verifique o "
 #, fuzzy
-#~ msgid "No lines found, but requested to be exported. Will skip this geometry type."
+#~ msgid ""
+#~ "No lines found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
 #, fuzzy
-#~ msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "Nenhuma Fronteira encontrada, mas requerida para exportação. Vou pular este tipo de geometria."
+#~ msgid ""
+#~ "No boundaries found, but requested to be exported. Will skip this "
+#~ "geometry type."
+#~ msgstr ""
+#~ "Nenhuma Fronteira encontrada, mas requerida para exportação. Vou pular "
+#~ "este tipo de geometria."
 #, fuzzy
-#~ msgid "No areas found, but requested to be exported. Will skip this geometry type."
+#~ msgid ""
+#~ "No areas found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
 #, fuzzy
-#~ msgid "No centroids found, but requested to be exported. Will skip this geometry type."
-#~ msgstr "%d Centróides encontrados, mas não requeridos para exportação. Verifique o parâmetro 'type'."
+#~ msgid ""
+#~ "No centroids found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
+#~ "%d Centróides encontrados, mas não requeridos para exportação. Verifique "
+#~ "o parâmetro 'type'."
 #, fuzzy
-#~ msgid "No faces found, but requested to be exported. Will skip this geometry type."
+#~ msgid ""
+#~ "No faces found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
 #, fuzzy
-#~ msgid "No kernels found, but requested to be exported. Will skip this geometry type."
+#~ msgid ""
+#~ "No kernels found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
 #, fuzzy
-#~ msgid "No volumes found, but requested to be exported. Will skip this geometry type."
+#~ msgid ""
+#~ "No volumes found, but requested to be exported. Will skip this geometry "
+#~ "type."
+#~ msgstr ""
 #~ msgid "Key column '%s' not found"
 #~ msgstr "Coluna chave '%s' não encontrada"
@@ -35503,7 +37455,9 @@
 #, fuzzy
 #~ msgid "Create a new vector map layer by combining other vector map layers."
-#~ msgstr "Converte um mapa vetorial binário do GRASS pela combinação de outros camadas de mapa vetorial."
+#~ msgstr ""
+#~ "Converte um mapa vetorial binário do GRASS pela combinação de outros "
+#~ "camadas de mapa vetorial."
 #, fuzzy
 #~ msgid "Patching vector map <%s@%s>..."
@@ -35530,8 +37484,12 @@
 #~ msgstr "Arquivo vetorial para criar"
 #, fuzzy
-#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
-#~ msgstr "Cria um buffer ao redor de feições de um determinado tipo (áreas devem conter centróide)"
+#~ msgid ""
+#~ "Creates a buffer around features of given type (areas must contain "
+#~ "centroid)."
+#~ msgstr ""
+#~ "Cria um buffer ao redor de feições de um determinado tipo (áreas devem "
+#~ "conter centróide)"
 #~ msgid "Buffer distance in map units"
 #~ msgstr "Distância do buffer (em unidades do mapa)"
@@ -35562,7 +37520,9 @@
 #, fuzzy
 #~ msgid "If not given reads from standard input"
-#~ msgstr "Arquivo ASCII para converter para vetor binário, se não for dado, lê da entrada padrão"
+#~ msgstr ""
+#~ "Arquivo ASCII para converter para vetor binário, se não for dado, lê da "
+#~ "entrada padrão"
 #, fuzzy
 #~ msgid "Type: %s"
@@ -35576,11 +37536,17 @@
 #~ msgstr "Suprimir impressão dos resíduos e outras informações"
 #, fuzzy
-#~ msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
-#~ msgstr "Usar opções de transformação (xshift, yshift, zshift, xscale, yscale, zscale, zrot) ao invés dos pontos"
+#~ msgid ""
+#~ "Instead of points use transformation parameters (xshift, yshift, zshift, "
+#~ "xscale, yscale, zscale, zrot)"
+#~ msgstr ""
+#~ "Usar opções de transformação (xshift, yshift, zshift, xscale, yscale, "
+#~ "zscale, zrot) ao invés dos pontos"
 #, fuzzy
-#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+#~ msgid ""
+#~ "The '%c' flag is deprecated and will be removed in future. Please use '--"
+#~ "quiet' instead."
 #~ msgstr "O vetor '%s' já existe."
 #, fuzzy
@@ -35633,8 +37599,12 @@
 #~ msgstr "Mostrar informação topológica (depuração)"
 #, fuzzy
-#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
-#~ msgstr "Calcula estatísticas univariadas para atributo. Variância e desvio padrão é calculado apenas para pontos se especificado."
+#~ msgid ""
+#~ "Calculates univariate statistics for attribute. Variance and standard "
+#~ "deviation is calculated only for points if specified."
+#~ msgstr ""
+#~ "Calcula estatísticas univariadas para atributo. Variância e desvio padrão "
+#~ "é calculado apenas para pontos se especificado."
 #~ msgid "Column name"
 #~ msgstr "Nome da coluna"
@@ -35719,11 +37689,15 @@
 #, fuzzy
 #~ msgid "Creates a vector map from ASCII points file or ASCII vector file."
+#~ msgstr ""
 #, fuzzy
 #~ msgid "ASCII file to be imported, if not given reads from standard input"
+#~ msgstr ""
 #, fuzzy
 #~ msgid "vector, external, import"
@@ -35731,14 +37705,19 @@
 #, fuzzy
 #~ msgid "Creates a new vector as a read-only link to OGR layer."
+#~ msgstr ""
 #, fuzzy
 #~ msgid "Output vector. If not given, available layers are printed only."
-#~ msgstr "Vetor de saída, se não for fornecido, camadas disponíveis serão apenas mostradas"
+#~ msgstr ""
+#~ "Vetor de saída, se não for fornecido, camadas disponíveis serão apenas "
+#~ "mostradas"
 #~ msgid ""
-#~ "OGR layer name. If not given, available layers are printed only. Examples:\n"
+#~ "OGR layer name. If not given, available layers are printed only. "
+#~ "Examples:\n"
 #~ "\t\tESRI Shapefile: shapefile name\n"
 #~ "\t\tMapInfo File: mapinfo file name"
 #~ msgstr ""
@@ -35754,8 +37733,11 @@
 #~ msgid "Cannot open data source"
 #~ msgstr "Não consegui abrir a fonte dos dados: %s"
-#~ msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-#~ msgstr "Tolerância em unidades de mapa, um valor para cada ferramenta (padrão: 0.0[,0.0,...])"
+#~ msgid ""
+#~ "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+#~ msgstr ""
+#~ "Tolerância em unidades de mapa, um valor para cada ferramenta (padrão: 0.0"
+#~ "[,0.0,...])"
 #, fuzzy
 #~ msgid "Copying vector lines..."
@@ -35767,11 +37749,14 @@
 #, fuzzy
 #~ msgid "If set to 0, z coordinates are used (3D vector only)"
-#~ msgstr "Valor do campo. Se definido em 0, coordenadas z serão usadas. (vetor 3D apenas)"
+#~ msgstr ""
+#~ "Valor do campo. Se definido em 0, coordenadas z serão usadas. (vetor 3D "
+#~ "apenas)"
 #, fuzzy
 #~ msgid "Attribute table column with values to interpolate"
+#~ msgstr ""
 #, fuzzy
 #~ msgid "No data points found"
@@ -35795,7 +37780,8 @@
 #~ msgstr "Encontrando classes de treinamento..."
 #~ msgid "The tolerance was reset to %g (map units). [category %d]"
-#~ msgstr "A tolerância foi ajustada para %g (unidades de mapa). [categoria %d]"
+#~ msgstr ""
+#~ "A tolerância foi ajustada para %g (unidades de mapa). [categoria %d]"
 #, fuzzy
 #~ msgid "Areas buffers... "
@@ -35830,13 +37816,18 @@
 #, fuzzy
 #~ msgid "Outputs basic information about a user-specified vector map."
-#~ msgstr "Imprime informações básicas sobre um mapa vetorial especificada pelo usuário."
+#~ msgstr ""
+#~ "Imprime informações básicas sobre um mapa vetorial especificada pelo "
+#~ "usuário."
 #~ msgid "Print vector history instead of info"
 #~ msgstr "Imprime histórico do vetor ao invés de informações"
-#~ msgid "Print types/names of table columns for specified layer instead of info"
-#~ msgstr "Mostra tipos/nomes das colunas da tabela para a camada especificada ao invés da info"
+#~ msgid ""
+#~ "Print types/names of table columns for specified layer instead of info"
+#~ msgstr ""
+#~ "Mostra tipos/nomes das colunas da tabela para a camada especificada ao "
+#~ "invés da info"
 #, fuzzy
 #~ msgid "Print topology information only"
@@ -35907,7 +37898,9 @@
 #, fuzzy
 #~ msgid "Use z-coordinates (3D vector only)"
+#~ msgstr ""
+#~ "apenas)"
 #, fuzzy
 #~ msgid "Output surface raster map (elevation)"
@@ -35941,11 +37934,15 @@
 #~ msgstr "Saída de vetor mostrando segmentos sobrepostos"
 #, fuzzy
-#~ msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
-#~ msgstr "Nome da coluna de atributos com valores para interpolar (se >0 camada)"
+#~ msgid ""
+#~ "Name of the attribute column with values to be used for approximation (if "
+#~ "layer>0)"
+#~ msgstr ""
+#~ "Nome da coluna de atributos com valores para interpolar (se >0 camada)"
 #~ msgid "Cannot write raster maps -- try to increase resolution"
-#~ msgstr "Não consegui escrever arquivo de células -- tente aumentar a resolução"
+#~ msgstr ""
+#~ "Não consegui escrever arquivo de células -- tente aumentar a resolução"
 #, fuzzy
 #~ msgid "vector, editing, digitization"
@@ -35961,7 +37958,9 @@
 #~ msgstr "Novo mapa vazio foi criado."
 #, fuzzy
-#~ msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+#~ msgid ""
+#~ "Map <%s> does not exist in current mapset. Add flag -n to create a new "
+#~ "map."
 #~ msgstr "Mapa não existe. Adicione a opção -n para criar um novo mapa"
 #, fuzzy
@@ -36036,20 +38035,33 @@
 #~ msgstr "Impossível ler o arquivo de cabeçalho de [%s]"
 #, fuzzy
-#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
+#~ msgid ""
+#~ "List paper formats ( name width height left right top bottom(margin) )"
 #~ msgstr "Formatos de papel (nome larg. altura esq. dir. cima baixo(margem) )"
-#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
-#~ msgstr "Arquivo contendo instruções de mapeamento (ou use 'input=-' para entrar do teclado)"
+#~ msgid ""
+#~ "File containing mapping instructions (or use input=- to enter from "
+#~ "keyboard)"
+#~ msgstr ""
+#~ "Arquivo contendo instruções de mapeamento (ou use 'input=-' para entrar "
+#~ "do teclado)"
 #~ msgid "PostScript output file"
 #~ msgstr "Arquivo de saída PostScript"
-#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr "Escala de saída do mapa, p.ex.: 1:25000 (padrão: Auto-ajuste para página)"
+#~ msgid ""
+#~ "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
+#~ msgstr ""
+#~ "Escala de saída do mapa, p.ex.: 1:25000 (padrão: Auto-ajuste para página)"
-#~ msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
-#~ msgstr "Usar <%s> na linha de comando é obsoleto. Ao invés disto, por favor use a instrução de mapeamento <%s>. O parâmetro <%s> será removido em versões futuras do GRASS."
+#~ msgid ""
+#~ "Using <%s> from the command line is depreciated. Please use the <%s> "
+#~ "mapping instruction instead. The parameter <%s> will be removed in future "
+#~ "versions of GRASS."
+#~ msgstr ""
+#~ "Usar <%s> na linha de comando é obsoleto. Ao invés disto, por favor use a "
+#~ "instrução de mapeamento <%s>. O parâmetro <%s> será removido em versões "
+#~ "futuras do GRASS."
 #~ msgid "Current region cannot be set."
 #~ msgstr "Região atual não pode ser ajustada."
@@ -36090,8 +38102,12 @@
 #~ msgstr "Nome do banco de dados"
 #, fuzzy
-#~ msgid "Do not use this option if schemas are not supported by driver/database server"
-#~ msgstr "Esquema do banco de dados. Não use essa opção se esquemas não forem suportados pelo driver/servidor de banco de dados"
+#~ msgid ""
+#~ "Do not use this option if schemas are not supported by driver/database "
+#~ "server"
+#~ msgstr ""
+#~ "Esquema do banco de dados. Não use essa opção se esquemas não forem "
+#~ "suportados pelo driver/servidor de banco de dados"
 #, fuzzy
 #~ msgid "database, SQL"
@@ -36116,7 +38132,9 @@
 #~ msgstr "A senha foi arquivada"
 #, fuzzy
-#~ msgid "Divides active display into two frames & displays maps/executes commands in each frame."
+#~ msgid ""
+#~ "Divides active display into two frames & displays maps/executes commands "
+#~ "in each frame."
 #~ msgstr "Divide exibir em."
 #, fuzzy
@@ -36156,7 +38174,9 @@
 #~ msgstr "Problema na leitura da saída r.stats"
 #, fuzzy
-#~ msgid "Creation option to the output format driver. Multiple options may be listed"
+#~ msgid ""
+#~ "Creation option to the output format driver. Multiple options may be "
+#~ "listed"
 #~ msgstr "para Múltipla"
 #, fuzzy
@@ -36185,7 +38205,8 @@
 #, fuzzy
 #~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr "Exibe texto no quadro ativo do monitor gráfico usando a fonte selecionada."
+#~ msgstr ""
+#~ "Exibe texto no quadro ativo do monitor gráfico usando a fonte selecionada."
 #, fuzzy
 #~ msgid "display, export"
@@ -36304,7 +38325,9 @@
 #, fuzzy
-#~ msgid "Value to update the column with (varchar values have to be in single quotes, e.g. 'grass')"
+#~ msgid ""
+#~ "Value to update the column with (varchar values have to be in single "
+#~ "quotes, e.g. 'grass')"
 #~ msgstr "para para para em"
 #, fuzzy
@@ -36360,11 +38383,15 @@
 #, fuzzy
-#~ msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
+#~ msgid ""
+#~ "The database must be in form printed by v.db.connect -g, i.e. with "
+#~ "substituted variables"
 #~ msgstr "Nome de banco de dados banco de dados em substituído"
 #, fuzzy
-#~ msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+#~ msgid ""
+#~ "Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+#~ "using gdalwarp."
 #~ msgstr "em de"
 #, fuzzy
@@ -36372,7 +38399,9 @@
 #, fuzzy
-#~ msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
+#~ msgid ""
+#~ "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
+#~ "single band"
 #~ msgstr "faixa para Cilindro faixa"
 #, fuzzy
@@ -36428,7 +38457,9 @@
 #~ msgstr "Número de cópias"
 #, fuzzy
-#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+#~ msgid ""
+#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+#~ "vector map."
 #~ msgstr "mapear."
 #, fuzzy
@@ -36472,8 +38503,11 @@
 #, fuzzy
-#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
-#~ msgstr "Calcula estatísticas univariada das células não nulas de um mapa raster."
+#~ msgid ""
+#~ "Calculates univariate statistics from a raster map based on vector "
+#~ "polygons and uploads statistics to new attribute columns."
+#~ msgstr ""
+#~ "Calcula estatísticas univariada das células não nulas de um mapa raster."
 #, fuzzy
 #~ msgid "vector, raster, statistics"
@@ -36517,7 +38551,8 @@
 #, fuzzy
 #~ msgid "calculates univariate statistics from a GRASS raster map"
+#~ msgstr ""
 #, fuzzy
 #~ msgid "Percentile to calculate (requires -e flag)"
@@ -36560,7 +38595,9 @@
 #~ msgstr "Altura em de exibir"
 #, fuzzy
-#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+#~ msgid ""
+#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+#~ "file into a vector map."
 #~ msgstr "Baixa mapear."
 #, fuzzy
@@ -36588,7 +38625,9 @@
 #~ msgstr "de"
 #, fuzzy
-#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+#~ msgid ""
+#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
+#~ "assumed"
 #~ msgstr "de não é para"
 #, fuzzy
@@ -36788,13 +38827,17 @@
 #~ msgstr "Nome do grupo de imagens"
 #, fuzzy
-#~ msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+#~ msgid ""
+#~ "Unable to open real-image in the 'cell_misc' directory. Raster map "
+#~ "probably wasn't created by i.fft"
 #~ msgstr ""
 #~ "Impossível abrir imagem real do diretório cell_misc.\n"
 #~ "Mapa de entrada provavelmente não foi criado por i.fft"
 #, fuzzy
-#~ msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+#~ msgid ""
+#~ "Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
 #~ msgstr ""
 #~ "Impossível abrir mapa imaginário no diretório cell_misc.\n"
@@ -36849,7 +38892,8 @@
 #~ msgstr "Grupo <%s> não encontrado."
 #, fuzzy
-#~ msgid "Interactively select and modify the imagery group camera reference file."
+#~ msgid ""
+#~ "Interactively select and modify the imagery group camera reference file."
 #~ msgstr "Selecionar trajeto interativamente"
 #, fuzzy
@@ -36981,11 +39025,13 @@
 #~ msgstr "Marque os pontos de controle no solo para retificar a imagem."
 #, fuzzy
-#~ msgid "Name of image to be rectified which will be initially drawn on screen"
+#~ msgid ""
+#~ "Name of image to be rectified which will be initially drawn on screen"
 #~ msgstr "Nome da imagem a retificar que será inicialmente exibida na tela."
 #, fuzzy
-#~ msgid "Name of a map from target mapset which will be initially drawn on screen"
+#~ msgid ""
+#~ "Name of a map from target mapset which will be initially drawn on screen"
 #~ msgstr "Nome de mapear destino ativo."
 #, fuzzy
@@ -37125,7 +39171,8 @@
 #, fuzzy
 #~ msgid "Unable to read cell header for first band file"
-#~ msgstr "Não consegui ler cabeçalho de células para o primeiro arquivo de banda."
+#~ msgstr ""
+#~ "Não consegui ler cabeçalho de células para o primeiro arquivo de banda."
 #~ msgid "Unable to open band files."
 #~ msgstr "Não consegui abrir os arquivos das bandas."
@@ -37149,7 +39196,8 @@
 #~ msgstr "Estados da condição de fronteira, 0-inativo, 1-ativo, 2-dirichlet"
 #~ msgid "%d boundaries were deleted, input areas are not preserved"
-#~ msgstr "%d fronteiras foram apagadas, áreas de entrada não foram preservadas"
+#~ msgstr ""
+#~ "%d fronteiras foram apagadas, áreas de entrada não foram preservadas"
 #~ msgid "Skipping all boundaries that are not part of an area."
 #~ msgstr "Pulando todas as fronteiras que não são parte de uma área."
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_ru.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_ru\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2009-05-15 00:23-0600\n"
 "Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
 "Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -254,13 +254,14 @@
 #: ../raster3d/r3.in.ascii/main.c:242 ../raster/r.in.poly/main.c:30
 #: ../raster/r.in.gdal/main.c:82 ../raster/r.in.bin/main.c:236
 #: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.png/main.c:522
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.external/main.c:524
-#: ../raster/r.in.ascii/main.c:70 ../raster/r.in.mat/main.c:92
-#: ../raster/r.in.arc/main.c:61 ../vector/v.in.ogr/main.c:106
-#: ../vector/v.in.db/main.c:53 ../vector/v.in.sites/main.c:58
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.convert/main.c:37 ../vector/v.in.lidar/main.c:148
-#: ../vector/v.in.ascii/main.c:49 ../vector/v.external/main.c:49
+#: ../raster/r.in.lidar/main.c:162 ../raster/r.in.xyz/main.c:161
+#: ../raster/r.external/main.c:524 ../raster/r.in.ascii/main.c:70
+#: ../raster/r.in.mat/main.c:92 ../raster/r.in.arc/main.c:61
+#: ../vector/v.in.ogr/main.c:106 ../vector/v.in.db/main.c:53
+#: ../vector/v.in.sites/main.c:58 ../vector/v.in.dxf/main.c:65
+#: ../vector/v.in.dwg/main.c:83 ../vector/v.convert/main.c:37
+#: ../vector/v.in.lidar/main.c:154 ../vector/v.in.ascii/main.c:49
+#: ../vector/v.external/main.c:49
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:3
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:3
 #: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
@@ -360,18 +361,18 @@
 #: ../raster/r.info/main.c:70 ../raster/r.surf.area/main.c:88
 #: ../raster/r.surf.fractal/main.c:38 ../raster/r.covar/main.c:51
 #: ../raster/r.statistics3/main.c:389 ../raster/r.rescale/main.c:48
-#: ../raster/r.solute.transport/main.c:229 ../raster/r.proj/main.c:146
-#: ../raster/r.out.mpeg/main.c:102 ../raster/r.fill.dir/main.c:85
-#: ../raster/r.resamp.interp/main.c:76 ../raster/r.univar/r.univar_main.c:96
-#: ../raster/r.cross/main.c:73 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.category/main.c:52 ../raster/r.clump/main.c:46
-#: ../raster/r.out.tiff/main.c:91 ../raster/r.in.xyz/main.c:160
-#: ../raster/r.texture/main.c:75 ../raster/r.surf.random/main.c:36
-#: ../raster/r.out.arc/main.c:60 ../raster/r.surf.contour/main.c:60
-#: ../raster/r.colors/main.c:168 ../raster/r.statistics/main.c:55
-#: ../raster/r.li/r.li.padcv/padcv.c:39 ../raster/r.li/r.li.mpa/mpa.c:41
-#: ../raster/r.li/r.li.patchnum/main.c:36 ../raster/r.li/r.li.mps/mps.c:42
-#: ../raster/r.li/r.li.pielou/pielou.c:58
+#: ../raster/r.solute.transport/main.c:229 ../raster/r.in.lidar/main.c:161
+#: ../raster/r.proj/main.c:146 ../raster/r.out.mpeg/main.c:102
+#: ../raster/r.fill.dir/main.c:85 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.univar/r.univar_main.c:96 ../raster/r.cross/main.c:73
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.category/main.c:52
+#: ../raster/r.clump/main.c:46 ../raster/r.out.tiff/main.c:91
+#: ../raster/r.in.xyz/main.c:160 ../raster/r.texture/main.c:75
+#: ../raster/r.surf.random/main.c:36 ../raster/r.out.arc/main.c:60
+#: ../raster/r.surf.contour/main.c:60 ../raster/r.colors/main.c:168
+#: ../raster/r.statistics/main.c:55 ../raster/r.li/r.li.padcv/padcv.c:39
+#: ../raster/r.li/r.li.mpa/mpa.c:41 ../raster/r.li/r.li.patchnum/main.c:36
+#: ../raster/r.li/r.li.mps/mps.c:42 ../raster/r.li/r.li.pielou/pielou.c:58
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:40
 #: ../raster/r.li/r.li.cwed/cwed.c:48 ../raster/r.li/r.li.padsd/padsd.c:39
 #: ../raster/r.li/r.li.richness/richness.c:41
@@ -426,6 +427,7 @@
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:2
 #: ../locale/scriptstrings/r.grow_to_translate.c:2
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:2
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
 #: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:2
@@ -1677,7 +1679,8 @@
 msgid "Illegal east coordinate <%s>, skipping."
 msgstr "Неверная восточная координата <%s>"
-#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
+#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.lidar/main.c:591
+#: ../raster/r.in.xyz/main.c:531
 #, c-format
 msgid "Pass #%d (of %d) ..."
 msgstr "Проход #%d (из %d) ..."
@@ -1731,7 +1734,7 @@
 #: ../vector/v.what/main.c:54 ../vector/v.transform/main.c:82
 #: ../vector/v.overlay/main.c:58 ../vector/v.class/main.c:44
 #: ../vector/v.build.polylines/main.c:113 ../vector/v.convert/main.c:36
-#: ../vector/v.in.lidar/main.c:147 ../vector/v.net.flow/main.c:58
+#: ../vector/v.in.lidar/main.c:153 ../vector/v.net.flow/main.c:58
 #: ../vector/v.segment/main.c:54 ../vector/v.normal/main.c:74
 #: ../vector/v.net.path/main.c:40 ../vector/v.univar/main.c:63
 #: ../vector/v.label/main.c:59 ../vector/v.to.rast/main.c:40
@@ -1855,7 +1858,7 @@
 #: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
 #: ../vector/v.net.allpairs/main.c:151 ../vector/v.in.dwg/main.c:237
 #: ../vector/v.net.timetable/main.c:103 ../vector/v.overlay/main.c:462
-#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:565
+#: ../vector/v.convert/att.c:81 ../vector/v.in.lidar/main.c:596
 #: ../vector/v.net.flow/main.c:170 ../vector/v.net.path/path.c:109
 #: ../vector/v.to.points/main.c:293 ../vector/v.surf.rst/main.c:579
 #: ../vector/v.net.centrality/main.c:242 ../vector/v.net.components/main.c:149
@@ -1866,7 +1869,7 @@
 #: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:796
 #: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
 #: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
-#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:570
+#: ../vector/v.convert/att.c:86 ../vector/v.in.lidar/main.c:601
 #: ../vector/v.to.points/main.c:298 ../vector/v.in.ascii/main.c:504
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
@@ -1878,7 +1881,7 @@
 #: ../vector/v.random/main.c:199 ../vector/v.in.dxf/write_vect.c:237
 #: ../vector/v.mkgrid/main.c:251 ../vector/v.reclass/main.c:232
 #: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:472
-#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:576
+#: ../vector/v.convert/att.c:91 ../vector/v.in.lidar/main.c:607
 #: ../vector/v.to.points/main.c:304 ../vector/v.in.ascii/main.c:394
 #, c-format
 msgid "Unable to grant privileges on table <%s>"
@@ -2364,7 +2367,7 @@
 "Стоимость назначенная null-ячейкам. По умолчанию, null-ячейки исключаются"
 #: ../raster/r.walk/main.c:274 ../raster/r.cost/main.c:229
-#: ../raster/r.in.xyz/main.c:238
+#: ../raster/r.in.lidar/main.c:211 ../raster/r.in.xyz/main.c:238
 msgid "Percent of map to keep in memory"
 msgstr "Процент карты сохраняемый в памяти"
@@ -2601,7 +2604,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:181
-#: ../vector/v.in.lidar/main.c:172
+#: ../vector/v.in.lidar/main.c:178
 msgid "Name for new location to create"
 msgstr "Название для создаваемой области"
@@ -2610,7 +2613,7 @@
 msgstr "Игнорировать проекцию (использовать проекцию области)"
 #: ../raster/r.in.gdal/main.c:144 ../raster/r.external/main.c:562
-#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:199
+#: ../vector/v.in.ogr/main.c:232 ../vector/v.in.lidar/main.c:213
 msgid "Extend location extents based on new dataset"
 msgstr "Расширить охват области на основе нового набора данных"
@@ -2685,7 +2688,7 @@
 msgstr ""
 #: ../raster/r.in.gdal/main.c:335 ../vector/v.in.ogr/main.c:480
-#: ../vector/v.in.lidar/main.c:320
+#: ../vector/v.in.lidar/main.c:351
 msgid ""
 "location."
@@ -2694,7 +2697,7 @@
 "создать новую область."
 #: ../raster/r.in.gdal/main.c:341 ../vector/v.in.ogr/main.c:486
-#: ../vector/v.in.lidar/main.c:326
+#: ../vector/v.in.lidar/main.c:357
 #, c-format
 msgid "Location <%s> created"
 msgstr "Область <%s> создана"
@@ -2707,13 +2710,15 @@
 "Невозможно конвертировать информацию о проекции исходного растрового слоя в "
 "формат GRASS для проверки"
-#: ../raster/r.in.gdal/main.c:370 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:516 ../vector/v.in.lidar/main.c:359
+#: ../raster/r.in.gdal/main.c:370 ../raster/r.in.lidar/main.c:296
+#: ../raster/r.external/main.c:105 ../vector/v.in.ogr/main.c:516
+#: ../vector/v.in.lidar/main.c:390
 msgid "Over-riding projection check"
 msgstr "Игнорирование проверки проекции"
-#: ../raster/r.in.gdal/main.c:381 ../raster/r.external/main.c:113
-#: ../vector/v.in.ogr/main.c:525 ../vector/v.in.lidar/main.c:368
+#: ../raster/r.in.gdal/main.c:381 ../raster/r.in.lidar/main.c:305
+#: ../raster/r.external/main.c:113 ../vector/v.in.ogr/main.c:525
+#: ../vector/v.in.lidar/main.c:399
 msgid ""
 "Projection of dataset does not appear to match current location.\n"
 "\n"
@@ -2729,9 +2734,10 @@
 msgid "Dataset PROJ_INFO is:\n"
 msgstr "Набор данных PROJ_INFO:\n"
-#: ../raster/r.in.gdal/main.c:424 ../raster/r.external/main.c:156
+#: ../raster/r.in.gdal/main.c:424 ../raster/r.in.lidar/main.c:321
+#: ../raster/r.in.lidar/main.c:328 ../raster/r.external/main.c:156
 #: ../vector/v.in.ogr/main.c:541 ../vector/v.in.ogr/main.c:548
-#: ../vector/v.in.lidar/main.c:384 ../vector/v.in.lidar/main.c:391
+#: ../vector/v.in.lidar/main.c:415 ../vector/v.in.lidar/main.c:422
 msgid "Import dataset PROJ_INFO is:\n"
 msgstr "Импорт набора данных PROJ_INFO:\n"
@@ -2753,8 +2759,9 @@
 "Учитывать параметр 'location' при генерации новой области из исходного "
 "набора данных.\n"
-#: ../raster/r.in.gdal/main.c:454 ../raster/r.external/main.c:186
-#: ../vector/v.in.ogr/main.c:599 ../vector/v.in.lidar/main.c:442
+#: ../raster/r.in.gdal/main.c:454 ../raster/r.in.lidar/main.c:379
+#: ../raster/r.external/main.c:186 ../vector/v.in.ogr/main.c:599
+#: ../vector/v.in.lidar/main.c:473
 msgid "Projection of input dataset and current location appear to match"
 msgstr "Проекция исходного набора данных и текущей области совпадают"
@@ -6908,7 +6915,7 @@
 msgid "SECTION 1a (of %1d): Initiating Memory."
 msgstr "СЕКЦИЯ 1a (из %1d): Инициализация памяти."
-#: ../raster/r.watershed/ram/init_vars.c:296
+#: ../raster/r.watershed/ram/init_vars.c:300
 #, c-format
 msgid "SECTION 1b (of %1d): Determining Offmap Flow."
 msgstr "СЕКЦИЯ 1b (из %1d): Определение потока вне слоя."
@@ -7945,6 +7952,157 @@
 msgid "Could not create and solve the linear equation system"
 msgstr "Невозможно создать и решить систему линейных уравнений"
+#: ../raster/r.in.lidar/main.c:163 ../raster/r.in.xyz/main.c:162
+#: ../vector/v.surf.bspline/main.c:93
+#: ../vector/v.lidar.edgedetection/main.c:73
+#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
+msgid "LIDAR"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:165
+#, fuzzy
+msgid "Create a raster map from LAS LiDAR points using univariate statistics."
+msgstr ""
+"Создать растровый слой из набор координат используя одномерную статистику."
+#: ../raster/r.in.lidar/main.c:169
+#, fuzzy
+msgid "LiDAR LAS input file"
+msgstr "Ввод прерван"
+#: ../raster/r.in.lidar/main.c:177 ../raster/r.in.xyz/main.c:176
+msgid "Statistic to use for raster values"
+msgstr "Статистика используемая для растровых значений"
+#: ../raster/r.in.lidar/main.c:181 ../raster/r.in.lidar/main.c:221
+#: ../raster/r.in.lidar/main.c:230 ../raster/r.in.xyz/main.c:180
+#: ../raster/r.in.xyz/main.c:248 ../raster/r.in.xyz/main.c:257
+msgid "Statistic"
+msgstr "Статистика"
+#: ../raster/r.in.lidar/main.c:189 ../raster/r.in.xyz/main.c:188
+#: ../raster/r.in.arc/main.c:81
+msgid "Storage type for resultant raster map"
+msgstr "Тип данных для выходного растрового слоя"
+#: ../raster/r.in.lidar/main.c:196 ../raster/r.in.xyz/main.c:223
+msgid "Filter range for z data (min,max)"
+msgstr "Диапазон фильтра для данных z (минимум,максимум)"
+#: ../raster/r.in.lidar/main.c:203 ../raster/r.in.xyz/main.c:230
+msgid "Scale to apply to z data"
+msgstr "Масштаб применяемый для данных z"
+#: ../raster/r.in.lidar/main.c:220 ../raster/r.in.xyz/main.c:247
+msgid "pth percentile of the values"
+msgstr "p-тый перцентиль значений"
+#: ../raster/r.in.lidar/main.c:229 ../raster/r.in.xyz/main.c:256
+msgid ""
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
+msgstr ""
+"Удалить <trim> процент наименьших и <trim> процент наибольших наблюдений"
+#: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:222
+#: ../vector/v.in.lidar/main.c:203
+msgid "Override dataset projection (use location's projection)"
+msgstr ""
+"Использовать другую проекцию для набора данных (использовать проекцию "
+"области)"
+#: ../raster/r.in.lidar/main.c:239 ../raster/r.in.xyz/main.c:261
+msgid "Scan data file for extent then exit"
+msgstr "Сканировать файл данных для определения охвата и выйти"
+#: ../raster/r.in.lidar/main.c:244 ../raster/r.in.xyz/main.c:266
+msgid "In scan mode, print using shell script style"
+msgstr "В режиме сканирования, выводить используя стиль скриптовой оболочки"
+#: ../raster/r.in.lidar/main.c:263 ../vector/v.in.lidar/main.c:238
+#, c-format
+msgid "Input file <%s> is not a LAS LiDAR point cloud"
+msgstr ""
+#: ../raster/r.in.lidar/main.c:281 ../vector/v.in.ogr/main.c:501
+#: ../vector/v.in.lidar/main.c:372
+msgid ""
+"Unable to convert input map projection information to GRASS format for "
+"checking"
+msgstr ""
+"Невозможно конвертировать информацию о проекции исходного слоя в формат "
+"GRASS для проверки"
+#: ../raster/r.in.lidar/main.c:311 ../vector/v.in.ogr/main.c:531
+#: ../vector/v.in.lidar/main.c:405
+msgid "GRASS LOCATION PROJ_INFO is:\n"
+msgstr "GRASS LOCATION PROJ_INFO:\n"
+#: ../raster/r.in.lidar/main.c:371 ../vector/v.in.ogr/main.c:591
+#: ../vector/v.in.lidar/main.c:465
+#, c-format
+msgid ""
+"\n"
+"You can use the -o flag to %s to override this projection check.\n"
+msgstr ""
+"\n"
+"Вы можете использовать параметр -o для %s, чтобы отменить использование "
+"проверки проекции.\n"
+#: ../raster/r.in.lidar/main.c:374 ../vector/v.in.ogr/main.c:594
+#: ../vector/v.in.lidar/main.c:468
+msgid ""
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
+msgstr ""
+"Рассмотреть создание новой области с параметром 'location' из исходного "
+"набора данных.\n"
+#: ../raster/r.in.lidar/main.c:391 ../raster/r.in.xyz/main.c:307
+#, fuzzy
+msgid "Invalid zrange"
+msgstr "неверное значение смещения на восток"
+#: ../raster/r.in.lidar/main.c:485 ../raster/r.in.xyz/main.c:394
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr "Невозможно вычислить персентиль без заданной опции pth!"
+#: ../raster/r.in.lidar/main.c:497 ../raster/r.in.xyz/main.c:406
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr "Невозможно вычислить укороченное среднее без заданной опции trim!"
+#: ../raster/r.in.lidar/main.c:560 ../raster/r.in.xyz/main.c:488
+msgid "zrange will not be taken into account during scan"
+msgstr "zrange при сканировании учитываться не будет"
+#: ../raster/r.in.lidar/main.c:579 ../raster/r.in.xyz/main.c:524
+#, fuzzy
+msgid "Reading data ..."
+msgstr "Чтение данных..."
+#: ../raster/r.in.lidar/main.c:596
+#, fuzzy
+msgid "Could not rewind input file"
+msgstr "Невозможно открыть выходной файл <%s>"
+#: ../raster/r.in.lidar/main.c:757 ../raster/r.in.xyz/main.c:721
+msgid "Writing to map ..."
+msgstr "Запись слоя ..."
+#: ../raster/r.in.lidar/main.c:1103 ../raster/r.in.xyz/main.c:1059
+#, c-format
+msgid "%lu points found in region."
+msgstr "%lu точек найдено в регионе."
+#: ../raster/r.in.lidar/main.c:1127 ../raster/r.in.xyz/main.c:1086
+msgid "Scanning data ..."
+msgstr "Сканирование данных ..."
+#: ../raster/r.in.lidar/main.c:1178 ../raster/r.in.xyz/main.c:1174
+#, c-format
+msgid "Range:     min         max\n"
+msgstr "Диапазон:     минимум         максимум\n"
 #: ../raster/r.proj/main.c:147 ../general/g.proj/main.c:61
 #: ../general/g.setproj/main.c:79 ../vector/v.proj/main.c:64
 #: ../locale/scriptstrings/m.proj_to_translate.c:3
@@ -8806,12 +8964,6 @@
 msgid "Unable to open TIFF world file for writing"
 msgstr "Невозможно открыть для записи world файл TIFF"
-#: ../raster/r.in.xyz/main.c:162 ../vector/v.surf.bspline/main.c:93
-#: ../vector/v.lidar.edgedetection/main.c:73
-#: ../vector/v.lidar.growing/main.c:76 ../vector/v.lidar.correction/main.c:69
-msgid "LIDAR"
-msgstr ""
 #: ../raster/r.in.xyz/main.c:164
 msgid ""
 "Create a raster map from an assemblage of many coordinates using univariate "
@@ -8823,19 +8975,6 @@
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
 msgstr "ASCII файл содержащий исходные данные (или \"-\" для чтения из stdin)"
-#: ../raster/r.in.xyz/main.c:176
-msgid "Statistic to use for raster values"
-msgstr "Статистика используемая для растровых значений"
-#: ../raster/r.in.xyz/main.c:180 ../raster/r.in.xyz/main.c:248
-#: ../raster/r.in.xyz/main.c:257
-msgid "Statistic"
-msgstr "Статистика"
-#: ../raster/r.in.xyz/main.c:188 ../raster/r.in.arc/main.c:81
-msgid "Storage type for resultant raster map"
-msgstr "Тип данных для выходного растрового слоя"
 #: ../raster/r.in.xyz/main.c:199
 msgid "Column number of x coordinates in input file (first column is 1)"
 msgstr "Номер столбца исходного файла для координат x (первый столбец - 1)"
@@ -8848,33 +8987,6 @@
 msgid "Column number of data values in input file"
 msgstr "Номер столбца содержащего данные в исходном файле"
-#: ../raster/r.in.xyz/main.c:223
-msgid "Filter range for z data (min,max)"
-msgstr "Диапазон фильтра для данных z (минимум,максимум)"
-#: ../raster/r.in.xyz/main.c:230
-msgid "Scale to apply to z data"
-msgstr "Масштаб применяемый для данных z"
-#: ../raster/r.in.xyz/main.c:247
-msgid "pth percentile of the values"
-msgstr "p-тый перцентиль значений"
-#: ../raster/r.in.xyz/main.c:256
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-"Удалить <trim> процент наименьших и <trim> процент наибольших наблюдений"
-#: ../raster/r.in.xyz/main.c:261
-msgid "Scan data file for extent then exit"
-msgstr "Сканировать файл данных для определения охвата и выйти"
-#: ../raster/r.in.xyz/main.c:266
-msgid "In scan mode, print using shell script style"
-msgstr "В режиме сканирования, выводить используя стиль скриптовой оболочки"
 #: ../raster/r.in.xyz/main.c:270
 msgid "Ignore broken lines"
 msgstr "Игнорировать неправильные линии"
@@ -8883,33 +8995,11 @@
 msgid "Please specify a reasonable column number."
 msgstr "Укажите правильный номер столбца."
-#: ../raster/r.in.xyz/main.c:307
-#, fuzzy
-msgid "Invalid zrange"
-msgstr "неверное значение смещения на восток"
-#: ../raster/r.in.xyz/main.c:394
-msgid "Unable to calculate percentile without the pth option specified!"
-msgstr "Невозможно вычислить персентиль без заданной опции pth!"
-#: ../raster/r.in.xyz/main.c:406
-msgid "Unable to calculate trimmed mean without the trim option specified!"
-msgstr "Невозможно вычислить укороченное среднее без заданной опции trim!"
 #: ../raster/r.in.xyz/main.c:482
 msgid ""
 "If input is not from a file it is only possible to perform a single pass."
 msgstr "Если исходные данные не из файла, возможен только один проход."
-#: ../raster/r.in.xyz/main.c:488
-msgid "zrange will not be taken into account during scan"
-msgstr "zrange при сканировании учитываться не будет"
-#: ../raster/r.in.xyz/main.c:524
-#, fuzzy
-msgid "Reading data ..."
-msgstr "Чтение данных..."
 #: ../raster/r.in.xyz/main.c:602 ../raster/r.in.xyz/main.c:610
 #: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
@@ -8941,24 +9031,6 @@
 msgid "Bad z-coordinate line %lu column %d. <%s>"
 msgstr "Неправильная строка %lu координаты z столбца %d. <%s>"
-#: ../raster/r.in.xyz/main.c:721
-msgid "Writing to map ..."
-msgstr "Запись слоя ..."
-#: ../raster/r.in.xyz/main.c:1059
-#, c-format
-msgid "%lu points found in region."
-msgstr "%lu точек найдено в регионе."
-#: ../raster/r.in.xyz/main.c:1086
-msgid "Scanning data ..."
-msgstr "Сканирование данных ..."
-#: ../raster/r.in.xyz/main.c:1174
-#, c-format
-msgid "Range:     min         max\n"
-msgstr "Диапазон:     минимум         максимум\n"
 #: ../raster/r.texture/main.c:79
 msgid "Generate images with textural features from a raster map."
 msgstr "Создание из растрового слоя изображений с текстурными объектами."
@@ -11109,7 +11181,7 @@
 #: ../raster/r.to.vect/main.c:97 ../raster/r.to.vect/main.c:104
 #: ../vector/v.in.ogr/main.c:192 ../vector/v.in.ogr/main.c:217
-#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:184
+#: ../vector/v.in.ogr/main.c:238 ../vector/v.in.lidar/main.c:198
 #: ../vector/v.to.rast/main.c:74 ../vector/v.to.rast/main.c:80
 #: ../vector/v.to.rast/main.c:86
 msgid "Attributes"
@@ -11162,7 +11234,7 @@
 #: ../raster/r.to.vect/util.c:157 ../raster/r.to.vect/areas_io.c:370
 #: ../vector/v.in.ogr/main.c:927 ../vector/v.random/main.c:294
-#: ../vector/v.in.lidar/main.c:696
+#: ../vector/v.in.lidar/main.c:755
 #, c-format
 msgid "Cannot insert new row: %s"
 msgstr "Невозможно вставить новый ряд: %s"
@@ -18011,8 +18083,7 @@
 msgstr "Невозможно выбрать атрибуты для cat=%d"
 #: ../vector/v.out.svg/main.c:370 ../vector/v.lrs/v.lrs.label/main.c:348
-#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.out.ogr/attrb.c:51
-#: ../vector/v.overlay/main.c:363
+#: ../vector/v.out.ogr/attrb.c:46 ../vector/v.overlay/main.c:363
 msgid "Unable to fetch data from table"
 msgstr "Невозможно выбрать данные из таблицы"
@@ -18517,16 +18588,16 @@
 "\t\tshape-файл ESRI: имя shape-файла\n"
 "\t\tФайл MapInfo: имя файла MapInfo"
-#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:163
+#: ../vector/v.in.ogr/main.c:138 ../vector/v.in.lidar/main.c:169
 msgid "Import subregion only"
 msgstr "Импортировать только субрегион"
 #: ../vector/v.in.ogr/main.c:139 ../vector/v.in.ogr/main.c:226
-#: ../vector/v.in.lidar/main.c:164 ../vector/v.in.lidar/main.c:193
+#: ../vector/v.in.lidar/main.c:170 ../vector/v.in.lidar/main.c:207
 msgid "Subregion"
 msgstr "Субрегион"
-#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:166
+#: ../vector/v.in.ogr/main.c:141 ../vector/v.in.lidar/main.c:172
 msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
 msgstr "Формат: xmin,ymin,xmax,ymax - обычно З,Ю,В,С"
@@ -18587,17 +18658,11 @@
 #: ../vector/v.in.ogr/main.c:216 ../vector/v.select/args.c:79
 #: ../vector/v.voronoi/main.c:138 ../vector/v.overlay/main.c:123
-#: ../vector/v.in.lidar/main.c:183 ../vector/v.to.points/main.c:215
+#: ../vector/v.in.lidar/main.c:197 ../vector/v.to.points/main.c:215
 msgid "Do not create attribute table"
 msgstr "Не создавать атрибутивную таблицу"
-#: ../vector/v.in.ogr/main.c:222 ../vector/v.in.lidar/main.c:189
-msgid "Override dataset projection (use location's projection)"
-msgstr ""
-"Использовать другую проекцию для набора данных (использовать проекцию "
-"области)"
-#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:194
+#: ../vector/v.in.ogr/main.c:227 ../vector/v.in.lidar/main.c:208
 msgid "Limit import to the current region"
 msgstr "Ограничить импорт текущим регионом"
@@ -18605,7 +18670,7 @@
 msgid "Change column names to lowercase characters"
 msgstr "Написать имена полей строчными буквами"
-#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:204
+#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.lidar/main.c:218
 msgid ""
 "Create the location specified by the \"location\" parameter and exit. Do not "
 "import the vector file."
@@ -18625,12 +18690,12 @@
 msgid "Data source contains %d layers:"
 msgstr "Источник данных содержит %d слоев:"
-#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:252
+#: ../vector/v.in.ogr/main.c:331 ../vector/v.in.lidar/main.c:272
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr "Векторный слой <%s> уже существует и будет перезаписан"
-#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:255
+#: ../vector/v.in.ogr/main.c:334 ../vector/v.in.lidar/main.c:275
 #: ../vector/v.edit/main.c:88
 #, c-format
 msgid "Vector map <%s> already exists"
@@ -18641,46 +18706,16 @@
 msgid "Layer <%s> not available"
 msgstr "Слой < %s > недоступен"
-#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:263
+#: ../vector/v.in.ogr/main.c:375 ../vector/v.in.lidar/main.c:294
 msgid "Select either the current region flag or the spatial option, not both"
 msgstr ""
 "Выбрать или параметр для текущего региона или пространственную опцию, но не "
 "оба одновременно"
-#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:291
+#: ../vector/v.in.ogr/main.c:403 ../vector/v.in.lidar/main.c:322
 msgid "4 parameters required for 'spatial' parameter"
 msgstr "4 параметра, требуемые для параметра 'spatial'"
-#: ../vector/v.in.ogr/main.c:501 ../vector/v.in.lidar/main.c:341
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"Невозможно конвертировать информацию о проекции исходного слоя в формат "
-"GRASS для проверки"
-#: ../vector/v.in.ogr/main.c:531 ../vector/v.in.lidar/main.c:374
-msgid "GRASS LOCATION PROJ_INFO is:\n"
-msgstr "GRASS LOCATION PROJ_INFO:\n"
-#: ../vector/v.in.ogr/main.c:591 ../vector/v.in.lidar/main.c:434
-#, c-format
-msgid ""
-"\n"
-"You can use the -o flag to %s to override this projection check.\n"
-msgstr ""
-"\n"
-"Вы можете использовать параметр -o для %s, чтобы отменить использование "
-"проверки проекции.\n"
-#: ../vector/v.in.ogr/main.c:594 ../vector/v.in.lidar/main.c:437
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Рассмотреть создание новой области с параметром 'location' из исходного "
-"набора данных.\n"
 #: ../vector/v.in.ogr/main.c:617
 #, fuzzy, c-format
 msgid "Using temporary vector <%s>"
@@ -18722,7 +18757,7 @@
 msgid "Column type not supported (%s)"
 msgstr "Тип поля не поддерживается (%s)"
-#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:558
+#: ../vector/v.in.ogr/main.c:784 ../vector/v.in.lidar/main.c:589
 #, c-format
 msgid "Unable open database <%s> by driver <%s>"
 msgstr "Невозможно открыть БД <%s> с помощью драйвера <%s>"
@@ -18773,27 +18808,27 @@
 msgstr "Очистить границы в узлах:"
 #: ../vector/v.in.ogr/main.c:1017
+#, fuzzy
+msgid "Merge boundaries:"
+msgstr "Разрыв границ:"
+#: ../vector/v.in.ogr/main.c:1022
 msgid "Change boundary dangles to lines:"
 msgstr "Преобразовать висячие границы в линии:"
-#: ../vector/v.in.ogr/main.c:1021
+#: ../vector/v.in.ogr/main.c:1026
 #, fuzzy
 msgid "Remove dangles:"
 msgstr "Удалить висящие узлы"
-#: ../vector/v.in.ogr/main.c:1027
+#: ../vector/v.in.ogr/main.c:1032
 msgid "Change boundary bridges to lines:"
 msgstr "Преобразовать мосты границ в линии:"
-#: ../vector/v.in.ogr/main.c:1031
+#: ../vector/v.in.ogr/main.c:1036
 msgid "Remove bridges:"
 msgstr "Удалить мосты:"
-#: ../vector/v.in.ogr/main.c:1037
-#, fuzzy
-msgid "Merge boundaries:"
-msgstr "Разрыв границ:"
 #: ../vector/v.in.ogr/main.c:1055 ../vector/v.overlay/area_area.c:68
 #: ../vector/v.buffer/main.c:607 ../vector/v.buffer/main.c:699
 msgid "Cannot calculate area centroid"
@@ -19716,7 +19751,7 @@
 msgstr "Используется функция drand48() вместо rand()"
 #: ../vector/v.random/main.c:142 ../vector/v.in.dxf/main.c:80
-#: ../vector/v.in.lidar/main.c:209 ../vector/v.external/args.c:53
+#: ../vector/v.in.lidar/main.c:223 ../vector/v.external/args.c:53
 #: ../vector/v.edit/args.c:216
 msgid "Do not build topology"
 msgstr "Не создавать топологию"
@@ -21594,7 +21629,7 @@
 msgid "Cannot select attributes for cat = %d"
-#: ../vector/v.out.ogr/attrb.c:64
+#: ../vector/v.out.ogr/attrb.c:58
 #, fuzzy, c-format
 msgid "No database record for cat = %d and export of 'cat' disabled"
 msgstr " "
@@ -23619,45 +23654,64 @@
 msgid "[%d] categories read into memory"
 msgstr "в память прочитано [%d] категорий "
-#: ../vector/v.in.lidar/main.c:149
+#: ../vector/v.in.lidar/main.c:155
 #, fuzzy
 msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
 msgstr "Конвертировать векторные слои OGR в векторные слои GRASS."
-#: ../vector/v.in.lidar/main.c:152
+#: ../vector/v.in.lidar/main.c:158
 #, fuzzy
 msgid "LAS input file"
-#: ../vector/v.in.lidar/main.c:153
+#: ../vector/v.in.lidar/main.c:159
 msgid "LiDAR input files in LAS format (*.las or *.laz)"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:178
+#: ../vector/v.in.lidar/main.c:185
+msgid "Only import points of selected return type"
+msgstr ""
+#: ../vector/v.in.lidar/main.c:186
 #, fuzzy
+msgid "If not specified, all points are imported"
+msgstr "Импортированы целочисленные значения"
+#: ../vector/v.in.lidar/main.c:192
+#, fuzzy
 msgid "Print LAS file info and exit"
 msgstr "Вывести историю растра вместо информации"
-#: ../vector/v.in.lidar/main.c:591
+#: ../vector/v.in.lidar/main.c:289
 #, fuzzy, c-format
+msgid "Unknown filter option <%s>"
+msgstr "Неизвестная опция правила: '%s'"
+#: ../vector/v.in.lidar/main.c:623
+#, fuzzy, c-format
 msgid "Importing %d points..."
 msgstr "Импорт точек... "
-#: ../vector/v.in.lidar/main.c:719
+#: ../vector/v.in.lidar/main.c:778
 #, fuzzy, c-format
 msgid "%d points imported"
 msgstr "Загружено %d точек"
-#: ../vector/v.in.lidar/main.c:721
+#: ../vector/v.in.lidar/main.c:780
 #, c-format
 msgid "%d input points were not valid"
 msgstr ""
-#: ../vector/v.in.lidar/main.c:723
+#: ../vector/v.in.lidar/main.c:782
 #, fuzzy, c-format
 msgid "%d input points were outside of the selected area"
 msgstr "%d точек вне порога"
+#: ../vector/v.in.lidar/main.c:784
+#, fuzzy, c-format
+msgid "%d input points were filtered by return number"
+msgstr "%d точек вне порога"
 #: ../vector/v.net.flow/main.c:60
 msgid "flow"
 msgstr ""
@@ -29599,6 +29653,46 @@
 msgid "Uncompressed geonames file from (with .txt extension)"
 msgstr "Несжатый файл geonames из (с расширением .txt)"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:1
+msgid "Download several tiles of MODIS products using pyModis"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:3
+#, fuzzy
+msgid "Name of MODIS product"
+msgstr "Имя исходного слоя"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:4
+msgid "Name of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:5
+msgid "Password of user to NASA ftp access, it's better use SETTING.py"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:6
+msgid "Folder where saves the data, full path"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:7
+#, fuzzy
+msgid "The names of tile/s to download"
+msgstr "Количество расставляемых точек"
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:8
+msgid "The day from start download. If not set the download starts from today"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:9
+msgid ""
+"The day to stop download. If not set the download stops 10 day before the "
+"start day"
+msgstr ""
+#: ../locale/scriptstrings/r.modis.download_to_translate.c:10
+msgid "For debug mode, it will write more info in the log file"
+msgstr ""
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
 msgid ""
 "Export a raster map to a text file as x,y,z values based on cell centers."
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_sl.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_sl\n"
 "PO-Revision-Date: 2005-06-10 11:15+0200\n"
 "Last-Translator: Miha Staut <mihastaut at yahoo.co.uk>\n"
 "Language-Team: Sloven¹èina <grass-translations at lists.osgeo.org>\n"
@@ -261,13 +261,14 @@
@@ -371,18 +372,18 @@
@@ -437,6 +438,7 @@
@@ -1681,7 +1683,8 @@
 msgstr "Koordinata za sever je prazna!"
 #, c-format
 msgstr ""
@@ -1736,7 +1739,7 @@
@@ -1865,7 +1868,7 @@
@@ -1876,7 +1879,7 @@
 #, fuzzy, c-format
@@ -1888,7 +1891,7 @@
 #, fuzzy, c-format
@@ -2380,7 +2383,7 @@
 "izkljuèene"
 msgstr "Dele¾ sloja, ki ga ohranjati v spominu raèunalnika"
@@ -2619,7 +2622,7 @@
 msgstr ""
 msgstr "Ime nove lokacije (location), ki bo ustvarjena"
@@ -2628,7 +2631,7 @@
 msgstr "Povozi projekcijo (uporabi projekcijo lokacije)"
 msgstr "Raz¹iri obseg lokacije glede na nov \"dataset\""
@@ -2696,14 +2699,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr ""
 #, fuzzy, c-format
 msgstr "ne morem odpreti %s"
@@ -2714,14 +2717,16 @@
 "for checking"
 msgstr ""
 #, fuzzy
 msgstr "Ne najdem vhodne datoteke %s\n"
 #, fuzzy
 msgid ""
@@ -2739,9 +2744,10 @@
 msgstr ""
 #, fuzzy
@@ -2759,8 +2765,9 @@
 "'location' parameter.\n"
 msgstr ""
 #, fuzzy
 msgstr ""
@@ -6893,7 +6900,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7841,6 +7848,153 @@
 msgstr "Ime rastrskega sloja"
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Vhodni sloj"
+#, fuzzy
+msgstr "Izpi¹e osnovne statistike za rastrske sloje"
+msgid "Statistic"
+msgstr ""
+#, fuzzy
+msgstr "Tip zapisa izhodnega rastrskega sloja"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Enote za naklon"
+msgid ""
+"observations"
+msgstr ""
+#, fuzzy
+msgstr "Povozi projekcijo (uporabi projekcijo lokacije)"
+msgstr ""
+#, fuzzy
+msgstr "Izpi¹e vrednosti v stilu lupinskega skripta"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+#, fuzzy
+msgstr "ne morem odpreti %s"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+#, fuzzy
+msgstr "neveljavna regija: %s"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Ri¹em ..."
+#, fuzzy
+msgstr "Ne najdem vhodne datoteke %s\n"
+#, fuzzy
+msgstr "Zapisujem novo datoteko...\n"
+#, fuzzy, c-format
+msgstr "Uporabi trenutno regijo"
+#, fuzzy
+msgstr "Ri¹em ..."
+#, c-format
+msgstr ""
@@ -8743,12 +8897,6 @@
 msgstr "Ne morem odpreti cellfile za [%s]"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8760,21 +8908,6 @@
-#, fuzzy
-msgstr "Izpi¹e osnovne statistike za rastrske sloje"
-msgid "Statistic"
-msgstr ""
-#, fuzzy
-msgstr "Tip zapisa izhodnega rastrskega sloja"
 msgstr ""
@@ -8787,34 +8920,6 @@
 msgstr ""
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Enote za naklon"
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Izpi¹e vrednosti v stilu lupinskega skripta"
 msgstr ""
@@ -8823,33 +8928,11 @@
 msgstr ""
-#, fuzzy
-msgstr "neveljavna regija: %s"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Ri¹em ..."
 #, c-format
@@ -8878,26 +8961,6 @@
 msgstr ""
-#, fuzzy
-msgstr "Zapisujem novo datoteko...\n"
-#, fuzzy, c-format
-msgstr "Uporabi trenutno regijo"
-#, fuzzy
-msgstr "Ri¹em ..."
-#, c-format
-msgstr ""
 #, fuzzy
@@ -11091,7 +11154,7 @@
 #, fuzzy
@@ -11140,7 +11203,7 @@
 #, c-format
 msgstr "Ne morem vstaviti nove vrstice: %s"
@@ -17966,8 +18029,7 @@
 msgstr "Ne morem izbrati (select) podatkov iz tabele"
 #, fuzzy
@@ -18469,17 +18531,17 @@
 msgstr ""
 #, fuzzy
 msgstr "Izpi¹i le tip podatkovnega zapisa rastrskega sloja"
 msgid "Subregion"
 msgstr ""
 msgstr ""
@@ -18537,18 +18599,13 @@
 #, fuzzy
 msgstr "Ne ustvari tabele z atributi."
 #, fuzzy
-msgstr "Povozi projekcijo (uporabi projekcijo lokacije)"
-#, fuzzy
@@ -18556,7 +18613,7 @@
 msgstr ""
 msgid ""
@@ -18576,12 +18633,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "Ime izhodnega vektorskega sloja"
 #, fuzzy, c-format
@@ -18592,38 +18649,14 @@
 msgstr ""
 msgstr ""
-msgid ""
-"checking"
-msgstr ""
-#, fuzzy
-msgstr "ne morem odpreti %s"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -18663,7 +18696,7 @@
 msgstr "Tip zapisa kolone ni podprt"
 #, fuzzy, c-format
 msgstr "Ne morem odpreti baze podatkov %s z gonilnikom %s"
@@ -18715,27 +18748,27 @@
 msgstr ""
+#, fuzzy
 msgstr ""
 #, fuzzy
 msgstr "Ne morem izraèunati centroida obmoèja."
 msgstr ""
 msgstr ""
-#, fuzzy
@@ -19651,7 +19684,7 @@
 msgstr ""
 msgstr ""
@@ -21514,7 +21547,7 @@
 #, fuzzy, c-format
 msgstr "Za vrstico (cat = %d) ni zapisa (record)<"
@@ -23542,45 +23575,64 @@
 msgstr "%-5d kategorij prebranih v spomin.\n"
 #, fuzzy
 msgstr "Uvozi binarno rastrsko datoteko v GRASS-ov rastrski sloj."
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Uvo¾ene bodo vrednosti z zapisom \"integer\""
+#, fuzzy
 #, fuzzy, c-format
+msgstr "Nepoznan tip"
+#, fuzzy, c-format
 #, fuzzy, c-format
 msgstr "nalo¾enih je bilo %d toèk\n"
 #, fuzzy, c-format
 msgstr "Y koordinata oziroma geografska ¹irina"
 #, fuzzy, c-format
+#, fuzzy, c-format
+msgstr "nalo¾enih je bilo %d toèk\n"
 msgid "flow"
 msgstr ""
@@ -29513,6 +29565,46 @@
 msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Vhodni rastrski sloj"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "©tevilo ¾eljenih toèk"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
@@ -37449,10 +37541,6 @@
 #~ msgstr "Ne najdem vhodne datoteke %s\n"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
-#~ msgstr "Ne najdem vhodne datoteke %s\n"
-#, fuzzy
 #~ msgid "unable to create raster"
 #~ msgstr "ne morem odpreti <%s>"
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_th.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_th\n"
 "PO-Revision-Date: 2008-01-05 15:19+0700\n"
 "Last-Translator: man <mansv68 at yahoo.co.th>\n"
 "Language-Team: Thai <grass-translations at lists.osgeo.org>\n"
@@ -251,13 +251,14 @@
@@ -355,18 +356,18 @@
@@ -421,6 +422,7 @@
@@ -1650,7 +1652,8 @@
 msgstr "ค่าพิกัด ตะวันออก ไม่ถูกต้อง <%s>"
 #, c-format
 msgstr "ผ่าน #%d (ของ %d) ..."
@@ -1704,7 +1707,7 @@
@@ -1829,7 +1832,7 @@
@@ -1840,7 +1843,7 @@
 #, c-format
@@ -1852,7 +1855,7 @@
 #, c-format
@@ -2332,7 +2335,7 @@
 msgstr "Cost แทนที่ null cells. โดยค่าตั้งต้น, null cells จะถูกแยกออก"
 msgstr "เปอร์เซ็นต์ของแผนที่ ที่จะจัดเก็บในหน่วยความจำ"
@@ -2564,7 +2567,7 @@
 msgstr ""
 msgstr "ชื่อของ ตำแหน่ง ใหม่ ที่จะสร้าง"
@@ -2573,7 +2576,7 @@
 msgstr "เขียนทับ Projection (ใช้ location's projection)"
 msgstr "ขยาย ขอบเขต ของตำแหน่ง ในชุดข้อมูลใหม่"
@@ -2645,7 +2648,7 @@
 msgstr ""
 msgid ""
 "Unable to convert input map projection to GRASS format; cannot create new "
 "location."
@@ -2654,7 +2657,7 @@
 "ตำแหน่งใหม่ได้"
 #, fuzzy, c-format
 msgstr "Location %s ถูกสร้าง!"
@@ -2667,13 +2670,15 @@
 msgstr ""
 "ไม่สามารถ แปลงข้อมูล  projection ของแผนที่ที่นำเข้า ไปสู่รูปแบบของ GRASS เพื่อตรวจสอบ"
 msgstr "ยกเลิกการตรวจสอบ projection"
 msgid ""
 "\n"
@@ -2689,9 +2694,10 @@
 msgstr "PROJ_INFO ของ ชุดข้อมูล  คือ:\n"
 msgstr "นำเข้า PROJ_INFO ของชุดข้อมูล  คือ:\n"
@@ -2711,8 +2717,9 @@
 msgstr "สร้าง ตำแหน่งใหม่ จาก ชุดข้อมูลที่นำเข้า โดยใช้ตัวแปร 'location'\n"
 msgstr "Projection ของ ชุดข้อมูลที่นำเข้า และ ตำแหน่งปัจจุบัน เข้ากันได้"
@@ -6804,7 +6811,7 @@
 msgstr "SECTION 1a (of %1d): Initiating Memory."
 #, c-format
 msgstr "SECTION 1b (of %1d): Determining Offmap Flow."
@@ -7802,6 +7809,151 @@
 msgstr "ไม่สามารถสร้าง และ แก้ปัญหา สมการเชิงเส้น"
+msgid "LIDAR"
+msgstr ""
+#, fuzzy
+msgstr ""
+"สร้าง แผนที่เชิงภาพ จาก การรวบรวม ของ ค่าพิกัดจำนวนมาก โดยใช้ Univariate Statistics"
+#, fuzzy
+msgstr "นำเข้า ล้มเหลว"
+msgstr "สถิติ ที่จะใช้กับค่า แผนที่เชิงภาพ"
+msgid "Statistic"
+msgstr ""
+msgstr "ชนิดที่จัดเก็บ สำหรับ แผนที่เชิงภาพ ผลลัพธ์"
+msgstr "ช่วงการกรอง สำหรับข้อมูล  z  (น้อยสุด,มากสุด)"
+msgstr ""
+msgstr "pth เปอร์เซ็นต์ ของ ค่า"
+msgid ""
+"observations"
+msgstr "ตัด <trim> เปอร์เซ็นต์ ของ ค่า เล็กสุด และ ใหญ่สุด ของค่า สังเกตุ"
+msgstr "ยกเลิก projection ของชุดแผนที่ (ใช้ location's projection)"
+msgstr "อ่านไฟล์ข้อมูล ของ ขอบเขต แล้ว ออก"
+msgstr "ในโหมดการกาด, การแสดง ใช้แบบ script"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+"ไม่สามารถ แปลงข้อมูล  projection ของแผนที่ที่นำเข้า ไปสู่รูปแบบของ GRASS เพื่อตรวจสอบ"
+msgstr "GRASS LOCATION PROJ_INFO คือ:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"คุณสามารถใช้ -o กับ %s เพื่อยกเลิกการตรวจสอบ projection.\n"
+#, fuzzy
+msgid ""
+"set.\n"
+msgstr "สร้าง ตำแหน่งใหม่โดยใช้ ตัวแปร  'location' จาก ชุดแผนที่ที่นำเข้า.\n"
+#, fuzzy
+msgstr "ค่าพิกัด ตะวันออก ไม่ถูกต้อง"
+msgstr "ไม่สามารถคำนวน เปอร์เซ็นต์ โดยไม่ ระบุเงื่อนไข pth"
+msgstr "ไม่สามารถคำนวน  trimmed mean โดยไม่ ระบุเงื่อนไข trim"
+msgstr "zrange จะไม่ถูกใส่ใน account ระหว่างการอ่าน"
+#, fuzzy
+msgstr "กำลังอ่านข้อมูล ..."
+#, fuzzy
+msgstr "ไม่สามารถเปิดไฟล์ผลลัพธ์ <%s>"
+msgstr "กำลังเขียน ไปที่ แผนที่ ..."
+#, fuzzy, c-format
+msgstr "พบ %d จุด ใน ขอบเขต"
+#, c-format
+msgstr "ช่วง:     น้อยสุด         มากสุด\n"
@@ -8650,12 +8802,6 @@
 msgstr "ไม่สามารถเปิดTIFF world file เพื่อเขียน"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8667,19 +8813,6 @@
 msgstr "ไฟล์ ASCII ที่มีข้อมูลที่จะนำเข้า (หรือ \"-\" เพื่ออ่านจาก stdin)"
-msgstr "สถิติ ที่จะใช้กับค่า แผนที่เชิงภาพ"
-msgid "Statistic"
-msgstr ""
-msgstr "ชนิดที่จัดเก็บ สำหรับ แผนที่เชิงภาพ ผลลัพธ์"
 msgstr "Column ลำดับที่ ของ ค่าพิกัด x ใน ไฟล์ที่จะนำเข้า (Column แรกคือ 1)"
@@ -8692,32 +8825,6 @@
 msgstr "Column ลำดับที่ ของ ข้อมูล ไฟล์ที่จะนำเข้า "
-msgstr "ช่วงการกรอง สำหรับข้อมูล  z  (น้อยสุด,มากสุด)"
-msgstr ""
-msgstr "pth เปอร์เซ็นต์ ของ ค่า"
-msgid ""
-"observations"
-msgstr "ตัด <trim> เปอร์เซ็นต์ ของ ค่า เล็กสุด และ ใหญ่สุด ของค่า สังเกตุ"
-msgstr "อ่านไฟล์ข้อมูล ของ ขอบเขต แล้ว ออก"
-msgstr "ในโหมดการกาด, การแสดง ใช้แบบ script"
 #, fuzzy
@@ -8727,33 +8834,11 @@
 msgstr "โปรดระบุ จำนวน column ที่ใช้ได้"
-#, fuzzy
-msgstr "ค่าพิกัด ตะวันออก ไม่ถูกต้อง"
-msgstr "ไม่สามารถคำนวน เปอร์เซ็นต์ โดยไม่ ระบุเงื่อนไข pth"
-msgstr "ไม่สามารถคำนวน  trimmed mean โดยไม่ ระบุเงื่อนไข trim"
 msgid ""
 msgstr "ถ้าการนำเข้าไม่ได้มาจาก ไฟล์ จะต้องใช้แบบ single pass"
-msgstr "zrange จะไม่ถูกใส่ใน account ระหว่างการอ่าน"
-#, fuzzy
-msgstr "กำลังอ่านข้อมูล ..."
 #, fuzzy, c-format
@@ -8784,24 +8869,6 @@
 msgstr "ค่าพิกัด z ไม่ดี  บรรทัดที่ %d column %d. <%s>"
-msgstr "กำลังเขียน ไปที่ แผนที่ ..."
-#, fuzzy, c-format
-msgstr "พบ %d จุด ใน ขอบเขต"
-#, c-format
-msgstr "ช่วง:     น้อยสุด         มากสุด\n"
 msgstr "สร้าง ภาพ ด้วยลวดลาย จากแผนที่เชิงภาพ"
@@ -10914,7 +10981,7 @@
 #, fuzzy
@@ -10962,7 +11029,7 @@
 #, c-format
 msgstr "ไม่สามารถแทรก  row: %s ใหม่ได้"
@@ -17719,8 +17786,7 @@
 msgstr "ไม่สามารถเลือก รายละเอียด สำหรับ cat=%d"
 msgstr "ไม่สามารถ เอาข้อมูล จากตาราง"
@@ -18222,16 +18288,16 @@
 "\t\tESRI Shapefile: directory ที่มี shapefiles\n"
 "\t\tMapInfo File: directory ที่มี mapinfo ไฟล์"
 msgstr "นำเข้า ขอบเขตย่อย เท่านั้น"
 msgid "Subregion"
 msgstr "ขอบเขตย่อย "
 msgstr "รูปแบบ: xmin,ymin,xmax,ymax - ตามปกติใช้ W,S,E,N"
@@ -18288,15 +18354,11 @@
 msgstr "ไม่ต้องสร้างตารางรายละเอียด"
-msgstr "ยกเลิก projection ของชุดแผนที่ (ใช้ location's projection)"
 msgstr "จำกัดการนำเข้า ภายในขอบเขตปัจจุบัน"
@@ -18304,7 +18366,7 @@
 msgstr "เปลี่ยนชื่อ column ไปเป็น ตัวอักษรแบบเล็ก"
 msgid ""
@@ -18324,12 +18386,12 @@
 msgstr "แหล่งข้อมูล มี %d ชั้นข้อมูล:"
 #, c-format
 msgstr "แผนที่เชิงเส้น <%s> มีอยู่แล้วและจะถูกเขียนทับ"
 #, c-format
@@ -18340,41 +18402,14 @@
 msgstr "ชั้นข้อมูล <%s> ไม่สามารถใช้งานได้"
 msgstr "เลือก ขอบเขตปัจจุบัน หรือ เงื่อนไขด้านตำแหน่ง,อันใดอันหนึ่ง"
 msgstr "ต้องการ 4 ตัวแปร สำหรับ ตัวแปร  'spatial'"
-msgid ""
-"checking"
-msgstr ""
-"ไม่สามารถ แปลงข้อมูล  projection ของแผนที่ที่นำเข้า ไปสู่รูปแบบของ GRASS เพื่อตรวจสอบ"
-msgstr "GRASS LOCATION PROJ_INFO คือ:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"คุณสามารถใช้ -o กับ %s เพื่อยกเลิกการตรวจสอบ projection.\n"
-#, fuzzy
-msgid ""
-"set.\n"
-msgstr "สร้าง ตำแหน่งใหม่โดยใช้ ตัวแปร  'location' จาก ชุดแผนที่ที่นำเข้า.\n"
 #, fuzzy, c-format
@@ -18414,7 +18449,7 @@
 msgstr "ชนิดของ Column ใช้ไม่ได้  (%s)"
 #, fuzzy, c-format
 msgstr "ไม่สามารถเปิดฐานข้อมูล <%s> โดยตัวขับ <%s>"
@@ -18465,27 +18500,27 @@
 msgstr "Clean boundaries ที่ nodes:"
+#, fuzzy
+msgstr "ตัด boundaries:"
 msgstr "เปลี่ยน boundary dangles ไปเป็นเส้น:"
 #, fuzzy
 msgstr "เอา dangles ออก"
 msgstr "เปลี่ยน boundary bridges ไปเป็นเส้น:"
 msgstr "เอา  bridges ออก:"
-#, fuzzy
-msgstr "ตัด boundaries:"
@@ -19400,7 +19435,7 @@
 msgstr "ใช้คำสั่ง Use drand48() แทน  rand()"
 msgstr "ไม่ต้องสร้าง topology"
@@ -21236,7 +21271,7 @@
 msgstr "ไม่สามารถเลือกรายละเอียด สำหรับ cat = %d"
 #, c-format
 msgstr ""
@@ -23229,45 +23264,64 @@
 msgstr "[%d] หมวดหมู่ อ่านไปไว้ที่หน่วยความจำ"
 #, fuzzy
 msgstr "แปลง ชั้นข้อมูลเชิงเส้น OGR ไปเป็น แผนที่เชิงเส้น GRASS"
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "ค่า Integer ถูกนำเข้า"
+#, fuzzy
 msgstr "แสดง ประวัติ ของ แผนที่เชิงภาพ"
 #, fuzzy, c-format
+msgstr "ไม่ทราบเงื่อนไข '%s'"
+#, fuzzy, c-format
 msgstr "กำลังนำเข้า จุด ..."
 #, fuzzy, c-format
 msgstr "%d จุดถูกอ่าน"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d จุด อยู่นอก threshold"
+#, fuzzy, c-format
+msgstr "%d จุด อยู่นอก threshold"
 msgid "flow"
 msgstr ""
@@ -29147,6 +29201,46 @@
 msgstr "ไฟล์ GNS ไม่ได้บีบอัด จาก NGA (ด้วยนามสกุล .txt)"
+msgstr ""
+#, fuzzy
+msgstr "ชื่อของชั้นข้อมูลที่จะนำเข้า"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "จำนวนจุดที่จะกำหนด"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_tr.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -9,7 +9,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_tr\n"
 "PO-Revision-Date: 2008-11-16 01:15+0200\n"
 "Last-Translator: Osman Yalçın YILMAZ <yilmazy at istanbul.edu.tr>\n"
 "Language-Team: Türkçe <grass-translations at lists.osgeo.org>\n"
@@ -356,18 +357,18 @@
@@ -422,6 +423,7 @@
@@ -1617,7 +1619,8 @@
 msgstr "Uygun olmayan doğu koordinatı <%s>"
 #, c-format
 msgstr ""
@@ -1671,7 +1674,7 @@
@@ -1798,7 +1801,7 @@
@@ -1809,7 +1812,7 @@
 #, c-format
@@ -1821,7 +1824,7 @@
 #, c-format
@@ -2281,7 +2284,7 @@
 msgstr ""
 msgstr "Hafızada tutulacak harita oranı"
@@ -2513,7 +2516,7 @@
 msgstr ""
 msgstr "oluşturulacak yeni mevki adı"
@@ -2522,7 +2525,7 @@
 msgstr "Projeksiyonun üstüne yaz (mevkinin projeksiyonunu kullan)"
 msgstr "Mevki sınırlarını yeni verinin sınırlarına göre genişlet "
@@ -2591,14 +2594,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr ""
 #, c-format
 msgstr "< %s> Mevkisi oluÅŸturuldu"
@@ -2609,13 +2612,15 @@
 "for checking"
 msgstr ""
 msgstr ""
 msgid ""
 "\n"
@@ -2629,9 +2634,10 @@
 msgstr "Veri takımı PROJ_INFO su:\n"
 msgstr "İçe aktarılacak veri takımı PROJ_INFO su:\n"
@@ -2648,8 +2654,9 @@
 msgstr ""
 msgstr "Girdi veri takımı ve geçerli mevkinin projeksiyonu eşleşiyor"
@@ -6594,7 +6601,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7515,6 +7522,145 @@
 msgstr ""
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Girdi dosya"
+msgstr "Raster değerler için kullanılacak istatistikler"
+msgid "Statistic"
+msgstr ""
+msgstr "Sonuç harita depolama türü"
+msgstr "z verisi süzme aralığı (en küçük, en büyük)"
+msgstr ""
+msgstr ""
+msgid ""
+"observations"
+msgstr ""
+msgstr "Veri takımı projeksiyonu üzerine yaz (mevkinin projeksiyonunu kullan)"
+msgstr ""
+msgstr ""
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+msgstr "GRASS MEVKİSİ PROJ_INFO su:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+msgid ""
+"set.\n"
+msgstr ""
+#, fuzzy
+msgstr "Geçersiz doğu"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Veri okunuyor..."
+#, fuzzy
+msgstr "<%s> çıktı dosyası açılamadı"
+msgstr "Haritaya yazılıyor ..."
+#, fuzzy, c-format
+msgstr "Bölgede %lu nokta bulundu"
+msgstr "Veri taranıyor..."
+#, c-format
+msgstr "Aralık:     en küçük          en büyük\n"
@@ -8344,12 +8490,6 @@
 msgstr "TIFF koordinat dosyası yazmak için açılamıyor."
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8360,19 +8500,6 @@
 msgstr ""
-msgstr "Raster değerler için kullanılacak istatistikler"
-msgid "Statistic"
-msgstr ""
-msgstr "Sonuç harita depolama türü"
 msgstr "Girdi dosyasındaki x koordinatları sütun numarası (ilk sütun 1'dir)"
@@ -8385,32 +8512,6 @@
 msgstr "Girdi dosyasındaki veri değerleri sütun numarası"
-msgstr "z verisi süzme aralığı (en küçük, en büyük)"
-msgstr ""
-msgstr ""
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-msgstr ""
 msgstr ""
@@ -8419,33 +8520,11 @@
 msgstr ""
-#, fuzzy
-msgstr "Geçersiz doğu"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "Veri okunuyor..."
 #, c-format
@@ -8474,24 +8553,6 @@
 msgstr ""
-msgstr "Haritaya yazılıyor ..."
-#, fuzzy, c-format
-msgstr "Bölgede %lu nokta bulundu"
-msgstr "Veri taranıyor..."
-#, c-format
-msgstr "Aralık:     en küçük          en büyük\n"
 msgstr ""
@@ -10568,7 +10629,7 @@
 msgid "Attributes"
@@ -10614,7 +10675,7 @@
 #, c-format
 msgstr "Yeni satır girilemiyor: %s"
@@ -17210,8 +17271,7 @@
 msgstr "cat=%d için öznitelik seçilemiyor"
 msgstr ""
@@ -17690,16 +17750,16 @@
 "\t\tMapInfo File: mapinfo file name"
 msgstr ""
 msgstr "Sadece alt bölgeyi içe aktar"
 msgid "Subregion"
 msgstr "Alt bölge"
 msgstr ""
@@ -17756,15 +17816,11 @@
 msgstr "Öznitelik tablosu oluşturmayın"
-msgstr "Veri takımı projeksiyonu üzerine yaz (mevkinin projeksiyonunu kullan)"
 msgstr ""
@@ -17772,7 +17828,7 @@
 msgstr "Sütun adlarını küçük harfli karakterlere dönüştür"
 msgid ""
@@ -17792,12 +17848,12 @@
 msgstr "Veri kaynağı %d katmanları içeriyor:"
 #, c-format
 msgstr "<%s> vektör haritası zaten mevcut ve üzerine yazılacak"
 #, c-format
@@ -17808,37 +17864,14 @@
 msgstr "<%s> katmanı mevcut değil"
 msgstr ""
 msgstr "'spatial' parametresi için 4 parametre gerekli"
-msgid ""
-"checking"
-msgstr ""
-msgstr "GRASS MEVKİSİ PROJ_INFO su:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-msgid ""
-"set.\n"
-msgstr ""
 #, fuzzy, c-format
@@ -17876,7 +17909,7 @@
 msgstr "(%s) sütun tipi desteklenmiyor"
 #, fuzzy, c-format
 msgstr "<%s> sürücüsüyle <%s> veritabanı açılamıyor"
@@ -17927,27 +17960,27 @@
 msgstr "Düğümlerdeki sınırları temizle:"
+#, fuzzy
+msgstr "Sınırları kır:"
 msgstr ""
 #, fuzzy
 msgstr "Köprüleri uzaklaştır:"
 msgstr "Sınır köprülerini çizgilere dönüştür:"
-#, fuzzy
-msgstr "Sınırları kır:"
@@ -18826,7 +18859,7 @@
 msgstr ""
 msgstr "Topoloji oluÅŸturma"
@@ -20597,7 +20630,7 @@
 msgstr "cat = %d için öznitelik seçilemiyor"
 #, c-format
 msgstr ""
@@ -22548,45 +22581,64 @@
 msgstr "[%d] kategori hafızaya alındı"
 #, fuzzy
 msgstr "OGR vektör katmanını GRASS vektör haritasına dönüştürür."
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Tamsayı değerler içeri aktarıldı"
+#, fuzzy
 msgstr "Desteklenen biçimleri yaz ve çık"
 #, fuzzy, c-format
+msgstr "Bilinmeyen kural seçeneği: '%s'"
+#, fuzzy, c-format
 msgstr "Noktalar içe aktarılıyor..."
 #, fuzzy, c-format
 msgstr "%d nokta yüklendi"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d nokta eşik dışında"
+#, fuzzy, c-format
+msgstr "%d nokta eşik dışında"
 msgid "flow"
 msgstr ""
@@ -28298,6 +28350,45 @@
 msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Girdi katmanı adı"
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_vi.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -8,7 +8,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_vi\n"
 "PO-Revision-Date: 2010-08-27 14:37+0700\n"
 "Last-Translator: \n"
 "Language-Team: American English <kde-i18n-doc at kde.org>\n"
@@ -255,13 +255,14 @@
@@ -361,18 +362,18 @@
@@ -427,6 +428,7 @@
@@ -1670,7 +1672,8 @@
 msgstr "Tọa độ đông không hợp lệ <%s>"
 #, c-format
 msgstr "Số lần chạy qua #%d (của %d)..."
@@ -1724,7 +1727,7 @@
@@ -1850,7 +1853,7 @@
@@ -1861,7 +1864,7 @@
 #, c-format
@@ -1873,7 +1876,7 @@
 #, c-format
@@ -2355,7 +2358,7 @@
 msgstr "Chi phí gán cho các ô rỗng. Theo mặc định, các ô rỗng bị loại bỏ"
 msgstr "Phần trăm bản đồ được giữ trong bộ nhớ"
@@ -2590,7 +2593,7 @@
 msgstr ""
 msgstr "Tên của vị trí mới cần tạo"
@@ -2599,7 +2602,7 @@
 msgstr "Ghi đè phép chiếu (dùng phép chiếu của vị trí)"
 msgstr "Mở rộng phạm vi của vị trí dựa trên bộ dữ liệu mới"
@@ -2670,7 +2673,7 @@
 msgstr ""
 msgid ""
 "location."
@@ -2679,7 +2682,7 @@
 "tạo vị trí mới."
 #, c-format
 msgstr "Vị trí <%s> được tạo ra"
@@ -2692,13 +2695,15 @@
 "Không thể đổi thông tin phép chiếu của bản đồ raster đầu vào thành định dạng "
 "GRASS để kiểm tra"
 msgstr "Kiểm tra ghi đè phép chiếu"
 msgid ""
 "\n"
@@ -2714,9 +2719,10 @@
 msgstr "Bộ dữ liệu PROJ_INFO là:\n"
 msgstr "PROJ_INFO của dữ liệu nhập vào là:\n"
@@ -2738,8 +2744,9 @@
 "Hãy xem xét việc tạo một vị trí mới từ bộ dữ liệu đầu vào bằng cách dùng "
 "tham số 'location'.\n"
 msgstr "Phép chiếu của bộ dữ liệu đầu vào và location hiện tại khớp nhau"
@@ -6864,7 +6871,7 @@
 msgstr "PHẦN 1a (của %1d): Đang khởi tạo bộ nhớ."
 #, c-format
 msgstr "PHẦN 1b (của %1d): Đang xác định Dòng chảy ra khỏi Bản đồ."
@@ -7904,6 +7911,156 @@
 msgstr "Không thể tạo và giải hệ phương trình tuyến tính"
+msgid "LIDAR"
+msgstr ""
+#, fuzzy
+msgstr ""
+"Tạo một bản đồ raster từ sự tập hợp nhiều tọa độ bằng các dùng thống kê một "
+"biến."
+#, fuzzy
+msgstr "Tập tin đầu vào"
+msgstr "Phép thống kê dùng cho các giá trị raster"
+msgid "Statistic"
+msgstr "Thống kê"
+msgstr "Kiểu lưu trữ cho bản đồ raster kết quả"
+msgstr "Miền giá trị lọc cho dữ liệu z (min,max)"
+msgstr "Tỷ lệ áp dụng cho dữ liệu z"
+msgstr "Số phần trăm pth của các giá trị"
+msgid ""
+"observations"
+msgstr ""
+"Bỏ <trim> phần trăm các quan sát nhỏ nhất và <trim> phần trăm các quan sát "
+"lớn nhất"
+msgstr "Ghi đè phép chiếu của dữ liệu (dùng phép chiếu của vị trí)"
+msgstr "Quét tập tin dữ liệu để lấy phạm vi và thoát"
+msgstr "Ở chế độ quét, in bằng cách dùng dạng tập lệnh shell"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr ""
+"Không thể đổi phép chiếu của bản đồ đầu vào thành định dạng GRASS để kiểm tra"
+msgstr "GRASS LOCATION PROJ_INFO là:\n"
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Bạn có thể dùng cờ -o cho %s để ghi đè kiểm tra phép chiếu này.\n"
+msgid ""
+"set.\n"
+msgstr ""
+"Hãy cân nhắc việc tạo vị trí mới với tham số 'location' từ bộ dữ liệu đầu "
+"vào.\n"
+msgstr "Miền zrange không hợp lệ"
+msgstr ""
+"Không thể tính toán số phần trăm mà không có tùy chọn pth được chỉ định!"
+msgstr ""
+"Không thể tính toán trị trung bình bị cắt bớt nếu tùy chọn trim không được "
+"chỉ định!"
+msgstr "miền giá trị z (zrange) sẽ không được xem xét trong quá trình quét"
+msgstr "Đang đọc dữ liệu ..."
+#, fuzzy
+msgstr "Không thể mở tập tin đầu ra <%s>."
+msgstr "Đang ghi bản đồ..."
+#, c-format
+msgstr "%lu điểm tìm thấy trong vùng."
+msgstr "Đang quét dữ liệu..."
+#, c-format
+msgstr "Miền:     tối thiểu       tối đa\n"
@@ -8771,12 +8928,6 @@
 msgstr "Không thể mở tập tin world TIFF để ghi"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8791,19 +8942,6 @@
 "Tập tin ASCII chứa dữ liệu đầu vào (hoặc nhập \"-\" để đọc từ đầu vào tiêu "
 "chuẩn)"
-msgstr "Phép thống kê dùng cho các giá trị raster"
-msgid "Statistic"
-msgstr "Thống kê"
-msgstr "Kiểu lưu trữ cho bản đồ raster kết quả"
 msgstr "Số thứ tự cột chứa tọa độ x trong tập tin đầu vào (cột đầu tiên là 1)"
@@ -8816,34 +8954,6 @@
 msgstr "Số thứ tự cột chứa giá trị dữ liệu trong tập tin đầu vào"
-msgstr "Miền giá trị lọc cho dữ liệu z (min,max)"
-msgstr "Tỷ lệ áp dụng cho dữ liệu z"
-msgstr "Số phần trăm pth của các giá trị"
-msgid ""
-"observations"
-msgstr ""
-"Bỏ <trim> phần trăm các quan sát nhỏ nhất và <trim> phần trăm các quan sát "
-"lớn nhất"
-msgstr "Quét tập tin dữ liệu để lấy phạm vi và thoát"
-msgstr "Ở chế độ quét, in bằng cách dùng dạng tập lệnh shell"
 msgstr "Bỏ qua các đường đứt"
@@ -8852,35 +8962,12 @@
 msgstr "Vui lòng chỉ định số thứ tự cột hợp lý."
-msgstr "Miền zrange không hợp lệ"
-msgstr ""
-"Không thể tính toán số phần trăm mà không có tùy chọn pth được chỉ định!"
-msgstr ""
-"Không thể tính toán trị trung bình bị cắt bớt nếu tùy chọn trim không được "
-"chỉ định!"
 msgid ""
 msgstr ""
 "Nếu đầu vào không phải từ một tập tin, chỉ có thể thực hiện một lần chạy qua."
-msgstr "miền giá trị z (zrange) sẽ không được xem xét trong quá trình quét"
-msgstr "Đang đọc dữ liệu ..."
 #, c-format
@@ -8912,24 +8999,6 @@
 msgstr "Dòng tọa độ z tồi %lu cột %d. <%s>"
-msgstr "Đang ghi bản đồ..."
-#, c-format
-msgstr "%lu điểm tìm thấy trong vùng."
-msgstr "Đang quét dữ liệu..."
-#, c-format
-msgstr "Miền:     tối thiểu       tối đa\n"
 msgstr "Tạo các ảnh với các đối tượng cấu trúc từ một bản đồ raster."
@@ -11092,7 +11161,7 @@
 msgid "Attributes"
@@ -11145,7 +11214,7 @@
 #, c-format
 msgstr "Không thể chèn hàng mới: %s"
@@ -17969,8 +18038,7 @@
 msgstr "Không thể chọn các thuộc tính cho phạm trù cat=%d"
 msgstr "Không thể lấy dữ liệu từ bảng"
@@ -18478,16 +18546,16 @@
\t\tESRI Shapefile: tên tập tin shape\n"
 "\t\tMapInfo File: tên tập tin mapinfo"
 msgstr "Chỉ nhập vùng con"
 msgid "Subregion"
 msgstr "Vùng con"
 msgstr "Định dạng: xmin,ymin,xmax,ymax  - thường là T,N,Đ,B"
@@ -18546,15 +18614,11 @@
 msgstr "Không tạo bảng thuộc tính"
-msgstr "Ghi đè phép chiếu của dữ liệu (dùng phép chiếu của vị trí)"
 msgstr "Giới hạn nhập theo vùng hiện tại"
@@ -18562,7 +18626,7 @@
 msgstr "Thay đổi tên các cột thành ký tự thường"
 msgid ""
@@ -18582,12 +18646,12 @@
 msgstr "Nguồn dữ liệu chứa %d lớp:"
 #, c-format
 msgstr "Bản đồ vec-tơ <%s> đã có và sẽ bị ghi đè"
 #, c-format
@@ -18598,44 +18662,16 @@
 msgstr "Lớp <%s> không dùng được"
 msgstr ""
 "Hoặc là chọn cờ vùng hiện tại hoặc chọn tùy chọn spatial (không gian), không "
 "được chọn cả hai"
 msgstr "4 tham số cần phải có cho tham số 'spatial'"
-msgid ""
-"checking"
-msgstr ""
-"Không thể đổi phép chiếu của bản đồ đầu vào thành định dạng GRASS để kiểm tra"
-msgstr "GRASS LOCATION PROJ_INFO là:\n"
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-"\n"
-"Bạn có thể dùng cờ -o cho %s để ghi đè kiểm tra phép chiếu này.\n"
-msgid ""
-"set.\n"
-msgstr ""
-"Hãy cân nhắc việc tạo vị trí mới với tham số 'location' từ bộ dữ liệu đầu "
-"vào.\n"
 #, fuzzy, c-format
@@ -18675,7 +18711,7 @@
 msgstr "Kiểu cột không được hỗ trợ (%s)"
 #, c-format
 msgstr "Không thể mở CSDL <%s> bằng trình điều khiển <%s>"
@@ -18726,27 +18762,27 @@
 msgstr "Làm sạch các ranh giới tại các nốt:"
+#, fuzzy
+msgstr "Ngắt các ranh giới:"
 msgstr "Thay đổi các đoạn thừa của ranh giới thành đường:"
 #, fuzzy
 msgstr "Loại bỏ các đoạn thừa"
 msgstr "Thay đổi các cầu ranh giới thành đường:"
 msgstr "Loại bỏ các cầu:"
-#, fuzzy
-msgstr "Ngắt các ranh giới:"
@@ -19665,7 +19701,7 @@
 msgstr "Dùng hàm drand48() thay vì hàm rand()"
 msgstr "Không xây dựng tôpô"
@@ -21549,7 +21585,7 @@
 msgstr "Không thể chọn các thuộc tính cho cat = %d"
 #, fuzzy, c-format
 msgstr "Không có bản ghi CSDL cho phạm trù %d"
@@ -23554,45 +23590,64 @@
 msgstr "[%d] phạm trù được đọc vào bộ nhớ"
 #, fuzzy
 msgstr "Đổi các lớp vec-tơ OGR thành bản đồ vec-tơ GRASS."
 #, fuzzy
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "Các giá trị số nguyên được nhập vào"
+#, fuzzy
 msgstr "Chỉ in ra lịch sử thay vì thông tin"
 #, fuzzy, c-format
+msgstr "Không hiểu tùy chọn quy tắc: '%s'"
+#, fuzzy, c-format
 msgstr "Đang nhập các điểm..."
 #, fuzzy, c-format
 msgstr "%d điểm đã nạp"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d điểm nằm ngoài ngưỡng"
+#, fuzzy, c-format
+msgstr "%d điểm nằm ngoài ngưỡng"
 msgid "flow"
 msgstr ""
@@ -29566,6 +29621,46 @@
 msgstr "Tập tin GNS không nén từ NGA (với đuôi mở rộng .txt)"
+msgstr ""
+#, fuzzy
+msgstr "Tên của lớp đầu vào"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "Số điểm cần cấp phát"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grassmods_zh.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -7,7 +7,7 @@
 msgstr ""
 "Project-Id-Version: grassmods_zh\n"
 "PO-Revision-Date: 2007-12-13 16:33+0100\n"
 "Last-Translator: Zhang Jun <nilarcs at gmail.com>\n"
 "Language-Team: Simplified Chinese <translations at grass.itc.it>\n"
@@ -257,13 +257,14 @@
@@ -367,18 +368,18 @@
@@ -433,6 +434,7 @@
@@ -1669,7 +1671,8 @@
 msgstr "使用地图中心点坐标\n"
 #, c-format
 msgstr ""
@@ -1849,7 +1852,7 @@
@@ -1860,7 +1863,7 @@
 #, fuzzy, c-format
@@ -1872,7 +1875,7 @@
 #, fuzzy, c-format
@@ -2352,7 +2355,7 @@
 msgstr "赋予空值像元的成本。默认情况下,空值像元是被排除的。"
 msgstr "载入内存的地图的百分比"
@@ -2585,7 +2588,7 @@
 msgstr ""
 msgstr "将要创建的新区域的名称"
@@ -2594,7 +2597,7 @@
 msgstr "覆盖投影(使用区域的投影)"
 msgstr "基于新的数据集扩展区域的范围"
@@ -2662,14 +2665,14 @@
 msgstr ""
 msgid ""
 "location."
 msgstr "不能将输入地图的投影转换为 GRASS 格式,无法创建新的区域。"
 #, fuzzy, c-format
 msgstr "位置名称"
@@ -2681,14 +2684,16 @@
 "for checking"
 msgstr "不能将输入地图的投影信息转换为 GRASS 格式来检查"
 #, fuzzy
 msgstr "无法获取栅格行\n"
 #, fuzzy
 msgid ""
@@ -2705,9 +2710,10 @@
 msgstr ""
 msgstr ""
@@ -2725,8 +2731,9 @@
 msgstr "考虑用 'location' 参数从输入的数据集创建新的区域。\n"
 #, fuzzy
 msgstr ""
@@ -6846,7 +6853,7 @@
 msgstr ""
 #, c-format
 msgstr ""
@@ -7792,6 +7799,152 @@
 msgstr "无法创建栅格地图 %s"
+msgid "LIDAR"
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "输入文件"
+#, fuzzy
+msgstr "报告栅格图层的统计数据"
+msgid "Statistic"
+msgstr ""
+msgstr "转换后的栅格图的存储类型"
+#, fuzzy
+msgstr "整数范围:min,max"
+msgstr ""
+#, fuzzy
+msgstr "表达坡度的格式"
+msgid ""
+"observations"
+msgstr ""
+#, fuzzy
+msgstr "覆盖投影(使用区域的投影)"
+msgstr ""
+#, fuzzy
+msgstr "以shell脚本的样式输出统计值"
+#, c-format
+msgstr ""
+msgid ""
+"checking"
+msgstr "不能将输入地图的投影信息转换为 GRASS 格式来检查"
+msgstr ""
+#, c-format
+msgid ""
+"\n"
+msgstr ""
+#, fuzzy
+msgid ""
+"set.\n"
+msgstr "考虑用 'location' 参数从输入的数据集创建新的区域。\n"
+#, fuzzy
+msgstr "无效的区域:%s"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "读取地图"
+#, fuzzy
+msgstr "无法打开矢量文件 <%s>"
+#, fuzzy
+msgstr "写入 %s ... "
+#, fuzzy, c-format
+msgstr "%d 个点在当前范围之外,将被忽略"
+msgstr ""
+#, c-format
+msgstr ""
@@ -8670,12 +8823,6 @@
 msgstr "无法找到文件 [%s]。"
-msgid "LIDAR"
-msgstr ""
 msgid ""
@@ -8687,20 +8834,6 @@
 msgstr "导入的ASCII栅格文件"
-#, fuzzy
-msgstr "报告栅格图层的统计数据"
-msgid "Statistic"
-msgstr ""
-msgstr "转换后的栅格图的存储类型"
 #, fuzzy
@@ -8714,35 +8847,6 @@
 msgstr ""
-#, fuzzy
-msgstr "整数范围:min,max"
-msgstr ""
-#, fuzzy
-msgstr "表达坡度的格式"
-msgid ""
-"observations"
-msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "以shell脚本的样式输出统计值"
 msgstr ""
@@ -8752,33 +8856,11 @@
 msgstr "请指定合理的 z 字段。"
-#, fuzzy
-msgstr "无效的区域:%s"
-msgstr ""
-msgstr ""
 msgid ""
 msgstr ""
-msgstr ""
-#, fuzzy
-msgstr "读取地图"
 #, c-format
@@ -8807,25 +8889,6 @@
 msgstr ""
-#, fuzzy
-msgstr "写入 %s ... "
-#, fuzzy, c-format
-msgstr "%d 个点在当前范围之外,将被忽略"
-msgstr ""
-#, c-format
-msgstr ""
 #, fuzzy
@@ -10993,7 +11056,7 @@
 #, fuzzy
@@ -11043,7 +11106,7 @@
 #, c-format
 msgstr "无法插入新行:%s"
@@ -17827,8 +17890,7 @@
 msgstr "无法选择类别 = %d 的属性"
 #, fuzzy
 msgstr "无法从表中选取数据"
@@ -18348,17 +18410,17 @@
 "\t\tESRI Shapefile:shapefile 的名称\n"
 "\t\tMapInfo File:mapinfo 文件名称"
 #, fuzzy
 msgstr "只打印栅格图的区域"
 msgid "Subregion"
 msgstr ""
 #, fuzzy
 msgstr "只导入子区域 (xmin,ymin,xmax,ymax  - 通常为 W,S,E,N)"
@@ -18422,17 +18484,12 @@
 msgstr "无法创建属性表"
 #, fuzzy
-msgstr "覆盖投影(使用区域的投影)"
-#, fuzzy
 msgstr "不更新当前区域"
@@ -18440,7 +18497,7 @@
 msgstr ""
 msgid ""
@@ -18460,12 +18517,12 @@
 msgstr ""
 #, fuzzy, c-format
 msgstr "栅格地图 %i 文件名成: %s 已经存在。它将被覆盖!\n"
 #, fuzzy, c-format
@@ -18476,39 +18533,15 @@
 msgstr "图层 '%s' 不可用"
 msgstr ""
 #, fuzzy
 msgstr "'spatial' 选项需要 4 个参数。"
-msgid ""
-"checking"
-msgstr "不能将输入地图的投影信息转换为 GRASS 格式来检查"
-msgstr ""
-#, c-format
-msgid ""
-"\n"
-msgstr ""
-#, fuzzy
-msgid ""
-"set.\n"
-msgstr "考虑用 'location' 参数从输入的数据集创建新的区域。\n"
 #, fuzzy, c-format
@@ -18546,7 +18579,7 @@
 msgstr "字段类型不支持 (%s)"
 #, fuzzy, c-format
 msgstr "无法打开数据库%s,通过驱动%s"
@@ -18599,27 +18632,27 @@
 msgstr ""
+#, fuzzy
 msgstr ""
 #, fuzzy
 msgstr "移除 [%s] 的空文件...\n"
 msgstr ""
 msgstr ""
-#, fuzzy
@@ -19536,7 +19569,7 @@
 msgstr "使用 drand48() 函数 (默认=rand() )"
 #, fuzzy
@@ -21419,7 +21452,7 @@
 #, fuzzy, c-format
 msgstr "类别 %d 没有相关的记录"
@@ -23422,45 +23455,64 @@
 msgstr "%-5d个类别读入内存。\n"
 #, fuzzy
 msgstr "将GRASS矢量图层转化为GRASS栅格图层。"
 #, fuzzy
 msgstr "输入文件"
 msgstr ""
+msgstr ""
 #, fuzzy
+msgstr "导入的整数值"
+#, fuzzy
 msgstr "打印栅格历史信息"
 #, fuzzy, c-format
+msgstr "未知的类型"
+#, fuzzy, c-format
 msgstr "导入地图 %d 的要素..."
 #, fuzzy, c-format
 msgstr "载入%d个点\n"
 #, c-format
 msgstr ""
 #, fuzzy, c-format
 msgstr "%d 个点超出范围"
+#, fuzzy, c-format
+msgstr "%d 个点超出范围"
 msgid "flow"
 msgstr ""
@@ -29326,6 +29378,46 @@
 msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "输入图层的名称"
+msgstr ""
+msgstr ""
+msgstr ""
+#, fuzzy
+msgstr "指定点的数量"
+msgstr ""
+msgid ""
+"start day"
+msgstr ""
+msgstr ""
 msgid ""
Modified: grass/trunk/locale/po/grasswxpy_cs.po
--- grass/trunk/locale/po/grasswxpy_cs.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasswxpy_cs.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -6,13 +6,13 @@
 # Miroslav Hoøej¹í <miroslav.horejsi at fsv.cvut.cz>, 2009/01.
 # Pavel Valenta <pavel.valenta at fsv.cvut.cz>, 2009/01.
-#: ../gui/wxpython/gui_modules/psmap.py:1097
+#: ../gui/wxpython/gui_modules/psmap.py:1096
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2211
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_cs\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2010-11-24 21:18+0100\n"
 "Last-Translator: Jan Trochta <j.trochta at gmail.com>\n"
 "Language-Team:  <cs at li.org>\n"
@@ -22,55 +22,71 @@
 "Language: \n"
 "X-Generator: KBabel 1.11.4\n"
-#: ../gui/wxpython/wxgui.py:96
+#: ../gui/wxpython/wxgui.py:97
 msgid "GRASS GIS Layer Manager"
 msgstr "GRASS GIS správce vrstev"
-#: ../gui/wxpython/wxgui.py:136
+#: ../gui/wxpython/wxgui.py:139
 #, fuzzy
-msgid "Main Toolbar"
+msgid "Data Toolbar"
 msgstr "Nástrojová li¹ta pro správu mapy"
-#: ../gui/wxpython/wxgui.py:144
+#: ../gui/wxpython/wxgui.py:147
 #, fuzzy
+msgid "Workspace Toolbar"
+msgstr "Pracovní oblast"
+#: ../gui/wxpython/wxgui.py:155
+#, fuzzy
+msgid "Misc Toolbar"
+msgstr "Nástrojová li¹ta pro správu mapy"
+#: ../gui/wxpython/wxgui.py:163
+#, fuzzy
 msgid "Tools Toolbar"
-#: ../gui/wxpython/wxgui.py:231
+#: ../gui/wxpython/wxgui.py:250
 msgid "Map layers"
 msgstr "Mapové vrstvy"
-#: ../gui/wxpython/wxgui.py:235 ../gui/wxpython/wxgui.py:375
+#: ../gui/wxpython/wxgui.py:254 ../gui/wxpython/wxgui.py:407
 msgid "Command console"
 msgstr "Pøíkazová konzole"
-#: ../gui/wxpython/wxgui.py:239
+#: ../gui/wxpython/wxgui.py:260
+#: ../gui/wxpython/gui_modules/preferences.py:1146
 msgid "Search module"
 msgstr "Hledat modul"
-#: ../gui/wxpython/wxgui.py:252 ../gui/wxpython/gui_modules/toolbars.py:207
+#: ../gui/wxpython/wxgui.py:267
+#: ../gui/wxpython/gui_modules/preferences.py:1156
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:282 ../gui/wxpython/gui_modules/toolbars.py:211
 msgid "3D view"
 msgstr "3D pohled"
-#: ../gui/wxpython/wxgui.py:296
+#: ../gui/wxpython/wxgui.py:328
 #, python-format
 msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:315
+#: ../gui/wxpython/wxgui.py:347
 msgid "Choose model to run"
 msgstr "Vybrat model ke spu¹tìní"
-#: ../gui/wxpython/wxgui.py:317 ../gui/wxpython/gui_modules/gmodeler.py:802
-#: ../gui/wxpython/gui_modules/gmodeler.py:846
+#: ../gui/wxpython/wxgui.py:349 ../gui/wxpython/gui_modules/gmodeler.py:796
+#: ../gui/wxpython/gui_modules/gmodeler.py:840
 msgid "GRASS Model File (*.gxm)|*.gxm"
 msgstr "GRASS soubor modulu (*.gxm)|*.gxm"
-#: ../gui/wxpython/wxgui.py:326 ../gui/wxpython/gui_modules/gmodeler.py:1117
+#: ../gui/wxpython/wxgui.py:358 ../gui/wxpython/gui_modules/gmodeler.py:1111
 msgid "Validating model..."
 msgstr "Vyhodnocuji model..."
-#: ../gui/wxpython/wxgui.py:330 ../gui/wxpython/gui_modules/gmodeler.py:919
+#: ../gui/wxpython/wxgui.py:362 ../gui/wxpython/gui_modules/gmodeler.py:913
 #, python-format
 msgid ""
 "Model is not valid. Do you want to run the model anyway?\n"
@@ -81,60 +97,60 @@
 "\n"
 "%s"
-#: ../gui/wxpython/wxgui.py:332 ../gui/wxpython/gui_modules/gmodeler.py:921
+#: ../gui/wxpython/wxgui.py:364 ../gui/wxpython/gui_modules/gmodeler.py:915
 msgid "Run model?"
 msgstr "Spustit modul?"
-#: ../gui/wxpython/wxgui.py:339 ../gui/wxpython/gui_modules/gmodeler.py:984
+#: ../gui/wxpython/wxgui.py:371 ../gui/wxpython/gui_modules/gmodeler.py:978
 msgid "Running model..."
 msgstr "Spou¹tím modul"
-#: ../gui/wxpython/wxgui.py:389 ../gui/wxpython/wxgui.py:1476
+#: ../gui/wxpython/wxgui.py:421 ../gui/wxpython/wxgui.py:1500
 msgid "Do you want to save changes in the workspace?"
 msgstr "Chcete ulo¾it zmìny v pracovním prostøedí?"
-#: ../gui/wxpython/wxgui.py:391 ../gui/wxpython/wxgui.py:1478
+#: ../gui/wxpython/wxgui.py:423 ../gui/wxpython/wxgui.py:1502
 msgid "Do you want to store current settings to workspace file?"
 msgstr "Chcete ulo¾it souèasné nastavní do souboru pracovního prostøedí?"
-#: ../gui/wxpython/wxgui.py:398
+#: ../gui/wxpython/wxgui.py:430
 #, python-format
 msgid "Close Map Display %d"
 msgstr "Zavøít Mapový displej %d"
-#: ../gui/wxpython/wxgui.py:497 ../gui/wxpython/wxgui.py:1159
+#: ../gui/wxpython/wxgui.py:529 ../gui/wxpython/wxgui.py:1155
 msgid "Selected map layer is not vector."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:502
+#: ../gui/wxpython/wxgui.py:534
 #, fuzzy
 msgid "Editing is allowed only for vector maps from the current mapset."
 msgstr "Pøebuduje topologii v¹ech vektorových map v souèasném mapsetu."
-#: ../gui/wxpython/wxgui.py:517
+#: ../gui/wxpython/wxgui.py:549
 msgid "Choose script file to run"
 msgstr "Vybrat soubor se skritp"
-#: ../gui/wxpython/wxgui.py:519
+#: ../gui/wxpython/wxgui.py:551
 msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
 msgstr "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
-#: ../gui/wxpython/wxgui.py:530
+#: ../gui/wxpython/wxgui.py:562
 #, python-format
 msgid "Script file '%s' doesn't exist. Operation cancelled."
 msgstr "Soubor skriptu '%s' neexistuje. Operace zru¹ena."
-#: ../gui/wxpython/wxgui.py:534
+#: ../gui/wxpython/wxgui.py:566
 #, python-format
 msgid "Launching script '%s'..."
 msgstr "Spou¹tím script  '%s'..."
-#: ../gui/wxpython/wxgui.py:549
+#: ../gui/wxpython/wxgui.py:581
 #, python-format
 msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
 msgstr "Nelze se pøepnout do location <%(loc)s> mapset <%(mapset)s>."
-#: ../gui/wxpython/wxgui.py:551 ../gui/wxpython/wxgui.py:572
+#: ../gui/wxpython/wxgui.py:583 ../gui/wxpython/wxgui.py:604
 #: ../gui/wxpython/scripts/r.li.setup.py:337
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1686
 #: ../gui/wxpython/gui_modules/mapdisp.py:367
@@ -149,8 +165,8 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:1029
 #: ../gui/wxpython/gui_modules/vdigit.py:1221
 #: ../gui/wxpython/gui_modules/vdigit.py:1247
-#: ../gui/wxpython/gui_modules/gmodeler.py:1438
-#: ../gui/wxpython/gui_modules/workspace.py:984
+#: ../gui/wxpython/gui_modules/gmodeler.py:1432
+#: ../gui/wxpython/gui_modules/workspace.py:991
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5365
 #: ../gui/wxpython/gui_modules/dbm.py:165
 #: ../gui/wxpython/gui_modules/dbm.py:1407
@@ -169,18 +185,18 @@
 #: ../gui/wxpython/gui_modules/profile.py:598
 #: ../gui/wxpython/gui_modules/layertree.py:505
 #: ../gui/wxpython/gui_modules/layertree.py:536
-#: ../gui/wxpython/gui_modules/preferences.py:1071
-#: ../gui/wxpython/gui_modules/preferences.py:1948
-#: ../gui/wxpython/gui_modules/preferences.py:1977
-#: ../gui/wxpython/gui_modules/preferences.py:1986
-#: ../gui/wxpython/gui_modules/preferences.py:1996
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+#: ../gui/wxpython/gui_modules/preferences.py:1970
+#: ../gui/wxpython/gui_modules/preferences.py:1999
+#: ../gui/wxpython/gui_modules/preferences.py:2008
+#: ../gui/wxpython/gui_modules/preferences.py:2018
 #: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:466
 #: ../gui/wxpython/gis_set.py:502 ../gui/wxpython/gis_set.py:568
 #: ../gui/wxpython/gis_set.py:725
 msgid "Error"
 msgstr "Chyba"
-#: ../gui/wxpython/wxgui.py:557
+#: ../gui/wxpython/wxgui.py:589
 #, python-format
 msgid ""
 "Current location is <%(loc)s>.\n"
@@ -189,22 +205,22 @@
 "Souèasná location je <%(loc)s>.\n"
 "Souèasný mapset je <%(mapset)s>."
-#: ../gui/wxpython/wxgui.py:560 ../gui/wxpython/wxgui.py:576
+#: ../gui/wxpython/wxgui.py:592 ../gui/wxpython/wxgui.py:608
 #: ../gui/wxpython/gui_modules/ghelp.py:563
 msgid "Info"
 msgstr "Informace"
-#: ../gui/wxpython/wxgui.py:571
+#: ../gui/wxpython/wxgui.py:603
 #, python-format
 msgid "Unable to switch to mapset <%s>."
 msgstr "Nelze se pøepnout do mapsetu <%s>."
-#: ../gui/wxpython/wxgui.py:575
+#: ../gui/wxpython/wxgui.py:607
 #, python-format
 msgid "Current mapset is <%s>."
 msgstr "Souèasný mapset je <%s>."
-#: ../gui/wxpython/wxgui.py:652
+#: ../gui/wxpython/wxgui.py:676
 msgid ""
 "Current workspace is not empty. Do you want to store current settings to "
 "workspace file?"
@@ -212,19 +228,19 @@
 "Pracovní plocha není prázdná. Pøejete si ulo¾it aktuální nastavení do "
 "souboru pracovního prostøedí?"
-#: ../gui/wxpython/wxgui.py:655
+#: ../gui/wxpython/wxgui.py:679
 msgid "Create new workspace?"
 msgstr "Vytvoøit nový soubor pracovní oblasti?"
-#: ../gui/wxpython/wxgui.py:681
+#: ../gui/wxpython/wxgui.py:705
 msgid "Choose workspace file"
 msgstr "Zvolit soubor workspace"
-#: ../gui/wxpython/wxgui.py:682 ../gui/wxpython/wxgui.py:889
+#: ../gui/wxpython/wxgui.py:706 ../gui/wxpython/wxgui.py:885
 msgid "GRASS Workspace File (*.gxw)|*.gxw"
 msgstr "GRASS soubor pracovního prostøedí (*.gxw)|*.gxw"
-#: ../gui/wxpython/wxgui.py:717
+#: ../gui/wxpython/wxgui.py:741
 #, python-format
 msgid ""
 "Reading workspace file <%s> failed.\n"
@@ -233,56 +249,57 @@
 "Ètení souboru workspace <%s> selhalo. \n"
 "Neplatný soubor, nelze parsovat XML dokument."
-#: ../gui/wxpython/wxgui.py:721 ../gui/wxpython/wxgui.py:830
-#: ../gui/wxpython/wxgui.py:866
+#: ../gui/wxpython/wxgui.py:745 ../gui/wxpython/wxgui.py:862
+#: ../gui/wxpython/wxgui.py:1241
 msgid "Please wait, loading workspace..."
 msgstr "Prosím èekejte, naèítám pracovní oblast..."
-#: ../gui/wxpython/wxgui.py:822 ../gui/wxpython/menustrings.py:15
-msgid "Load map layers into layer tree"
-msgstr "Naèíst mapové vrstvy do seznamu"
-#: ../gui/wxpython/wxgui.py:850
+#: ../gui/wxpython/wxgui.py:846
 msgid "Choose GRC file to load"
 msgstr "Vyberte soubor GRC k naètení"
-#: ../gui/wxpython/wxgui.py:851
+#: ../gui/wxpython/wxgui.py:847
 msgid "Old GRASS Workspace File (*.grc)|*.grc"
 msgstr "Starý soubor pracovního prostøedí  (*.grc)|*.grc"
-#: ../gui/wxpython/wxgui.py:888
+#: ../gui/wxpython/wxgui.py:884
 msgid "Choose file to save current workspace"
 msgstr "Vybrat soubor pro ulo¾ení aktuálního workspace"
-#: ../gui/wxpython/wxgui.py:903 ../gui/wxpython/wxgui.py:919
+#: ../gui/wxpython/wxgui.py:899 ../gui/wxpython/wxgui.py:915
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr "Soubor workspace <%s> ji¾ existuje. Pøejete si tento soubor pøepsat?"
-#: ../gui/wxpython/wxgui.py:905 ../gui/wxpython/wxgui.py:922
+#: ../gui/wxpython/wxgui.py:901 ../gui/wxpython/wxgui.py:918
 #: ../gui/wxpython/menustrings.py:9
 msgid "Save workspace"
 msgstr "Ulo¾it pracovní oblast"
-#: ../gui/wxpython/wxgui.py:943
+#: ../gui/wxpython/wxgui.py:939
 msgid "Writing current settings to workspace file failed."
 msgstr "Zápis aktuálního nastavení do souboru pracovní oblasti selhalo."
-#: ../gui/wxpython/wxgui.py:954 ../gui/wxpython/gui_modules/gmodeler.py:1437
+#: ../gui/wxpython/wxgui.py:950 ../gui/wxpython/gui_modules/gmodeler.py:1431
 #: ../gui/wxpython/gui_modules/profile.py:597
 #, python-format
 msgid "Unable to open file <%s> for writing."
 msgstr "Nelze otevøít soubor <%s> pro zápis."
-#: ../gui/wxpython/wxgui.py:1132
+#: ../gui/wxpython/wxgui.py:1128
 msgid "Nothing to import. No WMS layer selected."
 msgstr "Nic  neimportováno. Nebyla vybrána WMS vrstva."
-#: ../gui/wxpython/wxgui.py:1168
+#: ../gui/wxpython/wxgui.py:1164
 msgid "Please wait, loading attribute data..."
 msgstr "Prosím èekejte, naèítám atributové data..."
-#: ../gui/wxpython/wxgui.py:1418
+#: ../gui/wxpython/wxgui.py:1233
+#, fuzzy
+msgid "Add selected map layers into layer tree"
+msgstr "Pøidat pøipojené vrstvy do stromu vrstev"
+#: ../gui/wxpython/wxgui.py:1442
 #, python-format
 msgid ""
 "Do you want to remove map layer(s)\n"
@@ -293,23 +310,23 @@
 "%s\n"
 "ze seznamu vrstev?"
-#: ../gui/wxpython/wxgui.py:1421
+#: ../gui/wxpython/wxgui.py:1445
 msgid "Do you want to remove selected map layer(s) from layer tree?"
 msgstr "Pøejete si odstranit vybranou mapovou vrstvu ze stromu vrstev?"
-#: ../gui/wxpython/wxgui.py:1425
+#: ../gui/wxpython/wxgui.py:1449
 msgid "Remove map layer"
 msgstr "Odstranit mapovou vrstvu"
-#: ../gui/wxpython/wxgui.py:1485
+#: ../gui/wxpython/wxgui.py:1509
 msgid "Quit GRASS GUI"
 msgstr "Ukonèit GRASS GUI"
-#: ../gui/wxpython/wxgui.py:1514
+#: ../gui/wxpython/wxgui.py:1538
 msgid "No map layer selected. Operation cancelled."
 msgstr "Nebyla vybrána ¾ádná mapová vrstva. Operace ukonèena."
-#: ../gui/wxpython/wxgui.py:1515 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
+#: ../gui/wxpython/wxgui.py:1539 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
 #: ../gui/wxpython/gui_modules/ghelp.py:287
 #: ../gui/wxpython/gui_modules/gcmd.py:98
 #: ../gui/wxpython/gui_modules/dbm.py:2056
@@ -318,7 +335,7 @@
 msgid "Message"
 msgstr "Zpráva"
-#: ../gui/wxpython/wxgui.py:1545
+#: ../gui/wxpython/wxgui.py:1569
 #, fuzzy
 msgid "Starting GRASS GUI..."
 msgstr "Spustit &GRASS"
@@ -425,7 +442,7 @@
 msgid "Add scalebar and north arrow"
 msgstr "Mìøítko a smìrová rù¾ice"
-#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:438
+#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:440
 msgid "Add legend"
 msgstr "Legenda"
@@ -435,7 +452,7 @@
 #: ../gui/wxpython/icons/icon.py:152
 #: ../gui/wxpython/gui_modules/histogram.py:440
-#: ../gui/wxpython/gui_modules/mapdisp.py:1179
+#: ../gui/wxpython/gui_modules/mapdisp.py:1187
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:942
 msgid "Print display"
 msgstr "Tisk kompozice displeje"
@@ -457,7 +474,7 @@
 msgstr "Profil mapy povrchu"
 #: ../gui/wxpython/icons/icon.py:161
-#: ../gui/wxpython/gui_modules/mapdisp.py:1877
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
 msgid "Add text layer"
 msgstr "Pøidat vrstvu s textem"
@@ -476,581 +493,587 @@
 msgstr "Vytvoøit nový soubor pracovní oblasti (Ctrl+N)"
 #: ../gui/wxpython/icons/icon.py:171
-msgid "Load map layers into workspace (Ctrl+L)"
-msgstr "Naèíst mapové vrstvy do pracovní oblasti (Ctrl+L)"
-#: ../gui/wxpython/icons/icon.py:173
 msgid "Open existing workspace file (Ctrl+O)"
 msgstr "Otevøít existující soubor s pracovní oblastí (Ctrl+O)"
-#: ../gui/wxpython/icons/icon.py:175
+#: ../gui/wxpython/icons/icon.py:173
 msgid "Save current workspace to file (Ctrl+S)"
 msgstr "Ulo¾it pracovní oblast do souboru (Ctrl+S)"
-#: ../gui/wxpython/icons/icon.py:177 ../gui/wxpython/menustrings.py:29
-#: ../gui/wxpython/gui_modules/gdialogs.py:1146
+#: ../gui/wxpython/icons/icon.py:175
+#, fuzzy
+msgid "Add multiple raster or vector map layers (Ctrl+L)"
+msgstr "Pøidat rastrovou vrstvu (Ctrl+R)"
+#: ../gui/wxpython/icons/icon.py:177
+#, fuzzy
+msgid "Import/link raster or vector data"
+msgstr "Import rastrových dat"
+#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_modules/gdialogs.py:1147
 msgid "Import raster data"
-#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/gui_modules/gdialogs.py:1144
+#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:148
+#: ../gui/wxpython/gui_modules/gdialogs.py:1145
 #, fuzzy
 msgid "Link external raster data"
 msgstr "Pøipojit rastrová data"
-#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:56
-#: ../gui/wxpython/gui_modules/gdialogs.py:1140
+#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_modules/gdialogs.py:1141
 msgid "Import vector data"
 msgstr "Import vektorových dat"
-#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:150
-#: ../gui/wxpython/gui_modules/gdialogs.py:1138
+#: ../gui/wxpython/icons/icon.py:185 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_modules/gdialogs.py:1139
 #, fuzzy
 msgid "Link external vector data"
 msgstr "Pøipojit vektorová data"
-#: ../gui/wxpython/icons/icon.py:185
+#: ../gui/wxpython/icons/icon.py:187
 msgid "Add raster map layer (Ctrl+R)"
-#: ../gui/wxpython/icons/icon.py:187
+#: ../gui/wxpython/icons/icon.py:189
 #, fuzzy
 msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
 msgstr "Pøidat rùzné vrstvy zalo¾ené na rastru"
-#: ../gui/wxpython/icons/icon.py:189
+#: ../gui/wxpython/icons/icon.py:191
 msgid "Add vector map layer (Ctrl+V)"
 msgstr "Pøidat vektorovou vrstvu (Ctrl+V)"
-#: ../gui/wxpython/icons/icon.py:191
+#: ../gui/wxpython/icons/icon.py:193
 #, fuzzy
 msgid "Add various vector map layers (thematic, chart...)"
 msgstr "Pøidat rùznévektorové vrstvy"
-#: ../gui/wxpython/icons/icon.py:193
+#: ../gui/wxpython/icons/icon.py:195
 msgid "Add command layer"
 msgstr "Pøidat vrstvu s pøíkazem"
-#: ../gui/wxpython/icons/icon.py:195
+#: ../gui/wxpython/icons/icon.py:197
 msgid "Add group"
 msgstr "Pøidat skupinu"
-#: ../gui/wxpython/icons/icon.py:197
+#: ../gui/wxpython/icons/icon.py:199
 msgid "Add grid or vector labels overlay"
 msgstr "Pøidat vrstvu s popisky nebo møí¾kou"
-#: ../gui/wxpython/icons/icon.py:199
+#: ../gui/wxpython/icons/icon.py:201
 msgid "Delete selected map layer"
 msgstr "Odstranit vybranou vrstvu"
-#: ../gui/wxpython/icons/icon.py:201 ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/icons/icon.py:203 ../gui/wxpython/icons/icon.py:403
 msgid "Quit"
 msgstr "Ukonèit"
-#: ../gui/wxpython/icons/icon.py:203
+#: ../gui/wxpython/icons/icon.py:205
 msgid "Show attribute table"
 msgstr "Zobrazit atributovou tabulku"
-#: ../gui/wxpython/icons/icon.py:205
+#: ../gui/wxpython/icons/icon.py:207
 #, fuzzy
 msgid "Edit vector maps"
 msgstr "Export vektorové mapy"
-#: ../gui/wxpython/icons/icon.py:207
+#: ../gui/wxpython/icons/icon.py:209
 msgid "Add RGB map layer"
 msgstr "Pøidat vrstvu RGB"
-#: ../gui/wxpython/icons/icon.py:209
+#: ../gui/wxpython/icons/icon.py:211
 msgid "Add HIS map layer"
 msgstr "Pøidat vrstvu HIS"
-#: ../gui/wxpython/icons/icon.py:211
+#: ../gui/wxpython/icons/icon.py:213
 msgid "Add shaded relief map layer"
 msgstr "Pøidat mapu stínovaného reliéfu"
-#: ../gui/wxpython/icons/icon.py:213
+#: ../gui/wxpython/icons/icon.py:215
 msgid "Add raster flow arrows"
 msgstr "Pøidat rastrovou mapu smìrù odtokù"
-#: ../gui/wxpython/icons/icon.py:215
+#: ../gui/wxpython/icons/icon.py:217
 msgid "Add raster cell numbers"
 msgstr "Pøidat èísla kategorie rastrové buòky"
-#: ../gui/wxpython/icons/icon.py:217
+#: ../gui/wxpython/icons/icon.py:219
 #, fuzzy
 msgid "Add thematic area (choropleth) map layer"
 msgstr "Pøidat tématickou vrstvu s grafem"
-#: ../gui/wxpython/icons/icon.py:219
+#: ../gui/wxpython/icons/icon.py:221
 msgid "Add thematic chart layer"
-#: ../gui/wxpython/icons/icon.py:221
+#: ../gui/wxpython/icons/icon.py:223
 msgid "Add grid layer"
 msgstr "Pøidat vrstvu s møí¾kou (grid)"
-#: ../gui/wxpython/icons/icon.py:223
+#: ../gui/wxpython/icons/icon.py:225
 msgid "Add geodesic line layer"
 msgstr "Pøidat vrstvu s geodetickými èárami"
-#: ../gui/wxpython/icons/icon.py:225
+#: ../gui/wxpython/icons/icon.py:227
 msgid "Add rhumbline layer"
 msgstr "Pøidat vrstvu s rovnobì¾kami"
-#: ../gui/wxpython/icons/icon.py:227
+#: ../gui/wxpython/icons/icon.py:229
 msgid "Add labels"
 msgstr "Pøidat vrstvu s popisky"
-#: ../gui/wxpython/icons/icon.py:229
+#: ../gui/wxpython/icons/icon.py:231
 msgid "Add 3D raster map layer"
 msgstr "Pøidat 3D rastrovou vrstvu"
-#: ../gui/wxpython/icons/icon.py:230
+#: ../gui/wxpython/icons/icon.py:232
 msgid "Note that 3D raster data are rendered only in 3D view mode"
 msgstr "3D rastrová data mohou být zobrazena pouze v 3D módu"
-#: ../gui/wxpython/icons/icon.py:232
+#: ../gui/wxpython/icons/icon.py:234
 msgid "Show GUI settings"
 msgstr "Ukázat nastavení GUI"
-#: ../gui/wxpython/icons/icon.py:234
+#: ../gui/wxpython/icons/icon.py:236
 #, fuzzy
 msgid "Graphical Modeler"
 msgstr "Grafické modelování"
-#: ../gui/wxpython/icons/icon.py:236
+#: ../gui/wxpython/icons/icon.py:238
 #: ../gui/wxpython/gui_modules/gdialogs.py:416
 msgid "Set options"
 msgstr "Nastavit volby"
-#: ../gui/wxpython/icons/icon.py:238
+#: ../gui/wxpython/icons/icon.py:240 ../gui/wxpython/menustrings.py:198
 #, fuzzy
-msgid "Hardcopy Map Ouput Utility"
+msgid "Hardcopy Map Output Utility"
 msgstr "Nástroj pro tvorbu mapových výstupù ve formátu PostScript."
-#: ../gui/wxpython/icons/icon.py:240
+#: ../gui/wxpython/icons/icon.py:242
 #, fuzzy
 msgid "Raster Map Calculator"
 msgstr "3D rastrový kalkulátor"
-#: ../gui/wxpython/icons/icon.py:244
+#: ../gui/wxpython/icons/icon.py:246
 msgid "Digitize new point"
 msgstr "Pøidat nový bod"
-#: ../gui/wxpython/icons/icon.py:245 ../gui/wxpython/icons/icon.py:254
-#: ../gui/wxpython/icons/icon.py:257
+#: ../gui/wxpython/icons/icon.py:247 ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:259
 msgid "Left: new point"
 msgstr "Levé: nový bod"
-#: ../gui/wxpython/icons/icon.py:247
+#: ../gui/wxpython/icons/icon.py:249
 msgid "Digitize new line"
 msgstr "Pøidat novou linii"
-#: ../gui/wxpython/icons/icon.py:248 ../gui/wxpython/icons/icon.py:251
-#: ../gui/wxpython/icons/icon.py:275
+#: ../gui/wxpython/icons/icon.py:250 ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:277
 #, fuzzy
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
 msgstr "Levé: nový bod; Støední: Zpìt poslední bod; Pravé: uzavøít linii"
-#: ../gui/wxpython/icons/icon.py:250
+#: ../gui/wxpython/icons/icon.py:252
 msgid "Digitize new boundary"
 msgstr "Pøidat novou hranici"
-#: ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:255
 msgid "Digitize new centroid"
 msgstr "Pøidat nový centroid"
-#: ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:258
 msgid ""
 "Digitize new area (composition of boundaries without category and one "
 "centroid with category)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:259
+#: ../gui/wxpython/icons/icon.py:261
 msgid "Add new vertex"
 msgstr "Pøidat nový opìrný bod"
-#: ../gui/wxpython/icons/icon.py:260 ../gui/wxpython/icons/icon.py:263
-#: ../gui/wxpython/icons/icon.py:266 ../gui/wxpython/icons/icon.py:278
-#: ../gui/wxpython/icons/icon.py:281 ../gui/wxpython/icons/icon.py:284
-#: ../gui/wxpython/icons/icon.py:289 ../gui/wxpython/icons/icon.py:296
+#: ../gui/wxpython/icons/icon.py:262 ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:268 ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:283 ../gui/wxpython/icons/icon.py:286
+#: ../gui/wxpython/icons/icon.py:291 ../gui/wxpython/icons/icon.py:298
 #, fuzzy
 msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
 msgstr "Levé: Vybrat; Støední: zru¹it výbìr; Pravé: Potvrzení výbìru"
-#: ../gui/wxpython/icons/icon.py:262
-#: ../gui/wxpython/gui_modules/toolbars.py:782
+#: ../gui/wxpython/icons/icon.py:264
+#: ../gui/wxpython/gui_modules/toolbars.py:729
 msgid "Copy categories"
 msgstr "Kopírovat kategorie"
-#: ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:267
 msgid "Delete feature(s)"
 msgstr "Odstranit prvek(y)"
-#: ../gui/wxpython/icons/icon.py:268
+#: ../gui/wxpython/icons/icon.py:270
 msgid "Display/update attributes"
 msgstr "Zobrazit/aktualizovat atributy"
-#: ../gui/wxpython/icons/icon.py:269 ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/icons/icon.py:271 ../gui/wxpython/icons/icon.py:274
 msgid "Left: Select"
 msgstr "Levé: Vybrat"
-#: ../gui/wxpython/icons/icon.py:271
+#: ../gui/wxpython/icons/icon.py:273
 msgid "Display/update categories"
 msgstr "Zobrazit/aktualizovat kategorie"
-#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/icons/icon.py:276
 msgid "Edit line/boundary"
 msgstr "Upravit linii/hranici"
-#: ../gui/wxpython/icons/icon.py:277
+#: ../gui/wxpython/icons/icon.py:279
 msgid "Move feature(s)"
 msgstr "Posun prvku(ù)"
-#: ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:282
 msgid "Move vertex"
 msgstr "Pøemístit opìrný bod"
-#: ../gui/wxpython/icons/icon.py:283
+#: ../gui/wxpython/icons/icon.py:285
 msgid "Remove vertex"
 msgstr "Odstranit opìrný bod"
-#: ../gui/wxpython/icons/icon.py:286
-#: ../gui/wxpython/gui_modules/toolbars.py:857
+#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/gui_modules/toolbars.py:804
 msgid "Digitization settings"
 msgstr "Nastavení digitalizace"
-#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/icons/icon.py:290
 msgid "Split line/boundary"
 msgstr "rozdìlit linii/hranici"
-#: ../gui/wxpython/icons/icon.py:291
+#: ../gui/wxpython/icons/icon.py:293
 #, fuzzy
 msgid "Quit digitizer"
 msgstr "Vektorová digitalizace"
-#: ../gui/wxpython/icons/icon.py:292
+#: ../gui/wxpython/icons/icon.py:294
 msgid "Quit digitizer and save changes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:294
+#: ../gui/wxpython/icons/icon.py:296
 msgid "Additional tools (copy, flip, connect, etc.)"
 msgstr "Dal¹í nástroje (kopírovat, otoèit, spojit, atd.)"
-#: ../gui/wxpython/icons/icon.py:298
+#: ../gui/wxpython/icons/icon.py:300
 msgid "Undo"
 msgstr "Zpìt"
-#: ../gui/wxpython/icons/icon.py:299
+#: ../gui/wxpython/icons/icon.py:301
 msgid "Undo previous changes"
 msgstr "Zpìt pøedchozí zmìny"
-#: ../gui/wxpython/icons/icon.py:303
+#: ../gui/wxpython/icons/icon.py:305
 msgid "Draw/re-draw profile"
 msgstr "Vy/pøe-kreslit profil"
-#: ../gui/wxpython/icons/icon.py:305
+#: ../gui/wxpython/icons/icon.py:307
 msgid "Draw transect in map display window to profile"
 msgstr "Vykreslit transekt profilu v displeji "
-#: ../gui/wxpython/icons/icon.py:307
+#: ../gui/wxpython/icons/icon.py:309
 msgid "Profile options"
 msgstr "Nastavení profilu"
-#: ../gui/wxpython/icons/icon.py:309
+#: ../gui/wxpython/icons/icon.py:311
 #, fuzzy
 msgid "Save profile data to CSV file"
 msgstr "Ulo¾it profilová data do souboru csv"
-#: ../gui/wxpython/icons/icon.py:311
+#: ../gui/wxpython/icons/icon.py:313
 #, fuzzy
 msgid "Quit Profile Analysis Tool"
 msgstr "Analýza profilu"
-#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/icons/icon.py:317
 msgid "Set GCP"
 msgstr "Nastavit GCP (vlicovací body)"
-#: ../gui/wxpython/icons/icon.py:316
+#: ../gui/wxpython/icons/icon.py:318
 msgid "Define GCP (Ground Control Points)"
 msgstr "Definovat GCP (vlicovací body)"
-#: ../gui/wxpython/icons/icon.py:318 ../gui/wxpython/menustrings.py:186
+#: ../gui/wxpython/icons/icon.py:320 ../gui/wxpython/menustrings.py:186
 msgid "Georectify"
 msgstr "Georektifikace"
-#: ../gui/wxpython/icons/icon.py:320
+#: ../gui/wxpython/icons/icon.py:322
 msgid "Recalculate RMS error"
 msgstr "pøepoèítat RMS (støední kvadratickou chybu)"
-#: ../gui/wxpython/icons/icon.py:322
+#: ../gui/wxpython/icons/icon.py:324
 msgid "Save GCPs to POINTS file"
 msgstr "Ulo¾it vlicovací body do souboru POINTS"
-#: ../gui/wxpython/icons/icon.py:324
+#: ../gui/wxpython/icons/icon.py:326
 msgid "Add new GCP"
 msgstr "Pøidat nový vlicovací bod"
-#: ../gui/wxpython/icons/icon.py:326
+#: ../gui/wxpython/icons/icon.py:328
 msgid "Delete selected GCP"
 msgstr "Odstranit vybrané vlicovací body"
-#: ../gui/wxpython/icons/icon.py:328
+#: ../gui/wxpython/icons/icon.py:330
 msgid "Clear selected GCP"
 msgstr "Vymazat vybrané vlicovací bod"
-#: ../gui/wxpython/icons/icon.py:330
+#: ../gui/wxpython/icons/icon.py:332
 msgid "Reload GCPs from POINTS file"
 msgstr "Znovu naèíst vlicovací body z vybraného souboru POINTS"
-#: ../gui/wxpython/icons/icon.py:332
+#: ../gui/wxpython/icons/icon.py:334
 #, fuzzy
 msgid "Quit georectification"
 msgstr "Ukonèit nástroj pro georektifikaci"
-#: ../gui/wxpython/icons/icon.py:334
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1289
+#: ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1504
 #: ../gui/wxpython/gui_modules/gselect.py:1070
 msgid "Settings"
 msgstr "Nastavení"
-#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/icons/icon.py:337
 msgid "Settings dialog for georectification tool"
 msgstr "Nastavení nástroje pro georektifikaci"
-#: ../gui/wxpython/icons/icon.py:339
+#: ../gui/wxpython/icons/icon.py:341
 msgid "Switch to view control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:340
+#: ../gui/wxpython/icons/icon.py:342
 msgid "Change view settings"
 msgstr "Zmìnit nastavení zobrazení"
-#: ../gui/wxpython/icons/icon.py:342
+#: ../gui/wxpython/icons/icon.py:344
 msgid "Switch to surface (raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:343
+#: ../gui/wxpython/icons/icon.py:345
 msgid "Change surface (loaded raster maps) settings"
 msgstr "Zmìnit nastavení povrchu (naètené rastrové mapy)"
-#: ../gui/wxpython/icons/icon.py:345
+#: ../gui/wxpython/icons/icon.py:347
 msgid "Switch to vector (2D/3D) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:346
+#: ../gui/wxpython/icons/icon.py:348
 msgid "Change 2D/3D vector settings"
 msgstr "Zmìnit nastavení 2D/3D vektoru"
-#: ../gui/wxpython/icons/icon.py:348
+#: ../gui/wxpython/icons/icon.py:350
 msgid "Switch to volume (3D raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:349
+#: ../gui/wxpython/icons/icon.py:351
 msgid "Change volume (loaded 3D raster maps) settings"
 msgstr "Zmìnit nastavení  3D rastrù"
-#: ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:353
 msgid "Switch to lighting control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:352
+#: ../gui/wxpython/icons/icon.py:354
 msgid "Change lighting settings"
 msgstr "Zmìnit nastavení osvìtlení"
-#: ../gui/wxpython/icons/icon.py:354
+#: ../gui/wxpython/icons/icon.py:356
 msgid "Switch to fringe control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:355
+#: ../gui/wxpython/icons/icon.py:357
 msgid "Switch on/off fringes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:359
 msgid "3D view mode tools"
 msgstr "Nástroje 3D zobrazení"
-#: ../gui/wxpython/icons/icon.py:358
+#: ../gui/wxpython/icons/icon.py:360
 msgid "Show/hide 3D view mode settings dialog"
 msgstr "Ukázat /schovat nastavení 3D zobrazení"
-#: ../gui/wxpython/icons/icon.py:360
+#: ../gui/wxpython/icons/icon.py:362
 msgid "Quit 3D view mode"
 msgstr "Ukonèit 3D zobrazení"
-#: ../gui/wxpython/icons/icon.py:361
+#: ../gui/wxpython/icons/icon.py:363
 msgid "Switch back to 2D view mode"
 msgstr "Zpátky na 2D zobrazení"
-#: ../gui/wxpython/icons/icon.py:365
+#: ../gui/wxpython/icons/icon.py:367
 msgid "Create new model (Ctrl+N)"
 msgstr "Vytvoøit nový model (Ctrl+N)"
-#: ../gui/wxpython/icons/icon.py:367
+#: ../gui/wxpython/icons/icon.py:369
 msgid "Load model from file (Ctrl+O)"
 msgstr "Naèíst smodel ze souboru (Ctrl+O)"
-#: ../gui/wxpython/icons/icon.py:369
+#: ../gui/wxpython/icons/icon.py:371
 msgid "Save current model to file (Ctrl+S)"
 msgstr "Ulo¾it model do souboru (Ctrl+S)"
-#: ../gui/wxpython/icons/icon.py:371 ../gui/wxpython/menustrings.py:878
+#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:878
 msgid "Export model to image"
 msgstr "Export modelu do obrázku"
-#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:880
+#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:880
 msgid "Export model to Python script"
 msgstr "Exportovat model do Python skriptu"
-#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:888
+#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:888
 msgid "Add action (GRASS module) to model"
 msgstr "Pøidat akci do modelu"
-#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:890
 msgid "Add data item to model"
 msgstr "Pøidat data do modelu"
-#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:892
+#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:892
 msgid "Define relation between data and action items"
 msgstr "Definovat vztah mezi daty a akcemi"
-#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:190
+#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:190
 #: ../gui/wxpython/menustrings.py:903
 msgid "Run model"
 msgstr "Spustit model"
-#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:905
+#: ../gui/wxpython/icons/icon.py:385 ../gui/wxpython/menustrings.py:905
 msgid "Validate model"
 msgstr "Vyhodnotit model"
-#: ../gui/wxpython/icons/icon.py:385
+#: ../gui/wxpython/icons/icon.py:387
 msgid "Show modeler settings"
 msgstr "Ukázat nastavení modelování"
-#: ../gui/wxpython/icons/icon.py:387
+#: ../gui/wxpython/icons/icon.py:389
 msgid "Show model properties"
 msgstr "Ukázat vlastnosti modelování"
-#: ../gui/wxpython/icons/icon.py:389
+#: ../gui/wxpython/icons/icon.py:391
 msgid "Manage model variables"
 msgstr "Spravovat promìnné modelu"
-#: ../gui/wxpython/icons/icon.py:391
+#: ../gui/wxpython/icons/icon.py:393
 msgid "Redraw model canvas"
 msgstr "Pøekreslit okno modelování"
-#: ../gui/wxpython/icons/icon.py:393
-#: ../gui/wxpython/gui_modules/gmodeler.py:677
+#: ../gui/wxpython/icons/icon.py:395
+#: ../gui/wxpython/gui_modules/gmodeler.py:671
 msgid "Quit Graphical Modeler"
 msgstr "Ukonèit Grafické modelování"
-#: ../gui/wxpython/icons/icon.py:397
+#: ../gui/wxpython/icons/icon.py:399
 msgid "Select font"
 msgstr "Zvolit font"
-#: ../gui/wxpython/icons/icon.py:399
+#: ../gui/wxpython/icons/icon.py:401
 #, fuzzy
 msgid "Show manual"
 msgstr "Steinerùv strom"
-#: ../gui/wxpython/icons/icon.py:405
+#: ../gui/wxpython/icons/icon.py:407
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:407
+#: ../gui/wxpython/icons/icon.py:409
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:409
+#: ../gui/wxpython/icons/icon.py:411
 #, fuzzy
 msgid "Generate PostScript output"
-#: ../gui/wxpython/icons/icon.py:411
+#: ../gui/wxpython/icons/icon.py:413
 #, fuzzy
 msgid "Generate PDF output"
 msgstr "Vytvoøit bodovou vrstvu"
-#: ../gui/wxpython/icons/icon.py:413
+#: ../gui/wxpython/icons/icon.py:415
 #: ../gui/wxpython/gui_modules/histogram.py:432
-#: ../gui/wxpython/gui_modules/mapdisp.py:1171
+#: ../gui/wxpython/gui_modules/mapdisp.py:1179
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:934
 msgid "Page setup"
 msgstr "Nastavení stránky"
-#: ../gui/wxpython/icons/icon.py:414
+#: ../gui/wxpython/icons/icon.py:416
 msgid "Specify paper size, margins and orientation"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:416
+#: ../gui/wxpython/icons/icon.py:418
 msgid "Full extent"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:417
+#: ../gui/wxpython/icons/icon.py:419
 #, fuzzy
 msgid "Zoom to full extent"
 msgstr "Zvìt¹it podle výchozího regionu"
-#: ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:421
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1951
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2006
 #, fuzzy
 msgid "Map frame"
 msgstr "Mìøítko mapy"
-#: ../gui/wxpython/icons/icon.py:420
+#: ../gui/wxpython/icons/icon.py:422
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:320
+#: ../gui/wxpython/icons/icon.py:424
+#: ../gui/wxpython/gui_modules/nviz_tools.py:465
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2476
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:669
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:730
 msgid "Raster map"
 msgstr "Rastrová mapa"
-#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/icons/icon.py:425
 #, fuzzy
 msgid "Add raster map"
 msgstr "Pøidat 3D rastrovou mapu"
-#: ../gui/wxpython/icons/icon.py:425
-#: ../gui/wxpython/gui_modules/nviz_tools.py:629
+#: ../gui/wxpython/icons/icon.py:427
+#: ../gui/wxpython/gui_modules/nviz_tools.py:839
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3920
 msgid "Vector map"
 msgstr "Vektorová mapa"
-#: ../gui/wxpython/icons/icon.py:426
+#: ../gui/wxpython/icons/icon.py:428
 #, fuzzy
 msgid "Add vector map"
 msgstr "vektorová mapa"
-#: ../gui/wxpython/icons/icon.py:428
+#: ../gui/wxpython/icons/icon.py:430
 #, fuzzy
 msgid "Delete selected object"
 msgstr "Odstranit vybranou lokaci"
-#: ../gui/wxpython/icons/icon.py:430
+#: ../gui/wxpython/icons/icon.py:432
 #, fuzzy
 msgid "Show preview"
 msgstr "Zobrazit møí¾ku"
-#: ../gui/wxpython/icons/icon.py:432
+#: ../gui/wxpython/icons/icon.py:434
 #, fuzzy
 msgid "Quit Hardcopy Map Utility"
-#: ../gui/wxpython/icons/icon.py:434
+#: ../gui/wxpython/icons/icon.py:436
 #, fuzzy
 msgid "Add text"
-#: ../gui/wxpython/icons/icon.py:436
+#: ../gui/wxpython/icons/icon.py:438
 #, fuzzy
 msgid "Add map info"
 msgstr "Pøidat mapové prvky"
-#: ../gui/wxpython/icons/icon.py:440
+#: ../gui/wxpython/icons/icon.py:442
 #, fuzzy
 msgid "Add scale bar"
 msgstr "Pøidat vrstvu"
@@ -1075,79 +1098,79 @@
 msgid "Kriging"
 msgstr "Krigování"
-#: ../gui/wxpython/scripts/vkrige.py:109
-#: ../gui/wxpython/gui_modules/gmodeler.py:575
-#: ../gui/wxpython/gui_modules/menuform.py:1165
+#: ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gui_modules/gmodeler.py:569
+#: ../gui/wxpython/gui_modules/menuform.py:1160
 msgid "Command output"
 msgstr "Výstup pøíkazù"
-#: ../gui/wxpython/scripts/vkrige.py:115 ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/scripts/vkrige.py:114 ../gui/wxpython/menustrings.py:390
 msgid "Output"
 msgstr "Výstup"
-#: ../gui/wxpython/scripts/vkrige.py:119
+#: ../gui/wxpython/scripts/vkrige.py:118
 msgid "Name for the output raster map:"
 msgstr "Název výstupní rastrové mapy:"
-#: ../gui/wxpython/scripts/vkrige.py:127
+#: ../gui/wxpython/scripts/vkrige.py:126
 msgid "Export variance map as well: "
 msgstr "Exporovat také mapu rozdílu:"
-#: ../gui/wxpython/scripts/vkrige.py:140
+#: ../gui/wxpython/scripts/vkrige.py:139
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:229
 #: ../gui/wxpython/gui_modules/vclean.py:144
-#: ../gui/wxpython/gui_modules/gmodeler.py:3309
-#: ../gui/wxpython/gui_modules/gdialogs.py:985
-#: ../gui/wxpython/gui_modules/preferences.py:1533
+#: ../gui/wxpython/gui_modules/gmodeler.py:3303
+#: ../gui/wxpython/gui_modules/gdialogs.py:986
+#: ../gui/wxpython/gui_modules/preferences.py:1555
 msgid "Allow output files to overwrite existing files"
 msgstr "Povolit pøepsání existujících souborù"
-#: ../gui/wxpython/scripts/vkrige.py:153
+#: ../gui/wxpython/scripts/vkrige.py:152
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:133
 #: ../gui/wxpython/gui_modules/ghelp.py:223
 #: ../gui/wxpython/gui_modules/vclean.py:165
-#: ../gui/wxpython/gui_modules/gmodeler.py:3426
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/gmodeler.py:3420
+#: ../gui/wxpython/gui_modules/menuform.py:828
 msgid "&Run"
 msgstr "&Spustit"
-#: ../gui/wxpython/scripts/vkrige.py:268
+#: ../gui/wxpython/scripts/vkrige.py:267
 msgid "Kriging Module"
 msgstr "modul Krigování"
-#: ../gui/wxpython/scripts/vkrige.py:272
+#: ../gui/wxpython/scripts/vkrige.py:271
 msgid "Ready."
 msgstr "Pøipraven."
-#: ../gui/wxpython/scripts/vkrige.py:296
+#: ../gui/wxpython/scripts/vkrige.py:295
 msgid "Variogram fitting"
 msgstr "Pøizpùsobení variogramu"
-#: ../gui/wxpython/scripts/vkrige.py:306
+#: ../gui/wxpython/scripts/vkrige.py:305
 msgid "Plot/refresh variogram"
 msgstr "Vykreslit variogram"
-#: ../gui/wxpython/scripts/vkrige.py:317
+#: ../gui/wxpython/scripts/vkrige.py:316
 msgid ":"
 msgstr ":"
-#: ../gui/wxpython/scripts/vkrige.py:342
+#: ../gui/wxpython/scripts/vkrige.py:341
 msgid "Kriging techniques"
 msgstr "Techniky krigování"
-#: ../gui/wxpython/scripts/vkrige.py:356
+#: ../gui/wxpython/scripts/vkrige.py:355
 msgid "Block size:"
 msgstr "Velikost bloku:"
-#: ../gui/wxpython/scripts/vkrige.py:389
+#: ../gui/wxpython/scripts/vkrige.py:388
 msgid "Auto-fit variogram"
 msgstr "Automatické pøizpùsobení variogramu"
-#: ../gui/wxpython/scripts/vkrige.py:413
+#: ../gui/wxpython/scripts/vkrige.py:412
 msgid "Model: "
 msgstr "Model:"
-#: ../gui/wxpython/scripts/vkrige.py:497
+#: ../gui/wxpython/scripts/vkrige.py:496
 msgid "Work in progress! No functionality provided."
 msgstr "Na vývoji se pracuje! Zatím ¾ádnou funkci nemá."
@@ -1234,8 +1257,9 @@
 msgid "Workspace"
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:17
 #: ../gui/wxpython/menustrings.py:867
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
 msgid "New"
 msgstr "Nový"
@@ -1272,47 +1296,52 @@
 msgstr "Zavøít soubor pracovního prostøedí"
 #: ../gui/wxpython/menustrings.py:14
-msgid "Load map layers"
-msgstr "Naèíst mapové vrstvy"
-#: ../gui/wxpython/menustrings.py:16
 msgid "Load GRC file (Tcl/Tk GUI)"
 msgstr "Naèíst soubor GRC (Tcl/Tk grafické prostøedí)"
-#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/menustrings.py:15
 msgid "Load map layers from GRC file to layer tree"
 msgstr "Naèíst mapové vrstvy ze souboru GRD do stromu vrstev"
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:16
 #, fuzzy
 msgid "Map display"
 msgstr "zobrazit"
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:18
 #, fuzzy
 msgid "Open new map display window"
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:19
 #, fuzzy
 msgid "Close current"
 msgstr "Zabalit v¹echny kromì aktuální mapset"
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:20
 #, fuzzy
 msgid "Close current map display window"
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:21
 #, fuzzy
 msgid "Close all"
 msgstr "Zavøít dialog "
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:22
 #, fuzzy
 msgid "Close all open map display windows"
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+#, fuzzy
+msgid "Add multiple raster or vector map layers to current display"
 #: ../gui/wxpython/menustrings.py:25
 #, fuzzy
 msgid "Add raster"
@@ -1937,6 +1966,7 @@
 msgstr "Pøejmenuje data v aktuálním mapsetu"
 #: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2640
 msgid "Delete"
 msgstr "Smazat"
@@ -2067,11 +2097,6 @@
 "Jednoduchý nástroj pro pøevod zamìøení a mìøení vzdáleností do souøadnic a "
 "naopak."
-#: ../gui/wxpython/menustrings.py:198
-#, fuzzy
-msgid "Hardcopy Map Output Utility"
-msgstr "Nástroj pro tvorbu mapových výstupù ve formátu PostScript."
 #: ../gui/wxpython/menustrings.py:199
 #, fuzzy
 msgid "Launch Hardcopy Map Output Utility"
@@ -2500,9 +2525,8 @@
 msgstr "Nalezne nejbli¾¹í body mezi objekty ze dvou rastrových map."
 #: ../gui/wxpython/menustrings.py:298
-#: ../gui/wxpython/gui_modules/nviz_tools.py:351
-#: ../gui/wxpython/gui_modules/nviz_tools.py:549
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:602
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1238
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3049
 msgid "Mask"
 msgstr "Maska"
@@ -2672,7 +2696,7 @@
 msgstr "Urèí smìr povrchového odtoku na rastrovém modelu terénu."
 #: ../gui/wxpython/menustrings.py:330
-#: ../gui/wxpython/gui_modules/layertree.py:803
+#: ../gui/wxpython/gui_modules/layertree.py:799
 msgid "Shaded relief"
 msgstr "Mapa stínovaného reliéfu"
@@ -5095,7 +5119,7 @@
 msgstr "Naèíst model ze souboru"
 #: ../gui/wxpython/menustrings.py:872
-#: ../gui/wxpython/gui_modules/gmodeler.py:828
+#: ../gui/wxpython/gui_modules/gmodeler.py:822
 msgid "Save model"
 msgstr "Ulo¾it model"
@@ -5124,7 +5148,7 @@
 msgstr "Zavøít okno modelování"
 #: ../gui/wxpython/menustrings.py:885
-#: ../gui/wxpython/gui_modules/gmodeler.py:3003
+#: ../gui/wxpython/gui_modules/gmodeler.py:2997
 msgid "Modeler settings"
 msgstr "Nastavení modelování"
@@ -5169,7 +5193,7 @@
 msgstr "Odstranit data/akce z modelu"
 #: ../gui/wxpython/menustrings.py:899
-#: ../gui/wxpython/gui_modules/gmodeler.py:3288
+#: ../gui/wxpython/gui_modules/gmodeler.py:3282
 msgid "Model properties"
 msgstr "Vlastnosti modelu"
@@ -5312,8 +5336,8 @@
 msgstr "GRASS GIS HIstogram obrazu nebo rastrové mapy"
 #: ../gui/wxpython/gui_modules/histogram.py:332
-#: ../gui/wxpython/gui_modules/wxnviz.py:227
-#: ../gui/wxpython/gui_modules/wxnviz.py:238
+#: ../gui/wxpython/gui_modules/wxnviz.py:240
+#: ../gui/wxpython/gui_modules/wxnviz.py:251
 #, python-format
 msgid "Raster map <%s> not found"
 msgstr "Rastrová mapa <%s> nebyla nalezena."
@@ -5323,16 +5347,16 @@
 msgstr "vybrat font pro text histogramu"
 #: ../gui/wxpython/gui_modules/histogram.py:403
-#: ../gui/wxpython/gui_modules/mapdisp.py:1142
+#: ../gui/wxpython/gui_modules/mapdisp.py:1150
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:905
-#: ../gui/wxpython/gui_modules/gmodeler.py:1042
+#: ../gui/wxpython/gui_modules/gmodeler.py:1036
 msgid "Choose a file name to save the image (no need to add extension)"
 msgstr ""
 "vyberte jméno souboru pro ulo¾ení obrázku (není potøeba zadávat pøíponu "
 "soubru)"
 #: ../gui/wxpython/gui_modules/histogram.py:436
-#: ../gui/wxpython/gui_modules/mapdisp.py:1175
+#: ../gui/wxpython/gui_modules/mapdisp.py:1183
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:938
 msgid "Print preview"
 msgstr "Náhled tisku"
@@ -5366,15 +5390,15 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#: ../gui/wxpython/gui_modules/gdialogs.py:1005
+#: ../gui/wxpython/gui_modules/gdialogs.py:1006
 msgid "Command dialog"
 msgstr "Dialog pøíkazu"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:138
-#: ../gui/wxpython/gui_modules/gdialogs.py:1161
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
-#: ../gui/wxpython/gui_modules/gdialogs.py:1168
-#: ../gui/wxpython/gui_modules/gdialogs.py:1170
+#: ../gui/wxpython/gui_modules/gdialogs.py:1162
+#: ../gui/wxpython/gui_modules/gdialogs.py:1164
+#: ../gui/wxpython/gui_modules/gdialogs.py:1169
+#: ../gui/wxpython/gui_modules/gdialogs.py:1171
 #, python-format
 msgid "Open %s dialog"
 msgstr "Otevøít %s dialog "
@@ -5384,7 +5408,6 @@
 msgstr "Ulo¾it výraz do souboru"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#: ../gui/wxpython/gui_modules/gdialogs.py:739
 msgid "&Load"
 msgstr "&Nahrát"
@@ -5544,6 +5567,40 @@
 msgid "Unknow tag"
 msgstr "Neznámý"
+#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:47
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:97
+#, fuzzy, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr "Rastrová mapa <%s> nebyla nalezena."
+#: ../gui/wxpython/gui_modules/gpyshell.py:104
+msgid "Raster map <%s> added"
+#: ../gui/wxpython/gui_modules/gpyshell.py:106
+msgid "Vector map <%s> added"
+msgstr "Vektorové mapa <%s> je 3D"
 #: ../gui/wxpython/gui_modules/dbm_dialogs.py:67
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2998
 msgid "Database connection is not defined in DB file."
@@ -5608,7 +5665,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2279
 #: ../gui/wxpython/gui_modules/dbm.py:2387
 #: ../gui/wxpython/gui_modules/dbm.py:2642
-#: ../gui/wxpython/gui_modules/gdialogs.py:1352
+#: ../gui/wxpython/gui_modules/gdialogs.py:1353
 msgid "Layer"
 msgstr "Vrstva"
@@ -5642,16 +5699,16 @@
 msgstr "Typ mapy pro georektifikaci"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:328
-#: ../gui/wxpython/gui_modules/gmodeler.py:3560
+#: ../gui/wxpython/gui_modules/gmodeler.py:3554
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2028
-#: ../gui/wxpython/gui_modules/layertree.py:791
+#: ../gui/wxpython/gui_modules/layertree.py:787
 msgid "raster"
 msgstr "rastrová data"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3561
+#: ../gui/wxpython/gui_modules/gmodeler.py:3555
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2029
-#: ../gui/wxpython/gui_modules/layertree.py:812
+#: ../gui/wxpython/gui_modules/layertree.py:808
 msgid "vector"
@@ -5746,12 +5803,12 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1110
-#: ../gui/wxpython/gui_modules/toolbars.py:416
+#: ../gui/wxpython/gui_modules/toolbars.py:398
 msgid "source"
 msgstr "zdroj"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1112
 msgid "target"
 msgstr "cíl"
@@ -5955,14 +6012,14 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2371
 #: ../gui/wxpython/gui_modules/profile.py:1033
 #: ../gui/wxpython/gui_modules/profile.py:1388
-#: ../gui/wxpython/gui_modules/preferences.py:961
+#: ../gui/wxpython/gui_modules/preferences.py:966
 msgid "Apply changes for the current session"
 msgstr "Aplikovat zmìny jen pro toto spu¹tìní"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2373
 #: ../gui/wxpython/gui_modules/profile.py:1038
 #: ../gui/wxpython/gui_modules/profile.py:1390
-#: ../gui/wxpython/gui_modules/preferences.py:963
+#: ../gui/wxpython/gui_modules/preferences.py:968
 msgid ""
 "Apply and save changes to user settings file (default for next sessions)"
 msgstr ""
@@ -5971,7 +6028,7 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2375
 #: ../gui/wxpython/gui_modules/ogc_services.py:77
-#: ../gui/wxpython/gui_modules/gdialogs.py:995
+#: ../gui/wxpython/gui_modules/gdialogs.py:996
 msgid "Close dialog"
@@ -6004,12 +6061,14 @@
 msgstr "Nastavení symbolu"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2438
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1307
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:809
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1522
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:326
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:547
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3098
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3203
-#: ../gui/wxpython/gui_modules/preferences.py:1683
+#: ../gui/wxpython/gui_modules/preferences.py:1705
 msgid "Color:"
 msgstr "Barva:"
@@ -6085,16 +6144,16 @@
 msgstr "Nastavení Správce vlicovacích bodù ulo¾eno do souboru '%s'."
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:90
-#: ../gui/wxpython/gui_modules/mapdisp.py:771
-#: ../gui/wxpython/gui_modules/mapdisp.py:803
-#: ../gui/wxpython/gui_modules/mapdisp.py:874
-#: ../gui/wxpython/gui_modules/mapdisp.py:1027
+#: ../gui/wxpython/gui_modules/mapdisp.py:779
+#: ../gui/wxpython/gui_modules/mapdisp.py:811
+#: ../gui/wxpython/gui_modules/mapdisp.py:882
+#: ../gui/wxpython/gui_modules/mapdisp.py:1035
 msgid "Projection not defined (check the settings)"
 msgstr "Projekce není definována (zkontrolujte nastavení)"
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:107
-#: ../gui/wxpython/gui_modules/mapdisp.py:918
-#: ../gui/wxpython/gui_modules/mapdisp.py:1044
+#: ../gui/wxpython/gui_modules/mapdisp.py:926
+#: ../gui/wxpython/gui_modules/mapdisp.py:1052
 msgid "Error in projection (check the settings)"
 msgstr "Chyba v projekci (zkontrolujte nastavení)"
@@ -6122,7 +6181,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1718
 #: ../gui/wxpython/gui_modules/gcmd.py:89
-#: ../gui/wxpython/gui_modules/workspace.py:1000
+#: ../gui/wxpython/gui_modules/workspace.py:1007
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:424
 #: ../gui/wxpython/gui_modules/dbm.py:2357
 msgid "Warning"
@@ -6178,7 +6237,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:178
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:184
-#: ../gui/wxpython/gui_modules/preferences.py:1471
+#: ../gui/wxpython/gui_modules/preferences.py:1493
 msgid "Constrain display resolution to computational settings"
 msgstr "Nastavit zobrazené rozli¹ení jako výpoèetní "
@@ -6192,8 +6251,8 @@
 "mù¾e být upravena v oknì 'U¾ivatelské nastavení grafického prostøedí'."
 #: ../gui/wxpython/gui_modules/mapdisp.py:210
-#: ../gui/wxpython/gui_modules/mapdisp.py:1062
-#: ../gui/wxpython/gui_modules/mapdisp.py:1065
+#: ../gui/wxpython/gui_modules/mapdisp.py:1070
+#: ../gui/wxpython/gui_modules/mapdisp.py:1073
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:216
 msgid "Use defined projection"
 msgstr "Pou¾ít definovanou projekci"
@@ -6224,8 +6283,8 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:301
 #: ../gui/wxpython/gui_modules/mapdisp.py:312
 #: ../gui/wxpython/gui_modules/mapdisp.py:362
-#: ../gui/wxpython/gui_modules/mapdisp.py:507
-#: ../gui/wxpython/gui_modules/toolbars.py:201
+#: ../gui/wxpython/gui_modules/mapdisp.py:513
+#: ../gui/wxpython/gui_modules/toolbars.py:204
 #: ../gui/wxpython/gui_modules/layertree.py:582
 msgid "2D view"
 msgstr "2D zobrazení"
@@ -6255,78 +6314,78 @@
 "\n"
 "Detaily: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:381
+#: ../gui/wxpython/gui_modules/mapdisp.py:386
 msgid "Starting 3D view mode..."
 msgstr "Spou¹tím 3D zobrazení..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:387
 msgid "Please wait, loading data..."
 msgstr "Prosím èekejte, naèítám data..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:414
+#: ../gui/wxpython/gui_modules/mapdisp.py:420
 #, fuzzy
 msgid "3D View Toolbar"
 msgstr "Nástrojová li¹ta pro 3D zobrazení"
-#: ../gui/wxpython/gui_modules/mapdisp.py:438
+#: ../gui/wxpython/gui_modules/mapdisp.py:444
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:348
 msgid "Map Toolbar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:455
+#: ../gui/wxpython/gui_modules/mapdisp.py:461
 #, fuzzy
 msgid "Georectification Toolbar"
 msgstr "Nástrojová li¹ta pro georektifikaci"
-#: ../gui/wxpython/gui_modules/mapdisp.py:517
+#: ../gui/wxpython/gui_modules/mapdisp.py:523
 #: ../gui/wxpython/gui_modules/render.py:420
 #, python-format
 msgid "GRASS module '%s' not found. Unable to start map display window."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1127
+#: ../gui/wxpython/gui_modules/mapdisp.py:1135
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:890
 msgid "Nothing to render (empty map). Operation canceled."
 msgstr "Není co zobrazit (prázdná mapa). Operace ukonèena."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1300
+#: ../gui/wxpython/gui_modules/mapdisp.py:1308
 msgid "No raster or vector map layer selected for querying."
 msgstr "Nebyla vybrána ¾ádná vektorová mapa pro dotazování."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1301
+#: ../gui/wxpython/gui_modules/mapdisp.py:1309
 msgid "No map layer selected"
 msgstr "Nebyla vybrána ¾ádná mapová vrstva"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1396
+#: ../gui/wxpython/gui_modules/mapdisp.py:1404
 msgid "No vector map selected for querying."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1397
 #: ../gui/wxpython/gui_modules/mapdisp.py:1405
+#: ../gui/wxpython/gui_modules/mapdisp.py:1413
 msgid "Vector querying"
 msgstr "Dotazování vektorù"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1404
+#: ../gui/wxpython/gui_modules/mapdisp.py:1412
 msgid "Only vector map from the current mapset can be modified."
 msgstr "Upravována mù¾e být pouze vektorová mapa z aktuálního mapsetu"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1476
+#: ../gui/wxpython/gui_modules/mapdisp.py:1484
 msgid "Query surface (raster map)"
 msgstr "Dotaz na rastrovou mapu"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1483
+#: ../gui/wxpython/gui_modules/mapdisp.py:1491
 msgid "Query vector map"
 msgstr "Dotaz na vektorovou mapu"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1491
+#: ../gui/wxpython/gui_modules/mapdisp.py:1499
 msgid "Query raster/vector map(s) (display mode)"
 msgstr "Dotaz na rastrovou/vektorovou mapu (mód zobrazení)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1507
+#: ../gui/wxpython/gui_modules/mapdisp.py:1515
 msgid "Query vector map (edit mode)"
 msgstr "Dotaz na vektorovou mapu (editace atributù)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1633
+#: ../gui/wxpython/gui_modules/mapdisp.py:1641
 #, python-format
 msgid ""
 "Click and drag with left mouse button to measure.%sDouble click with left "
@@ -6335,87 +6394,87 @@
 "Kliknìte levým tlaèítkem my¹i a posunujte my¹ pro mìøení vzdálenosti. %"
 "sDvojklik sma¾e pøedchozí mìøení."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1639
+#: ../gui/wxpython/gui_modules/mapdisp.py:1647
 msgid "Measuring distance"
 msgstr "Mìøení vzdálenosti"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1642
+#: ../gui/wxpython/gui_modules/mapdisp.py:1650
 msgid "Measuring distance:"
 msgstr "Mìøená vzdálenost:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1652
+#: ../gui/wxpython/gui_modules/mapdisp.py:1660
 #, python-format
 msgid ""
 "Geodesic distance is not yet supported by this tool.\n"
 "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1681
-#: ../gui/wxpython/gui_modules/mapdisp.py:1687
+#: ../gui/wxpython/gui_modules/mapdisp.py:1690
+#: ../gui/wxpython/gui_modules/mapdisp.py:1696
 #, fuzzy
 msgid "segment"
 msgstr "Legenda"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1682
-#: ../gui/wxpython/gui_modules/mapdisp.py:1688
+#: ../gui/wxpython/gui_modules/mapdisp.py:1691
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
 #, fuzzy
 msgid "total distance"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1683
+#: ../gui/wxpython/gui_modules/mapdisp.py:1692
 #, fuzzy
 msgid "bearing"
 msgstr "Upozornìní"
 msgid "deg"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1819
+#: ../gui/wxpython/gui_modules/mapdisp.py:1828
 msgid "Scale and North arrow"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1825
+#: ../gui/wxpython/gui_modules/mapdisp.py:1834
 msgid "Show/hide scale and North arrow"
 msgstr "Zobrazit/skrýt mìøítko a smìrovou rù¾ici"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1826
+#: ../gui/wxpython/gui_modules/mapdisp.py:1835
 msgid "scale object"
 msgstr "mìøítko"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1855
+#: ../gui/wxpython/gui_modules/mapdisp.py:1864
 msgid "Show/hide legend"
 msgstr "Zobrazit/skrýt legendu"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1856
+#: ../gui/wxpython/gui_modules/mapdisp.py:1865
 msgid "legend object"
 msgstr "legenda"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1965
+#: ../gui/wxpython/gui_modules/mapdisp.py:1974
 msgid "Zoom to computational region"
 msgstr "Pøiblí¾it na výpoèetní region"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1969
+#: ../gui/wxpython/gui_modules/mapdisp.py:1978
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1058
 msgid "Zoom to default region"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1973
+#: ../gui/wxpython/gui_modules/mapdisp.py:1982
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1062
 msgid "Zoom to saved region"
 msgstr "Zvìt¹it podle ulo¾eného regionu"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1977
+#: ../gui/wxpython/gui_modules/mapdisp.py:1986
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1066
 msgid "Set computational region from display"
 msgstr "Nastavit výpoèetní region podle aktuálního zobrazení"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1981
+#: ../gui/wxpython/gui_modules/mapdisp.py:1990
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1070
 msgid "Save display geometry to named region"
 msgstr "Ulo¾it aktuální zobrazení jako pojmenovaný region"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2075
+#: ../gui/wxpython/gui_modules/mapdisp.py:2084
 msgid "GRASS GIS Map Display: "
 msgstr "GRASS GIS Mapové okno: "
@@ -6480,12 +6539,12 @@
 msgid "Unsupported feature type %d. Operation cancelled."
 msgstr "Neplatná hodnota souøadnice. Operace zru¹ena."
-#: ../gui/wxpython/gui_modules/wxvdigit.py:455
+#: ../gui/wxpython/gui_modules/wxvdigit.py:456
 msgid "Unknown feature type '%s'"
 msgstr "Typ prvku:"
-#: ../gui/wxpython/gui_modules/wxvdigit.py:460
+#: ../gui/wxpython/gui_modules/wxvdigit.py:461
 #, fuzzy
 msgid "Not enough points for line"
 msgstr "Vytvoøit body podél linií"
@@ -6540,7 +6599,7 @@
 msgstr "Musíte spustit tento pøíkaz z menu nebo z pøíkazové øádky"
 #: ../gui/wxpython/gui_modules/ghelp.py:340
-#: ../gui/wxpython/gui_modules/goutput.py:629
+#: ../gui/wxpython/gui_modules/goutput.py:641
 #, python-format
 msgid "%d modules match"
 msgstr "%d modulù odpovídá"
@@ -6602,11 +6661,11 @@
 #: ../gui/wxpython/gui_modules/ghelp.py:702
 #: ../gui/wxpython/gui_modules/ghelp.py:761
-#: ../gui/wxpython/gui_modules/gmodeler.py:3548
-#: ../gui/wxpython/gui_modules/gmodeler.py:3588
-#: ../gui/wxpython/gui_modules/gmodeler.py:3856
-#: ../gui/wxpython/gui_modules/gmodeler.py:3964
-#: ../gui/wxpython/gui_modules/gmodeler.py:4282
+#: ../gui/wxpython/gui_modules/gmodeler.py:3542
+#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3958
+#: ../gui/wxpython/gui_modules/gmodeler.py:4276
 msgid "Name"
 msgstr "Jméno"
@@ -6646,7 +6705,7 @@
 "Stáhnout v¹echny informace v¹etnì popisu a klíèových slov (èasovì nároèné)"
 #: ../gui/wxpython/gui_modules/ghelp.py:815
-#: ../gui/wxpython/gui_modules/gdialogs.py:959
+#: ../gui/wxpython/gui_modules/gdialogs.py:960
 #, fuzzy
 msgid "Options"
 msgstr "Volitelné"
@@ -6704,8 +6763,8 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1507
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3295
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
-#: ../gui/wxpython/gui_modules/gdialogs.py:1258
-#: ../gui/wxpython/gui_modules/menuform.py:1691
+#: ../gui/wxpython/gui_modules/gdialogs.py:1259
+#: ../gui/wxpython/gui_modules/menuform.py:1684
 msgid "Browse"
 msgstr "Procházet"
@@ -6780,8 +6839,8 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:874
 #: ../gui/wxpython/gui_modules/location_wizard.py:1037
 #: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/gui_modules/gmodeler.py:3549
-#: ../gui/wxpython/gui_modules/gmodeler.py:3608
+#: ../gui/wxpython/gui_modules/gmodeler.py:3543
+#: ../gui/wxpython/gui_modules/gmodeler.py:3602
 msgid "Description"
 msgstr "Popis"
@@ -6882,7 +6941,7 @@
 msgstr "Cesta k souboru s EPSG kódy:"
 #: ../gui/wxpython/gui_modules/location_wizard.py:1286
-#: ../gui/wxpython/gui_modules/preferences.py:1814
+#: ../gui/wxpython/gui_modules/preferences.py:1836
 msgid "EPSG code:"
 msgstr "Kód EPSG:"
@@ -7145,7 +7204,7 @@
 msgstr "Vybrat výstupní vektorovou mapu:"
 #: ../gui/wxpython/gui_modules/vclean.py:168
-#: ../gui/wxpython/gui_modules/menuform.py:832
+#: ../gui/wxpython/gui_modules/menuform.py:833
 msgid "Copy the current command string to the clipboard (Ctrl+C)"
 msgstr "Kopírovat pøíkaz do schránky (Ctrl+C)"
@@ -7227,286 +7286,290 @@
 msgid "Vector cleaning command copied to clipboard"
 msgstr "Pøíkaz pro èi¹tìní vektoru byl zkopírován do schráky"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:70
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:48
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:55
+#: ../gui/wxpython/gui_modules/nviz_tools.py:136
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:52
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:59
 msgid "View"
 msgstr "Pohled"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:74
-#: ../gui/wxpython/gui_modules/gmodeler.py:3154
+#: ../gui/wxpython/gui_modules/gmodeler.py:3148
 msgid "Data"
 msgstr "Data"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:78
-#: ../gui/wxpython/gui_modules/preferences.py:1236
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/preferences.py:1240
 msgid "Appearance"
 msgstr "Vzhled"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:112
+#: ../gui/wxpython/gui_modules/nviz_tools.py:216
 msgid "Control View"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:120
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1146
+#: ../gui/wxpython/gui_modules/nviz_tools.py:226
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1360
 msgid "W"
 msgstr "Z"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:122
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1148
+#: ../gui/wxpython/gui_modules/nviz_tools.py:227
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1362
 msgid "N"
 msgstr "S"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:129
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1155
+#: ../gui/wxpython/gui_modules/nviz_tools.py:228
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1369
 msgid "S"
 msgstr "J"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:131
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+#: ../gui/wxpython/gui_modules/nviz_tools.py:229
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
 msgid "E"
 msgstr "V"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:140
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:64
+#: ../gui/wxpython/gui_modules/nviz_tools.py:230
+#, fuzzy
+msgid "NW"
+msgstr "Z"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:231
+#, fuzzy
+msgid "NE"
+msgstr "S"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:232
+#, fuzzy
+msgid "SE"
+msgstr "J"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:233
+#, fuzzy
+msgid "SW"
+msgstr "Z"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:68
 msgid "Perspective:"
 msgstr "Perspektiva:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:150
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:143
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
 msgid "Twist:"
 msgstr "Otoèení:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:168
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1167
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:124
-#: ../gui/wxpython/gui_modules/gmodeler.py:3128
-#: ../gui/wxpython/gui_modules/gmodeler.py:3247
+#: ../gui/wxpython/gui_modules/nviz_tools.py:290
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1381
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:128
+#: ../gui/wxpython/gui_modules/gmodeler.py:3122
+#: ../gui/wxpython/gui_modules/gmodeler.py:3241
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4038
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4181
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4829
-#: ../gui/wxpython/gui_modules/gdialogs.py:1634
+#: ../gui/wxpython/gui_modules/gdialogs.py:1635
 msgid "Height:"
 msgstr "Vý¹ka:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:175
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:173
+#: ../gui/wxpython/gui_modules/nviz_tools.py:296
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:177
 msgid "Z-exag:"
 msgstr "Pøevý¹ení:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
-msgid "Look at:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:309
+#, fuzzy
+msgid "Look:"
 msgstr "Pohled na:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+#: ../gui/wxpython/gui_modules/nviz_tools.py:312
+#, fuzzy
+msgid "here"
+msgstr "koule"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:318
+#, fuzzy
+msgid "center"
+msgstr "Vykreslit"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:324
 msgid "top"
 msgstr "vr¹ek"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
-msgid "north"
-msgstr "sever"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
-msgid "south"
-msgstr "jih"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:197
-msgid "east"
-msgstr "východ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:198
-msgid "west"
-msgstr "západ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:199
-msgid "north-west"
-msgstr "severo-západ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:200
-msgid "north-east"
-msgstr "severo-východ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:201
-msgid "south-east"
-msgstr "jiho-východ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:202
-msgid "south-west"
-msgstr "jiho-západ"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:210
-msgid "Reset"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:330
+#, fuzzy
+msgid "reset"
 msgstr "Reset"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:211
+#: ../gui/wxpython/gui_modules/nviz_tools.py:331
 msgid "Reset to default view"
 msgstr "Reset na výchozí pohled"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:233
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:205
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:209
 msgid "Image Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:240
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:212
-#: ../gui/wxpython/gui_modules/preferences.py:1452
+#: ../gui/wxpython/gui_modules/nviz_tools.py:357
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:217
+#: ../gui/wxpython/gui_modules/preferences.py:1474
 msgid "Background color:"
 msgstr "Barva pozadí:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:272
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:394
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1471
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:353
 msgid "Surface"
 msgstr "Povrch"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:277
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:237
+#: ../gui/wxpython/gui_modules/nviz_tools.py:400
+#: ../gui/wxpython/gui_modules/nviz_tools.py:757
+#, fuzzy
+msgid "Constant surface"
+msgstr "Povrch nákladù"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:405
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:457
 msgid "Vector"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:282
+#: ../gui/wxpython/gui_modules/nviz_tools.py:411
 msgid "Volume"
 msgstr "3D rastr"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:298
+#: ../gui/wxpython/gui_modules/nviz_tools.py:435
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:243
 msgid "Lighting"
 msgstr "Osvìtlení"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:302
+#: ../gui/wxpython/gui_modules/nviz_tools.py:440
 msgid "Fringe"
 msgstr "Okraj"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:342
-msgid "Surface attributes"
-msgstr "Vlastnosti povrchu"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:349
-msgid "Topography"
-msgstr "Topografie"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:350
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
-#: ../gui/wxpython/gui_modules/profile.py:1222
-msgid "Color"
-msgstr "Barva"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:352
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1028
-msgid "Transparency"
-msgstr "Prùhlednost"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:353
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
-msgid "Shininess"
-msgstr "Jasnost"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:354
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1030
-msgid "Emission"
-msgstr "Emise"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:360
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1038
-msgid "map"
-msgstr "mapa"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:363
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1043
-msgid "unset"
-msgstr "zru¹it"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:368
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1048
-msgid "constant"
-msgstr "stejný"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:428
-#: ../gui/wxpython/gui_modules/nviz_tools.py:915
+#: ../gui/wxpython/gui_modules/nviz_tools.py:488
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1126
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:362
 msgid "Draw"
 msgstr "Vykreslit"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:435
-#: ../gui/wxpython/gui_modules/nviz_tools.py:922
+#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1133
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:368
 msgid "Mode:"
 msgstr "Mód:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:438
+#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
 msgid "coarse"
 msgstr "hrubý"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:439
+#: ../gui/wxpython/gui_modules/nviz_tools.py:499
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:372
 msgid "fine"
 msgstr "jemný"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:440
+#: ../gui/wxpython/gui_modules/nviz_tools.py:500
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:373
 msgid "both"
 msgstr "oba"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:450
-#: ../gui/wxpython/gui_modules/nviz_tools.py:936
+#: ../gui/wxpython/gui_modules/nviz_tools.py:509
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1147
 msgid "Shading:"
 msgstr "Stínìní:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:453
-#: ../gui/wxpython/gui_modules/nviz_tools.py:709
-#: ../gui/wxpython/gui_modules/nviz_tools.py:939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:512
+#: ../gui/wxpython/gui_modules/nviz_tools.py:920
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1150
 msgid "flat"
 msgstr "plocha"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:454
-#: ../gui/wxpython/gui_modules/nviz_tools.py:940
+#: ../gui/wxpython/gui_modules/nviz_tools.py:513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1151
 msgid "gouraud"
 msgstr "Gouraudovo stínování"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:462
+#: ../gui/wxpython/gui_modules/nviz_tools.py:521
 msgid "Set to all"
 msgstr "Nastavit v¹echny"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:463
+#: ../gui/wxpython/gui_modules/nviz_tools.py:522
 msgid "Use draw settings for all loaded surfaces"
 msgstr "Pou¾ít vykreslovací nastavení pro v¹echny naètené povrchy"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:470
-msgid "Coarse:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:400
+#, fuzzy
+msgid "Coarse mode:"
 msgstr "Hrubý:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:524
-msgid "res."
-msgstr "rozl."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:387
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:404
+#, fuzzy
+msgid "resolution:"
+msgstr "Rozli¹ení:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:492
-msgid "style"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:545
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:416
+#, fuzzy
+msgid "style:"
 msgstr "styl"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:548
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
 msgid "wire"
 msgstr "sí»"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:549
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:420
 msgid "surface"
 msgstr "povrch"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:505
-msgid "wire color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:561
+#, fuzzy
+msgid "Change wire color"
 msgstr "barva sítì"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:519
-msgid "Fine:"
-msgstr "Vyhlazený:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:568
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:383
+#, fuzzy
+msgid "Fine mode:"
+msgstr "Najít modul"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
-msgid "Mask zeros:"
-msgstr "Maskovat nulové hodnoty"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:593
+msgid "Surface attributes"
+msgstr "Vlastnosti povrchu"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
-msgid "by elevation"
-msgstr "podle vý¹ky"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:601
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1222
+msgid "Color"
+msgstr "Barva"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:563
-msgid "by color"
-msgstr "podle barvy"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:603
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1239
+msgid "Transparency"
+msgstr "Prùhlednost"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:578
+#: ../gui/wxpython/gui_modules/nviz_tools.py:604
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1240
+msgid "Shininess"
+msgstr "Jasnost"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:610
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1249
+msgid "map"
+msgstr "mapa"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:613
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1254
+msgid "unset"
+msgstr "zru¹it"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1259
+msgid "constant"
+msgstr "stejný"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:671
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4008
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4577
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4793
@@ -7515,153 +7578,195 @@
 msgid "Position"
 msgstr "Pozice"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:653
+#: ../gui/wxpython/gui_modules/nviz_tools.py:686
+msgid "Reset"
+msgstr "Reset"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:687
+#, fuzzy
+msgid "Reset to default position"
+msgstr "Reset na výchozí pohled"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:785
+#, fuzzy
+msgid "Fine resolution:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:797
+#, fuzzy
+msgid "Value:"
+msgstr "Hodnoty"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:863
 msgid "Show vector lines"
 msgstr "Ukázat vektorové linie"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:663
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:245
+#: ../gui/wxpython/gui_modules/nviz_tools.py:873
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:465
 msgid "Vector lines"
 msgstr "Vektorové linie"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:669
+#: ../gui/wxpython/gui_modules/nviz_tools.py:880
 msgid "Line:"
 msgstr "Linie:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:672
-#: ../gui/wxpython/gui_modules/nviz_tools.py:805
-msgid "width"
-msgstr "¹íøka"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:883
+msgid "width:"
+msgstr "¹íøka:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:688
-#: ../gui/wxpython/gui_modules/nviz_tools.py:790
-msgid "color"
-msgstr "barva"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:899
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1001
+msgid "color:"
+msgstr "barva:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:703
-msgid "display"
-msgstr "zobrazit"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+#: ../gui/wxpython/gui_modules/vdigit.py:158
+msgid "Display"
+msgstr "Displej"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:708
-msgid "on surface"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:919
+#, fuzzy
+msgid "on surface(s):"
 msgstr "na povrchu"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:718
-#: ../gui/wxpython/gui_modules/nviz_tools.py:836
+#: ../gui/wxpython/gui_modules/nviz_tools.py:929
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1050
 msgid "Height above surface:"
 msgstr "Vý¹ka nad povrchem:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:754
+#: ../gui/wxpython/gui_modules/nviz_tools.py:964
 msgid "Show vector points"
 msgstr "Ukázat vektorové body"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:973
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:487
 msgid "Vector points"
 msgstr "Vektorové body"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:769
+#: ../gui/wxpython/gui_modules/nviz_tools.py:980
 msgid "Icon:"
 msgstr "Ikona:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:772
-msgid "size"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:983
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
+#, fuzzy
+msgid "size:"
 msgstr "velikost"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:823
-msgid "symbol"
-msgstr "symbol"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1016
+msgid "width"
+msgstr "¹íøka"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:892
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1033
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
+msgid "symbol:"
+msgstr "symbol:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1046
+#, fuzzy
+msgid "Display on surface(s):"
+msgstr "Vzdálenost podél transektu"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
 msgid "3D raster map"
 msgstr "3D rastrová mapa"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:925
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1136
 msgid "isosurfaces"
 msgstr "Isopovrch"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1137
 msgid "slides"
 msgstr "Pláty"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:949
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1160
 msgid "Resolution:"
 msgstr "Rozli¹ení:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:971
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
 msgid "List of isosurfaces"
 msgstr "Seznam Isopovrchù"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1019
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1230
 msgid "Isosurface attributes"
 msgstr "Atributy Isopovrchu"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1025
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1236
 msgid "Topography level"
 msgstr "Úroveò topografie"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1241
+msgid "Emission"
+msgstr "Emise"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1342
 msgid "Show light model"
 msgstr "Ukázat svìtelný model"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1135
-msgid "Follow source viewpoint"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1141
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1355
 msgid "Light source position"
 msgstr "Umístìní zdroje svìtla"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1185
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1399
 msgid "Light color and intensity"
 msgstr "Barva svìtla a intenzita"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1199
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1413
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:299
 msgid "Brightness:"
 msgstr "Jas:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1423
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
 msgid "Ambient:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1270
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1485
 msgid "Edges with fringe"
 msgstr "Hrany s okrajem"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1487
 msgid "N && W"
 msgstr "S && Z"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1488
 msgid "N && E"
 msgstr "S && V"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1489
 msgid "S && W"
 msgstr "J &c Z"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1275
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1490
 msgid "S && E"
 msgstr "J && V"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1295
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1510
 msgid "Elevation of fringe from bottom:"
 msgstr "Vý¹ka okraje ze spodní strany"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2309
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2311
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1563
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1608
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1186
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1204
+#, fuzzy
+msgid "constant#"
+msgstr "stejný"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2667
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2669
 msgid "Level"
 msgstr "Úroveò"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2632
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3003
 msgid "Vector map is 3D"
 msgstr "Vektorové mapa je 3D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2635
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3006
 msgid "Vector map is 2D"
 msgstr "Vektorová mapa je 2D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2637
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3008
 #, python-format
 msgid "%(features)d features (%(points)d points)"
 msgstr "%(features)d prvkù (%(points)d bodù)"
@@ -7683,8 +7788,8 @@
 msgstr "Seznam vrstev"
 #: ../gui/wxpython/gui_modules/ogc_services.py:69
-#: ../gui/wxpython/gui_modules/gdialogs.py:1153
-#: ../gui/wxpython/gui_modules/gdialogs.py:1263
+#: ../gui/wxpython/gui_modules/gdialogs.py:1154
+#: ../gui/wxpython/gui_modules/gdialogs.py:1264
 msgid "Add imported layers into layer tree"
 msgstr "Pøidat importované vrstvy do stromu vrstev"
@@ -7697,14 +7802,14 @@
 msgstr "Pøipojit k serveru"
 #: ../gui/wxpython/gui_modules/ogc_services.py:85
-#: ../gui/wxpython/gui_modules/gdialogs.py:998
-#: ../gui/wxpython/gui_modules/gdialogs.py:1165
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
+#: ../gui/wxpython/gui_modules/gdialogs.py:1166
 msgid "&Import"
 msgstr "&Import"
 #: ../gui/wxpython/gui_modules/ogc_services.py:86
-#: ../gui/wxpython/gui_modules/gdialogs.py:999
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/gdialogs.py:1167
 msgid "Import selected layers"
 msgstr "Importovat vybrané vrstvy"
@@ -7720,17 +7825,17 @@
 msgid "Layers"
 msgstr "Vrstvy"
-#: ../gui/wxpython/gui_modules/prompt.py:393
+#: ../gui/wxpython/gui_modules/prompt.py:394
 #, python-format
 msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
 msgstr "Upozornìní: volba <%(flag)s> nebyla nalezena v '%(module)s'"
-#: ../gui/wxpython/gui_modules/prompt.py:396
+#: ../gui/wxpython/gui_modules/prompt.py:397
 #, python-format
 msgid "Warning: option <%(param)s> not found in '%(module)s'"
 msgstr "Upozornìní: volba <%(param)s> nebyla nalezena v '%(module)s'"
-#: ../gui/wxpython/gui_modules/prompt.py:617
+#: ../gui/wxpython/gui_modules/prompt.py:618
 msgid "Type GRASS command and run by pressing ENTER"
 msgstr "Napi¹te pøíkaz GRASSu a spus»te stisknutím ENTER"
@@ -7752,7 +7857,7 @@
 msgstr "Jméno zdroje"
 #: ../gui/wxpython/gui_modules/gselect.py:1083
-#: ../gui/wxpython/gui_modules/menuform.py:1690
+#: ../gui/wxpython/gui_modules/menuform.py:1683
 msgid "File"
 msgstr "Soubor"
@@ -7831,7 +7936,7 @@
 msgstr "Vektorová mapa <%s> nebyla nalezena."
 #: ../gui/wxpython/gui_modules/gselect.py:1285
-#: ../gui/wxpython/gui_modules/gmodeler.py:3331
+#: ../gui/wxpython/gui_modules/gmodeler.py:3325
 msgid "Name:"
 msgstr "Jméno:"
@@ -7849,62 +7954,74 @@
 msgid "Unable to save settings."
 msgstr "Nelze provést nastavení '%s'"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:29
 msgid "3D view settings"
 msgstr "Nastavení 3D zobrazení"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:67
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:146
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:71
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:180
 msgid "(value)"
 msgstr "(hodnota)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:79
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:127
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:158
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:187
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:83
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:131
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:162
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:191
 msgid "(step)"
 msgstr "(krok)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:94
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:98
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:258
 msgid "Position:"
 msgstr "Pozice:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:97
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:101
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:261
 msgid "(x)"
 msgstr "(x)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:252
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:249
+#, fuzzy
+msgid "Light"
+msgstr "Osvìtlení"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:285
+#, fuzzy
+msgid "(z)"
+msgstr "(x)"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:431
+#, fuzzy
+msgid "wire color:"
+msgstr "barva sítì"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
 msgid "Show lines"
 msgstr "Ukázat linie"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:274
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:494
 msgid "Show points"
 msgstr "Ukázat body"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:283
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:503
 msgid "Size:"
 msgstr "Velikost:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:298
-#: ../gui/wxpython/gui_modules/gmodeler.py:3110
-#: ../gui/wxpython/gui_modules/gmodeler.py:3229
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:518
+#: ../gui/wxpython/gui_modules/gmodeler.py:3104
+#: ../gui/wxpython/gui_modules/gmodeler.py:3223
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4026
-#: ../gui/wxpython/gui_modules/gdialogs.py:1630
+#: ../gui/wxpython/gui_modules/gdialogs.py:1631
 msgid "Width:"
 msgstr "©íøka:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:533
 msgid "Marker:"
 msgstr "Znaèka:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:695
 #, python-format
-msgid "Nviz settings saved to file <%s>."
-msgstr "Nastavení Nviz ulo¾eno do souboru <%s>."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
-#, python-format
 msgid "3D view settings saved to file <%s>."
 msgstr "Nastavení 3D zobrazení bylo ulo¾eno do souboru <%s>."
@@ -7919,8 +8036,8 @@
 #: ../gui/wxpython/gui_modules/gcmd.py:349
 #: ../gui/wxpython/gui_modules/render.py:627
 #: ../gui/wxpython/gui_modules/render.py:630
-#: ../gui/wxpython/gui_modules/menuform.py:2167
-#: ../gui/wxpython/gui_modules/menuform.py:2170
+#: ../gui/wxpython/gui_modules/menuform.py:2160
+#: ../gui/wxpython/gui_modules/menuform.py:2163
 msgid "Details:"
 msgstr "Detaily:"
@@ -7943,23 +8060,19 @@
 msgstr "Zavøít dialog a ulo¾it u¾ivatelské nastavení"
 #: ../gui/wxpython/gui_modules/vdigit.py:92
-#: ../gui/wxpython/gui_modules/gmodeler.py:3319
+#: ../gui/wxpython/gui_modules/gmodeler.py:3313
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1703
 #: ../gui/wxpython/gui_modules/profile.py:1040
 #: ../gui/wxpython/gui_modules/profile.py:1393
-#: ../gui/wxpython/gui_modules/preferences.py:966
+#: ../gui/wxpython/gui_modules/preferences.py:971
 msgid "Close dialog and ignore changes"
 msgstr "Zavøít dialog a ignorovat provedené zmìny"
 #: ../gui/wxpython/gui_modules/vdigit.py:151
-#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_modules/preferences.py:1109
 msgid "General"
 msgstr "Obecné"
-#: ../gui/wxpython/gui_modules/vdigit.py:158
-msgid "Display"
-msgstr "Displej"
 #: ../gui/wxpython/gui_modules/vdigit.py:163
 #: ../gui/wxpython/gui_modules/profile.py:1174
 msgid "Line width"
@@ -8071,7 +8184,7 @@
 msgstr "Vybrat dangles"
 #: ../gui/wxpython/gui_modules/vdigit.py:377
-#: ../gui/wxpython/gui_modules/preferences.py:1669
+#: ../gui/wxpython/gui_modules/preferences.py:1691
 msgid "Attributes"
 msgstr "Atributy"
@@ -8241,20 +8354,20 @@
 "Identifikátor vrstvy navíc vìt¹í ne¾ nula."
 #: ../gui/wxpython/gui_modules/vdigit.py:1060
-#: ../gui/wxpython/gui_modules/gmodeler.py:3785
-#: ../gui/wxpython/gui_modules/gmodeler.py:4142
+#: ../gui/wxpython/gui_modules/gmodeler.py:3779
+#: ../gui/wxpython/gui_modules/gmodeler.py:4136
 msgid "Delete selected"
 msgstr "Odstranit vybrané"
 #: ../gui/wxpython/gui_modules/vdigit.py:1064
-#: ../gui/wxpython/gui_modules/gmodeler.py:3786
-#: ../gui/wxpython/gui_modules/gmodeler.py:4143
+#: ../gui/wxpython/gui_modules/gmodeler.py:3780
+#: ../gui/wxpython/gui_modules/gmodeler.py:4137
 msgid "Delete all"
 msgstr "Odstranit v¹e"
 #: ../gui/wxpython/gui_modules/vdigit.py:1066
-#: ../gui/wxpython/gui_modules/gmodeler.py:3792
-#: ../gui/wxpython/gui_modules/gmodeler.py:4150
+#: ../gui/wxpython/gui_modules/gmodeler.py:3786
+#: ../gui/wxpython/gui_modules/gmodeler.py:4144
 #: ../gui/wxpython/gui_modules/dbm.py:1146
 #: ../gui/wxpython/gui_modules/dbm.py:1659
 msgid "Reload"
@@ -8352,6 +8465,11 @@
 msgid "Preview generated"
 msgstr ""
+#: ../gui/wxpython/gui_modules/psmap.py:353
+#, fuzzy
+msgid "Save file as"
+msgstr "Ulo¾it soubor jako..."
 #: ../gui/wxpython/gui_modules/psmap.py:392
 msgid "Failed to read file %s."
@@ -8367,12 +8485,12 @@
 msgid "Scalebar is not appropriate for this projection"
 msgstr "Definujte parametry pro %s projekci"
-#: ../gui/wxpython/gui_modules/psmap.py:861
+#: ../gui/wxpython/gui_modules/psmap.py:860
 #, fuzzy
 msgid "wxGUI Hardcopy Map Utility"
-#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/psmap.py:862
 #, fuzzy
 msgid ""
 "(C) 2011 by the GRASS Development Team\n"
@@ -8381,8 +8499,8 @@
 "(C) 2010 by the GRASS Development Team\n"
 "\n"
-#: ../gui/wxpython/gui_modules/psmap.py:864
-#: ../gui/wxpython/gui_modules/gmodeler.py:1236
+#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/gmodeler.py:1230
 msgid ""
 "This program is free software under the GNU General Public License(>=v2). "
 "Read the file COPYING that comes with GRASS for details."
@@ -8391,7 +8509,7 @@
 "(>=v2). Pro více detailù si prosím pøe¹tìte soubor COPYING který je pøilo¾en "
 "k instalaci."
-#: ../gui/wxpython/gui_modules/psmap.py:1095
+#: ../gui/wxpython/gui_modules/psmap.py:1094
 msgid "Click and drag to resize object"
 msgstr ""
@@ -8507,7 +8625,7 @@
 msgstr "Vektorové mapy"
 #: ../gui/wxpython/gui_modules/gmodeler.py:451
-#: ../gui/wxpython/gui_modules/gmodeler.py:574
+#: ../gui/wxpython/gui_modules/gmodeler.py:568
 msgid "Variables"
 msgstr "Promìnné"
@@ -8515,47 +8633,47 @@
 msgid "GRASS GIS Graphical Modeler"
 msgstr "GRASS GIS grafické modelování"
-#: ../gui/wxpython/gui_modules/gmodeler.py:572
+#: ../gui/wxpython/gui_modules/gmodeler.py:566
 msgid "Model"
 msgstr "Modelování"
-#: ../gui/wxpython/gui_modules/gmodeler.py:573
+#: ../gui/wxpython/gui_modules/gmodeler.py:567
 msgid "Items"
 msgstr "Prvky"
-#: ../gui/wxpython/gui_modules/gmodeler.py:642
+#: ../gui/wxpython/gui_modules/gmodeler.py:636
 msgid "Redrawing model..."
 msgstr "Pøekresluji model..."
-#: ../gui/wxpython/gui_modules/gmodeler.py:669
+#: ../gui/wxpython/gui_modules/gmodeler.py:663
 msgid "Do you want to save changes in the model?"
 msgstr "Chcete ulo¾it zmìny v modelu?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:671
+#: ../gui/wxpython/gui_modules/gmodeler.py:665
 msgid "Do you want to store current model settings to model file?"
 msgstr "Chcete ulo¾it souèasné nastavní do souboru modelu?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:738
+#: ../gui/wxpython/gui_modules/gmodeler.py:732
 #: ../gui/wxpython/gui_modules/dbm.py:2084
 msgid "Nothing to delete."
 msgstr "Není co smazat"
-#: ../gui/wxpython/gui_modules/gmodeler.py:742
+#: ../gui/wxpython/gui_modules/gmodeler.py:736
 #, python-format
 msgid "Do you want to permanently delete data?%s"
 msgstr "Chcete trvale odstranit data? %s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:743
+#: ../gui/wxpython/gui_modules/gmodeler.py:737
 msgid "Delete intermediate data?"
 msgstr "Smazat doèasná data"
-#: ../gui/wxpython/gui_modules/gmodeler.py:757
+#: ../gui/wxpython/gui_modules/gmodeler.py:751
 #, python-format
 msgid "%d maps deleted from current mapset"
 msgstr " %d map bylo smazáno ze souèasného mapsetu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:772
-#: ../gui/wxpython/gui_modules/gmodeler.py:885
+#: ../gui/wxpython/gui_modules/gmodeler.py:766
+#: ../gui/wxpython/gui_modules/gmodeler.py:879
 msgid ""
 "Current model is not empty. Do you want to store current settings to model "
 "file?"
@@ -8563,49 +8681,49 @@
 "Souèasný model není prázdný. Pøejete si ulo¾it aktuální nastavení do souboru "
 "modelu?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:775
-#: ../gui/wxpython/gui_modules/gmodeler.py:888
+#: ../gui/wxpython/gui_modules/gmodeler.py:769
+#: ../gui/wxpython/gui_modules/gmodeler.py:882
 msgid "Create new model?"
 msgstr "Vytvoøit nový model?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:800
+#: ../gui/wxpython/gui_modules/gmodeler.py:794
 msgid "Choose model file"
 msgstr "Vyberte model ze souboru"
-#: ../gui/wxpython/gui_modules/gmodeler.py:818
+#: ../gui/wxpython/gui_modules/gmodeler.py:812
 #, python-format
 msgid "%(items)d items (%(actions)d actions) loaded into model"
 msgstr "%(items)d prvkù (%(actions)d akcí) naèteno do modelu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:825
-#: ../gui/wxpython/gui_modules/gmodeler.py:862
+#: ../gui/wxpython/gui_modules/gmodeler.py:819
+#: ../gui/wxpython/gui_modules/gmodeler.py:856
 #, python-format
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr "Soubor s modelem <%s> ji¾ existuje. Pøejete si tento soubor pøepsat?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:835
-#: ../gui/wxpython/gui_modules/gmodeler.py:875
+#: ../gui/wxpython/gui_modules/gmodeler.py:829
+#: ../gui/wxpython/gui_modules/gmodeler.py:869
 #, python-format
 msgid "File <%s> saved"
 msgstr "Soubor <%s> byl ulo¾en"
-#: ../gui/wxpython/gui_modules/gmodeler.py:844
+#: ../gui/wxpython/gui_modules/gmodeler.py:838
 msgid "Choose file to save current model"
 msgstr "Vybrat soubor pro ulo¾ení aktuálního modelu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:864
+#: ../gui/wxpython/gui_modules/gmodeler.py:858
 msgid "File already exists"
 msgstr "Soubor ji¾ existuje"
-#: ../gui/wxpython/gui_modules/gmodeler.py:912
+#: ../gui/wxpython/gui_modules/gmodeler.py:906
 msgid "Model is empty. Nothing to run."
 msgstr "Model je prázdný. Není co spustit."
-#: ../gui/wxpython/gui_modules/gmodeler.py:999
+#: ../gui/wxpython/gui_modules/gmodeler.py:993
 msgid "Model is empty. Nothing to validate."
 msgstr "Model je prázdný. Není co vyhodnotit."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1006
+#: ../gui/wxpython/gui_modules/gmodeler.py:1000
 #, python-format
 msgid ""
 "Model is not valid.\n"
@@ -8616,38 +8734,38 @@
 "\n"
 "%s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1009
+#: ../gui/wxpython/gui_modules/gmodeler.py:1003
 msgid "Model is valid."
 msgstr "Model je platný"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1070
-#: ../gui/wxpython/gui_modules/gmodeler.py:1113
+#: ../gui/wxpython/gui_modules/gmodeler.py:1064
+#: ../gui/wxpython/gui_modules/gmodeler.py:1107
 #, python-format
 msgid "Model exported to <%s>"
 msgstr "Model exportován do <%s>"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1078
+#: ../gui/wxpython/gui_modules/gmodeler.py:1072
 msgid "Choose file to save"
 msgstr "Vyberte soubor k ulo¾ení"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1080
+#: ../gui/wxpython/gui_modules/gmodeler.py:1074
 msgid "Python script (*.py)|*.py"
 msgstr "Python skript (*.py)|*.py"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1094
+#: ../gui/wxpython/gui_modules/gmodeler.py:1088
 #, python-format
 msgid "File <%s> already exists. Do you want to overwrite this file?"
 msgstr "Soubor <%s> ji¾ existuje. Pøejete si tento soubor pøepsat?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1096
+#: ../gui/wxpython/gui_modules/gmodeler.py:1090
 msgid "Save file"
 msgstr "Ulo¾it soubor"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1233
+#: ../gui/wxpython/gui_modules/gmodeler.py:1227
 msgid "wxGUI Graphical Modeler"
 msgstr "wxGUI Grafické modelování"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1235
+#: ../gui/wxpython/gui_modules/gmodeler.py:1229
 msgid ""
 "\n"
@@ -8655,7 +8773,7 @@
 "\n"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1366
+#: ../gui/wxpython/gui_modules/gmodeler.py:1360
 #, python-format
 msgid ""
 "Reading model file <%s> failed.\n"
@@ -8664,87 +8782,87 @@
 "Ètení souboru modelu <%s> selhalo. \n"
 "Neplatný soubor, nelze parsovat XML dokument."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1372
+#: ../gui/wxpython/gui_modules/gmodeler.py:1366
 msgid "Please wait, loading model..."
 msgstr "Prosím èekejte, naèítám model..."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1427
+#: ../gui/wxpython/gui_modules/gmodeler.py:1421
 msgid "Writing current settings to model file failed."
 msgstr "Zápis aktuálního nastavení do souboru modelu selhalo."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1728
-#: ../gui/wxpython/gui_modules/gmodeler.py:1785
-#: ../gui/wxpython/gui_modules/gmodeler.py:1912
-#: ../gui/wxpython/gui_modules/menuform.py:384
+#: ../gui/wxpython/gui_modules/gmodeler.py:1722
+#: ../gui/wxpython/gui_modules/gmodeler.py:1779
+#: ../gui/wxpython/gui_modules/gmodeler.py:1906
+#: ../gui/wxpython/gui_modules/menuform.py:385
 msgid "unknown"
 msgstr "neznámý"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2010
+#: ../gui/wxpython/gui_modules/gmodeler.py:2004
 msgid "<not defined>"
 msgstr "<nedefinováno>"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2020
+#: ../gui/wxpython/gui_modules/gmodeler.py:2014
 msgid "Data properties"
 msgstr "Vlastnosti dat"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2027
+#: ../gui/wxpython/gui_modules/gmodeler.py:2021
 msgid "Name of raster map:"
 msgstr "Jméno rastrové mapy:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2029
+#: ../gui/wxpython/gui_modules/gmodeler.py:2023
 msgid "Name of vector map:"
 msgstr "Jméno vektorové mapy:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2031
+#: ../gui/wxpython/gui_modules/gmodeler.py:2025
 msgid "Name of element:"
 msgstr "Jméno prvku:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2224
+#: ../gui/wxpython/gui_modules/gmodeler.py:2218
 #: ../gui/wxpython/gui_modules/layertree.py:272
 msgid "Remove"
 msgstr "Odstranit"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2228
+#: ../gui/wxpython/gui_modules/gmodeler.py:2222
 msgid "Disable"
 msgstr "Zakázat"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+#: ../gui/wxpython/gui_modules/gmodeler.py:2225
 msgid "Enable"
 msgstr "Povolit"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2236
+#: ../gui/wxpython/gui_modules/gmodeler.py:2230
 msgid "Add control point"
 msgstr "Pøidat vlicovací bod"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2238
+#: ../gui/wxpython/gui_modules/gmodeler.py:2232
 msgid "Remove control point"
 msgstr "Odstranit vlicovací bod"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2245
+#: ../gui/wxpython/gui_modules/gmodeler.py:2239
 msgid "Intermediate"
 msgstr "pøechodné"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2256
+#: ../gui/wxpython/gui_modules/gmodeler.py:2250
 #: ../gui/wxpython/gui_modules/layertree.py:286
 msgid "Properties"
 msgstr "Vlastnosti"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2260
+#: ../gui/wxpython/gui_modules/gmodeler.py:2254
 msgid "Change ID"
 msgstr "Zmìnit ID"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2316
+#: ../gui/wxpython/gui_modules/gmodeler.py:2310
 msgid "Add new GRASS module to the model"
 msgstr "Pøidat nový modul do modelu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2334
-#: ../gui/wxpython/gui_modules/gmodeler.py:3857
-#: ../gui/wxpython/gui_modules/gmodeler.py:4283
-#: ../gui/wxpython/gui_modules/preferences.py:1518
+#: ../gui/wxpython/gui_modules/gmodeler.py:2328
+#: ../gui/wxpython/gui_modules/gmodeler.py:3851
+#: ../gui/wxpython/gui_modules/gmodeler.py:4277
+#: ../gui/wxpython/gui_modules/preferences.py:1540
 msgid "Command"
 msgstr "Pøíkazy"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2402
+#: ../gui/wxpython/gui_modules/gmodeler.py:2396
 msgid ""
 "Command not defined.\n"
 "\n"
@@ -8754,7 +8872,7 @@
 "\n"
 "Nelze pøidat novou akci do modelu."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2408
+#: ../gui/wxpython/gui_modules/gmodeler.py:2402
 #, python-format
 msgid ""
 "'%s' is not a GRASS module.\n"
@@ -8765,172 +8883,172 @@
 "\n"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3018
+#: ../gui/wxpython/gui_modules/gmodeler.py:3012
 msgid "Action"
 msgstr "Akce"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3023
+#: ../gui/wxpython/gui_modules/gmodeler.py:3017
 msgid "Validity"
 msgstr "Ovìøování"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3031
+#: ../gui/wxpython/gui_modules/gmodeler.py:3025
 msgid "Valid:"
 msgstr "Platné"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3048
+#: ../gui/wxpython/gui_modules/gmodeler.py:3042
 msgid "Invalid:"
 msgstr "Neplatné:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3065
+#: ../gui/wxpython/gui_modules/gmodeler.py:3059
 msgid "Running:"
 msgstr "Bì¾í:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3082
+#: ../gui/wxpython/gui_modules/gmodeler.py:3076
 msgid "Disabled:"
 msgstr "Zakázané:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3102
-#: ../gui/wxpython/gui_modules/gmodeler.py:3221
+#: ../gui/wxpython/gui_modules/gmodeler.py:3096
+#: ../gui/wxpython/gui_modules/gmodeler.py:3215
 #, fuzzy
 msgid "Shape size"
 msgstr "Index ostrosti"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3159
+#: ../gui/wxpython/gui_modules/gmodeler.py:3153
 #: ../gui/wxpython/gui_modules/profile.py:1252
 msgid "Type"
 msgstr "Typ"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3167
+#: ../gui/wxpython/gui_modules/gmodeler.py:3161
 msgid "Raster:"
 msgstr "Rastr:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3184
+#: ../gui/wxpython/gui_modules/gmodeler.py:3178
 msgid "3D raster:"
 msgstr "3D rastr:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3201
+#: ../gui/wxpython/gui_modules/gmodeler.py:3195
 msgid "Vector:"
 msgstr "Vektor:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3295
+#: ../gui/wxpython/gui_modules/gmodeler.py:3289
 #: ../gui/wxpython/gui_modules/layertree.py:374
 #: ../gui/wxpython/gui_modules/layertree.py:407
 msgid "Metadata"
 msgstr "Metadata"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3297
+#: ../gui/wxpython/gui_modules/gmodeler.py:3291
 msgid "Commands"
 msgstr "Pøíkazy"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3317
+#: ../gui/wxpython/gui_modules/gmodeler.py:3311
 msgid "Apply properties"
 msgstr "Pøijmout vlastnosti"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3340
+#: ../gui/wxpython/gui_modules/gmodeler.py:3334
 msgid "Description:"
 msgstr "Popis:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3349
+#: ../gui/wxpython/gui_modules/gmodeler.py:3343
 msgid "Author(s):"
 msgstr "Autoøi:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3398
+#: ../gui/wxpython/gui_modules/gmodeler.py:3392
 msgid "Model parameters"
 msgstr "Parametry modelu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3545
+#: ../gui/wxpython/gui_modules/gmodeler.py:3539
 msgid "List of variables - right-click to delete"
 msgstr "Seznam promìnných - kliknìte pravým tlaèítkem pro vymazání"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3595
+#: ../gui/wxpython/gui_modules/gmodeler.py:3589
 #: ../gui/wxpython/gui_modules/dbm.py:885
 #: ../gui/wxpython/gui_modules/dbm.py:2226
 msgid "Data type"
 msgstr "Datový typ"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3601
+#: ../gui/wxpython/gui_modules/gmodeler.py:3595
 msgid "Default value"
 msgstr "výchozí hodnota"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3553
+#: ../gui/wxpython/gui_modules/gmodeler.py:3547
 msgid "Add new variable"
 msgstr "Pøidat novou promìnnou"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3557
+#: ../gui/wxpython/gui_modules/gmodeler.py:3551
 #, fuzzy
 msgid "integer"
 msgstr "Ukazatel"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3558
+#: ../gui/wxpython/gui_modules/gmodeler.py:3552
 msgid "float"
 msgstr "desetinné èíslo"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3559
+#: ../gui/wxpython/gui_modules/gmodeler.py:3553
 msgid "string"
 msgstr "øetìzec"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3567
+#: ../gui/wxpython/gui_modules/gmodeler.py:3561
 msgid "Add new variable to the model"
 msgstr "Pøidat novou promìnnou do modelu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3715
+#: ../gui/wxpython/gui_modules/gmodeler.py:3709
 #, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
 msgstr "Promìnná <%s> ji¾ v modelu existuje. pøidání promìnné selhalo."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3744
+#: ../gui/wxpython/gui_modules/gmodeler.py:3738
 msgid "Do you want to delete all variables from the model?"
 msgstr "Pøejete si odstranit v¹echny promìnné z modelu?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3746
+#: ../gui/wxpython/gui_modules/gmodeler.py:3740
 msgid "Delete variables"
 msgstr "Smazat promìnné"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3826
+#: ../gui/wxpython/gui_modules/gmodeler.py:3820
 msgid "Condition: "
 msgstr "Podmínka:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3828
+#: ../gui/wxpython/gui_modules/gmodeler.py:3822
 msgid "Condition: not defined"
 msgstr "Podmínka: nedefinována"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3844
 msgid "Condition"
 msgstr "Podmínka"
 msgid "ID"
 msgstr "ID"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+#: ../gui/wxpython/gui_modules/gmodeler.py:3892
 msgid "loop"
 msgstr "smyèka"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3906
+#: ../gui/wxpython/gui_modules/gmodeler.py:3900
 msgid "Loop properties"
 msgstr "Vlastnosti smyèky"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3912
+#: ../gui/wxpython/gui_modules/gmodeler.py:3906
 msgid "List of items in loop"
 msgstr "Seznam prvkù ve smyèce"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3961
+#: ../gui/wxpython/gui_modules/gmodeler.py:3955
 msgid "List of items - right-click to delete"
 msgstr "Sesznam prvkù - pryvým klikem sma¾ete"
 msgid "In block"
 msgstr "V bloku"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3965
+#: ../gui/wxpython/gui_modules/gmodeler.py:3959
 msgid "Command / Condition"
 msgstr "Pøíkaz / Podmínka"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4092
+#: ../gui/wxpython/gui_modules/gmodeler.py:4086
 #: ../gui/wxpython/gui_modules/dbm.py:1178
 #, python-format
 msgid ""
@@ -8940,38 +9058,38 @@
 "Vybrané záznamy dat (%d) budou natrvalo smazány z tabulky. Pøejete si je "
 "smazat?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4095
+#: ../gui/wxpython/gui_modules/gmodeler.py:4089
 #: ../gui/wxpython/gui_modules/dbm.py:1181
 #: ../gui/wxpython/gui_modules/dbm.py:1227
 msgid "Delete records"
 msgstr "Smazat záznamy"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4149
+#: ../gui/wxpython/gui_modules/gmodeler.py:4143
 msgid "Normalize"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4247
+#: ../gui/wxpython/gui_modules/gmodeler.py:4241
 msgid "if-else"
 msgstr "if-else"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4268
+#: ../gui/wxpython/gui_modules/gmodeler.py:4262
 msgid "If-else properties"
 msgstr "Vlastnosti If-else"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4274
+#: ../gui/wxpython/gui_modules/gmodeler.py:4268
 msgid "List of items in 'if' block"
 msgstr "Seznam prvkù v bloku 'if' "
-#: ../gui/wxpython/gui_modules/gmodeler.py:4279
+#: ../gui/wxpython/gui_modules/gmodeler.py:4273
 msgid "List of items in 'else' block"
 msgstr "Seznam prvkù v bloku 'else' "
-#: ../gui/wxpython/gui_modules/workspace.py:983
+#: ../gui/wxpython/gui_modules/workspace.py:990
 #, python-format
 msgid "Unable to open file <%s> for reading."
 msgstr "Nelze otevøít soubor workspace <%s> pro zápis."
-#: ../gui/wxpython/gui_modules/workspace.py:996
+#: ../gui/wxpython/gui_modules/workspace.py:1003
 #, python-format
 msgid ""
 "Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -8984,7 +9102,7 @@
 "\n"
 "Poèet vynechaných linií: %(line)d"
-#: ../gui/wxpython/gui_modules/workspace.py:1214
+#: ../gui/wxpython/gui_modules/workspace.py:1221
 #, python-format
 msgid " row %d:"
 msgstr "øádek: %d"
@@ -9084,7 +9202,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1640
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4906
-#: ../gui/wxpython/gui_modules/preferences.py:2163
+#: ../gui/wxpython/gui_modules/preferences.py:2185
 msgid "Font size:"
 msgstr "Velikost fontu:"
@@ -9426,10 +9544,6 @@
 msgid "Size and style"
 msgstr "styl linie"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
-msgid "symbol:"
-msgstr "symbol:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3291
 #, fuzzy
 msgid "eps file:"
@@ -9453,11 +9567,6 @@
 msgid "Size"
 msgstr " Velikost"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
-#, fuzzy
-msgid "size:"
-msgstr "velikost"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3322
 #, fuzzy
 msgid "size from map table column:"
@@ -9667,9 +9776,9 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4596
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5081
 #: ../gui/wxpython/gui_modules/profile.py:967
-#: ../gui/wxpython/gui_modules/preferences.py:1240
-#: ../gui/wxpython/gui_modules/preferences.py:1372
-#: ../gui/wxpython/gui_modules/preferences.py:2114
+#: ../gui/wxpython/gui_modules/preferences.py:1244
+#: ../gui/wxpython/gui_modules/preferences.py:1394
+#: ../gui/wxpython/gui_modules/preferences.py:2136
 msgid "Font settings"
 msgstr "Nastavení písma"
@@ -9974,45 +10083,45 @@
 "Pøíkaz '%s' je¹tì nebyl implementován do WxGUI. Zkuste jej pøidat jako "
 "vrstvu pøíkazù."
-#: ../gui/wxpython/gui_modules/goutput.py:606
+#: ../gui/wxpython/gui_modules/goutput.py:605
 msgid "Save file as..."
-#: ../gui/wxpython/gui_modules/goutput.py:721
+#: ../gui/wxpython/gui_modules/goutput.py:733
 msgid ""
 "Please note that the data are left in inconsistent state and may be corrupted"
 msgstr "Data jsou ponechána v nevhodném stavu a mohou být poru¹ena"
-#: ../gui/wxpython/gui_modules/goutput.py:724
+#: ../gui/wxpython/gui_modules/goutput.py:736
 msgid "Command aborted"
 msgstr "Pøíkaz pøeru¹en"
-#: ../gui/wxpython/gui_modules/goutput.py:732
+#: ../gui/wxpython/gui_modules/goutput.py:744
 msgid "Command finished"
 msgstr "Pøíkaz ukonèen"
-#: ../gui/wxpython/gui_modules/wxnviz.py:302
+#: ../gui/wxpython/gui_modules/wxnviz.py:327
 #, python-format
 msgid "Vector map <%s> not found"
-#: ../gui/wxpython/gui_modules/wxnviz.py:354
-#: ../gui/wxpython/gui_modules/wxnviz.py:366
+#: ../gui/wxpython/gui_modules/wxnviz.py:392
+#: ../gui/wxpython/gui_modules/wxnviz.py:404
 #, python-format
 msgid "3d raster map <%s> not found"
 msgstr "3D rastrová mapa <%s> nebyla nalezena."
-#: ../gui/wxpython/gui_modules/toolbars.py:211
+#: ../gui/wxpython/gui_modules/toolbars.py:217
 msgid "3D view mode not available"
 msgstr "3D mód není k dispozici"
-#: ../gui/wxpython/gui_modules/toolbars.py:212
-#: ../gui/wxpython/gui_modules/toolbars.py:229
+#: ../gui/wxpython/gui_modules/toolbars.py:218
+#: ../gui/wxpython/gui_modules/toolbars.py:235
 #, python-format
 msgid "Reason: %s"
 msgstr "Dùvody: %s"
-#: ../gui/wxpython/gui_modules/toolbars.py:213
+#: ../gui/wxpython/gui_modules/toolbars.py:219
 msgid ""
 "Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
 "(hopefully this will be fixed soon). Please keep an eye out for updated "
@@ -10022,16 +10131,16 @@
 "se to brzy zmìní). Prosím kontrolujte nové verze GRASS GIS. Zatím mù¾ete "
 "pou¾ít modul \"NVIZ\" z nabídky."
-#: ../gui/wxpython/gui_modules/toolbars.py:221
-#: ../gui/wxpython/gui_modules/toolbars.py:1162
+#: ../gui/wxpython/gui_modules/toolbars.py:227
+#: ../gui/wxpython/gui_modules/toolbars.py:1108
 msgid "Digitize"
 msgstr "Digitalizovat"
-#: ../gui/wxpython/gui_modules/toolbars.py:228
+#: ../gui/wxpython/gui_modules/toolbars.py:234
 msgid "Vector digitizer not available"
 msgstr "Vektorová digitalizace není dostupná"
-#: ../gui/wxpython/gui_modules/toolbars.py:230
+#: ../gui/wxpython/gui_modules/toolbars.py:236
 msgid ""
 "Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
 "will be fixed soon). Please keep an eye out for updated versions of GRASS. "
@@ -10041,91 +10150,91 @@
 "to brzy zmìní). Prosím kontrolujte nové verze GRASS GIS. Zatím mù¾ete pou¾ít "
 "modul \"v.digit\" z nabídky vytvoøit vektor."
-#: ../gui/wxpython/gui_modules/toolbars.py:421
+#: ../gui/wxpython/gui_modules/toolbars.py:403
 msgid "Set map canvas for "
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:423
+#: ../gui/wxpython/gui_modules/toolbars.py:405
 msgid " / Zoom to map"
 msgstr " / Pøiblí¾it na mapu"
-#: ../gui/wxpython/gui_modules/toolbars.py:790
+#: ../gui/wxpython/gui_modules/toolbars.py:737
 msgid "Duplicate attributes"
 msgstr "Duplicitní atributy"
-#: ../gui/wxpython/gui_modules/toolbars.py:867
+#: ../gui/wxpython/gui_modules/toolbars.py:814
 msgid "Copy features from (background) vector map"
 msgstr "Kopírovat prvky z podkladové vektorové mapy"
-#: ../gui/wxpython/gui_modules/toolbars.py:875
+#: ../gui/wxpython/gui_modules/toolbars.py:822
 msgid "Flip selected lines/boundaries"
 msgstr "Otoèit vybrané linie/hranice"
-#: ../gui/wxpython/gui_modules/toolbars.py:883
+#: ../gui/wxpython/gui_modules/toolbars.py:830
 msgid "Merge selected lines/boundaries"
 msgstr "Pøipojit vybrané linie/hranice"
-#: ../gui/wxpython/gui_modules/toolbars.py:891
+#: ../gui/wxpython/gui_modules/toolbars.py:838
 msgid "Break selected lines/boundaries at intersection"
 msgstr "Rozdìlit vybrané linie/hranice na prùseèíku"
-#: ../gui/wxpython/gui_modules/toolbars.py:899
+#: ../gui/wxpython/gui_modules/toolbars.py:846
 msgid "Snap selected lines/boundaries (only to nodes)"
 msgstr "Spojit vybrané linie/hranice (pouze na uzlech)"
-#: ../gui/wxpython/gui_modules/toolbars.py:907
+#: ../gui/wxpython/gui_modules/toolbars.py:854
 msgid "Connect selected lines/boundaries"
 msgstr "Spojit vybrané linie/hranice"
-#: ../gui/wxpython/gui_modules/toolbars.py:915
+#: ../gui/wxpython/gui_modules/toolbars.py:862
 msgid "Query features"
 msgstr "Dotazovat prvky"
-#: ../gui/wxpython/gui_modules/toolbars.py:923
+#: ../gui/wxpython/gui_modules/toolbars.py:870
 msgid "Z bulk-labeling of 3D lines"
 msgstr "Pøiøazení Z souøadnice pro popisky u 3D linií"
-#: ../gui/wxpython/gui_modules/toolbars.py:931
+#: ../gui/wxpython/gui_modules/toolbars.py:878
 msgid "Feature type conversion"
 msgstr "Konverze typù vektorových prvkù"
-#: ../gui/wxpython/gui_modules/toolbars.py:1042
+#: ../gui/wxpython/gui_modules/toolbars.py:989
 msgid "Vector map is not 3D. Operation canceled."
 msgstr "Vektorová mapa není 3D. Operace ukonèena."
-#: ../gui/wxpython/gui_modules/toolbars.py:1107
-#: ../gui/wxpython/gui_modules/toolbars.py:1189
-#: ../gui/wxpython/gui_modules/toolbars.py:1268
+#: ../gui/wxpython/gui_modules/toolbars.py:1053
+#: ../gui/wxpython/gui_modules/toolbars.py:1135
+#: ../gui/wxpython/gui_modules/toolbars.py:1214
 msgid "Select vector map"
 msgstr "Vybrat vektorovou mapu"
-#: ../gui/wxpython/gui_modules/toolbars.py:1145
+#: ../gui/wxpython/gui_modules/toolbars.py:1091
 #, python-format
 msgid "Please wait, opening vector map <%s> for editing..."
 msgstr "Prosím poèkejte, otevírá se vektorová mapa <%s> pro editaci..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1197
+#: ../gui/wxpython/gui_modules/toolbars.py:1143
 #, python-format
 msgid "Do you want to save changes in vector map <%s>?"
 msgstr "Chcete ulo¾it zmìny do vektorové mapy <%s>?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1199
+#: ../gui/wxpython/gui_modules/toolbars.py:1145
 msgid "Save changes?"
 msgstr "Ulo¾it zmìny?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1206
+#: ../gui/wxpython/gui_modules/toolbars.py:1152
 #, python-format
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
 msgstr ""
 "Prosím poèkejte, zavírám a buduji topologii pro vektorovou mapu <%s>..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1217
+#: ../gui/wxpython/gui_modules/toolbars.py:1163
 #, fuzzy, python-format
 msgid "Editing of vector map <%s> successfully finished"
 msgstr "Zavøít dialog pøi ukonèení"
-#: ../gui/wxpython/gui_modules/toolbars.py:1274
-#: ../gui/wxpython/gui_modules/toolbars.py:1279
+#: ../gui/wxpython/gui_modules/toolbars.py:1220
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
 msgid "New vector map"
 msgstr "Nová vektorová mapa"
@@ -10396,7 +10505,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1117
-#: ../gui/wxpython/gui_modules/preferences.py:626
+#: ../gui/wxpython/gui_modules/preferences.py:642
 msgid "Edit selected record"
 msgstr "Editovat vybraný záznam"
@@ -10414,14 +10523,14 @@
 msgstr "Smazat v¹echny záznamy"
 #: ../gui/wxpython/gui_modules/dbm.py:1129
-#: ../gui/wxpython/gui_modules/gdialogs.py:861
-#: ../gui/wxpython/gui_modules/gdialogs.py:1389
+#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:1390
 msgid "Select all"
 msgstr "Vybrat v¹e"
 #: ../gui/wxpython/gui_modules/dbm.py:1130
-#: ../gui/wxpython/gui_modules/gdialogs.py:863
-#: ../gui/wxpython/gui_modules/gdialogs.py:1390
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
+#: ../gui/wxpython/gui_modules/gdialogs.py:1391
 msgid "Deselect all"
 msgstr "Zru¹it výbìr"
@@ -10719,7 +10828,7 @@
 msgstr "Vyvoøit atributovou tabulku"
 #: ../gui/wxpython/gui_modules/gdialogs.py:204
-#: ../gui/wxpython/gui_modules/preferences.py:1553
+#: ../gui/wxpython/gui_modules/preferences.py:1575
 msgid "Add created map into layer tree"
 msgstr "Pøidat vytvoøenou mapu do stromu vrstev"
@@ -10781,8 +10890,8 @@
 msgstr "Otoèení:"
 #: ../gui/wxpython/gui_modules/gdialogs.py:631
-#: ../gui/wxpython/gui_modules/preferences.py:1259
-#: ../gui/wxpython/gui_modules/preferences.py:1388
+#: ../gui/wxpython/gui_modules/preferences.py:1263
+#: ../gui/wxpython/gui_modules/preferences.py:1410
 msgid "Set font"
 msgstr "Nastavit písmo"
@@ -10794,97 +10903,107 @@
 "Pøesuòte my¹í (v módu ukazatele) na novou pozici.\n"
 "Dvojklik pro zmìnu nastavení."
-#: ../gui/wxpython/gui_modules/gdialogs.py:768
+#: ../gui/wxpython/gui_modules/gdialogs.py:739
+#, fuzzy
+msgid "&Add"
+msgstr "Pøidat"
+#: ../gui/wxpython/gui_modules/gdialogs.py:741
+#, fuzzy
+msgid "Add selected map layers to current display"
+msgstr "Pøidat rastrovou vrstvu (Ctrl+R)"
+#: ../gui/wxpython/gui_modules/gdialogs.py:769
 msgid "Map layer type:"
 msgstr "Typ mapové vrstvy:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:780
+#: ../gui/wxpython/gui_modules/gdialogs.py:781
 msgid "Select toggle"
 msgstr "Vybrat pøepínaè"
-#: ../gui/wxpython/gui_modules/gdialogs.py:787
+#: ../gui/wxpython/gui_modules/gdialogs.py:788
 msgid "Mapset:"
 msgstr "Mapset:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:797
+#: ../gui/wxpython/gui_modules/gdialogs.py:798
 msgid "Filter:"
 msgstr "Filtr:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
 msgid "List of maps:"
 msgstr "Seznam map:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:863
 msgid "Invert selection"
 msgstr "Obrátit výbìr"
-#: ../gui/wxpython/gui_modules/gdialogs.py:936
+#: ../gui/wxpython/gui_modules/gdialogs.py:937
 msgid "Multiple import"
 msgstr "Hromadný import"
-#: ../gui/wxpython/gui_modules/gdialogs.py:950
+#: ../gui/wxpython/gui_modules/gdialogs.py:951
 #, python-format
 msgid " List of %s layers "
 msgstr "Seznam  %s vrstev"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1151
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
 msgid "Add linked layers into layer tree"
 msgstr "Pøidat pøipojené vrstvy do stromu vrstev"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1158
+#: ../gui/wxpython/gui_modules/gdialogs.py:1159
 msgid "&Link"
 msgstr "&Pøipojit"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1159
+#: ../gui/wxpython/gui_modules/gdialogs.py:1160
 msgid "Link selected layers"
 msgstr "Pøipojit vybrané vrstvy"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1253
+#: ../gui/wxpython/gui_modules/gdialogs.py:1254
 msgid "Import DXF layers"
 msgstr "Import DXF vrstev"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1257
+#: ../gui/wxpython/gui_modules/gdialogs.py:1258
 msgid "Choose DXF file to import"
 msgstr "Vyberte soubor DXF pro import"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1353
+#: ../gui/wxpython/gui_modules/gdialogs.py:1354
 msgid "Layer name"
 msgstr "Název vrstvy"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1354
+#: ../gui/wxpython/gui_modules/gdialogs.py:1355
 msgid "Name for GRASS map"
 msgstr "Název mapové vrstvy"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1436
+#: ../gui/wxpython/gui_modules/gdialogs.py:1437
 msgid "Set Map Layer Opacity"
 msgstr "Nastavit prùhlednost mapové vrstvy"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1460
+#: ../gui/wxpython/gui_modules/gdialogs.py:1461
 msgid "transparent"
 msgstr "Prùhledný"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1463
+#: ../gui/wxpython/gui_modules/gdialogs.py:1464
 msgid "opaque"
 msgstr "Neprùhledný"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1582
+#: ../gui/wxpython/gui_modules/gdialogs.py:1583
 msgid "Set image size"
 msgstr "Nastavit velikost obrazu"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1591
+#: ../gui/wxpython/gui_modules/gdialogs.py:1592
 msgid "Image size"
 msgstr "Velikost obrazu"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1638
+#: ../gui/wxpython/gui_modules/gdialogs.py:1639
 msgid "Template:"
 msgstr "©ablona:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1676
+#: ../gui/wxpython/gui_modules/gdialogs.py:1677
 #, fuzzy
 msgid "GRASS GIS SQL Query Utility"
 msgstr "GRASS GIS - Mapové okno"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1687
+#: ../gui/wxpython/gui_modules/gdialogs.py:1688
 #, fuzzy
 msgid " SQL statement "
 msgstr "SQL pøíkaz"
@@ -11177,55 +11296,55 @@
 msgstr "Skupina vrstev:"
 #: ../gui/wxpython/gui_modules/layertree.py:743
-#: ../gui/wxpython/gui_modules/layertree.py:1310
+#: ../gui/wxpython/gui_modules/layertree.py:1309
 msgid "Click to edit layer settings"
 msgstr "Kliknìte pro nastavení vrstev "
-#: ../gui/wxpython/gui_modules/layertree.py:788
+#: ../gui/wxpython/gui_modules/layertree.py:784
 msgid "(double click to set properties)"
 msgstr "(dvojklik pro nastavení vlastností)"
-#: ../gui/wxpython/gui_modules/layertree.py:794
+#: ../gui/wxpython/gui_modules/layertree.py:790
 msgid "3d raster"
 msgstr "3D rastrová data"
-#: ../gui/wxpython/gui_modules/layertree.py:797
+#: ../gui/wxpython/gui_modules/layertree.py:793
 msgid "RGB"
 msgstr "RGB"
-#: ../gui/wxpython/gui_modules/layertree.py:800
+#: ../gui/wxpython/gui_modules/layertree.py:796
 msgid "HIS"
 msgstr "HIS"
-#: ../gui/wxpython/gui_modules/layertree.py:806
+#: ../gui/wxpython/gui_modules/layertree.py:802
 msgid "raster cell numbers"
 msgstr "Èíslo kategorie rastrové buòky"
-#: ../gui/wxpython/gui_modules/layertree.py:809
+#: ../gui/wxpython/gui_modules/layertree.py:805
 msgid "raster flow arrows"
 msgstr "Smìry odtoku v rastrové mapì"
-#: ../gui/wxpython/gui_modules/layertree.py:815
+#: ../gui/wxpython/gui_modules/layertree.py:811
 msgid "thematic area (choropleth) map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:818
+#: ../gui/wxpython/gui_modules/layertree.py:814
 msgid "thematic charts"
 msgstr "tématická mapa s grafem"
-#: ../gui/wxpython/gui_modules/layertree.py:821
+#: ../gui/wxpython/gui_modules/layertree.py:817
 msgid "grid"
 msgstr "møí¾ka (grid)"
-#: ../gui/wxpython/gui_modules/layertree.py:824
+#: ../gui/wxpython/gui_modules/layertree.py:820
 msgid "geodesic line"
 msgstr "Geodetické èáry"
-#: ../gui/wxpython/gui_modules/layertree.py:827
+#: ../gui/wxpython/gui_modules/layertree.py:823
 msgid "rhumbline"
 msgstr "zemìpisné èáry"
-#: ../gui/wxpython/gui_modules/layertree.py:830
+#: ../gui/wxpython/gui_modules/layertree.py:826
 msgid "vector labels"
 msgstr "vektorové popisky"
@@ -11233,154 +11352,154 @@
 msgid "Please wait, updating data..."
 msgstr "Prosím èekejte, aktualizuji data..."
-#: ../gui/wxpython/gui_modules/layertree.py:1389
+#: ../gui/wxpython/gui_modules/layertree.py:1388
 msgid "opacity:"
 msgstr "prùhlednost:"
-#: ../gui/wxpython/gui_modules/layertree.py:1406
+#: ../gui/wxpython/gui_modules/layertree.py:1405
 #, python-format
 msgid "Map <%s> not found."
 msgstr "Mapa <%s> nebyla nalezena."
-#: ../gui/wxpython/gui_modules/menuform.py:147
-#: ../gui/wxpython/gui_modules/menuform.py:1654
+#: ../gui/wxpython/gui_modules/menuform.py:148
+#: ../gui/wxpython/gui_modules/menuform.py:1647
 msgid "Select Color"
 msgstr "Zvolit barvu"
-#: ../gui/wxpython/gui_modules/menuform.py:451
+#: ../gui/wxpython/gui_modules/menuform.py:452
 #, python-format
 msgid "Parameter element '%(element)s' not found: '%(value)s'"
 msgstr "Parametry prvku  '%(element)s' nebyly nalezeny: '%(value)s'"
-#: ../gui/wxpython/gui_modules/menuform.py:472
+#: ../gui/wxpython/gui_modules/menuform.py:473
 #, python-format
 msgid "Flag not found: %s"
 msgstr "Pøepínaè nebyl nalezen: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:501
+#: ../gui/wxpython/gui_modules/menuform.py:502
 #, python-format
 msgid "Parameter '%(name)s' (%(desc)s) is missing."
 msgstr "Parametr %(name)s (%(desc)s) chybí."
-#: ../gui/wxpython/gui_modules/menuform.py:530
+#: ../gui/wxpython/gui_modules/menuform.py:531
 msgid "<required>"
 msgstr "<po¾ádováno>"
-#: ../gui/wxpython/gui_modules/menuform.py:797
+#: ../gui/wxpython/gui_modules/menuform.py:798
 msgid "Enter parameters for '"
 msgstr "Definujte parametry pro '"
-#: ../gui/wxpython/gui_modules/menuform.py:808
+#: ../gui/wxpython/gui_modules/menuform.py:809
 msgid "Close this window without executing the command (Ctrl+Q)"
 msgstr "Zavøi toto okno bez spu¹tìní pøíkazu (Ctrl+Q)"
-#: ../gui/wxpython/gui_modules/menuform.py:828
+#: ../gui/wxpython/gui_modules/menuform.py:829
 msgid "Run the command (Ctrl+R)"
 msgstr "Spustit pøíkaz (Ctrl+R)"
-#: ../gui/wxpython/gui_modules/menuform.py:831
+#: ../gui/wxpython/gui_modules/menuform.py:832
 #, fuzzy
 msgid "C&opy"
 msgstr "Kopírovat"
-#: ../gui/wxpython/gui_modules/menuform.py:846
+#: ../gui/wxpython/gui_modules/menuform.py:847
 msgid "Show manual page of the command (Ctrl+H)"
 msgstr "Ukázat manuálovou stránku pøíkazu (Ctrl+H)"
-#: ../gui/wxpython/gui_modules/menuform.py:867
+#: ../gui/wxpython/gui_modules/menuform.py:868
 msgid "Add created map(s) into layer tree"
-#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:883
 msgid "Close dialog on finish"
-#: ../gui/wxpython/gui_modules/menuform.py:884
+#: ../gui/wxpython/gui_modules/menuform.py:885
 msgid ""
 "Close dialog when command is successfully finished. Change this settings in "
 "Preferences dialog ('Command' tab)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1059
+#: ../gui/wxpython/gui_modules/menuform.py:1060
 #, python-format
 msgid "'%s' copied to clipboard"
 msgstr "'%s' zkopírováno do schránky"
-#: ../gui/wxpython/gui_modules/menuform.py:1121
-#: ../gui/wxpython/gui_modules/menuform.py:1134
+#: ../gui/wxpython/gui_modules/menuform.py:1122
+#: ../gui/wxpython/gui_modules/menuform.py:1135
 msgid "Required"
 msgstr "Po¾adováno"
-#: ../gui/wxpython/gui_modules/menuform.py:1124
+#: ../gui/wxpython/gui_modules/menuform.py:1125
 msgid "Optional"
 msgstr "Volitelné"
-#: ../gui/wxpython/gui_modules/menuform.py:1174
+#: ../gui/wxpython/gui_modules/menuform.py:1168
 msgid "Manual"
 msgstr "Manuálová stránka"
-#: ../gui/wxpython/gui_modules/menuform.py:1215
-#: ../gui/wxpython/gui_modules/menuform.py:1726
+#: ../gui/wxpython/gui_modules/menuform.py:1208
+#: ../gui/wxpython/gui_modules/menuform.py:1719
 msgid "Parameterized in model"
 msgstr "Parametrizace v modelu"
-#: ../gui/wxpython/gui_modules/menuform.py:1290
+#: ../gui/wxpython/gui_modules/menuform.py:1283
 msgid "[multiple]"
 msgstr "[mnohonásobné]"
-#: ../gui/wxpython/gui_modules/menuform.py:1337
+#: ../gui/wxpython/gui_modules/menuform.py:1330
 msgid "valid range"
 msgstr "platný rozsah"
-#: ../gui/wxpython/gui_modules/menuform.py:1499
+#: ../gui/wxpython/gui_modules/menuform.py:1492
 msgid "Format"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1501
+#: ../gui/wxpython/gui_modules/menuform.py:1494
 msgid "Native / Linked OGR"
 msgstr ""
 #, fuzzy
 msgid "Direct OGR"
 msgstr "Smìr"
-#: ../gui/wxpython/gui_modules/menuform.py:1673
+#: ../gui/wxpython/gui_modules/menuform.py:1666
 msgid "Transparent"
 msgstr "Prùhledný"
-#: ../gui/wxpython/gui_modules/menuform.py:1689
+#: ../gui/wxpython/gui_modules/menuform.py:1682
 #, python-format
 msgid "Choose %s"
 msgstr "Vybrat %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1717
+#: ../gui/wxpython/gui_modules/menuform.py:1710
 msgid "or enter values interactively"
 msgstr "nebo vlo¾te hodnoty interaktivnì"
-#: ../gui/wxpython/gui_modules/menuform.py:2133
+#: ../gui/wxpython/gui_modules/menuform.py:2126
 #, python-format
 msgid "Error in %s"
 msgstr "Chyba v %s"
-#: ../gui/wxpython/gui_modules/menuform.py:2166
-#: ../gui/wxpython/gui_modules/menuform.py:2169
+#: ../gui/wxpython/gui_modules/menuform.py:2159
+#: ../gui/wxpython/gui_modules/menuform.py:2162
 msgid "Unable to fetch interface description for command '%s'."
 msgstr "Nelze získat popis rozhraní pro pøíkaz '%s'."
-#: ../gui/wxpython/gui_modules/menuform.py:2280
+#: ../gui/wxpython/gui_modules/menuform.py:2276
 msgid "Unable to parse command '%s'"
 msgstr "Nelze spustit pøíkaz %s"
-#: ../gui/wxpython/gui_modules/menuform.py:2284
+#: ../gui/wxpython/gui_modules/menuform.py:2280
 #, python-format
 msgid "%(cmd)s: parameter '%(key)s' not available"
 msgstr "%(cmd)s: parametr '%(key)s' není dostupný"
-#: ../gui/wxpython/gui_modules/menuform.py:2409
+#: ../gui/wxpython/gui_modules/menuform.py:2441
 #, python-format
 msgid "usage: %s <grass command>"
 msgstr "pou¾ití: %s <grass pøíkaz>"
@@ -11390,115 +11509,115 @@
 msgstr "Jdi na"
 #: ../gui/wxpython/gui_modules/globalvar.py:119
-#: ../gui/wxpython/gui_modules/preferences.py:1798
+#: ../gui/wxpython/gui_modules/preferences.py:1820
 msgid "Projection"
 msgstr "Projekce"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:269
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
 msgid "Easting"
 msgstr "Východ"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:270
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:290
 msgid "Northing"
 msgstr "Sever"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:271
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:291
 msgid "Elevation"
 msgstr "Vý¹ka"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:272
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:292
 msgid "Surface map elevation"
 msgstr "Vý¹ka mapy povrchu"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:273
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:293
 msgid "Surface map color"
 msgstr "Barva mapy povrchu"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:282
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:302
 msgid "XY distance from previous"
 msgstr "XY vzdálenost od pøedchozího"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:283
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:303
 msgid "XYZ distance from previous"
 msgstr "XYZ vzdálenost od pøedchozího"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:284
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:304
 #, fuzzy
 msgid "Distance along surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:309
 #, fuzzy
 msgid "Distance along exag. surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:296
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:316
 msgid "No point on surface"
 msgstr "®ádný bod na povrchu"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:301
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:321
 msgid "Function not implemented yet"
 msgstr "Funcke je¹tì není ilplementována"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:602
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:639
 msgid "Loading raster map"
 msgstr "Naèítám rastrovou mapu"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:606
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:643
 msgid "Loading 3d raster map"
 msgstr "Naèítám 3D rastrovou mapu"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:612
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:649
 msgid "failed"
 msgstr "selhalo"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:614
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:651
 #, python-format
 msgid "Unsupported layer type '%s'"
 msgstr "Nepodporovaný typ vrstvy '%s'"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:668
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:729
 msgid "Unable to unload raster map"
 msgstr "Nelze naèíst rastrovou mapu"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:673
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:734
 msgid "Unable to unload 3d raster map"
 msgstr "Nelze naèíst 3D rastrovou mapu"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:674
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:735
 msgid "3d raster map"
 msgstr "3D rastrová mapa:"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:681
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:742
 msgid "unloaded successfully"
 msgstr "naèteno "
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:725
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:786
 #, python-format
 msgid "Loading vector map <%(name)s> (%(type)s) failed"
 msgstr "Naèítání vektorové mapy '%(name)s' %(type)s selhalo"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:781
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:842
 #, python-format
 msgid "Unable to unload vector map <%(name)s> (%(type)s)"
 msgstr "Nelze naèíst vektorovou mapu <%(name)s> (%(type)s)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:784
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:845
 #, python-format
 msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
 msgstr "Vektorová mapa <%(name)s> (%(type)s) úspì¹nì naètena"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1071
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1148
 #, python-format
 msgid "Vector point layer not found (id = %d)"
 msgstr "Vektorová bodová vrstva nenalezena (id = %d)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1073
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1150
 #, python-format
 msgid "Unable to set data layer properties (id = %d)"
 msgstr "Nelze nastavit vlastnosti datové vrstvy (id = %d)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1076
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1153
 #, python-format
 msgid ""
 "Setting data layer properties failed.\n"
@@ -11509,102 +11628,107 @@
 "\n"
 "%s"
-#: ../gui/wxpython/gui_modules/preferences.py:416
+#: ../gui/wxpython/gui_modules/preferences.py:427
 msgid "Segment break"
 msgstr "Zlom segmentu"
-#: ../gui/wxpython/gui_modules/preferences.py:621
+#: ../gui/wxpython/gui_modules/preferences.py:637
 msgid "Collapse all except PERMANENT and current"
 msgstr "Zabalit v¹echny kromì PERMANENT a aktuální mapset"
-#: ../gui/wxpython/gui_modules/preferences.py:622
+#: ../gui/wxpython/gui_modules/preferences.py:638
 msgid "Collapse all except PERMANENT"
 msgstr "Zabalit v¹echny kromì PERMANENT mapset"
-#: ../gui/wxpython/gui_modules/preferences.py:623
+#: ../gui/wxpython/gui_modules/preferences.py:639
 msgid "Collapse all except current"
 msgstr "Zabalit v¹echny kromì aktuální mapset"
-#: ../gui/wxpython/gui_modules/preferences.py:624
+#: ../gui/wxpython/gui_modules/preferences.py:640
 msgid "Collapse all"
 msgstr "Zabalit v¹echny"
-#: ../gui/wxpython/gui_modules/preferences.py:625
+#: ../gui/wxpython/gui_modules/preferences.py:641
 msgid "Expand all"
 msgstr "Zozbalit v¹echny"
-#: ../gui/wxpython/gui_modules/preferences.py:627
+#: ../gui/wxpython/gui_modules/preferences.py:643
 msgid "Display selected"
 msgstr "Zobrazit vybrané"
-#: ../gui/wxpython/gui_modules/preferences.py:635
+#: ../gui/wxpython/gui_modules/preferences.py:651
 msgid "Classic (labels only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:636
+#: ../gui/wxpython/gui_modules/preferences.py:652
 msgid "Combined (labels and module names)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:637
+#: ../gui/wxpython/gui_modules/preferences.py:653
 msgid "Professional (module names only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:657
+#: ../gui/wxpython/gui_modules/preferences.py:673
 msgid "box"
 msgstr "rám"
-#: ../gui/wxpython/gui_modules/preferences.py:658
+#: ../gui/wxpython/gui_modules/preferences.py:674
 msgid "sphere"
 msgstr "koule"
-#: ../gui/wxpython/gui_modules/preferences.py:659
+#: ../gui/wxpython/gui_modules/preferences.py:675
 msgid "cube"
 msgstr "krychle"
-#: ../gui/wxpython/gui_modules/preferences.py:660
+#: ../gui/wxpython/gui_modules/preferences.py:676
 msgid "diamond"
 msgstr "diamant"
-#: ../gui/wxpython/gui_modules/preferences.py:661
+#: ../gui/wxpython/gui_modules/preferences.py:677
 msgid "dtree"
 msgstr "dtree"
-#: ../gui/wxpython/gui_modules/preferences.py:662
+#: ../gui/wxpython/gui_modules/preferences.py:678
 msgid "ctree"
 msgstr "ctree"
-#: ../gui/wxpython/gui_modules/preferences.py:663
+#: ../gui/wxpython/gui_modules/preferences.py:679
 msgid "aster"
 msgstr "astra"
-#: ../gui/wxpython/gui_modules/preferences.py:664
+#: ../gui/wxpython/gui_modules/preferences.py:680
 msgid "gyro"
 msgstr "gyro"
-#: ../gui/wxpython/gui_modules/preferences.py:665
+#: ../gui/wxpython/gui_modules/preferences.py:681
 msgid "histogram"
 msgstr "Histogram"
-#: ../gui/wxpython/gui_modules/preferences.py:727
-#, python-format
+#: ../gui/wxpython/gui_modules/preferences.py:713
+#, fuzzy, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr "Nelze provést nastavení '%s'"
+#: ../gui/wxpython/gui_modules/preferences.py:737
 msgid ""
 "Error: Reading settings from file <%(file)s> failed.\n"
-"       Details: %(detail)s\n"
-"       Line: '%(line)s'"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
 msgstr ""
 "Chyba: ètení nastavení ze souboru <%(file)s> selhano.\n"
 "       Detaily: %(detail)s\n"
 "       øádek: '%(line)s'"
-#: ../gui/wxpython/gui_modules/preferences.py:750
+#: ../gui/wxpython/gui_modules/preferences.py:758
 msgid "Cannot create directory for settings [home]/.grass7"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:751
+#: ../gui/wxpython/gui_modules/preferences.py:759
 msgid "Error saving preferences"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:787
+#: ../gui/wxpython/gui_modules/preferences.py:794
 #, python-format
 msgid ""
 "Writing settings to file <%(file)s> failed.\n"
@@ -11615,114 +11739,120 @@
 "\n"
 "Detaily: %(detail)s"
-#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/gui_modules/preferences.py:893
 msgid "Unable to set "
 msgstr "Nelze nastavit "
-#: ../gui/wxpython/gui_modules/preferences.py:914
-#: ../gui/wxpython/gui_modules/preferences.py:920
+#: ../gui/wxpython/gui_modules/preferences.py:919
+#: ../gui/wxpython/gui_modules/preferences.py:925
 #, python-format
 msgid "Unable to parse settings '%s'"
-#: ../gui/wxpython/gui_modules/preferences.py:931
+#: ../gui/wxpython/gui_modules/preferences.py:936
 msgid "User settings"
 msgstr "U¾ivatelské nastavení"
-#: ../gui/wxpython/gui_modules/preferences.py:951
+#: ../gui/wxpython/gui_modules/preferences.py:956
 msgid "Set to default"
 msgstr "Nastavit na výchozí nastavení"
-#: ../gui/wxpython/gui_modules/preferences.py:959
+#: ../gui/wxpython/gui_modules/preferences.py:964
 msgid "Revert settings to default and apply changes"
 msgstr "Znovu nastavit výchozí nastavení a ulo¾it"
-#: ../gui/wxpython/gui_modules/preferences.py:1021
+#: ../gui/wxpython/gui_modules/preferences.py:1026
 msgid "Settings applied to current session but not saved"
 msgstr "Nastavení jsou pøijata ale nejsou ulo¾ena "
-#: ../gui/wxpython/gui_modules/preferences.py:1039
+#: ../gui/wxpython/gui_modules/preferences.py:1044
 #, python-format
 msgid "Settings saved to file '%s'."
 msgstr "Nastavení ulo¾eno do souboru '%s'."
-#: ../gui/wxpython/gui_modules/preferences.py:1070
+#: ../gui/wxpython/gui_modules/preferences.py:1075
 msgid "Key column cannot be empty string."
 msgstr "Klíèový sloupec nemù¾e obsahovat prázdný øetìzec."
-#: ../gui/wxpython/gui_modules/preferences.py:1084
+#: ../gui/wxpython/gui_modules/preferences.py:1089
 #, fuzzy
 msgid "GUI Settings"
 msgstr "Nastavení grafického prostøedí (GUI)"
-#: ../gui/wxpython/gui_modules/preferences.py:1107
-msgid "General settings"
-msgstr "Obecné nastavení"
-#: ../gui/wxpython/gui_modules/preferences.py:1118
-msgid "Element list:"
-msgstr "Seznam prvkù"
-#: ../gui/wxpython/gui_modules/preferences.py:1140
-msgid "Save current window layout as default"
-msgstr "Ulo¾it aktuální nastavení oken jako výchozí"
-#: ../gui/wxpython/gui_modules/preferences.py:1143
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Ulo¾it aktuální pozici a velikost okna Správa vrstev a mapový displej a "
-"pou¾ít jako výchozí pøi pøí¹tích spu¹tìní."
-#: ../gui/wxpython/gui_modules/preferences.py:1156
+#: ../gui/wxpython/gui_modules/preferences.py:1115
 msgid "Layer Manager settings"
 msgstr "Nastavení okna Správy vrstev"
-#: ../gui/wxpython/gui_modules/preferences.py:1167
+#: ../gui/wxpython/gui_modules/preferences.py:1126
 msgid "Ask when removing map layer from layer tree"
 msgstr "Zeptat se pøi odstraòování mapy ze stromu vrstev"
-#: ../gui/wxpython/gui_modules/preferences.py:1177
+#: ../gui/wxpython/gui_modules/preferences.py:1136
 msgid "Ask when quiting wxGUI or closing display"
 msgstr "Zeptat se pøi ukonèení wxGUI nebo pøi zavírání displeje"
-#: ../gui/wxpython/gui_modules/preferences.py:1191
+#: ../gui/wxpython/gui_modules/preferences.py:1146
+#: ../gui/wxpython/gui_modules/preferences.py:1156
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1169
+msgid "Automatically copy selected text to clipboard (in Command console)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1183
 #, fuzzy
 msgid "Workspace settings"
 msgstr "Aktualizovat nastavení"
-#: ../gui/wxpython/gui_modules/preferences.py:1199
+#: ../gui/wxpython/gui_modules/preferences.py:1191
 msgid "Suppress positioning Map Display Window(s)"
 msgstr "Zachovat pozici okna Mapového displeje"
-#: ../gui/wxpython/gui_modules/preferences.py:1211
+#: ../gui/wxpython/gui_modules/preferences.py:1203
 msgid "Suppress positioning Layer Manager window"
 msgstr "Zachovat pozici okna Správce vrstev"
-#: ../gui/wxpython/gui_modules/preferences.py:1254
+#: ../gui/wxpython/gui_modules/preferences.py:1214
+msgid "Save current window layout as default"
+msgstr "Ulo¾it aktuální nastavení oken jako výchozí"
+#: ../gui/wxpython/gui_modules/preferences.py:1217
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+"Ulo¾it aktuální pozici a velikost okna Správa vrstev a mapový displej a "
+"pou¾ít jako výchozí pøi pøí¹tích spu¹tìní."
+#: ../gui/wxpython/gui_modules/preferences.py:1258
 msgid "Font for command output:"
 msgstr "Font pro výstup pøíkazù:"
-#: ../gui/wxpython/gui_modules/preferences.py:1268
+#: ../gui/wxpython/gui_modules/preferences.py:1272
 #, fuzzy
 msgid "Appearance settings"
 msgstr "Roz¹íøené nastavení"
-#: ../gui/wxpython/gui_modules/preferences.py:1280
+#: ../gui/wxpython/gui_modules/preferences.py:1283
+msgid "Element list:"
+msgstr "Seznam prvkù"
+#: ../gui/wxpython/gui_modules/preferences.py:1302
 #, fuzzy
 msgid "Menu style:"
 msgstr "Steinerùv strom"
-#: ../gui/wxpython/gui_modules/preferences.py:1304
+#: ../gui/wxpython/gui_modules/preferences.py:1326
 msgid "Height of map selection popup window (in pixels):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1328
+#: ../gui/wxpython/gui_modules/preferences.py:1350
 msgid "Icon theme:"
 msgstr "Téma ikonek:"
-#: ../gui/wxpython/gui_modules/preferences.py:1346
+#: ../gui/wxpython/gui_modules/preferences.py:1368
 msgid ""
 "Note: For changing the icon theme, you must save the settings and restart "
 "this GUI."
@@ -11730,117 +11860,117 @@
 "Poznámka: Pro zmìnu tématu ikon, musíte ulo¾it nastavení a poté restartovat "
 "GUI"
-#: ../gui/wxpython/gui_modules/preferences.py:1368
+#: ../gui/wxpython/gui_modules/preferences.py:1390
 #, fuzzy
 msgid "Map Display"
 msgstr "zobrazit"
-#: ../gui/wxpython/gui_modules/preferences.py:1383
+#: ../gui/wxpython/gui_modules/preferences.py:1405
 msgid "Default font for GRASS displays:"
 msgstr "Výchozí písmo pro GRASS monitory:"
-#: ../gui/wxpython/gui_modules/preferences.py:1400
+#: ../gui/wxpython/gui_modules/preferences.py:1422
 msgid "Default display settings"
 msgstr "Výchozí nastavení displeje"
-#: ../gui/wxpython/gui_modules/preferences.py:1412
+#: ../gui/wxpython/gui_modules/preferences.py:1434
 msgid "Display driver:"
 msgstr "Ovladaè displeje:"
-#: ../gui/wxpython/gui_modules/preferences.py:1432
+#: ../gui/wxpython/gui_modules/preferences.py:1454
 msgid "Statusbar mode:"
 msgstr "Výchozí zobrazení na stavové li¹tì:"
-#: ../gui/wxpython/gui_modules/preferences.py:1484
+#: ../gui/wxpython/gui_modules/preferences.py:1506
 msgid "Enable auto-rendering"
 msgstr "Zapnout/vypnout automatické vykreslování"
-#: ../gui/wxpython/gui_modules/preferences.py:1497
+#: ../gui/wxpython/gui_modules/preferences.py:1519
 msgid "Enable auto-zooming to selected map layer"
 msgstr "Povolit automatické pøiblí¾ení na vybranou mapovou vrstvu"
-#: ../gui/wxpython/gui_modules/preferences.py:1521
+#: ../gui/wxpython/gui_modules/preferences.py:1543
 msgid "Command dialog settings"
 msgstr "Dialog nastavení pøíkazù"
-#: ../gui/wxpython/gui_modules/preferences.py:1543
+#: ../gui/wxpython/gui_modules/preferences.py:1565
 #, fuzzy
 msgid "Close dialog when command is successfully finished"
-#: ../gui/wxpython/gui_modules/preferences.py:1564
+#: ../gui/wxpython/gui_modules/preferences.py:1586
 msgid "Allow interactive input"
 msgstr "Povolit interaktivní vstup"
-#: ../gui/wxpython/gui_modules/preferences.py:1574
+#: ../gui/wxpython/gui_modules/preferences.py:1596
 msgid "Verbosity level:"
 msgstr "Úroveò upovídanosti pøíkazù:"
-#: ../gui/wxpython/gui_modules/preferences.py:1593
+#: ../gui/wxpython/gui_modules/preferences.py:1615
 msgid "Raster settings"
 msgstr "Nastavení rastru"
-#: ../gui/wxpython/gui_modules/preferences.py:1604
+#: ../gui/wxpython/gui_modules/preferences.py:1626
 msgid "Make null cells opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1615
+#: ../gui/wxpython/gui_modules/preferences.py:1637
 msgid "Default color table"
 msgstr "Výchozí tabulka barev"
-#: ../gui/wxpython/gui_modules/preferences.py:1641
+#: ../gui/wxpython/gui_modules/preferences.py:1663
 msgid "Vector settings"
 msgstr "Nastavení vektorù"
-#: ../gui/wxpython/gui_modules/preferences.py:1647
+#: ../gui/wxpython/gui_modules/preferences.py:1669
 msgid "Display:"
 msgstr "Zobrazit:"
-#: ../gui/wxpython/gui_modules/preferences.py:1677
+#: ../gui/wxpython/gui_modules/preferences.py:1699
 msgid "Highlighting"
 msgstr "Zvýraznìní"
-#: ../gui/wxpython/gui_modules/preferences.py:1693
+#: ../gui/wxpython/gui_modules/preferences.py:1715
 msgid "Line width (in pixels):"
 msgstr "©íøka linie (v pixelech):"
-#: ../gui/wxpython/gui_modules/preferences.py:1716
+#: ../gui/wxpython/gui_modules/preferences.py:1738
 msgid "Data browser"
 msgstr "Datový prohlí¾eè"
-#: ../gui/wxpython/gui_modules/preferences.py:1721
+#: ../gui/wxpython/gui_modules/preferences.py:1743
 msgid "Left mouse double click:"
 msgstr "Dvojklik levých tlaèítkem my¹i:"
-#: ../gui/wxpython/gui_modules/preferences.py:1733
+#: ../gui/wxpython/gui_modules/preferences.py:1755
 msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
 msgstr "Kódování atributù (napø. utf-8, ascii, iso8859-1, Windows-1250):"
-#: ../gui/wxpython/gui_modules/preferences.py:1744
+#: ../gui/wxpython/gui_modules/preferences.py:1766
 msgid "Ask when deleting data record(s) from table"
 msgstr "Zeptat se pøi odstraòování dat z tabulky"
-#: ../gui/wxpython/gui_modules/preferences.py:1765
+#: ../gui/wxpython/gui_modules/preferences.py:1787
 msgid "Create table"
 msgstr "Vytvoøit tabulku"
-#: ../gui/wxpython/gui_modules/preferences.py:1772
+#: ../gui/wxpython/gui_modules/preferences.py:1794
 msgid "Key column:"
 msgstr "Sloupec s klíèem:"
-#: ../gui/wxpython/gui_modules/preferences.py:1805
+#: ../gui/wxpython/gui_modules/preferences.py:1827
 msgid "Projection statusbar settings"
 msgstr "Nastavení stavového øádku projekce"
-#: ../gui/wxpython/gui_modules/preferences.py:1831
+#: ../gui/wxpython/gui_modules/preferences.py:1853
 msgid "Proj.4 string (required):"
 msgstr "Proj.4 øatìzec (vy¾adováno):"
-#: ../gui/wxpython/gui_modules/preferences.py:1847
+#: ../gui/wxpython/gui_modules/preferences.py:1869
 msgid "EPSG file:"
 msgstr "Soubor s EPSG kódy:"
-#: ../gui/wxpython/gui_modules/preferences.py:1862
+#: ../gui/wxpython/gui_modules/preferences.py:1884
 msgid ""
 "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
 "directly."
@@ -11848,55 +11978,55 @@
 "Naèíst EPSG kódy (buïte trpìliví), vlo¾it EPSG k´d nebo vlo¾it Proj.4øetìzec "
 "pøímo."
-#: ../gui/wxpython/gui_modules/preferences.py:1870
+#: ../gui/wxpython/gui_modules/preferences.py:1892
 msgid "&Load EPSG codes"
 msgstr "&Naèíst Kódy EPSG:"
-#: ../gui/wxpython/gui_modules/preferences.py:1881
+#: ../gui/wxpython/gui_modules/preferences.py:1903
 msgid "Coordinates format"
 msgstr "Formát souøadnic"
-#: ../gui/wxpython/gui_modules/preferences.py:1890
+#: ../gui/wxpython/gui_modules/preferences.py:1912
 msgid "LL projections"
 msgstr "Projekce Lat/long"
-#: ../gui/wxpython/gui_modules/preferences.py:1909
+#: ../gui/wxpython/gui_modules/preferences.py:1931
 msgid "Precision:"
 msgstr "Pøesnost:"
-#: ../gui/wxpython/gui_modules/preferences.py:1947
+#: ../gui/wxpython/gui_modules/preferences.py:1969
 #, python-format
 msgid "Unable to read EPSG codes: %s"
 msgstr "Nelze pøe¹íst EPSG kódy: %s"
-#: ../gui/wxpython/gui_modules/preferences.py:1976
-#: ../gui/wxpython/gui_modules/preferences.py:1985
-#: ../gui/wxpython/gui_modules/preferences.py:1995
+#: ../gui/wxpython/gui_modules/preferences.py:1998
+#: ../gui/wxpython/gui_modules/preferences.py:2007
+#: ../gui/wxpython/gui_modules/preferences.py:2017
 #, python-format
 msgid "EPSG code %s not found"
 msgstr "EPSG kód %s nebyl nalezen"
-#: ../gui/wxpython/gui_modules/preferences.py:2003
+#: ../gui/wxpython/gui_modules/preferences.py:2025
 msgid "Select default display font"
 msgstr "Vybrat výchozí písmo"
-#: ../gui/wxpython/gui_modules/preferences.py:2028
+#: ../gui/wxpython/gui_modules/preferences.py:2050
 msgid "Select output font"
 msgstr "Zvolit font výstupu"
-#: ../gui/wxpython/gui_modules/preferences.py:2121
+#: ../gui/wxpython/gui_modules/preferences.py:2143
 msgid "Select font:"
 msgstr "Vybrat font:"
-#: ../gui/wxpython/gui_modules/preferences.py:2145
+#: ../gui/wxpython/gui_modules/preferences.py:2167
 msgid "Character encoding:"
 msgstr "Kódování znakù:"
-#: ../gui/wxpython/gui_modules/preferences.py:2263
+#: ../gui/wxpython/gui_modules/preferences.py:2285
 msgid "Manage access to mapsets"
 msgstr "Správa pøístupu do mapsetù"
-#: ../gui/wxpython/gui_modules/preferences.py:2276
+#: ../gui/wxpython/gui_modules/preferences.py:2298
 msgid ""
 "Check a mapset to make it accessible, uncheck it to hide it.\n"
 "  Notes:\n"
@@ -11910,11 +12040,11 @@
 " - Mù¾ete zapisovat pouze do souèasného mapsetu.\n"
 " - Mù¾ete zapisovat pouze do mapsetu  který vlastníte."
-#: ../gui/wxpython/gui_modules/preferences.py:2350
+#: ../gui/wxpython/gui_modules/preferences.py:2372
 msgid "Mapset"
 msgstr "Mapset"
-#: ../gui/wxpython/gui_modules/preferences.py:2351
+#: ../gui/wxpython/gui_modules/preferences.py:2373
 msgid "Owner"
 msgstr "Vlastník"
@@ -12195,6 +12325,79 @@
 "databanka). Vytvoøte takový adresáø, jestli¾e ji¾ takový nemáte vytvoøen. "
 "OBlíbený název je \"grassdata\", umístìn ve va¹m domovském adresáøi."
+#~ msgid "Load map layers into layer tree"
+#~ msgstr "Naèíst mapové vrstvy do seznamu"
+#~ msgid "Load map layers into workspace (Ctrl+L)"
+#~ msgstr "Naèíst mapové vrstvy do pracovní oblasti (Ctrl+L)"
+#, fuzzy
+#~ msgid "Hardcopy Map Ouput Utility"
+#~ msgstr "Nástroj pro tvorbu mapových výstupù ve formátu PostScript."
+#~ msgid "Load map layers"
+#~ msgstr "Naèíst mapové vrstvy"
+#~ msgid "north"
+#~ msgstr "sever"
+#~ msgid "south"
+#~ msgstr "jih"
+#~ msgid "east"
+#~ msgstr "východ"
+#~ msgid "west"
+#~ msgstr "západ"
+#~ msgid "north-west"
+#~ msgstr "severo-západ"
+#~ msgid "north-east"
+#~ msgstr "severo-východ"
+#~ msgid "south-east"
+#~ msgstr "jiho-východ"
+#~ msgid "south-west"
+#~ msgstr "jiho-západ"
+#~ msgid "Topography"
+#~ msgstr "Topografie"
+#~ msgid "res."
+#~ msgstr "rozl."
+#~ msgid "Fine:"
+#~ msgstr "Vyhlazený:"
+#~ msgid "Mask zeros:"
+#~ msgstr "Maskovat nulové hodnoty"
+#~ msgid "by elevation"
+#~ msgstr "podle vý¹ky"
+#~ msgid "by color"
+#~ msgstr "podle barvy"
+#~ msgid "color"
+#~ msgstr "barva"
+#~ msgid "display"
+#~ msgstr "zobrazit"
+#~ msgid "size"
+#~ msgstr "velikost"
+#~ msgid "symbol"
+#~ msgstr "symbol"
+#~ msgid "Nviz settings saved to file <%s>."
+#~ msgstr "Nastavení Nviz ulo¾eno do souboru <%s>."
+#~ msgid "General settings"
+#~ msgstr "Obecné nastavení"
 #~ msgid "Start Graphical Modeler"
 #~ msgstr "Spustit Grafické modelování"
@@ -12721,12 +12924,6 @@
 #~ msgid "fine:"
 #~ msgstr "jemný:"
-#~ msgid "width:"
-#~ msgstr "¹íøka:"
-#~ msgid "color:"
-#~ msgstr "barva:"
 #~ msgid "Import raster data using GDAL"
 #~ msgstr "Import rastrových dat pomocí GDAL"
@@ -12841,9 +13038,6 @@
 #~ msgid "Icon size:"
 #~ msgstr "Velikost ikon:"
-#~ msgid "Vector map <%s> is 3D"
-#~ msgstr "Vektorové mapa <%s> je 3D"
 #~ msgid "Vector map <%s> is 2D"
 #~ msgstr "Vektorová mapa <%s> je 2D"
Modified: grass/trunk/locale/po/grasswxpy_de.po
--- grass/trunk/locale/po/grasswxpy_de.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasswxpy_de.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -6,13 +6,13 @@
 # Georg Lösel <georg*de-schorsch.de>, 2008.
 # Markus Neteler <neteler osgeo.org>, 2008, 2009, 2010.
 # Robert Nuske <rnuske gwdg.de>, 2009, 2010.
-#: ../gui/wxpython/gui_modules/psmap.py:1097
+#: ../gui/wxpython/gui_modules/psmap.py:1096
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2211
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_de\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2011-05-14 23:51+0100\n"
 "Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
 "Language-Team: Deutsch <grass-translations at lists.osgeo.org>\n"
@@ -22,57 +22,73 @@
 "Language: \n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
-#: ../gui/wxpython/wxgui.py:96
+#: ../gui/wxpython/wxgui.py:97
 msgid "GRASS GIS Layer Manager"
 msgstr "GRASS GIS Ebenen-Manager"
-#: ../gui/wxpython/wxgui.py:136
+#: ../gui/wxpython/wxgui.py:139
 #, fuzzy
-msgid "Main Toolbar"
+msgid "Data Toolbar"
 msgstr "Werkzeugleiste Karte"
-#: ../gui/wxpython/wxgui.py:144
+#: ../gui/wxpython/wxgui.py:147
 #, fuzzy
+msgid "Workspace Toolbar"
+msgstr "Projekt"
+#: ../gui/wxpython/wxgui.py:155
+#, fuzzy
+msgid "Misc Toolbar"
+msgstr "Werkzeugleiste Karte"
+#: ../gui/wxpython/wxgui.py:163
+#, fuzzy
 msgid "Tools Toolbar"
-#: ../gui/wxpython/wxgui.py:231
+#: ../gui/wxpython/wxgui.py:250
 msgid "Map layers"
 msgstr "Kartenebenen"
-#: ../gui/wxpython/wxgui.py:235 ../gui/wxpython/wxgui.py:375
+#: ../gui/wxpython/wxgui.py:254 ../gui/wxpython/wxgui.py:407
 msgid "Command console"
 msgstr "Befehlszeile"
-#: ../gui/wxpython/wxgui.py:239
+#: ../gui/wxpython/wxgui.py:260
 msgid "Search module"
 msgstr "Suchmodul"
-#: ../gui/wxpython/wxgui.py:252 ../gui/wxpython/gui_modules/toolbars.py:207
+#: ../gui/wxpython/wxgui.py:267
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:282 ../gui/wxpython/gui_modules/toolbars.py:211
 msgid "3D view"
 msgstr "3D Ansicht"
-#: ../gui/wxpython/wxgui.py:296
+#: ../gui/wxpython/wxgui.py:328
 msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
 msgstr ""
 "Hardcopy Map Output Utility ist nicht verfügbar. Dies kann mit Hilfe von %s "
 "installiert werden"
-#: ../gui/wxpython/wxgui.py:315
+#: ../gui/wxpython/wxgui.py:347
 msgid "Choose model to run"
 msgstr "Wähle auszuführendes Modell"
-#: ../gui/wxpython/wxgui.py:317 ../gui/wxpython/gui_modules/gmodeler.py:802
-#: ../gui/wxpython/gui_modules/gmodeler.py:846
+#: ../gui/wxpython/wxgui.py:349 ../gui/wxpython/gui_modules/gmodeler.py:796
+#: ../gui/wxpython/gui_modules/gmodeler.py:840
 msgid "GRASS Model File (*.gxm)|*.gxm"
 msgstr "GRASS Model File (*.gxm)|*.gxm"
-#: ../gui/wxpython/wxgui.py:326 ../gui/wxpython/gui_modules/gmodeler.py:1117
+#: ../gui/wxpython/wxgui.py:358 ../gui/wxpython/gui_modules/gmodeler.py:1111
 msgid "Validating model..."
 msgstr "Überprüfe Modell..."
-#: ../gui/wxpython/wxgui.py:330 ../gui/wxpython/gui_modules/gmodeler.py:919
+#: ../gui/wxpython/wxgui.py:362 ../gui/wxpython/gui_modules/gmodeler.py:913
 #, python-format
 msgid ""
 "Model is not valid. Do you want to run the model anyway?\n"
@@ -83,62 +99,62 @@
 "\n"
 "%s"
-#: ../gui/wxpython/wxgui.py:332 ../gui/wxpython/gui_modules/gmodeler.py:921
+#: ../gui/wxpython/wxgui.py:364 ../gui/wxpython/gui_modules/gmodeler.py:915
 msgid "Run model?"
 msgstr "Ausführen des Modells?"
-#: ../gui/wxpython/wxgui.py:339 ../gui/wxpython/gui_modules/gmodeler.py:984
+#: ../gui/wxpython/wxgui.py:371 ../gui/wxpython/gui_modules/gmodeler.py:978
 msgid "Running model..."
 msgstr "Modell wird ausgeführt..."
-#: ../gui/wxpython/wxgui.py:389 ../gui/wxpython/wxgui.py:1476
+#: ../gui/wxpython/wxgui.py:421 ../gui/wxpython/wxgui.py:1500
 msgid "Do you want to save changes in the workspace?"
 msgstr "Wollen Sie die Änderungen im Projekt speichern?"
-#: ../gui/wxpython/wxgui.py:391 ../gui/wxpython/wxgui.py:1478
+#: ../gui/wxpython/wxgui.py:423 ../gui/wxpython/wxgui.py:1502
 msgid "Do you want to store current settings to workspace file?"
 msgstr ""
 "Wollen Sie die aktuellen Einstellungen in einer Projektdatei speichern?"
-#: ../gui/wxpython/wxgui.py:398
+#: ../gui/wxpython/wxgui.py:430
 #, python-format
 msgid "Close Map Display %d"
 msgstr "Schließe Kartenanzeige %d"
-#: ../gui/wxpython/wxgui.py:497 ../gui/wxpython/wxgui.py:1159
+#: ../gui/wxpython/wxgui.py:529 ../gui/wxpython/wxgui.py:1155
 #, fuzzy
 msgid "Selected map layer is not vector."
 msgstr "Ausgwählte Karte ist keine Vektorkarte."
-#: ../gui/wxpython/wxgui.py:502
+#: ../gui/wxpython/wxgui.py:534
 #, fuzzy
 msgid "Editing is allowed only for vector maps from the current mapset."
 msgstr "Erzeuge Topologie für alle Vektorkarten im aktuellen Mapset."
-#: ../gui/wxpython/wxgui.py:517
+#: ../gui/wxpython/wxgui.py:549
 msgid "Choose script file to run"
 msgstr "Wähle auszuführendes Skript"
-#: ../gui/wxpython/wxgui.py:519
+#: ../gui/wxpython/wxgui.py:551
 msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
 msgstr "Python Skript (*.py)|*.py|Bash Skript (*.sh)|*.sh"
-#: ../gui/wxpython/wxgui.py:530
+#: ../gui/wxpython/wxgui.py:562
 #, python-format
 msgid "Script file '%s' doesn't exist. Operation cancelled."
 msgstr "Skript-Datei '%s' ist nicht vorhanden. Berechnung wurde abgebrochen."
-#: ../gui/wxpython/wxgui.py:534
+#: ../gui/wxpython/wxgui.py:566
 #, python-format
 msgid "Launching script '%s'..."
 msgstr "Starten des Skriptes '%s'..."
-#: ../gui/wxpython/wxgui.py:549
+#: ../gui/wxpython/wxgui.py:581
 #, python-format
 msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
 msgstr "Kann nicht in Location <%(loc)s>  und Mapset <%(mapset)s> wechseln."
-#: ../gui/wxpython/wxgui.py:551 ../gui/wxpython/wxgui.py:572
+#: ../gui/wxpython/wxgui.py:583 ../gui/wxpython/wxgui.py:604
 #: ../gui/wxpython/scripts/r.li.setup.py:337
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1686
 #: ../gui/wxpython/gui_modules/mapdisp.py:367
@@ -153,8 +169,8 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:1029
 #: ../gui/wxpython/gui_modules/vdigit.py:1221
 #: ../gui/wxpython/gui_modules/vdigit.py:1247
-#: ../gui/wxpython/gui_modules/gmodeler.py:1438
-#: ../gui/wxpython/gui_modules/workspace.py:984
+#: ../gui/wxpython/gui_modules/gmodeler.py:1432
+#: ../gui/wxpython/gui_modules/workspace.py:991
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5365
 #: ../gui/wxpython/gui_modules/dbm.py:165
 #: ../gui/wxpython/gui_modules/dbm.py:1407
@@ -173,18 +189,18 @@
 #: ../gui/wxpython/gui_modules/profile.py:598
 #: ../gui/wxpython/gui_modules/layertree.py:505
 #: ../gui/wxpython/gui_modules/layertree.py:536
-#: ../gui/wxpython/gui_modules/preferences.py:1071
-#: ../gui/wxpython/gui_modules/preferences.py:1948
-#: ../gui/wxpython/gui_modules/preferences.py:1977
-#: ../gui/wxpython/gui_modules/preferences.py:1986
-#: ../gui/wxpython/gui_modules/preferences.py:1996
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+#: ../gui/wxpython/gui_modules/preferences.py:1970
+#: ../gui/wxpython/gui_modules/preferences.py:1999
+#: ../gui/wxpython/gui_modules/preferences.py:2008
+#: ../gui/wxpython/gui_modules/preferences.py:2018
 #: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:466
 #: ../gui/wxpython/gis_set.py:502 ../gui/wxpython/gis_set.py:568
 #: ../gui/wxpython/gis_set.py:725
 msgid "Error"
 msgstr "Fehler"
-#: ../gui/wxpython/wxgui.py:557
+#: ../gui/wxpython/wxgui.py:589
 #, python-format
 msgid ""
 "Current location is <%(loc)s>.\n"
@@ -193,22 +209,22 @@
 "Aktuelle Location ist <%(loc)s>.\n"
 "Aktuelles Mapset ist <%(mapset)s>."
-#: ../gui/wxpython/wxgui.py:560 ../gui/wxpython/wxgui.py:576
+#: ../gui/wxpython/wxgui.py:592 ../gui/wxpython/wxgui.py:608
 #: ../gui/wxpython/gui_modules/ghelp.py:563
 msgid "Info"
 msgstr "Info"
-#: ../gui/wxpython/wxgui.py:571
+#: ../gui/wxpython/wxgui.py:603
 #, python-format
 msgid "Unable to switch to mapset <%s>."
 msgstr "Kann nicht in Mapset <%s> wechseln."
-#: ../gui/wxpython/wxgui.py:575
+#: ../gui/wxpython/wxgui.py:607
 #, python-format
 msgid "Current mapset is <%s>."
 msgstr "Aktuelles Mapset ist <%s>."
-#: ../gui/wxpython/wxgui.py:652
+#: ../gui/wxpython/wxgui.py:676
 msgid ""
 "Current workspace is not empty. Do you want to store current settings to "
 "workspace file?"
@@ -216,19 +232,19 @@
 "Aktuelles Projekt ist nicht leer. Wollen Sie die aktuellen Einstellungen in "
 "einer Projektdatei speichern?"
-#: ../gui/wxpython/wxgui.py:655
+#: ../gui/wxpython/wxgui.py:679
 msgid "Create new workspace?"
 msgstr "Neues Projekt erstellen?"
-#: ../gui/wxpython/wxgui.py:681
+#: ../gui/wxpython/wxgui.py:705
 msgid "Choose workspace file"
 msgstr "Wählen Sie eine Projektdatei"
-#: ../gui/wxpython/wxgui.py:682 ../gui/wxpython/wxgui.py:889
+#: ../gui/wxpython/wxgui.py:706 ../gui/wxpython/wxgui.py:885
 msgid "GRASS Workspace File (*.gxw)|*.gxw"
 msgstr "GRASS Workspace File (*.gxw)|*.gxw"
-#: ../gui/wxpython/wxgui.py:717
+#: ../gui/wxpython/wxgui.py:741
 #, python-format
 msgid ""
 "Reading workspace file <%s> failed.\n"
@@ -237,58 +253,59 @@
 "Lesen der Workspace-Datei <%s> fehlgeschlagen.\n"
 "Ungültige Datei, Parsen des XML-Dokumentes nicht möglich."
-#: ../gui/wxpython/wxgui.py:721 ../gui/wxpython/wxgui.py:830
-#: ../gui/wxpython/wxgui.py:866
+#: ../gui/wxpython/wxgui.py:745 ../gui/wxpython/wxgui.py:862
+#: ../gui/wxpython/wxgui.py:1241
 msgid "Please wait, loading workspace..."
 msgstr "Bitte warten Sie, ich lade das Projekt..."
-#: ../gui/wxpython/wxgui.py:822 ../gui/wxpython/menustrings.py:15
-msgid "Load map layers into layer tree"
-msgstr "Kartenebenen in Baumstruktur laden"
-#: ../gui/wxpython/wxgui.py:850
+#: ../gui/wxpython/wxgui.py:846
 msgid "Choose GRC file to load"
 msgstr "Wählen Sie die zu ladende GRC-Datei"
-#: ../gui/wxpython/wxgui.py:851
+#: ../gui/wxpython/wxgui.py:847
 msgid "Old GRASS Workspace File (*.grc)|*.grc"
 msgstr "Alter GRASS Workspace File (*.grc)|*.grc"
-#: ../gui/wxpython/wxgui.py:888
+#: ../gui/wxpython/wxgui.py:884
 msgid "Choose file to save current workspace"
 msgstr "Wählen Sie eine Datei, um das aktuelle Projekt zu speichern"
-#: ../gui/wxpython/wxgui.py:903 ../gui/wxpython/wxgui.py:919
+#: ../gui/wxpython/wxgui.py:899 ../gui/wxpython/wxgui.py:915
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
 "Projektdatei <%s> existiert bereits. Wollen Sie die Datei überschreiben?"
-#: ../gui/wxpython/wxgui.py:905 ../gui/wxpython/wxgui.py:922
+#: ../gui/wxpython/wxgui.py:901 ../gui/wxpython/wxgui.py:918
 #: ../gui/wxpython/menustrings.py:9
 msgid "Save workspace"
 msgstr "Speichere Projekt"
-#: ../gui/wxpython/wxgui.py:943
+#: ../gui/wxpython/wxgui.py:939
 msgid "Writing current settings to workspace file failed."
 msgstr ""
 "Schreiben der aktuellen Einstellungen in die Workspace-Datei fehlgeschlagen."
-#: ../gui/wxpython/wxgui.py:954 ../gui/wxpython/gui_modules/gmodeler.py:1437
+#: ../gui/wxpython/wxgui.py:950 ../gui/wxpython/gui_modules/gmodeler.py:1431
 #: ../gui/wxpython/gui_modules/profile.py:597
 #, python-format
 msgid "Unable to open file <%s> for writing."
 msgstr "Kann die Datei <%s> nicht zum Schreiben öffnen."
-#: ../gui/wxpython/wxgui.py:1132
+#: ../gui/wxpython/wxgui.py:1128
 msgid "Nothing to import. No WMS layer selected."
 msgstr "Kein Import. Kein WMS-Layer ausgewählt."
-#: ../gui/wxpython/wxgui.py:1168
+#: ../gui/wxpython/wxgui.py:1164
 msgid "Please wait, loading attribute data..."
 msgstr "Bitte warten Sie, ich lade Attributdaten..."
-#: ../gui/wxpython/wxgui.py:1418
+#: ../gui/wxpython/wxgui.py:1233
+#, fuzzy
+msgid "Add selected map layers into layer tree"
+msgstr "Importierte Ebenen der Baumstruktur hinzufügen"
+#: ../gui/wxpython/wxgui.py:1442
 #, python-format
 msgid ""
 "Do you want to remove map layer(s)\n"
@@ -299,24 +316,24 @@
 "%s\n"
 "aus der Baumstruktur entfernen?"
-#: ../gui/wxpython/wxgui.py:1421
+#: ../gui/wxpython/wxgui.py:1445
 msgid "Do you want to remove selected map layer(s) from layer tree?"
 msgstr ""
 "Wollen Sie die selektierten Kartenebene(n) aus der Baumstruktur entfernen?"
-#: ../gui/wxpython/wxgui.py:1425
+#: ../gui/wxpython/wxgui.py:1449
 msgid "Remove map layer"
 msgstr "Entferne Kartenebene"
-#: ../gui/wxpython/wxgui.py:1485
+#: ../gui/wxpython/wxgui.py:1509
 msgid "Quit GRASS GUI"
 msgstr "GRASS GUI schließen"
-#: ../gui/wxpython/wxgui.py:1514
+#: ../gui/wxpython/wxgui.py:1538
 msgid "No map layer selected. Operation cancelled."
 msgstr "Keine Kartenebene selektiert. Breche die Operation ab."
-#: ../gui/wxpython/wxgui.py:1515 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
+#: ../gui/wxpython/wxgui.py:1539 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
 #: ../gui/wxpython/gui_modules/ghelp.py:287
 #: ../gui/wxpython/gui_modules/gcmd.py:98
 #: ../gui/wxpython/gui_modules/dbm.py:2056
@@ -325,7 +342,7 @@
 msgid "Message"
 msgstr "Nachricht"
-#: ../gui/wxpython/wxgui.py:1545
+#: ../gui/wxpython/wxgui.py:1569
 msgid "Starting GRASS GUI..."
 msgstr "Starte GRASS GUI..."
@@ -429,7 +446,7 @@
 msgid "Add scalebar and north arrow"
 msgstr "Maßstab und Nordpfeil hinzufügen"
-#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:438
+#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:440
 msgid "Add legend"
 msgstr "Legende hinzufügen"
@@ -439,7 +456,7 @@
 #: ../gui/wxpython/icons/icon.py:152
 #: ../gui/wxpython/gui_modules/histogram.py:440
-#: ../gui/wxpython/gui_modules/mapdisp.py:1179
+#: ../gui/wxpython/gui_modules/mapdisp.py:1187
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:942
 msgid "Print display"
 msgstr "Anzeige drucken"
@@ -461,7 +478,7 @@
 msgstr "Zuprofilierende Oberflächenkarte"
 #: ../gui/wxpython/icons/icon.py:161
-#: ../gui/wxpython/gui_modules/mapdisp.py:1877
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
 msgid "Add text layer"
 msgstr "Text-Ebene hinzufügen"
@@ -479,583 +496,589 @@
 msgstr "Erzeuge neue Workspace-Datei (Ctrl+N)"
 #: ../gui/wxpython/icons/icon.py:171
-msgid "Load map layers into workspace (Ctrl+L)"
-msgstr "Lade Kartenlayer in Workspace (Ctrl+L)"
-#: ../gui/wxpython/icons/icon.py:173
 msgid "Open existing workspace file (Ctrl+O)"
 msgstr "Öffne bestehende Workspace-Datei (Ctrl+O)"
-#: ../gui/wxpython/icons/icon.py:175
+#: ../gui/wxpython/icons/icon.py:173
 msgid "Save current workspace to file (Ctrl+S)"
 msgstr "Speicher aktuelle Workspace-Datei (Ctrl+S)"
-#: ../gui/wxpython/icons/icon.py:177 ../gui/wxpython/menustrings.py:29
-#: ../gui/wxpython/gui_modules/gdialogs.py:1146
+#: ../gui/wxpython/icons/icon.py:175
+#, fuzzy
+msgid "Add multiple raster or vector map layers (Ctrl+L)"
+msgstr "Rasterkarte hinzufügen (Ctrl+R)"
+#: ../gui/wxpython/icons/icon.py:177
+#, fuzzy
+msgid "Import/link raster or vector data"
+msgstr "Importiere Rasterdaten"
+#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_modules/gdialogs.py:1147
 msgid "Import raster data"
-#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/gui_modules/gdialogs.py:1144
+#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:148
+#: ../gui/wxpython/gui_modules/gdialogs.py:1145
 msgid "Link external raster data"
 msgstr "Einbindung externer Rasterdaten"
-#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:56
-#: ../gui/wxpython/gui_modules/gdialogs.py:1140
+#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_modules/gdialogs.py:1141
 msgid "Import vector data"
 msgstr "Importiere Vektordaten"
-#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:150
-#: ../gui/wxpython/gui_modules/gdialogs.py:1138
+#: ../gui/wxpython/icons/icon.py:185 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_modules/gdialogs.py:1139
 msgid "Link external vector data"
 msgstr "Einbindung externer Vektordaten"
-#: ../gui/wxpython/icons/icon.py:185
+#: ../gui/wxpython/icons/icon.py:187
 msgid "Add raster map layer (Ctrl+R)"
-#: ../gui/wxpython/icons/icon.py:187
+#: ../gui/wxpython/icons/icon.py:189
 msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
 msgstr "Verschiedene Rasterkartenlayer hinzufügen (RGB, HIS, shaded relief...)"
-#: ../gui/wxpython/icons/icon.py:189
+#: ../gui/wxpython/icons/icon.py:191
 msgid "Add vector map layer (Ctrl+V)"
 msgstr "Vektorkartenlayer hinzufügen (Ctrl+V)"
-#: ../gui/wxpython/icons/icon.py:191
+#: ../gui/wxpython/icons/icon.py:193
 msgid "Add various vector map layers (thematic, chart...)"
 msgstr "Verschiedene Vektorkarten hinzufügen (thematisch, Diagramm...)"
-#: ../gui/wxpython/icons/icon.py:193
+#: ../gui/wxpython/icons/icon.py:195
 msgid "Add command layer"
 msgstr "Befehlslayer hinzufügen"
-#: ../gui/wxpython/icons/icon.py:195
+#: ../gui/wxpython/icons/icon.py:197
 msgid "Add group"
 msgstr "Ebenen-Gruppe hinzufügen"
-#: ../gui/wxpython/icons/icon.py:197
+#: ../gui/wxpython/icons/icon.py:199
 msgid "Add grid or vector labels overlay"
 msgstr "Gitternetz oder Vektorbeschriftung hinzufügen"
-#: ../gui/wxpython/icons/icon.py:199
+#: ../gui/wxpython/icons/icon.py:201
 msgid "Delete selected map layer"
 msgstr "Selektierte Ebenen löschen"
-#: ../gui/wxpython/icons/icon.py:201 ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/icons/icon.py:203 ../gui/wxpython/icons/icon.py:403
 msgid "Quit"
 msgstr "Beenden"
-#: ../gui/wxpython/icons/icon.py:203
+#: ../gui/wxpython/icons/icon.py:205
 msgid "Show attribute table"
 msgstr "Attributtabelle anzeigen"
-#: ../gui/wxpython/icons/icon.py:205
+#: ../gui/wxpython/icons/icon.py:207
 msgid "Edit vector maps"
 msgstr "Editiere Vektorkarte"
-#: ../gui/wxpython/icons/icon.py:207
+#: ../gui/wxpython/icons/icon.py:209
 msgid "Add RGB map layer"
 msgstr "RGB-Karte hinzufügen"
-#: ../gui/wxpython/icons/icon.py:209
+#: ../gui/wxpython/icons/icon.py:211
 msgid "Add HIS map layer"
 msgstr "HIS-Karte hinzufügen"
-#: ../gui/wxpython/icons/icon.py:211
+#: ../gui/wxpython/icons/icon.py:213
 msgid "Add shaded relief map layer"
 msgstr "Ebene Schummerungskarte hinzufügen"
-#: ../gui/wxpython/icons/icon.py:213
+#: ../gui/wxpython/icons/icon.py:215
 msgid "Add raster flow arrows"
 msgstr "Raster mit Vektoren hinzufügen"
-#: ../gui/wxpython/icons/icon.py:215
+#: ../gui/wxpython/icons/icon.py:217
 msgid "Add raster cell numbers"
 msgstr "Rasternummern hinzufügen"
-#: ../gui/wxpython/icons/icon.py:217
+#: ../gui/wxpython/icons/icon.py:219
 #, fuzzy
 msgid "Add thematic area (choropleth) map layer"
 msgstr "Ebene mit Diagrammen hinzufügen"
-#: ../gui/wxpython/icons/icon.py:219
+#: ../gui/wxpython/icons/icon.py:221
 msgid "Add thematic chart layer"
-#: ../gui/wxpython/icons/icon.py:221
+#: ../gui/wxpython/icons/icon.py:223
 msgid "Add grid layer"
 msgstr "Ebene mit Gitternetz hinzufügen"
-#: ../gui/wxpython/icons/icon.py:223
+#: ../gui/wxpython/icons/icon.py:225
 msgid "Add geodesic line layer"
 msgstr "Ebene mit geodätischer Linie hinzufügen"
-#: ../gui/wxpython/icons/icon.py:225
+#: ../gui/wxpython/icons/icon.py:227
 msgid "Add rhumbline layer"
 msgstr "Ebene mit Rhumblinie hinzufügen"
-#: ../gui/wxpython/icons/icon.py:227
+#: ../gui/wxpython/icons/icon.py:229
 msgid "Add labels"
 msgstr "Beschriftungen hinzufügen"
-#: ../gui/wxpython/icons/icon.py:229
+#: ../gui/wxpython/icons/icon.py:231
 msgid "Add 3D raster map layer"
 msgstr "3D Rasterkarte hinzufügen"
-#: ../gui/wxpython/icons/icon.py:230
+#: ../gui/wxpython/icons/icon.py:232
 msgid "Note that 3D raster data are rendered only in 3D view mode"
 msgstr "3D-Rasterdaten werden nur in 3D-Ansichtmodus dargestellt."
-#: ../gui/wxpython/icons/icon.py:232
+#: ../gui/wxpython/icons/icon.py:234
 msgid "Show GUI settings"
 msgstr "Zeige GUI-Einstellungen"
-#: ../gui/wxpython/icons/icon.py:234
+#: ../gui/wxpython/icons/icon.py:236
 #, fuzzy
 msgid "Graphical Modeler"
 msgstr "Graphical modeler"
-#: ../gui/wxpython/icons/icon.py:236
+#: ../gui/wxpython/icons/icon.py:238
 #: ../gui/wxpython/gui_modules/gdialogs.py:416
 msgid "Set options"
 msgstr "Einstellungen vornehmen"
-#: ../gui/wxpython/icons/icon.py:238
+#: ../gui/wxpython/icons/icon.py:240 ../gui/wxpython/menustrings.py:198
 #, fuzzy
-msgid "Hardcopy Map Ouput Utility"
+msgid "Hardcopy Map Output Utility"
 msgstr "Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format."
-#: ../gui/wxpython/icons/icon.py:240
+#: ../gui/wxpython/icons/icon.py:242
 #, fuzzy
 msgid "Raster Map Calculator"
 msgstr "Rasterkartenrechner"
-#: ../gui/wxpython/icons/icon.py:244
+#: ../gui/wxpython/icons/icon.py:246
 msgid "Digitize new point"
 msgstr "Neuen Punkt digitalisieren"
-#: ../gui/wxpython/icons/icon.py:245 ../gui/wxpython/icons/icon.py:254
-#: ../gui/wxpython/icons/icon.py:257
+#: ../gui/wxpython/icons/icon.py:247 ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:259
 msgid "Left: new point"
 msgstr "Links: neuer Punkt"
-#: ../gui/wxpython/icons/icon.py:247
+#: ../gui/wxpython/icons/icon.py:249
 msgid "Digitize new line"
 msgstr "Neue Linie digitalisieren"
-#: ../gui/wxpython/icons/icon.py:248 ../gui/wxpython/icons/icon.py:251
-#: ../gui/wxpython/icons/icon.py:275
+#: ../gui/wxpython/icons/icon.py:250 ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:277
 #, fuzzy
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
 msgstr ""
 "Links: neuer Punkt; Mitte: letzten Punkt zurücknehmen; Rechts: Linie "
 "schließen"
-#: ../gui/wxpython/icons/icon.py:250
+#: ../gui/wxpython/icons/icon.py:252
 msgid "Digitize new boundary"
 msgstr "Neue Grenze digitalisieren"
-#: ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:255
 msgid "Digitize new centroid"
 msgstr "neues Zentroid digitalisieren"
-#: ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:258
 msgid ""
 "Digitize new area (composition of boundaries without category and one "
 "centroid with category)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:259
+#: ../gui/wxpython/icons/icon.py:261
 msgid "Add new vertex"
 msgstr "Neuen Vertex hinzufügen"
-#: ../gui/wxpython/icons/icon.py:260 ../gui/wxpython/icons/icon.py:263
-#: ../gui/wxpython/icons/icon.py:266 ../gui/wxpython/icons/icon.py:278
-#: ../gui/wxpython/icons/icon.py:281 ../gui/wxpython/icons/icon.py:284
-#: ../gui/wxpython/icons/icon.py:289 ../gui/wxpython/icons/icon.py:296
+#: ../gui/wxpython/icons/icon.py:262 ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:268 ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:283 ../gui/wxpython/icons/icon.py:286
+#: ../gui/wxpython/icons/icon.py:291 ../gui/wxpython/icons/icon.py:298
 #, fuzzy
 msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
 msgstr "Links: Selektieren; Mitte: Selektion aufheben; Rechts: Bestätigen"
-#: ../gui/wxpython/icons/icon.py:262
-#: ../gui/wxpython/gui_modules/toolbars.py:782
+#: ../gui/wxpython/icons/icon.py:264
+#: ../gui/wxpython/gui_modules/toolbars.py:729
 msgid "Copy categories"
 msgstr "Kategorien kopieren"
-#: ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:267
 msgid "Delete feature(s)"
 msgstr "Feature löschen"
-#: ../gui/wxpython/icons/icon.py:268
+#: ../gui/wxpython/icons/icon.py:270
 msgid "Display/update attributes"
 msgstr "Zeige/Aktualisiere Attribute"
-#: ../gui/wxpython/icons/icon.py:269 ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/icons/icon.py:271 ../gui/wxpython/icons/icon.py:274
 msgid "Left: Select"
 msgstr "Links: Selektieren"
-#: ../gui/wxpython/icons/icon.py:271
+#: ../gui/wxpython/icons/icon.py:273
 msgid "Display/update categories"
 msgstr "Zeige/Aktualisiere Kategorien"
-#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/icons/icon.py:276
 msgid "Edit line/boundary"
 msgstr "Editiere Linie/Grenze"
-#: ../gui/wxpython/icons/icon.py:277
+#: ../gui/wxpython/icons/icon.py:279
 msgid "Move feature(s)"
 msgstr "Verschiebe Feature"
-#: ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:282
 msgid "Move vertex"
 msgstr "Verschiebe Vertex"
-#: ../gui/wxpython/icons/icon.py:283
+#: ../gui/wxpython/icons/icon.py:285
 msgid "Remove vertex"
 msgstr "Entferne Vertex"
-#: ../gui/wxpython/icons/icon.py:286
-#: ../gui/wxpython/gui_modules/toolbars.py:857
+#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/gui_modules/toolbars.py:804
 msgid "Digitization settings"
 msgstr "Digitalisier-Einstellungen"
-#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/icons/icon.py:290
 msgid "Split line/boundary"
 msgstr "Trenne Linie/Grenze"
-#: ../gui/wxpython/icons/icon.py:291
+#: ../gui/wxpython/icons/icon.py:293
 msgid "Quit digitizer"
 msgstr "Beende Vektor-Digitalisierung"
-#: ../gui/wxpython/icons/icon.py:292
+#: ../gui/wxpython/icons/icon.py:294
 msgid "Quit digitizer and save changes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:294
+#: ../gui/wxpython/icons/icon.py:296
 msgid "Additional tools (copy, flip, connect, etc.)"
 msgstr "Zusätzliche Werkzeuge (Kopieren, Umdrehen, Verbinden, etc.)"
-#: ../gui/wxpython/icons/icon.py:298
+#: ../gui/wxpython/icons/icon.py:300
 msgid "Undo"
 msgstr "Rückgängig"
-#: ../gui/wxpython/icons/icon.py:299
+#: ../gui/wxpython/icons/icon.py:301
 msgid "Undo previous changes"
 msgstr "Vorherige Änderungen rückgängig"
-#: ../gui/wxpython/icons/icon.py:303
+#: ../gui/wxpython/icons/icon.py:305
 msgid "Draw/re-draw profile"
 msgstr "(erneutes) zeichnen des Profils"
-#: ../gui/wxpython/icons/icon.py:305
+#: ../gui/wxpython/icons/icon.py:307
 msgid "Draw transect in map display window to profile"
 msgstr ""
 "Zeichne ein Transekt in das Kartenfenster, für das ein Profil erstellt wird"
-#: ../gui/wxpython/icons/icon.py:307
+#: ../gui/wxpython/icons/icon.py:309
 msgid "Profile options"
 msgstr "Profileinstellungen"
-#: ../gui/wxpython/icons/icon.py:309
+#: ../gui/wxpython/icons/icon.py:311
 msgid "Save profile data to CSV file"
 msgstr "Speicher Profiledaten in csv-Datei"
-#: ../gui/wxpython/icons/icon.py:311
+#: ../gui/wxpython/icons/icon.py:313
 msgid "Quit Profile Analysis Tool"
 msgstr "Beende Profil-Analyse"
-#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/icons/icon.py:317
 msgid "Set GCP"
 msgstr "GCPs setzten"
-#: ../gui/wxpython/icons/icon.py:316
+#: ../gui/wxpython/icons/icon.py:318
 msgid "Define GCP (Ground Control Points)"
 msgstr "Definiere GCPs (Ground Control Points)"
-#: ../gui/wxpython/icons/icon.py:318 ../gui/wxpython/menustrings.py:186
+#: ../gui/wxpython/icons/icon.py:320 ../gui/wxpython/menustrings.py:186
 msgid "Georectify"
 msgstr "Georektifizieren"
-#: ../gui/wxpython/icons/icon.py:320
+#: ../gui/wxpython/icons/icon.py:322
 msgid "Recalculate RMS error"
 msgstr "Berechne den RMS-Fehler"
-#: ../gui/wxpython/icons/icon.py:322
+#: ../gui/wxpython/icons/icon.py:324
 msgid "Save GCPs to POINTS file"
 msgstr "Speichere GCPs in POINTS Datei"
-#: ../gui/wxpython/icons/icon.py:324
+#: ../gui/wxpython/icons/icon.py:326
 msgid "Add new GCP"
 msgstr "Neuen GCP hinzufügen"
-#: ../gui/wxpython/icons/icon.py:326
+#: ../gui/wxpython/icons/icon.py:328
 msgid "Delete selected GCP"
 msgstr "Selektierten GCP löschen"
-#: ../gui/wxpython/icons/icon.py:328
+#: ../gui/wxpython/icons/icon.py:330
 msgid "Clear selected GCP"
 msgstr "Selektierten GCP reinigen"
-#: ../gui/wxpython/icons/icon.py:330
+#: ../gui/wxpython/icons/icon.py:332
 msgid "Reload GCPs from POINTS file"
 msgstr "Lade erneut GCPs aus POINTS-Datei"
-#: ../gui/wxpython/icons/icon.py:332
+#: ../gui/wxpython/icons/icon.py:334
 msgid "Quit georectification"
 msgstr "Beende Georektifikationsmodul"
-#: ../gui/wxpython/icons/icon.py:334
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1289
+#: ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1504
 #: ../gui/wxpython/gui_modules/gselect.py:1070
 msgid "Settings"
 msgstr "Einstellungen"
-#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/icons/icon.py:337
 msgid "Settings dialog for georectification tool"
 msgstr "Einstellungsdialog für Georektifikationswerkzeug"
-#: ../gui/wxpython/icons/icon.py:339
+#: ../gui/wxpython/icons/icon.py:341
 #, fuzzy
 msgid "Switch to view control page"
 msgstr "Wechsle zu Einstellungen für Ansicht"
-#: ../gui/wxpython/icons/icon.py:340
+#: ../gui/wxpython/icons/icon.py:342
 msgid "Change view settings"
 msgstr "Ändere Einstellungen für Darstellung"
-#: ../gui/wxpython/icons/icon.py:342
+#: ../gui/wxpython/icons/icon.py:344
 #, fuzzy
 msgid "Switch to surface (raster) control page"
 msgstr "Wechsle zu Einstellungen für Oberflächen (Raster)"
-#: ../gui/wxpython/icons/icon.py:343
+#: ../gui/wxpython/icons/icon.py:345
 msgid "Change surface (loaded raster maps) settings"
 msgstr "Ändere Oberflächen-Eigenschaften (geladene Rasterkarte)"
-#: ../gui/wxpython/icons/icon.py:345
+#: ../gui/wxpython/icons/icon.py:347
 #, fuzzy
 msgid "Switch to vector (2D/3D) control page"
 msgstr "Wechsle zu Einstellungen für Vektoren (2D/3D) "
-#: ../gui/wxpython/icons/icon.py:346
+#: ../gui/wxpython/icons/icon.py:348
 msgid "Change 2D/3D vector settings"
 msgstr "Ändere 2D/3D Vektoreinstellungen"
-#: ../gui/wxpython/icons/icon.py:348
+#: ../gui/wxpython/icons/icon.py:350
 #, fuzzy
 msgid "Switch to volume (3D raster) control page"
 msgstr "Wechsle zu Einstellungen für Volumen (3D-Raster)"
-#: ../gui/wxpython/icons/icon.py:349
+#: ../gui/wxpython/icons/icon.py:351
 #, fuzzy
 msgid "Change volume (loaded 3D raster maps) settings"
 msgstr "Ändere Volumen-Einstellungen (geladene 3D-Rasterkarte) "
-#: ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:353
 #, fuzzy
 msgid "Switch to lighting control page"
 msgstr "Wechsle zu Einstellungen für die Lichtverhältnisse"
-#: ../gui/wxpython/icons/icon.py:352
+#: ../gui/wxpython/icons/icon.py:354
 msgid "Change lighting settings"
 msgstr "Ändere Beleuchtungseinstellung"
-#: ../gui/wxpython/icons/icon.py:354
+#: ../gui/wxpython/icons/icon.py:356
 #, fuzzy
 msgid "Switch to fringe control page"
 msgstr "Wechsle zu Einstellungen der Randzone"
-#: ../gui/wxpython/icons/icon.py:355
+#: ../gui/wxpython/icons/icon.py:357
 msgid "Switch on/off fringes"
 msgstr "Randzonen ein-/ausblenden"
-#: ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:359
 msgid "3D view mode tools"
 msgstr "3D Ansicht-Werkszeugsleiste"
-#: ../gui/wxpython/icons/icon.py:358
+#: ../gui/wxpython/icons/icon.py:360
 msgid "Show/hide 3D view mode settings dialog"
 msgstr "Einstellungen für 3D Ansicht anzeigen/ausblenden"
-#: ../gui/wxpython/icons/icon.py:360
+#: ../gui/wxpython/icons/icon.py:362
 msgid "Quit 3D view mode"
 msgstr "Verlasse den 3D-Ansicht-Modus"
-#: ../gui/wxpython/icons/icon.py:361
+#: ../gui/wxpython/icons/icon.py:363
 msgid "Switch back to 2D view mode"
 msgstr "Wechsle zu 2D-Ansicht zurück"
-#: ../gui/wxpython/icons/icon.py:365
+#: ../gui/wxpython/icons/icon.py:367
 msgid "Create new model (Ctrl+N)"
 msgstr "Erstelle neues Modell (Ctrl+N)"
-#: ../gui/wxpython/icons/icon.py:367
+#: ../gui/wxpython/icons/icon.py:369
 msgid "Load model from file (Ctrl+O)"
 msgstr "Lade Modell aus Datei (Ctrl+O)"
-#: ../gui/wxpython/icons/icon.py:369
+#: ../gui/wxpython/icons/icon.py:371
 msgid "Save current model to file (Ctrl+S)"
 msgstr "Speichere aktuelles Modell in Datei (Ctrl+S)"
-#: ../gui/wxpython/icons/icon.py:371 ../gui/wxpython/menustrings.py:878
+#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:878
 msgid "Export model to image"
 msgstr "Exportiere Modell als Bild"
-#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:880
+#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:880
 msgid "Export model to Python script"
 msgstr "Exportiere Modell als Python-Skript"
-#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:888
+#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:888
 msgid "Add action (GRASS module) to model"
 msgstr "Füge Aktion (GRASS Modul) zu Modell hinzu"
-#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:890
 msgid "Add data item to model"
 msgstr "Füge Daten-Objekt zu Modell hinzu"
-#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:892
+#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:892
 msgid "Define relation between data and action items"
 msgstr "Definiere Beziehung zwischen Daten und Aktionen"
-#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:190
+#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:190
 #: ../gui/wxpython/menustrings.py:903
 msgid "Run model"
 msgstr "Start des Modells"
-#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:905
+#: ../gui/wxpython/icons/icon.py:385 ../gui/wxpython/menustrings.py:905
 msgid "Validate model"
 msgstr "Überprüfung des Modells"
-#: ../gui/wxpython/icons/icon.py:385
+#: ../gui/wxpython/icons/icon.py:387
 msgid "Show modeler settings"
 msgstr "Zeige Modeler-Einstellungen"
-#: ../gui/wxpython/icons/icon.py:387
+#: ../gui/wxpython/icons/icon.py:389
 msgid "Show model properties"
 msgstr "Zeige Modell-Eigenschaften"
-#: ../gui/wxpython/icons/icon.py:389
+#: ../gui/wxpython/icons/icon.py:391
 msgid "Manage model variables"
 msgstr "Verwalte Modell-Variablen"
-#: ../gui/wxpython/icons/icon.py:391
+#: ../gui/wxpython/icons/icon.py:393
 #, fuzzy
 msgid "Redraw model canvas"
 msgstr "Neuzeichnen des Modell-Grafikfensters"
-#: ../gui/wxpython/icons/icon.py:393
-#: ../gui/wxpython/gui_modules/gmodeler.py:677
+#: ../gui/wxpython/icons/icon.py:395
+#: ../gui/wxpython/gui_modules/gmodeler.py:671
 msgid "Quit Graphical Modeler"
 msgstr "Verlasse Graphical Modeler"
-#: ../gui/wxpython/icons/icon.py:397
+#: ../gui/wxpython/icons/icon.py:399
 msgid "Select font"
 msgstr "Schrift auswählen"
-#: ../gui/wxpython/icons/icon.py:399
+#: ../gui/wxpython/icons/icon.py:401
 #, fuzzy
 msgid "Show manual"
 msgstr "Schattenkarten"
-#: ../gui/wxpython/icons/icon.py:405
+#: ../gui/wxpython/icons/icon.py:407
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:407
+#: ../gui/wxpython/icons/icon.py:409
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:409
+#: ../gui/wxpython/icons/icon.py:411
 #, fuzzy
 msgid "Generate PostScript output"
-#: ../gui/wxpython/icons/icon.py:411
+#: ../gui/wxpython/icons/icon.py:413
 #, fuzzy
 msgid "Generate PDF output"
 msgstr "Erzeuge Punkte"
-#: ../gui/wxpython/icons/icon.py:413
+#: ../gui/wxpython/icons/icon.py:415
 #: ../gui/wxpython/gui_modules/histogram.py:432
-#: ../gui/wxpython/gui_modules/mapdisp.py:1171
+#: ../gui/wxpython/gui_modules/mapdisp.py:1179
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:934
 msgid "Page setup"
 msgstr "Seiteneinstellungen"
-#: ../gui/wxpython/icons/icon.py:414
+#: ../gui/wxpython/icons/icon.py:416
 msgid "Specify paper size, margins and orientation"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:416
+#: ../gui/wxpython/icons/icon.py:418
 msgid "Full extent"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:417
+#: ../gui/wxpython/icons/icon.py:419
 #, fuzzy
 msgid "Zoom to full extent"
 msgstr "Auf die Standardregion zoomen"
-#: ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:421
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1951
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2006
 #, fuzzy
 msgid "Map frame"
 msgstr "Kartenmaßstab"
-#: ../gui/wxpython/icons/icon.py:420
+#: ../gui/wxpython/icons/icon.py:422
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:320
+#: ../gui/wxpython/icons/icon.py:424
+#: ../gui/wxpython/gui_modules/nviz_tools.py:465
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2476
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:669
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:730
 msgid "Raster map"
 msgstr "Rasterkarte"
-#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/icons/icon.py:425
 #, fuzzy
 msgid "Add raster map"
-#: ../gui/wxpython/icons/icon.py:425
-#: ../gui/wxpython/gui_modules/nviz_tools.py:629
+#: ../gui/wxpython/icons/icon.py:427
+#: ../gui/wxpython/gui_modules/nviz_tools.py:839
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3920
 msgid "Vector map"
 msgstr "Vektorkarte"
-#: ../gui/wxpython/icons/icon.py:426
+#: ../gui/wxpython/icons/icon.py:428
 #, fuzzy
 msgid "Add vector map"
 msgstr "Vektor hinzufügen"
-#: ../gui/wxpython/icons/icon.py:428
+#: ../gui/wxpython/icons/icon.py:430
 #, fuzzy
 msgid "Delete selected object"
 msgstr "Ausgewählte Location löschen"
-#: ../gui/wxpython/icons/icon.py:430
+#: ../gui/wxpython/icons/icon.py:432
 #, fuzzy
 msgid "Show preview"
 msgstr "Gitternetz anzeigen"
-#: ../gui/wxpython/icons/icon.py:432
+#: ../gui/wxpython/icons/icon.py:434
 #, fuzzy
 msgid "Quit Hardcopy Map Utility"
-#: ../gui/wxpython/icons/icon.py:434
+#: ../gui/wxpython/icons/icon.py:436
 #, fuzzy
 msgid "Add text"
-#: ../gui/wxpython/icons/icon.py:436
+#: ../gui/wxpython/icons/icon.py:438
 #, fuzzy
 msgid "Add map info"
 msgstr "Kartenelemente hinzufügen"
-#: ../gui/wxpython/icons/icon.py:440
+#: ../gui/wxpython/icons/icon.py:442
 #, fuzzy
 msgid "Add scale bar"
 msgstr "Layer hinzufügen"
@@ -1080,80 +1103,80 @@
 msgid "Kriging"
 msgstr "Kriging"
-#: ../gui/wxpython/scripts/vkrige.py:109
-#: ../gui/wxpython/gui_modules/gmodeler.py:575
-#: ../gui/wxpython/gui_modules/menuform.py:1165
+#: ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gui_modules/gmodeler.py:569
+#: ../gui/wxpython/gui_modules/menuform.py:1160
 msgid "Command output"
 msgstr "Befehlsausgabe"
-#: ../gui/wxpython/scripts/vkrige.py:115 ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/scripts/vkrige.py:114 ../gui/wxpython/menustrings.py:390
 msgid "Output"
 msgstr "Ergebnis"
-#: ../gui/wxpython/scripts/vkrige.py:119
+#: ../gui/wxpython/scripts/vkrige.py:118
 msgid "Name for the output raster map:"
 msgstr "Name für Ausgaberasterkarte:"
-#: ../gui/wxpython/scripts/vkrige.py:127
+#: ../gui/wxpython/scripts/vkrige.py:126
 msgid "Export variance map as well: "
 msgstr "Exportiere auch Varianz-Karte: "
-#: ../gui/wxpython/scripts/vkrige.py:140
+#: ../gui/wxpython/scripts/vkrige.py:139
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:229
 #: ../gui/wxpython/gui_modules/vclean.py:144
-#: ../gui/wxpython/gui_modules/gmodeler.py:3309
-#: ../gui/wxpython/gui_modules/gdialogs.py:985
-#: ../gui/wxpython/gui_modules/preferences.py:1533
+#: ../gui/wxpython/gui_modules/gmodeler.py:3303
+#: ../gui/wxpython/gui_modules/gdialogs.py:986
+#: ../gui/wxpython/gui_modules/preferences.py:1555
 msgid "Allow output files to overwrite existing files"
 msgstr "Erlaube, dass Ausgabedateien existierende Dateien überschreiben"
-#: ../gui/wxpython/scripts/vkrige.py:153
+#: ../gui/wxpython/scripts/vkrige.py:152
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:133
 #: ../gui/wxpython/gui_modules/ghelp.py:223
 #: ../gui/wxpython/gui_modules/vclean.py:165
-#: ../gui/wxpython/gui_modules/gmodeler.py:3426
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/gmodeler.py:3420
+#: ../gui/wxpython/gui_modules/menuform.py:828
 msgid "&Run"
 msgstr "&Los"
-#: ../gui/wxpython/scripts/vkrige.py:268
+#: ../gui/wxpython/scripts/vkrige.py:267
 msgid "Kriging Module"
 msgstr "Kriging Modul"
-#: ../gui/wxpython/scripts/vkrige.py:272
+#: ../gui/wxpython/scripts/vkrige.py:271
 msgid "Ready."
 msgstr "Fertig."
-#: ../gui/wxpython/scripts/vkrige.py:296
+#: ../gui/wxpython/scripts/vkrige.py:295
 msgid "Variogram fitting"
 msgstr "Variogram fitting"
-#: ../gui/wxpython/scripts/vkrige.py:306
+#: ../gui/wxpython/scripts/vkrige.py:305
 msgid "Plot/refresh variogram"
 msgstr "Stelle Variogram dar"
-#: ../gui/wxpython/scripts/vkrige.py:317
+#: ../gui/wxpython/scripts/vkrige.py:316
 #, fuzzy
 msgid ":"
 msgstr ":"
-#: ../gui/wxpython/scripts/vkrige.py:342
+#: ../gui/wxpython/scripts/vkrige.py:341
 msgid "Kriging techniques"
 msgstr "Kriging-Methoden"
-#: ../gui/wxpython/scripts/vkrige.py:356
+#: ../gui/wxpython/scripts/vkrige.py:355
 msgid "Block size:"
 msgstr "Blockgröße:"
-#: ../gui/wxpython/scripts/vkrige.py:389
+#: ../gui/wxpython/scripts/vkrige.py:388
 msgid "Auto-fit variogram"
 msgstr "Auto-fit-Variogram"
-#: ../gui/wxpython/scripts/vkrige.py:413
+#: ../gui/wxpython/scripts/vkrige.py:412
 msgid "Model: "
 msgstr "Modell:"
-#: ../gui/wxpython/scripts/vkrige.py:497
+#: ../gui/wxpython/scripts/vkrige.py:496
 msgid "Work in progress! No functionality provided."
 msgstr "Work in progress! Keine Funktionalität vorhanden."
@@ -1240,8 +1263,9 @@
 msgid "Workspace"
 msgstr "Projekt"
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:17
 #: ../gui/wxpython/menustrings.py:867
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
 msgid "New"
 msgstr "Neu"
@@ -1278,45 +1302,50 @@
 msgstr "Schließe Workspace-Datei"
 #: ../gui/wxpython/menustrings.py:14
-msgid "Load map layers"
-msgstr "Lade Kartenebenen"
-#: ../gui/wxpython/menustrings.py:16
 msgid "Load GRC file (Tcl/Tk GUI)"
 msgstr "Lade GRC-Datei (Tcl/Tk GUI)"
-#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/menustrings.py:15
 msgid "Load map layers from GRC file to layer tree"
 msgstr "Lade Kartenebenen aus GRC-Datei in Baumstruktur"
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:16
 msgid "Map display"
 msgstr "Kartenanzeige"
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:18
 #, fuzzy
 msgid "Open new map display window"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:19
 msgid "Close current"
 msgstr "Aktuelles einklappen "
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:20
 #, fuzzy
 msgid "Close current map display window"
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:21
 msgid "Close all"
 msgstr "Alles schließen"
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:22
 #, fuzzy
 msgid "Close all open map display windows"
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+#, fuzzy
+msgid "Add multiple raster or vector map layers to current display"
+msgstr "Rasterkartenlayer zur aktuellen Kartenanzeige hinzufügen"
 #: ../gui/wxpython/menustrings.py:25
 msgid "Add raster"
 msgstr "Raster hinzufügen"
@@ -1940,6 +1969,7 @@
 msgstr "Benennt Datenbank Daten im aktuellen Mapset um"
 #: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2640
 msgid "Delete"
 msgstr "Löschen"
@@ -2069,11 +2099,6 @@
 "Eine einfache Anwendung zur Konvertierung von Richtung und Entfernung in "
 "Koordinaten und umgekehrt."
-#: ../gui/wxpython/menustrings.py:198
-#, fuzzy
-msgid "Hardcopy Map Output Utility"
-msgstr "Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format."
 #: ../gui/wxpython/menustrings.py:199
 #, fuzzy
 msgid "Launch Hardcopy Map Output Utility"
@@ -2503,9 +2528,8 @@
 msgstr "Findet den nächsten Punkt zwischen Objekten in zwei Rasterkarten."
 #: ../gui/wxpython/menustrings.py:298
-#: ../gui/wxpython/gui_modules/nviz_tools.py:351
-#: ../gui/wxpython/gui_modules/nviz_tools.py:549
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:602
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1238
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3049
 msgid "Mask"
 msgstr "Maske"
@@ -2674,7 +2698,7 @@
 msgstr "Verfolgt einen Fluss durch ein Rasterhöhenmodell."
 #: ../gui/wxpython/menustrings.py:330
-#: ../gui/wxpython/gui_modules/layertree.py:803
+#: ../gui/wxpython/gui_modules/layertree.py:799
 msgid "Shaded relief"
 msgstr "Reliefschattierungen"
@@ -5145,7 +5169,7 @@
 msgstr "Lade Modell aus einer Datei"
 #: ../gui/wxpython/menustrings.py:872
-#: ../gui/wxpython/gui_modules/gmodeler.py:828
+#: ../gui/wxpython/gui_modules/gmodeler.py:822
 msgid "Save model"
 msgstr "Speichere Modell"
@@ -5174,7 +5198,7 @@
 msgstr "Schließe Modeler-Fenster"
 #: ../gui/wxpython/menustrings.py:885
-#: ../gui/wxpython/gui_modules/gmodeler.py:3003
+#: ../gui/wxpython/gui_modules/gmodeler.py:2997
 msgid "Modeler settings"
 msgstr "Modeler-Einstellungen"
@@ -5219,7 +5243,7 @@
 msgstr "Entferne Aktion/Daten aus Modell"
 #: ../gui/wxpython/menustrings.py:899
-#: ../gui/wxpython/gui_modules/gmodeler.py:3288
+#: ../gui/wxpython/gui_modules/gmodeler.py:3282
 msgid "Model properties"
 msgstr "Modell-Eigenschaften"
@@ -5361,8 +5385,8 @@
 msgstr "GRASS GIS Histogramm eines Bildes oder Rasterkarte"
 #: ../gui/wxpython/gui_modules/histogram.py:332
-#: ../gui/wxpython/gui_modules/wxnviz.py:227
-#: ../gui/wxpython/gui_modules/wxnviz.py:238
+#: ../gui/wxpython/gui_modules/wxnviz.py:240
+#: ../gui/wxpython/gui_modules/wxnviz.py:251
 #, python-format
 msgid "Raster map <%s> not found"
 msgstr "Rasterkarte <%s> nicht gefunden"
@@ -5372,16 +5396,16 @@
 msgstr "Wähle Font für Text im Histogramm"
 #: ../gui/wxpython/gui_modules/histogram.py:403
-#: ../gui/wxpython/gui_modules/mapdisp.py:1142
+#: ../gui/wxpython/gui_modules/mapdisp.py:1150
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:905
-#: ../gui/wxpython/gui_modules/gmodeler.py:1042
+#: ../gui/wxpython/gui_modules/gmodeler.py:1036
 msgid "Choose a file name to save the image (no need to add extension)"
 msgstr ""
 "Wähle einen Dateinamen, um Bild zu speichern (Anfügen einer Extension nicht "
 "erforderlich)"
 #: ../gui/wxpython/gui_modules/histogram.py:436
-#: ../gui/wxpython/gui_modules/mapdisp.py:1175
+#: ../gui/wxpython/gui_modules/mapdisp.py:1183
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:938
 msgid "Print preview"
 msgstr "Druckvorschau"
@@ -5415,15 +5439,15 @@
 msgstr "&Säubere"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#: ../gui/wxpython/gui_modules/gdialogs.py:1005
+#: ../gui/wxpython/gui_modules/gdialogs.py:1006
 msgid "Command dialog"
 msgstr "Befehldialogfenster"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:138
-#: ../gui/wxpython/gui_modules/gdialogs.py:1161
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
-#: ../gui/wxpython/gui_modules/gdialogs.py:1168
-#: ../gui/wxpython/gui_modules/gdialogs.py:1170
+#: ../gui/wxpython/gui_modules/gdialogs.py:1162
+#: ../gui/wxpython/gui_modules/gdialogs.py:1164
+#: ../gui/wxpython/gui_modules/gdialogs.py:1169
+#: ../gui/wxpython/gui_modules/gdialogs.py:1171
 #, python-format
 msgid "Open %s dialog"
 msgstr "Öffne %s Dialog"
@@ -5433,7 +5457,6 @@
 msgstr "Speichere Ausdruck in Datei"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#: ../gui/wxpython/gui_modules/gdialogs.py:739
 msgid "&Load"
 msgstr "&Lade"
@@ -5594,6 +5617,40 @@
 msgid "Unknow tag"
 msgstr "Unbekannte Auswahl"
+#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:47
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:97
+#, fuzzy, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr "Rasterkarte <%s> nicht gefunden"
+#: ../gui/wxpython/gui_modules/gpyshell.py:104
+msgid "Raster map <%s> added"
+#: ../gui/wxpython/gui_modules/gpyshell.py:106
+msgid "Vector map <%s> added"
+msgstr "Neue Vektorkarte <%s> erzeugt"
 #: ../gui/wxpython/gui_modules/dbm_dialogs.py:67
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2998
 msgid "Database connection is not defined in DB file."
@@ -5657,7 +5714,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2279
 #: ../gui/wxpython/gui_modules/dbm.py:2387
 #: ../gui/wxpython/gui_modules/dbm.py:2642
-#: ../gui/wxpython/gui_modules/gdialogs.py:1352
+#: ../gui/wxpython/gui_modules/gdialogs.py:1353
 msgid "Layer"
 msgstr "Ebene"
@@ -5691,16 +5748,16 @@
 msgstr "Kartentyp der georektifiziert wird"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:328
-#: ../gui/wxpython/gui_modules/gmodeler.py:3560
+#: ../gui/wxpython/gui_modules/gmodeler.py:3554
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2028
-#: ../gui/wxpython/gui_modules/layertree.py:791
+#: ../gui/wxpython/gui_modules/layertree.py:787
 msgid "raster"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3561
+#: ../gui/wxpython/gui_modules/gmodeler.py:3555
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2029
-#: ../gui/wxpython/gui_modules/layertree.py:812
+#: ../gui/wxpython/gui_modules/layertree.py:808
 msgid "vector"
 msgstr "Vektor"
@@ -5800,12 +5857,12 @@
 msgstr "Fenster nicht definiert für"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1110
-#: ../gui/wxpython/gui_modules/toolbars.py:416
+#: ../gui/wxpython/gui_modules/toolbars.py:398
 msgid "source"
 msgstr "Quelle"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1112
 msgid "target"
 msgstr "Ziel"
@@ -6009,14 +6066,14 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2371
 #: ../gui/wxpython/gui_modules/profile.py:1033
 #: ../gui/wxpython/gui_modules/profile.py:1388
-#: ../gui/wxpython/gui_modules/preferences.py:961
+#: ../gui/wxpython/gui_modules/preferences.py:966
 msgid "Apply changes for the current session"
 msgstr "Wende Änderungen auf aktuelle Sitzung an"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2373
 #: ../gui/wxpython/gui_modules/profile.py:1038
 #: ../gui/wxpython/gui_modules/profile.py:1390
-#: ../gui/wxpython/gui_modules/preferences.py:963
+#: ../gui/wxpython/gui_modules/preferences.py:968
 msgid ""
 "Apply and save changes to user settings file (default for next sessions)"
 msgstr ""
@@ -6025,7 +6082,7 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2375
 #: ../gui/wxpython/gui_modules/ogc_services.py:77
-#: ../gui/wxpython/gui_modules/gdialogs.py:995
+#: ../gui/wxpython/gui_modules/gdialogs.py:996
 msgid "Close dialog"
 msgstr "Dialog schließen"
@@ -6058,12 +6115,14 @@
 msgstr "Symbol-Einstellungen"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2438
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1307
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:809
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1522
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:326
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:547
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3098
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3203
-#: ../gui/wxpython/gui_modules/preferences.py:1683
+#: ../gui/wxpython/gui_modules/preferences.py:1705
 msgid "Color:"
 msgstr "Farbe:"
@@ -6137,16 +6196,16 @@
 msgstr "GCP Manager-Einstellungen in Datei '%s' gespeichert."
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:90
-#: ../gui/wxpython/gui_modules/mapdisp.py:771
-#: ../gui/wxpython/gui_modules/mapdisp.py:803
-#: ../gui/wxpython/gui_modules/mapdisp.py:874
-#: ../gui/wxpython/gui_modules/mapdisp.py:1027
+#: ../gui/wxpython/gui_modules/mapdisp.py:779
+#: ../gui/wxpython/gui_modules/mapdisp.py:811
+#: ../gui/wxpython/gui_modules/mapdisp.py:882
+#: ../gui/wxpython/gui_modules/mapdisp.py:1035
 msgid "Projection not defined (check the settings)"
 msgstr "Projektion nicht definiert (überprüfe Einstellungen)"
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:107
-#: ../gui/wxpython/gui_modules/mapdisp.py:918
-#: ../gui/wxpython/gui_modules/mapdisp.py:1044
+#: ../gui/wxpython/gui_modules/mapdisp.py:926
+#: ../gui/wxpython/gui_modules/mapdisp.py:1052
 msgid "Error in projection (check the settings)"
 msgstr "Fehler in der Projektion (überprüfen sie die Einstellungen)"
@@ -6174,7 +6233,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1718
 #: ../gui/wxpython/gui_modules/gcmd.py:89
-#: ../gui/wxpython/gui_modules/workspace.py:1000
+#: ../gui/wxpython/gui_modules/workspace.py:1007
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:424
 #: ../gui/wxpython/gui_modules/dbm.py:2357
 msgid "Warning"
@@ -6229,7 +6288,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:178
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:184
-#: ../gui/wxpython/gui_modules/preferences.py:1471
+#: ../gui/wxpython/gui_modules/preferences.py:1493
 msgid "Constrain display resolution to computational settings"
 msgstr ""
 "Beschränke die Auflösung des Kartenfensters auf die Einstellungen des "
@@ -6246,8 +6305,8 @@
 "Benutzereinstellungen' bestimmt werden. "
 #: ../gui/wxpython/gui_modules/mapdisp.py:210
-#: ../gui/wxpython/gui_modules/mapdisp.py:1062
-#: ../gui/wxpython/gui_modules/mapdisp.py:1065
+#: ../gui/wxpython/gui_modules/mapdisp.py:1070
+#: ../gui/wxpython/gui_modules/mapdisp.py:1073
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:216
 msgid "Use defined projection"
 msgstr "Verwende definierte Projektion"
@@ -6279,8 +6338,8 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:301
 #: ../gui/wxpython/gui_modules/mapdisp.py:312
 #: ../gui/wxpython/gui_modules/mapdisp.py:362
-#: ../gui/wxpython/gui_modules/mapdisp.py:507
-#: ../gui/wxpython/gui_modules/toolbars.py:201
+#: ../gui/wxpython/gui_modules/mapdisp.py:513
+#: ../gui/wxpython/gui_modules/toolbars.py:204
 #: ../gui/wxpython/gui_modules/layertree.py:582
 msgid "2D view"
 msgstr "2D Ansicht"
@@ -6311,30 +6370,30 @@
 "\n"
 "Einzelheiten: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:381
+#: ../gui/wxpython/gui_modules/mapdisp.py:386
 msgid "Starting 3D view mode..."
 msgstr "Starte 3D-Ansichtsmodus..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:387
 msgid "Please wait, loading data..."
 msgstr "Bitte warten Sie, ich lade Daten..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:414
+#: ../gui/wxpython/gui_modules/mapdisp.py:420
 #, fuzzy
 msgid "3D View Toolbar"
 msgstr "3D-Ansicht-Werkzeugleiste"
-#: ../gui/wxpython/gui_modules/mapdisp.py:438
+#: ../gui/wxpython/gui_modules/mapdisp.py:444
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:348
 msgid "Map Toolbar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:455
+#: ../gui/wxpython/gui_modules/mapdisp.py:461
 #, fuzzy
 msgid "Georectification Toolbar"
 msgstr "Werkzeugleiste Georektifizierung"
-#: ../gui/wxpython/gui_modules/mapdisp.py:517
+#: ../gui/wxpython/gui_modules/mapdisp.py:523
 #: ../gui/wxpython/gui_modules/render.py:420
 msgid "GRASS module '%s' not found. Unable to start map display window."
@@ -6342,49 +6401,49 @@
 "GRASS Module '%s' nicht gefunden. Map Display-Fenster kann nicht gestartet "
 "werden."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1127
+#: ../gui/wxpython/gui_modules/mapdisp.py:1135
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:890
 msgid "Nothing to render (empty map). Operation canceled."
 msgstr "Keine Daten zu rendern (leere Karte). Berechnung abgebrochen."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1300
+#: ../gui/wxpython/gui_modules/mapdisp.py:1308
 msgid "No raster or vector map layer selected for querying."
 msgstr "Es wurde keine Raster- oder Vektorkarte für die Abfrage ausgewählt."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1301
+#: ../gui/wxpython/gui_modules/mapdisp.py:1309
 msgid "No map layer selected"
 msgstr "Es wurde kein Kartenebene ausgewählt"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1396
+#: ../gui/wxpython/gui_modules/mapdisp.py:1404
 msgid "No vector map selected for querying."
 msgstr "Es wurde keine Vektorkarte für die Abfrage ausgewählt."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1397
 #: ../gui/wxpython/gui_modules/mapdisp.py:1405
+#: ../gui/wxpython/gui_modules/mapdisp.py:1413
 msgid "Vector querying"
 msgstr "Vektorabfrage"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1404
+#: ../gui/wxpython/gui_modules/mapdisp.py:1412
 msgid "Only vector map from the current mapset can be modified."
 msgstr "Es können nur Vektorkarten des aktuellen Mapsets geändert werden."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1476
+#: ../gui/wxpython/gui_modules/mapdisp.py:1484
 msgid "Query surface (raster map)"
 msgstr "Oberfläche (Rasterkarte) abfragen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1483
+#: ../gui/wxpython/gui_modules/mapdisp.py:1491
 msgid "Query vector map"
 msgstr "Vektorkarten abfragen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1491
+#: ../gui/wxpython/gui_modules/mapdisp.py:1499
 msgid "Query raster/vector map(s) (display mode)"
 msgstr "Frage Raster-/Vektorkarte(n) ab (Anzeige-Modus)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1507
+#: ../gui/wxpython/gui_modules/mapdisp.py:1515
 msgid "Query vector map (edit mode)"
 msgstr "Frage Vektorkarte ab (Editier-Modus)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1633
+#: ../gui/wxpython/gui_modules/mapdisp.py:1641
 #, python-format
 msgid ""
 "Click and drag with left mouse button to measure.%sDouble click with left "
@@ -6393,15 +6452,15 @@
 "Klicken und ziehen mit der linken Maustaste um zu messen.%sDoppelklick mit "
 "der linken Maustaste, um zu Löschen."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1639
+#: ../gui/wxpython/gui_modules/mapdisp.py:1647
 msgid "Measuring distance"
 msgstr "Messe Strecke"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1642
+#: ../gui/wxpython/gui_modules/mapdisp.py:1650
 msgid "Measuring distance:"
 msgstr "Messe Strecke:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1652
+#: ../gui/wxpython/gui_modules/mapdisp.py:1660
 msgid ""
 "Geodesic distance is not yet supported by this tool.\n"
@@ -6410,72 +6469,72 @@
 "Geodäsische Distanz wird von diesem Tool nicht unterstützt.\n"
 "Grund: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1681
-#: ../gui/wxpython/gui_modules/mapdisp.py:1687
+#: ../gui/wxpython/gui_modules/mapdisp.py:1690
+#: ../gui/wxpython/gui_modules/mapdisp.py:1696
 msgid "segment"
 msgstr "Segment"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1682
-#: ../gui/wxpython/gui_modules/mapdisp.py:1688
+#: ../gui/wxpython/gui_modules/mapdisp.py:1691
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
 #, fuzzy
 msgid "total distance"
 msgstr "gesamte Distanz"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1683
+#: ../gui/wxpython/gui_modules/mapdisp.py:1692
 #, fuzzy
 msgid "bearing"
 msgstr "Richtung"
 #, fuzzy
 msgid "deg"
 msgstr "deg"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1819
+#: ../gui/wxpython/gui_modules/mapdisp.py:1828
 msgid "Scale and North arrow"
 msgstr "Maßstab und Nordpfeil"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1825
+#: ../gui/wxpython/gui_modules/mapdisp.py:1834
 msgid "Show/hide scale and North arrow"
 msgstr "Maßstab und Nordpfeil anzeigen/verbergen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1826
+#: ../gui/wxpython/gui_modules/mapdisp.py:1835
 msgid "scale object"
 msgstr "Maßstabsobjekt"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1855
+#: ../gui/wxpython/gui_modules/mapdisp.py:1864
 msgid "Show/hide legend"
 msgstr "Legende anzeigen/verbergen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1856
+#: ../gui/wxpython/gui_modules/mapdisp.py:1865
 msgid "legend object"
 msgstr "Legendenobjekt"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1965
+#: ../gui/wxpython/gui_modules/mapdisp.py:1974
 msgid "Zoom to computational region"
 msgstr "Auf den Arbeitsbereich zoomen (mit g.region definiert)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1969
+#: ../gui/wxpython/gui_modules/mapdisp.py:1978
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1058
 msgid "Zoom to default region"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1973
+#: ../gui/wxpython/gui_modules/mapdisp.py:1982
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1062
 msgid "Zoom to saved region"
 msgstr "Auf die gespeicherte Region zoomen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1977
+#: ../gui/wxpython/gui_modules/mapdisp.py:1986
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1066
 msgid "Set computational region from display"
 msgstr "Arbeitsbereich auf Grundlage der aktuellen Darstellung setzen"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1981
+#: ../gui/wxpython/gui_modules/mapdisp.py:1990
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1070
 msgid "Save display geometry to named region"
 msgstr "Größe des Kartenfensters in benannter Region speichern"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2075
+#: ../gui/wxpython/gui_modules/mapdisp.py:2084
 msgid "GRASS GIS Map Display: "
 msgstr "GRASS GIS Kartenfenster: "
@@ -6543,12 +6602,12 @@
 msgid "Unsupported feature type %d. Operation cancelled."
 msgstr "Nicht unterstützter Objekttyp %d. Operation abgebrochen."
-#: ../gui/wxpython/gui_modules/wxvdigit.py:455
+#: ../gui/wxpython/gui_modules/wxvdigit.py:456
 #, python-format
 msgid "Unknown feature type '%s'"
 msgstr "Unbekannter Objekttyp '%s'"
-#: ../gui/wxpython/gui_modules/wxvdigit.py:460
+#: ../gui/wxpython/gui_modules/wxvdigit.py:461
 msgid "Not enough points for line"
 msgstr "Nicht genügend Punkte für Linie"
@@ -6607,7 +6666,7 @@
 "Sie müssen diesen Befehl aus dem Menue oder aus der Kommandozeile starten"
 #: ../gui/wxpython/gui_modules/ghelp.py:340
-#: ../gui/wxpython/gui_modules/goutput.py:629
+#: ../gui/wxpython/gui_modules/goutput.py:641
 msgid "%d modules match"
 msgstr "%d Module stimmen überein"
@@ -6671,11 +6730,11 @@
 #: ../gui/wxpython/gui_modules/ghelp.py:702
 #: ../gui/wxpython/gui_modules/ghelp.py:761
-#: ../gui/wxpython/gui_modules/gmodeler.py:3548
-#: ../gui/wxpython/gui_modules/gmodeler.py:3588
-#: ../gui/wxpython/gui_modules/gmodeler.py:3856
-#: ../gui/wxpython/gui_modules/gmodeler.py:3964
-#: ../gui/wxpython/gui_modules/gmodeler.py:4282
+#: ../gui/wxpython/gui_modules/gmodeler.py:3542
+#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3958
+#: ../gui/wxpython/gui_modules/gmodeler.py:4276
 msgid "Name"
 msgstr "Name"
@@ -6716,7 +6775,7 @@
 "(etwas Geduld)"
 #: ../gui/wxpython/gui_modules/ghelp.py:815
-#: ../gui/wxpython/gui_modules/gdialogs.py:959
+#: ../gui/wxpython/gui_modules/gdialogs.py:960
 msgid "Options"
 msgstr "Optionen"
@@ -6776,8 +6835,8 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1507
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3295
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
-#: ../gui/wxpython/gui_modules/gdialogs.py:1258
-#: ../gui/wxpython/gui_modules/menuform.py:1691
+#: ../gui/wxpython/gui_modules/gdialogs.py:1259
+#: ../gui/wxpython/gui_modules/menuform.py:1684
 msgid "Browse"
 msgstr "Blättern"
@@ -6857,8 +6916,8 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:874
 #: ../gui/wxpython/gui_modules/location_wizard.py:1037
 #: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/gui_modules/gmodeler.py:3549
-#: ../gui/wxpython/gui_modules/gmodeler.py:3608
+#: ../gui/wxpython/gui_modules/gmodeler.py:3543
+#: ../gui/wxpython/gui_modules/gmodeler.py:3602
 msgid "Description"
 msgstr "Beschreibung"
@@ -6959,7 +7018,7 @@
 msgstr "Pfad zu der Datei mit EPSG Codes:"
 #: ../gui/wxpython/gui_modules/location_wizard.py:1286
-#: ../gui/wxpython/gui_modules/preferences.py:1814
+#: ../gui/wxpython/gui_modules/preferences.py:1836
 msgid "EPSG code:"
 msgstr "EPSG Code:"
@@ -7230,7 +7289,7 @@
 msgstr "Selektiere Vektorkarte für Ausgabe:"
 #: ../gui/wxpython/gui_modules/vclean.py:168
-#: ../gui/wxpython/gui_modules/menuform.py:832
+#: ../gui/wxpython/gui_modules/menuform.py:833
 msgid "Copy the current command string to the clipboard (Ctrl+C)"
 msgstr "Kopiere die aktuelle Befehlszeile in die Zwischenablage (Ctrl+C)"
@@ -7320,289 +7379,292 @@
 msgstr ""
 "Befehl zum Säubern von Vektordaten wurden in die Zwischenablage kopiert"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:70
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:48
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:55
+#: ../gui/wxpython/gui_modules/nviz_tools.py:136
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:52
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:59
 msgid "View"
 msgstr "Ansicht"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:74
-#: ../gui/wxpython/gui_modules/gmodeler.py:3154
+#: ../gui/wxpython/gui_modules/gmodeler.py:3148
 msgid "Data"
 msgstr "Daten"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:78
-#: ../gui/wxpython/gui_modules/preferences.py:1236
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/preferences.py:1240
 msgid "Appearance"
 msgstr "Erscheinung"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:112
+#: ../gui/wxpython/gui_modules/nviz_tools.py:216
 #, fuzzy
 msgid "Control View"
 msgstr "Kontrolle der Ansicht"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:120
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1146
+#: ../gui/wxpython/gui_modules/nviz_tools.py:226
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1360
 msgid "W"
 msgstr "W"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:122
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1148
+#: ../gui/wxpython/gui_modules/nviz_tools.py:227
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1362
 msgid "N"
 msgstr "N"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:129
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1155
+#: ../gui/wxpython/gui_modules/nviz_tools.py:228
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1369
 msgid "S"
 msgstr "S"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:131
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+#: ../gui/wxpython/gui_modules/nviz_tools.py:229
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
 msgid "E"
 msgstr "O"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:140
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:64
+#: ../gui/wxpython/gui_modules/nviz_tools.py:230
+#, fuzzy
+msgid "NW"
+msgstr "W"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:231
+#, fuzzy
+msgid "NE"
+msgstr "N"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:232
+#, fuzzy
+msgid "SE"
+msgstr "S"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:233
+#, fuzzy
+msgid "SW"
+msgstr "W"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:68
 msgid "Perspective:"
 msgstr "Perspektive:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:150
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:143
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
 msgid "Twist:"
 msgstr "Drehung:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:168
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1167
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:124
-#: ../gui/wxpython/gui_modules/gmodeler.py:3128
-#: ../gui/wxpython/gui_modules/gmodeler.py:3247
+#: ../gui/wxpython/gui_modules/nviz_tools.py:290
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1381
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:128
+#: ../gui/wxpython/gui_modules/gmodeler.py:3122
+#: ../gui/wxpython/gui_modules/gmodeler.py:3241
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4038
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4181
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4829
-#: ../gui/wxpython/gui_modules/gdialogs.py:1634
+#: ../gui/wxpython/gui_modules/gdialogs.py:1635
 msgid "Height:"
 msgstr "Höhe:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:175
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:173
+#: ../gui/wxpython/gui_modules/nviz_tools.py:296
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:177
 msgid "Z-exag:"
 msgstr "Z-Überh:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
-msgid "Look at:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:309
+#, fuzzy
+msgid "Look:"
 msgstr "Schau auf:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+#: ../gui/wxpython/gui_modules/nviz_tools.py:312
+#, fuzzy
+msgid "here"
+msgstr "Kugel"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:318
+#, fuzzy
+msgid "center"
+msgstr "Rendern"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:324
 msgid "top"
 msgstr "oben"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
-msgid "north"
-msgstr "Norden"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
-msgid "south"
-msgstr "Süden"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:197
-msgid "east"
-msgstr "Osten"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:198
-msgid "west"
-msgstr "Westen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:199
-msgid "north-west"
-msgstr "Nordwesten"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:200
-msgid "north-east"
-msgstr "Nordosten"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:201
-msgid "south-east"
-msgstr "Südosten"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:202
-msgid "south-west"
-msgstr "Südwesten"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:210
-msgid "Reset"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:330
+#, fuzzy
+msgid "reset"
 msgstr "Zurücksetzen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:211
+#: ../gui/wxpython/gui_modules/nviz_tools.py:331
 msgid "Reset to default view"
 msgstr "Zurücksetzen auf Standardansicht"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:233
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:205
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:209
 #, fuzzy
 msgid "Image Appearance"
 msgstr "Image Appearance"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:240
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:212
-#: ../gui/wxpython/gui_modules/preferences.py:1452
+#: ../gui/wxpython/gui_modules/nviz_tools.py:357
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:217
+#: ../gui/wxpython/gui_modules/preferences.py:1474
 msgid "Background color:"
 msgstr "Hintergrundfarbe: "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:272
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:394
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1471
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:353
 msgid "Surface"
 msgstr "Oberfläche"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:277
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:237
+#: ../gui/wxpython/gui_modules/nviz_tools.py:400
+#: ../gui/wxpython/gui_modules/nviz_tools.py:757
+#, fuzzy
+msgid "Constant surface"
+msgstr "Kostenoberfläche"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:405
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:457
 msgid "Vector"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:282
+#: ../gui/wxpython/gui_modules/nviz_tools.py:411
 msgid "Volume"
 msgstr "Volumen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:298
+#: ../gui/wxpython/gui_modules/nviz_tools.py:435
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:243
 msgid "Lighting"
 msgstr "Beleuchtung"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:302
+#: ../gui/wxpython/gui_modules/nviz_tools.py:440
 msgid "Fringe"
 msgstr "Randzone"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:342
-msgid "Surface attributes"
-msgstr "Oberflächenattribute"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:349
-msgid "Topography"
-msgstr "Topographie"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:350
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
-#: ../gui/wxpython/gui_modules/profile.py:1222
-msgid "Color"
-msgstr "Farbe"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:352
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1028
-msgid "Transparency"
-msgstr "Transparenz"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:353
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
-msgid "Shininess"
-msgstr "Glanz"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:354
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1030
-msgid "Emission"
-msgstr "Emission"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:360
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1038
-msgid "map"
-msgstr "Karte"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:363
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1043
-msgid "unset"
-msgstr "zurücksetzen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:368
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1048
-msgid "constant"
-msgstr "konstant"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:428
-#: ../gui/wxpython/gui_modules/nviz_tools.py:915
+#: ../gui/wxpython/gui_modules/nviz_tools.py:488
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1126
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:362
 msgid "Draw"
 msgstr "Zeichnen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:435
-#: ../gui/wxpython/gui_modules/nviz_tools.py:922
+#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1133
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:368
 msgid "Mode:"
 msgstr "Modus:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:438
+#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
 msgid "coarse"
 msgstr "grob"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:439
+#: ../gui/wxpython/gui_modules/nviz_tools.py:499
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:372
 msgid "fine"
 msgstr "fein"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:440
+#: ../gui/wxpython/gui_modules/nviz_tools.py:500
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:373
 msgid "both"
 msgstr "beides"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:450
-#: ../gui/wxpython/gui_modules/nviz_tools.py:936
+#: ../gui/wxpython/gui_modules/nviz_tools.py:509
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1147
 msgid "Shading:"
 msgstr "Schummerung:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:453
-#: ../gui/wxpython/gui_modules/nviz_tools.py:709
-#: ../gui/wxpython/gui_modules/nviz_tools.py:939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:512
+#: ../gui/wxpython/gui_modules/nviz_tools.py:920
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1150
 msgid "flat"
 msgstr "flach"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:454
-#: ../gui/wxpython/gui_modules/nviz_tools.py:940
+#: ../gui/wxpython/gui_modules/nviz_tools.py:513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1151
 msgid "gouraud"
 msgstr "gouraud"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:462
+#: ../gui/wxpython/gui_modules/nviz_tools.py:521
 msgid "Set to all"
 msgstr "Alle setzen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:463
+#: ../gui/wxpython/gui_modules/nviz_tools.py:522
 msgid "Use draw settings for all loaded surfaces"
 msgstr "Verwende Zeichenvorschriften für alle geladenen Oberflächen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:470
-msgid "Coarse:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:400
+#, fuzzy
+msgid "Coarse mode:"
 msgstr "Grob:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:524
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:387
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:404
 #, fuzzy
-msgid "res."
-msgstr "Auflösung"
+msgid "resolution:"
+msgstr "Auflösung:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:492
-msgid "style"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:545
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:416
+#, fuzzy
+msgid "style:"
 msgstr "Stil"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:548
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
 msgid "wire"
 msgstr "Gitternetz"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:549
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:420
 msgid "surface"
 msgstr "Oberfläche"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:505
-msgid "wire color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:561
+#, fuzzy
+msgid "Change wire color"
 msgstr "Gitterfarbe"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:519
-msgid "Fine:"
-msgstr "fein:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:568
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:383
+#, fuzzy
+msgid "Fine mode:"
+msgstr "Finde Module"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
-msgid "Mask zeros:"
-msgstr "Nullen maskieren:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:593
+msgid "Surface attributes"
+msgstr "Oberflächenattribute"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
-msgid "by elevation"
-msgstr "nach Höhenlage"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:601
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1222
+msgid "Color"
+msgstr "Farbe"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:563
-msgid "by color"
-msgstr "nach Farbe"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:603
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1239
+msgid "Transparency"
+msgstr "Transparenz"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:578
+#: ../gui/wxpython/gui_modules/nviz_tools.py:604
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1240
+msgid "Shininess"
+msgstr "Glanz"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:610
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1249
+msgid "map"
+msgstr "Karte"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:613
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1254
+msgid "unset"
+msgstr "zurücksetzen"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1259
+msgid "constant"
+msgstr "konstant"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:671
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4008
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4577
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4793
@@ -7611,155 +7673,199 @@
 msgid "Position"
 msgstr "Position"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:653
+#: ../gui/wxpython/gui_modules/nviz_tools.py:686
+msgid "Reset"
+msgstr "Zurücksetzen"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:687
+#, fuzzy
+msgid "Reset to default position"
+msgstr "Zurücksetzen auf Standardansicht"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:785
+#, fuzzy
+msgid "Fine resolution:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:797
+#, fuzzy
+msgid "Value:"
+msgstr "Werte"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:863
 msgid "Show vector lines"
 msgstr "Zeige Vektorlinien"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:663
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:245
+#: ../gui/wxpython/gui_modules/nviz_tools.py:873
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:465
 msgid "Vector lines"
 msgstr "Vektorlinien"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:669
+#: ../gui/wxpython/gui_modules/nviz_tools.py:880
 msgid "Line:"
 msgstr "Linie:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:672
-#: ../gui/wxpython/gui_modules/nviz_tools.py:805
-msgid "width"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:883
+#, fuzzy
+msgid "width:"
 msgstr "Breite"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:688
-#: ../gui/wxpython/gui_modules/nviz_tools.py:790
-msgid "color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:899
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1001
+#, fuzzy
+msgid "color:"
 msgstr "Farbe"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:703
-msgid "display"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+#: ../gui/wxpython/gui_modules/vdigit.py:158
+msgid "Display"
 msgstr "Fenster"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:708
-msgid "on surface"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:919
+#, fuzzy
+msgid "on surface(s):"
 msgstr "auf der Oberfläche"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:718
-#: ../gui/wxpython/gui_modules/nviz_tools.py:836
+#: ../gui/wxpython/gui_modules/nviz_tools.py:929
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1050
 msgid "Height above surface:"
 msgstr "Höhe über Grund:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:754
+#: ../gui/wxpython/gui_modules/nviz_tools.py:964
 msgid "Show vector points"
 msgstr "Vektorpunkte anzeigen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:973
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:487
 msgid "Vector points"
 msgstr "Vektorpunkte"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:769
+#: ../gui/wxpython/gui_modules/nviz_tools.py:980
 msgid "Icon:"
 msgstr "Symbol:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:772
-msgid "size"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:983
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
+#, fuzzy
+msgid "size:"
 msgstr "Größe"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:823
-msgid "symbol"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1016
+msgid "width"
+msgstr "Breite"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1033
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
+#, fuzzy
+msgid "symbol:"
 msgstr "Symbol"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:892
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1046
+#, fuzzy
+msgid "Display on surface(s):"
+msgstr "Distanz entlang Oberfläche"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
 msgid "3D raster map"
 msgstr "3D Rasterkarte"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:925
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1136
 msgid "isosurfaces"
 msgstr "Iso-Oberfläche"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1137
 msgid "slides"
 msgstr "Folien"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:949
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1160
 msgid "Resolution:"
 msgstr "Auflösung:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:971
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
 msgid "List of isosurfaces"
 msgstr "Liste der Iso-Oberflächen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1019
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1230
 msgid "Isosurface attributes"
 msgstr "Attribute der Iso-Oberflächen"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1025
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1236
 msgid "Topography level"
 msgstr "Topographisches Level"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1241
+msgid "Emission"
+msgstr "Emission"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1342
 msgid "Show light model"
 msgstr "Zeige Licht-Modell"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1135
-#, fuzzy
-msgid "Follow source viewpoint"
-msgstr "Folge Quell-Betrachtungspunkt"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1141
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1355
 msgid "Light source position"
 msgstr "Position der Lichtquelle"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1185
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1399
 msgid "Light color and intensity"
 msgstr "Lichtfarbe und -intensität"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1199
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1413
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:299
 msgid "Brightness:"
 msgstr "Helligkeit:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1423
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
 #, fuzzy
 msgid "Ambient:"
 msgstr "Umgebend:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1270
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1485
 msgid "Edges with fringe"
 msgstr "Kanten mit Randzone"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1487
 msgid "N && W"
 msgstr "N && W"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1488
 msgid "N && E"
 msgstr "N && E"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1489
 msgid "S && W"
 msgstr "S && W"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1275
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1490
 msgid "S && E"
 msgstr "S && E"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1295
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1510
 msgid "Elevation of fringe from bottom:"
 msgstr "Höhe der Randzone von unten:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2309
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2311
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1563
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1608
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1186
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1204
+#, fuzzy
+msgid "constant#"
+msgstr "konstant"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2667
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2669
 msgid "Level"
 msgstr "Level"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2632
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3003
 msgid "Vector map is 3D"
 msgstr "Vektorkarte ist 3D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2635
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3006
 msgid "Vector map is 2D"
 msgstr "Vektorkarte ist 2D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2637
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3008
 #, python-format
 msgid "%(features)d features (%(points)d points)"
 msgstr "%(features)d Objekte (%(points)d points)"
@@ -7781,8 +7887,8 @@
 msgstr "Liste der Layer"
 #: ../gui/wxpython/gui_modules/ogc_services.py:69
-#: ../gui/wxpython/gui_modules/gdialogs.py:1153
-#: ../gui/wxpython/gui_modules/gdialogs.py:1263
+#: ../gui/wxpython/gui_modules/gdialogs.py:1154
+#: ../gui/wxpython/gui_modules/gdialogs.py:1264
 msgid "Add imported layers into layer tree"
 msgstr "Importierte Ebenen der Baumstruktur hinzufügen"
@@ -7795,14 +7901,14 @@
 msgstr "Verbinde zu Server"
 #: ../gui/wxpython/gui_modules/ogc_services.py:85
-#: ../gui/wxpython/gui_modules/gdialogs.py:998
-#: ../gui/wxpython/gui_modules/gdialogs.py:1165
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
+#: ../gui/wxpython/gui_modules/gdialogs.py:1166
 msgid "&Import"
 msgstr "&Import"
 #: ../gui/wxpython/gui_modules/ogc_services.py:86
-#: ../gui/wxpython/gui_modules/gdialogs.py:999
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/gdialogs.py:1167
 msgid "Import selected layers"
 msgstr "Importiere ausgewählte Ebenen"
@@ -7818,17 +7924,17 @@
 msgid "Layers"
 msgstr "Ebenen"
-#: ../gui/wxpython/gui_modules/prompt.py:393
+#: ../gui/wxpython/gui_modules/prompt.py:394
 #, python-format
 msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
 msgstr "Warnung: Flag <%(flag)s> nicht gefunden in '%(module)s'"
-#: ../gui/wxpython/gui_modules/prompt.py:396
+#: ../gui/wxpython/gui_modules/prompt.py:397
 #, python-format
 msgid "Warning: option <%(param)s> not found in '%(module)s'"
 msgstr "Warnung: Option <%(param)s> nicht gefunden in '%(module)s'"
-#: ../gui/wxpython/gui_modules/prompt.py:617
+#: ../gui/wxpython/gui_modules/prompt.py:618
 msgid "Type GRASS command and run by pressing ENTER"
 msgstr "GRASS Befehl eingeben und durch Drücken von ENTER ausführen"
@@ -7850,7 +7956,7 @@
 msgstr "Name der Quelle"
 #: ../gui/wxpython/gui_modules/gselect.py:1083
-#: ../gui/wxpython/gui_modules/menuform.py:1690
+#: ../gui/wxpython/gui_modules/menuform.py:1683
 msgid "File"
 msgstr "Datei"
@@ -7926,7 +8032,7 @@
 msgstr "Einstellungen <%s> nicht gefunden"
 #: ../gui/wxpython/gui_modules/gselect.py:1285
-#: ../gui/wxpython/gui_modules/gmodeler.py:3331
+#: ../gui/wxpython/gui_modules/gmodeler.py:3325
 msgid "Name:"
 msgstr "Name:"
@@ -7942,62 +8048,74 @@
 msgid "Unable to save settings."
 msgstr "Kann Einstellungen nicht speichern."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:29
 msgid "3D view settings"
 msgstr "Einstellungen der 3D-Ansicht"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:67
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:146
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:71
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:180
 msgid "(value)"
 msgstr "(Wert)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:79
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:127
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:158
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:187
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:83
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:131
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:162
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:191
 msgid "(step)"
 msgstr "(Schrittweite)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:94
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:98
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:258
 msgid "Position:"
 msgstr "Position:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:97
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:101
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:261
 msgid "(x)"
 msgstr "(x)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:252
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:249
+#, fuzzy
+msgid "Light"
+msgstr "Beleuchtung"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:285
+#, fuzzy
+msgid "(z)"
+msgstr "(x)"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:431
+#, fuzzy
+msgid "wire color:"
+msgstr "Gitterfarbe"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
 msgid "Show lines"
 msgstr "Linien anzeigen"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:274
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:494
 msgid "Show points"
 msgstr "Punkte anzeigen"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:283
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:503
 msgid "Size:"
 msgstr "Größe:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:298
-#: ../gui/wxpython/gui_modules/gmodeler.py:3110
-#: ../gui/wxpython/gui_modules/gmodeler.py:3229
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:518
+#: ../gui/wxpython/gui_modules/gmodeler.py:3104
+#: ../gui/wxpython/gui_modules/gmodeler.py:3223
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4026
-#: ../gui/wxpython/gui_modules/gdialogs.py:1630
+#: ../gui/wxpython/gui_modules/gdialogs.py:1631
 msgid "Width:"
 msgstr "Breite:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:533
 msgid "Marker:"
 msgstr "Marker:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:695
 #, python-format
-msgid "Nviz settings saved to file <%s>."
-msgstr "Nviz-Einstellungen in der Datei <%s> gespeichert."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
-#, python-format
 msgid "3D view settings saved to file <%s>."
 msgstr "Einstellungen für 3D-Ansicht gespeichert in Datei <%s>."
@@ -8012,8 +8130,8 @@
 #: ../gui/wxpython/gui_modules/gcmd.py:349
 #: ../gui/wxpython/gui_modules/render.py:627
 #: ../gui/wxpython/gui_modules/render.py:630
-#: ../gui/wxpython/gui_modules/menuform.py:2167
-#: ../gui/wxpython/gui_modules/menuform.py:2170
+#: ../gui/wxpython/gui_modules/menuform.py:2160
+#: ../gui/wxpython/gui_modules/menuform.py:2163
 msgid "Details:"
 msgstr "Einzelheiten:"
@@ -8038,23 +8156,19 @@
 "Benutzereinstellungen"
 #: ../gui/wxpython/gui_modules/vdigit.py:92
-#: ../gui/wxpython/gui_modules/gmodeler.py:3319
+#: ../gui/wxpython/gui_modules/gmodeler.py:3313
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1703
 #: ../gui/wxpython/gui_modules/profile.py:1040
 #: ../gui/wxpython/gui_modules/profile.py:1393
-#: ../gui/wxpython/gui_modules/preferences.py:966
+#: ../gui/wxpython/gui_modules/preferences.py:971
 msgid "Close dialog and ignore changes"
 msgstr "Schließe den Dialog und ignoriere die Änderungen"
 #: ../gui/wxpython/gui_modules/vdigit.py:151
-#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_modules/preferences.py:1109
 msgid "General"
 msgstr "Allgemein"
-#: ../gui/wxpython/gui_modules/vdigit.py:158
-msgid "Display"
-msgstr "Fenster"
 #: ../gui/wxpython/gui_modules/vdigit.py:163
 #: ../gui/wxpython/gui_modules/profile.py:1174
 msgid "Line width"
@@ -8167,7 +8281,7 @@
 msgstr "Selektiere Überstände (dangles)"
 #: ../gui/wxpython/gui_modules/vdigit.py:377
-#: ../gui/wxpython/gui_modules/preferences.py:1669
+#: ../gui/wxpython/gui_modules/preferences.py:1691
 msgid "Attributes"
 msgstr "Attribute"
@@ -8339,20 +8453,20 @@
 "Layer Nummern müssen größer als Null sein."
 #: ../gui/wxpython/gui_modules/vdigit.py:1060
-#: ../gui/wxpython/gui_modules/gmodeler.py:3785
-#: ../gui/wxpython/gui_modules/gmodeler.py:4142
+#: ../gui/wxpython/gui_modules/gmodeler.py:3779
+#: ../gui/wxpython/gui_modules/gmodeler.py:4136
 msgid "Delete selected"
 msgstr "Selektierte löschen"
 #: ../gui/wxpython/gui_modules/vdigit.py:1064
-#: ../gui/wxpython/gui_modules/gmodeler.py:3786
-#: ../gui/wxpython/gui_modules/gmodeler.py:4143
+#: ../gui/wxpython/gui_modules/gmodeler.py:3780
+#: ../gui/wxpython/gui_modules/gmodeler.py:4137
 msgid "Delete all"
 msgstr "Alle löschen"
 #: ../gui/wxpython/gui_modules/vdigit.py:1066
-#: ../gui/wxpython/gui_modules/gmodeler.py:3792
-#: ../gui/wxpython/gui_modules/gmodeler.py:4150
+#: ../gui/wxpython/gui_modules/gmodeler.py:3786
+#: ../gui/wxpython/gui_modules/gmodeler.py:4144
 #: ../gui/wxpython/gui_modules/dbm.py:1146
 #: ../gui/wxpython/gui_modules/dbm.py:1659
 msgid "Reload"
@@ -8450,6 +8564,11 @@
 msgid "Preview generated"
 msgstr ""
+#: ../gui/wxpython/gui_modules/psmap.py:353
+#, fuzzy
+msgid "Save file as"
+msgstr "Speichere Datei als..."
 #: ../gui/wxpython/gui_modules/psmap.py:392
 msgid "Failed to read file %s."
@@ -8465,12 +8584,12 @@
 msgid "Scalebar is not appropriate for this projection"
 msgstr "Geben Sie Parameter an für die %s Projektion "
-#: ../gui/wxpython/gui_modules/psmap.py:861
+#: ../gui/wxpython/gui_modules/psmap.py:860
 #, fuzzy
 msgid "wxGUI Hardcopy Map Utility"
-#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/psmap.py:862
 #, fuzzy
 msgid ""
 "(C) 2011 by the GRASS Development Team\n"
@@ -8479,8 +8598,8 @@
 "(C) 2010 by the GRASS Development Team\n"
 "\n"
-#: ../gui/wxpython/gui_modules/psmap.py:864
-#: ../gui/wxpython/gui_modules/gmodeler.py:1236
+#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/gmodeler.py:1230
 #, fuzzy
 msgid ""
 "This program is free software under the GNU General Public License(>=v2). "
@@ -8490,7 +8609,7 @@
 "(>=v2). Lesen sie für Details die Datei COPYING, die mit GRASS ausgeliefert "
 "wird."
-#: ../gui/wxpython/gui_modules/psmap.py:1095
+#: ../gui/wxpython/gui_modules/psmap.py:1094
 msgid "Click and drag to resize object"
 msgstr ""
@@ -8608,7 +8727,7 @@
 msgstr "Vektorkarten"
 #: ../gui/wxpython/gui_modules/gmodeler.py:451
-#: ../gui/wxpython/gui_modules/gmodeler.py:574
+#: ../gui/wxpython/gui_modules/gmodeler.py:568
 msgid "Variables"
 msgstr "Variablen"
@@ -8616,47 +8735,47 @@
 msgid "GRASS GIS Graphical Modeler"
 msgstr "GRASS GIS Graphical Modeler"
-#: ../gui/wxpython/gui_modules/gmodeler.py:572
+#: ../gui/wxpython/gui_modules/gmodeler.py:566
 msgid "Model"
 msgstr "Modell"
-#: ../gui/wxpython/gui_modules/gmodeler.py:573
+#: ../gui/wxpython/gui_modules/gmodeler.py:567
 msgid "Items"
 msgstr "Objekte"
-#: ../gui/wxpython/gui_modules/gmodeler.py:642
+#: ../gui/wxpython/gui_modules/gmodeler.py:636
 msgid "Redrawing model..."
 msgstr "Stelle Modell neu dar..."
-#: ../gui/wxpython/gui_modules/gmodeler.py:669
+#: ../gui/wxpython/gui_modules/gmodeler.py:663
 msgid "Do you want to save changes in the model?"
 msgstr "Wollen Sie die Änderungen im Modell speichern?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:671
+#: ../gui/wxpython/gui_modules/gmodeler.py:665
 msgid "Do you want to store current model settings to model file?"
 msgstr "Wollen sie die aktuellen Einstellungen in eine Modell-Datei speichern?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:738
+#: ../gui/wxpython/gui_modules/gmodeler.py:732
 #: ../gui/wxpython/gui_modules/dbm.py:2084
 msgid "Nothing to delete."
 msgstr "Nichts zu löschen."
-#: ../gui/wxpython/gui_modules/gmodeler.py:742
+#: ../gui/wxpython/gui_modules/gmodeler.py:736
 #, python-format
 msgid "Do you want to permanently delete data?%s"
 msgstr "Wollen sie die Daten dauerhaft löschen?%s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:743
+#: ../gui/wxpython/gui_modules/gmodeler.py:737
 msgid "Delete intermediate data?"
 msgstr "Lösche temporäre Daten?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:757
+#: ../gui/wxpython/gui_modules/gmodeler.py:751
 #, python-format
 msgid "%d maps deleted from current mapset"
 msgstr "%d Karte aus dem aktuellen Mapset gelöscht"
-#: ../gui/wxpython/gui_modules/gmodeler.py:772
-#: ../gui/wxpython/gui_modules/gmodeler.py:885
+#: ../gui/wxpython/gui_modules/gmodeler.py:766
+#: ../gui/wxpython/gui_modules/gmodeler.py:879
 msgid ""
 "Current model is not empty. Do you want to store current settings to model "
 "file?"
@@ -8664,52 +8783,52 @@
 "Aktuelles Modell ist nicht leer. Wollen sie die aktuellen Einstellungen in "
 "eine Modell-Datei speichern?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:775
-#: ../gui/wxpython/gui_modules/gmodeler.py:888
+#: ../gui/wxpython/gui_modules/gmodeler.py:769
+#: ../gui/wxpython/gui_modules/gmodeler.py:882
 msgid "Create new model?"
 msgstr "Neues Modell erstellen?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:800
+#: ../gui/wxpython/gui_modules/gmodeler.py:794
 msgid "Choose model file"
 msgstr "Auswahl der Modell-Datei"
-#: ../gui/wxpython/gui_modules/gmodeler.py:818
+#: ../gui/wxpython/gui_modules/gmodeler.py:812
 msgid "%(items)d items (%(actions)d actions) loaded into model"
 msgstr "%(items)d items (%(actions)d actions) in Modell geladen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:825
-#: ../gui/wxpython/gui_modules/gmodeler.py:862
+#: ../gui/wxpython/gui_modules/gmodeler.py:819
+#: ../gui/wxpython/gui_modules/gmodeler.py:856
 #, python-format
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
 "Modell-Datei <%s> existiert bereits. Wollen Sie diese Datei überschreiben?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:835
-#: ../gui/wxpython/gui_modules/gmodeler.py:875
+#: ../gui/wxpython/gui_modules/gmodeler.py:829
+#: ../gui/wxpython/gui_modules/gmodeler.py:869
 #, python-format
 msgid "File <%s> saved"
 msgstr "Datei <%s> gespeichert"
-#: ../gui/wxpython/gui_modules/gmodeler.py:844
+#: ../gui/wxpython/gui_modules/gmodeler.py:838
 msgid "Choose file to save current model"
 msgstr "Wählen Sie eine Datei, um das aktuelle Modell zu speichern"
-#: ../gui/wxpython/gui_modules/gmodeler.py:864
+#: ../gui/wxpython/gui_modules/gmodeler.py:858
 msgid "File already exists"
 msgstr "Die Datei existiert bereits."
-#: ../gui/wxpython/gui_modules/gmodeler.py:912
+#: ../gui/wxpython/gui_modules/gmodeler.py:906
 #, fuzzy
 msgid "Model is empty. Nothing to run."
 msgstr "Modell ist leer. Nichts ausgeführt."
-#: ../gui/wxpython/gui_modules/gmodeler.py:999
+#: ../gui/wxpython/gui_modules/gmodeler.py:993
 #, fuzzy
 msgid "Model is empty. Nothing to validate."
 msgstr "Modell ist leer. Nichts überprüft."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1006
+#: ../gui/wxpython/gui_modules/gmodeler.py:1000
 #, python-format
 msgid ""
 "Model is not valid.\n"
@@ -8720,38 +8839,38 @@
 "\n"
 "%s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1009
+#: ../gui/wxpython/gui_modules/gmodeler.py:1003
 msgid "Model is valid."
 msgstr "Modell ist gültig."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1070
-#: ../gui/wxpython/gui_modules/gmodeler.py:1113
+#: ../gui/wxpython/gui_modules/gmodeler.py:1064
+#: ../gui/wxpython/gui_modules/gmodeler.py:1107
 #, python-format
 msgid "Model exported to <%s>"
 msgstr "Modell exportiert in <%s>"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1078
+#: ../gui/wxpython/gui_modules/gmodeler.py:1072
 msgid "Choose file to save"
 msgstr "Wählen Sie die zu speichernde Datei"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1080
+#: ../gui/wxpython/gui_modules/gmodeler.py:1074
 msgid "Python script (*.py)|*.py"
 msgstr "Pythont Skript (*.py)|*.py"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1094
+#: ../gui/wxpython/gui_modules/gmodeler.py:1088
 #, python-format
 msgid "File <%s> already exists. Do you want to overwrite this file?"
 msgstr "Datei <%s> existiert bereits. Wollen Sie die Datei überschreiben?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1096
+#: ../gui/wxpython/gui_modules/gmodeler.py:1090
 msgid "Save file"
 msgstr "Speichere Datei"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1233
+#: ../gui/wxpython/gui_modules/gmodeler.py:1227
 msgid "wxGUI Graphical Modeler"
 msgstr "wxGUI Graphical Modeler"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1235
+#: ../gui/wxpython/gui_modules/gmodeler.py:1229
 msgid ""
 "\n"
@@ -8759,7 +8878,7 @@
 "\n"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1366
+#: ../gui/wxpython/gui_modules/gmodeler.py:1360
 #, python-format
 msgid ""
 "Reading model file <%s> failed.\n"
@@ -8768,89 +8887,89 @@
 "Lesen der Modell-Datei <%s> nicht erfolgreich.\n"
 "Ungültige Datei, Parsing der XML-Datei nicht möglich."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1372
+#: ../gui/wxpython/gui_modules/gmodeler.py:1366
 msgid "Please wait, loading model..."
 msgstr "Bitte warten Sie, lade Modell..."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1427
+#: ../gui/wxpython/gui_modules/gmodeler.py:1421
 msgid "Writing current settings to model file failed."
 msgstr ""
 "Das Schreiben der aktuellen Einstellungen in die Modell-Datei nicht "
 "erfolgreich."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1728
-#: ../gui/wxpython/gui_modules/gmodeler.py:1785
-#: ../gui/wxpython/gui_modules/gmodeler.py:1912
-#: ../gui/wxpython/gui_modules/menuform.py:384
+#: ../gui/wxpython/gui_modules/gmodeler.py:1722
+#: ../gui/wxpython/gui_modules/gmodeler.py:1779
+#: ../gui/wxpython/gui_modules/gmodeler.py:1906
+#: ../gui/wxpython/gui_modules/menuform.py:385
 msgid "unknown"
 msgstr "unbekannt"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2010
+#: ../gui/wxpython/gui_modules/gmodeler.py:2004
 msgid "<not defined>"
 msgstr "<nicht definiert>"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2020
+#: ../gui/wxpython/gui_modules/gmodeler.py:2014
 msgid "Data properties"
 msgstr "Dateneigenschaften"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2027
+#: ../gui/wxpython/gui_modules/gmodeler.py:2021
 msgid "Name of raster map:"
 msgstr "Name der Rasterkarte:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2029
+#: ../gui/wxpython/gui_modules/gmodeler.py:2023
 msgid "Name of vector map:"
 msgstr "Name der Vektorkarte:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2031
+#: ../gui/wxpython/gui_modules/gmodeler.py:2025
 msgid "Name of element:"
 msgstr "Name des Elements:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2224
+#: ../gui/wxpython/gui_modules/gmodeler.py:2218
 #: ../gui/wxpython/gui_modules/layertree.py:272
 msgid "Remove"
 msgstr "Entfernen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2228
+#: ../gui/wxpython/gui_modules/gmodeler.py:2222
 msgid "Disable"
 msgstr "Ausschalten"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+#: ../gui/wxpython/gui_modules/gmodeler.py:2225
 msgid "Enable"
 msgstr "Aktiviere"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2236
+#: ../gui/wxpython/gui_modules/gmodeler.py:2230
 msgid "Add control point"
 msgstr "Füge Kontrollpunkt hinzu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2238
+#: ../gui/wxpython/gui_modules/gmodeler.py:2232
 msgid "Remove control point"
 msgstr "Entferne Kontrollpunkt"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2245
+#: ../gui/wxpython/gui_modules/gmodeler.py:2239
 msgid "Intermediate"
 msgstr "Temporär"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2256
+#: ../gui/wxpython/gui_modules/gmodeler.py:2250
 #: ../gui/wxpython/gui_modules/layertree.py:286
 msgid "Properties"
 msgstr "Eigenschaften"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2260
+#: ../gui/wxpython/gui_modules/gmodeler.py:2254
 msgid "Change ID"
 msgstr "Ändere ID"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2316
+#: ../gui/wxpython/gui_modules/gmodeler.py:2310
 msgid "Add new GRASS module to the model"
 msgstr "Neues GRASS-Modul zu Modell hinzufügen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2334
-#: ../gui/wxpython/gui_modules/gmodeler.py:3857
-#: ../gui/wxpython/gui_modules/gmodeler.py:4283
-#: ../gui/wxpython/gui_modules/preferences.py:1518
+#: ../gui/wxpython/gui_modules/gmodeler.py:2328
+#: ../gui/wxpython/gui_modules/gmodeler.py:3851
+#: ../gui/wxpython/gui_modules/gmodeler.py:4277
+#: ../gui/wxpython/gui_modules/preferences.py:1540
 msgid "Command"
 msgstr "Befehle"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2402
+#: ../gui/wxpython/gui_modules/gmodeler.py:2396
 msgid ""
 "Command not defined.\n"
 "\n"
@@ -8860,7 +8979,7 @@
 "\n"
 "Hinzufügen einer neuen Aktion zu Modell nicht möglich."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2408
+#: ../gui/wxpython/gui_modules/gmodeler.py:2402
 #, python-format
 msgid ""
 "'%s' is not a GRASS module.\n"
@@ -8871,174 +8990,174 @@
 "\n"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3018
+#: ../gui/wxpython/gui_modules/gmodeler.py:3012
 msgid "Action"
 msgstr "Aktion"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3023
+#: ../gui/wxpython/gui_modules/gmodeler.py:3017
 msgid "Validity"
 msgstr "Gültigkeit"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3031
+#: ../gui/wxpython/gui_modules/gmodeler.py:3025
 msgid "Valid:"
 msgstr "Gültig:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3048
+#: ../gui/wxpython/gui_modules/gmodeler.py:3042
 msgid "Invalid:"
 msgstr "Ungültig:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3065
+#: ../gui/wxpython/gui_modules/gmodeler.py:3059
 msgid "Running:"
 msgstr "Berechnung:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3082
+#: ../gui/wxpython/gui_modules/gmodeler.py:3076
 msgid "Disabled:"
 msgstr "Deaktiviert:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3102
-#: ../gui/wxpython/gui_modules/gmodeler.py:3221
+#: ../gui/wxpython/gui_modules/gmodeler.py:3096
+#: ../gui/wxpython/gui_modules/gmodeler.py:3215
 msgid "Shape size"
 msgstr "Shape Größe"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3159
+#: ../gui/wxpython/gui_modules/gmodeler.py:3153
 #: ../gui/wxpython/gui_modules/profile.py:1252
 msgid "Type"
 msgstr "Typ"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3167
+#: ../gui/wxpython/gui_modules/gmodeler.py:3161
 msgid "Raster:"
 msgstr "Raster:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3184
+#: ../gui/wxpython/gui_modules/gmodeler.py:3178
 msgid "3D raster:"
 msgstr "3D Raster:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3201
+#: ../gui/wxpython/gui_modules/gmodeler.py:3195
 msgid "Vector:"
 msgstr "Vektor:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3295
+#: ../gui/wxpython/gui_modules/gmodeler.py:3289
 #: ../gui/wxpython/gui_modules/layertree.py:374
 #: ../gui/wxpython/gui_modules/layertree.py:407
 msgid "Metadata"
 msgstr "Metadaten"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3297
+#: ../gui/wxpython/gui_modules/gmodeler.py:3291
 msgid "Commands"
 msgstr "Befehle"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3317
+#: ../gui/wxpython/gui_modules/gmodeler.py:3311
 msgid "Apply properties"
 msgstr "Wende Eigenschaften an"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3340
+#: ../gui/wxpython/gui_modules/gmodeler.py:3334
 msgid "Description:"
 msgstr "Beschreibung:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3349
+#: ../gui/wxpython/gui_modules/gmodeler.py:3343
 msgid "Author(s):"
 msgstr "Autor(en):"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3398
+#: ../gui/wxpython/gui_modules/gmodeler.py:3392
 msgid "Model parameters"
 msgstr "Modellparameter"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3545
+#: ../gui/wxpython/gui_modules/gmodeler.py:3539
 msgid "List of variables - right-click to delete"
 msgstr "Liste von Variablen - Rechtsklick für Löschen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3595
+#: ../gui/wxpython/gui_modules/gmodeler.py:3589
 #: ../gui/wxpython/gui_modules/dbm.py:885
 #: ../gui/wxpython/gui_modules/dbm.py:2226
 msgid "Data type"
 msgstr "Datentyp"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3601
+#: ../gui/wxpython/gui_modules/gmodeler.py:3595
 msgid "Default value"
 msgstr "Standardwert"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3553
+#: ../gui/wxpython/gui_modules/gmodeler.py:3547
 msgid "Add new variable"
 msgstr "Neue Variable hinzufügen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3557
+#: ../gui/wxpython/gui_modules/gmodeler.py:3551
 msgid "integer"
 msgstr "Integer"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3558
+#: ../gui/wxpython/gui_modules/gmodeler.py:3552
 #, fuzzy
 msgid "float"
 msgstr "Fließkomma"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3559
+#: ../gui/wxpython/gui_modules/gmodeler.py:3553
 msgid "string"
 msgstr "Zeichenkette"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3567
+#: ../gui/wxpython/gui_modules/gmodeler.py:3561
 msgid "Add new variable to the model"
 msgstr "Neue Variable zu Modell hinzufügen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3715
+#: ../gui/wxpython/gui_modules/gmodeler.py:3709
 #, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
 msgstr ""
 "Variable <%s> ist im Modell bereits vorhanden. Hinzufügen nicht erfolgreich."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3744
+#: ../gui/wxpython/gui_modules/gmodeler.py:3738
 msgid "Do you want to delete all variables from the model?"
 msgstr "Wollen sie alle Variablen aus dem Modell löschen?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3746
+#: ../gui/wxpython/gui_modules/gmodeler.py:3740
 msgid "Delete variables"
 msgstr "Lösche Variablen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3826
+#: ../gui/wxpython/gui_modules/gmodeler.py:3820
 msgid "Condition: "
 msgstr "Bedingung:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3828
+#: ../gui/wxpython/gui_modules/gmodeler.py:3822
 msgid "Condition: not defined"
 msgstr "Bedingung: nicht definiert"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3844
 msgid "Condition"
 msgstr "Bedingung"
 msgid "ID"
 msgstr "ID"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+#: ../gui/wxpython/gui_modules/gmodeler.py:3892
 #, fuzzy
 msgid "loop"
 msgstr "Loop"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3906
+#: ../gui/wxpython/gui_modules/gmodeler.py:3900
 msgid "Loop properties"
 msgstr "Loop-Eigenschaften"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3912
+#: ../gui/wxpython/gui_modules/gmodeler.py:3906
 msgid "List of items in loop"
 msgstr "Liste von Elementen im Loop"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3961
+#: ../gui/wxpython/gui_modules/gmodeler.py:3955
 msgid "List of items - right-click to delete"
 msgstr "Liste von Elementen - Rechtsklick für Löschen"
 #, fuzzy
 msgid "In block"
 msgstr "Im Block"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3965
+#: ../gui/wxpython/gui_modules/gmodeler.py:3959
 msgid "Command / Condition"
 msgstr "Befehl / Bedingung"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4092
+#: ../gui/wxpython/gui_modules/gmodeler.py:4086
 #: ../gui/wxpython/gui_modules/dbm.py:1178
 #, python-format
 msgid ""
@@ -9048,38 +9167,38 @@
 "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. "
 "Wollen Sie diese Datensätze löschen?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4095
+#: ../gui/wxpython/gui_modules/gmodeler.py:4089
 #: ../gui/wxpython/gui_modules/dbm.py:1181
 #: ../gui/wxpython/gui_modules/dbm.py:1227
 msgid "Delete records"
 msgstr "Datensätze löschen"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4149
+#: ../gui/wxpython/gui_modules/gmodeler.py:4143
 msgid "Normalize"
 msgstr "Normalisiere"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4247
+#: ../gui/wxpython/gui_modules/gmodeler.py:4241
 msgid "if-else"
 msgstr "if-else"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4268
+#: ../gui/wxpython/gui_modules/gmodeler.py:4262
 msgid "If-else properties"
 msgstr "If-Else-Eigenschaften"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4274
+#: ../gui/wxpython/gui_modules/gmodeler.py:4268
 msgid "List of items in 'if' block"
 msgstr "Liste von Objekte im 'if'-Block"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4279
+#: ../gui/wxpython/gui_modules/gmodeler.py:4273
 msgid "List of items in 'else' block"
 msgstr "Liste von Objekte im 'else'-Block"
-#: ../gui/wxpython/gui_modules/workspace.py:983
+#: ../gui/wxpython/gui_modules/workspace.py:990
 #, python-format
 msgid "Unable to open file <%s> for reading."
 msgstr "Kann die Datei <%s> nicht zum Lesen öffnen."
-#: ../gui/wxpython/gui_modules/workspace.py:996
+#: ../gui/wxpython/gui_modules/workspace.py:1003
 #, python-format
 msgid ""
 "Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -9093,7 +9212,7 @@
 "\n"
 "Anzahl der übersprungenen Zeilen: %(line)d"
-#: ../gui/wxpython/gui_modules/workspace.py:1214
+#: ../gui/wxpython/gui_modules/workspace.py:1221
 #, python-format
 msgid " row %d:"
 msgstr " Zeile %d:"
@@ -9193,7 +9312,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1640
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4906
-#: ../gui/wxpython/gui_modules/preferences.py:2163
+#: ../gui/wxpython/gui_modules/preferences.py:2185
 msgid "Font size:"
 msgstr "Schriftgröße:"
@@ -9535,11 +9654,6 @@
 msgid "Size and style"
 msgstr "Liniestil"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
-#, fuzzy
-msgid "symbol:"
-msgstr "Symbol"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3291
 #, fuzzy
 msgid "eps file:"
@@ -9563,11 +9677,6 @@
 msgid "Size"
 msgstr "Größe"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
-#, fuzzy
-msgid "size:"
-msgstr "Größe"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3322
 #, fuzzy
 msgid "size from map table column:"
@@ -9775,9 +9884,9 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4596
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5081
 #: ../gui/wxpython/gui_modules/profile.py:967
-#: ../gui/wxpython/gui_modules/preferences.py:1240
-#: ../gui/wxpython/gui_modules/preferences.py:1372
-#: ../gui/wxpython/gui_modules/preferences.py:2114
+#: ../gui/wxpython/gui_modules/preferences.py:1244
+#: ../gui/wxpython/gui_modules/preferences.py:1394
+#: ../gui/wxpython/gui_modules/preferences.py:2136
 msgid "Font settings"
 msgstr "Schrifteinstellungen"
@@ -10083,47 +10192,47 @@
 "Befehl '%s' wurde noch nicht in der WxGUI implementiert. Versuchen Sie es "
 "stattdessen als Befehlsebene hinzuzufügen."
-#: ../gui/wxpython/gui_modules/goutput.py:606
+#: ../gui/wxpython/gui_modules/goutput.py:605
 msgid "Save file as..."
-#: ../gui/wxpython/gui_modules/goutput.py:721
+#: ../gui/wxpython/gui_modules/goutput.py:733
 msgid ""
 "Please note that the data are left in inconsistent state and may be corrupted"
 msgstr ""
 "Daten wurden in einem inkonsistenten Zustand zurückgelassen und können "
 "beschädigt sein"
-#: ../gui/wxpython/gui_modules/goutput.py:724
+#: ../gui/wxpython/gui_modules/goutput.py:736
 msgid "Command aborted"
 msgstr "Befehl abgebrochen"
-#: ../gui/wxpython/gui_modules/goutput.py:732
+#: ../gui/wxpython/gui_modules/goutput.py:744
 msgid "Command finished"
 msgstr "Befehl ausgeführt"
-#: ../gui/wxpython/gui_modules/wxnviz.py:302
+#: ../gui/wxpython/gui_modules/wxnviz.py:327
 #, python-format
 msgid "Vector map <%s> not found"
 msgstr "Vektorkarte <%s> nicht gefunden"
-#: ../gui/wxpython/gui_modules/wxnviz.py:354
-#: ../gui/wxpython/gui_modules/wxnviz.py:366
+#: ../gui/wxpython/gui_modules/wxnviz.py:392
+#: ../gui/wxpython/gui_modules/wxnviz.py:404
 #, python-format
 msgid "3d raster map <%s> not found"
 msgstr "3d-Rasterkarte <%s> nicht gefunden"
-#: ../gui/wxpython/gui_modules/toolbars.py:211
+#: ../gui/wxpython/gui_modules/toolbars.py:217
 msgid "3D view mode not available"
 msgstr "3D Ansicht nicht verfügbar"
-#: ../gui/wxpython/gui_modules/toolbars.py:212
-#: ../gui/wxpython/gui_modules/toolbars.py:229
+#: ../gui/wxpython/gui_modules/toolbars.py:218
+#: ../gui/wxpython/gui_modules/toolbars.py:235
 #, python-format
 msgid "Reason: %s"
 msgstr "Grund: %s"
-#: ../gui/wxpython/gui_modules/toolbars.py:213
+#: ../gui/wxpython/gui_modules/toolbars.py:219
 msgid ""
 "Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
 "(hopefully this will be fixed soon). Please keep an eye out for updated "
@@ -10134,16 +10243,16 @@
 "von GRASS. In der Zwischenzeit können Sie \"NVIZ\" unter File menue "
 "verwenden."
-#: ../gui/wxpython/gui_modules/toolbars.py:221
-#: ../gui/wxpython/gui_modules/toolbars.py:1162
+#: ../gui/wxpython/gui_modules/toolbars.py:227
+#: ../gui/wxpython/gui_modules/toolbars.py:1108
 msgid "Digitize"
 msgstr "Digitalisieren"
-#: ../gui/wxpython/gui_modules/toolbars.py:228
+#: ../gui/wxpython/gui_modules/toolbars.py:234
 msgid "Vector digitizer not available"
 msgstr "Vektordigitalisierer nicht vorhanden"
-#: ../gui/wxpython/gui_modules/toolbars.py:230
+#: ../gui/wxpython/gui_modules/toolbars.py:236
 msgid ""
 "Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
 "will be fixed soon). Please keep an eye out for updated versions of GRASS. "
@@ -10154,92 +10263,92 @@
 "auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"v."
 "digit\" aus dem Menü \"Vektor\" - \"Vektorkarten pflegen\" verwenden."
-#: ../gui/wxpython/gui_modules/toolbars.py:421
+#: ../gui/wxpython/gui_modules/toolbars.py:403
 #, fuzzy
 msgid "Set map canvas for "
 msgstr "Setze Darstellungsfenster für"
-#: ../gui/wxpython/gui_modules/toolbars.py:423
+#: ../gui/wxpython/gui_modules/toolbars.py:405
 msgid " / Zoom to map"
 msgstr " / Zoom zu Karte"
-#: ../gui/wxpython/gui_modules/toolbars.py:790
+#: ../gui/wxpython/gui_modules/toolbars.py:737
 msgid "Duplicate attributes"
 msgstr "Doppelte Attribute"
-#: ../gui/wxpython/gui_modules/toolbars.py:867
+#: ../gui/wxpython/gui_modules/toolbars.py:814
 msgid "Copy features from (background) vector map"
 msgstr "Kopiere Feature aus der (Hintergrund-) Vektorkarte."
-#: ../gui/wxpython/gui_modules/toolbars.py:875
+#: ../gui/wxpython/gui_modules/toolbars.py:822
 msgid "Flip selected lines/boundaries"
 msgstr "Drehe selektierte Linien/Grenzen um."
-#: ../gui/wxpython/gui_modules/toolbars.py:883
+#: ../gui/wxpython/gui_modules/toolbars.py:830
 msgid "Merge selected lines/boundaries"
 msgstr "Führe selektierte Linien/Grenzen zusammen."
-#: ../gui/wxpython/gui_modules/toolbars.py:891
+#: ../gui/wxpython/gui_modules/toolbars.py:838
 msgid "Break selected lines/boundaries at intersection"
 msgstr "Teile selektierte Linien/Grenzen an der Kreuzung"
-#: ../gui/wxpython/gui_modules/toolbars.py:899
+#: ../gui/wxpython/gui_modules/toolbars.py:846
 msgid "Snap selected lines/boundaries (only to nodes)"
 msgstr "Snape selektierte Linien/Grenzen (nur auf Knoten)"
-#: ../gui/wxpython/gui_modules/toolbars.py:907
+#: ../gui/wxpython/gui_modules/toolbars.py:854
 msgid "Connect selected lines/boundaries"
 msgstr "Verbinde selektierte Linien/Grenzen"
-#: ../gui/wxpython/gui_modules/toolbars.py:915
+#: ../gui/wxpython/gui_modules/toolbars.py:862
 msgid "Query features"
 msgstr "Feature abfragen"
-#: ../gui/wxpython/gui_modules/toolbars.py:923
+#: ../gui/wxpython/gui_modules/toolbars.py:870
 msgid "Z bulk-labeling of 3D lines"
 msgstr "Z Massenbeschriftung von 3D Linien"
-#: ../gui/wxpython/gui_modules/toolbars.py:931
+#: ../gui/wxpython/gui_modules/toolbars.py:878
 msgid "Feature type conversion"
 msgstr "Featuretyp-Konvertierungen"
-#: ../gui/wxpython/gui_modules/toolbars.py:1042
+#: ../gui/wxpython/gui_modules/toolbars.py:989
 msgid "Vector map is not 3D. Operation canceled."
 msgstr "Vektorkarte ist nicht 3D. Breche die Operation ab."
-#: ../gui/wxpython/gui_modules/toolbars.py:1107
-#: ../gui/wxpython/gui_modules/toolbars.py:1189
-#: ../gui/wxpython/gui_modules/toolbars.py:1268
+#: ../gui/wxpython/gui_modules/toolbars.py:1053
+#: ../gui/wxpython/gui_modules/toolbars.py:1135
+#: ../gui/wxpython/gui_modules/toolbars.py:1214
 msgid "Select vector map"
 msgstr "Vektorkarte selektieren"
-#: ../gui/wxpython/gui_modules/toolbars.py:1145
+#: ../gui/wxpython/gui_modules/toolbars.py:1091
 #, python-format
 msgid "Please wait, opening vector map <%s> for editing..."
 msgstr "Bitte warten Sie, ich öffne die Vektorkarte <%s> zum Editieren..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1197
+#: ../gui/wxpython/gui_modules/toolbars.py:1143
 #, python-format
 msgid "Do you want to save changes in vector map <%s>?"
 msgstr "Wollen Sie die Änderungen in der Vektorkarte <%s> speichern?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1199
+#: ../gui/wxpython/gui_modules/toolbars.py:1145
 msgid "Save changes?"
 msgstr "Änderungen speichern?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1206
+#: ../gui/wxpython/gui_modules/toolbars.py:1152
 #, python-format
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
 msgstr ""
 "Bitte warten Sie, ich erneuere die Topologie schließe die Vektorkarte <%s>..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1217
+#: ../gui/wxpython/gui_modules/toolbars.py:1163
 #, python-format
 msgid "Editing of vector map <%s> successfully finished"
 msgstr "Bearbeitung der Vektorkarte <%s> erfolgreich abgeschlossen"
-#: ../gui/wxpython/gui_modules/toolbars.py:1274
-#: ../gui/wxpython/gui_modules/toolbars.py:1279
+#: ../gui/wxpython/gui_modules/toolbars.py:1220
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
 msgid "New vector map"
 msgstr "Neue Vektorkarte"
@@ -10517,7 +10626,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1117
-#: ../gui/wxpython/gui_modules/preferences.py:626
+#: ../gui/wxpython/gui_modules/preferences.py:642
 msgid "Edit selected record"
 msgstr "Ausgewählten Datensatz editieren"
@@ -10535,14 +10644,14 @@
 msgstr "Alle Datensätze löschen"
 #: ../gui/wxpython/gui_modules/dbm.py:1129
-#: ../gui/wxpython/gui_modules/gdialogs.py:861
-#: ../gui/wxpython/gui_modules/gdialogs.py:1389
+#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:1390
 msgid "Select all"
 msgstr "Alle selektieren"
 #: ../gui/wxpython/gui_modules/dbm.py:1130
-#: ../gui/wxpython/gui_modules/gdialogs.py:863
-#: ../gui/wxpython/gui_modules/gdialogs.py:1390
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
+#: ../gui/wxpython/gui_modules/gdialogs.py:1391
 msgid "Deselect all"
 msgstr "Alle Selektierungen aufheben"
@@ -10842,7 +10951,7 @@
 msgstr "Erzeuge Attributtabelle"
 #: ../gui/wxpython/gui_modules/gdialogs.py:204
-#: ../gui/wxpython/gui_modules/preferences.py:1553
+#: ../gui/wxpython/gui_modules/preferences.py:1575
 msgid "Add created map into layer tree"
 msgstr "Erzeugte Karte der Baumstruktur hinzufügen"
@@ -10904,8 +11013,8 @@
 msgstr "Rotation:"
 #: ../gui/wxpython/gui_modules/gdialogs.py:631
-#: ../gui/wxpython/gui_modules/preferences.py:1259
-#: ../gui/wxpython/gui_modules/preferences.py:1388
+#: ../gui/wxpython/gui_modules/preferences.py:1263
+#: ../gui/wxpython/gui_modules/preferences.py:1410
 msgid "Set font"
 msgstr "Schrift"
@@ -10917,98 +11026,108 @@
 "Ziehe Sie den Text mit der Maus im Zeiger-Modus in die gewünschte Position.\n"
 "Doppelklick ändert die Einstellung."
-#: ../gui/wxpython/gui_modules/gdialogs.py:768
+#: ../gui/wxpython/gui_modules/gdialogs.py:739
+#, fuzzy
+msgid "&Add"
+msgstr "Hinzufügen"
+#: ../gui/wxpython/gui_modules/gdialogs.py:741
+#, fuzzy
+msgid "Add selected map layers to current display"
+msgstr "Rasterkartenlayer zur aktuellen Kartenanzeige hinzufügen"
+#: ../gui/wxpython/gui_modules/gdialogs.py:769
 msgid "Map layer type:"
 msgstr "Typ der Kartenebene:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:780
+#: ../gui/wxpython/gui_modules/gdialogs.py:781
 #, fuzzy
 msgid "Select toggle"
 msgstr "Wähle umschalten"
-#: ../gui/wxpython/gui_modules/gdialogs.py:787
+#: ../gui/wxpython/gui_modules/gdialogs.py:788
 msgid "Mapset:"
 msgstr "Mapset:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:797
+#: ../gui/wxpython/gui_modules/gdialogs.py:798
 msgid "Filter:"
 msgstr "Filter:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
 msgid "List of maps:"
 msgstr "Liste der Karten:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:863
 msgid "Invert selection"
 msgstr "Invertiere Auswahl"
-#: ../gui/wxpython/gui_modules/gdialogs.py:936
+#: ../gui/wxpython/gui_modules/gdialogs.py:937
 msgid "Multiple import"
 msgstr "Mehrfach-Import"
-#: ../gui/wxpython/gui_modules/gdialogs.py:950
+#: ../gui/wxpython/gui_modules/gdialogs.py:951
 #, python-format
 msgid " List of %s layers "
 msgstr " Liste der %s Ebenen"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1151
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
 msgid "Add linked layers into layer tree"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1158
+#: ../gui/wxpython/gui_modules/gdialogs.py:1159
 msgid "&Link"
 msgstr "&Link"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1159
+#: ../gui/wxpython/gui_modules/gdialogs.py:1160
 msgid "Link selected layers"
 msgstr "Binde ausgewählte Ebenen ein"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1253
+#: ../gui/wxpython/gui_modules/gdialogs.py:1254
 msgid "Import DXF layers"
 msgstr "Importiere DXF-Layer"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1257
+#: ../gui/wxpython/gui_modules/gdialogs.py:1258
 msgid "Choose DXF file to import"
 msgstr "Wählen Sie zu importierende DXF-Datei"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1353
+#: ../gui/wxpython/gui_modules/gdialogs.py:1354
 msgid "Layer name"
 msgstr "Name der Ebene"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1354
+#: ../gui/wxpython/gui_modules/gdialogs.py:1355
 msgid "Name for GRASS map"
 msgstr "Name für GRASS Karte"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1436
+#: ../gui/wxpython/gui_modules/gdialogs.py:1437
 msgid "Set Map Layer Opacity"
 msgstr "Bestimme die Deckkraft der Kartenebene"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1460
+#: ../gui/wxpython/gui_modules/gdialogs.py:1461
 msgid "transparent"
 msgstr "transparent"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1463
+#: ../gui/wxpython/gui_modules/gdialogs.py:1464
 msgid "opaque"
 msgstr "deckend"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1582
+#: ../gui/wxpython/gui_modules/gdialogs.py:1583
 msgid "Set image size"
 msgstr "Setze Bildgröße"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1591
+#: ../gui/wxpython/gui_modules/gdialogs.py:1592
 msgid "Image size"
 msgstr "Bildgröße"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1638
+#: ../gui/wxpython/gui_modules/gdialogs.py:1639
 msgid "Template:"
 msgstr "Vorlage:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1676
+#: ../gui/wxpython/gui_modules/gdialogs.py:1677
 #, fuzzy
 msgid "GRASS GIS SQL Query Utility"
 msgstr "GRASS GIS - Kartenfenster"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1687
+#: ../gui/wxpython/gui_modules/gdialogs.py:1688
 #, fuzzy
 msgid " SQL statement "
 msgstr "SQL-Ausdruck"
@@ -11302,56 +11421,56 @@
 msgstr "Ebenen-Gruppe:"
 #: ../gui/wxpython/gui_modules/layertree.py:743
-#: ../gui/wxpython/gui_modules/layertree.py:1310
+#: ../gui/wxpython/gui_modules/layertree.py:1309
 msgid "Click to edit layer settings"
 msgstr "Klicke um Ebenen-Einstellungen zu ändern."
-#: ../gui/wxpython/gui_modules/layertree.py:788
+#: ../gui/wxpython/gui_modules/layertree.py:784
 msgid "(double click to set properties)"
 msgstr "(Doppelklick um Eigenschaften zu definieren)"
-#: ../gui/wxpython/gui_modules/layertree.py:794
+#: ../gui/wxpython/gui_modules/layertree.py:790
 msgid "3d raster"
 msgstr "3D Raster"
-#: ../gui/wxpython/gui_modules/layertree.py:797
+#: ../gui/wxpython/gui_modules/layertree.py:793
 msgid "RGB"
 msgstr "RGB"
-#: ../gui/wxpython/gui_modules/layertree.py:800
+#: ../gui/wxpython/gui_modules/layertree.py:796
 msgid "HIS"
 msgstr "HIS"
-#: ../gui/wxpython/gui_modules/layertree.py:806
+#: ../gui/wxpython/gui_modules/layertree.py:802
 msgid "raster cell numbers"
 msgstr "Rasternummern"
-#: ../gui/wxpython/gui_modules/layertree.py:809
+#: ../gui/wxpython/gui_modules/layertree.py:805
 msgid "raster flow arrows"
 msgstr "Raster Vektoren"
-#: ../gui/wxpython/gui_modules/layertree.py:815
+#: ../gui/wxpython/gui_modules/layertree.py:811
 #, fuzzy
 msgid "thematic area (choropleth) map"
 msgstr "Zeigt thematische Vektorkarten an."
-#: ../gui/wxpython/gui_modules/layertree.py:818
+#: ../gui/wxpython/gui_modules/layertree.py:814
 msgid "thematic charts"
 msgstr "thematische Diagramme"
-#: ../gui/wxpython/gui_modules/layertree.py:821
+#: ../gui/wxpython/gui_modules/layertree.py:817
 msgid "grid"
 msgstr "Gitternetz"
-#: ../gui/wxpython/gui_modules/layertree.py:824
+#: ../gui/wxpython/gui_modules/layertree.py:820
 msgid "geodesic line"
 msgstr "geodätische Linie"
-#: ../gui/wxpython/gui_modules/layertree.py:827
+#: ../gui/wxpython/gui_modules/layertree.py:823
 msgid "rhumbline"
 msgstr "Rhumblinie"
-#: ../gui/wxpython/gui_modules/layertree.py:830
+#: ../gui/wxpython/gui_modules/layertree.py:826
 msgid "vector labels"
 msgstr "Vektorbeschriftung"
@@ -11359,68 +11478,68 @@
 msgid "Please wait, updating data..."
 msgstr "Bitte warten Sie, ich aktualisiere Daten..."
-#: ../gui/wxpython/gui_modules/layertree.py:1389
+#: ../gui/wxpython/gui_modules/layertree.py:1388
 msgid "opacity:"
 msgstr "Deckkraft"
-#: ../gui/wxpython/gui_modules/layertree.py:1406
+#: ../gui/wxpython/gui_modules/layertree.py:1405
 #, python-format
 msgid "Map <%s> not found."
 msgstr "Karte <%s> nicht gefunden"
-#: ../gui/wxpython/gui_modules/menuform.py:147
-#: ../gui/wxpython/gui_modules/menuform.py:1654
+#: ../gui/wxpython/gui_modules/menuform.py:148
+#: ../gui/wxpython/gui_modules/menuform.py:1647
 msgid "Select Color"
 msgstr "Wählen Sie eine Farbe"
-#: ../gui/wxpython/gui_modules/menuform.py:451
+#: ../gui/wxpython/gui_modules/menuform.py:452
 #, python-format
 msgid "Parameter element '%(element)s' not found: '%(value)s'"
 msgstr "Parameter-Element '%(element)s' nicht gefunden: '%(value)s'"
-#: ../gui/wxpython/gui_modules/menuform.py:472
+#: ../gui/wxpython/gui_modules/menuform.py:473
 #, python-format
 msgid "Flag not found: %s"
 msgstr "Schalter nicht gefunden: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:501
+#: ../gui/wxpython/gui_modules/menuform.py:502
 #, python-format
 msgid "Parameter '%(name)s' (%(desc)s) is missing."
 msgstr "Parameter %(name)s (%(desc)s) fehlt."
-#: ../gui/wxpython/gui_modules/menuform.py:530
+#: ../gui/wxpython/gui_modules/menuform.py:531
 msgid "<required>"
 msgstr "<erfordert>"
-#: ../gui/wxpython/gui_modules/menuform.py:797
+#: ../gui/wxpython/gui_modules/menuform.py:798
 msgid "Enter parameters for '"
 msgstr "Geben Sie Parameter an für '"
-#: ../gui/wxpython/gui_modules/menuform.py:808
+#: ../gui/wxpython/gui_modules/menuform.py:809
 msgid "Close this window without executing the command (Ctrl+Q)"
 msgstr "Schließe dieses Fenster ohne den Befehl auszuführen (Ctrl+Q)"
-#: ../gui/wxpython/gui_modules/menuform.py:828
+#: ../gui/wxpython/gui_modules/menuform.py:829
 msgid "Run the command (Ctrl+R)"
 msgstr "Führe den Befehl aus (Ctrl+R)"
-#: ../gui/wxpython/gui_modules/menuform.py:831
+#: ../gui/wxpython/gui_modules/menuform.py:832
 msgid "C&opy"
 msgstr "&Kopieren"
-#: ../gui/wxpython/gui_modules/menuform.py:846
+#: ../gui/wxpython/gui_modules/menuform.py:847
 msgid "Show manual page of the command (Ctrl+H)"
 msgstr "Zeige die Handbuchseite des Befehls an (Ctrl+H)"
-#: ../gui/wxpython/gui_modules/menuform.py:867
+#: ../gui/wxpython/gui_modules/menuform.py:868
 msgid "Add created map(s) into layer tree"
 msgstr "Erzeugte Karte(n) der Baumstruktur hinzufügen"
-#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:883
 msgid "Close dialog on finish"
 msgstr "Schließe den Dialog beim Beenden"
-#: ../gui/wxpython/gui_modules/menuform.py:884
+#: ../gui/wxpython/gui_modules/menuform.py:885
 msgid ""
 "Close dialog when command is successfully finished. Change this settings in "
 "Preferences dialog ('Command' tab)."
@@ -11428,88 +11547,88 @@
 "Schließe Dialog wenn Befehl erfolgreich ausgeführt. Ändere Einstellungen in "
 "Preferences-Dialog ('Command' tab)."
-#: ../gui/wxpython/gui_modules/menuform.py:1059
+#: ../gui/wxpython/gui_modules/menuform.py:1060
 #, python-format
 msgid "'%s' copied to clipboard"
 msgstr "'%s' in die Zwischenablage kopiert"
-#: ../gui/wxpython/gui_modules/menuform.py:1121
-#: ../gui/wxpython/gui_modules/menuform.py:1134
+#: ../gui/wxpython/gui_modules/menuform.py:1122
+#: ../gui/wxpython/gui_modules/menuform.py:1135
 msgid "Required"
 msgstr "Erfordert"
-#: ../gui/wxpython/gui_modules/menuform.py:1124
+#: ../gui/wxpython/gui_modules/menuform.py:1125
 msgid "Optional"
 msgstr "Optional"
-#: ../gui/wxpython/gui_modules/menuform.py:1174
+#: ../gui/wxpython/gui_modules/menuform.py:1168
 msgid "Manual"
 msgstr "Handbuch"
-#: ../gui/wxpython/gui_modules/menuform.py:1215
-#: ../gui/wxpython/gui_modules/menuform.py:1726
+#: ../gui/wxpython/gui_modules/menuform.py:1208
+#: ../gui/wxpython/gui_modules/menuform.py:1719
 msgid "Parameterized in model"
 msgstr "Parametrisiert im Modell"
-#: ../gui/wxpython/gui_modules/menuform.py:1290
+#: ../gui/wxpython/gui_modules/menuform.py:1283
 msgid "[multiple]"
 msgstr "[mehrere]"
-#: ../gui/wxpython/gui_modules/menuform.py:1337
+#: ../gui/wxpython/gui_modules/menuform.py:1330
 msgid "valid range"
 msgstr "gültiger Wertebereich"
-#: ../gui/wxpython/gui_modules/menuform.py:1499
+#: ../gui/wxpython/gui_modules/menuform.py:1492
 msgid "Format"
 msgstr "Format"
-#: ../gui/wxpython/gui_modules/menuform.py:1501
+#: ../gui/wxpython/gui_modules/menuform.py:1494
 msgid "Native / Linked OGR"
 msgstr ""
 #, fuzzy
 msgid "Direct OGR"
 msgstr "Richtung"
-#: ../gui/wxpython/gui_modules/menuform.py:1673
+#: ../gui/wxpython/gui_modules/menuform.py:1666
 msgid "Transparent"
 msgstr "Transparent"
-#: ../gui/wxpython/gui_modules/menuform.py:1689
+#: ../gui/wxpython/gui_modules/menuform.py:1682
 #, python-format
 msgid "Choose %s"
 msgstr "Wählen Sie %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1717
+#: ../gui/wxpython/gui_modules/menuform.py:1710
 msgid "or enter values interactively"
 msgstr "oder gebe Werte interaktiv ein"
-#: ../gui/wxpython/gui_modules/menuform.py:2133
+#: ../gui/wxpython/gui_modules/menuform.py:2126
 #, python-format
 msgid "Error in %s"
 msgstr "Fehler in %s"
-#: ../gui/wxpython/gui_modules/menuform.py:2166
-#: ../gui/wxpython/gui_modules/menuform.py:2169
+#: ../gui/wxpython/gui_modules/menuform.py:2159
+#: ../gui/wxpython/gui_modules/menuform.py:2162
 #, fuzzy, python-format
 msgid "Unable to fetch interface description for command '%s'."
 msgstr ""
 "Kann die Interface-Beschreibung für den Befehl '%s' nicht ermitteln. "
 "Details: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:2280
+#: ../gui/wxpython/gui_modules/menuform.py:2276
 #, python-format
 msgid "Unable to parse command '%s'"
 msgstr "Kann den Befehl '%s' nicht parsen"
-#: ../gui/wxpython/gui_modules/menuform.py:2284
+#: ../gui/wxpython/gui_modules/menuform.py:2280
 #, python-format
 msgid "%(cmd)s: parameter '%(key)s' not available"
 msgstr "%(cmd)s: Parameter '%(key)s' nicht vorhanden"
-#: ../gui/wxpython/gui_modules/menuform.py:2409
+#: ../gui/wxpython/gui_modules/menuform.py:2441
 #, python-format
 msgid "usage: %s <grass command>"
 msgstr "Verwendung: %s <GRASS Befehl>"
@@ -11519,115 +11638,115 @@
 msgstr "Gehe zu"
 #: ../gui/wxpython/gui_modules/globalvar.py:119
-#: ../gui/wxpython/gui_modules/preferences.py:1798
+#: ../gui/wxpython/gui_modules/preferences.py:1820
 msgid "Projection"
 msgstr "Projektion"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:269
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
 msgid "Easting"
 msgstr "Ostwert"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:270
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:290
 msgid "Northing"
 msgstr "Nordwert"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:271
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:291
 msgid "Elevation"
 msgstr "Höhe"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:272
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:292
 msgid "Surface map elevation"
 msgstr "Rasteroberflächenhöhe"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:273
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:293
 msgid "Surface map color"
 msgstr "Rasteroberflächenfarbe"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:282
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:302
 #, fuzzy
 msgid "XY distance from previous"
 msgstr "XY-Distanz von vorhergehenden Punkt"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:283
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:303
 #, fuzzy
 msgid "XYZ distance from previous"
 msgstr "XYZ-Distanz von vorhergehenden Punkt"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:284
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:304
 msgid "Distance along surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:309
 msgid "Distance along exag. surface"
 msgstr "Distanz entlang überhöhter Oberfläche"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:296
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:316
 msgid "No point on surface"
 msgstr "Kein Punkt auf der Oberfläche"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:301
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:321
 msgid "Function not implemented yet"
 msgstr "Funktion  noch nicht implementiert"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:602
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:639
 msgid "Loading raster map"
 msgstr "Lade Rasterkarte"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:606
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:643
 msgid "Loading 3d raster map"
 msgstr "Lade 3D Rasterkarte"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:612
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:649
 msgid "failed"
 msgstr "fehlgeschlagen"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:614
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:651
 #, python-format
 msgid "Unsupported layer type '%s'"
 msgstr "Nicht unterstützter Layertyp '%s'"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:668
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:729
 msgid "Unable to unload raster map"
 msgstr "Kann Rasterkarte nicht entfernen"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:673
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:734
 msgid "Unable to unload 3d raster map"
 msgstr "Kann 3D Rasterkarte nicht entfernen"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:674
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:735
 msgid "3d raster map"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:681
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:742
 msgid "unloaded successfully"
 msgstr "erfolgreich entfernt"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:725
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:786
 #, python-format
 msgid "Loading vector map <%(name)s> (%(type)s) failed"
 msgstr "Laden der Vektorkarte <%(name)s> (%(type)s) fehlgeschlagen"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:781
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:842
 #, python-format
 msgid "Unable to unload vector map <%(name)s> (%(type)s)"
 msgstr "Kann die Vektorkarte <%(name)s> (%(type)s) nicht entfernen"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:784
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:845
 #, python-format
 msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
 msgstr "Vektorkarte <%(name)s> (%(type)s) erfolgreich entfernt"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1071
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1148
 #, python-format
 msgid "Vector point layer not found (id = %d)"
 msgstr "Vektor-Punktebene nicht gefunden (id=%d)"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1073
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1150
 #, python-format
 msgid "Unable to set data layer properties (id = %d)"
 msgstr "Kann die Eigenschaften der Datenebene (id=%d) nicht setzen."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1076
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1153
 #, python-format
 msgid ""
 "Setting data layer properties failed.\n"
@@ -11638,103 +11757,108 @@
 "\n"
 "%s"
-#: ../gui/wxpython/gui_modules/preferences.py:416
+#: ../gui/wxpython/gui_modules/preferences.py:427
 msgid "Segment break"
 msgstr "Segment break"
-#: ../gui/wxpython/gui_modules/preferences.py:621
+#: ../gui/wxpython/gui_modules/preferences.py:637
 msgid "Collapse all except PERMANENT and current"
 msgstr "Alle einklappen außer PERMANENT und Aktuelles"
-#: ../gui/wxpython/gui_modules/preferences.py:622
+#: ../gui/wxpython/gui_modules/preferences.py:638
 msgid "Collapse all except PERMANENT"
 msgstr "Alle einklappen außer PERMANENT"
-#: ../gui/wxpython/gui_modules/preferences.py:623
+#: ../gui/wxpython/gui_modules/preferences.py:639
 msgid "Collapse all except current"
 msgstr "Alle einklappen außer Aktuelles"
-#: ../gui/wxpython/gui_modules/preferences.py:624
+#: ../gui/wxpython/gui_modules/preferences.py:640
 msgid "Collapse all"
 msgstr "Alle einklappen"
-#: ../gui/wxpython/gui_modules/preferences.py:625
+#: ../gui/wxpython/gui_modules/preferences.py:641
 msgid "Expand all"
 msgstr "Alle ausklappen"
-#: ../gui/wxpython/gui_modules/preferences.py:627
+#: ../gui/wxpython/gui_modules/preferences.py:643
 msgid "Display selected"
 msgstr "Ausgewählten anzeigen"
-#: ../gui/wxpython/gui_modules/preferences.py:635
+#: ../gui/wxpython/gui_modules/preferences.py:651
 msgid "Classic (labels only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:636
+#: ../gui/wxpython/gui_modules/preferences.py:652
 msgid "Combined (labels and module names)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:637
+#: ../gui/wxpython/gui_modules/preferences.py:653
 msgid "Professional (module names only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:657
+#: ../gui/wxpython/gui_modules/preferences.py:673
 msgid "box"
 msgstr "Box"
-#: ../gui/wxpython/gui_modules/preferences.py:658
+#: ../gui/wxpython/gui_modules/preferences.py:674
 msgid "sphere"
 msgstr "Kugel"
-#: ../gui/wxpython/gui_modules/preferences.py:659
+#: ../gui/wxpython/gui_modules/preferences.py:675
 msgid "cube"
 msgstr "Würfel"
-#: ../gui/wxpython/gui_modules/preferences.py:660
+#: ../gui/wxpython/gui_modules/preferences.py:676
 msgid "diamond"
 msgstr "Raute"
-#: ../gui/wxpython/gui_modules/preferences.py:661
+#: ../gui/wxpython/gui_modules/preferences.py:677
 msgid "dtree"
 msgstr "dtree"
-#: ../gui/wxpython/gui_modules/preferences.py:662
+#: ../gui/wxpython/gui_modules/preferences.py:678
 msgid "ctree"
 msgstr "ctree"
-#: ../gui/wxpython/gui_modules/preferences.py:663
+#: ../gui/wxpython/gui_modules/preferences.py:679
 msgid "aster"
 msgstr "Stern"
-#: ../gui/wxpython/gui_modules/preferences.py:664
+#: ../gui/wxpython/gui_modules/preferences.py:680
 msgid "gyro"
 msgstr "Kreisel"
-#: ../gui/wxpython/gui_modules/preferences.py:665
+#: ../gui/wxpython/gui_modules/preferences.py:681
 msgid "histogram"
 msgstr "Histogramm"
-#: ../gui/wxpython/gui_modules/preferences.py:727
-#, python-format
+#: ../gui/wxpython/gui_modules/preferences.py:713
+#, fuzzy, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr "Kann die Einstellungen '%s' nicht parsen."
+#: ../gui/wxpython/gui_modules/preferences.py:737
 msgid ""
 "Error: Reading settings from file <%(file)s> failed.\n"
-"       Details: %(detail)s\n"
-"       Line: '%(line)s'"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
 msgstr ""
 "Fehler: Das Lesen der Einstellungen aus der Datei <%(file)s> ist "
 "fehlgeschlagen.\n"
 "           Einzelheiten: %(detail)s\n"
 "           Zeile: '%(line)s'"
-#: ../gui/wxpython/gui_modules/preferences.py:750
+#: ../gui/wxpython/gui_modules/preferences.py:758
 msgid "Cannot create directory for settings [home]/.grass7"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:751
+#: ../gui/wxpython/gui_modules/preferences.py:759
 msgid "Error saving preferences"
 msgstr "Fehler beim Speichern der Einstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:787
+#: ../gui/wxpython/gui_modules/preferences.py:794
 #, python-format
 msgid ""
 "Writing settings to file <%(file)s> failed.\n"
@@ -11745,115 +11869,121 @@
 "\n"
 "Einzelheiten: %(detail)s"
-#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/gui_modules/preferences.py:893
 msgid "Unable to set "
 msgstr "Kann nicht setzen"
-#: ../gui/wxpython/gui_modules/preferences.py:914
-#: ../gui/wxpython/gui_modules/preferences.py:920
+#: ../gui/wxpython/gui_modules/preferences.py:919
+#: ../gui/wxpython/gui_modules/preferences.py:925
 #, python-format
 msgid "Unable to parse settings '%s'"
-#: ../gui/wxpython/gui_modules/preferences.py:931
+#: ../gui/wxpython/gui_modules/preferences.py:936
 msgid "User settings"
 msgstr "Benutzereinstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:951
+#: ../gui/wxpython/gui_modules/preferences.py:956
 msgid "Set to default"
 msgstr "Auf Standardwerte setzten"
-#: ../gui/wxpython/gui_modules/preferences.py:959
+#: ../gui/wxpython/gui_modules/preferences.py:964
 msgid "Revert settings to default and apply changes"
 msgstr "Kehre zu den Standardeinstellungen zurück und wende die Änderungen an"
-#: ../gui/wxpython/gui_modules/preferences.py:1021
+#: ../gui/wxpython/gui_modules/preferences.py:1026
 msgid "Settings applied to current session but not saved"
 msgstr "Einstellungen bei aktueller Session angewendet, aber nicht gespeichert"
-#: ../gui/wxpython/gui_modules/preferences.py:1039
+#: ../gui/wxpython/gui_modules/preferences.py:1044
 #, python-format
 msgid "Settings saved to file '%s'."
 msgstr "Einstellungen in der Datei '%s' gespeichert."
-#: ../gui/wxpython/gui_modules/preferences.py:1070
+#: ../gui/wxpython/gui_modules/preferences.py:1075
 msgid "Key column cannot be empty string."
 msgstr "Die Schlüsselspalte kann kein leerer Zeichenkette sein."
-#: ../gui/wxpython/gui_modules/preferences.py:1084
+#: ../gui/wxpython/gui_modules/preferences.py:1089
 #, fuzzy
 msgid "GUI Settings"
 msgstr "GUI-Benutzereinstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:1107
-msgid "General settings"
-msgstr "Allgemeine Einstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:1118
-msgid "Element list:"
-msgstr "Liste der Elemente:"
-#: ../gui/wxpython/gui_modules/preferences.py:1140
-msgid "Save current window layout as default"
-msgstr "Speichere das aktuelle Fensterlayout als Standard"
-#: ../gui/wxpython/gui_modules/preferences.py:1143
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Speichere die aktuelle Position und Größe des 'Layer Manager'-Fensters und "
-"der geöffneten Kartenfenster. Diese Werte werden als Standard für die "
-"nächste Sitzung verwendet."
-#: ../gui/wxpython/gui_modules/preferences.py:1156
+#: ../gui/wxpython/gui_modules/preferences.py:1115
 msgid "Layer Manager settings"
 msgstr "Einstellungen des Layer Manager"
-#: ../gui/wxpython/gui_modules/preferences.py:1167
+#: ../gui/wxpython/gui_modules/preferences.py:1126
 msgid "Ask when removing map layer from layer tree"
 msgstr "Frage vor dem Entfernen einer Kartenebenen aus der Baumstruktur"
-#: ../gui/wxpython/gui_modules/preferences.py:1177
+#: ../gui/wxpython/gui_modules/preferences.py:1136
 msgid "Ask when quiting wxGUI or closing display"
 msgstr "Frage vor dem Schließen des wxGUIs oder eines Fensters."
-#: ../gui/wxpython/gui_modules/preferences.py:1191
+#: ../gui/wxpython/gui_modules/preferences.py:1146
+#: ../gui/wxpython/gui_modules/preferences.py:1156
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1169
+msgid "Automatically copy selected text to clipboard (in Command console)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1183
 #, fuzzy
 msgid "Workspace settings"
 msgstr "Aktualisiere Einstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:1199
+#: ../gui/wxpython/gui_modules/preferences.py:1191
 msgid "Suppress positioning Map Display Window(s)"
 msgstr "Positionieren der Kartenfenster unterdrücken"
-#: ../gui/wxpython/gui_modules/preferences.py:1211
+#: ../gui/wxpython/gui_modules/preferences.py:1203
 msgid "Suppress positioning Layer Manager window"
 msgstr "Positionieren des Layer Managers unterdrücken"
-#: ../gui/wxpython/gui_modules/preferences.py:1254
+#: ../gui/wxpython/gui_modules/preferences.py:1214
+msgid "Save current window layout as default"
+msgstr "Speichere das aktuelle Fensterlayout als Standard"
+#: ../gui/wxpython/gui_modules/preferences.py:1217
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+"Speichere die aktuelle Position und Größe des 'Layer Manager'-Fensters und "
+"der geöffneten Kartenfenster. Diese Werte werden als Standard für die "
+"nächste Sitzung verwendet."
+#: ../gui/wxpython/gui_modules/preferences.py:1258
 msgid "Font for command output:"
 msgstr "Schirftart für Befehlsausgabe"
-#: ../gui/wxpython/gui_modules/preferences.py:1268
+#: ../gui/wxpython/gui_modules/preferences.py:1272
 #, fuzzy
 msgid "Appearance settings"
 msgstr "Fortgeschrittene Einstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:1280
+#: ../gui/wxpython/gui_modules/preferences.py:1283
+msgid "Element list:"
+msgstr "Liste der Elemente:"
+#: ../gui/wxpython/gui_modules/preferences.py:1302
 #, fuzzy
 msgid "Menu style:"
 msgstr "Menue-Baum"
-#: ../gui/wxpython/gui_modules/preferences.py:1304
+#: ../gui/wxpython/gui_modules/preferences.py:1326
 msgid "Height of map selection popup window (in pixels):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1328
+#: ../gui/wxpython/gui_modules/preferences.py:1350
 msgid "Icon theme:"
 msgstr "Symbol-Design:"
-#: ../gui/wxpython/gui_modules/preferences.py:1346
+#: ../gui/wxpython/gui_modules/preferences.py:1368
 msgid ""
 "Note: For changing the icon theme, you must save the settings and restart "
 "this GUI."
@@ -11861,116 +11991,116 @@
 "Hinweis: Um das Symbol-Design zu ändern müssen die Einstellungen gespeichert "
 "werden und das GUI erneut gestartet werden."
-#: ../gui/wxpython/gui_modules/preferences.py:1368
+#: ../gui/wxpython/gui_modules/preferences.py:1390
 #, fuzzy
 msgid "Map Display"
 msgstr "Kartenanzeige"
-#: ../gui/wxpython/gui_modules/preferences.py:1383
+#: ../gui/wxpython/gui_modules/preferences.py:1405
 msgid "Default font for GRASS displays:"
 msgstr "Standard Schrift für GRASS Fenster:"
-#: ../gui/wxpython/gui_modules/preferences.py:1400
+#: ../gui/wxpython/gui_modules/preferences.py:1422
 msgid "Default display settings"
 msgstr "Standard Fenstereinstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:1412
+#: ../gui/wxpython/gui_modules/preferences.py:1434
 msgid "Display driver:"
 msgstr "Treiber für die Darstellung im Fenster:"
-#: ../gui/wxpython/gui_modules/preferences.py:1432
+#: ../gui/wxpython/gui_modules/preferences.py:1454
 msgid "Statusbar mode:"
 msgstr "Modus der Statuszeile:"
-#: ../gui/wxpython/gui_modules/preferences.py:1484
+#: ../gui/wxpython/gui_modules/preferences.py:1506
 msgid "Enable auto-rendering"
 msgstr "Auto-Rendering einschalten"
-#: ../gui/wxpython/gui_modules/preferences.py:1497
+#: ../gui/wxpython/gui_modules/preferences.py:1519
 msgid "Enable auto-zooming to selected map layer"
 msgstr "Aktiviere Auto-Zooming auf selektierte Kartenlayer"
-#: ../gui/wxpython/gui_modules/preferences.py:1521
+#: ../gui/wxpython/gui_modules/preferences.py:1543
 msgid "Command dialog settings"
 msgstr "Einstellungen für die Befehle"
-#: ../gui/wxpython/gui_modules/preferences.py:1543
+#: ../gui/wxpython/gui_modules/preferences.py:1565
 msgid "Close dialog when command is successfully finished"
 msgstr "Schließe Dialog, wenn Befehl erfolgreich ausgeführt"
-#: ../gui/wxpython/gui_modules/preferences.py:1564
+#: ../gui/wxpython/gui_modules/preferences.py:1586
 msgid "Allow interactive input"
 msgstr "Erlaube interaktive Eingabe"
-#: ../gui/wxpython/gui_modules/preferences.py:1574
+#: ../gui/wxpython/gui_modules/preferences.py:1596
 msgid "Verbosity level:"
 msgstr "Gesprächigkeitsstufe:"
-#: ../gui/wxpython/gui_modules/preferences.py:1593
+#: ../gui/wxpython/gui_modules/preferences.py:1615
 msgid "Raster settings"
 msgstr "Raster Einstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:1604
+#: ../gui/wxpython/gui_modules/preferences.py:1626
 msgid "Make null cells opaque"
 msgstr "Mache NULL-Zellen transparent"
-#: ../gui/wxpython/gui_modules/preferences.py:1615
+#: ../gui/wxpython/gui_modules/preferences.py:1637
 msgid "Default color table"
 msgstr "Standard-Farbtabelle"
-#: ../gui/wxpython/gui_modules/preferences.py:1641
+#: ../gui/wxpython/gui_modules/preferences.py:1663
 msgid "Vector settings"
 msgstr "Vektor Einstellungen"
-#: ../gui/wxpython/gui_modules/preferences.py:1647
+#: ../gui/wxpython/gui_modules/preferences.py:1669
 msgid "Display:"
 msgstr "Fenster:"
-#: ../gui/wxpython/gui_modules/preferences.py:1677
+#: ../gui/wxpython/gui_modules/preferences.py:1699
 msgid "Highlighting"
 msgstr "Highlighting"
-#: ../gui/wxpython/gui_modules/preferences.py:1693
+#: ../gui/wxpython/gui_modules/preferences.py:1715
 msgid "Line width (in pixels):"
 msgstr "Liniebreite (in Pixel):"
-#: ../gui/wxpython/gui_modules/preferences.py:1716
+#: ../gui/wxpython/gui_modules/preferences.py:1738
 msgid "Data browser"
 msgstr "Daten-Browser"
-#: ../gui/wxpython/gui_modules/preferences.py:1721
+#: ../gui/wxpython/gui_modules/preferences.py:1743
 msgid "Left mouse double click:"
 msgstr "Doppelklick mit linker Maustaste:"
-#: ../gui/wxpython/gui_modules/preferences.py:1733
+#: ../gui/wxpython/gui_modules/preferences.py:1755
 msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
 msgstr "Encoding (z.B. utf-8, ascii, iso8859-1, koi8-r):"
-#: ../gui/wxpython/gui_modules/preferences.py:1744
+#: ../gui/wxpython/gui_modules/preferences.py:1766
 msgid "Ask when deleting data record(s) from table"
 msgstr "Frage vor dem Löschen von Datensätzen aus einer Tabelle"
-#: ../gui/wxpython/gui_modules/preferences.py:1765
+#: ../gui/wxpython/gui_modules/preferences.py:1787
 msgid "Create table"
 msgstr "Erzeuge Tabelle"
-#: ../gui/wxpython/gui_modules/preferences.py:1772
+#: ../gui/wxpython/gui_modules/preferences.py:1794
 msgid "Key column:"
 msgstr "Schlüsselspalte:"
-#: ../gui/wxpython/gui_modules/preferences.py:1805
+#: ../gui/wxpython/gui_modules/preferences.py:1827
 msgid "Projection statusbar settings"
 msgstr "Einstellungen für Projektions-Statusleiste"
-#: ../gui/wxpython/gui_modules/preferences.py:1831
+#: ../gui/wxpython/gui_modules/preferences.py:1853
 msgid "Proj.4 string (required):"
 msgstr "Proj.4 string (erforderlich):"
-#: ../gui/wxpython/gui_modules/preferences.py:1847
+#: ../gui/wxpython/gui_modules/preferences.py:1869
 msgid "EPSG file:"
 msgstr "EPSG Datei:"
-#: ../gui/wxpython/gui_modules/preferences.py:1862
+#: ../gui/wxpython/gui_modules/preferences.py:1884
 msgid ""
 "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
 "directly."
@@ -11978,55 +12108,55 @@
 "Lade EPSG-Codes. Eingabe des EPSG-Code oder direkte Eingabe des Proj.4-"
 "String."
-#: ../gui/wxpython/gui_modules/preferences.py:1870
+#: ../gui/wxpython/gui_modules/preferences.py:1892
 msgid "&Load EPSG codes"
 msgstr "&Lade EPSG Codes"
-#: ../gui/wxpython/gui_modules/preferences.py:1881
+#: ../gui/wxpython/gui_modules/preferences.py:1903
 msgid "Coordinates format"
 msgstr "Koordinatenformat"
-#: ../gui/wxpython/gui_modules/preferences.py:1890
+#: ../gui/wxpython/gui_modules/preferences.py:1912
 msgid "LL projections"
 msgstr "LL-Projektionen"
-#: ../gui/wxpython/gui_modules/preferences.py:1909
+#: ../gui/wxpython/gui_modules/preferences.py:1931
 msgid "Precision:"
 msgstr "Genauigkeit:"
-#: ../gui/wxpython/gui_modules/preferences.py:1947
+#: ../gui/wxpython/gui_modules/preferences.py:1969
 #, python-format
 msgid "Unable to read EPSG codes: %s"
 msgstr "Kann die EPGS codes nicht lesen: %s"
-#: ../gui/wxpython/gui_modules/preferences.py:1976
-#: ../gui/wxpython/gui_modules/preferences.py:1985
-#: ../gui/wxpython/gui_modules/preferences.py:1995
+#: ../gui/wxpython/gui_modules/preferences.py:1998
+#: ../gui/wxpython/gui_modules/preferences.py:2007
+#: ../gui/wxpython/gui_modules/preferences.py:2017
 #, python-format
 msgid "EPSG code %s not found"
 msgstr "EPSG Code <%s> nicht gefunden"
-#: ../gui/wxpython/gui_modules/preferences.py:2003
+#: ../gui/wxpython/gui_modules/preferences.py:2025
 msgid "Select default display font"
 msgstr "Wähle Standard Schrift"
-#: ../gui/wxpython/gui_modules/preferences.py:2028
+#: ../gui/wxpython/gui_modules/preferences.py:2050
 msgid "Select output font"
 msgstr "Aausgabeschrift auswählen"
-#: ../gui/wxpython/gui_modules/preferences.py:2121
+#: ../gui/wxpython/gui_modules/preferences.py:2143
 msgid "Select font:"
 msgstr "Wählen Sie eine Schrift"
-#: ../gui/wxpython/gui_modules/preferences.py:2145
+#: ../gui/wxpython/gui_modules/preferences.py:2167
 msgid "Character encoding:"
 msgstr "Zeichenkodierung:"
-#: ../gui/wxpython/gui_modules/preferences.py:2263
+#: ../gui/wxpython/gui_modules/preferences.py:2285
 msgid "Manage access to mapsets"
 msgstr "Zugangsrechte der Mapsets verwalten"
-#: ../gui/wxpython/gui_modules/preferences.py:2276
+#: ../gui/wxpython/gui_modules/preferences.py:2298
 msgid ""
 "Check a mapset to make it accessible, uncheck it to hide it.\n"
 "  Notes:\n"
@@ -12041,11 +12171,11 @@
 "    - Sie können nur in der selektierten Mapset speichern.\n"
 "    - Sie können nur in den Mapsets schreiben, die Ihnen gehören."
-#: ../gui/wxpython/gui_modules/preferences.py:2350
+#: ../gui/wxpython/gui_modules/preferences.py:2372
 msgid "Mapset"
 msgstr "Mapset"
-#: ../gui/wxpython/gui_modules/preferences.py:2351
+#: ../gui/wxpython/gui_modules/preferences.py:2373
 msgid "Owner"
 msgstr "Eigentümer"
@@ -12331,6 +12461,81 @@
 "Erstellen Sie jetzt eins, wenn Sie es noch nicht getan haben. Eine beliebte "
 "Wahl ist \"grassdata\" im eigenen Heimatverzeichnis."
+#~ msgid "Load map layers into layer tree"
+#~ msgstr "Kartenebenen in Baumstruktur laden"
+#~ msgid "Load map layers into workspace (Ctrl+L)"
+#~ msgstr "Lade Kartenlayer in Workspace (Ctrl+L)"
+#, fuzzy
+#~ msgid "Hardcopy Map Ouput Utility"
+#~ msgstr "Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format."
+#~ msgid "Load map layers"
+#~ msgstr "Lade Kartenebenen"
+#~ msgid "north"
+#~ msgstr "Norden"
+#~ msgid "south"
+#~ msgstr "Süden"
+#~ msgid "east"
+#~ msgstr "Osten"
+#~ msgid "west"
+#~ msgstr "Westen"
+#~ msgid "north-west"
+#~ msgstr "Nordwesten"
+#~ msgid "north-east"
+#~ msgstr "Nordosten"
+#~ msgid "south-east"
+#~ msgstr "Südosten"
+#~ msgid "south-west"
+#~ msgstr "Südwesten"
+#~ msgid "Topography"
+#~ msgstr "Topographie"
+#, fuzzy
+#~ msgid "res."
+#~ msgstr "Auflösung"
+#~ msgid "Fine:"
+#~ msgstr "fein:"
+#~ msgid "Mask zeros:"
+#~ msgstr "Nullen maskieren:"
+#~ msgid "by elevation"
+#~ msgstr "nach Höhenlage"
+#~ msgid "by color"
+#~ msgstr "nach Farbe"
+#~ msgid "display"
+#~ msgstr "Fenster"
+#~ msgid "size"
+#~ msgstr "Größe"
+#~ msgid "symbol"
+#~ msgstr "Symbol"
+#, fuzzy
+#~ msgid "Follow source viewpoint"
+#~ msgstr "Folge Quell-Betrachtungspunkt"
+#~ msgid "Nviz settings saved to file <%s>."
+#~ msgstr "Nviz-Einstellungen in der Datei <%s> gespeichert."
+#~ msgid "General settings"
+#~ msgstr "Allgemeine Einstellungen"
 #~ msgid "Start Graphical Modeler"
 #~ msgstr "Starte Graphical Modeler"
Modified: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasswxpy_el.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -2,13 +2,13 @@
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2008 GRASS Development Team
-#: ../gui/wxpython/gui_modules/psmap.py:1097
+#: ../gui/wxpython/gui_modules/psmap.py:1096
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2211
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_el\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2008-10-01 14:42+0300\n"
 "Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
 "Language-Team: Báóßëåéïò Áíôùíßïõ <grass-translations at lists."
@@ -19,53 +19,67 @@
 "Language: \n"
 "X-Generator: KBabel 1.11.4\n"
-#: ../gui/wxpython/wxgui.py:96
+#: ../gui/wxpython/wxgui.py:97
 msgid "GRASS GIS Layer Manager"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:136
-msgid "Main Toolbar"
+#: ../gui/wxpython/wxgui.py:139
+msgid "Data Toolbar"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:144
+#: ../gui/wxpython/wxgui.py:147
+msgid "Workspace Toolbar"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:155
+msgid "Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:163
 msgid "Tools Toolbar"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:231
+#: ../gui/wxpython/wxgui.py:250
 msgid "Map layers"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:235 ../gui/wxpython/wxgui.py:375
+#: ../gui/wxpython/wxgui.py:254 ../gui/wxpython/wxgui.py:407
 msgid "Command console"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:239
+#: ../gui/wxpython/wxgui.py:260
 msgid "Search module"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:252 ../gui/wxpython/gui_modules/toolbars.py:207
+#: ../gui/wxpython/wxgui.py:267
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:282 ../gui/wxpython/gui_modules/toolbars.py:211
 msgid "3D view"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:296
+#: ../gui/wxpython/wxgui.py:328
 #, python-format
 msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:315
+#: ../gui/wxpython/wxgui.py:347
 msgid "Choose model to run"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:317 ../gui/wxpython/gui_modules/gmodeler.py:802
-#: ../gui/wxpython/gui_modules/gmodeler.py:846
+#: ../gui/wxpython/wxgui.py:349 ../gui/wxpython/gui_modules/gmodeler.py:796
+#: ../gui/wxpython/gui_modules/gmodeler.py:840
 msgid "GRASS Model File (*.gxm)|*.gxm"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:326 ../gui/wxpython/gui_modules/gmodeler.py:1117
+#: ../gui/wxpython/wxgui.py:358 ../gui/wxpython/gui_modules/gmodeler.py:1111
 msgid "Validating model..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:330 ../gui/wxpython/gui_modules/gmodeler.py:919
+#: ../gui/wxpython/wxgui.py:362 ../gui/wxpython/gui_modules/gmodeler.py:913
 #, python-format
 msgid ""
 "Model is not valid. Do you want to run the model anyway?\n"
@@ -73,59 +87,59 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:332 ../gui/wxpython/gui_modules/gmodeler.py:921
+#: ../gui/wxpython/wxgui.py:364 ../gui/wxpython/gui_modules/gmodeler.py:915
 msgid "Run model?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:339 ../gui/wxpython/gui_modules/gmodeler.py:984
+#: ../gui/wxpython/wxgui.py:371 ../gui/wxpython/gui_modules/gmodeler.py:978
 msgid "Running model..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:389 ../gui/wxpython/wxgui.py:1476
+#: ../gui/wxpython/wxgui.py:421 ../gui/wxpython/wxgui.py:1500
 msgid "Do you want to save changes in the workspace?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:391 ../gui/wxpython/wxgui.py:1478
+#: ../gui/wxpython/wxgui.py:423 ../gui/wxpython/wxgui.py:1502
 msgid "Do you want to store current settings to workspace file?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:398
+#: ../gui/wxpython/wxgui.py:430
 #, python-format
 msgid "Close Map Display %d"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:497 ../gui/wxpython/wxgui.py:1159
+#: ../gui/wxpython/wxgui.py:529 ../gui/wxpython/wxgui.py:1155
 msgid "Selected map layer is not vector."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:502
+#: ../gui/wxpython/wxgui.py:534
 msgid "Editing is allowed only for vector maps from the current mapset."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:517
+#: ../gui/wxpython/wxgui.py:549
 msgid "Choose script file to run"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:519
+#: ../gui/wxpython/wxgui.py:551
 msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:530
+#: ../gui/wxpython/wxgui.py:562
 #, python-format
 msgid "Script file '%s' doesn't exist. Operation cancelled."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:534
+#: ../gui/wxpython/wxgui.py:566
 #, python-format
 msgid "Launching script '%s'..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:549
+#: ../gui/wxpython/wxgui.py:581
 #, python-format
 msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:551 ../gui/wxpython/wxgui.py:572
+#: ../gui/wxpython/wxgui.py:583 ../gui/wxpython/wxgui.py:604
 #: ../gui/wxpython/scripts/r.li.setup.py:337
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1686
 #: ../gui/wxpython/gui_modules/mapdisp.py:367
@@ -140,8 +154,8 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:1029
 #: ../gui/wxpython/gui_modules/vdigit.py:1221
 #: ../gui/wxpython/gui_modules/vdigit.py:1247
-#: ../gui/wxpython/gui_modules/gmodeler.py:1438
-#: ../gui/wxpython/gui_modules/workspace.py:984
+#: ../gui/wxpython/gui_modules/gmodeler.py:1432
+#: ../gui/wxpython/gui_modules/workspace.py:991
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5365
 #: ../gui/wxpython/gui_modules/dbm.py:165
 #: ../gui/wxpython/gui_modules/dbm.py:1407
@@ -160,114 +174,114 @@
 #: ../gui/wxpython/gui_modules/profile.py:598
 #: ../gui/wxpython/gui_modules/layertree.py:505
 #: ../gui/wxpython/gui_modules/layertree.py:536
-#: ../gui/wxpython/gui_modules/preferences.py:1071
-#: ../gui/wxpython/gui_modules/preferences.py:1948
-#: ../gui/wxpython/gui_modules/preferences.py:1977
-#: ../gui/wxpython/gui_modules/preferences.py:1986
-#: ../gui/wxpython/gui_modules/preferences.py:1996
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+#: ../gui/wxpython/gui_modules/preferences.py:1970
+#: ../gui/wxpython/gui_modules/preferences.py:1999
+#: ../gui/wxpython/gui_modules/preferences.py:2008
+#: ../gui/wxpython/gui_modules/preferences.py:2018
 #: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:466
 #: ../gui/wxpython/gis_set.py:502 ../gui/wxpython/gis_set.py:568
 #: ../gui/wxpython/gis_set.py:725
 msgid "Error"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:557
+#: ../gui/wxpython/wxgui.py:589
 #, python-format
 msgid ""
 "Current location is <%(loc)s>.\n"
 "Current mapset is <%(mapset)s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:560 ../gui/wxpython/wxgui.py:576
+#: ../gui/wxpython/wxgui.py:592 ../gui/wxpython/wxgui.py:608
 #: ../gui/wxpython/gui_modules/ghelp.py:563
 msgid "Info"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:571
+#: ../gui/wxpython/wxgui.py:603
 #, python-format
 msgid "Unable to switch to mapset <%s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:575
+#: ../gui/wxpython/wxgui.py:607
 #, python-format
 msgid "Current mapset is <%s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:652
+#: ../gui/wxpython/wxgui.py:676
 msgid ""
 "Current workspace is not empty. Do you want to store current settings to "
 "workspace file?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:655
+#: ../gui/wxpython/wxgui.py:679
 msgid "Create new workspace?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:681
+#: ../gui/wxpython/wxgui.py:705
 msgid "Choose workspace file"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:682 ../gui/wxpython/wxgui.py:889
+#: ../gui/wxpython/wxgui.py:706 ../gui/wxpython/wxgui.py:885
 msgid "GRASS Workspace File (*.gxw)|*.gxw"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:717
+#: ../gui/wxpython/wxgui.py:741
 #, python-format
 msgid ""
 "Reading workspace file <%s> failed.\n"
 "Invalid file, unable to parse XML document."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:721 ../gui/wxpython/wxgui.py:830
-#: ../gui/wxpython/wxgui.py:866
+#: ../gui/wxpython/wxgui.py:745 ../gui/wxpython/wxgui.py:862
+#: ../gui/wxpython/wxgui.py:1241
 msgid "Please wait, loading workspace..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:822 ../gui/wxpython/menustrings.py:15
-msgid "Load map layers into layer tree"
-msgstr ""
-#: ../gui/wxpython/wxgui.py:850
+#: ../gui/wxpython/wxgui.py:846
 msgid "Choose GRC file to load"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:851
+#: ../gui/wxpython/wxgui.py:847
 msgid "Old GRASS Workspace File (*.grc)|*.grc"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:888
+#: ../gui/wxpython/wxgui.py:884
 msgid "Choose file to save current workspace"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:903 ../gui/wxpython/wxgui.py:919
+#: ../gui/wxpython/wxgui.py:899 ../gui/wxpython/wxgui.py:915
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:905 ../gui/wxpython/wxgui.py:922
+#: ../gui/wxpython/wxgui.py:901 ../gui/wxpython/wxgui.py:918
 #: ../gui/wxpython/menustrings.py:9
 msgid "Save workspace"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:943
+#: ../gui/wxpython/wxgui.py:939
 msgid "Writing current settings to workspace file failed."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:954 ../gui/wxpython/gui_modules/gmodeler.py:1437
+#: ../gui/wxpython/wxgui.py:950 ../gui/wxpython/gui_modules/gmodeler.py:1431
 #: ../gui/wxpython/gui_modules/profile.py:597
 #, python-format
 msgid "Unable to open file <%s> for writing."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1132
+#: ../gui/wxpython/wxgui.py:1128
 msgid "Nothing to import. No WMS layer selected."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1168
+#: ../gui/wxpython/wxgui.py:1164
 msgid "Please wait, loading attribute data..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1418
+#: ../gui/wxpython/wxgui.py:1233
+msgid "Add selected map layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1442
 #, python-format
 msgid ""
 "Do you want to remove map layer(s)\n"
@@ -275,23 +289,23 @@
 "from layer tree?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1421
+#: ../gui/wxpython/wxgui.py:1445
 msgid "Do you want to remove selected map layer(s) from layer tree?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1425
+#: ../gui/wxpython/wxgui.py:1449
 msgid "Remove map layer"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1485
+#: ../gui/wxpython/wxgui.py:1509
 msgid "Quit GRASS GUI"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1514
+#: ../gui/wxpython/wxgui.py:1538
 msgid "No map layer selected. Operation cancelled."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1515 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
+#: ../gui/wxpython/wxgui.py:1539 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
 #: ../gui/wxpython/gui_modules/ghelp.py:287
 #: ../gui/wxpython/gui_modules/gcmd.py:98
 #: ../gui/wxpython/gui_modules/dbm.py:2056
@@ -300,7 +314,7 @@
 msgid "Message"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1545
+#: ../gui/wxpython/wxgui.py:1569
 msgid "Starting GRASS GUI..."
 msgstr ""
@@ -402,7 +416,7 @@
 msgid "Add scalebar and north arrow"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:438
+#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:440
 msgid "Add legend"
 msgstr ""
@@ -412,7 +426,7 @@
 #: ../gui/wxpython/icons/icon.py:152
 #: ../gui/wxpython/gui_modules/histogram.py:440
-#: ../gui/wxpython/gui_modules/mapdisp.py:1179
+#: ../gui/wxpython/gui_modules/mapdisp.py:1187
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:942
 msgid "Print display"
 msgstr ""
@@ -434,7 +448,7 @@
 msgstr ""
 #: ../gui/wxpython/icons/icon.py:161
-#: ../gui/wxpython/gui_modules/mapdisp.py:1877
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
 msgid "Add text layer"
 msgstr ""
@@ -451,554 +465,558 @@
 msgstr ""
 #: ../gui/wxpython/icons/icon.py:171
-msgid "Load map layers into workspace (Ctrl+L)"
+msgid "Open existing workspace file (Ctrl+O)"
 msgstr ""
 #: ../gui/wxpython/icons/icon.py:173
-msgid "Open existing workspace file (Ctrl+O)"
+msgid "Save current workspace to file (Ctrl+S)"
 msgstr ""
 #: ../gui/wxpython/icons/icon.py:175
-msgid "Save current workspace to file (Ctrl+S)"
+msgid "Add multiple raster or vector map layers (Ctrl+L)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:177 ../gui/wxpython/menustrings.py:29
-#: ../gui/wxpython/gui_modules/gdialogs.py:1146
+#: ../gui/wxpython/icons/icon.py:177
+msgid "Import/link raster or vector data"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_modules/gdialogs.py:1147
 msgid "Import raster data"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/gui_modules/gdialogs.py:1144
+#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:148
+#: ../gui/wxpython/gui_modules/gdialogs.py:1145
 msgid "Link external raster data"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:56
-#: ../gui/wxpython/gui_modules/gdialogs.py:1140
+#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_modules/gdialogs.py:1141
 msgid "Import vector data"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:150
-#: ../gui/wxpython/gui_modules/gdialogs.py:1138
+#: ../gui/wxpython/icons/icon.py:185 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_modules/gdialogs.py:1139
 msgid "Link external vector data"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:185
+#: ../gui/wxpython/icons/icon.py:187
 msgid "Add raster map layer (Ctrl+R)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:187
+#: ../gui/wxpython/icons/icon.py:189
 msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:189
+#: ../gui/wxpython/icons/icon.py:191
 msgid "Add vector map layer (Ctrl+V)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:191
+#: ../gui/wxpython/icons/icon.py:193
 msgid "Add various vector map layers (thematic, chart...)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:193
+#: ../gui/wxpython/icons/icon.py:195
 msgid "Add command layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:195
+#: ../gui/wxpython/icons/icon.py:197
 msgid "Add group"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:197
+#: ../gui/wxpython/icons/icon.py:199
 msgid "Add grid or vector labels overlay"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:199
+#: ../gui/wxpython/icons/icon.py:201
 msgid "Delete selected map layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:201 ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/icons/icon.py:203 ../gui/wxpython/icons/icon.py:403
 msgid "Quit"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:203
+#: ../gui/wxpython/icons/icon.py:205
 msgid "Show attribute table"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:205
+#: ../gui/wxpython/icons/icon.py:207
 msgid "Edit vector maps"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:207
+#: ../gui/wxpython/icons/icon.py:209
 msgid "Add RGB map layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:209
+#: ../gui/wxpython/icons/icon.py:211
 msgid "Add HIS map layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:211
+#: ../gui/wxpython/icons/icon.py:213
 msgid "Add shaded relief map layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:213
+#: ../gui/wxpython/icons/icon.py:215
 msgid "Add raster flow arrows"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:215
+#: ../gui/wxpython/icons/icon.py:217
 msgid "Add raster cell numbers"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:217
+#: ../gui/wxpython/icons/icon.py:219
 msgid "Add thematic area (choropleth) map layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:219
+#: ../gui/wxpython/icons/icon.py:221
 msgid "Add thematic chart layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:221
+#: ../gui/wxpython/icons/icon.py:223
 msgid "Add grid layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:223
+#: ../gui/wxpython/icons/icon.py:225
 msgid "Add geodesic line layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:225
+#: ../gui/wxpython/icons/icon.py:227
 msgid "Add rhumbline layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:227
+#: ../gui/wxpython/icons/icon.py:229
 msgid "Add labels"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:229
+#: ../gui/wxpython/icons/icon.py:231
 msgid "Add 3D raster map layer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:230
+#: ../gui/wxpython/icons/icon.py:232
 msgid "Note that 3D raster data are rendered only in 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:232
+#: ../gui/wxpython/icons/icon.py:234
 msgid "Show GUI settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:234
+#: ../gui/wxpython/icons/icon.py:236
 msgid "Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:236
+#: ../gui/wxpython/icons/icon.py:238
 #: ../gui/wxpython/gui_modules/gdialogs.py:416
 msgid "Set options"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:238
-msgid "Hardcopy Map Ouput Utility"
+#: ../gui/wxpython/icons/icon.py:240 ../gui/wxpython/menustrings.py:198
+msgid "Hardcopy Map Output Utility"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:240
+#: ../gui/wxpython/icons/icon.py:242
 msgid "Raster Map Calculator"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:244
+#: ../gui/wxpython/icons/icon.py:246
 msgid "Digitize new point"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:245 ../gui/wxpython/icons/icon.py:254
-#: ../gui/wxpython/icons/icon.py:257
+#: ../gui/wxpython/icons/icon.py:247 ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:259
 msgid "Left: new point"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:247
+#: ../gui/wxpython/icons/icon.py:249
 msgid "Digitize new line"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:248 ../gui/wxpython/icons/icon.py:251
-#: ../gui/wxpython/icons/icon.py:275
+#: ../gui/wxpython/icons/icon.py:250 ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:277
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:250
+#: ../gui/wxpython/icons/icon.py:252
 msgid "Digitize new boundary"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:255
 msgid "Digitize new centroid"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:258
 msgid ""
 "Digitize new area (composition of boundaries without category and one "
 "centroid with category)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:259
+#: ../gui/wxpython/icons/icon.py:261
 msgid "Add new vertex"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:260 ../gui/wxpython/icons/icon.py:263
-#: ../gui/wxpython/icons/icon.py:266 ../gui/wxpython/icons/icon.py:278
-#: ../gui/wxpython/icons/icon.py:281 ../gui/wxpython/icons/icon.py:284
-#: ../gui/wxpython/icons/icon.py:289 ../gui/wxpython/icons/icon.py:296
+#: ../gui/wxpython/icons/icon.py:262 ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:268 ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:283 ../gui/wxpython/icons/icon.py:286
+#: ../gui/wxpython/icons/icon.py:291 ../gui/wxpython/icons/icon.py:298
 msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:262
-#: ../gui/wxpython/gui_modules/toolbars.py:782
+#: ../gui/wxpython/icons/icon.py:264
+#: ../gui/wxpython/gui_modules/toolbars.py:729
 msgid "Copy categories"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:267
 msgid "Delete feature(s)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:268
+#: ../gui/wxpython/icons/icon.py:270
 msgid "Display/update attributes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:269 ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/icons/icon.py:271 ../gui/wxpython/icons/icon.py:274
 msgid "Left: Select"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:271
+#: ../gui/wxpython/icons/icon.py:273
 msgid "Display/update categories"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/icons/icon.py:276
 msgid "Edit line/boundary"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:277
+#: ../gui/wxpython/icons/icon.py:279
 msgid "Move feature(s)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:282
 msgid "Move vertex"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:283
+#: ../gui/wxpython/icons/icon.py:285
 msgid "Remove vertex"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:286
-#: ../gui/wxpython/gui_modules/toolbars.py:857
+#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/gui_modules/toolbars.py:804
 msgid "Digitization settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/icons/icon.py:290
 msgid "Split line/boundary"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:291
+#: ../gui/wxpython/icons/icon.py:293
 msgid "Quit digitizer"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:292
+#: ../gui/wxpython/icons/icon.py:294
 msgid "Quit digitizer and save changes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:294
+#: ../gui/wxpython/icons/icon.py:296
 msgid "Additional tools (copy, flip, connect, etc.)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:298
+#: ../gui/wxpython/icons/icon.py:300
 msgid "Undo"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:299
+#: ../gui/wxpython/icons/icon.py:301
 msgid "Undo previous changes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:303
+#: ../gui/wxpython/icons/icon.py:305
 msgid "Draw/re-draw profile"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:305
+#: ../gui/wxpython/icons/icon.py:307
 msgid "Draw transect in map display window to profile"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:307
+#: ../gui/wxpython/icons/icon.py:309
 msgid "Profile options"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:309
+#: ../gui/wxpython/icons/icon.py:311
 msgid "Save profile data to CSV file"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:311
+#: ../gui/wxpython/icons/icon.py:313
 msgid "Quit Profile Analysis Tool"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/icons/icon.py:317
 msgid "Set GCP"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:316
+#: ../gui/wxpython/icons/icon.py:318
 msgid "Define GCP (Ground Control Points)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:318 ../gui/wxpython/menustrings.py:186
+#: ../gui/wxpython/icons/icon.py:320 ../gui/wxpython/menustrings.py:186
 msgid "Georectify"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:320
+#: ../gui/wxpython/icons/icon.py:322
 msgid "Recalculate RMS error"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:322
+#: ../gui/wxpython/icons/icon.py:324
 msgid "Save GCPs to POINTS file"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:324
+#: ../gui/wxpython/icons/icon.py:326
 msgid "Add new GCP"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:326
+#: ../gui/wxpython/icons/icon.py:328
 msgid "Delete selected GCP"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:328
+#: ../gui/wxpython/icons/icon.py:330
 msgid "Clear selected GCP"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:330
+#: ../gui/wxpython/icons/icon.py:332
 msgid "Reload GCPs from POINTS file"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:332
+#: ../gui/wxpython/icons/icon.py:334
 msgid "Quit georectification"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:334
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1289
+#: ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1504
 #: ../gui/wxpython/gui_modules/gselect.py:1070
 msgid "Settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/icons/icon.py:337
 msgid "Settings dialog for georectification tool"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:339
+#: ../gui/wxpython/icons/icon.py:341
 msgid "Switch to view control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:340
+#: ../gui/wxpython/icons/icon.py:342
 msgid "Change view settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:342
+#: ../gui/wxpython/icons/icon.py:344
 msgid "Switch to surface (raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:343
+#: ../gui/wxpython/icons/icon.py:345
 msgid "Change surface (loaded raster maps) settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:345
+#: ../gui/wxpython/icons/icon.py:347
 msgid "Switch to vector (2D/3D) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:346
+#: ../gui/wxpython/icons/icon.py:348
 msgid "Change 2D/3D vector settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:348
+#: ../gui/wxpython/icons/icon.py:350
 msgid "Switch to volume (3D raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:349
+#: ../gui/wxpython/icons/icon.py:351
 msgid "Change volume (loaded 3D raster maps) settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:353
 msgid "Switch to lighting control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:352
+#: ../gui/wxpython/icons/icon.py:354
 msgid "Change lighting settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:354
+#: ../gui/wxpython/icons/icon.py:356
 msgid "Switch to fringe control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:355
+#: ../gui/wxpython/icons/icon.py:357
 msgid "Switch on/off fringes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:359
 msgid "3D view mode tools"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:358
+#: ../gui/wxpython/icons/icon.py:360
 msgid "Show/hide 3D view mode settings dialog"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:360
+#: ../gui/wxpython/icons/icon.py:362
 msgid "Quit 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:361
+#: ../gui/wxpython/icons/icon.py:363
 msgid "Switch back to 2D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:365
+#: ../gui/wxpython/icons/icon.py:367
 msgid "Create new model (Ctrl+N)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:367
+#: ../gui/wxpython/icons/icon.py:369
 msgid "Load model from file (Ctrl+O)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:369
+#: ../gui/wxpython/icons/icon.py:371
 msgid "Save current model to file (Ctrl+S)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:371 ../gui/wxpython/menustrings.py:878
+#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:878
 msgid "Export model to image"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:880
+#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:880
 msgid "Export model to Python script"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:888
+#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:888
 msgid "Add action (GRASS module) to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:890
 msgid "Add data item to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:892
+#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:892
 msgid "Define relation between data and action items"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:190
+#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:190
 #: ../gui/wxpython/menustrings.py:903
 msgid "Run model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:905
+#: ../gui/wxpython/icons/icon.py:385 ../gui/wxpython/menustrings.py:905
 msgid "Validate model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:385
+#: ../gui/wxpython/icons/icon.py:387
 msgid "Show modeler settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:387
+#: ../gui/wxpython/icons/icon.py:389
 msgid "Show model properties"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:389
+#: ../gui/wxpython/icons/icon.py:391
 msgid "Manage model variables"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:391
+#: ../gui/wxpython/icons/icon.py:393
 msgid "Redraw model canvas"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:393
-#: ../gui/wxpython/gui_modules/gmodeler.py:677
+#: ../gui/wxpython/icons/icon.py:395
+#: ../gui/wxpython/gui_modules/gmodeler.py:671
 msgid "Quit Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:397
+#: ../gui/wxpython/icons/icon.py:399
 msgid "Select font"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:399
+#: ../gui/wxpython/icons/icon.py:401
 msgid "Show manual"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:405
+#: ../gui/wxpython/icons/icon.py:407
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:407
+#: ../gui/wxpython/icons/icon.py:409
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:409
+#: ../gui/wxpython/icons/icon.py:411
 msgid "Generate PostScript output"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:411
+#: ../gui/wxpython/icons/icon.py:413
 msgid "Generate PDF output"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:413
+#: ../gui/wxpython/icons/icon.py:415
 #: ../gui/wxpython/gui_modules/histogram.py:432
-#: ../gui/wxpython/gui_modules/mapdisp.py:1171
+#: ../gui/wxpython/gui_modules/mapdisp.py:1179
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:934
 msgid "Page setup"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:414
+#: ../gui/wxpython/icons/icon.py:416
 msgid "Specify paper size, margins and orientation"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:416
+#: ../gui/wxpython/icons/icon.py:418
 msgid "Full extent"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:417
+#: ../gui/wxpython/icons/icon.py:419
 msgid "Zoom to full extent"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:421
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1951
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2006
 msgid "Map frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:420
+#: ../gui/wxpython/icons/icon.py:422
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:320
+#: ../gui/wxpython/icons/icon.py:424
+#: ../gui/wxpython/gui_modules/nviz_tools.py:465
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2476
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:669
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:730
 msgid "Raster map"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/icons/icon.py:425
 msgid "Add raster map"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:425
-#: ../gui/wxpython/gui_modules/nviz_tools.py:629
+#: ../gui/wxpython/icons/icon.py:427
+#: ../gui/wxpython/gui_modules/nviz_tools.py:839
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3920
 msgid "Vector map"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:426
+#: ../gui/wxpython/icons/icon.py:428
 msgid "Add vector map"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:428
+#: ../gui/wxpython/icons/icon.py:430
 msgid "Delete selected object"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:430
+#: ../gui/wxpython/icons/icon.py:432
 msgid "Show preview"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:432
+#: ../gui/wxpython/icons/icon.py:434
 msgid "Quit Hardcopy Map Utility"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:434
+#: ../gui/wxpython/icons/icon.py:436
 msgid "Add text"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:436
+#: ../gui/wxpython/icons/icon.py:438
 msgid "Add map info"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:440
+#: ../gui/wxpython/icons/icon.py:442
 msgid "Add scale bar"
 msgstr ""
@@ -1022,79 +1040,79 @@
 msgid "Kriging"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:109
-#: ../gui/wxpython/gui_modules/gmodeler.py:575
-#: ../gui/wxpython/gui_modules/menuform.py:1165
+#: ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gui_modules/gmodeler.py:569
+#: ../gui/wxpython/gui_modules/menuform.py:1160
 msgid "Command output"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:115 ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/scripts/vkrige.py:114 ../gui/wxpython/menustrings.py:390
 msgid "Output"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:119
+#: ../gui/wxpython/scripts/vkrige.py:118
 msgid "Name for the output raster map:"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:127
+#: ../gui/wxpython/scripts/vkrige.py:126
 msgid "Export variance map as well: "
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:140
+#: ../gui/wxpython/scripts/vkrige.py:139
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:229
 #: ../gui/wxpython/gui_modules/vclean.py:144
-#: ../gui/wxpython/gui_modules/gmodeler.py:3309
-#: ../gui/wxpython/gui_modules/gdialogs.py:985
-#: ../gui/wxpython/gui_modules/preferences.py:1533
+#: ../gui/wxpython/gui_modules/gmodeler.py:3303
+#: ../gui/wxpython/gui_modules/gdialogs.py:986
+#: ../gui/wxpython/gui_modules/preferences.py:1555
 msgid "Allow output files to overwrite existing files"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:153
+#: ../gui/wxpython/scripts/vkrige.py:152
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:133
 #: ../gui/wxpython/gui_modules/ghelp.py:223
 #: ../gui/wxpython/gui_modules/vclean.py:165
-#: ../gui/wxpython/gui_modules/gmodeler.py:3426
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/gmodeler.py:3420
+#: ../gui/wxpython/gui_modules/menuform.py:828
 msgid "&Run"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:268
+#: ../gui/wxpython/scripts/vkrige.py:267
 msgid "Kriging Module"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:272
+#: ../gui/wxpython/scripts/vkrige.py:271
 msgid "Ready."
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:296
+#: ../gui/wxpython/scripts/vkrige.py:295
 msgid "Variogram fitting"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:306
+#: ../gui/wxpython/scripts/vkrige.py:305
 msgid "Plot/refresh variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:317
+#: ../gui/wxpython/scripts/vkrige.py:316
 msgid ":"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:342
+#: ../gui/wxpython/scripts/vkrige.py:341
 msgid "Kriging techniques"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:356
+#: ../gui/wxpython/scripts/vkrige.py:355
 msgid "Block size:"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:389
+#: ../gui/wxpython/scripts/vkrige.py:388
 msgid "Auto-fit variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:413
+#: ../gui/wxpython/scripts/vkrige.py:412
 msgid "Model: "
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:497
+#: ../gui/wxpython/scripts/vkrige.py:496
 msgid "Work in progress! No functionality provided."
 msgstr ""
@@ -1179,8 +1197,9 @@
 msgid "Workspace"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:17
 #: ../gui/wxpython/menustrings.py:867
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
 msgid "New"
 msgstr ""
@@ -1217,41 +1236,45 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:14
-msgid "Load map layers"
-msgstr ""
-#: ../gui/wxpython/menustrings.py:16
 msgid "Load GRC file (Tcl/Tk GUI)"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/menustrings.py:15
 msgid "Load map layers from GRC file to layer tree"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:16
 msgid "Map display"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:18
 msgid "Open new map display window"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:19
 msgid "Close current"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:20
 msgid "Close current map display window"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:21
 msgid "Close all"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:22
 msgid "Close all open map display windows"
 msgstr ""
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+msgid "Add multiple raster or vector map layers to current display"
+msgstr ""
 #: ../gui/wxpython/menustrings.py:25
 msgid "Add raster"
 msgstr ""
@@ -1796,6 +1819,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2640
 msgid "Delete"
 msgstr ""
@@ -1918,10 +1942,6 @@
 "coordinates and vice versa."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:198
-msgid "Hardcopy Map Output Utility"
-msgstr ""
 #: ../gui/wxpython/menustrings.py:199
 msgid "Launch Hardcopy Map Output Utility"
 msgstr ""
@@ -2319,9 +2339,8 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:298
-#: ../gui/wxpython/gui_modules/nviz_tools.py:351
-#: ../gui/wxpython/gui_modules/nviz_tools.py:549
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:602
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1238
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3049
 msgid "Mask"
 msgstr ""
@@ -2470,7 +2489,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:330
-#: ../gui/wxpython/gui_modules/layertree.py:803
+#: ../gui/wxpython/gui_modules/layertree.py:799
 msgid "Shaded relief"
 msgstr ""
@@ -4697,7 +4716,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:872
-#: ../gui/wxpython/gui_modules/gmodeler.py:828
+#: ../gui/wxpython/gui_modules/gmodeler.py:822
 msgid "Save model"
 msgstr ""
@@ -4726,7 +4745,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:885
-#: ../gui/wxpython/gui_modules/gmodeler.py:3003
+#: ../gui/wxpython/gui_modules/gmodeler.py:2997
 msgid "Modeler settings"
 msgstr ""
@@ -4771,7 +4790,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:899
-#: ../gui/wxpython/gui_modules/gmodeler.py:3288
+#: ../gui/wxpython/gui_modules/gmodeler.py:3282
 msgid "Model properties"
 msgstr ""
@@ -4909,8 +4928,8 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:332
-#: ../gui/wxpython/gui_modules/wxnviz.py:227
-#: ../gui/wxpython/gui_modules/wxnviz.py:238
+#: ../gui/wxpython/gui_modules/wxnviz.py:240
+#: ../gui/wxpython/gui_modules/wxnviz.py:251
 #, python-format
 msgid "Raster map <%s> not found"
 msgstr ""
@@ -4920,14 +4939,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:403
-#: ../gui/wxpython/gui_modules/mapdisp.py:1142
+#: ../gui/wxpython/gui_modules/mapdisp.py:1150
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:905
-#: ../gui/wxpython/gui_modules/gmodeler.py:1042
+#: ../gui/wxpython/gui_modules/gmodeler.py:1036
 msgid "Choose a file name to save the image (no need to add extension)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:436
-#: ../gui/wxpython/gui_modules/mapdisp.py:1175
+#: ../gui/wxpython/gui_modules/mapdisp.py:1183
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:938
 msgid "Print preview"
 msgstr ""
@@ -4961,15 +4980,15 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#: ../gui/wxpython/gui_modules/gdialogs.py:1005
+#: ../gui/wxpython/gui_modules/gdialogs.py:1006
 msgid "Command dialog"
 msgstr ""
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:138
-#: ../gui/wxpython/gui_modules/gdialogs.py:1161
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
-#: ../gui/wxpython/gui_modules/gdialogs.py:1168
-#: ../gui/wxpython/gui_modules/gdialogs.py:1170
+#: ../gui/wxpython/gui_modules/gdialogs.py:1162
+#: ../gui/wxpython/gui_modules/gdialogs.py:1164
+#: ../gui/wxpython/gui_modules/gdialogs.py:1169
+#: ../gui/wxpython/gui_modules/gdialogs.py:1171
 #, python-format
 msgid "Open %s dialog"
 msgstr ""
@@ -4979,7 +4998,6 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#: ../gui/wxpython/gui_modules/gdialogs.py:739
 msgid "&Load"
 msgstr ""
@@ -5132,6 +5150,40 @@
 msgid "Unknow tag"
 msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:47
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:97
+#, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:104
+#, python-format
+msgid "Raster map <%s> added"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:106
+#, python-format
+msgid "Vector map <%s> added"
+msgstr ""
 #: ../gui/wxpython/gui_modules/dbm_dialogs.py:67
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2998
 msgid "Database connection is not defined in DB file."
@@ -5190,7 +5242,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2279
 #: ../gui/wxpython/gui_modules/dbm.py:2387
 #: ../gui/wxpython/gui_modules/dbm.py:2642
-#: ../gui/wxpython/gui_modules/gdialogs.py:1352
+#: ../gui/wxpython/gui_modules/gdialogs.py:1353
 msgid "Layer"
 msgstr ""
@@ -5224,16 +5276,16 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:328
-#: ../gui/wxpython/gui_modules/gmodeler.py:3560
+#: ../gui/wxpython/gui_modules/gmodeler.py:3554
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2028
-#: ../gui/wxpython/gui_modules/layertree.py:791
+#: ../gui/wxpython/gui_modules/layertree.py:787
 msgid "raster"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3561
+#: ../gui/wxpython/gui_modules/gmodeler.py:3555
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2029
-#: ../gui/wxpython/gui_modules/layertree.py:812
+#: ../gui/wxpython/gui_modules/layertree.py:808
 msgid "vector"
 msgstr ""
@@ -5325,12 +5377,12 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1110
-#: ../gui/wxpython/gui_modules/toolbars.py:416
+#: ../gui/wxpython/gui_modules/toolbars.py:398
 msgid "source"
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1112
 msgid "target"
 msgstr ""
@@ -5516,21 +5568,21 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2371
 #: ../gui/wxpython/gui_modules/profile.py:1033
 #: ../gui/wxpython/gui_modules/profile.py:1388
-#: ../gui/wxpython/gui_modules/preferences.py:961
+#: ../gui/wxpython/gui_modules/preferences.py:966
 msgid "Apply changes for the current session"
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2373
 #: ../gui/wxpython/gui_modules/profile.py:1038
 #: ../gui/wxpython/gui_modules/profile.py:1390
-#: ../gui/wxpython/gui_modules/preferences.py:963
+#: ../gui/wxpython/gui_modules/preferences.py:968
 msgid ""
 "Apply and save changes to user settings file (default for next sessions)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2375
 #: ../gui/wxpython/gui_modules/ogc_services.py:77
-#: ../gui/wxpython/gui_modules/gdialogs.py:995
+#: ../gui/wxpython/gui_modules/gdialogs.py:996
 msgid "Close dialog"
 msgstr ""
@@ -5560,12 +5612,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2438
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1307
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:809
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1522
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:326
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:547
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3098
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3203
-#: ../gui/wxpython/gui_modules/preferences.py:1683
+#: ../gui/wxpython/gui_modules/preferences.py:1705
 msgid "Color:"
 msgstr ""
@@ -5637,16 +5691,16 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:90
-#: ../gui/wxpython/gui_modules/mapdisp.py:771
-#: ../gui/wxpython/gui_modules/mapdisp.py:803
-#: ../gui/wxpython/gui_modules/mapdisp.py:874
-#: ../gui/wxpython/gui_modules/mapdisp.py:1027
+#: ../gui/wxpython/gui_modules/mapdisp.py:779
+#: ../gui/wxpython/gui_modules/mapdisp.py:811
+#: ../gui/wxpython/gui_modules/mapdisp.py:882
+#: ../gui/wxpython/gui_modules/mapdisp.py:1035
 msgid "Projection not defined (check the settings)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:107
-#: ../gui/wxpython/gui_modules/mapdisp.py:918
-#: ../gui/wxpython/gui_modules/mapdisp.py:1044
+#: ../gui/wxpython/gui_modules/mapdisp.py:926
+#: ../gui/wxpython/gui_modules/mapdisp.py:1052
 msgid "Error in projection (check the settings)"
 msgstr ""
@@ -5674,7 +5728,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1718
 #: ../gui/wxpython/gui_modules/gcmd.py:89
-#: ../gui/wxpython/gui_modules/workspace.py:1000
+#: ../gui/wxpython/gui_modules/workspace.py:1007
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:424
 #: ../gui/wxpython/gui_modules/dbm.py:2357
 msgid "Warning"
@@ -5726,7 +5780,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:178
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:184
-#: ../gui/wxpython/gui_modules/preferences.py:1471
+#: ../gui/wxpython/gui_modules/preferences.py:1493
 msgid "Constrain display resolution to computational settings"
 msgstr ""
@@ -5738,8 +5792,8 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp.py:210
-#: ../gui/wxpython/gui_modules/mapdisp.py:1062
-#: ../gui/wxpython/gui_modules/mapdisp.py:1065
+#: ../gui/wxpython/gui_modules/mapdisp.py:1070
+#: ../gui/wxpython/gui_modules/mapdisp.py:1073
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:216
 msgid "Use defined projection"
 msgstr ""
@@ -5764,8 +5818,8 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:301
 #: ../gui/wxpython/gui_modules/mapdisp.py:312
 #: ../gui/wxpython/gui_modules/mapdisp.py:362
-#: ../gui/wxpython/gui_modules/mapdisp.py:507
-#: ../gui/wxpython/gui_modules/toolbars.py:201
+#: ../gui/wxpython/gui_modules/mapdisp.py:513
+#: ../gui/wxpython/gui_modules/toolbars.py:204
 #: ../gui/wxpython/gui_modules/layertree.py:582
 msgid "2D view"
 msgstr ""
@@ -5789,160 +5843,160 @@
 "Details: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:381
+#: ../gui/wxpython/gui_modules/mapdisp.py:386
 msgid "Starting 3D view mode..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:387
 msgid "Please wait, loading data..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:414
+#: ../gui/wxpython/gui_modules/mapdisp.py:420
 msgid "3D View Toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:438
+#: ../gui/wxpython/gui_modules/mapdisp.py:444
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:348
 msgid "Map Toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:455
+#: ../gui/wxpython/gui_modules/mapdisp.py:461
 msgid "Georectification Toolbar"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:517
+#: ../gui/wxpython/gui_modules/mapdisp.py:523
 #: ../gui/wxpython/gui_modules/render.py:420
 #, python-format
 msgid "GRASS module '%s' not found. Unable to start map display window."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1127
+#: ../gui/wxpython/gui_modules/mapdisp.py:1135
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:890
 msgid "Nothing to render (empty map). Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1300
+#: ../gui/wxpython/gui_modules/mapdisp.py:1308
 msgid "No raster or vector map layer selected for querying."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1301
+#: ../gui/wxpython/gui_modules/mapdisp.py:1309
 msgid "No map layer selected"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1396
+#: ../gui/wxpython/gui_modules/mapdisp.py:1404
 msgid "No vector map selected for querying."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1397
 #: ../gui/wxpython/gui_modules/mapdisp.py:1405
+#: ../gui/wxpython/gui_modules/mapdisp.py:1413
 msgid "Vector querying"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1404
+#: ../gui/wxpython/gui_modules/mapdisp.py:1412
 msgid "Only vector map from the current mapset can be modified."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1476
+#: ../gui/wxpython/gui_modules/mapdisp.py:1484
 msgid "Query surface (raster map)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1483
+#: ../gui/wxpython/gui_modules/mapdisp.py:1491
 msgid "Query vector map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1491
+#: ../gui/wxpython/gui_modules/mapdisp.py:1499
 msgid "Query raster/vector map(s) (display mode)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1507
+#: ../gui/wxpython/gui_modules/mapdisp.py:1515
 msgid "Query vector map (edit mode)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1633
+#: ../gui/wxpython/gui_modules/mapdisp.py:1641
 #, python-format
 msgid ""
 "Click and drag with left mouse button to measure.%sDouble click with left "
 "button to clear."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1639
+#: ../gui/wxpython/gui_modules/mapdisp.py:1647
 msgid "Measuring distance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1642
+#: ../gui/wxpython/gui_modules/mapdisp.py:1650
 msgid "Measuring distance:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1652
+#: ../gui/wxpython/gui_modules/mapdisp.py:1660
 #, python-format
 msgid ""
 "Geodesic distance is not yet supported by this tool.\n"
 "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1681
-#: ../gui/wxpython/gui_modules/mapdisp.py:1687
+#: ../gui/wxpython/gui_modules/mapdisp.py:1690
+#: ../gui/wxpython/gui_modules/mapdisp.py:1696
 msgid "segment"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1682
-#: ../gui/wxpython/gui_modules/mapdisp.py:1688
+#: ../gui/wxpython/gui_modules/mapdisp.py:1691
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
 msgid "total distance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1683
+#: ../gui/wxpython/gui_modules/mapdisp.py:1692
 msgid "bearing"
 msgstr ""
 msgid "deg"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1819
+#: ../gui/wxpython/gui_modules/mapdisp.py:1828
 msgid "Scale and North arrow"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1825
+#: ../gui/wxpython/gui_modules/mapdisp.py:1834
 msgid "Show/hide scale and North arrow"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1826
+#: ../gui/wxpython/gui_modules/mapdisp.py:1835
 msgid "scale object"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1855
+#: ../gui/wxpython/gui_modules/mapdisp.py:1864
 msgid "Show/hide legend"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1856
+#: ../gui/wxpython/gui_modules/mapdisp.py:1865
 msgid "legend object"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1965
+#: ../gui/wxpython/gui_modules/mapdisp.py:1974
 msgid "Zoom to computational region"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1969
+#: ../gui/wxpython/gui_modules/mapdisp.py:1978
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1058
 msgid "Zoom to default region"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1973
+#: ../gui/wxpython/gui_modules/mapdisp.py:1982
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1062
 msgid "Zoom to saved region"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1977
+#: ../gui/wxpython/gui_modules/mapdisp.py:1986
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1066
 msgid "Set computational region from display"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1981
+#: ../gui/wxpython/gui_modules/mapdisp.py:1990
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1070
 msgid "Save display geometry to named region"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:2075
+#: ../gui/wxpython/gui_modules/mapdisp.py:2084
 msgid "GRASS GIS Map Display: "
 msgstr ""
@@ -6003,12 +6057,12 @@
 msgid "Unsupported feature type %d. Operation cancelled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:455
+#: ../gui/wxpython/gui_modules/wxvdigit.py:456
 #, python-format
 msgid "Unknown feature type '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxvdigit.py:460
+#: ../gui/wxpython/gui_modules/wxvdigit.py:461
 msgid "Not enough points for line"
 msgstr ""
@@ -6062,7 +6116,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ghelp.py:340
-#: ../gui/wxpython/gui_modules/goutput.py:629
+#: ../gui/wxpython/gui_modules/goutput.py:641
 #, python-format
 msgid "%d modules match"
 msgstr ""
@@ -6122,11 +6176,11 @@
 #: ../gui/wxpython/gui_modules/ghelp.py:702
 #: ../gui/wxpython/gui_modules/ghelp.py:761
-#: ../gui/wxpython/gui_modules/gmodeler.py:3548
-#: ../gui/wxpython/gui_modules/gmodeler.py:3588
-#: ../gui/wxpython/gui_modules/gmodeler.py:3856
-#: ../gui/wxpython/gui_modules/gmodeler.py:3964
-#: ../gui/wxpython/gui_modules/gmodeler.py:4282
+#: ../gui/wxpython/gui_modules/gmodeler.py:3542
+#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3958
+#: ../gui/wxpython/gui_modules/gmodeler.py:4276
 msgid "Name"
 msgstr ""
@@ -6164,7 +6218,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ghelp.py:815
-#: ../gui/wxpython/gui_modules/gdialogs.py:959
+#: ../gui/wxpython/gui_modules/gdialogs.py:960
 msgid "Options"
 msgstr ""
@@ -6221,8 +6275,8 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1507
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3295
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
-#: ../gui/wxpython/gui_modules/gdialogs.py:1258
-#: ../gui/wxpython/gui_modules/menuform.py:1691
+#: ../gui/wxpython/gui_modules/gdialogs.py:1259
+#: ../gui/wxpython/gui_modules/menuform.py:1684
 msgid "Browse"
 msgstr ""
@@ -6296,8 +6350,8 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:874
 #: ../gui/wxpython/gui_modules/location_wizard.py:1037
 #: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/gui_modules/gmodeler.py:3549
-#: ../gui/wxpython/gui_modules/gmodeler.py:3608
+#: ../gui/wxpython/gui_modules/gmodeler.py:3543
+#: ../gui/wxpython/gui_modules/gmodeler.py:3602
 msgid "Description"
 msgstr ""
@@ -6398,7 +6452,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/location_wizard.py:1286
-#: ../gui/wxpython/gui_modules/preferences.py:1814
+#: ../gui/wxpython/gui_modules/preferences.py:1836
 msgid "EPSG code:"
 msgstr ""
@@ -6655,7 +6709,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vclean.py:168
-#: ../gui/wxpython/gui_modules/menuform.py:832
+#: ../gui/wxpython/gui_modules/menuform.py:833
 msgid "Copy the current command string to the clipboard (Ctrl+C)"
 msgstr ""
@@ -6737,286 +6791,276 @@
 msgid "Vector cleaning command copied to clipboard"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:70
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:48
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:55
+#: ../gui/wxpython/gui_modules/nviz_tools.py:136
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:52
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:59
 msgid "View"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:74
-#: ../gui/wxpython/gui_modules/gmodeler.py:3154
+#: ../gui/wxpython/gui_modules/gmodeler.py:3148
 msgid "Data"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:78
-#: ../gui/wxpython/gui_modules/preferences.py:1236
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/preferences.py:1240
 msgid "Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:112
+#: ../gui/wxpython/gui_modules/nviz_tools.py:216
 msgid "Control View"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:120
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1146
+#: ../gui/wxpython/gui_modules/nviz_tools.py:226
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1360
 msgid "W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:122
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1148
+#: ../gui/wxpython/gui_modules/nviz_tools.py:227
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1362
 msgid "N"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:129
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1155
+#: ../gui/wxpython/gui_modules/nviz_tools.py:228
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1369
 msgid "S"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:131
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+#: ../gui/wxpython/gui_modules/nviz_tools.py:229
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
 msgid "E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:140
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:64
-msgid "Perspective:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:230
+msgid "NW"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:150
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:143
-msgid "Twist:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:231
+msgid "NE"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:168
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1167
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:124
-#: ../gui/wxpython/gui_modules/gmodeler.py:3128
-#: ../gui/wxpython/gui_modules/gmodeler.py:3247
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4038
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4181
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4829
-#: ../gui/wxpython/gui_modules/gdialogs.py:1634
-msgid "Height:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:232
+msgid "SE"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:175
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:173
-msgid "Z-exag:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:233
+msgid "SW"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
-msgid "Look at:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:68
+msgid "Perspective:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
-msgid "top"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
+msgid "Twist:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
-msgid "north"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:290
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1381
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:128
+#: ../gui/wxpython/gui_modules/gmodeler.py:3122
+#: ../gui/wxpython/gui_modules/gmodeler.py:3241
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4038
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4181
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:4829
+#: ../gui/wxpython/gui_modules/gdialogs.py:1635
+msgid "Height:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
-msgid "south"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:296
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:177
+msgid "Z-exag:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:197
-msgid "east"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:309
+msgid "Look:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:198
-msgid "west"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:312
+msgid "here"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:199
-msgid "north-west"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:318
+msgid "center"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:200
-msgid "north-east"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:324
+msgid "top"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:201
-msgid "south-east"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:330
+msgid "reset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:202
-msgid "south-west"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:210
-msgid "Reset"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:211
+#: ../gui/wxpython/gui_modules/nviz_tools.py:331
 msgid "Reset to default view"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:233
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:205
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:209
 msgid "Image Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:240
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:212
-#: ../gui/wxpython/gui_modules/preferences.py:1452
+#: ../gui/wxpython/gui_modules/nviz_tools.py:357
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:217
+#: ../gui/wxpython/gui_modules/preferences.py:1474
 msgid "Background color:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:272
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:394
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1471
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:353
 msgid "Surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:277
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:237
+#: ../gui/wxpython/gui_modules/nviz_tools.py:400
+#: ../gui/wxpython/gui_modules/nviz_tools.py:757
+msgid "Constant surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:405
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:457
 msgid "Vector"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:282
+#: ../gui/wxpython/gui_modules/nviz_tools.py:411
 msgid "Volume"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:298
+#: ../gui/wxpython/gui_modules/nviz_tools.py:435
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:243
 msgid "Lighting"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:302
+#: ../gui/wxpython/gui_modules/nviz_tools.py:440
 msgid "Fringe"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:342
-msgid "Surface attributes"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:349
-msgid "Topography"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:350
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
-#: ../gui/wxpython/gui_modules/profile.py:1222
-msgid "Color"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:352
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1028
-msgid "Transparency"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:353
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
-msgid "Shininess"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:354
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1030
-msgid "Emission"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:360
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1038
-msgid "map"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:363
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1043
-msgid "unset"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:368
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1048
-msgid "constant"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:428
-#: ../gui/wxpython/gui_modules/nviz_tools.py:915
+#: ../gui/wxpython/gui_modules/nviz_tools.py:488
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1126
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:362
 msgid "Draw"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:435
-#: ../gui/wxpython/gui_modules/nviz_tools.py:922
+#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1133
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:368
 msgid "Mode:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:438
+#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
 msgid "coarse"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:439
+#: ../gui/wxpython/gui_modules/nviz_tools.py:499
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:372
 msgid "fine"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:440
+#: ../gui/wxpython/gui_modules/nviz_tools.py:500
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:373
 msgid "both"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:450
-#: ../gui/wxpython/gui_modules/nviz_tools.py:936
+#: ../gui/wxpython/gui_modules/nviz_tools.py:509
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1147
 msgid "Shading:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:453
-#: ../gui/wxpython/gui_modules/nviz_tools.py:709
-#: ../gui/wxpython/gui_modules/nviz_tools.py:939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:512
+#: ../gui/wxpython/gui_modules/nviz_tools.py:920
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1150
 msgid "flat"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:454
-#: ../gui/wxpython/gui_modules/nviz_tools.py:940
+#: ../gui/wxpython/gui_modules/nviz_tools.py:513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1151
 msgid "gouraud"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:462
+#: ../gui/wxpython/gui_modules/nviz_tools.py:521
 msgid "Set to all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:463
+#: ../gui/wxpython/gui_modules/nviz_tools.py:522
 msgid "Use draw settings for all loaded surfaces"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:470
-msgid "Coarse:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:400
+msgid "Coarse mode:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:524
-msgid "res."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:387
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:404
+msgid "resolution:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:492
-msgid "style"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:545
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:416
+msgid "style:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:548
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
 msgid "wire"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:549
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:420
 msgid "surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:505
-msgid "wire color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:561
+msgid "Change wire color"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:519
-msgid "Fine:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:568
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:383
+msgid "Fine mode:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
-msgid "Mask zeros:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:593
+msgid "Surface attributes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
-msgid "by elevation"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:601
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1222
+msgid "Color"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:563
-msgid "by color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:603
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1239
+msgid "Transparency"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:578
+#: ../gui/wxpython/gui_modules/nviz_tools.py:604
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1240
+msgid "Shininess"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:610
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1249
+msgid "map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:613
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1254
+msgid "unset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1259
+msgid "constant"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:671
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4008
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4577
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4793
@@ -7025,153 +7069,188 @@
 msgid "Position"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:653
+#: ../gui/wxpython/gui_modules/nviz_tools.py:686
+msgid "Reset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:687
+msgid "Reset to default position"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:785
+msgid "Fine resolution:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:797
+msgid "Value:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:863
 msgid "Show vector lines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:663
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:245
+#: ../gui/wxpython/gui_modules/nviz_tools.py:873
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:465
 msgid "Vector lines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:669
+#: ../gui/wxpython/gui_modules/nviz_tools.py:880
 msgid "Line:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:672
-#: ../gui/wxpython/gui_modules/nviz_tools.py:805
-msgid "width"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:883
+msgid "width:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:688
-#: ../gui/wxpython/gui_modules/nviz_tools.py:790
-msgid "color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:899
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1001
+msgid "color:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:703
-msgid "display"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+#: ../gui/wxpython/gui_modules/vdigit.py:158
+msgid "Display"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:708
-msgid "on surface"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:919
+msgid "on surface(s):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:718
-#: ../gui/wxpython/gui_modules/nviz_tools.py:836
+#: ../gui/wxpython/gui_modules/nviz_tools.py:929
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1050
 msgid "Height above surface:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:754
+#: ../gui/wxpython/gui_modules/nviz_tools.py:964
 msgid "Show vector points"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:973
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:487
 msgid "Vector points"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:769
+#: ../gui/wxpython/gui_modules/nviz_tools.py:980
 msgid "Icon:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:772
-msgid "size"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:983
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
+msgid "size:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:823
-msgid "symbol"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1016
+msgid "width"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:892
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1033
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
+msgid "symbol:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1046
+msgid "Display on surface(s):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
 msgid "3D raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:925
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1136
 msgid "isosurfaces"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1137
 msgid "slides"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:949
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1160
 msgid "Resolution:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:971
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
 msgid "List of isosurfaces"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1019
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1230
 msgid "Isosurface attributes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1025
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1236
 msgid "Topography level"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
-msgid "Show light model"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1241
+msgid "Emission"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1135
-msgid "Follow source viewpoint"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1342
+msgid "Show light model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1141
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1355
 msgid "Light source position"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1185
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1399
 msgid "Light color and intensity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1199
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1413
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:299
 msgid "Brightness:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1423
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
 msgid "Ambient:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1270
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1485
 msgid "Edges with fringe"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1487
 msgid "N && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1488
 msgid "N && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1489
 msgid "S && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1275
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1490
 msgid "S && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1295
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1510
 msgid "Elevation of fringe from bottom:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2309
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2311
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1563
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1608
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1186
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1204
+msgid "constant#"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2667
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2669
 msgid "Level"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2632
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3003
 msgid "Vector map is 3D"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2635
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3006
 msgid "Vector map is 2D"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2637
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3008
 #, python-format
 msgid "%(features)d features (%(points)d points)"
 msgstr ""
@@ -7193,8 +7272,8 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ogc_services.py:69
-#: ../gui/wxpython/gui_modules/gdialogs.py:1153
-#: ../gui/wxpython/gui_modules/gdialogs.py:1263
+#: ../gui/wxpython/gui_modules/gdialogs.py:1154
+#: ../gui/wxpython/gui_modules/gdialogs.py:1264
 msgid "Add imported layers into layer tree"
 msgstr ""
@@ -7207,14 +7286,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ogc_services.py:85
-#: ../gui/wxpython/gui_modules/gdialogs.py:998
-#: ../gui/wxpython/gui_modules/gdialogs.py:1165
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
+#: ../gui/wxpython/gui_modules/gdialogs.py:1166
 msgid "&Import"
 msgstr ""
 #: ../gui/wxpython/gui_modules/ogc_services.py:86
-#: ../gui/wxpython/gui_modules/gdialogs.py:999
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/gdialogs.py:1167
 msgid "Import selected layers"
 msgstr ""
@@ -7230,17 +7309,17 @@
 msgid "Layers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:393
+#: ../gui/wxpython/gui_modules/prompt.py:394
 #, python-format
 msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:396
+#: ../gui/wxpython/gui_modules/prompt.py:397
 #, python-format
 msgid "Warning: option <%(param)s> not found in '%(module)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:617
+#: ../gui/wxpython/gui_modules/prompt.py:618
 msgid "Type GRASS command and run by pressing ENTER"
 msgstr ""
@@ -7262,7 +7341,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gselect.py:1083
-#: ../gui/wxpython/gui_modules/menuform.py:1690
+#: ../gui/wxpython/gui_modules/menuform.py:1683
 msgid "File"
 msgstr ""
@@ -7338,7 +7417,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gselect.py:1285
-#: ../gui/wxpython/gui_modules/gmodeler.py:3331
+#: ../gui/wxpython/gui_modules/gmodeler.py:3325
 msgid "Name:"
 msgstr ""
@@ -7354,62 +7433,71 @@
 msgid "Unable to save settings."
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:29
 msgid "3D view settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:67
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:146
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:71
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:180
 msgid "(value)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:79
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:127
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:158
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:187
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:83
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:131
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:162
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:191
 msgid "(step)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:94
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:98
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:258
 msgid "Position:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:97
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:101
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:261
 msgid "(x)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:252
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:249
+msgid "Light"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:285
+msgid "(z)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:431
+msgid "wire color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
 msgid "Show lines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:274
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:494
 msgid "Show points"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:283
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:503
 msgid "Size:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:298
-#: ../gui/wxpython/gui_modules/gmodeler.py:3110
-#: ../gui/wxpython/gui_modules/gmodeler.py:3229
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:518
+#: ../gui/wxpython/gui_modules/gmodeler.py:3104
+#: ../gui/wxpython/gui_modules/gmodeler.py:3223
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4026
-#: ../gui/wxpython/gui_modules/gdialogs.py:1630
+#: ../gui/wxpython/gui_modules/gdialogs.py:1631
 msgid "Width:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:533
 msgid "Marker:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:695
 #, python-format
-msgid "Nviz settings saved to file <%s>."
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
-#, python-format
 msgid "3D view settings saved to file <%s>."
 msgstr ""
@@ -7424,8 +7512,8 @@
 #: ../gui/wxpython/gui_modules/gcmd.py:349
 #: ../gui/wxpython/gui_modules/render.py:627
 #: ../gui/wxpython/gui_modules/render.py:630
-#: ../gui/wxpython/gui_modules/menuform.py:2167
-#: ../gui/wxpython/gui_modules/menuform.py:2170
+#: ../gui/wxpython/gui_modules/menuform.py:2160
+#: ../gui/wxpython/gui_modules/menuform.py:2163
 msgid "Details:"
 msgstr ""
@@ -7448,23 +7536,19 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:92
-#: ../gui/wxpython/gui_modules/gmodeler.py:3319
+#: ../gui/wxpython/gui_modules/gmodeler.py:3313
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1703
 #: ../gui/wxpython/gui_modules/profile.py:1040
 #: ../gui/wxpython/gui_modules/profile.py:1393
-#: ../gui/wxpython/gui_modules/preferences.py:966
+#: ../gui/wxpython/gui_modules/preferences.py:971
 msgid "Close dialog and ignore changes"
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:151
-#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_modules/preferences.py:1109
 msgid "General"
 msgstr ""
-#: ../gui/wxpython/gui_modules/vdigit.py:158
-msgid "Display"
-msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:163
 #: ../gui/wxpython/gui_modules/profile.py:1174
 msgid "Line width"
@@ -7575,7 +7659,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:377
-#: ../gui/wxpython/gui_modules/preferences.py:1669
+#: ../gui/wxpython/gui_modules/preferences.py:1691
 msgid "Attributes"
 msgstr ""
@@ -7739,20 +7823,20 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:1060
-#: ../gui/wxpython/gui_modules/gmodeler.py:3785
-#: ../gui/wxpython/gui_modules/gmodeler.py:4142
+#: ../gui/wxpython/gui_modules/gmodeler.py:3779
+#: ../gui/wxpython/gui_modules/gmodeler.py:4136
 msgid "Delete selected"
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:1064
-#: ../gui/wxpython/gui_modules/gmodeler.py:3786
-#: ../gui/wxpython/gui_modules/gmodeler.py:4143
+#: ../gui/wxpython/gui_modules/gmodeler.py:3780
+#: ../gui/wxpython/gui_modules/gmodeler.py:4137
 msgid "Delete all"
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:1066
-#: ../gui/wxpython/gui_modules/gmodeler.py:3792
-#: ../gui/wxpython/gui_modules/gmodeler.py:4150
+#: ../gui/wxpython/gui_modules/gmodeler.py:3786
+#: ../gui/wxpython/gui_modules/gmodeler.py:4144
 #: ../gui/wxpython/gui_modules/dbm.py:1146
 #: ../gui/wxpython/gui_modules/dbm.py:1659
 msgid "Reload"
@@ -7844,6 +7928,10 @@
 msgid "Preview generated"
 msgstr ""
+#: ../gui/wxpython/gui_modules/psmap.py:353
+msgid "Save file as"
+msgstr ""
 #: ../gui/wxpython/gui_modules/psmap.py:392
 #, python-format
 msgid "Failed to read file %s."
@@ -7858,24 +7946,24 @@
 msgid "Scalebar is not appropriate for this projection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:861
+#: ../gui/wxpython/gui_modules/psmap.py:860
 msgid "wxGUI Hardcopy Map Utility"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/psmap.py:862
 msgid ""
 "(C) 2011 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:864
-#: ../gui/wxpython/gui_modules/gmodeler.py:1236
+#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/gmodeler.py:1230
 msgid ""
 "This program is free software under the GNU General Public License(>=v2). "
 "Read the file COPYING that comes with GRASS for details."
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:1095
+#: ../gui/wxpython/gui_modules/psmap.py:1094
 msgid "Click and drag to resize object"
 msgstr ""
@@ -7990,7 +8078,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gmodeler.py:451
-#: ../gui/wxpython/gui_modules/gmodeler.py:574
+#: ../gui/wxpython/gui_modules/gmodeler.py:568
 msgid "Variables"
 msgstr ""
@@ -7998,95 +8086,95 @@
 msgid "GRASS GIS Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:572
+#: ../gui/wxpython/gui_modules/gmodeler.py:566
 msgid "Model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:573
+#: ../gui/wxpython/gui_modules/gmodeler.py:567
 msgid "Items"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:642
+#: ../gui/wxpython/gui_modules/gmodeler.py:636
 msgid "Redrawing model..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:669
+#: ../gui/wxpython/gui_modules/gmodeler.py:663
 msgid "Do you want to save changes in the model?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:671
+#: ../gui/wxpython/gui_modules/gmodeler.py:665
 msgid "Do you want to store current model settings to model file?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:738
+#: ../gui/wxpython/gui_modules/gmodeler.py:732
 #: ../gui/wxpython/gui_modules/dbm.py:2084
 msgid "Nothing to delete."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:742
+#: ../gui/wxpython/gui_modules/gmodeler.py:736
 #, python-format
 msgid "Do you want to permanently delete data?%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:743
+#: ../gui/wxpython/gui_modules/gmodeler.py:737
 msgid "Delete intermediate data?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:757
+#: ../gui/wxpython/gui_modules/gmodeler.py:751
 #, python-format
 msgid "%d maps deleted from current mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:772
-#: ../gui/wxpython/gui_modules/gmodeler.py:885
+#: ../gui/wxpython/gui_modules/gmodeler.py:766
+#: ../gui/wxpython/gui_modules/gmodeler.py:879
 msgid ""
 "Current model is not empty. Do you want to store current settings to model "
 "file?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:775
-#: ../gui/wxpython/gui_modules/gmodeler.py:888
+#: ../gui/wxpython/gui_modules/gmodeler.py:769
+#: ../gui/wxpython/gui_modules/gmodeler.py:882
 msgid "Create new model?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:800
+#: ../gui/wxpython/gui_modules/gmodeler.py:794
 msgid "Choose model file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:818
+#: ../gui/wxpython/gui_modules/gmodeler.py:812
 #, python-format
 msgid "%(items)d items (%(actions)d actions) loaded into model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:825
-#: ../gui/wxpython/gui_modules/gmodeler.py:862
+#: ../gui/wxpython/gui_modules/gmodeler.py:819
+#: ../gui/wxpython/gui_modules/gmodeler.py:856
 #, python-format
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:835
-#: ../gui/wxpython/gui_modules/gmodeler.py:875
+#: ../gui/wxpython/gui_modules/gmodeler.py:829
+#: ../gui/wxpython/gui_modules/gmodeler.py:869
 #, python-format
 msgid "File <%s> saved"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:844
+#: ../gui/wxpython/gui_modules/gmodeler.py:838
 msgid "Choose file to save current model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:864
+#: ../gui/wxpython/gui_modules/gmodeler.py:858
 msgid "File already exists"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:912
+#: ../gui/wxpython/gui_modules/gmodeler.py:906
 msgid "Model is empty. Nothing to run."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:999
+#: ../gui/wxpython/gui_modules/gmodeler.py:993
 msgid "Model is empty. Nothing to validate."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1006
+#: ../gui/wxpython/gui_modules/gmodeler.py:1000
 #, python-format
 msgid ""
 "Model is not valid.\n"
@@ -8094,138 +8182,138 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1009
+#: ../gui/wxpython/gui_modules/gmodeler.py:1003
 msgid "Model is valid."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1070
-#: ../gui/wxpython/gui_modules/gmodeler.py:1113
+#: ../gui/wxpython/gui_modules/gmodeler.py:1064
+#: ../gui/wxpython/gui_modules/gmodeler.py:1107
 #, python-format
 msgid "Model exported to <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1078
+#: ../gui/wxpython/gui_modules/gmodeler.py:1072
 msgid "Choose file to save"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1080
+#: ../gui/wxpython/gui_modules/gmodeler.py:1074
 msgid "Python script (*.py)|*.py"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1094
+#: ../gui/wxpython/gui_modules/gmodeler.py:1088
 #, python-format
 msgid "File <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1096
+#: ../gui/wxpython/gui_modules/gmodeler.py:1090
 msgid "Save file"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1233
+#: ../gui/wxpython/gui_modules/gmodeler.py:1227
 msgid "wxGUI Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1235
+#: ../gui/wxpython/gui_modules/gmodeler.py:1229
 msgid ""
 "(C) 2010 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1366
+#: ../gui/wxpython/gui_modules/gmodeler.py:1360
 #, python-format
 msgid ""
 "Reading model file <%s> failed.\n"
 "Invalid file, unable to parse XML document."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1372
+#: ../gui/wxpython/gui_modules/gmodeler.py:1366
 msgid "Please wait, loading model..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1427
+#: ../gui/wxpython/gui_modules/gmodeler.py:1421
 msgid "Writing current settings to model file failed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1728
-#: ../gui/wxpython/gui_modules/gmodeler.py:1785
-#: ../gui/wxpython/gui_modules/gmodeler.py:1912
-#: ../gui/wxpython/gui_modules/menuform.py:384
+#: ../gui/wxpython/gui_modules/gmodeler.py:1722
+#: ../gui/wxpython/gui_modules/gmodeler.py:1779
+#: ../gui/wxpython/gui_modules/gmodeler.py:1906
+#: ../gui/wxpython/gui_modules/menuform.py:385
 msgid "unknown"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2010
+#: ../gui/wxpython/gui_modules/gmodeler.py:2004
 msgid "<not defined>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2020
+#: ../gui/wxpython/gui_modules/gmodeler.py:2014
 msgid "Data properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2027
+#: ../gui/wxpython/gui_modules/gmodeler.py:2021
 msgid "Name of raster map:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2029
+#: ../gui/wxpython/gui_modules/gmodeler.py:2023
 msgid "Name of vector map:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2031
+#: ../gui/wxpython/gui_modules/gmodeler.py:2025
 msgid "Name of element:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2224
+#: ../gui/wxpython/gui_modules/gmodeler.py:2218
 #: ../gui/wxpython/gui_modules/layertree.py:272
 msgid "Remove"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2228
+#: ../gui/wxpython/gui_modules/gmodeler.py:2222
 msgid "Disable"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+#: ../gui/wxpython/gui_modules/gmodeler.py:2225
 msgid "Enable"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2236
+#: ../gui/wxpython/gui_modules/gmodeler.py:2230
 msgid "Add control point"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2238
+#: ../gui/wxpython/gui_modules/gmodeler.py:2232
 msgid "Remove control point"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2245
+#: ../gui/wxpython/gui_modules/gmodeler.py:2239
 msgid "Intermediate"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2256
+#: ../gui/wxpython/gui_modules/gmodeler.py:2250
 #: ../gui/wxpython/gui_modules/layertree.py:286
 msgid "Properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2260
+#: ../gui/wxpython/gui_modules/gmodeler.py:2254
 msgid "Change ID"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2316
+#: ../gui/wxpython/gui_modules/gmodeler.py:2310
 msgid "Add new GRASS module to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2334
-#: ../gui/wxpython/gui_modules/gmodeler.py:3857
-#: ../gui/wxpython/gui_modules/gmodeler.py:4283
-#: ../gui/wxpython/gui_modules/preferences.py:1518
+#: ../gui/wxpython/gui_modules/gmodeler.py:2328
+#: ../gui/wxpython/gui_modules/gmodeler.py:3851
+#: ../gui/wxpython/gui_modules/gmodeler.py:4277
+#: ../gui/wxpython/gui_modules/preferences.py:1540
 msgid "Command"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2402
+#: ../gui/wxpython/gui_modules/gmodeler.py:2396
 msgid ""
 "Command not defined.\n"
 "\n"
 "Unable to add new action to the model."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2408
+#: ../gui/wxpython/gui_modules/gmodeler.py:2402
 #, python-format
 msgid ""
 "'%s' is not a GRASS module.\n"
@@ -8233,170 +8321,170 @@
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3018
+#: ../gui/wxpython/gui_modules/gmodeler.py:3012
 msgid "Action"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3023
+#: ../gui/wxpython/gui_modules/gmodeler.py:3017
 msgid "Validity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3031
+#: ../gui/wxpython/gui_modules/gmodeler.py:3025
 msgid "Valid:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3048
+#: ../gui/wxpython/gui_modules/gmodeler.py:3042
 msgid "Invalid:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3065
+#: ../gui/wxpython/gui_modules/gmodeler.py:3059
 msgid "Running:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3082
+#: ../gui/wxpython/gui_modules/gmodeler.py:3076
 msgid "Disabled:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3102
-#: ../gui/wxpython/gui_modules/gmodeler.py:3221
+#: ../gui/wxpython/gui_modules/gmodeler.py:3096
+#: ../gui/wxpython/gui_modules/gmodeler.py:3215
 msgid "Shape size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3159
+#: ../gui/wxpython/gui_modules/gmodeler.py:3153
 #: ../gui/wxpython/gui_modules/profile.py:1252
 msgid "Type"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3167
+#: ../gui/wxpython/gui_modules/gmodeler.py:3161
 msgid "Raster:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3184
+#: ../gui/wxpython/gui_modules/gmodeler.py:3178
 msgid "3D raster:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3201
+#: ../gui/wxpython/gui_modules/gmodeler.py:3195
 msgid "Vector:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3295
+#: ../gui/wxpython/gui_modules/gmodeler.py:3289
 #: ../gui/wxpython/gui_modules/layertree.py:374
 #: ../gui/wxpython/gui_modules/layertree.py:407
 msgid "Metadata"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3297
+#: ../gui/wxpython/gui_modules/gmodeler.py:3291
 msgid "Commands"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3317
+#: ../gui/wxpython/gui_modules/gmodeler.py:3311
 msgid "Apply properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3340
+#: ../gui/wxpython/gui_modules/gmodeler.py:3334
 msgid "Description:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3349
+#: ../gui/wxpython/gui_modules/gmodeler.py:3343
 msgid "Author(s):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3398
+#: ../gui/wxpython/gui_modules/gmodeler.py:3392
 msgid "Model parameters"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3545
+#: ../gui/wxpython/gui_modules/gmodeler.py:3539
 msgid "List of variables - right-click to delete"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3595
+#: ../gui/wxpython/gui_modules/gmodeler.py:3589
 #: ../gui/wxpython/gui_modules/dbm.py:885
 #: ../gui/wxpython/gui_modules/dbm.py:2226
 msgid "Data type"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3601
+#: ../gui/wxpython/gui_modules/gmodeler.py:3595
 msgid "Default value"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3553
+#: ../gui/wxpython/gui_modules/gmodeler.py:3547
 msgid "Add new variable"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3557
+#: ../gui/wxpython/gui_modules/gmodeler.py:3551
 msgid "integer"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3558
+#: ../gui/wxpython/gui_modules/gmodeler.py:3552
 msgid "float"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3559
+#: ../gui/wxpython/gui_modules/gmodeler.py:3553
 msgid "string"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3567
+#: ../gui/wxpython/gui_modules/gmodeler.py:3561
 msgid "Add new variable to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3715
+#: ../gui/wxpython/gui_modules/gmodeler.py:3709
 #, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3744
+#: ../gui/wxpython/gui_modules/gmodeler.py:3738
 msgid "Do you want to delete all variables from the model?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3746
+#: ../gui/wxpython/gui_modules/gmodeler.py:3740
 msgid "Delete variables"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3826
+#: ../gui/wxpython/gui_modules/gmodeler.py:3820
 msgid "Condition: "
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3828
+#: ../gui/wxpython/gui_modules/gmodeler.py:3822
 msgid "Condition: not defined"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3844
 msgid "Condition"
 msgstr ""
 msgid "ID"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+#: ../gui/wxpython/gui_modules/gmodeler.py:3892
 msgid "loop"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3906
+#: ../gui/wxpython/gui_modules/gmodeler.py:3900
 msgid "Loop properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3912
+#: ../gui/wxpython/gui_modules/gmodeler.py:3906
 msgid "List of items in loop"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3961
+#: ../gui/wxpython/gui_modules/gmodeler.py:3955
 msgid "List of items - right-click to delete"
 msgstr ""
 msgid "In block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3965
+#: ../gui/wxpython/gui_modules/gmodeler.py:3959
 msgid "Command / Condition"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4092
+#: ../gui/wxpython/gui_modules/gmodeler.py:4086
 #: ../gui/wxpython/gui_modules/dbm.py:1178
 #, python-format
 msgid ""
@@ -8404,38 +8492,38 @@
 "to delete them?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4095
+#: ../gui/wxpython/gui_modules/gmodeler.py:4089
 #: ../gui/wxpython/gui_modules/dbm.py:1181
 #: ../gui/wxpython/gui_modules/dbm.py:1227
 msgid "Delete records"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4149
+#: ../gui/wxpython/gui_modules/gmodeler.py:4143
 msgid "Normalize"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4247
+#: ../gui/wxpython/gui_modules/gmodeler.py:4241
 msgid "if-else"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4268
+#: ../gui/wxpython/gui_modules/gmodeler.py:4262
 msgid "If-else properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4274
+#: ../gui/wxpython/gui_modules/gmodeler.py:4268
 msgid "List of items in 'if' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4279
+#: ../gui/wxpython/gui_modules/gmodeler.py:4273
 msgid "List of items in 'else' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:983
+#: ../gui/wxpython/gui_modules/workspace.py:990
 #, python-format
 msgid "Unable to open file <%s> for reading."
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:996
+#: ../gui/wxpython/gui_modules/workspace.py:1003
 #, python-format
 msgid ""
 "Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -8444,7 +8532,7 @@
 "Number of skipped lines: %(line)d"
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:1214
+#: ../gui/wxpython/gui_modules/workspace.py:1221
 #, python-format
 msgid " row %d:"
 msgstr ""
@@ -8543,7 +8631,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1640
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4906
-#: ../gui/wxpython/gui_modules/preferences.py:2163
+#: ../gui/wxpython/gui_modules/preferences.py:2185
 msgid "Font size:"
 msgstr ""
@@ -8836,10 +8924,6 @@
 msgid "Size and style"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
-msgid "symbol:"
-msgstr ""
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3291
 msgid "eps file:"
 msgstr ""
@@ -8861,10 +8945,6 @@
 msgid "Size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
-msgid "size:"
-msgstr ""
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3322
 msgid "size from map table column:"
 msgstr ""
@@ -9046,9 +9126,9 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4596
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5081
 #: ../gui/wxpython/gui_modules/profile.py:967
-#: ../gui/wxpython/gui_modules/preferences.py:1240
-#: ../gui/wxpython/gui_modules/preferences.py:1372
-#: ../gui/wxpython/gui_modules/preferences.py:2114
+#: ../gui/wxpython/gui_modules/preferences.py:1244
+#: ../gui/wxpython/gui_modules/preferences.py:1394
+#: ../gui/wxpython/gui_modules/preferences.py:2136
 msgid "Font settings"
 msgstr ""
@@ -9327,151 +9407,151 @@
 "layer instead."
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:606
+#: ../gui/wxpython/gui_modules/goutput.py:605
 msgid "Save file as..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:721
+#: ../gui/wxpython/gui_modules/goutput.py:733
 msgid ""
 "Please note that the data are left in inconsistent state and may be corrupted"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:724
+#: ../gui/wxpython/gui_modules/goutput.py:736
 msgid "Command aborted"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:732
+#: ../gui/wxpython/gui_modules/goutput.py:744
 msgid "Command finished"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxnviz.py:302
+#: ../gui/wxpython/gui_modules/wxnviz.py:327
 #, python-format
 msgid "Vector map <%s> not found"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxnviz.py:354
-#: ../gui/wxpython/gui_modules/wxnviz.py:366
+#: ../gui/wxpython/gui_modules/wxnviz.py:392
+#: ../gui/wxpython/gui_modules/wxnviz.py:404
 #, python-format
 msgid "3d raster map <%s> not found"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:211
+#: ../gui/wxpython/gui_modules/toolbars.py:217
 msgid "3D view mode not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:212
-#: ../gui/wxpython/gui_modules/toolbars.py:229
+#: ../gui/wxpython/gui_modules/toolbars.py:218
+#: ../gui/wxpython/gui_modules/toolbars.py:235
 #, python-format
 msgid "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:213
+#: ../gui/wxpython/gui_modules/toolbars.py:219
 msgid ""
 "Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
 "(hopefully this will be fixed soon). Please keep an eye out for updated "
 "versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:221
-#: ../gui/wxpython/gui_modules/toolbars.py:1162
+#: ../gui/wxpython/gui_modules/toolbars.py:227
+#: ../gui/wxpython/gui_modules/toolbars.py:1108
 msgid "Digitize"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:228
+#: ../gui/wxpython/gui_modules/toolbars.py:234
 msgid "Vector digitizer not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:230
+#: ../gui/wxpython/gui_modules/toolbars.py:236
 msgid ""
 "Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
 "will be fixed soon). Please keep an eye out for updated versions of GRASS. "
 "In the meantime you can use \"v.digit\" from the Develop Vector menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:421
+#: ../gui/wxpython/gui_modules/toolbars.py:403
 msgid "Set map canvas for "
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:423
+#: ../gui/wxpython/gui_modules/toolbars.py:405
 msgid " / Zoom to map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:790
+#: ../gui/wxpython/gui_modules/toolbars.py:737
 msgid "Duplicate attributes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:867
+#: ../gui/wxpython/gui_modules/toolbars.py:814
 msgid "Copy features from (background) vector map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:875
+#: ../gui/wxpython/gui_modules/toolbars.py:822
 msgid "Flip selected lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:883
+#: ../gui/wxpython/gui_modules/toolbars.py:830
 msgid "Merge selected lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:891
+#: ../gui/wxpython/gui_modules/toolbars.py:838
 msgid "Break selected lines/boundaries at intersection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:899
+#: ../gui/wxpython/gui_modules/toolbars.py:846
 msgid "Snap selected lines/boundaries (only to nodes)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:907
+#: ../gui/wxpython/gui_modules/toolbars.py:854
 msgid "Connect selected lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:915
+#: ../gui/wxpython/gui_modules/toolbars.py:862
 msgid "Query features"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:923
+#: ../gui/wxpython/gui_modules/toolbars.py:870
 msgid "Z bulk-labeling of 3D lines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:931
+#: ../gui/wxpython/gui_modules/toolbars.py:878
 msgid "Feature type conversion"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1042
+#: ../gui/wxpython/gui_modules/toolbars.py:989
 msgid "Vector map is not 3D. Operation canceled."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1107
-#: ../gui/wxpython/gui_modules/toolbars.py:1189
-#: ../gui/wxpython/gui_modules/toolbars.py:1268
+#: ../gui/wxpython/gui_modules/toolbars.py:1053
+#: ../gui/wxpython/gui_modules/toolbars.py:1135
+#: ../gui/wxpython/gui_modules/toolbars.py:1214
 msgid "Select vector map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1145
+#: ../gui/wxpython/gui_modules/toolbars.py:1091
 #, python-format
 msgid "Please wait, opening vector map <%s> for editing..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1197
+#: ../gui/wxpython/gui_modules/toolbars.py:1143
 #, python-format
 msgid "Do you want to save changes in vector map <%s>?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1199
+#: ../gui/wxpython/gui_modules/toolbars.py:1145
 msgid "Save changes?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1206
+#: ../gui/wxpython/gui_modules/toolbars.py:1152
 #, python-format
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1217
+#: ../gui/wxpython/gui_modules/toolbars.py:1163
 #, python-format
 msgid "Editing of vector map <%s> successfully finished"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1274
-#: ../gui/wxpython/gui_modules/toolbars.py:1279
+#: ../gui/wxpython/gui_modules/toolbars.py:1220
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
 msgid "New vector map"
 msgstr ""
@@ -9730,7 +9810,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/dbm.py:1117
-#: ../gui/wxpython/gui_modules/preferences.py:626
+#: ../gui/wxpython/gui_modules/preferences.py:642
 msgid "Edit selected record"
 msgstr ""
@@ -9748,14 +9828,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/dbm.py:1129
-#: ../gui/wxpython/gui_modules/gdialogs.py:861
-#: ../gui/wxpython/gui_modules/gdialogs.py:1389
+#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:1390
 msgid "Select all"
 msgstr ""
 #: ../gui/wxpython/gui_modules/dbm.py:1130
-#: ../gui/wxpython/gui_modules/gdialogs.py:863
-#: ../gui/wxpython/gui_modules/gdialogs.py:1390
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
+#: ../gui/wxpython/gui_modules/gdialogs.py:1391
 msgid "Deselect all"
 msgstr ""
@@ -10021,7 +10101,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gdialogs.py:204
-#: ../gui/wxpython/gui_modules/preferences.py:1553
+#: ../gui/wxpython/gui_modules/preferences.py:1575
 msgid "Add created map into layer tree"
 msgstr ""
@@ -10077,8 +10157,8 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gdialogs.py:631
-#: ../gui/wxpython/gui_modules/preferences.py:1259
-#: ../gui/wxpython/gui_modules/preferences.py:1388
+#: ../gui/wxpython/gui_modules/preferences.py:1263
+#: ../gui/wxpython/gui_modules/preferences.py:1410
 msgid "Set font"
 msgstr ""
@@ -10088,96 +10168,104 @@
 "Double-click to change options"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:768
+#: ../gui/wxpython/gui_modules/gdialogs.py:739
+msgid "&Add"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:741
+msgid "Add selected map layers to current display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:769
 msgid "Map layer type:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:780
+#: ../gui/wxpython/gui_modules/gdialogs.py:781
 msgid "Select toggle"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:787
+#: ../gui/wxpython/gui_modules/gdialogs.py:788
 msgid "Mapset:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:797
+#: ../gui/wxpython/gui_modules/gdialogs.py:798
 msgid "Filter:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
 msgid "List of maps:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:863
 msgid "Invert selection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:936
+#: ../gui/wxpython/gui_modules/gdialogs.py:937
 msgid "Multiple import"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:950
+#: ../gui/wxpython/gui_modules/gdialogs.py:951
 #, python-format
 msgid " List of %s layers "
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1151
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
 msgid "Add linked layers into layer tree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1158
+#: ../gui/wxpython/gui_modules/gdialogs.py:1159
 msgid "&Link"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1159
+#: ../gui/wxpython/gui_modules/gdialogs.py:1160
 msgid "Link selected layers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1253
+#: ../gui/wxpython/gui_modules/gdialogs.py:1254
 msgid "Import DXF layers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1257
+#: ../gui/wxpython/gui_modules/gdialogs.py:1258
 msgid "Choose DXF file to import"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1353
+#: ../gui/wxpython/gui_modules/gdialogs.py:1354
 msgid "Layer name"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1354
+#: ../gui/wxpython/gui_modules/gdialogs.py:1355
 msgid "Name for GRASS map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1436
+#: ../gui/wxpython/gui_modules/gdialogs.py:1437
 msgid "Set Map Layer Opacity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1460
+#: ../gui/wxpython/gui_modules/gdialogs.py:1461
 msgid "transparent"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1463
+#: ../gui/wxpython/gui_modules/gdialogs.py:1464
 msgid "opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1582
+#: ../gui/wxpython/gui_modules/gdialogs.py:1583
 msgid "Set image size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1591
+#: ../gui/wxpython/gui_modules/gdialogs.py:1592
 msgid "Image size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1638
+#: ../gui/wxpython/gui_modules/gdialogs.py:1639
 msgid "Template:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1676
+#: ../gui/wxpython/gui_modules/gdialogs.py:1677
 msgid "GRASS GIS SQL Query Utility"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1687
+#: ../gui/wxpython/gui_modules/gdialogs.py:1688
 msgid " SQL statement "
 msgstr ""
@@ -10460,55 +10548,55 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/layertree.py:743
-#: ../gui/wxpython/gui_modules/layertree.py:1310
+#: ../gui/wxpython/gui_modules/layertree.py:1309
 msgid "Click to edit layer settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:788
+#: ../gui/wxpython/gui_modules/layertree.py:784
 msgid "(double click to set properties)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:794
+#: ../gui/wxpython/gui_modules/layertree.py:790
 msgid "3d raster"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:797
+#: ../gui/wxpython/gui_modules/layertree.py:793
 msgid "RGB"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:800
+#: ../gui/wxpython/gui_modules/layertree.py:796
 msgid "HIS"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:806
+#: ../gui/wxpython/gui_modules/layertree.py:802
 msgid "raster cell numbers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:809
+#: ../gui/wxpython/gui_modules/layertree.py:805
 msgid "raster flow arrows"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:815
+#: ../gui/wxpython/gui_modules/layertree.py:811
 msgid "thematic area (choropleth) map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:818
+#: ../gui/wxpython/gui_modules/layertree.py:814
 msgid "thematic charts"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:821
+#: ../gui/wxpython/gui_modules/layertree.py:817
 msgid "grid"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:824
+#: ../gui/wxpython/gui_modules/layertree.py:820
 msgid "geodesic line"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:827
+#: ../gui/wxpython/gui_modules/layertree.py:823
 msgid "rhumbline"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:830
+#: ../gui/wxpython/gui_modules/layertree.py:826
 msgid "vector labels"
 msgstr ""
@@ -10516,152 +10604,152 @@
 msgid "Please wait, updating data..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:1389
+#: ../gui/wxpython/gui_modules/layertree.py:1388
 msgid "opacity:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:1406
+#: ../gui/wxpython/gui_modules/layertree.py:1405
 #, python-format
 msgid "Map <%s> not found."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:147
-#: ../gui/wxpython/gui_modules/menuform.py:1654
+#: ../gui/wxpython/gui_modules/menuform.py:148
+#: ../gui/wxpython/gui_modules/menuform.py:1647
 msgid "Select Color"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:451
+#: ../gui/wxpython/gui_modules/menuform.py:452
 #, python-format
 msgid "Parameter element '%(element)s' not found: '%(value)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:472
+#: ../gui/wxpython/gui_modules/menuform.py:473
 #, python-format
 msgid "Flag not found: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:501
+#: ../gui/wxpython/gui_modules/menuform.py:502
 #, python-format
 msgid "Parameter '%(name)s' (%(desc)s) is missing."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:530
+#: ../gui/wxpython/gui_modules/menuform.py:531
 msgid "<required>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:797
+#: ../gui/wxpython/gui_modules/menuform.py:798
 msgid "Enter parameters for '"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:808
+#: ../gui/wxpython/gui_modules/menuform.py:809
 msgid "Close this window without executing the command (Ctrl+Q)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:828
+#: ../gui/wxpython/gui_modules/menuform.py:829
 msgid "Run the command (Ctrl+R)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:831
+#: ../gui/wxpython/gui_modules/menuform.py:832
 msgid "C&opy"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:846
+#: ../gui/wxpython/gui_modules/menuform.py:847
 msgid "Show manual page of the command (Ctrl+H)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:867
+#: ../gui/wxpython/gui_modules/menuform.py:868
 msgid "Add created map(s) into layer tree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:883
 msgid "Close dialog on finish"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:884
+#: ../gui/wxpython/gui_modules/menuform.py:885
 msgid ""
 "Close dialog when command is successfully finished. Change this settings in "
 "Preferences dialog ('Command' tab)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1059
+#: ../gui/wxpython/gui_modules/menuform.py:1060
 #, python-format
 msgid "'%s' copied to clipboard"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1121
-#: ../gui/wxpython/gui_modules/menuform.py:1134
+#: ../gui/wxpython/gui_modules/menuform.py:1122
+#: ../gui/wxpython/gui_modules/menuform.py:1135
 msgid "Required"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1124
+#: ../gui/wxpython/gui_modules/menuform.py:1125
 msgid "Optional"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1174
+#: ../gui/wxpython/gui_modules/menuform.py:1168
 msgid "Manual"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1215
-#: ../gui/wxpython/gui_modules/menuform.py:1726
+#: ../gui/wxpython/gui_modules/menuform.py:1208
+#: ../gui/wxpython/gui_modules/menuform.py:1719
 msgid "Parameterized in model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1290
+#: ../gui/wxpython/gui_modules/menuform.py:1283
 msgid "[multiple]"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1337
+#: ../gui/wxpython/gui_modules/menuform.py:1330
 msgid "valid range"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1499
+#: ../gui/wxpython/gui_modules/menuform.py:1492
 msgid "Format"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1501
+#: ../gui/wxpython/gui_modules/menuform.py:1494
 msgid "Native / Linked OGR"
 msgstr ""
 msgid "Direct OGR"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1673
+#: ../gui/wxpython/gui_modules/menuform.py:1666
 msgid "Transparent"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1689
+#: ../gui/wxpython/gui_modules/menuform.py:1682
 #, python-format
 msgid "Choose %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1717
+#: ../gui/wxpython/gui_modules/menuform.py:1710
 msgid "or enter values interactively"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2133
+#: ../gui/wxpython/gui_modules/menuform.py:2126
 #, python-format
 msgid "Error in %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2166
-#: ../gui/wxpython/gui_modules/menuform.py:2169
+#: ../gui/wxpython/gui_modules/menuform.py:2159
+#: ../gui/wxpython/gui_modules/menuform.py:2162
 #, python-format
 msgid "Unable to fetch interface description for command '%s'."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2280
+#: ../gui/wxpython/gui_modules/menuform.py:2276
 #, python-format
 msgid "Unable to parse command '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2284
+#: ../gui/wxpython/gui_modules/menuform.py:2280
 #, python-format
 msgid "%(cmd)s: parameter '%(key)s' not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2409
+#: ../gui/wxpython/gui_modules/menuform.py:2441
 #, python-format
 msgid "usage: %s <grass command>"
 msgstr ""
@@ -10671,113 +10759,113 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/globalvar.py:119
-#: ../gui/wxpython/gui_modules/preferences.py:1798
+#: ../gui/wxpython/gui_modules/preferences.py:1820
 msgid "Projection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:269
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
 msgid "Easting"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:270
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:290
 msgid "Northing"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:271
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:291
 msgid "Elevation"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:272
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:292
 msgid "Surface map elevation"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:273
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:293
 msgid "Surface map color"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:282
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:302
 msgid "XY distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:283
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:303
 msgid "XYZ distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:284
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:304
 msgid "Distance along surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:309
 msgid "Distance along exag. surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:296
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:316
 msgid "No point on surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:301
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:321
 msgid "Function not implemented yet"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:602
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:639
 msgid "Loading raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:606
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:643
 msgid "Loading 3d raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:612
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:649
 msgid "failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:614
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:651
 #, python-format
 msgid "Unsupported layer type '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:668
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:729
 msgid "Unable to unload raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:673
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:734
 msgid "Unable to unload 3d raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:674
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:735
 msgid "3d raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:681
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:742
 msgid "unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:725
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:786
 #, python-format
 msgid "Loading vector map <%(name)s> (%(type)s) failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:781
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:842
 #, python-format
 msgid "Unable to unload vector map <%(name)s> (%(type)s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:784
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:845
 #, python-format
 msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1071
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1148
 #, python-format
 msgid "Vector point layer not found (id = %d)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1073
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1150
 #, python-format
 msgid "Unable to set data layer properties (id = %d)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1076
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1153
 #, python-format
 msgid ""
 "Setting data layer properties failed.\n"
@@ -10785,99 +10873,104 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:416
+#: ../gui/wxpython/gui_modules/preferences.py:427
 msgid "Segment break"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:621
+#: ../gui/wxpython/gui_modules/preferences.py:637
 msgid "Collapse all except PERMANENT and current"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:622
+#: ../gui/wxpython/gui_modules/preferences.py:638
 msgid "Collapse all except PERMANENT"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:623
+#: ../gui/wxpython/gui_modules/preferences.py:639
 msgid "Collapse all except current"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:624
+#: ../gui/wxpython/gui_modules/preferences.py:640
 msgid "Collapse all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:625
+#: ../gui/wxpython/gui_modules/preferences.py:641
 msgid "Expand all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:627
+#: ../gui/wxpython/gui_modules/preferences.py:643
 msgid "Display selected"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:635
+#: ../gui/wxpython/gui_modules/preferences.py:651
 msgid "Classic (labels only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:636
+#: ../gui/wxpython/gui_modules/preferences.py:652
 msgid "Combined (labels and module names)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:637
+#: ../gui/wxpython/gui_modules/preferences.py:653
 msgid "Professional (module names only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:657
+#: ../gui/wxpython/gui_modules/preferences.py:673
 msgid "box"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:658
+#: ../gui/wxpython/gui_modules/preferences.py:674
 msgid "sphere"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:659
+#: ../gui/wxpython/gui_modules/preferences.py:675
 msgid "cube"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:660
+#: ../gui/wxpython/gui_modules/preferences.py:676
 msgid "diamond"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:661
+#: ../gui/wxpython/gui_modules/preferences.py:677
 msgid "dtree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:662
+#: ../gui/wxpython/gui_modules/preferences.py:678
 msgid "ctree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:663
+#: ../gui/wxpython/gui_modules/preferences.py:679
 msgid "aster"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:664
+#: ../gui/wxpython/gui_modules/preferences.py:680
 msgid "gyro"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:665
+#: ../gui/wxpython/gui_modules/preferences.py:681
 msgid "histogram"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:727
+#: ../gui/wxpython/gui_modules/preferences.py:713
 #, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:737
+#, python-format
 msgid ""
 "Error: Reading settings from file <%(file)s> failed.\n"
-"       Details: %(detail)s\n"
-"       Line: '%(line)s'"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:750
+#: ../gui/wxpython/gui_modules/preferences.py:758
 msgid "Cannot create directory for settings [home]/.grass7"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:751
+#: ../gui/wxpython/gui_modules/preferences.py:759
 msgid "Error saving preferences"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:787
+#: ../gui/wxpython/gui_modules/preferences.py:794
 #, python-format
 msgid ""
 "Writing settings to file <%(file)s> failed.\n"
@@ -10885,276 +10978,282 @@
 "Details: %(detail)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/gui_modules/preferences.py:893
 msgid "Unable to set "
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:914
-#: ../gui/wxpython/gui_modules/preferences.py:920
+#: ../gui/wxpython/gui_modules/preferences.py:919
+#: ../gui/wxpython/gui_modules/preferences.py:925
 #, python-format
 msgid "Unable to parse settings '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:931
+#: ../gui/wxpython/gui_modules/preferences.py:936
 msgid "User settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:951
+#: ../gui/wxpython/gui_modules/preferences.py:956
 msgid "Set to default"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:959
+#: ../gui/wxpython/gui_modules/preferences.py:964
 msgid "Revert settings to default and apply changes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1021
+#: ../gui/wxpython/gui_modules/preferences.py:1026
 msgid "Settings applied to current session but not saved"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1039
+#: ../gui/wxpython/gui_modules/preferences.py:1044
 #, python-format
 msgid "Settings saved to file '%s'."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1070
+#: ../gui/wxpython/gui_modules/preferences.py:1075
 msgid "Key column cannot be empty string."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1084
+#: ../gui/wxpython/gui_modules/preferences.py:1089
 msgid "GUI Settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1107
-msgid "General settings"
+#: ../gui/wxpython/gui_modules/preferences.py:1115
+msgid "Layer Manager settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1118
-msgid "Element list:"
+#: ../gui/wxpython/gui_modules/preferences.py:1126
+msgid "Ask when removing map layer from layer tree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1140
-msgid "Save current window layout as default"
+#: ../gui/wxpython/gui_modules/preferences.py:1136
+msgid "Ask when quiting wxGUI or closing display"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1143
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1146
 #: ../gui/wxpython/gui_modules/preferences.py:1156
-msgid "Layer Manager settings"
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1167
-msgid "Ask when removing map layer from layer tree"
+#: ../gui/wxpython/gui_modules/preferences.py:1169
+msgid "Automatically copy selected text to clipboard (in Command console)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1177
-msgid "Ask when quiting wxGUI or closing display"
+#: ../gui/wxpython/gui_modules/preferences.py:1183
+msgid "Workspace settings"
 msgstr ""
 #: ../gui/wxpython/gui_modules/preferences.py:1191
-msgid "Workspace settings"
-msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1199
 msgid "Suppress positioning Map Display Window(s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1211
+#: ../gui/wxpython/gui_modules/preferences.py:1203
 msgid "Suppress positioning Layer Manager window"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1254
+#: ../gui/wxpython/gui_modules/preferences.py:1214
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1217
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1258
 msgid "Font for command output:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1268
+#: ../gui/wxpython/gui_modules/preferences.py:1272
 msgid "Appearance settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1280
+#: ../gui/wxpython/gui_modules/preferences.py:1283
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1302
 msgid "Menu style:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1304
+#: ../gui/wxpython/gui_modules/preferences.py:1326
 msgid "Height of map selection popup window (in pixels):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1328
+#: ../gui/wxpython/gui_modules/preferences.py:1350
 msgid "Icon theme:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1346
+#: ../gui/wxpython/gui_modules/preferences.py:1368
 msgid ""
 "Note: For changing the icon theme, you must save the settings and restart "
 "this GUI."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1368
+#: ../gui/wxpython/gui_modules/preferences.py:1390
 msgid "Map Display"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1383
+#: ../gui/wxpython/gui_modules/preferences.py:1405
 msgid "Default font for GRASS displays:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1400
+#: ../gui/wxpython/gui_modules/preferences.py:1422
 msgid "Default display settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1412
+#: ../gui/wxpython/gui_modules/preferences.py:1434
 msgid "Display driver:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1432
+#: ../gui/wxpython/gui_modules/preferences.py:1454
 msgid "Statusbar mode:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1484
+#: ../gui/wxpython/gui_modules/preferences.py:1506
 msgid "Enable auto-rendering"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1497
+#: ../gui/wxpython/gui_modules/preferences.py:1519
 msgid "Enable auto-zooming to selected map layer"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1521
+#: ../gui/wxpython/gui_modules/preferences.py:1543
 msgid "Command dialog settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1543
+#: ../gui/wxpython/gui_modules/preferences.py:1565
 msgid "Close dialog when command is successfully finished"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1564
+#: ../gui/wxpython/gui_modules/preferences.py:1586
 msgid "Allow interactive input"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1574
+#: ../gui/wxpython/gui_modules/preferences.py:1596
 msgid "Verbosity level:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1593
+#: ../gui/wxpython/gui_modules/preferences.py:1615
 msgid "Raster settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1604
+#: ../gui/wxpython/gui_modules/preferences.py:1626
 msgid "Make null cells opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1615
+#: ../gui/wxpython/gui_modules/preferences.py:1637
 msgid "Default color table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1641
+#: ../gui/wxpython/gui_modules/preferences.py:1663
 msgid "Vector settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1647
+#: ../gui/wxpython/gui_modules/preferences.py:1669
 msgid "Display:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1677
+#: ../gui/wxpython/gui_modules/preferences.py:1699
 msgid "Highlighting"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1693
+#: ../gui/wxpython/gui_modules/preferences.py:1715
 msgid "Line width (in pixels):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1716
+#: ../gui/wxpython/gui_modules/preferences.py:1738
 msgid "Data browser"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1721
+#: ../gui/wxpython/gui_modules/preferences.py:1743
 msgid "Left mouse double click:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1733
+#: ../gui/wxpython/gui_modules/preferences.py:1755
 msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1744
+#: ../gui/wxpython/gui_modules/preferences.py:1766
 msgid "Ask when deleting data record(s) from table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1765
+#: ../gui/wxpython/gui_modules/preferences.py:1787
 msgid "Create table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1772
+#: ../gui/wxpython/gui_modules/preferences.py:1794
 msgid "Key column:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1805
+#: ../gui/wxpython/gui_modules/preferences.py:1827
 msgid "Projection statusbar settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1831
+#: ../gui/wxpython/gui_modules/preferences.py:1853
 msgid "Proj.4 string (required):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1847
+#: ../gui/wxpython/gui_modules/preferences.py:1869
 msgid "EPSG file:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1862
+#: ../gui/wxpython/gui_modules/preferences.py:1884
 msgid ""
 "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
 "directly."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1870
+#: ../gui/wxpython/gui_modules/preferences.py:1892
 msgid "&Load EPSG codes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1881
+#: ../gui/wxpython/gui_modules/preferences.py:1903
 msgid "Coordinates format"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1890
+#: ../gui/wxpython/gui_modules/preferences.py:1912
 msgid "LL projections"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1909
+#: ../gui/wxpython/gui_modules/preferences.py:1931
 msgid "Precision:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1947
+#: ../gui/wxpython/gui_modules/preferences.py:1969
 #, python-format
 msgid "Unable to read EPSG codes: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1976
-#: ../gui/wxpython/gui_modules/preferences.py:1985
-#: ../gui/wxpython/gui_modules/preferences.py:1995
+#: ../gui/wxpython/gui_modules/preferences.py:1998
+#: ../gui/wxpython/gui_modules/preferences.py:2007
+#: ../gui/wxpython/gui_modules/preferences.py:2017
 #, python-format
 msgid "EPSG code %s not found"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2003
+#: ../gui/wxpython/gui_modules/preferences.py:2025
 msgid "Select default display font"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2028
+#: ../gui/wxpython/gui_modules/preferences.py:2050
 msgid "Select output font"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2121
+#: ../gui/wxpython/gui_modules/preferences.py:2143
 msgid "Select font:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2145
+#: ../gui/wxpython/gui_modules/preferences.py:2167
 msgid "Character encoding:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2263
+#: ../gui/wxpython/gui_modules/preferences.py:2285
 msgid "Manage access to mapsets"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2276
+#: ../gui/wxpython/gui_modules/preferences.py:2298
 msgid ""
 "Check a mapset to make it accessible, uncheck it to hide it.\n"
 "  Notes:\n"
@@ -11163,11 +11262,11 @@
 "    - You may only write to mapsets which you own."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2350
+#: ../gui/wxpython/gui_modules/preferences.py:2372
 msgid "Mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2351
+#: ../gui/wxpython/gui_modules/preferences.py:2373
 msgid "Owner"
 msgstr ""
Modified: grass/trunk/locale/po/grasswxpy_es.po
--- grass/trunk/locale/po/grasswxpy_es.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasswxpy_es.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -4,13 +4,13 @@
 # Carlos Davila <carluti at users.sourceforge.net>, 2008.
 # Javier Garcia Prieto <fjgarciaprieto hotmail.com>, 2009.
-#: ../gui/wxpython/gui_modules/psmap.py:1097
+#: ../gui/wxpython/gui_modules/psmap.py:1096
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2211
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_es\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2009-12-09 13:20-0600\n"
 "Last-Translator: Javier Garcia Prieto <fjgarciaprieto hotmail.com>\n"
 "Language-Team: Español <grass-translations at lists.osgeo.org>\n"
@@ -21,59 +21,75 @@
 "X-Generator: KBabel 1.11.4\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
-#: ../gui/wxpython/wxgui.py:96
+#: ../gui/wxpython/wxgui.py:97
 msgid "GRASS GIS Layer Manager"
 msgstr "Administrador de capas SIG GRASS."
-#: ../gui/wxpython/wxgui.py:136
+#: ../gui/wxpython/wxgui.py:139
 #, fuzzy
-msgid "Main Toolbar"
+msgid "Data Toolbar"
 msgstr "Barra de herramientas de mapa."
-#: ../gui/wxpython/wxgui.py:144
+#: ../gui/wxpython/wxgui.py:147
 #, fuzzy
+msgid "Workspace Toolbar"
+msgstr "Entorno de trabajo."
+#: ../gui/wxpython/wxgui.py:155
+#, fuzzy
+msgid "Misc Toolbar"
+msgstr "Barra de herramientas de mapa."
+#: ../gui/wxpython/wxgui.py:163
+#, fuzzy
 msgid "Tools Toolbar"
-#: ../gui/wxpython/wxgui.py:231
+#: ../gui/wxpython/wxgui.py:250
 #, fuzzy
 msgid "Map layers"
 msgstr "Capas de mapas."
-#: ../gui/wxpython/wxgui.py:235 ../gui/wxpython/wxgui.py:375
+#: ../gui/wxpython/wxgui.py:254 ../gui/wxpython/wxgui.py:407
 #, fuzzy
 msgid "Command console"
 msgstr "Comando finalizado."
-#: ../gui/wxpython/wxgui.py:239
+#: ../gui/wxpython/wxgui.py:260
 msgid "Search module"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:252 ../gui/wxpython/gui_modules/toolbars.py:207
+#: ../gui/wxpython/wxgui.py:267
+#: ../gui/wxpython/gui_modules/preferences.py:1156
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:282 ../gui/wxpython/gui_modules/toolbars.py:211
 msgid "3D view"
 msgstr "Vista 3D."
-#: ../gui/wxpython/wxgui.py:296
+#: ../gui/wxpython/wxgui.py:328
 #, python-format
 msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:315
+#: ../gui/wxpython/wxgui.py:347
 #, fuzzy
 msgid "Choose model to run"
 msgstr "Seleccionar la proyección."
-#: ../gui/wxpython/wxgui.py:317 ../gui/wxpython/gui_modules/gmodeler.py:802
-#: ../gui/wxpython/gui_modules/gmodeler.py:846
+#: ../gui/wxpython/wxgui.py:349 ../gui/wxpython/gui_modules/gmodeler.py:796
+#: ../gui/wxpython/gui_modules/gmodeler.py:840
 msgid "GRASS Model File (*.gxm)|*.gxm"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:326 ../gui/wxpython/gui_modules/gmodeler.py:1117
+#: ../gui/wxpython/wxgui.py:358 ../gui/wxpython/gui_modules/gmodeler.py:1111
 #, fuzzy
 msgid "Validating model..."
 msgstr "Intervalo válido."
-#: ../gui/wxpython/wxgui.py:330 ../gui/wxpython/gui_modules/gmodeler.py:919
+#: ../gui/wxpython/wxgui.py:362 ../gui/wxpython/gui_modules/gmodeler.py:913
 #, python-format
 msgid ""
 "Model is not valid. Do you want to run the model anyway?\n"
@@ -81,57 +97,57 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:332 ../gui/wxpython/gui_modules/gmodeler.py:921
+#: ../gui/wxpython/wxgui.py:364 ../gui/wxpython/gui_modules/gmodeler.py:915
 msgid "Run model?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:339 ../gui/wxpython/gui_modules/gmodeler.py:984
+#: ../gui/wxpython/wxgui.py:371 ../gui/wxpython/gui_modules/gmodeler.py:978
 msgid "Running model..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:389 ../gui/wxpython/wxgui.py:1476
+#: ../gui/wxpython/wxgui.py:421 ../gui/wxpython/wxgui.py:1500
 msgid "Do you want to save changes in the workspace?"
 msgstr "¿Desea guardar los cambios en el entorno de trabajo?"
-#: ../gui/wxpython/wxgui.py:391 ../gui/wxpython/wxgui.py:1478
+#: ../gui/wxpython/wxgui.py:423 ../gui/wxpython/wxgui.py:1502
 msgid "Do you want to store current settings to workspace file?"
 msgstr ""
 "¿Desea guardar los ajustes actuales en un archivo de entorno de trabajo?"
-#: ../gui/wxpython/wxgui.py:398
+#: ../gui/wxpython/wxgui.py:430
 #, python-format
 msgid "Close Map Display %d"
 msgstr "Cerrar ventana de visualización del mapa % d ."
-#: ../gui/wxpython/wxgui.py:497 ../gui/wxpython/wxgui.py:1159
+#: ../gui/wxpython/wxgui.py:529 ../gui/wxpython/wxgui.py:1155
 msgid "Selected map layer is not vector."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:502
+#: ../gui/wxpython/wxgui.py:534
 #, fuzzy
 msgid "Editing is allowed only for vector maps from the current mapset."
 msgstr "Crea la topología para un mapa vectorial de GRASS."
-#: ../gui/wxpython/wxgui.py:517
+#: ../gui/wxpython/wxgui.py:549
 #, fuzzy
 msgid "Choose script file to run"
 msgstr "Seleccionar directorio de entrada de datos hacia GRASS:"
-#: ../gui/wxpython/wxgui.py:519
+#: ../gui/wxpython/wxgui.py:551
 msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:530
+#: ../gui/wxpython/wxgui.py:562
 #, fuzzy, python-format
 msgid "Script file '%s' doesn't exist. Operation cancelled."
 msgstr "Se necesitan al menos %d GCP. Operación cancelada."
-#: ../gui/wxpython/wxgui.py:534
+#: ../gui/wxpython/wxgui.py:566
 #, python-format
 msgid "Launching script '%s'..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:549
+#: ../gui/wxpython/wxgui.py:581
 msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
 msgstr ""
@@ -139,7 +155,7 @@
 "\n"
 "Detalles: %(err)s"
-#: ../gui/wxpython/wxgui.py:551 ../gui/wxpython/wxgui.py:572
+#: ../gui/wxpython/wxgui.py:583 ../gui/wxpython/wxgui.py:604
 #: ../gui/wxpython/scripts/r.li.setup.py:337
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1686
 #: ../gui/wxpython/gui_modules/mapdisp.py:367
@@ -154,8 +170,8 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:1029
 #: ../gui/wxpython/gui_modules/vdigit.py:1221
 #: ../gui/wxpython/gui_modules/vdigit.py:1247
-#: ../gui/wxpython/gui_modules/gmodeler.py:1438
-#: ../gui/wxpython/gui_modules/workspace.py:984
+#: ../gui/wxpython/gui_modules/gmodeler.py:1432
+#: ../gui/wxpython/gui_modules/workspace.py:991
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5365
 #: ../gui/wxpython/gui_modules/dbm.py:165
 #: ../gui/wxpython/gui_modules/dbm.py:1407
@@ -174,40 +190,40 @@
 #: ../gui/wxpython/gui_modules/profile.py:598
 #: ../gui/wxpython/gui_modules/layertree.py:505
 #: ../gui/wxpython/gui_modules/layertree.py:536
-#: ../gui/wxpython/gui_modules/preferences.py:1071
-#: ../gui/wxpython/gui_modules/preferences.py:1948
-#: ../gui/wxpython/gui_modules/preferences.py:1977
-#: ../gui/wxpython/gui_modules/preferences.py:1986
-#: ../gui/wxpython/gui_modules/preferences.py:1996
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+#: ../gui/wxpython/gui_modules/preferences.py:1970
+#: ../gui/wxpython/gui_modules/preferences.py:1999
+#: ../gui/wxpython/gui_modules/preferences.py:2008
+#: ../gui/wxpython/gui_modules/preferences.py:2018
 #: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:466
 #: ../gui/wxpython/gis_set.py:502 ../gui/wxpython/gis_set.py:568
 #: ../gui/wxpython/gis_set.py:725
 msgid "Error"
 msgstr "Error."
-#: ../gui/wxpython/wxgui.py:557
+#: ../gui/wxpython/wxgui.py:589
 #, python-format
 msgid ""
 "Current location is <%(loc)s>.\n"
 "Current mapset is <%(mapset)s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:560 ../gui/wxpython/wxgui.py:576
+#: ../gui/wxpython/wxgui.py:592 ../gui/wxpython/wxgui.py:608
 #: ../gui/wxpython/gui_modules/ghelp.py:563
 msgid "Info"
 msgstr "Información."
-#: ../gui/wxpython/wxgui.py:571
+#: ../gui/wxpython/wxgui.py:603
 msgid "Unable to switch to mapset <%s>."
 msgstr "No se puede crear el mapa vectorial <%s>."
-#: ../gui/wxpython/wxgui.py:575
+#: ../gui/wxpython/wxgui.py:607
 msgid "Current mapset is <%s>."
 msgstr "Cambiar directorio de mapas actual."
-#: ../gui/wxpython/wxgui.py:652
+#: ../gui/wxpython/wxgui.py:676
 msgid ""
 "Current workspace is not empty. Do you want to store current settings to "
 "workspace file?"
@@ -215,19 +231,19 @@
 "El área de trabajo actual no está vacía. ¿Desea guardar los ajustes actuales "
 "en un archivo de espacio de trabajo?"
-#: ../gui/wxpython/wxgui.py:655
+#: ../gui/wxpython/wxgui.py:679
 msgid "Create new workspace?"
 msgstr "¿Crear un nuevo entorno de trabajo?"
-#: ../gui/wxpython/wxgui.py:681
+#: ../gui/wxpython/wxgui.py:705
 msgid "Choose workspace file"
 msgstr "Seleccione el espacio de trabajo."
-#: ../gui/wxpython/wxgui.py:682 ../gui/wxpython/wxgui.py:889
+#: ../gui/wxpython/wxgui.py:706 ../gui/wxpython/wxgui.py:885
 msgid "GRASS Workspace File (*.gxw)|*.gxw"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:717
+#: ../gui/wxpython/wxgui.py:741
 msgid ""
 "Reading workspace file <%s> failed.\n"
@@ -237,67 +253,68 @@
 "espacio de trabajo (.GRC) <%s> ha fallado. Archivo no válido. No ha sido "
 "posible analizar el documento XML."
-#: ../gui/wxpython/wxgui.py:721 ../gui/wxpython/wxgui.py:830
-#: ../gui/wxpython/wxgui.py:866
+#: ../gui/wxpython/wxgui.py:745 ../gui/wxpython/wxgui.py:862
+#: ../gui/wxpython/wxgui.py:1241
 msgid "Please wait, loading workspace..."
 msgstr ""
 "Por favor espere, cargando el archivo que contiene los parámetros de "
 "configuración del espacio de trabajo (.GRC)."
-#: ../gui/wxpython/wxgui.py:822 ../gui/wxpython/menustrings.py:15
-msgid "Load map layers into layer tree"
-msgstr "Cargar capas de mapa en el árbol de capas."
-#: ../gui/wxpython/wxgui.py:850
+#: ../gui/wxpython/wxgui.py:846
 msgid "Choose GRC file to load"
 msgstr ""
 "Seleccione el archivo que contiene los parámetros de configuración del "
 "espacio de trabajo (.GRC) a cargar."
-#: ../gui/wxpython/wxgui.py:851
+#: ../gui/wxpython/wxgui.py:847
 msgid "Old GRASS Workspace File (*.grc)|*.grc"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:888
+#: ../gui/wxpython/wxgui.py:884
 msgid "Choose file to save current workspace"
 msgstr ""
 "Seleccione el archivo donde guardar la configuración del espacio de trabajo "
 "actual."
-#: ../gui/wxpython/wxgui.py:903 ../gui/wxpython/wxgui.py:919
+#: ../gui/wxpython/wxgui.py:899 ../gui/wxpython/wxgui.py:915
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
 "El archivo de entorno de trabajo <%s> ya existe. ¿Quiere sobrescribirlo?"
-#: ../gui/wxpython/wxgui.py:905 ../gui/wxpython/wxgui.py:922
+#: ../gui/wxpython/wxgui.py:901 ../gui/wxpython/wxgui.py:918
 #: ../gui/wxpython/menustrings.py:9
 msgid "Save workspace"
 msgstr "Guardar entorno de trabajo."
-#: ../gui/wxpython/wxgui.py:943
+#: ../gui/wxpython/wxgui.py:939
 #, fuzzy
 msgid "Writing current settings to workspace file failed."
 msgstr ""
 "La escritura del archivo de configuración del espacio de trabajo actual (% "
 "s) ha fallado."
-#: ../gui/wxpython/wxgui.py:954 ../gui/wxpython/gui_modules/gmodeler.py:1437
+#: ../gui/wxpython/wxgui.py:950 ../gui/wxpython/gui_modules/gmodeler.py:1431
 #: ../gui/wxpython/gui_modules/profile.py:597
 msgid "Unable to open file <%s> for writing."
 msgstr "No es posible abrir el archivo <%s> para su lectura."
-#: ../gui/wxpython/wxgui.py:1132
+#: ../gui/wxpython/wxgui.py:1128
 #, fuzzy
 msgid "Nothing to import. No WMS layer selected."
 msgstr "No se ha seleccionado alguna capa de mapas."
-#: ../gui/wxpython/wxgui.py:1168
+#: ../gui/wxpython/wxgui.py:1164
 msgid "Please wait, loading attribute data..."
 msgstr "Por favor espere, cargando datos del atributo."
-#: ../gui/wxpython/wxgui.py:1418
+#: ../gui/wxpython/wxgui.py:1233
+#, fuzzy
+msgid "Add selected map layers into layer tree"
+msgstr "Añadir las capas ligadas al árbol de capas."
+#: ../gui/wxpython/wxgui.py:1442
 #, python-format
 msgid ""
 "Do you want to remove map layer(s)\n"
@@ -308,24 +325,24 @@
 "%s\n"
 " del árbol de capas?"
-#: ../gui/wxpython/wxgui.py:1421
+#: ../gui/wxpython/wxgui.py:1445
 msgid "Do you want to remove selected map layer(s) from layer tree?"
 msgstr ""
 "¿Desea remover la(s) capa(s) de mapa seleccionada(s) del árbol de capas?"
-#: ../gui/wxpython/wxgui.py:1425
+#: ../gui/wxpython/wxgui.py:1449
 msgid "Remove map layer"
 msgstr "Remover la capa de mapa."
-#: ../gui/wxpython/wxgui.py:1485
+#: ../gui/wxpython/wxgui.py:1509
 msgid "Quit GRASS GUI"
 msgstr "Cerrar la Interfaz gráfica de usuario GRASS."
-#: ../gui/wxpython/wxgui.py:1514
+#: ../gui/wxpython/wxgui.py:1538
 msgid "No map layer selected. Operation cancelled."
 msgstr "No se ha seleccionado ninguna capa de mapa. Operación cancelada."
-#: ../gui/wxpython/wxgui.py:1515 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
+#: ../gui/wxpython/wxgui.py:1539 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
 #: ../gui/wxpython/gui_modules/ghelp.py:287
 #: ../gui/wxpython/gui_modules/gcmd.py:98
 #: ../gui/wxpython/gui_modules/dbm.py:2056
@@ -334,7 +351,7 @@
 msgid "Message"
 msgstr "Mensaje"
-#: ../gui/wxpython/wxgui.py:1545
+#: ../gui/wxpython/wxgui.py:1569
 #, fuzzy
 msgid "Starting GRASS GUI..."
 msgstr "Iniciar GRASS."
@@ -443,7 +460,7 @@
 msgid "Add scalebar and north arrow"
 msgstr "Añadir barra de escala e indicador de Norte."
-#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:438
+#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:440
 msgid "Add legend"
 msgstr "Añadir leyenda."
@@ -453,7 +470,7 @@
 #: ../gui/wxpython/icons/icon.py:152
 #: ../gui/wxpython/gui_modules/histogram.py:440
-#: ../gui/wxpython/gui_modules/mapdisp.py:1179
+#: ../gui/wxpython/gui_modules/mapdisp.py:1187
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:942
 msgid "Print display"
 msgstr "Imprimir visualización."
@@ -475,7 +492,7 @@
 msgstr "Mapa de perfil de superficie."
 #: ../gui/wxpython/icons/icon.py:161
-#: ../gui/wxpython/gui_modules/mapdisp.py:1877
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
 msgid "Add text layer"
 msgstr "Añadir capa de texto."
@@ -495,612 +512,617 @@
 #: ../gui/wxpython/icons/icon.py:171
 #, fuzzy
-msgid "Load map layers into workspace (Ctrl+L)"
-msgstr "Cargar capas de mapa en el entorno de trabajo."
-#: ../gui/wxpython/icons/icon.py:173
-#, fuzzy
 msgid "Open existing workspace file (Ctrl+O)"
 msgstr "Abrir archivo de entorno de trabajo existente."
-#: ../gui/wxpython/icons/icon.py:175
+#: ../gui/wxpython/icons/icon.py:173
 #, fuzzy
 msgid "Save current workspace to file (Ctrl+S)"
 msgstr "Guardar entorno de trabajo actual a archivo."
-#: ../gui/wxpython/icons/icon.py:177 ../gui/wxpython/menustrings.py:29
-#: ../gui/wxpython/gui_modules/gdialogs.py:1146
+#: ../gui/wxpython/icons/icon.py:175
 #, fuzzy
+msgid "Add multiple raster or vector map layers (Ctrl+L)"
+msgstr "Añadir capa de mapa raster."
+#: ../gui/wxpython/icons/icon.py:177
+#, fuzzy
+msgid "Import/link raster or vector data"
+msgstr "Importar mapa raster."
+#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_modules/gdialogs.py:1147
+#, fuzzy
 msgid "Import raster data"
-#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/gui_modules/gdialogs.py:1144
+#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:148
+#: ../gui/wxpython/gui_modules/gdialogs.py:1145
 #, fuzzy
 msgid "Link external raster data"
 msgstr "Cargando mapa raster."
-#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:56
-#: ../gui/wxpython/gui_modules/gdialogs.py:1140
+#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_modules/gdialogs.py:1141
 #, fuzzy
 msgid "Import vector data"
 msgstr "Importar mapa vectorial."
-#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:150
-#: ../gui/wxpython/gui_modules/gdialogs.py:1138
+#: ../gui/wxpython/icons/icon.py:185 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_modules/gdialogs.py:1139
 #, fuzzy
 msgid "Link external vector data"
 msgstr "Metadatos básicos de vector."
-#: ../gui/wxpython/icons/icon.py:185
+#: ../gui/wxpython/icons/icon.py:187
 #, fuzzy
 msgid "Add raster map layer (Ctrl+R)"
-#: ../gui/wxpython/icons/icon.py:187
+#: ../gui/wxpython/icons/icon.py:189
 #, fuzzy
 msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
 msgstr "Añadir diversas capas de mapas basadas en imágenes raster."
-#: ../gui/wxpython/icons/icon.py:189
+#: ../gui/wxpython/icons/icon.py:191
 #, fuzzy
 msgid "Add vector map layer (Ctrl+V)"
 msgstr "Añadir capa de mapa vectorial."
-#: ../gui/wxpython/icons/icon.py:191
+#: ../gui/wxpython/icons/icon.py:193
 #, fuzzy
 msgid "Add various vector map layers (thematic, chart...)"
 msgstr "Añadir varias capas  de mapas basados en vectores."
-#: ../gui/wxpython/icons/icon.py:193
+#: ../gui/wxpython/icons/icon.py:195
 msgid "Add command layer"
 msgstr "Añadir capa de comandos."
-#: ../gui/wxpython/icons/icon.py:195
+#: ../gui/wxpython/icons/icon.py:197
 #, fuzzy
 msgid "Add group"
 msgstr "Añadir grupo de capas"
-#: ../gui/wxpython/icons/icon.py:197
+#: ../gui/wxpython/icons/icon.py:199
 msgid "Add grid or vector labels overlay"
 msgstr "Añadir mascara de cuadrícula o etiquetas de vectores."
-#: ../gui/wxpython/icons/icon.py:199
+#: ../gui/wxpython/icons/icon.py:201
 #, fuzzy
 msgid "Delete selected map layer"
 msgstr "Borrar la capa seleccionada."
-#: ../gui/wxpython/icons/icon.py:201 ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/icons/icon.py:203 ../gui/wxpython/icons/icon.py:403
 msgid "Quit"
 msgstr "Salir."
-#: ../gui/wxpython/icons/icon.py:203
+#: ../gui/wxpython/icons/icon.py:205
 msgid "Show attribute table"
 msgstr "Mostrar tabla de atributos."
-#: ../gui/wxpython/icons/icon.py:205
+#: ../gui/wxpython/icons/icon.py:207
 #, fuzzy
 msgid "Edit vector maps"
 msgstr "Exportar mapa vectorial."
-#: ../gui/wxpython/icons/icon.py:207
+#: ../gui/wxpython/icons/icon.py:209
 #, fuzzy
 msgid "Add RGB map layer"
 msgstr "Añadir capa de espacio de color Rojo, Verde y Azul (RGB)."
-#: ../gui/wxpython/icons/icon.py:209
+#: ../gui/wxpython/icons/icon.py:211
 #, fuzzy
 msgid "Add HIS map layer"
 msgstr "Añadir capa de espacio de color Tono-Saturación e intensidad (HIS)."
-#: ../gui/wxpython/icons/icon.py:211
+#: ../gui/wxpython/icons/icon.py:213
 msgid "Add shaded relief map layer"
 msgstr "Añadir capa de mapa de sombreado de relieve."
-#: ../gui/wxpython/icons/icon.py:213
+#: ../gui/wxpython/icons/icon.py:215
 msgid "Add raster flow arrows"
 msgstr "Añadir flechas de flujo raster."
-#: ../gui/wxpython/icons/icon.py:215
+#: ../gui/wxpython/icons/icon.py:217
 msgid "Add raster cell numbers"
 msgstr "Añadir números de celdas raster."
-#: ../gui/wxpython/icons/icon.py:217
+#: ../gui/wxpython/icons/icon.py:219
 #, fuzzy
 msgid "Add thematic area (choropleth) map layer"
 msgstr "Añadir capa de carta temática."
-#: ../gui/wxpython/icons/icon.py:219
+#: ../gui/wxpython/icons/icon.py:221
 msgid "Add thematic chart layer"
-#: ../gui/wxpython/icons/icon.py:221
+#: ../gui/wxpython/icons/icon.py:223
 msgid "Add grid layer"
 msgstr "Añadir capa de cuadrícula."
-#: ../gui/wxpython/icons/icon.py:223
+#: ../gui/wxpython/icons/icon.py:225
 msgid "Add geodesic line layer"
 msgstr "Añadir capa de líneas geodésicas."
-#: ../gui/wxpython/icons/icon.py:225
+#: ../gui/wxpython/icons/icon.py:227
 msgid "Add rhumbline layer"
 msgstr "Añadir capa de Línea de rumbo de navegación o loxódromo (loxodrome)."
-#: ../gui/wxpython/icons/icon.py:227
+#: ../gui/wxpython/icons/icon.py:229
 msgid "Add labels"
 msgstr "Añadir etiquetas."
-#: ../gui/wxpython/icons/icon.py:229
+#: ../gui/wxpython/icons/icon.py:231
 #, fuzzy
 msgid "Add 3D raster map layer"
-#: ../gui/wxpython/icons/icon.py:230
+#: ../gui/wxpython/icons/icon.py:232
 msgid "Note that 3D raster data are rendered only in 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:232
+#: ../gui/wxpython/icons/icon.py:234
 #, fuzzy
 msgid "Show GUI settings"
 msgstr "Mostrar configuración."
-#: ../gui/wxpython/icons/icon.py:234
+#: ../gui/wxpython/icons/icon.py:236
 #, fuzzy
 msgid "Graphical Modeler"
 msgstr "Ayuda del SIG GRASS."
-#: ../gui/wxpython/icons/icon.py:236
+#: ../gui/wxpython/icons/icon.py:238
 #: ../gui/wxpython/gui_modules/gdialogs.py:416
 msgid "Set options"
 msgstr "Establecer opciones."
-#: ../gui/wxpython/icons/icon.py:238
+#: ../gui/wxpython/icons/icon.py:240 ../gui/wxpython/menustrings.py:198
 #, fuzzy
-msgid "Hardcopy Map Ouput Utility"
+msgid "Hardcopy Map Output Utility"
 msgstr "Utilería de copia impresa del mapa de salida PostScript."
-#: ../gui/wxpython/icons/icon.py:240
+#: ../gui/wxpython/icons/icon.py:242
 #, fuzzy
 msgid "Raster Map Calculator"
 msgstr "Calculadora tridimensional (3D) de mapas raster."
-#: ../gui/wxpython/icons/icon.py:244
+#: ../gui/wxpython/icons/icon.py:246
 msgid "Digitize new point"
 msgstr "Digitalizar nuevo punto."
-#: ../gui/wxpython/icons/icon.py:245 ../gui/wxpython/icons/icon.py:254
-#: ../gui/wxpython/icons/icon.py:257
+#: ../gui/wxpython/icons/icon.py:247 ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:259
 msgid "Left: new point"
 msgstr "Izquierda: nuevo punto"
-#: ../gui/wxpython/icons/icon.py:247
+#: ../gui/wxpython/icons/icon.py:249
 msgid "Digitize new line"
 msgstr "Digitalizar nueva línea."
-#: ../gui/wxpython/icons/icon.py:248 ../gui/wxpython/icons/icon.py:251
-#: ../gui/wxpython/icons/icon.py:275
+#: ../gui/wxpython/icons/icon.py:250 ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:277
 #, fuzzy
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
 msgstr ""
 "Izquierda: nuevo punto; Centro: deshacer último punto; Derecha: cerrar la "
 "línea."
-#: ../gui/wxpython/icons/icon.py:250
+#: ../gui/wxpython/icons/icon.py:252
 msgid "Digitize new boundary"
 msgstr "Digitalizar nuevo contorno."
-#: ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:255
 msgid "Digitize new centroid"
 msgstr "Digitalizar nuevo centroide."
-#: ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:258
 msgid ""
 "Digitize new area (composition of boundaries without category and one "
 "centroid with category)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:259
+#: ../gui/wxpython/icons/icon.py:261
 msgid "Add new vertex"
 msgstr "Añadir nuevo vértice."
-#: ../gui/wxpython/icons/icon.py:260 ../gui/wxpython/icons/icon.py:263
-#: ../gui/wxpython/icons/icon.py:266 ../gui/wxpython/icons/icon.py:278
-#: ../gui/wxpython/icons/icon.py:281 ../gui/wxpython/icons/icon.py:284
-#: ../gui/wxpython/icons/icon.py:289 ../gui/wxpython/icons/icon.py:296
+#: ../gui/wxpython/icons/icon.py:262 ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:268 ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:283 ../gui/wxpython/icons/icon.py:286
+#: ../gui/wxpython/icons/icon.py:291 ../gui/wxpython/icons/icon.py:298
 #, fuzzy
 msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
 msgstr "Izquierda: seleccionar; Centro: des seleccionar; Derecha: confirmar."
-#: ../gui/wxpython/icons/icon.py:262
-#: ../gui/wxpython/gui_modules/toolbars.py:782
+#: ../gui/wxpython/icons/icon.py:264
+#: ../gui/wxpython/gui_modules/toolbars.py:729
 msgid "Copy categories"
 msgstr "Copiar categorías."
-#: ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:267
 msgid "Delete feature(s)"
 msgstr "Borrar objeto(s) espacial(es)."
-#: ../gui/wxpython/icons/icon.py:268
+#: ../gui/wxpython/icons/icon.py:270
 msgid "Display/update attributes"
 msgstr "Visualizar / actualizar atributos."
-#: ../gui/wxpython/icons/icon.py:269 ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/icons/icon.py:271 ../gui/wxpython/icons/icon.py:274
 msgid "Left: Select"
 msgstr "Izquierda: seleccionar."
-#: ../gui/wxpython/icons/icon.py:271
+#: ../gui/wxpython/icons/icon.py:273
 msgid "Display/update categories"
 msgstr "Visualizar / actualizar categorías."
-#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/icons/icon.py:276
 msgid "Edit line/boundary"
 msgstr "Editar línea / contorno."
-#: ../gui/wxpython/icons/icon.py:277
+#: ../gui/wxpython/icons/icon.py:279
 msgid "Move feature(s)"
 msgstr "Mover objetos espaciales."
-#: ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:282
 msgid "Move vertex"
 msgstr "Mover vértice."
-#: ../gui/wxpython/icons/icon.py:283
+#: ../gui/wxpython/icons/icon.py:285
 msgid "Remove vertex"
 msgstr "Eliminar vértice."
-#: ../gui/wxpython/icons/icon.py:286
-#: ../gui/wxpython/gui_modules/toolbars.py:857
+#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/gui_modules/toolbars.py:804
 msgid "Digitization settings"
 msgstr "Configuración de la digitalización."
-#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/icons/icon.py:290
 msgid "Split line/boundary"
 msgstr "Dividir línea / contorno."
-#: ../gui/wxpython/icons/icon.py:291
+#: ../gui/wxpython/icons/icon.py:293
 #, fuzzy
 msgid "Quit digitizer"
 msgstr "Error del digitalizador de vectores."
-#: ../gui/wxpython/icons/icon.py:292
+#: ../gui/wxpython/icons/icon.py:294
 msgid "Quit digitizer and save changes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:294
+#: ../gui/wxpython/icons/icon.py:296
 msgid "Additional tools (copy, flip, connect, etc.)"
 msgstr "Herramientas adicionales (copiar, invertir, conectar, etc.)."
-#: ../gui/wxpython/icons/icon.py:298
+#: ../gui/wxpython/icons/icon.py:300
 msgid "Undo"
 msgstr "Deshacer."
-#: ../gui/wxpython/icons/icon.py:299
+#: ../gui/wxpython/icons/icon.py:301
 msgid "Undo previous changes"
 msgstr "Deshacer cambios anteriores."
-#: ../gui/wxpython/icons/icon.py:303
+#: ../gui/wxpython/icons/icon.py:305
 msgid "Draw/re-draw profile"
 msgstr "Dibujar / redibujar perfil."
-#: ../gui/wxpython/icons/icon.py:305
+#: ../gui/wxpython/icons/icon.py:307
 msgid "Draw transect in map display window to profile"
 msgstr ""
 "Para procesar el trazo del perfil, dibuje el transecto en la ventana de "
 "despliegue del mapa."
-#: ../gui/wxpython/icons/icon.py:307
+#: ../gui/wxpython/icons/icon.py:309
 msgid "Profile options"
 msgstr "Opciones de perfilado."
-#: ../gui/wxpython/icons/icon.py:309
+#: ../gui/wxpython/icons/icon.py:311
 #, fuzzy
 msgid "Save profile data to CSV file"
 msgstr "Guardar visualización en archivo gráfico."
-#: ../gui/wxpython/icons/icon.py:311
+#: ../gui/wxpython/icons/icon.py:313
 #, fuzzy
 msgid "Quit Profile Analysis Tool"
 msgstr "Análisis del perfil del terreno."
-#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/icons/icon.py:317
 msgid "Set GCP"
 msgstr "Establecer puntos de control sobre el terreno (GCP)."
-#: ../gui/wxpython/icons/icon.py:316
+#: ../gui/wxpython/icons/icon.py:318
 msgid "Define GCP (Ground Control Points)"
 msgstr "Definir GCP (Puntos de Control sobre el Terreno)."
-#: ../gui/wxpython/icons/icon.py:318 ../gui/wxpython/menustrings.py:186
+#: ../gui/wxpython/icons/icon.py:320 ../gui/wxpython/menustrings.py:186
 msgid "Georectify"
 msgstr "Georrectificar."
-#: ../gui/wxpython/icons/icon.py:320
+#: ../gui/wxpython/icons/icon.py:322
 msgid "Recalculate RMS error"
 msgstr "Recalcular error RMS."
-#: ../gui/wxpython/icons/icon.py:322
+#: ../gui/wxpython/icons/icon.py:324
 msgid "Save GCPs to POINTS file"
 msgstr "Guardar GCP en archivo de PUNTOS."
-#: ../gui/wxpython/icons/icon.py:324
+#: ../gui/wxpython/icons/icon.py:326
 msgid "Add new GCP"
 msgstr "Añadir nuevo GCP."
-#: ../gui/wxpython/icons/icon.py:326
+#: ../gui/wxpython/icons/icon.py:328
 msgid "Delete selected GCP"
 msgstr "Borrar el GCP seleccionado."
-#: ../gui/wxpython/icons/icon.py:328
+#: ../gui/wxpython/icons/icon.py:330
 msgid "Clear selected GCP"
 msgstr "Limpiar el GCP seleccionado."
-#: ../gui/wxpython/icons/icon.py:330
+#: ../gui/wxpython/icons/icon.py:332
 #, fuzzy
 msgid "Reload GCPs from POINTS file"
 msgstr "Recargar GCP del archivo de PUNTOS seleccionado."
-#: ../gui/wxpython/icons/icon.py:332
+#: ../gui/wxpython/icons/icon.py:334
 #, fuzzy
 msgid "Quit georectification"
 msgstr "Salir del módulo de georrectificación."
-#: ../gui/wxpython/icons/icon.py:334
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1289
+#: ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1504
 #: ../gui/wxpython/gui_modules/gselect.py:1070
 msgid "Settings"
 msgstr "Configuración, ajustes."
-#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/icons/icon.py:337
 msgid "Settings dialog for georectification tool"
 msgstr "Diálogo de configuración para la herramienta de georrectificación."
-#: ../gui/wxpython/icons/icon.py:339
+#: ../gui/wxpython/icons/icon.py:341
 msgid "Switch to view control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:340
+#: ../gui/wxpython/icons/icon.py:342
 #, fuzzy
 msgid "Change view settings"
 msgstr "Cambiar configuración."
-#: ../gui/wxpython/icons/icon.py:342
+#: ../gui/wxpython/icons/icon.py:344
 msgid "Switch to surface (raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:343
+#: ../gui/wxpython/icons/icon.py:345
 #, fuzzy
 msgid "Change surface (loaded raster maps) settings"
 msgstr "Recodificar mapa raster usando reglas."
-#: ../gui/wxpython/icons/icon.py:345
+#: ../gui/wxpython/icons/icon.py:347
 msgid "Switch to vector (2D/3D) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:346
+#: ../gui/wxpython/icons/icon.py:348
 #, fuzzy
 msgid "Change 2D/3D vector settings"
-#: ../gui/wxpython/icons/icon.py:348
+#: ../gui/wxpython/icons/icon.py:350
 msgid "Switch to volume (3D raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:349
+#: ../gui/wxpython/icons/icon.py:351
 msgid "Change volume (loaded 3D raster maps) settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:353
 msgid "Switch to lighting control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:352
+#: ../gui/wxpython/icons/icon.py:354
 #, fuzzy
 msgid "Change lighting settings"
-#: ../gui/wxpython/icons/icon.py:354
+#: ../gui/wxpython/icons/icon.py:356
 msgid "Switch to fringe control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:355
+#: ../gui/wxpython/icons/icon.py:357
 msgid "Switch on/off fringes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:359
 #, fuzzy
 msgid "3D view mode tools"
 msgstr "Herramientas de visualización 3D."
-#: ../gui/wxpython/icons/icon.py:358
+#: ../gui/wxpython/icons/icon.py:360
 #, fuzzy
 msgid "Show/hide 3D view mode settings dialog"
 msgstr "Mostrar diálogo de configuración de NVIZ."
-#: ../gui/wxpython/icons/icon.py:360
+#: ../gui/wxpython/icons/icon.py:362
 msgid "Quit 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:361
+#: ../gui/wxpython/icons/icon.py:363
 msgid "Switch back to 2D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:365
+#: ../gui/wxpython/icons/icon.py:367
 #, fuzzy
 msgid "Create new model (Ctrl+N)"
 msgstr "Crear un nuevo directorio de mapas de usuario (mapset)."
-#: ../gui/wxpython/icons/icon.py:367
+#: ../gui/wxpython/icons/icon.py:369
 #, fuzzy
 msgid "Load model from file (Ctrl+O)"
 msgstr "Cargar archivo de trabajo desde el archivo."
-#: ../gui/wxpython/icons/icon.py:369
+#: ../gui/wxpython/icons/icon.py:371
 #, fuzzy
 msgid "Save current model to file (Ctrl+S)"
-#: ../gui/wxpython/icons/icon.py:371 ../gui/wxpython/menustrings.py:878
+#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:878
 #, fuzzy
 msgid "Export model to image"
-#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:880
+#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:880
 msgid "Export model to Python script"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:888
+#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:888
 msgid "Add action (GRASS module) to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:890
 msgid "Add data item to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:892
+#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:892
 msgid "Define relation between data and action items"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:190
+#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:190
 #: ../gui/wxpython/menustrings.py:903
 msgid "Run model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:905
+#: ../gui/wxpython/icons/icon.py:385 ../gui/wxpython/menustrings.py:905
 msgid "Validate model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:385
+#: ../gui/wxpython/icons/icon.py:387
 #, fuzzy
 msgid "Show modeler settings"
-#: ../gui/wxpython/icons/icon.py:387
+#: ../gui/wxpython/icons/icon.py:389
 #, fuzzy
 msgid "Show model properties"
 msgstr "Propiedades de capa."
-#: ../gui/wxpython/icons/icon.py:389
+#: ../gui/wxpython/icons/icon.py:391
 #, fuzzy
 msgid "Manage model variables"
 msgstr "Administrar tablas."
-#: ../gui/wxpython/icons/icon.py:391
+#: ../gui/wxpython/icons/icon.py:393
 msgid "Redraw model canvas"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:393
-#: ../gui/wxpython/gui_modules/gmodeler.py:677
+#: ../gui/wxpython/icons/icon.py:395
+#: ../gui/wxpython/gui_modules/gmodeler.py:671
 msgid "Quit Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:397
+#: ../gui/wxpython/icons/icon.py:399
 msgid "Select font"
 msgstr "Seleccionar tipo de letra."
-#: ../gui/wxpython/icons/icon.py:399
+#: ../gui/wxpython/icons/icon.py:401
 #, fuzzy
 msgid "Show manual"
 msgstr "Árbol de Steiner"
-#: ../gui/wxpython/icons/icon.py:405
+#: ../gui/wxpython/icons/icon.py:407
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:407
+#: ../gui/wxpython/icons/icon.py:409
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:409
+#: ../gui/wxpython/icons/icon.py:411
 #, fuzzy
 msgid "Generate PostScript output"
-#: ../gui/wxpython/icons/icon.py:411
+#: ../gui/wxpython/icons/icon.py:413
 #, fuzzy
 msgid "Generate PDF output"
 msgstr "Generar puntos."
-#: ../gui/wxpython/icons/icon.py:413
+#: ../gui/wxpython/icons/icon.py:415
 #: ../gui/wxpython/gui_modules/histogram.py:432
-#: ../gui/wxpython/gui_modules/mapdisp.py:1171
+#: ../gui/wxpython/gui_modules/mapdisp.py:1179
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:934
 msgid "Page setup"
 msgstr "Configuración de página."
-#: ../gui/wxpython/icons/icon.py:414
+#: ../gui/wxpython/icons/icon.py:416
 msgid "Specify paper size, margins and orientation"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:416
+#: ../gui/wxpython/icons/icon.py:418
 msgid "Full extent"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:417
+#: ../gui/wxpython/icons/icon.py:419
 #, fuzzy
 msgid "Zoom to full extent"
 msgstr "Acercamiento a la región predeterminada (zoom)."
-#: ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:421
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1951
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2006
 #, fuzzy
 msgid "Map frame"
 msgstr "Escala de mapa."
-#: ../gui/wxpython/icons/icon.py:420
+#: ../gui/wxpython/icons/icon.py:422
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:320
+#: ../gui/wxpython/icons/icon.py:424
+#: ../gui/wxpython/gui_modules/nviz_tools.py:465
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2476
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:669
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:730
 msgid "Raster map"
 msgstr "Mapa raster:"
-#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/icons/icon.py:425
 #, fuzzy
 msgid "Add raster map"
 msgstr "Añadir mapa raster 3D."
-#: ../gui/wxpython/icons/icon.py:425
-#: ../gui/wxpython/gui_modules/nviz_tools.py:629
+#: ../gui/wxpython/icons/icon.py:427
+#: ../gui/wxpython/gui_modules/nviz_tools.py:839
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3920
 #, fuzzy
 msgid "Vector map"
 msgstr "Nuevo mapa vectorial."
-#: ../gui/wxpython/icons/icon.py:426
+#: ../gui/wxpython/icons/icon.py:428
 #, fuzzy
 msgid "Add vector map"
 msgstr "Vector."
-#: ../gui/wxpython/icons/icon.py:428
+#: ../gui/wxpython/icons/icon.py:430
 #, fuzzy
 msgid "Delete selected object"
 msgstr "Borrar la locación seleccionada."
-#: ../gui/wxpython/icons/icon.py:430
+#: ../gui/wxpython/icons/icon.py:432
 #, fuzzy
 msgid "Show preview"
 msgstr "Mostrar la rejilla."
-#: ../gui/wxpython/icons/icon.py:432
+#: ../gui/wxpython/icons/icon.py:434
 #, fuzzy
 msgid "Quit Hardcopy Map Utility"
-#: ../gui/wxpython/icons/icon.py:434
+#: ../gui/wxpython/icons/icon.py:436
 #, fuzzy
 msgid "Add text"
-#: ../gui/wxpython/icons/icon.py:436
+#: ../gui/wxpython/icons/icon.py:438
 #, fuzzy
 msgid "Add map info"
 msgstr "Añadir elementos al mapa."
-#: ../gui/wxpython/icons/icon.py:440
+#: ../gui/wxpython/icons/icon.py:442
 #, fuzzy
 msgid "Add scale bar"
 msgstr "Añadir una capa."
@@ -1126,84 +1148,84 @@
 msgid "Kriging"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:109
-#: ../gui/wxpython/gui_modules/gmodeler.py:575
-#: ../gui/wxpython/gui_modules/menuform.py:1165
+#: ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gui_modules/gmodeler.py:569
+#: ../gui/wxpython/gui_modules/menuform.py:1160
 msgid "Command output"
 msgstr "Salida de la orden."
-#: ../gui/wxpython/scripts/vkrige.py:115 ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/scripts/vkrige.py:114 ../gui/wxpython/menustrings.py:390
 msgid "Output"
 msgstr "Salida."
-#: ../gui/wxpython/scripts/vkrige.py:119
+#: ../gui/wxpython/scripts/vkrige.py:118
 #, fuzzy
 msgid "Name for the output raster map:"
 msgstr "Nombre para el nuevo mapa vectorial:"
-#: ../gui/wxpython/scripts/vkrige.py:127
+#: ../gui/wxpython/scripts/vkrige.py:126
 #, fuzzy
 msgid "Export variance map as well: "
 msgstr "Exportar mapa raster."
-#: ../gui/wxpython/scripts/vkrige.py:140
+#: ../gui/wxpython/scripts/vkrige.py:139
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:229
 #: ../gui/wxpython/gui_modules/vclean.py:144
-#: ../gui/wxpython/gui_modules/gmodeler.py:3309
-#: ../gui/wxpython/gui_modules/gdialogs.py:985
-#: ../gui/wxpython/gui_modules/preferences.py:1533
+#: ../gui/wxpython/gui_modules/gmodeler.py:3303
+#: ../gui/wxpython/gui_modules/gdialogs.py:986
+#: ../gui/wxpython/gui_modules/preferences.py:1555
 msgid "Allow output files to overwrite existing files"
 msgstr "Permitir que los archivos de salida sobrescriban archivos existentes."
-#: ../gui/wxpython/scripts/vkrige.py:153
+#: ../gui/wxpython/scripts/vkrige.py:152
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:133
 #: ../gui/wxpython/gui_modules/ghelp.py:223
 #: ../gui/wxpython/gui_modules/vclean.py:165
-#: ../gui/wxpython/gui_modules/gmodeler.py:3426
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/gmodeler.py:3420
+#: ../gui/wxpython/gui_modules/menuform.py:828
 msgid "&Run"
 msgstr "Ejecuta&r"
-#: ../gui/wxpython/scripts/vkrige.py:268
+#: ../gui/wxpython/scripts/vkrige.py:267
 msgid "Kriging Module"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:272
+#: ../gui/wxpython/scripts/vkrige.py:271
 msgid "Ready."
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:296
+#: ../gui/wxpython/scripts/vkrige.py:295
 msgid "Variogram fitting"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:306
+#: ../gui/wxpython/scripts/vkrige.py:305
 msgid "Plot/refresh variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:317
+#: ../gui/wxpython/scripts/vkrige.py:316
 #, fuzzy
 msgid ":"
 msgstr "X:"
-#: ../gui/wxpython/scripts/vkrige.py:342
+#: ../gui/wxpython/scripts/vkrige.py:341
 msgid "Kriging techniques"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:356
+#: ../gui/wxpython/scripts/vkrige.py:355
 #, fuzzy
 msgid "Block size:"
 msgstr "Tamaño de ícono:"
-#: ../gui/wxpython/scripts/vkrige.py:389
+#: ../gui/wxpython/scripts/vkrige.py:388
 msgid "Auto-fit variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:413
+#: ../gui/wxpython/scripts/vkrige.py:412
 #, fuzzy
 msgid "Model: "
 msgstr "Modo:"
-#: ../gui/wxpython/scripts/vkrige.py:497
+#: ../gui/wxpython/scripts/vkrige.py:496
 msgid "Work in progress! No functionality provided."
 msgstr ""
@@ -1292,8 +1314,9 @@
 msgid "Workspace"
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:17
 #: ../gui/wxpython/menustrings.py:867
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
 msgid "New"
 msgstr "Nuevo."
@@ -1331,49 +1354,54 @@
 #: ../gui/wxpython/menustrings.py:14
-msgid "Load map layers"
-msgstr "Cargar capas de mapa."
-#: ../gui/wxpython/menustrings.py:16
 msgid "Load GRC file (Tcl/Tk GUI)"
 msgstr "Cargar archivo de entorno GRC (GUI Tcl/Tk)."
-#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/menustrings.py:15
 msgid "Load map layers from GRC file to layer tree"
 msgstr "Cargar capas de mapa desde el archivo GRC en el árbol de capas."
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:16
 #, fuzzy
 msgid "Map display"
 msgstr "Mostrar."
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:18
 #, fuzzy
 msgid "Open new map display window"
 msgstr ""
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:19
 #, fuzzy
 msgid "Close current"
 msgstr "Cerrar archivo de entorno de trabajo actual"
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:20
 #, fuzzy
 msgid "Close current map display window"
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:21
 #, fuzzy
 msgid "Close all"
 msgstr "Cerrar diálogo."
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:22
 #, fuzzy
 msgid "Close all open map display windows"
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+#, fuzzy
+msgid "Add multiple raster or vector map layers to current display"
 #: ../gui/wxpython/menustrings.py:25
 #, fuzzy
 msgid "Add raster"
@@ -2022,6 +2050,7 @@
 "mapas actual del usuario."
 #: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2640
 msgid "Delete"
 msgstr "Borrar."
@@ -2161,11 +2190,6 @@
 "Una utilería simple para convertir medidas de rumbo y distancia a "
 "coordenadas y viceversa."
-#: ../gui/wxpython/menustrings.py:198
-#, fuzzy
-msgid "Hardcopy Map Output Utility"
-msgstr "Utilería de copia impresa del mapa de salida PostScript."
 #: ../gui/wxpython/menustrings.py:199
 #, fuzzy
 msgid "Launch Hardcopy Map Output Utility"
@@ -2630,9 +2654,8 @@
 msgstr "Localiza los puntos más próximos entre objetos en dos mapas raster."
 #: ../gui/wxpython/menustrings.py:298
-#: ../gui/wxpython/gui_modules/nviz_tools.py:351
-#: ../gui/wxpython/gui_modules/nviz_tools.py:549
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:602
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1238
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3049
 msgid "Mask"
 msgstr "Máscara."
@@ -2811,7 +2834,7 @@
 "Traza un flujo mediante un modelo de elevación sobre una capa de mapa raster."
 #: ../gui/wxpython/menustrings.py:330
-#: ../gui/wxpython/gui_modules/layertree.py:803
+#: ../gui/wxpython/gui_modules/layertree.py:799
 msgid "Shaded relief"
 msgstr "Relieve sombreado."
@@ -5347,7 +5370,7 @@
 #: ../gui/wxpython/menustrings.py:872
-#: ../gui/wxpython/gui_modules/gmodeler.py:828
+#: ../gui/wxpython/gui_modules/gmodeler.py:822
 #, fuzzy
 msgid "Save model"
 msgstr "Modo de categoría."
@@ -5381,7 +5404,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:885
-#: ../gui/wxpython/gui_modules/gmodeler.py:3003
+#: ../gui/wxpython/gui_modules/gmodeler.py:2997
 #, fuzzy
 msgid "Modeler settings"
 msgstr "Configuración general."
@@ -5433,7 +5456,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:899
-#: ../gui/wxpython/gui_modules/gmodeler.py:3288
+#: ../gui/wxpython/gui_modules/gmodeler.py:3282
 #, fuzzy
 msgid "Model properties"
@@ -5589,8 +5612,8 @@
 msgstr "Crear histograma de imagen o archivo raster."
 #: ../gui/wxpython/gui_modules/histogram.py:332
-#: ../gui/wxpython/gui_modules/wxnviz.py:227
-#: ../gui/wxpython/gui_modules/wxnviz.py:238
+#: ../gui/wxpython/gui_modules/wxnviz.py:240
+#: ../gui/wxpython/gui_modules/wxnviz.py:251
 msgid "Raster map <%s> not found"
 msgstr "No se ha encontrado el mapa <%s> ."
@@ -5600,14 +5623,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:403
-#: ../gui/wxpython/gui_modules/mapdisp.py:1142
+#: ../gui/wxpython/gui_modules/mapdisp.py:1150
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:905
-#: ../gui/wxpython/gui_modules/gmodeler.py:1042
+#: ../gui/wxpython/gui_modules/gmodeler.py:1036
 msgid "Choose a file name to save the image (no need to add extension)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:436
-#: ../gui/wxpython/gui_modules/mapdisp.py:1175
+#: ../gui/wxpython/gui_modules/mapdisp.py:1183
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:938
 msgid "Print preview"
 msgstr "Vista previa de impresión."
@@ -5647,16 +5670,16 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#: ../gui/wxpython/gui_modules/gdialogs.py:1005
+#: ../gui/wxpython/gui_modules/gdialogs.py:1006
 #, fuzzy
 msgid "Command dialog"
 msgstr "Ajustes del diálogo de comandos."
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:138
-#: ../gui/wxpython/gui_modules/gdialogs.py:1161
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
-#: ../gui/wxpython/gui_modules/gdialogs.py:1168
-#: ../gui/wxpython/gui_modules/gdialogs.py:1170
+#: ../gui/wxpython/gui_modules/gdialogs.py:1162
+#: ../gui/wxpython/gui_modules/gdialogs.py:1164
+#: ../gui/wxpython/gui_modules/gdialogs.py:1169
+#: ../gui/wxpython/gui_modules/gdialogs.py:1171
 msgid "Open %s dialog"
@@ -5667,7 +5690,6 @@
 msgstr "Guardar entorno de trabajo actual al archivo."
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#: ../gui/wxpython/gui_modules/gdialogs.py:739
 #, fuzzy
 msgid "&Load"
 msgstr "Cargar"
@@ -5846,6 +5868,40 @@
 msgid "Unknow tag"
 msgstr "Desconocido"
+#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:47
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:97
+#, fuzzy, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr "No se ha encontrado el mapa <%s> ."
+#: ../gui/wxpython/gui_modules/gpyshell.py:104
+msgid "Raster map <%s> added"
+#: ../gui/wxpython/gui_modules/gpyshell.py:106
+msgid "Vector map <%s> added"
+msgstr "El mapa vectorial <%s> es tridimensional (3D)."
 #: ../gui/wxpython/gui_modules/dbm_dialogs.py:67
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2998
 msgid "Database connection is not defined in DB file."
@@ -5911,7 +5967,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2279
 #: ../gui/wxpython/gui_modules/dbm.py:2387
 #: ../gui/wxpython/gui_modules/dbm.py:2642
-#: ../gui/wxpython/gui_modules/gdialogs.py:1352
+#: ../gui/wxpython/gui_modules/gdialogs.py:1353
 msgid "Layer"
 msgstr "Capa."
@@ -5945,16 +6001,16 @@
 msgstr "Tipo de mapa a georrectificar."
 #: ../gui/wxpython/gui_modules/gcpmanager.py:328
-#: ../gui/wxpython/gui_modules/gmodeler.py:3560
+#: ../gui/wxpython/gui_modules/gmodeler.py:3554
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2028
-#: ../gui/wxpython/gui_modules/layertree.py:791
+#: ../gui/wxpython/gui_modules/layertree.py:787
 msgid "raster"
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3561
+#: ../gui/wxpython/gui_modules/gmodeler.py:3555
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2029
-#: ../gui/wxpython/gui_modules/layertree.py:812
+#: ../gui/wxpython/gui_modules/layertree.py:808
 msgid "vector"
 msgstr "Vector."
@@ -6055,12 +6111,12 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1110
-#: ../gui/wxpython/gui_modules/toolbars.py:416
+#: ../gui/wxpython/gui_modules/toolbars.py:398
 msgid "source"
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1112
 msgid "target"
 msgstr ""
@@ -6266,14 +6322,14 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2371
 #: ../gui/wxpython/gui_modules/profile.py:1033
 #: ../gui/wxpython/gui_modules/profile.py:1388
-#: ../gui/wxpython/gui_modules/preferences.py:961
+#: ../gui/wxpython/gui_modules/preferences.py:966
 msgid "Apply changes for the current session"
 msgstr "Aplicar cambios para la sesión actual."
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2373
 #: ../gui/wxpython/gui_modules/profile.py:1038
 #: ../gui/wxpython/gui_modules/profile.py:1390
-#: ../gui/wxpython/gui_modules/preferences.py:963
+#: ../gui/wxpython/gui_modules/preferences.py:968
 msgid ""
 "Apply and save changes to user settings file (default for next sessions)"
 msgstr ""
@@ -6282,7 +6338,7 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2375
 #: ../gui/wxpython/gui_modules/ogc_services.py:77
-#: ../gui/wxpython/gui_modules/gdialogs.py:995
+#: ../gui/wxpython/gui_modules/gdialogs.py:996
 msgid "Close dialog"
@@ -6312,12 +6368,14 @@
 msgstr "Configuración de símbolos."
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2438
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1307
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:809
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1522
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:326
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:547
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3098
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3203
-#: ../gui/wxpython/gui_modules/preferences.py:1683
+#: ../gui/wxpython/gui_modules/preferences.py:1705
 msgid "Color:"
 msgstr "Color:"
@@ -6398,16 +6456,16 @@
 msgstr "La configuración del perfil ha sido guardada en el archivo '%s'."
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:90
-#: ../gui/wxpython/gui_modules/mapdisp.py:771
-#: ../gui/wxpython/gui_modules/mapdisp.py:803
-#: ../gui/wxpython/gui_modules/mapdisp.py:874
-#: ../gui/wxpython/gui_modules/mapdisp.py:1027
+#: ../gui/wxpython/gui_modules/mapdisp.py:779
+#: ../gui/wxpython/gui_modules/mapdisp.py:811
+#: ../gui/wxpython/gui_modules/mapdisp.py:882
+#: ../gui/wxpython/gui_modules/mapdisp.py:1035
 msgid "Projection not defined (check the settings)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:107
-#: ../gui/wxpython/gui_modules/mapdisp.py:918
-#: ../gui/wxpython/gui_modules/mapdisp.py:1044
+#: ../gui/wxpython/gui_modules/mapdisp.py:926
+#: ../gui/wxpython/gui_modules/mapdisp.py:1052
 msgid "Error in projection (check the settings)"
 msgstr ""
@@ -6437,7 +6495,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1718
 #: ../gui/wxpython/gui_modules/gcmd.py:89
-#: ../gui/wxpython/gui_modules/workspace.py:1000
+#: ../gui/wxpython/gui_modules/workspace.py:1007
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:424
 #: ../gui/wxpython/gui_modules/dbm.py:2357
 msgid "Warning"
@@ -6494,7 +6552,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:178
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:184
-#: ../gui/wxpython/gui_modules/preferences.py:1471
+#: ../gui/wxpython/gui_modules/preferences.py:1493
 msgid "Constrain display resolution to computational settings"
 msgstr ""
 "Restringir la resolución de pantalla a la configuración de cálculo "
@@ -6511,8 +6569,8 @@
 "configurar en el diálogo 'Configuración de la interfaz gráfica de usuario'."
 #: ../gui/wxpython/gui_modules/mapdisp.py:210
-#: ../gui/wxpython/gui_modules/mapdisp.py:1062
-#: ../gui/wxpython/gui_modules/mapdisp.py:1065
+#: ../gui/wxpython/gui_modules/mapdisp.py:1070
+#: ../gui/wxpython/gui_modules/mapdisp.py:1073
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:216
 #, fuzzy
 msgid "Use defined projection"
@@ -6538,8 +6596,8 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:301
 #: ../gui/wxpython/gui_modules/mapdisp.py:312
 #: ../gui/wxpython/gui_modules/mapdisp.py:362
-#: ../gui/wxpython/gui_modules/mapdisp.py:507
-#: ../gui/wxpython/gui_modules/toolbars.py:201
+#: ../gui/wxpython/gui_modules/mapdisp.py:513
+#: ../gui/wxpython/gui_modules/toolbars.py:204
 #: ../gui/wxpython/gui_modules/layertree.py:582
 msgid "2D view"
 msgstr "Vista 2D."
@@ -6570,84 +6628,84 @@
 "\n"
 "Detalles: %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:381
+#: ../gui/wxpython/gui_modules/mapdisp.py:386
 msgid "Starting 3D view mode..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:387
 msgid "Please wait, loading data..."
 msgstr "Por favor espere, cargando datos..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:414
+#: ../gui/wxpython/gui_modules/mapdisp.py:420
 #, fuzzy
 msgid "3D View Toolbar"
 msgstr "Barra de herramientas de Nviz."
-#: ../gui/wxpython/gui_modules/mapdisp.py:438
+#: ../gui/wxpython/gui_modules/mapdisp.py:444
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:348
 msgid "Map Toolbar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:455
+#: ../gui/wxpython/gui_modules/mapdisp.py:461
 #, fuzzy
 msgid "Georectification Toolbar"
 msgstr "Barra de herramientas de georrectificación."
-#: ../gui/wxpython/gui_modules/mapdisp.py:517
+#: ../gui/wxpython/gui_modules/mapdisp.py:523
 #: ../gui/wxpython/gui_modules/render.py:420
 #, python-format
 msgid "GRASS module '%s' not found. Unable to start map display window."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1127
+#: ../gui/wxpython/gui_modules/mapdisp.py:1135
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:890
 #, fuzzy
 msgid "Nothing to render (empty map). Operation canceled."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1300
+#: ../gui/wxpython/gui_modules/mapdisp.py:1308
 msgid "No raster or vector map layer selected for querying."
 msgstr ""
 "No se ha seleccionado ningún mapa raster o vectorial para ser consultado."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1301
+#: ../gui/wxpython/gui_modules/mapdisp.py:1309
 msgid "No map layer selected"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1396
+#: ../gui/wxpython/gui_modules/mapdisp.py:1404
 msgid "No vector map selected for querying."
 msgstr "No se ha seleccionado algún mapa vectorial para consultar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1397
 #: ../gui/wxpython/gui_modules/mapdisp.py:1405
+#: ../gui/wxpython/gui_modules/mapdisp.py:1413
 msgid "Vector querying"
 msgstr "Consulta de vectores."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1404
+#: ../gui/wxpython/gui_modules/mapdisp.py:1412
 msgid "Only vector map from the current mapset can be modified."
 msgstr ""
 "Solo los mapas vectoriales del directorio de mapas de usuario (mapset) "
 "actual pueden ser modificados."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1476
+#: ../gui/wxpython/gui_modules/mapdisp.py:1484
 #, fuzzy
 msgid "Query surface (raster map)"
 msgstr "Superponer mapas raster."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1483
+#: ../gui/wxpython/gui_modules/mapdisp.py:1491
 #, fuzzy
 msgid "Query vector map"
 msgstr "Superponer mapas vectoriales."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1491
+#: ../gui/wxpython/gui_modules/mapdisp.py:1499
 msgid "Query raster/vector map(s) (display mode)"
 msgstr "Consultar mapa(s) raster / vectorial (modo de visualización)."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1507
+#: ../gui/wxpython/gui_modules/mapdisp.py:1515
 msgid "Query vector map (edit mode)"
 msgstr "Consultar mapa vectorial (modo de edición)."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1633
+#: ../gui/wxpython/gui_modules/mapdisp.py:1641
 #, python-format
 msgid ""
 "Click and drag with left mouse button to measure.%sDouble click with left "
@@ -6656,88 +6714,88 @@
 "Pulse y arrastre con el botón izquierdo del ratón para medir. %s . Haga "
 "doble clic izquierdo para limpiar."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1639
+#: ../gui/wxpython/gui_modules/mapdisp.py:1647
 msgid "Measuring distance"
 msgstr "Midiendo distancia."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1642
+#: ../gui/wxpython/gui_modules/mapdisp.py:1650
 msgid "Measuring distance:"
 msgstr "Midiendo distancia:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1652
+#: ../gui/wxpython/gui_modules/mapdisp.py:1660
 #, python-format
 msgid ""
 "Geodesic distance is not yet supported by this tool.\n"
 "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1681
-#: ../gui/wxpython/gui_modules/mapdisp.py:1687
+#: ../gui/wxpython/gui_modules/mapdisp.py:1690
+#: ../gui/wxpython/gui_modules/mapdisp.py:1696
 #, fuzzy
 msgid "segment"
 msgstr "Leyenda."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1682
-#: ../gui/wxpython/gui_modules/mapdisp.py:1688
+#: ../gui/wxpython/gui_modules/mapdisp.py:1691
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
 #, fuzzy
 msgid "total distance"
 msgstr "Medir distancia."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1683
+#: ../gui/wxpython/gui_modules/mapdisp.py:1692
 #, fuzzy
 msgid "bearing"
 msgstr "Aviso"
 msgid "deg"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1819
+#: ../gui/wxpython/gui_modules/mapdisp.py:1828
 msgid "Scale and North arrow"
 msgstr "Escala y flecha de Norte."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1825
+#: ../gui/wxpython/gui_modules/mapdisp.py:1834
 msgid "Show/hide scale and North arrow"
 msgstr "Mostrar / ocultar escala y flecha de Norte."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1826
+#: ../gui/wxpython/gui_modules/mapdisp.py:1835
 msgid "scale object"
 msgstr "Escalar objeto."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1855
+#: ../gui/wxpython/gui_modules/mapdisp.py:1864
 msgid "Show/hide legend"
 msgstr "Mostrar / ocultar leyenda."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1856
+#: ../gui/wxpython/gui_modules/mapdisp.py:1865
 msgid "legend object"
 msgstr "Objeto de la leyenda."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1965
+#: ../gui/wxpython/gui_modules/mapdisp.py:1974
 #, fuzzy
 msgid "Zoom to computational region"
 msgstr "Acercamiento a la región de cálculo (definida mediante g.region)."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1969
+#: ../gui/wxpython/gui_modules/mapdisp.py:1978
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1058
 msgid "Zoom to default region"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1973
+#: ../gui/wxpython/gui_modules/mapdisp.py:1982
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1062
 msgid "Zoom to saved region"
 msgstr "Acercamiento a una región guardada (zoom)."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1977
+#: ../gui/wxpython/gui_modules/mapdisp.py:1986
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1066
 msgid "Set computational region from display"
 msgstr "Establece la región de cálculo desde la pantalla."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1981
+#: ../gui/wxpython/gui_modules/mapdisp.py:1990
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1070
 msgid "Save display geometry to named region"
 msgstr "Guardar la geometría de la visualización a la región nombrada."
-#: ../gui/wxpython/gui_modules/mapdisp.py:2075
+#: ../gui/wxpython/gui_modules/mapdisp.py:2084
 msgid "GRASS GIS Map Display: "
 msgstr "Ventana de visualización del mapa GRASS GIS :"
@@ -6802,12 +6860,12 @@
 msgid "Unsupported feature type %d. Operation cancelled."
 msgstr "Valor de coordenada no válido. Operación cancelada."
-#: ../gui/wxpython/gui_modules/wxvdigit.py:455
+#: ../gui/wxpython/gui_modules/wxvdigit.py:456
 msgid "Unknown feature type '%s'"
 msgstr "Id de característica."
-#: ../gui/wxpython/gui_modules/wxvdigit.py:460
+#: ../gui/wxpython/gui_modules/wxvdigit.py:461
 #, fuzzy
 msgid "Not enough points for line"
 msgstr "Generar puntos a lo largo de líneas."
@@ -6865,7 +6923,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ghelp.py:340
-#: ../gui/wxpython/gui_modules/goutput.py:629
+#: ../gui/wxpython/gui_modules/goutput.py:641
 #, python-format
 msgid "%d modules match"
 msgstr ""
@@ -6931,11 +6989,11 @@
 #: ../gui/wxpython/gui_modules/ghelp.py:702
 #: ../gui/wxpython/gui_modules/ghelp.py:761
-#: ../gui/wxpython/gui_modules/gmodeler.py:3548
-#: ../gui/wxpython/gui_modules/gmodeler.py:3588
-#: ../gui/wxpython/gui_modules/gmodeler.py:3856
-#: ../gui/wxpython/gui_modules/gmodeler.py:3964
-#: ../gui/wxpython/gui_modules/gmodeler.py:4282
+#: ../gui/wxpython/gui_modules/gmodeler.py:3542
+#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3958
+#: ../gui/wxpython/gui_modules/gmodeler.py:4276
 msgid "Name"
 msgstr ""
@@ -6974,7 +7032,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ghelp.py:815
-#: ../gui/wxpython/gui_modules/gdialogs.py:959
+#: ../gui/wxpython/gui_modules/gdialogs.py:960
 #, fuzzy
 msgid "Options"
 msgstr "Opcional."
@@ -7033,8 +7091,8 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1507
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3295
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
-#: ../gui/wxpython/gui_modules/gdialogs.py:1258
-#: ../gui/wxpython/gui_modules/menuform.py:1691
+#: ../gui/wxpython/gui_modules/gdialogs.py:1259
+#: ../gui/wxpython/gui_modules/menuform.py:1684
 msgid "Browse"
 msgstr "Explorar"
@@ -7113,8 +7171,8 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:874
 #: ../gui/wxpython/gui_modules/location_wizard.py:1037
 #: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/gui_modules/gmodeler.py:3549
-#: ../gui/wxpython/gui_modules/gmodeler.py:3608
+#: ../gui/wxpython/gui_modules/gmodeler.py:3543
+#: ../gui/wxpython/gui_modules/gmodeler.py:3602
 msgid "Description"
 msgstr "Descripción."
@@ -7216,7 +7274,7 @@
 msgstr "Ruta al archivo de códigos EPSG:"
 #: ../gui/wxpython/gui_modules/location_wizard.py:1286
-#: ../gui/wxpython/gui_modules/preferences.py:1814
+#: ../gui/wxpython/gui_modules/preferences.py:1836
 msgid "EPSG code:"
 msgstr "Código EPSG:"
@@ -7497,7 +7555,7 @@
 msgstr "Seleccionar mapa vectorial:"
 #: ../gui/wxpython/gui_modules/vclean.py:168
-#: ../gui/wxpython/gui_modules/menuform.py:832
+#: ../gui/wxpython/gui_modules/menuform.py:833
 #, fuzzy
 msgid "Copy the current command string to the clipboard (Ctrl+C)"
 msgstr "Copiar la cadena del comando actual al portapapeles."
@@ -7587,293 +7645,293 @@
 msgid "Vector cleaning command copied to clipboard"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:70
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:48
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:55
+#: ../gui/wxpython/gui_modules/nviz_tools.py:136
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:52
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:59
 msgid "View"
 msgstr "Visualización."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:74
-#: ../gui/wxpython/gui_modules/gmodeler.py:3154
+#: ../gui/wxpython/gui_modules/gmodeler.py:3148
 #, fuzzy
 msgid "Data"
 msgstr "Base de datos."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:78
-#: ../gui/wxpython/gui_modules/preferences.py:1236
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/preferences.py:1240
 msgid "Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:112
+#: ../gui/wxpython/gui_modules/nviz_tools.py:216
 msgid "Control View"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:120
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1146
+#: ../gui/wxpython/gui_modules/nviz_tools.py:226
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1360
 msgid "W"
 msgstr "W"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:122
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1148
+#: ../gui/wxpython/gui_modules/nviz_tools.py:227
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1362
 msgid "N"
 msgstr "N"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:129
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1155
+#: ../gui/wxpython/gui_modules/nviz_tools.py:228
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1369
 msgid "S"
 msgstr "S"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:131
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+#: ../gui/wxpython/gui_modules/nviz_tools.py:229
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
 msgid "E"
 msgstr "E"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:140
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:64
+#: ../gui/wxpython/gui_modules/nviz_tools.py:230
+#, fuzzy
+msgid "NW"
+msgstr "W"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:231
+#, fuzzy
+msgid "NE"
+msgstr "N"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:232
+#, fuzzy
+msgid "SE"
+msgstr "S"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:233
+#, fuzzy
+msgid "SW"
+msgstr "W"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:68
 msgid "Perspective:"
 msgstr "Perspectiva:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:150
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:143
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
 msgid "Twist:"
 msgstr "Giro:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:168
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1167
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:124
-#: ../gui/wxpython/gui_modules/gmodeler.py:3128
-#: ../gui/wxpython/gui_modules/gmodeler.py:3247
+#: ../gui/wxpython/gui_modules/nviz_tools.py:290
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1381
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:128
+#: ../gui/wxpython/gui_modules/gmodeler.py:3122
+#: ../gui/wxpython/gui_modules/gmodeler.py:3241
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4038
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4181
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4829
-#: ../gui/wxpython/gui_modules/gdialogs.py:1634
+#: ../gui/wxpython/gui_modules/gdialogs.py:1635
 msgid "Height:"
 msgstr "Altitud:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:175
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:173
+#: ../gui/wxpython/gui_modules/nviz_tools.py:296
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:177
 msgid "Z-exag:"
 msgstr "Exageración Z:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
-msgid "Look at:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:309
+#, fuzzy
+msgid "Look:"
 msgstr "Mirar hacia:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+#: ../gui/wxpython/gui_modules/nviz_tools.py:312
+#, fuzzy
+msgid "here"
+msgstr "Esfera."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:318
+#, fuzzy
+msgid "center"
+msgstr "Renderizar"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:324
 msgid "top"
 msgstr "Superior."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
-msgid "north"
-msgstr "Norte."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
-msgid "south"
-msgstr "Sur."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:197
-msgid "east"
-msgstr "Este."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:198
-msgid "west"
-msgstr "Oeste."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:199
-msgid "north-west"
-msgstr "Nor - oeste."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:200
-msgid "north-east"
-msgstr "Nor - este."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:201
-msgid "south-east"
-msgstr "Sur - este."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:202
-msgid "south-west"
-msgstr "Sur - oeste."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:210
-msgid "Reset"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:330
+#, fuzzy
+msgid "reset"
 msgstr "Reiniciar."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:211
+#: ../gui/wxpython/gui_modules/nviz_tools.py:331
 msgid "Reset to default view"
 msgstr "Reiniciar a la visualización predeterminada."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:233
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:205
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:209
 msgid "Image Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:240
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:212
-#: ../gui/wxpython/gui_modules/preferences.py:1452
+#: ../gui/wxpython/gui_modules/nviz_tools.py:357
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:217
+#: ../gui/wxpython/gui_modules/preferences.py:1474
 msgid "Background color:"
 msgstr "Color de fondo:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:272
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:394
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1471
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:353
 msgid "Surface"
 msgstr "Superficie."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:277
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:237
+#: ../gui/wxpython/gui_modules/nviz_tools.py:400
+#: ../gui/wxpython/gui_modules/nviz_tools.py:757
+#, fuzzy
+msgid "Constant surface"
+msgstr "Superficies de coste."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:405
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:457
 msgid "Vector"
 msgstr "Vector."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:282
+#: ../gui/wxpython/gui_modules/nviz_tools.py:411
 #, fuzzy
 msgid "Volume"
 msgstr "Volúmenes."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:298
+#: ../gui/wxpython/gui_modules/nviz_tools.py:435
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:243
 #, fuzzy
 msgid "Lighting"
 msgstr "Resaltar."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:302
+#: ../gui/wxpython/gui_modules/nviz_tools.py:440
 msgid "Fringe"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:342
-msgid "Surface attributes"
-msgstr "Atributos de superficie."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:349
-msgid "Topography"
-msgstr "Topografía."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:350
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
-#: ../gui/wxpython/gui_modules/profile.py:1222
-msgid "Color"
-msgstr "Reglas de color."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:352
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1028
-msgid "Transparency"
-msgstr "Transparencia."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:353
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
-msgid "Shininess"
-msgstr "Brillantez."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:354
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1030
-msgid "Emission"
-msgstr "Emisión."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:360
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1038
-msgid "map"
-msgstr "Mapa."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:363
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1043
-msgid "unset"
-msgstr "Desestablecer."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:368
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1048
-msgid "constant"
-msgstr "Constante."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:428
-#: ../gui/wxpython/gui_modules/nviz_tools.py:915
+#: ../gui/wxpython/gui_modules/nviz_tools.py:488
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1126
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:362
 msgid "Draw"
 msgstr "Dibujar."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:435
-#: ../gui/wxpython/gui_modules/nviz_tools.py:922
+#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1133
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:368
 msgid "Mode:"
 msgstr "Modo:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:438
+#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
 msgid "coarse"
 msgstr "Grueso."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:439
+#: ../gui/wxpython/gui_modules/nviz_tools.py:499
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:372
 msgid "fine"
 msgstr "Fino."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:440
+#: ../gui/wxpython/gui_modules/nviz_tools.py:500
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:373
 msgid "both"
 msgstr "Ambos."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:450
-#: ../gui/wxpython/gui_modules/nviz_tools.py:936
+#: ../gui/wxpython/gui_modules/nviz_tools.py:509
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1147
 msgid "Shading:"
 msgstr "Sombreado:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:453
-#: ../gui/wxpython/gui_modules/nviz_tools.py:709
-#: ../gui/wxpython/gui_modules/nviz_tools.py:939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:512
+#: ../gui/wxpython/gui_modules/nviz_tools.py:920
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1150
 msgid "flat"
 msgstr "Plano:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:454
-#: ../gui/wxpython/gui_modules/nviz_tools.py:940
+#: ../gui/wxpython/gui_modules/nviz_tools.py:513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1151
 msgid "gouraud"
 msgstr "Gourard."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:462
+#: ../gui/wxpython/gui_modules/nviz_tools.py:521
 msgid "Set to all"
 msgstr "Seleccionar todo"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:463
+#: ../gui/wxpython/gui_modules/nviz_tools.py:522
 msgid "Use draw settings for all loaded surfaces"
 msgstr "Utilizar ajustes de dibujo para todas las superficies cargadas."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:470
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:400
 #, fuzzy
-msgid "Coarse:"
+msgid "Coarse mode:"
 msgstr "Grosor:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:524
-msgid "res."
-msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:387
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:404
+#, fuzzy
+msgid "resolution:"
+msgstr "Resolución."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:492
+#: ../gui/wxpython/gui_modules/nviz_tools.py:545
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:416
 #, fuzzy
-msgid "style"
+msgid "style:"
 msgstr "Estilo."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:548
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
 msgid "wire"
 msgstr "Alambre."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:549
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:420
 msgid "surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:505
+#: ../gui/wxpython/gui_modules/nviz_tools.py:561
 #, fuzzy
-msgid "wire color"
+msgid "Change wire color"
 msgstr "Color del alambre."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:519
+#: ../gui/wxpython/gui_modules/nviz_tools.py:568
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:383
 #, fuzzy
-msgid "Fine:"
+msgid "Fine mode:"
 msgstr "Fineza:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
-msgid "Mask zeros:"
-msgstr "Enmascarar ceros:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:593
+msgid "Surface attributes"
+msgstr "Atributos de superficie."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
-msgid "by elevation"
-msgstr "Por elevación."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:601
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1222
+msgid "Color"
+msgstr "Reglas de color."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:563
-msgid "by color"
-msgstr "Por color."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:603
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1239
+msgid "Transparency"
+msgstr "Transparencia."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:578
+#: ../gui/wxpython/gui_modules/nviz_tools.py:604
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1240
+msgid "Shininess"
+msgstr "Brillantez."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:610
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1249
+msgid "map"
+msgstr "Mapa."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:613
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1254
+msgid "unset"
+msgstr "Desestablecer."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1259
+msgid "constant"
+msgstr "Constante."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:671
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4008
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4577
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4793
@@ -7882,165 +7940,204 @@
 msgid "Position"
 msgstr "Posición."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:653
+#: ../gui/wxpython/gui_modules/nviz_tools.py:686
+msgid "Reset"
+msgstr "Reiniciar."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:687
+#, fuzzy
+msgid "Reset to default position"
+msgstr "Reiniciar a la visualización predeterminada."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:785
+#, fuzzy
+msgid "Fine resolution:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:797
+#, fuzzy
+msgid "Value:"
+msgstr "Valores."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:863
 msgid "Show vector lines"
 msgstr "Mostrar líneas vectoriales."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:663
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:245
+#: ../gui/wxpython/gui_modules/nviz_tools.py:873
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:465
 msgid "Vector lines"
 msgstr "Lineas vectoriales."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:669
+#: ../gui/wxpython/gui_modules/nviz_tools.py:880
 #, fuzzy
 msgid "Line:"
 msgstr "Línea."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:672
-#: ../gui/wxpython/gui_modules/nviz_tools.py:805
-#, fuzzy
-msgid "width"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:883
+msgid "width:"
 msgstr "Anchura de línea:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:688
-#: ../gui/wxpython/gui_modules/nviz_tools.py:790
-#, fuzzy
-msgid "color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:899
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1001
+msgid "color:"
 msgstr "Color:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:703
-#, fuzzy
-msgid "display"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+#: ../gui/wxpython/gui_modules/vdigit.py:158
+msgid "Display"
 msgstr "Mostrar."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:708
-msgid "on surface"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:919
+#, fuzzy
+msgid "on surface(s):"
 msgstr "En superficie."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:718
-#: ../gui/wxpython/gui_modules/nviz_tools.py:836
+#: ../gui/wxpython/gui_modules/nviz_tools.py:929
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1050
 msgid "Height above surface:"
 msgstr "Altura sobre la superficie."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:754
+#: ../gui/wxpython/gui_modules/nviz_tools.py:964
 msgid "Show vector points"
 msgstr "Mostrar puntos vectoriales."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:973
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:487
 msgid "Vector points"
 msgstr "Puntos vectoriales."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:769
+#: ../gui/wxpython/gui_modules/nviz_tools.py:980
 #, fuzzy
 msgid "Icon:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:772
-msgid "size"
-msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:983
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
+#, fuzzy
+msgid "size:"
+msgstr "Tamaño:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:823
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1016
 #, fuzzy
-msgid "symbol"
+msgid "width"
+msgstr "Anchura de línea:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1033
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
+msgid "symbol:"
 msgstr "Simbolo:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:892
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1046
 #, fuzzy
+msgid "Display on surface(s):"
+msgstr "Distancia a lo largo de un transecto."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
+#, fuzzy
 msgid "3D raster map"
 msgstr "Mapa raster 3D."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:925
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1136
 msgid "isosurfaces"
 msgstr "Isosuperficies."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1137
 msgid "slides"
 msgstr "Diapositivas."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:949
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1160
 msgid "Resolution:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:971
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
 msgid "List of isosurfaces"
 msgstr "Lista de isosuperficies."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1019
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1230
 msgid "Isosurface attributes"
 msgstr "Atributos de isosuperficies."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1025
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1236
 msgid "Topography level"
 msgstr "Nivel de topografía."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1241
+msgid "Emission"
+msgstr "Emisión."
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1342
 #, fuzzy
 msgid "Show light model"
 msgstr "Mostrar líneas."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1135
-msgid "Follow source viewpoint"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1141
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1355
 #, fuzzy
 msgid "Light source position"
 msgstr "Seleccionar localización de origen:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1185
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1399
 msgid "Light color and intensity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1199
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1413
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:299
 #, fuzzy
 msgid "Brightness:"
 msgstr "Riqueza."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1423
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
 msgid "Ambient:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1270
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1485
 msgid "Edges with fringe"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1487
 msgid "N && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1488
 msgid "N && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1489
 msgid "S && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1275
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1490
 msgid "S && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1295
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1510
 msgid "Elevation of fringe from bottom:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2309
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2311
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1563
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1608
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1186
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1204
+#, fuzzy
+msgid "constant#"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2667
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2669
 msgid "Level"
 msgstr "Nivel."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2632
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3003
 #, fuzzy
 msgid "Vector map is 3D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2635
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3006
 #, fuzzy
 msgid "Vector map is 2D"
 msgstr "El mapa vectorial <%s> es bidimensional (2D)."
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2637
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3008
 msgid "%(features)d features (%(points)d points)"
 msgstr "%(primitives)d primitivas (%(points)d puntos)."
@@ -8065,8 +8162,8 @@
 msgstr "Lista de capas"
 #: ../gui/wxpython/gui_modules/ogc_services.py:69
-#: ../gui/wxpython/gui_modules/gdialogs.py:1153
-#: ../gui/wxpython/gui_modules/gdialogs.py:1263
+#: ../gui/wxpython/gui_modules/gdialogs.py:1154
+#: ../gui/wxpython/gui_modules/gdialogs.py:1264
 msgid "Add imported layers into layer tree"
 msgstr "Añadir las capas importadas al árbol de capas."
@@ -8080,14 +8177,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ogc_services.py:85
-#: ../gui/wxpython/gui_modules/gdialogs.py:998
-#: ../gui/wxpython/gui_modules/gdialogs.py:1165
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
+#: ../gui/wxpython/gui_modules/gdialogs.py:1166
 msgid "&Import"
 msgstr "&Importar."
 #: ../gui/wxpython/gui_modules/ogc_services.py:86
-#: ../gui/wxpython/gui_modules/gdialogs.py:999
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/gdialogs.py:1167
 msgid "Import selected layers"
 msgstr "Importar las capas seleccionadas."
@@ -8106,17 +8203,17 @@
 msgid "Layers"
 msgstr "Capa"
-#: ../gui/wxpython/gui_modules/prompt.py:393
+#: ../gui/wxpython/gui_modules/prompt.py:394
 #, python-format
 msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:396
+#: ../gui/wxpython/gui_modules/prompt.py:397
 #, python-format
 msgid "Warning: option <%(param)s> not found in '%(module)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:617
+#: ../gui/wxpython/gui_modules/prompt.py:618
 msgid "Type GRASS command and run by pressing ENTER"
 msgstr "Teclee un comando GRASS, para ejecutarlo presione la tecla ENTER."
@@ -8141,7 +8238,7 @@
 msgstr "Nombre de columna."
 #: ../gui/wxpython/gui_modules/gselect.py:1083
-#: ../gui/wxpython/gui_modules/menuform.py:1690
+#: ../gui/wxpython/gui_modules/menuform.py:1683
 msgid "File"
 msgstr "Archivo"
@@ -8226,7 +8323,7 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1285
-#: ../gui/wxpython/gui_modules/gmodeler.py:3331
+#: ../gui/wxpython/gui_modules/gmodeler.py:3325
 msgid "Name:"
 msgstr ""
@@ -8244,62 +8341,74 @@
 msgid "Unable to save settings."
 msgstr "No se puede analizar la orden %s ."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:29
 #, fuzzy
 msgid "3D view settings"
 msgstr "ráster"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:67
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:146
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:71
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:180
 msgid "(value)"
 msgstr "(valor)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:79
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:127
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:158
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:187
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:83
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:131
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:162
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:191
 msgid "(step)"
 msgstr "(paso)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:94
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:98
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:258
 msgid "Position:"
 msgstr "Posición:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:97
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:101
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:261
 msgid "(x)"
 msgstr "(x)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:252
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:249
+#, fuzzy
+msgid "Light"
+msgstr "Resaltar."
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:285
+#, fuzzy
+msgid "(z)"
+msgstr "(x)"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:431
+#, fuzzy
+msgid "wire color:"
+msgstr "Color del alambre."
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
 msgid "Show lines"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:274
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:494
 msgid "Show points"
 msgstr "Mostrar puntos."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:283
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:503
 msgid "Size:"
 msgstr "Tamaño:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:298
-#: ../gui/wxpython/gui_modules/gmodeler.py:3110
-#: ../gui/wxpython/gui_modules/gmodeler.py:3229
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:518
+#: ../gui/wxpython/gui_modules/gmodeler.py:3104
+#: ../gui/wxpython/gui_modules/gmodeler.py:3223
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4026
-#: ../gui/wxpython/gui_modules/gdialogs.py:1630
+#: ../gui/wxpython/gui_modules/gdialogs.py:1631
 msgid "Width:"
 msgstr "Anchura:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:533
 msgid "Marker:"
 msgstr "Marcador:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
-#, python-format
-msgid "Nviz settings saved to file <%s>."
-msgstr "Los ajustes de Nviz se han guardado en el archivo <%s>."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:695
 msgid "3D view settings saved to file <%s>."
@@ -8315,8 +8424,8 @@
 #: ../gui/wxpython/gui_modules/gcmd.py:349
 #: ../gui/wxpython/gui_modules/render.py:627
 #: ../gui/wxpython/gui_modules/render.py:630
-#: ../gui/wxpython/gui_modules/menuform.py:2167
-#: ../gui/wxpython/gui_modules/menuform.py:2170
+#: ../gui/wxpython/gui_modules/menuform.py:2160
+#: ../gui/wxpython/gui_modules/menuform.py:2163
 msgid "Details:"
 msgstr "Detalles."
@@ -8341,23 +8450,19 @@
 "usuario."
 #: ../gui/wxpython/gui_modules/vdigit.py:92
-#: ../gui/wxpython/gui_modules/gmodeler.py:3319
+#: ../gui/wxpython/gui_modules/gmodeler.py:3313
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1703
 #: ../gui/wxpython/gui_modules/profile.py:1040
 #: ../gui/wxpython/gui_modules/profile.py:1393
-#: ../gui/wxpython/gui_modules/preferences.py:966
+#: ../gui/wxpython/gui_modules/preferences.py:971
 msgid "Close dialog and ignore changes"
 msgstr "Cerrar el diálogo e ignorar los cambios."
 #: ../gui/wxpython/gui_modules/vdigit.py:151
-#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_modules/preferences.py:1109
 msgid "General"
 msgstr "General."
-#: ../gui/wxpython/gui_modules/vdigit.py:158
-msgid "Display"
-msgstr "Mostrar."
 #: ../gui/wxpython/gui_modules/vdigit.py:163
 #: ../gui/wxpython/gui_modules/profile.py:1174
 msgid "Line width"
@@ -8472,7 +8577,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:377
-#: ../gui/wxpython/gui_modules/preferences.py:1669
+#: ../gui/wxpython/gui_modules/preferences.py:1691
 msgid "Attributes"
 msgstr "Atributos."
@@ -8644,20 +8749,20 @@
 "El número de capa debe ser mayor que cero."
 #: ../gui/wxpython/gui_modules/vdigit.py:1060
-#: ../gui/wxpython/gui_modules/gmodeler.py:3785
-#: ../gui/wxpython/gui_modules/gmodeler.py:4142
+#: ../gui/wxpython/gui_modules/gmodeler.py:3779
+#: ../gui/wxpython/gui_modules/gmodeler.py:4136
 msgid "Delete selected"
 msgstr "Borrar lo seleccionado."
 #: ../gui/wxpython/gui_modules/vdigit.py:1064
-#: ../gui/wxpython/gui_modules/gmodeler.py:3786
-#: ../gui/wxpython/gui_modules/gmodeler.py:4143
+#: ../gui/wxpython/gui_modules/gmodeler.py:3780
+#: ../gui/wxpython/gui_modules/gmodeler.py:4137
 msgid "Delete all"
 msgstr "Borrar todo."
 #: ../gui/wxpython/gui_modules/vdigit.py:1066
-#: ../gui/wxpython/gui_modules/gmodeler.py:3792
-#: ../gui/wxpython/gui_modules/gmodeler.py:4150
+#: ../gui/wxpython/gui_modules/gmodeler.py:3786
+#: ../gui/wxpython/gui_modules/gmodeler.py:4144
 #: ../gui/wxpython/gui_modules/dbm.py:1146
 #: ../gui/wxpython/gui_modules/dbm.py:1659
 msgid "Reload"
@@ -8753,6 +8858,11 @@
 msgid "Preview generated"
 msgstr ""
+#: ../gui/wxpython/gui_modules/psmap.py:353
+#, fuzzy
+msgid "Save file as"
+msgstr "Guardar archivo como..."
 #: ../gui/wxpython/gui_modules/psmap.py:392
 msgid "Failed to read file %s."
@@ -8768,25 +8878,25 @@
 msgid "Scalebar is not appropriate for this projection"
 msgstr "Introducir parámetros para la proyección %s:"
-#: ../gui/wxpython/gui_modules/psmap.py:861
+#: ../gui/wxpython/gui_modules/psmap.py:860
 #, fuzzy
 msgid "wxGUI Hardcopy Map Utility"
-#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/psmap.py:862
 msgid ""
 "(C) 2011 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:864
-#: ../gui/wxpython/gui_modules/gmodeler.py:1236
+#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/gmodeler.py:1230
 msgid ""
 "This program is free software under the GNU General Public License(>=v2). "
 "Read the file COPYING that comes with GRASS for details."
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:1095
+#: ../gui/wxpython/gui_modules/psmap.py:1094
 msgid "Click and drag to resize object"
 msgstr ""
@@ -8914,7 +9024,7 @@
 #: ../gui/wxpython/gui_modules/gmodeler.py:451
-#: ../gui/wxpython/gui_modules/gmodeler.py:574
+#: ../gui/wxpython/gui_modules/gmodeler.py:568
 #, fuzzy
 msgid "Variables"
 msgstr "Enlistar tablas"
@@ -8924,54 +9034,54 @@
 msgid "GRASS GIS Graphical Modeler"
 msgstr "Ayuda del SIG GRASS."
-#: ../gui/wxpython/gui_modules/gmodeler.py:572
+#: ../gui/wxpython/gui_modules/gmodeler.py:566
 #, fuzzy
 msgid "Model"
 msgstr "Modo."
-#: ../gui/wxpython/gui_modules/gmodeler.py:573
+#: ../gui/wxpython/gui_modules/gmodeler.py:567
 msgid "Items"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:642
+#: ../gui/wxpython/gui_modules/gmodeler.py:636
 msgid "Redrawing model..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:669
+#: ../gui/wxpython/gui_modules/gmodeler.py:663
 #, fuzzy
 msgid "Do you want to save changes in the model?"
 msgstr "¿Desea guardar los cambios en el entorno de trabajo?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:671
+#: ../gui/wxpython/gui_modules/gmodeler.py:665
 #, fuzzy
 msgid "Do you want to store current model settings to model file?"
 msgstr ""
 "¿Desea guardar los ajustes actuales en un archivo de entorno de trabajo?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:738
+#: ../gui/wxpython/gui_modules/gmodeler.py:732
 #: ../gui/wxpython/gui_modules/dbm.py:2084
 msgid "Nothing to delete."
 msgstr "No hay algo para eliminar."
-#: ../gui/wxpython/gui_modules/gmodeler.py:742
+#: ../gui/wxpython/gui_modules/gmodeler.py:736
 msgid "Do you want to permanently delete data?%s"
 msgstr "¿Desea guardar los cambios en el mapa vectorial <%s>?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:743
+#: ../gui/wxpython/gui_modules/gmodeler.py:737
 #, fuzzy
 msgid "Delete intermediate data?"
 msgstr "Eliminar lo filtrado."
-#: ../gui/wxpython/gui_modules/gmodeler.py:757
+#: ../gui/wxpython/gui_modules/gmodeler.py:751
 msgid "%d maps deleted from current mapset"
 msgstr ""
 "Elimina archivos de elementos de bases de datos del directorio de mapas "
 "actual del usuario."
-#: ../gui/wxpython/gui_modules/gmodeler.py:772
-#: ../gui/wxpython/gui_modules/gmodeler.py:885
+#: ../gui/wxpython/gui_modules/gmodeler.py:766
+#: ../gui/wxpython/gui_modules/gmodeler.py:879
 #, fuzzy
 msgid ""
 "Current model is not empty. Do you want to store current settings to model "
@@ -8980,55 +9090,55 @@
 "El área de trabajo actual no está vacía. ¿Desea guardar los ajustes actuales "
 "en un archivo de espacio de trabajo?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:775
-#: ../gui/wxpython/gui_modules/gmodeler.py:888
+#: ../gui/wxpython/gui_modules/gmodeler.py:769
+#: ../gui/wxpython/gui_modules/gmodeler.py:882
 #, fuzzy
 msgid "Create new model?"
 msgstr "Crear un nuevo directorio de mapas de usuario (mapset)."
-#: ../gui/wxpython/gui_modules/gmodeler.py:800
+#: ../gui/wxpython/gui_modules/gmodeler.py:794
 #, fuzzy
 msgid "Choose model file"
 msgstr "Seleccionar archivo DXF:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:818
+#: ../gui/wxpython/gui_modules/gmodeler.py:812
 #, python-format
 msgid "%(items)d items (%(actions)d actions) loaded into model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:825
-#: ../gui/wxpython/gui_modules/gmodeler.py:862
+#: ../gui/wxpython/gui_modules/gmodeler.py:819
+#: ../gui/wxpython/gui_modules/gmodeler.py:856
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
 "El archivo de entorno de trabajo <%s> ya existe. ¿Quiere sobrescribirlo?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:835
-#: ../gui/wxpython/gui_modules/gmodeler.py:875
+#: ../gui/wxpython/gui_modules/gmodeler.py:829
+#: ../gui/wxpython/gui_modules/gmodeler.py:869
 msgid "File <%s> saved"
 msgstr "Archivo de PUNTOS <%s> guardado."
-#: ../gui/wxpython/gui_modules/gmodeler.py:844
+#: ../gui/wxpython/gui_modules/gmodeler.py:838
 #, fuzzy
 msgid "Choose file to save current model"
 msgstr ""
 "Seleccione el archivo donde guardar la configuración del espacio de trabajo "
 "actual."
-#: ../gui/wxpython/gui_modules/gmodeler.py:864
+#: ../gui/wxpython/gui_modules/gmodeler.py:858
 msgid "File already exists"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:912
+#: ../gui/wxpython/gui_modules/gmodeler.py:906
 msgid "Model is empty. Nothing to run."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:999
+#: ../gui/wxpython/gui_modules/gmodeler.py:993
 msgid "Model is empty. Nothing to validate."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1006
+#: ../gui/wxpython/gui_modules/gmodeler.py:1000
 msgid ""
 "Model is not valid.\n"
@@ -9039,49 +9149,49 @@
 "\n"
 "%s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1009
+#: ../gui/wxpython/gui_modules/gmodeler.py:1003
 msgid "Model is valid."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1070
-#: ../gui/wxpython/gui_modules/gmodeler.py:1113
+#: ../gui/wxpython/gui_modules/gmodeler.py:1064
+#: ../gui/wxpython/gui_modules/gmodeler.py:1107
 #, python-format
 msgid "Model exported to <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1078
+#: ../gui/wxpython/gui_modules/gmodeler.py:1072
 #, fuzzy
 msgid "Choose file to save"
 msgstr ""
 "Seleccione el archivo que contiene los parámetros de configuración del "
 "espacio de trabajo (.GRC) a cargar."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1080
+#: ../gui/wxpython/gui_modules/gmodeler.py:1074
 msgid "Python script (*.py)|*.py"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1094
+#: ../gui/wxpython/gui_modules/gmodeler.py:1088
 msgid "File <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1096
+#: ../gui/wxpython/gui_modules/gmodeler.py:1090
 #, fuzzy
 msgid "Save file"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1233
+#: ../gui/wxpython/gui_modules/gmodeler.py:1227
 msgid "wxGUI Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1235
+#: ../gui/wxpython/gui_modules/gmodeler.py:1229
 msgid ""
 "(C) 2010 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1366
+#: ../gui/wxpython/gui_modules/gmodeler.py:1360
 msgid ""
 "Reading model file <%s> failed.\n"
@@ -9091,106 +9201,106 @@
 "espacio de trabajo (.GRC) <%s> ha fallado. Archivo no válido. No ha sido "
 "posible analizar el documento XML."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1372
+#: ../gui/wxpython/gui_modules/gmodeler.py:1366
 #, fuzzy
 msgid "Please wait, loading model..."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1427
+#: ../gui/wxpython/gui_modules/gmodeler.py:1421
 #, fuzzy
 msgid "Writing current settings to model file failed."
 msgstr ""
 "La escritura del archivo de configuración del espacio de trabajo actual (% "
 "s) ha fallado."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1728
-#: ../gui/wxpython/gui_modules/gmodeler.py:1785
-#: ../gui/wxpython/gui_modules/gmodeler.py:1912
-#: ../gui/wxpython/gui_modules/menuform.py:384
+#: ../gui/wxpython/gui_modules/gmodeler.py:1722
+#: ../gui/wxpython/gui_modules/gmodeler.py:1779
+#: ../gui/wxpython/gui_modules/gmodeler.py:1906
+#: ../gui/wxpython/gui_modules/menuform.py:385
 msgid "unknown"
 msgstr "Desconocido."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2010
+#: ../gui/wxpython/gui_modules/gmodeler.py:2004
 msgid "<not defined>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2020
+#: ../gui/wxpython/gui_modules/gmodeler.py:2014
 #, fuzzy
 msgid "Data properties"
 msgstr "Propiedades de capa."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2027
+#: ../gui/wxpython/gui_modules/gmodeler.py:2021
 #, fuzzy
 msgid "Name of raster map:"
 msgstr "Mapa raster recodificado:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2029
+#: ../gui/wxpython/gui_modules/gmodeler.py:2023
 #, fuzzy
 msgid "Name of vector map:"
 msgstr "Nombre para el nuevo mapa vectorial:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2031
+#: ../gui/wxpython/gui_modules/gmodeler.py:2025
 msgid "Name of element:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2224
+#: ../gui/wxpython/gui_modules/gmodeler.py:2218
 #: ../gui/wxpython/gui_modules/layertree.py:272
 msgid "Remove"
 msgstr "Remover."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2228
+#: ../gui/wxpython/gui_modules/gmodeler.py:2222
 #, fuzzy
 msgid "Disable"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+#: ../gui/wxpython/gui_modules/gmodeler.py:2225
 #, fuzzy
 msgid "Enable"
 msgstr "Tabla."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2236
+#: ../gui/wxpython/gui_modules/gmodeler.py:2230
 #, fuzzy
 msgid "Add control point"
 msgstr "Punto de control sobre el terreno (GCP)."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2238
+#: ../gui/wxpython/gui_modules/gmodeler.py:2232
 #, fuzzy
 msgid "Remove control point"
 msgstr "Establecer puntos de control sobre el terreno (GCP)."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2245
+#: ../gui/wxpython/gui_modules/gmodeler.py:2239
 msgid "Intermediate"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2256
+#: ../gui/wxpython/gui_modules/gmodeler.py:2250
 #: ../gui/wxpython/gui_modules/layertree.py:286
 msgid "Properties"
 msgstr "Propiedades."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2260
+#: ../gui/wxpython/gui_modules/gmodeler.py:2254
 #, fuzzy
 msgid "Change ID"
 msgstr "Cambiar valores."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2316
+#: ../gui/wxpython/gui_modules/gmodeler.py:2310
 msgid "Add new GRASS module to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2334
-#: ../gui/wxpython/gui_modules/gmodeler.py:3857
-#: ../gui/wxpython/gui_modules/gmodeler.py:4283
-#: ../gui/wxpython/gui_modules/preferences.py:1518
+#: ../gui/wxpython/gui_modules/gmodeler.py:2328
+#: ../gui/wxpython/gui_modules/gmodeler.py:3851
+#: ../gui/wxpython/gui_modules/gmodeler.py:4277
+#: ../gui/wxpython/gui_modules/preferences.py:1540
 msgid "Command"
 msgstr "Comando."
-#: ../gui/wxpython/gui_modules/gmodeler.py:2402
+#: ../gui/wxpython/gui_modules/gmodeler.py:2396
 msgid ""
 "Command not defined.\n"
 "\n"
 "Unable to add new action to the model."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2408
+#: ../gui/wxpython/gui_modules/gmodeler.py:2402
 #, python-format
 msgid ""
 "'%s' is not a GRASS module.\n"
@@ -9198,198 +9308,198 @@
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3018
+#: ../gui/wxpython/gui_modules/gmodeler.py:3012
 #, fuzzy
 msgid "Action"
 msgstr "Dirección."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3023
+#: ../gui/wxpython/gui_modules/gmodeler.py:3017
 msgid "Validity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3031
+#: ../gui/wxpython/gui_modules/gmodeler.py:3025
 #, fuzzy
 msgid "Valid:"
 msgstr "Intervalo válido."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3048
+#: ../gui/wxpython/gui_modules/gmodeler.py:3042
 #, fuzzy
 msgid "Invalid:"
 msgstr "Valor no válido: %s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3065
+#: ../gui/wxpython/gui_modules/gmodeler.py:3059
 msgid "Running:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3082
+#: ../gui/wxpython/gui_modules/gmodeler.py:3076
 #, fuzzy
 msgid "Disabled:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3102
-#: ../gui/wxpython/gui_modules/gmodeler.py:3221
+#: ../gui/wxpython/gui_modules/gmodeler.py:3096
+#: ../gui/wxpython/gui_modules/gmodeler.py:3215
 #, fuzzy
 msgid "Shape size"
 msgstr "Índice de forma."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3159
+#: ../gui/wxpython/gui_modules/gmodeler.py:3153
 #: ../gui/wxpython/gui_modules/profile.py:1252
 msgid "Type"
 msgstr "Tipo."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3167
+#: ../gui/wxpython/gui_modules/gmodeler.py:3161
 #, fuzzy
 msgid "Raster:"
 msgstr "Raster."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3184
+#: ../gui/wxpython/gui_modules/gmodeler.py:3178
 #, fuzzy
 msgid "3D raster:"
 msgstr "raster 3D."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3201
+#: ../gui/wxpython/gui_modules/gmodeler.py:3195
 #, fuzzy
 msgid "Vector:"
 msgstr "Vector."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3295
+#: ../gui/wxpython/gui_modules/gmodeler.py:3289
 #: ../gui/wxpython/gui_modules/layertree.py:374
 #: ../gui/wxpython/gui_modules/layertree.py:407
 msgid "Metadata"
 msgstr "Metadatos."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3297
+#: ../gui/wxpython/gui_modules/gmodeler.py:3291
 #, fuzzy
 msgid "Commands"
 msgstr "Comando."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3317
+#: ../gui/wxpython/gui_modules/gmodeler.py:3311
 #, fuzzy
 msgid "Apply properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3340
+#: ../gui/wxpython/gui_modules/gmodeler.py:3334
 #, fuzzy
 msgid "Description:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3349
+#: ../gui/wxpython/gui_modules/gmodeler.py:3343
 #, fuzzy
 msgid "Author(s):"
 msgstr "Autores."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3398
+#: ../gui/wxpython/gui_modules/gmodeler.py:3392
 #, fuzzy
 msgid "Model parameters"
 msgstr "Parámetros del terreno."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3545
+#: ../gui/wxpython/gui_modules/gmodeler.py:3539
 #, fuzzy
 msgid "List of variables - right-click to delete"
 msgstr "Lista de categorías - haga clic derecho para eliminar."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3595
+#: ../gui/wxpython/gui_modules/gmodeler.py:3589
 #: ../gui/wxpython/gui_modules/dbm.py:885
 #: ../gui/wxpython/gui_modules/dbm.py:2226
 msgid "Data type"
 msgstr "Tipo de dato."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3601
+#: ../gui/wxpython/gui_modules/gmodeler.py:3595
 #, fuzzy
 msgid "Default value"
 msgstr "Seleccionar valor."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3553
+#: ../gui/wxpython/gui_modules/gmodeler.py:3547
 #, fuzzy
 msgid "Add new variable"
 msgstr "Añadir nuevo vértice."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3557
+#: ../gui/wxpython/gui_modules/gmodeler.py:3551
 #, fuzzy
 msgid "integer"
 msgstr "Puntero."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3558
+#: ../gui/wxpython/gui_modules/gmodeler.py:3552
 msgid "float"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3559
+#: ../gui/wxpython/gui_modules/gmodeler.py:3553
 msgid "string"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3567
+#: ../gui/wxpython/gui_modules/gmodeler.py:3561
 msgid "Add new variable to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3715
+#: ../gui/wxpython/gui_modules/gmodeler.py:3709
 msgid "Variable <%s> already exists in the model. Adding variable failed."
 msgstr ""
 "No ha sido posible crear la nueva tabla <%s> por que esta ya existe en la "
 "base de datos."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3744
+#: ../gui/wxpython/gui_modules/gmodeler.py:3738
 #, fuzzy
 msgid "Do you want to delete all variables from the model?"
 msgstr ""
 "¿Desea remover la(s) capa(s) de mapa seleccionada(s) del árbol de capas?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3746
+#: ../gui/wxpython/gui_modules/gmodeler.py:3740
 #, fuzzy
 msgid "Delete variables"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3826
+#: ../gui/wxpython/gui_modules/gmodeler.py:3820
 #, fuzzy
 msgid "Condition: "
 msgstr "Opcional."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3828
+#: ../gui/wxpython/gui_modules/gmodeler.py:3822
 msgid "Condition: not defined"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3844
 #, fuzzy
 msgid "Condition"
 msgstr "Opcional."
 msgid "ID"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+#: ../gui/wxpython/gui_modules/gmodeler.py:3892
 msgid "loop"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3906
+#: ../gui/wxpython/gui_modules/gmodeler.py:3900
 #, fuzzy
 msgid "Loop properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3912
+#: ../gui/wxpython/gui_modules/gmodeler.py:3906
 #, fuzzy
 msgid "List of items in loop"
 msgstr "Lista de duplicados."
-#: ../gui/wxpython/gui_modules/gmodeler.py:3961
+#: ../gui/wxpython/gui_modules/gmodeler.py:3955
 #, fuzzy
 msgid "List of items - right-click to delete"
 msgid "In block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3965
+#: ../gui/wxpython/gui_modules/gmodeler.py:3959
 #, fuzzy
 msgid "Command / Condition"
 msgstr "Ajustes del diálogo de comandos."
-#: ../gui/wxpython/gui_modules/gmodeler.py:4092
+#: ../gui/wxpython/gui_modules/gmodeler.py:4086
 #: ../gui/wxpython/gui_modules/dbm.py:1178
 #, python-format
 msgid ""
@@ -9399,39 +9509,39 @@
 "Los registros seleccionados (%d) serán borrados permanentemente de la tabla. "
 "¿Desea eliminarlos?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4095
+#: ../gui/wxpython/gui_modules/gmodeler.py:4089
 #: ../gui/wxpython/gui_modules/dbm.py:1181
 #: ../gui/wxpython/gui_modules/dbm.py:1227
 msgid "Delete records"
 msgstr "Borrar todos los registros."
-#: ../gui/wxpython/gui_modules/gmodeler.py:4149
+#: ../gui/wxpython/gui_modules/gmodeler.py:4143
 msgid "Normalize"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4247
+#: ../gui/wxpython/gui_modules/gmodeler.py:4241
 msgid "if-else"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4268
+#: ../gui/wxpython/gui_modules/gmodeler.py:4262
 #, fuzzy
 msgid "If-else properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4274
+#: ../gui/wxpython/gui_modules/gmodeler.py:4268
 msgid "List of items in 'if' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4279
+#: ../gui/wxpython/gui_modules/gmodeler.py:4273
 msgid "List of items in 'else' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:983
+#: ../gui/wxpython/gui_modules/workspace.py:990
 #, python-format
 msgid "Unable to open file <%s> for reading."
 msgstr "No es posible abrir el archivo <%s> para su lectura."
-#: ../gui/wxpython/gui_modules/workspace.py:996
+#: ../gui/wxpython/gui_modules/workspace.py:1003
 #, python-format
 msgid ""
 "Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -9445,7 +9555,7 @@
 "\n"
 "Número de línea(s) omitida(s): %(line) d"
-#: ../gui/wxpython/gui_modules/workspace.py:1214
+#: ../gui/wxpython/gui_modules/workspace.py:1221
 #, python-format
 msgid " row %d:"
 msgstr "Fila %d."
@@ -9545,7 +9655,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1640
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4906
-#: ../gui/wxpython/gui_modules/preferences.py:2163
+#: ../gui/wxpython/gui_modules/preferences.py:2185
 #, fuzzy
 msgid "Font size:"
 msgstr "Tamaño de ícono:"
@@ -9889,10 +9999,6 @@
 msgid "Size and style"
 msgstr "Estilo de linea."
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
-msgid "symbol:"
-msgstr "Simbolo:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3291
 #, fuzzy
 msgid "eps file:"
@@ -9916,11 +10022,6 @@
 msgid "Size"
 msgstr "Tamaño."
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
-#, fuzzy
-msgid "size:"
-msgstr "Tamaño:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3322
 #, fuzzy
 msgid "size from map table column:"
@@ -10130,9 +10231,9 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4596
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5081
 #: ../gui/wxpython/gui_modules/profile.py:967
-#: ../gui/wxpython/gui_modules/preferences.py:1240
-#: ../gui/wxpython/gui_modules/preferences.py:1372
-#: ../gui/wxpython/gui_modules/preferences.py:2114
+#: ../gui/wxpython/gui_modules/preferences.py:1244
+#: ../gui/wxpython/gui_modules/preferences.py:1394
+#: ../gui/wxpython/gui_modules/preferences.py:2136
 msgid "Font settings"
 msgstr "Configuración de tipo de letra."
@@ -10439,11 +10540,11 @@
 "layer instead."
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:606
+#: ../gui/wxpython/gui_modules/goutput.py:605
 msgid "Save file as..."
-#: ../gui/wxpython/gui_modules/goutput.py:721
+#: ../gui/wxpython/gui_modules/goutput.py:733
 #, fuzzy
 msgid ""
 "Please note that the data are left in inconsistent state and may be corrupted"
@@ -10451,147 +10552,147 @@
 "Por favor note que los datos se han dejado en un estado inconsistente y "
 "podrían encontrarse corruptos."
-#: ../gui/wxpython/gui_modules/goutput.py:724
+#: ../gui/wxpython/gui_modules/goutput.py:736
 msgid "Command aborted"
 msgstr "Comando abortado."
-#: ../gui/wxpython/gui_modules/goutput.py:732
+#: ../gui/wxpython/gui_modules/goutput.py:744
 msgid "Command finished"
 msgstr "Comando finalizado."
-#: ../gui/wxpython/gui_modules/wxnviz.py:302
+#: ../gui/wxpython/gui_modules/wxnviz.py:327
 #, fuzzy, python-format
 msgid "Vector map <%s> not found"
 msgstr "No se ha encontrado el mapa <%s> ."
-#: ../gui/wxpython/gui_modules/wxnviz.py:354
-#: ../gui/wxpython/gui_modules/wxnviz.py:366
+#: ../gui/wxpython/gui_modules/wxnviz.py:392
+#: ../gui/wxpython/gui_modules/wxnviz.py:404
 msgid "3d raster map <%s> not found"
-#: ../gui/wxpython/gui_modules/toolbars.py:211
+#: ../gui/wxpython/gui_modules/toolbars.py:217
 msgid "3D view mode not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:212
-#: ../gui/wxpython/gui_modules/toolbars.py:229
+#: ../gui/wxpython/gui_modules/toolbars.py:218
+#: ../gui/wxpython/gui_modules/toolbars.py:235
 #, python-format
 msgid "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:213
+#: ../gui/wxpython/gui_modules/toolbars.py:219
 msgid ""
 "Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
 "(hopefully this will be fixed soon). Please keep an eye out for updated "
 "versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:221
-#: ../gui/wxpython/gui_modules/toolbars.py:1162
+#: ../gui/wxpython/gui_modules/toolbars.py:227
+#: ../gui/wxpython/gui_modules/toolbars.py:1108
 msgid "Digitize"
 msgstr "Digitalizar una nueva línea."
-#: ../gui/wxpython/gui_modules/toolbars.py:228
+#: ../gui/wxpython/gui_modules/toolbars.py:234
 #, fuzzy
 msgid "Vector digitizer not available"
 msgstr "Barra de herramientas del digitalizador vectorial."
-#: ../gui/wxpython/gui_modules/toolbars.py:230
+#: ../gui/wxpython/gui_modules/toolbars.py:236
 msgid ""
 "Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
 "will be fixed soon). Please keep an eye out for updated versions of GRASS. "
 "In the meantime you can use \"v.digit\" from the Develop Vector menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:421
+#: ../gui/wxpython/gui_modules/toolbars.py:403
 msgid "Set map canvas for "
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:423
+#: ../gui/wxpython/gui_modules/toolbars.py:405
 #, fuzzy
 msgid " / Zoom to map"
 msgstr "Acercamiento al mapa seleccionado."
-#: ../gui/wxpython/gui_modules/toolbars.py:790
+#: ../gui/wxpython/gui_modules/toolbars.py:737
 msgid "Duplicate attributes"
 msgstr "Duplicar atributos."
-#: ../gui/wxpython/gui_modules/toolbars.py:867
+#: ../gui/wxpython/gui_modules/toolbars.py:814
 msgid "Copy features from (background) vector map"
 msgstr "Copiar atributos del mapa vectorial ubicado en segundo plano."
-#: ../gui/wxpython/gui_modules/toolbars.py:875
+#: ../gui/wxpython/gui_modules/toolbars.py:822
 msgid "Flip selected lines/boundaries"
 msgstr "Invertir las lineas o fronteras seleccionadas."
-#: ../gui/wxpython/gui_modules/toolbars.py:883
+#: ../gui/wxpython/gui_modules/toolbars.py:830
 msgid "Merge selected lines/boundaries"
 msgstr "Combina las líneas o fronteras seleccionadas."
-#: ../gui/wxpython/gui_modules/toolbars.py:891
+#: ../gui/wxpython/gui_modules/toolbars.py:838
 msgid "Break selected lines/boundaries at intersection"
 msgstr "Separa las lineas o fronteras seleccionadas en la intersección."
-#: ../gui/wxpython/gui_modules/toolbars.py:899
+#: ../gui/wxpython/gui_modules/toolbars.py:846
 msgid "Snap selected lines/boundaries (only to nodes)"
 msgstr "Ajustar las líneas / fronteras seleccionadas (únicamente a los nodos)."
-#: ../gui/wxpython/gui_modules/toolbars.py:907
+#: ../gui/wxpython/gui_modules/toolbars.py:854
 msgid "Connect selected lines/boundaries"
 msgstr "Conectar las líneas / fronteras seleccionadas."
-#: ../gui/wxpython/gui_modules/toolbars.py:915
+#: ../gui/wxpython/gui_modules/toolbars.py:862
 msgid "Query features"
 msgstr "Consultar atributos."
-#: ../gui/wxpython/gui_modules/toolbars.py:923
+#: ../gui/wxpython/gui_modules/toolbars.py:870
 msgid "Z bulk-labeling of 3D lines"
 msgstr "Etiquetado en bloque Z de líneas 3D."
-#: ../gui/wxpython/gui_modules/toolbars.py:931
+#: ../gui/wxpython/gui_modules/toolbars.py:878
 msgid "Feature type conversion"
 msgstr "Conversión del tipo de atributo."
-#: ../gui/wxpython/gui_modules/toolbars.py:1042
+#: ../gui/wxpython/gui_modules/toolbars.py:989
 msgid "Vector map is not 3D. Operation canceled."
 msgstr "El mapa de vectores no es tridimensional (3D). Operación cancelada."
-#: ../gui/wxpython/gui_modules/toolbars.py:1107
-#: ../gui/wxpython/gui_modules/toolbars.py:1189
-#: ../gui/wxpython/gui_modules/toolbars.py:1268
+#: ../gui/wxpython/gui_modules/toolbars.py:1053
+#: ../gui/wxpython/gui_modules/toolbars.py:1135
+#: ../gui/wxpython/gui_modules/toolbars.py:1214
 msgid "Select vector map"
 msgstr "Seleccionar un mapa vectorial."
-#: ../gui/wxpython/gui_modules/toolbars.py:1145
+#: ../gui/wxpython/gui_modules/toolbars.py:1091
 #, python-format
 msgid "Please wait, opening vector map <%s> for editing..."
 msgstr ""
 "Por favor, espere, abriendo el mapa vectorial <% s> para su edición ..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1197
+#: ../gui/wxpython/gui_modules/toolbars.py:1143
 #, python-format
 msgid "Do you want to save changes in vector map <%s>?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1199
+#: ../gui/wxpython/gui_modules/toolbars.py:1145
 msgid "Save changes?"
 msgstr "¿Guardar los cambios?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1206
+#: ../gui/wxpython/gui_modules/toolbars.py:1152
 #, python-format
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
 msgstr ""
 "Por favor espere, cerrando y reconstruyendo la topología del mapa vectorial <"
 "% s> ..."
-#: ../gui/wxpython/gui_modules/toolbars.py:1217
+#: ../gui/wxpython/gui_modules/toolbars.py:1163
 msgid "Editing of vector map <%s> successfully finished"
 msgstr "Cerrar el diálogo al finalizar."
-#: ../gui/wxpython/gui_modules/toolbars.py:1274
-#: ../gui/wxpython/gui_modules/toolbars.py:1279
+#: ../gui/wxpython/gui_modules/toolbars.py:1220
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
 msgid "New vector map"
 msgstr "Nuevo mapa vectorial."
@@ -10872,7 +10973,7 @@
 msgstr "Lista de capas."
 #: ../gui/wxpython/gui_modules/dbm.py:1117
-#: ../gui/wxpython/gui_modules/preferences.py:626
+#: ../gui/wxpython/gui_modules/preferences.py:642
 msgid "Edit selected record"
 msgstr "Editar el registro seleccionado."
@@ -10890,14 +10991,14 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1129
-#: ../gui/wxpython/gui_modules/gdialogs.py:861
-#: ../gui/wxpython/gui_modules/gdialogs.py:1389
+#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:1390
 msgid "Select all"
 msgstr "Seleccionar todo."
 #: ../gui/wxpython/gui_modules/dbm.py:1130
-#: ../gui/wxpython/gui_modules/gdialogs.py:863
-#: ../gui/wxpython/gui_modules/gdialogs.py:1390
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
+#: ../gui/wxpython/gui_modules/gdialogs.py:1391
 msgid "Deselect all"
 msgstr "Deseleccionar todo."
@@ -11207,7 +11308,7 @@
 msgstr "Crear la tabla de atributos."
 #: ../gui/wxpython/gui_modules/gdialogs.py:204
-#: ../gui/wxpython/gui_modules/preferences.py:1553
+#: ../gui/wxpython/gui_modules/preferences.py:1575
 msgid "Add created map into layer tree"
 msgstr "Añadir el mapa creado al árbol de capas"
@@ -11269,8 +11370,8 @@
 msgstr "Rotación:"
 #: ../gui/wxpython/gui_modules/gdialogs.py:631
-#: ../gui/wxpython/gui_modules/preferences.py:1259
-#: ../gui/wxpython/gui_modules/preferences.py:1388
+#: ../gui/wxpython/gui_modules/preferences.py:1263
+#: ../gui/wxpython/gui_modules/preferences.py:1410
 msgid "Set font"
 msgstr "Establecer el tipo de letra."
@@ -11282,100 +11383,110 @@
 "Arrastrar texto con el ratón en modo puntero a la posición.\n"
 "Doble pulsación para cambiar las opciones."
-#: ../gui/wxpython/gui_modules/gdialogs.py:768
+#: ../gui/wxpython/gui_modules/gdialogs.py:739
+#, fuzzy
+msgid "&Add"
+msgstr "Añadir."
+#: ../gui/wxpython/gui_modules/gdialogs.py:741
+#, fuzzy
+msgid "Add selected map layers to current display"
+msgstr "Añadir capa de mapa raster."
+#: ../gui/wxpython/gui_modules/gdialogs.py:769
 msgid "Map layer type:"
 msgstr "Tipo de capa de mapa:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:780
+#: ../gui/wxpython/gui_modules/gdialogs.py:781
 #, fuzzy
 msgid "Select toggle"
 msgstr "Seleccionar color"
-#: ../gui/wxpython/gui_modules/gdialogs.py:787
+#: ../gui/wxpython/gui_modules/gdialogs.py:788
 msgid "Mapset:"
 msgstr "Directorio de mapas:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:797
+#: ../gui/wxpython/gui_modules/gdialogs.py:798
 msgid "Filter:"
 msgstr "Filtro:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
 msgid "List of maps:"
 msgstr "Lista de mapas:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:863
 #, fuzzy
 msgid "Invert selection"
 msgstr "Sección transversal."
-#: ../gui/wxpython/gui_modules/gdialogs.py:936
+#: ../gui/wxpython/gui_modules/gdialogs.py:937
 msgid "Multiple import"
 msgstr "Importación múltiple."
-#: ../gui/wxpython/gui_modules/gdialogs.py:950
+#: ../gui/wxpython/gui_modules/gdialogs.py:951
 #, python-format
 msgid " List of %s layers "
 msgstr "Lista de capas %s ."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1151
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
 msgid "Add linked layers into layer tree"
 msgstr "Añadir las capas ligadas al árbol de capas."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1158
+#: ../gui/wxpython/gui_modules/gdialogs.py:1159
 msgid "&Link"
 msgstr "&Liga."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1159
+#: ../gui/wxpython/gui_modules/gdialogs.py:1160
 msgid "Link selected layers"
 msgstr "Ligar las capas seleccionadas."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1253
+#: ../gui/wxpython/gui_modules/gdialogs.py:1254
 msgid "Import DXF layers"
 msgstr "Importar capas de mapas DXF."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1257
+#: ../gui/wxpython/gui_modules/gdialogs.py:1258
 msgid "Choose DXF file to import"
 msgstr "Seleccionar archivo DXF a importar:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1353
+#: ../gui/wxpython/gui_modules/gdialogs.py:1354
 msgid "Layer name"
 msgstr "Nombre de capa."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1354
+#: ../gui/wxpython/gui_modules/gdialogs.py:1355
 msgid "Name for GRASS map"
 msgstr "Nombre del mapa GRASS."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1436
+#: ../gui/wxpython/gui_modules/gdialogs.py:1437
 msgid "Set Map Layer Opacity"
 msgstr "Establecer opacidad de la capa de mapa."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1460
+#: ../gui/wxpython/gui_modules/gdialogs.py:1461
 msgid "transparent"
 msgstr "Transparente."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1463
+#: ../gui/wxpython/gui_modules/gdialogs.py:1464
 msgid "opaque"
 msgstr "Opaco."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1582
+#: ../gui/wxpython/gui_modules/gdialogs.py:1583
 msgid "Set image size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1591
+#: ../gui/wxpython/gui_modules/gdialogs.py:1592
 #, fuzzy
 msgid "Image size"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1638
+#: ../gui/wxpython/gui_modules/gdialogs.py:1639
 msgid "Template:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1676
+#: ../gui/wxpython/gui_modules/gdialogs.py:1677
 #, fuzzy
 msgid "GRASS GIS SQL Query Utility"
 msgstr "Visualización de mapas - SIG GRASS."
-#: ../gui/wxpython/gui_modules/gdialogs.py:1687
+#: ../gui/wxpython/gui_modules/gdialogs.py:1688
 #, fuzzy
 msgid " SQL statement "
 msgstr "Sentencia SQL."
@@ -11674,55 +11785,55 @@
 msgstr "Grupo de capas:"
 #: ../gui/wxpython/gui_modules/layertree.py:743
-#: ../gui/wxpython/gui_modules/layertree.py:1310
+#: ../gui/wxpython/gui_modules/layertree.py:1309
 msgid "Click to edit layer settings"
 msgstr "Pulse aquí para editar la configuración de la capa."
-#: ../gui/wxpython/gui_modules/layertree.py:788
+#: ../gui/wxpython/gui_modules/layertree.py:784
 msgid "(double click to set properties)"
 msgstr "(Haga doble clic para establecer las propiedades)."
-#: ../gui/wxpython/gui_modules/layertree.py:794
+#: ../gui/wxpython/gui_modules/layertree.py:790
 msgid "3d raster"
 msgstr "raster 3D."
-#: ../gui/wxpython/gui_modules/layertree.py:797
+#: ../gui/wxpython/gui_modules/layertree.py:793
 msgid "RGB"
 msgstr "Rojo, verde y azul (RGB)."
-#: ../gui/wxpython/gui_modules/layertree.py:800
+#: ../gui/wxpython/gui_modules/layertree.py:796
 msgid "HIS"
 msgstr "Tono, Intensidad y Saturación (HIS)."
-#: ../gui/wxpython/gui_modules/layertree.py:806
+#: ../gui/wxpython/gui_modules/layertree.py:802
 msgid "raster cell numbers"
 msgstr "Número de celdas del mapa raster."
-#: ../gui/wxpython/gui_modules/layertree.py:809
+#: ../gui/wxpython/gui_modules/layertree.py:805
 msgid "raster flow arrows"
 msgstr "Flechas de flujo del mapa raster."
-#: ../gui/wxpython/gui_modules/layertree.py:815
+#: ../gui/wxpython/gui_modules/layertree.py:811
 msgid "thematic area (choropleth) map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:818
+#: ../gui/wxpython/gui_modules/layertree.py:814
 msgid "thematic charts"
 msgstr "Cartas temáticas."
-#: ../gui/wxpython/gui_modules/layertree.py:821
+#: ../gui/wxpython/gui_modules/layertree.py:817
 msgid "grid"
 msgstr "Rejilla (grid)."
-#: ../gui/wxpython/gui_modules/layertree.py:824
+#: ../gui/wxpython/gui_modules/layertree.py:820
 msgid "geodesic line"
 msgstr "Linea geodésica."
-#: ../gui/wxpython/gui_modules/layertree.py:827
+#: ../gui/wxpython/gui_modules/layertree.py:823
 msgid "rhumbline"
 msgstr "Línea de rumbo de navegación o loxódromo (loxodrome)"
-#: ../gui/wxpython/gui_modules/layertree.py:830
+#: ../gui/wxpython/gui_modules/layertree.py:826
 msgid "vector labels"
 msgstr "Etiquetas de vectores."
@@ -11730,162 +11841,162 @@
 msgid "Please wait, updating data..."
 msgstr "Por favor espere, actualizando datos..."
-#: ../gui/wxpython/gui_modules/layertree.py:1389
+#: ../gui/wxpython/gui_modules/layertree.py:1388
 msgid "opacity:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:1406
+#: ../gui/wxpython/gui_modules/layertree.py:1405
 #, python-format
 msgid "Map <%s> not found."
-#: ../gui/wxpython/gui_modules/menuform.py:147
-#: ../gui/wxpython/gui_modules/menuform.py:1654
+#: ../gui/wxpython/gui_modules/menuform.py:148
+#: ../gui/wxpython/gui_modules/menuform.py:1647
 msgid "Select Color"
 msgstr "Seleccionar color."
-#: ../gui/wxpython/gui_modules/menuform.py:451
+#: ../gui/wxpython/gui_modules/menuform.py:452
 #, python-format
 msgid "Parameter element '%(element)s' not found: '%(value)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:472
+#: ../gui/wxpython/gui_modules/menuform.py:473
 #, python-format
 msgid "Flag not found: %s"
 msgstr "No se ha encontrado la opción: %s ."
-#: ../gui/wxpython/gui_modules/menuform.py:501
+#: ../gui/wxpython/gui_modules/menuform.py:502
 msgid "Parameter '%(name)s' (%(desc)s) is missing."
 msgstr "No se encuentra el parámetro %(name)s (%(desc)s).\n"
-#: ../gui/wxpython/gui_modules/menuform.py:530
+#: ../gui/wxpython/gui_modules/menuform.py:531
 msgid "<required>"
 msgstr "<requerido>"
-#: ../gui/wxpython/gui_modules/menuform.py:797
+#: ../gui/wxpython/gui_modules/menuform.py:798
 #, fuzzy
 msgid "Enter parameters for '"
 msgstr "Introducir parámetros para"
-#: ../gui/wxpython/gui_modules/menuform.py:808
+#: ../gui/wxpython/gui_modules/menuform.py:809
 #, fuzzy
 msgid "Close this window without executing the command (Ctrl+Q)"
 msgstr "Cierra esta pantalla sin ejecutar el comando."
-#: ../gui/wxpython/gui_modules/menuform.py:828
+#: ../gui/wxpython/gui_modules/menuform.py:829
 #, fuzzy
 msgid "Run the command (Ctrl+R)"
 msgstr "Ejecutar la orden."
-#: ../gui/wxpython/gui_modules/menuform.py:831
+#: ../gui/wxpython/gui_modules/menuform.py:832
 #, fuzzy
 msgid "C&opy"
 msgstr "Copiar."
-#: ../gui/wxpython/gui_modules/menuform.py:846
+#: ../gui/wxpython/gui_modules/menuform.py:847
 #, fuzzy
 msgid "Show manual page of the command (Ctrl+H)"
 msgstr "Mostrar página del manual que describe el comando."
-#: ../gui/wxpython/gui_modules/menuform.py:867
+#: ../gui/wxpython/gui_modules/menuform.py:868
 #, fuzzy
 msgid "Add created map(s) into layer tree"
-#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:883
 msgid "Close dialog on finish"
-#: ../gui/wxpython/gui_modules/menuform.py:884
+#: ../gui/wxpython/gui_modules/menuform.py:885
 msgid ""
 "Close dialog when command is successfully finished. Change this settings in "
 "Preferences dialog ('Command' tab)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1059
+#: ../gui/wxpython/gui_modules/menuform.py:1060
 #, python-format
 msgid "'%s' copied to clipboard"
 msgstr "'%s' copiado al portapapeles."
-#: ../gui/wxpython/gui_modules/menuform.py:1121
-#: ../gui/wxpython/gui_modules/menuform.py:1134
+#: ../gui/wxpython/gui_modules/menuform.py:1122
+#: ../gui/wxpython/gui_modules/menuform.py:1135
 msgid "Required"
 msgstr "Requerido."
-#: ../gui/wxpython/gui_modules/menuform.py:1124
+#: ../gui/wxpython/gui_modules/menuform.py:1125
 msgid "Optional"
 msgstr "Opcional."
-#: ../gui/wxpython/gui_modules/menuform.py:1174
+#: ../gui/wxpython/gui_modules/menuform.py:1168
 msgid "Manual"
 msgstr "Manual."
-#: ../gui/wxpython/gui_modules/menuform.py:1215
-#: ../gui/wxpython/gui_modules/menuform.py:1726
+#: ../gui/wxpython/gui_modules/menuform.py:1208
+#: ../gui/wxpython/gui_modules/menuform.py:1719
 #, fuzzy
 msgid "Parameterized in model"
 msgstr "No se ha encontrado el parámetro: %s ."
-#: ../gui/wxpython/gui_modules/menuform.py:1290
+#: ../gui/wxpython/gui_modules/menuform.py:1283
 msgid "[multiple]"
 msgstr "[múltiple]"
-#: ../gui/wxpython/gui_modules/menuform.py:1337
+#: ../gui/wxpython/gui_modules/menuform.py:1330
 #, fuzzy
 msgid "valid range"
-#: ../gui/wxpython/gui_modules/menuform.py:1499
+#: ../gui/wxpython/gui_modules/menuform.py:1492
 msgid "Format"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1501
+#: ../gui/wxpython/gui_modules/menuform.py:1494
 msgid "Native / Linked OGR"
 msgstr ""
 #, fuzzy
 msgid "Direct OGR"
 msgstr "Dirección."
-#: ../gui/wxpython/gui_modules/menuform.py:1673
+#: ../gui/wxpython/gui_modules/menuform.py:1666
 msgid "Transparent"
-#: ../gui/wxpython/gui_modules/menuform.py:1689
+#: ../gui/wxpython/gui_modules/menuform.py:1682
 #, python-format
 msgid "Choose %s"
 msgstr "Seleccionar %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1717
+#: ../gui/wxpython/gui_modules/menuform.py:1710
 #, fuzzy
 msgid "or enter values interactively"
 msgstr "Recodificar de forma interactiva."
-#: ../gui/wxpython/gui_modules/menuform.py:2133
+#: ../gui/wxpython/gui_modules/menuform.py:2126
 #, python-format
 msgid "Error in %s"
 msgstr "Error en %s ."
-#: ../gui/wxpython/gui_modules/menuform.py:2166
-#: ../gui/wxpython/gui_modules/menuform.py:2169
+#: ../gui/wxpython/gui_modules/menuform.py:2159
+#: ../gui/wxpython/gui_modules/menuform.py:2162
 msgid "Unable to fetch interface description for command '%s'."
 msgstr "No se puede obtener la descripción de la interfaz para la orden '%s'."
-#: ../gui/wxpython/gui_modules/menuform.py:2280
+#: ../gui/wxpython/gui_modules/menuform.py:2276
 msgid "Unable to parse command '%s'"
-#: ../gui/wxpython/gui_modules/menuform.py:2284
+#: ../gui/wxpython/gui_modules/menuform.py:2280
 #, python-format
 msgid "%(cmd)s: parameter '%(key)s' not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2409
+#: ../gui/wxpython/gui_modules/menuform.py:2441
 #, python-format
 msgid "usage: %s <grass command>"
 msgstr "uso: %s <grass command>"
@@ -11895,125 +12006,125 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/globalvar.py:119
-#: ../gui/wxpython/gui_modules/preferences.py:1798
+#: ../gui/wxpython/gui_modules/preferences.py:1820
 #, fuzzy
 msgid "Projection"
 msgstr "Proyección:"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:269
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
 #, fuzzy
 msgid "Easting"
 msgstr "Este."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:270
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:290
 #, fuzzy
 msgid "Northing"
 msgstr "Norte."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:271
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:291
 #, fuzzy
 msgid "Elevation"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:272
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:292
 #, fuzzy
 msgid "Surface map elevation"
 msgstr ""
 "Programa de generación de superficies a partir de contornos rasterizados."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:273
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:293
 #, fuzzy
 msgid "Surface map color"
 msgstr "Administrar colores de imágenes."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:282
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:302
 msgid "XY distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:283
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:303
 msgid "XYZ distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:284
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:304
 #, fuzzy
 msgid "Distance along surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:309
 #, fuzzy
 msgid "Distance along exag. surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:296
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:316
 #, fuzzy
 msgid "No point on surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:301
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:321
 msgid "Function not implemented yet"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:602
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:639
 msgid "Loading raster map"
 msgstr "Cargando mapa raster."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:606
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:643
 msgid "Loading 3d raster map"
 msgstr "Cargando mapa raster 3D."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:612
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:649
 msgid "failed"
 msgstr "Fallado"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:614
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:651
 #, python-format
 msgid "Unsupported layer type '%s'"
 msgstr "Tipo de capa no soportado '%s'."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:668
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:729
 msgid "Unable to unload raster map"
 msgstr "No ha sido posible descargar el mapa raster."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:673
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:734
 msgid "Unable to unload 3d raster map"
 msgstr "raster."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:674
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:735
 msgid "3d raster map"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:681
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:742
 msgid "unloaded successfully"
 msgstr "Exitosamente descargado."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:725
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:786
 #, python-format
 msgid "Loading vector map <%(name)s> (%(type)s) failed"
 msgstr "Ha fallado la carga del mapa vectorial <%(name)s> (%(type)s)."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:781
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:842
 #, python-format
 msgid "Unable to unload vector map <%(name)s> (%(type)s)"
 msgstr "No ha sido posible descargar el mapa vectorial<%(name)s> (%(type)s)."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:784
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:845
 #, python-format
 msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
 msgstr ""
 "El mapa vectorial <%(name)s> (%(type)s) ha sido exitosamente descargado."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1071
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1148
 msgid "Vector point layer not found (id = %d)"
 msgstr "No se ha encontrado la capa de mapa vectorial puntual (id=%d)."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1073
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1150
 msgid "Unable to set data layer properties (id = %d)"
 msgstr ""
 "No ha sido posible establecer las propiedades de la capa de datos (id=%d)."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1076
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1153
 #, python-format
 msgid ""
 "Setting data layer properties failed.\n"
@@ -12024,103 +12135,108 @@
 "\n"
 "%s"
-#: ../gui/wxpython/gui_modules/preferences.py:416
+#: ../gui/wxpython/gui_modules/preferences.py:427
 msgid "Segment break"
 msgstr "Cambio de segmento."
-#: ../gui/wxpython/gui_modules/preferences.py:621
+#: ../gui/wxpython/gui_modules/preferences.py:637
 msgid "Collapse all except PERMANENT and current"
 msgstr "Ocultar todos, excepto los conjuntos de mapas PERMANENT y actual."
-#: ../gui/wxpython/gui_modules/preferences.py:622
+#: ../gui/wxpython/gui_modules/preferences.py:638
 msgid "Collapse all except PERMANENT"
 msgstr "Ocultar todos, excepto el conjunto de mapas PERMANENT."
-#: ../gui/wxpython/gui_modules/preferences.py:623
+#: ../gui/wxpython/gui_modules/preferences.py:639
 msgid "Collapse all except current"
 msgstr "Ocultar todos, excepto el conjunto de mapas actual."
-#: ../gui/wxpython/gui_modules/preferences.py:624
+#: ../gui/wxpython/gui_modules/preferences.py:640
 msgid "Collapse all"
 msgstr "Ocultar todos los conjuntos de mapas."
-#: ../gui/wxpython/gui_modules/preferences.py:625
+#: ../gui/wxpython/gui_modules/preferences.py:641
 msgid "Expand all"
 msgstr "Expandir / mostrar todo."
-#: ../gui/wxpython/gui_modules/preferences.py:627
+#: ../gui/wxpython/gui_modules/preferences.py:643
 msgid "Display selected"
 msgstr "Mostrar lo seleccionado."
-#: ../gui/wxpython/gui_modules/preferences.py:635
+#: ../gui/wxpython/gui_modules/preferences.py:651
 msgid "Classic (labels only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:636
+#: ../gui/wxpython/gui_modules/preferences.py:652
 msgid "Combined (labels and module names)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:637
+#: ../gui/wxpython/gui_modules/preferences.py:653
 msgid "Professional (module names only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:657
+#: ../gui/wxpython/gui_modules/preferences.py:673
 msgid "box"
 msgstr "Cuadro."
-#: ../gui/wxpython/gui_modules/preferences.py:658
+#: ../gui/wxpython/gui_modules/preferences.py:674
 msgid "sphere"
 msgstr "Esfera."
-#: ../gui/wxpython/gui_modules/preferences.py:659
+#: ../gui/wxpython/gui_modules/preferences.py:675
 msgid "cube"
 msgstr "Cubo."
-#: ../gui/wxpython/gui_modules/preferences.py:660
+#: ../gui/wxpython/gui_modules/preferences.py:676
 msgid "diamond"
 msgstr "Diamante."
-#: ../gui/wxpython/gui_modules/preferences.py:661
+#: ../gui/wxpython/gui_modules/preferences.py:677
 msgid "dtree"
 msgstr "Arbol d"
-#: ../gui/wxpython/gui_modules/preferences.py:662
+#: ../gui/wxpython/gui_modules/preferences.py:678
 msgid "ctree"
 msgstr "Arbol c"
-#: ../gui/wxpython/gui_modules/preferences.py:663
+#: ../gui/wxpython/gui_modules/preferences.py:679
 msgid "aster"
 msgstr "Asterisco (forma de estrella)."
-#: ../gui/wxpython/gui_modules/preferences.py:664
+#: ../gui/wxpython/gui_modules/preferences.py:680
 msgid "gyro"
 msgstr "Giroscópo."
-#: ../gui/wxpython/gui_modules/preferences.py:665
+#: ../gui/wxpython/gui_modules/preferences.py:681
 msgid "histogram"
 msgstr "Histograma."
-#: ../gui/wxpython/gui_modules/preferences.py:727
-#, python-format
+#: ../gui/wxpython/gui_modules/preferences.py:713
+#, fuzzy, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr "No se puede analizar la orden %s ."
+#: ../gui/wxpython/gui_modules/preferences.py:737
 msgid ""
 "Error: Reading settings from file <%(file)s> failed.\n"
-"       Details: %(detail)s\n"
-"       Line: '%(line)s'"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
 msgstr ""
 "Error: Ha fallado la lectura de parámetros de configuración desde el archivo "
 "<%(file)s> .\n"
 "       Detalles: %(detail)s\n"
 "       Línea: '%(line)s'"
-#: ../gui/wxpython/gui_modules/preferences.py:750
+#: ../gui/wxpython/gui_modules/preferences.py:758
 msgid "Cannot create directory for settings [home]/.grass7"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:751
+#: ../gui/wxpython/gui_modules/preferences.py:759
 msgid "Error saving preferences"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:787
+#: ../gui/wxpython/gui_modules/preferences.py:794
 #, python-format
 msgid ""
 "Writing settings to file <%(file)s> failed.\n"
@@ -12131,122 +12247,128 @@
 "\n"
 "Detales: %(detail)s"
-#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/gui_modules/preferences.py:893
 msgid "Unable to set "
 msgstr "Imposible de establecer."
-#: ../gui/wxpython/gui_modules/preferences.py:914
-#: ../gui/wxpython/gui_modules/preferences.py:920
+#: ../gui/wxpython/gui_modules/preferences.py:919
+#: ../gui/wxpython/gui_modules/preferences.py:925
 msgid "Unable to parse settings '%s'"
-#: ../gui/wxpython/gui_modules/preferences.py:931
+#: ../gui/wxpython/gui_modules/preferences.py:936
 #, fuzzy
 msgid "User settings"
 msgstr "Configuración de interfaz gráfica de usuario."
-#: ../gui/wxpython/gui_modules/preferences.py:951
+#: ../gui/wxpython/gui_modules/preferences.py:956
 msgid "Set to default"
 msgstr "Establecer a lo predeterminado."
-#: ../gui/wxpython/gui_modules/preferences.py:959
+#: ../gui/wxpython/gui_modules/preferences.py:964
 msgid "Revert settings to default and apply changes"
 msgstr "Revertir los ajustes a lo predeterminado y aplicar los cambios."
-#: ../gui/wxpython/gui_modules/preferences.py:1021
+#: ../gui/wxpython/gui_modules/preferences.py:1026
 msgid "Settings applied to current session but not saved"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1039
+#: ../gui/wxpython/gui_modules/preferences.py:1044
 #, python-format
 msgid "Settings saved to file '%s'."
 msgstr "La configuración ha sido guardada en el archivo '%s'."
-#: ../gui/wxpython/gui_modules/preferences.py:1070
+#: ../gui/wxpython/gui_modules/preferences.py:1075
 msgid "Key column cannot be empty string."
 msgstr "La columna de clave no puede contener una cadena vacía."
-#: ../gui/wxpython/gui_modules/preferences.py:1084
+#: ../gui/wxpython/gui_modules/preferences.py:1089
 #, fuzzy
 msgid "GUI Settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1107
-msgid "General settings"
-msgstr "Configuración general."
-#: ../gui/wxpython/gui_modules/preferences.py:1118
-msgid "Element list:"
-msgstr "Lista de elementos:"
-#: ../gui/wxpython/gui_modules/preferences.py:1140
-msgid "Save current window layout as default"
-msgstr ""
-"Guardar parámetros de visualización de la ventana actual como "
-"predeterminados."
-#: ../gui/wxpython/gui_modules/preferences.py:1143
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Guardar la posición y tamaño actuales, tanto de la ventana del Administrador "
-"de capas, como de la(s) de visualización de mapas abiertas y utilizar como "
-"ajustes predeterminados para próximas sesiones."
-#: ../gui/wxpython/gui_modules/preferences.py:1156
+#: ../gui/wxpython/gui_modules/preferences.py:1115
 msgid "Layer Manager settings"
 msgstr "Ajustes del administrador de Capas."
-#: ../gui/wxpython/gui_modules/preferences.py:1167
+#: ../gui/wxpython/gui_modules/preferences.py:1126
 msgid "Ask when removing map layer from layer tree"
 msgstr "Preguntar cuando se remueve una capa de mapas del árbol de capas."
-#: ../gui/wxpython/gui_modules/preferences.py:1177
+#: ../gui/wxpython/gui_modules/preferences.py:1136
 msgid "Ask when quiting wxGUI or closing display"
 msgstr ""
 "Preguntar cuando se abandona la interfaz gráfica de usuario wx o se cierre "
 "la ventana."
-#: ../gui/wxpython/gui_modules/preferences.py:1191
+#: ../gui/wxpython/gui_modules/preferences.py:1146
+#: ../gui/wxpython/gui_modules/preferences.py:1156
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1169
+msgid "Automatically copy selected text to clipboard (in Command console)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1183
 #, fuzzy
 msgid "Workspace settings"
 msgstr "Configuración de mapa de bits (raster)."
-#: ../gui/wxpython/gui_modules/preferences.py:1199
+#: ../gui/wxpython/gui_modules/preferences.py:1191
 msgid "Suppress positioning Map Display Window(s)"
 msgstr ""
 "Suprimir el posicionamiento de la(s) ventana(s) de visualización de mapas."
-#: ../gui/wxpython/gui_modules/preferences.py:1211
+#: ../gui/wxpython/gui_modules/preferences.py:1203
 msgid "Suppress positioning Layer Manager window"
 msgstr "Suprimir el posicionamiento de la ventana del administrador de capas."
-#: ../gui/wxpython/gui_modules/preferences.py:1254
+#: ../gui/wxpython/gui_modules/preferences.py:1214
+msgid "Save current window layout as default"
+msgstr ""
+"Guardar parámetros de visualización de la ventana actual como "
+"predeterminados."
+#: ../gui/wxpython/gui_modules/preferences.py:1217
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+"Guardar la posición y tamaño actuales, tanto de la ventana del Administrador "
+"de capas, como de la(s) de visualización de mapas abiertas y utilizar como "
+"ajustes predeterminados para próximas sesiones."
+#: ../gui/wxpython/gui_modules/preferences.py:1258
 #, fuzzy
 msgid "Font for command output:"
 msgstr "Salida de la orden."
-#: ../gui/wxpython/gui_modules/preferences.py:1268
+#: ../gui/wxpython/gui_modules/preferences.py:1272
 #, fuzzy
 msgid "Appearance settings"
 msgstr "Configuración avanzada."
-#: ../gui/wxpython/gui_modules/preferences.py:1280
+#: ../gui/wxpython/gui_modules/preferences.py:1283
+msgid "Element list:"
+msgstr "Lista de elementos:"
+#: ../gui/wxpython/gui_modules/preferences.py:1302
 #, fuzzy
 msgid "Menu style:"
 msgstr "Árbol de Steiner."
-#: ../gui/wxpython/gui_modules/preferences.py:1304
+#: ../gui/wxpython/gui_modules/preferences.py:1326
 msgid "Height of map selection popup window (in pixels):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1328
+#: ../gui/wxpython/gui_modules/preferences.py:1350
 msgid "Icon theme:"
 msgstr "Tema de iconos:"
-#: ../gui/wxpython/gui_modules/preferences.py:1346
+#: ../gui/wxpython/gui_modules/preferences.py:1368
 msgid ""
 "Note: For changing the icon theme, you must save the settings and restart "
 "this GUI."
@@ -12254,182 +12376,182 @@
 "Nota: Para cambiar el tema de los iconos, debe usted guardar la "
 "configuración y reiniciar la interfaz gráfica de usuario (GUI)."
-#: ../gui/wxpython/gui_modules/preferences.py:1368
+#: ../gui/wxpython/gui_modules/preferences.py:1390
 #, fuzzy
 msgid "Map Display"
 msgstr "Mostrar."
-#: ../gui/wxpython/gui_modules/preferences.py:1383
+#: ../gui/wxpython/gui_modules/preferences.py:1405
 msgid "Default font for GRASS displays:"
 msgstr "Tipo de letra predeterminado para las ventanas de GRASS."
-#: ../gui/wxpython/gui_modules/preferences.py:1400
+#: ../gui/wxpython/gui_modules/preferences.py:1422
 msgid "Default display settings"
 msgstr "Ajustes predeterminados de pantalla."
-#: ../gui/wxpython/gui_modules/preferences.py:1412
+#: ../gui/wxpython/gui_modules/preferences.py:1434
 msgid "Display driver:"
 msgstr "Manejador de pantalla:"
-#: ../gui/wxpython/gui_modules/preferences.py:1432
+#: ../gui/wxpython/gui_modules/preferences.py:1454
 msgid "Statusbar mode:"
 msgstr "Modo de la barra de estado:"
-#: ../gui/wxpython/gui_modules/preferences.py:1484
+#: ../gui/wxpython/gui_modules/preferences.py:1506
 msgid "Enable auto-rendering"
 msgstr "Habilitar auto representación."
-#: ../gui/wxpython/gui_modules/preferences.py:1497
+#: ../gui/wxpython/gui_modules/preferences.py:1519
 #, fuzzy
 msgid "Enable auto-zooming to selected map layer"
 msgstr "ráster."
-#: ../gui/wxpython/gui_modules/preferences.py:1521
+#: ../gui/wxpython/gui_modules/preferences.py:1543
 msgid "Command dialog settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1543
+#: ../gui/wxpython/gui_modules/preferences.py:1565
 #, fuzzy
 msgid "Close dialog when command is successfully finished"
-#: ../gui/wxpython/gui_modules/preferences.py:1564
+#: ../gui/wxpython/gui_modules/preferences.py:1586
 #, fuzzy
 msgid "Allow interactive input"
-#: ../gui/wxpython/gui_modules/preferences.py:1574
+#: ../gui/wxpython/gui_modules/preferences.py:1596
 msgid "Verbosity level:"
 msgstr "Nivel de detalle:"
-#: ../gui/wxpython/gui_modules/preferences.py:1593
+#: ../gui/wxpython/gui_modules/preferences.py:1615
 msgid "Raster settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1604
+#: ../gui/wxpython/gui_modules/preferences.py:1626
 msgid "Make null cells opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1615
+#: ../gui/wxpython/gui_modules/preferences.py:1637
 #, fuzzy
 msgid "Default color table"
 msgstr "Establece la tabla de color."
-#: ../gui/wxpython/gui_modules/preferences.py:1641
+#: ../gui/wxpython/gui_modules/preferences.py:1663
 msgid "Vector settings"
 msgstr "Configuración de vector."
-#: ../gui/wxpython/gui_modules/preferences.py:1647
+#: ../gui/wxpython/gui_modules/preferences.py:1669
 msgid "Display:"
 msgstr "Presentación:"
-#: ../gui/wxpython/gui_modules/preferences.py:1677
+#: ../gui/wxpython/gui_modules/preferences.py:1699
 msgid "Highlighting"
 msgstr "Resaltar."
-#: ../gui/wxpython/gui_modules/preferences.py:1693
+#: ../gui/wxpython/gui_modules/preferences.py:1715
 msgid "Line width (in pixels):"
 msgstr "Ancho de Línea (en píxeles):"
-#: ../gui/wxpython/gui_modules/preferences.py:1716
+#: ../gui/wxpython/gui_modules/preferences.py:1738
 msgid "Data browser"
 msgstr "Explorador de datos."
-#: ../gui/wxpython/gui_modules/preferences.py:1721
+#: ../gui/wxpython/gui_modules/preferences.py:1743
 msgid "Left mouse double click:"
 msgstr "Doble click izquierdo del ratón:"
-#: ../gui/wxpython/gui_modules/preferences.py:1733
+#: ../gui/wxpython/gui_modules/preferences.py:1755
 msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
 msgstr "Codificación (por ejemplo, UTF-8, ASCII, iso8859-1, KOI8-R):"
-#: ../gui/wxpython/gui_modules/preferences.py:1744
+#: ../gui/wxpython/gui_modules/preferences.py:1766
 msgid "Ask when deleting data record(s) from table"
 msgstr "Preguntar al eliminar registro(s) de datos la tabla."
-#: ../gui/wxpython/gui_modules/preferences.py:1765
+#: ../gui/wxpython/gui_modules/preferences.py:1787
 msgid "Create table"
 msgstr "Crear tabla."
-#: ../gui/wxpython/gui_modules/preferences.py:1772
+#: ../gui/wxpython/gui_modules/preferences.py:1794
 msgid "Key column:"
 msgstr "Columna clave:"
-#: ../gui/wxpython/gui_modules/preferences.py:1805
+#: ../gui/wxpython/gui_modules/preferences.py:1827
 #, fuzzy
 msgid "Projection statusbar settings"
 msgstr "Configuración de tipo de letra del perfil."
-#: ../gui/wxpython/gui_modules/preferences.py:1831
+#: ../gui/wxpython/gui_modules/preferences.py:1853
 msgid "Proj.4 string (required):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1847
+#: ../gui/wxpython/gui_modules/preferences.py:1869
 #, fuzzy
 msgid "EPSG file:"
 msgstr "Código EPSG:"
-#: ../gui/wxpython/gui_modules/preferences.py:1862
+#: ../gui/wxpython/gui_modules/preferences.py:1884
 msgid ""
 "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
 "directly."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1870
+#: ../gui/wxpython/gui_modules/preferences.py:1892
 #, fuzzy
 msgid "&Load EPSG codes"
 msgstr "Explorar códigos EPSG"
-#: ../gui/wxpython/gui_modules/preferences.py:1881
+#: ../gui/wxpython/gui_modules/preferences.py:1903
 #, fuzzy
 msgid "Coordinates format"
 msgstr "Coordenadas."
-#: ../gui/wxpython/gui_modules/preferences.py:1890
+#: ../gui/wxpython/gui_modules/preferences.py:1912
 #, fuzzy
 msgid "LL projections"
 msgstr "Administrar proyecciones."
-#: ../gui/wxpython/gui_modules/preferences.py:1909
+#: ../gui/wxpython/gui_modules/preferences.py:1931
 #, fuzzy
 msgid "Precision:"
-#: ../gui/wxpython/gui_modules/preferences.py:1947
+#: ../gui/wxpython/gui_modules/preferences.py:1969
 msgid "Unable to read EPSG codes: %s"
 msgstr "No se pueden leer los códigos EPSG: %s ."
-#: ../gui/wxpython/gui_modules/preferences.py:1976
-#: ../gui/wxpython/gui_modules/preferences.py:1985
-#: ../gui/wxpython/gui_modules/preferences.py:1995
+#: ../gui/wxpython/gui_modules/preferences.py:1998
+#: ../gui/wxpython/gui_modules/preferences.py:2007
+#: ../gui/wxpython/gui_modules/preferences.py:2017
 msgid "EPSG code %s not found"
 msgstr "ERROR: No se encuentra la locación <%s>."
-#: ../gui/wxpython/gui_modules/preferences.py:2003
+#: ../gui/wxpython/gui_modules/preferences.py:2025
 msgid "Select default display font"
 msgstr "Seleccionar la fuente predeterminada para la pantalla."
-#: ../gui/wxpython/gui_modules/preferences.py:2028
+#: ../gui/wxpython/gui_modules/preferences.py:2050
 #, fuzzy
 msgid "Select output font"
 msgstr "Seleccionar tipo de letra."
-#: ../gui/wxpython/gui_modules/preferences.py:2121
+#: ../gui/wxpython/gui_modules/preferences.py:2143
 msgid "Select font:"
 msgstr "Seleccione el tipo de letra."
-#: ../gui/wxpython/gui_modules/preferences.py:2145
+#: ../gui/wxpython/gui_modules/preferences.py:2167
 msgid "Character encoding:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2263
+#: ../gui/wxpython/gui_modules/preferences.py:2285
 #, fuzzy
 msgid "Manage access to mapsets"
 msgstr "Cambiar directorio de mapas actual."
-#: ../gui/wxpython/gui_modules/preferences.py:2276
+#: ../gui/wxpython/gui_modules/preferences.py:2298
 #, fuzzy
 msgid ""
 "Check a mapset to make it accessible, uncheck it to hide it.\n"
@@ -12442,11 +12564,11 @@
 "para ocultarlo. %s Nota: Los directorios de mapas de usuario (mapset) "
 "PERMANENT, así como el actual serán accesibles siempre."
-#: ../gui/wxpython/gui_modules/preferences.py:2350
+#: ../gui/wxpython/gui_modules/preferences.py:2372
 msgid "Mapset"
 msgstr "Directorio de mapas de usuario (mapset)."
-#: ../gui/wxpython/gui_modules/preferences.py:2351
+#: ../gui/wxpython/gui_modules/preferences.py:2373
 msgid "Owner"
 msgstr "Propietario."
@@ -12724,7 +12846,75 @@
 "si todavía no lo ha hecho. Una elección común es \"grassdata\", ubicado en "
 "su directorio home."
+#~ msgid "Load map layers into layer tree"
+#~ msgstr "Cargar capas de mapa en el árbol de capas."
 #, fuzzy
+#~ msgid "Load map layers into workspace (Ctrl+L)"
+#~ msgstr "Cargar capas de mapa en el entorno de trabajo."
+#, fuzzy
+#~ msgid "Hardcopy Map Ouput Utility"
+#~ msgstr "Utilería de copia impresa del mapa de salida PostScript."
+#~ msgid "Load map layers"
+#~ msgstr "Cargar capas de mapa."
+#~ msgid "north"
+#~ msgstr "Norte."
+#~ msgid "south"
+#~ msgstr "Sur."
+#~ msgid "east"
+#~ msgstr "Este."
+#~ msgid "west"
+#~ msgstr "Oeste."
+#~ msgid "north-west"
+#~ msgstr "Nor - oeste."
+#~ msgid "north-east"
+#~ msgstr "Nor - este."
+#~ msgid "south-east"
+#~ msgstr "Sur - este."
+#~ msgid "south-west"
+#~ msgstr "Sur - oeste."
+#~ msgid "Topography"
+#~ msgstr "Topografía."
+#~ msgid "Mask zeros:"
+#~ msgstr "Enmascarar ceros:"
+#~ msgid "by elevation"
+#~ msgstr "Por elevación."
+#~ msgid "by color"
+#~ msgstr "Por color."
+#, fuzzy
+#~ msgid "color"
+#~ msgstr "Color:"
+#, fuzzy
+#~ msgid "display"
+#~ msgstr "Mostrar."
+#, fuzzy
+#~ msgid "symbol"
+#~ msgstr "Simbolo:"
+#~ msgid "Nviz settings saved to file <%s>."
+#~ msgstr "Los ajustes de Nviz se han guardado en el archivo <%s>."
+#~ msgid "General settings"
+#~ msgstr "Configuración general."
+#, fuzzy
 #~ msgid "Show help page"
 #~ msgstr "Mostrar líneas."
@@ -13107,18 +13297,9 @@
 #~ msgid "Icon size:"
 #~ msgstr "Tamaño de ícono:"
-#~ msgid "width:"
-#~ msgstr "Anchura de línea:"
-#~ msgid "color:"
-#~ msgstr "Color:"
 #~ msgid "Layer properties"
 #~ msgstr "Propiedades de capa."
-#~ msgid "Vector map <%s> is 3D"
-#~ msgstr "El mapa vectorial <%s> es tridimensional (3D)."
 #~ msgid "Vector map <%s> is 2D"
 #~ msgstr "El mapa vectorial <%s> es bidimensional (2D)."
Modified: grass/trunk/locale/po/grasswxpy_fr.po
--- grass/trunk/locale/po/grasswxpy_fr.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasswxpy_fr.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -5,13 +5,13 @@
 # Eve (alias 'phyto') <dendrosociology[a]yahoo.co.uk>, 2006.
 # BAIN <bain toraval.fr>, 2007.
 # Sylvain Maillard <sylvain.maillard gmail.com>, 2011.
-#: ../gui/wxpython/gui_modules/psmap.py:1097
+#: ../gui/wxpython/gui_modules/psmap.py:1096
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2211
 msgid ""
 msgstr ""
 "Project-Id-Version: grasstcl_fr\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2011-05-21 09:48+0100\n"
 "Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
 "Language-Team: français <grass-translations at lists.osgeo.org>\n"
@@ -25,60 +25,76 @@
 "X-Poedit-SourceCharset: utf-8\n"
 "X-Poedit-Bookmarks: 101,-1,-1,-1,-1,-1,-1,-1,-1,-1\n"
-#: ../gui/wxpython/wxgui.py:96
+#: ../gui/wxpython/wxgui.py:97
 #, fuzzy
 msgid "GRASS GIS Layer Manager"
 msgstr "Gestionnaire des tables d'attributs GRASS"
-#: ../gui/wxpython/wxgui.py:136
+#: ../gui/wxpython/wxgui.py:139
 #, fuzzy
-msgid "Main Toolbar"
+msgid "Data Toolbar"
 msgstr "Barre d'outils pour les cartes"
-#: ../gui/wxpython/wxgui.py:144
+#: ../gui/wxpython/wxgui.py:147
 #, fuzzy
+msgid "Workspace Toolbar"
+msgstr "&Espace de travail"
+#: ../gui/wxpython/wxgui.py:155
+#, fuzzy
+msgid "Misc Toolbar"
+msgstr "Barre d'outils pour les cartes"
+#: ../gui/wxpython/wxgui.py:163
+#, fuzzy
 msgid "Tools Toolbar"
-#: ../gui/wxpython/wxgui.py:231
+#: ../gui/wxpython/wxgui.py:250
 #, fuzzy
 msgid "Map layers"
 msgstr "Charger des cartes"
-#: ../gui/wxpython/wxgui.py:235 ../gui/wxpython/wxgui.py:375
+#: ../gui/wxpython/wxgui.py:254 ../gui/wxpython/wxgui.py:407
 #, fuzzy
 msgid "Command console"
 msgstr "Messages de la commande"
-#: ../gui/wxpython/wxgui.py:239
+#: ../gui/wxpython/wxgui.py:260
 msgid "Search module"
 msgstr "Rechercher un module"
-#: ../gui/wxpython/wxgui.py:252 ../gui/wxpython/gui_modules/toolbars.py:207
+#: ../gui/wxpython/wxgui.py:267
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:282 ../gui/wxpython/gui_modules/toolbars.py:211
 msgid "3D view"
 msgstr "Vue 3D"
-#: ../gui/wxpython/wxgui.py:296
+#: ../gui/wxpython/wxgui.py:328
 #, python-format
 msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:315
+#: ../gui/wxpython/wxgui.py:347
 #, fuzzy
 msgid "Choose model to run"
 msgstr "Choisir la projection"
-#: ../gui/wxpython/wxgui.py:317 ../gui/wxpython/gui_modules/gmodeler.py:802
-#: ../gui/wxpython/gui_modules/gmodeler.py:846
+#: ../gui/wxpython/wxgui.py:349 ../gui/wxpython/gui_modules/gmodeler.py:796
+#: ../gui/wxpython/gui_modules/gmodeler.py:840
 msgid "GRASS Model File (*.gxm)|*.gxm"
 msgstr "Ficher modèle GRASS (*.gxm)|*.gxm"
-#: ../gui/wxpython/wxgui.py:326 ../gui/wxpython/gui_modules/gmodeler.py:1117
+#: ../gui/wxpython/wxgui.py:358 ../gui/wxpython/gui_modules/gmodeler.py:1111
 #, fuzzy
 msgid "Validating model..."
 msgstr "Plage de validité"
-#: ../gui/wxpython/wxgui.py:330 ../gui/wxpython/gui_modules/gmodeler.py:919
+#: ../gui/wxpython/wxgui.py:362 ../gui/wxpython/gui_modules/gmodeler.py:913
 #, python-format
 msgid ""
 "Model is not valid. Do you want to run the model anyway?\n"
@@ -89,66 +105,66 @@
 "\n"
 "%s"
-#: ../gui/wxpython/wxgui.py:332 ../gui/wxpython/gui_modules/gmodeler.py:921
+#: ../gui/wxpython/wxgui.py:364 ../gui/wxpython/gui_modules/gmodeler.py:915
 msgid "Run model?"
 msgstr "Exécuter le modèle ?"
-#: ../gui/wxpython/wxgui.py:339 ../gui/wxpython/gui_modules/gmodeler.py:984
+#: ../gui/wxpython/wxgui.py:371 ../gui/wxpython/gui_modules/gmodeler.py:978
 msgid "Running model..."
 msgstr "Modèle en cours d'exécution ..."
-#: ../gui/wxpython/wxgui.py:389 ../gui/wxpython/wxgui.py:1476
+#: ../gui/wxpython/wxgui.py:421 ../gui/wxpython/wxgui.py:1500
 #, fuzzy
 msgid "Do you want to save changes in the workspace?"
 msgstr "Choisir le fichier où sauver l'environnement courant"
-#: ../gui/wxpython/wxgui.py:391 ../gui/wxpython/wxgui.py:1478
+#: ../gui/wxpython/wxgui.py:423 ../gui/wxpython/wxgui.py:1502
 #, fuzzy
 msgid "Do you want to store current settings to workspace file?"
 msgstr ""
 "L'espace de travail n'est pas vide.  Voulez-vous sauver les paramètres "
 "courants dans un fichier ?"
-#: ../gui/wxpython/wxgui.py:398
+#: ../gui/wxpython/wxgui.py:430
 msgid "Close Map Display %d"
 msgstr "Efface l'écran"
-#: ../gui/wxpython/wxgui.py:497 ../gui/wxpython/wxgui.py:1159
+#: ../gui/wxpython/wxgui.py:529 ../gui/wxpython/wxgui.py:1155
 msgid "Selected map layer is not vector."
 msgstr "La couche sélectionnée n'est pas un vecteur."
-#: ../gui/wxpython/wxgui.py:502
+#: ../gui/wxpython/wxgui.py:534
 #, fuzzy
 msgid "Editing is allowed only for vector maps from the current mapset."
 msgstr "Convertir des couches vectorielles OGR en carte vectorielle GRASS."
-#: ../gui/wxpython/wxgui.py:517
+#: ../gui/wxpython/wxgui.py:549
 #, fuzzy
 msgid "Choose script file to run"
 msgstr "Choisir le répertoire d'entrée"
-#: ../gui/wxpython/wxgui.py:519
+#: ../gui/wxpython/wxgui.py:551
 msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
 msgstr "Script Python (*.py)|*.py|Bash script (*.sh)|*.sh"
-#: ../gui/wxpython/wxgui.py:530
+#: ../gui/wxpython/wxgui.py:562
 msgid "Script file '%s' doesn't exist. Operation cancelled."
 msgstr "Un minimum de %d PCS est requis.  Opération annulée."
-#: ../gui/wxpython/wxgui.py:534
+#: ../gui/wxpython/wxgui.py:566
 #, python-format
 msgid "Launching script '%s'..."
 msgstr "Lancement du script '%s'..."
-#: ../gui/wxpython/wxgui.py:549
+#: ../gui/wxpython/wxgui.py:581
 msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
 msgstr ""
 "Impossible de créer la nouvelle localisation.  Localisation <%s> non créée."
-#: ../gui/wxpython/wxgui.py:551 ../gui/wxpython/wxgui.py:572
+#: ../gui/wxpython/wxgui.py:583 ../gui/wxpython/wxgui.py:604
 #: ../gui/wxpython/scripts/r.li.setup.py:337
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1686
 #: ../gui/wxpython/gui_modules/mapdisp.py:367
@@ -163,8 +179,8 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:1029
 #: ../gui/wxpython/gui_modules/vdigit.py:1221
 #: ../gui/wxpython/gui_modules/vdigit.py:1247
-#: ../gui/wxpython/gui_modules/gmodeler.py:1438
-#: ../gui/wxpython/gui_modules/workspace.py:984
+#: ../gui/wxpython/gui_modules/gmodeler.py:1432
+#: ../gui/wxpython/gui_modules/workspace.py:991
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5365
 #: ../gui/wxpython/gui_modules/dbm.py:165
 #: ../gui/wxpython/gui_modules/dbm.py:1407
@@ -183,40 +199,40 @@
 #: ../gui/wxpython/gui_modules/profile.py:598
 #: ../gui/wxpython/gui_modules/layertree.py:505
 #: ../gui/wxpython/gui_modules/layertree.py:536
-#: ../gui/wxpython/gui_modules/preferences.py:1071
-#: ../gui/wxpython/gui_modules/preferences.py:1948
-#: ../gui/wxpython/gui_modules/preferences.py:1977
-#: ../gui/wxpython/gui_modules/preferences.py:1986
-#: ../gui/wxpython/gui_modules/preferences.py:1996
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+#: ../gui/wxpython/gui_modules/preferences.py:1970
+#: ../gui/wxpython/gui_modules/preferences.py:1999
+#: ../gui/wxpython/gui_modules/preferences.py:2008
+#: ../gui/wxpython/gui_modules/preferences.py:2018
 #: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:466
 #: ../gui/wxpython/gis_set.py:502 ../gui/wxpython/gis_set.py:568
 #: ../gui/wxpython/gis_set.py:725
 msgid "Error"
 msgstr "Erreur"
-#: ../gui/wxpython/wxgui.py:557
+#: ../gui/wxpython/wxgui.py:589
 #, python-format
 msgid ""
 "Current location is <%(loc)s>.\n"
 "Current mapset is <%(mapset)s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:560 ../gui/wxpython/wxgui.py:576
+#: ../gui/wxpython/wxgui.py:592 ../gui/wxpython/wxgui.py:608
 #: ../gui/wxpython/gui_modules/ghelp.py:563
 msgid "Info"
 msgstr "Info"
-#: ../gui/wxpython/wxgui.py:571
+#: ../gui/wxpython/wxgui.py:603
 msgid "Unable to switch to mapset <%s>."
 msgstr "Impossible de créer la carte vectorielle <%s>."
-#: ../gui/wxpython/wxgui.py:575
+#: ../gui/wxpython/wxgui.py:607
 msgid "Current mapset is <%s>."
 msgstr "Sauver les paramètres courants ?"
-#: ../gui/wxpython/wxgui.py:652
+#: ../gui/wxpython/wxgui.py:676
 #, fuzzy
 msgid ""
 "Current workspace is not empty. Do you want to store current settings to "
@@ -225,20 +241,20 @@
-#: ../gui/wxpython/wxgui.py:655
+#: ../gui/wxpython/wxgui.py:679
 #, fuzzy
 msgid "Create new workspace?"
 msgstr "Créer un nouvel espace de travail"
-#: ../gui/wxpython/wxgui.py:681
+#: ../gui/wxpython/wxgui.py:705
 msgid "Choose workspace file"
 msgstr "Choisir un fichier d'environnement"
-#: ../gui/wxpython/wxgui.py:682 ../gui/wxpython/wxgui.py:889
+#: ../gui/wxpython/wxgui.py:706 ../gui/wxpython/wxgui.py:885
 msgid "GRASS Workspace File (*.gxw)|*.gxw"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:717
+#: ../gui/wxpython/wxgui.py:741
 msgid ""
 "Reading workspace file <%s> failed.\n"
@@ -247,61 +263,62 @@
 "Lecture du fichier d'environnement <%s> impossible.  Fichier invalide, "
 "incapable de déchiffrer le document XML"
-#: ../gui/wxpython/wxgui.py:721 ../gui/wxpython/wxgui.py:830
-#: ../gui/wxpython/wxgui.py:866
+#: ../gui/wxpython/wxgui.py:745 ../gui/wxpython/wxgui.py:862
+#: ../gui/wxpython/wxgui.py:1241
 msgid "Please wait, loading workspace..."
 msgstr "Patience, l'environnement est en cours de chargement..."
-#: ../gui/wxpython/wxgui.py:822 ../gui/wxpython/menustrings.py:15
-msgid "Load map layers into layer tree"
-msgstr "Charger des cartes dans l'arborescence des couches"
-#: ../gui/wxpython/wxgui.py:850
+#: ../gui/wxpython/wxgui.py:846
 msgid "Choose GRC file to load"
 msgstr "Choisir un fichier GRC à charger"
-#: ../gui/wxpython/wxgui.py:851
+#: ../gui/wxpython/wxgui.py:847
 msgid "Old GRASS Workspace File (*.grc)|*.grc"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:888
+#: ../gui/wxpython/wxgui.py:884
 msgid "Choose file to save current workspace"
-#: ../gui/wxpython/wxgui.py:903 ../gui/wxpython/wxgui.py:919
+#: ../gui/wxpython/wxgui.py:899 ../gui/wxpython/wxgui.py:915
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
 "Le fichier denvironnement <%s> existe déjà.  Voulez-vous écraser ce fichier ?"
-#: ../gui/wxpython/wxgui.py:905 ../gui/wxpython/wxgui.py:922
+#: ../gui/wxpython/wxgui.py:901 ../gui/wxpython/wxgui.py:918
 #: ../gui/wxpython/menustrings.py:9
 msgid "Save workspace"
 msgstr "Sauver l'espace de travail"
-#: ../gui/wxpython/wxgui.py:943
+#: ../gui/wxpython/wxgui.py:939
 #, fuzzy
 msgid "Writing current settings to workspace file failed."
 msgstr ""
 "Ecriture des paramètres courant dans le fichier d'environnement (%s) non "
 "réussie."
-#: ../gui/wxpython/wxgui.py:954 ../gui/wxpython/gui_modules/gmodeler.py:1437
+#: ../gui/wxpython/wxgui.py:950 ../gui/wxpython/gui_modules/gmodeler.py:1431
 #: ../gui/wxpython/gui_modules/profile.py:597
 msgid "Unable to open file <%s> for writing."
 msgstr "Impossible d'ouvrir le fichier d'environnement <%s> en écriture."
-#: ../gui/wxpython/wxgui.py:1132
+#: ../gui/wxpython/wxgui.py:1128
 #, fuzzy
 msgid "Nothing to import. No WMS layer selected."
 msgstr "Pas de couche sélectionnée"
-#: ../gui/wxpython/wxgui.py:1168
+#: ../gui/wxpython/wxgui.py:1164
 msgid "Please wait, loading attribute data..."
 msgstr "Patientez, chargement des données d'attributs"
-#: ../gui/wxpython/wxgui.py:1418
+#: ../gui/wxpython/wxgui.py:1233
+#, fuzzy
+msgid "Add selected map layers into layer tree"
+msgstr "Ajouter les couches importées dans l'arborescence"
+#: ../gui/wxpython/wxgui.py:1442
 msgid ""
 "Do you want to remove map layer(s)\n"
@@ -309,24 +326,24 @@
 "from layer tree?"
 msgstr "Voulez-vous enlever la couche %s de l'arborescence"
-#: ../gui/wxpython/wxgui.py:1421
+#: ../gui/wxpython/wxgui.py:1445
 #, fuzzy
 msgid "Do you want to remove selected map layer(s) from layer tree?"
 msgstr "Voulez-vous enlever la couche sélectionnée de l'arborescence"
-#: ../gui/wxpython/wxgui.py:1425
+#: ../gui/wxpython/wxgui.py:1449
 msgid "Remove map layer"
 msgstr "Enlever la couche"
-#: ../gui/wxpython/wxgui.py:1485
+#: ../gui/wxpython/wxgui.py:1509
 msgid "Quit GRASS GUI"
 msgstr "Quitter l'interface graphique"
-#: ../gui/wxpython/wxgui.py:1514
+#: ../gui/wxpython/wxgui.py:1538
 msgid "No map layer selected. Operation cancelled."
 msgstr "Aucune couche sélectionnée.  Opération annulée."
-#: ../gui/wxpython/wxgui.py:1515 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
+#: ../gui/wxpython/wxgui.py:1539 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
 #: ../gui/wxpython/gui_modules/ghelp.py:287
 #: ../gui/wxpython/gui_modules/gcmd.py:98
 #: ../gui/wxpython/gui_modules/dbm.py:2056
@@ -335,7 +352,7 @@
 msgid "Message"
 msgstr "Message"
-#: ../gui/wxpython/wxgui.py:1545
+#: ../gui/wxpython/wxgui.py:1569
 #, fuzzy
 msgid "Starting GRASS GUI..."
 msgstr "Démarrer GRASS"
@@ -445,7 +462,7 @@
 msgid "Add scalebar and north arrow"
 msgstr "Ajouter une échelle et la rose des vents"
-#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:438
+#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:440
 msgid "Add legend"
 msgstr "Ajouter la légende"
@@ -456,7 +473,7 @@
 #: ../gui/wxpython/icons/icon.py:152
 #: ../gui/wxpython/gui_modules/histogram.py:440
-#: ../gui/wxpython/gui_modules/mapdisp.py:1179
+#: ../gui/wxpython/gui_modules/mapdisp.py:1187
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:942
 msgid "Print display"
 msgstr "Imprimer l'image écran"
@@ -478,7 +495,7 @@
 msgstr ""
 #: ../gui/wxpython/icons/icon.py:161
-#: ../gui/wxpython/gui_modules/mapdisp.py:1877
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
 msgid "Add text layer"
 msgstr "Ajouter une couche de texte"
@@ -498,606 +515,611 @@
 #: ../gui/wxpython/icons/icon.py:171
 #, fuzzy
-msgid "Load map layers into workspace (Ctrl+L)"
-msgstr "Charger des cartes dans l'espace de travail"
-#: ../gui/wxpython/icons/icon.py:173
-#, fuzzy
 msgid "Open existing workspace file (Ctrl+O)"
 msgstr "Ouvrir un fichier espace de travail existant"
-#: ../gui/wxpython/icons/icon.py:175
+#: ../gui/wxpython/icons/icon.py:173
 #, fuzzy
 msgid "Save current workspace to file (Ctrl+S)"
 msgstr "Sauver l'espace de travail courant"
-#: ../gui/wxpython/icons/icon.py:177 ../gui/wxpython/menustrings.py:29
-#: ../gui/wxpython/gui_modules/gdialogs.py:1146
+#: ../gui/wxpython/icons/icon.py:175
 #, fuzzy
+msgid "Add multiple raster or vector map layers (Ctrl+L)"
+msgstr "Ajouter une couche 'raster'"
+#: ../gui/wxpython/icons/icon.py:177
+#, fuzzy
+msgid "Import/link raster or vector data"
+msgstr "Importer une couche &matricielle"
+#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_modules/gdialogs.py:1147
+#, fuzzy
 msgid "Import raster data"
-#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/gui_modules/gdialogs.py:1144
+#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:148
+#: ../gui/wxpython/gui_modules/gdialogs.py:1145
 #, fuzzy
 msgid "Link external raster data"
 msgstr "Créer un nouvelle carte vectorielle"
-#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:56
-#: ../gui/wxpython/gui_modules/gdialogs.py:1140
+#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_modules/gdialogs.py:1141
 #, fuzzy
 msgid "Import vector data"
 msgstr "Importer une couche &vectorielle"
-#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:150
-#: ../gui/wxpython/gui_modules/gdialogs.py:1138
+#: ../gui/wxpython/icons/icon.py:185 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_modules/gdialogs.py:1139
 #, fuzzy
 msgid "Link external vector data"
-#: ../gui/wxpython/icons/icon.py:185
+#: ../gui/wxpython/icons/icon.py:187
 #, fuzzy
 msgid "Add raster map layer (Ctrl+R)"
-#: ../gui/wxpython/icons/icon.py:187
+#: ../gui/wxpython/icons/icon.py:189
 #, fuzzy
 msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
-#: ../gui/wxpython/icons/icon.py:189
+#: ../gui/wxpython/icons/icon.py:191
 #, fuzzy
 msgid "Add vector map layer (Ctrl+V)"
 msgstr "Ajouter une couche vectorielle"
-#: ../gui/wxpython/icons/icon.py:191
+#: ../gui/wxpython/icons/icon.py:193
 #, fuzzy
 msgid "Add various vector map layers (thematic, chart...)"
-#: ../gui/wxpython/icons/icon.py:193
+#: ../gui/wxpython/icons/icon.py:195
 msgid "Add command layer"
 msgstr "Ajouter une commande de couche"
-#: ../gui/wxpython/icons/icon.py:195
+#: ../gui/wxpython/icons/icon.py:197
 #, fuzzy
 msgid "Add group"
 msgstr "Ajouter un groupe"
-#: ../gui/wxpython/icons/icon.py:197
+#: ../gui/wxpython/icons/icon.py:199
 msgid "Add grid or vector labels overlay"
 msgstr "Ajouter une couche carroyage ou des étiquettes"
-#: ../gui/wxpython/icons/icon.py:199
+#: ../gui/wxpython/icons/icon.py:201
 #, fuzzy
 msgid "Delete selected map layer"
 msgstr "Effacer la couche sélectionnée"
-#: ../gui/wxpython/icons/icon.py:201 ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/icons/icon.py:203 ../gui/wxpython/icons/icon.py:403
 msgid "Quit"
 msgstr "Quitter"
-#: ../gui/wxpython/icons/icon.py:203
+#: ../gui/wxpython/icons/icon.py:205
 msgid "Show attribute table"
 msgstr "Visualiser la table des attributs"
-#: ../gui/wxpython/icons/icon.py:205
+#: ../gui/wxpython/icons/icon.py:207
 #, fuzzy
 msgid "Edit vector maps"
 msgstr "Exporter une couche ve&ctorielle"
-#: ../gui/wxpython/icons/icon.py:207
+#: ../gui/wxpython/icons/icon.py:209
 #, fuzzy
 msgid "Add RGB map layer"
 msgstr "Ajouter une couche RVB"
-#: ../gui/wxpython/icons/icon.py:209
+#: ../gui/wxpython/icons/icon.py:211
 #, fuzzy
 msgid "Add HIS map layer"
 msgstr "Ajouter une couche TIS"
-#: ../gui/wxpython/icons/icon.py:211
+#: ../gui/wxpython/icons/icon.py:213
 msgid "Add shaded relief map layer"
 msgstr "Ajouter une carte en relief ombré"
-#: ../gui/wxpython/icons/icon.py:213
+#: ../gui/wxpython/icons/icon.py:215
 msgid "Add raster flow arrows"
 msgstr "Ajouter des flèches de flux (raster) "
-#: ../gui/wxpython/icons/icon.py:215
+#: ../gui/wxpython/icons/icon.py:217
 msgid "Add raster cell numbers"
 msgstr "AJouter le numéro des cellules (raster)"
-#: ../gui/wxpython/icons/icon.py:217
+#: ../gui/wxpython/icons/icon.py:219
 #, fuzzy
 msgid "Add thematic area (choropleth) map layer"
 msgstr "Ajouter une charte thématique"
-#: ../gui/wxpython/icons/icon.py:219
+#: ../gui/wxpython/icons/icon.py:221
 msgid "Add thematic chart layer"
-#: ../gui/wxpython/icons/icon.py:221
+#: ../gui/wxpython/icons/icon.py:223
 msgid "Add grid layer"
 msgstr "Ajouter une couche carroyage"
-#: ../gui/wxpython/icons/icon.py:223
+#: ../gui/wxpython/icons/icon.py:225
 msgid "Add geodesic line layer"
 msgstr "Ajouter une couche avec ligne géodésique"
-#: ../gui/wxpython/icons/icon.py:225
+#: ../gui/wxpython/icons/icon.py:227
 msgid "Add rhumbline layer"
 msgstr "Ajouter une rhumbline"
-#: ../gui/wxpython/icons/icon.py:227
+#: ../gui/wxpython/icons/icon.py:229
 msgid "Add labels"
 msgstr "Ajouter des étiquettes"
-#: ../gui/wxpython/icons/icon.py:229
+#: ../gui/wxpython/icons/icon.py:231
 #, fuzzy
 msgid "Add 3D raster map layer"
-#: ../gui/wxpython/icons/icon.py:230
+#: ../gui/wxpython/icons/icon.py:232
 msgid "Note that 3D raster data are rendered only in 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:232
+#: ../gui/wxpython/icons/icon.py:234
 #, fuzzy
 msgid "Show GUI settings"
 msgstr "Montrer les réglages"
-#: ../gui/wxpython/icons/icon.py:234
+#: ../gui/wxpython/icons/icon.py:236
 #, fuzzy
 msgid "Graphical Modeler"
-#: ../gui/wxpython/icons/icon.py:236
+#: ../gui/wxpython/icons/icon.py:238
 #: ../gui/wxpython/gui_modules/gdialogs.py:416
 msgid "Set options"
 msgstr "Modifier les options"
-#: ../gui/wxpython/icons/icon.py:238
-msgid "Hardcopy Map Ouput Utility"
+#: ../gui/wxpython/icons/icon.py:240 ../gui/wxpython/menustrings.py:198
+msgid "Hardcopy Map Output Utility"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:240
+#: ../gui/wxpython/icons/icon.py:242
 #, fuzzy
 msgid "Raster Map Calculator"
-#: ../gui/wxpython/icons/icon.py:244
+#: ../gui/wxpython/icons/icon.py:246
 msgid "Digitize new point"
 msgstr "Digitaliser un nouveau pont"
-#: ../gui/wxpython/icons/icon.py:245 ../gui/wxpython/icons/icon.py:254
-#: ../gui/wxpython/icons/icon.py:257
+#: ../gui/wxpython/icons/icon.py:247 ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:259
 msgid "Left: new point"
 msgstr "Gauche : nouveau point"
-#: ../gui/wxpython/icons/icon.py:247
+#: ../gui/wxpython/icons/icon.py:249
 msgid "Digitize new line"
 msgstr "Digitaliser une nouvelle ligne"
-#: ../gui/wxpython/icons/icon.py:248 ../gui/wxpython/icons/icon.py:251
-#: ../gui/wxpython/icons/icon.py:275
+#: ../gui/wxpython/icons/icon.py:250 ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:277
 #, fuzzy
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
 msgstr ""
 "Gauche : nouveau point ; Milieu : Annuler dernière action ; Droite : fermer "
 "la ligne"
-#: ../gui/wxpython/icons/icon.py:250
+#: ../gui/wxpython/icons/icon.py:252
 msgid "Digitize new boundary"
 msgstr "Digitaliser un nouveau contour"
-#: ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:255
 msgid "Digitize new centroid"
 msgstr "Digitaliser un nouveau centroïde"
-#: ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:258
 msgid ""
 "Digitize new area (composition of boundaries without category and one "
 "centroid with category)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:259
+#: ../gui/wxpython/icons/icon.py:261
 msgid "Add new vertex"
 msgstr "Ajouter un nouveau vertex"
-#: ../gui/wxpython/icons/icon.py:260 ../gui/wxpython/icons/icon.py:263
-#: ../gui/wxpython/icons/icon.py:266 ../gui/wxpython/icons/icon.py:278
-#: ../gui/wxpython/icons/icon.py:281 ../gui/wxpython/icons/icon.py:284
-#: ../gui/wxpython/icons/icon.py:289 ../gui/wxpython/icons/icon.py:296
+#: ../gui/wxpython/icons/icon.py:262 ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:268 ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:283 ../gui/wxpython/icons/icon.py:286
+#: ../gui/wxpython/icons/icon.py:291 ../gui/wxpython/icons/icon.py:298
 #, fuzzy
 msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
 msgstr "Gauche : Sélectionner ; Milieu : Désélectionner : Droite : Confirmer"
-#: ../gui/wxpython/icons/icon.py:262
-#: ../gui/wxpython/gui_modules/toolbars.py:782
+#: ../gui/wxpython/icons/icon.py:264
+#: ../gui/wxpython/gui_modules/toolbars.py:729
 msgid "Copy categories"
 msgstr "Copier les catégories"
-#: ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:267
 msgid "Delete feature(s)"
 msgstr "Effacer un (des) objet(s)"
-#: ../gui/wxpython/icons/icon.py:268
+#: ../gui/wxpython/icons/icon.py:270
 msgid "Display/update attributes"
 msgstr "Afficher/mettre à jour les attributs"
-#: ../gui/wxpython/icons/icon.py:269 ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/icons/icon.py:271 ../gui/wxpython/icons/icon.py:274
 msgid "Left: Select"
 msgstr "Gauche : Sélectionner "
-#: ../gui/wxpython/icons/icon.py:271
+#: ../gui/wxpython/icons/icon.py:273
 msgid "Display/update categories"
 msgstr "Afficher/mettre à jour les catégories"
-#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/icons/icon.py:276
 msgid "Edit line/boundary"
 msgstr "Éditer une ligne / un contour"
-#: ../gui/wxpython/icons/icon.py:277
+#: ../gui/wxpython/icons/icon.py:279
 msgid "Move feature(s)"
 msgstr "Bouger un (des) objet(s)"
-#: ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:282
 msgid "Move vertex"
 msgstr "Déplacer un vertex"
-#: ../gui/wxpython/icons/icon.py:283
+#: ../gui/wxpython/icons/icon.py:285
 msgid "Remove vertex"
 msgstr "Supprimer un vertex"
-#: ../gui/wxpython/icons/icon.py:286
-#: ../gui/wxpython/gui_modules/toolbars.py:857
+#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/gui_modules/toolbars.py:804
 msgid "Digitization settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/icons/icon.py:290
 msgid "Split line/boundary"
 msgstr "Couper une ligne/limite"
-#: ../gui/wxpython/icons/icon.py:291
+#: ../gui/wxpython/icons/icon.py:293
 #, fuzzy
 msgid "Quit digitizer"
 msgstr "Barre d'outils pour le digitaliseur vectoriel"
-#: ../gui/wxpython/icons/icon.py:292
+#: ../gui/wxpython/icons/icon.py:294
 msgid "Quit digitizer and save changes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:294
+#: ../gui/wxpython/icons/icon.py:296
 msgid "Additional tools (copy, flip, connect, etc.)"
 msgstr "Outils additionnels (copier, retourner, connecter, ...)"
-#: ../gui/wxpython/icons/icon.py:298
+#: ../gui/wxpython/icons/icon.py:300
 msgid "Undo"
 msgstr "Annuler"
-#: ../gui/wxpython/icons/icon.py:299
+#: ../gui/wxpython/icons/icon.py:301
 msgid "Undo previous changes"
 msgstr "Annuler les changements précédents"
-#: ../gui/wxpython/icons/icon.py:303
+#: ../gui/wxpython/icons/icon.py:305
 msgid "Draw/re-draw profile"
 msgstr "Trace/retrace le profil"
-#: ../gui/wxpython/icons/icon.py:305
+#: ../gui/wxpython/icons/icon.py:307
 msgid "Draw transect in map display window to profile"
 msgstr "Tracer la ligne de coupe sur la carte affichée"
-#: ../gui/wxpython/icons/icon.py:307
+#: ../gui/wxpython/icons/icon.py:309
 msgid "Profile options"
 msgstr "Options pour les profils"
-#: ../gui/wxpython/icons/icon.py:309
+#: ../gui/wxpython/icons/icon.py:311
 #, fuzzy
 msgid "Save profile data to CSV file"
 msgstr "Sauver l'image écran dans un ficher PNG"
-#: ../gui/wxpython/icons/icon.py:311
+#: ../gui/wxpython/icons/icon.py:313
 msgid "Quit Profile Analysis Tool"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/icons/icon.py:317
 msgid "Set GCP"
 msgstr "Ajuster les points de contrôles (PCS)"
-#: ../gui/wxpython/icons/icon.py:316
+#: ../gui/wxpython/icons/icon.py:318
 msgid "Define GCP (Ground Control Points)"
 msgstr "Définir les points de contrôle au sol (PCS)"
-#: ../gui/wxpython/icons/icon.py:318 ../gui/wxpython/menustrings.py:186
+#: ../gui/wxpython/icons/icon.py:320 ../gui/wxpython/menustrings.py:186
 msgid "Georectify"
 msgstr "Géoré&férencer"
-#: ../gui/wxpython/icons/icon.py:320
+#: ../gui/wxpython/icons/icon.py:322
 msgid "Recalculate RMS error"
 msgstr "Recalculer l'erreur RMS"
-#: ../gui/wxpython/icons/icon.py:322
+#: ../gui/wxpython/icons/icon.py:324
 msgid "Save GCPs to POINTS file"
 msgstr "Enregistrer GCPs dans un fichier de points"
-#: ../gui/wxpython/icons/icon.py:324
+#: ../gui/wxpython/icons/icon.py:326
 msgid "Add new GCP"
 msgstr "Ajouter de nouveaux PCS"
-#: ../gui/wxpython/icons/icon.py:326
+#: ../gui/wxpython/icons/icon.py:328
 msgid "Delete selected GCP"
 msgstr "Effacer les points de contrôles (PCS) sélectionnés"
-#: ../gui/wxpython/icons/icon.py:328
+#: ../gui/wxpython/icons/icon.py:330
 msgid "Clear selected GCP"
 msgstr "Nettoyer les points de contrôles (PCS) sélectionnés"
-#: ../gui/wxpython/icons/icon.py:330
+#: ../gui/wxpython/icons/icon.py:332
 #, fuzzy
 msgid "Reload GCPs from POINTS file"
 msgstr "Recharger les PCS depuis un fichier Points"
-#: ../gui/wxpython/icons/icon.py:332
+#: ../gui/wxpython/icons/icon.py:334
 #, fuzzy
 msgid "Quit georectification"
 msgstr "Quitter le module de géo-correction"
-#: ../gui/wxpython/icons/icon.py:334
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1289
+#: ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1504
 #: ../gui/wxpython/gui_modules/gselect.py:1070
 msgid "Settings"
 msgstr "Réglages"
-#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/icons/icon.py:337
 msgid "Settings dialog for georectification tool"
 msgstr "Paramètres pour l'outil de géo-correction "
-#: ../gui/wxpython/icons/icon.py:339
+#: ../gui/wxpython/icons/icon.py:341
 msgid "Switch to view control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:340
+#: ../gui/wxpython/icons/icon.py:342
 #, fuzzy
 msgid "Change view settings"
 msgstr "Modifier les réglages"
-#: ../gui/wxpython/icons/icon.py:342
+#: ../gui/wxpython/icons/icon.py:344
 msgid "Switch to surface (raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:343
+#: ../gui/wxpython/icons/icon.py:345
 #, fuzzy
 msgid "Change surface (loaded raster maps) settings"
 msgstr "Recoder une carte 'raster' en utilisant des règles"
-#: ../gui/wxpython/icons/icon.py:345
+#: ../gui/wxpython/icons/icon.py:347
 msgid "Switch to vector (2D/3D) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:346
+#: ../gui/wxpython/icons/icon.py:348
 #, fuzzy
 msgid "Change 2D/3D vector settings"
-#: ../gui/wxpython/icons/icon.py:348
+#: ../gui/wxpython/icons/icon.py:350
 msgid "Switch to volume (3D raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:349
+#: ../gui/wxpython/icons/icon.py:351
 msgid "Change volume (loaded 3D raster maps) settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:353
 msgid "Switch to lighting control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:352
+#: ../gui/wxpython/icons/icon.py:354
 #, fuzzy
 msgid "Change lighting settings"
-#: ../gui/wxpython/icons/icon.py:354
+#: ../gui/wxpython/icons/icon.py:356
 msgid "Switch to fringe control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:355
+#: ../gui/wxpython/icons/icon.py:357
 msgid "Switch on/off fringes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:359
 #, fuzzy
 msgid "3D view mode tools"
 msgstr "Outils NVIZ"
-#: ../gui/wxpython/icons/icon.py:358
+#: ../gui/wxpython/icons/icon.py:360
 #, fuzzy
 msgid "Show/hide 3D view mode settings dialog"
 msgstr "Afficher la boîte de dialogue des paramètres NVIZ"
-#: ../gui/wxpython/icons/icon.py:360
+#: ../gui/wxpython/icons/icon.py:362
 msgid "Quit 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:361
+#: ../gui/wxpython/icons/icon.py:363
 msgid "Switch back to 2D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:365
+#: ../gui/wxpython/icons/icon.py:367
 #, fuzzy
 msgid "Create new model (Ctrl+N)"
 msgstr "Créer un nouveau jeu de cartes"
-#: ../gui/wxpython/icons/icon.py:367
+#: ../gui/wxpython/icons/icon.py:369
 #, fuzzy
 msgid "Load model from file (Ctrl+O)"
-#: ../gui/wxpython/icons/icon.py:369
+#: ../gui/wxpython/icons/icon.py:371
 #, fuzzy
 msgid "Save current model to file (Ctrl+S)"
-#: ../gui/wxpython/icons/icon.py:371 ../gui/wxpython/menustrings.py:878
+#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:878
 #, fuzzy
 msgid "Export model to image"
-#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:880
+#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:880
 msgid "Export model to Python script"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:888
+#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:888
 msgid "Add action (GRASS module) to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:890
 msgid "Add data item to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:892
+#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:892
 msgid "Define relation between data and action items"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:190
+#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:190
 #: ../gui/wxpython/menustrings.py:903
 msgid "Run model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:905
+#: ../gui/wxpython/icons/icon.py:385 ../gui/wxpython/menustrings.py:905
 msgid "Validate model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:385
+#: ../gui/wxpython/icons/icon.py:387
 #, fuzzy
 msgid "Show modeler settings"
-#: ../gui/wxpython/icons/icon.py:387
+#: ../gui/wxpython/icons/icon.py:389
 #, fuzzy
 msgid "Show model properties"
 msgstr " Propriétés de la couche"
-#: ../gui/wxpython/icons/icon.py:389
+#: ../gui/wxpython/icons/icon.py:391
 #, fuzzy
 msgid "Manage model variables"
 msgstr "Gérer"
-#: ../gui/wxpython/icons/icon.py:391
+#: ../gui/wxpython/icons/icon.py:393
 msgid "Redraw model canvas"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:393
-#: ../gui/wxpython/gui_modules/gmodeler.py:677
+#: ../gui/wxpython/icons/icon.py:395
+#: ../gui/wxpython/gui_modules/gmodeler.py:671
 msgid "Quit Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:397
+#: ../gui/wxpython/icons/icon.py:399
 msgid "Select font"
 msgstr "Sélectionner une police"
-#: ../gui/wxpython/icons/icon.py:399
+#: ../gui/wxpython/icons/icon.py:401
 #, fuzzy
 msgid "Show manual"
 msgstr "Carte des ombres"
-#: ../gui/wxpython/icons/icon.py:405
+#: ../gui/wxpython/icons/icon.py:407
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:407
+#: ../gui/wxpython/icons/icon.py:409
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:409
+#: ../gui/wxpython/icons/icon.py:411
 msgid "Generate PostScript output"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:411
+#: ../gui/wxpython/icons/icon.py:413
 #, fuzzy
 msgid "Generate PDF output"
 msgstr "Générer &des points"
-#: ../gui/wxpython/icons/icon.py:413
+#: ../gui/wxpython/icons/icon.py:415
 #: ../gui/wxpython/gui_modules/histogram.py:432
-#: ../gui/wxpython/gui_modules/mapdisp.py:1171
+#: ../gui/wxpython/gui_modules/mapdisp.py:1179
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:934
 msgid "Page setup"
 msgstr "Mise en page"
-#: ../gui/wxpython/icons/icon.py:414
+#: ../gui/wxpython/icons/icon.py:416
 msgid "Specify paper size, margins and orientation"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:416
+#: ../gui/wxpython/icons/icon.py:418
 msgid "Full extent"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:417
+#: ../gui/wxpython/icons/icon.py:419
 #, fuzzy
 msgid "Zoom to full extent"
 msgstr "Zoom sur la région par défaut"
-#: ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:421
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1951
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2006
 #, fuzzy
 msgid "Map frame"
-#: ../gui/wxpython/icons/icon.py:420
+#: ../gui/wxpython/icons/icon.py:422
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:320
+#: ../gui/wxpython/icons/icon.py:424
+#: ../gui/wxpython/gui_modules/nviz_tools.py:465
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2476
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:669
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:730
 msgid "Raster map"
 msgstr "Couche matricielle"
-#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/icons/icon.py:425
 #, fuzzy
 msgid "Add raster map"
 msgstr "Ajouter une carte 3D (raster)"
-#: ../gui/wxpython/icons/icon.py:425
-#: ../gui/wxpython/gui_modules/nviz_tools.py:629
+#: ../gui/wxpython/icons/icon.py:427
+#: ../gui/wxpython/gui_modules/nviz_tools.py:839
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3920
 #, fuzzy
 msgid "Vector map"
 msgstr "vecteur"
-#: ../gui/wxpython/icons/icon.py:426
+#: ../gui/wxpython/icons/icon.py:428
 #, fuzzy
 msgid "Add vector map"
 msgstr "vecteur"
-#: ../gui/wxpython/icons/icon.py:428
+#: ../gui/wxpython/icons/icon.py:430
 #, fuzzy
 msgid "Delete selected object"
 msgstr "Effacer la localisation sélectionnée"
-#: ../gui/wxpython/icons/icon.py:430
+#: ../gui/wxpython/icons/icon.py:432
 #, fuzzy
 msgid "Show preview"
 msgstr "Aperçu avant impression"
-#: ../gui/wxpython/icons/icon.py:432
+#: ../gui/wxpython/icons/icon.py:434
 msgid "Quit Hardcopy Map Utility"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:434
+#: ../gui/wxpython/icons/icon.py:436
 #, fuzzy
 msgid "Add text"
-#: ../gui/wxpython/icons/icon.py:436
+#: ../gui/wxpython/icons/icon.py:438
 #, fuzzy
 msgid "Add map info"
 msgstr "Ajouter une légende"
-#: ../gui/wxpython/icons/icon.py:440
+#: ../gui/wxpython/icons/icon.py:442
 #, fuzzy
 msgid "Add scale bar"
@@ -1123,84 +1145,84 @@
 msgid "Kriging"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:109
-#: ../gui/wxpython/gui_modules/gmodeler.py:575
-#: ../gui/wxpython/gui_modules/menuform.py:1165
+#: ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gui_modules/gmodeler.py:569
+#: ../gui/wxpython/gui_modules/menuform.py:1160
 msgid "Command output"
-#: ../gui/wxpython/scripts/vkrige.py:115 ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/scripts/vkrige.py:114 ../gui/wxpython/menustrings.py:390
 msgid "Output"
 msgstr "Sortie"
-#: ../gui/wxpython/scripts/vkrige.py:119
+#: ../gui/wxpython/scripts/vkrige.py:118
 #, fuzzy
 msgid "Name for the output raster map:"
 msgstr "Nom pour la nouvelle carte vectorielle :"
-#: ../gui/wxpython/scripts/vkrige.py:127
+#: ../gui/wxpython/scripts/vkrige.py:126
 #, fuzzy
 msgid "Export variance map as well: "
 msgstr "Exporter une couche mat&ricielle"
-#: ../gui/wxpython/scripts/vkrige.py:140
+#: ../gui/wxpython/scripts/vkrige.py:139
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:229
 #: ../gui/wxpython/gui_modules/vclean.py:144
-#: ../gui/wxpython/gui_modules/gmodeler.py:3309
-#: ../gui/wxpython/gui_modules/gdialogs.py:985
-#: ../gui/wxpython/gui_modules/preferences.py:1533
+#: ../gui/wxpython/gui_modules/gmodeler.py:3303
+#: ../gui/wxpython/gui_modules/gdialogs.py:986
+#: ../gui/wxpython/gui_modules/preferences.py:1555
 msgid "Allow output files to overwrite existing files"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:153
+#: ../gui/wxpython/scripts/vkrige.py:152
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:133
 #: ../gui/wxpython/gui_modules/ghelp.py:223
 #: ../gui/wxpython/gui_modules/vclean.py:165
-#: ../gui/wxpython/gui_modules/gmodeler.py:3426
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/gmodeler.py:3420
+#: ../gui/wxpython/gui_modules/menuform.py:828
 msgid "&Run"
 msgstr "&Exécuter"
-#: ../gui/wxpython/scripts/vkrige.py:268
+#: ../gui/wxpython/scripts/vkrige.py:267
 msgid "Kriging Module"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:272
+#: ../gui/wxpython/scripts/vkrige.py:271
 msgid "Ready."
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:296
+#: ../gui/wxpython/scripts/vkrige.py:295
 msgid "Variogram fitting"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:306
+#: ../gui/wxpython/scripts/vkrige.py:305
 msgid "Plot/refresh variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:317
+#: ../gui/wxpython/scripts/vkrige.py:316
 #, fuzzy
 msgid ":"
 msgstr "X :"
-#: ../gui/wxpython/scripts/vkrige.py:342
+#: ../gui/wxpython/scripts/vkrige.py:341
 msgid "Kriging techniques"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:356
+#: ../gui/wxpython/scripts/vkrige.py:355
 #, fuzzy
 msgid "Block size:"
 msgstr "Taille de l'icône"
-#: ../gui/wxpython/scripts/vkrige.py:389
+#: ../gui/wxpython/scripts/vkrige.py:388
 msgid "Auto-fit variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:413
+#: ../gui/wxpython/scripts/vkrige.py:412
 #, fuzzy
 msgid "Model: "
 msgstr "Mode :"
-#: ../gui/wxpython/scripts/vkrige.py:497
+#: ../gui/wxpython/scripts/vkrige.py:496
 msgid "Work in progress! No functionality provided."
 msgstr ""
@@ -1287,8 +1309,9 @@
 msgid "Workspace"
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:17
 #: ../gui/wxpython/menustrings.py:867
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
 msgid "New"
 msgstr "Nouveau"
@@ -1330,48 +1353,53 @@
 #: ../gui/wxpython/menustrings.py:14
-msgid "Load map layers"
-msgstr "Charger des cartes"
-#: ../gui/wxpython/menustrings.py:16
 msgid "Load GRC file (Tcl/Tk GUI)"
 msgstr "Charger un fichier GRC (interface Tcl/Tk)"
-#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/menustrings.py:15
 #, fuzzy
 msgid "Load map layers from GRC file to layer tree"
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:16
 #, fuzzy
 msgid "Map display"
 msgstr "Afficher :"
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:18
 #, fuzzy
 msgid "Open new map display window"
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:19
 #, fuzzy
 msgid "Close current"
 msgstr "Fermer le fichier d'espace de travail courant"
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:20
 #, fuzzy
 msgid "Close current map display window"
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:21
 #, fuzzy
 msgid "Close all"
 msgstr "Fermer la boîte de dialogue"
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:22
 #, fuzzy
 msgid "Close all open map display windows"
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+#, fuzzy
+msgid "Add multiple raster or vector map layers to current display"
 #: ../gui/wxpython/menustrings.py:25
 #, fuzzy
 msgid "Add raster"
@@ -2015,6 +2043,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2640
 msgid "Delete"
 msgstr "Effacer"
@@ -2144,10 +2173,6 @@
 "coordinates and vice versa."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:198
-msgid "Hardcopy Map Output Utility"
-msgstr ""
 #: ../gui/wxpython/menustrings.py:199
 msgid "Launch Hardcopy Map Output Utility"
 msgstr ""
@@ -2579,9 +2604,8 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:298
-#: ../gui/wxpython/gui_modules/nviz_tools.py:351
-#: ../gui/wxpython/gui_modules/nviz_tools.py:549
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:602
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1238
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3049
 msgid "Mask"
 msgstr "Masque"
@@ -2739,7 +2763,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:330
-#: ../gui/wxpython/gui_modules/layertree.py:803
+#: ../gui/wxpython/gui_modules/layertree.py:799
 msgid "Shaded relief"
 msgstr "Ombrage"
@@ -5067,7 +5091,7 @@
 #: ../gui/wxpython/menustrings.py:872
-#: ../gui/wxpython/gui_modules/gmodeler.py:828
+#: ../gui/wxpython/gui_modules/gmodeler.py:822
 msgid "Save model"
 msgstr ""
@@ -5100,7 +5124,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:885
-#: ../gui/wxpython/gui_modules/gmodeler.py:3003
+#: ../gui/wxpython/gui_modules/gmodeler.py:2997
 #, fuzzy
 msgid "Modeler settings"
 msgstr "Paramètres généraux"
@@ -5152,7 +5176,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:899
-#: ../gui/wxpython/gui_modules/gmodeler.py:3288
+#: ../gui/wxpython/gui_modules/gmodeler.py:3282
 #, fuzzy
 msgid "Model properties"
@@ -5301,8 +5325,8 @@
 msgstr "Créer l'histogramme de l'image ou du fichier 'raster'"
 #: ../gui/wxpython/gui_modules/histogram.py:332
-#: ../gui/wxpython/gui_modules/wxnviz.py:227
-#: ../gui/wxpython/gui_modules/wxnviz.py:238
+#: ../gui/wxpython/gui_modules/wxnviz.py:240
+#: ../gui/wxpython/gui_modules/wxnviz.py:251
 msgid "Raster map <%s> not found"
 msgstr "ERREUR : Jeu de cartes <%s> non trouvé"
@@ -5312,14 +5336,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:403
-#: ../gui/wxpython/gui_modules/mapdisp.py:1142
+#: ../gui/wxpython/gui_modules/mapdisp.py:1150
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:905
-#: ../gui/wxpython/gui_modules/gmodeler.py:1042
+#: ../gui/wxpython/gui_modules/gmodeler.py:1036
 msgid "Choose a file name to save the image (no need to add extension)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:436
-#: ../gui/wxpython/gui_modules/mapdisp.py:1175
+#: ../gui/wxpython/gui_modules/mapdisp.py:1183
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:938
 msgid "Print preview"
@@ -5357,16 +5381,16 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#: ../gui/wxpython/gui_modules/gdialogs.py:1005
+#: ../gui/wxpython/gui_modules/gdialogs.py:1006
 #, fuzzy
 msgid "Command dialog"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:138
-#: ../gui/wxpython/gui_modules/gdialogs.py:1161
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
-#: ../gui/wxpython/gui_modules/gdialogs.py:1168
-#: ../gui/wxpython/gui_modules/gdialogs.py:1170
+#: ../gui/wxpython/gui_modules/gdialogs.py:1162
+#: ../gui/wxpython/gui_modules/gdialogs.py:1164
+#: ../gui/wxpython/gui_modules/gdialogs.py:1169
+#: ../gui/wxpython/gui_modules/gdialogs.py:1171
 #, python-format
 msgid "Open %s dialog"
 msgstr "Ouvrir la boite de dialogue %s"
@@ -5377,7 +5401,6 @@
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#: ../gui/wxpython/gui_modules/gdialogs.py:739
 #, fuzzy
 msgid "&Load"
 msgstr "Charger"
@@ -5549,6 +5572,40 @@
 msgid "Unknow tag"
 msgstr "Inconnu"
+#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:47
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:97
+#, fuzzy, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr "ERREUR : Jeu de cartes <%s> non trouvé"
+#: ../gui/wxpython/gui_modules/gpyshell.py:104
+msgid "Raster map <%s> added"
+#: ../gui/wxpython/gui_modules/gpyshell.py:106
+msgid "Vector map <%s> added"
+msgstr "La carte vectorielle <%s> est en 3D"
 #: ../gui/wxpython/gui_modules/dbm_dialogs.py:67
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2998
 msgid "Database connection is not defined in DB file."
@@ -5608,7 +5665,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2279
 #: ../gui/wxpython/gui_modules/dbm.py:2387
 #: ../gui/wxpython/gui_modules/dbm.py:2642
-#: ../gui/wxpython/gui_modules/gdialogs.py:1352
+#: ../gui/wxpython/gui_modules/gdialogs.py:1353
 msgid "Layer"
 msgstr "Couche"
@@ -5642,16 +5699,16 @@
 msgstr "Type de carte à géo-rectifier"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:328
-#: ../gui/wxpython/gui_modules/gmodeler.py:3560
+#: ../gui/wxpython/gui_modules/gmodeler.py:3554
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2028
-#: ../gui/wxpython/gui_modules/layertree.py:791
+#: ../gui/wxpython/gui_modules/layertree.py:787
 msgid "raster"
 msgstr "raster"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3561
+#: ../gui/wxpython/gui_modules/gmodeler.py:3555
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2029
-#: ../gui/wxpython/gui_modules/layertree.py:812
+#: ../gui/wxpython/gui_modules/layertree.py:808
 msgid "vector"
 msgstr "vecteur"
@@ -5759,12 +5816,12 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1110
-#: ../gui/wxpython/gui_modules/toolbars.py:416
+#: ../gui/wxpython/gui_modules/toolbars.py:398
 msgid "source"
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1112
 msgid "target"
 msgstr ""
@@ -5968,14 +6025,14 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2371
 #: ../gui/wxpython/gui_modules/profile.py:1033
 #: ../gui/wxpython/gui_modules/profile.py:1388
-#: ../gui/wxpython/gui_modules/preferences.py:961
+#: ../gui/wxpython/gui_modules/preferences.py:966
 msgid "Apply changes for the current session"
 msgstr "Appliquer les changements pour la session courante"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2373
 #: ../gui/wxpython/gui_modules/profile.py:1038
 #: ../gui/wxpython/gui_modules/profile.py:1390
-#: ../gui/wxpython/gui_modules/preferences.py:963
+#: ../gui/wxpython/gui_modules/preferences.py:968
 msgid ""
 "Apply and save changes to user settings file (default for next sessions)"
 msgstr ""
@@ -5984,7 +6041,7 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2375
 #: ../gui/wxpython/gui_modules/ogc_services.py:77
-#: ../gui/wxpython/gui_modules/gdialogs.py:995
+#: ../gui/wxpython/gui_modules/gdialogs.py:996
 msgid "Close dialog"
@@ -6014,12 +6071,14 @@
 msgstr "Paramètres des symbôles"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2438
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1307
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:809
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1522
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:326
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:547
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3098
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3203
-#: ../gui/wxpython/gui_modules/preferences.py:1683
+#: ../gui/wxpython/gui_modules/preferences.py:1705
 msgid "Color:"
 msgstr "Couleur :"
@@ -6099,16 +6158,16 @@
 msgstr "Paramètres de géo-rectification sauvés dans le fichier '%s'."
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:90
-#: ../gui/wxpython/gui_modules/mapdisp.py:771
-#: ../gui/wxpython/gui_modules/mapdisp.py:803
-#: ../gui/wxpython/gui_modules/mapdisp.py:874
-#: ../gui/wxpython/gui_modules/mapdisp.py:1027
+#: ../gui/wxpython/gui_modules/mapdisp.py:779
+#: ../gui/wxpython/gui_modules/mapdisp.py:811
+#: ../gui/wxpython/gui_modules/mapdisp.py:882
+#: ../gui/wxpython/gui_modules/mapdisp.py:1035
 msgid "Projection not defined (check the settings)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:107
-#: ../gui/wxpython/gui_modules/mapdisp.py:918
-#: ../gui/wxpython/gui_modules/mapdisp.py:1044
+#: ../gui/wxpython/gui_modules/mapdisp.py:926
+#: ../gui/wxpython/gui_modules/mapdisp.py:1052
 msgid "Error in projection (check the settings)"
 msgstr ""
@@ -6137,7 +6196,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1718
 #: ../gui/wxpython/gui_modules/gcmd.py:89
-#: ../gui/wxpython/gui_modules/workspace.py:1000
+#: ../gui/wxpython/gui_modules/workspace.py:1007
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:424
 #: ../gui/wxpython/gui_modules/dbm.py:2357
 msgid "Warning"
@@ -6195,7 +6254,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:178
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:184
-#: ../gui/wxpython/gui_modules/preferences.py:1471
+#: ../gui/wxpython/gui_modules/preferences.py:1493
 msgid "Constrain display resolution to computational settings"
 msgstr ""
@@ -6207,8 +6266,8 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp.py:210
-#: ../gui/wxpython/gui_modules/mapdisp.py:1062
-#: ../gui/wxpython/gui_modules/mapdisp.py:1065
+#: ../gui/wxpython/gui_modules/mapdisp.py:1070
+#: ../gui/wxpython/gui_modules/mapdisp.py:1073
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:216
 #, fuzzy
 msgid "Use defined projection"
@@ -6234,8 +6293,8 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:301
 #: ../gui/wxpython/gui_modules/mapdisp.py:312
 #: ../gui/wxpython/gui_modules/mapdisp.py:362
-#: ../gui/wxpython/gui_modules/mapdisp.py:507
-#: ../gui/wxpython/gui_modules/toolbars.py:201
+#: ../gui/wxpython/gui_modules/mapdisp.py:513
+#: ../gui/wxpython/gui_modules/toolbars.py:204
 #: ../gui/wxpython/gui_modules/layertree.py:582
 msgid "2D view"
 msgstr ""
@@ -6265,83 +6324,83 @@
 "\n"
 "Détails : %s"
-#: ../gui/wxpython/gui_modules/mapdisp.py:381
+#: ../gui/wxpython/gui_modules/mapdisp.py:386
 msgid "Starting 3D view mode..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:387
 msgid "Please wait, loading data..."
 msgstr "Un peu de patience, chargement des données"
-#: ../gui/wxpython/gui_modules/mapdisp.py:414
+#: ../gui/wxpython/gui_modules/mapdisp.py:420
 #, fuzzy
 msgid "3D View Toolbar"
 msgstr "Barre d'outils NVIZ"
-#: ../gui/wxpython/gui_modules/mapdisp.py:438
+#: ../gui/wxpython/gui_modules/mapdisp.py:444
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:348
 msgid "Map Toolbar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:455
+#: ../gui/wxpython/gui_modules/mapdisp.py:461
 #, fuzzy
 msgid "Georectification Toolbar"
 msgstr "Barre d'outils pour la géo-rectification"
-#: ../gui/wxpython/gui_modules/mapdisp.py:517
+#: ../gui/wxpython/gui_modules/mapdisp.py:523
 #: ../gui/wxpython/gui_modules/render.py:420
 #, python-format
 msgid "GRASS module '%s' not found. Unable to start map display window."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1127
+#: ../gui/wxpython/gui_modules/mapdisp.py:1135
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:890
 #, fuzzy
 msgid "Nothing to render (empty map). Operation canceled."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1300
+#: ../gui/wxpython/gui_modules/mapdisp.py:1308
 #, fuzzy
 msgid "No raster or vector map layer selected for querying."
 msgstr "Aucune carte vectorielle sélectionnée pour une interrogation"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1301
+#: ../gui/wxpython/gui_modules/mapdisp.py:1309
 msgid "No map layer selected"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1396
+#: ../gui/wxpython/gui_modules/mapdisp.py:1404
 msgid "No vector map selected for querying."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1397
 #: ../gui/wxpython/gui_modules/mapdisp.py:1405
+#: ../gui/wxpython/gui_modules/mapdisp.py:1413
 #, fuzzy
 msgid "Vector querying"
 msgstr "Lignes vectorielles"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1404
+#: ../gui/wxpython/gui_modules/mapdisp.py:1412
 msgid "Only vector map from the current mapset can be modified."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1476
+#: ../gui/wxpython/gui_modules/mapdisp.py:1484
 #, fuzzy
 msgid "Query surface (raster map)"
 msgstr "Interroge une (des) carte(s) 'raster' ou vectorielle(s)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1483
+#: ../gui/wxpython/gui_modules/mapdisp.py:1491
 #, fuzzy
 msgid "Query vector map"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1491
+#: ../gui/wxpython/gui_modules/mapdisp.py:1499
 msgid "Query raster/vector map(s) (display mode)"
 msgstr "Interroger une (des) carte(s) 'raster'/vectorielle(s) (mode écran)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1507
+#: ../gui/wxpython/gui_modules/mapdisp.py:1515
 msgid "Query vector map (edit mode)"
 msgstr "Interroger carte vectorielle (mode édition)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1633
+#: ../gui/wxpython/gui_modules/mapdisp.py:1641
 #, python-format
 msgid ""
 "Click and drag with left mouse button to measure.%sDouble click with left "
@@ -6350,88 +6409,88 @@
 "Clicker et glisser avec le bouton gauche de la souris pour mesurer %s Double "
 "clicker avec le bouton gauche pour annuler"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1639
+#: ../gui/wxpython/gui_modules/mapdisp.py:1647
 msgid "Measuring distance"
 msgstr "Mesurage de la distance"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1642
+#: ../gui/wxpython/gui_modules/mapdisp.py:1650
 msgid "Measuring distance:"
 msgstr "Mesurage de la distance :"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1652
+#: ../gui/wxpython/gui_modules/mapdisp.py:1660
 #, python-format
 msgid ""
 "Geodesic distance is not yet supported by this tool.\n"
 "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1681
-#: ../gui/wxpython/gui_modules/mapdisp.py:1687
+#: ../gui/wxpython/gui_modules/mapdisp.py:1690
+#: ../gui/wxpython/gui_modules/mapdisp.py:1696
 #, fuzzy
 msgid "segment"
 msgstr "Clause SQL"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1682
-#: ../gui/wxpython/gui_modules/mapdisp.py:1688
+#: ../gui/wxpython/gui_modules/mapdisp.py:1691
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
 #, fuzzy
 msgid "total distance"
 msgstr "Mesurer une distance"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1683
+#: ../gui/wxpython/gui_modules/mapdisp.py:1692
 #, fuzzy
 msgid "bearing"
 msgstr "Attention"
 msgid "deg"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1819
+#: ../gui/wxpython/gui_modules/mapdisp.py:1828
 msgid "Scale and North arrow"
 msgstr "Echelle et rose des vents"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1825
+#: ../gui/wxpython/gui_modules/mapdisp.py:1834
 msgid "Show/hide scale and North arrow"
 msgstr "Afficher/cacher l'échelle et la rose des vents"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1826
+#: ../gui/wxpython/gui_modules/mapdisp.py:1835
 msgid "scale object"
 msgstr "Mettre l'objet à l'échelle"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1855
+#: ../gui/wxpython/gui_modules/mapdisp.py:1864
 msgid "Show/hide legend"
 msgstr "Afficher/cacher la légende"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1856
+#: ../gui/wxpython/gui_modules/mapdisp.py:1865
 msgid "legend object"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1965
+#: ../gui/wxpython/gui_modules/mapdisp.py:1974
 #, fuzzy
 msgid "Zoom to computational region"
 msgstr "Zoomer sur la région calculée (définie avec g.region)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1969
+#: ../gui/wxpython/gui_modules/mapdisp.py:1978
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1058
 msgid "Zoom to default region"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1973
+#: ../gui/wxpython/gui_modules/mapdisp.py:1982
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1062
 msgid "Zoom to saved region"
 msgstr "Zoom sur la région sauvegardée"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1977
+#: ../gui/wxpython/gui_modules/mapdisp.py:1986
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1066
 msgid "Set computational region from display"
 msgstr "Définir la région calculée à partir de celle de l'écran"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1981
+#: ../gui/wxpython/gui_modules/mapdisp.py:1990
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1070
 msgid "Save display geometry to named region"
 msgstr "Sauvegarder la géométrie de l'écran dans un nom de région"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2075
+#: ../gui/wxpython/gui_modules/mapdisp.py:2084
 msgid "GRASS GIS Map Display: "
 msgstr ""
@@ -6495,12 +6554,12 @@
 msgid "Unsupported feature type %d. Operation cancelled."
 msgstr "Valeur de coordonnées invalide. Opération annulée."
-#: ../gui/wxpython/gui_modules/wxvdigit.py:455
+#: ../gui/wxpython/gui_modules/wxvdigit.py:456
 msgid "Unknown feature type '%s'"
 msgstr "Type de carte :"
-#: ../gui/wxpython/gui_modules/wxvdigit.py:460
+#: ../gui/wxpython/gui_modules/wxvdigit.py:461
 #, fuzzy
 msgid "Not enough points for line"
 msgstr "Générer des points le long des lignes"
@@ -6558,7 +6617,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ghelp.py:340
-#: ../gui/wxpython/gui_modules/goutput.py:629
+#: ../gui/wxpython/gui_modules/goutput.py:641
 #, python-format
 msgid "%d modules match"
 msgstr ""
@@ -6622,11 +6681,11 @@
 #: ../gui/wxpython/gui_modules/ghelp.py:702
 #: ../gui/wxpython/gui_modules/ghelp.py:761
-#: ../gui/wxpython/gui_modules/gmodeler.py:3548
-#: ../gui/wxpython/gui_modules/gmodeler.py:3588
-#: ../gui/wxpython/gui_modules/gmodeler.py:3856
-#: ../gui/wxpython/gui_modules/gmodeler.py:3964
-#: ../gui/wxpython/gui_modules/gmodeler.py:4282
+#: ../gui/wxpython/gui_modules/gmodeler.py:3542
+#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3958
+#: ../gui/wxpython/gui_modules/gmodeler.py:4276
 msgid "Name"
 msgstr ""
@@ -6665,7 +6724,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ghelp.py:815
-#: ../gui/wxpython/gui_modules/gdialogs.py:959
+#: ../gui/wxpython/gui_modules/gdialogs.py:960
 #, fuzzy
 msgid "Options"
 msgstr "Optionnel"
@@ -6724,8 +6783,8 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1507
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3295
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
-#: ../gui/wxpython/gui_modules/gdialogs.py:1258
-#: ../gui/wxpython/gui_modules/menuform.py:1691
+#: ../gui/wxpython/gui_modules/gdialogs.py:1259
+#: ../gui/wxpython/gui_modules/menuform.py:1684
 msgid "Browse"
 msgstr "Parcourir"
@@ -6803,8 +6862,8 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:874
 #: ../gui/wxpython/gui_modules/location_wizard.py:1037
 #: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/gui_modules/gmodeler.py:3549
-#: ../gui/wxpython/gui_modules/gmodeler.py:3608
+#: ../gui/wxpython/gui_modules/gmodeler.py:3543
+#: ../gui/wxpython/gui_modules/gmodeler.py:3602
 msgid "Description"
 msgstr "Description"
@@ -6910,7 +6969,7 @@
 msgstr "Chemin vers le fichier contenant les codes EPSG : "
 #: ../gui/wxpython/gui_modules/location_wizard.py:1286
-#: ../gui/wxpython/gui_modules/preferences.py:1814
+#: ../gui/wxpython/gui_modules/preferences.py:1836
 msgid "EPSG code:"
 msgstr "Code EPSG : "
@@ -7181,7 +7240,7 @@
 msgstr "Importer des cartes vectorielles"
 #: ../gui/wxpython/gui_modules/vclean.py:168
-#: ../gui/wxpython/gui_modules/menuform.py:832
+#: ../gui/wxpython/gui_modules/menuform.py:833
 #, fuzzy
 msgid "Copy the current command string to the clipboard (Ctrl+C)"
 msgstr "Copier la chaîne de commande dans le presse-papier"
@@ -7269,294 +7328,294 @@
 msgid "Vector cleaning command copied to clipboard"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:70
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:48
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:55
+#: ../gui/wxpython/gui_modules/nviz_tools.py:136
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:52
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:59
 msgid "View"
 msgstr "Vue"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:74
-#: ../gui/wxpython/gui_modules/gmodeler.py:3154
+#: ../gui/wxpython/gui_modules/gmodeler.py:3148
 #, fuzzy
 msgid "Data"
 msgstr "Base de données GRASS :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:78
-#: ../gui/wxpython/gui_modules/preferences.py:1236
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/preferences.py:1240
 msgid "Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:112
+#: ../gui/wxpython/gui_modules/nviz_tools.py:216
 msgid "Control View"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:120
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1146
+#: ../gui/wxpython/gui_modules/nviz_tools.py:226
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1360
 msgid "W"
 msgstr "O"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:122
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1148
+#: ../gui/wxpython/gui_modules/nviz_tools.py:227
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1362
 msgid "N"
 msgstr "N"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:129
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1155
+#: ../gui/wxpython/gui_modules/nviz_tools.py:228
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1369
 msgid "S"
 msgstr "S"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:131
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+#: ../gui/wxpython/gui_modules/nviz_tools.py:229
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
 msgid "E"
 msgstr "E"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:140
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:64
+#: ../gui/wxpython/gui_modules/nviz_tools.py:230
+#, fuzzy
+msgid "NW"
+msgstr "O"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:231
+#, fuzzy
+msgid "NE"
+msgstr "N"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:232
+#, fuzzy
+msgid "SE"
+msgstr "S"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:233
+#, fuzzy
+msgid "SW"
+msgstr "O"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:68
 msgid "Perspective:"
 msgstr "Perspective :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:150
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:143
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
 msgid "Twist:"
 msgstr "Basculer :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:168
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1167
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:124
-#: ../gui/wxpython/gui_modules/gmodeler.py:3128
-#: ../gui/wxpython/gui_modules/gmodeler.py:3247
+#: ../gui/wxpython/gui_modules/nviz_tools.py:290
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1381
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:128
+#: ../gui/wxpython/gui_modules/gmodeler.py:3122
+#: ../gui/wxpython/gui_modules/gmodeler.py:3241
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4038
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4181
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4829
-#: ../gui/wxpython/gui_modules/gdialogs.py:1634
+#: ../gui/wxpython/gui_modules/gdialogs.py:1635
 msgid "Height:"
 msgstr "Hauteur :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:175
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:173
+#: ../gui/wxpython/gui_modules/nviz_tools.py:296
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:177
 msgid "Z-exag:"
 msgstr "Exagération verticale :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
-msgid "Look at:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:309
+#, fuzzy
+msgid "Look:"
 msgstr "Regarder vers :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+#: ../gui/wxpython/gui_modules/nviz_tools.py:312
+msgid "here"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:318
+#, fuzzy
+msgid "center"
+msgstr "Générer (l'affichage)"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:324
 msgid "top"
 msgstr "Sommet"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
-msgid "north"
-msgstr "nord"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
-msgid "south"
-msgstr "sud"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:197
-msgid "east"
-msgstr "est"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:198
-msgid "west"
-msgstr "ouest"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:199
-msgid "north-west"
-msgstr "nord-ouest"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:200
-msgid "north-east"
-msgstr "nord-est"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:201
-msgid "south-east"
-msgstr "sud-est"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:202
-msgid "south-west"
-msgstr "sud-ouest"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:210
-msgid "Reset"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:330
+#, fuzzy
+msgid "reset"
 msgstr "Remise à zéro"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:211
+#: ../gui/wxpython/gui_modules/nviz_tools.py:331
 msgid "Reset to default view"
 msgstr "Revenir à la vue par défaut"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:233
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:205
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:209
 msgid "Image Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:240
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:212
-#: ../gui/wxpython/gui_modules/preferences.py:1452
+#: ../gui/wxpython/gui_modules/nviz_tools.py:357
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:217
+#: ../gui/wxpython/gui_modules/preferences.py:1474
 msgid "Background color:"
 msgstr "Couleur d'arrière-plan :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:272
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:394
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1471
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:353
 msgid "Surface"
 msgstr "Surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:277
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:237
+#: ../gui/wxpython/gui_modules/nviz_tools.py:400
+#: ../gui/wxpython/gui_modules/nviz_tools.py:757
 #, fuzzy
+msgid "Constant surface"
+msgstr "Surface de coût"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:405
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:457
+#, fuzzy
 msgid "Vector"
 msgstr "vecteur"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:282
+#: ../gui/wxpython/gui_modules/nviz_tools.py:411
 #, fuzzy
 msgid "Volume"
 msgstr "champs"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:298
+#: ../gui/wxpython/gui_modules/nviz_tools.py:435
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:243
 msgid "Lighting"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:302
+#: ../gui/wxpython/gui_modules/nviz_tools.py:440
 msgid "Fringe"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:342
-msgid "Surface attributes"
-msgstr "Attibuts pour les surfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:349
-msgid "Topography"
-msgstr "Topographie"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:350
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
-#: ../gui/wxpython/gui_modules/profile.py:1222
-msgid "Color"
-msgstr "Couleur des lignes "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:352
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1028
-msgid "Transparency"
-msgstr "Transparence"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:353
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
-msgid "Shininess"
-msgstr "Luminosité"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:354
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1030
-msgid "Emission"
-msgstr "Emission"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:360
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1038
-msgid "map"
-msgstr "carte"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:363
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1043
-msgid "unset"
-msgstr "non défini"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:368
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1048
-msgid "constant"
-msgstr "constante"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:428
-#: ../gui/wxpython/gui_modules/nviz_tools.py:915
+#: ../gui/wxpython/gui_modules/nviz_tools.py:488
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1126
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:362
 msgid "Draw"
 msgstr "Dessiner"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:435
-#: ../gui/wxpython/gui_modules/nviz_tools.py:922
+#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1133
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:368
 msgid "Mode:"
 msgstr "Mode :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:438
+#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
 msgid "coarse"
 msgstr "grossier"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:439
+#: ../gui/wxpython/gui_modules/nviz_tools.py:499
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:372
 msgid "fine"
 msgstr "fin"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:440
+#: ../gui/wxpython/gui_modules/nviz_tools.py:500
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:373
 msgid "both"
 msgstr "les deux"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:450
-#: ../gui/wxpython/gui_modules/nviz_tools.py:936
+#: ../gui/wxpython/gui_modules/nviz_tools.py:509
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1147
 msgid "Shading:"
 msgstr "Ombrage"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:453
-#: ../gui/wxpython/gui_modules/nviz_tools.py:709
-#: ../gui/wxpython/gui_modules/nviz_tools.py:939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:512
+#: ../gui/wxpython/gui_modules/nviz_tools.py:920
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1150
 msgid "flat"
 msgstr "plat"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:454
-#: ../gui/wxpython/gui_modules/nviz_tools.py:940
+#: ../gui/wxpython/gui_modules/nviz_tools.py:513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1151
 msgid "gouraud"
 msgstr "gouraud"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:462
+#: ../gui/wxpython/gui_modules/nviz_tools.py:521
 #, fuzzy
 msgid "Set to all"
 msgstr "Tout sélectionner"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:463
+#: ../gui/wxpython/gui_modules/nviz_tools.py:522
 #, fuzzy
 msgid "Use draw settings for all loaded surfaces"
 msgstr "Utiliser pour toutes les surfaces chargées"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:470
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:400
 #, fuzzy
-msgid "Coarse:"
+msgid "Coarse mode:"
 msgstr "grossier :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:524
-msgid "res."
-msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:387
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:404
+#, fuzzy
+msgid "resolution:"
+msgstr "Résolution :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:492
-msgid "style"
-msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:545
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:416
+#, fuzzy
+msgid "style:"
+msgstr "Arbre de Steiner"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:548
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
 msgid "wire"
 msgstr "treillis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:549
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:420
 msgid "surface"
 msgstr "Surface "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:505
+#: ../gui/wxpython/gui_modules/nviz_tools.py:561
 #, fuzzy
-msgid "wire color"
+msgid "Change wire color"
 msgstr "Couleur du treillis :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:519
+#: ../gui/wxpython/gui_modules/nviz_tools.py:568
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:383
 #, fuzzy
-msgid "Fine:"
+msgid "Fine mode:"
 msgstr "fin :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
-msgid "Mask zeros:"
-msgstr "Masquer les zéros"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:593
+msgid "Surface attributes"
+msgstr "Attibuts pour les surfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
-msgid "by elevation"
-msgstr "par altitude"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:601
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1222
+msgid "Color"
+msgstr "Couleur des lignes "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:563
-msgid "by color"
-msgstr "par couleur"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:603
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1239
+msgid "Transparency"
+msgstr "Transparence"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:578
+#: ../gui/wxpython/gui_modules/nviz_tools.py:604
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1240
+msgid "Shininess"
+msgstr "Luminosité"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:610
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1249
+msgid "map"
+msgstr "carte"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:613
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1254
+msgid "unset"
+msgstr "non défini"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1259
+msgid "constant"
+msgstr "constante"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:671
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4008
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4577
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4793
@@ -7565,164 +7624,203 @@
 msgid "Position"
 msgstr "Position"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:653
+#: ../gui/wxpython/gui_modules/nviz_tools.py:686
+msgid "Reset"
+msgstr "Remise à zéro"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:687
+#, fuzzy
+msgid "Reset to default position"
+msgstr "Revenir à la vue par défaut"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:785
+#, fuzzy
+msgid "Fine resolution:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:797
+#, fuzzy
+msgid "Value:"
+msgstr "(valeur)"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:863
 msgid "Show vector lines"
 msgstr "Montrer les lignes vectorielles"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:663
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:245
+#: ../gui/wxpython/gui_modules/nviz_tools.py:873
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:465
 msgid "Vector lines"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:669
+#: ../gui/wxpython/gui_modules/nviz_tools.py:880
 #, fuzzy
 msgid "Line:"
 msgstr "Ligne"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:672
-#: ../gui/wxpython/gui_modules/nviz_tools.py:805
-#, fuzzy
-msgid "width"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:883
+msgid "width:"
 msgstr "largeur :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:688
-#: ../gui/wxpython/gui_modules/nviz_tools.py:790
-#, fuzzy
-msgid "color"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:899
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1001
+msgid "color:"
 msgstr "couleur :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:703
+#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+#: ../gui/wxpython/gui_modules/vdigit.py:158
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:919
 #, fuzzy
-msgid "display"
-msgstr "Afficher :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:708
-msgid "on surface"
+msgid "on surface(s):"
 msgstr "sur la surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:718
-#: ../gui/wxpython/gui_modules/nviz_tools.py:836
+#: ../gui/wxpython/gui_modules/nviz_tools.py:929
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1050
 msgid "Height above surface:"
 msgstr "Hauteur au-dessus de la surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:754
+#: ../gui/wxpython/gui_modules/nviz_tools.py:964
 msgid "Show vector points"
 msgstr "Afficher les points vectoriels"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:973
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:487
 msgid "Vector points"
 msgstr "Points vectoriels"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:769
+#: ../gui/wxpython/gui_modules/nviz_tools.py:980
 #, fuzzy
 msgid "Icon:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:772
-msgid "size"
-msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:983
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
+#, fuzzy
+msgid "size:"
+msgstr "Taille:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:823
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1016
 #, fuzzy
-msgid "symbol"
+msgid "width"
+msgstr "largeur :"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1033
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
+msgid "symbol:"
 msgstr "symbôle :"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:892
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1046
 #, fuzzy
+msgid "Display on surface(s):"
+msgstr "iso-surfaces"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
+#, fuzzy
 msgid "3D raster map"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:925
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1136
 msgid "isosurfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1137
 msgid "slides"
 msgstr "vues"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:949
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1160
 msgid "Resolution:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:971
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
 msgid "List of isosurfaces"
 msgstr "Liste des iso-surfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1019
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1230
 msgid "Isosurface attributes"
 msgstr "attributs des iso-surfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1025
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1236
 msgid "Topography level"
 msgstr "Niveau topographique"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1241
+msgid "Emission"
+msgstr "Emission"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1342
 #, fuzzy
 msgid "Show light model"
 msgstr "Afficher les lignes"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1135
-msgid "Follow source viewpoint"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1141
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1355
 #, fuzzy
 msgid "Light source position"
 msgstr "Choisir la localisation initiale : "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1185
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1399
 msgid "Light color and intensity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1199
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1413
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:299
 msgid "Brightness:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1423
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
 msgid "Ambient:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1270
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1485
 msgid "Edges with fringe"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1487
 msgid "N && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1488
 msgid "N && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1489
 msgid "S && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1275
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1490
 msgid "S && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1295
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1510
 msgid "Elevation of fringe from bottom:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2309
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2311
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1563
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1608
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1186
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1204
+#, fuzzy
+msgid "constant#"
+msgstr "constante"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2667
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2669
 msgid "Level"
 msgstr "Niveau"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2632
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3003
 #, fuzzy
 msgid "Vector map is 3D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2635
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3006
 #, fuzzy
 msgid "Vector map is 2D"
 msgstr "La carte vectorielle <%s> est en 2D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2637
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3008
 msgid "%(features)d features (%(points)d points)"
 msgstr "%(primitives)d primitives (%(points)d points)"
@@ -7747,8 +7845,8 @@
 msgstr "Liste des couches %s"
 #: ../gui/wxpython/gui_modules/ogc_services.py:69
-#: ../gui/wxpython/gui_modules/gdialogs.py:1153
-#: ../gui/wxpython/gui_modules/gdialogs.py:1263
+#: ../gui/wxpython/gui_modules/gdialogs.py:1154
+#: ../gui/wxpython/gui_modules/gdialogs.py:1264
 msgid "Add imported layers into layer tree"
 msgstr "Ajouter les couches importées dans l'arborescence"
@@ -7761,14 +7859,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ogc_services.py:85
-#: ../gui/wxpython/gui_modules/gdialogs.py:998
-#: ../gui/wxpython/gui_modules/gdialogs.py:1165
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
+#: ../gui/wxpython/gui_modules/gdialogs.py:1166
 msgid "&Import"
 msgstr "&Importer"
 #: ../gui/wxpython/gui_modules/ogc_services.py:86
-#: ../gui/wxpython/gui_modules/gdialogs.py:999
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/gdialogs.py:1167
 msgid "Import selected layers"
 msgstr "Importer les couches sélectionnées"
@@ -7786,17 +7884,17 @@
 msgid "Layers"
 msgstr "Couche"
-#: ../gui/wxpython/gui_modules/prompt.py:393
+#: ../gui/wxpython/gui_modules/prompt.py:394
 #, python-format
 msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:396
+#: ../gui/wxpython/gui_modules/prompt.py:397
 #, python-format
 msgid "Warning: option <%(param)s> not found in '%(module)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/prompt.py:617
+#: ../gui/wxpython/gui_modules/prompt.py:618
 msgid "Type GRASS command and run by pressing ENTER"
 msgstr "Entrez une commande GRASS et exécuter-la en appuyant sur ENTER"
@@ -7819,7 +7917,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gselect.py:1083
-#: ../gui/wxpython/gui_modules/menuform.py:1690
+#: ../gui/wxpython/gui_modules/menuform.py:1683
 msgid "File"
 msgstr "Fichier"
@@ -7903,7 +8001,7 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1285
-#: ../gui/wxpython/gui_modules/gmodeler.py:3331
+#: ../gui/wxpython/gui_modules/gmodeler.py:3325
 msgid "Name:"
 msgstr ""
@@ -7921,62 +8019,74 @@
 msgid "Unable to save settings."
 msgstr "Impossible d'interpréter la commande %s"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:29
 #, fuzzy
 msgid "3D view settings"
 msgstr "Montrer les réglages"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:67
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:146
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:71
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:180
 msgid "(value)"
 msgstr "(valeur)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:79
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:127
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:158
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:187
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:83
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:131
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:162
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:191
 msgid "(step)"
 msgstr "(pas)"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:94
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:98
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:258
 msgid "Position:"
 msgstr "Position :"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:97
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:101
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:261
 msgid "(x)"
 msgstr "(x) "
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:252
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:249
+#, fuzzy
+msgid "Light"
+msgstr "Hauteur"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:285
+#, fuzzy
+msgid "(z)"
+msgstr "(x) "
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:431
+#, fuzzy
+msgid "wire color:"
+msgstr "Couleur du treillis :"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
 msgid "Show lines"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:274
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:494
 msgid "Show points"
 msgstr "Afficher les points"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:283
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:503
 msgid "Size:"
 msgstr "Taille:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:298
-#: ../gui/wxpython/gui_modules/gmodeler.py:3110
-#: ../gui/wxpython/gui_modules/gmodeler.py:3229
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:518
+#: ../gui/wxpython/gui_modules/gmodeler.py:3104
+#: ../gui/wxpython/gui_modules/gmodeler.py:3223
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4026
-#: ../gui/wxpython/gui_modules/gdialogs.py:1630
+#: ../gui/wxpython/gui_modules/gdialogs.py:1631
 msgid "Width:"
 msgstr "Largeur :"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:533
 msgid "Marker:"
 msgstr "Marque : "
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
-#, python-format
-msgid "Nviz settings saved to file <%s>."
-msgstr "Paramètres NVIZ enregistrés dans <%s>."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:695
 msgid "3D view settings saved to file <%s>."
@@ -7992,8 +8102,8 @@
 #: ../gui/wxpython/gui_modules/gcmd.py:349
 #: ../gui/wxpython/gui_modules/render.py:627
 #: ../gui/wxpython/gui_modules/render.py:630
-#: ../gui/wxpython/gui_modules/menuform.py:2167
-#: ../gui/wxpython/gui_modules/menuform.py:2170
+#: ../gui/wxpython/gui_modules/menuform.py:2160
+#: ../gui/wxpython/gui_modules/menuform.py:2163
 msgid "Details:"
 msgstr ""
@@ -8016,23 +8126,19 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:92
-#: ../gui/wxpython/gui_modules/gmodeler.py:3319
+#: ../gui/wxpython/gui_modules/gmodeler.py:3313
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1703
 #: ../gui/wxpython/gui_modules/profile.py:1040
 #: ../gui/wxpython/gui_modules/profile.py:1393
-#: ../gui/wxpython/gui_modules/preferences.py:966
+#: ../gui/wxpython/gui_modules/preferences.py:971
 msgid "Close dialog and ignore changes"
 msgstr "Femer la boîte de dialogue et ignorer les changements"
 #: ../gui/wxpython/gui_modules/vdigit.py:151
-#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_modules/preferences.py:1109
 msgid "General"
 msgstr "Général"
-#: ../gui/wxpython/gui_modules/vdigit.py:158
-msgid "Display"
-msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:163
 #: ../gui/wxpython/gui_modules/profile.py:1174
 msgid "Line width"
@@ -8143,7 +8249,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:377
-#: ../gui/wxpython/gui_modules/preferences.py:1669
+#: ../gui/wxpython/gui_modules/preferences.py:1691
 msgid "Attributes"
 msgstr ""
@@ -8309,20 +8415,20 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:1060
-#: ../gui/wxpython/gui_modules/gmodeler.py:3785
-#: ../gui/wxpython/gui_modules/gmodeler.py:4142
+#: ../gui/wxpython/gui_modules/gmodeler.py:3779
+#: ../gui/wxpython/gui_modules/gmodeler.py:4136
 msgid "Delete selected"
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:1064
-#: ../gui/wxpython/gui_modules/gmodeler.py:3786
-#: ../gui/wxpython/gui_modules/gmodeler.py:4143
+#: ../gui/wxpython/gui_modules/gmodeler.py:3780
+#: ../gui/wxpython/gui_modules/gmodeler.py:4137
 msgid "Delete all"
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:1066
-#: ../gui/wxpython/gui_modules/gmodeler.py:3792
-#: ../gui/wxpython/gui_modules/gmodeler.py:4150
+#: ../gui/wxpython/gui_modules/gmodeler.py:3786
+#: ../gui/wxpython/gui_modules/gmodeler.py:4144
 #: ../gui/wxpython/gui_modules/dbm.py:1146
 #: ../gui/wxpython/gui_modules/dbm.py:1659
 msgid "Reload"
@@ -8420,6 +8526,11 @@
 msgid "Preview generated"
 msgstr ""
+#: ../gui/wxpython/gui_modules/psmap.py:353
+#, fuzzy
+msgid "Save file as"
+msgstr "Sauver le fichier sous ..."
 #: ../gui/wxpython/gui_modules/psmap.py:392
 msgid "Failed to read file %s."
@@ -8435,24 +8546,24 @@
 msgid "Scalebar is not appropriate for this projection"
 msgstr "Entrez les paramètres pour"
-#: ../gui/wxpython/gui_modules/psmap.py:861
+#: ../gui/wxpython/gui_modules/psmap.py:860
 msgid "wxGUI Hardcopy Map Utility"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/psmap.py:862
 msgid ""
 "(C) 2011 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:864
-#: ../gui/wxpython/gui_modules/gmodeler.py:1236
+#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/gmodeler.py:1230
 msgid ""
 "This program is free software under the GNU General Public License(>=v2). "
 "Read the file COPYING that comes with GRASS for details."
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:1095
+#: ../gui/wxpython/gui_modules/psmap.py:1094
 msgid "Click and drag to resize object"
 msgstr ""
@@ -8578,7 +8689,7 @@
 #: ../gui/wxpython/gui_modules/gmodeler.py:451
-#: ../gui/wxpython/gui_modules/gmodeler.py:574
+#: ../gui/wxpython/gui_modules/gmodeler.py:568
 #, fuzzy
 msgid "Variables"
 msgstr "Lister les tables"
@@ -8588,53 +8699,53 @@
 msgid "GRASS GIS Graphical Modeler"
 msgstr "Gestionnaire des tables d'attributs GRASS"
-#: ../gui/wxpython/gui_modules/gmodeler.py:572
+#: ../gui/wxpython/gui_modules/gmodeler.py:566
 #, fuzzy
 msgid "Model"
 msgstr "Mode :"
-#: ../gui/wxpython/gui_modules/gmodeler.py:573
+#: ../gui/wxpython/gui_modules/gmodeler.py:567
 msgid "Items"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:642
+#: ../gui/wxpython/gui_modules/gmodeler.py:636
 msgid "Redrawing model..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:669
+#: ../gui/wxpython/gui_modules/gmodeler.py:663
 #, fuzzy
 msgid "Do you want to save changes in the model?"
 msgstr "Choisir le fichier où sauver l'environnement courant"
-#: ../gui/wxpython/gui_modules/gmodeler.py:671
+#: ../gui/wxpython/gui_modules/gmodeler.py:665
 #, fuzzy
 msgid "Do you want to store current model settings to model file?"
 msgstr ""
 "L'espace de travail n'est pas vide.  Voulez-vous sauver les paramètres "
 "courants dans un fichier ?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:738
+#: ../gui/wxpython/gui_modules/gmodeler.py:732
 #: ../gui/wxpython/gui_modules/dbm.py:2084
 msgid "Nothing to delete."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:742
+#: ../gui/wxpython/gui_modules/gmodeler.py:736
 msgid "Do you want to permanently delete data?%s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:743
+#: ../gui/wxpython/gui_modules/gmodeler.py:737
 #, fuzzy
 msgid "Delete intermediate data?"
 msgstr "Suppression filtrée"
-#: ../gui/wxpython/gui_modules/gmodeler.py:757
+#: ../gui/wxpython/gui_modules/gmodeler.py:751
 #, python-format
 msgid "%d maps deleted from current mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:772
-#: ../gui/wxpython/gui_modules/gmodeler.py:885
+#: ../gui/wxpython/gui_modules/gmodeler.py:766
+#: ../gui/wxpython/gui_modules/gmodeler.py:879
 #, fuzzy
 msgid ""
 "Current model is not empty. Do you want to store current settings to model "
@@ -8643,53 +8754,53 @@
-#: ../gui/wxpython/gui_modules/gmodeler.py:775
-#: ../gui/wxpython/gui_modules/gmodeler.py:888
+#: ../gui/wxpython/gui_modules/gmodeler.py:769
+#: ../gui/wxpython/gui_modules/gmodeler.py:882
 #, fuzzy
 msgid "Create new model?"
 msgstr "Créer un nouveau jeu de cartes"
-#: ../gui/wxpython/gui_modules/gmodeler.py:800
+#: ../gui/wxpython/gui_modules/gmodeler.py:794
 #, fuzzy
 msgid "Choose model file"
 msgstr "Choisir le fichier DXF :"
-#: ../gui/wxpython/gui_modules/gmodeler.py:818
+#: ../gui/wxpython/gui_modules/gmodeler.py:812
 #, python-format
 msgid "%(items)d items (%(actions)d actions) loaded into model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:825
-#: ../gui/wxpython/gui_modules/gmodeler.py:862
+#: ../gui/wxpython/gui_modules/gmodeler.py:819
+#: ../gui/wxpython/gui_modules/gmodeler.py:856
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
 "Le fichier denvironnement <%s> existe déjà.  Voulez-vous écraser ce fichier ?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:835
-#: ../gui/wxpython/gui_modules/gmodeler.py:875
+#: ../gui/wxpython/gui_modules/gmodeler.py:829
+#: ../gui/wxpython/gui_modules/gmodeler.py:869
 msgid "File <%s> saved"
 msgstr "Fichier POINTS <%s> sauvé"
-#: ../gui/wxpython/gui_modules/gmodeler.py:844
+#: ../gui/wxpython/gui_modules/gmodeler.py:838
 #, fuzzy
 msgid "Choose file to save current model"
-#: ../gui/wxpython/gui_modules/gmodeler.py:864
+#: ../gui/wxpython/gui_modules/gmodeler.py:858
 msgid "File already exists"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:912
+#: ../gui/wxpython/gui_modules/gmodeler.py:906
 msgid "Model is empty. Nothing to run."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:999
+#: ../gui/wxpython/gui_modules/gmodeler.py:993
 msgid "Model is empty. Nothing to validate."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1006
+#: ../gui/wxpython/gui_modules/gmodeler.py:1000
 #, python-format
 msgid ""
 "Model is not valid.\n"
@@ -8697,47 +8808,47 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1009
+#: ../gui/wxpython/gui_modules/gmodeler.py:1003
 msgid "Model is valid."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1070
-#: ../gui/wxpython/gui_modules/gmodeler.py:1113
+#: ../gui/wxpython/gui_modules/gmodeler.py:1064
+#: ../gui/wxpython/gui_modules/gmodeler.py:1107
 #, python-format
 msgid "Model exported to <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1078
+#: ../gui/wxpython/gui_modules/gmodeler.py:1072
 #, fuzzy
 msgid "Choose file to save"
 msgstr "Choisir un fichier GRC à charger"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1080
+#: ../gui/wxpython/gui_modules/gmodeler.py:1074
 msgid "Python script (*.py)|*.py"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1094
+#: ../gui/wxpython/gui_modules/gmodeler.py:1088
 msgid "File <%s> already exists. Do you want to overwrite this file?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1096
+#: ../gui/wxpython/gui_modules/gmodeler.py:1090
 #, fuzzy
 msgid "Save file"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1233
+#: ../gui/wxpython/gui_modules/gmodeler.py:1227
 msgid "wxGUI Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1235
+#: ../gui/wxpython/gui_modules/gmodeler.py:1229
 msgid ""
 "(C) 2010 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1366
+#: ../gui/wxpython/gui_modules/gmodeler.py:1360
 msgid ""
 "Reading model file <%s> failed.\n"
@@ -8746,106 +8857,106 @@
 "Lecture du fichier d'environnement <%s> impossible.  Fichier invalide, "
 "incapable de déchiffrer le document XML"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1372
+#: ../gui/wxpython/gui_modules/gmodeler.py:1366
 #, fuzzy
 msgid "Please wait, loading model..."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1427
+#: ../gui/wxpython/gui_modules/gmodeler.py:1421
 #, fuzzy
 msgid "Writing current settings to model file failed."
 msgstr ""
 "Ecriture des paramètres courant dans le fichier d'environnement (%s) non "
 "réussie."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1728
-#: ../gui/wxpython/gui_modules/gmodeler.py:1785
-#: ../gui/wxpython/gui_modules/gmodeler.py:1912
-#: ../gui/wxpython/gui_modules/menuform.py:384
+#: ../gui/wxpython/gui_modules/gmodeler.py:1722
+#: ../gui/wxpython/gui_modules/gmodeler.py:1779
+#: ../gui/wxpython/gui_modules/gmodeler.py:1906
+#: ../gui/wxpython/gui_modules/menuform.py:385
 msgid "unknown"
 msgstr "Inconnu"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2010
+#: ../gui/wxpython/gui_modules/gmodeler.py:2004
 msgid "<not defined>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2020
+#: ../gui/wxpython/gui_modules/gmodeler.py:2014
 #, fuzzy
 msgid "Data properties"
 msgstr " Propriétés de la couche"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2027
+#: ../gui/wxpython/gui_modules/gmodeler.py:2021
 #, fuzzy
 msgid "Name of raster map:"
 msgstr "Carte 'raster' recodée :"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2029
+#: ../gui/wxpython/gui_modules/gmodeler.py:2023
 #, fuzzy
 msgid "Name of vector map:"
 msgstr "Nom pour la nouvelle carte vectorielle :"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2031
+#: ../gui/wxpython/gui_modules/gmodeler.py:2025
 msgid "Name of element:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2224
+#: ../gui/wxpython/gui_modules/gmodeler.py:2218
 #: ../gui/wxpython/gui_modules/layertree.py:272
 msgid "Remove"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2228
+#: ../gui/wxpython/gui_modules/gmodeler.py:2222
 #, fuzzy
 msgid "Disable"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+#: ../gui/wxpython/gui_modules/gmodeler.py:2225
 #, fuzzy
 msgid "Enable"
 msgstr "Table"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2236
+#: ../gui/wxpython/gui_modules/gmodeler.py:2230
 #, fuzzy
 msgid "Add control point"
 msgstr "Point de contrôle au sol"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2238
+#: ../gui/wxpython/gui_modules/gmodeler.py:2232
 #, fuzzy
 msgid "Remove control point"
 msgstr "Définir les points de contrôle au sol (PCS)"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2245
+#: ../gui/wxpython/gui_modules/gmodeler.py:2239
 msgid "Intermediate"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2256
+#: ../gui/wxpython/gui_modules/gmodeler.py:2250
 #: ../gui/wxpython/gui_modules/layertree.py:286
 msgid "Properties"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2260
+#: ../gui/wxpython/gui_modules/gmodeler.py:2254
 #, fuzzy
 msgid "Change ID"
 msgstr "Changer les valeurs"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2316
+#: ../gui/wxpython/gui_modules/gmodeler.py:2310
 msgid "Add new GRASS module to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2334
-#: ../gui/wxpython/gui_modules/gmodeler.py:3857
-#: ../gui/wxpython/gui_modules/gmodeler.py:4283
-#: ../gui/wxpython/gui_modules/preferences.py:1518
+#: ../gui/wxpython/gui_modules/gmodeler.py:2328
+#: ../gui/wxpython/gui_modules/gmodeler.py:3851
+#: ../gui/wxpython/gui_modules/gmodeler.py:4277
+#: ../gui/wxpython/gui_modules/preferences.py:1540
 msgid "Command"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2402
+#: ../gui/wxpython/gui_modules/gmodeler.py:2396
 msgid ""
 "Command not defined.\n"
 "\n"
 "Unable to add new action to the model."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2408
+#: ../gui/wxpython/gui_modules/gmodeler.py:2402
 #, python-format
 msgid ""
 "'%s' is not a GRASS module.\n"
@@ -8853,190 +8964,190 @@
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3018
+#: ../gui/wxpython/gui_modules/gmodeler.py:3012
 msgid "Action"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3023
+#: ../gui/wxpython/gui_modules/gmodeler.py:3017
 msgid "Validity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3031
+#: ../gui/wxpython/gui_modules/gmodeler.py:3025
 #, fuzzy
 msgid "Valid:"
 msgstr "Plage de validité"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3048
+#: ../gui/wxpython/gui_modules/gmodeler.py:3042
 #, fuzzy
 msgid "Invalid:"
 msgstr "Valeur invalide : %s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3065
+#: ../gui/wxpython/gui_modules/gmodeler.py:3059
 msgid "Running:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3082
+#: ../gui/wxpython/gui_modules/gmodeler.py:3076
 #, fuzzy
 msgid "Disabled:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3102
-#: ../gui/wxpython/gui_modules/gmodeler.py:3221
+#: ../gui/wxpython/gui_modules/gmodeler.py:3096
+#: ../gui/wxpython/gui_modules/gmodeler.py:3215
 #, fuzzy
 msgid "Shape size"
 msgstr "Indice de forme"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3159
+#: ../gui/wxpython/gui_modules/gmodeler.py:3153
 #: ../gui/wxpython/gui_modules/profile.py:1252
 msgid "Type"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3167
+#: ../gui/wxpython/gui_modules/gmodeler.py:3161
 #, fuzzy
 msgid "Raster:"
 msgstr "raster"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3184
+#: ../gui/wxpython/gui_modules/gmodeler.py:3178
 #, fuzzy
 msgid "3D raster:"
 msgstr "Ajouter une carte 3D (raster)"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3201
+#: ../gui/wxpython/gui_modules/gmodeler.py:3195
 #, fuzzy
 msgid "Vector:"
 msgstr "vecteur"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3295
+#: ../gui/wxpython/gui_modules/gmodeler.py:3289
 #: ../gui/wxpython/gui_modules/layertree.py:374
 #: ../gui/wxpython/gui_modules/layertree.py:407
 msgid "Metadata"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3297
+#: ../gui/wxpython/gui_modules/gmodeler.py:3291
 #, fuzzy
 msgid "Commands"
 msgstr "Messages de la commande"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3317
+#: ../gui/wxpython/gui_modules/gmodeler.py:3311
 #, fuzzy
 msgid "Apply properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3340
+#: ../gui/wxpython/gui_modules/gmodeler.py:3334
 #, fuzzy
 msgid "Description:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3349
+#: ../gui/wxpython/gui_modules/gmodeler.py:3343
 msgid "Author(s):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3398
+#: ../gui/wxpython/gui_modules/gmodeler.py:3392
 #, fuzzy
 msgid "Model parameters"
 msgstr "Paramètres de terrain"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3545
+#: ../gui/wxpython/gui_modules/gmodeler.py:3539
 msgid "List of variables - right-click to delete"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3595
+#: ../gui/wxpython/gui_modules/gmodeler.py:3589
 #: ../gui/wxpython/gui_modules/dbm.py:885
 #: ../gui/wxpython/gui_modules/dbm.py:2226
 msgid "Data type"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3601
+#: ../gui/wxpython/gui_modules/gmodeler.py:3595
 #, fuzzy
 msgid "Default value"
 msgstr "Défaut"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3553
+#: ../gui/wxpython/gui_modules/gmodeler.py:3547
 #, fuzzy
 msgid "Add new variable"
 msgstr "Ajouter un nouveau vertex"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3557
+#: ../gui/wxpython/gui_modules/gmodeler.py:3551
 #, fuzzy
 msgid "integer"
 msgstr "Pointer"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3558
+#: ../gui/wxpython/gui_modules/gmodeler.py:3552
 msgid "float"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3559
+#: ../gui/wxpython/gui_modules/gmodeler.py:3553
 msgid "string"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3567
+#: ../gui/wxpython/gui_modules/gmodeler.py:3561
 msgid "Add new variable to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3715
+#: ../gui/wxpython/gui_modules/gmodeler.py:3709
 #, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3744
+#: ../gui/wxpython/gui_modules/gmodeler.py:3738
 #, fuzzy
 msgid "Do you want to delete all variables from the model?"
 msgstr "Voulez-vous enlever la couche sélectionnée de l'arborescence"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3746
+#: ../gui/wxpython/gui_modules/gmodeler.py:3740
 #, fuzzy
 msgid "Delete variables"
 msgstr "Effacer un (des) objet(s)"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3826
+#: ../gui/wxpython/gui_modules/gmodeler.py:3820
 #, fuzzy
 msgid "Condition: "
 msgstr "Optionnel"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3828
+#: ../gui/wxpython/gui_modules/gmodeler.py:3822
 msgid "Condition: not defined"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3844
 #, fuzzy
 msgid "Condition"
 msgstr "Optionnel"
 msgid "ID"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+#: ../gui/wxpython/gui_modules/gmodeler.py:3892
 msgid "loop"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3906
+#: ../gui/wxpython/gui_modules/gmodeler.py:3900
 #, fuzzy
 msgid "Loop properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3912
+#: ../gui/wxpython/gui_modules/gmodeler.py:3906
 msgid "List of items in loop"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3961
+#: ../gui/wxpython/gui_modules/gmodeler.py:3955
 msgid "List of items - right-click to delete"
 msgstr ""
 msgid "In block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3965
+#: ../gui/wxpython/gui_modules/gmodeler.py:3959
 #, fuzzy
 msgid "Command / Condition"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4092
+#: ../gui/wxpython/gui_modules/gmodeler.py:4086
 #: ../gui/wxpython/gui_modules/dbm.py:1178
 #, python-format
 msgid ""
@@ -9044,39 +9155,39 @@
 "to delete them?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4095
+#: ../gui/wxpython/gui_modules/gmodeler.py:4089
 #: ../gui/wxpython/gui_modules/dbm.py:1181
 #: ../gui/wxpython/gui_modules/dbm.py:1227
 msgid "Delete records"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4149
+#: ../gui/wxpython/gui_modules/gmodeler.py:4143
 msgid "Normalize"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4247
+#: ../gui/wxpython/gui_modules/gmodeler.py:4241
 msgid "if-else"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4268
+#: ../gui/wxpython/gui_modules/gmodeler.py:4262
 #, fuzzy
 msgid "If-else properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4274
+#: ../gui/wxpython/gui_modules/gmodeler.py:4268
 msgid "List of items in 'if' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4279
+#: ../gui/wxpython/gui_modules/gmodeler.py:4273
 msgid "List of items in 'else' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:983
+#: ../gui/wxpython/gui_modules/workspace.py:990
 #, python-format
 msgid "Unable to open file <%s> for reading."
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:996
+#: ../gui/wxpython/gui_modules/workspace.py:1003
 #, python-format
 msgid ""
 "Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -9085,7 +9196,7 @@
 "Number of skipped lines: %(line)d"
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:1214
+#: ../gui/wxpython/gui_modules/workspace.py:1221
 #, python-format
 msgid " row %d:"
 msgstr ""
@@ -9185,7 +9296,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1640
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4906
-#: ../gui/wxpython/gui_modules/preferences.py:2163
+#: ../gui/wxpython/gui_modules/preferences.py:2185
 msgid "Font size:"
 msgstr "Taille du texte :"
@@ -9524,10 +9635,6 @@
 msgid "Size and style"
 msgstr "Pente et exposition"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
-msgid "symbol:"
-msgstr "symbôle :"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3291
 #, fuzzy
 msgid "eps file:"
@@ -9551,11 +9658,6 @@
 msgid "Size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
-#, fuzzy
-msgid "size:"
-msgstr "Taille:"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3322
 msgid "size from map table column:"
 msgstr ""
@@ -9760,9 +9862,9 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4596
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5081
 #: ../gui/wxpython/gui_modules/profile.py:967
-#: ../gui/wxpython/gui_modules/preferences.py:1240
-#: ../gui/wxpython/gui_modules/preferences.py:1372
-#: ../gui/wxpython/gui_modules/preferences.py:2114
+#: ../gui/wxpython/gui_modules/preferences.py:1244
+#: ../gui/wxpython/gui_modules/preferences.py:1394
+#: ../gui/wxpython/gui_modules/preferences.py:2136
 msgid "Font settings"
 msgstr ""
@@ -10070,154 +10172,154 @@
 "layer instead."
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:606
+#: ../gui/wxpython/gui_modules/goutput.py:605
 msgid "Save file as..."
-#: ../gui/wxpython/gui_modules/goutput.py:721
+#: ../gui/wxpython/gui_modules/goutput.py:733
 msgid ""
 "Please note that the data are left in inconsistent state and may be corrupted"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:724
+#: ../gui/wxpython/gui_modules/goutput.py:736
 msgid "Command aborted"
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:732
+#: ../gui/wxpython/gui_modules/goutput.py:744
 msgid "Command finished"
 msgstr ""
-#: ../gui/wxpython/gui_modules/wxnviz.py:302
+#: ../gui/wxpython/gui_modules/wxnviz.py:327
 #, fuzzy, python-format
 msgid "Vector map <%s> not found"
 msgstr "La carte vectorielle <%s> est en 3D"
-#: ../gui/wxpython/gui_modules/wxnviz.py:354
-#: ../gui/wxpython/gui_modules/wxnviz.py:366
+#: ../gui/wxpython/gui_modules/wxnviz.py:392
+#: ../gui/wxpython/gui_modules/wxnviz.py:404
 msgid "3d raster map <%s> not found"
 msgstr "ERREUR : Jeu de cartes <%s> non trouvé"
-#: ../gui/wxpython/gui_modules/toolbars.py:211
+#: ../gui/wxpython/gui_modules/toolbars.py:217
 msgid "3D view mode not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:212
-#: ../gui/wxpython/gui_modules/toolbars.py:229
+#: ../gui/wxpython/gui_modules/toolbars.py:218
+#: ../gui/wxpython/gui_modules/toolbars.py:235
 #, python-format
 msgid "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:213
+#: ../gui/wxpython/gui_modules/toolbars.py:219
 msgid ""
 "Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
 "(hopefully this will be fixed soon). Please keep an eye out for updated "
 "versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:221
-#: ../gui/wxpython/gui_modules/toolbars.py:1162
+#: ../gui/wxpython/gui_modules/toolbars.py:227
+#: ../gui/wxpython/gui_modules/toolbars.py:1108
 msgid "Digitize"
 msgstr "Numériser"
-#: ../gui/wxpython/gui_modules/toolbars.py:228
+#: ../gui/wxpython/gui_modules/toolbars.py:234
 #, fuzzy
 msgid "Vector digitizer not available"
 msgstr "Barre d'outils pour le digitaliseur vectoriel"
-#: ../gui/wxpython/gui_modules/toolbars.py:230
+#: ../gui/wxpython/gui_modules/toolbars.py:236
 msgid ""
 "Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
 "will be fixed soon). Please keep an eye out for updated versions of GRASS. "
 "In the meantime you can use \"v.digit\" from the Develop Vector menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:421
+#: ../gui/wxpython/gui_modules/toolbars.py:403
 msgid "Set map canvas for "
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:423
+#: ../gui/wxpython/gui_modules/toolbars.py:405
 #, fuzzy
 msgid " / Zoom to map"
 msgstr "Zomme sur la carte"
-#: ../gui/wxpython/gui_modules/toolbars.py:790
+#: ../gui/wxpython/gui_modules/toolbars.py:737
 msgid "Duplicate attributes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:867
+#: ../gui/wxpython/gui_modules/toolbars.py:814
 msgid "Copy features from (background) vector map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:875
+#: ../gui/wxpython/gui_modules/toolbars.py:822
 msgid "Flip selected lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:883
+#: ../gui/wxpython/gui_modules/toolbars.py:830
 msgid "Merge selected lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:891
+#: ../gui/wxpython/gui_modules/toolbars.py:838
 msgid "Break selected lines/boundaries at intersection"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:899
+#: ../gui/wxpython/gui_modules/toolbars.py:846
 msgid "Snap selected lines/boundaries (only to nodes)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:907
+#: ../gui/wxpython/gui_modules/toolbars.py:854
 msgid "Connect selected lines/boundaries"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:915
+#: ../gui/wxpython/gui_modules/toolbars.py:862
 msgid "Query features"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:923
+#: ../gui/wxpython/gui_modules/toolbars.py:870
 msgid "Z bulk-labeling of 3D lines"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:931
+#: ../gui/wxpython/gui_modules/toolbars.py:878
 msgid "Feature type conversion"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1042
+#: ../gui/wxpython/gui_modules/toolbars.py:989
 #, fuzzy
 msgid "Vector map is not 3D. Operation canceled."
 msgstr "Aucune couche sélectionnée.  Opération annulée."
-#: ../gui/wxpython/gui_modules/toolbars.py:1107
-#: ../gui/wxpython/gui_modules/toolbars.py:1189
-#: ../gui/wxpython/gui_modules/toolbars.py:1268
+#: ../gui/wxpython/gui_modules/toolbars.py:1053
+#: ../gui/wxpython/gui_modules/toolbars.py:1135
+#: ../gui/wxpython/gui_modules/toolbars.py:1214
 msgid "Select vector map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1145
+#: ../gui/wxpython/gui_modules/toolbars.py:1091
 #, python-format
 msgid "Please wait, opening vector map <%s> for editing..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1197
+#: ../gui/wxpython/gui_modules/toolbars.py:1143
 #, python-format
 msgid "Do you want to save changes in vector map <%s>?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1199
+#: ../gui/wxpython/gui_modules/toolbars.py:1145
 msgid "Save changes?"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1206
+#: ../gui/wxpython/gui_modules/toolbars.py:1152
 #, python-format
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:1217
+#: ../gui/wxpython/gui_modules/toolbars.py:1163
 msgid "Editing of vector map <%s> successfully finished"
 msgstr "Fermer la boîte de dialogue après exécution"
-#: ../gui/wxpython/gui_modules/toolbars.py:1274
-#: ../gui/wxpython/gui_modules/toolbars.py:1279
+#: ../gui/wxpython/gui_modules/toolbars.py:1220
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
 msgid "New vector map"
 msgstr ""
@@ -10480,7 +10582,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/dbm.py:1117
-#: ../gui/wxpython/gui_modules/preferences.py:626
+#: ../gui/wxpython/gui_modules/preferences.py:642
 msgid "Edit selected record"
 msgstr ""
@@ -10498,14 +10600,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/dbm.py:1129
-#: ../gui/wxpython/gui_modules/gdialogs.py:861
-#: ../gui/wxpython/gui_modules/gdialogs.py:1389
+#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:1390
 msgid "Select all"
 #: ../gui/wxpython/gui_modules/dbm.py:1130
-#: ../gui/wxpython/gui_modules/gdialogs.py:863
-#: ../gui/wxpython/gui_modules/gdialogs.py:1390
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
+#: ../gui/wxpython/gui_modules/gdialogs.py:1391
 msgid "Deselect all"
 msgstr "Tout désélectionner"
@@ -10781,7 +10883,7 @@
 msgstr "Créer la table d'attributs"
 #: ../gui/wxpython/gui_modules/gdialogs.py:204
-#: ../gui/wxpython/gui_modules/preferences.py:1553
+#: ../gui/wxpython/gui_modules/preferences.py:1575
 msgid "Add created map into layer tree"
 msgstr "Ajouter la carte créée dans l'arborescence des couches"
@@ -10844,8 +10946,8 @@
 msgstr "Rotation :"
 #: ../gui/wxpython/gui_modules/gdialogs.py:631
-#: ../gui/wxpython/gui_modules/preferences.py:1259
-#: ../gui/wxpython/gui_modules/preferences.py:1388
+#: ../gui/wxpython/gui_modules/preferences.py:1263
+#: ../gui/wxpython/gui_modules/preferences.py:1410
 msgid "Set font"
 msgstr "Définir la police"
@@ -10857,101 +10959,110 @@
 "Glisser le texte avec la souris en mode pointeur.\n"
 "Double click pour modifier les options."
-#: ../gui/wxpython/gui_modules/gdialogs.py:768
+#: ../gui/wxpython/gui_modules/gdialogs.py:739
+msgid "&Add"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:741
+#, fuzzy
+msgid "Add selected map layers to current display"
+msgstr "Ajouter une couche 'raster'"
+#: ../gui/wxpython/gui_modules/gdialogs.py:769
 msgid "Map layer type:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:780
+#: ../gui/wxpython/gui_modules/gdialogs.py:781
 #, fuzzy
 msgid "Select toggle"
 msgstr "Choisir une couleur"
-#: ../gui/wxpython/gui_modules/gdialogs.py:787
+#: ../gui/wxpython/gui_modules/gdialogs.py:788
 msgid "Mapset:"
 msgstr "Jeu de cartes :"
-#: ../gui/wxpython/gui_modules/gdialogs.py:797
+#: ../gui/wxpython/gui_modules/gdialogs.py:798
 msgid "Filter:"
 msgstr "Filtre :"
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
 msgid "List of maps:"
 msgstr "Liste des cartes :"
-#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:863
 msgid "Invert selection"
 msgstr "Inverser la sélection"
-#: ../gui/wxpython/gui_modules/gdialogs.py:936
+#: ../gui/wxpython/gui_modules/gdialogs.py:937
 msgid "Multiple import"
 msgstr "Importation multiple"
-#: ../gui/wxpython/gui_modules/gdialogs.py:950
+#: ../gui/wxpython/gui_modules/gdialogs.py:951
 #, python-format
 msgid " List of %s layers "
-#: ../gui/wxpython/gui_modules/gdialogs.py:1151
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
 #, fuzzy
 msgid "Add linked layers into layer tree"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1158
+#: ../gui/wxpython/gui_modules/gdialogs.py:1159
 msgid "&Link"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1159
+#: ../gui/wxpython/gui_modules/gdialogs.py:1160
 msgid "Link selected layers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1253
+#: ../gui/wxpython/gui_modules/gdialogs.py:1254
 msgid "Import DXF layers"
 msgstr "Importer des couches DXF"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1257
+#: ../gui/wxpython/gui_modules/gdialogs.py:1258
 msgid "Choose DXF file to import"
 msgstr "Choisir le fichier DXF à importer"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1353
+#: ../gui/wxpython/gui_modules/gdialogs.py:1354
 msgid "Layer name"
 msgstr "Nom de la couche"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1354
+#: ../gui/wxpython/gui_modules/gdialogs.py:1355
 #, fuzzy
 msgid "Name for GRASS map"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1436
+#: ../gui/wxpython/gui_modules/gdialogs.py:1437
 msgid "Set Map Layer Opacity"
 msgstr "Ajuster l'opacité de la carte"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1460
+#: ../gui/wxpython/gui_modules/gdialogs.py:1461
 msgid "transparent"
 msgstr "transparent"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1463
+#: ../gui/wxpython/gui_modules/gdialogs.py:1464
 msgid "opaque"
 msgstr "opaque"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1582
+#: ../gui/wxpython/gui_modules/gdialogs.py:1583
 msgid "Set image size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1591
+#: ../gui/wxpython/gui_modules/gdialogs.py:1592
 #, fuzzy
 msgid "Image size"
 msgstr "Taille de l'icône"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1638
+#: ../gui/wxpython/gui_modules/gdialogs.py:1639
 msgid "Template:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1676
+#: ../gui/wxpython/gui_modules/gdialogs.py:1677
 #, fuzzy
 msgid "GRASS GIS SQL Query Utility"
 msgstr "SIG GRASS - Moniteur d'affichage des cartes"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1687
+#: ../gui/wxpython/gui_modules/gdialogs.py:1688
 #, fuzzy
 msgid " SQL statement "
 msgstr "Clause SQL"
@@ -11240,55 +11351,55 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/layertree.py:743
-#: ../gui/wxpython/gui_modules/layertree.py:1310
+#: ../gui/wxpython/gui_modules/layertree.py:1309
 msgid "Click to edit layer settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:788
+#: ../gui/wxpython/gui_modules/layertree.py:784
 msgid "(double click to set properties)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:794
+#: ../gui/wxpython/gui_modules/layertree.py:790
 msgid "3d raster"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:797
+#: ../gui/wxpython/gui_modules/layertree.py:793
 msgid "RGB"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:800
+#: ../gui/wxpython/gui_modules/layertree.py:796
 msgid "HIS"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:806
+#: ../gui/wxpython/gui_modules/layertree.py:802
 msgid "raster cell numbers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:809
+#: ../gui/wxpython/gui_modules/layertree.py:805
 msgid "raster flow arrows"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:815
+#: ../gui/wxpython/gui_modules/layertree.py:811
 msgid "thematic area (choropleth) map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:818
+#: ../gui/wxpython/gui_modules/layertree.py:814
 msgid "thematic charts"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:821
+#: ../gui/wxpython/gui_modules/layertree.py:817
 msgid "grid"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:824
+#: ../gui/wxpython/gui_modules/layertree.py:820
 msgid "geodesic line"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:827
+#: ../gui/wxpython/gui_modules/layertree.py:823
 msgid "rhumbline"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:830
+#: ../gui/wxpython/gui_modules/layertree.py:826
 msgid "vector labels"
 msgstr ""
@@ -11296,158 +11407,158 @@
 msgid "Please wait, updating data..."
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:1389
+#: ../gui/wxpython/gui_modules/layertree.py:1388
 msgid "opacity:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:1406
+#: ../gui/wxpython/gui_modules/layertree.py:1405
 #, python-format
 msgid "Map <%s> not found."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:147
-#: ../gui/wxpython/gui_modules/menuform.py:1654
+#: ../gui/wxpython/gui_modules/menuform.py:148
+#: ../gui/wxpython/gui_modules/menuform.py:1647
 msgid "Select Color"
 msgstr "Choisir la couleur"
-#: ../gui/wxpython/gui_modules/menuform.py:451
+#: ../gui/wxpython/gui_modules/menuform.py:452
 #, python-format
 msgid "Parameter element '%(element)s' not found: '%(value)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:472
+#: ../gui/wxpython/gui_modules/menuform.py:473
 #, python-format
 msgid "Flag not found: %s"
 msgstr "FLag non trouvé : %s"
-#: ../gui/wxpython/gui_modules/menuform.py:501
+#: ../gui/wxpython/gui_modules/menuform.py:502
 #, python-format
 msgid "Parameter '%(name)s' (%(desc)s) is missing."
 msgstr "Le paramètre '%(name)s' (%(desc)s) est manquant."
-#: ../gui/wxpython/gui_modules/menuform.py:530
+#: ../gui/wxpython/gui_modules/menuform.py:531
 msgid "<required>"
 msgstr "<obligatoire>"
-#: ../gui/wxpython/gui_modules/menuform.py:797
+#: ../gui/wxpython/gui_modules/menuform.py:798
 msgid "Enter parameters for '"
 msgstr "Entrer les paramètres pour '"
-#: ../gui/wxpython/gui_modules/menuform.py:808
+#: ../gui/wxpython/gui_modules/menuform.py:809
 msgid "Close this window without executing the command (Ctrl+Q)"
 msgstr "Fermer la fenêtre sans exécuter la commande (Ctrl+Q)"
-#: ../gui/wxpython/gui_modules/menuform.py:828
+#: ../gui/wxpython/gui_modules/menuform.py:829
 msgid "Run the command (Ctrl+R)"
 msgstr "Exécuter la commande (Ctrl+R)"
-#: ../gui/wxpython/gui_modules/menuform.py:831
+#: ../gui/wxpython/gui_modules/menuform.py:832
 msgid "C&opy"
 msgstr "&Copier"
-#: ../gui/wxpython/gui_modules/menuform.py:846
+#: ../gui/wxpython/gui_modules/menuform.py:847
 msgid "Show manual page of the command (Ctrl+H)"
 msgstr "Afficher la page de manuel pour la commande (Ctrl+H)"
-#: ../gui/wxpython/gui_modules/menuform.py:867
+#: ../gui/wxpython/gui_modules/menuform.py:868
 #, fuzzy
 msgid "Add created map(s) into layer tree"
-#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:883
 msgid "Close dialog on finish"
-#: ../gui/wxpython/gui_modules/menuform.py:884
+#: ../gui/wxpython/gui_modules/menuform.py:885
 msgid ""
 "Close dialog when command is successfully finished. Change this settings in "
 "Preferences dialog ('Command' tab)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1059
+#: ../gui/wxpython/gui_modules/menuform.py:1060
 #, python-format
 msgid "'%s' copied to clipboard"
 msgstr "'%s' copié dans le presse-papier"
-#: ../gui/wxpython/gui_modules/menuform.py:1121
-#: ../gui/wxpython/gui_modules/menuform.py:1134
+#: ../gui/wxpython/gui_modules/menuform.py:1122
+#: ../gui/wxpython/gui_modules/menuform.py:1135
 #, fuzzy
 msgid "Required"
 msgstr "Requis"
-#: ../gui/wxpython/gui_modules/menuform.py:1124
+#: ../gui/wxpython/gui_modules/menuform.py:1125
 msgid "Optional"
 msgstr "Optionnel"
-#: ../gui/wxpython/gui_modules/menuform.py:1174
+#: ../gui/wxpython/gui_modules/menuform.py:1168
 msgid "Manual"
 msgstr "Manuel"
-#: ../gui/wxpython/gui_modules/menuform.py:1215
-#: ../gui/wxpython/gui_modules/menuform.py:1726
+#: ../gui/wxpython/gui_modules/menuform.py:1208
+#: ../gui/wxpython/gui_modules/menuform.py:1719
 msgid "Parameterized in model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1290
+#: ../gui/wxpython/gui_modules/menuform.py:1283
 msgid "[multiple]"
 msgstr "[multiple]"
-#: ../gui/wxpython/gui_modules/menuform.py:1337
+#: ../gui/wxpython/gui_modules/menuform.py:1330
 #, fuzzy
 msgid "valid range"
-#: ../gui/wxpython/gui_modules/menuform.py:1499
+#: ../gui/wxpython/gui_modules/menuform.py:1492
 msgid "Format"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1501
+#: ../gui/wxpython/gui_modules/menuform.py:1494
 msgid "Native / Linked OGR"
 msgstr ""
 msgid "Direct OGR"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1673
+#: ../gui/wxpython/gui_modules/menuform.py:1666
 msgid "Transparent"
 msgstr "Transparent"
-#: ../gui/wxpython/gui_modules/menuform.py:1689
+#: ../gui/wxpython/gui_modules/menuform.py:1682
 #, python-format
 msgid "Choose %s"
 msgstr "Choisir %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1717
+#: ../gui/wxpython/gui_modules/menuform.py:1710
 #, fuzzy
 msgid "or enter values interactively"
 msgstr "Re-codage interactif"
-#: ../gui/wxpython/gui_modules/menuform.py:2133
+#: ../gui/wxpython/gui_modules/menuform.py:2126
 #, python-format
 msgid "Error in %s"
 msgstr "Erreur dans %s"
-#: ../gui/wxpython/gui_modules/menuform.py:2166
-#: ../gui/wxpython/gui_modules/menuform.py:2169
+#: ../gui/wxpython/gui_modules/menuform.py:2159
+#: ../gui/wxpython/gui_modules/menuform.py:2162
 msgid "Unable to fetch interface description for command '%s'."
 msgstr ""
 "Impossible de trouver la description de l'interface pour la commande '%s'. "
 "Détails : %s"
-#: ../gui/wxpython/gui_modules/menuform.py:2280
+#: ../gui/wxpython/gui_modules/menuform.py:2276
 msgid "Unable to parse command '%s'"
 msgstr "Impossible d'interpréter la commande '%s'"
-#: ../gui/wxpython/gui_modules/menuform.py:2284
+#: ../gui/wxpython/gui_modules/menuform.py:2280
 #, python-format
 msgid "%(cmd)s: parameter '%(key)s' not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2409
+#: ../gui/wxpython/gui_modules/menuform.py:2441
 #, python-format
 msgid "usage: %s <grass command>"
 msgstr "Utilisation : %s <grass command>"
@@ -11457,116 +11568,116 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/globalvar.py:119
-#: ../gui/wxpython/gui_modules/preferences.py:1798
+#: ../gui/wxpython/gui_modules/preferences.py:1820
 msgid "Projection"
 msgstr "Projection"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:269
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
 #, fuzzy
 msgid "Easting"
 msgstr "Est"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:270
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:290
 #, fuzzy
 msgid "Northing"
 msgstr "Nord"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:271
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:291
 msgid "Elevation"
 msgstr "Altitude"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:272
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:292
 msgid "Surface map elevation"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:273
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:293
 #, fuzzy
 msgid "Surface map color"
 msgstr "&Gérer les couleurs d'image"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:282
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:302
 msgid "XY distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:283
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:303
 msgid "XYZ distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:284
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:304
 msgid "Distance along surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:309
 msgid "Distance along exag. surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:296
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:316
 msgid "No point on surface"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:301
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:321
 msgid "Function not implemented yet"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:602
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:639
 msgid "Loading raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:606
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:643
 msgid "Loading 3d raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:612
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:649
 msgid "failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:614
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:651
 #, python-format
 msgid "Unsupported layer type '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:668
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:729
 msgid "Unable to unload raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:673
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:734
 msgid "Unable to unload 3d raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:674
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:735
 msgid "3d raster map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:681
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:742
 msgid "unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:725
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:786
 #, python-format
 msgid "Loading vector map <%(name)s> (%(type)s) failed"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:781
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:842
 #, python-format
 msgid "Unable to unload vector map <%(name)s> (%(type)s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:784
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:845
 #, python-format
 msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1071
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1148
 #, python-format
 msgid "Vector point layer not found (id = %d)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1073
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1150
 #, python-format
 msgid "Unable to set data layer properties (id = %d)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1076
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1153
 #, python-format
 msgid ""
 "Setting data layer properties failed.\n"
@@ -11574,99 +11685,104 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:416
+#: ../gui/wxpython/gui_modules/preferences.py:427
 msgid "Segment break"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:621
+#: ../gui/wxpython/gui_modules/preferences.py:637
 msgid "Collapse all except PERMANENT and current"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:622
+#: ../gui/wxpython/gui_modules/preferences.py:638
 msgid "Collapse all except PERMANENT"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:623
+#: ../gui/wxpython/gui_modules/preferences.py:639
 msgid "Collapse all except current"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:624
+#: ../gui/wxpython/gui_modules/preferences.py:640
 msgid "Collapse all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:625
+#: ../gui/wxpython/gui_modules/preferences.py:641
 msgid "Expand all"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:627
+#: ../gui/wxpython/gui_modules/preferences.py:643
 msgid "Display selected"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:635
+#: ../gui/wxpython/gui_modules/preferences.py:651
 msgid "Classic (labels only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:636
+#: ../gui/wxpython/gui_modules/preferences.py:652
 msgid "Combined (labels and module names)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:637
+#: ../gui/wxpython/gui_modules/preferences.py:653
 msgid "Professional (module names only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:657
+#: ../gui/wxpython/gui_modules/preferences.py:673
 msgid "box"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:658
+#: ../gui/wxpython/gui_modules/preferences.py:674
 msgid "sphere"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:659
+#: ../gui/wxpython/gui_modules/preferences.py:675
 msgid "cube"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:660
+#: ../gui/wxpython/gui_modules/preferences.py:676
 msgid "diamond"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:661
+#: ../gui/wxpython/gui_modules/preferences.py:677
 msgid "dtree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:662
+#: ../gui/wxpython/gui_modules/preferences.py:678
 msgid "ctree"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:663
+#: ../gui/wxpython/gui_modules/preferences.py:679
 msgid "aster"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:664
+#: ../gui/wxpython/gui_modules/preferences.py:680
 msgid "gyro"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:665
+#: ../gui/wxpython/gui_modules/preferences.py:681
 msgid "histogram"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:727
+#: ../gui/wxpython/gui_modules/preferences.py:713
+#, fuzzy, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr "Impossible de lire la liste : %s"
+#: ../gui/wxpython/gui_modules/preferences.py:737
 #, python-format
 msgid ""
 "Error: Reading settings from file <%(file)s> failed.\n"
-"       Details: %(detail)s\n"
-"       Line: '%(line)s'"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:750
+#: ../gui/wxpython/gui_modules/preferences.py:758
 msgid "Cannot create directory for settings [home]/.grass7"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:751
+#: ../gui/wxpython/gui_modules/preferences.py:759
 msgid "Error saving preferences"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:787
+#: ../gui/wxpython/gui_modules/preferences.py:794
 #, python-format
 msgid ""
 "Writing settings to file <%(file)s> failed.\n"
@@ -11674,283 +11790,289 @@
 "Details: %(detail)s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:888
+#: ../gui/wxpython/gui_modules/preferences.py:893
 msgid "Unable to set "
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:914
-#: ../gui/wxpython/gui_modules/preferences.py:920
+#: ../gui/wxpython/gui_modules/preferences.py:919
+#: ../gui/wxpython/gui_modules/preferences.py:925
 #, python-format
 msgid "Unable to parse settings '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:931
+#: ../gui/wxpython/gui_modules/preferences.py:936
 msgid "User settings"
 msgstr "Paramètres de l'utilisateur"
-#: ../gui/wxpython/gui_modules/preferences.py:951
+#: ../gui/wxpython/gui_modules/preferences.py:956
 msgid "Set to default"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:959
+#: ../gui/wxpython/gui_modules/preferences.py:964
 msgid "Revert settings to default and apply changes"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1021
+#: ../gui/wxpython/gui_modules/preferences.py:1026
 msgid "Settings applied to current session but not saved"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1039
+#: ../gui/wxpython/gui_modules/preferences.py:1044
 #, python-format
 msgid "Settings saved to file '%s'."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1070
+#: ../gui/wxpython/gui_modules/preferences.py:1075
 msgid "Key column cannot be empty string."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1084
+#: ../gui/wxpython/gui_modules/preferences.py:1089
 #, fuzzy
 msgid "GUI Settings"
 msgstr "Paramètres de l'interface utilisateur"
-#: ../gui/wxpython/gui_modules/preferences.py:1107
-msgid "General settings"
-msgstr "Paramètres généraux"
-#: ../gui/wxpython/gui_modules/preferences.py:1118
-msgid "Element list:"
+#: ../gui/wxpython/gui_modules/preferences.py:1115
+msgid "Layer Manager settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1140
-msgid "Save current window layout as default"
-msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1126
+msgid "Ask when removing map layer from layer tree"
+msgstr "Demander lors de l'enlèvement d'une couche de l'arborescence"
-#: ../gui/wxpython/gui_modules/preferences.py:1143
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
+#: ../gui/wxpython/gui_modules/preferences.py:1136
+msgid "Ask when quiting wxGUI or closing display"
 msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1146
 #: ../gui/wxpython/gui_modules/preferences.py:1156
-msgid "Layer Manager settings"
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1167
-msgid "Ask when removing map layer from layer tree"
-msgstr "Demander lors de l'enlèvement d'une couche de l'arborescence"
-#: ../gui/wxpython/gui_modules/preferences.py:1177
-msgid "Ask when quiting wxGUI or closing display"
+#: ../gui/wxpython/gui_modules/preferences.py:1169
+msgid "Automatically copy selected text to clipboard (in Command console)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1191
+#: ../gui/wxpython/gui_modules/preferences.py:1183
 #, fuzzy
 msgid "Workspace settings"
 msgstr "Modifier les réglages"
-#: ../gui/wxpython/gui_modules/preferences.py:1199
+#: ../gui/wxpython/gui_modules/preferences.py:1191
 msgid "Suppress positioning Map Display Window(s)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1211
+#: ../gui/wxpython/gui_modules/preferences.py:1203
 msgid "Suppress positioning Layer Manager window"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1254
+#: ../gui/wxpython/gui_modules/preferences.py:1214
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1217
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1258
 msgid "Font for command output:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1268
+#: ../gui/wxpython/gui_modules/preferences.py:1272
 #, fuzzy
 msgid "Appearance settings"
-#: ../gui/wxpython/gui_modules/preferences.py:1280
+#: ../gui/wxpython/gui_modules/preferences.py:1283
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1302
 #, fuzzy
 msgid "Menu style:"
 msgstr "Arbre de Steiner"
-#: ../gui/wxpython/gui_modules/preferences.py:1304
+#: ../gui/wxpython/gui_modules/preferences.py:1326
 msgid "Height of map selection popup window (in pixels):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1328
+#: ../gui/wxpython/gui_modules/preferences.py:1350
 msgid "Icon theme:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1346
+#: ../gui/wxpython/gui_modules/preferences.py:1368
 msgid ""
 "Note: For changing the icon theme, you must save the settings and restart "
 "this GUI."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1368
+#: ../gui/wxpython/gui_modules/preferences.py:1390
 #, fuzzy
 msgid "Map Display"
 msgstr "Afficher :"
-#: ../gui/wxpython/gui_modules/preferences.py:1383
+#: ../gui/wxpython/gui_modules/preferences.py:1405
 msgid "Default font for GRASS displays:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1400
+#: ../gui/wxpython/gui_modules/preferences.py:1422
 msgid "Default display settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1412
+#: ../gui/wxpython/gui_modules/preferences.py:1434
 msgid "Display driver:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1432
+#: ../gui/wxpython/gui_modules/preferences.py:1454
 msgid "Statusbar mode:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1484
+#: ../gui/wxpython/gui_modules/preferences.py:1506
 msgid "Enable auto-rendering"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1497
+#: ../gui/wxpython/gui_modules/preferences.py:1519
 msgid "Enable auto-zooming to selected map layer"
 msgstr "Activer le zoom automatique sur la couche sélectionnée"
-#: ../gui/wxpython/gui_modules/preferences.py:1521
+#: ../gui/wxpython/gui_modules/preferences.py:1543
 msgid "Command dialog settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1543
+#: ../gui/wxpython/gui_modules/preferences.py:1565
 msgid "Close dialog when command is successfully finished"
 msgstr "Fermer la boîte de dialogue après l'exécution réussie"
-#: ../gui/wxpython/gui_modules/preferences.py:1564
+#: ../gui/wxpython/gui_modules/preferences.py:1586
 #, fuzzy
 msgid "Allow interactive input"
 msgstr "Authoriser les entrées interactives"
-#: ../gui/wxpython/gui_modules/preferences.py:1574
+#: ../gui/wxpython/gui_modules/preferences.py:1596
 msgid "Verbosity level:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1593
+#: ../gui/wxpython/gui_modules/preferences.py:1615
 msgid "Raster settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1604
+#: ../gui/wxpython/gui_modules/preferences.py:1626
 msgid "Make null cells opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1615
+#: ../gui/wxpython/gui_modules/preferences.py:1637
 msgid "Default color table"
 msgstr "Table de couleur par défaut"
-#: ../gui/wxpython/gui_modules/preferences.py:1641
+#: ../gui/wxpython/gui_modules/preferences.py:1663
 msgid "Vector settings"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1647
+#: ../gui/wxpython/gui_modules/preferences.py:1669
 msgid "Display:"
 msgstr "Afficher :"
-#: ../gui/wxpython/gui_modules/preferences.py:1677
+#: ../gui/wxpython/gui_modules/preferences.py:1699
 msgid "Highlighting"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1693
+#: ../gui/wxpython/gui_modules/preferences.py:1715
 msgid "Line width (in pixels):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1716
+#: ../gui/wxpython/gui_modules/preferences.py:1738
 msgid "Data browser"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1721
+#: ../gui/wxpython/gui_modules/preferences.py:1743
 msgid "Left mouse double click:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1733
+#: ../gui/wxpython/gui_modules/preferences.py:1755
 msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1744
+#: ../gui/wxpython/gui_modules/preferences.py:1766
 msgid "Ask when deleting data record(s) from table"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1765
+#: ../gui/wxpython/gui_modules/preferences.py:1787
 msgid "Create table"
 msgstr "Créer une table"
-#: ../gui/wxpython/gui_modules/preferences.py:1772
+#: ../gui/wxpython/gui_modules/preferences.py:1794
 msgid "Key column:"
 msgstr "Colonne clef :"
-#: ../gui/wxpython/gui_modules/preferences.py:1805
+#: ../gui/wxpython/gui_modules/preferences.py:1827
 msgid "Projection statusbar settings"
 msgstr "Paramètres de la barre de statut de projection"
-#: ../gui/wxpython/gui_modules/preferences.py:1831
+#: ../gui/wxpython/gui_modules/preferences.py:1853
 msgid "Proj.4 string (required):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1847
+#: ../gui/wxpython/gui_modules/preferences.py:1869
 msgid "EPSG file:"
 msgstr "Fichier EPSG :"
-#: ../gui/wxpython/gui_modules/preferences.py:1862
+#: ../gui/wxpython/gui_modules/preferences.py:1884
 msgid ""
 "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
 "directly."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1870
+#: ../gui/wxpython/gui_modules/preferences.py:1892
 #, fuzzy
 msgid "&Load EPSG codes"
 msgstr "Charger les codes EPSG :"
-#: ../gui/wxpython/gui_modules/preferences.py:1881
+#: ../gui/wxpython/gui_modules/preferences.py:1903
 msgid "Coordinates format"
 msgstr "Format des coordonnées"
-#: ../gui/wxpython/gui_modules/preferences.py:1890
+#: ../gui/wxpython/gui_modules/preferences.py:1912
 msgid "LL projections"
 msgstr "Projections LL"
-#: ../gui/wxpython/gui_modules/preferences.py:1909
+#: ../gui/wxpython/gui_modules/preferences.py:1931
 msgid "Precision:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:1947
+#: ../gui/wxpython/gui_modules/preferences.py:1969
 msgid "Unable to read EPSG codes: %s"
 msgstr "Impossible de lire les codes EPSG : %s"
-#: ../gui/wxpython/gui_modules/preferences.py:1976
-#: ../gui/wxpython/gui_modules/preferences.py:1985
-#: ../gui/wxpython/gui_modules/preferences.py:1995
+#: ../gui/wxpython/gui_modules/preferences.py:1998
+#: ../gui/wxpython/gui_modules/preferences.py:2007
+#: ../gui/wxpython/gui_modules/preferences.py:2017
 #, python-format
 msgid "EPSG code %s not found"
 msgstr "Code EPSG %s non trouvé"
-#: ../gui/wxpython/gui_modules/preferences.py:2003
+#: ../gui/wxpython/gui_modules/preferences.py:2025
 msgid "Select default display font"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2028
+#: ../gui/wxpython/gui_modules/preferences.py:2050
 msgid "Select output font"
 msgstr "Sélectionner une police"
-#: ../gui/wxpython/gui_modules/preferences.py:2121
+#: ../gui/wxpython/gui_modules/preferences.py:2143
 msgid "Select font:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2145
+#: ../gui/wxpython/gui_modules/preferences.py:2167
 msgid "Character encoding:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2263
+#: ../gui/wxpython/gui_modules/preferences.py:2285
 msgid "Manage access to mapsets"
 msgstr "Gérer l'accès aux jeux de cartes"
-#: ../gui/wxpython/gui_modules/preferences.py:2276
+#: ../gui/wxpython/gui_modules/preferences.py:2298
 msgid ""
 "Check a mapset to make it accessible, uncheck it to hide it.\n"
 "  Notes:\n"
@@ -11959,11 +12081,11 @@
 "    - You may only write to mapsets which you own."
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2350
+#: ../gui/wxpython/gui_modules/preferences.py:2372
 msgid "Mapset"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:2351
+#: ../gui/wxpython/gui_modules/preferences.py:2373
 msgid "Owner"
 msgstr ""
@@ -12232,7 +12354,71 @@
 "home directory."
 msgstr ""
+#~ msgid "Load map layers into layer tree"
+#~ msgstr "Charger des cartes dans l'arborescence des couches"
 #, fuzzy
+#~ msgid "Load map layers into workspace (Ctrl+L)"
+#~ msgstr "Charger des cartes dans l'espace de travail"
+#~ msgid "Load map layers"
+#~ msgstr "Charger des cartes"
+#~ msgid "north"
+#~ msgstr "nord"
+#~ msgid "south"
+#~ msgstr "sud"
+#~ msgid "east"
+#~ msgstr "est"
+#~ msgid "west"
+#~ msgstr "ouest"
+#~ msgid "north-west"
+#~ msgstr "nord-ouest"
+#~ msgid "north-east"
+#~ msgstr "nord-est"
+#~ msgid "south-east"
+#~ msgstr "sud-est"
+#~ msgid "south-west"
+#~ msgstr "sud-ouest"
+#~ msgid "Topography"
+#~ msgstr "Topographie"
+#~ msgid "Mask zeros:"
+#~ msgstr "Masquer les zéros"
+#~ msgid "by elevation"
+#~ msgstr "par altitude"
+#~ msgid "by color"
+#~ msgstr "par couleur"
+#, fuzzy
+#~ msgid "color"
+#~ msgstr "couleur :"
+#, fuzzy
+#~ msgid "display"
+#~ msgstr "Afficher :"
+#, fuzzy
+#~ msgid "symbol"
+#~ msgstr "symbôle :"
+#~ msgid "Nviz settings saved to file <%s>."
+#~ msgstr "Paramètres NVIZ enregistrés dans <%s>."
+#~ msgid "General settings"
+#~ msgstr "Paramètres généraux"
+#, fuzzy
 #~ msgid "Show help page"
 #~ msgstr "Afficher les lignes"
@@ -12732,9 +12918,6 @@
 #~ "\n"
 #~ "Détails : %s"
-#~ msgid "Height"
-#~ msgstr "Hauteur"
 #~ msgid "Twist"
 #~ msgstr "Basculer :"
@@ -13072,21 +13255,12 @@
 #~ msgid "Icon size:"
 #~ msgstr "Taille de l'icône"
-#~ msgid "width:"
-#~ msgstr "largeur :"
-#~ msgid "color:"
-#~ msgstr "couleur :"
 #~ msgid "Default"
 #~ msgstr "Défaut"
 #~ msgid "Layer properties"
 #~ msgstr " Propriétés de la couche"
-#~ msgid "Vector map <%s> is 3D"
-#~ msgstr "La carte vectorielle <%s> est en 3D"
 #~ msgid "Vector map <%s> is 2D"
 #~ msgstr "La carte vectorielle <%s> est en 2D"
Modified: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po	2011-06-09 17:35:44 UTC (rev 46647)
+++ grass/trunk/locale/po/grasswxpy_id.po	2011-06-09 18:04:03 UTC (rev 46648)
@@ -2,13 +2,13 @@
 # Firman Hadi <jalmiburung at gmail.com>, 2008.
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2008, GRASS Development Team
-#: ../gui/wxpython/gui_modules/psmap.py:1097
+#: ../gui/wxpython/gui_modules/psmap.py:1096
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2211
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_id\n"
 "Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-05-29 11:35+0200\n"
+"POT-Creation-Date: 2011-06-09 19:50+0200\n"
 "PO-Revision-Date: 2009-04-10 21:13+0700\n"
 "Last-Translator: Firman Hadi <jalmiburung at gmail.com>\n"
 "Language-Team: deutsch <grass-translations at lists.osgeo.org>\n"
@@ -21,60 +21,76 @@
 "X-Poedit-Language: Indonesian\n"
 "X-Poedit-Country: INDONESIA\n"
-#: ../gui/wxpython/wxgui.py:96
+#: ../gui/wxpython/wxgui.py:97
 #, fuzzy
 msgid "GRASS GIS Layer Manager"
 msgstr "GRASS GIS Attribute Table Manager"
-#: ../gui/wxpython/wxgui.py:136
+#: ../gui/wxpython/wxgui.py:139
 #, fuzzy
-msgid "Main Toolbar"
+msgid "Data Toolbar"
 msgstr "Map Toolbar"
-#: ../gui/wxpython/wxgui.py:144
+#: ../gui/wxpython/wxgui.py:147
 #, fuzzy
+msgid "Workspace Toolbar"
+msgstr "Workspace "
+#: ../gui/wxpython/wxgui.py:155
+#, fuzzy
+msgid "Misc Toolbar"
+msgstr "Map Toolbar"
+#: ../gui/wxpython/wxgui.py:163
+#, fuzzy
 msgid "Tools Toolbar"
-#: ../gui/wxpython/wxgui.py:231
+#: ../gui/wxpython/wxgui.py:250
 #, fuzzy
 msgid "Map layers"
 msgstr "Layer peta"
-#: ../gui/wxpython/wxgui.py:235 ../gui/wxpython/wxgui.py:375
+#: ../gui/wxpython/wxgui.py:254 ../gui/wxpython/wxgui.py:407
 #, fuzzy
 msgid "Command console"
 msgstr "Perintah berhasil dijalankan (%d detik)"
-#: ../gui/wxpython/wxgui.py:239
+#: ../gui/wxpython/wxgui.py:260
 msgid "Search module"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:252 ../gui/wxpython/gui_modules/toolbars.py:207
+#: ../gui/wxpython/wxgui.py:267
+#: ../gui/wxpython/gui_modules/preferences.py:1156
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:282 ../gui/wxpython/gui_modules/toolbars.py:211
 msgid "3D view"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:296
+#: ../gui/wxpython/wxgui.py:328
 #, python-format
 msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:315
+#: ../gui/wxpython/wxgui.py:347
 #, fuzzy
 msgid "Choose model to run"
 msgstr "Tutup dialog di akhir perintah"
-#: ../gui/wxpython/wxgui.py:317 ../gui/wxpython/gui_modules/gmodeler.py:802
-#: ../gui/wxpython/gui_modules/gmodeler.py:846
+#: ../gui/wxpython/wxgui.py:349 ../gui/wxpython/gui_modules/gmodeler.py:796
+#: ../gui/wxpython/gui_modules/gmodeler.py:840
 msgid "GRASS Model File (*.gxm)|*.gxm"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:326 ../gui/wxpython/gui_modules/gmodeler.py:1117
+#: ../gui/wxpython/wxgui.py:358 ../gui/wxpython/gui_modules/gmodeler.py:1111
 #, fuzzy
 msgid "Validating model..."
 msgstr "Rentang yang valid"
-#: ../gui/wxpython/wxgui.py:330 ../gui/wxpython/gui_modules/gmodeler.py:919
+#: ../gui/wxpython/wxgui.py:362 ../gui/wxpython/gui_modules/gmodeler.py:913
 #, python-format
 msgid ""
 "Model is not valid. Do you want to run the model anyway?\n"
@@ -82,64 +98,64 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:332 ../gui/wxpython/gui_modules/gmodeler.py:921
+#: ../gui/wxpython/wxgui.py:364 ../gui/wxpython/gui_modules/gmodeler.py:915
 msgid "Run model?"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:339 ../gui/wxpython/gui_modules/gmodeler.py:984
+#: ../gui/wxpython/wxgui.py:371 ../gui/wxpython/gui_modules/gmodeler.py:978
 msgid "Running model..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:389 ../gui/wxpython/wxgui.py:1476
+#: ../gui/wxpython/wxgui.py:421 ../gui/wxpython/wxgui.py:1500
 #, fuzzy
 msgid "Do you want to save changes in the workspace?"
 msgstr "Apakah Anda ingin menyimpan perubahan dalam peta vektor <%s>?"
-#: ../gui/wxpython/wxgui.py:391 ../gui/wxpython/wxgui.py:1478
+#: ../gui/wxpython/wxgui.py:423 ../gui/wxpython/wxgui.py:1502
 #, fuzzy
 msgid "Do you want to store current settings to workspace file?"
 msgstr ""
 "Workspace tidak kosong. Apakah Anda hendak menyimpan pengaturan saat ini ke "
 "berkas workspace?"
-#: ../gui/wxpython/wxgui.py:398
+#: ../gui/wxpython/wxgui.py:430
 msgid "Close Map Display %d"
 msgstr "GRASS GIS Map Display: "
-#: ../gui/wxpython/wxgui.py:497 ../gui/wxpython/wxgui.py:1159
+#: ../gui/wxpython/wxgui.py:529 ../gui/wxpython/wxgui.py:1155
 msgid "Selected map layer is not vector."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:502
+#: ../gui/wxpython/wxgui.py:534
 msgid "Editing is allowed only for vector maps from the current mapset."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:517
+#: ../gui/wxpython/wxgui.py:549
 #, fuzzy
 msgid "Choose script file to run"
 msgstr "Pilih berkas workspace"
-#: ../gui/wxpython/wxgui.py:519
+#: ../gui/wxpython/wxgui.py:551
 msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:530
+#: ../gui/wxpython/wxgui.py:562
 msgid "Script file '%s' doesn't exist. Operation cancelled."
 msgstr "Tidak ada layer peta terpilih. Operasi digagalkan."
-#: ../gui/wxpython/wxgui.py:534
+#: ../gui/wxpython/wxgui.py:566
 #, python-format
 msgid "Launching script '%s'..."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:549
+#: ../gui/wxpython/wxgui.py:581
 #, python-format
 msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:551 ../gui/wxpython/wxgui.py:572
+#: ../gui/wxpython/wxgui.py:583 ../gui/wxpython/wxgui.py:604
 #: ../gui/wxpython/scripts/r.li.setup.py:337
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1686
 #: ../gui/wxpython/gui_modules/mapdisp.py:367
@@ -154,8 +170,8 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:1029
 #: ../gui/wxpython/gui_modules/vdigit.py:1221
 #: ../gui/wxpython/gui_modules/vdigit.py:1247
-#: ../gui/wxpython/gui_modules/gmodeler.py:1438
-#: ../gui/wxpython/gui_modules/workspace.py:984
+#: ../gui/wxpython/gui_modules/gmodeler.py:1432
+#: ../gui/wxpython/gui_modules/workspace.py:991
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5365
 #: ../gui/wxpython/gui_modules/dbm.py:165
 #: ../gui/wxpython/gui_modules/dbm.py:1407
@@ -174,40 +190,40 @@
 #: ../gui/wxpython/gui_modules/profile.py:598
 #: ../gui/wxpython/gui_modules/layertree.py:505
 #: ../gui/wxpython/gui_modules/layertree.py:536
-#: ../gui/wxpython/gui_modules/preferences.py:1071
-#: ../gui/wxpython/gui_modules/preferences.py:1948
-#: ../gui/wxpython/gui_modules/preferences.py:1977
-#: ../gui/wxpython/gui_modules/preferences.py:1986
-#: ../gui/wxpython/gui_modules/preferences.py:1996
+#: ../gui/wxpython/gui_modules/preferences.py:1076
+#: ../gui/wxpython/gui_modules/preferences.py:1970
+#: ../gui/wxpython/gui_modules/preferences.py:1999
+#: ../gui/wxpython/gui_modules/preferences.py:2008
+#: ../gui/wxpython/gui_modules/preferences.py:2018
 #: ../gui/wxpython/gis_set.py:208 ../gui/wxpython/gis_set.py:466
 #: ../gui/wxpython/gis_set.py:502 ../gui/wxpython/gis_set.py:568
 #: ../gui/wxpython/gis_set.py:725
 msgid "Error"
 msgstr "Kesalahan "
-#: ../gui/wxpython/wxgui.py:557
+#: ../gui/wxpython/wxgui.py:589
 #, python-format
 msgid ""
 "Current location is <%(loc)s>.\n"
 "Current mapset is <%(mapset)s>."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:560 ../gui/wxpython/wxgui.py:576
+#: ../gui/wxpython/wxgui.py:592 ../gui/wxpython/wxgui.py:608
 #: ../gui/wxpython/gui_modules/ghelp.py:563
 msgid "Info"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:571
+#: ../gui/wxpython/wxgui.py:603
 msgid "Unable to switch to mapset <%s>."
 msgstr "Tidak bisa membuat sebuah peta vektor baru <%s>."
-#: ../gui/wxpython/wxgui.py:575
+#: ../gui/wxpython/wxgui.py:607
 msgid "Current mapset is <%s>."
 msgstr "Ubah mapset saat ini."
-#: ../gui/wxpython/wxgui.py:652
+#: ../gui/wxpython/wxgui.py:676
 #, fuzzy
 msgid ""
 "Current workspace is not empty. Do you want to store current settings to "
@@ -216,20 +232,20 @@
 "berkas workspace?"
-#: ../gui/wxpython/wxgui.py:655
+#: ../gui/wxpython/wxgui.py:679
 #, fuzzy
 msgid "Create new workspace?"
 msgstr "Buat sebuah berkas workspace baru"
-#: ../gui/wxpython/wxgui.py:681
+#: ../gui/wxpython/wxgui.py:705
 msgid "Choose workspace file"
-#: ../gui/wxpython/wxgui.py:682 ../gui/wxpython/wxgui.py:889
+#: ../gui/wxpython/wxgui.py:706 ../gui/wxpython/wxgui.py:885
 msgid "GRASS Workspace File (*.gxw)|*.gxw"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:717
+#: ../gui/wxpython/wxgui.py:741
 msgid ""
 "Reading workspace file <%s> failed.\n"
@@ -238,57 +254,58 @@
 "Gagal dalam pembacaan berkas workspace <%s>. Berkas tidak valid, tidak mampu "
 "membaca dokumen XML."
-#: ../gui/wxpython/wxgui.py:721 ../gui/wxpython/wxgui.py:830
-#: ../gui/wxpython/wxgui.py:866
+#: ../gui/wxpython/wxgui.py:745 ../gui/wxpython/wxgui.py:862
+#: ../gui/wxpython/wxgui.py:1241
 msgid "Please wait, loading workspace..."
 msgstr "Silakan tunggu, sedang memuat workspace ..."
-#: ../gui/wxpython/wxgui.py:822 ../gui/wxpython/menustrings.py:15
-msgid "Load map layers into layer tree"
-msgstr "Tampilkan layer peta ke dalam layer tree"
-#: ../gui/wxpython/wxgui.py:850
+#: ../gui/wxpython/wxgui.py:846
 msgid "Choose GRC file to load"
 msgstr "Pilih berkas GRC untuk dimuat"
-#: ../gui/wxpython/wxgui.py:851
+#: ../gui/wxpython/wxgui.py:847
 msgid "Old GRASS Workspace File (*.grc)|*.grc"
 msgstr ""
-#: ../gui/wxpython/wxgui.py:888
+#: ../gui/wxpython/wxgui.py:884
 msgid "Choose file to save current workspace"
 msgstr "Pilih berkas untuk menyimpan workspace saat ini"
-#: ../gui/wxpython/wxgui.py:903 ../gui/wxpython/wxgui.py:919
+#: ../gui/wxpython/wxgui.py:899 ../gui/wxpython/wxgui.py:915
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
 msgstr "Berkas Workspace <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/wxgui.py:905 ../gui/wxpython/wxgui.py:922
+#: ../gui/wxpython/wxgui.py:901 ../gui/wxpython/wxgui.py:918
 #: ../gui/wxpython/menustrings.py:9
 msgid "Save workspace"
 msgstr "Simpan workspace"
-#: ../gui/wxpython/wxgui.py:943
+#: ../gui/wxpython/wxgui.py:939
 #, fuzzy
 msgid "Writing current settings to workspace file failed."
 msgstr "Penulisan pengaturan saat ini ke berkas workspace gagal (%s)."
-#: ../gui/wxpython/wxgui.py:954 ../gui/wxpython/gui_modules/gmodeler.py:1437
+#: ../gui/wxpython/wxgui.py:950 ../gui/wxpython/gui_modules/gmodeler.py:1431
 #: ../gui/wxpython/gui_modules/profile.py:597
 msgid "Unable to open file <%s> for writing."
 msgstr "Tidak mampu membuka berkas <%s> untuk dibaca."
-#: ../gui/wxpython/wxgui.py:1132
+#: ../gui/wxpython/wxgui.py:1128
 msgid "Nothing to import. No WMS layer selected."
 msgstr ""
-#: ../gui/wxpython/wxgui.py:1168
+#: ../gui/wxpython/wxgui.py:1164
 msgid "Please wait, loading attribute data..."
 msgstr "Silakan tunggu, sedang menampilkan data atribut ..."
-#: ../gui/wxpython/wxgui.py:1418
+#: ../gui/wxpython/wxgui.py:1233
+#, fuzzy
+msgid "Add selected map layers into layer tree"
+msgstr "Tampilkan layer peta ke dalam layer tree"
+#: ../gui/wxpython/wxgui.py:1442
 msgid ""
 "Do you want to remove map layer(s)\n"
@@ -296,25 +313,25 @@
 "from layer tree?"
 msgstr "Apakah Anda hendak menghapus layer peta <%s> dari layer tree?"
-#: ../gui/wxpython/wxgui.py:1421
+#: ../gui/wxpython/wxgui.py:1445
 #, fuzzy
 msgid "Do you want to remove selected map layer(s) from layer tree?"
 msgstr "Apakah Anda hendak menghapus layer peta terpilih dari layer tree?"
-#: ../gui/wxpython/wxgui.py:1425
+#: ../gui/wxpython/wxgui.py:1449
 msgid "Remove map layer"
 msgstr "Hapus layer peta"
-#: ../gui/wxpython/wxgui.py:1485
+#: ../gui/wxpython/wxgui.py:1509
 #, fuzzy
 msgid "Quit GRASS GUI"
 msgstr "Tentang GRASS GIS"
-#: ../gui/wxpython/wxgui.py:1514
+#: ../gui/wxpython/wxgui.py:1538
 msgid "No map layer selected. Operation cancelled."
-#: ../gui/wxpython/wxgui.py:1515 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
+#: ../gui/wxpython/wxgui.py:1539 ../gui/wxpython/gui_modules/dbm_dialogs.py:77
 #: ../gui/wxpython/gui_modules/ghelp.py:287
 #: ../gui/wxpython/gui_modules/gcmd.py:98
 #: ../gui/wxpython/gui_modules/dbm.py:2056
@@ -323,7 +340,7 @@
 msgid "Message"
 msgstr "Pesan"
-#: ../gui/wxpython/wxgui.py:1545
+#: ../gui/wxpython/wxgui.py:1569
 #, fuzzy
 msgid "Starting GRASS GUI..."
 msgstr "Jalankan GRASS"
@@ -434,7 +451,7 @@
 msgid "Add scalebar and north arrow"
 msgstr "Tambahkan skala garis dan arah utara"
-#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:438
+#: ../gui/wxpython/icons/icon.py:148 ../gui/wxpython/icons/icon.py:440
 msgid "Add legend"
 msgstr "Tambahkan legenda"
@@ -445,7 +462,7 @@
 #: ../gui/wxpython/icons/icon.py:152
 #: ../gui/wxpython/gui_modules/histogram.py:440
-#: ../gui/wxpython/gui_modules/mapdisp.py:1179
+#: ../gui/wxpython/gui_modules/mapdisp.py:1187
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:942
 msgid "Print display"
 msgstr "Cetak tampilan"
@@ -467,7 +484,7 @@
 msgstr "Profil peta permukaan"
 #: ../gui/wxpython/icons/icon.py:161
-#: ../gui/wxpython/gui_modules/mapdisp.py:1877
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
 msgid "Add text layer"
 msgstr "Tambahkan layer teks"
@@ -487,611 +504,616 @@
 #: ../gui/wxpython/icons/icon.py:171
 #, fuzzy
-msgid "Load map layers into workspace (Ctrl+L)"
-msgstr "Muat semua peta pada workspace"
-#: ../gui/wxpython/icons/icon.py:173
-#, fuzzy
 msgid "Open existing workspace file (Ctrl+O)"
 msgstr "Buka berkas workspace yang telah ada "
-#: ../gui/wxpython/icons/icon.py:175
+#: ../gui/wxpython/icons/icon.py:173
 #, fuzzy
 msgid "Save current workspace to file (Ctrl+S)"
 msgstr "Simpan workspace ke dalam berkas"
-#: ../gui/wxpython/icons/icon.py:177 ../gui/wxpython/menustrings.py:29
-#: ../gui/wxpython/gui_modules/gdialogs.py:1146
+#: ../gui/wxpython/icons/icon.py:175
 #, fuzzy
+msgid "Add multiple raster or vector map layers (Ctrl+L)"
+msgstr "Tambahkan layer peta raster"
+#: ../gui/wxpython/icons/icon.py:177
+#, fuzzy
+msgid "Import/link raster or vector data"
+msgstr "Impor peta raster "
+#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:29
+#: ../gui/wxpython/gui_modules/gdialogs.py:1147
+#, fuzzy
 msgid "Import raster data"
-#: ../gui/wxpython/icons/icon.py:179 ../gui/wxpython/menustrings.py:148
-#: ../gui/wxpython/gui_modules/gdialogs.py:1144
+#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:148
+#: ../gui/wxpython/gui_modules/gdialogs.py:1145
 #, fuzzy
 msgid "Link external raster data"
 msgstr "Tidak berhasil memperbaharui peta vektor."
-#: ../gui/wxpython/icons/icon.py:181 ../gui/wxpython/menustrings.py:56
-#: ../gui/wxpython/gui_modules/gdialogs.py:1140
+#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:56
+#: ../gui/wxpython/gui_modules/gdialogs.py:1141
 #, fuzzy
 msgid "Import vector data"
 msgstr "Impor peta vektor "
-#: ../gui/wxpython/icons/icon.py:183 ../gui/wxpython/menustrings.py:150
-#: ../gui/wxpython/gui_modules/gdialogs.py:1138
+#: ../gui/wxpython/icons/icon.py:185 ../gui/wxpython/menustrings.py:150
+#: ../gui/wxpython/gui_modules/gdialogs.py:1139
 #, fuzzy
 msgid "Link external vector data"
-#: ../gui/wxpython/icons/icon.py:185
+#: ../gui/wxpython/icons/icon.py:187
 #, fuzzy
 msgid "Add raster map layer (Ctrl+R)"
-#: ../gui/wxpython/icons/icon.py:187
+#: ../gui/wxpython/icons/icon.py:189
 #, fuzzy
 msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
-#: ../gui/wxpython/icons/icon.py:189
+#: ../gui/wxpython/icons/icon.py:191
 #, fuzzy
 msgid "Add vector map layer (Ctrl+V)"
 msgstr "Tambahkan layer peta vektor"
-#: ../gui/wxpython/icons/icon.py:191
+#: ../gui/wxpython/icons/icon.py:193
 #, fuzzy
 msgid "Add various vector map layers (thematic, chart...)"
-#: ../gui/wxpython/icons/icon.py:193
+#: ../gui/wxpython/icons/icon.py:195
 msgid "Add command layer"
 msgstr "Tambahkan layer perintah"
-#: ../gui/wxpython/icons/icon.py:195
+#: ../gui/wxpython/icons/icon.py:197
 #, fuzzy
 msgid "Add group"
 msgstr "Tambahkan grup layer"
-#: ../gui/wxpython/icons/icon.py:197
+#: ../gui/wxpython/icons/icon.py:199
 msgid "Add grid or vector labels overlay"
 msgstr "Tambahkan overlay label grid atau vektor"
-#: ../gui/wxpython/icons/icon.py:199
+#: ../gui/wxpython/icons/icon.py:201
 #, fuzzy
 msgid "Delete selected map layer"
 msgstr "Hapus layer terpilih"
-#: ../gui/wxpython/icons/icon.py:201 ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/icons/icon.py:203 ../gui/wxpython/icons/icon.py:403
 msgid "Quit"
 msgstr "Keluar "
-#: ../gui/wxpython/icons/icon.py:203
+#: ../gui/wxpython/icons/icon.py:205
 msgid "Show attribute table"
 msgstr "Perlihatkan tabel atribut"
-#: ../gui/wxpython/icons/icon.py:205
+#: ../gui/wxpython/icons/icon.py:207
 #, fuzzy
 msgid "Edit vector maps"
 msgstr "Ekspor peta vektor "
-#: ../gui/wxpython/icons/icon.py:207
+#: ../gui/wxpython/icons/icon.py:209
 #, fuzzy
 msgid "Add RGB map layer"
 msgstr "Tambahkan layer RGB"
-#: ../gui/wxpython/icons/icon.py:209
+#: ../gui/wxpython/icons/icon.py:211
 #, fuzzy
 msgid "Add HIS map layer"
 msgstr "Tambahkan layer HIS"
-#: ../gui/wxpython/icons/icon.py:211
+#: ../gui/wxpython/icons/icon.py:213
 msgid "Add shaded relief map layer"
 msgstr "Tambahkan layer peta relief berbayang"
-#: ../gui/wxpython/icons/icon.py:213
+#: ../gui/wxpython/icons/icon.py:215
 msgid "Add raster flow arrows"
 msgstr "Tambahkan panah aliran raster"
-#: ../gui/wxpython/icons/icon.py:215
+#: ../gui/wxpython/icons/icon.py:217
 msgid "Add raster cell numbers"
 msgstr "Tambahkan nomor sel raster"
-#: ../gui/wxpython/icons/icon.py:217
+#: ../gui/wxpython/icons/icon.py:219
 #, fuzzy
 msgid "Add thematic area (choropleth) map layer"
 msgstr "Tambahkan layer diagram tematik"
-#: ../gui/wxpython/icons/icon.py:219
+#: ../gui/wxpython/icons/icon.py:221
 msgid "Add thematic chart layer"
-#: ../gui/wxpython/icons/icon.py:221
+#: ../gui/wxpython/icons/icon.py:223
 msgid "Add grid layer"
 msgstr "Tambahkan layer grid"
-#: ../gui/wxpython/icons/icon.py:223
+#: ../gui/wxpython/icons/icon.py:225
 msgid "Add geodesic line layer"
 msgstr "Tambahkan sebuah layer garis geodesi"
-#: ../gui/wxpython/icons/icon.py:225
+#: ../gui/wxpython/icons/icon.py:227
 msgid "Add rhumbline layer"
 msgstr "Tambahkan sebuah layer rhumbline"
-#: ../gui/wxpython/icons/icon.py:227
+#: ../gui/wxpython/icons/icon.py:229
 msgid "Add labels"
 msgstr "Tambahkan label"
-#: ../gui/wxpython/icons/icon.py:229
+#: ../gui/wxpython/icons/icon.py:231
 #, fuzzy
 msgid "Add 3D raster map layer"
-#: ../gui/wxpython/icons/icon.py:230
+#: ../gui/wxpython/icons/icon.py:232
 msgid "Note that 3D raster data are rendered only in 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:232
+#: ../gui/wxpython/icons/icon.py:234
 #, fuzzy
 msgid "Show GUI settings"
 msgstr "Perlihatkan pengaturan "
-#: ../gui/wxpython/icons/icon.py:234
+#: ../gui/wxpython/icons/icon.py:236
 #, fuzzy
 msgid "Graphical Modeler"
 msgstr "Bantuan GRASS GIS GUI"
-#: ../gui/wxpython/icons/icon.py:236
+#: ../gui/wxpython/icons/icon.py:238
 #: ../gui/wxpython/gui_modules/gdialogs.py:416
 msgid "Set options"
 msgstr "Pilihan pengaturan"
-#: ../gui/wxpython/icons/icon.py:238
+#: ../gui/wxpython/icons/icon.py:240 ../gui/wxpython/menustrings.py:198
 #, fuzzy
-msgid "Hardcopy Map Ouput Utility"
+msgid "Hardcopy Map Output Utility"
 msgstr "Utilitas output peta dalam bentuk cetak PostScript"
-#: ../gui/wxpython/icons/icon.py:240
+#: ../gui/wxpython/icons/icon.py:242
 #, fuzzy
 msgid "Raster Map Calculator"
 msgstr "Kalkulator peta raster 3D"
-#: ../gui/wxpython/icons/icon.py:244
+#: ../gui/wxpython/icons/icon.py:246
 msgid "Digitize new point"
 msgstr "Digitasi titik baru "
-#: ../gui/wxpython/icons/icon.py:245 ../gui/wxpython/icons/icon.py:254
-#: ../gui/wxpython/icons/icon.py:257
+#: ../gui/wxpython/icons/icon.py:247 ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:259
 msgid "Left: new point"
 msgstr "Klik kiri: titik baru"
-#: ../gui/wxpython/icons/icon.py:247
+#: ../gui/wxpython/icons/icon.py:249
 msgid "Digitize new line"
 msgstr "Digitasi garis baru "
-#: ../gui/wxpython/icons/icon.py:248 ../gui/wxpython/icons/icon.py:251
-#: ../gui/wxpython/icons/icon.py:275
+#: ../gui/wxpython/icons/icon.py:250 ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:277
 #, fuzzy
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
 msgstr ""
 "Klik kiri: titik baru; Klik tengah: gagalkan titik terakhir; Klik kanan: "
 "tutup garis"
-#: ../gui/wxpython/icons/icon.py:250
+#: ../gui/wxpython/icons/icon.py:252
 msgid "Digitize new boundary"
 msgstr "Digitasi batas baru "
-#: ../gui/wxpython/icons/icon.py:253
+#: ../gui/wxpython/icons/icon.py:255
 msgid "Digitize new centroid"
 msgstr "Digitasi centroid baru "
-#: ../gui/wxpython/icons/icon.py:256
+#: ../gui/wxpython/icons/icon.py:258
 msgid ""
 "Digitize new area (composition of boundaries without category and one "
 "centroid with category)"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:259
+#: ../gui/wxpython/icons/icon.py:261
 msgid "Add new vertex"
 msgstr "Tambahkan sebuah vertex baru"
-#: ../gui/wxpython/icons/icon.py:260 ../gui/wxpython/icons/icon.py:263
-#: ../gui/wxpython/icons/icon.py:266 ../gui/wxpython/icons/icon.py:278
-#: ../gui/wxpython/icons/icon.py:281 ../gui/wxpython/icons/icon.py:284
-#: ../gui/wxpython/icons/icon.py:289 ../gui/wxpython/icons/icon.py:296
+#: ../gui/wxpython/icons/icon.py:262 ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:268 ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:283 ../gui/wxpython/icons/icon.py:286
+#: ../gui/wxpython/icons/icon.py:291 ../gui/wxpython/icons/icon.py:298
 #, fuzzy
 msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
 msgstr "Klik kiri: Pilih; Klik tengah: Tidak jadi pilih; Klik kanan: Tetapkan"
-#: ../gui/wxpython/icons/icon.py:262
-#: ../gui/wxpython/gui_modules/toolbars.py:782
+#: ../gui/wxpython/icons/icon.py:264
+#: ../gui/wxpython/gui_modules/toolbars.py:729
 msgid "Copy categories"
 msgstr "Salin kategori "
-#: ../gui/wxpython/icons/icon.py:265
+#: ../gui/wxpython/icons/icon.py:267
 msgid "Delete feature(s)"
 msgstr "Hapus fitur"
-#: ../gui/wxpython/icons/icon.py:268
+#: ../gui/wxpython/icons/icon.py:270
 msgid "Display/update attributes"
 msgstr "Tampilkan/ubah atribut"
-#: ../gui/wxpython/icons/icon.py:269 ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/icons/icon.py:271 ../gui/wxpython/icons/icon.py:274
 msgid "Left: Select"
 msgstr "Klik kiri: Pilih"
-#: ../gui/wxpython/icons/icon.py:271
+#: ../gui/wxpython/icons/icon.py:273
 msgid "Display/update categories"
 msgstr "Tampilkan/ubah kategori"
-#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/icons/icon.py:276
 msgid "Edit line/boundary"
 msgstr "Edit garis/batas "
-#: ../gui/wxpython/icons/icon.py:277
+#: ../gui/wxpython/icons/icon.py:279
 msgid "Move feature(s)"
 msgstr "Gerakkan fitur"
-#: ../gui/wxpython/icons/icon.py:280
+#: ../gui/wxpython/icons/icon.py:282
 msgid "Move vertex"
 msgstr "Pindahkan vertex "
-#: ../gui/wxpython/icons/icon.py:283
+#: ../gui/wxpython/icons/icon.py:285
 msgid "Remove vertex"
 msgstr "Hapus vertex "
-#: ../gui/wxpython/icons/icon.py:286
-#: ../gui/wxpython/gui_modules/toolbars.py:857
+#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/gui_modules/toolbars.py:804
 msgid "Digitization settings"
 msgstr "Pengaturan digitasi"
-#: ../gui/wxpython/icons/icon.py:288
+#: ../gui/wxpython/icons/icon.py:290
 msgid "Split line/boundary"
 msgstr "Pecah garis/batas"
-#: ../gui/wxpython/icons/icon.py:291
+#: ../gui/wxpython/icons/icon.py:293
 #, fuzzy
 msgid "Quit digitizer"
 msgstr "Toolbar digitasi vektor"
-#: ../gui/wxpython/icons/icon.py:292
+#: ../gui/wxpython/icons/icon.py:294
 msgid "Quit digitizer and save changes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:294
+#: ../gui/wxpython/icons/icon.py:296
 msgid "Additional tools (copy, flip, connect, etc.)"
 msgstr "Perkakas tambahan (salin, putar, hubungkan, dsb.)"
-#: ../gui/wxpython/icons/icon.py:298
+#: ../gui/wxpython/icons/icon.py:300
 msgid "Undo"
 msgstr "Gagalkan"
-#: ../gui/wxpython/icons/icon.py:299
+#: ../gui/wxpython/icons/icon.py:301
 msgid "Undo previous changes"
 msgstr "Gagalkan perubahan sebelumnya"
-#: ../gui/wxpython/icons/icon.py:303
+#: ../gui/wxpython/icons/icon.py:305
 msgid "Draw/re-draw profile"
 msgstr "Gambar/gambar-ulang profil"
-#: ../gui/wxpython/icons/icon.py:305
+#: ../gui/wxpython/icons/icon.py:307
 msgid "Draw transect in map display window to profile"
 msgstr "Gambar transek dalam jendela tampilan peta untuk membuat profil"
-#: ../gui/wxpython/icons/icon.py:307
+#: ../gui/wxpython/icons/icon.py:309
 msgid "Profile options"
 msgstr "Opsi profil"
-#: ../gui/wxpython/icons/icon.py:309
+#: ../gui/wxpython/icons/icon.py:311
 #, fuzzy
 msgid "Save profile data to CSV file"
 msgstr "Simpan tampilan ke dalam berkas PNG"
-#: ../gui/wxpython/icons/icon.py:311
+#: ../gui/wxpython/icons/icon.py:313
 #, fuzzy
 msgid "Quit Profile Analysis Tool"
 msgstr "Analisis profil"
-#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/icons/icon.py:317
 msgid "Set GCP"
 msgstr "Tentukan GCP"
-#: ../gui/wxpython/icons/icon.py:316
+#: ../gui/wxpython/icons/icon.py:318
 msgid "Define GCP (Ground Control Points)"
 msgstr "Definisikan GCP "
-#: ../gui/wxpython/icons/icon.py:318 ../gui/wxpython/menustrings.py:186
+#: ../gui/wxpython/icons/icon.py:320 ../gui/wxpython/menustrings.py:186
 msgid "Georectify"
 msgstr "Georektifikasi "
-#: ../gui/wxpython/icons/icon.py:320
+#: ../gui/wxpython/icons/icon.py:322
 msgid "Recalculate RMS error"
 msgstr "Hitung ulang kesalahan RMS"
-#: ../gui/wxpython/icons/icon.py:322
+#: ../gui/wxpython/icons/icon.py:324
 msgid "Save GCPs to POINTS file"
 msgstr "Simpan GCP ke dalam berkas POINTS "
-#: ../gui/wxpython/icons/icon.py:324
+#: ../gui/wxpython/icons/icon.py:326
 msgid "Add new GCP"
 msgstr "Tambahkan sebuah GCP baru"
-#: ../gui/wxpython/icons/icon.py:326
+#: ../gui/wxpython/icons/icon.py:328
 msgid "Delete selected GCP"
 msgstr "Hapus GCP terpilih"
-#: ../gui/wxpython/icons/icon.py:328
+#: ../gui/wxpython/icons/icon.py:330
 msgid "Clear selected GCP"
 msgstr "Bersihkan GCP terpilih"
-#: ../gui/wxpython/icons/icon.py:330
+#: ../gui/wxpython/icons/icon.py:332
 #, fuzzy
 msgid "Reload GCPs from POINTS file"
 msgstr "Muat ulang GCP dari berkas POINT terpilih"
-#: ../gui/wxpython/icons/icon.py:332
+#: ../gui/wxpython/icons/icon.py:334
 #, fuzzy
 msgid "Quit georectification"
 msgstr "Keluar dari modul georektifikasi"
-#: ../gui/wxpython/icons/icon.py:334
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1289
+#: ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1504
 #: ../gui/wxpython/gui_modules/gselect.py:1070
 msgid "Settings"
 msgstr "Pengaturan"
-#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/icons/icon.py:337
 msgid "Settings dialog for georectification tool"
 msgstr "Dialog pengaturan untuk tool georektifikasi"
-#: ../gui/wxpython/icons/icon.py:339
+#: ../gui/wxpython/icons/icon.py:341
 msgid "Switch to view control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:340
+#: ../gui/wxpython/icons/icon.py:342
 #, fuzzy
 msgid "Change view settings"
 msgstr "Ubah pengaturan "
-#: ../gui/wxpython/icons/icon.py:342
+#: ../gui/wxpython/icons/icon.py:344
 msgid "Switch to surface (raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:343
+#: ../gui/wxpython/icons/icon.py:345
 #, fuzzy
 msgid "Change surface (loaded raster maps) settings"
 msgstr "Pengkodean-ulang peta raster dengan rules"
-#: ../gui/wxpython/icons/icon.py:345
+#: ../gui/wxpython/icons/icon.py:347
 msgid "Switch to vector (2D/3D) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:346
+#: ../gui/wxpython/icons/icon.py:348
 #, fuzzy
 msgid "Change 2D/3D vector settings"
-#: ../gui/wxpython/icons/icon.py:348
+#: ../gui/wxpython/icons/icon.py:350
 msgid "Switch to volume (3D raster) control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:349
+#: ../gui/wxpython/icons/icon.py:351
 msgid "Change volume (loaded 3D raster maps) settings"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:353
 msgid "Switch to lighting control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:352
+#: ../gui/wxpython/icons/icon.py:354
 #, fuzzy
 msgid "Change lighting settings"
-#: ../gui/wxpython/icons/icon.py:354
+#: ../gui/wxpython/icons/icon.py:356
 msgid "Switch to fringe control page"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:355
+#: ../gui/wxpython/icons/icon.py:357
 msgid "Switch on/off fringes"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:359
 msgid "3D view mode tools"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:358
+#: ../gui/wxpython/icons/icon.py:360
 #, fuzzy
 msgid "Show/hide 3D view mode settings dialog"
-#: ../gui/wxpython/icons/icon.py:360
+#: ../gui/wxpython/icons/icon.py:362
 msgid "Quit 3D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:361
+#: ../gui/wxpython/icons/icon.py:363
 msgid "Switch back to 2D view mode"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:365
+#: ../gui/wxpython/icons/icon.py:367
 #, fuzzy
 msgid "Create new model (Ctrl+N)"
-#: ../gui/wxpython/icons/icon.py:367
+#: ../gui/wxpython/icons/icon.py:369
 #, fuzzy
 msgid "Load model from file (Ctrl+O)"
-#: ../gui/wxpython/icons/icon.py:369
+#: ../gui/wxpython/icons/icon.py:371
 #, fuzzy
 msgid "Save current model to file (Ctrl+S)"
-#: ../gui/wxpython/icons/icon.py:371 ../gui/wxpython/menustrings.py:878
+#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:878
 #, fuzzy
 msgid "Export model to image"
-#: ../gui/wxpython/icons/icon.py:373 ../gui/wxpython/menustrings.py:880
+#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:880
 msgid "Export model to Python script"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:375 ../gui/wxpython/menustrings.py:888
+#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:888
 msgid "Add action (GRASS module) to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:377 ../gui/wxpython/menustrings.py:890
+#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:890
 msgid "Add data item to model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:379 ../gui/wxpython/menustrings.py:892
+#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:892
 msgid "Define relation between data and action items"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:381 ../gui/wxpython/menustrings.py:190
+#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:190
 #: ../gui/wxpython/menustrings.py:903
 msgid "Run model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:383 ../gui/wxpython/menustrings.py:905
+#: ../gui/wxpython/icons/icon.py:385 ../gui/wxpython/menustrings.py:905
 msgid "Validate model"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:385
+#: ../gui/wxpython/icons/icon.py:387
 #, fuzzy
 msgid "Show modeler settings"
-#: ../gui/wxpython/icons/icon.py:387
+#: ../gui/wxpython/icons/icon.py:389
 #, fuzzy
 msgid "Show model properties"
 msgstr "Karakteristik"
-#: ../gui/wxpython/icons/icon.py:389
+#: ../gui/wxpython/icons/icon.py:391
 #, fuzzy
 msgid "Manage model variables"
 msgstr "Kelola tabel"
-#: ../gui/wxpython/icons/icon.py:391
+#: ../gui/wxpython/icons/icon.py:393
 msgid "Redraw model canvas"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:393
-#: ../gui/wxpython/gui_modules/gmodeler.py:677
+#: ../gui/wxpython/icons/icon.py:395
+#: ../gui/wxpython/gui_modules/gmodeler.py:671
 #, fuzzy
 msgid "Quit Graphical Modeler"
-#: ../gui/wxpython/icons/icon.py:397
+#: ../gui/wxpython/icons/icon.py:399
 msgid "Select font"
 msgstr "Pilih jenis huruf"
-#: ../gui/wxpython/icons/icon.py:399
+#: ../gui/wxpython/icons/icon.py:401
 #, fuzzy
 msgid "Show manual"
 msgstr "Peta bayangan "
-#: ../gui/wxpython/icons/icon.py:405
+#: ../gui/wxpython/icons/icon.py:407
 msgid "Generate text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:407
+#: ../gui/wxpython/icons/icon.py:409
 msgid "Load text file with mapping instructions"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:409
+#: ../gui/wxpython/icons/icon.py:411
 #, fuzzy
 msgid "Generate PostScript output"
-#: ../gui/wxpython/icons/icon.py:411
+#: ../gui/wxpython/icons/icon.py:413
 #, fuzzy
 msgid "Generate PDF output"
 msgstr "Hasilkan titik"
-#: ../gui/wxpython/icons/icon.py:413
+#: ../gui/wxpython/icons/icon.py:415
 #: ../gui/wxpython/gui_modules/histogram.py:432
-#: ../gui/wxpython/gui_modules/mapdisp.py:1171
+#: ../gui/wxpython/gui_modules/mapdisp.py:1179
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:934
 msgid "Page setup"
 msgstr "Pengaturan halaman"
-#: ../gui/wxpython/icons/icon.py:414
+#: ../gui/wxpython/icons/icon.py:416
 msgid "Specify paper size, margins and orientation"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:416
+#: ../gui/wxpython/icons/icon.py:418
 msgid "Full extent"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:417
+#: ../gui/wxpython/icons/icon.py:419
 #, fuzzy
 msgid "Zoom to full extent"
 msgstr "Perbesaran sesuai dengan region standar"
-#: ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:421
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1951
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2006
 #, fuzzy
 msgid "Map frame"
 msgstr "Skala peta"
-#: ../gui/wxpython/icons/icon.py:420
+#: ../gui/wxpython/icons/icon.py:422
 msgid "Click and drag to place map frame"
 msgstr ""
-#: ../gui/wxpython/icons/icon.py:422
-#: ../gui/wxpython/gui_modules/nviz_tools.py:320
+#: ../gui/wxpython/icons/icon.py:424
+#: ../gui/wxpython/gui_modules/nviz_tools.py:465
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2476
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:669
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:730
 #, fuzzy
 msgid "Raster map"
 msgstr "Peta raster:"
-#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/icons/icon.py:425
 #, fuzzy
 msgid "Add raster map"
-#: ../gui/wxpython/icons/icon.py:425
-#: ../gui/wxpython/gui_modules/nviz_tools.py:629
+#: ../gui/wxpython/icons/icon.py:427
+#: ../gui/wxpython/gui_modules/nviz_tools.py:839
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3920
 #, fuzzy
 msgid "Vector map"
 msgstr "Peta vektor baru"
-#: ../gui/wxpython/icons/icon.py:426
+#: ../gui/wxpython/icons/icon.py:428
 #, fuzzy
 msgid "Add vector map"
 msgstr "vektor "
-#: ../gui/wxpython/icons/icon.py:428
+#: ../gui/wxpython/icons/icon.py:430
 #, fuzzy
 msgid "Delete selected object"
 msgstr "Hapus location terpilih"
-#: ../gui/wxpython/icons/icon.py:430
+#: ../gui/wxpython/icons/icon.py:432
 #, fuzzy
 msgid "Show preview"
 msgstr "Tampilkan grid"
-#: ../gui/wxpython/icons/icon.py:432
+#: ../gui/wxpython/icons/icon.py:434
 #, fuzzy
 msgid "Quit Hardcopy Map Utility"
-#: ../gui/wxpython/icons/icon.py:434
+#: ../gui/wxpython/icons/icon.py:436
 #, fuzzy
 msgid "Add text"
-#: ../gui/wxpython/icons/icon.py:436
+#: ../gui/wxpython/icons/icon.py:438
 #, fuzzy
 msgid "Add map info"
-#: ../gui/wxpython/icons/icon.py:440
+#: ../gui/wxpython/icons/icon.py:442
 #, fuzzy
 msgid "Add scale bar"
 msgstr "Tambahkan layer"
@@ -1118,85 +1140,85 @@
 msgid "Kriging"
 msgstr "Tiling "
-#: ../gui/wxpython/scripts/vkrige.py:109
-#: ../gui/wxpython/gui_modules/gmodeler.py:575
-#: ../gui/wxpython/gui_modules/menuform.py:1165
+#: ../gui/wxpython/scripts/vkrige.py:108
+#: ../gui/wxpython/gui_modules/gmodeler.py:569
+#: ../gui/wxpython/gui_modules/menuform.py:1160
 msgid "Command output"
 msgstr "Output perintah"
-#: ../gui/wxpython/scripts/vkrige.py:115 ../gui/wxpython/menustrings.py:390
+#: ../gui/wxpython/scripts/vkrige.py:114 ../gui/wxpython/menustrings.py:390
 msgid "Output"
 msgstr "Output "
-#: ../gui/wxpython/scripts/vkrige.py:119
+#: ../gui/wxpython/scripts/vkrige.py:118
 #, fuzzy
 msgid "Name for the output raster map:"
 msgstr "Nama untuk peta vektor baru:"
-#: ../gui/wxpython/scripts/vkrige.py:127
+#: ../gui/wxpython/scripts/vkrige.py:126
 #, fuzzy
 msgid "Export variance map as well: "
 msgstr "Ekspor peta raster "
-#: ../gui/wxpython/scripts/vkrige.py:140
+#: ../gui/wxpython/scripts/vkrige.py:139
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:229
 #: ../gui/wxpython/gui_modules/vclean.py:144
-#: ../gui/wxpython/gui_modules/gmodeler.py:3309
-#: ../gui/wxpython/gui_modules/gdialogs.py:985
-#: ../gui/wxpython/gui_modules/preferences.py:1533
+#: ../gui/wxpython/gui_modules/gmodeler.py:3303
+#: ../gui/wxpython/gui_modules/gdialogs.py:986
+#: ../gui/wxpython/gui_modules/preferences.py:1555
 msgid "Allow output files to overwrite existing files"
 msgstr "Ijinkan berkas output untuk menimpa berkas yang ada"
-#: ../gui/wxpython/scripts/vkrige.py:153
+#: ../gui/wxpython/scripts/vkrige.py:152
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:133
 #: ../gui/wxpython/gui_modules/ghelp.py:223
 #: ../gui/wxpython/gui_modules/vclean.py:165
-#: ../gui/wxpython/gui_modules/gmodeler.py:3426
-#: ../gui/wxpython/gui_modules/menuform.py:827
+#: ../gui/wxpython/gui_modules/gmodeler.py:3420
+#: ../gui/wxpython/gui_modules/menuform.py:828
 msgid "&Run"
 msgstr "&Jalankan"
-#: ../gui/wxpython/scripts/vkrige.py:268
+#: ../gui/wxpython/scripts/vkrige.py:267
 msgid "Kriging Module"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:272
+#: ../gui/wxpython/scripts/vkrige.py:271
 #, fuzzy
 msgid "Ready."
 msgstr "Muat-ulang"
-#: ../gui/wxpython/scripts/vkrige.py:296
+#: ../gui/wxpython/scripts/vkrige.py:295
 msgid "Variogram fitting"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:306
+#: ../gui/wxpython/scripts/vkrige.py:305
 msgid "Plot/refresh variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:317
+#: ../gui/wxpython/scripts/vkrige.py:316
 #, fuzzy
 msgid ":"
 msgstr "X:"
-#: ../gui/wxpython/scripts/vkrige.py:342
+#: ../gui/wxpython/scripts/vkrige.py:341
 msgid "Kriging techniques"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:356
+#: ../gui/wxpython/scripts/vkrige.py:355
 #, fuzzy
 msgid "Block size:"
 msgstr "Tema ikon:"
-#: ../gui/wxpython/scripts/vkrige.py:389
+#: ../gui/wxpython/scripts/vkrige.py:388
 msgid "Auto-fit variogram"
 msgstr ""
-#: ../gui/wxpython/scripts/vkrige.py:413
+#: ../gui/wxpython/scripts/vkrige.py:412
 #, fuzzy
 msgid "Model: "
 msgstr "Mode"
-#: ../gui/wxpython/scripts/vkrige.py:497
+#: ../gui/wxpython/scripts/vkrige.py:496
 msgid "Work in progress! No functionality provided."
 msgstr ""
@@ -1284,8 +1306,9 @@
 msgid "Workspace"
 msgstr "Workspace "
-#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:19
+#: ../gui/wxpython/menustrings.py:4 ../gui/wxpython/menustrings.py:17
 #: ../gui/wxpython/menustrings.py:867
+#: ../gui/wxpython/gui_modules/nviz_tools.py:768
 msgid "New"
 msgstr ""
@@ -1329,48 +1352,53 @@
 #: ../gui/wxpython/menustrings.py:14
-msgid "Load map layers"
-msgstr "Tampilkan layer peta"
-#: ../gui/wxpython/menustrings.py:16
 msgid "Load GRC file (Tcl/Tk GUI)"
 msgstr "Tampilkan berkas GRC (GUI Tcl/Tk)"
-#: ../gui/wxpython/menustrings.py:17
+#: ../gui/wxpython/menustrings.py:15
 #, fuzzy
 msgid "Load map layers from GRC file to layer tree"
-#: ../gui/wxpython/menustrings.py:18
+#: ../gui/wxpython/menustrings.py:16
 #, fuzzy
 msgid "Map display"
 msgstr "Tampilan"
-#: ../gui/wxpython/menustrings.py:20
+#: ../gui/wxpython/menustrings.py:18
 #, fuzzy
 msgid "Open new map display window"
-#: ../gui/wxpython/menustrings.py:21
+#: ../gui/wxpython/menustrings.py:19
 #, fuzzy
 msgid "Close current"
 msgstr "Tutup workspace saat ini"
-#: ../gui/wxpython/menustrings.py:22
+#: ../gui/wxpython/menustrings.py:20
 #, fuzzy
 msgid "Close current map display window"
-#: ../gui/wxpython/menustrings.py:23
+#: ../gui/wxpython/menustrings.py:21
 #, fuzzy
 msgid "Close all"
-#: ../gui/wxpython/menustrings.py:24
+#: ../gui/wxpython/menustrings.py:22
 #, fuzzy
 msgid "Close all open map display windows"
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+#, fuzzy
+msgid "Add multiple raster or vector map layers to current display"
 #: ../gui/wxpython/menustrings.py:25
 #, fuzzy
 msgid "Add raster"
@@ -2015,6 +2043,7 @@
 "Ubah nama berkas elemen basis data dalam mapset saat ini milik pengguna"
 #: ../gui/wxpython/menustrings.py:165
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2640
 msgid "Delete"
 msgstr "Hapus "
@@ -2149,11 +2178,6 @@
 "coordinates and vice versa."
 msgstr ""
-#: ../gui/wxpython/menustrings.py:198
-#, fuzzy
-msgid "Hardcopy Map Output Utility"
-msgstr "Utilitas output peta dalam bentuk cetak PostScript"
 #: ../gui/wxpython/menustrings.py:199
 #, fuzzy
 msgid "Launch Hardcopy Map Output Utility"
@@ -2610,9 +2634,8 @@
 msgstr "Cari titik terdekat antara obyek-obyek dalam dua peta raster."
 #: ../gui/wxpython/menustrings.py:298
-#: ../gui/wxpython/gui_modules/nviz_tools.py:351
-#: ../gui/wxpython/gui_modules/nviz_tools.py:549
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+#: ../gui/wxpython/gui_modules/nviz_tools.py:602
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1238
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3049
 msgid "Mask"
 msgstr "Mask"
@@ -2792,7 +2815,7 @@
 "raster. "
 #: ../gui/wxpython/menustrings.py:330
-#: ../gui/wxpython/gui_modules/layertree.py:803
+#: ../gui/wxpython/gui_modules/layertree.py:799
 msgid "Shaded relief"
 msgstr "Relief berbayang "
@@ -5270,7 +5293,7 @@
 #: ../gui/wxpython/menustrings.py:872
-#: ../gui/wxpython/gui_modules/gmodeler.py:828
+#: ../gui/wxpython/gui_modules/gmodeler.py:822
 #, fuzzy
 msgid "Save model"
 msgstr "Mode kategori"
@@ -5305,7 +5328,7 @@
 msgstr "Window bergerak "
 #: ../gui/wxpython/menustrings.py:885
-#: ../gui/wxpython/gui_modules/gmodeler.py:3003
+#: ../gui/wxpython/gui_modules/gmodeler.py:2997
 #, fuzzy
 msgid "Modeler settings"
 msgstr "Pengaturan umum"
@@ -5358,7 +5381,7 @@
 msgstr "Hasilkan dari basisdata"
 #: ../gui/wxpython/menustrings.py:899
-#: ../gui/wxpython/gui_modules/gmodeler.py:3288
+#: ../gui/wxpython/gui_modules/gmodeler.py:3282
 #, fuzzy
 msgid "Model properties"
@@ -5518,8 +5541,8 @@
 msgstr "Buat histogram dari berkas citra atau raster"
 #: ../gui/wxpython/gui_modules/histogram.py:332
-#: ../gui/wxpython/gui_modules/wxnviz.py:227
-#: ../gui/wxpython/gui_modules/wxnviz.py:238
+#: ../gui/wxpython/gui_modules/wxnviz.py:240
+#: ../gui/wxpython/gui_modules/wxnviz.py:251
 msgid "Raster map <%s> not found"
 msgstr "ERROR: Mapset <%s> tidak ada"
@@ -5529,14 +5552,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:403
-#: ../gui/wxpython/gui_modules/mapdisp.py:1142
+#: ../gui/wxpython/gui_modules/mapdisp.py:1150
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:905
-#: ../gui/wxpython/gui_modules/gmodeler.py:1042
+#: ../gui/wxpython/gui_modules/gmodeler.py:1036
 msgid "Choose a file name to save the image (no need to add extension)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/histogram.py:436
-#: ../gui/wxpython/gui_modules/mapdisp.py:1175
+#: ../gui/wxpython/gui_modules/mapdisp.py:1183
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:938
 msgid "Print preview"
 msgstr "Tampilan cetak"
@@ -5575,16 +5598,16 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:137
-#: ../gui/wxpython/gui_modules/gdialogs.py:1005
+#: ../gui/wxpython/gui_modules/gdialogs.py:1006
 #, fuzzy
 msgid "Command dialog"
 msgstr "Pengaturan dialog perintah"
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:138
-#: ../gui/wxpython/gui_modules/gdialogs.py:1161
-#: ../gui/wxpython/gui_modules/gdialogs.py:1163
-#: ../gui/wxpython/gui_modules/gdialogs.py:1168
-#: ../gui/wxpython/gui_modules/gdialogs.py:1170
+#: ../gui/wxpython/gui_modules/gdialogs.py:1162
+#: ../gui/wxpython/gui_modules/gdialogs.py:1164
+#: ../gui/wxpython/gui_modules/gdialogs.py:1169
+#: ../gui/wxpython/gui_modules/gdialogs.py:1171
 msgid "Open %s dialog"
@@ -5595,7 +5618,6 @@
 #: ../gui/wxpython/gui_modules/mcalc_builder.py:142
-#: ../gui/wxpython/gui_modules/gdialogs.py:739
 #, fuzzy
 msgid "&Load"
 msgstr "Memuat"
@@ -5769,6 +5791,40 @@
 msgid "Unknow tag"
 msgstr "tidak diketahui"
+#: ../gui/wxpython/gui_modules/gpyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:47
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gpyshell.py:97
+msgid "Raster or vector map <%s> not found"
+msgstr "ERROR: Mapset <%s> tidak ada"
+#: ../gui/wxpython/gui_modules/gpyshell.py:104
+msgid "Raster map <%s> added"
+#: ../gui/wxpython/gui_modules/gpyshell.py:106
+msgid "Vector map <%s> added"
+msgstr "Peta vektor baru"
 #: ../gui/wxpython/gui_modules/dbm_dialogs.py:67
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2998
 msgid "Database connection is not defined in DB file."
@@ -5836,7 +5892,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2279
 #: ../gui/wxpython/gui_modules/dbm.py:2387
 #: ../gui/wxpython/gui_modules/dbm.py:2642
-#: ../gui/wxpython/gui_modules/gdialogs.py:1352
+#: ../gui/wxpython/gui_modules/gdialogs.py:1353
 msgid "Layer"
 msgstr "Layer"
@@ -5870,16 +5926,16 @@
 msgstr "Tipe peta untuk georektifikasi"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:328
-#: ../gui/wxpython/gui_modules/gmodeler.py:3560
+#: ../gui/wxpython/gui_modules/gmodeler.py:3554
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2028
-#: ../gui/wxpython/gui_modules/layertree.py:791
+#: ../gui/wxpython/gui_modules/layertree.py:787
 msgid "raster"
 msgstr "raster"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3561
+#: ../gui/wxpython/gui_modules/gmodeler.py:3555
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:2029
-#: ../gui/wxpython/gui_modules/layertree.py:812
+#: ../gui/wxpython/gui_modules/layertree.py:808
 msgid "vector"
 msgstr "vektor "
@@ -5981,13 +6037,13 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1110
-#: ../gui/wxpython/gui_modules/toolbars.py:416
+#: ../gui/wxpython/gui_modules/toolbars.py:398
 #, fuzzy
 msgid "source"
 msgstr "Cost surface"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1112
 msgid "target"
 msgstr ""
@@ -6192,14 +6248,14 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2371
 #: ../gui/wxpython/gui_modules/profile.py:1033
 #: ../gui/wxpython/gui_modules/profile.py:1388
-#: ../gui/wxpython/gui_modules/preferences.py:961
+#: ../gui/wxpython/gui_modules/preferences.py:966
 msgid "Apply changes for the current session"
 msgstr "Terapkan perubahan untuk sesi saat ini"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2373
 #: ../gui/wxpython/gui_modules/profile.py:1038
 #: ../gui/wxpython/gui_modules/profile.py:1390
-#: ../gui/wxpython/gui_modules/preferences.py:963
+#: ../gui/wxpython/gui_modules/preferences.py:968
 msgid ""
 "Apply and save changes to user settings file (default for next sessions)"
 msgstr ""
@@ -6208,7 +6264,7 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2375
 #: ../gui/wxpython/gui_modules/ogc_services.py:77
-#: ../gui/wxpython/gui_modules/gdialogs.py:995
+#: ../gui/wxpython/gui_modules/gdialogs.py:996
 #, fuzzy
 msgid "Close dialog"
@@ -6239,12 +6295,14 @@
 msgstr "Pengaturan simbol"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2438
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1307
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:809
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1403
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1522
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:326
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:547
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3098
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3203
-#: ../gui/wxpython/gui_modules/preferences.py:1683
+#: ../gui/wxpython/gui_modules/preferences.py:1705
 msgid "Color:"
 msgstr "Warna: "
@@ -6325,16 +6383,16 @@
 msgstr "Pengaturan profil disimpan ke dalam berkas '%s'."
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:90
-#: ../gui/wxpython/gui_modules/mapdisp.py:771
-#: ../gui/wxpython/gui_modules/mapdisp.py:803
-#: ../gui/wxpython/gui_modules/mapdisp.py:874
-#: ../gui/wxpython/gui_modules/mapdisp.py:1027
+#: ../gui/wxpython/gui_modules/mapdisp.py:779
+#: ../gui/wxpython/gui_modules/mapdisp.py:811
+#: ../gui/wxpython/gui_modules/mapdisp.py:882
+#: ../gui/wxpython/gui_modules/mapdisp.py:1035
 msgid "Projection not defined (check the settings)"
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:107
-#: ../gui/wxpython/gui_modules/mapdisp.py:918
-#: ../gui/wxpython/gui_modules/mapdisp.py:1044
+#: ../gui/wxpython/gui_modules/mapdisp.py:926
+#: ../gui/wxpython/gui_modules/mapdisp.py:1052
 msgid "Error in projection (check the settings)"
 msgstr ""
@@ -6363,7 +6421,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp_window.py:1718
 #: ../gui/wxpython/gui_modules/gcmd.py:89
-#: ../gui/wxpython/gui_modules/workspace.py:1000
+#: ../gui/wxpython/gui_modules/workspace.py:1007
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:424
 #: ../gui/wxpython/gui_modules/dbm.py:2357
 msgid "Warning"
@@ -6420,7 +6478,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:178
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:184
-#: ../gui/wxpython/gui_modules/preferences.py:1471
+#: ../gui/wxpython/gui_modules/preferences.py:1493
 msgid "Constrain display resolution to computational settings"
 msgstr "Batas resolusi display sesuai pengaturan komputasi"
@@ -6434,8 +6492,8 @@
 "untuk tampilan peta baru dapat diatur di dalam dialog 'User GUI setting'."
 #: ../gui/wxpython/gui_modules/mapdisp.py:210
-#: ../gui/wxpython/gui_modules/mapdisp.py:1062
-#: ../gui/wxpython/gui_modules/mapdisp.py:1065
+#: ../gui/wxpython/gui_modules/mapdisp.py:1070
+#: ../gui/wxpython/gui_modules/mapdisp.py:1073
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:216
 #, fuzzy
 msgid "Use defined projection"
@@ -6461,8 +6519,8 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:301
 #: ../gui/wxpython/gui_modules/mapdisp.py:312
 #: ../gui/wxpython/gui_modules/mapdisp.py:362
-#: ../gui/wxpython/gui_modules/mapdisp.py:507
-#: ../gui/wxpython/gui_modules/toolbars.py:201
+#: ../gui/wxpython/gui_modules/mapdisp.py:513
+#: ../gui/wxpython/gui_modules/toolbars.py:204
 #: ../gui/wxpython/gui_modules/layertree.py:582
 msgid "2D view"
 msgstr ""
@@ -6488,86 +6546,86 @@
 "Details: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:381
+#: ../gui/wxpython/gui_modules/mapdisp.py:386
 #, fuzzy
 msgid "Starting 3D view mode..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:382
+#: ../gui/wxpython/gui_modules/mapdisp.py:387
 #, fuzzy
 msgid "Please wait, loading data..."
-#: ../gui/wxpython/gui_modules/mapdisp.py:414
+#: ../gui/wxpython/gui_modules/mapdisp.py:420
 #, fuzzy
 msgid "3D View Toolbar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:438
+#: ../gui/wxpython/gui_modules/mapdisp.py:444
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:348
 msgid "Map Toolbar"
-#: ../gui/wxpython/gui_modules/mapdisp.py:455
+#: ../gui/wxpython/gui_modules/mapdisp.py:461
 #, fuzzy
 msgid "Georectification Toolbar"
 msgstr "Toolbar Georektifikasi"
-#: ../gui/wxpython/gui_modules/mapdisp.py:517
+#: ../gui/wxpython/gui_modules/mapdisp.py:523
 #: ../gui/wxpython/gui_modules/render.py:420
 #, python-format
 msgid "GRASS module '%s' not found. Unable to start map display window."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1127
+#: ../gui/wxpython/gui_modules/mapdisp.py:1135
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:890
 #, fuzzy
 msgid "Nothing to render (empty map). Operation canceled."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1300
+#: ../gui/wxpython/gui_modules/mapdisp.py:1308
 #, fuzzy
 msgid "No raster or vector map layer selected for querying."
 msgstr "Tidak ada peta vektor terpilih untuk kueri."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1301
+#: ../gui/wxpython/gui_modules/mapdisp.py:1309
 #, fuzzy
 msgid "No map layer selected"
 msgstr "Tidak ada layer peta yang dipilih untuk kueri."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1396
+#: ../gui/wxpython/gui_modules/mapdisp.py:1404
 msgid "No vector map selected for querying."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1397
 #: ../gui/wxpython/gui_modules/mapdisp.py:1405
+#: ../gui/wxpython/gui_modules/mapdisp.py:1413
 msgid "Vector querying"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1404
+#: ../gui/wxpython/gui_modules/mapdisp.py:1412
 msgid "Only vector map from the current mapset can be modified."
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1476
+#: ../gui/wxpython/gui_modules/mapdisp.py:1484
 #, fuzzy
 msgid "Query surface (raster map)"
 msgstr "Tumpang-susun peta raster"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1483
+#: ../gui/wxpython/gui_modules/mapdisp.py:1491
 #, fuzzy
 msgid "Query vector map"
 msgstr "Tumpang-susun peta vektor"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1491
+#: ../gui/wxpython/gui_modules/mapdisp.py:1499
 msgid "Query raster/vector map(s) (display mode)"
 msgstr "Kueri peta raster/vektor (mode display)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1507
+#: ../gui/wxpython/gui_modules/mapdisp.py:1515
 #, fuzzy
 msgid "Query vector map (edit mode)"
 msgstr "Kueri peta vektor (mode edit)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1633
+#: ../gui/wxpython/gui_modules/mapdisp.py:1641
 #, python-format
 msgid ""
 "Click and drag with left mouse button to measure.%sDouble click with left "
@@ -6576,88 +6634,88 @@
 "Klik dan geser dengan tombol kiri tetikus untuk mengukur.%sKlik ganda dengan "
 "tombol kiri untuk membersihkan."
-#: ../gui/wxpython/gui_modules/mapdisp.py:1639
+#: ../gui/wxpython/gui_modules/mapdisp.py:1647
 msgid "Measuring distance"
 msgstr "Pengukuran jarak"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1642
+#: ../gui/wxpython/gui_modules/mapdisp.py:1650
 msgid "Measuring distance:"
 msgstr "Pengukuran jarak:"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1652
+#: ../gui/wxpython/gui_modules/mapdisp.py:1660
 #, python-format
 msgid ""
 "Geodesic distance is not yet supported by this tool.\n"
 "Reason: %s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1681
-#: ../gui/wxpython/gui_modules/mapdisp.py:1687
+#: ../gui/wxpython/gui_modules/mapdisp.py:1690
+#: ../gui/wxpython/gui_modules/mapdisp.py:1696
 #, fuzzy
 msgid "segment"
 msgstr "Legenda"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1682
-#: ../gui/wxpython/gui_modules/mapdisp.py:1688
+#: ../gui/wxpython/gui_modules/mapdisp.py:1691
+#: ../gui/wxpython/gui_modules/mapdisp.py:1697
 #, fuzzy
 msgid "total distance"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1683
+#: ../gui/wxpython/gui_modules/mapdisp.py:1692
 #, fuzzy
 msgid "bearing"
 msgstr "Peringatan"
 msgid "deg"
 msgstr ""
-#: ../gui/wxpython/gui_modules/mapdisp.py:1819
+#: ../gui/wxpython/gui_modules/mapdisp.py:1828
 msgid "Scale and North arrow"
 msgstr "Skala dan arah Utara"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1825
+#: ../gui/wxpython/gui_modules/mapdisp.py:1834
 msgid "Show/hide scale and North arrow"
 msgstr "Tampilkan/sembunyikan skala dan arah Utara"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1826
+#: ../gui/wxpython/gui_modules/mapdisp.py:1835
 msgid "scale object"
 msgstr "skala obyek"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1855
+#: ../gui/wxpython/gui_modules/mapdisp.py:1864
 msgid "Show/hide legend"
 msgstr "Tampilkan/sembunyikan legenda"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1856
+#: ../gui/wxpython/gui_modules/mapdisp.py:1865
 msgid "legend object"
 msgstr "legenda obyek"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1965
+#: ../gui/wxpython/gui_modules/mapdisp.py:1974
 #, fuzzy
 msgid "Zoom to computational region"
 msgstr "Perbesaran ke computational region (g.region)"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1969
+#: ../gui/wxpython/gui_modules/mapdisp.py:1978
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1058
 msgid "Zoom to default region"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1973
+#: ../gui/wxpython/gui_modules/mapdisp.py:1982
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1062
 msgid "Zoom to saved region"
 msgstr "Perbesaran sesuai dengan region tersimpan"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1977
+#: ../gui/wxpython/gui_modules/mapdisp.py:1986
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1066
 msgid "Set computational region from display"
 msgstr "Set region komputasi berdasarkan tampilan"
-#: ../gui/wxpython/gui_modules/mapdisp.py:1981
+#: ../gui/wxpython/gui_modules/mapdisp.py:1990
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:1070
 msgid "Save display geometry to named region"
 msgstr "Simpan geometri tampilan ke region tertentu"
-#: ../gui/wxpython/gui_modules/mapdisp.py:2075
+#: ../gui/wxpython/gui_modules/mapdisp.py:2084
 msgid "GRASS GIS Map Display: "
@@ -6722,12 +6780,12 @@
 msgid "Unsupported feature type %d. Operation cancelled."
 msgstr "Nilai koordinat tidak valid. Operasi dibatalkan."
-#: ../gui/wxpython/gui_modules/wxvdigit.py:455
+#: ../gui/wxpython/gui_modules/wxvdigit.py:456
 #, fuzzy, python-format
 msgid "Unknown feature type '%s'"
 msgstr "ID Fitur"
-#: ../gui/wxpython/gui_modules/wxvdigit.py:460
+#: ../gui/wxpython/gui_modules/wxvdigit.py:461
 #, fuzzy
 msgid "Not enough points for line"
 msgstr "Buat titik sepanjang garis"
@@ -6786,7 +6844,7 @@
 msgstr "Tidak mampu menjalankan perintah, perintah lainnya sedang berjalan ..."
 #: ../gui/wxpython/gui_modules/ghelp.py:340
-#: ../gui/wxpython/gui_modules/goutput.py:629
+#: ../gui/wxpython/gui_modules/goutput.py:641
 #, python-format
 msgid "%d modules match"
 msgstr ""
@@ -6852,11 +6910,11 @@
 #: ../gui/wxpython/gui_modules/ghelp.py:702
 #: ../gui/wxpython/gui_modules/ghelp.py:761
-#: ../gui/wxpython/gui_modules/gmodeler.py:3548
-#: ../gui/wxpython/gui_modules/gmodeler.py:3588
-#: ../gui/wxpython/gui_modules/gmodeler.py:3856
-#: ../gui/wxpython/gui_modules/gmodeler.py:3964
-#: ../gui/wxpython/gui_modules/gmodeler.py:4282
+#: ../gui/wxpython/gui_modules/gmodeler.py:3542
+#: ../gui/wxpython/gui_modules/gmodeler.py:3582
+#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3958
+#: ../gui/wxpython/gui_modules/gmodeler.py:4276
 #, fuzzy
 msgid "Name"
 msgstr "Ubah nama "
@@ -6897,7 +6955,7 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ghelp.py:815
-#: ../gui/wxpython/gui_modules/gdialogs.py:959
+#: ../gui/wxpython/gui_modules/gdialogs.py:960
 #, fuzzy
 msgid "Options"
 msgstr "Opsional"
@@ -6957,8 +7015,8 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1507
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3295
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3480
-#: ../gui/wxpython/gui_modules/gdialogs.py:1258
-#: ../gui/wxpython/gui_modules/menuform.py:1691
+#: ../gui/wxpython/gui_modules/gdialogs.py:1259
+#: ../gui/wxpython/gui_modules/menuform.py:1684
 msgid "Browse"
 msgstr "Jelajah "
@@ -7036,8 +7094,8 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:874
 #: ../gui/wxpython/gui_modules/location_wizard.py:1037
 #: ../gui/wxpython/gui_modules/location_wizard.py:1302
-#: ../gui/wxpython/gui_modules/gmodeler.py:3549
-#: ../gui/wxpython/gui_modules/gmodeler.py:3608
+#: ../gui/wxpython/gui_modules/gmodeler.py:3543
+#: ../gui/wxpython/gui_modules/gmodeler.py:3602
 msgid "Description"
 msgstr "Deskripsi"
@@ -7143,7 +7201,7 @@
 msgstr "Path ke berkas kode EPSG"
 #: ../gui/wxpython/gui_modules/location_wizard.py:1286
-#: ../gui/wxpython/gui_modules/preferences.py:1814
+#: ../gui/wxpython/gui_modules/preferences.py:1836
 msgid "EPSG code:"
 msgstr "Kode EPSG:"
@@ -7417,7 +7475,7 @@
 msgstr "Pilih peta vektor"
 #: ../gui/wxpython/gui_modules/vclean.py:168
-#: ../gui/wxpython/gui_modules/menuform.py:832
+#: ../gui/wxpython/gui_modules/menuform.py:833
 #, fuzzy
 msgid "Copy the current command string to the clipboard (Ctrl+C)"
 msgstr "Salin perintah saat ini ke clipboard"
@@ -7506,318 +7564,310 @@
 msgid "Vector cleaning command copied to clipboard"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:70
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:48
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:55
+#: ../gui/wxpython/gui_modules/nviz_tools.py:136
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:52
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:59
 msgid "View"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:74
-#: ../gui/wxpython/gui_modules/gmodeler.py:3154
+#: ../gui/wxpython/gui_modules/gmodeler.py:3148
 #, fuzzy
 msgid "Data"
 msgstr "Basisdata"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:78
-#: ../gui/wxpython/gui_modules/preferences.py:1236
+#: ../gui/wxpython/gui_modules/nviz_tools.py:144
+#: ../gui/wxpython/gui_modules/preferences.py:1240
 msgid "Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:112
+#: ../gui/wxpython/gui_modules/nviz_tools.py:216
 msgid "Control View"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:120
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1146
+#: ../gui/wxpython/gui_modules/nviz_tools.py:226
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1360
 msgid "W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:122
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1148
+#: ../gui/wxpython/gui_modules/nviz_tools.py:227
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1362
 #, fuzzy
 msgid "N"
 msgstr "N:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:129
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1155
+#: ../gui/wxpython/gui_modules/nviz_tools.py:228
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1369
 msgid "S"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:131
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+#: ../gui/wxpython/gui_modules/nviz_tools.py:229
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1371
 #, fuzzy
 msgid "E"
 msgstr "E:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:140
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:64
+#: ../gui/wxpython/gui_modules/nviz_tools.py:230
 #, fuzzy
+msgid "NW"
+msgstr "N:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:231
+#, fuzzy
+msgid "NE"
+msgstr "N:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:232
+#, fuzzy
+msgid "SE"
+msgstr "E:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:233
+msgid "SW"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:68
+#, fuzzy
 msgid "Perspective:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:150
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:143
+#: ../gui/wxpython/gui_modules/nviz_tools.py:273
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:147
 #, fuzzy
 msgid "Twist:"
 msgstr "Daftar "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:168
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1167
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:124
-#: ../gui/wxpython/gui_modules/gmodeler.py:3128
-#: ../gui/wxpython/gui_modules/gmodeler.py:3247
+#: ../gui/wxpython/gui_modules/nviz_tools.py:290
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1381
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:128
+#: ../gui/wxpython/gui_modules/gmodeler.py:3122
+#: ../gui/wxpython/gui_modules/gmodeler.py:3241
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4038
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4181
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4829
-#: ../gui/wxpython/gui_modules/gdialogs.py:1634
+#: ../gui/wxpython/gui_modules/gdialogs.py:1635
 #, fuzzy
 msgid "Height:"
 msgstr "Berat:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:175
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:173
+#: ../gui/wxpython/gui_modules/nviz_tools.py:296
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:177
 msgid "Z-exag:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:189
-msgid "Look at:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:309
+msgid "Look:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+#: ../gui/wxpython/gui_modules/nviz_tools.py:312
 #, fuzzy
-msgid "top"
-msgstr "Atas"
+msgid "here"
+msgstr "Vertex"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:195
+#: ../gui/wxpython/gui_modules/nviz_tools.py:318
 #, fuzzy
-msgid "north"
-msgstr "Utara"
+msgid "center"
+msgstr "Render"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:196
+#: ../gui/wxpython/gui_modules/nviz_tools.py:324
 #, fuzzy
-msgid "south"
-msgstr "Selatan"
+msgid "top"
+msgstr "Atas"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:197
+#: ../gui/wxpython/gui_modules/nviz_tools.py:330
 #, fuzzy
-msgid "east"
+msgid "reset"
 msgstr "Barat"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:198
+#: ../gui/wxpython/gui_modules/nviz_tools.py:331
 #, fuzzy
-msgid "west"
-msgstr "Barat"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:199
-msgid "north-west"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:200
-msgid "north-east"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:201
-msgid "south-east"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:202
-msgid "south-west"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:210
-#, fuzzy
-msgid "Reset"
-msgstr "Barat"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:211
-#, fuzzy
 msgid "Reset to default view"
 msgstr "Kembalikan aturan ke standar"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:233
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:205
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:209
 msgid "Image Appearance"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:240
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:212
-#: ../gui/wxpython/gui_modules/preferences.py:1452
+#: ../gui/wxpython/gui_modules/nviz_tools.py:357
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:217
+#: ../gui/wxpython/gui_modules/preferences.py:1474
 #, fuzzy
 msgid "Background color:"
 msgstr "Background peta vektor"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:272
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1256
+#: ../gui/wxpython/gui_modules/nviz_tools.py:394
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1471
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:353
 #, fuzzy
 msgid "Surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:277
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:237
+#: ../gui/wxpython/gui_modules/nviz_tools.py:400
+#: ../gui/wxpython/gui_modules/nviz_tools.py:757
 #, fuzzy
+msgid "Constant surface"
+msgstr "Cost surface"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:405
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:457
+#, fuzzy
 msgid "Vector"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:282
+#: ../gui/wxpython/gui_modules/nviz_tools.py:411
 #, fuzzy
 msgid "Volume"
 msgstr "Volume"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:298
+#: ../gui/wxpython/gui_modules/nviz_tools.py:435
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:243
 #, fuzzy
 msgid "Lighting"
 msgstr "Penyorotan"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:302
+#: ../gui/wxpython/gui_modules/nviz_tools.py:440
 #, fuzzy
 msgid "Fringe"
 msgstr "Garis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:342
-#, fuzzy
-msgid "Surface attributes"
-msgstr "Ubah atribut"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:349
-msgid "Topography"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:350
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1026
-#: ../gui/wxpython/gui_modules/profile.py:1222
-msgid "Color"
-msgstr "Warna"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:352
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1028
-#, fuzzy
-msgid "Transparency"
-msgstr "Transparans"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:353
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1029
-msgid "Shininess"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:354
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1030
-msgid "Emission"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:360
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1038
-msgid "map"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:363
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1043
-msgid "unset"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:368
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1048
-msgid "constant"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:428
-#: ../gui/wxpython/gui_modules/nviz_tools.py:915
+#: ../gui/wxpython/gui_modules/nviz_tools.py:488
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1126
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:362
 msgid "Draw"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:435
-#: ../gui/wxpython/gui_modules/nviz_tools.py:922
+#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1133
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:368
 #, fuzzy
 msgid "Mode:"
 msgstr "Mode"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:438
+#: ../gui/wxpython/gui_modules/nviz_tools.py:498
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:371
 msgid "coarse"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:439
+#: ../gui/wxpython/gui_modules/nviz_tools.py:499
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:372
 #, fuzzy
 msgid "fine"
 msgstr "Garis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:440
+#: ../gui/wxpython/gui_modules/nviz_tools.py:500
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:373
 #, fuzzy
 msgid "both"
 msgstr "Utara"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:450
-#: ../gui/wxpython/gui_modules/nviz_tools.py:936
+#: ../gui/wxpython/gui_modules/nviz_tools.py:509
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1147
 #, fuzzy
 msgid "Shading:"
 msgstr "Snapping"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:453
-#: ../gui/wxpython/gui_modules/nviz_tools.py:709
-#: ../gui/wxpython/gui_modules/nviz_tools.py:939
+#: ../gui/wxpython/gui_modules/nviz_tools.py:512
+#: ../gui/wxpython/gui_modules/nviz_tools.py:920
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1150
 msgid "flat"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:454
-#: ../gui/wxpython/gui_modules/nviz_tools.py:940
+#: ../gui/wxpython/gui_modules/nviz_tools.py:513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1151
 msgid "gouraud"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:462
+#: ../gui/wxpython/gui_modules/nviz_tools.py:521
 #, fuzzy
 msgid "Set to all"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:463
+#: ../gui/wxpython/gui_modules/nviz_tools.py:522
 msgid "Use draw settings for all loaded surfaces"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:470
+#: ../gui/wxpython/gui_modules/nviz_tools.py:529
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:400
 #, fuzzy
-msgid "Coarse:"
+msgid "Coarse mode:"
 msgstr "Bentuk garis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:474
-#: ../gui/wxpython/gui_modules/nviz_tools.py:524
-msgid "res."
-msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:572
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:387
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:404
+#, fuzzy
+msgid "resolution:"
+msgstr "Resolusi Atas-Bawah"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:492
+#: ../gui/wxpython/gui_modules/nviz_tools.py:545
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:416
 #, fuzzy
-msgid "style"
+msgid "style:"
 msgstr "Gaya"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:495
+#: ../gui/wxpython/gui_modules/nviz_tools.py:548
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:419
 msgid "wire"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:549
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:420
 #, fuzzy
 msgid "surface"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:505
+#: ../gui/wxpython/gui_modules/nviz_tools.py:561
 #, fuzzy
-msgid "wire color"
+msgid "Change wire color"
 msgstr "Warna garis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:519
+#: ../gui/wxpython/gui_modules/nviz_tools.py:568
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:383
 #, fuzzy
-msgid "Fine:"
+msgid "Fine mode:"
 msgstr "Garis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:554
-msgid "Mask zeros:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:593
+#, fuzzy
+msgid "Surface attributes"
+msgstr "Ubah atribut"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:601
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1237
+#: ../gui/wxpython/gui_modules/profile.py:1222
+msgid "Color"
+msgstr "Warna"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:603
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1239
+#, fuzzy
+msgid "Transparency"
+msgstr "Transparans"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:604
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1240
+msgid "Shininess"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:558
-msgid "by elevation"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:610
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1249
+msgid "map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:563
-#, fuzzy
-msgid "by color"
-msgstr "Y coord"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:613
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1254
+msgid "unset"
+msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:578
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1259
+msgid "constant"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:671
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4008
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4577
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4793
@@ -7827,175 +7877,215 @@
 msgid "Position"
 msgstr "Deskripsi"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:653
+#: ../gui/wxpython/gui_modules/nviz_tools.py:686
 #, fuzzy
+msgid "Reset"
+msgstr "Barat"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:687
+#, fuzzy
+msgid "Reset to default position"
+msgstr "Kembalikan aturan ke standar"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:785
+#, fuzzy
+msgid "Fine resolution:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:797
+#, fuzzy
+msgid "Value:"
+msgstr "Volume"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:863
+#, fuzzy
 msgid "Show vector lines"
 msgstr "Pilih garis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:663
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:245
+#: ../gui/wxpython/gui_modules/nviz_tools.py:873
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:465
 #, fuzzy
 msgid "Vector lines"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:669
+#: ../gui/wxpython/gui_modules/nviz_tools.py:880
 #, fuzzy
 msgid "Line:"
 msgstr "Garis"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:672
-#: ../gui/wxpython/gui_modules/nviz_tools.py:805
+#: ../gui/wxpython/gui_modules/nviz_tools.py:883
 #, fuzzy
-msgid "width"
+msgid "width:"
 msgstr "Lebar:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:688
-#: ../gui/wxpython/gui_modules/nviz_tools.py:790
+#: ../gui/wxpython/gui_modules/nviz_tools.py:899
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1001
 #, fuzzy
-msgid "color"
+msgid "color:"
 msgstr "Warna: "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:703
-#, fuzzy
-msgid "display"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:914
+#: ../gui/wxpython/gui_modules/vdigit.py:158
+msgid "Display"
 msgstr "Tampilan"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:708
+#: ../gui/wxpython/gui_modules/nviz_tools.py:919
 #, fuzzy
-msgid "on surface"
+msgid "on surface(s):"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:718
-#: ../gui/wxpython/gui_modules/nviz_tools.py:836
+#: ../gui/wxpython/gui_modules/nviz_tools.py:929
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1050
 msgid "Height above surface:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:754
+#: ../gui/wxpython/gui_modules/nviz_tools.py:964
 #, fuzzy
 msgid "Show vector points"
 msgstr "IDW dari peta vektor"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:763
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:973
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:487
 #, fuzzy
 msgid "Vector points"
 msgstr "Titik perturbasi"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:769
+#: ../gui/wxpython/gui_modules/nviz_tools.py:980
 #, fuzzy
 msgid "Icon:"
 msgstr "Tema ikon:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:772
+#: ../gui/wxpython/gui_modules/nviz_tools.py:983
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
 #, fuzzy
-msgid "size"
+msgid "size:"
 msgstr "Ukuran"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:823
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1016
 #, fuzzy
-msgid "symbol"
+msgid "width"
+msgstr "Lebar:"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1033
+#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
+#, fuzzy
+msgid "symbol:"
 msgstr "Simbolisasi"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:892
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1046
 #, fuzzy
+msgid "Display on surface(s):"
+msgstr "Jarak sepanjang transek"
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
+#, fuzzy
 msgid "3D raster map"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:925
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1136
 #, fuzzy
 msgid "isosurfaces"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:926
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1137
 msgid "slides"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:949
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1160
 #, fuzzy
 msgid "Resolution:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:971
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
 #, fuzzy
 msgid "List of isosurfaces"
 msgstr "Daftar layer"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1019
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1230
 #, fuzzy
 msgid "Isosurface attributes"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1025
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1236
 msgid "Topography level"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1130
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1241
+msgid "Emission"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1342
 #, fuzzy
 msgid "Show light model"
 msgstr "Garis aliran "
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1135
-msgid "Follow source viewpoint"
-msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1141
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1355
 #, fuzzy
 msgid "Light source position"
 msgstr "Pilih sumber location:"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1185
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1399
 msgid "Light color and intensity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1199
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1413
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:299
 #, fuzzy
 msgid "Brightness:"
 msgstr "Keragaman"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1209
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1423
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
 msgid "Ambient:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1270
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1485
 msgid "Edges with fringe"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1272
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1487
 msgid "N && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1273
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1488
 msgid "N && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1274
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1489
 msgid "S && W"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1275
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1490
 msgid "S && E"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:1295
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1510
 msgid "Elevation of fringe from bottom:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2309
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2311
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1563
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1608
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1186
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1204
+msgid "constant#"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2667
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2669
 msgid "Level"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2632
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3003
 #, fuzzy
 msgid "Vector map is 3D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2635
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3006
 #, fuzzy
 msgid "Vector map is 2D"
-#: ../gui/wxpython/gui_modules/nviz_tools.py:2637
+#: ../gui/wxpython/gui_modules/nviz_tools.py:3008
 #, python-format
 msgid "%(features)d features (%(points)d points)"
 msgstr ""
@@ -8021,8 +8111,8 @@
 #: ../gui/wxpython/gui_modules/ogc_services.py:69
-#: ../gui/wxpython/gui_modules/gdialogs.py:1153
-#: ../gui/wxpython/gui_modules/gdialogs.py:1263
+#: ../gui/wxpython/gui_modules/gdialogs.py:1154
+#: ../gui/wxpython/gui_modules/gdialogs.py:1264
 #, fuzzy
 msgid "Add imported layers into layer tree"
 msgstr "Tampilkan layer peta ke dalam layer tree"
@@ -8037,14 +8127,14 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/ogc_services.py:85
-#: ../gui/wxpython/gui_modules/gdialogs.py:998
-#: ../gui/wxpython/gui_modules/gdialogs.py:1165
+#: ../gui/wxpython/gui_modules/gdialogs.py:999
+#: ../gui/wxpython/gui_modules/gdialogs.py:1166
 msgid "&Import"
 msgstr ""
 #: ../gui/wxpython/gui_modules/ogc_services.py:86
-#: ../gui/wxpython/gui_modules/gdialogs.py:999
-#: ../gui/wxpython/gui_modules/gdialogs.py:1166
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/gdialogs.py:1167
 #, fuzzy
 msgid "Import selected layers"
 msgstr "Hapus layer terpilih"
@@ -8064,17 +8154,17 @@
 msgid "Layers"
 msgstr "Layer"
-#: ../gui/wxpython/gui_modules/prompt.py:393
+#: ../gui/wxpython/gui_modules/prompt.py:394
 msgid "Warning: flag <%(flag)s> not found in '%(module)s'"
 msgstr "ERROR: Location <%s> tidak ada"
-#: ../gui/wxpython/gui_modules/prompt.py:396
+#: ../gui/wxpython/gui_modules/prompt.py:397
 msgid "Warning: option <%(param)s> not found in '%(module)s'"
-#: ../gui/wxpython/gui_modules/prompt.py:617
+#: ../gui/wxpython/gui_modules/prompt.py:618
 msgid "Type GRASS command and run by pressing ENTER"
 msgstr "Ketikkan perintah GRASS dan jalankan dengan menekan ENTER"
@@ -8099,7 +8189,7 @@
 msgstr "Nama kolom"
 #: ../gui/wxpython/gui_modules/gselect.py:1083
-#: ../gui/wxpython/gui_modules/menuform.py:1690
+#: ../gui/wxpython/gui_modules/menuform.py:1683
 msgid "File"
 msgstr "Berkas"
@@ -8185,7 +8275,7 @@
 #: ../gui/wxpython/gui_modules/gselect.py:1285
-#: ../gui/wxpython/gui_modules/gmodeler.py:3331
+#: ../gui/wxpython/gui_modules/gmodeler.py:3325
 #, fuzzy
 msgid "Name:"
 msgstr "Ubah nama "
@@ -8204,70 +8294,81 @@
 msgid "Unable to save settings."
 msgstr "Tidak mampu mengeset"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:29
 #, fuzzy
 msgid "3D view settings"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:67
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:146
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:176
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:71
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:150
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:180
 #, fuzzy
 msgid "(value)"
 msgstr "Tetapkan nilai"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:79
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:127
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:158
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:187
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:83
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:131
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:162
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:191
 #, fuzzy
 msgid "(step)"
 msgstr "Tahapan"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:94
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:98
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:258
 #, fuzzy
 msgid "Position:"
 msgstr "Proyeksi:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:97
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:101
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:261
 msgid "(x)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:252
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:249
 #, fuzzy
+msgid "Light"
+msgstr "Penyorotan"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:285
+msgid "(z)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:431
+#, fuzzy
+msgid "wire color:"
+msgstr "Warna garis"
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
+#, fuzzy
 msgid "Show lines"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:274
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:494
 #, fuzzy
 msgid "Show points"
 msgstr "Perlihatkan pengaturan "
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:283
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:503
 #, fuzzy
 msgid "Size:"
 msgstr "Ukuran"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:298
-#: ../gui/wxpython/gui_modules/gmodeler.py:3110
-#: ../gui/wxpython/gui_modules/gmodeler.py:3229
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:518
+#: ../gui/wxpython/gui_modules/gmodeler.py:3104
+#: ../gui/wxpython/gui_modules/gmodeler.py:3223
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4026
-#: ../gui/wxpython/gui_modules/gdialogs.py:1630
+#: ../gui/wxpython/gui_modules/gdialogs.py:1631
 msgid "Width:"
 msgstr "Lebar:"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:313
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:533
 #, fuzzy
 msgid "Marker:"
 msgstr "Layer"
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:403
+#: ../gui/wxpython/gui_modules/nviz_preferences.py:695
-msgid "Nviz settings saved to file <%s>."
-msgstr "Pengesetan disimpan pada berkas '%s'."
-#: ../gui/wxpython/gui_modules/nviz_preferences.py:472
-#, fuzzy, python-format
 msgid "3D view settings saved to file <%s>."
@@ -8283,8 +8384,8 @@
 #: ../gui/wxpython/gui_modules/gcmd.py:349
 #: ../gui/wxpython/gui_modules/render.py:627
 #: ../gui/wxpython/gui_modules/render.py:630
-#: ../gui/wxpython/gui_modules/menuform.py:2167
-#: ../gui/wxpython/gui_modules/menuform.py:2170
+#: ../gui/wxpython/gui_modules/menuform.py:2160
+#: ../gui/wxpython/gui_modules/menuform.py:2163
 msgid "Details:"
 msgstr "Deil:"
@@ -8309,23 +8410,19 @@
 "Tutup dialog dan simpan perubahan ke dalam berkas pengaturan milik pengguna"
 #: ../gui/wxpython/gui_modules/vdigit.py:92
-#: ../gui/wxpython/gui_modules/gmodeler.py:3319
+#: ../gui/wxpython/gui_modules/gmodeler.py:3313
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1703
 #: ../gui/wxpython/gui_modules/profile.py:1040
 #: ../gui/wxpython/gui_modules/profile.py:1393
-#: ../gui/wxpython/gui_modules/preferences.py:966
+#: ../gui/wxpython/gui_modules/preferences.py:971
 msgid "Close dialog and ignore changes"
 msgstr "Tutup dialog dan abaikan perubahan"
 #: ../gui/wxpython/gui_modules/vdigit.py:151
-#: ../gui/wxpython/gui_modules/preferences.py:1104
+#: ../gui/wxpython/gui_modules/preferences.py:1109
 msgid "General"
 msgstr "Umum"
-#: ../gui/wxpython/gui_modules/vdigit.py:158
-msgid "Display"
-msgstr "Tampilan"
 #: ../gui/wxpython/gui_modules/vdigit.py:163
 #: ../gui/wxpython/gui_modules/profile.py:1174
 msgid "Line width"
@@ -8437,7 +8534,7 @@
 msgstr "Pilih dangle"
 #: ../gui/wxpython/gui_modules/vdigit.py:377
-#: ../gui/wxpython/gui_modules/preferences.py:1669
+#: ../gui/wxpython/gui_modules/preferences.py:1691
 msgid "Attributes"
 msgstr "Atribut"
@@ -8610,20 +8707,20 @@
 "Nomor layer harus lebih besar dari nol."
 #: ../gui/wxpython/gui_modules/vdigit.py:1060
-#: ../gui/wxpython/gui_modules/gmodeler.py:3785
-#: ../gui/wxpython/gui_modules/gmodeler.py:4142
+#: ../gui/wxpython/gui_modules/gmodeler.py:3779
+#: ../gui/wxpython/gui_modules/gmodeler.py:4136
 msgid "Delete selected"
 msgstr "Hapus yang terpilih"
 #: ../gui/wxpython/gui_modules/vdigit.py:1064
-#: ../gui/wxpython/gui_modules/gmodeler.py:3786
-#: ../gui/wxpython/gui_modules/gmodeler.py:4143
+#: ../gui/wxpython/gui_modules/gmodeler.py:3780
+#: ../gui/wxpython/gui_modules/gmodeler.py:4137
 msgid "Delete all"
 msgstr "Hapus semua"
 #: ../gui/wxpython/gui_modules/vdigit.py:1066
-#: ../gui/wxpython/gui_modules/gmodeler.py:3792
-#: ../gui/wxpython/gui_modules/gmodeler.py:4150
+#: ../gui/wxpython/gui_modules/gmodeler.py:3786
+#: ../gui/wxpython/gui_modules/gmodeler.py:4144
 #: ../gui/wxpython/gui_modules/dbm.py:1146
 #: ../gui/wxpython/gui_modules/dbm.py:1659
 msgid "Reload"
@@ -8718,6 +8815,11 @@
 msgid "Preview generated"
 msgstr ""
+#: ../gui/wxpython/gui_modules/psmap.py:353
+#, fuzzy
+msgid "Save file as"
+msgstr "Simpan berkas sebagai ..."
 #: ../gui/wxpython/gui_modules/psmap.py:392
 msgid "Failed to read file %s."
@@ -8733,25 +8835,25 @@
 msgid "Scalebar is not appropriate for this projection"
 msgstr "Masukkan parameter untuk"
-#: ../gui/wxpython/gui_modules/psmap.py:861
+#: ../gui/wxpython/gui_modules/psmap.py:860
 #, fuzzy
 msgid "wxGUI Hardcopy Map Utility"
-#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/psmap.py:862
 msgid ""
 "(C) 2011 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:864
-#: ../gui/wxpython/gui_modules/gmodeler.py:1236
+#: ../gui/wxpython/gui_modules/psmap.py:863
+#: ../gui/wxpython/gui_modules/gmodeler.py:1230
 msgid ""
 "This program is free software under the GNU General Public License(>=v2). "
 "Read the file COPYING that comes with GRASS for details."
 msgstr ""
-#: ../gui/wxpython/gui_modules/psmap.py:1095
+#: ../gui/wxpython/gui_modules/psmap.py:1094
 msgid "Click and drag to resize object"
 msgstr ""
@@ -8879,7 +8981,7 @@
 #: ../gui/wxpython/gui_modules/gmodeler.py:451
-#: ../gui/wxpython/gui_modules/gmodeler.py:574
+#: ../gui/wxpython/gui_modules/gmodeler.py:568
 #, fuzzy
 msgid "Variables"
 msgstr "Volume"
@@ -8889,55 +8991,55 @@
 msgid "GRASS GIS Graphical Modeler"
 msgstr "Bantuan GRASS GIS GUI"
-#: ../gui/wxpython/gui_modules/gmodeler.py:572
+#: ../gui/wxpython/gui_modules/gmodeler.py:566
 #, fuzzy
 msgid "Model"
 msgstr "Mode"
-#: ../gui/wxpython/gui_modules/gmodeler.py:573
+#: ../gui/wxpython/gui_modules/gmodeler.py:567
 msgid "Items"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:642
+#: ../gui/wxpython/gui_modules/gmodeler.py:636
 #, fuzzy
 msgid "Redrawing model..."
 msgstr "Rentang yang valid"
-#: ../gui/wxpython/gui_modules/gmodeler.py:669
+#: ../gui/wxpython/gui_modules/gmodeler.py:663
 #, fuzzy
 msgid "Do you want to save changes in the model?"
 msgstr "Apakah Anda ingin menyimpan perubahan dalam peta vektor <%s>?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:671
+#: ../gui/wxpython/gui_modules/gmodeler.py:665
 #, fuzzy
 msgid "Do you want to store current model settings to model file?"
 msgstr ""
 "Workspace tidak kosong. Apakah Anda hendak menyimpan pengaturan saat ini ke "
 "berkas workspace?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:738
+#: ../gui/wxpython/gui_modules/gmodeler.py:732
 #: ../gui/wxpython/gui_modules/dbm.py:2084
 #, fuzzy
 msgid "Nothing to delete."
 msgstr "Tidak ada yang dapat diekstrak."
-#: ../gui/wxpython/gui_modules/gmodeler.py:742
+#: ../gui/wxpython/gui_modules/gmodeler.py:736
 msgid "Do you want to permanently delete data?%s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:743
+#: ../gui/wxpython/gui_modules/gmodeler.py:737
 #, fuzzy
 msgid "Delete intermediate data?"
 msgstr "Hapus yang tersaring"
-#: ../gui/wxpython/gui_modules/gmodeler.py:757
+#: ../gui/wxpython/gui_modules/gmodeler.py:751
 msgid "%d maps deleted from current mapset"
 msgstr "Hapus berkas elemen basis data dari mapset saat ini milik pengguna."
-#: ../gui/wxpython/gui_modules/gmodeler.py:772
-#: ../gui/wxpython/gui_modules/gmodeler.py:885
+#: ../gui/wxpython/gui_modules/gmodeler.py:766
+#: ../gui/wxpython/gui_modules/gmodeler.py:879
 #, fuzzy
 msgid ""
 "Current model is not empty. Do you want to store current settings to model "
@@ -8946,52 +9048,52 @@
 "berkas workspace?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:775
-#: ../gui/wxpython/gui_modules/gmodeler.py:888
+#: ../gui/wxpython/gui_modules/gmodeler.py:769
+#: ../gui/wxpython/gui_modules/gmodeler.py:882
 #, fuzzy
 msgid "Create new model?"
 msgstr "Buat mapset baru"
-#: ../gui/wxpython/gui_modules/gmodeler.py:800
+#: ../gui/wxpython/gui_modules/gmodeler.py:794
 #, fuzzy
 msgid "Choose model file"
 msgstr "Pilih berkas kode EPSG"
-#: ../gui/wxpython/gui_modules/gmodeler.py:818
+#: ../gui/wxpython/gui_modules/gmodeler.py:812
 #, python-format
 msgid "%(items)d items (%(actions)d actions) loaded into model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:825
-#: ../gui/wxpython/gui_modules/gmodeler.py:862
+#: ../gui/wxpython/gui_modules/gmodeler.py:819
+#: ../gui/wxpython/gui_modules/gmodeler.py:856
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
 msgstr "Berkas Workspace <%s> sudah ada. Anda ingin menimpanya?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:835
-#: ../gui/wxpython/gui_modules/gmodeler.py:875
+#: ../gui/wxpython/gui_modules/gmodeler.py:829
+#: ../gui/wxpython/gui_modules/gmodeler.py:869
 msgid "File <%s> saved"
 msgstr "Berkas POINTS <%s> berhasil disimpan"
-#: ../gui/wxpython/gui_modules/gmodeler.py:844
+#: ../gui/wxpython/gui_modules/gmodeler.py:838
 #, fuzzy
 msgid "Choose file to save current model"
 msgstr "Pilih berkas untuk menyimpan workspace saat ini"
-#: ../gui/wxpython/gui_modules/gmodeler.py:864
+#: ../gui/wxpython/gui_modules/gmodeler.py:858
 msgid "File already exists"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:912
+#: ../gui/wxpython/gui_modules/gmodeler.py:906
 msgid "Model is empty. Nothing to run."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:999
+#: ../gui/wxpython/gui_modules/gmodeler.py:993
 msgid "Model is empty. Nothing to validate."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1006
+#: ../gui/wxpython/gui_modules/gmodeler.py:1000
 #, python-format
 msgid ""
 "Model is not valid.\n"
@@ -8999,46 +9101,46 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1009
+#: ../gui/wxpython/gui_modules/gmodeler.py:1003
 msgid "Model is valid."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1070
-#: ../gui/wxpython/gui_modules/gmodeler.py:1113
+#: ../gui/wxpython/gui_modules/gmodeler.py:1064
+#: ../gui/wxpython/gui_modules/gmodeler.py:1107
 #, python-format
 msgid "Model exported to <%s>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1078
+#: ../gui/wxpython/gui_modules/gmodeler.py:1072
 #, fuzzy
 msgid "Choose file to save"
 msgstr "Pilih berkas GRC untuk dimuat"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1080
+#: ../gui/wxpython/gui_modules/gmodeler.py:1074
 msgid "Python script (*.py)|*.py"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1094
+#: ../gui/wxpython/gui_modules/gmodeler.py:1088
 msgid "File <%s> already exists. Do you want to overwrite this file?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1096
+#: ../gui/wxpython/gui_modules/gmodeler.py:1090
 #, fuzzy
 msgid "Save file"
-#: ../gui/wxpython/gui_modules/gmodeler.py:1233
+#: ../gui/wxpython/gui_modules/gmodeler.py:1227
 msgid "wxGUI Graphical Modeler"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1235
+#: ../gui/wxpython/gui_modules/gmodeler.py:1229
 msgid ""
 "(C) 2010 by the GRASS Development Team\n"
 "\n"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:1366
+#: ../gui/wxpython/gui_modules/gmodeler.py:1360
 msgid ""
 "Reading model file <%s> failed.\n"
@@ -9047,105 +9149,105 @@
 "Gagal dalam pembacaan berkas workspace <%s>. Berkas tidak valid, tidak mampu "
 "membaca dokumen XML."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1372
+#: ../gui/wxpython/gui_modules/gmodeler.py:1366
 #, fuzzy
 msgid "Please wait, loading model..."
 msgstr "Silakan tunggu, sedang menampilkan data atribut ..."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1427
+#: ../gui/wxpython/gui_modules/gmodeler.py:1421
 #, fuzzy
 msgid "Writing current settings to model file failed."
 msgstr "Penulisan pengaturan saat ini ke berkas workspace gagal (%s)."
-#: ../gui/wxpython/gui_modules/gmodeler.py:1728
-#: ../gui/wxpython/gui_modules/gmodeler.py:1785
-#: ../gui/wxpython/gui_modules/gmodeler.py:1912
-#: ../gui/wxpython/gui_modules/menuform.py:384
+#: ../gui/wxpython/gui_modules/gmodeler.py:1722
+#: ../gui/wxpython/gui_modules/gmodeler.py:1779
+#: ../gui/wxpython/gui_modules/gmodeler.py:1906
+#: ../gui/wxpython/gui_modules/menuform.py:385
 msgid "unknown"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2010
+#: ../gui/wxpython/gui_modules/gmodeler.py:2004
 msgid "<not defined>"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2020
+#: ../gui/wxpython/gui_modules/gmodeler.py:2014
 #, fuzzy
 msgid "Data properties"
 msgstr "Karakteristik"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2027
+#: ../gui/wxpython/gui_modules/gmodeler.py:2021
 #, fuzzy
 msgid "Name of raster map:"
 msgstr "Peta raster hasil kode-ulang:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2029
+#: ../gui/wxpython/gui_modules/gmodeler.py:2023
 #, fuzzy
 msgid "Name of vector map:"
 msgstr "Nama untuk peta vektor baru:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2031
+#: ../gui/wxpython/gui_modules/gmodeler.py:2025
 #, fuzzy
 msgid "Name of element:"
 msgstr "Ubah nama mapset"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2224
+#: ../gui/wxpython/gui_modules/gmodeler.py:2218
 #: ../gui/wxpython/gui_modules/layertree.py:272
 msgid "Remove"
 msgstr "Hapus"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2228
+#: ../gui/wxpython/gui_modules/gmodeler.py:2222
 #, fuzzy
 msgid "Disable"
 msgstr "Daftar tabel"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2231
+#: ../gui/wxpython/gui_modules/gmodeler.py:2225
 #, fuzzy
 msgid "Enable"
 msgstr "Tabel"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2236
+#: ../gui/wxpython/gui_modules/gmodeler.py:2230
 #, fuzzy
 msgid "Add control point"
 msgstr "Ground Control Point"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2238
+#: ../gui/wxpython/gui_modules/gmodeler.py:2232
 #, fuzzy
 msgid "Remove control point"
 msgstr "Hilangkan outlier dalam titik"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2245
+#: ../gui/wxpython/gui_modules/gmodeler.py:2239
 msgid "Intermediate"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2256
+#: ../gui/wxpython/gui_modules/gmodeler.py:2250
 #: ../gui/wxpython/gui_modules/layertree.py:286
 msgid "Properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2260
+#: ../gui/wxpython/gui_modules/gmodeler.py:2254
 #, fuzzy
 msgid "Change ID"
 msgstr "Buat mapset"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2316
+#: ../gui/wxpython/gui_modules/gmodeler.py:2310
 msgid "Add new GRASS module to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2334
-#: ../gui/wxpython/gui_modules/gmodeler.py:3857
-#: ../gui/wxpython/gui_modules/gmodeler.py:4283
-#: ../gui/wxpython/gui_modules/preferences.py:1518
+#: ../gui/wxpython/gui_modules/gmodeler.py:2328
+#: ../gui/wxpython/gui_modules/gmodeler.py:3851
+#: ../gui/wxpython/gui_modules/gmodeler.py:4277
+#: ../gui/wxpython/gui_modules/preferences.py:1540
 msgid "Command"
 msgstr "Perintah"
-#: ../gui/wxpython/gui_modules/gmodeler.py:2402
+#: ../gui/wxpython/gui_modules/gmodeler.py:2396
 msgid ""
 "Command not defined.\n"
 "\n"
 "Unable to add new action to the model."
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:2408
+#: ../gui/wxpython/gui_modules/gmodeler.py:2402
 #, python-format
 msgid ""
 "'%s' is not a GRASS module.\n"
@@ -9153,196 +9255,196 @@
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3018
+#: ../gui/wxpython/gui_modules/gmodeler.py:3012
 #, fuzzy
 msgid "Action"
 msgstr "Arah"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3023
+#: ../gui/wxpython/gui_modules/gmodeler.py:3017
 msgid "Validity"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3031
+#: ../gui/wxpython/gui_modules/gmodeler.py:3025
 msgid "Valid:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3048
+#: ../gui/wxpython/gui_modules/gmodeler.py:3042
 #, fuzzy
 msgid "Invalid:"
 msgstr "Nilai tidak valid: %s"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3065
+#: ../gui/wxpython/gui_modules/gmodeler.py:3059
 msgid "Running:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3082
+#: ../gui/wxpython/gui_modules/gmodeler.py:3076
 #, fuzzy
 msgid "Disabled:"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3102
-#: ../gui/wxpython/gui_modules/gmodeler.py:3221
+#: ../gui/wxpython/gui_modules/gmodeler.py:3096
+#: ../gui/wxpython/gui_modules/gmodeler.py:3215
 #, fuzzy
 msgid "Shape size"
 msgstr "Indeks bentuk "
-#: ../gui/wxpython/gui_modules/gmodeler.py:3159
+#: ../gui/wxpython/gui_modules/gmodeler.py:3153
 #: ../gui/wxpython/gui_modules/profile.py:1252
 msgid "Type"
 msgstr "Tipe"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3167
+#: ../gui/wxpython/gui_modules/gmodeler.py:3161
 #, fuzzy
 msgid "Raster:"
 msgstr "Raster"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3184
+#: ../gui/wxpython/gui_modules/gmodeler.py:3178
 #, fuzzy
 msgid "3D raster:"
 msgstr "raster"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3201
+#: ../gui/wxpython/gui_modules/gmodeler.py:3195
 #, fuzzy
 msgid "Vector:"
 msgstr "Vektor"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3295
+#: ../gui/wxpython/gui_modules/gmodeler.py:3289
 #: ../gui/wxpython/gui_modules/layertree.py:374
 #: ../gui/wxpython/gui_modules/layertree.py:407
 msgid "Metadata"
 msgstr "Metadata"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3297
+#: ../gui/wxpython/gui_modules/gmodeler.py:3291
 #, fuzzy
 msgid "Commands"
 msgstr "Perintah"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3317
+#: ../gui/wxpython/gui_modules/gmodeler.py:3311
 #, fuzzy
 msgid "Apply properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3340
+#: ../gui/wxpython/gui_modules/gmodeler.py:3334
 #, fuzzy
 msgid "Description:"
 msgstr "Deskripsi"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3349
+#: ../gui/wxpython/gui_modules/gmodeler.py:3343
 msgid "Author(s):"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3398
+#: ../gui/wxpython/gui_modules/gmodeler.py:3392
 #, fuzzy
 msgid "Model parameters"
 msgstr "Parameter medan"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3545
+#: ../gui/wxpython/gui_modules/gmodeler.py:3539
 #, fuzzy
 msgid "List of variables - right-click to delete"
 msgstr "Tabel %s - klik-kanan untuk menghapus rekaman"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3595
+#: ../gui/wxpython/gui_modules/gmodeler.py:3589
 #: ../gui/wxpython/gui_modules/dbm.py:885
 #: ../gui/wxpython/gui_modules/dbm.py:2226
 msgid "Data type"
 msgstr "Tipe data"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3601
+#: ../gui/wxpython/gui_modules/gmodeler.py:3595
 #, fuzzy
 msgid "Default value"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3553
+#: ../gui/wxpython/gui_modules/gmodeler.py:3547
 #, fuzzy
 msgid "Add new variable"
 msgstr "Tambahkan sebuah vertex baru"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3557
+#: ../gui/wxpython/gui_modules/gmodeler.py:3551
 #, fuzzy
 msgid "integer"
 msgstr "Pointer"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3558
+#: ../gui/wxpython/gui_modules/gmodeler.py:3552
 msgid "float"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3559
+#: ../gui/wxpython/gui_modules/gmodeler.py:3553
 #, fuzzy
 msgid "string"
 msgstr "Tiling "
-#: ../gui/wxpython/gui_modules/gmodeler.py:3567
+#: ../gui/wxpython/gui_modules/gmodeler.py:3561
 msgid "Add new variable to the model"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3715
+#: ../gui/wxpython/gui_modules/gmodeler.py:3709
 msgid "Variable <%s> already exists in the model. Adding variable failed."
 msgstr ""
 "Tidak dapat membuat sebuah tabel baru. Nama tabel atau nama kolom kunci "
 "tidak dapat ditemukan "
-#: ../gui/wxpython/gui_modules/gmodeler.py:3744
+#: ../gui/wxpython/gui_modules/gmodeler.py:3738
 #, fuzzy
 msgid "Do you want to delete all variables from the model?"
 msgstr "Apakah Anda hendak menghapus layer peta terpilih dari layer tree?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3746
+#: ../gui/wxpython/gui_modules/gmodeler.py:3740
 #, fuzzy
 msgid "Delete variables"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3826
+#: ../gui/wxpython/gui_modules/gmodeler.py:3820
 #, fuzzy
 msgid "Condition: "
 msgstr "Opsional"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3828
+#: ../gui/wxpython/gui_modules/gmodeler.py:3822
 msgid "Condition: not defined"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3850
+#: ../gui/wxpython/gui_modules/gmodeler.py:3844
 #, fuzzy
 msgid "Condition"
 msgstr "Opsional"
 msgid "ID"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3898
+#: ../gui/wxpython/gui_modules/gmodeler.py:3892
 msgid "loop"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3906
+#: ../gui/wxpython/gui_modules/gmodeler.py:3900
 #, fuzzy
 msgid "Loop properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3912
+#: ../gui/wxpython/gui_modules/gmodeler.py:3906
 #, fuzzy
 msgid "List of items in loop"
 msgstr "Daftar kategori"
-#: ../gui/wxpython/gui_modules/gmodeler.py:3961
+#: ../gui/wxpython/gui_modules/gmodeler.py:3955
 #, fuzzy
 msgid "List of items - right-click to delete"
 msgid "In block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:3965
+#: ../gui/wxpython/gui_modules/gmodeler.py:3959
 #, fuzzy
 msgid "Command / Condition"
 msgstr "Pengaturan dialog perintah"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4092
+#: ../gui/wxpython/gui_modules/gmodeler.py:4086
 #: ../gui/wxpython/gui_modules/dbm.py:1178
 #, python-format
 msgid ""
@@ -9352,39 +9454,39 @@
 "Rekaman data terpilih (%d) akan dihapus secara permanen dari tabel. Anda "
 "benar-benar ingin menghapusnya?"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4095
+#: ../gui/wxpython/gui_modules/gmodeler.py:4089
 #: ../gui/wxpython/gui_modules/dbm.py:1181
 #: ../gui/wxpython/gui_modules/dbm.py:1227
 msgid "Delete records"
 msgstr "Hapus rekap"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4149
+#: ../gui/wxpython/gui_modules/gmodeler.py:4143
 msgid "Normalize"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4247
+#: ../gui/wxpython/gui_modules/gmodeler.py:4241
 msgid "if-else"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4268
+#: ../gui/wxpython/gui_modules/gmodeler.py:4262
 #, fuzzy
 msgid "If-else properties"
-#: ../gui/wxpython/gui_modules/gmodeler.py:4274
+#: ../gui/wxpython/gui_modules/gmodeler.py:4268
 msgid "List of items in 'if' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gmodeler.py:4279
+#: ../gui/wxpython/gui_modules/gmodeler.py:4273
 msgid "List of items in 'else' block"
 msgstr ""
-#: ../gui/wxpython/gui_modules/workspace.py:983
+#: ../gui/wxpython/gui_modules/workspace.py:990
 #, python-format
 msgid "Unable to open file <%s> for reading."
 msgstr "Tidak mampu membuka berkas <%s> untuk dibaca."
-#: ../gui/wxpython/gui_modules/workspace.py:996
+#: ../gui/wxpython/gui_modules/workspace.py:1003
 msgid ""
 "Some lines were skipped when reading settings from file <%(file)s>.\n"
@@ -9397,7 +9499,7 @@
 "\n"
 "Jumlah baris yang diabaikan: %d"
-#: ../gui/wxpython/gui_modules/workspace.py:1214
+#: ../gui/wxpython/gui_modules/workspace.py:1221
 #, python-format
 msgid " row %d:"
 msgstr " baris %d:"
@@ -9499,7 +9601,7 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:1640
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4906
-#: ../gui/wxpython/gui_modules/preferences.py:2163
+#: ../gui/wxpython/gui_modules/preferences.py:2185
 #, fuzzy
 msgid "Font size:"
 msgstr "Tema ikon:"
@@ -9844,11 +9946,6 @@
 msgid "Size and style"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3285
-#, fuzzy
-msgid "symbol:"
-msgstr "Simbolisasi"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3291
 #, fuzzy
 msgid "eps file:"
@@ -9872,11 +9969,6 @@
 msgid "Size"
 msgstr "Ukuran"
-#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3320
-#, fuzzy
-msgid "size:"
-msgstr "Ukuran"
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:3322
 #, fuzzy
 msgid "size from map table column:"
@@ -10084,9 +10176,9 @@
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:4596
 #: ../gui/wxpython/gui_modules/psmap_dialogs.py:5081
 #: ../gui/wxpython/gui_modules/profile.py:967
-#: ../gui/wxpython/gui_modules/preferences.py:1240
-#: ../gui/wxpython/gui_modules/preferences.py:1372
-#: ../gui/wxpython/gui_modules/preferences.py:2114
+#: ../gui/wxpython/gui_modules/preferences.py:1244
+#: ../gui/wxpython/gui_modules/preferences.py:1394
+#: ../gui/wxpython/gui_modules/preferences.py:2136
 msgid "Font settings"
 msgstr "Jenis huruf"
@@ -10404,11 +10496,11 @@
 "layer instead."
 msgstr ""
-#: ../gui/wxpython/gui_modules/goutput.py:606
+#: ../gui/wxpython/gui_modules/goutput.py:605
 msgid "Save file as..."
-#: ../gui/wxpython/gui_modules/goutput.py:721
+#: ../gui/wxpython/gui_modules/goutput.py:733
 #, fuzzy
 msgid ""
 "Please note that the data are left in inconsistent state and may be corrupted"
@@ -10416,149 +10508,149 @@
 "Harap dicatat bahwa data dibiarkan dalam tahap inkonsisten dan bisa menjadi "
 "rusak"
-#: ../gui/wxpython/gui_modules/goutput.py:724
+#: ../gui/wxpython/gui_modules/goutput.py:736
 msgid "Command aborted"
 msgstr "Perintah dibatalkan"
-#: ../gui/wxpython/gui_modules/goutput.py:732
+#: ../gui/wxpython/gui_modules/goutput.py:744
 #, fuzzy
 msgid "Command finished"
 msgstr "Perintah berhasil dijalankan (%d detik)"
-#: ../gui/wxpython/gui_modules/wxnviz.py:302
+#: ../gui/wxpython/gui_modules/wxnviz.py:327
 msgid "Vector map <%s> not found"
 msgstr "ERROR: Mapset <%s> tidak ada"
-#: ../gui/wxpython/gui_modules/wxnviz.py:354
-#: ../gui/wxpython/gui_modules/wxnviz.py:366
+#: ../gui/wxpython/gui_modules/wxnviz.py:392
+#: ../gui/wxpython/gui_modules/wxnviz.py:404
 msgid "3d raster map <%s> not found"
-#: ../gui/wxpython/gui_modules/toolbars.py:211
+#: ../gui/wxpython/gui_modules/toolbars.py:217
 msgid "3D view mode not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:212
-#: ../gui/wxpython/gui_modules/toolbars.py:229
+#: ../gui/wxpython/gui_modules/toolbars.py:218
+#: ../gui/wxpython/gui_modules/toolbars.py:235
 msgid "Reason: %s"
 msgstr "Region "
-#: ../gui/wxpython/gui_modules/toolbars.py:213
+#: ../gui/wxpython/gui_modules/toolbars.py:219
 msgid ""
 "Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
 "(hopefully this will be fixed soon). Please keep an eye out for updated "
 "versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:221
-#: ../gui/wxpython/gui_modules/toolbars.py:1162
+#: ../gui/wxpython/gui_modules/toolbars.py:227
+#: ../gui/wxpython/gui_modules/toolbars.py:1108
 #, fuzzy
 msgid "Digitize"
 msgstr "Digitasi garis baru "
-#: ../gui/wxpython/gui_modules/toolbars.py:228
+#: ../gui/wxpython/gui_modules/toolbars.py:234
 #, fuzzy
 msgid "Vector digitizer not available"
 msgstr "Toolbar digitasi vektor"
-#: ../gui/wxpython/gui_modules/toolbars.py:230
+#: ../gui/wxpython/gui_modules/toolbars.py:236
 msgid ""
 "Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
 "will be fixed soon). Please keep an eye out for updated versions of GRASS. "
 "In the meantime you can use \"v.digit\" from the Develop Vector menu."
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:421
+#: ../gui/wxpython/gui_modules/toolbars.py:403
 msgid "Set map canvas for "
 msgstr ""
-#: ../gui/wxpython/gui_modules/toolbars.py:423
+#: ../gui/wxpython/gui_modules/toolbars.py:405
 #, fuzzy
 msgid " / Zoom to map"
 msgstr "Perbesaran sesuai peta terpilih "
-#: ../gui/wxpython/gui_modules/toolbars.py:790
+#: ../gui/wxpython/gui_modules/toolbars.py:737
 #, fuzzy
 msgid "Duplicate attributes"
 msgstr "Perbaharui atribut"
-#: ../gui/wxpython/gui_modules/toolbars.py:867
+#: ../gui/wxpython/gui_modules/toolbars.py:814
 msgid "Copy features from (background) vector map"
 msgstr "Salin fitur dari peta vektor (background)"
-#: ../gui/wxpython/gui_modules/toolbars.py:875
+#: ../gui/wxpython/gui_modules/toolbars.py:822
 msgid "Flip selected lines/boundaries"
 msgstr "Balikkan garis/batas terpilih"
-#: ../gui/wxpython/gui_modules/toolbars.py:883
+#: ../gui/wxpython/gui_modules/toolbars.py:830
 msgid "Merge selected lines/boundaries"
 msgstr "Gabungkan garis/batas terpilih"
-#: ../gui/wxpython/gui_modules/toolbars.py:891
+#: ../gui/wxpython/gui_modules/toolbars.py:838
 msgid "Break selected lines/boundaries at intersection"
 msgstr "Potong garis/batas terpilih pada interseksi"
-#: ../gui/wxpython/gui_modules/toolbars.py:899
+#: ../gui/wxpython/gui_modules/toolbars.py:846
 msgid "Snap selected lines/boundaries (only to nodes)"
 msgstr "Tarik garis/batas terpilih (hanya ke simpul)"
-#: ../gui/wxpython/gui_modules/toolbars.py:907
+#: ../gui/wxpython/gui_modules/toolbars.py:854
 msgid "Connect selected lines/boundaries"
 msgstr "Hubungkan garis/batas terpilih"
-#: ../gui/wxpython/gui_modules/toolbars.py:915
+#: ../gui/wxpython/gui_modules/toolbars.py:862
 #, fuzzy
 msgid "Query features"
 msgstr "Fitur terdekat"
-#: ../gui/wxpython/gui_modules/toolbars.py:923
+#: ../gui/wxpython/gui_modules/toolbars.py:870
 msgid "Z bulk-labeling of 3D lines"
 msgstr "Pelabelan Z dari garis 3D"
-#: ../gui/wxpython/gui_modules/toolbars.py:931
+#: ../gui/wxpython/gui_modules/toolbars.py:878
 msgid "Feature type conversion"
 msgstr "Konversi tipe fitur"
-#: ../gui/wxpython/gui_modules/toolbars.py:1042
+#: ../gui/wxpython/gui_modules/toolbars.py:989
 #, fuzzy
 msgid "Vector map is not 3D. Operation canceled."
 msgstr "Tidak ada layer peta terpilih. Operasi digagalkan."
-#: ../gui/wxpython/gui_modules/toolbars.py:1107
-#: ../gui/wxpython/gui_modules/toolbars.py:1189
-#: ../gui/wxpython/gui_modules/toolbars.py:1268
+#: ../gui/wxpython/gui_modules/toolbars.py:1053
+#: ../gui/wxpython/gui_modules/toolbars.py:1135
+#: ../gui/wxpython/gui_modules/toolbars.py:1214
 msgid "Select vector map"
-#: ../gui/wxpython/gui_modules/toolbars.py:1145
+#: ../gui/wxpython/gui_modules/toolbars.py:1091
 msgid "Please wait, opening vector map <%s> for editing..."
 msgstr "Tidak ada peta vektor yang dipilih untuk diubah."
-#: ../gui/wxpython/gui_modules/toolbars.py:1197
+#: ../gui/wxpython/gui_modules/toolbars.py:1143
 #, python-format
 msgid "Do you want to save changes in vector map <%s>?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1199
+#: ../gui/wxpython/gui_modules/toolbars.py:1145
 msgid "Save changes?"
 msgstr "Simpan perubahan?"
-#: ../gui/wxpython/gui_modules/toolbars.py:1206
+#: ../gui/wxpython/gui_modules/toolbars.py:1152
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
 msgstr "Tool untuk membersihkan topologi peta vektor."
-#: ../gui/wxpython/gui_modules/toolbars.py:1217
+#: ../gui/wxpython/gui_modules/toolbars.py:1163
 msgid "Editing of vector map <%s> successfully finished"
 msgstr "Tutup dialog di akhir perintah"
-#: ../gui/wxpython/gui_modules/toolbars.py:1274
-#: ../gui/wxpython/gui_modules/toolbars.py:1279
+#: ../gui/wxpython/gui_modules/toolbars.py:1220
+#: ../gui/wxpython/gui_modules/toolbars.py:1225
 msgid "New vector map"
 msgstr "Peta vektor baru"
@@ -10833,7 +10925,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1117
-#: ../gui/wxpython/gui_modules/preferences.py:626
+#: ../gui/wxpython/gui_modules/preferences.py:642
 msgid "Edit selected record"
 msgstr "Edit rekap terpilih"
@@ -10851,14 +10943,14 @@
 msgstr "Hapus semua rekap"
 #: ../gui/wxpython/gui_modules/dbm.py:1129
-#: ../gui/wxpython/gui_modules/gdialogs.py:861
-#: ../gui/wxpython/gui_modules/gdialogs.py:1389
+#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:1390
 msgid "Select all"
 msgstr "Pilih semua"
 #: ../gui/wxpython/gui_modules/dbm.py:1130
-#: ../gui/wxpython/gui_modules/gdialogs.py:863
-#: ../gui/wxpython/gui_modules/gdialogs.py:1390
+#: ../gui/wxpython/gui_modules/gdialogs.py:864
+#: ../gui/wxpython/gui_modules/gdialogs.py:1391
 msgid "Deselect all"
 msgstr "Tidak-pilih semua"
@@ -11164,7 +11256,7 @@
 msgstr "Perlihatkan tabel atribut"
 #: ../gui/wxpython/gui_modules/gdialogs.py:204
-#: ../gui/wxpython/gui_modules/preferences.py:1553
+#: ../gui/wxpython/gui_modules/preferences.py:1575
 #, fuzzy
 msgid "Add created map into layer tree"
@@ -11225,8 +11317,8 @@
 msgstr "Rotasi:"
 #: ../gui/wxpython/gui_modules/gdialogs.py:631
-#: ../gui/wxpython/gui_modules/preferences.py:1259
-#: ../gui/wxpython/gui_modules/preferences.py:1388
+#: ../gui/wxpython/gui_modules/preferences.py:1263
+#: ../gui/wxpython/gui_modules/preferences.py:1410
 msgid "Set font"
 msgstr "Tentukan jenis huruf"
@@ -11238,109 +11330,118 @@
 "Tarik teks dengan tetikus dalam mode pointer ke dalam posisi.\n"
 "Klik-ganda untuk merubah pilihan"
-#: ../gui/wxpython/gui_modules/gdialogs.py:768
+#: ../gui/wxpython/gui_modules/gdialogs.py:739
+msgid "&Add"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:741
+#, fuzzy
+msgid "Add selected map layers to current display"
+msgstr "Tambahkan layer peta raster"
+#: ../gui/wxpython/gui_modules/gdialogs.py:769
 msgid "Map layer type:"
 msgstr "Tipe layer peta:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:780
+#: ../gui/wxpython/gui_modules/gdialogs.py:781
 #, fuzzy
 msgid "Select toggle"
-#: ../gui/wxpython/gui_modules/gdialogs.py:787
+#: ../gui/wxpython/gui_modules/gdialogs.py:788
 msgid "Mapset:"
 msgstr "Mapset:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:797
+#: ../gui/wxpython/gui_modules/gdialogs.py:798
 msgid "Filter:"
 msgstr "Filter:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:809
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
 msgid "List of maps:"
 msgstr "Daftar peta:"
-#: ../gui/wxpython/gui_modules/gdialogs.py:862
+#: ../gui/wxpython/gui_modules/gdialogs.py:863
 #, fuzzy
 msgid "Invert selection"
 msgstr "Potongan melintang"
-#: ../gui/wxpython/gui_modules/gdialogs.py:936
+#: ../gui/wxpython/gui_modules/gdialogs.py:937
 #, fuzzy
 msgid "Multiple import"
 msgstr "Impor WMS"
-#: ../gui/wxpython/gui_modules/gdialogs.py:950
+#: ../gui/wxpython/gui_modules/gdialogs.py:951
 msgid " List of %s layers "
-#: ../gui/wxpython/gui_modules/gdialogs.py:1151
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
 #, fuzzy
 msgid "Add linked layers into layer tree"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1158
+#: ../gui/wxpython/gui_modules/gdialogs.py:1159
 #, fuzzy
 msgid "&Link"
 msgstr "Garis"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1159
+#: ../gui/wxpython/gui_modules/gdialogs.py:1160
 #, fuzzy
 msgid "Link selected layers"
 msgstr "Modifikasi layer terpilih"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1253
+#: ../gui/wxpython/gui_modules/gdialogs.py:1254
 msgid "Import DXF layers"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1257
+#: ../gui/wxpython/gui_modules/gdialogs.py:1258
 #, fuzzy
 msgid "Choose DXF file to import"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1353
+#: ../gui/wxpython/gui_modules/gdialogs.py:1354
 #, fuzzy
 msgid "Layer name"
 msgstr "Nama tabel"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1354
+#: ../gui/wxpython/gui_modules/gdialogs.py:1355
 #, fuzzy
 msgid "Name for GRASS map"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1436
+#: ../gui/wxpython/gui_modules/gdialogs.py:1437
 #, fuzzy
 msgid "Set Map Layer Opacity"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1460
+#: ../gui/wxpython/gui_modules/gdialogs.py:1461
 #, fuzzy
 msgid "transparent"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1463
+#: ../gui/wxpython/gui_modules/gdialogs.py:1464
 msgid "opaque"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1582
+#: ../gui/wxpython/gui_modules/gdialogs.py:1583
 msgid "Set image size"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1591
+#: ../gui/wxpython/gui_modules/gdialogs.py:1592
 #, fuzzy
 msgid "Image size"
 msgstr "Pengaturan halaman"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1638
+#: ../gui/wxpython/gui_modules/gdialogs.py:1639
 msgid "Template:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/gdialogs.py:1676
+#: ../gui/wxpython/gui_modules/gdialogs.py:1677
 #, fuzzy
 msgid "GRASS GIS SQL Query Utility"
 msgstr "GRASS GIS - Map display"
-#: ../gui/wxpython/gui_modules/gdialogs.py:1687
+#: ../gui/wxpython/gui_modules/gdialogs.py:1688
 #, fuzzy
 msgid " SQL statement "
 msgstr "Pernyataan SQL"
@@ -11638,57 +11739,57 @@
 msgstr "Grup layer:"
 #: ../gui/wxpython/gui_modules/layertree.py:743
-#: ../gui/wxpython/gui_modules/layertree.py:1310
+#: ../gui/wxpython/gui_modules/layertree.py:1309
 #, fuzzy
 msgid "Click to edit layer settings"
 msgstr "Klik di sini untuk menyembunyikan pengaturan 3D"
-#: ../gui/wxpython/gui_modules/layertree.py:788
+#: ../gui/wxpython/gui_modules/layertree.py:784
 msgid "(double click to set properties)"
 msgstr "(klik ganda untuk menentuk karakteristik)"
-#: ../gui/wxpython/gui_modules/layertree.py:794
+#: ../gui/wxpython/gui_modules/layertree.py:790
 #, fuzzy
 msgid "3d raster"
 msgstr "raster"
-#: ../gui/wxpython/gui_modules/layertree.py:797
+#: ../gui/wxpython/gui_modules/layertree.py:793
 msgid "RGB"
 msgstr "RGB"
-#: ../gui/wxpython/gui_modules/layertree.py:800
+#: ../gui/wxpython/gui_modules/layertree.py:796
 msgid "HIS"
 msgstr "HIS"
-#: ../gui/wxpython/gui_modules/layertree.py:806
+#: ../gui/wxpython/gui_modules/layertree.py:802
 msgid "raster cell numbers"
 msgstr "nomor sel raster"
-#: ../gui/wxpython/gui_modules/layertree.py:809
+#: ../gui/wxpython/gui_modules/layertree.py:805
 msgid "raster flow arrows"
 msgstr "panah aliran raster"
-#: ../gui/wxpython/gui_modules/layertree.py:815
+#: ../gui/wxpython/gui_modules/layertree.py:811
 msgid "thematic area (choropleth) map"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:818
+#: ../gui/wxpython/gui_modules/layertree.py:814
 msgid "thematic charts"
 msgstr "diagram tematik"
-#: ../gui/wxpython/gui_modules/layertree.py:821
+#: ../gui/wxpython/gui_modules/layertree.py:817
 msgid "grid"
 msgstr "grid"
-#: ../gui/wxpython/gui_modules/layertree.py:824
+#: ../gui/wxpython/gui_modules/layertree.py:820
 msgid "geodesic line"
 msgstr "garis geodesik"
-#: ../gui/wxpython/gui_modules/layertree.py:827
+#: ../gui/wxpython/gui_modules/layertree.py:823
 msgid "rhumbline"
 msgstr "rhumbline"
-#: ../gui/wxpython/gui_modules/layertree.py:830
+#: ../gui/wxpython/gui_modules/layertree.py:826
 msgid "vector labels"
 msgstr "label vektor"
@@ -11697,161 +11798,161 @@
 msgid "Please wait, updating data..."
-#: ../gui/wxpython/gui_modules/layertree.py:1389
+#: ../gui/wxpython/gui_modules/layertree.py:1388
 msgid "opacity:"
 msgstr ""
-#: ../gui/wxpython/gui_modules/layertree.py:1406
+#: ../gui/wxpython/gui_modules/layertree.py:1405
 msgid "Map <%s> not found."
-#: ../gui/wxpython/gui_modules/menuform.py:147
-#: ../gui/wxpython/gui_modules/menuform.py:1654
+#: ../gui/wxpython/gui_modules/menuform.py:148
+#: ../gui/wxpython/gui_modules/menuform.py:1647
 msgid "Select Color"
 msgstr "Pilih warna"
-#: ../gui/wxpython/gui_modules/menuform.py:451
+#: ../gui/wxpython/gui_modules/menuform.py:452
 #, python-format
 msgid "Parameter element '%(element)s' not found: '%(value)s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:472
+#: ../gui/wxpython/gui_modules/menuform.py:473
 #, python-format
 msgid "Flag not found: %s"
 msgstr "Flag tidak ditemukan: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:501
+#: ../gui/wxpython/gui_modules/menuform.py:502
 msgid "Parameter '%(name)s' (%(desc)s) is missing."
 msgstr "%(Nama) parameter (%(deskripsi)) tidak ada. \n"
-#: ../gui/wxpython/gui_modules/menuform.py:530
+#: ../gui/wxpython/gui_modules/menuform.py:531
 msgid "<required>"
 msgstr "<dibutuhkan>"
-#: ../gui/wxpython/gui_modules/menuform.py:797
+#: ../gui/wxpython/gui_modules/menuform.py:798
 #, fuzzy
 msgid "Enter parameters for '"
-#: ../gui/wxpython/gui_modules/menuform.py:808
+#: ../gui/wxpython/gui_modules/menuform.py:809
 msgid "Close this window without executing the command (Ctrl+Q)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:828
+#: ../gui/wxpython/gui_modules/menuform.py:829
 #, fuzzy
 msgid "Run the command (Ctrl+R)"
 msgstr "Jalankan perintah"
-#: ../gui/wxpython/gui_modules/menuform.py:831
+#: ../gui/wxpython/gui_modules/menuform.py:832
 #, fuzzy
 msgid "C&opy"
 msgstr "Salin "
-#: ../gui/wxpython/gui_modules/menuform.py:846
+#: ../gui/wxpython/gui_modules/menuform.py:847
 #, fuzzy
 msgid "Show manual page of the command (Ctrl+H)"
 msgstr "Tampilkan halaman manual dari perintah"
-#: ../gui/wxpython/gui_modules/menuform.py:867
+#: ../gui/wxpython/gui_modules/menuform.py:868
 #, fuzzy
 msgid "Add created map(s) into layer tree"
-#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:883
 msgid "Close dialog on finish"
-#: ../gui/wxpython/gui_modules/menuform.py:884
+#: ../gui/wxpython/gui_modules/menuform.py:885
 msgid ""
 "Close dialog when command is successfully finished. Change this settings in "
 "Preferences dialog ('Command' tab)."
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1059
+#: ../gui/wxpython/gui_modules/menuform.py:1060
 #, python-format
 msgid "'%s' copied to clipboard"
 msgstr "'%s' berhasil disalin ke clipboard"
-#: ../gui/wxpython/gui_modules/menuform.py:1121
-#: ../gui/wxpython/gui_modules/menuform.py:1134
+#: ../gui/wxpython/gui_modules/menuform.py:1122
+#: ../gui/wxpython/gui_modules/menuform.py:1135
 msgid "Required"
 msgstr "Dibutuhkan"
-#: ../gui/wxpython/gui_modules/menuform.py:1124
+#: ../gui/wxpython/gui_modules/menuform.py:1125
 msgid "Optional"
 msgstr "Opsional"
-#: ../gui/wxpython/gui_modules/menuform.py:1174
+#: ../gui/wxpython/gui_modules/menuform.py:1168
 msgid "Manual"
 msgstr "Manual"
-#: ../gui/wxpython/gui_modules/menuform.py:1215
-#: ../gui/wxpython/gui_modules/menuform.py:1726
+#: ../gui/wxpython/gui_modules/menuform.py:1208
+#: ../gui/wxpython/gui_modules/menuform.py:1719
 #, fuzzy
 msgid "Parameterized in model"
 msgstr "Parameter tidak ditemukan: %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1290
+#: ../gui/wxpython/gui_modules/menuform.py:1283
 msgid "[multiple]"
 msgstr "[berganda]"
-#: ../gui/wxpython/gui_modules/menuform.py:1337
+#: ../gui/wxpython/gui_modules/menuform.py:1330
 #, fuzzy
 msgid "valid range"
-#: ../gui/wxpython/gui_modules/menuform.py:1499
+#: ../gui/wxpython/gui_modules/menuform.py:1492
 msgid "Format"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:1501
+#: ../gui/wxpython/gui_modules/menuform.py:1494
 msgid "Native / Linked OGR"
 msgstr ""
 #, fuzzy
 msgid "Direct OGR"
 msgstr "Arah"
-#: ../gui/wxpython/gui_modules/menuform.py:1673
+#: ../gui/wxpython/gui_modules/menuform.py:1666
 msgid "Transparent"
-#: ../gui/wxpython/gui_modules/menuform.py:1689
+#: ../gui/wxpython/gui_modules/menuform.py:1682
 #, python-format
 msgid "Choose %s"
 msgstr "Pilih %s"
-#: ../gui/wxpython/gui_modules/menuform.py:1717
+#: ../gui/wxpython/gui_modules/menuform.py:1710
 #, fuzzy
 msgid "or enter values interactively"
 msgstr "Pengkodean-ulang secara interaktif "
-#: ../gui/wxpython/gui_modules/menuform.py:2133
+#: ../gui/wxpython/gui_modules/menuform.py:2126
 msgid "Error in %s"
 msgstr "Kesalahan "
-#: ../gui/wxpython/gui_modules/menuform.py:2166
-#: ../gui/wxpython/gui_modules/menuform.py:2169
+#: ../gui/wxpython/gui_modules/menuform.py:2159
+#: ../gui/wxpython/gui_modules/menuform.py:2162
 msgid "Unable to fetch interface description for command '%s'."
 msgstr "Tidak dapat mengambil deskripsi antarmuka untuk perintah '%s'."
-#: ../gui/wxpython/gui_modules/menuform.py:2280
+#: ../gui/wxpython/gui_modules/menuform.py:2276
 msgid "Unable to parse command '%s'"
 msgstr "Tidak dapat menganalisis kesalahan perintah %s"
-#: ../gui/wxpython/gui_modules/menuform.py:2284
+#: ../gui/wxpython/gui_modules/menuform.py:2280
 #, python-format
 msgid "%(cmd)s: parameter '%(key)s' not available"
 msgstr ""
-#: ../gui/wxpython/gui_modules/menuform.py:2409
+#: ../gui/wxpython/gui_modules/menuform.py:2441
 #, python-format
 msgid "usage: %s <grass command>"
 msgstr "pengunaan: %s <perintah grass>"
@@ -11861,128 +11962,128 @@
 msgstr ""
 #: ../gui/wxpython/gui_modules/globalvar.py:119
-#: ../gui/wxpython/gui_modules/preferences.py:1798
+#: ../gui/wxpython/gui_modules/preferences.py:1820
 #, fuzzy
 msgid "Projection"
 msgstr "Proyeksi:"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:269
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
 #, fuzzy
 msgid "Easting"
 msgstr "Timur"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:270
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:290
 #, fuzzy
 msgid "Northing"
 msgstr "Utara"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:271
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:291
 msgid "Elevation"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:272
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:292
 #, fuzzy
 msgid "Surface map elevation"
 msgstr "Program pembentukan permukaan dari kontur raster."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:273
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:293
 #, fuzzy
 msgid "Surface map color"
 msgstr "Kelola warna citra"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:282
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:302
 msgid "XY distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:283
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:303
 msgid "XYZ distance from previous"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:284
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:304
 #, fuzzy
 msgid "Distance along surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:289
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:309
 #, fuzzy
 msgid "Distance along exag. surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:296
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:316
 #, fuzzy
 msgid "No point on surface"
 msgstr "Cost surface"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:301
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:321
 #, fuzzy
 msgid "Function not implemented yet"
 msgstr "Belum diimplementasikan"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:602
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:639
 #, fuzzy
 msgid "Loading raster map"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:606
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:643
 #, fuzzy
 msgid "Loading 3d raster map"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:612
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:649
 #, fuzzy
 msgid "failed"
 msgstr "Profil"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:614
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:651
 #, python-format
 msgid "Unsupported layer type '%s'"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:668
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:729
 #, fuzzy
 msgid "Unable to unload raster map"
 msgstr "Tidak berhasil memperbaharui peta vektor."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:673
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:734
 #, fuzzy
 msgid "Unable to unload 3d raster map"
 msgstr "Tidak dapat memperbesar ke peta raster <%s>"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:674
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:735
 #, fuzzy
 msgid "3d raster map"
 msgstr "Peta raster:"
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:681
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:742
 msgid "unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:725
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:786
 msgid "Loading vector map <%(name)s> (%(type)s) failed"
 msgstr "Nilai casting '%(value)' ke %(tipe) gagal."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:781
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:842
 msgid "Unable to unload vector map <%(name)s> (%(type)s)"
 msgstr "Tidak bisa membuat sebuah peta vektor baru <%s>."
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:784
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:845
 #, python-format
 msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1071
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1148
 #, python-format
 msgid "Vector point layer not found (id = %d)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1073
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1150
 #, python-format
 msgid "Unable to set data layer properties (id = %d)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1076
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1153
 #, python-format
 msgid ""
 "Setting data layer properties failed.\n"
@@ -11990,105 +12091,110 @@
 "%s"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:416
+#: ../gui/wxpython/gui_modules/preferences.py:427
 msgid "Segment break"
 msgstr "Segment break"
-#: ../gui/wxpython/gui_modules/preferences.py:621
+#: ../gui/wxpython/gui_modules/preferences.py:637
 msgid "Collapse all except PERMANENT and current"
 msgstr "Putus semua kecuali PERMANENT dan current"
-#: ../gui/wxpython/gui_modules/preferences.py:622
+#: ../gui/wxpython/gui_modules/preferences.py:638
 msgid "Collapse all except PERMANENT"
 msgstr "Putuskan semua kecuali PERMANENT"
-#: ../gui/wxpython/gui_modules/preferences.py:623
+#: ../gui/wxpython/gui_modules/preferences.py:639
 #, fuzzy
 msgid "Collapse all except current"
-#: ../gui/wxpython/gui_modules/preferences.py:624
+#: ../gui/wxpython/gui_modules/preferences.py:640
 msgid "Collapse all"
 msgstr "Tutup semua"
-#: ../gui/wxpython/gui_modules/preferences.py:625
+#: ../gui/wxpython/gui_modules/preferences.py:641
 msgid "Expand all"
 msgstr "Kembangkan semua"
-#: ../gui/wxpython/gui_modules/preferences.py:627
+#: ../gui/wxpython/gui_modules/preferences.py:643
 msgid "Display selected"
 msgstr "Tampilkan yang terpilih"
-#: ../gui/wxpython/gui_modules/preferences.py:635
+#: ../gui/wxpython/gui_modules/preferences.py:651
 msgid "Classic (labels only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:636
+#: ../gui/wxpython/gui_modules/preferences.py:652
 msgid "Combined (labels and module names)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:637
+#: ../gui/wxpython/gui_modules/preferences.py:653
 msgid "Professional (module names only)"
 msgstr ""
-#: ../gui/wxpython/gui_modules/preferences.py:657
