[GRASS-SVN] r46704 - grass/branches/develbranch_6/raster/r.univar2
svn_grass at osgeo.org
Tue Jun 14 08:04:15 EDT 2011
Author: mmetz
Date: 2011-06-14 05:04:15 -0700 (Tue, 14 Jun 2011)
New Revision: 46704
grass/branches/develbranch_6/raster/r.univar2/globals.h
grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c
grass/branches/develbranch_6/raster/r.univar2/stats.c
hopefully failsafe reading of the zonal map (backport r46703)
Modified: grass/branches/develbranch_6/raster/r.univar2/globals.h
--- grass/branches/develbranch_6/raster/r.univar2/globals.h 2011-06-14 12:01:11 UTC (rev 46703)
+++ grass/branches/develbranch_6/raster/r.univar2/globals.h 2011-06-14 12:04:15 UTC (rev 46704)
@@ -5,6 +5,7 @@
* Author(s): Soeren Gebbert
* Based on r.univar from Hamish Bowman, University of Otago, New Zealand
* and Martin Landa
+ * zonal loop by Markus Metz
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
Modified: grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c
--- grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c 2011-06-14 12:01:11 UTC (rev 46703)
+++ grass/branches/develbranch_6/raster/r.univar2/r3.univar_main.c 2011-06-14 12:04:15 UTC (rev 46704)
@@ -77,11 +77,8 @@
int main(int argc, char *argv[])
- float val_f; /* for misc use */
- double val_d; /* for misc use */
- int first = TRUE; /* min/max init flag */
+ FCELL val_f; /* for misc use */
+ DCELL val_d; /* for misc use */
int map_type, zmap_type;
univar_stat *stats;
@@ -92,9 +89,8 @@
unsigned int rows, cols, depths;
unsigned int x, y, z;
double dmin, dmax;
- int zone, use_zone = 0;
+ int zone, n_zones, use_zone = 0;
char *mapset, *name;
- struct FPRange zone_range;
struct GModule *module;
@@ -157,19 +153,15 @@
if (zmap == NULL)
G3d_fatalError(_("Error opening g3d map <%s>"), zonemap);
- if (G3d_tileTypeMap(zmap) != CELL_TYPE)
- G_fatal_error("Zoning raster must be of type CELL");
zmap_type = G3d_tileTypeMap(zmap);
- if (zmap_type != CELL_TYPE)
- if (G3d_readRange(zonemap, mapset, &zone_range) == -1)
- G_fatal_error("Can not read range for zoning raster");
- G3d_range_min_max(zmap, &dmin, &dmax);
if (G3d_readCats(zonemap, mapset, &(zone_info.cats)))
G_warning("no category support for zoning raster");
+ G3d_range_init(zmap);
+ if (!G3d_range_load(zmap))
+ G_fatal_error(_("Unable it load G3d range"));
+ G3d_range_min_max(zmap, &dmin, &dmax);
/* properly round dmin and dmax */
if (dmin < 0)
@@ -180,7 +172,8 @@
zone_info.max = dmax - 0.5;
else
zone_info.max = dmax + 0.5;
+ G_debug(1, "min: %d, max: %d", zone_info.min, zone_info.max);
zone_info.n_zones = zone_info.max - zone_info.min + 1;
use_zone = 1;
@@ -204,8 +197,14 @@
i = 0;
while (param.percentile->answers[i])
i++;
+ n_zones = zone_info.n_zones;
+ if (n_zones == 0)
+ n_zones = 1;
stats = create_univar_stat_struct(map_type, i);
- for (i = 0; i < zone_info.n_zones; i++) {
+ for (i = 0; i < n_zones; i++) {
unsigned int j;
for (j = 0; j < stats[i].n_perc; j++) {
sscanf(param.percentile->answers[j], "%lf", &(stats[i].perc[j]));
@@ -218,8 +217,27 @@
for (y = 0; y < rows; y++) {
for (x = 0; x < cols; x++) {
zone = 0;
- if (zone_info.n_zones)
- G3d_getValue(zmap, x, y, z, &zone, CELL_TYPE);
+ if (zone_info.n_zones) {
+ if (zmap_type == FCELL_TYPE) {
+ G3d_getValue(zmap, x, y, z, &val_f, FCELL_TYPE);
+ if (G3d_isNullValueNum(&val_f, FCELL_TYPE))
+ continue;
+ if (val_f < 0)
+ zone = val_f - 0.5;
+ else
+ zone = val_f + 0.5;
+ else if (zmap_type == DCELL_TYPE) {
+ G3d_getValue(zmap, x, y, z, &val_d, DCELL_TYPE);
+ if (G3d_isNullValueNum(&val_d, DCELL_TYPE))
+ continue;
+ if (val_d < 0)
+ zone = val_d - 0.5;
+ else
+ zone = val_d + 0.5;
+ zone -= zone_info.min;
if (map_type == FCELL_TYPE) {
G3d_getValue(map, x, y, z, &val_f, map_type);
if (!G3d_isNullValueNum(&val_f, map_type)) {
@@ -252,6 +270,7 @@
stats[zone].n++;
+ stats[zone].size++;
else if (map_type == DCELL_TYPE) {
G3d_getValue(map, x, y, z, &val_d, map_type);
@@ -272,7 +291,7 @@
stats[zone].sumsq += val_d * val_d;
stats[zone].sum_abs += fabs(val_d);
- if (first) {
+ if (stats[zone].first) {
stats[zone].max = val_d;
stats[zone].min = val_d;
stats[zone].first = FALSE;
@@ -285,6 +304,7 @@
stats[zone].n++;
Modified: grass/branches/develbranch_6/raster/r.univar2/stats.c
--- grass/branches/develbranch_6/raster/r.univar2/stats.c 2011-06-14 12:01:11 UTC (rev 46703)
+++ grass/branches/develbranch_6/raster/r.univar2/stats.c 2011-06-14 12:04:15 UTC (rev 46704)
@@ -30,8 +30,8 @@
stats[i].sum = 0.0;
stats[i].sumsq = 0.0;
- stats[i].min = 0.0 / 0.0; /*set to nan as default */
- stats[i].max = 0.0 / 0.0; /*set to nan as default */
+ stats[i].min = 0.0 / 0.0; /* set to nan as default */
+ stats[i].max = 0.0 / 0.0; /* set to nan as default */
stats[i].n_perc = n_perc;
if (n_perc > 0)
stats[i].perc = (double *)G_malloc(n_perc * sizeof(double));
@@ -372,7 +372,7 @@
fprintf(stdout,"%s%s", G_get_cat(z + zone_info.min, &(zone_info.cats)), zone_info.sep);
- /* total cells */
+ /* non-null cells cells */
fprintf(stdout, "%d%s", stats[z].n, zone_info.sep);
/* null cells */
fprintf(stdout, "%d%s", stats[z].size - stats[z].n, zone_info.sep);
