[GRASS-SVN] r46705 - grass/branches/releasebranch_6_4/raster/r.univar2
Tue Jun 14 08:05:50 EDT 2011
Author: mmetz
Date: 2011-06-14 05:05:50 -0700 (Tue, 14 Jun 2011)
New Revision: 46705
   grass/branches/releasebranch_6_4/raster/r.univar2/globals.h
   grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c
   grass/branches/releasebranch_6_4/raster/r.univar2/stats.c
hopefully failsafe reading of the zonal map (backport r46703)
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/globals.h
--- grass/branches/releasebranch_6_4/raster/r.univar2/globals.h	2011-06-14 12:04:15 UTC (rev 46704)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/globals.h	2011-06-14 12:05:50 UTC (rev 46705)
@@ -5,6 +5,7 @@
  *   Author(s): Soeren Gebbert
  *              Based on r.univar from Hamish Bowman, University of Otago, New Zealand
  *              and Martin Landa
+ *              zonal loop by Markus Metz
  *      This program is free software under the GNU General Public
  *      License (>=v2). Read the file COPYING that comes with GRASS
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c
--- grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c	2011-06-14 12:04:15 UTC (rev 46704)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/r3.univar_main.c	2011-06-14 12:05:50 UTC (rev 46705)
@@ -77,11 +77,8 @@
 int main(int argc, char *argv[])
-    float val_f;		/* for misc use */
-    double val_d;		/* for misc use */
-    int first = TRUE;		/* min/max init flag */
+    FCELL val_f;		/* for misc use */
+    DCELL val_d;		/* for misc use */
     int map_type, zmap_type;
     univar_stat *stats;
@@ -92,9 +89,8 @@
     unsigned int rows, cols, depths;
     unsigned int x, y, z;
     double dmin, dmax;
-    int zone, use_zone = 0;
+    int zone, n_zones, use_zone = 0;
     char *mapset, *name;
-    struct FPRange zone_range;
     struct GModule *module;
@@ -157,19 +153,15 @@
 	if (zmap == NULL)
 	    G3d_fatalError(_("Error opening g3d map <%s>"), zonemap);
-	if (G3d_tileTypeMap(zmap) != CELL_TYPE)
-	    G_fatal_error("Zoning raster must be of type CELL");
 	zmap_type = G3d_tileTypeMap(zmap);
-	if (zmap_type != CELL_TYPE)
-	if (G3d_readRange(zonemap, mapset, &zone_range) == -1)
-	    G_fatal_error("Can not read range for zoning raster");
-	G3d_range_min_max(zmap, &dmin, &dmax);
 	if (G3d_readCats(zonemap, mapset, &(zone_info.cats)))
 	    G_warning("no category support for zoning raster");
+	G3d_range_init(zmap);
+	if (!G3d_range_load(zmap))
+	    G_fatal_error(_("Unable it load G3d range"));
+	G3d_range_min_max(zmap, &dmin, &dmax);
 	/* properly round dmin and dmax */
 	if (dmin < 0)
@@ -180,7 +172,8 @@
 	    zone_info.max = dmax - 0.5;
 	else
 	    zone_info.max = dmax + 0.5;
+	G_debug(1, "min: %d, max: %d", zone_info.min, zone_info.max);
 	zone_info.n_zones = zone_info.max - zone_info.min + 1;
 	use_zone = 1;
@@ -204,8 +197,14 @@
     i = 0;
     while (param.percentile->answers[i])
 	i++;
+    n_zones = zone_info.n_zones;
+    if (n_zones == 0)
+        n_zones = 1;
     stats = create_univar_stat_struct(map_type, i);
-    for (i = 0; i < zone_info.n_zones; i++) {
+    for (i = 0; i < n_zones; i++) {
 	unsigned int j;
 	for (j = 0; j < stats[i].n_perc; j++) {
 	    sscanf(param.percentile->answers[j], "%lf", &(stats[i].perc[j]));
@@ -218,8 +217,27 @@
 	for (y = 0; y < rows; y++) {
 	    for (x = 0; x < cols; x++) {
 		zone = 0;
-		if (zone_info.n_zones)
-		    G3d_getValue(zmap, x, y, z, &zone, CELL_TYPE);
+		if (zone_info.n_zones) {
+		    if (zmap_type == FCELL_TYPE) {
+			G3d_getValue(zmap, x, y, z, &val_f, FCELL_TYPE);
+			if (G3d_isNullValueNum(&val_f, FCELL_TYPE))
+			    continue;
+			if (val_f < 0)
+			    zone = val_f - 0.5;
+			else
+			    zone = val_f + 0.5;
+		    else if (zmap_type == DCELL_TYPE) {
+			G3d_getValue(zmap, x, y, z, &val_d, DCELL_TYPE);
+			if (G3d_isNullValueNum(&val_d, DCELL_TYPE))
+			    continue;
+			if (val_d < 0)
+			    zone = val_d - 0.5;
+			else
+			    zone = val_d + 0.5;
+                    zone -= zone_info.min;
 		if (map_type == FCELL_TYPE) {
 		    G3d_getValue(map, x, y, z, &val_f, map_type);
 		    if (!G3d_isNullValueNum(&val_f, map_type)) {
@@ -252,6 +270,7 @@
 			stats[zone].n++;
+		    stats[zone].size++;
 		else if (map_type == DCELL_TYPE) {
 		    G3d_getValue(map, x, y, z, &val_d, map_type);
@@ -272,7 +291,7 @@
 			stats[zone].sumsq += val_d * val_d;
 			stats[zone].sum_abs += fabs(val_d);
-			if (first) {
+			if (stats[zone].first) {
 			    stats[zone].max = val_d;
 			    stats[zone].min = val_d;
 			    stats[zone].first = FALSE;
@@ -285,6 +304,7 @@
 			stats[zone].n++;
Modified: grass/branches/releasebranch_6_4/raster/r.univar2/stats.c
--- grass/branches/releasebranch_6_4/raster/r.univar2/stats.c	2011-06-14 12:04:15 UTC (rev 46704)
+++ grass/branches/releasebranch_6_4/raster/r.univar2/stats.c	2011-06-14 12:05:50 UTC (rev 46705)
@@ -30,8 +30,8 @@
 	stats[i].sum = 0.0;
 	stats[i].sumsq = 0.0;
-	stats[i].min = 0.0 / 0.0;	/*set to nan as default */
-	stats[i].max = 0.0 / 0.0;	/*set to nan as default */
+	stats[i].min = 0.0 / 0.0;	/* set to nan as default */
+	stats[i].max = 0.0 / 0.0;	/* set to nan as default */
 	stats[i].n_perc = n_perc;
 	if (n_perc > 0)
 	    stats[i].perc = (double *)G_malloc(n_perc * sizeof(double));
@@ -372,7 +372,7 @@
 	    fprintf(stdout,"%s%s", G_get_cat(z + zone_info.min, &(zone_info.cats)), zone_info.sep);
-	/* total cells */
+	/* non-null cells cells */
 	fprintf(stdout, "%d%s", stats[z].n, zone_info.sep);
 	/* null cells */
 	fprintf(stdout, "%d%s", stats[z].size - stats[z].n, zone_info.sep);
