[GRASS-SVN] r46756 - grass/trunk/vector/v.net.salesman
svn_grass at osgeo.org
Wed Jun 22 09:38:39 EDT 2011
Author: mmetz
Date: 2011-06-22 06:38:39 -0700 (Wed, 22 Jun 2011)
New Revision: 46756
grass/trunk/vector/v.net.salesman/main.c
use cost cache
Modified: grass/trunk/vector/v.net.salesman/main.c
--- grass/trunk/vector/v.net.salesman/main.c 2011-06-22 13:38:03 UTC (rev 46755)
+++ grass/trunk/vector/v.net.salesman/main.c 2011-06-22 13:38:39 UTC (rev 46756)
@@ -80,6 +80,7 @@
int i, j, k, ret, city, city1;
int nlines, type, ltype, afield, tfield, geo, cat;
int node, node1, node2, line;
+ double **cost_cache; /* pointer to array of pointers to arrays of cached costs */
struct Option *map, *output, *afield_opt, *tfield_opt, *afcol, *abcol,
*type_opt, *term_opt;
struct Flag *geo_f;
@@ -225,6 +226,10 @@
for (i = 0; i < ncities; i++) {
costs[i] = (COST *) G_malloc(ncities * sizeof(COST));
+ cost_cache = (double **) G_malloc(ncities * sizeof(double *));
+ for (i = 0; i < ncities; i++) {
+ cost_cache[i] = (double *) G_malloc(ncities * sizeof(double));
if (abcol->answer) {
bcosts = (COST **) G_malloc(ncities * sizeof(COST *));
@@ -258,6 +263,7 @@
/* TODO: add to directional cost cache: from, to, cost */
costs[i][k].city = j;
costs[i][k].cost = cost;
+ cost_cache[i][j] = cost;
k++;
@@ -271,19 +277,10 @@
if (i == j)
continue;
- /* TODO: get cost from directional cost cache */
- /* from = cities[j], to = cities[i] */
- ret =
- Vect_net_shortest_path(&Map, cities[j], cities[i], NULL,
- &cost);
- if (ret == -1)
- G_fatal_error(_("Destination node [%d] is unreachable "
- "from node [%d]"), cities[j], cities[i]);
- if (bcosts[i][k].cost > cost) {
- bcosts[i][k].cost = cost;
- k++;
+ bcosts[i][k].city = j;
+ bcosts[i][k].cost = cost_cache[j][i];
+ k++;
qsort((void *)bcosts[i], k, sizeof(COST), cmp);
@@ -327,7 +324,7 @@
continue;
tmpcost = 0;
for (k = 0; k < ncities - 1; k++) {
- G_debug(2, "? %d (%d) - %d (%d)", j, cnode(j),
+ G_debug(2, "forward? %d (%d) - %d (%d)", j, cnode(j),
costs[j][k].city, cnode(costs[j][k].city));
if (!cused[costs[j][k].city])
continue; /* only used */
@@ -338,11 +335,11 @@
/* forward/backward: tmpcost = min(fcost) + min(bcost) */
if (bcosts) {
+ G_debug(2, "backward? %d (%d) - %d (%d)", j, cnode(j),
bcosts[j][k].city, cnode(bcosts[j][k].city));
if (!cused[bcosts[j][k].city])
- /* directional costs j -> k */
+ /* directional costs k -> j */
tmpcost += bcosts[j][k].cost;
break; /* first nearest */
@@ -362,24 +359,19 @@
city1 = 0;
for (j = 0; j < ncyc; j++) {
/* cost from j to j + 1 (directional) */
- node1 = cities[cycle[j]];
- node2 = cities[cycle[j + 1]];
- /* from = cities[cycle[j]], to = cities[cycle[j + 1]] */
- ret = Vect_net_shortest_path(&Map, node1, node2, NULL, &tcost);
+ /* get cost from directional cost cache */
+ tcost = cost_cache[cycle[j]][cycle[j + 1]];
tmpcost = -tcost;
/* check insertion of city between j and j + 1 */
/* cost from j to city (directional) */
- node2 = cities[city];
+ tcost = cost_cache[cycle[j]][city];
tmpcost += tcost;
/* cost from city to j + 1 (directional) */
- node1 = cities[city];
+ tcost = cost_cache[city][cycle[j + 1]];
tmpcost += tcost;
/* tmpcost must always be > 0 */
