[GRASS-SVN] r46757 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Thu Jun 23 07:20:53 EDT 2011
Author: martinl
Date: 2011-06-23 04:20:53 -0700 (Thu, 23 Jun 2011)
New Revision: 46757
grass/trunk/scripts/g.extension/g.extension.py
g.extension: support multiple GRASS_ADDONS_PATH values
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2011-06-22 13:38:39 UTC (rev 46756)
+++ grass/trunk/scripts/g.extension/g.extension.py 2011-06-23 11:20:53 UTC (rev 46757)
@@ -416,10 +416,17 @@
if options['prefix'] == '$GRASS_ADDON_PATH':
if not os.environ.has_key('GRASS_ADDON_PATH') or \
not os.environ['GRASS_ADDON_PATH']:
- grass.warning(_("GRASS_ADDON_PATH is not defined, installing to ~/.grass7/addons/"))
- options['prefix'] = os.path.join(os.environ['HOME'], '.grass7', 'addons')
+ major_version = int(grass.version()['version'].split('.', 1)[0])
+ grass.warning(_("GRASS_ADDON_PATH is not defined, "
+ "installing to ~/.grass%d/addons/") % major_version)
+ options['prefix'] = os.path.join(os.environ['HOME'], '.grass%d' % major_version, 'addons')
else:
- options['prefix'] = os.environ['GRASS_ADDON_PATH']
+ path_list = os.environ['GRASS_ADDON_PATH'].split(os.pathsep)
+ if len(path_list) < 1:
+ grass.fatal(_("Invalid GRASS_ADDON_PATH value - '%s'") % os.environ['GRASS_ADDON_PATH'])
+ if len(path_list) > 1:
+ grass.warning(_("GRASS_ADDON_PATH has more items, using first defined - '%s'") % path_list[0])
+ options['prefix'] = path_list[0]
# check dirs
check_dirs()
