[GRASS-SVN] r46787 - grass/trunk/raster3d/r3.stats
svn_grass at osgeo.org
Sun Jun 26 09:52:04 EDT 2011
Author: huhabla
Date: 2011-06-26 06:52:04 -0700 (Sun, 26 Jun 2011)
New Revision: 46787
Added:
grass/trunk/raster3d/r3.stats/test.r3.stats.sh
grass/trunk/raster3d/r3.stats/test_volume_double_stats_1.ref
grass/trunk/raster3d/r3.stats/test_volume_double_stats_18.ref
grass/trunk/raster3d/r3.stats/test_volume_double_stats_22.ref
grass/trunk/raster3d/r3.stats/test_volume_double_stats_3.ref
grass/trunk/raster3d/r3.stats/test_volume_double_stats_9.ref
grass/trunk/raster3d/r3.stats/test_volume_double_stats_e.ref
grass/trunk/raster3d/r3.stats/test_volume_float_stats_1.ref
grass/trunk/raster3d/r3.stats/test_volume_float_stats_14.ref
grass/trunk/raster3d/r3.stats/test_volume_float_stats_2.ref
grass/trunk/raster3d/r3.stats/test_volume_float_stats_21.ref
grass/trunk/raster3d/r3.stats/test_volume_float_stats_7.ref
grass/trunk/raster3d/r3.stats/test_volume_float_stats_e.ref
grass/trunk/raster3d/r3.stats/r3.stats.html
Added test case for r3.stats
Modified: grass/trunk/raster3d/r3.stats/r3.stats.html
--- grass/trunk/raster3d/r3.stats/r3.stats.html 2011-06-26 09:45:07 UTC (rev 46786)
+++ grass/trunk/raster3d/r3.stats/r3.stats.html 2011-06-26 13:52:04 UTC (rev 46787)
@@ -13,7 +13,6 @@
array defined by the current 3D region settings, not the original extent and
resolution of the input map. See <em><A HREF="g.region.html">g.region</A></em>.
<P>
-The region setting will not effect the memory consumption of this module.
The number of subranges in case of value range calculation or the number of
equal value groups effect the memory consumption and the calculation time.
You can expect a huge time consumption to calculate the equal value groups (flag <em>-e</em>)
Added: grass/trunk/raster3d/r3.stats/test.r3.stats.sh
--- grass/trunk/raster3d/r3.stats/test.r3.stats.sh (rev 0)
+++ grass/trunk/raster3d/r3.stats/test.r3.stats.sh 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,30 @@
+# Tests for r3.stats
+# We set up a specific region in the
+# @preprocess step of this test. We generate
+# voxel data with r3.mapcalc. The region setting
+# should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+# We create several (float, double, null value) voxel map
+# with value = col + row + depth.
+r3.mapcalc --o expr="volume_float = float(col() + row() + depth())"
+r3.mapcalc --o expr="volume_double = double(col() + row() + depth())"
+# Add null value information to test correct null value handling
+r3.mapcalc --o expr="volume_float_null = if(row() == 1 || row() == 5, null(), volume_float)"
+r3.mapcalc --o expr="volume_double_null = if(row() == 2 || row() == 6, null(), volume_double)"
+# @test r3.stats with float maps and @file validation.
+# The module output on stdout is piped into text files
+r3.stats input=volume_float_null nsteps=1 > test_volume_float_stats_1.txt
+r3.stats input=volume_float_null nsteps=2 > test_volume_float_stats_2.txt
+r3.stats input=volume_float_null nsteps=7 > test_volume_float_stats_7.txt
+r3.stats input=volume_float_null nsteps=14 > test_volume_float_stats_14.txt
+r3.stats input=volume_float_null nsteps=21 > test_volume_float_stats_21.txt
+r3.stats -e input=volume_float_null > test_volume_float_stats_e.txt
+# Test double maps
+r3.stats input=volume_double_null nsteps=1 > test_volume_double_stats_1.txt
+r3.stats input=volume_double_null nsteps=3 > test_volume_double_stats_3.txt
+r3.stats input=volume_double_null nsteps=9 > test_volume_double_stats_9.txt
+r3.stats input=volume_double_null nsteps=18 > test_volume_double_stats_18.txt
+r3.stats input=volume_double_null nsteps=22 > test_volume_double_stats_22.txt
+r3.stats -e input=volume_double_null > test_volume_double_stats_e.txt
Added: grass/trunk/raster3d/r3.stats/test_volume_double_stats_1.ref
--- grass/trunk/raster3d/r3.stats/test_volume_double_stats_1.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_double_stats_1.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,13 @@
+ num | minimum <= value | value < maximum | volume | perc | cell count
+ 1 3.000000000 25.000000001 360000.000 75.00000 360
+ 2 * * 120000.000 25.00000 120
+Sum of non Null cells:
+ Volume = 360000.000
+ Percentage = 75.000
+ Cell count = 360
+Sum of all cells:
+ Volume = 480000.000
+ Percentage = 100.000
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_double_stats_18.ref
--- grass/trunk/raster3d/r3.stats/test_volume_double_stats_18.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_double_stats_18.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,30 @@
+ 1 3.000000000 4.222222222 3000.000 0.62500 3
+ 2 4.222222222 5.444444444 4000.000 0.83333 4
+ 3 5.444444444 6.666666667 7000.000 1.45833 7
+ 4 6.666666667 7.888888889 11000.000 2.29167 11
+ 5 7.888888889 9.111111111 32000.000 6.66667 32
+ 6 9.111111111 10.333333333 22000.000 4.58333 22
+ 7 10.333333333 11.555555556 25000.000 5.20833 25
+ 8 11.555555556 12.777777778 27000.000 5.62500 27
+ 9 12.777777778 14.000000000 29000.000 6.04167 29
+ 10 14.000000000 15.222222222 59000.000 12.29167 59
+ 11 15.222222222 16.444444444 28000.000 5.83333 28
+ 12 16.444444444 17.666666667 26000.000 5.41667 26
+ 13 17.666666667 18.888888889 23000.000 4.79167 23
+ 14 18.888888889 20.111111111 35000.000 7.29167 35
+ 15 20.111111111 21.333333333 12000.000 2.50000 12
+ 16 21.333333333 22.555555556 8000.000 1.66667 8
+ 17 22.555555556 23.777777778 5000.000 1.04167 5
+ 18 23.777777778 25.000000001 4000.000 0.83333 4
+ 19 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_double_stats_22.ref
--- grass/trunk/raster3d/r3.stats/test_volume_double_stats_22.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_double_stats_22.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,34 @@
+ 1 3.000000000 4.000000000 1000.000 0.20833 1
+ 2 4.000000000 5.000000000 2000.000 0.41667 2
+ 3 5.000000000 6.000000000 4000.000 0.83333 4
+ 4 6.000000000 7.000000000 7000.000 1.45833 7
+ 5 7.000000000 8.000000000 11000.000 2.29167 11
+ 6 8.000000000 9.000000000 14000.000 2.91667 14
+ 7 9.000000000 10.000000000 18000.000 3.75000 18
+ 8 10.000000000 11.000000000 22000.000 4.58333 22
+ 9 11.000000000 12.000000000 25000.000 5.20833 25
+ 10 12.000000000 13.000000000 27000.000 5.62500 27
+ 11 13.000000000 14.000000000 29000.000 6.04167 29
+ 12 14.000000000 15.000000000 30000.000 6.25000 30
+ 13 15.000000000 16.000000000 29000.000 6.04167 29
+ 14 16.000000000 17.000000000 28000.000 5.83333 28
+ 15 17.000000000 18.000000000 26000.000 5.41667 26
+ 16 18.000000000 19.000000000 23000.000 4.79167 23
+ 17 19.000000000 20.000000000 19000.000 3.95833 19
+ 18 20.000000000 21.000000000 16000.000 3.33333 16
+ 19 21.000000000 22.000000000 12000.000 2.50000 12
+ 20 22.000000000 23.000000000 8000.000 1.66667 8
+ 21 23.000000000 24.000000000 5000.000 1.04167 5
+ 22 24.000000000 25.000000001 4000.000 0.83333 4
+ 23 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_double_stats_3.ref
--- grass/trunk/raster3d/r3.stats/test_volume_double_stats_3.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_double_stats_3.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,15 @@
+ 1 3.000000000 10.333333333 79000.000 16.45833 79
+ 2 10.333333333 17.666666667 194000.000 40.41667 194
+ 3 17.666666667 25.000000001 87000.000 18.12500 87
+ 4 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_double_stats_9.ref
--- grass/trunk/raster3d/r3.stats/test_volume_double_stats_9.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_double_stats_9.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,21 @@
+ 1 3.000000000 5.444444444 7000.000 1.45833 7
+ 2 5.444444444 7.888888889 18000.000 3.75000 18
+ 3 7.888888889 10.333333333 54000.000 11.25000 54
+ 4 10.333333333 12.777777778 52000.000 10.83333 52
+ 5 12.777777778 15.222222222 88000.000 18.33333 88
+ 6 15.222222222 17.666666667 54000.000 11.25000 54
+ 7 17.666666667 20.111111111 58000.000 12.08333 58
+ 8 20.111111111 22.555555556 20000.000 4.16667 20
+ 9 22.555555556 25.000000001 9000.000 1.87500 9
+ 10 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_double_stats_e.ref
--- grass/trunk/raster3d/r3.stats/test_volume_double_stats_e.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_double_stats_e.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,36 @@
+ num | value | volume | perc | cell count
+ 1 3.000000 1000.000 0.20833 1
+ 2 4.000000 2000.000 0.41667 2
+ 3 5.000000 4000.000 0.83333 4
+ 4 6.000000 7000.000 1.45833 7
+ 5 7.000000 11000.000 2.29167 11
+ 6 8.000000 14000.000 2.91667 14
+ 7 9.000000 18000.000 3.75000 18
+ 8 10.000000 22000.000 4.58333 22
+ 9 11.000000 25000.000 5.20833 25
+ 10 12.000000 27000.000 5.62500 27
+ 11 13.000000 29000.000 6.04167 29
+ 12 14.000000 30000.000 6.25000 30
+ 13 15.000000 29000.000 6.04167 29
+ 14 16.000000 28000.000 5.83333 28
+ 15 17.000000 26000.000 5.41667 26
+ 16 18.000000 23000.000 4.79167 23
+ 17 19.000000 19000.000 3.95833 19
+ 18 20.000000 16000.000 3.33333 16
+ 19 21.000000 12000.000 2.50000 12
+ 20 22.000000 8000.000 1.66667 8
+ 21 23.000000 5000.000 1.04167 5
+ 22 24.000000 3000.000 0.62500 3
+ 23 25.000000 1000.000 0.20833 1
+ 24 * 120000.000 25.00000 120
+Number of groups with equal values: 23
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_float_stats_1.ref
--- grass/trunk/raster3d/r3.stats/test_volume_float_stats_1.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_float_stats_1.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,13 @@
+ 1 4.000000000 25.000000001 360000.000 75.00000 360
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_float_stats_14.ref
--- grass/trunk/raster3d/r3.stats/test_volume_float_stats_14.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_float_stats_14.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,26 @@
+ 1 4.000000000 5.500000000 4000.000 0.83333 4
+ 2 5.500000000 7.000000000 6000.000 1.25000 6
+ 3 7.000000000 8.500000000 22000.000 4.58333 22
+ 4 8.500000000 10.000000000 17000.000 3.54167 17
+ 5 10.000000000 11.500000000 45000.000 9.37500 45
+ 6 11.500000000 13.000000000 27000.000 5.62500 27
+ 7 13.000000000 14.500000000 59000.000 12.29167 59
+ 8 14.500000000 16.000000000 30000.000 6.25000 30
+ 9 16.000000000 17.500000000 56000.000 11.66667 56
+ 10 17.500000000 19.000000000 24000.000 5.00000 24
+ 11 19.000000000 20.500000000 38000.000 7.91667 38
+ 12 20.500000000 22.000000000 13000.000 2.70833 13
+ 13 22.000000000 23.500000000 15000.000 3.12500 15
+ 14 23.500000000 25.000000001 4000.000 0.83333 4
+ 15 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_float_stats_2.ref
--- grass/trunk/raster3d/r3.stats/test_volume_float_stats_2.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_float_stats_2.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,14 @@
+ 1 4.000000000 14.500000000 180000.000 37.50000 180
+ 2 14.500000000 25.000000001 180000.000 37.50000 180
+ 3 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_float_stats_21.ref
--- grass/trunk/raster3d/r3.stats/test_volume_float_stats_21.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_float_stats_21.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,33 @@
+ 1 4.000000000 5.000000000 1000.000 0.20833 1
+ 2 5.000000000 6.000000000 3000.000 0.62500 3
+ 3 6.000000000 7.000000000 6000.000 1.25000 6
+ 4 7.000000000 8.000000000 9000.000 1.87500 9
+ 5 8.000000000 9.000000000 13000.000 2.70833 13
+ 6 9.000000000 10.000000000 17000.000 3.54167 17
+ 7 10.000000000 11.000000000 21000.000 4.37500 21
+ 8 11.000000000 12.000000000 24000.000 5.00000 24
+ 9 12.000000000 13.000000000 27000.000 5.62500 27
+ 10 13.000000000 14.000000000 29000.000 6.04167 29
+ 11 14.000000000 15.000000000 30000.000 6.25000 30
+ 12 15.000000000 16.000000000 30000.000 6.25000 30
+ 13 16.000000000 17.000000000 29000.000 6.04167 29
+ 14 17.000000000 18.000000000 27000.000 5.62500 27
+ 15 18.000000000 19.000000000 24000.000 5.00000 24
+ 16 19.000000000 20.000000000 21000.000 4.37500 21
+ 17 20.000000000 21.000000000 17000.000 3.54167 17
+ 18 21.000000000 22.000000000 13000.000 2.70833 13
+ 19 22.000000000 23.000000000 9000.000 1.87500 9
+ 20 23.000000000 24.000000000 6000.000 1.25000 6
+ 21 24.000000000 25.000000001 4000.000 0.83333 4
+ 22 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_float_stats_7.ref
--- grass/trunk/raster3d/r3.stats/test_volume_float_stats_7.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_float_stats_7.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,19 @@
+ 1 4.000000000 7.000000000 10000.000 2.08333 10
+ 2 7.000000000 10.000000000 39000.000 8.12500 39
+ 3 10.000000000 13.000000000 72000.000 15.00000 72
+ 4 13.000000000 16.000000000 89000.000 18.54167 89
+ 5 16.000000000 19.000000000 80000.000 16.66667 80
+ 6 19.000000000 22.000000000 51000.000 10.62500 51
+ 7 22.000000000 25.000000001 19000.000 3.95833 19
+ 8 * * 120000.000 25.00000 120
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
Added: grass/trunk/raster3d/r3.stats/test_volume_float_stats_e.ref
--- grass/trunk/raster3d/r3.stats/test_volume_float_stats_e.ref (rev 0)
+++ grass/trunk/raster3d/r3.stats/test_volume_float_stats_e.ref 2011-06-26 13:52:04 UTC (rev 46787)
@@ -0,0 +1,35 @@
+ 1 4.000000 1000.000 0.20833 1
+ 2 5.000000 3000.000 0.62500 3
+ 3 6.000000 6000.000 1.25000 6
+ 4 7.000000 9000.000 1.87500 9
+ 5 8.000000 13000.000 2.70833 13
+ 6 9.000000 17000.000 3.54167 17
+ 7 10.000000 21000.000 4.37500 21
+ 8 11.000000 24000.000 5.00000 24
+ 9 12.000000 27000.000 5.62500 27
+ 10 13.000000 29000.000 6.04167 29
+ 11 14.000000 30000.000 6.25000 30
+ 12 15.000000 30000.000 6.25000 30
+ 13 16.000000 29000.000 6.04167 29
+ 14 17.000000 27000.000 5.62500 27
+ 15 18.000000 24000.000 5.00000 24
+ 16 19.000000 21000.000 4.37500 21
+ 17 20.000000 17000.000 3.54167 17
+ 18 21.000000 13000.000 2.70833 13
+ 19 22.000000 9000.000 1.87500 9
+ 20 23.000000 6000.000 1.25000 6
+ 21 24.000000 3000.000 0.62500 3
+ 22 25.000000 1000.000 0.20833 1
+ 23 * 120000.000 25.00000 120
+Number of groups with equal values: 22
+ Cell count = 360
+Sum of all cells:
+ Cell count = 480
