[GRASS-SVN] r46823 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Tue Jun 28 09:06:53 EDT 2011
Author: mmetz
Date: 2011-06-28 06:06:53 -0700 (Tue, 28 Jun 2011)
New Revision: 46823
grass/trunk/gui/wxpython/gui_modules/gselect.py
grass/trunk/gui/wxpython/gui_modules/menuform.py
layer input option: support for native vectors
Modified: grass/trunk/gui/wxpython/gui_modules/gselect.py
--- grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-06-28 10:30:07 UTC (rev 46822)
+++ grass/trunk/gui/wxpython/gui_modules/gselect.py 2011-06-28 13:06:53 UTC (rev 46823)
@@ -663,10 +663,15 @@
fs = '|',
flags = 'g',
map = vector)
- for line in ret.splitlines():
- layerinfo = line.split('|')
- layername = layerinfo[0].split('/')
- layers.append(layername[len(layername) - 1])
+ if ret:
+ for line in ret.splitlines():
+ layerinfo = line.split('|')
+ layername = layerinfo[0].split('/')
+ # use this to get layer names
+ # but only when all modules use Vect_get_field2()
+ # which is not the case right now
+ ### layers.append(layername[len(layername) - 1])
+ layers.append(layername[0])
elif dsn:
ret = gcmd.RunCommand('v.in.ogr',
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py 2011-06-28 10:30:07 UTC (rev 46822)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py 2011-06-28 13:06:53 UTC (rev 46823)
@@ -237,18 +237,18 @@
if p.get('element', '') == 'layer':
layer = p.get('value', '')
if layer != '':
- layer = p.get('value', 1)
+ layer = p.get('value', '')
else:
- layer = p.get('default', 1)
+ layer = p.get('default', '')
break
elif p.get('element', '') == 'layer': # -> layer
# get layer
if layer != '':
else:
# get map name
pMap = self.task.get_param(p['wxId'][0], element = 'wxId-bind', raiseError = False)
@@ -278,16 +278,16 @@
native = False
break
# TODO: update only if needed
- #if native:
- # if map:
- # self.data[win.InsertLayers] = { 'vector' : map }
- # else:
- # self.data[win.InsertLayers] = { }
- #else:
- # if map:
- # self.data[win.InsertLayers] = { 'dsn' : map.rstrip('@OGR') }
- # else:
+ if native:
+ if map:
+ self.data[win.InsertLayers] = { 'vector' : map }
+ else:
+ self.data[win.InsertLayers] = { }
+ else:
+ if map:
+ self.data[win.InsertLayers] = { 'dsn' : map.rstrip('@OGR') }
+ else:
elif name == 'TableSelect':
self.data[win.InsertTables] = { 'driver' : driver,
@@ -1029,7 +1029,7 @@
self.goutput.RunCmd(cmd, onDone = self.OnDone)
except AttributeError, e:
- print >> sys.stderr, "%s: Propably not running in wxgui.py session?" % (e)
+ print >> sys.stderr, "%s: Probably not running in wxgui.py session?" % (e)
print >> sys.stderr, "parent window is: %s" % (str(self.parent))
else:
gcmd.Command(cmd)
@@ -1553,9 +1553,7 @@
size = globalvar.DIALOG_TEXTCTRL_SIZE)
win.Bind(wx.EVT_TEXT, self.OnSetValue)
else:
- value = p.get('value', '')
- if not value:
- value = p.get('default', '')
+ value = self._getValue(p)
if p.get('prompt', '') in ('layer',
'layer_all'):
@@ -1567,15 +1565,14 @@
win = gselect.LayerSelect(parent = which_panel,
all = all,
default = p['default'])
- win.Bind(wx.EVT_COMBOBOX, self.OnUpdateSelection)
- win.Bind(wx.EVT_COMBOBOX, self.OnSetValue)
+ win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
+ win.Bind(wx.EVT_TEXT, self.OnSetValue)
else:
win = wx.SpinCtrl(parent = which_panel, id = wx.ID_ANY,
min = 1, max = 100, initial = int(p['default']))
win.Bind(wx.EVT_SPINCTRL, self.OnSetValue)
- if p.get('value','') == '':
- win.SetItems([p['value']])
- win.SetSelection(0)
+ win.SetValue(str(value))
p['wxId'] = [ win.GetId() ]
@@ -2069,13 +2066,15 @@
if not found:
return
- if name in ('LayerSelect', 'DriverSelect', 'TableSelect',
+ if name in ('DriverSelect', 'TableSelect',
'LocationSelect', 'MapsetSelect', 'ProjSelect'):
porf['value'] = me.GetStringSelection()
elif name == 'GdalSelect':
porf['value'] = event.dsn
elif name == 'ModelParam':
porf['parameterized'] = me.IsChecked()
+ elif name == 'LayerSelect':
+ porf['value'] = me.GetValue()
else:
