[GRASS-SVN] r46858 - grass/trunk/include/vect
svn_grass at osgeo.org
Thu Jun 30 03:39:13 EDT 2011
Author: martinl
Date: 2011-06-30 00:39:13 -0700 (Thu, 30 Jun 2011)
New Revision: 46858
grass/trunk/include/vect/dig_structs.h
vlib: doxygen documentation added for dig_structs.h
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h 2011-06-29 16:26:35 UTC (rev 46857)
+++ grass/trunk/include/vect/dig_structs.h 2011-06-30 07:39:13 UTC (rev 46858)
@@ -1,10 +1,11 @@
\file include/vect/dig_structs.h
- \brief Structures for diglib (vector library)
+ \brief Data structures for \ref vectorlib
\author Written by Dave Gerdes (CERL) 5/1988
\author Updated to GRASS 5.7 by Radim Blazek (2001)
+ \author Doxygenized by Martin Landa <landa.martin gmail.com> (2011)
#include <grass/config.h>
@@ -27,570 +28,1578 @@
#include "ogr_api.h"
#endif
-/*! \brief plus_t size
+ \brief plus_t size
- 3.10 changes plus_t to ints.
- This assumes that any reasonable machine will use 4 bytes to
- store an int. The diglib code is not guaranteed to work if
- plus_t is changed to a type that is larger than an int.
+ 3.10 changes plus_t to ints. This assumes that any reasonable
+ machine will use 4 bytes to store an int. The diglib code is not
+ guaranteed to work if plus_t is changed to a type that is larger
+ than an int.
typedef int plus_t;
-/*! \brief Used by sites lib */
+ \brief Used by sites lib
struct site_att
- int cat; /* category */
- double *dbl; /* double attributes */
- char **str; /* string attributes */
+ \brief Category number
+ int cat;
+ \brief Array of double attributes
+ double *dbl;
+ \brief Array of string attributes
+ char **str;
-/*! \brief Bounding box */
+ \brief Bounding box
struct bound_box
- double N; /* north */
- double S; /* south */
- double E; /* east */
- double W; /* west */
- double T; /* top */
- double B; /* bottom */
+ \brief North
+ double N;
+ \brief South
+ double S;
+ \brief East
+ double E;
+ \brief West
+ double W;
+ \brief Top
+ double T;
+ \brief Bottom
+ double B;
-/*! \brief File definition */
+ \brief File definition
struct gvfile
+ \brief File descriptor
FILE *file;
- char *start; /* pointer to beginnig of the file in the memory */
- char *current; /* current position set by dig_seek() */
- char *end; /* end of file in the memory (pointer to first byte after) */
- off_t size; /* size of the file loaded to memory */
- off_t alloc; /* allocated space */
- int loaded; /* 0 - not loaded, 1 - loaded */
+ \brief Pointer to beginnig of the file in the memory
+ char *start;
+ \brief Current position set by dig_seek()
+ char *current;
+ \brief End of file in the memory (pointer to first byte after)
+ char *end;
+ \brief Size of the file loaded to memory
+ off_t size;
+ \brief Allocated space
+ off_t alloc;
+ \brief Is file loaded?
+ - 0 - not loaded
+ - 1 - loaded
+ int loaded;
-/*! \brief Field information */
+ \brief Field (layer) information
struct field_info
- int number; /* field number */
- char *name; /* field name */
- char *driver; /* db driver */
- char *database; /* db database */
- char *table; /* db table */
- char *key; /* table key */
+ \brief Field number
+ int number;
+ \brief Field name (optional)
+ char *name;
+ \brief Name of DB driver ('sqlite', 'dbf', ...)
+ char *driver;
+ brief Name of database
+ char *database;
+ \brief Name of DB table
+ char *table;
+ \brief Name of key column (usually 'cat')
+ char *key;
-/*! \brief Database links */
+ \brief Database links
struct dblinks
- struct field_info *field; /* pointer to the first field_info structure */
- int alloc_fields; /* number of allocated slots */
- int n_fields; /* number of available fields */
+ \brief Pointer to the first field_info structure
+ struct field_info *field;
+ \brief Number of allocated slots
+ int alloc_fields;
+ \brief Number of available fields (layers)
+ int n_fields;
-/*! \brief Portability info - set in V1_open_new/old() */
+ \brief Portability info
+ Set by V1_open_new() or V1_open_old()
struct Port_info
- int byte_order; /* file byte order */
- int off_t_size; /* off_t size */
+ \brief File byte order
+ int byte_order;
+ \brief Size of `off_t` data type
+ int off_t_size;
- /* conversion matrices between file and native byte order */
+ \brief Vonversion matrices between file and native byte order (double)
unsigned char dbl_cnvrt[PORT_DOUBLE];
+ \brief Vonversion matrices between file and native byte order (float)
unsigned char flt_cnvrt[PORT_FLOAT];
+ \brief Vonversion matrices between file and native byte order (long)
unsigned char lng_cnvrt[PORT_LONG];
+ \brief Vonversion matrices between file and native byte order (int)
unsigned char int_cnvrt[PORT_INT];
+ \brief Vonversion matrices between file and native byte order (short)
unsigned char shrt_cnvrt[PORT_SHORT];
+ \brief Vonversion matrices between file and native byte order (off_t)
unsigned char off_t_cnvrt[PORT_OFF_T];
- /* *_quick specify if native byte order of that type is the same
- as byte order of vector file (TRUE) or not (FALSE) */
+ \brief Byte order for dbl
+ Specify if native byte order of that type is the same
+ as byte order of vector file (TRUE) or not (FALSE)
int dbl_quick;
int flt_quick;
+ \brief Byte order for lng
int lng_quick;
+ \brief Byte order for int
int int_quick;
+ \brief Byte order for shrt
int shrt_quick;
+ \brief Byte order for off_t
int off_t_quick;
-/*! \brief List of dead lines in the file, the space can be reused,
- not yet used
+ \brief List of dead lines in the file
\todo Implement it
+ The space can be reused, not yet used
struct recycle
char dummy;
-/*! \brief Vector map head */
+ \brief Vector map header
struct dig_head
- /* elements */
- char *organization; /* orgranization name */
- char *date; /* map date */
- char *your_name; /* user name */
- char *map_name; /* map name */
- char *source_date; /* source date */
- long orig_scale; /* original scale */
- char *line_3; /* comments */
- int plani_zone; /* zone */
- double digit_thresh; /* threshold for digitization */
+ \brief Orgranization name
+ char *organization;
+ \brief Map date
+ char *date;
+ \brief User name
+ char *your_name;
+ \brief Map name
+ char *map_name;
+ \brief Source date
+ char *source_date;
+ \brief Original scale
+ long orig_scale;
+ \brief Comments
+ char *line_3;
+ \brief Zone (UTM only)
+ int plani_zone;
+ \brief Threshold for digitization
+ double digit_thresh;
/* Programmers should NOT touch any thing below here */
/* Library takes care of everything for you */
/* coor elements */
- int Version_Major; /* backward compatibility info */
+ \brief Backward compatibility info - major version
+ int Version_Major;
+ \brief Backward compatibility info - minor version
int Version_Minor;
+ \brief Backward compatibility info - back major version
int Back_Major;
+ \brief Backward compatibility info - back minor version
int Back_Minor;
- int with_z; /* 2D/3D vector data */
+ \brief 2D/3D vector data
- off_t size; /* coor file size */
- long head_size; /* coor header size */
+ - zero for 2D data
+ - non-zero for 3D data
+ int with_z;
- struct Port_info port; /* portability information */
+ \brief Coor file size
+ off_t size;
+ \brief Coor header size
+ long head_size;
- off_t last_offset; /* offset of last read line */
+ \brief Portability information
+ struct Port_info port;
- struct recycle *recycle; /* recycle dead line, not implemented yet */
+ \brief Offset of last read line
+ off_t last_offset;
+ \brief Recycle dead line
+ \todo Not implemented yet
+ struct recycle *recycle;
-/*! \brief Coor file info */
+ \brief Coor file info
struct Coor_info
- off_t size; /* total size, in bytes */
- long mtime; /* time of last modification */
+ \brief Total size (in bytes)
+ off_t size;
+ \brief Time of last modification
+ long mtime;
-/*! \brief Non-native format info (OGR)
+ \brief Non-native format info (OGR)
\todo Structure size should not change depending on compilation I
-think, do it better */
+think, do it better
struct Format_info_ogr
- char *driver_name; /* OGR driver name */
- char *dsn; /* OGR datasource name */
- char *layer_name; /* OGR layer name */
+ \brief OGR driver name
+ char *driver_name;
+ \brief OGR datasource name
+ char *dsn;
+ \brief OGR layer name
+ char *layer_name;
#ifdef HAVE_OGR
- OGRSFDriverH driver; /* pointer to OGRDriver */
- OGRDataSourceH ds; /* pointer to OGRDataSourceH */
- OGRLayerH layer; /* pointer to OGRLayerH */
+ \brief Pointer to OGRDriver
+ OGRSFDriverH driver;
+ \brief Pointer to OGRDataSource
+ OGRDataSourceH ds;
+ \brief Pointer to OGRLayer
+ OGRLayerH layer;
#else
void *driver;
void *ds;
void *layer;
#endif
+ \brief Array of OGR DSN options
char **dsn_options;
+ \brief Array of OGR layer options
char **layer_options;
/* Level 1 (used by V*_read_next_line_ogr) */
- struct line_pnts **lines; /* points cache */
- int *lines_types; /* list of line types */
- int lines_alloc; /* number of allocated lines */
- int lines_num; /* number of lines in cache */
- int lines_next; /* next line to be read from cache */
+ \brief Points cache (level 1)
+ struct line_pnts **lines;
+ \brief List of line types (level 1)
+ int *lines_types;
+ \brief Number of allocated lines (level 1)
+ int lines_alloc;
+ \brief Number of lines in cache (level 1)
+ int lines_num;
+ \brief Next line to be read from cache (level 1)
+ int lines_next;
/* Level 2 */
+ \brief Cache to avoid repeated reading (level 2)
+ NULL if no feature is in cache
#ifdef HAVE_OGR
- OGRFeatureH feature_cache; /* cache to avoid repeated reading, NULL if no feature is in cache */
+ OGRFeatureH feature_cache;
#else
void *feature_cache;
#endif
- int feature_cache_id; /* id of feature read in feature_cache */
+ \brief Feature id read in feature_cache (level 2)
+ int feature_cache_id;
- /* Array where OGR feature/part info is stored for each line in
- * GRASS. This is not used for GV_CENTROID. Because one feature
- * may contain more elements (geometry collection also
- * recursively), offset for one line may be stored in more
- * records. First record is FID, next records are part indexes if
- * necessary. Example: 5. ring in 3. polygon in 7. feature
- * (multipolygon) of geometry collection which has FID = 123 123
- * (feature 123: geometry colletion) 6 (7. feature in geometry
- * collection: multiPolygon) 2 (3. polygon) 4 (5. ring in the
- * polygon)
- int *offset; /* offset list */
- int offset_num; /* number of items in offset */
- int offset_alloc; /* space allocated for offset */
+ \brief Offset list
- int next_line; /* used by V2_read_next_line_ogr */
+ Array where OGR feature/part info is stored for each line in
+ GRASS. This is not used for GV_CENTROID. Because one feature
+ may contain more elements (geometry collection also
+ recursively), offset for one line may be stored in more
+ records. First record is FID, next records are part indexes if
+ necessary. Example: 5. ring in 3. polygon in 7. feature
+ (multipolygon) of geometry collection which has FID = 123 123
+ (feature 123: geometry colletion) 6 (7. feature in geometry
+ collection: multiPolygon) 2 (3. polygon) 4 (5. ring in the
+ polygon)
+ int *offset;
+ \brief Number of items in offset
+ int offset_num;
+ \brief Space allocated for offset
+ int offset_alloc;
+ Used by V2_read_next_line_ogr()
+ int next_line;
-/*! \brief Non-native format info */
+ \brief Non-native format info (currently only OGR is implemented)
struct Format_info
- int i; /* id? */
- struct Format_info_ogr ogr; /* OGR info */
+ \brief id?
+ int i;
+ \brief OGR info
+ struct Format_info_ogr ogr;
-/*! \brief Category index */
+ \brief Category index
struct Cat_index
- int field; /* field number */
- int n_cats; /* number of items in cat array */
- int a_cats; /* allocated space in cat array */
- int (*cat)[3]; /* array of cats (cat, type, lines/area) */
- int n_ucats; /* number of unique cats (not updated) */
- int n_types; /* number of types in type */
- int type[7][2]; /* number of elements for each type
- * (point, line, boundary, centroid,
- * area, face, kernel) */
- off_t offset; /* offset of the beginning of this
- * index in cidx file */
+ \brief Field (layer) number
+ int field;
+ \brief Number of items in cat array
+ int n_cats;
+ \brief Allocated space in cat array
+ int a_cats;
+ \brief Array of cats (cat, type, lines/area)
+ int (*cat)[3];
+ \brief Number of unique cats (not updated)
+ int n_ucats;
+ \brief Number of types in type
+ int n_types;
+ \brief Number of elements for each type
+ - GV_POINT
+ - GV_LINE
+ - GV_BOUNDARY
+ - GV_CENTROID
+ - GV_FACE
+ - GV_KERNEL
+ - GV_AREA
+ int type[7][2];
+ \brief Offset of the beginning of this index in cidx file
+ off_t offset;
-/*! \brief Plus head info */
+ \brief Plus header info
struct Plus_head
- /*** version info ***/
- int Version_Major; /* version codes */
+ \brief Version info (major)
+ \brief Version info (minor)
int Version_Minor;
- int Back_Major; /* earliest version that can use this data format */
+ \brief Earliest version that can use this data format (major)
+ int Back_Major;
+ \brief Earliest version that can use this data format (minor)
int Back_Minor;
- int spidx_Version_Major; /* version codes for spatial index */
+ \brief Version codes for spatial index (major)
+ int spidx_Version_Major;
+ \brief Version codes for spatial index (minor)
int spidx_Version_Minor;
- int spidx_Back_Major; /* earliest version that can use this data format */
+ int spidx_Back_Major;
int spidx_Back_Minor;
- int cidx_Version_Major; /* version codes for category index */
+ \brief Version codes for category index (major)
+ int cidx_Version_Major;
+ \brief Version codes for category index (minor)
int cidx_Version_Minor;
- int cidx_Back_Major; /* earliest version that can use this data format */
+ int cidx_Back_Major;
int cidx_Back_Minor;
- int spidx_with_z; /* 2D/3D spatial index */
- int off_t_size; /* offset size here because Plus_head
- is available to all releveant
- functions */
+ - WITH_Z
+ - WITHOUT_Z
+ int with_z;
+ \brief 2D/3D spatial index
+ - WITH_Z
+ - WITHOUT_Z
+ int spidx_with_z;
+ \brief Offset size
+ Because Plus_head is available to all releveant
+ functions
+ int off_t_size;
/*** file header size ***/
- long head_size; /* topo header size */
- long spidx_head_size; /* spatial index header size */
- long cidx_head_size; /* category index header size */
+ \brief Topo header size
+ long head_size;
+ \brief Spatial index header size
+ long spidx_head_size;
+ \brief Category index header size
+ long cidx_head_size;
- int release_support; /* release memory occupied by support
- (topo, spatial, category) */
+ \brief Release memory occupied by support
+ (topo, spatial, category)
+ int release_support;
/*** portability info */
- struct Port_info spidx_port; /* portability information for
- spatial index */
- struct Port_info cidx_port; /* portability information for
- category index */
- int mode; /* read, write, RW */
- int built; /* the highest level of topology
- currently available
- (GV_BUILD_*) */
+ \brief Portability information for spatial index
+ struct Port_info spidx_port;
+ category index
+ struct Port_info cidx_port;
+ \brie Access mode
+ - GV_MODE_READ
+ - GV_MODE_WRITE
+ - GV_MODE_RW
+ int mode;
- struct bound_box box; /* vector map bounding box */
+ \brief Highest level of topology currently available
+ - GV_BUILD_NONE
+ - GV_BUILD_BASE
+ - GV_BUILD_AREAS
+ - GV_BUILD_ATTACH_ISLES
+ - GV_BUILD_CENTROIDS
+ - GV_BUILD_ALL
+ int built;
+ \brief Bounding box of features
+ struct bound_box box;
/*** topology ***/
- struct P_node **Node; /* struct P_node array of pointers
- 1st item is 1 for */
- struct P_line **Line; /* struct P_line array of pointers
- all these (not 0) */
+ \brief Array topo nodes
+ struct P_node **Node;
+ \brief Array topo lines/edges
+ struct P_line **Line;
+ \brief Array topo areas
struct P_area **Area;
+ \brief Array topo isles
struct P_isle **Isle;
- /* add here P_FACE, P_VOLUME, P_HOLE */
+ /* add here P_FACE, P_VOLUME, P_HOLE */
+ \brief Current number of nodes
+ plus_t n_nodes;
+ \brief Current number of edges
+ plus_t n_edges;
+ \brief Current number of lines
+ plus_t n_lines;
+ \brief Current number of areas
+ plus_t n_areas;
+ \brief Current number of isles
+ plus_t n_isles;
+ \brief Current number of faces
+ plus_t n_faces;
+ \brief Current number of volumes
+ plus_t n_volumes;
+ \brief Current number of holes
+ plus_t n_holes;
- plus_t n_nodes; /* current number of nodes */
- plus_t n_edges; /* current number of edges */
- plus_t n_lines; /* current number of lines */
- plus_t n_areas; /* current number of areas */
- plus_t n_isles; /* current number of isles */
- plus_t n_faces; /* current number of faces */
- plus_t n_volumes; /* current number of volumes */
- plus_t n_holes; /* current number of holes */
+ \brief Current number of points
+ plus_t n_plines;
+ plus_t n_llines;
+ \brief Current number of boundaries
+ plus_t n_blines;
+ \brief Current number of centroids
+ plus_t n_clines;
+ plus_t n_flines;
+ \brief Current number of kernels
+ plus_t n_klines;
+ \brief Current number of volume faces
+ plus_t n_vfaces;
+ \brief Current number of hole faces
+ plus_t n_hfaces;
- plus_t n_plines; /* current number of points */
- plus_t n_llines; /* current number of lines */
- plus_t n_blines; /* current number of boundaries */
- plus_t n_clines; /* current number of centroids */
- plus_t n_flines; /* current number of faces */
- plus_t n_klines; /* current number of kernels*/
- plus_t n_vfaces; /* current number of volume faces */
- plus_t n_hfaces; /* current number of hole faces */
+ \brief Number of allocated nodes
- plus_t alloc_nodes; /* number of nodes we have alloc'ed
- space for i.e. array size - 1 */
- plus_t alloc_edges; /* number of edges we have alloc'ed space for */
- plus_t alloc_lines; /* number of lines we have alloc'ed space for */
- plus_t alloc_areas; /* number of areas we have alloc'ed space for */
- plus_t alloc_isles; /* number of isles we have alloc'ed space for */
- plus_t alloc_faces; /* number of faces we have alloc'ed space for */
- plus_t alloc_volumes; /* number of volumes we have alloc'ed space for */
- plus_t alloc_holes; /* number of holes we have alloc'ed space for */
+ i.e. array size - 1
+ plus_t alloc_nodes;
+ \brief Number of allocated edges
- off_t Node_offset; /* offset of array of nodes in topo file */
- off_t Edge_offset; /* offset of array of edges in topo file */
- off_t Line_offset; /* offset of array of lines in topo file */
- off_t Area_offset; /* offset of array of areas in topo file */
- off_t Isle_offset; /* offset of array of isles in topo file */
- off_t Volume_offset; /* offset of array of volumes in topo file */
- off_t Hole_offset; /* offset of array of holes in topo file */
+ plus_t alloc_edges;
+ plus_t alloc_lines;
+ \brief Number of allocated areas
+ plus_t alloc_areas;
+ \brief Number of allocated isles
+ plus_t alloc_isles;
+ \brief Number of allocated faces
+ plus_t alloc_faces;
+ \brief Number of allocated volumes
+ plus_t alloc_volumes;
+ \brief Number of allocated holes
+ plus_t alloc_holes;
+ \brief Offset of array of nodes in topo file
+ off_t Node_offset;
+ \brief Offset of array of edges in topo file
+ off_t Edge_offset;
+ \brief Offset of array of lines in topo file
+ off_t Line_offset;
+ \brief Offset of array of areas in topo file
+ off_t Area_offset;
+ \brief Offset of array of isles in topo file
+ off_t Isle_offset;
+ \brief Offset of array of volumes in topo file
+ off_t Volume_offset;
+ \brief Offset of array of holes in topo file
+ off_t Hole_offset;
/*** spatial index ***/
- int Spidx_built; /* set to 1 if spatial index is available */
- int Spidx_new; /* set to 1 if new spatial index will be generated */
- int Spidx_file; /* set to 1 to build new indices in file */
+ \brief Spatial index built?
- struct gvfile spidx_fp; /* spatial index file pointer */
+ Set to 1 if spatial index is available
+ int Spidx_built;
+ \brief Build new spatial index
- off_t Node_spidx_offset; /* offset of nodes in sidx file */
- off_t Line_spidx_offset; /* offset of lines in sidx file */
- off_t Area_spidx_offset; /* offset of areas in sidx file */
- off_t Isle_spidx_offset; /* offset of isles in sidx file */
- off_t Face_spidx_offset; /* offset of faces in sidx file */
- off_t Volume_spidx_offset; /* offset of volumes in sidx file */
- off_t Hole_spidx_offset; /* offset of holes in sidx file */
+ Set to 1 if new spatial index will be generated
+ int Spidx_new;
+ \brief Build new spatial index in file
- struct RTree *Node_spidx; /* node spatial index */
- struct RTree *Line_spidx; /* line spatial index */
- struct RTree *Area_spidx; /* area spatial index */
- struct RTree *Isle_spidx; /* isle spatial index */
- struct RTree *Face_spidx; /* face spatial index */
- struct RTree *Volume_spidx; /* volume spatial index */
- struct RTree *Hole_spidx; /* hole spatial index */
+ Set to 1 to build new indices in file
+ int Spidx_file;
+ \brief Spatial index file pointer
+ struct gvfile spidx_fp;
+ \brief Offset of nodes in sidx file
+ off_t Node_spidx_offset;
+ \brief Offset of lines in sidx file
+ off_t Line_spidx_offset;
+ \brief Offset of areas in sidx file
+ off_t Area_spidx_offset;
+ \brief Offset of isles in sidx file
+ off_t Isle_spidx_offset;
+ \brief Offset of faces in sidx file
+ off_t Face_spidx_offset;
+ \brief Offset of volumes in sidx file
+ off_t Volume_spidx_offset;
+ \brief Offset of holes in sidx file
+ off_t Hole_spidx_offset;
+ \brief Node spatial index
+ struct RTree *Node_spidx;
+ \brief Line spatial index
+ struct RTree *Line_spidx;
+ \brief Area spatial index
+ struct RTree *Area_spidx;
+ \brief Isles spatial index
+ struct RTree *Isle_spidx;
+ \brief Faces spatial index
+ struct RTree *Face_spidx;
+ \brief Volumes spatial index
+ struct RTree *Volume_spidx;
+ \brief Holes spatial index
+ struct RTree *Hole_spidx;
/*** category index ***/
- /* By default, category index is not updated */
- int update_cidx; /* update category index if vector is modified */
+ \brief Update category index if vector is modified
- int n_cidx; /* number of cat indexes (one for each field) */
- int a_cidx; /* allocated space for cat indexes */
- struct Cat_index *cidx; /* array of category indexes */
- int cidx_up_to_date; /* set to 1 when cidx is created and reset to 0 whenever any line is changed */
+ By default, category index is not updated
+ int update_cidx;
- off_t coor_size; /* size of coor file */
- long coor_mtime; /* time of last coor modification */
+ \brief Number of category indexes (one for each field/layer)
+ int n_cidx;
+ \brief Allocated space for category indexes
+ int a_cidx;
+ \brief Array of category indexes
+ struct Cat_index *cidx;
+ \brief Category index to be updated
+ Set to 1 when cidx is created
+ and reset to 0 whenever any line is changed
+ int cidx_up_to_date;
+ \brief Size of coor file
+ off_t coor_size;
+ \brief Time of last coor modification
+ long coor_mtime;
/*** level 2 ***/
- /* update: list of lines and nodes updated (topo info for the line
- was changed) by last write/rewrite/delete operation.
- Lines/nodes in the list may be deleted (e.g. delete boundary:
- first added for delete area and then delete */
- int do_uplist; /* used internaly in diglib to know if list is maintained */
+ \brief Used internaly in diglib to know if list is maintained
+ int do_uplist;
- int *uplines; /* array of updated lines */
- int alloc_uplines; /* allocated array */
- int n_uplines; /* number of updated lines */
- int *upnodes; /* array of updated nodes */
- int alloc_upnodes; /* allocated array */
- int n_upnodes; /* number of updated nodes */
+ \brief Array of updated lines
+ List of lines and nodes updated (topo info for the line was
+ changed) by last write/rewrite/delete operation. Lines/nodes in
+ the list may be deleted (e.g. delete boundary: first added for
+ delete area and then delete
+ int *uplines;
+ \brief Allocated array (level 2)
+ int alloc_uplines;
+ \brief Number of updated lines (level 2)
+ int n_uplines;
+ \brief Array of updated nodes (level 2)
+ int *upnodes;
+ int alloc_upnodes;
+ \brief number of updated nodes (level 2)
+ int n_upnodes;
-/*! \brief Vector map info */
+/*! \brief
+ Vector map info
struct Map_info
/* common info for all formats */
- int format; /* format (native, ogr) */
- int temporary; /* temporary file flag, not yet used */
+ \brief Format (native, ogr)
+ - GV_FORMAT_NATIVE
+ - GV_FORMAT_OGR
+ - GV_FORMAT_DIRECT
+ int format;
+ \brief Temporary file flag, not yet used
+ int temporary;
- struct dblinks *dblnk; /* info about db links */
+ \brief DB links
+ struct dblinks *dblnk;
- struct Plus_head plus; /* topo file head info */
+ \brief Header info
+ struct Plus_head plus;
/* graph-related section */
- int graph_line_type; /* line type used to build the graph */
- dglGraph_s graph; /* graph structure */
- dglSPCache_s spCache; /* shortest path cache */
- double *edge_fcosts; /* costs used for graph, (dglGetEdge()
- is not supported for _DGL_V1) */
+ \brief Graph-related section - line type used to build the graph
+ int graph_line_type;
+ \brief Graph-related section - graph structure
+ dglGraph_s graph;
+ \brief Graph-related section - shortest path cache
+ dglSPCache_s spCache;
+ \brief Graph-related section - forward costs used for graph
+ dglGetEdge() is not supported for _DGL_V1)
+ double *edge_fcosts;
+ \brief Graph-related section - backward costs used for graph
double *edge_bcosts;
- double *node_costs; /* node costs */
- int cost_multip; /* edge and node costs
- multiplicator */
+ \brief Graph-related section - node costs used for graph
+ double *node_costs;
+ \brief Graph-related section - edge and node costs multiplicator
+ int cost_multip;
- int open; /* should be 0x5522AA22 (VECT_OPEN_CODE) if opened correctly
- or 0x22AA2255 (VECT_CLOSED_CODE) if closed
- anything else implies that structure has
- never been initialized
- int mode; /* Open mode - read (GV_MODE_READ),
- write (GV_MODE_WRITE),
- rw (GV_MODE_RW) */
- int level; /* Topology level - 1, 2, (3) */
- int head_only; /* only header is opened */
- int support_updated; /* support files were updated */
- plus_t next_line; /* for level 2 sequential reads */
+ \brief Open indicator
- char *name; /* for 4.0 just name, and mapset */
- char *mapset; /* mapset name */
+ Should be 0x5522AA22 (VECT_OPEN_CODE) if opened correctly
+ or 0x22AA2255 (VECT_CLOSED_CODE) if closed
+ anything else implies that structure has
+ never been initialized
+ int open;
+ /* Open mode
+ - read (GV_MODE_READ),
+ - write (GV_MODE_WRITE),
+ - rw (GV_MODE_RW)
+ int mode;
+ \brief Topology level
+ - 1 (without topo)
+ - 2 (with topo)
+ - 3 (with 3D topo) - not yet implemented
+ int level;
+ \brie Open only header
+ Non-zero code to open only header of vector map
+ int head_only;
+ \brief Support files were updated
+ Non-zero code to indicate that supoort file were updated
+ int support_updated;
+ \brief Sequential read (level 1)
+ plus_t next_line;
+ \brief Map name (for 4.0)
+ char *name;
+ \brief Mapset name
+ char *mapset;
/* location and gisdbase is usefull if changed (v.proj or external apps) */
- char *location; /* location name */
- char *gisdbase; /* gisdbase path */
+ \brief Location name
+ char *location;
+ \brief GISDBASE path
+ char *gisdbase;
/* constraints for reading in lines (not polys yet) */
+ \brief Constrainys for reading features (region)
+ Non-zero code to enable this constraint
int Constraint_region_flag;
+ \brief Constraints for reading features (type)
int Constraint_type_flag;
+ \brief Constraints for reading features (north)
double Constraint_N;
+ \brief Constraints for reading features (south)
double Constraint_S;
+ \brief Constraints for reading features (east)
double Constraint_E;
+ \brief Constraints for reading features (west)
double Constraint_W;
+ \brief Constraints for reading features (top)
double Constraint_T;
+ \brief Constraints for reading features (bottom)
double Constraint_B;
int Constraint_type;
+ \brief ???
int proj;
/* format specific */
- /* native */
- struct gvfile dig_fp; /* dig file pointer */
- struct dig_head head; /* coor file head */
+ \brief GV file pointer (native format only)
+ struct gvfile dig_fp;
+ \brief Coor file header info (native format only)
+ struct dig_head head;
/* non native */
- struct Format_info fInfo; /* format information */
+ \brief Format info for non-native formats
+ struct Format_info fInfo;
- /* history file */
+ \brief History file
FILE *hist_fp;
/* temporary solution for sites - to be removed ?*/
- struct site_att *site_att; /* array of attributes loaded from db */
- int n_site_att; /* number of attributes in site_att array */
- int n_site_dbl; /* number of double attributes for one site */
- int n_site_str; /* number of string attributes for one site */
+ \brief Array of attributes loaded from db
+ \todo To be removed?
+ struct site_att *site_att;
+ \brief Number of attributes in site_att array
+ int n_site_att;
+ \brief Number of double attributes for one site
+ int n_site_dbl;
+ \brief Number of string attributes for one site
+ int n_site_str;
-/*! \brief Node (topology) info */
+ \brief Topological primitive - node
struct P_node
+ \brief X coordinate
double x; /* X coordinate */
- double y; /* Y coordinate */
- double z; /* Z coordinate */
- plus_t alloc_lines; /* allocated space for lines */
- plus_t n_lines; /* number of attached lines (size of
- lines, angle). If 0, then is
- degenerate node, for snappingi ???
- plus_t *lines; /* list of connected lines */
- float *angles; /* respected angles; angles for
- lines/boundaries are in radians
- between -PI and PI. Value for
- points or lines with identical
- points (degenerated) is set to
- -9. */
+ \brief Y coordinate
+ double y;
+ \brief Z coordinate (used only for 3D data
+ double z;
+ \brief Allocated space for lines
+ \brief Number of attached lines (size of
+ lines, angle)
+ If 0, then is degenerate node, for snappingi ???
+ plus_t n_lines;
+ \brief List of connected lines
+ plus_t *lines;
+ \brief List of respected angles
+ Angles for lines/boundaries are in radians between -PI and
+ PI. Value for points or lines with identical points
+ (degenerated) is set to -9.
+ float *angles;
-/*! \brief Line (topology) info */
+ \brief Topological primitive - line (edge)
struct P_line
- plus_t N1; /* start node */
- plus_t N2; /* end node */
- plus_t left; /* area/isle number to left, negative
- for isle area number for centroid,
- negative for duplicate centroid
- plus_t right; /* area/isle number to right, negative
- * for isle */
+ \brief Start node
+ plus_t N1;
+ \brief End node
+ plus_t N2;
+ \brief Area/isle number to left
- double N; /* line bounding Box */
+ - negative for isle
+ - area number for centroid (negative for duplicate centroid)
+ plus_t left;
+ \brief Area/isle number to right
+ plus_t right;
+ \brief Line bounding box - north
+ double N;
+ \brief Line bounding box - south
double S;
+ \brief Line bounding box - east
double E;
+ \brief Line bounding box - west
double W;
+ \brief Line bounding box - top (3D data only)
+ double T;
+ \brief Line bounding box - bottom (3D data only)
+ double B;
- off_t offset; /* offset in coor file for line */
- int type; /* line type */
+ \brief Offset in coor file for line
+ off_t offset;
+ \brief Line type
+ - GV_POINT
+ - GV_LINE
+ - GV_BOUNDARY
+ - GV_CENTROID
+ - GV_FACE
+ - GV_KERNEL
+ - GV_AREA
+ - GV_VOLUME
+ int type;
-/*! \brief Area (topology) info */
+ \brief Topological primitive - area
struct P_area
- double N; /* area bounding Box */
+ \brief Area bounding box - north
+ double N;
+ \brief Area bounding box - south
double S;
+ \brief Area bounding box - east
double E;
+ \brief Area bounding box - west
double W;
- plus_t n_lines; /* number of boundary lines */
- plus_t alloc_lines; /* allocated space */
- plus_t *lines; /* list of boundary lines, negative
- means direction N2 to N1, lines are
- in clockwise order */
+ \brief Area bounding box - top
+ double T;
+ \brief Area bounding box - bottom
+ double B;
+ \brief Number of boundary lines
+ plus_t n_lines;
+ \brief List of boundary lines
+ - negative means direction N2 to N1
+ - lines are in clockwise order
+ plus_t *lines;
/********* Above this line is compatible with P_isle **********/
- plus_t centroid; /* number of first centroid within area */
- plus_t n_isles; /* number of islands inside */
+ \brief Number of first centroid within area
+ plus_t centroid;
+ \brief Number of islands inside
+ plus_t n_isles;
+ \brief Allocated space for isles
plus_t alloc_isles;
- plus_t *isles; /* 1st generation interior islands */
+ \brief 1st generation interior islands
+ plus_t *isles;
-/*! \brief Isle (topology) info */
+ \brief Topological primitive - isle
struct P_isle
- double N; /* isle bounding Box */
+ \brief Isle bounding box - north
+ double N;
+ \brief Isle bounding box - south
double S;
+ \brief Isle bounding box - east
double E;
+ \brief Isle bounding box - west
double W;
+ \brief Isle bounding box - top
+ double T;
+ \brief Isle bounding box - bottom
+ double B;
+ plus_t n_lines;
plus_t alloc_lines;
- in counter clockwise order */
+ - lines are in counter clockwise order
+ plus_t *lines;
/********* Above this line is compatible with P_area **********/
- plus_t area; /* area it exists w/in, if any */
+ \brief Area it exists w/in, if any
+ plus_t area;
-/*! \brief Line points (feature geometry info */
+ \brief Feature geometry info
struct line_pnts
- double *x; /* pointer to 1st x coordinate */
- double *y; /* pointer to 1st y coordinate */
- double *z; /* pointer to 1st z coordinate */
- int n_points; /* number of points */
- int alloc_points; /* allocated space */
+ \brief Array of X coordinates
+ double *x;
+ \brief Array of Y coordinates
+ double *y;
+ \brief Array of Z coordinates
+ double *z;
+ \brief Number of points
+ int n_points;
+ \brief Allocated space for points
+ int alloc_points;
-/*! \brief Line categories (feature category info */
+ \brief Feature category info
struct line_cats
- int *field; /* pointer to array of fields */
- int *cat; /* pointer to array of categories */
- int n_cats; /* number of vector categories attached to element */
- int alloc_cats; /* allocated space */
+ \brief Array of fields (layers)
+ int *field;
+ \brief Array of categories
+ int *cat;
+ \brief Number of categories attached to element
+ int n_cats;
+ \brief Allocated space for categories
+ int alloc_cats;
/*! \brief Category list */
struct cat_list
- int field; /* category field */
- int *min; /* pointer to array of minimun values */
- int *max; /* pointer to array of maximum values */
- int n_ranges; /* number ranges */
- int alloc_ranges; /* allocated space */
+ \brief Category field (layer)
+ int field;
+ \brief Array of minimun values
+ int *min;
+ \brief Array of maximum values
+ int *max;
+ \brie Number of ranges
+ int n_ranges;
+ \brief Allocated space for ranges
+ int alloc_ranges;
-/*! \brief List of integers
+ \brief List of integers
\todo To be moved to gislib?
struct ilist
- int *value; /* items */
- int n_values; /* number of values */
- int alloc_values; /* allocated space */
+ \brief Array of values
+ int *value;
+ \brief Number of values in the array
+ int n_values;
+ \brief Allocated space for values
+ int alloc_values;
-/*! \brief Vector array. Space allocated is size + 1. */
+ \brief Vector array
+ Space allocated is size + 1
struct varray
- int size; /* array size */
- int *c; /* array where 'class' or new category
- or something like that is stored */
+ \brief Array size
+ int size;
+ \brief Array
+ Where 'class' or new category
+ or something like that is stored
+ int *c;
-/*! \brief Spatial index for use in modules. */
+ \brief Spatial index info
+ For use in modules
struct spatial_index
- struct RTree *si_tree; /* pointer to the tree */
- char *name; /* sidx name */
+ \brief Pointer to the search tree (R*Tree)
+ struct RTree *si_tree;
+ \brief Name (used ?)
+ char *name;
#endif /* DIG___STRUCTS___ */
