[GRASS-SVN] r46859 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Jun 30 05:52:26 EDT 2011
Author: martinl
Date: 2011-06-30 02:52:26 -0700 (Thu, 30 Jun 2011)
New Revision: 46859
grass/trunk/lib/init/grass.py
check if GRASS_ADDON_PATH is undefined, then use $HOME/.grass7/addons
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-06-30 07:39:13 UTC (rev 46858)
+++ grass/trunk/lib/init/grass.py 2011-06-30 09:52:26 UTC (rev 46859)
@@ -276,11 +276,14 @@
def set_paths():
addon_path = os.getenv('GRASS_ADDON_PATH')
- if addon_path:
- path_prepend(addon_path, 'PATH')
- path_prepend(os.path.join(addon_path, 'scripts'), 'PATH')
- path_prepend(os.path.join(addon_path, 'bin'), 'PATH')
+ if not addon_path:
+ addon_path = os.path.join(os.getenv('HOME'), '.grass7', 'addons')
+ message(_("GRASS_ADDON_PATH undefined, using '%s'") % addon_path)
+ path_prepend(addon_path, 'PATH')
+ path_prepend(os.path.join(addon_path, 'scripts'), 'PATH')
+ path_prepend(os.path.join(addon_path, 'bin'), 'PATH')
path_prepend(gfile('scripts'), 'PATH')
path_prepend(gfile('bin'), 'PATH')
