[GRASS-SVN] r45714 - grass/branches/develbranch_6/vector/v.in.dwg
svn_grass at osgeo.org
Fri Mar 18 15:10:28 EDT 2011
Author: martinl
Date: 2011-03-18 12:10:28 -0700 (Fri, 18 Mar 2011)
New Revision: 45714
grass/branches/develbranch_6/vector/v.in.dwg/main.c
fix r45706
Modified: grass/branches/develbranch_6/vector/v.in.dwg/main.c
--- grass/branches/develbranch_6/vector/v.in.dwg/main.c 2011-03-18 19:07:00 UTC (rev 45713)
+++ grass/branches/develbranch_6/vector/v.in.dwg/main.c 2011-03-18 19:10:28 UTC (rev 45714)
@@ -216,7 +216,7 @@
if (db_execute_immediate(driver, &sql) != DB_OK) {
db_close_database(driver);
db_shutdown_driver(driver);
- G_fatal_error(_("Unable to create table: '%s'", db_get_string(&sql)));
+ G_fatal_error(_("Unable to create table: '%s'"), db_get_string(&sql));
if (db_create_index2(driver, Fi->table, "cat") != DB_OK)
