[GRASS-SVN] r45715 - grass/trunk/vector/v.in.dwg
Fri Mar 18 15:14:36 EDT 2011
Author: martinl
Date: 2011-03-18 12:14:36 -0700 (Fri, 18 Mar 2011)
New Revision: 45715
   grass/trunk/vector/v.in.dwg/main.c
fix r45706
Modified: grass/trunk/vector/v.in.dwg/main.c
--- grass/trunk/vector/v.in.dwg/main.c	2011-03-18 19:10:28 UTC (rev 45714)
+++ grass/trunk/vector/v.in.dwg/main.c	2011-03-18 19:14:36 UTC (rev 45715)
@@ -234,7 +234,7 @@
     if (db_execute_immediate(driver, &sql) != DB_OK) {
 	db_close_database(driver);
 	db_shutdown_driver(driver);
-	G_fatal_error(_("Unable to create table: '%s'", db_get_string(&sql)));
+	G_fatal_error(_("Unable to create table: '%s'"), db_get_string(&sql));
     if (db_create_index2(driver, Fi->table, "cat") != DB_OK)
