[GRASS-SVN] r45726 - grass/trunk/lib/init
svn_grass at osgeo.org
Tue Mar 22 10:43:53 EDT 2011
Author: martinl
Date: 2011-03-22 07:43:53 -0700 (Tue, 22 Mar 2011)
New Revision: 45726
grass/trunk/lib/init/grass.py
startup: create new location using -c
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-03-22 14:17:56 UTC (rev 45725)
+++ grass/trunk/lib/init/grass.py 2011-03-22 14:43:53 UTC (rev 45726)
@@ -48,7 +48,7 @@
# i18N
import gettext
-gettext.install('grasslibs', os.path.join(gisbase, 'locale'), unicode=True)
+gettext.install('grasslibs', os.path.join(gisbase, 'locale'), unicode = True)
tmpdir = None
lockfile = None
@@ -152,7 +152,7 @@
_("Flags"),
_("print this help message"),
_("show version information and exit"),
- _("create given mapset if it doesn't exist"),
+ _("create given location/mapset if it doesn't exist"),
_("use text based interface"),
_("and set as default"),
_("use $DEFAULT_GUI graphical user interface"),
@@ -428,7 +428,7 @@
kv['GRASS_GUI'] = grass_gui
write_gisrc(kv)
-def non_interactive(arg):
+def non_interactive(arg, geofile = None):
global gisdbase, location_name, mapset, location
# Try non-interactive startup
l = None
@@ -460,9 +460,20 @@
else:
# the user wants to create mapset on the fly
if create_new:
- if not os.access(os.path.join(os.path.join(gisdbase, location_name, "PERMANENT", "DEFAULT_WIND")), os.F_OK):
- fatal(_("The location <%s> does not exist. Please create it first.") % location_name)
+ if not os.access(os.path.join(os.path.join(gisdbase, location_name,
+ "PERMANENT", "DEFAULT_WIND")), os.F_OK):
+ # create new location
+ gisdbase = os.path.join(gisdbase, location_name)
+ location_name = mapset
+ mapset = "PERMANENT"
+ if os.access(os.path.join(os.path.join(gisdbase, location_name,
+ fatal(_("Failed to create new location. The location <%s> already exists." % location_name))
+ sys.path.append(gfile('etc', 'python'))
+ from grass.script import core as grass
+ grass.create_location(gisdbase, location_name, filename = geofile)
else:
+ # create new mapset
os.mkdir(location)
# copy PERMANENT/DEFAULT_WIND to <mapset>/WIND
s = readfile(os.path.join(gisdbase, location_name, "PERMANENT", "DEFAULT_WIND"))
@@ -826,11 +837,11 @@
args = []
for i in sys.argv[1:]:
# Check if the user asked for the version
- if i in ["-v","--version"]:
+ if i in ["-v", "--version"]:
message('\n' + readfile(gfile("etc", "license")))
sys.exit()
# Check if the user asked for help
- elif i in ["help","-h","-help","--help"]:
+ elif i in ["help", "-h", "-help", "--help"]:
help_message()
sys.exit()
# Check if the -text flag was given
@@ -840,7 +851,7 @@
elif i == "-gui":
grass_gui = default_gui
# Check if the -wxpython flag was given
- elif i in ["-wxpython","-wx"]:
+ elif i in ["-wxpython", "-wx"]:
grass_gui = 'wxpython'
# Check if the user wants to create a new mapset
elif i == "-c":
@@ -954,7 +965,11 @@
# Try interactive startup
location = None
else:
- non_interactive(args[0])
+ if create_new:
+ if len(args) > 1:
+ non_interactive(args[1], args[0])
+ else:
+ non_interactive(args[0])
# User selects LOCATION and MAPSET if not set
set_data()
