[GRASS-SVN] r45727 - grass/trunk/lib/init
svn_grass at osgeo.org
Tue Mar 22 10:59:49 EDT 2011
Author: martinl
Date: 2011-03-22 07:59:49 -0700 (Tue, 22 Mar 2011)
New Revision: 45727
grass/trunk/lib/init/grass.py
startup: support also `-c EPSG:x`
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2011-03-22 14:43:53 UTC (rev 45726)
+++ grass/trunk/lib/init/grass.py 2011-03-22 14:59:49 UTC (rev 45727)
@@ -471,7 +471,14 @@
fatal(_("Failed to create new location. The location <%s> already exists." % location_name))
sys.path.append(gfile('etc', 'python'))
from grass.script import core as grass
- grass.create_location(gisdbase, location_name, filename = geofile)
+ try:
+ if geofile and geofile.find('EPSG:') > -1:
+ epsg = geofile.split(':', 1)[1]
+ grass.create_location(gisdbase, location_name, epsg = epsg)
+ else:
+ grass.create_location(gisdbase, location_name, filename = geofile)
+ except grass.ScriptError, e:
+ fatal(e.value.strip('"').strip("'").replace('\\n', os.linesep))
else:
# create new mapset
os.mkdir(location)
