[GRASS-SVN] r45757 - in grass/branches/releasebranch_6_4/lib: ogsf symbol vector/Vlib
Sat Mar 26 06:53:54 EDT 2011
Author: marisn
Date: 2011-03-26 03:53:54 -0700 (Sat, 26 Mar 2011)
New Revision: 45757
   grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c
   grass/branches/releasebranch_6_4/lib/ogsf/gv.c
   grass/branches/releasebranch_6_4/lib/symbol/read.c
   grass/branches/releasebranch_6_4/lib/vector/Vlib/dbcolumns.c
Fix possible pointer and sprintf abuse (reported by cppcheck)
Modified: grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c
--- grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c	2011-03-26 10:22:29 UTC (rev 45756)
+++ grass/branches/releasebranch_6_4/lib/ogsf/GVL2.c	2011-03-26 10:53:54 UTC (rev 45757)
@@ -297,10 +297,10 @@
 	*rows = gvl->rows;
 	*cols = gvl->cols;
 	*depths = gvl->depths;
-    G_debug(3, "GVL_get_dims() id=%d, rows=%d, cols=%d, depths=%d",
+	G_debug(3, "GVL_get_dims() id=%d, rows=%d, cols=%d, depths=%d",
 	    gvl->gvol_id, gvl->rows, gvl->cols, gvl->depths);
     return;
Modified: grass/branches/releasebranch_6_4/lib/ogsf/gv.c
--- grass/branches/releasebranch_6_4/lib/ogsf/gv.c	2011-03-26 10:22:29 UTC (rev 45756)
+++ grass/branches/releasebranch_6_4/lib/ogsf/gv.c	2011-03-26 10:53:54 UTC (rev 45757)
@@ -181,11 +181,11 @@
     int i;
-    G_debug(5, "gv_set_defaults() id=%d", gv->gvect_id);
     if (!gv) {
 	return (-1);
+    G_debug(5, "gv_set_defaults() id=%d", gv->gvect_id);
     gv->filename = NULL;
     gv->n_lines = gv->n_surfs = gv->use_mem = 0;
Modified: grass/branches/releasebranch_6_4/lib/symbol/read.c
--- grass/branches/releasebranch_6_4/lib/symbol/read.c	2011-03-26 10:22:29 UTC (rev 45756)
+++ grass/branches/releasebranch_6_4/lib/symbol/read.c	2011-03-26 10:53:54 UTC (rev 45757)
@@ -216,7 +216,7 @@
     fclose(fp);
     G_free(s);			/* TODO: free all */
-    G_warning(msg);
+    G_warning("%s", msg);
     return NULL;
@@ -231,7 +231,7 @@
     int i, j, k, l;
     FILE *fp;
-    char group[500], name[500], buf[2001];
+    char group[500], name[500], buf[2001], temp_buf[2001];
     char *ms, *c;
     double x, y, x2, y2, rad, ang1, ang2;
     int r, g, b;
@@ -342,8 +342,8 @@
 		sscanf(data, "%lf %lf %lf %lf %lf %c", &x, &y, &rad, &ang1,
 		       &ang2, &clock);
 	    if (ret < 5) {
-		sprintf(buf, "Incorrect arc definition: '%s'", buf);
-		return (err(fp, symb, buf));
+		sprintf(temp_buf, "Incorrect arc definition: '%s'", buf);
+		return (err(fp, symb, temp_buf));
 	    if (ret == 6 && (clock == 'c' || clock == 'C'))
 		i = 1;
@@ -426,8 +426,8 @@
 	else {
-	    sprintf(buf, "Unknown keyword in symbol: '%s'", buf);
+	    sprintf(temp_buf, "Unknown keyword in symbol: '%s'", buf);
 	    break;
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/dbcolumns.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/dbcolumns.c	2011-03-26 10:22:29 UTC (rev 45756)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/dbcolumns.c	2011-03-26 10:53:54 UTC (rev 45757)
@@ -45,7 +45,7 @@
     dbHandle handle;
     dbString table_name;
     dbTable *table;
-    char buf[2000];
+    char buf[2000], temp_buf[2000];
     num_dblinks = Vect_get_num_dblinks(Map);
@@ -75,9 +75,11 @@
 	if (col == 0)
 	    sprintf(buf, "%s",
 		    db_get_column_name(db_get_table_column(table, col)));
-	else
-	    sprintf(buf, "%s,%s", buf,
+	else {
+	    sprintf(temp_buf, ",%s",
+	    strcat(buf, temp_buf);
     G_debug(3, "%s", buf);
@@ -104,7 +106,7 @@
     dbHandle handle;
     dbTable *table;
-    char buf[2000];
@@ -135,10 +137,12 @@
 	    sprintf(buf, "%s",
 		    db_sqltype_name(db_get_column_sqltype
 				    (db_get_table_column(table, col))));
-	else
+	else {
@@ -166,7 +170,7 @@
     dbHandle handle;
     dbTable *table;
-    char buf[2000];
@@ -198,11 +202,13 @@
 		    db_get_column_name(db_get_table_column(table, col)),
-	else
-	    sprintf(buf, "%s,%s(%s)", buf,
+	else {
+	    sprintf(temp_buf, ",%s(%s)",
