[GRASS-SVN] r45758 - grass-addons/display/d.barb
Sat Mar 26 07:13:31 EDT 2011
Author: hamish
Date: 2011-03-26 04:13:31 -0700 (Sat, 26 Mar 2011)
New Revision: 45758
   grass-addons/display/d.barb/description.html
   grass-addons/display/d.barb/draw.c
   grass-addons/display/d.barb/grid.c
   grass-addons/display/d.barb/legend.c
   grass-addons/display/d.barb/local_proto.h
   grass-addons/display/d.barb/main.c
   grass-addons/display/d.barb/points.c
further improve barb rendering;
error mark fn takes e,n as coords;
border around legend example;
determine raster e,n coords from col,row;
fix arrow heading convention, drawing argument types
Modified: grass-addons/display/d.barb/description.html
--- grass-addons/display/d.barb/description.html	2011-03-26 10:53:54 UTC (rev 45757)
+++ grass-addons/display/d.barb/description.html	2011-03-26 11:13:31 UTC (rev 45758)
@@ -60,6 +60,13 @@
   80 35
   97 35
   97 5
+ color black
+ polyline
+  80 5
+  80 35
+  97 35
+  97 5
+  80 5
 EOF
 d.barb legend_velo=5,10,15,20,25 \
Modified: grass-addons/display/d.barb/draw.c
--- grass-addons/display/d.barb/draw.c	2011-03-26 10:53:54 UTC (rev 45757)
+++ grass-addons/display/d.barb/draw.c	2011-03-26 11:13:31 UTC (rev 45758)
@@ -6,7 +6,6 @@
 #include <grass/glocale.h>
 #include "local_proto.h"
-#define PI M_PI
 #define RpD ((2 * M_PI) / 360.) 	/* radians/degree */
 #define D2R(d) (double)(d * RpD)	/* degrees->radians */
@@ -17,7 +16,7 @@
     G_debug(3, "in draw_barb()");
-    unknown_(150, 50);
+//dbg:    unknown_(594578,4920392);
     R_standard_color(color);
@@ -32,12 +31,12 @@
     else {
 	/* calc barb parameters */
-//compass_deg=0;
+//dbg: compass_deg=0;
 	/* draw barb bits */
 	draw_circle(easting, northing, 10.0, FALSE);
 	draw_feather(easting, northing, 10.0 /*radius*/, velocity, compass_deg);
-//      int i;
+//dbg:      int i;
 //	for (i=0; i < 360; i+=20)
 //	    draw_feather(easting, northing, 20.0 /*radius*/, velocity, i);
@@ -50,7 +49,8 @@
 void arrow_360(double easting, double northing, double theta, int aspect_type,
 	       double scale, int style)
-    arrow_mag(easting, northing, aspect_type == TYPE_GRASS ? theta : 90 - theta, scale, style);
+    arrow_mag(easting, northing,
+	      aspect_type == TYPE_GRASS ? theta : 90 - theta, scale, style);
     return;
@@ -59,63 +59,62 @@
 /* angle is measured in degrees counter-clockwise from east */
 void arrow_mag(double easting, double northing, double theta, double length, int style)
-    double x, y, dx, dy, mid_x, mid_y;
+    double x, y, dx, dy, tail_x, tail_y;
     double theta_offset;
-    int col, row;
-    G_debug(0, "in arrow_mag()");
+    G_debug(4, "in arrow_mag()");
-    //tmp init
-//    col = row = 0;
-col=(int)(D_u_to_d_col(easting) + 0.5);
-row=(int)(D_u_to_d_row(northing) + 0.5);
-G_debug(0, "  col=%d  row=%d", col, row);
-    theta *= -1;		/* display coords use inverse y */
+    /* convert to compass dir ?! */
+    theta = 90 - theta;
+    if (theta < 0)
+	theta += 360;
-    /* find the display coordinates of the middle of the cell */
-    mid_x = col + (.5);
-    mid_y = row + (.5);
+    /* display coords use inverse y */
+    theta *= -1;
+    tail_x = D_u_to_d_col(easting);
+    tail_y = D_u_to_d_row(northing);
     /* tail */
-    R_move_abs(mid_x, mid_y);
+    R_move_abs((int)(tail_x + 0.5), (int)(tail_y + 0.5));
     /* head */
-    x = mid_x + (length * cos(D2R(theta)));
-    y = mid_y + (length * sin(D2R(theta)));
-    R_cont_abs(x, y);
+    x = tail_x + (length * cos(D2R(theta)));
+    y = tail_y + (length * sin(D2R(theta)));
+    R_cont_abs((int)(x + 0.5), (int)(y + 0.5));
     if (style == TYPE_ARROW) {
-	/* fin 1 */
 	theta_offset = theta + 20;
-	dx = mid_x + (0.6 * length * cos(D2R(theta_offset)));
-	dy = mid_y + (0.6 * length * sin(D2R(theta_offset)));
-	R_cont_abs(dx, dy);
+	if(theta_offset > 360)
+	    theta_offset -= 360;
+	/* fin 1 */
+	dx = tail_x + (0.6 * length * cos(D2R(theta_offset)));
+	dy = tail_y + (0.6 * length * sin(D2R(theta_offset)));
+	R_cont_abs((int)(dx + 0.5), (int)(dy + 0.5));
 	/* fin 2 */
-	R_move_abs(x, y);
+	R_move_abs((int)(x + 0.5), (int)(y + 0.5));
 	theta_offset = theta - 20;
 /* draw a grey '?' if data is non-sensical */
-// FIXME: change x,y to _east,north_ or %x %y of display _frame_
-void unknown_(int x, int y)
+void unknown_(double easting, double northing)
-    // ref center,center
-    //    x = D_x + (int)(D_ew * .3);
-    //    y = D_y + (int)(D_ns * .4);
+    double x, y;
-//    int x, y;
-//    x = (int?)D_U_to_d_col(easting);
-//    y = D_u_to_d_row(northing);
+    x = D_u_to_d_col(easting);
+    y = D_u_to_d_row(northing);
     R_standard_color(D_translate_color("grey"));
-    R_move_abs(x, y);
     R_text_size(8, 8);
     R_text("?");
@@ -208,7 +207,8 @@
     double x, y, dx, dy, angle, rot_angle, flag_angle1, flag_angle2;
     double stem_length = 5.;   /* length of tail */
-    int xi[4], yi[4];
+    double xd[4], yd[4];
+    int i, xi[4], yi[4];
     G_debug(4, "draw_feather()");
@@ -226,7 +226,7 @@
     flag_angle1 = rot_angle + 30;
     if(flag_angle1 > 360)
 	flag_angle1 -= 360;
-// 150 is good   45,195
+    /* for equilateral flag ~150 is good, try 45,195 */
     flag_angle2 = flag_angle1 + 150;
     if(flag_angle2 > 360)
 	flag_angle2 -= 360;
@@ -234,10 +234,10 @@
     G_debug(5, "  compass_deg=%.2f   angle=%.2f   rot_angle=%.2f", compass_deg, angle, rot_angle);
-//D_line_width(2);
+    /* D_line_width(2); */
     if (velocity < 5) {
-//dot	draw_circle(easting, northing, 2.0, TRUE);
+	/*dot:	draw_circle(easting, northing, 2.0, TRUE); */
 	draw_circle(easting, northing, 3*radius/4, FALSE);
 	return;
@@ -253,8 +253,7 @@
     dy = D_u_to_d_row(northing) + stem_length * radius * sin(D2R(angle));
     R_cont_abs((int)floor(dx + 0.5), (int)floor(dy + 0.5));
-    /* TODO: simplify following into a loop */
+    /* TODO: simplify following into loops */
   if (velocity < 50) {
 //R_RGB_color(0, 255, 0);
     if ( velocity >= 10 ) {
@@ -344,21 +343,22 @@
 //R_RGB_color(255, 0, 255);
+    /* beyond 50 kts gets a filled triangle (flag) at the end */
     if ( velocity >= 50 ) {
-	/* beyond 50 kts gets a filled triangle (flag) at the end */
-// inner angle is same as barb lines, outer angle is equal but opposite
+	/* inner angle is same as barb lines, outer angle is perpendicular to the barb */
+	xd[0] = D_u_to_d_col(easting) + stem_length * radius * cos(D2R(angle));
+	yd[0] = D_u_to_d_row(northing) + stem_length * radius * sin(D2R(angle));
+	xd[1] = xd[0] + radius*2 * cos(D2R(flag_angle1));
+	yd[1] = yd[0] + radius*2 * sin(D2R(flag_angle1));
+	xd[2] = xd[1] + radius*2 * (2/sqrt(3)) * cos(D2R(flag_angle2)); /* cos(30)=sqrt(3)/2 */
+	yd[2] = yd[1] + radius*2 * (2/sqrt(3)) * sin(D2R(flag_angle2));
+	xd[3] = xd[0];
+	yd[3] = yd[0];
-// TODO: calc x2 using trig instead of 2.35 approx.
-// TODO: store/hold as double* array and only rount to int for R_() at last minute
-	xi[0] = (int)floor(0.5 + D_u_to_d_col(easting) + stem_length * radius * cos(D2R(angle)));
-	yi[0] = (int)floor(0.5 + D_u_to_d_row(northing) + stem_length * radius * sin(D2R(angle)));
-	xi[1] = (int)floor(0.5 + xi[0] + radius*2 * cos(D2R(flag_angle1)));
-	yi[1] = (int)floor(0.5 + yi[0] + radius*2 * sin(D2R(flag_angle1)));
-	xi[2] = xi[1] + (int)floor(0.5 + radius*2.35 * cos(D2R(flag_angle2)));
-	yi[2] = yi[1] + (int)floor(0.5 + radius*2.35 * sin(D2R(flag_angle2)));
-	xi[3] = xi[0];
-	yi[3] = yi[0];
+	for (i = 0; i < 4; i++) {
+	    xi[i] = (int)floor(xd[i] + 0.5);
+	    yi[i] = (int)floor(yd[i] + 0.5);
 	R_polygon_abs(xi, yi, 4);
@@ -452,26 +452,28 @@
 	return;
+    /* beyond 100 kts gets two 50kt flags at the end */
+    if ( velocity >= 100 ) {
+	xd[0] = xd[2];
+	yd[0] = yd[2];
+	xd[3] = xd[0];
+	yd[3] = yd[0];
-    if ( velocity >= 100 ) {
-	/* beyond 100 kts gets two 50kt flags at the end */
-	xi[0] = xi[2];
-	yi[0] = yi[2];
-//	xi[0] = (int)floor(0.5 + D_u_to_d_col(easting) + (stem_length - 1.3) * radius * cos(D2R(angle)));
-//	yi[0] = (int)floor(0.5 + D_u_to_d_row(northing) + (stem_length - 1.3) * radius * sin(D2R(angle)));
-	xi[3] = xi[0];
-	yi[3] = yi[0];
   if ( velocity < 150 ) {
     if (velocity >= 110) {
 	dx = D_u_to_d_col(easting) + (stem_length - 2.8) * radius * cos(D2R(angle));
 	dy = D_u_to_d_row(northing) + (stem_length - 2.8) * radius * sin(D2R(angle));
@@ -567,28 +569,26 @@
+    /* beyond 150 kts gets three 50kt flags at the end */
     if ( velocity >= 150 ) {
-	/* beyond 150 kts gets three 50kt flags at the end */
-	xi[0] = xi[2];
-	yi[0] = yi[2];
-	xi[3] = xi[0];
-	yi[3] = yi[0];
+	xd[0] = xd[2];
+	yd[0] = yd[2];
+	xd[3] = xd[0];
+	yd[3] = yd[0];
+    /* barb rendering currenly saturates at 150 kts */
-//TODO: move out of loop
-    if ( velocity >= 155 )
-	G_warning(_("Maximum wind barb displayed is 150 knots"));
     return;
Modified: grass-addons/display/d.barb/grid.c
--- grass-addons/display/d.barb/grid.c	2011-03-26 10:53:54 UTC (rev 45757)
+++ grass-addons/display/d.barb/grid.c	2011-03-26 11:13:31 UTC (rev 45758)
@@ -22,6 +22,7 @@
     int no_arrow;		/* boolean */
     float aspect_f = -1.0;
     float length = -1.0;
+    double easting, northing;
     G_debug(0, "Doing Eulerian field ...");
     G_warning("Not working yet -- use d.rast.arrow instead.");
@@ -125,32 +126,34 @@
 	   /** Now draw the arrows **/
+	    if (G_is_null_value(dir_u_ptr, dir_u_raster_type))
+		continue;
+	    R_standard_color(color);
+	    easting = G_col_to_easting(col + 0.5, &window);
+	    northing = G_row_to_northing(row + 0.5, &window);
 	    /* case switch for standard GRASS aspect map
-	    R_standard_color(color);
-	    if (G_is_null_value(dir_u_ptr, dir_u_raster_type))
-		continue;
-	    else if (aspect_f >= 0.0 && aspect_f <= 360.0) {
+	    if (aspect_f >= 0.0 && aspect_f <= 360.0) {
 		if (mag_v_map) {
 		    if (aspect_type == TYPE_GRASS)
-			arrow_mag(3.,4., aspect_f, length, style);
+			arrow_mag(easting, northing, aspect_f, length, style);
 		    else
-			arrow_mag(3.,4., 90 - aspect_f, length, style);
+			arrow_mag(easting, northing, 90 - aspect_f, length, style);
 		else {
-		    if (aspect_type == TYPE_GRASS) ;	//todo                        arrow_360(aspect_f);
+		    if (aspect_type == TYPE_GRASS) ;	//todo   arrow_360(aspect_f);
 		    else;	//  arrow_360(90 - aspect_f);
 	    else {
 		R_standard_color(D_parse_color("grey", 0));
-		unknown_(10, 10);
+		unknown_(easting, northing);
 	    dir_u_ptr =
 		G_incr_void_ptr(dir_u_ptr, G_raster_size(dir_u_raster_type));
 	    mag_v_ptr =
Modified: grass-addons/display/d.barb/legend.c
--- grass-addons/display/d.barb/legend.c	2011-03-26 10:53:54 UTC (rev 45757)
+++ grass-addons/display/d.barb/legend.c	2011-03-26 11:13:31 UTC (rev 45758)
@@ -9,7 +9,7 @@
 	       double key_fontsize, int style, double scale, double peak,
 	       int color)
-    double easting, northing, px, py, velo;
+    double easting, northing, px, py, velo, angle;
     int Xpx, Ypx;
     int t, b, l, r;
     int i;
@@ -17,6 +17,11 @@
     G_debug(1, "Doing legend ... (%d entries)", num_velos);
+    if (style == TYPE_BARB)
+	angle = 90;
+    else
+	angle = 0;
     D_get_screen_window(&t, &b, &l, &r);
     for (i = 0; i < num_velos; i++) {
@@ -48,16 +53,20 @@
 	/* Y: center justify: */
 	R_move_abs(Xpx, Ypx + key_fontsize/2);
-	/* X: right justify the text + 10px buffer: */
+	/* X: right justify the text + 10px buffer (a wee bit more for wind barbs) */
  	/* text width is 0.81 of text height? so even though we set width
            to txsiz with R_text_size(), we still have to reduce.. hmmm */
-	R_move_rel(-10 - (strlen(buff) * key_fontsize * 0.81), 0);
+	    R_move_rel(-20 - (strlen(buff) * key_fontsize * 0.81), 0);
+	else
+	    R_move_rel(-10 - (strlen(buff) * key_fontsize * 0.81), 0);
 	R_text_size(key_fontsize, key_fontsize);
 	R_text(buff);
 	/* arrow then starts at the given x-percent, to the right of the text */
-	draw_barb(easting, northing, velo, 0.0, color, scale, style);
+	draw_barb(easting, northing, velo, angle, color, scale, style);
Modified: grass-addons/display/d.barb/local_proto.h
--- grass-addons/display/d.barb/local_proto.h	2011-03-26 10:53:54 UTC (rev 45757)
+++ grass-addons/display/d.barb/local_proto.h	2011-03-26 11:13:31 UTC (rev 45758)
@@ -22,7 +22,7 @@
 /* draw.c */
 void draw_barb(double, double, double, double, int, double, int);
-void unknown_(int, int);
+void unknown_(double, double);
 void arrow_mag(double, double, double, double, int);
 void arrow_360(double, double, double, int, double, int);
 void mark_the_spot(double, double);
Modified: grass-addons/display/d.barb/main.c
--- grass-addons/display/d.barb/main.c	2011-03-26 10:53:54 UTC (rev 45757)
+++ grass-addons/display/d.barb/main.c	2011-03-26 11:13:31 UTC (rev 45758)
@@ -5,7 +5,7 @@
  *              points map with data stored as attributes in database column
  * AUTHORS:     Hamish Bowman, Dunedin, New Zealand
- *              Parts of code derived from d.rast.arrow and d.barscale.
+ *              Grid code derived from d.rast.arrow
  * COPYRIGHT:   (c) 2008-2011 by Hamish Bowman, and The GRASS Development Team
  *              This program is free software under the GNU General Public
@@ -234,6 +234,7 @@
 	do_legend(keyat_opt->answers, keyvelo_opt->answers, num_leg_velo,
 		  key_fontsize, style, scale, peak, color);
+	D_add_to_list(G_recreate_command());
 	R_close_driver();
 	exit(EXIT_SUCCESS);
Modified: grass-addons/display/d.barb/points.c
--- grass-addons/display/d.barb/points.c	2011-03-26 10:53:54 UTC (rev 45757)
+++ grass-addons/display/d.barb/points.c	2011-03-26 11:13:31 UTC (rev 45758)
@@ -91,7 +91,10 @@
     peak = max_magnitude(magn, num_pts);
     G_debug(0, "  peak = %.2f", peak);
+    if (style == TYPE_BARB && peak > 150)
+	G_warning(_("Maximum wind barb displayed is 150 knots"));
     peak = 1.;    // TODO: window width * 0.20
     scale_fact = (peak ) * scale;
