[GRASS-SVN] r45759 - grass-addons/display/d.barb
svn_grass at osgeo.org
Sat Mar 26 07:22:14 EDT 2011
Author: hamish
Date: 2011-03-26 04:22:14 -0700 (Sat, 26 Mar 2011)
New Revision: 45759
grass-addons/display/d.barb/draw.c
grass-addons/display/d.barb/grid.c
grass-addons/display/d.barb/legend.c
grass-addons/display/d.barb/points.c
run grass_indent.sh
Modified: grass-addons/display/d.barb/draw.c
--- grass-addons/display/d.barb/draw.c 2011-03-26 11:13:31 UTC (rev 45758)
+++ grass-addons/display/d.barb/draw.c 2011-03-26 11:22:14 UTC (rev 45759)
@@ -6,7 +6,7 @@
#include <grass/glocale.h>
#include "local_proto.h"
-#define RpD ((2 * M_PI) / 360.) /* radians/degree */
+#define RpD ((2 * M_PI) / 360.) /* radians/degree */
#define D2R(d) (double)(d * RpD) /* degrees->radians */
@@ -16,7 +16,7 @@
G_debug(3, "in draw_barb()");
-//dbg: unknown_(594578,4920392);
+ //dbg: unknown_(594578,4920392);
R_standard_color(color);
@@ -24,21 +24,23 @@
(int)(D_u_to_d_row(northing) + 0.5));
if (style != TYPE_BARB) {
- if (velocity == velocity) /* ie not NaN */
+ if (velocity == velocity) /* ie not NaN */
arrow_mag(easting, northing, compass_deg, velocity, style);
else
- arrow_360(easting, northing, compass_deg, TYPE_GRASS, scale, style);
+ arrow_360(easting, northing, compass_deg, TYPE_GRASS, scale,
+ style);
else {
/* calc barb parameters */
-//dbg: compass_deg=0;
+ //dbg: compass_deg=0;
/* draw barb bits */
draw_circle(easting, northing, 10.0, FALSE);
- draw_feather(easting, northing, 10.0 /*radius*/, velocity, compass_deg);
+ draw_feather(easting, northing, 10.0 /*radius */ , velocity,
+ compass_deg);
-//dbg: int i;
-// for (i=0; i < 360; i+=20)
-// draw_feather(easting, northing, 20.0 /*radius*/, velocity, i);
+ //dbg: int i;
+ // for (i=0; i < 360; i+=20)
+ // draw_feather(easting, northing, 20.0 /*radius*/, velocity, i);
@@ -57,7 +59,8 @@
/* draw an arrow, with magnitude and direction */
/* angle is measured in degrees counter-clockwise from east */
-void arrow_mag(double easting, double northing, double theta, double length, int style)
+void arrow_mag(double easting, double northing, double theta, double length,
+ int style)
double x, y, dx, dy, tail_x, tail_y;
double theta_offset;
@@ -86,7 +89,7 @@
if (style == TYPE_ARROW) {
theta_offset = theta + 20;
- if(theta_offset > 360)
+ if (theta_offset > 360)
theta_offset -= 360;
/* fin 1 */
@@ -124,22 +127,22 @@
SYMBOL *Symb;
RGBA_Color *line_color, *fill_color;
- int R,G,B;
+ int R, G, B;
int Xpx, Ypx;
int t, b, l, r;
int color;
line_color = G_malloc(sizeof(RGBA_Color));
fill_color = G_malloc(sizeof(RGBA_Color));
- Symb = S_read( "basic/cross1" );
+ Symb = S_read("basic/cross1");
G_str_to_color("black", &R, &G, &B);
line_color->r = (unsigned char)R;
line_color->g = (unsigned char)G;
line_color->b = (unsigned char)B;
line_color->a = RGBA_COLOR_OPAQUE;
-// R_RGB_color(R, G, B);
+ // R_RGB_color(R, G, B);
color = G_str_to_color("yellow", &R, &G, &B);
fill_color->r = (unsigned char)R;
@@ -147,20 +150,21 @@
fill_color->b = (unsigned char)B;
fill_color->a = RGBA_COLOR_OPAQUE;
- S_stroke( Symb, 6, 0, 0 );
+ S_stroke(Symb, 6, 0, 0);
D_get_screen_window(&t, &b, &l, &r);
Xpx = (int)((perc_x * (r - l) / 100.) + 0.5);
- Ypx = (int)(((100. - perc_y) * (b - t) / 100.)+0.5);
+ Ypx = (int)(((100. - perc_y) * (b - t) / 100.) + 0.5);
- D_symbol( Symb, Xpx, Ypx, line_color, fill_color );
+ D_symbol(Symb, Xpx, Ypx, line_color, fill_color);
return;
/* draws a circle at the map coords given by e,n.
- radius is in display pixels, fill is boolean */
+ radius is in display pixels, fill is boolean */
/*** change fill to int=0-8 for cloud cover? ***/
void draw_circle(double easting, double northing, double radius, int fill)
@@ -170,27 +174,29 @@
G_debug(4, "draw_circle()");
- n = (int)(360 / step) + 1; /* number of vertices */
+ n = (int)(360 / step) + 1; /* number of vertices */
xi = G_calloc(n + 1, sizeof(int));
yi = G_calloc(n + 1, sizeof(int));
- /* for loop moving around the circle */
+ /* for loop moving around the circle */
for (i = 0; i <= n; i++) {
angle = D2R(step * i);
xi[i] = (int)floor(0.5 + D_u_to_d_col(easting) + radius * cos(angle));
- yi[i] = (int)floor(0.5 + D_u_to_d_row(northing) + radius * sin(angle));
- G_debug(5, "angle=%.2f xi[%d]=%d yi[%d]=%d", step*i, i, xi[i], i, yi[i]);
+ yi[i] =
+ (int)floor(0.5 + D_u_to_d_row(northing) + radius * sin(angle));
+ G_debug(5, "angle=%.2f xi[%d]=%d yi[%d]=%d", step * i, i, xi[i], i,
+ yi[i]);
- /* close it*/
+ /* close it */
xi[n] = xi[0];
yi[n] = yi[0];
if (fill)
- R_polygon_abs(xi, yi, n);
+ R_polygon_abs(xi, yi, n);
else
- R_polyline_abs(xi, yi, n);
+ R_polyline_abs(xi, yi, n);
G_free(xi);
G_free(yi);
@@ -200,13 +206,13 @@
/* draws the stem and tail of a wind barb centered at e,n.
- radius is scaling in display pixels, velocity is assumed as knots,
- angle is cartesian convention CCW from positive x-axis */
-void draw_feather(double easting, double northing, double radius, double velocity,
- double compass_deg)
+ radius is scaling in display pixels, velocity is assumed as knots,
+ angle is cartesian convention CCW from positive x-axis */
+void draw_feather(double easting, double northing, double radius,
+ double velocity, double compass_deg)
double x, y, dx, dy, angle, rot_angle, flag_angle1, flag_angle2;
- double stem_length = 5.; /* length of tail */
+ double stem_length = 5.; /* length of tail */
double xd[4], yd[4];
int i, xi[4], yi[4];
@@ -214,35 +220,36 @@
/* barb points to FROM direction */
angle = compass_deg - 90;
- if(angle < 0)
+ if (angle < 0)
angle += 360;
- else if(angle > 360)
+ else if (angle > 360)
angle -= 360;
rot_angle = angle + 60;
- if(rot_angle > 360)
+ if (rot_angle > 360)
rot_angle -= 360;
flag_angle1 = rot_angle + 30;
- if(flag_angle1 > 360)
+ if (flag_angle1 > 360)
flag_angle1 -= 360;
/* for equilateral flag ~150 is good, try 45,195 */
flag_angle2 = flag_angle1 + 150;
- if(flag_angle2 > 360)
+ if (flag_angle2 > 360)
flag_angle2 -= 360;
- G_debug(5, " compass_deg=%.2f angle=%.2f rot_angle=%.2f", compass_deg, angle, rot_angle);
+ G_debug(5, " compass_deg=%.2f angle=%.2f rot_angle=%.2f",
+ compass_deg, angle, rot_angle);
/* D_line_width(2); */
if (velocity < 5) {
- /*dot: draw_circle(easting, northing, 2.0, TRUE); */
- draw_circle(easting, northing, 3*radius/4, FALSE);
+ /*dot: draw_circle(easting, northing, 2.0, TRUE); */
+ draw_circle(easting, northing, 3 * radius / 4, FALSE);
return;
-//R_RGB_color(255, 0, 0);
+ //R_RGB_color(255, 0, 0);
/* move to head */
x = D_u_to_d_col(easting) + radius * cos(D2R(angle));
y = D_u_to_d_row(northing) + radius * sin(D2R(angle));
@@ -254,104 +261,120 @@
R_cont_abs((int)floor(dx + 0.5), (int)floor(dy + 0.5));
/* TODO: simplify following into loops */
- if (velocity < 50) {
-//R_RGB_color(0, 255, 0);
- if ( velocity >= 10 ) {
- x = dx + radius*2 * cos(D2R(rot_angle));
- y = dy + radius*2 * sin(D2R(rot_angle));
- R_cont_abs((int)floor(x + 0.5), (int)floor(y + 0.5));
- else if (velocity >= 5) {
- x = dx + radius * cos(D2R(rot_angle));
- y = dy + radius * sin(D2R(rot_angle));
- else
- return;
+ if (velocity < 50) {
+ //R_RGB_color(0, 255, 0);
+ if (velocity >= 10) {
+ x = dx + radius * 2 * cos(D2R(rot_angle));
+ y = dy + radius * 2 * sin(D2R(rot_angle));
+ R_cont_abs((int)floor(x + 0.5), (int)floor(y + 0.5));
+ else if (velocity >= 5) {
+ x = dx + radius * cos(D2R(rot_angle));
+ y = dy + radius * sin(D2R(rot_angle));
+ else
+ return;
-//R_RGB_color(0, 0, 255);
- if ( velocity >= 20 ) {
- dx = D_u_to_d_col(easting) + (stem_length - 0.5) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 0.5) * radius * sin(D2R(angle));
- R_move_abs((int)floor(dx + 0.5), (int)floor(dy + 0.5));
- else if (velocity >= 15) {
- else
- return;
+ //R_RGB_color(0, 0, 255);
+ if (velocity >= 20) {
+ dx = D_u_to_d_col(easting) + (stem_length -
+ 0.5) * radius * cos(D2R(angle));
+ dy = D_u_to_d_row(northing) + (stem_length -
+ 0.5) * radius * sin(D2R(angle));
+ R_move_abs((int)floor(dx + 0.5), (int)floor(dy + 0.5));
+ else if (velocity >= 15) {
+ else
+ return;
-//R_RGB_color(0, 255, 255);
- if ( velocity >= 30 ) {
- dx = D_u_to_d_col(easting) + (stem_length - 1) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 1) * radius * sin(D2R(angle));
- else if (velocity >= 25) {
- else
- return;
+ //R_RGB_color(0, 255, 255);
+ if (velocity >= 30) {
+ 1) * radius * cos(D2R(angle));
+ 1) * radius * sin(D2R(angle));
+ else if (velocity >= 25) {
+ else
+ return;
-//R_RGB_color(255, 255, 0);
- if ( velocity >= 40 ) {
- dx = D_u_to_d_col(easting) + (stem_length - 1.5) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 1.5) * radius * sin(D2R(angle));
- else if (velocity >= 35) {
- else
- return;
+ //R_RGB_color(255, 255, 0);
+ if (velocity >= 40) {
+ 1.5) * radius * cos(D2R(angle));
+ 1.5) * radius * sin(D2R(angle));
+ else if (velocity >= 35) {
+ else
+ return;
- if (velocity >= 45) {
- dx = D_u_to_d_col(easting) + (stem_length - 2) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 2) * radius * sin(D2R(angle));
+ if (velocity >= 45) {
+ 2) * radius * cos(D2R(angle));
+ 2) * radius * sin(D2R(angle));
+ else
+ return;
- else
- return;
-//R_RGB_color(255, 0, 255);
+ //R_RGB_color(255, 0, 255);
/* beyond 50 kts gets a filled triangle (flag) at the end */
- if ( velocity >= 50 ) {
+ if (velocity >= 50) {
/* inner angle is same as barb lines, outer angle is perpendicular to the barb */
- xd[0] = D_u_to_d_col(easting) + stem_length * radius * cos(D2R(angle));
- yd[0] = D_u_to_d_row(northing) + stem_length * radius * sin(D2R(angle));
- xd[1] = xd[0] + radius*2 * cos(D2R(flag_angle1));
- yd[1] = yd[0] + radius*2 * sin(D2R(flag_angle1));
- xd[2] = xd[1] + radius*2 * (2/sqrt(3)) * cos(D2R(flag_angle2)); /* cos(30)=sqrt(3)/2 */
- yd[2] = yd[1] + radius*2 * (2/sqrt(3)) * sin(D2R(flag_angle2));
+ xd[0] =
+ D_u_to_d_col(easting) + stem_length * radius * cos(D2R(angle));
+ yd[0] =
+ D_u_to_d_row(northing) + stem_length * radius * sin(D2R(angle));
+ xd[1] = xd[0] + radius * 2 * cos(D2R(flag_angle1));
+ yd[1] = yd[0] + radius * 2 * sin(D2R(flag_angle1));
+ xd[2] = xd[1] + radius * 2 * (2 / sqrt(3)) * cos(D2R(flag_angle2)); /* cos(30)=sqrt(3)/2 */
+ yd[2] = yd[1] + radius * 2 * (2 / sqrt(3)) * sin(D2R(flag_angle2));
xd[3] = xd[0];
yd[3] = yd[0];
@@ -362,105 +385,123 @@
R_polygon_abs(xi, yi, 4);
- if ( velocity < 100 ) {
- if (velocity >= 60) {
- dx = D_u_to_d_col(easting) + (stem_length - 1.6) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 1.6) * radius * sin(D2R(angle));
- else if (velocity >= 55) {
- else
- return;
+ if (velocity < 100) {
- if (velocity >= 70) {
- dx = D_u_to_d_col(easting) + (stem_length - 2.1) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 2.1) * radius * sin(D2R(angle));
- else if (velocity >= 65) {
- else
- return;
+ if (velocity >= 60) {
+ 1.6) * radius * cos(D2R(angle));
+ 1.6) * radius * sin(D2R(angle));
+ else if (velocity >= 55) {
+ else
+ return;
- if (velocity >= 80) {
- dx = D_u_to_d_col(easting) + (stem_length - 2.6) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 2.6) * radius * sin(D2R(angle));
- else if (velocity >= 75) {
- else
- return;
+ if (velocity >= 70) {
+ 2.1) * radius * cos(D2R(angle));
+ 2.1) * radius * sin(D2R(angle));
+ else if (velocity >= 65) {
+ else
+ return;
- if (velocity >= 90) {
- dx = D_u_to_d_col(easting) + (stem_length - 3.1) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 3.1) * radius * sin(D2R(angle));
- else if (velocity >= 85) {
- else
- return;
+ if (velocity >= 80) {
+ 2.6) * radius * cos(D2R(angle));
+ 2.6) * radius * sin(D2R(angle));
+ else if (velocity >= 75) {
+ else
+ return;
- if (velocity >= 95) {
- dx = D_u_to_d_col(easting) + (stem_length - 3.6) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 3.6) * radius * sin(D2R(angle));
+ if (velocity >= 90) {
+ 3.1) * radius * cos(D2R(angle));
+ 3.1) * radius * sin(D2R(angle));
+ else if (velocity >= 85) {
+ else
+ return;
+ if (velocity >= 95) {
+ 3.6) * radius * cos(D2R(angle));
+ 3.6) * radius * sin(D2R(angle));
+ else
+ return;
- else
- return;
/* beyond 100 kts gets two 50kt flags at the end */
- if ( velocity >= 100 ) {
+ if (velocity >= 100) {
xd[0] = xd[2];
yd[0] = yd[2];
xd[3] = xd[0];
yd[3] = yd[0];
@@ -472,112 +513,130 @@
- if ( velocity < 150 ) {
+ if (velocity < 150) {
- if (velocity >= 110) {
- dx = D_u_to_d_col(easting) + (stem_length - 2.8) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 2.8) * radius * sin(D2R(angle));
- else if (velocity >= 105) {
- else
- return;
+ if (velocity >= 110) {
+ 2.8) * radius * cos(D2R(angle));
+ 2.8) * radius * sin(D2R(angle));
+ else if (velocity >= 105) {
+ else
+ return;
- if (velocity >= 120) {
- dx = D_u_to_d_col(easting) + (stem_length - 3.2) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 3.2) * radius * sin(D2R(angle));
- else if (velocity >= 115) {
- else
- return;
+ if (velocity >= 120) {
+ 3.2) * radius * cos(D2R(angle));
+ 3.2) * radius * sin(D2R(angle));
+ else if (velocity >= 115) {
+ else
+ return;
- if (velocity >= 130) {
- dx = D_u_to_d_col(easting) + (stem_length - 3.7) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 3.7) * radius * sin(D2R(angle));
- else if (velocity >= 125) {
- else
- return;
+ if (velocity >= 130) {
+ 3.7) * radius * cos(D2R(angle));
+ 3.7) * radius * sin(D2R(angle));
+ else if (velocity >= 125) {
+ else
+ return;
- if (velocity >= 140) {
- dx = D_u_to_d_col(easting) + (stem_length - 4.2) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 4.2) * radius * sin(D2R(angle));
- else if (velocity >= 135) {
- else
- return;
+ if (velocity >= 140) {
+ 4.2) * radius * cos(D2R(angle));
+ 4.2) * radius * sin(D2R(angle));
+ else if (velocity >= 135) {
+ else
+ return;
- if (velocity >= 145) {
- dx = D_u_to_d_col(easting) + (stem_length - 4.7) * radius * cos(D2R(angle));
- dy = D_u_to_d_row(northing) + (stem_length - 4.7) * radius * sin(D2R(angle));
+ if (velocity >= 145) {
+ 4.7) * radius * cos(D2R(angle));
+ 4.7) * radius * sin(D2R(angle));
- R_move_abs((int)(D_u_to_d_col(easting) + 0.5),
- (int)(D_u_to_d_row(northing) + 0.5));
- x = D_u_to_d_col(easting) + radius * cos(D2R(angle));
- y = D_u_to_d_row(northing) + radius * sin(D2R(angle));
+ R_move_abs((int)(D_u_to_d_col(easting) + 0.5),
+ (int)(D_u_to_d_row(northing) + 0.5));
+ x = D_u_to_d_col(easting) + radius * cos(D2R(angle));
+ y = D_u_to_d_row(northing) + radius * sin(D2R(angle));
+ else
+ return;
- else
- return;
/* beyond 150 kts gets three 50kt flags at the end */
- if ( velocity >= 150 ) {
+ if (velocity >= 150) {
xd[0] = xd[2];
yd[0] = yd[2];
xd[3] = xd[0];
yd[3] = yd[0];
Modified: grass-addons/display/d.barb/grid.c
--- grass-addons/display/d.barb/grid.c 2011-03-26 11:13:31 UTC (rev 45758)
+++ grass-addons/display/d.barb/grid.c 2011-03-26 11:22:14 UTC (rev 45759)
@@ -141,7 +141,8 @@
if (aspect_type == TYPE_GRASS)
arrow_mag(easting, northing, aspect_f, length, style);
else
- arrow_mag(easting, northing, 90 - aspect_f, length, style);
+ arrow_mag(easting, northing, 90 - aspect_f, length,
+ style);
else {
if (aspect_type == TYPE_GRASS) ; //todo arrow_360(aspect_f);
Modified: grass-addons/display/d.barb/legend.c
--- grass-addons/display/d.barb/legend.c 2011-03-26 11:13:31 UTC (rev 45758)
+++ grass-addons/display/d.barb/legend.c 2011-03-26 11:22:14 UTC (rev 45759)
@@ -31,12 +31,12 @@
G_debug(4, "Legend entry: %.15g at [%.2f,%.2f]", velo, px, py);
-// frame percent, utm, display pixels, raster array coords. all -> utm ?
+ // frame percent, utm, display pixels, raster array coords. all -> utm ?
/* convert screen percentage to east,north */
-// check if +.5 rounding is really needed
+ // check if +.5 rounding is really needed
Xpx = (int)((px * (r - l) / 100.) + 0.5);
- Ypx = (int)(((100. - py) * (b - t) / 100.)+0.5);
+ Ypx = (int)(((100. - py) * (b - t) / 100.) + 0.5);
easting = D_d_to_u_col(Xpx);
northing = D_d_to_u_row(Ypx);
@@ -51,25 +51,24 @@
sprintf(buff, "%s", velo_list[i]);
/* Y: center justify: */
- R_move_abs(Xpx, Ypx + key_fontsize/2);
+ R_move_abs(Xpx, Ypx + key_fontsize / 2);
/* X: right justify the text + 10px buffer (a wee bit more for wind barbs) */
- /* text width is 0.81 of text height? so even though we set width
- to txsiz with R_text_size(), we still have to reduce.. hmmm */
+ /* text width is 0.81 of text height? so even though we set width
+ to txsiz with R_text_size(), we still have to reduce.. hmmm */
if (style == TYPE_BARB)
R_move_rel(-20 - (strlen(buff) * key_fontsize * 0.81), 0);
else
R_move_rel(-10 - (strlen(buff) * key_fontsize * 0.81), 0);
R_text_size(key_fontsize, key_fontsize);
R_text(buff);
/* arrow then starts at the given x-percent, to the right of the text */
draw_barb(easting, northing, velo, angle, color, scale, style);
return;
Modified: grass-addons/display/d.barb/points.c
--- grass-addons/display/d.barb/points.c 2011-03-26 11:13:31 UTC (rev 45758)
+++ grass-addons/display/d.barb/points.c 2011-03-26 11:22:14 UTC (rev 45759)
@@ -19,21 +19,21 @@
int i;
double peak = -DBL_MAX, scale_fact;
-//? needed? static struct line_pnts *Points;
-// /* Create and initialize struct's where to store points/lines and categories */
-// Points = Vect_new_line_struct();
-// Cats = Vect_new_cats_struct();
+ //? needed? static struct line_pnts *Points;
+ // /* Create and initialize struct's where to store points/lines and categories */
+ // Points = Vect_new_line_struct();
+ // Cats = Vect_new_cats_struct();
- magn = NULL; /* init in case it isn't used */
+ magn = NULL; /* init in case it isn't used */
G_debug(0, "Doing sparse points ...");
if ((mapset = G_find_vector2(vinput_name, "")) == NULL)
- G_fatal_error(_("Vector map <%s> not found"), vinput_name);
+ G_fatal_error(_("Vector map <%s> not found"), vinput_name);
/* Predetermine level at which a map will be opened for reading */
if (Vect_set_open_level(2))
- G_fatal_error(_("Unable to set predetermined vector open level"));
+ G_fatal_error(_("Unable to set predetermined vector open level"));
/* Open existing vector for reading lib/vector/Vlib/open.c */
if (1 > Vect_open_old(&vMap, vinput_name, mapset))
@@ -42,15 +42,15 @@
G_debug(0, "<%s> is open", vinput_name);
/* we need to scan through and find the greatest value in of the
- magnitude within the current region and scale from that. hence
- the following complexity ... */
+ magnitude within the current region and scale from that. hence
+ the following complexity ... */
num_pts = count_pts_in_region(&vMap);
G_debug(0, " %d points found in region", num_pts);
coord_x = G_calloc(num_pts + 1, sizeof(double));
coord_y = G_calloc(num_pts + 1, sizeof(double));
dirn = G_calloc(num_pts + 1, sizeof(double));
- if(mag_v_col)
+ if (mag_v_col)
magn = G_calloc(num_pts + 1, sizeof(double));
else
magn = NULL;
@@ -59,22 +59,22 @@
coord_x, coord_y, dirn, magn);
if (aspect_type == TYPE_GRASS) {
- for (i=0; i < num_pts; i++) {
-// G_debug(0, "in=%.1f out=%.1f", dirn[i], 90-dirn[i] < 0 ? 360+90-dirn[i] : 90-dirn[i]);
+ for (i = 0; i < num_pts; i++) {
+ // G_debug(0, "in=%.1f out=%.1f", dirn[i], 90-dirn[i] < 0 ? 360+90-dirn[i] : 90-dirn[i]);
dirn[i] = 90 - dirn[i];
if (dirn[i] < 0)
dirn[i] += 360;
-// to figure out:
-// also pass u,v columns and calc dir,mag prior to filling dirn,magn arrays
+ // to figure out:
+ // also pass u,v columns and calc dir,mag prior to filling dirn,magn arrays
/* somehow check, load attributes see d.vect */
if(is_component) {
read u attrib;
read v attrib;
@@ -88,22 +88,22 @@
if (aspect_type == TYPE_COMPASS)
dir = 90 - dir;
peak = max_magnitude(magn, num_pts);
G_debug(0, " peak = %.2f", peak);
if (style == TYPE_BARB && peak > 150)
G_warning(_("Maximum wind barb displayed is 150 knots"));
- peak = 1.; // TODO: window width * 0.20
- scale_fact = (peak ) * scale;
+ peak = 1.; // TODO: window width * 0.20
+ scale_fact = (peak) * scale;
draw_barb(coord_x[i], coord_y[i], magn[i] * scale_fact, dirn[i],
- Vect_close(&vMap);
+ Vect_close(&vMap);
return;
@@ -119,7 +119,7 @@
G_debug(0, "count_pts_in_region()");
G_get_window(&window);
G_debug(0, " n=%.2f s=%.2f e=%.2f w=%.2f", window.north, window.south,
- window.east, window.west);
+ window.east, window.west);
@@ -131,15 +131,15 @@
Vect_rewind(Map);
while (1) {
- ltype = Vect_read_next_line(Map, Points, Cats);
- switch (ltype) {
- case -1:
- G_fatal_error(_("Can't read vector map"));
- case -2: /* EOF */
- return count;
+ ltype = Vect_read_next_line(Map, Points, Cats);
+ switch (ltype) {
+ case -1:
+ G_fatal_error(_("Can't read vector map"));
+ case -2: /* EOF */
+ return count;
- if(! (ltype & GV_POINTS))
+ if (!(ltype & GV_POINTS))
continue;
if (Points->x[0] > window.east || Points->x[0] < window.west ||
@@ -149,14 +149,15 @@
count++;
- return -1; /* shouldn't get here */
+ return -1; /* shouldn't get here */
/* populates arrays */
/* rather redundant WRT count_pts_in_region() ... */
void fill_arrays(struct Map_info *Map, int layer, char *dir_u, char *mag_v,
- int is_uv, double *Xs, double *Ys, double *Dirs, double *Mags)
+ int is_uv, double *Xs, double *Ys, double *Dirs,
+ double *Mags)
int i, ltype, nrec;
@@ -189,7 +190,7 @@
db_CatValArray_init(&cvarr_dir_u);
- if(Mags)
+ if (Mags)
db_CatValArray_init(&cvarr_mag_v);
@@ -197,20 +198,23 @@
dir_u, NULL, &cvarr_dir_u);
G_debug(0, "nrec (%s) = %d", dir_u, nrec);
- if (cvarr_dir_u.ctype != DB_C_TYPE_INT && cvarr_dir_u.ctype != DB_C_TYPE_DOUBLE)
- G_fatal_error(_("Direction/u column (%s) is not a numeric."), dir_u);
+ if (cvarr_dir_u.ctype != DB_C_TYPE_INT &&
+ cvarr_dir_u.ctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_("Direction/u column (%s) is not a numeric."), dir_u);
if (nrec < 0)
G_fatal_error(_("Cannot select data (%s) from table"), dir_u);
G_debug(0, "%d records selected from table", nrec);
- if(Mags) {
+ if (Mags) {
nrec = db_select_CatValArray(driver, fi->table, fi->key,
- mag_v, NULL, &cvarr_mag_v);
+ mag_v, NULL, &cvarr_mag_v);
G_debug(0, "nrec (%s) = %d", mag_v, nrec);
- if (cvarr_mag_v.ctype != DB_C_TYPE_INT && cvarr_mag_v.ctype != DB_C_TYPE_DOUBLE)
- G_fatal_error(_("Magnitude/v column (%s) is not a numeric."), mag_v);
+ if (cvarr_mag_v.ctype != DB_C_TYPE_INT &&
+ cvarr_mag_v.ctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_("Magnitude/v column (%s) is not a numeric."),
+ mag_v);
if (nrec < 0)
G_fatal_error(_("Cannot select data (%s) from table"), mag_v);
@@ -221,18 +225,18 @@
i = 0;
while (1) {
- switch (ltype) {
- case -1:
+ switch (ltype) {
+ case -1:
db_close_database_shutdown_driver(driver);
G_debug(0, " Array fill done.");
- return;
+ return;
continue;
@@ -241,35 +245,37 @@
Xs[i] = Points->x[0];
Ys[i] = Points->y[0];
- G_debug(5, " Xs[%d] = %.2f Ys[%d] = %.2f cat = %d", i, Xs[i],
+ G_debug(5, " Xs[%d] = %.2f Ys[%d] = %.2f cat = %d", i, Xs[i],
i, Ys[i], Cats->cat[0]);
/* Read rotation from db */
- if (db_CatValArray_get_value(&cvarr_dir_u, Cats->cat[0], &cv_dir_u) != DB_OK)
- Dirs[i] = 0.0/0.0; /* NaN */
+ if (db_CatValArray_get_value(&cvarr_dir_u, Cats->cat[0], &cv_dir_u) !=
+ DB_OK)
+ Dirs[i] = 0.0 / 0.0; /* NaN */
else
Dirs[i] = cvarr_dir_u.ctype == DB_C_TYPE_INT ?
- (double)cv_dir_u->val.i : cv_dir_u->val.d;
+ (double)cv_dir_u->val.i : cv_dir_u->val.d;
/* Read magnitude from db */
- if(Mags) {
- if (db_CatValArray_get_value(&cvarr_mag_v, Cats->cat[0], &cv_mag_v) != DB_OK)
- Mags[i] = 0.0/0.0; /* NaN */
+ if (Mags) {
+ (&cvarr_mag_v, Cats->cat[0], &cv_mag_v) != DB_OK)
+ Mags[i] = 0.0 / 0.0; /* NaN */
else
Mags[i] = cvarr_mag_v.ctype == DB_C_TYPE_INT ?
- (double)cv_mag_v->val.i : cv_mag_v->val.d;
+ (double)cv_mag_v->val.i : cv_mag_v->val.d;
- if(Mags[i] < 0) /* magnitude is scalar and can only be positive */
+ if (Mags[i] < 0) /* magnitude is scalar and can only be positive */
Mags[i] = 0;
- G_debug(5, " Dirs[%d] = %.2f Mags[%d] = %.2f", i, Dirs[i],
+ G_debug(5, " Dirs[%d] = %.2f Mags[%d] = %.2f", i, Dirs[i],
i, Mags[i]);
i++;
- return; /* shouldn't get here */
+ return; /* shouldn't get here */
@@ -278,8 +284,9 @@
double maxmag = -DBL_MAX;
int i;
- for(i = 0; i < n; i++) {
- if(magn[i] > maxmag)
+ for (i = 0; i < n; i++) {
+ if (magn[i] > maxmag)
maxmag = magn[i];
return maxmag;
