[GRASS-SVN] r46148 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Sun May 1 03:49:22 EDT 2011
Author: neteler
Date: 2011-05-01 00:49:22 -0700 (Sun, 01 May 2011)
New Revision: 46148
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
Fred Maranh?\195?\163o: cont'ed
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2011-05-01 07:49:01 UTC (rev 46147)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2011-05-01 07:49:22 UTC (rev 46148)
@@ -12,7 +12,7 @@
"Project-Id-Version: grassmods_pt_br\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-04-19 00:30+0200\n"
-"PO-Revision-Date: 2011-04-23 21:55-0300\n"
+"PO-Revision-Date: 2011-04-30 20:23-0300\n"
"Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
"Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -942,7 +942,6 @@
msgstr "Mostra/adiciona/remove carimbo de data em um mapa raster 3D"
#: ../raster3d/base/r3.timestamp.main.c:52
-#, fuzzy
msgid "Input grid3 filename"
msgstr "Nome do arquivo grid3 de entrada"
@@ -961,7 +960,7 @@
msgstr ""
#: ../raster3d/base/mask_functions.c:100 ../raster/r.null/null.c:260
-#, fuzzy, c-format
+#, c-format
msgid "%s: illegal value spec"
msgstr "%s: spec de valor ilegal"
@@ -1277,7 +1276,6 @@
msgstr "Nome do mapa raster base"
#: ../raster/r.median/main.c:58 ../raster/r.random/main.c:62
-#, fuzzy
msgid "Name of cover raster map"
msgstr "Nome do mapa raster de cobertura"
@@ -1331,9 +1329,8 @@
msgstr "Lendo a saída do r.stats"
#: ../raster/r.his/main.c:65
-#, fuzzy
msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr "Gera camadas vermelha verde e azul combinando valores de matiz (hue), intensidade e saturação (HIS) a partir das camadas raster fornecidas pelo usuário."
+msgstr "Gera camadas de mapa raster vermelha, verde e azul combinando valores de matiz (hue), intensidade e saturação (HIS) a partir das camadas de mapas raster de entrada fornecidas pelo usuário."
#: ../raster/r.his/main.c:74 ../display/d.his/main.c:76
msgid "Name of layer to be used for HUE"
@@ -1543,7 +1540,7 @@
#: ../raster/r.out.mat/main.c:282
#, fuzzy
msgid "Exporting raster as double FP values"
-msgstr "Coluna %d definida como inteiro só possui valores double"
+msgstr "Exportanto raster como valores PF double"
#: ../raster/r.out.mat/main.c:325
msgid "Reading in map ... "
@@ -1561,9 +1558,8 @@
#: ../raster/r.in.poly/main.c:29 ../raster/r.in.gdal/main.c:79
#: ../raster/r.in.bin/main.c:234 ../raster/r.external/main.c:506
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#, fuzzy
msgid "raster, import"
-msgstr "raster, import"
+msgstr "raster, importar"
#: ../raster/r.in.poly/main.c:31
msgid "Creates raster maps from ASCII polygon/line/point data files."
@@ -1588,45 +1584,42 @@
msgstr "Número mínimo de linhas para manter na memória é 1"
#: ../raster/r.in.poly/get_item.c:75
-#, fuzzy, c-format
+#, c-format
msgid "Illegal coordinate <%s, %s>, skipping."
-msgstr "Coordenada Leste ilegal <%s>"
+msgstr "Coordenada ilegal <%s, %s>, pulando."
#: ../raster/r.in.poly/get_item.c:80
-#, fuzzy, c-format
+#, c-format
msgid "Illegal north coordinate <%s>, skipping."
-msgstr "Coordenada norte ilegal <%s>"
+msgstr "Coordenada norte ilegal <%s>, pulando"
#: ../raster/r.in.poly/get_item.c:85
-#, fuzzy, c-format
+#, c-format
msgid "Illegal east coordinate <%s>, skipping."
+msgstr "Coordenada Leste ilegal <%s>, pulando."
#: ../raster/r.in.poly/poly2rast.c:36
-#, fuzzy, c-format
+#, c-format
msgid "Can't create raster map <%s>"
-msgstr "Não consegui criar arquivo raster <%s>."
+msgstr "Não consegui criar mapa raster <%s>"
#: ../raster/r.in.poly/poly2rast.c:56 ../raster/r.in.xyz/main.c:528
-#, fuzzy, c-format
+#, c-format
msgid "Pass #%d (of %d) ..."
-msgstr "classe %d (%d)\n"
+msgstr "Passagem #%d (de %d) ..."
#: ../raster/r.in.poly/poly2rast.c:78 ../raster/r.carve/raster.c:32
#: ../vector/v.to.rast/vect2rast.c:182
-#, fuzzy
msgid "Writing raster map..."
-msgstr "Escrevendo novo arquivo...\n"
+msgstr "Escrevendo mapa raster..."
#: ../raster/r.contour/main.c:91
-#, fuzzy
msgid "raster, DEM, contours, vector"
-msgstr "Nome do arquivo vetor de saída"
+msgstr "raster, MDT, contornos, vetor"
#: ../raster/r.contour/main.c:92
-#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
-msgstr "Produz um mapa vetorial binário do GRASS, com as curvas especificadas a partir de uma camada raster do GRASS."
+msgstr "Produz um mapa vetorial dos contornos especificados a partir de um mapa raster."
#: ../raster/r.contour/main.c:104
msgid "List of contour levels"
@@ -1674,9 +1667,9 @@
#: ../raster/r.contour/main.c:165 ../raster/r.stats/main.c:315
#: ../raster/r.recode/read_rules.c:19
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read fp range of raster map <%s>"
-msgstr "Não consegui escrever em <%s>"
+msgstr "Não consegui ler intervalo pf do mapa raster <%s>"
#: ../raster/r.contour/main.c:185 ../raster/r.random/random.c:74
#: ../raster/r.to.vect/main.c:158 ../display/d.vect.chart/plot.c:44
@@ -1717,9 +1710,9 @@
#: ../vector/v.to.3d/trans2.c:52 ../doc/vector/v.example/main.c:128
#: ../ps/ps.map/catval.c:54 ../ps/ps.map/catval.c:116
#: ../ps/ps.map/catval.c:182
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Não conseguir abrir banco de dados %s com driver %s"
+msgstr "Não conseguir abrir banco de dados <%s> com driver <%s>"
#: ../raster/r.contour/main.c:196 ../vector/v.in.ogr/main.c:790
#: ../vector/v.net.distance/main.c:208 ../vector/v.distance/main.c:818
@@ -1729,18 +1722,18 @@
#: ../vector/v.net.path/path.c:109 ../vector/v.to.points/main.c:295
#: ../vector/v.surf.rst/main.c:613 ../vector/v.net.centrality/main.c:240
#: ../vector/v.net.components/main.c:147
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create table: '%s'"
-msgstr "Não consegui criar arquivo [%s]"
+msgstr "Não consegui criar tabela: '%s'"
#: ../raster/r.contour/main.c:201 ../vector/v.in.ogr/main.c:795
#: ../vector/v.in.sites/main.c:174 ../vector/v.in.dxf/write_vect.c:225
#: ../vector/v.reclass/main.c:223 ../vector/v.in.dwg/main.c:223
#: ../vector/v.convert/att.c:85 ../vector/v.to.points/main.c:300
#: ../vector/v.in.ascii/in.c:505
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Não consegui abrir arquivo de saída <%s>."
+msgstr "Não consegui criar índice para tabela <%s>, chave <%s>"
#: ../raster/r.contour/main.c:206 ../raster/r.to.vect/main.c:203
#: ../vector/v.sample/main.c:223 ../vector/v.in.ogr/main.c:801
@@ -1750,41 +1743,38 @@
#: ../vector/v.in.dwg/main.c:228 ../vector/v.overlay/main.c:474
#: ../vector/v.convert/att.c:90 ../vector/v.to.points/main.c:306
#: ../vector/v.in.ascii/in.c:395
-#, fuzzy, c-format
+#, c-format
msgid "Unable to grant privileges on table <%s>"
-msgstr "Não posso dar privilégios na tabela %s"
+msgstr "Não posso dar privilégios na tabela <%s>"
#: ../raster/r.contour/main.c:224 ../vector/v.overlay/line_area.c:217
#: ../vector/v.overlay/area_area.c:238 ../vector/v.convert/att.c:110
#: ../vector/v.to.points/main.c:63
-#, fuzzy, c-format
+#, c-format
msgid "Unable to insert new record: '%s'"
-msgstr "Não consegui inserir nova linha: %s"
+msgstr "Não consegui inserir novo registro: '%s'"
#: ../raster/r.contour/main.c:244 ../vector/v.generalize/displacement.c:78
-#, fuzzy
msgid "Reading data..."
-msgstr "Rotacionando dados ... "
+msgstr "Lendo dados... "
#: ../raster/r.contour/main.c:270
-#, fuzzy, c-format
+#, c-format
msgid "Range of data: min=%f, max=%f"
-msgstr "Intervalo de inteiro: min,max"
+msgstr "Intervalo de dados: min=%f, max=%f"
#: ../raster/r.contour/main.c:272
-#, fuzzy
msgid "Range of data: empty"
+msgstr "Intervalo de dados: vazio"
#: ../raster/r.contour/main.c:299 ../raster/r.contour/main.c:303
-#, fuzzy
msgid "This step value is not allowed"
-msgstr "** Valores negativos não são permitidos!"
+msgstr "Este valor de passo não é permitido"
#: ../raster/r.contour/main.c:327
-#, fuzzy, c-format
+#, c-format
msgid "Range of levels: min = %f, max = %f"
+msgstr "Intervalo de valores: min = %f, max = %f"
#: ../raster/r.contour/main.c:356
#, fuzzy
@@ -1792,24 +1782,22 @@
#: ../raster/r.contour/cont.c:81
-#, fuzzy, c-format
+#, c-format
msgid "Writing vector contours (total levels %d)..."
-msgstr "Escrevendo [%s]..."
+msgstr "Escrevendo contornos de vetores (%d níveis no total)..."
#: ../raster/r.contour/cont.c:211
-#, fuzzy, c-format
+#, c-format
msgid "%d crossings founds"
-msgstr "%s: nenhum ponto de dados encontrado"
+msgstr "%d cruzamentos encontrados"
#: ../raster/r.contour/cont.c:262
-#, fuzzy
msgid "Illegal edge number"
-msgstr "Nome ilegal do arquivo de saída"
+msgstr "Número ilegal de arestas"
#: ../raster/r.contour/cont.c:370
-#, fuzzy
msgid "Edge number out of range"
-msgstr "Número de quadros"
+msgstr "Número de arestas fora do intervalo"
#: ../raster/r.out.pov/main.c:123
msgid "Converts a raster map layer into a height-field file for POVRAY."
@@ -1836,27 +1824,25 @@
msgstr "Fator de sobrelevação"
#: ../raster/r.out.pov/main.c:183
-#, fuzzy, c-format
+#, c-format
msgid "Invalid output filename <%s>"
+msgstr "Nome do arquivo de saída <%s> inválido"
#: ../raster/r.out.pov/main.c:193
-#, fuzzy, c-format
+#, c-format
msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr "Varredura mapear é"
+msgstr "Mapa raster é muito grande! Excede %d colunas ou %d linhas"
#: ../raster/r.out.pov/main.c:214
-#, fuzzy
msgid "Negative elevation values in input"
-msgstr "Nome do Arquivo raster de elevação"
+msgstr "Valores de elevação negativos na entrada"
#: ../raster/r.basins.fill/main.c:53 ../raster/r.lake/main.c:148
#: ../raster/r.watershed/front/main.c:56 ../raster/r.fill.dir/main.c:84
#: ../raster/r.topmodel/main.c:55 ../raster/r.water.outlet/main.c:48
#: ../raster/r.carve/main.c:77 ../raster/r.topidx/main.c:37
-#, fuzzy
msgid "raster, hydrology"
-msgstr "Inportação de vetor incompleta"
+msgstr "raster, hidrologia"
#: ../raster/r.basins.fill/main.c:55
#, fuzzy
@@ -1875,12 +1861,12 @@
#: ../raster/r.basins.fill/main.c:72
msgid "Number of passes through the dataset"
-msgstr "Número de passagens nos dados"
+msgstr "Número de passagens no conjunto de dados"
#: ../raster/r.basins.fill/main.c:99 ../raster/r.in.gdal/main.c:229
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> already exists"
-msgstr "O vetor '%s' já existe."
+msgstr "Mapa raster <%s> já existe"
#: ../raster/r.basins.fill/main.c:131
#, fuzzy
@@ -1894,9 +1880,9 @@
#: ../raster/r.basins.fill/main.c:155 ../raster/r.resample/main.c:152
#: ../raster/r.cross/main.c:194
-#, fuzzy, c-format
+#, c-format
msgid "Creating support files for <%s>..."
-msgstr "Criando arquivos de suporte para %s..."
+msgstr "Criando arquivos de suporte para <%s>..."
#: ../raster/r.describe/main.c:61
msgid "Prints terse list of category values found in a raster map layer."
@@ -1952,9 +1938,9 @@
msgstr ""
#: ../raster/r.describe/main.c:137
-#, fuzzy, c-format
+#, c-format
msgid "%s: [%s] not found"
-msgstr "[%s] não encontrado."
+msgstr "%s: [%s] não encontrado"
#: ../raster/r.le/r.le.trace/main.c:59
msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
@@ -1974,9 +1960,8 @@
msgstr "Mapa raster a ser amostrado"
#: ../raster/r.le/r.le.setup/main.c:71
-#, fuzzy
msgid "Vector map to overlay"
+msgstr "Mapa vetorial para sobrepor"
#: ../raster/r.le/r.le.patch/main.c:49
msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
@@ -1987,17 +1972,15 @@
msgstr ""
#: ../raster/r.mfilter.fp/main.c:58 ../raster/r.mfilter/main.c:51
-#, fuzzy
msgid "raster, map algebra"
+msgstr "raster, álgebra de mapas"
#: ../raster/r.mfilter.fp/main.c:59
#, fuzzy
msgid "Raster map matrix filter."
-msgstr "Matriz de filtro do arquivo raster"
+msgstr "Filtro de matriz de mapa raster"
#: ../raster/r.mfilter.fp/main.c:70
-#, fuzzy
msgid "Name of filter file"
msgstr "Nome do arquivo de filtro"
@@ -2031,14 +2014,13 @@
msgstr ""
#: ../raster/r.mfilter.fp/main.c:138 ../raster/r.mfilter/main.c:133
-#, fuzzy
msgid "Raster map too small for the size of the filter"
-msgstr "Mapa raster do qual copiarei a tabela de cores"
+msgstr "Mapa raster muito pequeno para o tamanho do filtro"
#: ../raster/r.mfilter.fp/getfilt.c:27 ../raster/r.mfilter/getfilt.c:26
-#, fuzzy, c-format
+#, c-format
msgid "Cannot open filter file '%s'"
-msgstr "Não consegui abrir o arquivo [%s]"
+msgstr "Não consegui abrir o arquivo de filtro '%s'"
#: ../raster/r.mfilter.fp/getfilt.c:47 ../raster/r.mfilter/getfilt.c:46
#, fuzzy
@@ -3019,7 +3001,7 @@
#: ../raster/r.in.gdal/main.c:136 ../raster/r.external/main.c:546
#: ../vector/v.in.ogr/main.c:231
msgid "Extend location extents based on new dataset"
-msgstr "Estender locação baseado nos novos dados"
+msgstr "Estender locação baseado no novo conjunto de dados"
#: ../raster/r.in.gdal/main.c:140 ../raster/r.external/main.c:554
#: ../vector/v.in.ogr/main.c:202
@@ -3130,13 +3112,12 @@
#: ../raster/r.in.gdal/main.c:364 ../raster/r.external/main.c:107
#: ../vector/v.in.ogr/main.c:518
-#, fuzzy
msgid ""
"Projection of dataset does not appear to match current location.\n"
"\n"
msgstr ""
-"Projeção dos dados de entrada e locação atual parecem combinar.\n"
-"Continuando com a importação...\n"
+"Projeção do conjunto de dados parece não combinar com a locação atual.\n"
+"\n"
#: ../raster/r.in.gdal/main.c:369 ../raster/r.external/main.c:112
#, fuzzy
@@ -3145,35 +3126,30 @@
#: ../raster/r.in.gdal/main.c:380 ../raster/r.external/main.c:123
msgid "Dataset PROJ_INFO is:\n"
-msgstr ""
+msgstr "PROJ_INFO do conjunto de dados é:\n"
#: ../raster/r.in.gdal/main.c:407 ../raster/r.external/main.c:150
#: ../vector/v.in.ogr/main.c:534 ../vector/v.in.ogr/main.c:541
-#, fuzzy
msgid "Import dataset PROJ_INFO is:\n"
-msgstr "Locação: %s\n"
+msgstr "PROJ_INFO do conjunto de dados importado é:\n"
#: ../raster/r.in.gdal/main.c:429
-#, fuzzy
msgid ""
"\n"
"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"Você pode usar a opção -o para %s para ignorar esta verificação.\n"
+"Você pode usar a opção -o para r.in.gdal para ignorar esta verificaçãoe usar a definição de locação para o conjunto de dados.\n"
#: ../raster/r.in.gdal/main.c:432 ../raster/r.external/main.c:175
#, fuzzy
msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
-msgstr "Considere gerar uma nova locação com o parâmetro 'location' do dado de entrada.\n"
+msgstr "Considere gerar uma nova locação a partir do conjunto de dados de entrada usando o parâmetro 'location'.\n"
#: ../raster/r.in.gdal/main.c:437 ../raster/r.external/main.c:180
#: ../vector/v.in.ogr/main.c:592
-#, fuzzy
msgid "Projection of input dataset and current location appear to match"
-msgstr ""
+msgstr "Projeção do conjunto de dados de entrada e locação atual parecem combinar"
#: ../raster/r.in.gdal/main.c:443 ../raster/r.external/main.c:614
#, fuzzy
@@ -3268,7 +3244,7 @@
#: ../raster/r.composite/main.c:273
#, fuzzy, c-format
msgid "Raster map <%s> created."
+msgstr "Mapa raster <%s> criado."
#: ../raster/r.in.bin/main.c:49 ../raster/r.in.bin/main.c:58
#: ../raster/r.in.bin/main.c:510
@@ -3729,9 +3705,8 @@
"\n"
#: ../raster/r.support/front/front.c:54
-#, fuzzy
msgid "raster, metadata"
+msgstr "raster, metadados"
#: ../raster/r.support/front/front.c:55
msgid "Allows creation and/or modification of raster map layer support files."
@@ -4272,9 +4247,8 @@
#: ../raster/r.regression.line/main.c:42 ../raster/r.support.stats/main.c:39
#: ../raster/r.quantile/main.c:254
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:2
-#, fuzzy
msgid "raster, statistics"
-msgstr "Estatísticas de transição de classe."
+msgstr "raster, statísticas"
#: ../raster/r.stats/main.c:105
msgid "Generates area statistics for raster map layers."
@@ -37745,13 +37719,11 @@
#~ " Try:\n"
#~ msgstr "Mapa raster [%s] existe no grupo."
-#, fuzzy
#~ msgid "raster3d, voxel, statistics"
-#~ msgstr "Estatísticas de transição de classe."
+#~ msgstr "raster3d, voxel, estatísticas"
-#, fuzzy
#~ msgid "raster, color transformation"
-#~ msgstr "Mostrar informação topológica (depuração)"
+#~ msgstr "raster, transformação de cor"
#, fuzzy
#~ msgid "raster, export, png"
