[GRASS-SVN] r46149 - grass/trunk/locale/po
svn_grass at osgeo.org
Sun May 1 03:50:04 EDT 2011
Author: neteler
Date: 2011-05-01 00:50:04 -0700 (Sun, 01 May 2011)
New Revision: 46149
grass/trunk/locale/po/grassmods_pt_br.po
Fred Maranh?\195?\163o: cont'ed
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2011-05-01 07:49:22 UTC (rev 46148)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2011-05-01 07:50:04 UTC (rev 46149)
@@ -12,7 +12,7 @@
"Project-Id-Version: grassmods_pt_br\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2011-04-23 15:35+0200\n"
-"PO-Revision-Date: 2011-04-23 21:55-0300\n"
+"PO-Revision-Date: 2011-04-30 20:23-0300\n"
"Last-Translator: Fred Ulisses Maranhão <fred.maranhao at gmail.com>\n"
"Language-Team: Brasilian Portuguese <grass-translations at lists.osgeo.org>\n"
"MIME-Version: 1.0\n"
@@ -291,7 +291,6 @@
msgstr "Mostra/adiciona/remove carimbo de data em um mapa raster 3D"
#: ../raster3d/r3.timestamp/r3.timestamp.main.c:53
-#, fuzzy
msgid "Input grid3 filename"
msgstr "Nome do arquivo grid3 de entrada"
@@ -1030,7 +1029,7 @@
msgstr ""
#: ../raster3d/base/mask_functions.c:100 ../raster/r.null/main.c:258
-#, fuzzy, c-format
+#, c-format
msgid "%s: illegal value spec"
msgstr "%s: spec de valor ilegal"
@@ -1408,9 +1407,8 @@
msgstr ""
#: ../raster/r.his/main.c:67
-#, fuzzy
msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
-msgstr "Gera camadas vermelha verde e azul combinando valores de matiz (hue), intensidade e saturação (HIS) a partir das camadas raster fornecidas pelo usuário."
+msgstr "Gera camadas de mapa raster vermelha, verde e azul combinando valores de matiz (hue), intensidade e saturação (HIS) a partir das camadas de mapas raster de entrada fornecidas pelo usuário."
#: ../raster/r.his/main.c:76 ../display/d.his/main.c:76
msgid "Name of layer to be used for HUE"
@@ -1527,7 +1525,7 @@
#: ../raster/r.out.mat/main.c:260
#, fuzzy
msgid "Exporting raster as double FP values"
-msgstr "Coluna %d definida como inteiro só possui valores double"
+msgstr "Exportanto raster como valores PF double"
#: ../raster/r.out.mat/main.c:303
msgid "Reading in map ... "
@@ -1565,30 +1563,29 @@
msgstr "Número mínimo de linhas para manter na memória é 1"
#: ../raster/r.in.poly/get_item.c:76
-#, fuzzy, c-format
+#, c-format
msgid "Illegal coordinate <%s, %s>, skipping."
-msgstr "Coordenada Leste ilegal <%s>"
+msgstr "Coordenada ilegal <%s, %s>, pulando."
#: ../raster/r.in.poly/get_item.c:81
-#, fuzzy, c-format
+#, c-format
msgid "Illegal north coordinate <%s>, skipping."
-msgstr "Coordenada norte ilegal <%s>"
+msgstr "Coordenada norte ilegal <%s>, pulando"
#: ../raster/r.in.poly/get_item.c:86
-#, fuzzy, c-format
+#, c-format
msgid "Illegal east coordinate <%s>, skipping."
+msgstr "Coordenada Leste ilegal <%s>, pulando."
#: ../raster/r.in.poly/poly2rast.c:55 ../raster/r.in.xyz/main.c:531
-#, fuzzy, c-format
+#, c-format
msgid "Pass #%d (of %d) ..."
-msgstr "classe %d (%d)\n"
+msgstr "Passagem #%d (de %d) ..."
#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
#: ../vector/v.to.rast/vect2rast.c:175
-#, fuzzy
msgid "Writing raster map..."
-msgstr "Escrevendo novo arquivo...\n"
+msgstr "Escrevendo mapa raster..."
#: ../raster/r.contour/main.c:87
msgid "DEM"
@@ -1681,9 +1678,8 @@
msgstr ""
#: ../raster/r.contour/main.c:90
-#, fuzzy
msgid "Produces a vector map of specified contours from a raster map."
-msgstr "Produz um mapa vetorial binário do GRASS, com as curvas especificadas a partir de uma camada raster do GRASS."
+msgstr "Produz um mapa vetorial dos contornos especificados a partir de um mapa raster."
#: ../raster/r.contour/main.c:101
msgid "List of contour levels"
@@ -1710,9 +1706,9 @@
msgstr ""
#: ../raster/r.contour/main.c:141 ../raster/r.stats/main.c:307
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read fp range of raster map <%s>"
-msgstr "Não consegui escrever em <%s>"
+msgstr "Não consegui ler intervalo pf do mapa raster <%s>"
#: ../raster/r.contour/main.c:161 ../raster/r.random/random.c:73
#: ../raster/r.to.vect/main.c:166 ../display/d.vect.chart/plot.c:43
@@ -1751,9 +1747,9 @@
#: ../vector/v.to.3d/trans2.c:54 ../doc/vector/v.example/main.c:131
#: ../ps/ps.map/catval.c:54 ../ps/ps.map/catval.c:116
#: ../ps/ps.map/catval.c:182
-#, fuzzy, c-format
+#, c-format
msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Não conseguir abrir banco de dados %s com driver %s"
+msgstr "Não conseguir abrir banco de dados <%s> com driver <%s>"
#: ../raster/r.contour/main.c:172 ../vector/v.in.ogr/main.c:791
#: ../vector/v.net.distance/main.c:210 ../vector/v.distance/main.c:981
@@ -1763,18 +1759,18 @@
#: ../vector/v.net.path/path.c:109 ../vector/v.to.points/main.c:293
#: ../vector/v.surf.rst/main.c:579 ../vector/v.net.centrality/main.c:242
#: ../vector/v.net.components/main.c:149
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create table: '%s'"
-msgstr "Não consegui criar arquivo [%s]"
+msgstr "Não consegui criar tabela: '%s'"
#: ../raster/r.contour/main.c:177 ../vector/v.in.ogr/main.c:796
#: ../vector/v.in.sites/main.c:176 ../vector/v.in.dxf/write_vect.c:240
#: ../vector/v.reclass/main.c:227 ../vector/v.in.dwg/main.c:241
#: ../vector/v.convert/att.c:86 ../vector/v.to.points/main.c:298
#: ../vector/v.in.ascii/main.c:504
-#, fuzzy, c-format
+#, c-format
msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Não consegui abrir arquivo de saída <%s>."
+msgstr "Não consegui criar índice para tabela <%s>, chave <%s>"
#: ../raster/r.contour/main.c:182 ../raster/r.to.vect/main.c:211
#: ../vector/v.sample/main.c:196 ../vector/v.in.ogr/main.c:802
@@ -1784,41 +1780,38 @@
#: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:472
#: ../vector/v.convert/att.c:91 ../vector/v.to.points/main.c:304
#: ../vector/v.in.ascii/main.c:394
-#, fuzzy, c-format
+#, c-format
msgid "Unable to grant privileges on table <%s>"
-msgstr "Não posso dar privilégios na tabela %s"
+msgstr "Não posso dar privilégios na tabela <%s>"
#: ../raster/r.contour/main.c:200 ../vector/v.overlay/line_area.c:217
#: ../vector/v.overlay/area_area.c:238 ../vector/v.convert/att.c:111
#: ../vector/v.to.points/main.c:63
-#, fuzzy, c-format
+#, c-format
msgid "Unable to insert new record: '%s'"
-msgstr "Não consegui inserir nova linha: %s"
+msgstr "Não consegui inserir novo registro: '%s'"
#: ../raster/r.contour/main.c:220 ../vector/v.generalize/displacement.c:79
-#, fuzzy
msgid "Reading data..."
-msgstr "Rotacionando dados ... "
+msgstr "Lendo dados... "
#: ../raster/r.contour/main.c:246
-#, fuzzy, c-format
+#, c-format
msgid "Range of data: min=%f, max=%f"
-msgstr "Intervalo de inteiro: min,max"
+msgstr "Intervalo de dados: min=%f, max=%f"
#: ../raster/r.contour/main.c:248
-#, fuzzy
msgid "Range of data: empty"
+msgstr "Intervalo de dados: vazio"
#: ../raster/r.contour/main.c:276 ../raster/r.contour/main.c:279
-#, fuzzy
msgid "This step value is not allowed"
-msgstr "** Valores negativos não são permitidos!"
+msgstr "Este valor de passo não é permitido"
#: ../raster/r.contour/main.c:304
-#, fuzzy, c-format
+#, c-format
msgid "Range of levels: min = %f, max = %f"
+msgstr "Intervalo de valores: min = %f, max = %f"
#: ../raster/r.contour/main.c:333
#, fuzzy
@@ -1826,24 +1819,22 @@
#: ../raster/r.contour/cont.c:82
-#, fuzzy, c-format
+#, c-format
msgid "Writing vector contours (total levels %d)..."
-msgstr "Escrevendo [%s]..."
+msgstr "Escrevendo contornos de vetores (%d níveis no total)..."
#: ../raster/r.contour/cont.c:212
-#, fuzzy, c-format
+#, c-format
msgid "%d crossings founds"
-msgstr "%s: nenhum ponto de dados encontrado"
+msgstr "%d cruzamentos encontrados"
#: ../raster/r.contour/cont.c:263
-#, fuzzy
msgid "Illegal edge number"
-msgstr "Nome ilegal do arquivo de saída"
+msgstr "Número ilegal de arestas"
#: ../raster/r.contour/cont.c:371
-#, fuzzy
msgid "Edge number out of range"
-msgstr "Número de quadros"
+msgstr "Número de arestas fora do intervalo"
#: ../raster/r.out.pov/main.c:124
#, fuzzy
@@ -1867,19 +1858,18 @@
msgstr "Fator de sobrelevação"
#: ../raster/r.out.pov/main.c:170
-#, fuzzy, c-format
+#, c-format
msgid "Invalid output filename <%s>"
+msgstr "Nome do arquivo de saída <%s> inválido"
#: ../raster/r.out.pov/main.c:180
-#, fuzzy, c-format
+#, c-format
msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr "Varredura mapear é"
+msgstr "Mapa raster é muito grande! Excede %d colunas ou %d linhas"
#: ../raster/r.out.pov/main.c:201
-#, fuzzy
msgid "Negative elevation values in input"
-msgstr "Nome do Arquivo raster de elevação"
+msgstr "Valores de elevação negativos na entrada"
#: ../raster/r.basins.fill/main.c:57
#, fuzzy
@@ -1898,7 +1888,7 @@
#: ../raster/r.basins.fill/main.c:73
msgid "Number of passes through the dataset"
-msgstr "Número de passagens nos dados"
+msgstr "Número de passagens no conjunto de dados"
#: ../raster/r.basins.fill/main.c:121
#, fuzzy
@@ -1912,9 +1902,9 @@
#: ../raster/r.basins.fill/main.c:145 ../raster/r.resample/main.c:125
#: ../raster/r.cross/main.c:173
-#, fuzzy, c-format
+#, c-format
msgid "Creating support files for <%s>..."
-msgstr "Criando arquivos de suporte para %s..."
+msgstr "Criando arquivos de suporte para <%s>..."
#: ../raster/r.basins.fill/read_map.c:39
#, fuzzy, c-format
@@ -1990,9 +1980,8 @@
msgstr "Mapa raster a ser amostrado"
#: ../raster/r.le/r.le.setup/main.c:67
-#, fuzzy
msgid "Vector map to overlay"
-msgstr "Inportação de vetor incompleta"
+msgstr "Mapa vetorial para sobrepor"
#: ../raster/r.le/r.le.patch/main.c:50
msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
@@ -2490,7 +2479,7 @@
#: ../raster/r.in.gdal/main.c:135 ../raster/r.external/main.c:562
#: ../vector/v.in.ogr/main.c:232
msgid "Extend location extents based on new dataset"
-msgstr "Estender locação baseado nos novos dados"
+msgstr "Estender locação baseado no novo conjunto de dados"
#: ../raster/r.in.gdal/main.c:146
#, fuzzy
@@ -2530,9 +2519,9 @@
msgstr "O vetor '%s' já existe."
#: ../raster/r.in.gdal/main.c:229
-#, fuzzy, c-format
+#, c-format
msgid "Raster map <%s> already exists"
-msgstr "O vetor '%s' já existe."
+msgstr "Mapa raster <%s> já existe"
#: ../raster/r.in.gdal/main.c:246
msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
@@ -2568,13 +2557,12 @@
#: ../raster/r.in.gdal/main.c:369 ../raster/r.external/main.c:113
#: ../vector/v.in.ogr/main.c:525
-#, fuzzy
msgid ""
"Projection of dataset does not appear to match current location.\n"
"\n"
msgstr ""
-"Projeção dos dados de entrada e locação atual parecem combinar.\n"
-"Continuando com a importação...\n"
+"Projeção do conjunto de dados parece não combinar com a locação atual.\n"
+"\n"
#: ../raster/r.in.gdal/main.c:374 ../raster/r.external/main.c:118
#, fuzzy
@@ -2583,35 +2571,30 @@
#: ../raster/r.in.gdal/main.c:385 ../raster/r.external/main.c:129
msgid "Dataset PROJ_INFO is:\n"
-msgstr ""
+msgstr "PROJ_INFO do conjunto de dados é:\n"
#: ../raster/r.in.gdal/main.c:412 ../raster/r.external/main.c:156
#: ../vector/v.in.ogr/main.c:541 ../vector/v.in.ogr/main.c:548
-#, fuzzy
msgid "Import dataset PROJ_INFO is:\n"
-msgstr "Locação: %s\n"
+msgstr "PROJ_INFO do conjunto de dados importado é:\n"
#: ../raster/r.in.gdal/main.c:434
-#, fuzzy
msgid ""
"\n"
"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
msgstr ""
"\n"
-"Você pode usar a opção -o para %s para ignorar esta verificação.\n"
+"Você pode usar a opção -o para r.in.gdal para ignorar esta verificaçãoe usar a definição de locação para o conjunto de dados.\n"
#: ../raster/r.in.gdal/main.c:437 ../raster/r.external/main.c:181
#, fuzzy
msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
-msgstr "Considere gerar uma nova locação com o parâmetro 'location' do dado de entrada.\n"
+msgstr "Considere gerar uma nova locação a partir do conjunto de dados de entrada usando o parâmetro 'location'.\n"
#: ../raster/r.in.gdal/main.c:442 ../raster/r.external/main.c:186
#: ../vector/v.in.ogr/main.c:599
-#, fuzzy
msgid "Projection of input dataset and current location appear to match"
-msgstr ""
+msgstr "Projeção do conjunto de dados de entrada e locação atual parecem combinar"
#: ../raster/r.in.gdal/main.c:448 ../raster/r.external/main.c:644
#, fuzzy
@@ -2702,7 +2685,7 @@
#: ../raster/r.surf.fractal/main.c:85 ../raster/r.composite/main.c:261
#, fuzzy, c-format
msgid "Raster map <%s> created."
+msgstr "Mapa raster <%s> criado."
#: ../raster/r.in.bin/main.c:50 ../raster/r.in.bin/main.c:59
#: ../raster/r.in.bin/main.c:512
@@ -4773,14 +4756,13 @@
msgstr "Aplicar filtro somente para valores zerados"
#: ../raster/r.mfilter/main.c:124
-#, fuzzy
msgid "Raster map too small for the size of the filter"
-msgstr "Mapa raster do qual copiarei a tabela de cores"
+msgstr "Mapa raster muito pequeno para o tamanho do filtro"
#: ../raster/r.mfilter/getfilt.c:27
-#, fuzzy, c-format
+#, c-format
msgid "Cannot open filter file '%s'"
-msgstr "Não consegui abrir o arquivo [%s]"
+msgstr "Não consegui abrir o arquivo de filtro '%s'"
#: ../raster/r.mfilter/getfilt.c:47
#, fuzzy
@@ -5505,7 +5487,6 @@
msgstr "Cria um mapa raster e um mapa vetorial de pontos contendo locais aleatórios"
#: ../raster/r.random/main.c:64
-#, fuzzy
msgid "Name of cover raster map"
msgstr "Nome do mapa raster de cobertura"
@@ -36807,7 +36788,6 @@
#~ msgid "Required"
#~ msgstr "quieto"
-#, fuzzy
#~ msgid "Name of filter file"
#~ msgstr "Nome do arquivo de filtro"
@@ -37383,9 +37363,8 @@
#~ msgid "unable to open accum file in valid_basins()"
#~ msgstr "Não consegui abrir os arquivos das bandas."
-#, fuzzy
#~ msgid "Can't create raster map <%s>"
-#~ msgstr "Não consegui criar arquivo raster <%s>."
+#~ msgstr "Não consegui criar mapa raster <%s>"
#, fuzzy
#~ msgid "Quant table not changed for %s"
@@ -37877,9 +37856,8 @@
#~ msgid "raster, imagery, colors"
#~ msgstr "Inportação de vetor incompleta"
-#, fuzzy
#~ msgid "raster, import"
-#~ msgstr "raster, import"
+#~ msgstr "raster, importar"
#, fuzzy
#~ msgid "raster, imagery"
@@ -38249,9 +38227,8 @@
#~ msgid "%s higher above pointer wrong"
#~ msgstr "Altura da câmera sobre o terreno"
-#, fuzzy
#~ msgid "raster, DEM, contours, vector"
-#~ msgstr "Nome do arquivo vetor de saída"
+#~ msgstr "raster, MDT, contornos, vetor"
#, fuzzy
#~ msgid "raster, random, cell"
@@ -38287,9 +38264,8 @@
#~ msgid "Name of the longitude input raster map [decimal degrees]"
#~ msgstr "Nome do arquivo raster com as latitudes [graus decimais]"
-#, fuzzy
#~ msgid "raster, metadata"
-#~ msgstr "Inportação de vetor incompleta"
+#~ msgstr "raster, metadados"
#, fuzzy
#~ msgid "raster, composite"
@@ -38681,9 +38657,8 @@
#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
#~ msgstr "de"
-#, fuzzy
#~ msgid "%s: [%s] not found"
-#~ msgstr "[%s] não encontrado."
+#~ msgstr "%s: [%s] não encontrado"
#, fuzzy
#~ msgid "Please choose a unit by entering one of the following letter codes:"
@@ -39677,9 +39652,8 @@
#~ msgid "Converts a raster map layer into a height-field file for POVRAY."
#~ msgstr "Converte uma camada raster num campo de altura (height field) para o POVRAY."
-#, fuzzy
#~ msgid "raster, map algebra"
+#~ msgstr "raster, álgebra de mapas"
#~ msgid "Converts a raster map layer into an ASCII text file."
#~ msgstr "Converte uma camada raster para um arquivo de texto ASCII"
@@ -39703,9 +39677,8 @@
#~ msgid "Interpolating raster map <%s> (%d rows)... "
#~ msgstr "Interpolando mapa raster <%s> ... %d linhas ..."
-#, fuzzy
#~ msgid "raster, statistics"
-#~ msgstr "Estatísticas de transição de classe."
+#~ msgstr "raster, statísticas"
#~ msgid "Converts raster maps into the VTK-Ascii format"
#~ msgstr "Converte mapas raster para o formato VTK-ASCII"
@@ -40700,13 +40673,12 @@
#~ msgid "<%s> is an ilegal name"
#~ msgstr "[%s] é um nome ilegal"
-#, fuzzy
#~ msgid "raster, hydrology"
+#~ msgstr "raster, hidrologia"
#, fuzzy
#~ msgid "Raster map matrix filter."
-#~ msgstr "Matriz de filtro do arquivo raster"
+#~ msgstr "Filtro de matriz de mapa raster"
#, fuzzy
#~ msgid "Export GRASS raster as non-georeferenced PNG image."
@@ -40980,16 +40952,14 @@
#~ msgid " 1. nearest neighbor\n"
#~ msgstr "assumindo amostragem por vizinhança próxima"
-#, fuzzy
#~ msgid "raster3d, voxel, statistics"
+#~ msgstr "raster3d, voxel, estatísticas"
#~ msgid "Exports a GRASS raster map to a binary array."
#~ msgstr "Exporta um mapa raster do GRASS para um arquivo binário."
-#, fuzzy
#~ msgid "raster, color transformation"
-#~ msgstr "Mostrar informação topológica (depuração)"
+#~ msgstr "raster, transformação de cor"
#, fuzzy
#~ msgid "raster, export, png"
