[GRASS-SVN] r46180 - grass/branches/develbranch_6/lib/db/dbmi_client
svn_grass at osgeo.org
Wed May 4 05:24:24 EDT 2011
Author: mmetz
Date: 2011-05-04 02:24:24 -0700 (Wed, 04 May 2011)
New Revision: 46180
grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
fix warning messages
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c 2011-05-04 09:23:30 UTC (rev 46179)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c 2011-05-04 09:24:24 UTC (rev 46180)
@@ -103,7 +103,7 @@
db_set_handle(&from_handle, from_dbname, NULL);
if (db_open_database(from_driver, &from_handle) != DB_OK) {
G_warning(_("Unable to open database <%s> by driver <%s>"),
- from_drvname, from_dbname);
+ from_dbname, from_drvname);
db_close_database_shutdown_driver(from_driver);
return DB_FAILED;
@@ -124,7 +124,7 @@
db_set_handle(&to_handle, to_dbname, NULL);
if (db_open_database(to_driver, &to_handle) != DB_OK) {
- to_drvname, to_dbname);
+ to_dbname, to_drvname);
db_close_database_shutdown_driver(to_driver);
if (from_driver != to_driver) {
