[GRASS-SVN] r46181 - grass/trunk/lib/db/dbmi_client
Wed May 4 05:37:11 EDT 2011
Author: mmetz
Date: 2011-05-04 02:37:11 -0700 (Wed, 04 May 2011)
New Revision: 46181
   grass/trunk/lib/db/dbmi_client/copy_tab.c
fix warning messages, add safety check
Modified: grass/trunk/lib/db/dbmi_client/copy_tab.c
--- grass/trunk/lib/db/dbmi_client/copy_tab.c	2011-05-04 09:24:24 UTC (rev 46180)
+++ grass/trunk/lib/db/dbmi_client/copy_tab.c	2011-05-04 09:37:11 UTC (rev 46181)
@@ -87,12 +87,20 @@
     db_init_string(&sql);
     db_init_string(&value_string);
-    /* Make a copy of input values and sort it */
-    if (ivals) {
-	ivalues = (int *)G_malloc(nvals * sizeof(int));
-	memcpy(ivalues, ivals, nvals * sizeof(int));
-	qsort((void *)ivalues, nvals, sizeof(int), cmp);
+    if (selcol) {
+	if (!ivals || (ivals && nvals == 0)) {
+	    G_warning(_("Array of values to select from column <%s> is empty"), selcol);
+	    return DB_FAILED;
+	/* Make a copy of input values and sort it */
+	if (ivals) {
+	    ivalues = (int *)G_malloc(nvals * sizeof(int));
+	    memcpy(ivalues, ivals, nvals * sizeof(int));
+	    qsort((void *)ivalues, nvals, sizeof(int), cmp);
+    else
+	ivalues = NULL;
     /* Open input driver and database */
     from_driver = db_start_driver(from_drvname);
@@ -103,7 +111,7 @@
     db_set_handle(&from_handle, from_dbname, NULL);
     if (db_open_database(from_driver, &from_handle) != DB_OK) {
 	G_warning(_("Unable to open database <%s> by driver <%s>"),
-		  from_drvname, from_dbname);
+		  from_dbname, from_drvname);
 	db_close_database_shutdown_driver(from_driver);
 	return DB_FAILED;
@@ -124,7 +132,7 @@
 	db_set_handle(&to_handle, to_dbname, NULL);
 	if (db_open_database(to_driver, &to_handle) != DB_OK) {
-		      to_drvname, to_dbname);
+		      to_dbname, to_drvname);
 	    db_close_database_shutdown_driver(to_driver);
 	    if (from_driver != to_driver) {
