[GRASS-SVN] r46185 -
grass/branches/develbranch_6/gui/wxpython/gui_modules
svn_grass at osgeo.org
Wed May 4 12:48:08 EDT 2011
Author: martinl
Date: 2011-05-04 09:48:08 -0700 (Wed, 04 May 2011)
New Revision: 46185
grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
wxGUI: avoid gettext warning
(merge r46183 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py 2011-05-04 16:45:48 UTC (rev 46184)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py 2011-05-04 16:48:08 UTC (rev 46185)
@@ -680,8 +680,9 @@
if errLines:
gcmd.GError(parent = self,
- message = _("Error when reading file '%s'.\n\nLines: %s") % \
- (translatorsfile, os.linesep.join(map (utils.UnicodeString, errLines))))
+ message = _("Error when reading file '%s'.") % translatorsfile + \
+ "\n\n" + _("Lines:") + " %s" % \
+ os.linesep.join(map(utils.UnicodeString, errLines)))
else:
contribs = None
@@ -735,8 +736,9 @@
if errLines:
else:
translators = None
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2011-05-04 16:45:48 UTC (rev 46184)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py 2011-05-04 16:48:08 UTC (rev 46185)
@@ -1980,11 +1980,11 @@
cmdout, cmderr = grass.Popen([cmd, '--interface-description'], stdout = grass.PIPE,
stderr = grass.PIPE).communicate()
except OSError, e:
- raise gcmd.GException, _("Unable to fetch interface description for command '%s'. "
- "Details: %s") % (cmd, e)
+ raise gcmd.GException, _("Unable to fetch interface description for command '%s'.") % cmd + \
+ _("Details:") + "%s" % e
if cmderr and cmderr[:7] != 'WARNING':
- "Details: %s") % (cmd, cmderr)
+ _("Details:") + " %s" % cmderr
return cmdout.replace('grass-interface.dtd', os.path.join(globalvar.ETCDIR, 'grass-interface.dtd'))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2011-05-04 16:45:48 UTC (rev 46184)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py 2011-05-04 16:48:08 UTC (rev 46185)
@@ -654,9 +654,11 @@
if ret != 0:
if rast:
- message = _("Unable to zoom to raster map <%s>.\n\nDetails: %s") % (rast[0], msg)
+ message = _("Unable to zoom to raster map <%s>.") % rast[0] + \
+ "\n\n" + _("Details:") + " %s" % msg
elif vect:
- message = _("Unable to zoom to vector map <%s>.\n\nDetails: %s") % (vect[0], msg)
+ message = _("Unable to zoom to vector map <%s>.") % vect[0] + \
else:
message = _("Unable to get current geographic extent. "
"Force quiting wxGUI. Please run manually g.region to "
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-05-04 16:45:48 UTC (rev 46184)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py 2011-05-04 16:48:08 UTC (rev 46185)
@@ -83,8 +83,8 @@
def Database(self, driver, database):
"""!Opening database failed
- GError(message = _('Unable to open database <%s> by driver <%s>. '
- 'Operation cancelled.') % (database, driver),
+ GError(message = _('Unable to open database <%(db)s> by driver <%(driver)s>. '
+ 'Operation cancelled.') % { 'db' : database, 'driver' : driver},
parent = self.parent,
caption = self.caption)
