[GRASS-SVN] r46255 - grass/branches/develbranch_6/scripts/g.extension
Fri May 13 05:13:53 EDT 2011
Author: hamish
Date: 2011-05-13 02:13:53 -0700 (Fri, 13 May 2011)
New Revision: 46255
   grass/branches/develbranch_6/scripts/g.extension/g.extension
quoting fix
Modified: grass/branches/develbranch_6/scripts/g.extension/g.extension
--- grass/branches/develbranch_6/scripts/g.extension/g.extension	2011-05-13 09:07:30 UTC (rev 46254)
+++ grass/branches/develbranch_6/scripts/g.extension/g.extension	2011-05-13 09:13:53 UTC (rev 46255)
@@ -305,7 +305,7 @@
          su -c "rm -f \"${MYINST_DIR}/$PROGTYPE/${MODULE}\""
       fi
       g.message "You need to enter the root password next to install ${MODULE}:"
-      su -c "make MODULE_TOPDIR="$GISBASE" ARCH_DISTDIR="$TMPDIR/dist" INST_DIR="$MYINST_DIR" install"
+      su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/dist\" INST_DIR=\"$MYINST_DIR\" install"
    else
       if test -f "${MYINST_DIR}/$PROGTYPE/${MODULE}" ; then
          rm -f "${MYINST_DIR}/$PROGTYPE/${MODULE}"
