[GRASS-SVN] r46256 -
grass/branches/releasebranch_6_4/scripts/g.extension
svn_grass at osgeo.org
Fri May 13 05:16:35 EDT 2011
Author: hamish
Date: 2011-05-13 02:16:35 -0700 (Fri, 13 May 2011)
New Revision: 46256
grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
quoting fix (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/g.extension/g.extension
--- grass/branches/releasebranch_6_4/scripts/g.extension/g.extension 2011-05-13 09:13:53 UTC (rev 46255)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/g.extension 2011-05-13 09:16:35 UTC (rev 46256)
@@ -305,7 +305,7 @@
su -c "rm -f \"${MYINST_DIR}/$PROGTYPE/${MODULE}\""
fi
g.message "You need to enter the root password next to install ${MODULE}:"
- su -c "make MODULE_TOPDIR="$GISBASE" ARCH_DISTDIR="$TMPDIR/dist" INST_DIR="$MYINST_DIR" install"
+ su -c "make MODULE_TOPDIR=\"$GISBASE\" ARCH_DISTDIR=\"$TMPDIR/dist\" INST_DIR=\"$MYINST_DIR\" install"
else
if test -f "${MYINST_DIR}/$PROGTYPE/${MODULE}" ; then
rm -f "${MYINST_DIR}/$PROGTYPE/${MODULE}"
