[GRASS-SVN] r46324 - grass/trunk/raster/r.out.gdal
svn_grass at osgeo.org
Tue May 17 10:58:26 EDT 2011
Author: mmetz
Date: 2011-05-17 07:58:26 -0700 (Tue, 17 May 2011)
New Revision: 46324
grass/trunk/raster/r.out.gdal/export_band.c
do not use Rast_get_null_value_row()
Modified: grass/trunk/raster/r.out.gdal/export_band.c
--- grass/trunk/raster/r.out.gdal/export_band.c 2011-05-17 13:08:32 UTC (rev 46323)
+++ grass/trunk/raster/r.out.gdal/export_band.c 2011-05-17 14:58:26 UTC (rev 46324)
@@ -63,12 +63,8 @@
G_warning(_("Unable to allocate buffer for reading raster map"));
return -1;
- char *nulls = (char *)G_malloc(cols);
- if (nulls == NULL) {
- G_warning(_("Unable to allocate buffer for reading raster map"));
- return -1;
+ /* the following routine must be kept identical to export_band */
/* Copy data form GRASS raster to GDAL raster */
int row, col;
@@ -89,10 +85,8 @@
for (row = 0; row < rows; row++) {
Rast_get_row(fd, bufer, row, maptype);
- Rast_get_null_value_row(fd, nulls, row);
for (col = 0; col < cols; col++) {
- if (nulls[col]) {
- ((FCELL *) bufer)[col] = fnullval;
+ if (Rast_is_f_null_value(&((FCELL *) bufer)[col])) {
n_nulls++;
else {
@@ -117,9 +111,8 @@
- if (nulls[col]) {
+ if (Rast_is_d_null_value(&((DCELL *) bufer)[col])) {
((DCELL *) bufer)[col] = dnullval;
n_nulls++;
@@ -145,9 +138,8 @@
- if (nulls[col]) {
+ if (Rast_is_c_null_value(&((CELL *) bufer)[col])) {
((CELL *) bufer)[col] = inullval;
n_nulls++;
@@ -206,6 +198,8 @@
ret = -1;
+ G_free(bufer);
return ret;
@@ -360,12 +354,8 @@
return -1;
- return -1;
+ /* the following routine must be kept identical to exact_checks */
int row, col;
@@ -385,9 +375,8 @@
- if (nulls[col]) {
if (n_nulls == 0) {
GDALSetRasterNoDataValue(hBand, nodataval);
@@ -415,9 +404,8 @@
- if (nulls[col]) {
if (n_nulls == 0) {
@@ -445,9 +433,8 @@
- if (nulls[col]) {
if (n_nulls == 0) {
@@ -466,6 +453,8 @@
+ G_free(bufer);
return ret;
