[GRASS-SVN] r46325 - grass/branches/develbranch_6/raster/r.out.gdal
Tue May 17 10:58:45 EDT 2011
Author: mmetz
Date: 2011-05-17 07:58:44 -0700 (Tue, 17 May 2011)
New Revision: 46325
   grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
do not use G_get_null_value_row()
Modified: grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
--- grass/branches/develbranch_6/raster/r.out.gdal/export_band.c	2011-05-17 14:58:26 UTC (rev 46324)
+++ grass/branches/develbranch_6/raster/r.out.gdal/export_band.c	2011-05-17 14:58:44 UTC (rev 46325)
@@ -67,12 +67,8 @@
 	G_warning(_("Unable to allocate buffer for reading raster map"));
 	return -1;
-    char *nulls = (char *)G_malloc(cols);
-    if (nulls == NULL) {
-	G_warning(_("Unable to allocate buffer for reading raster map"));
-	return -1;
+    /* the following routine must be kept identical to export_band */
     /* Copy data form GRASS raster to GDAL raster */
     int row, col;
@@ -97,9 +93,8 @@
 			  name, row);
 		return -1;
-	    G_get_null_value_row(fd, nulls, row);
 	    for (col = 0; col < cols; col++) {
-		if (nulls[col]) {
+		if (G_is_f_null_value(&(((FCELL *) bufer)[col]))) {
 		    ((FCELL *) bufer)[col] = fnullval;
 		    n_nulls++;
@@ -129,9 +124,8 @@
 			  name, row);
 		return -1;
-		if (nulls[col]) {
+		if (G_is_d_null_value(&(((DCELL *) bufer)[col]))) {
 		    ((DCELL *) bufer)[col] = dnullval;
 		    n_nulls++;
@@ -161,9 +155,8 @@
 			  name, row);
 		return -1;
-		if (nulls[col]) {
+		if (G_is_c_null_value(&(((CELL *) bufer)[col]))) {
 		    ((CELL *) bufer)[col] = inullval;
 		    n_nulls++;
@@ -222,6 +215,8 @@
 	ret = -1;
+    G_free(bufer);
     return ret;
@@ -380,12 +375,8 @@
 	return -1;
-	return -1;
     int row, col;
@@ -409,9 +400,8 @@
 			  name, row);
 		return -1;
-		if (nulls[col]) {
 		    if (n_nulls == 0) {
 			GDALSetRasterNoDataValue(hBand, nodataval);
@@ -443,9 +433,8 @@
 			  name, row);
 		return -1;
-		if (nulls[col]) {
 		    if (n_nulls == 0) {
@@ -477,9 +466,8 @@
 			  name, row);
 		return -1;
-		if (nulls[col]) {
 		    if (n_nulls == 0) {
@@ -498,6 +486,8 @@
+    G_free(bufer);
     return ret;
