[GRASS-SVN] r46378 - grass/branches/releasebranch_6_4/ps/ps.map
svn_grass at osgeo.org
Mon May 23 04:12:43 EDT 2011
Author: hamish
Date: 2011-05-23 01:12:43 -0700 (Mon, 23 May 2011)
New Revision: 46378
grass/branches/releasebranch_6_4/ps/ps.map/main.c
grass/branches/releasebranch_6_4/ps/ps.map/map_setup.c
don't require output file if the -b flag is used.
G_important_message() does not survive --quiet, so use fprintf(stderr,...) instead. (match parser.c)
Modified: grass/branches/releasebranch_6_4/ps/ps.map/main.c
--- grass/branches/releasebranch_6_4/ps/ps.map/main.c 2011-05-23 07:38:50 UTC (rev 46377)
+++ grass/branches/releasebranch_6_4/ps/ps.map/main.c 2011-05-23 08:12:43 UTC (rev 46378)
@@ -259,16 +259,20 @@
copies_set = 1;
- if (output_file->answer) {
- if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
- G_fatal_error("%s - %s: %s", G_program_name(),
- output_file->answer, strerror(errno));
+ if (!bflag->answer) {
+ if (output_file->answer) {
+ if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
+ G_fatal_error("%s - %s: %s", G_program_name(),
+ output_file->answer, strerror(errno));
+ else {
+ fprintf(stderr, _("ERROR: Required parameter <%s> not set:\n\t(%s)\n"),
+ output_file->key, output_file->description);
+ usage(1);
- else {
- G_important_message(_("\nERROR: Required parameter <%s> not set:\n (%s).\n"),
- output_file->key, output_file->description);
- usage(1);
+ else
+ PS.fp = NULL;
/* get current mapset */
@@ -730,7 +734,6 @@
PS.page_height - (PS.map_bot / 72.0), PS.map_right / 72.0,
PS.page_height - (PS.map_top / 72.0));
/* +/- 0.5 ? see ps.map.c brd.* */
- unlink(output_file->answer); /* fixme: don't open it in the first place */
exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_6_4/ps/ps.map/map_setup.c
--- grass/branches/releasebranch_6_4/ps/ps.map/map_setup.c 2011-05-23 07:38:50 UTC (rev 46377)
+++ grass/branches/releasebranch_6_4/ps/ps.map/map_setup.c 2011-05-23 08:12:43 UTC (rev 46378)
@@ -105,6 +105,11 @@
PS.map_bot, PS.map_left, PS.map_right);
+ /* no need to go on if we're just here for a look-see. (-b flag) */
+ if (!PS.fp)
+ return 0;
/* save original graphics state */
fprintf(PS.fp, "gsave ");
