[GRASS-SVN] r46379 - grass/trunk/scripts/r.mask
svn_grass at osgeo.org
Mon May 23 05:20:55 EDT 2011
Author: aghisla
Date: 2011-05-23 02:20:55 -0700 (Mon, 23 May 2011)
New Revision: 46379
grass/trunk/scripts/r.mask/r.mask.py
Check datatype of input map - translated from shell.
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py 2011-05-23 08:12:43 UTC (rev 46378)
+++ grass/trunk/scripts/r.mask/r.mask.py 2011-05-23 09:20:55 UTC (rev 46379)
@@ -68,6 +68,16 @@
if not grass.find_file(input)['file'] and not remove:
grass.fatal(_("<%s> does not exist.") % input)
+ if not 'MASKCATS' in grass.gisenv() and not remove:
+ ## beware: next check is made with != , not with 'is', otherwise:
+ #>>> grass.raster_info("basin_50K")['datatype'] is "CELL"
+ #False
+ # even if:
+ #>>> "CELL" is "CELL"
+ #True
+ if grass.raster_info(input)['datatype'] != "CELL":
+ grass.fatal(_("Raster map %s must be integer for maskcats parameter") % input)
mapset = grass.gisenv()['MAPSET']
exists = bool(grass.find_file('MASK', element = 'cell', mapset = mapset)['file'])
