[GRASS-SVN] r49172 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Thu Nov 10 10:40:24 EST 2011
Author: mmetz
Date: 2011-11-10 07:40:23 -0800 (Thu, 10 Nov 2011)
New Revision: 49172
grass/trunk/display/d.vect/attr.c
martinl: fix #1184
Modified: grass/trunk/display/d.vect/attr.c
--- grass/trunk/display/d.vect/attr.c 2011-11-10 15:26:24 UTC (rev 49171)
+++ grass/trunk/display/d.vect/attr.c 2011-11-10 15:40:23 UTC (rev 49172)
@@ -47,12 +47,10 @@
Vect_rewind(Map);
while (1) {
ltype = Vect_read_next_line(Map, Points, Cats);
- switch (ltype) {
- case -1:
+ if (ltype == -1)
G_fatal_error(_("Unable to read vector map"));
- case -2: /* EOF */
- return 0;
+ else if (ltype == -2) /* EOF */
+ break;
if (!(type & ltype) && !((type & GV_AREA) && (ltype & GV_CENTROID)))
continue; /* used for both lines and labels */
