[GRASS-SVN] r49173 - grass/branches/releasebranch_6_4/display/d.vect
Thu Nov 10 10:40:30 EST 2011
Author: martinl
Date: 2011-11-10 07:40:30 -0800 (Thu, 10 Nov 2011)
New Revision: 49173
   grass/branches/releasebranch_6_4/display/d.vect/attr.c
d.vect: attempt to fix #1184
	(merge r49171 from devbr6)
Modified: grass/branches/releasebranch_6_4/display/d.vect/attr.c
--- grass/branches/releasebranch_6_4/display/d.vect/attr.c	2011-11-10 15:40:23 UTC (rev 49172)
+++ grass/branches/releasebranch_6_4/display/d.vect/attr.c	2011-11-10 15:40:30 UTC (rev 49173)
@@ -49,13 +49,11 @@
     Vect_rewind(Map);
     while (1) {
 	ltype = Vect_read_next_line(Map, Points, Cats);
-	switch (ltype) {
-	case -1:
+	if (ltype == -1)
 	    G_fatal_error(_("Can't read vector map"));
-	case -2:		/* EOF */
-	    return 0;
+	else if (ltype == -2)
+	    break;
 	if (!(type & ltype))
 	    continue;		/* used for both lines and labels */
