[GRASS-SVN] r49215 - grass/trunk/lib/gis
Mon Nov 14 02:55:10 EST 2011
Author: martinl
Date: 2011-11-13 23:55:10 -0800 (Sun, 13 Nov 2011)
New Revision: 49215
   grass/trunk/lib/gis/parser_standard_options.c
gislib: introduce G_define_standard_flag()
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c	2011-11-14 07:53:31 UTC (rev 49214)
+++ grass/trunk/lib/gis/parser_standard_options.c	2011-11-14 07:55:10 UTC (rev 49215)
@@ -21,10 +21,10 @@
   \brief Create standardised Option structure.
-  This function will create a standardised Option structure defined
-  by parameter opt. A list of valid parameters can be found in gis.h.
-  It allocates memory for the Option structure and returns a pointer
-  to this memory.
+  This function will create a standardised Option structure defined by
+  parameter <i>opt</i>. A list of valid parameters bellow. It
+  allocates memory for the Option structure and returns a pointer to
+  this memory.
   If an invalid parameter was specified a empty Option structure will
   be returned (not NULL).
@@ -584,3 +584,36 @@
     return Opt;
+  \brief Create standardised Flag structure.
+  This function will create a standardised Flag structure defined by
+  parameter <i>flag</i>. A list of valid parameters bellow. It
+  allocates memory for the Flag structure and returns a pointer to
+  this memory.
+  If an invalid parameter was specified a empty Flag structure will be
+  returned (not NULL).
+  - G_FLG_DB_TABLE
+  \param flag type of Flag struct to create
+  \return pointer to an Flag struct
+struct Flag *G_define_standard_flag(int flag)
+    struct Flag *Flg;
+    Flg = G_define_flag();
+    switch (flag) {
+    case G_FLG_DB_TABLE:
+	Flg->key = 't';
+	Flg->description = _("Do not create attribute table");
+	break;
+    return Flg;
