[GRASS-SVN] r49216 - grass/trunk
svn_grass at osgeo.org
Mon Nov 14 02:55:45 EST 2011
Author: martinl
Date: 2011-11-13 23:55:45 -0800 (Sun, 13 Nov 2011)
New Revision: 49216
grass/trunk/grasslib.dox
doxygen: minor clean up of main page
Modified: grass/trunk/grasslib.dox
--- grass/trunk/grasslib.dox 2011-11-14 07:55:10 UTC (rev 49215)
+++ grass/trunk/grasslib.dox 2011-11-14 07:55:45 UTC (rev 49216)
@@ -1,31 +1,32 @@
/*! \mainpage GRASS 7 Programmer's Manual
<!-- * doxygenized from "GRASS 5 Programmer's Manual"
by M. Neteler 2/2004
- * updated 8/2005, 2006, 2007, 2008, 2010
+ * updated 8/2005, 2006-2008, 2010-2011
-<a href="http://grass.osgeo.org">GRASS GIS</a> (<b>Geographic
-Resources Analysis Support System</b>) is an open source, Free
-Software <em>Geographical Information System</em> (GIS) with raster,
+<a href="http://grass.osgeo.org">GRASS GIS</a> (<i>Geographic
+Resources Analysis Support System</i>) is an open source, free
+software <em>Geographical Information System</em> (GIS) with raster,
topological %vector, image processing, and graphics production
functionality that operates on various platforms through a graphical
user interface (GUI) or command line interface (CLI). It is released
-under GNU General Public License (GPL).
+under <a href="http://www.fsf.org/copyleft/gpl.html">GNU General
+Public License</a> (GPL).
This manual introduces the reader to the <i>Geographic Resources
Analysis Support System</i> from the programming perspective. Design
theory, system support libraries, system maintenance, and system
-enhancement are all presented. Standard GRASS 4.x conventions are
-still used in much of the code. This work is part of ongoing research
+enhancement are all presented. This work is part of ongoing research
being performed by the <a
href="http://grass.osgeo.org/community/team.php">GRASS Development
Team</a>, an international team of programmers, GRASS module authors
are cited within their module's source code and the contributed manual
pages.
-© 2000-2011 GRASS Development Team
+© 2000-2011 by the GRASS Development Team
-Published under <a href="http://www.fsf.org/copyleft/fdl.html">GNU Free Documentation License</a> (GFDL)
+Published under <a href="http://www.fsf.org/copyleft/fdl.html">GNU
+Free Documentation License</a> (GFDL).
This manual comes with ABSOLUTELY NO WARRANTY. The development of
@@ -33,8 +34,9 @@
href="http://www.osgeo.org">Open Source Geospatial Foundation</a>, who
provides the GRASS main infrastructure.
-Main web site: <a href="http://grass.osgeo.org">http://grass.osgeo.org</a>
+Main web site: <a
+href="http://grass.osgeo.org">http://grass.osgeo.org</a>
<b>Table of contents</b>
- \subpage libsOverview
@@ -49,23 +51,24 @@
- \subpage Multiple_Architecture_Conventions
- \subpage vectmodules
- \subpage vectmodules_oper
-<i>Missing entries below are either not yet uploaded to SVN (need to
-be migrated from GRASS 5 Programmer's manual) or are simply
+<i>Note: Missing entries below are either not yet uploaded to SVN
+(need to be migrated from GRASS 5 Programmer's manual) or are simply
undocumented.</i>
+<i>Note: PLEASE UPDATE FOR GRASS 7</i>
<!-- original:
http://trac.osgeo.org/grass/browser/grass-web/trunk/images/grass7_arch.odp
\image html "grass7_arch.png" "GRASS 7 Architecture"
-<b>PLEASE UPDATE FOR GRASS 7</b>
\section libsOverview Libraries
\section corelibs Core libraries
-(the name refers to the directory name in lib/ in the source code)
+(the name refers to the directory name in <tt>lib/</tt> in the source code)
- gis: \ref gislib
- raster: \ref rasterlib
@@ -73,7 +76,7 @@
\section libs Further libraries
\subsection displaylibs Display Libraries and Drivers
@@ -151,26 +154,27 @@
A GRASS <b>raster map</b> consists of several files in several subdirectories in a mapset,
organized as follows:
- - <b>cellhd/</b>:
- map header including projection code, coordinates representing
+<dl>
+ <dt><b>cellhd/</b></dt>
+ <dd>map header including projection code, coordinates representing
the spatial extent of the raster map, number of rows and columns, resolution,
- and information about map compression;</li>
- - <b>cell/, fcell/ or grid3/</b>:
- generic matrix of values in a compressed, portable
- format which depends on the raster data type (integer, floating %point or 3D grid);</li>
- - <b>hist/</b>:
- history file which contains metadata such as the data source,
+ and information about map compression;</dd>
+ <dt><b>cell/, fcell/ or grid3/</b></dt>
+ <dd>generic matrix of values in a compressed, portable
+ format which depends on the raster data type (integer, floating %point or 3D grid);</dd>
+ <dt><b>hist/</b></dt>
+ <dd>history file which contains metadata such as the data source,
the command that was used to generate the raster map, or
- other information provided by the user;</li>
- - <b>cats/</b>:
- optional category file which contains text or numeric labels assigned
- to the raster map categories;</li>
- - <b>colr/</b>:
- optional color table;</li>
- - <b>cell_misc/</b>:
- optional timestamp, range of values, quantization rules (for floating %point maps)
- and null (no-data) files; </li>
+ other information provided by the user;</dd>
+ <dt><b>cats/</b></dt>
+ <dd>optional category file which contains text or numeric labels assigned
+ to the raster map categories;</dd>
+ <dt><b>colr/</b></dt>
+ <dd>optional color table;</dd>
+ <dt><b>cell_misc/</b></dt>
+ <dd>optional timestamp, range of values, quantization rules (for floating %point maps)
+ and null (no-data) files;</dd>
+</dl>
A GRASS <b>%vector maps</b> are stored in several separate files in a
single directory (see \ref vectorlib). While the
@@ -178,19 +182,27 @@
external DBMS (PostgreSQL, MySQL, ODBC), the geometric data are saved
as follows:
- - <b>head</b>: %vector map ASCII header with information about the map creation
- (date and name), its scale and threshold;</li>
- - <b>coor</b>: binary geometry file which includes the coordinates of graphic
- elements (primitives) that define the %vector feature;</li>
- - <b>topo</b>: binary topology file describes the spatial relationships between the
- map's graphic elements;</li>
- - <b>hist</b>: history ASCII file with complete commands that were used to
+<dl>
+ <dt><b>head</b></dt>
+ <dd>%vector map ASCII header with information about the map creation
+ (date and name), its scale and threshold;</dd>
+ <dt><b>coor</b></dt>
+ <dd>binary geometry file which includes the coordinates of graphic
+ elements (primitives) that define the %vector feature;</dd>
+ <dt><b>topo</b></dt>
+ <dd>binary topology file describes the spatial relationships between the
+ map's graphic elements;</dd>
+ <dt><b>hist</b></dt>
+ <dd>history ASCII file with complete commands that were used to
create the %vector map, as well as the name and date/time of the map
- creation;</li>
- - <b>cidx</b>: binary category index file which is used to %link the %vector
- object IDs to the attribute table rows;</li>
- - <b>dbln</b>: ASCII file which contains definition(s) of %link to attribute
- storage in database (DBMS).</li>
+ creation;</dd>
+ <dt><b>cidx</b></dt>
+ <dd>binary category index file which is used to %link the %vector
+ object IDs to the attribute table rows;</dd>
+ <dt><b>dbln</b></dt>
+ <dd>ASCII file which contains definition(s) of %link to attribute
+ storage in database (DBMS).</dd>
+</dl>
<!-- original:
http://trac.osgeo.org/grass/browser/grass-web/trunk/images/loc_struct.odg
