[GRASS-SVN] r48713 - grass/trunk/gui/wxpython/gui_modules
svn_grass at osgeo.org
Mon Oct 10 16:31:56 EDT 2011
Author: annakrat
Date: 2011-10-10 13:31:55 -0700 (Mon, 10 Oct 2011)
New Revision: 48713
grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py
grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
wxGUI: georectifier partially rewritten (base class is MapFrameBase), co-author Vaclav Petras
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmanager.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmanager.py 2011-10-10 20:05:34 UTC (rev 48712)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmanager.py 2011-10-10 20:31:55 UTC (rev 48713)
@@ -721,14 +721,14 @@
else:
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
-class GCP(MapFrame, wx.Frame, ColumnSorterMixin):
+class GCP(MapFrame, ColumnSorterMixin):
Manages ground control points for georectifying. Calculates RMS statics.
Calls i.rectify or v.transform to georectify map.
def __init__(self, parent, grwiz = None, id = wx.ID_ANY,
title = _("Manage Ground Control Points"),
- size = (700, 300), toolbars=["gcpdisp"], Map=None, lmgr=None):
+ size = (700, 300), toolbars = ["gcpdisp"], Map = None, lmgr = None):
self.grwiz = grwiz # GR Wizard
@@ -738,8 +738,8 @@
self.show_target = True
#wx.Frame.__init__(self, parent, id, title, size = size, name = "GCPFrame")
- MapFrame.__init__(self, parent, id, title, size = size,
- Map=Map, toolbars=["gcpdisp"], lmgr=lmgr, name='GCPMapWindow')
+ MapFrame.__init__(self, parent = parent, title = title, size = size,
+ Map = Map, toolbars = toolbars, lmgr = lmgr, name = 'GCPMapWindow')
# init variables
@@ -890,11 +890,20 @@
# Used by the ColumnSorterMixin, see wx/lib/mixins/listctrl.py
def GetListCtrl(self):
return self.list
+ def GetMapCoordList(self):
+ return self.mapcoordlist
def GetSortImages(self):
return (self.sm_dn, self.sm_up)
+ def GetFwdError(self):
+ return self.fwd_rmserror
+ def GetBkwError(self):
+ return self.bkw_rmserror
def InitMapDisplay(self):
self.list.LoadData()
@@ -938,7 +947,7 @@
0.0, # forward error
0.0 ] ) # backward error
- if self.statusbarWin['toggle'].GetSelection() == 7: # go to
+ if self.statusbarManager.GetMode() == 8: # go to
self.StatusbarUpdate()
def DeleteGCP(self, event):
@@ -979,11 +988,10 @@
self.UpdateColours()
if self.list.selectedkey > 0:
- self.statusbarWin['goto'].SetValue(self.list.selectedkey)
- #self.statusbarWin['goto'].SetValue(0)
+ self.statusbarManager.SetProperty('gotoGCP', self.list.selectedkey)
def ClearGCP(self, event):
Modified: grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2011-10-10 20:05:34 UTC (rev 48712)
+++ grass/trunk/gui/wxpython/gui_modules/gcpmapdisp.py 2011-10-10 20:31:55 UTC (rev 48713)
@@ -53,6 +53,8 @@
import globalvar
import utils
import gdialogs
+import mapdisp_statusbar as sb
+from mapdisp import MapFrameBase
from grass.script import core as grass
from debug import Debug
from icon import Icons
@@ -63,14 +65,13 @@
# for standalone app
cmdfilename = None
-class MapFrame(wx.Frame):
+class MapFrame(MapFrameBase):
"""!Main frame for map display window. Drawing takes place in
child double buffered drawing window.
- def __init__(self, parent=None, id=wx.ID_ANY, title=_("GRASS GIS Manage Ground Control Points"),
- style=wx.DEFAULT_FRAME_STYLE, toolbars=["gcpdisp"],
- tree=None, notebook=None, lmgr=None, page=None,
- Map=None, auimgr=None, **kwargs):
+ def __init__(self, parent=None, title=_("GRASS GIS Manage Ground Control Points"),
+ toolbars=["gcpdisp"], tree=None, notebook=None, lmgr=None,
+ page=None, Map=None, auimgr=None, name = 'GCPMapWindow', **kwargs):
"""!Main map display window with toolbars, statusbar and
DrawWindow
@@ -83,42 +84,12 @@
@param auimgs AUI manager
@param kwargs wx.Frame attribures
- self._layerManager = lmgr # Layer Manager object
- self.Map = Map # instance of render.Map
- self.tree = tree # Layer Manager layer tree object
- self.page = page # Notebook page holding the layer tree
- self.layerbook = notebook # Layer Manager layer tree notebook
- self.parent = parent
- if 'name' not in kwargs:
- kwargs['name'] = 'GCPMapWindow'
- wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
+ MapFrameBase.__init__(self, parent = parent, title = title, toolbars = toolbars,
+ tree = tree, notebook = notebook, lmgr = lmgr, page = page,
+ Map = Map, auimgr = auimgr, name = name, **kwargs)
- # available cursors
- self.cursors = {
- # default: cross
- # "default" : wx.StockCursor(wx.CURSOR_DEFAULT),
- "default" : wx.StockCursor(wx.CURSOR_ARROW),
- "cross" : wx.StockCursor(wx.CURSOR_CROSS),
- "hand" : wx.StockCursor(wx.CURSOR_HAND),
- "pencil" : wx.StockCursor(wx.CURSOR_PENCIL),
- "sizenwse": wx.StockCursor(wx.CURSOR_SIZENWSE)
- # set the size & system icon
- self.SetClientSize(self.GetSize())
- self.iconsize = (16, 16)
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
- # Fancy gui
- self._mgr = wx.aui.AuiManager(self)
# Add toolbars
self.toolbars = { 'map' : None,
@@ -133,6 +104,7 @@
self.activemap = self.toolbars['gcpdisp'].togglemap
self.activemap.SetSelection(0)
self.SrcMap = self.grwiz.SrcMap # instance of render.Map
self.TgtMap = self.grwiz.TgtMap # instance of render.Map
self._mgr.SetDockSizeConstraint(0.5, 0.5)
@@ -140,103 +112,33 @@
# Add statusbar
- self.statusbar = self.CreateStatusBar(number=4, style=0)
- self.statusbar.SetStatusWidths([-5, -2, -1, -1])
- self.statusbarWin = dict()
- self.statusbarWin['toggle'] = wx.Choice(self.statusbar, wx.ID_ANY,
- choices = [_("Coordinates"),
- _("Extent"),
- _("Comp. region"),
- _("Show comp. extent"),
- _("Display mode"),
- _("Display geometry"),
- _("Map scale"),
- _("Go to GCP No."),
- _("RMS error")])
- # set StatusBar to Go to GCP No.
- self.statusbarWin['toggle'].SetSelection(7)
- self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
- # auto-rendering checkbox
- self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Render"))
- self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
- self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
- key='autoRendering',
- subkey='enabled'))
- self.statusbarWin['render'].SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
- # show region
- self.statusbarWin['region'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Show computational extent"))
- self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.statusbarWin['region'])
- self.statusbarWin['region'].SetValue(False)
- self.statusbarWin['region'].Hide()
- self.statusbarWin['region'].SetToolTip(wx.ToolTip (_("Show/hide computational "
- "region extent (set with g.region). "
- "Display region drawn as a blue box inside the "
- "computational region, "
- "computational region inside a display region "
- "as a red box).")))
- # set resolution
- self.statusbarWin['resolution'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Constrain display resolution to computational settings"))
- self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.statusbarWin['resolution'])
- self.statusbarWin['resolution'].SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
- self.statusbarWin['resolution'].Hide()
- self.statusbarWin['resolution'].SetToolTip(wx.ToolTip (_("Constrain display resolution "
- "to computational region settings. "
- "Default value for new map displays can "
- "be set up in 'User GUI settings' dialog.")))
- # map scale
- self.statusbarWin['mapscale'] = wx.ComboBox(parent = self.statusbar, id = wx.ID_ANY,
- style = wx.TE_PROCESS_ENTER,
- size=(150, -1))
- self.statusbarWin['mapscale'].SetItems(['1:1000',
- '1:5000',
- '1:10000',
- '1:25000',
- '1:50000',
- '1:100000',
- '1:1000000'])
- self.statusbarWin['mapscale'].Hide()
- self.statusbarWin['mapscale'].SetToolTip(wx.ToolTip (_("As everyone's monitors and resolutions "
- "are set differently these values are not "
- "true map scales, but should get you into "
- "the right neighborhood.")))
- self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.statusbarWin['mapscale'])
- self.statusbar.Bind(wx.EVT_COMBOBOX, self.OnChangeMapScale, self.statusbarWin['mapscale'])
- # go to
- self.statusbarWin['goto'] = wx.SpinCtrl(parent=self.statusbar, id=wx.ID_ANY,
- min=0)
- self.statusbar.Bind(wx.EVT_SPINCTRL, self.OnGoTo, self.statusbarWin['goto'])
- self.statusbarWin['goto'].Hide()
- self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
- # projection, unused but BufferedWindow checks for it
- self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
- label=_("Use defined projection"))
- self.statusbarWin['projection'].SetValue(False)
- size = self.statusbarWin['projection'].GetSize()
- self.statusbarWin['projection'].SetMinSize((size[0] + 150, size[1]))
- self.statusbarWin['projection'].SetToolTip(wx.ToolTip (_("Reproject coordinates displayed "
- "in the statusbar. Projection can be "
- "defined in GUI preferences dialog "
- "(tab 'Display')")))
- self.statusbarWin['projection'].Hide()
- # mask
- self.statusbarWin['mask'] = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
- label = '')
- self.statusbarWin['mask'].SetForegroundColour(wx.Colour(255, 0, 0))
+ # items for choice
+ self.statusbarItems = [sb.SbCoordinates,
+ sb.SbRegionExtent,
+ sb.SbCompRegionExtent,
+ sb.SbShowRegion,
+ sb.SbResolution,
+ sb.SbDisplayGeometry,
+ sb.SbMapScale,
+ sb.SbProjection,
+ sb.SbGoToGCP,
+ sb.SbRMSError]
- # on-render gauge
- self.statusbarWin['progress'] = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
- range=0, style=wx.GA_HORIZONTAL)
- self.statusbarWin['progress'].Hide()
+ # create statusbar and its manager
+ statusbar = self.CreateStatusBar(number = 4, style = 0)
+ statusbar.SetStatusWidths([-5, -2, -1, -1])
+ self.statusbarManager = sb.SbManager(mapframe = self, statusbar = statusbar)
- self.StatusbarReposition() # reposition statusbar
+ # fill statusbar manager
+ self.statusbarManager.AddStatusbarItemsByClass(self.statusbarItems, mapframe = self, statusbar = statusbar)
+ self.statusbarManager.AddStatusbarItem(sb.SbMask(self, statusbar = statusbar, position = 2))
+ self.statusbarManager.AddStatusbarItem(sb.SbRender(self, statusbar = statusbar, position = 3))
+ self.statusbarManager.SetMode(8) # goto GCP
+ self.statusbarManager.Update()
# Init map display (buffered DC & set default cursor)
@@ -402,7 +304,7 @@
Update progress bar info
- self.statusbarWin['progress'].SetValue(event.value)
+ self.GetProgressBar().SetValue(event.value)
event.Skip()
@@ -581,309 +483,7 @@
else:
self.Map.alignRegion = False
# event.Skip()
- def OnToggleRender(self, event):
- Enable/disable auto-rendering
- if self.statusbarWin['render'].GetValue():
- self.OnRender(None)
- def OnToggleShowRegion(self, event):
- Show/Hide extent in map canvas
- if self.statusbarWin['region'].GetValue():
- # show extent
- self.MapWindow.regionCoords = []
- else:
- del self.MapWindow.regionCoords
- # redraw map if auto-rendering is enabled
- def OnToggleResolution(self, event):
- Use resolution of computation region settings
- for redering image instead of display resolution
- def OnToggleStatus(self, event):
- Toggle status text
- self.StatusbarUpdate()
- def OnChangeMapScale(self, event):
- Map scale changed by user
- scale = event.GetString()
- try:
- if scale[:2] != '1:':
- raise ValueError
- value = int(scale[2:])
- except ValueError:
- self.statusbarWin['mapscale'].SetValue('1:%ld' % int(self.mapScaleValue))
- return
- dEW = value * (self.Map.region['cols'] / self.ppm[0])
- dNS = value * (self.Map.region['rows'] / self.ppm[1])
- self.Map.region['n'] = self.Map.region['center_northing'] + dNS / 2.
- self.Map.region['s'] = self.Map.region['center_northing'] - dNS / 2.
- self.Map.region['w'] = self.Map.region['center_easting'] - dEW / 2.
- self.Map.region['e'] = self.Map.region['center_easting'] + dEW / 2.
- # add to zoom history
- self.MapWindow.ZoomHistory(self.Map.region['n'], self.Map.region['s'],
- self.Map.region['e'], self.Map.region['w'])
- # redraw a map
- self.MapWindow.UpdateMap()
- self.statusbarWin['mapscale'].SetFocus()
- def OnGoTo(self, event):
- Go to position
- #GCPNo = int(event.GetString())
- GCPNo = self.statusbarWin['goto'].GetValue()
- if GCPNo < 0 or GCPNo > len(self.mapcoordlist):
- wx.MessageBox(parent=self,
- message="%s 1 - %s." % (_("Valid Range:"),
- len(self.mapcoordlist)),
- caption=_("Invalid GCP Number"), style=wx.OK | wx.ICON_ERROR | wx.CENTRE)
- return
- if GCPNo == 0:
- return
- self.list.selectedkey = GCPNo
- self.list.selected = self.list.FindItemData(-1, GCPNo)
- self.list.render = False
- self.list.SetItemState(self.list.selected,
- wx.LIST_STATE_SELECTED,
- wx.LIST_STATE_SELECTED)
- self.list.render = True
- # Source MapWindow:
- begin = (self.mapcoordlist[GCPNo][1], self.mapcoordlist[GCPNo][2])
- begin = self.SrcMapWindow.Cell2Pixel(begin)
- end = begin
- self.SrcMapWindow.Zoom(begin, end, 0)
- # redraw map
- self.SrcMapWindow.UpdateMap()
- if self.show_target:
- # Target MapWindow:
- begin = (self.mapcoordlist[GCPNo][3], self.mapcoordlist[GCPNo][4])
- begin = self.TgtMapWindow.Cell2Pixel(begin)
- end = begin
- self.TgtMapWindow.Zoom(begin, end, 0)
- # redraw map
- self.TgtMapWindow.UpdateMap()
- self.statusbarWin['goto'].SetFocus()
- def StatusbarUpdate(self):
- """!Update statusbar content"""
- self.mapScaleValue = self.ppm = None
- if self.statusbarWin['toggle'].GetSelection() == 0: # Coordinates
- self.statusbar.SetStatusText("", 0)
- # enable long help
- self.StatusbarEnableLongHelp()
- elif self.statusbarWin['toggle'].GetSelection() in (1, 2): # Extent
- sel = self.statusbarWin['toggle'].GetSelection()
- if sel == 1:
- region = self.Map.region
- else:
- region = self.Map.GetRegion() # computation region
- precision = int(UserSettings.Get(group = 'projection', key = 'format',
- subkey = 'precision'))
- format = UserSettings.Get(group = 'projection', key = 'format',
- subkey = 'll')
- if self.Map.projinfo['proj'] == 'll' and format == 'DMS':
- w, s = utils.Deg2DMS(region["w"], region["s"],
- string = False, precision = precision)
- e, n = utils.Deg2DMS(region["e"], region["n"],
- if sel == 1:
- self.statusbar.SetStatusText("%s - %s, %s - %s" %
- (w, e, s, n), 0)
- else:
- ewres, nsres = utils.Deg2DMS(region['ewres'], region['nsres'],
- self.statusbar.SetStatusText("%s - %s, %s - %s (%s, %s)" %
- (w, e, s, n, ewres, nsres), 0)
- else:
- w, s = region["w"], region["s"]
- e, n = region["e"], region["n"]
- if sel == 1:
- self.statusbar.SetStatusText("%.*f - %.*f, %.*f - %.*f" %
- (precision, w, precision, e,
- precision, s, precision, n), 0)
- else:
- ewres, nsres = region['ewres'], region['nsres']
- self.statusbar.SetStatusText("%.*f - %.*f, %.*f - %.*f (%.*f, %.*f)" %
- precision, s, precision, n,
- precision, ewres, precision, nsres), 0)
- elif self.statusbarWin['toggle'].GetSelection() == 3: # Show comp. extent
- self.statusbarWin['region'].Show()
- # disable long help
- self.StatusbarEnableLongHelp(False)
- elif self.statusbarWin['toggle'].GetSelection() == 4: # Display mode
- self.statusbarWin['resolution'].Show()
- elif self.statusbarWin['toggle'].GetSelection() == 5: # Display geometry
- self.statusbar.SetStatusText("rows=%d; cols=%d; nsres=%.2f; ewres=%.2f" %
- (self.Map.region["rows"], self.Map.region["cols"],
- self.Map.region["nsres"], self.Map.region["ewres"]), 0)
- elif self.statusbarWin['toggle'].GetSelection() == 6: # Map scale
- # TODO: need to be fixed...
- ### screen X region problem
- ### user should specify ppm
- dc = wx.ScreenDC()
- dpSizePx = wx.DisplaySize() # display size in pixels
- dpSizeMM = wx.DisplaySizeMM() # display size in mm (system)
- dpSizeIn = (dpSizeMM[0] / 25.4, dpSizeMM[1] / 25.4) # inches
- sysPpi = dc.GetPPI()
- comPpi = (dpSizePx[0] / dpSizeIn[0],
- dpSizePx[1] / dpSizeIn[1])
- ppi = comPpi # pixel per inch
- self.ppm = ((ppi[0] / 2.54) * 100, # pixel per meter
- (ppi[1] / 2.54) * 100)
- Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): size: px=%d,%d mm=%f,%f "
- "in=%f,%f ppi: sys=%d,%d com=%d,%d; ppm=%f,%f" % \
- (dpSizePx[0], dpSizePx[1], dpSizeMM[0], dpSizeMM[1],
- dpSizeIn[0], dpSizeIn[1],
- sysPpi[0], sysPpi[1], comPpi[0], comPpi[1],
- self.ppm[0], self.ppm[1]))
- heightCm = region['rows'] / self.ppm[1] * 100
- widthCm = region['cols'] / self.ppm[0] * 100
- Debug.msg(4, "MapFrame.StatusbarUpdate(mapscale): width_cm=%f, height_cm=%f" %
- (widthCm, heightCm))
- xscale = (region['e'] - region['w']) / (region['cols'] / self.ppm[0])
- yscale = (region['n'] - region['s']) / (region['rows'] / self.ppm[1])
- scale = (xscale + yscale) / 2.
- Debug.msg(3, "MapFrame.StatusbarUpdate(mapscale): xscale=%f, yscale=%f -> scale=%f" % \
- (xscale, yscale, scale))
- self.statusbar.SetStatusText("")
- try:
- self.statusbarWin['mapscale'].SetValue("1:%ld" % (scale + 0.5))
- except TypeError:
- pass
- self.mapScaleValue = scale
- self.statusbarWin['mapscale'].Show()
- elif self.statusbarWin['toggle'].GetSelection() == 7: # go to
- max = self.list.GetItemCount()
- if max < 1:
- max = 1
- self.statusbarWin['goto'].SetRange(0, max)
- self.statusbarWin['goto'].Show()
- elif self.statusbarWin['toggle'].GetSelection() == 8: # RMS error
- self.statusbar.SetStatusText(_("Forward: %(forw)s, Backward: %(back)s") %
- { 'forw' : self.fwd_rmserror,
- 'back' : self.bkw_rmserror })
- # self.StatusbarEnableLongHelp(False)
- else:
- self.statusbar.SetStatusText("", 1)
- def StatusbarEnableLongHelp(self, enable=True):
- """!Enable/disable toolbars long help"""
- for toolbar in self.toolbars.itervalues():
- if toolbar:
- toolbar.EnableLongHelp(enable)
- def StatusbarReposition(self):
- """!Reposition checkbox in statusbar"""
- # reposition checkbox
- widgets = [(0, self.statusbarWin['region']),
- (0, self.statusbarWin['resolution']),
- (0, self.statusbarWin['mapscale']),
- (0, self.statusbarWin['progress']),
- (0, self.statusbarWin['goto']),
- (1, self.statusbarWin['toggle']),
- (2, self.statusbarWin['mask']),
- (3, self.statusbarWin['render'])]
- for idx, win in widgets:
- rect = self.statusbar.GetFieldRect(idx)
- wWin, hWin = win.GetBestSize()
- if idx == 0: # show region / mapscale / process bar
- # -> size
- if win == self.statusbarWin['progress']:
- wWin = rect.width - 6
- # -> position
- # if win == self.statusbarWin['region']:
- # x, y = rect.x + rect.width - wWin, rect.y - 1
- # align left
- # else:
- x, y = rect.x + 3, rect.y - 1
- w, h = wWin, rect.height + 2
- else: # choice || auto-rendering
- x, y = rect.x, rect.y - 1
- w, h = rect.width, rect.height + 2
- if idx == 1: # choice
- h = hWin
- elif idx == 2: # mask
- x += 5
- y += 4
- elif idx == 3: # render
- x += 5
- win.SetPosition((x, y))
- win.SetSize((w, h))
def SaveToFile(self, event):
"""!Save map to image
@@ -950,16 +550,8 @@
# will be called before PopupMenu returns.
self.PopupMenu(printmenu)
printmenu.Destroy()
- def GetRender(self):
- """!Returns current instance of render.Map()
- return self.Map
- def GetWindow(self):
- """!Get map window"""
- return self.MapWindow
def FormatDist(self, dist):
"""!Format length numbers and units in a nice way,
as a function of length. From code by Hamish Bowman
@@ -1079,16 +671,6 @@
self.PopupMenu(zoommenu)
zoommenu.Destroy()
- def SetProperties(self, render=False, mode=0, showCompExtent=False,
- constrainRes=False, projection=False):
- """!Set properies of map display window"""
- self.statusbarWin['render'].SetValue(render)
- self.statusbarWin['toggle'].SetSelection(mode)
- self.statusbarWin['region'].SetValue(showCompExtent)
- self.statusbarWin['resolution'].SetValue(constrainRes)
- if showCompExtent:
def IsStandalone(self):
"""!Check if Map display is standalone"""
@@ -1105,4 +687,13 @@
return self._layerManager
+ def GetSrcWindow(self):
+ return self.SrcMapWindow
+ def GetTgtWindow(self):
+ return self.TgtMapWindow
+ def GetShowTarget(self):
+ return self.show_target
# end of class MapFrame
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-10 20:05:34 UTC (rev 48712)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py 2011-10-10 20:31:55 UTC (rev 48713)
@@ -129,11 +129,7 @@
# Fancy gui
- def IsAutoRendered(self):
- """!Checks if auto-rendering is enabled"""
- return True
def SetProperty(self, name, value):
"""!Sets property"""
self.statusbarManager.SetProperty(name, value)
@@ -223,7 +219,54 @@
return scale
+ def GetProgressBar(self):
+ """!Returns progress bar
+ Progress bar can be used by other classes.
+ return self.statusbarManager.GetProgressBar()
+ def GetRender(self):
+ """!Returns current instance of render.Map()
+ @todo make this method obsolate (name GetMap is better)
+ return self.Map
+ def GetMap(self):
+ """!Returns current Map instance
+ return self.Map
+ def GetWindow(self):
+ """!Get map window"""
+ return self.MapWindow
+ def StatusbarUpdate(self):
+ """!Update statusbar content"""
+ def IsAutoRendered(self):
+ """!Check if auto-rendering is enabled"""
+ return self.GetProperty('render')
+ def CoordinatesChanged(self):
+ """!Shows current coordinates on statusbar.
+ Used in BufferedWindow to report change of map coordinates (under mouse cursor).
+ self.statusbarManager.ShowItem('coordinates')
+ def StatusbarReposition(self):
+ """!Reposition items in statusbar"""
+ self.statusbarManager.Reposition()
+ def StatusbarEnableLongHelp(self, enable = True):
+ """!Enable/disable toolbars long help"""
+ for toolbar in self.toolbars.itervalues():
+ if toolbar:
+ toolbar.EnableLongHelp(enable)
@@ -581,7 +624,6 @@
self.toolbars['map'].combo.SetValue(_("2D view"))
self.toolbars['map'].Enable2D(True)
- self.statusbarWin['toggle'].Enable(True)
self._mgr.Update()
@@ -778,33 +820,8 @@
self.Map.alignRegion = True
else:
- # event.Skip()
- """!Check if auto-rendering is enabled"""
- return self.GetProperty('render')
- def CoordinatesChanged(self):
- """!Shows current coordinates on statusbar.
+ # event.Skip()
- Used in BufferedWindow to report change of map coordinates (under mouse cursor).
- self.statusbarManager.ShowItem('coordinates')
- self.statusbarManager.Update()
- def StatusbarEnableLongHelp(self, enable = True):
- if toolbar:
- """!Reposition items in statusbar"""
- self.statusbarManager.Reposition()
@@ -898,29 +915,7 @@
pgnum = self.layerbook.GetPageIndex(self.page)
if pgnum > -1:
self.layerbook.DeletePage(pgnum)
- @todo make this method obsolate (name GetMap is better)
- return self.Map
- def GetMap(self):
- """!Returns current Map instance
- return self.Map
- def GetProgressBar(self):
- """!Returns progress bar
- Progress bar can be used by other classes.
- return self.statusbarManager.GetProgressBar()
def QueryMap(self, x, y):
"""!Query raster or vector map layers by r/v.what
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py 2011-10-10 20:05:34 UTC (rev 48712)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_statusbar.py 2011-10-10 20:31:55 UTC (rev 48713)
@@ -58,6 +58,9 @@
and call Update method to show particular widgets.
User settings (group = 'display', key = 'statusbarMode', subkey = 'selection')
are taken into account.
+ @todo generalize access to UserSettings (specify group, etc.)
+ @todo add GetMode method using name instead of index
def __init__(self, mapframe, statusbar):
"""!Connects manager to statusbar
@@ -69,7 +72,7 @@
self.choice = wx.Choice(self.statusbar, wx.ID_ANY)
- self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus)
+ self.choice.Bind(wx.EVT_CHOICE, self.OnToggleStatus)
self.statusbarItems = dict()
@@ -550,7 +553,7 @@
self.widget.Hide()
- self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo)
+ self.widget.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo)
def ReprojectENToMap(self, e, n, useDefinedProjection):
"""!Reproject east, north from user defined projection
@@ -958,3 +961,97 @@
"""!Sets progress range."""
self.widget.SetRange(range)
+class SbGoToGCP(SbItem):
+ """!SpinCtrl to select GCP to focus on
+ Requires MapFrame.GetSrcWindow, MapFrame.GetTgtWindow, MapFrame.GetListCtrl,
+ MapFrame.GetMapCoordList.
+ def __init__(self, mapframe, statusbar, position = 0):
+ SbItem.__init__(self, mapframe, statusbar, position)
+ self.name = 'gotoGCP'
+ self.label = _("Go to GCP No.")
+ self.widget = wx.SpinCtrl(parent = self.statusbar, id = wx.ID_ANY,
+ value = "", min = 0)
+ self.widget.Hide()
+ self.widget.Bind(wx.EVT_TEXT_ENTER, self.OnGoToGCP)
+ self.widget.Bind(wx.EVT_SPINCTRL, self.OnGoToGCP)
+ def OnGoToGCP(self, event):
+ """!Zooms to given GCP."""
+ GCPNo = self.GetValue()
+ mapCoords = self.mapFrame.GetMapCoordList()
+ if GCPNo < 0 or GCPNo > len(mapCoords): # always false, spin checks it
+ gcmd.GMessage(parent=self,
+ message="%s 1 - %s." % (_("Valid Range:"),
+ len(mapCoords)))
+ return
+ if GCPNo == 0:
+ return
+ listCtrl = self.mapFrame.GetListCtrl()
+ listCtrl.selectedkey = GCPNo
+ listCtrl.selected = listCtrl.FindItemData(-1, GCPNo)
+ listCtrl.render = False
+ listCtrl.SetItemState(listCtrl.selected,
+ wx.LIST_STATE_SELECTED,
+ wx.LIST_STATE_SELECTED)
+ listCtrl.render = True
+ srcWin = self.mapFrame.GetSrcWindow()
+ tgtWin = self.mapFrame.GetTgtWindow()
+ # Source MapWindow:
+ begin = (mapCoords[GCPNo][1], mapCoords[GCPNo][2])
+ begin = srcWin.Cell2Pixel(begin)
+ end = begin
+ srcWin.Zoom(begin, end, 0)
+ # redraw map
+ srcWin.UpdateMap()
+ if self.mapFrame.GetShowTarget():
+ # Target MapWindow:
+ begin = (mapCoords[GCPNo][3], mapCoords[GCPNo][4])
+ begin = tgtWin.Cell2Pixel(begin)
+ end = begin
+ tgtWin.Zoom(begin, end, 0)
+ # redraw map
+ tgtWin.UpdateMap()
+ self.GetWidget().SetFocus()
+ def Update(self):
+ self.statusbar.SetStatusText("")
+ max = self.mapFrame.GetListCtrl().GetItemCount()
+ if max < 1:
+ max = 1
+ self.widget.SetRange(0, max)
+ self.Show()
+ # disable long help
+ self.mapFrame.StatusbarEnableLongHelp(False)
+class SbRMSError(SbTextItem):
+ """!Shows RMS error.
+ Requires MapFrame.GetFwdError, MapFrame.GetBkwError.
+ SbTextItem.__init__(self, mapframe, statusbar, position)
+ self.name = 'RMSError'
+ self.label = _("RMS error")
+ def Show(self):
+ self.SetValue(_("Forward: %(forw)s, Backward: %(back)s") %
+ { 'forw' : self.mapFrame.GetFwdError(),
+ 'back' : self.mapFrame.GetBkwError() })
+ SbTextItem.Show(self)
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-10 20:05:34 UTC (rev 48712)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py 2011-10-10 20:31:55 UTC (rev 48713)
@@ -174,7 +174,9 @@
if self.parent.statusbarManager.GetMode() == 0: # Coordinates
updated = False
if hasattr(self, "digit"):
- updated = self._onMotion((e, n), precision)
+ precision = int(UserSettings.Get(group = 'projection', key = 'format',
+ subkey = 'precision'))
+ updated = self._onMotion(self.lastEN, precision)
if not updated:
self.parent.CoordinatesChanged()
